[GRASS-SVN] r73486 - grass-addons/grass7/raster/r.gsflow.hydrodem
svn_grass at osgeo.org
Wed Oct 3 23:58:33 PDT 2018
Author: awickert
Date: 2018-10-03 23:58:33 -0700 (Wed, 03 Oct 2018)
New Revision: 73486
grass-addons/grass7/raster/r.gsflow.hydrodem/r.gsflow.hydrodem.py
r.gsflow.hydrodem: Use stream channel average z instead of whole-cell minimum elevation; general cleanup
Modified: grass-addons/grass7/raster/r.gsflow.hydrodem/r.gsflow.hydrodem.py
--- grass-addons/grass7/raster/r.gsflow.hydrodem/r.gsflow.hydrodem.py 2018-10-03 19:07:13 UTC (rev 73485)
+++ grass-addons/grass7/raster/r.gsflow.hydrodem/r.gsflow.hydrodem.py 2018-10-04 06:58:33 UTC (rev 73486)
@@ -108,26 +108,16 @@
gscript.use_temp_region()
- # Get number of rows and columns
- colNames = np.array(gscript.vector_db_select(grid, layer=1)['columns'])
- colValues = np.array(gscript.vector_db_select(grid, layer=1)['values'].values())
- cats = colValues[:,colNames == 'cat'].astype(int).squeeze()
- rows = colValues[:,colNames == 'row'].astype(int).squeeze()
- cols = colValues[:,colNames == 'col'].astype(int).squeeze()
- nRows = np.max(rows)
- nCols = np.max(cols)
- # Set the region
- g.region(vector=grid, rows=nRows, cols=nCols)
- #g.region(raster=dem)
+ # Set the region to capture only the channel
+ g.region(raster=dem)
v.to_rast(input=streams, output=streams_MODFLOW, use='val', value=1.0,
type='line', overwrite=gscript.overwrite(), quiet=True)
- r.mapcalc('tmp'+" = "+streams_MODFLOW+" * DEM", overwrite=True)
+ r.mapcalc('tmp'+" = "+streams_MODFLOW+" * " + dem, overwrite=True)
g.rename(raster=('tmp',streams_MODFLOW), overwrite=True, quiet=True)
- #g.region(res=resolution, quiet=True)
+ g.region(raster=DEM_MODFLOW, quiet=True)
+ print "ALTERED"
r.resamp_stats(input=streams_MODFLOW, output=streams_MODFLOW,
- method='minimum', overwrite=gscript.overwrite(), quiet=True)
+ method='average', overwrite=gscript.overwrite(), quiet=True)
r.resamp_stats(input=dem, output=DEM_MODFLOW, method='average',
r.patch(input=streams_MODFLOW+','+DEM_MODFLOW, output=DEM_MODFLOW,
