[GRASS-SVN] r73734 - grass/branches/releasebranch_7_6/lib/init
svn_grass at osgeo.org
Fri Nov 30 04:18:43 PST 2018
Author: neteler
Date: 2018-11-30 04:18:42 -0800 (Fri, 30 Nov 2018)
New Revision: 73734
grass/branches/releasebranch_7_6/lib/init/grass.py
init: increase PEP8 compliance (trunk, r73347)
This still leaves most of W191, E501, and E101 and some E402, E122, E127.
Modified: grass/branches/releasebranch_7_6/lib/init/grass.py
--- grass/branches/releasebranch_7_6/lib/init/grass.py 2018-11-30 12:01:04 UTC (rev 73733)
+++ grass/branches/releasebranch_7_6/lib/init/grass.py 2018-11-30 12:18:42 UTC (rev 73734)
@@ -140,7 +140,7 @@
def clean_env(gisrc):
env_curr = read_gisrc(gisrc)
env_new = {}
- for k,v in env_curr.items():
+ for k, v in env_curr.items():
if k.endswith('PID') or k.startswith('MONITOR'):
continue
env_new[k] = v
@@ -429,8 +429,9 @@
tmp = tempfile.gettempdir()
if tmp:
- tmpdir = os.path.join(tmp, "grass7-%(user)s-%(lock)s" % {'user': user,
- 'lock': gis_lock})
+ tmpdir = os.path.join(
+ tmp, "grass7-%(user)s-%(lock)s" % {'user': user,
+ 'lock': gis_lock})
try:
os.mkdir(tmpdir, 0o700)
except:
@@ -439,8 +440,9 @@
if not tmp:
for ttmp in ("/tmp", "/var/tmp", "/usr/tmp"):
tmp = ttmp
- 'user': user, 'lock': gis_lock})
try:
except:
@@ -733,6 +735,7 @@
os.environ['HOME'] = os.path.join(os.getenv('HOMEDRIVE'),
os.getenv('HOMEPATH'))
def create_initial_gisrc(filename):
# for convenience, define GISDBASE as pwd:
s = r"""GISDBASE: %s
@@ -1021,15 +1024,15 @@
# not a valid mapset, but dir exists, assuming
# broken/incomplete mapset
fatal(_("Unable to create new mapset <{mapset}>"
- " because <{path}> is a file.")
- .format(mapset=mapset, path=path))
+ " because <{path}> is a file.")
+ .format(mapset=mapset, path=path))
elif os.path.isdir(path):
warning(_("The mapset <{}> is missing the WIND file"
- " (computational region). It will be"
- " fixed now. Note that this warning"
- " may become an error in future versions.")
+ " (computational region). It will be"
+ " fixed now. Note that this warning"
+ " may become an error in future versions.")
.format(mapset))
else:
# create mapset directory
@@ -1063,7 +1066,7 @@
if not os.path.exists(wxpath("gis_set.py")) and grass_gui != 'text':
debug("No GUI available, switching to text mode")
return False
# Check for text interface
if grass_gui == 'text':
# TODO: maybe this should be removed and solved from outside
@@ -1080,6 +1083,7 @@
return True
def gui_startup(grass_gui):
"""Start GUI for startup (setting gisrc file)"""
if grass_gui in ('wxpython', 'gtext'):
@@ -1188,7 +1192,7 @@
os.environ['ISIS_LIB'] = isis + os.sep + "lib"
os.environ['ISIS_3RDPARTY'] = isis + os.sep + "3rdParty" + os.sep + "lib"
os.environ['QT_PLUGIN_PATH'] = isis + os.sep + "3rdParty" + os.sep + "plugins"
- #os.environ['ISIS3DATA'] = isis + "$ISIS3DATA"
+ # os.environ['ISIS3DATA'] = isis + "$ISIS3DATA"
libpath = os.getenv('LD_LIBRARY_PATH', '')
isislibpath = os.getenv('ISIS_LIB')
isis3rdparty = os.getenv('ISIS_3RDPARTY')
