[GRASS-SVN] r73366 - in grass/trunk: raster/r.fill.stats raster/r.resamp.bspline scripts/r.fillnulls temporal/t.rast.gapfill vector/v.surf.rst vector/v.vol.rst
Wed Sep 19 05:27:00 PDT 2018
Author: neteler
Date: 2018-09-19 05:27:00 -0700 (Wed, 19 Sep 2018)
New Revision: 73366
   grass/trunk/raster/r.fill.stats/main.c
   grass/trunk/raster/r.resamp.bspline/main.c
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
   grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
   grass/trunk/vector/v.surf.rst/main.c
   grass/trunk/vector/v.vol.rst/main.c
keywords: add "no-data filling" keyword for keyword index
Modified: grass/trunk/raster/r.fill.stats/main.c
--- grass/trunk/raster/r.fill.stats/main.c	2018-09-19 11:09:57 UTC (rev 73365)
+++ grass/trunk/raster/r.fill.stats/main.c	2018-09-19 12:27:00 UTC (rev 73366)
@@ -776,7 +776,7 @@
     G_add_keyword(_("surface"));
     G_add_keyword(_("interpolation"));
     G_add_keyword(_("IDW"));
-    G_add_keyword(_("null data"));
+    G_add_keyword(_("no-data filling"));
     module->description =
         _("Rapidly fills 'no data' cells (NULLs) of a raster map with interpolated values (IDW).");
Modified: grass/trunk/raster/r.resamp.bspline/main.c
--- grass/trunk/raster/r.resamp.bspline/main.c	2018-09-19 11:09:57 UTC (rev 73365)
+++ grass/trunk/raster/r.resamp.bspline/main.c	2018-09-19 12:27:00 UTC (rev 73366)
@@ -80,6 +80,8 @@
     G_add_keyword(_("resample"));
+    G_add_keyword(_("splines"));
 	_("Performs bilinear or bicubic spline interpolation with Tykhonov regularization.");
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2018-09-19 11:09:57 UTC (rev 73365)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2018-09-19 12:27:00 UTC (rev 73366)
@@ -29,6 +29,8 @@
 #% keyword: surface
 #% keyword: elevation
 #% keyword: interpolation
+#% keyword: splines
+#% keyword: no-data filling
 #%end
 #%option G_OPT_R_INPUT
 #%end
Modified: grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
--- grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py	2018-09-19 11:09:57 UTC (rev 73365)
+++ grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py	2018-09-19 12:27:00 UTC (rev 73366)
@@ -26,6 +26,7 @@
 #% keyword: raster
 #% keyword: time
 #%end
 #%option G_OPT_STRDS_INPUT
Modified: grass/trunk/vector/v.surf.rst/main.c
--- grass/trunk/vector/v.surf.rst/main.c	2018-09-19 11:09:57 UTC (rev 73365)
+++ grass/trunk/vector/v.surf.rst/main.c	2018-09-19 12:27:00 UTC (rev 73366)
@@ -147,7 +147,9 @@
     G_add_keyword(_("vector"));
+    G_add_keyword(_("RST"));
     G_add_keyword(_("3D"));
     module->label = _("Performs surface interpolation from vector points map by splines.");
 	_("Spatial approximation and topographic analysis from given "
Modified: grass/trunk/vector/v.vol.rst/main.c
--- grass/trunk/vector/v.vol.rst/main.c	2018-09-19 11:09:57 UTC (rev 73365)
+++ grass/trunk/vector/v.vol.rst/main.c	2018-09-19 12:27:00 UTC (rev 73366)
@@ -237,6 +237,8 @@
+    G_add_keyword(_("3D"));
 	_("Interpolates point data to a 3D raster map using "
 	  "regularized spline with tension (RST) algorithm.");
