[GRASS-SVN] r73230 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Sun Sep 2 19:31:55 PDT 2018
Author: wenzeslaus
Date: 2018-09-02 19:31:55 -0700 (Sun, 02 Sep 2018)
New Revision: 73230
grass/trunk/gui/wxpython/gui_core/gselect.py
wxGUI/gui_core: lazy import both of the pygrass (ctypes) dependent modules
If one can be lazy imported, the other can be too.
Avoids or postpones a fatal error at startup when uncaught exception happens.
Also translate the error message and avoid 'is False',
use not (style and readability).
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2018-09-03 02:04:19 UTC (rev 73229)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2018-09-03 02:31:55 UTC (rev 73230)
@@ -67,12 +67,6 @@
import grass.script as grass
from grass.script import task as gtask
from grass.exceptions import CalledModuleError
-try:
- from grass.pygrass import messages
-except ImportError as e:
- print(_("Unable to import pyGRASS: %s\n"
- "Some functionality will be not accessible") % e,
- file=sys.stderr)
from gui_core.widgets import ManageSettingsWidget, CoordinatesValidator
@@ -516,7 +510,7 @@
renamed_elements.append(elementdict[elem])
if element in ('stds', 'strds', 'str3ds', 'stvds'):
- if self.tgis_error is False:
+ if not self.tgis_error:
import grass.temporal as tgis
filesdict = tgis.tlist_grouped(
elementdict[element], element == 'stds')
@@ -763,11 +757,19 @@
if self.type in ('stds', 'strds', 'str3ds', 'stvds'):
# Initiate the temporal framework. Catch database error
# and set the error flag for the stds listing.
- import grass.temporal as tgis
try:
- tgis.init(True)
- except messages.FatalError as e:
- sys.stderr.write("Temporal GIS error:\n%s" % e)
+ import grass.temporal as tgis
+ from grass.pygrass import messages
+ try:
+ tgis.init(True)
+ except messages.FatalError as e:
+ sys.stderr.write(_("Temporal GIS error:\n%s") % e)
+ self.tgis_error = True
+ except ImportError as e:
+ # PyGRASS (ctypes) is the likely cause
+ "Unable to import pyGRASS: %s\n"
+ "Some functionality will be not accessible") % e)
if 'mapsets' in kargs:
self.mapsets = kargs['mapsets']
