[GRASS-SVN] r73287 - sandbox/wenzeslaus/g.citation
svn_grass at osgeo.org
Fri Sep 7 12:03:55 PDT 2018
Author: neteler
Date: 2018-09-07 12:03:54 -0700 (Fri, 07 Sep 2018)
New Revision: 73287
sandbox/wenzeslaus/g.citation/g.citation.html
g.citation addon: workaround for HTML parse error of <p> tag in example
Modified: sandbox/wenzeslaus/g.citation/g.citation.html
--- sandbox/wenzeslaus/g.citation/g.citation.html 2018-09-07 15:57:47 UTC (rev 73286)
+++ sandbox/wenzeslaus/g.citation/g.citation.html 2018-09-07 19:03:54 UTC (rev 73287)
@@ -31,10 +31,11 @@
<ul>
<li>Don't use the <tt>format=dict</tt> for further processing.
It is meant for exploration of what information the module
- acquired.
- <li>The structure of the JSON output is yet not guaranteed.
+ acquired.</li>
+ <li>The structure of the JSON output is yet not guaranteed.</li>
</ul>
<h2>EXAMPLES</h2>
<div class="code"><pre>
@@ -45,19 +46,21 @@
g.citation f=pretty-json -a -s | grep '"name": ' | sort | uniq
</pre></div>
-g.citation -s format=citeproc vsep="<p>" -a > all.html
+g.citation -s format=citeproc vsep="< p>" -a > all.html
</pre></div>
<h2>KNOWN ISSUES</h2>
<ul>
<li>More output formats or styles are needed.
The following formats were suggested so far:
- <tt>csl,datacite,dublincore,json-ld,narcxml</tt>
+ <tt>csl,datacite,dublincore,json-ld,narcxml</tt></li>
<li>The structure of the JSON output is not guaranteed. It reflects
- the internal structure (only the empty entries are removed).
- <li>Version and date in CFF output are incomplete.
+ the internal structure (only the empty entries are removed).</li>
+ <li>Version and date in CFF output are incomplete.</li>
</ul>
<h2>SEE ALSO</h2>
@@ -68,8 +71,8 @@
<h2>AUTHORS</h2>
-Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a> (ORCID: 0000-0001-5566-9236)
-Peter Loewe, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a> (ORCID: 0000-0003-2257-0517)
+Vaclav Petras, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a> (ORCID: 0000-0001-5566-9236)<br>
+Peter Loewe, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a> (ORCID: 0000-0003-2257-0517)<br>
Markus Neteler, <a href="http://geospatial.ncsu.edu/osgeorel/">NCSU GeoForAll Lab</a> (ORCID: 0000-0003-1916-1966)
<p><i>Last changed: $Date$</i>
