[GRASS-SVN] r73509 - grass/trunk/raster/r.resamp.bspline
svn_grass at osgeo.org
Tue Oct 9 06:09:01 PDT 2018
Author: mmetz
Date: 2018-10-09 06:09:01 -0700 (Tue, 09 Oct 2018)
New Revision: 73509
grass/trunk/raster/r.resamp.bspline/main.c
r.resamp.bspline: use Segment_[open|close]()
Modified: grass/trunk/raster/r.resamp.bspline/main.c
--- grass/trunk/raster/r.resamp.bspline/main.c 2018-10-09 13:01:42 UTC (rev 73508)
+++ grass/trunk/raster/r.resamp.bspline/main.c 2018-10-09 13:09:01 UTC (rev 73509)
@@ -45,8 +45,7 @@
double **N, **obsVect; /* Interpolation and least-square matrix */
SEGMENT in_seg, out_seg, mask_seg;
- const char *in_file, *out_file, *mask_file;
- int in_fd, out_fd, mask_fd;
+ char *in_file, *out_file, *mask_file;
double seg_size;
int seg_mb, segments_in_memory;
int have_mask;
@@ -313,15 +312,10 @@
segments_in_memory = 1;
in_file = G_tempfile();
- in_fd = creat(in_file, 0666);
- if (Segment_format(in_fd, nrows, ncols, SEGSIZE, SEGSIZE, sizeof(double)) != 1)
+ if (Segment_open(&in_seg, in_file, nrows, ncols, SEGSIZE, SEGSIZE,
+ sizeof(double), segments_in_memory) != 1)
G_fatal_error(_("Can not create temporary file"));
- close(in_fd);
- in_fd = open(in_file, 2);
- if (Segment_init(&in_seg, in_fd, segments_in_memory) != 1)
- G_fatal_error(_("Can not initialize temporary file"));
/* read raster input */
inrastfd = Rast_open_old(in_opt->answer, "");
drastbuf = Rast_allocate_buf(DCELL_TYPE);
@@ -375,9 +369,7 @@
G_done_msg(_("Cross validation finished for ew_step = %f and ns_step = %f"), stepE, stepN);
- Segment_release(&in_seg); /* release memory */
- close(in_fd);
- unlink(in_file);
+ Segment_close(&in_seg); /* release memory */
exit(EXIT_SUCCESS);
@@ -398,15 +390,10 @@
/* use destination window */
mask_file = G_tempfile();
- mask_fd = creat(mask_file, 0666);
- if (Segment_format(mask_fd, nrows, ncols, SEGSIZE, SEGSIZE, sizeof(char)) != 1)
+ if (Segment_open(&mask_seg, mask_file, nrows, ncols, SEGSIZE, SEGSIZE,
+ sizeof(char), segments_in_memory) != 1)
- close(mask_fd);
- mask_fd = open(mask_file, 2);
- if (Segment_init(&mask_seg, mask_fd, segments_in_memory) != 1)
if (mask_opt->answer) {
maskfd = Rast_open_old(mask_opt->answer, "");
maskbuf = Rast_allocate_buf(CELL_TYPE);
@@ -470,15 +457,10 @@
out_file = G_tempfile();
- out_fd = creat(out_file, 0666);
- if (Segment_format(out_fd, nrows, ncols, SEGSIZE, SEGSIZE, sizeof(double)) != 1)
+ if (Segment_open(&out_seg, out_file, nrows, ncols, SEGSIZE, SEGSIZE,
- close(out_fd);
- out_fd = open(out_file, 2);
- if (Segment_init(&out_seg, out_fd, segments_in_memory) != 1)
/* initialize output */
G_message(_("Initializing output..."));
@@ -735,14 +717,10 @@
} /*! END WHILE; last_column = TRUE */
} /*! END WHILE; last_row = TRUE */
- close(in_fd);
- unlink(in_file);
if (have_mask) {
- Segment_release(&mask_seg); /* release memory */
- close(mask_fd);
- unlink(mask_file);
+ Segment_close(&mask_seg); /* release memory */
G_message(_("Writing output..."));
@@ -771,9 +749,7 @@
G_warning("only NULL cells in output raster");
- Segment_release(&out_seg); /* release memory */
- close(out_fd);
- unlink(out_file);
+ Segment_close(&out_seg); /* release memory */
Rast_close(outrastfd);
