[GRASS-SVN] r73577 - grass/trunk/vector/v.in.ogr
Sat Oct 20 01:19:14 PDT 2018
Author: mmetz
Date: 2018-10-20 01:19:14 -0700 (Sat, 20 Oct 2018)
New Revision: 73577
   grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: disable unreliable OGR extents for spatial filter
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2018-10-19 11:34:22 UTC (rev 73576)
+++ grass/trunk/vector/v.in.ogr/main.c	2018-10-20 08:19:14 UTC (rev 73577)
@@ -2179,6 +2179,8 @@
 	    /* use OGR extents if possible, needed to skip corrupted data
 	     * in OGR dsn/layer */
+	    /* BUT: OGR extents are unreliable,
+	     * sometimes excluding valid features */
 	    have_ogr_extent[layer] = 1;
 	/* OGR_L_GetExtent():
@@ -2236,7 +2238,10 @@
     for (layer = 0; layer < nlayers; layer++) {
 	int have_filter = 0;
-	if (have_ogr_extent[layer]) {
+	/* OGR extents are unreliable,
+	 * sometimes excluding valid features:
+	 * disabled */
+	if (0 && have_ogr_extent[layer]) {
 	    if (*xmin <= *xmax && *ymin <= *ymax) {
 		/* check for any overlap */
 		if (xminl[layer] > *xmax || xmaxl[layer] < *xmin ||
@@ -2257,9 +2262,7 @@
 		    ymaxl[layer] = MIN(ymaxl[layer], *ymax);
-	    /* disable spatial filter based on extents as reported by OGR
-	     * because these extents can be wrong */
-	    /* have_filter = 1; */
+	    have_filter = 1;
 	else if (*xmin <= *xmax && *ymin <= *ymax) {
 	    xminl[layer] = *xmin;
