[GRASS-SVN] r73622 - grass-addons/grass7/vector/v.stream.inbasin
Mon Oct 29 19:46:08 PDT 2018
Author: awickert
Date: 2018-10-29 19:46:08 -0700 (Mon, 29 Oct 2018)
New Revision: 73622
   grass-addons/grass7/vector/v.stream.inbasin/v.stream.inbasin.py
v.stream.inbasin: specific choice of pour point
Modified: grass-addons/grass7/vector/v.stream.inbasin/v.stream.inbasin.py
--- grass-addons/grass7/vector/v.stream.inbasin/v.stream.inbasin.py	2018-10-29 13:17:16 UTC (rev 73621)
+++ grass-addons/grass7/vector/v.stream.inbasin/v.stream.inbasin.py	2018-10-30 02:46:08 UTC (rev 73622)
@@ -43,6 +43,12 @@
 #%  required: no
 #%end
+#%option G_OPT_R_INPUT
+#%  key: draindir
+#%  label: Drainage directions (needed if exact coordinates used)
+#%  required: no
+#%end
 #%option
 #%  key: cat
 #%  label: Farthest downstream segment category
@@ -82,6 +88,12 @@
 #%  required: no
 #%end
+#%flag
+#%  key: s
+#%  description: Snap provided coordinates to nearest segment endpoint
+#%  guisection: Settings
+#%end
 # IMPORT MODULES #
@@ -128,6 +140,8 @@
     output_basins = options['output_basin']
     output_streams = options['output_streams']
     output_pour_point = options['output_pour_point']
+    draindir = options['draindir']
+    snapflag = flags['s']
     #print options
     #print flags
@@ -138,73 +152,89 @@
     else:
         gscript.fatal('You must set either "cat" or "x_outlet" and "y_outlet".')
     # NEED TO ADD IF-STATEMENT HERE TO AVOID AUTOMATIC OVERWRITING!!!!!!!!!!!
-    if downstream_cat == '':
-        # Need to find outlet pour point -- start by creating a point at this
-        # location to use with v.distance
-        try:
-            v.db_droptable(table='tmp', flags='f')
-        except:
-            pass
-        tmp = vector.Vector('tmp')
-        _cols = [(u'cat',       'INTEGER PRIMARY KEY'),
-                 (u'x',         'DOUBLE PRECISION'),
-                 (u'y',         'DOUBLE PRECISION'),
-                 (u'strcat',    'DOUBLE PRECISION')]
-        tmp.open('w', tab_name='tmp', tab_cols=_cols)
-        point0 = Point(x_outlet,y_outlet)
-        tmp.write(point0, cat=1, attrs=(str(x_outlet), str(y_outlet), 0), )
-        tmp.table.conn.commit()
-        tmp.build()
-        tmp.close()
-        # Now v.distance
-        gscript.run_command('v.distance', from_='tmp', to=streams, upload='cat', column='strcat')
-        #v.distance(_from_='tmp', to=streams, upload='cat', column='strcat')
-        downstream_cat = gscript.vector_db_select(map='tmp', columns='strcat')
-        downstream_cat = int(downstream_cat['values'].values()[0][0])
+    if snapflag or (downstream_cat != ''):
+        if downstream_cat == '':
+            # Need to find outlet pour point -- start by creating a point at this
+            # location to use with v.distance
+            try:
+                v.db_droptable(table='tmp', flags='f')
+            except:
+                pass
+            tmp = vector.Vector('tmp')
+            _cols = [(u'cat',       'INTEGER PRIMARY KEY'),
+                     (u'x',         'DOUBLE PRECISION'),
+                     (u'y',         'DOUBLE PRECISION'),
+                     (u'strcat',    'DOUBLE PRECISION')]
+            tmp.open('w', tab_name='tmp', tab_cols=_cols)
+            point0 = Point(x_outlet,y_outlet)
+            tmp.write(point0, cat=1, attrs=(str(x_outlet), str(y_outlet), 0), )
+            tmp.table.conn.commit()
+            tmp.build()
+            tmp.close()
+            # Now v.distance
+            gscript.run_command('v.distance', from_='tmp', to=streams, upload='cat', column='strcat')
+            #v.distance(_from_='tmp', to=streams, upload='cat', column='strcat')
+            downstream_cat = gscript.vector_db_select(map='tmp', columns='strcat')
+            downstream_cat = int(downstream_cat['values'].values()[0][0])
-    # Attributes of streams
-    colNames = np.array(vector_db_select(streams)['columns'])
-    colValues = np.array(vector_db_select(streams)['values'].values())
-    tostream = colValues[:,colNames == 'tostream'].astype(int).squeeze()
