[GRASS-SVN] r73704 - grass/trunk/lib/init
svn_grass at osgeo.org
Sat Nov 24 02:52:25 PST 2018
Author: mmetz
Date: 2018-11-24 02:52:25 -0800 (Sat, 24 Nov 2018)
New Revision: 73704
grass/trunk/lib/init/grass.py
libinit: use clean_default_db() from script.setup
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2018-11-24 10:51:08 UTC (rev 73703)
+++ grass/trunk/lib/init/grass.py 2018-11-24 10:52:25 UTC (rev 73704)
@@ -2228,22 +2228,10 @@
# close GUI if running
close_gui()
- # clean the sqlite db
- from grass.script import db as gdb
- from grass.script import core as gcore
- conn = gdb.db_connection()
- if conn and conn['driver'] == 'sqlite':
- # check if db exists
- gisenv = gcore.gisenv()
- database = conn['database']
- database = database.replace('$GISDBASE', gisenv['GISDBASE'])
- database = database.replace('$LOCATION_NAME', gisenv['LOCATION_NAME'])
- database = database.replace('$MAPSET', gisenv['MAPSET'])
- if os.path.exists(database):
- message(_("Cleaning up sqlite database ..."))
- gcore.start_command('db.execute', sql = 'VACUUM')
# here we are at the end of grass session
+ from grass.script import setup as gsetup
+ gsetup.clean_default_db()
clear_screen()
# save 'last used' GISRC after removing variables which shouldn't
# be saved, e.g. d.mon related
