[GRASS-SVN] r73376 - grass-addons/grass7/imagery/i.segment.stats
svn_grass at osgeo.org
Thu Sep 20 05:06:45 PDT 2018
Author: mlennert
Date: 2018-09-20 05:06:45 -0700 (Thu, 20 Sep 2018)
New Revision: 73376
grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
i.segment.stats: better handling of temp attribute table to avoid conflict with existing table
Modified: grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py
--- grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py 2018-09-19 14:33:13 UTC (rev 73375)
+++ grass-addons/grass7/imagery/i.segment.stats/i.segment.stats.py 2018-09-20 12:06:45 UTC (rev 73376)
@@ -105,6 +105,11 @@
if gscript.find_file(temporary_vect, element='vector')['name']:
gscript.run_command('g.remove', flags='f', type_='vector',
name=temporary_vect, quiet=True)
+ if gscript.db_table_exist(temporary_vect):
+ gscript.run_command('db.execute',
+ sql='DROP TABLE %s' % temporary_vect,
+ quiet=True)
if insert_sql:
os.remove(insert_sql)
@@ -247,13 +252,18 @@
output=temporary_vect,
type_='area',
flags='vt',
- overwrite=True,
- quiet=True)
+ overwrite=True,
+ quiet=True)
insert_sql = gscript.tempfile()
fsql = open(insert_sql, 'w')
fsql.write('BEGIN TRANSACTION;\n')
- create_statement = 'CREATE TABLE ' + vectormap + ' (cat int, '
+ if gscript.overwrite():
+ fsql.write('DROP TABLE %s;' % temporary_vect)
+ else:
+ gscript.fatal(_("Table %s already exists. Use --o to overwrite" % temporary_vect))
+ create_statement = 'CREATE TABLE ' + temporary_vect + ' (cat int, '
for header in output_header[1:-1]:
create_statement += header + ' double precision, '
create_statement += output_header[-1] + ' double precision);\n'
@@ -260,7 +270,7 @@
fsql.write(create_statement)
for key in output_dict:
if len(output_dict[key]) + 1 == len(output_header):
- sql = "INSERT INTO " + vectormap + " VALUES (" + key+","+",".join(output_dict[key])+");\n"
+ sql = "INSERT INTO %s VALUES (%s, %s);\n" % (temporary_vect, key, ",".join(output_dict[key]))
sql = sql.replace('inf', 'NULL')
fsql.write(sql)
else:
@@ -270,9 +280,9 @@
fsql.write('END TRANSACTION;')
fsql.close()
- gscript.run_command('g.copy', vector=temporary_vect+','+vectormap, quiet=True)
gscript.run_command('db.execute', input=insert_sql, quiet=True)
- gscript.run_command('v.db.connect', map_=vectormap, table=vectormap, quiet=True)
+ gscript.run_command('v.db.connect', map_=temporary_vect, table=temporary_vect, quiet=True)
+ gscript.run_command('g.copy', vector="%s,%s" % (temporary_vect, vectormap), quiet=True)
if error_objects:
object_string = ', '.join(error_objects[:100])
