[GRASS-SVN] r73727 - grass-promo/grassposter/2018_AGU_Geospatial_Research_Tool
svn_grass at osgeo.org
Thu Nov 29 19:21:06 PST 2018
Author: wenzeslaus
Date: 2018-11-29 19:21:06 -0800 (Thu, 29 Nov 2018)
New Revision: 73727
grass-promo/grassposter/2018_AGU_Geospatial_Research_Tool/poster.tex
poster: short points to fit the paper
Modified: grass-promo/grassposter/2018_AGU_Geospatial_Research_Tool/poster.tex
--- grass-promo/grassposter/2018_AGU_Geospatial_Research_Tool/poster.tex 2018-11-30 02:44:13 UTC (rev 73726)
+++ grass-promo/grassposter/2018_AGU_Geospatial_Research_Tool/poster.tex 2018-11-30 03:21:06 UTC (rev 73727)
@@ -192,6 +192,7 @@
\column{0.25}
\block{\blocktitlewrap{Why GRASS GIS as a Tool?}}{
@@ -209,7 +210,7 @@
% Basic Topics
\item Community-driven project
\item Long-term releases, stable APIs and emphasis on science
- \item Single integrated environment for 2D and 3D raster analysis, image processing, vector data analysis and spatio-temporal data processing
+ \item Single environment for vector data analysis, 2D and 3D raster analysis, image processing and spatio-temporal data
% GRASS GIS
% distribution strives to provide single integrated environment for 2D and 3D
% raster analysis, image processing, vector data analysis and spatio-temporal
@@ -220,9 +221,9 @@
% implemented in the modules.
\end{itemize}
\block{\blocktitlewrap{Why GRASS GIS as a Platform?}}{
@@ -234,7 +235,8 @@
\begin{itemize}
\item New code typically contributed to Addons repository.
\item Mature code is moved to the main code base.
- \item Both main code base and Addons maintained by the community.
+ \item Organization into modules makes contributions easy.
+ % \item Both main code base and Addons maintained by the community.
\end{itemize}
@@ -247,10 +249,9 @@
\CustomBlockFontSize
\begin{itemize}
- \item Radim Blazek introduced several modules for vector network analysis in 2003
- including shortest path analysis (\gmodule{v.net.path}) and traveling salesman (\gmodule{v.net.salesman}).
- \item The number of available modules increased to almost 20.
- \item Stepan Turek implemented turns support into all relevant vector network modules in 2014.
+ \item Several modules for vector network analysis by Radim Blazek available since 2003 (e.g. \gmodule{v.net.salesman}).
+ \item The number of modules increased to almost 20.
+ \item Turn support added by Stepan Turek in 2014.
% \item Since version 7.0 fine control over node costs available.
% combination with r.cost/r.walk workflows \citep{Petrasova2014}
\end{itemize}
@@ -261,11 +262,11 @@
\begin{minipage}{0.9\linewidth}
\begin{center}
\includegraphics[width=\textwidth]{network_trips}
-A series of trips to collect samples across North Carolina, USA
-for water quality measurements
-as part of the Polyfluorinated Alkyl Substance Testing (PFAST) project.
-Trips are distinguished by color and were computed using multiple
-iterations of traveling salesman (\gmodule{v.net.salesman}).
+Trips to collect samples across North Carolina, USA
+as part of a water pollution testing project (PFAST).
+% Polyfluorinated Alkyl Substance Testing
+% Trips are distinguished by color and were computed using multiple
+% iterations of traveling salesman (\gmodule{v.net.salesman}).
\end{center}
\end{minipage}
@@ -297,16 +298,16 @@
\citep{leppelt2015grass}.
\end{itemize}
-\vspace*{1.5cm}
+\vspace*{.5ex}
\begin{minipage}{\linewidth}
\centering
-\includegraphics[width=.7\linewidth]{images/temporal_precip_temp}
+\includegraphics[width=\linewidth]{images/temporal_precip_temp}
Creating a synchronized animation of monthly total precipitation and mean temperature for NC, USA
\end{minipage}
-\vspace*{1cm}
+% \vspace*{1cm}
@@ -386,14 +387,14 @@
\begin{itemize}
- \item \gmodule{r.sim.water} module \citep{Mitas1998b}
- for simulating overland flow integrated into the Emergency Routing Decision Planning \citep{raghavan2014deploying}.
+ \item \gmodule{r.sim.water} \citep{Mitas1998b}
+ overland flow simulation used for emergency routing \citep{raghavan2014deploying}.
% TODO: paralelized
- \item \gmodule{r.watershed} for least cost path water accumulation from 1989
- and updated for massive data sets in 2011.
+ \item Least cost flow \gmodule{r.watershed} from '89
+ updated for massive data in '11.
% TODO: refs
- \item \cite{Petrasova2014} utilized in \emph{Tangible Landscape}, a tangible GIS system,
- \gmodule{r.damflood}, a dam break inundation simulation by \cite{cannata2012two}.
+ \item \cite{Petrasova2014} used in \emph{Tangible Landscape}
+ dam break inundation \gmodule{r.damflood} \cite{cannata2012two}.
\end{itemize}
% \bigskip
@@ -402,18 +403,18 @@
\centering
-\begin{minipage}{0.485\linewidth}
+\begin{minipage}{0.47\linewidth}
\centering
\includegraphics[width=0.7\textwidth]{rsimwater_architects}
\end{minipage}
+\begin{minipage}{0.5\linewidth}
\includegraphics[width=\textwidth]{damflood_tangible}
\end{minipage}
-\vspace{2mm}
+\vspace{0.1ex}
\begin{center}
-Overland flow simulated used for landscape
-architecture design in Tangible Landscape environment (left)
+Flow used for landscape
+architecture design (left)
and a dam breach on Lake Raleigh, NC, USA (right)
\end{center}