@@ -1204,7 +1208,7 @@
# thus it always on Vista and XP will print an error.
# See discussion for Windows not following its own documentation and
# not accepting ISO codes as valid locale identifiers http://bugs.python.org/issue10466
- language = 'None' # Such string sometimes is present in wx file
+ language = 'None' # Such string sometimes is present in wx file
encoding = None
# Override value is stored in wxGUI preferences file.
@@ -1221,7 +1225,7 @@
language = ''.join(line.split(';')[-1:])
break
fd.close()
# Backwards compatability with old wx preferences files
if language == 'C':
language = 'en'
@@ -1236,10 +1240,12 @@
# If we get here, system locale settings are terribly wrong
# There is no point to continue as GRASS/Python will fail
# in some other unpredictable way.
- sys.stderr.write("System locale is not usable (LC_ALL variable not defined). "
- "Most likely it indicates misconfigured environment.\n")
+ sys.stderr.write(
+ "System locale is not usable (LC_ALL variable not defined)."
+ " Most likely it indicates misconfigured environment.\n")
sys.stderr.write("Reported error message: %s\n" % e)
- ## TOO DRASTIC: sys.exit("Fix system locale settings and then try again.")
+ # it would be too drastic to exit
+ # sys.exit("Fix system locale settings and then try again.")
locale.setlocale(locale.LC_ALL, 'C')
sys.stderr.write("Default locale settings are missing. GRASS running with C locale.")
@@ -1273,8 +1279,11 @@
os.environ['LC_MESSAGES'] = 'C'
os.environ['LC_NUMERIC'] = 'C'
os.environ['LC_TIME'] = 'C'
- sys.stderr.write("To avoid Unicode errors in GUI, install en_US.UTF-8 locale and restart GRASS.\n"
- "Also consider upgrading your Python version to one containg fix for Python Issue 30755.\n")
+ sys.stderr.write(
+ "To avoid Unicode errors in GUI, install"
+ " en_US.UTF-8 locale and restart GRASS.\n"
+ "Also consider upgrading your Python version"
+ " to one containing fix for Python Issue 30755.\n")
return
# en_US locale might be missing, still all messages in
# GRASS are already in en_US language.
@@ -1295,10 +1304,12 @@
gettext.install('grasslibs', gpath('locale'))
- sys.stderr.write("All attempts to enable English language have failed. "
- "GRASS running with C locale.\n"
- "If you observe UnicodeError in Python, install en_US.UTF-8 "
- "locale and restart GRASS.\n")
+ sys.stderr.write(
+ "All attempts to enable English language have"
+ " failed. GRASS running with C locale.\n"
+ "If you observe UnicodeError in Python,"
+ " install en_US.UTF-8"
+ " locale and restart GRASS.\n")
return
else:
# The last attempt...
@@ -1377,15 +1388,17 @@
msg = None
if ret == 2:
if not force_gislock_removal:
- msg = _("%(user)s is currently running GRASS in selected mapset (" \
- "file %(file)s found). Concurrent use not allowed.\nYou can force launching GRASS using -f flag " \
- "(note that you need permission for this operation). Have another look in the processor " \
+ msg = _("%(user)s is currently running GRASS in selected mapset"
+ " (file %(file)s found). Concurrent use not allowed.\n"
+ "You can force launching GRASS using -f flag"
+ " (note that you need permission for this operation)."
