[GRASS-SVN] r73602 - grass-addons/grass7/raster/r.width.funct
svn_grass at osgeo.org
Tue Oct 23 03:26:54 PDT 2018
Author: madi
Date: 2018-10-23 03:26:54 -0700 (Tue, 23 Oct 2018)
New Revision: 73602
grass-addons/grass7/raster/r.width.funct/r.width.funct.py
fixed findint function to handle the case in which the function presents two min, similarly to what was done for r.hypso
Modified: grass-addons/grass7/raster/r.width.funct/r.width.funct.py
--- grass-addons/grass7/raster/r.width.funct/r.width.funct.py 2018-10-22 21:31:49 UTC (rev 73601)
+++ grass-addons/grass7/raster/r.width.funct/r.width.funct.py 2018-10-23 10:26:54 UTC (rev 73602)
@@ -47,6 +47,7 @@
import matplotlib.pyplot as plt
import grass.script as grass
import numpy as np
+from operator import itemgetter
def main():
stats = grass.read_command('r.stats', input = options['map'], sep = 'space', nv = '*', nsteps = '255', flags = 'Anc').split('\n')[:-1]
@@ -120,8 +121,10 @@
plt.close('all')
def findint(kl,f):
- Xf = np.abs(kl-f); Xf = np.where(Xf==Xf.min())
- #z1, z2, f1, f2 = kl[float(Xf[0])][0], kl[float(Xf[0]-1)][0], kl[float(Xf[0])][1], kl[float(Xf[0]-1)][1]
+ Xf = np.abs(kl-f);
+ Xf = np.where(Xf==Xf.min())
+ item = itemgetter(0)(Xf)
+ Xf = item[0]
z1, z2, f1, f2 = kl[int(Xf[0])][0], kl[int(Xf[0]-1)][0], kl[int(Xf[0])][1], kl[int(Xf[0]-1)][1]
z = z1 + ((z2 - z1) / (f2 - f1)) * (f - f1)
return z
