[GRASS-SVN] r73507 - grass/trunk/vector/v.surf.bspline
Tue Oct 9 05:35:12 PDT 2018
Author: mmetz
Date: 2018-10-09 05:35:12 -0700 (Tue, 09 Oct 2018)
New Revision: 73507
   grass/trunk/vector/v.surf.bspline/main.c
v.surf.bspline: use Segment_[open|close]()
Modified: grass/trunk/vector/v.surf.bspline/main.c
--- grass/trunk/vector/v.surf.bspline/main.c	2018-10-09 11:59:14 UTC (rev 73506)
+++ grass/trunk/vector/v.surf.bspline/main.c	2018-10-09 12:35:12 UTC (rev 73507)
@@ -55,8 +55,7 @@
     double **N, **obsVect;	/* Interpolation and least-square matrix */
     SEGMENT out_seg, mask_seg;
-    const char *out_file, *mask_file;
-    int out_fd, mask_fd;
+    char *out_file, *mask_file;
     double seg_size;
     int seg_mb, segments_in_memory;
     int have_mask;
@@ -451,7 +450,6 @@
     /* Alloc raster matrix */
     have_mask = 0;
     out_file = mask_file = NULL;
-    out_fd = mask_fd = -1;
     if (grid == TRUE) {
 	int row;
 	DCELL *drastbuf;
@@ -470,15 +468,10 @@
 	G_debug(1, "%d %dx%d segments held in memory", segments_in_memory, SEGSIZE, SEGSIZE);
 	out_file = G_tempfile();
-	out_fd = creat(out_file, 0666);
-	if (Segment_format(out_fd, nrows, ncols, SEGSIZE, SEGSIZE, sizeof(double)) != 1)
+	if (Segment_open(&out_seg, out_file, nrows, ncols, SEGSIZE,
+	     SEGSIZE, sizeof(double), segments_in_memory) != 1)
 	    G_fatal_error(_("Can not create temporary file"));
-	close(out_fd);
-	out_fd = open(out_file, 2);
-	if (Segment_init(&out_seg, out_fd, segments_in_memory) != 1)
-	    G_fatal_error(_("Can not initialize temporary file"));
 	/* initialize output */
 	G_message(_("Initializing output..."));
@@ -498,15 +491,10 @@
 	    G_message(_("Load masking map"));
 	    mask_file = G_tempfile();
-	    mask_fd = creat(mask_file, 0666);
-	    if (Segment_format(mask_fd, nrows, ncols, SEGSIZE, SEGSIZE, sizeof(char)) != 1)
+	    if (Segment_open(&mask_seg, mask_file, nrows, ncols, SEGSIZE,
+		 SEGSIZE, sizeof(char), segments_in_memory) != 1)
-	    close(mask_fd);
-	    mask_fd = open(mask_file, 2);
-	    if (Segment_init(&mask_seg, mask_fd, segments_in_memory) != 1)
 	    maskfd = Rast_open_old(mask_opt->answer, "");
 	    for (row = 0; row < nrows; row++) {
@@ -904,9 +892,7 @@
 	if (have_mask) {
-	    Segment_release(&mask_seg);	/* release memory  */
-	    close(mask_fd);
-	    unlink(mask_file);
+	    Segment_close(&mask_seg);	/* close segment structure  */
 	drastbuf = Rast_allocate_buf(DCELL_TYPE);
@@ -921,9 +907,7 @@
 	Rast_close(raster);
-	Segment_release(&out_seg);	/* release memory  */
-	close(out_fd);
-	unlink(out_file);
+	Segment_close(&out_seg);	/* close segment structure  */
 	/* set map title */
 	sprintf(title, "%s interpolation with Tykhonov regularization",
 		type_opt->answer);
