[GRASS-SVN] r73264 - grass/trunk/lib/init
svn_grass at osgeo.org
Tue Sep 4 20:34:04 PDT 2018
Author: wenzeslaus
Date: 2018-09-04 20:34:04 -0700 (Tue, 04 Sep 2018)
New Revision: 73264
grass/trunk/lib/init/grass.py
init: use the two dash text option in after-error suggestion
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2018-09-05 03:26:37 UTC (rev 73263)
+++ grass/trunk/lib/init/grass.py 2018-09-05 03:34:04 UTC (rev 73264)
@@ -381,7 +381,7 @@
version_flag=_("show version information and exit"),
create=_("create given database, location or mapset if it doesn't exist"),
exit_after=_("exit after creation of location or mapset. Only with -c flag"),
- force_removal=_("force removal of .gislock if exists (use with care!). Only with -text flag"),
+ force_removal=_("force removal of .gislock if exists (use with care!). Only with --text flag"),
text=_("use text based interface (skip welcome screen)"),
text_detail=_("and set as default"),
gtext=_("use text based interface (show welcome screen)"),
@@ -1129,7 +1129,7 @@
" report this error to the GRASS developers.\n"
"On systems with package manager, make sure you have the right"
" GUI package, probably named grass-gui, installed.\n"
- "To run GRASS GIS in text mode use the -text flag.\n"
+ "To run GRASS GIS in text mode use the --text flag.\n"
"Use '--help' for further options\n"
" {cmd_name} --help\n"
"See also: https://grass.osgeo.org/{cmd_name}/manuals/helptext.html").format(
@@ -2109,7 +2109,7 @@
if not set_mapset_interactive(grass_gui):
# No GUI available, update gisrc file
fatal(_("<{0}> requested, but not available. Run GRASS in text "
- "mode (-text) or install missing package (usually "
+ "mode (--text) or install missing package (usually "
"'grass-gui').").format(grass_gui))
else:
# Try non-interactive start up
