[GRASS-SVN] r73326 - in grass/trunk: gui/wxpython/core lib/python/script
svn_grass at osgeo.org
Fri Sep 14 12:29:52 PDT 2018
Author: annakrat
Date: 2018-09-14 12:29:52 -0700 (Fri, 14 Sep 2018)
New Revision: 73326
grass/trunk/gui/wxpython/core/render.py
grass/trunk/lib/python/script/utils.py
add function for safe passing text into environment under both Python 2 and 3 on Windows
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py 2018-09-14 18:07:28 UTC (rev 73325)
+++ grass/trunk/gui/wxpython/core/render.py 2018-09-14 19:29:52 UTC (rev 73326)
@@ -33,7 +33,7 @@
import wx
from grass.script import core as grass
-from grass.script.utils import try_remove
+from grass.script.utils import try_remove, text_to_string
from grass.script.task import cmdlist_to_tuple, cmdtuple_to_list
from grass.pydispatch.signal import Signal
from grass.exceptions import CalledModuleError
@@ -391,7 +391,7 @@
if self.layer.GetType() in ('vector', 'thememap'):
if os.path.isfile(self.layer._legrow):
os.remove(self.layer._legrow)
- env_cmd['GRASS_LEGEND_FILE'] = self.layer._legrow
+ env_cmd['GRASS_LEGEND_FILE'] = text_to_string(self.layer._legrow)
cmd_render = copy.deepcopy(cmd)
cmd_render[1]['quiet'] = True # be quiet
@@ -464,7 +464,7 @@
"GRASS_RENDER_FILE_COMPRESSION": "0",
"GRASS_RENDER_TRUECOLOR": "TRUE",
"GRASS_RENDER_TRANSPARENT": "TRUE",
- "GRASS_LEGEND_FILE": self.Map.legfile
+ "GRASS_LEGEND_FILE": text_to_string(self.Map.legfile)
self._init()
Modified: grass/trunk/lib/python/script/utils.py
--- grass/trunk/lib/python/script/utils.py 2018-09-14 18:07:28 UTC (rev 73325)
+++ grass/trunk/lib/python/script/utils.py 2018-09-14 19:29:52 UTC (rev 73326)
@@ -235,6 +235,18 @@
return bytes(string)
+def text_to_string(text, encoding=None):
+ """Convert text to str. Useful when passing text into environments,
+ in Python 2 it needs to be bytes on Windows, in Python 3 in needs unicode.
+ if sys.version[0] == '2':
+ # Python 2
+ return encode(text, encoding=encoding)
+ else:
+ # Python 3
+ return decode(text, encoding=encoding)
def parse_key_val(s, sep='=', dflt=None, val_type=None, vsep=None):
"""Parse a string into a dictionary, where entries are separated
by newlines and the key and value are separated by `sep` (default: `=`)
