[GRASS-SVN] r73511 - grass/trunk/raster/r.watershed/seg
Tue Oct 9 06:31:07 PDT 2018
Author: mmetz
Date: 2018-10-09 06:31:07 -0700 (Tue, 09 Oct 2018)
New Revision: 73511
   grass/trunk/raster/r.watershed/seg/bseg_close.c
   grass/trunk/raster/r.watershed/seg/bseg_open.c
   grass/trunk/raster/r.watershed/seg/cseg_close.c
   grass/trunk/raster/r.watershed/seg/cseg_open.c
   grass/trunk/raster/r.watershed/seg/dseg_close.c
   grass/trunk/raster/r.watershed/seg/dseg_open.c
   grass/trunk/raster/r.watershed/seg/sseg_close.c
   grass/trunk/raster/r.watershed/seg/sseg_open.c
r.watershed/seg: use Segment_[open|close]()
Modified: grass/trunk/raster/r.watershed/seg/bseg_close.c
--- grass/trunk/raster/r.watershed/seg/bseg_close.c	2018-10-09 13:21:00 UTC (rev 73510)
+++ grass/trunk/raster/r.watershed/seg/bseg_close.c	2018-10-09 13:31:07 UTC (rev 73511)
@@ -4,9 +4,7 @@
 int bseg_close(BSEG * bseg)
-    Segment_release(&(bseg->seg));
-    close(bseg->fd);
-    unlink(bseg->filename);
+    Segment_close(&(bseg->seg));
     if (bseg->name) {
 	G_free(bseg->name);
 	bseg->name = NULL;
Modified: grass/trunk/raster/r.watershed/seg/bseg_open.c
--- grass/trunk/raster/r.watershed/seg/bseg_open.c	2018-10-09 13:21:00 UTC (rev 73510)
+++ grass/trunk/raster/r.watershed/seg/bseg_open.c	2018-10-09 13:31:07 UTC (rev 73511)
@@ -2,6 +2,7 @@
 #include <unistd.h>
 #include <fcntl.h>
 #include <grass/segment.h>
+#include <grass/glocale.h>
 #include "Gwater.h"
@@ -9,7 +10,6 @@
     char *filename;
     int errflag;
-    int fd;
     bseg->filename = NULL;
     bseg->fd = -1;
@@ -17,43 +17,36 @@
     bseg->mapset = NULL;
     filename = G_tempfile();
-    if (-1 == (fd = creat(filename, 0666))) {
-	G_warning("bseg_open(): unable to create segment file");
-	return -2;
-    if (0 > (errflag = Segment_format(fd, Rast_window_rows(),
-				      Rast_window_cols(), srows, scols,
-				      sizeof(char)))) {
-	close(fd);
-	unlink(filename);
+    if (0 > (errflag = Segment_open(&(bseg->seg), filename, Rast_window_rows(),
+				    Rast_window_cols(), srows, scols,
+				    sizeof(char), nsegs_in_memory))) {
 	if (errflag == -1) {
-	    G_warning("bseg_open(): could not write segment file");
+	    G_warning(_("File name is invalid"));
 	    return -1;
-	else {
-	    G_warning("bseg_open(): illegal configuration parameter(s)");
+	else if (errflag == -2) {
+	    G_warning(_("File write error"));
+	    return -2;
+	else if (errflag == -3) {
+	    G_warning(_("Illegal parameters are passed"));
 	    return -3;
-    close(fd);
-    if (-1 == (fd = open(filename, 2))) {
-	unlink(filename);
-	G_warning("bseg_open(): unable to re-open segment file");
-	return -4;
-    if (0 > (errflag = Segment_init(&(bseg->seg), fd, nsegs_in_memory))) {
-	close(fd);
-	unlink(filename);
-	if (errflag == -1) {
-	    G_warning("bseg_open(): could not read segment file");
+	else if (errflag == -4) {
+	    G_warning(_("File could not be re-opened"));
+	    return -4;
+	else if (errflag == -5) {
