[GRASS-SVN] r73334 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Sat Sep 15 13:37:12 PDT 2018
Author: wenzeslaus
Date: 2018-09-15 13:37:12 -0700 (Sat, 15 Sep 2018)
New Revision: 73334
grass/trunk/gui/wxpython/core/render.py
wxGUI/core: replace grass.script.tempfile by tempfile.NamedTemporaryFile (fixes #3637)
Switches from mapset temporary directory to system temporary
directory which was previously set up for the session for
all GUI rendering files.
This also refactors and unifies handling of the temporary files related
to rendering, although on error and when removing/deleting the layers
removing of the files happens in the same way as before.
All files are now using NamedTemporaryFile instead of some using
g.tempfile and some NamedTemporaryFile. This means that when mapset
is switched, files are present in the (correct) session directory,
not incorrect mapset directory and then not deleted later.
(Deleting these files could cause rendering errors, while not deleting
them would lead to accumulating of files in mapset temporary directory).
See also:
* r28605 which adds glob for one delete when core.utils.GetTempfile(),
i.e., g.tempfile was still used (the glob part is still there)
* r56444 which adds mkstemp() for some of the files
* r60947 attempt to fix cleaning of deleting temporary files (#560)
which changes mkstemp to NamedTemporaryFile (still used now)
* r69085 which checked legend row file (legrow) name of last character
being digit (isdigit()) which was true for files from g.tempfile
but does not seem to have a reason (removed now)
* #3635 which investigates a suspicious cleanups of mapset temporary
directory which at this point seemed to be cleaning rendering files
from GUI (r37863, r21048)
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py 2018-09-15 20:01:06 UTC (rev 73333)
+++ grass/trunk/gui/wxpython/core/render.py 2018-09-15 20:37:12 UTC (rev 73334)
@@ -47,6 +47,22 @@
from core.gthread import gThread
+def get_tempfile_name(suffix, create=False):
+ """Returns a name for a temporary file in system directory"""
+ # this picks TMPDIR which we have set for GRASS session
+ # which may mitigate problems (like not cleaning files) in case we
+ # go little beyond what is in the documentation in terms of opening
+ # closing and removing the tmp file
+ tmp = tempfile.NamedTemporaryFile(suffix=suffix, delete=False)
+ # we don't want it open, we just need the name
+ name = tmp.name
+ tmp.close()
+ if not create:
+ # remove empty file to have a clean state later
+ os.remove(name)
+ return name
class Layer(object):
"""Virtual class which stores information about layers (map layers and
overlays) of the map composition.
@@ -81,12 +97,7 @@
else:
tempfile_sfx = ".ppm"
- mapfile = tempfile.NamedTemporaryFile(
- suffix=tempfile_sfx, delete=False)
- # we don't want it open, we just need the name
- self.mapfile = mapfile.name
- mapfile.close()
- os.remove(self.mapfile) # remove empty file
+ self.mapfile = get_tempfile_name(suffix=tempfile_sfx)
self.maskfile = self.mapfile.rsplit(".", 1)[0] + ".pgm"
@@ -118,6 +129,7 @@
self.active, self.opacity, self.hidden))
def __del__(self):
+ self.Clean()
Debug.msg(3, "Layer.__del__(): layer=%s, cmd='%s'" %
(self.name, self.GetCmd(string=True)))
@@ -317,7 +329,15 @@
"""Get render manager """
return self.renderMgr
+ def Clean(self):
+ if self.mapfile:
+ try_remove(self.mapfile)
+ self.mapfile = None
+ if self.maskfile:
+ try_remove(self.maskfile)
+ self.maskfile = None
class MapLayer(Layer):
def __init__(self, *args, **kwargs):
@@ -325,7 +345,7 @@
Layer.__init__(self, *args, **kwargs)
if self.type in ('vector', 'thememap'):
- self._legrow = grass.tempfile(create=True)
+ self._legrow = get_tempfile_name(suffix=".legrow", create=True)
else:
self._legrow = ''
@@ -343,7 +363,13 @@
except IndexError:
return self.name
+ def Clean(self):
+ Layer.Clean(self)
+ if self._legrow:
+ try_remove(self._legrow)
+ self._legrow = None
class Overlay(Layer):
def __init__(self, id, *args, **kwargs):
@@ -633,8 +659,7 @@
if layer.GetType() not in ('vector', 'thememap'):
continue
- if os.path.isfile(layer._legrow) and layer._legrow[-1].isdigit() \
- and layer.hidden is False:
+ if os.path.isfile(layer._legrow) and not layer.hidden:
with open(layer._legrow) as infile:
line = infile.read()
outfile.write(line)
@@ -744,11 +769,9 @@
self.gisrc = gisrc
# generated file for g.pnmcomp output for rendering the map
- self.legfile = grass.tempfile(create=False) + '.leg'
- self.tmpdir = os.path.dirname(self.legfile)
- self.mapfile = grass.tempfile(create=False) + '.ppm'
+ self.legfile = get_tempfile_name(suffix='.leg')
+ self.mapfile = get_tempfile_name(suffix='.ppm')
# setting some initial env. variables
if not self.GetWindow():
sys.stderr.write(_("Trying to recover from default region..."))
@@ -1318,6 +1341,9 @@
if base == '' or tempbase == '':
return None
basefile = os.path.join(base, tempbase) + r'.*'
+ # this comes all the way from r28605, so leaving
+ # it as it is, although it does not really fit with the
+ # new system (but probably works well enough)
for f in glob.glob(basefile):
os.remove(f)
@@ -1566,11 +1592,8 @@
def _clean(self, llist):
for layer in llist:
- if layer.maskfile:
- try_remove(layer.maskfile)
- if layer.mapfile:
- try_remove(layer.mapfile)
- llist.remove(layer)
+ layer.Clean()
+ del llist[:]
def Clean(self):
"""Clean layer stack - go trough all layers and remove them
@@ -1580,6 +1603,8 @@
self._clean(self.layers)
self._clean(self.overlays)
+ try_remove(self.legfile)
def ReverseListOfLayers(self):
"""Reverse list of layers"""
