[GRASS-SVN] r73550 - grass/branches/releasebranch_7_6/scripts/r.fillnulls
svn_grass at osgeo.org
Mon Oct 15 02:27:46 PDT 2018
Author: neteler
Date: 2018-10-15 02:27:46 -0700 (Mon, 15 Oct 2018)
New Revision: 73550
grass/branches/releasebranch_7_6/scripts/r.fillnulls/r.fillnulls.py
r.fillnulls: added memory parameter for internal r.resamp.bspline call (trunk, r73549)
Modified: grass/branches/releasebranch_7_6/scripts/r.fillnulls/r.fillnulls.py
--- grass/branches/releasebranch_7_6/scripts/r.fillnulls/r.fillnulls.py 2018-10-15 09:27:12 UTC (rev 73549)
+++ grass/branches/releasebranch_7_6/scripts/r.fillnulls/r.fillnulls.py 2018-10-15 09:27:46 UTC (rev 73550)
@@ -14,7 +14,7 @@
# PURPOSE: fills NULL (no data areas) in raster maps
# The script respects a user mask (MASK) if present.
-# COPYRIGHT: (C) 2001-2016 by the GRASS Development Team
+# COPYRIGHT: (C) 2001-2018 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -97,6 +97,15 @@
#% answer: 0.01
#% guisection: Spline options
#%end
+#%option
+#% key: memory
+#% type: integer
+#% required: no
+#% multiple: no
+#% label: Maximum memory to be used (in MB)
+#% description: Cache size for raster rows
+#% answer: 300
+#%end
import sys
@@ -141,6 +150,7 @@
segmax = int(options['segmax'])
npmin = int(options['npmin'])
lambda_ = float(options['lambda'])
+ memory = options['memory']
quiet = True # FIXME
mapset = grass.gisenv()['MAPSET']
unique = str(os.getpid()) # Shouldn't we use temp name?
@@ -450,12 +460,12 @@
grass.run_command('r.resamp.bspline', input=input, mask=usermask,
output=prefix + 'filled', method=method,
ew_step=3 * reg['ewres'], ns_step=3 * reg['nsres'],
- lambda_=lambda_, flags='n')
+ lambda_=lambda_, memory=memory, flags='n')
else:
# restoring user's mask, if present:
if usermask:
