[GRASS-SVN] r73284 - grass/trunk/imagery/i.segment
Fri Sep 7 08:57:00 PDT 2018
Author: mmetz
Date: 2018-09-07 08:56:59 -0700 (Fri, 07 Sep 2018)
New Revision: 73284
   grass/trunk/imagery/i.segment/iseg.h
   grass/trunk/imagery/i.segment/open_files.c
i.segment: avoid integer overflow with extremely large regions
Modified: grass/trunk/imagery/i.segment/iseg.h
--- grass/trunk/imagery/i.segment/iseg.h	2018-09-07 08:01:47 UTC (rev 73283)
+++ grass/trunk/imagery/i.segment/iseg.h	2018-09-07 15:56:59 UTC (rev 73284)
@@ -110,7 +110,7 @@
     /* region growing internal structure */
     struct RG_TREE *reg_tree;   /* search tree with region stats */
-    int min_reg_size;		/* minimum region size */
+    LARGEINT min_reg_size;	/* minimum region size */
     struct reg_stats rs, rs_i, rs_k;
     struct ngbr_stats ns;
Modified: grass/trunk/imagery/i.segment/open_files.c
--- grass/trunk/imagery/i.segment/open_files.c	2018-09-07 08:01:47 UTC (rev 73283)
+++ grass/trunk/imagery/i.segment/open_files.c	2018-09-07 15:56:59 UTC (rev 73284)
@@ -508,7 +508,8 @@
 static int manage_memory(int srows, int scols, struct globals *globals)
     double reg_size_mb, segs_mb;
-    int reg_size_count, nseg, nseg_total;
+    LARGEINT reg_size_count;
+    int nseg, nseg_total;
     segs_mb = globals->mb;
     if (globals->method == ORM_RG) {
@@ -546,6 +547,7 @@
     /* calculate number of segments in memory */
+    /* nseg: integer overflow possible with large segs_mb */
     if (globals->bounds_map != NULL) {
 	/* input bands, segment ids, bounds map */
 	if (globals->method == ORM_MS) {
