[GRASS-SVN] r73355 - grass/trunk/lib/init
svn_grass at osgeo.org
Sun Sep 16 18:52:46 PDT 2018
Author: wenzeslaus
Date: 2018-09-16 18:52:46 -0700 (Sun, 16 Sep 2018)
New Revision: 73355
grass/trunk/lib/init/README
init: replace obsolete doc by link to up-to-date doc (see #2679, r72791, r73354)
Modified: grass/trunk/lib/init/README
--- grass/trunk/lib/init/README 2018-09-17 01:42:41 UTC (rev 73354)
+++ grass/trunk/lib/init/README 2018-09-17 01:52:46 UTC (rev 73355)
@@ -8,75 +8,8 @@
You can set an alias "grass77" to e.g. "grass77 --text" to use text mode by default.
Or set the environmental variable GRASS_GUI=text.
+ See grass77 --help or the command's manual page for more details
+ about invocation.
-o GRASS non-interactive startup examples
- You can startup GRASS non-interactively using some env variables.
- LOCATION
- GISDBASE
- LOCATION_NAME
- MAPSET
- LOCATION var overrides GISDBASE/LOCATION_NAME/MAPSET location.
- ex1)
- export LOCATION=/usr/home/grass/usr/data1/loc1/map1
- export GISDBASE=/usr/home/grass/usr/data1
- export LOCATION_NAME=loc1
- export MAPSET=map1
- grass77 - # non-interactive startup using LOCATION location
- ex2)
- # GISDBASE/LOCATION_NAME/MAPSET location
- Also, the first argument of grass77 can override these env vars.
- ex3)
- grass77 /usr/home/grass/usr/data2/loc2-1/map1-1
- # /usr/home/grass/usr/data2/loc2-1/map1-1 location
- ex4)
- ex5)
- grass77 map1-1 # non-interactive startup using
- # GISDBASE/LOCATION_NAME/map1-1 location
- ex6)
- grass77 loc2-1/map1-1
- # GISDBASE/loc2-1/map1-1 location
Send any suggestions to <grass-dev at lists.osgeo.org> at https://lists.osgeo.org/pipermail/grass-dev/
