[GRASS-SVN] r73370 - grass-addons/grass7/general/g.proj.identify
svn_grass at osgeo.org
Wed Sep 19 06:27:24 PDT 2018
Author: neteler
Date: 2018-09-19 06:27:24 -0700 (Wed, 19 Sep 2018)
New Revision: 73370
grass-addons/grass7/general/g.proj.identify/g.proj.identify.html
g.proj.identify addon: improve examples
Modified: grass-addons/grass7/general/g.proj.identify/g.proj.identify.html
--- grass-addons/grass7/general/g.proj.identify/g.proj.identify.html 2018-09-19 13:26:53 UTC (rev 73369)
+++ grass-addons/grass7/general/g.proj.identify/g.proj.identify.html 2018-09-19 13:27:24 UTC (rev 73370)
@@ -1,22 +1,30 @@
<h2>DESCRIPTION</h2>
-<em>g.proj.identify</em> allows to automaticaly identify EPSG code for given WKT prj.
-User can print EPSG from current location or for given WKT file.
-Conversion from given EPSG code to WKT and proj4 is supported.
+<em>g.proj.identify</em> allows to automaticaly identify the EPSG code from
+a given Well-Know Text (WKT) projection string stored in a file. The user
+can also print the EPSG code of the current location.
+The conversion from a given EPSG code to WKT and proj4 is supported.
<h2>EXAMPLE</h2>
<div class="code"><pre>
-print EPSG code of current Location- without parameters
+# print EPSG code of current Location - use without parameters
g.proj.identify
-print WKT and proj4 for gieven EPSG code
-g.proj.identify.py -p -w epsg=4326
+# identify EPSG code from WKT definition stored in file 'myproj.wkt'
+g.proj.identify wkt=myproj.wkt
+# print WKT and proj4 for given EPSG code, independent from current location
+g.proj.identify -p -w epsg=4326
</pre></div>
<h2>SEE ALSO</h2>
<em>
- <a href="g.proj.html">r.proj</a>,
+<a href="g.proj.html">g.proj</a>,
+<a href="m.proj.html">m.proj</a>,
+<a href="r.proj.html">r.proj</a>,
+<a href="v.proj.html">v.proj</a>
</em>
<h2>AUTHORS</h2>