+	    G_warning(_("Prepared file could not be read"));
 	    return -5;
-	else {
-	    G_warning("bseg_open(): out of memory");
+	else if (errflag == -6) {
+	    G_warning(_("Out of memory"));
 	    return -6;
     bseg->filename = filename;
-    bseg->fd = fd;
     return 0;
Modified: grass/trunk/raster/r.watershed/seg/cseg_close.c
--- grass/trunk/raster/r.watershed/seg/cseg_close.c	2018-10-09 13:21:00 UTC (rev 73510)
+++ grass/trunk/raster/r.watershed/seg/cseg_close.c	2018-10-09 13:31:07 UTC (rev 73511)
@@ -5,9 +5,7 @@
 int cseg_close(CSEG * cseg)
-    Segment_release(&(cseg->seg));
-    close(cseg->fd);
-    unlink(cseg->filename);
+    Segment_close(&(cseg->seg));
     if (cseg->name) {
 	G_free(cseg->name);
 	cseg->name = NULL;
Modified: grass/trunk/raster/r.watershed/seg/cseg_open.c
--- grass/trunk/raster/r.watershed/seg/cseg_open.c	2018-10-09 13:21:00 UTC (rev 73510)
+++ grass/trunk/raster/r.watershed/seg/cseg_open.c	2018-10-09 13:31:07 UTC (rev 73511)
@@ -1,6 +1,7 @@
 #include <grass/gis.h>
 #include <unistd.h>
 #include <fcntl.h>
 #include "Gwater.h"
@@ -8,7 +9,6 @@
     char *filename;
     int errflag;
-    int fd;
     cseg->filename = NULL;
     cseg->fd = -1;
@@ -16,44 +16,36 @@
     cseg->mapset = NULL;
-	G_warning("cseg_open(): unable to create segment file");
-	return -2;
-    if (0 >
-	(errflag =
-	 Segment_format(fd, Rast_window_rows(), Rast_window_cols(), srows,
-			scols, sizeof(CELL)))) {
-	close(fd);
-	unlink(filename);
+    if (0 > (errflag = Segment_open(&(cseg->seg), filename, Rast_window_rows(),
+				    sizeof(CELL), nsegs_in_memory))) {
-	    G_warning("cseg_open(): could not write segment file");
 	    return -1;
-	else {
-	    G_warning("cseg_open(): illegal configuration parameter(s)");
+	    return -2;
 	    return -3;
-    close(fd);
-	unlink(filename);
-	G_warning("cseg_open(): unable to re-open segment file");
-	return -4;
-    if (0 > (errflag = Segment_init(&(cseg->seg), fd, nsegs_in_memory))) {
-	close(fd);
-	unlink(filename);
-	    G_warning("cseg_open(): could not read segment file");
+	    return -4;
 	    return -5;
-	else {
-	    G_warning("cseg_open(): out of memory");
 	    return -6;
     cseg->filename = filename;
-    cseg->fd = fd;
     return 0;
Modified: grass/trunk/raster/r.watershed/seg/dseg_close.c
--- grass/trunk/raster/r.watershed/seg/dseg_close.c	2018-10-09 13:21:00 UTC (rev 73510)
+++ grass/trunk/raster/r.watershed/seg/dseg_close.c	2018-10-09 13:31:07 UTC (rev 73511)
@@ -4,9 +4,7 @@
 int dseg_close(DSEG * dseg)
-    Segment_release(&(dseg->seg));
-    close(dseg->fd);
-    unlink(dseg->filename);
+    Segment_close(&(dseg->seg));
     if (dseg->name) {
 	G_free(dseg->name);
 	dseg->name = NULL;
Modified: grass/trunk/raster/r.watershed/seg/dseg_open.c
--- grass/trunk/raster/r.watershed/seg/dseg_open.c	2018-10-09 13:21:00 UTC (rev 73510)
+++ grass/trunk/raster/r.watershed/seg/dseg_open.c	2018-10-09 13:31:07 UTC (rev 73511)
@@ -2,6 +2,7 @@
 #include <unistd.h>
