[GRASS-SVN] r73672 - grass-addons/grass7/vector/v.gsflow.hruparams
Tue Nov 13 07:07:24 PST 2018
Author: awickert
Date: 2018-11-13 07:07:24 -0800 (Tue, 13 Nov 2018)
New Revision: 73672
   grass-addons/grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.py
v.gsflow.hruparams: soils and land cover
Modified: grass-addons/grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.py
--- grass-addons/grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.py	2018-11-13 15:07:05 UTC (rev 73671)
+++ grass-addons/grass7/vector/v.gsflow.hruparams/v.gsflow.hruparams.py	2018-11-13 15:07:24 UTC (rev 73672)
@@ -37,6 +37,20 @@
 #%  guidependency: layer,column
 #%end
+#%option G_OPT_R_INPUT
+#%  key: cov_type
+#%  label: land cover: 0=bare soil; 1=grasses; 2=shrubs; 3=trees; 4=coniferous
+#%  required: no
+#%  guidependency: layer,column
+#%end
+#%  key: soil_type
+#%  label: soil: 1=sand; 2=loam; 3=clay
+#%  required: no
+#%end
 #%option G_OPT_V_INPUT
 #%  key: input
 #%  label: Sub-basins to become HRUs
@@ -114,6 +128,8 @@
     slope = options['slope']
     aspect = options['aspect']
     elevation = options['elevation']
+    land_cover = options['cov_type']
+    soil = options['soil_type']
     # CREATE HRUs FROM SUB-BASINS  #
@@ -167,6 +183,8 @@
                                               # from HRU to stream segment)
     hru_columns.append('obsin_segment integer') # Index of measured streamflow station that replaces
                                                 # inflow to a segment
+    hru_columns.append('cov_type integer') # 0=bare soil;1=grasses; 2=shrubs; 3=trees; 4=coniferous
+    hru_columns.append('soil_type integer') # 1=sand; 2=loam; 3=clay
     # Create strings
     hru_columns = ",".join(hru_columns)
@@ -368,6 +386,26 @@
     # Segment number = HRU ID number
     v.db_update(map=HRU, column='hru_segment', query_column='id', quiet=True)
+    # LAND USE/COVER
+    if land_cover != '':
+        # NEED TO FIX THIS!!!!
+        #v.rast_stats(map=HRU, raster=land_cover, method='average', column_prefix='tmp', flags='c', quiet=True)
+        #v.db_update(map=HRU, column='cov_type', query_column='tmp_average', quiet=True)
+        #v.db_dropcolumn(map=HRU, columns='tmp_average', quiet=True)
+        v.db_update(map=HRU, column='cov_type', value=1, quiet=True)
+        v.what_rast(map=HRU, type='centroid', raster=land_cover, column='cov_type', quiet=True)
+    # SOIL
+    if soil != '':
+        #v.rast_stats(map=HRU, raster=soil, method='average', column_prefix='tmp', flags='c', quiet=True)
+        #v.db_update(map=HRU, column='soil_type', query_column='tmp_average', quiet=True)
+        v.db_update(map=HRU, column='soil_type', value=1, quiet=True)
+        v.what_rast(map=HRU, type='centroid', raster=soil, column='soil_type', quiet=True)
 if __name__ == "__main__":
     main()
