[GRASS-SVN] r73688 - grass-addons/grass7/imagery/i.sentinel/i.sentinel.preproc
svn_grass at osgeo.org
Tue Nov 20 23:53:13 PST 2018
Author: martinl
Date: 2018-11-20 23:53:13 -0800 (Tue, 20 Nov 2018)
New Revision: 73688
grass-addons/grass7/imagery/i.sentinel/i.sentinel.preproc/i.sentinel.preproc.py
i.sentinel.preproc: use standard options if possible
Modified: grass-addons/grass7/imagery/i.sentinel/i.sentinel.preproc/i.sentinel.preproc.py
--- grass-addons/grass7/imagery/i.sentinel/i.sentinel.preproc/i.sentinel.preproc.py 2018-11-21 07:43:53 UTC (rev 73687)
+++ grass-addons/grass7/imagery/i.sentinel/i.sentinel.preproc/i.sentinel.preproc.py 2018-11-21 07:53:13 UTC (rev 73688)
@@ -24,31 +24,20 @@
#% keyword: import
#% keyword: atmospheric correction
#%End
-#%option
+#%option G_OPT_M_DIR
#% key: input_dir
-#% type: string
-#% gisprompt: old,dir,dir
#% description: Name of the directory where the image and metadata file are stored (*.SAFE)
#% required : yes
-#% multiple: no
#% guisection: Input
#%end
-#%option
-#% key: elevation
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: Name of input elevation raster map (in m)
+#%option G_OPT_R_ELEV
#% required : yes
-#% multiple: no
#%end
-#%option
+#%option G_OPT_R_INPUT
#% key: visibility
-#% type: string
-#% description: Name of input visibility raster map (in Km)
+#% description: Name of input visibility raster map (in m)
#% required : no
-#% multiple: no
#%end
#%option
@@ -78,19 +67,16 @@
#% required : no
#% guisection: 6S Parameters
#%end
-#%option
+#%option G_OPT_F_INPUT
#% key: aeronet_file
-#% type: string
-#% gisprompt: old,file,file
#% description: Name of the AERONET file for computing AOD at 550nm
#% required : no
-#% multiple: no
#%end
#%option
#% key: suffix
#% type: string
-#% description: Suffix for output maps
+#% description: Suffix for output raster maps
#% required : yes
#% guisection: Output
#%end
@@ -103,11 +89,9 @@
#% required : no
#%end
-#%option
+#%option G_OPT_F_OUTPUT
#% key: text_file
-#% type: string
-#% gisprompt: new,file,file
-#% description: Name of of output text file to be used as input in i.sentinel.mask
+#% description: Name for output text file to be used as input in i.sentinel.mask
#% required : no
#%end
@@ -190,13 +174,13 @@
try:
if flags["r"]:
gscript.run_command('i.sentinel.import',
- input=input_dir,
- flags='r')
+ input=input_dir,
+ flags='r')
else:
- input=input_dir)
+ input=input_dir)
except:
- gscript.fatal('Module rquire i.sentinel.import. Please install it using g.extension.')
+ gscript.fatal('Module requires i.sentinel.import. Please install it using g.extension.')
# Create xml "tree" for reading parameters from metadata
tree = et.parse(mtd_file)
