[GRASS-SVN] r73477 - grass-addons/grass7/vector/v.gsflow.grid
svn_grass at osgeo.org
Mon Oct 1 17:47:15 PDT 2018
Author: awickert
Date: 2018-10-01 17:47:14 -0700 (Mon, 01 Oct 2018)
New Revision: 73477
grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py
v.gsflow.grid: Multiple b.c. cells
Modified: grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py
--- grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py 2018-10-01 22:28:10 UTC (rev 73476)
+++ grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py 2018-10-02 00:47:14 UTC (rev 73477)
@@ -268,7 +268,33 @@
# Also get x and y while we are at it: may be needed later
bc_x = colValues[:,colNames == 'x'].astype(float).squeeze()
bc_y = colValues[:,colNames == 'y'].astype(float).squeeze()
- if (bc_row != pp_row) and (bc_col != pp_col):
+ if (bc_row != pp_row).all() and (bc_col != pp_col).all():
+ if bc_row.ndim > 0:
+ if len(bc_row) > 1:
+ for i in range(len(bc_row)):
+ UNTESTED!!!!
+ And probably unimportant -- having 2 cells with river
+ going through them is most likely going to happen with
+ two adjacent cells -- so a side and a corner
+ _col1, _row1 = str(bc_col[i]), str(pp_row[i])
+ _col2, _row2 = str(pp_col[i]), str(bc_row[i])
+ # Check if either of these is covered by the basin mask
+ _ismask_1 = gscript.vector_db_select(grid, layer=1, where='(row == '+_row1+') AND (col =='+_col1+')', columns='basinmask')
+ _ismask_1 = int(_ismask_1['values'].values()[0][0])
+ _ismask_2 = gscript.vector_db_select(grid, layer=1, where='(row == '+_row2+') AND (col =='+_col2+')', columns='basinmask')
+ _ismask_2 = int(_ismask_2['values'].values()[0][0])
+ # check if either of these is the other point
+ NOT DOING THIS YET -- HAVEN'T THOUGHT THROUGH IF
+ ACTUALLY NECESSARY. (And this is an edge case anyway)
+ # If both covered by mask, error
+ if _ismask_1 and _ismask_2:
+ gscript.fatal('All possible b.c. cells covered by basin mask.\n\
+ Contact the developer: awickert (at) umn(.)edu')
# If not diagonal, two possible locations that are adjacent
# to the pour point
_col1, _row1 = str(bc_col), str(pp_row)