+ " Have another look in the processor "
"manager just to be sure..." % {
'user': user, 'file': lockfile})
else:
try_remove(lockfile)
- message(_("%(user)s is currently running GRASS in selected mapset (" \
- "file %(file)s found). Forcing to launch GRASS..." % {
+ message(_("%(user)s is currently running GRASS in selected mapset"
+ " (file %(file)s found). Forcing to launch GRASS..." % {
'user': user, 'file': lockfile}))
elif ret != 0:
msg = _("Unable to properly access '%s'.\n"
@@ -1543,7 +1556,6 @@
# Start the chosen GUI but ignore text
debug("GRASS GUI should be <%s>" % grass_gui)
# Check for gui interface
if grass_gui == "wxpython":
Popen([os.getenv('GRASS_PYTHON'), wxpath("wxgui.py")])
@@ -1564,7 +1576,8 @@
os.kill(int(pid), signal.SIGTERM)
except OSError as e:
message(_("Unable to close GUI. {0}").format(e))
def clear_screen():
"""Clear terminal"""
if windows:
@@ -1650,7 +1663,8 @@
f.write("GRASS GIS %s > '\n" % grass_version)
f.write("set BOGUS=``;unset BOGUS\n")
- path = os.path.join(userhome, ".grass.cshrc") # left for backward compatibility
+ # csh shell rc file left for backward compatibility
+ path = os.path.join(userhome, ".grass.cshrc")
if os.access(path, os.R_OK):
f.write(readfile(path) + '\n')
if os.access(grass_env_file, os.R_OK):
@@ -1669,14 +1683,11 @@
path = os.getenv('PATH').split(':')
f.write("set path = ( %s ) \n" % ' '.join(path))
f.close()
writefile(tcshrc, readfile(cshrc))
process = Popen([gpath("etc", "run"), os.getenv('SHELL')])
os.environ['HOME'] = userhome
return process
@@ -1730,14 +1741,11 @@
f.write(line + '\n')
f.write("export PATH=\"%s\"\n" % os.getenv('PATH'))
- f.write("export HOME=\"%s\"\n" % userhome) # restore user home path
+ f.write("export HOME=\"%s\"\n" % userhome) # restore user home path
+ f.close()
- f.close()
return process
@@ -1798,7 +1806,7 @@
if arg == 'path':
sys.stdout.write("%s\n" % gisbase)
elif arg == 'arch':
- val = grep('ARCH',linesplat)
+ val = grep('ARCH', linesplat)
sys.stdout.write("%s\n" % val[0].split('=')[1].strip())
elif arg == 'build':
build = gpath('include', 'grass', 'confparms.h')
@@ -1807,7 +1815,7 @@
filebuild.close()
sys.stdout.write("%s\n" % val.strip().strip('"').strip())
elif arg == 'compiler':
- val = grep('CC',linesplat)
+ val = grep('CC', linesplat)
elif arg == 'revision':
rev = gpath('include', 'grass', 'gis.h')
@@ -1815,7 +1823,8 @@
linesrev = filerev.readlines()
val = grep('#define GIS_H_VERSION', linesrev)
filerev.close()
- sys.stdout.write("%s\n" % val[0].split(':')[1].rstrip('$"\n').strip())
+ sys.stdout.write(
+ "%s\n" % val[0].split(':')[1].rstrip('$"\n').strip())
elif arg == 'version':
sys.stdout.write("%s\n" % grass_version)
else:
@@ -1834,7 +1843,7 @@
user = os.getenv('LOGNAME')
if not user:
try:
- p = Popen(['whoami'], stdout = subprocess.PIPE)
+ p = Popen(['whoami'], stdout=subprocess.PIPE)
s = p.stdout.read()
p.wait()
user = s.strip()
@@ -1858,6 +1867,7 @@
self.geofile = None
self.tmp_location = False
def parse_cmdline(argv, default_gui):
"""Parse the standard part of command line parameters"""
params = Parameters()
@@ -1904,7 +1914,7 @@
elif len(args) == 1:
if params.tmp_location:
params.geofile = args[0]
- else:
+ else:
params.mapset = args[0]
else:
params.mapset = None
@@ -1911,7 +1921,7 @@
return params
-### MAIN script starts here
+# The main script starts here
# Get the system name
windows = sys.platform == 'win32'
@@ -1921,7 +1931,7 @@
# TODO: it is OK to remove this?
# at the beginning of this file were are happily getting GISBASE
# from the environment and we don't care about inconsistencies it might cause
-### commented-out: broken winGRASS
+# The following was commented out because of breaking winGRASS
# if 'GISBASE' in os.environ:
# sys.exit(_("ERROR: GRASS GIS is already running "
# "(environmental variable GISBASE found)"))
@@ -1989,7 +1999,8 @@
# Set the username
user = get_username()
- # TODO: this might need to be moved before processing of parameters and getting batch job
+ # TODO: this might need to be moved before processing of parameters
+ # and getting batch job
# Set language
# This has to be called before any _() function call!
# Subsequent functions are using _() calls and
@@ -2077,7 +2088,7 @@
# Try non-interactive start up
# tmp loc requires other things to be set as well
- set_mapset(gisrc=gisrc, geofile=params.geofile,
+ set_mapset(gisrc=gisrc, geofile=params.geofile,
create_new=True,
tmp_location=params.tmp_location, tmpdir=tmpdir)
elif params.create_new and params.geofile:
