[GRASS-SVN] r73609 - grass/branches/releasebranch_7_4/raster/r.relief
svn_grass at osgeo.org
Wed Oct 24 13:05:33 PDT 2018
Author: martinl
Date: 2018-10-24 13:05:32 -0700 (Wed, 24 Oct 2018)
New Revision: 73609
grass/branches/releasebranch_7_4/raster/r.relief/main.c
grass/branches/releasebranch_7_4/raster/r.relief/r.relief.html
r.relief: output is required, update manual (G74: merge from r73608)
Modified: grass/branches/releasebranch_7_4/raster/r.relief/main.c
--- grass/branches/releasebranch_7_4/raster/r.relief/main.c 2018-10-24 20:03:33 UTC (rev 73608)
+++ grass/branches/releasebranch_7_4/raster/r.relief/main.c 2018-10-24 20:05:32 UTC (rev 73609)
@@ -112,10 +112,11 @@
module->label = _("Creates shaded relief map from an elevation map (DEM).");
parm.elevation = G_define_standard_option(G_OPT_R_INPUT);
+ parm.elevation->description = _("Name of input raster (typically elevation) map");
parm.relief = G_define_standard_option(G_OPT_R_OUTPUT);
- parm.relief->label = _("Name for output shaded relief map");
+ parm.relief->description = _("Name for output shaded relief map");
parm.altitude = G_define_option();
parm.altitude->key = "altitude";
parm.altitude->type = TYPE_DOUBLE;
Modified: grass/branches/releasebranch_7_4/raster/r.relief/r.relief.html
--- grass/branches/releasebranch_7_4/raster/r.relief/r.relief.html 2018-10-24 20:03:33 UTC (rev 73608)
+++ grass/branches/releasebranch_7_4/raster/r.relief/r.relief.html 2018-10-24 20:05:32 UTC (rev 73609)
@@ -1,22 +1,20 @@
<h2>DESCRIPTION</h2>
-<em>r.relief</em> creates a raster shaded relief map based on
-current resolution settings and on sun altitude, azimuth, and
-z-exaggeration values entered by the user. If no output shademap
-name is given, the new shaded relief map is named <em><input_map
->.shade</em>. The map is assigned a grey-scale color table.
+<em>r.relief</em> creates a raster shaded relief map based on current
+resolution settings and on sun altitude, azimuth, and z-exaggeration
+values entered by the user.
<p>The parameters controlling the shading are:
<ol>
-<li>A raster map layer to provide elevation values for the shaded
-relief map. Typically, this would be a map layer of elevation;
+<li>An <b>input</b> raster map to provide elevation values for the shaded
+relief map. Typically, this would be a map layer of elevation;
however, any raster map layer can be named.
<li>The <b>altitude</b> of the sun in degrees above the horizon
(a value between 0 and 90 degrees).
-<li>The <b>azimuth</b> of the sun in degrees to the east of north
-(a value between 0 and 360 degrees; clockwise from north).
+<li>The <b>azimuth</b> of the sun in degrees to the east of north (a
+value between 0 and 360 degrees; clockwise from north)
<li>The scaling parameter, which compensates for a different
horizontal <b>scale</b> than vertical scale. If <b>scale</b> is a
@@ -25,7 +23,7 @@
vertical scales.)
<li>The <b>zscale</b> exaggeration factor that changes the apparent relief
-for the shaded relief map. This can be any positive (or negative) floating
+for the shaded relief map. This can be any positive (or negative) floating
point value. (Default=1.0)
<li>Horizontal distances are calculated in meters, using geodesic
@@ -42,10 +40,11 @@
<h2>NOTES</h2>
-To visually improve the result of shade maps from low resolution elevation
-models, use <em>r.resamp.interp</em> with bilinear or bicubic method to
-resample the DEM at higher resolution. <em>r.relief</em> is then
-run on the resampled DEM.
+To visually improve the result of shade maps from low resolution
+elevation models,
+use <em><a href="r.resamp.interp.html">r.resamp.interp</a></em> with
+bilinear or bicubic method to resample the DEM at higher
+resolution. <em>r.relief</em> is then run on the resampled DEM.
<h2>EXAMPLES</h2>
@@ -67,7 +66,10 @@
<h3>Colorizing a shaded relief map</h3>
-Color can be added later using <em><a href="r.shade.html">r.shade</a></em>:
+Color can be added later
+using <em><a href="r.shade.html">r.shade</a></em>
+or <em><a href="d.shade.html">d.shade</a></em>:
<div class="code"><pre>
r.shade shade=elevation_shade color=elevation output=elevation_shaded
</pre></div>
@@ -89,9 +91,10 @@
map to GeoTIFF format along with its associated color table due to limitations
in the GeoTIFF format.
<p>
-The most simple way to export it while even reducing the file size is to
-export as palette byte map. This requires a conversion done in <tt>r.mapcalc</tt>,
-using the # operator to convert map category values to their grey scale
+The most simple way to export it while even reducing the file size is
+to export as palette byte map. This requires a conversion done
+in <em><a href="r.mapcalc.html">r.mapcalc</a></em>, using the #
+operator to convert map category values to their grey scale
equivalents:
@@ -98,7 +101,7 @@
# using the map created above
# create new map from map category values
-r.mapcalc "elevation_shade_byte = #elevation_shade"
+r.mapcalc expression="elevation_shade_byte = #elevation_shade"
# verify data range
r.info elevation_shade_byte
@@ -118,13 +121,6 @@
<h2>SEE ALSO</h2>
<p>
- RGB version not ported to GRASS 6 (why?):
- <em><a href="shade.clr.sh.html">shade.clr.sh</a></em><br>
- d.shade and r.shade probably cover most of the shade.clr functionality
- however, it is not possible to create shade+color map in one step
- delete this note when it is solved or if it is not considered as an issue
<em>
<a href="d.shade.html">d.shade</a>,
<a href="d.his.html">d.his</a>,
