[GRASS-SVN] r73562 - grass/branches/releasebranch_7_6/vector/v.surf.rst
svn_grass at osgeo.org
Tue Oct 16 17:27:12 PDT 2018
Author: annakrat
Date: 2018-10-16 17:27:12 -0700 (Tue, 16 Oct 2018)
New Revision: 73562
grass/branches/releasebranch_7_6/vector/v.surf.rst/main.c
v.surf.rst: clarify default smooth value (merge from trunk, r73554)
Modified: grass/branches/releasebranch_7_6/vector/v.surf.rst/main.c
--- grass/branches/releasebranch_7_6/vector/v.surf.rst/main.c 2018-10-16 19:25:44 UTC (rev 73561)
+++ grass/branches/releasebranch_7_6/vector/v.surf.rst/main.c 2018-10-17 00:27:12 UTC (rev 73562)
@@ -281,7 +281,8 @@
parm.rsm->key = "smooth";
parm.rsm->type = TYPE_DOUBLE;
parm.rsm->required = NO;
- parm.rsm->description = _("Smoothing parameter");
+ parm.rsm->label = _("Smoothing parameter");
+ parm.rsm->description = _("Smoothing is by default 0.5 unless smooth_column is specified");
parm.rsm->guisection = _("Parameters");
parm.scol = G_define_option();
