[GRASS-SVN] r73324 - grass-addons/grass7/raster/r.neighborhoodmatrix
svn_grass at osgeo.org
Fri Sep 14 05:36:17 PDT 2018
Author: mlennert
Date: 2018-09-14 05:36:16 -0700 (Fri, 14 Sep 2018)
New Revision: 73324
Removed:
grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py
r.neighborhoodmatrix: new C-version is implemented, no need for python file anymore
Deleted: grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py
--- grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py 2018-09-13 20:26:24 UTC (rev 73323)
+++ grass-addons/grass7/raster/r.neighborhoodmatrix/r.neighborhoodmatrix.py 2018-09-14 12:36:16 UTC (rev 73324)
@@ -1,201 +0,0 @@
-#!/usr/bin/env python
-# MODULE: r.neighborhoodmatrix
-# AUTHOR(S): Moritz Lennert
-# PURPOSE: Calculates a neighborhood matrix for a raster map with regions
-# (e.g. the output of r.clump or i.segment)
-# COPYRIGHT: (C) 1997-2016 by the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: Calculates a neighborhood matrix for a raster map with regions
-#% keyword: raster
-#% keyword: neighboorhood
-#% keyword: regions
-#%end
-#%option G_OPT_R_INPUT
-#% description: Raster for which to calculate the neighboorhood matrix
-#% required: yes
-#%end
-#%option G_OPT_F_OUTPUT
-#% description: Name for output file (- for standard output)
-#% required: yes
-#% answer: -
-#%end
-#%option G_OPT_F_SEP
-#%end
-#%option
-#% key: processes
-#% type: integer
-#% description: Number of processes to run in parallel (for multiple rasters)
-#% required: no
-#% answer: 1
-#%end
-#%flag
-#% key: d
-#% description: Also take into account diagonal neighbors
-#%end
-#%flag
-#% key: l
-#% description: Also output length of common border (in pixels)
-#%end
-import grass.script as gscript
-import sys
-import os
-import atexit
-import heapq
-from functools import partial
-from multiprocessing import Pool, Process, Queue
-def cleanup():
- for mapname in mapnames:
- gscript.run_command('g.remove', flags='f', type='raster',
- name=mapname, quiet=True)
- for filename in filenames:
- os.remove(filename)
- if outfile:
- os.remove(outfile)
- return 0
-def worker(input_queue, rinput, separator, result_queue):
- for mapname, modifier in iter(input_queue.get, 'STOP'):
- expression = "%s = if(%s%s!=%s, %s%s, null())" % (mapname, rinput, modifier, rinput, rinput, modifier)
- gscript.run_command('r.mapcalc',
- expression=expression,
- quiet=True)
- tfdir = gscript.tempdir()
- tf = os.path.join(tfdir, mapname)
- rstats_results = gscript.read_command('r.stats',
- input_=[rinput, mapname],
- flags='nc',
- output=tf,
- separator=separator,
- quiet=True)
- result_queue.put(tf)
-# Sort by both cat values
-def keyfunc(s):
- return [int(x) for x in s.split(separator)[:2]]
-def decorated_file(f, key):
- for line in f:
- yield (key(line), line)
-def main():
- global mapnames
- mapnames = []
- global filenames
- filenames = []
- global outfile
- outfile = None
- rinput = options['input']
- output = options['output']
- #Check that input map is CELL
- datatype = gscript.parse_command('r.info', flags='g', map=rinput)['datatype']
- if datatype != 'CELL':
- gscript.fatal(_("Input map has to be of CELL (integer) type"))
- mapinfo = gscript.raster_info(rinput)
- if mapinfo['max'] == mapinfo['min']:
- gscript.fatal(_("Need at least two different category values to determine neighbors"))
- global separator
- separator = gscript.separator(options['separator'])
- processes = int(options['processes'])
- pid = os.getpid()
- nbnames = ['nl', 'nr', 'nu', 'nd', 'nul', 'nur', 'nll', 'nlr']
- modifiers = ['[0,-1]', '[0,1]', '[1,0]', '[-1,0]', '[1,-1]', '[1,1]', '[-1,-1]', '[-1,1]']
- # If the diagonal flag is not set, only keep direct neighbors
- if not flags['d']:
- nbnames = nbnames[:4]
- modifiers = modifiers[:4]
- mapnames = ["nb_temp_%s_map_%d" % (nbname, pid) for nbname in nbnames]
- input_data = zip(mapnames, modifiers)
- input_queue = Queue()
- for input_datum in input_data:
- input_queue.put(input_datum)
- result_queue = Queue()
- # Launch processes for r.mapcalc and r.stats in as many processes as
- # requested
- processes_list = []
- for p in xrange(processes):
- proc = Process(target=worker, args=(input_queue, rinput, separator, result_queue))
- proc.start()
- processes_list.append(proc)
- input_queue.put('STOP')
- for p in processes_list:
- p.join()
- result_queue.put('STOP')
- # Now merge all r.stats outputs (which are already sorted)
- # into one file
- for tf in iter(result_queue.get, 'STOP'):
- filenames.append(tf)
- files = map(open, filenames)
- outfile = gscript.tempfile()
- # This code comes from https://stackoverflow.com/a/1001625
- with open(outfile, 'wb') as outf:
- for line in heapq.merge(*[decorated_file(f, keyfunc) for f in files]):
- outf.write(line[1])
- # Define final output
- if output == '-':
- of = sys.stdout
- else:
- of = open(output, 'w')
- # Read the merged output file and sum the results per neighborhood pair
- OldAcat = None
- OldBcat = None
- Sum = 0
- with open(outfile, 'r') as fin:
- for line in fin:
- Acat = line.split(separator)[0]
- Bcat = line.split(separator)[1]
- value = int(line.split(separator)[2])
- if Acat == OldAcat and Bcat == OldBcat:
- Sum += value
- else:
- if OldAcat and OldBcat:
- if flags['l']:
- woutput = separator.join([OldAcat, OldBcat, str(Sum)])
- else:
- woutput = separator.join([OldAcat, OldBcat])
- of.write(woutput+"\n")
- OldAcat = Acat
- OldBcat = Bcat
- Sum = value
- if flags['l']:
- else:
- of.close()
-if __name__ == "__main__":
- options, flags = gscript.parser()
- atexit.register(cleanup)
- main()