-    cats = colValues[:,colNames == 'cat'].astype(int).squeeze() # = "fromstream"
+        # Attributes of streams
+        colNames = np.array(vector_db_select(streams)['columns'])
+        colValues = np.array(vector_db_select(streams)['values'].values())
+        tostream = colValues[:,colNames == 'tostream'].astype(int).squeeze()
+        cats = colValues[:,colNames == 'cat'].astype(int).squeeze() # = "fromstream"
-    # Find network
-    basincats = [downstream_cat] # start here
-    most_upstream_cats = [downstream_cat] # all of those for which new cats must be sought
-    while True:
-        if len(most_upstream_cats) == 0:
-            break
-        tmp = list(most_upstream_cats) # copy to a temp file: old values
-        most_upstream_cats = [] # Ready to accept new values
-        for ucat in tmp:
-            most_upstream_cats += list(cats[tostream == int(ucat)])
-            basincats += most_upstream_cats
-    basincats = list(set(list(basincats)))
+        # Find network
+        basincats = [downstream_cat] # start here
+        most_upstream_cats = [downstream_cat] # all of those for which new cats must be sought
+        while True:
+            if len(most_upstream_cats) == 0:
+                break
+            tmp = list(most_upstream_cats) # copy to a temp file: old values
+            most_upstream_cats = [] # Ready to accept new values
+            for ucat in tmp:
+                most_upstream_cats += list(cats[tostream == int(ucat)])
+                basincats += most_upstream_cats
+        basincats = list(set(list(basincats)))
-    basincats_str = ','.join(map(str, basincats))
-    # Many basins out -- need to use overwrite flag in future!
-    #SQL_OR = 'rnum = ' + ' OR rnum = '.join(map(str, basincats))
-    #SQL_OR = 'cat = ' + ' OR cat = '.join(map(str, basincats))
-    SQL_LIST =  'cat IN (' + ', '.join(map(str, basincats)) + ')'
-    if len(basins) > 0:
-        v.extract(input=basins, output=output_basins, where=SQL_LIST, overwrite=gscript.overwrite(), quiet=True)
-    if len(streams) > 0:
-        v.extract(input=streams, output=output_streams, cats=basincats_str, overwrite=gscript.overwrite(), quiet=True)
+        basincats_str = ','.join(map(str, basincats))
+        # Many basins out -- need to use overwrite flag in future!
+        #SQL_OR = 'rnum = ' + ' OR rnum = '.join(map(str, basincats))
+        #SQL_OR = 'cat = ' + ' OR cat = '.join(map(str, basincats))
+        SQL_LIST =  'cat IN (' + ', '.join(map(str, basincats)) + ')'
+        if len(basins) > 0:
+            v.extract(input=basins, output=output_basins, where=SQL_LIST, overwrite=gscript.overwrite(), quiet=True)
+        if len(streams) > 0:
+            v.extract(input=streams, output=output_streams, cats=basincats_str, overwrite=gscript.overwrite(), quiet=True)
+    else:
+        # Have coordinates and will limit the area that way.
+        r.water_outlet(input=draindir, output='tmp', coordinates=(x_outlet, y_outlet), overwrite=True)
+        r.to_vect(input='tmp', output='tmp', type='area', overwrite=True)
+        v.clip(input=basins, clip='tmp', output=output_basins, overwrite=True)
+        basincats = gscript.vector_db_select('basins_inbasin').values()[0].keys()
     # If we want to output the pour point location
     if len(output_pour_point) > 0:
-        _pp = gscript.vector_db_select(map=streams, columns='x2,y2', where='cat='+str(downstream_cat))
-        _xy = np.squeeze(_pp['values'].values())
-        _x = float(_xy[0])
-        _y = float(_xy[1])
         try:
             v.db_droptable(table=output_pour_point, flags='f')
         except:
             pass
+            _pp = gscript.vector_db_select(map=streams, columns='x2,y2', where='cat='+str(downstream_cat))
+            _xy = np.squeeze(_pp['values'].values())
+            _x = float(_xy[0])
+            _y = float(_xy[1])
+        else:
+            _x = x_outlet
+            _y = y_outlet
         pptmp = vector.Vector(output_pour_point)
@@ -216,6 +246,5 @@
         pptmp.build()
         pptmp.close()
 if __name__ == "__main__":
     main()
