[GRASS-SVN] r73238 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Mon Sep 3 13:44:12 PDT 2018
Author: mmetz
Date: 2018-09-03 13:44:12 -0700 (Mon, 03 Sep 2018)
New Revision: 73238
grass/trunk/lib/python/script/core.py
libpython: by default, no error output is produced even though the output in case of failure reads "Process ended with non-zero return code 1. See errors in the (error) output.", change default to cpature and report error output
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2018-09-03 20:17:54 UTC (rev 73237)
+++ grass/trunk/lib/python/script/core.py 2018-09-03 20:44:12 UTC (rev 73238)
@@ -80,7 +80,7 @@
raise_on_error = False # raise exception instead of calling fatal()
-_capture_stderr = False # capture stderr of subprocesses if possible
+_capture_stderr = True # capture stderr of subprocesses if possible
def call(*args, **kwargs):