 #include <fcntl.h>
 #include "Gwater.h"
@@ -9,7 +10,6 @@
     char *filename;
     int errflag;
-    int fd;
     dseg->filename = NULL;
     dseg->fd = -1;
@@ -17,44 +17,36 @@
     dseg->mapset = NULL;
-	G_warning("dseg_open(): unable to create segment file");
-	return -2;
-    if (0 >
-	(errflag =
-			scols, sizeof(double)))) {
-	close(fd);
-	unlink(filename);
+    if (0 > (errflag = Segment_open(&(dseg->seg), filename, Rast_window_rows(),
+				    sizeof(DCELL), nsegs_in_memory))) {
-	    G_warning("dseg_open(): could not write segment file");
 	    return -1;
-	else {
-	    G_warning("dseg_open(): illegal configuration parameter(s)");
+	    return -2;
 	    return -3;
-    close(fd);
-	unlink(filename);
-	G_warning("dseg_open(): unable to re-open segment file");
-	return -4;
-    if (0 > (errflag = Segment_init(&(dseg->seg), fd, nsegs_in_memory))) {
-	close(fd);
-	unlink(filename);
-	    G_warning("dseg_open(): could not read segment file");
+	    return -4;
 	    return -5;
-	else {
-	    G_warning("dseg_open(): out of memory");
 	    return -6;
     dseg->filename = filename;
-    dseg->fd = fd;
     return 0;
Modified: grass/trunk/raster/r.watershed/seg/sseg_close.c
--- grass/trunk/raster/r.watershed/seg/sseg_close.c	2018-10-09 13:21:00 UTC (rev 73510)
+++ grass/trunk/raster/r.watershed/seg/sseg_close.c	2018-10-09 13:31:07 UTC (rev 73511)
@@ -5,8 +5,7 @@
 int seg_close(SSEG * sseg)
-    Segment_release(&(sseg->seg));
-    close(sseg->fd);
-    unlink(sseg->filename);
+    Segment_close(&(sseg->seg));
     return 0;
Modified: grass/trunk/raster/r.watershed/seg/sseg_open.c
--- grass/trunk/raster/r.watershed/seg/sseg_open.c	2018-10-09 13:21:00 UTC (rev 73510)
+++ grass/trunk/raster/r.watershed/seg/sseg_open.c	2018-10-09 13:31:07 UTC (rev 73511)
@@ -2,6 +2,7 @@
 #include <unistd.h>
 #include <fcntl.h>
 #include "Gwater.h"
 int
@@ -10,48 +11,41 @@
     char *filename;
     int errflag;
-    int fd;
     sseg->filename = NULL;
     sseg->fd = -1;
-	G_warning("seg_open(): unable to create segment file");
-	return -2;
-    if (0 > (errflag = Segment_format(fd, rows, cols,
-				      row_in_seg, col_in_seg, size_struct))) {
-	close(fd);
-	unlink(filename);
+    if (0 > (errflag = Segment_open(&(sseg->seg), filename, rows, cols,
+				    row_in_seg, col_in_seg,
+				    size_struct, nsegs_in_memory))) {
-	    G_warning("seg_open(): could not write segment file");
 	    return -1;
-	else {
-	    G_warning("seg_open(): illegal configuration parameter(s)");
+	    return -2;
 	    return -3;
-    close(fd);
-	unlink(filename);
-	G_warning("seg_open(): unable to re-open segment file");
-	return -4;
-    if (0 > (errflag = Segment_init(&(sseg->seg), fd, nsegs_in_memory))) {
-	close(fd);
-	unlink(filename);
-	    G_warning("seg_open(): could not read segment file");
+	    return -4;
 	    return -5;
-	else {
-	    G_warning("seg_open(): out of memory");
 	    return -6;
     sseg->filename = filename;
-    sseg->fd = fd;
     return 0;
