[GRASS-SVN] r73527 - in grass/trunk/lib/gis: . testsuite
svn_grass at osgeo.org
Sat Oct 13 11:14:20 PDT 2018
Author: huhabla
Date: 2018-10-13 11:14:20 -0700 (Sat, 13 Oct 2018)
New Revision: 73527
Added:
grass/trunk/lib/gis/testsuite/test_parser_json.py
grass/trunk/lib/gis/parser_json.c
Added tests to the GRASS GIS JSON parser
Modified: grass/trunk/lib/gis/parser_json.c
--- grass/trunk/lib/gis/parser_json.c 2018-10-13 15:47:09 UTC (rev 73526)
+++ grass/trunk/lib/gis/parser_json.c 2018-10-13 18:14:20 UTC (rev 73527)
@@ -200,7 +200,7 @@
file_name = G_tempfile();
- fprintf(stderr, "Filename: %s\n", file_name);
+ /* fprintf(stderr, "Filename: %s\n", file_name); */
fp = fopen(file_name, "w+");
if (fp == NULL)
@@ -256,9 +256,6 @@
/* Print the input options
- TODO: Check for URLs in the answer to create import options
- TODO: Check for mapset names in the answer and remove the current mapset name from the string
if (st->n_opts && num_inputs > 0) {
struct Option *opt;
@@ -289,9 +286,6 @@
/* Print the output options
- TODO: Check export options in the answer to create export options
- TODO: Check for mapset names in the answer and remove the mapset name from the string
if (st->n_opts && num_outputs > 0) {
struct Option *opt;
Added: grass/trunk/lib/gis/testsuite/test_parser_json.py
--- grass/trunk/lib/gis/testsuite/test_parser_json.py (rev 0)
+++ grass/trunk/lib/gis/testsuite/test_parser_json.py 2018-10-13 18:14:20 UTC (rev 73527)
@@ -0,0 +1,98 @@
+"""Test the JSON extension of the GRASS parser
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+ at author Soeren Gebbert
+import subprocess
+from grass.gunittest.case import TestCase
+import simplejson
+class TestParserJson(TestCase):
+ def test_r_slope_aspect_json(self):
+ args = ["r.slope.aspect",
+ "elevation=elevation+https://storage.googleapis.com/graas-geodata/elev_ned_30m.tif",
+ "slope=slope+GTiff",
+ "aspect=aspect+GTiff", "--json"]
+ inputs = [
+ {"import_descr": {"source": "https://storage.googleapis.com/graas-geodata/elev_ned_30m.tif",
+ "type": "raster"},
+ "param": "elevation", "value": "elevation"},
+ {"param": "format", "value": "degrees"},
+ {"param": "precision", "value": "FCELL"},
+ {"param": "zscale", "value": "1.0"},
+ {"param": "min_slope", "value": "0.0"}
+ outputs = [
+ {"export": {"format": "GTiff", "type": "raster"},
+ "param": "slope", "value": "slope"},
+ "param": "aspect", "value": "aspect"}
+ stdout, stderr = subprocess.Popen(args, stdout=subprocess.PIPE).communicate()
+ print(stdout)
+ json_code = simplejson.loads(stdout)
+ self.assertEqual(json_code["module"], "r.slope.aspect")
+ self.assertEqual(len(json_code["inputs"]), 5)
+ self.assertEqual(json_code["inputs"], inputs)
+ self.assertEqual(json_code["outputs"], outputs)
+ def test_v_out_ascii(self):
+ args = ["v.out.ascii",
+ "input=hospitals at PERMANENT",
+ "output=myfile+TXT",
+ "--json"]
+ inputs = [
+ {"param": "input", "value": "hospitals at PERMANENT"},
+ {"param": "layer", "value": "1"},
+ {"param": "type", "value": "point,line,boundary,centroid,area,face,kernel"},
+ {"param": "format", "value": "point"},
+ {"param": "separator", "value": "pipe"},
+ {"param": "precision", "value": "8"}
+ outputs = [
+ {"export": {"format": "TXT", "type": "file"},
+ "param": "output", "value": "$file::myfile"}
+ print(stdout)
+ self.assertEqual(json_code["module"], "v.out.ascii")
+ self.assertEqual(len(json_code["inputs"]), 6)
+ def test_v_info(self):
+ args = ["v.info",
+ "map=hospitals at PERMANENT",
+ "-c",
+ "--json"]
+ inputs = [
+ {"param": "map", "value": "hospitals at PERMANENT"},
+ print(stdout)
+ self.assertEqual(json_code["module"], "v.info")
+ self.assertEqual(len(json_code["inputs"]), 2)
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
