[GRASS-SVN] r73678 - grass/branches/releasebranch_7_6/scripts/v.rast.stats
svn_grass at osgeo.org
Tue Nov 13 15:02:37 PST 2018
Author: veroandreo
Date: 2018-11-13 15:02:37 -0800 (Tue, 13 Nov 2018)
New Revision: 73678
grass/branches/releasebranch_7_6/scripts/v.rast.stats/v.rast.stats.py
v.rast.stats: add where option (trunk r73666)
Modified: grass/branches/releasebranch_7_6/scripts/v.rast.stats/v.rast.stats.py
--- grass/branches/releasebranch_7_6/scripts/v.rast.stats/v.rast.stats.py 2018-11-13 16:36:50 UTC (rev 73677)
+++ grass/branches/releasebranch_7_6/scripts/v.rast.stats/v.rast.stats.py 2018-11-13 23:02:37 UTC (rev 73678)
@@ -40,6 +40,8 @@
#%end
#%option G_OPT_V_FIELD
#%end
+#%option G_OPT_DB_WHERE
+#%end
#%option G_OPT_R_INPUTS
#% key: raster
#% description: Name of input raster map to calculate statistics from
@@ -103,6 +105,7 @@
colprefixes = options['column_prefix'].split(',')
vector = options['map']
layer = options['layer']
+ where = options['where']
percentile = options['percentile']
basecols = options['method'].split(',')
@@ -154,13 +157,15 @@
# prepare base raster for zonal statistics
try:
nlines = grass.vector_info_topo(vector)['lines']
+ kwargs = {}
+ if where:
+ kwargs['where'] = where
# Create densified lines rather than thin lines
if flags['d'] and nlines > 0:
- grass.run_command('v.to.rast', input=vector, layer=layer, output=rastertmp,
- use='cat', flags='d', quiet=True)
- else:
- use='cat', quiet=True)
+ kwargs['flags'] = 'd'
+ grass.run_command('v.to.rast', input=vector, layer=layer, output=rastertmp,
+ use='cat', quiet=True, **kwargs)
except CalledModuleError:
grass.fatal(_("An error occurred while converting vector to raster"))
