[GRASS-SVN] r73554 - grass/trunk/vector/v.surf.rst
Mon Oct 15 18:52:04 PDT 2018
Author: annakrat
Date: 2018-10-15 18:52:04 -0700 (Mon, 15 Oct 2018)
New Revision: 73554
   grass/trunk/vector/v.surf.rst/main.c
v.surf.rst: clarify default smooth value
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2018-10-15 19:52:02 UTC (rev 73553)
+++ grass/trunk/vector/v.surf.rst/main.c	2018-10-16 01:52:04 UTC (rev 73554)
@@ -281,7 +281,8 @@
     parm.rsm->key = "smooth";
     parm.rsm->type = TYPE_DOUBLE;
     parm.rsm->required = NO;
-    parm.rsm->description = _("Smoothing parameter");
+    parm.rsm->label = _("Smoothing parameter");
+    parm.rsm->description = _("Smoothing is by default 0.5 unless smooth_column is specified");
     parm.rsm->guisection = _("Parameters");
     parm.scol = G_define_option();
