[GRASS-SVN] r73523 - grass-addons/grass7/raster/r.object.geometry
svn_grass at osgeo.org
Fri Oct 12 02:11:40 PDT 2018
Author: mlennert
Date: 2018-10-12 02:11:39 -0700 (Fri, 12 Oct 2018)
New Revision: 73523
grass-addons/grass7/raster/r.object.geometry/main.c
grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html
r.object.geometry: add mean x and y coordinates to object statistics
Modified: grass-addons/grass7/raster/r.object.geometry/main.c
--- grass-addons/grass7/raster/r.object.geometry/main.c 2018-10-11 20:07:22 UTC (rev 73522)
+++ grass-addons/grass7/raster/r.object.geometry/main.c 2018-10-12 09:11:39 UTC (rev 73523)
@@ -52,8 +52,9 @@
int len;
struct obj_geo
- double area, perimeter;
+ double area, perimeter, x, y;
int min_row, max_row, min_col, max_col; /* bounding box */
+ int num;
} *obj_geos;
double unit_area;
int n_objects;
@@ -135,6 +136,9 @@
obj_geos[i].max_row = 0;
obj_geos[i].min_col = ncols;
obj_geos[i].max_col = 0;
+ obj_geos[i].x = 0;
+ obj_geos[i].y = 0;
+ obj_geos[i].num = 0;
unit_area = 0.0;
@@ -174,9 +178,12 @@
if (!cur_null) {
if (flag_m->answer) {
obj_geos[cur - min].area += unit_area;
+ obj_geos[cur - min].num += 1;
} else {
obj_geos[cur - min].area += 1;
+ obj_geos[cur - min].x += Rast_col_to_easting(col - 0.5, &cellhd);
+ obj_geos[cur - min].y += Rast_row_to_northing(row + 0.5, &cellhd);
if (obj_geos[cur - min].min_row > row)
obj_geos[cur - min].min_row = row;
if (obj_geos[cur - min].max_row < row + 1)
@@ -294,7 +301,9 @@
fprintf(out_fp, "perimeter%s", sep);
fprintf(out_fp, "compact_square%s", sep);
fprintf(out_fp, "compact_circle%s", sep);
- fprintf(out_fp, "fd");
+ fprintf(out_fp, "fd%s", sep);
+ fprintf(out_fp, "mean_x%s", sep);
+ fprintf(out_fp, "mean_y");
fprintf(out_fp, "\n");
/* print table body */
@@ -310,7 +319,11 @@
fprintf(out_fp, "%f%s", 4 * sqrt(obj_geos[i].area) / obj_geos[i].perimeter, sep);
fprintf(out_fp, "%f%s", obj_geos[i].perimeter / (2 * sqrt(M_PI * obj_geos[i].area)), sep);
/* log 1 = 0, so avoid that by always adding 0.001 to the area: */
- fprintf(out_fp, "%f", 2 * log(obj_geos[i].perimeter) / log (obj_geos[i].area + 0.001));
+ fprintf(out_fp, "%f%s", 2 * log(obj_geos[i].perimeter) / log (obj_geos[i].area + 0.001), sep);
+ if (!flag_m->answer)
+ obj_geos[i].num = obj_geos[i].area;
+ fprintf(out_fp, "%f%s", obj_geos[i].x / obj_geos[i].num, sep);
+ fprintf(out_fp, "%f", obj_geos[i].y / obj_geos[i].num);
/* TODO: convert bounding box area and perimeter to (square) meters for -m flag */
Modified: grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html
--- grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html 2018-10-11 20:07:22 UTC (rev 73522)
+++ grass-addons/grass7/raster/r.object.geometry/r.object.geometry.html 2018-10-12 09:11:39 UTC (rev 73523)
@@ -15,7 +15,8 @@
<p>
Statistics currently calculated are exactly the same as in
-<em><a href="v.to.db.html">v.to.db</a></em> (except for compact_square):
+<em><a href="v.to.db.html">v.to.db</a></em> (except for compact_square and
+mean coordinates):
<ul>
<li>area</li>
@@ -25,6 +26,8 @@
<li>compact_circle (compactness compared to a circle:
<tt>compact_circle = perimeter / ( 2 * sqrt(PI * area) )</tt>)</li>
<li>fractal dimension ( <tt>fd = 2 * ( log(perimeter) / log(area + 0.001) )</tt> )</li>
+<li>mean x coordinate of object (in map units)</li>
+<li>mean y coordinate of object (in map units)</li>
</ul>
<h2>NOTES</h2>
