[GRASS-SVN] r73475 - grass-addons/grass7/vector/v.gsflow.grid
Mon Oct 1 15:18:14 PDT 2018
Author: awickert
Date: 2018-10-01 15:18:14 -0700 (Mon, 01 Oct 2018)
New Revision: 73475
   grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py
v.gsflow.grid: typecast whole array
Modified: grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py
--- grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py	2018-10-01 21:57:44 UTC (rev 73474)
+++ grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py	2018-10-01 22:18:14 UTC (rev 73475)
@@ -259,12 +259,12 @@
         # Find out if this is diagonal: finite difference works only N-S, W-E
         colNames = np.array(gscript.vector_db_select(pp, layer=1)['columns'])
         colValues = np.array(gscript.vector_db_select(pp, layer=1)['values'].values())
-        pp_row = int(colValues[:,colNames == 'row'].astype(int).squeeze())
-        pp_col = int(colValues[:,colNames == 'col'].astype(int).squeeze())
+        pp_row = colValues[:,colNames == 'row'].astype(int).squeeze()
+        pp_col = colValues[:,colNames == 'col'].astype(int).squeeze()
         colNames = np.array(gscript.vector_db_select(bc_cell, layer=1)['columns'])
         colValues = np.array(gscript.vector_db_select(bc_cell, layer=1)['values'].values())
-        bc_row = int(colValues[:,colNames == 'row'].astype(int).squeeze())
-        bc_col = int(colValues[:,colNames == 'col'].astype(int).squeeze())
+        bc_row = colValues[:,colNames == 'row'].astype(int).squeeze()
+        bc_col = colValues[:,colNames == 'col'].astype(int).squeeze()
         # Also get x and y while we are at it: may be needed later
         bc_x = float(colValues[:,colNames == 'x'].astype(float).squeeze())
         bc_y = float(colValues[:,colNames == 'y'].astype(float).squeeze())
