[GRASS-SVN] r73611 - grass-addons/grass7/imagery/i.segment.uspo
svn_grass at osgeo.org
Fri Oct 26 05:10:18 PDT 2018
Author: mlennert
Date: 2018-10-26 05:10:18 -0700 (Fri, 26 Oct 2018)
New Revision: 73611
grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py
i.segment.uspo: handle case where segmentation leads to one single segment
Modified: grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py
--- grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py 2018-10-26 07:36:50 UTC (rev 73610)
+++ grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py 2018-10-26 12:10:18 UTC (rev 73611)
@@ -365,6 +365,11 @@
len(autocor_per_raster)
result_queue.put([mapname, mean_lv, mean_autocor,
threshold, minsize])
+ else:
+ # If resulting map contains only one segment, then give high
+ # value of variance and 0 for spatial autocorrelation in order
+ # to give this map a low priority
+ result_queue.put([mapname, 999999, 0, threshold, minsize])
except:
exc_info = sys.exc_info()
@@ -401,6 +406,11 @@
result_queue.put(
[mapname, mean_lv, mean_autocor, threshold, minsize])
+ else:
except:
@@ -910,31 +920,43 @@
maplist += regional_maplist
# Calculate optimization function values and get indices of best values
- optlist = create_optimization_list(variancelist,
- autocorlist,
- opt_function,
- alpha,
- directions[indicator])
- if rg:
- regiondict[region] = zip(
- threshlist, minsizelist, variancelist, autocorlist, optlist)
+ if max(variancelist) > min(variancelist) and max(autocorlist) > min(autocorlist):
+ optlist = create_optimization_list(variancelist,
+ autocorlist,
+ opt_function,
+ alpha,
+ directions[indicator])
+ if rg:
+ regiondict[region] = zip(
+ threshlist, minsizelist, variancelist, autocorlist, optlist)
+ else:
+ threshlist, hrlist, radiuslist, minsizelist, variancelist, autocorlist, optlist)
+ optimal_indices = find_optimal_value_indices(optlist, nb_best)
+ best_values[region] = []
+ rank = 1
+ for optind in optimal_indices:
+ if rg:
+ best_values[region].append(
+ [threshlist[optind], minsizelist[optind], optlist[optind]])
+ else:
+ best_values[region].append([threshlist[optind], hrlist[optind],
+ radiuslist[optind], minsizelist[optind], optlist[optind]])
+ maps_to_keep.append([regional_maplist[optind], rank,
+ parms['region']])
+ rank += 1
else:
- threshlist, hrlist, radiuslist, minsizelist, variancelist, autocorlist, optlist)
- optimal_indices = find_optimal_value_indices(optlist, nb_best)
- best_values[region] = []
- rank = 1
- for optind in optimal_indices:
if rg:
- [threshlist[optind], minsizelist[optind], optlist[optind]])
+ [threshlist[0], minsizelist[0], -1])
else:
- best_values[region].append([threshlist[optind], hrlist[optind],
- radiuslist[optind], minsizelist[optind], optlist[optind]])
- maps_to_keep.append([regional_maplist[optind], rank,
- parms['region']])
- rank += 1
+ best_values[region].append([threshlist[0], hrlist[0],
+ radiuslist[0], minsizelist[0],
+ -1])
+ maps_to_keep.append([regional_maplist[0], -1,
+ parms['region']])
# Create output
