[GRASS-SVN] r73338 - grass/trunk/lib/init
svn_grass at osgeo.org
Sat Sep 15 19:45:09 PDT 2018
Author: wenzeslaus
Date: 2018-09-15 19:45:09 -0700 (Sat, 15 Sep 2018)
New Revision: 73338
grass/trunk/lib/init/grass.py
init: call clean_temp always at exit
This is has the same behaviour as before, i.e. clean_temp called at all exits
and it is similar to what was there before r73336, i.e. .tmp deleted at exit.
Additionally this calls clean_temp also in some error states when then
exist function calls in the call are not reached.
See #3635 for removal of Python-based clean up procedures (which should be covered by clean_temp).
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2018-09-16 02:22:14 UTC (rev 73337)
+++ grass/trunk/lib/init/grass.py 2018-09-16 02:45:09 UTC (rev 73338)
@@ -2142,6 +2142,9 @@
# unlock the mapset which is current at the time of turning off
# in case mapset was changed
atexit.register(lambda: unlock_gisrc_mapset(gisrc, gisrcrc))
+ # clean always at exit, cleans whatever is current mapset based on
+ # the GISRC env variable
+ atexit.register(clean_temp)
# build user fontcap if specified but not present
make_fontcap()
@@ -2153,10 +2156,8 @@
# only non-error, interactive version continues from here
if batch_job:
returncode = run_batch_job(batch_job)
- clean_temp()
sys.exit(returncode)
elif params.exit_grass:
- clean_temp()
sys.exit(0)
else:
clear_screen()
@@ -2193,9 +2194,6 @@
close_gui()
# here we are at the end of grass session
clear_screen()
- # TODO: can we just register this atexit?
- # TODO: and what is difference to deleting .tmp which we do?
- clean_temp()
# save 'last used' GISRC after removing variables which shouldn't
# be saved, e.g. d.mon related
clean_env(gisrc)
