[GRASS-SVN] r73358 - in grass/trunk/lib/python/pygrass: . raster
Sun Sep 16 21:04:08 PDT 2018
Author: annakrat
Date: 2018-09-16 21:04:08 -0700 (Sun, 16 Sep 2018)
New Revision: 73358
   grass/trunk/lib/python/pygrass/raster/category.py
   grass/trunk/lib/python/pygrass/utils.py
pygrass: work on Python 3 support - fixes to get raster tests working
Modified: grass/trunk/lib/python/pygrass/raster/category.py
--- grass/trunk/lib/python/pygrass/raster/category.py	2018-09-17 02:30:53 UTC (rev 73357)
+++ grass/trunk/lib/python/pygrass/raster/category.py	2018-09-17 04:04:08 UTC (rev 73358)
@@ -11,7 +11,7 @@
 from grass.exceptions import ImplementationError
 from grass.pygrass.errors import GrassError
+from grass.pygrass.utils import decode
 from grass.pygrass.raster.raster_type import TYPE as RTYPE
@@ -146,11 +146,11 @@
         min_cat = ctypes.pointer(RTYPE[self.mtype]['grass def']())
         max_cat = ctypes.pointer(RTYPE[self.mtype]['grass def']())
-        lab = libraster.Rast_get_ith_cat(ctypes.byref(self.c_cats),
-                                         index,
-                                         ctypes.cast(min_cat, ctypes.c_void_p),
-                                         ctypes.cast(max_cat, ctypes.c_void_p),
-                                         self._gtype)
+        lab = decode(libraster.Rast_get_ith_cat(ctypes.byref(self.c_cats),
+                                                index,
+                                                ctypes.cast(min_cat, ctypes.c_void_p),
+                                                ctypes.cast(max_cat, ctypes.c_void_p),
+                                                self._gtype))
         # Manage C function Errors
         if lab == '':
             raise GrassError(_("Error executing: Rast_get_ith_cat"))
Modified: grass/trunk/lib/python/pygrass/utils.py
--- grass/trunk/lib/python/pygrass/utils.py	2018-09-17 02:30:53 UTC (rev 73357)
+++ grass/trunk/lib/python/pygrass/utils.py	2018-09-17 04:04:08 UTC (rev 73358)
@@ -7,6 +7,7 @@
 import grass.lib.gis as libgis
 libgis.G_gisinit('')
 import grass.lib.raster as libraster
+from grass.lib.ctypes_preamble import String
 from grass.script import core as grasscore
 from grass.script import utils as grassutils
@@ -117,6 +118,19 @@
     grasscore.run_command('g.copy', quiet=True, **kwargs)
+def decode(obj, encoding=None):
+    """Decode string coming from c functions,
+    can be ctypes class String, bytes, or None
+    if isinstance(obj, String):
+        return grassutils.decode(obj.data, encoding=encoding)
+    elif isinstance(obj, bytes):
+        return grassutils.decode(obj)
+    else:
+        # eg None
+        return obj
 def getenv(env):
     """Return the current grass environment variables
@@ -125,7 +139,7 @@
     True
-    return grassutils.decode(libgis.G_getenv_nofatal(env))
+    return decode(libgis.G_getenv_nofatal(env))
 def get_mapset_raster(mapname, mapset=''):
@@ -135,7 +149,7 @@
     True
-    return grassutils.decode(libgis.G_find_raster2(mapname, mapset))
+    return decode(libgis.G_find_raster2(mapname, mapset))
 def get_mapset_vector(mapname, mapset=''):
@@ -145,7 +159,7 @@
     True
-    return grassutils.decode(libgis.G_find_vector2(mapname, mapset))
+    return decode(libgis.G_find_vector2(mapname, mapset))
 def is_clean_name(name):
