[GRASS-SVN] r73389 - grass-addons/grass7/imagery/i.segment.uspo
Mon Sep 24 10:57:18 PDT 2018
Author: neteler
Date: 2018-09-24 10:57:18 -0700 (Mon, 24 Sep 2018)
New Revision: 73389
   grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py
i.segment.uspo addon: fix r73387
Modified: grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py
--- grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py	2018-09-24 15:22:12 UTC (rev 73388)
+++ grass-addons/grass7/imagery/i.segment.uspo/i.segment.uspo.py	2018-09-24 17:57:18 UTC (rev 73389)
@@ -29,271 +29,271 @@
 # Geo-Information, 4(4), pp. 2292-2305, http://dx.doi.org/10.3390/ijgi4042292
-# %Module
-# % description: Unsupervised segmentation parameter optimization
-# % keyword: imagery
-# % keyword: variance
-# % keyword: segmentation
-# % keyword: threshold
-# %end
+#%Module
+#% description: Unsupervised segmentation parameter optimization
+#% keyword: imagery
+#% keyword: variance
+#% keyword: segmentation
+#% keyword: threshold
+#%end
-# %option G_OPT_I_GROUP
-# % description: Group to use for segmentation
-# % required : yes
-# %end
+#%option G_OPT_I_GROUP
+#% description: Group to use for segmentation
+#% required : yes
+#%end
-# %option G_OPT_R_MAPS
-# % key: maps
-# % description: Raster band(s) for  which to calculate variance (default: all group members)
-# % required : no
-# %end
+#%option G_OPT_R_MAPS
+#% key: maps
+#% description: Raster band(s) for  which to calculate variance (default: all group members)
+#% required : no
+#%end
-# % key: seeds
-# % description: Seeds for segmentation
-# % required : no
-# %end
+#% key: seeds
+#% description: Seeds for segmentation
+#% required : no
+#%end
-# %option G_OPT_F_OUTPUT
-# % description: Name for output file (- for standard output)
-# % required : no
-# %end
+#%option G_OPT_F_OUTPUT
+#% description: Name for output file (- for standard output)
+#% required : no
+#%end
-# %option G_OPT_R_OUTPUT
-# % key: segment_map
-# % description: Prefix for "best" output segmentation map per region
-# % required : no
-# %end
+#%option G_OPT_R_OUTPUT
+#% key: segment_map
+#% description: Prefix for "best" output segmentation map per region
+#% required : no
+#%end
-# %option G_OPT_M_REGION
-# % key: regions
-# % description: Regions in which to analyze the variance
-# % required: yes
-# % multiple: yes
-# %end
+#%option G_OPT_M_REGION
+#% key: regions
+#% description: Regions in which to analyze the variance
+#% required: yes
+#% multiple: yes
+#%end
-# %option
-# % key: segmentation_method
-# % type: string
-# % description: Segmentation method to use
-# % required: yes
-# % options: region_growing,mean_shift
-# % answer: region_growing
-# %end
+#%option
+#% key: segmentation_method
+#% type: string
+#% description: Segmentation method to use
+#% required: yes
+#% options: region_growing,mean_shift
+#% answer: region_growing
+#%end
-# %option
-# % key: thresholds
-# % type: double
-# % description: Thresholds to test
-# % required: no
-# % multiple: yes
-# % guisection: General
-# %end
+#%option
+#% key: thresholds
+#% type: double
+#% description: Thresholds to test
+#% required: no
+#% multiple: yes
+#% guisection: General
+#%end
-# %option
-# % key: threshold_start
-# % type: double
-# % description: Lowest threshold to test
-# % required: no
-# %end
+#%option
+#% key: threshold_start
+#% type: double
+#% description: Lowest threshold to test
+#% required: no
+#%end
-# %option
-# % key: threshold_stop
-# % type: double
-# % description: Threshold at which to stop (not included)
-# % required: no
-# %end
+#%option
+#% key: threshold_stop
+#% type: double
+#% description: Threshold at which to stop (not included)
+#% required: no
+#%end
-# %option
-# % key: threshold_step
-# % type: double
-# % description: Step to use between thresholds
-# % required: no
-# %end
+#%option
+#% key: threshold_step
+#% type: double
+#% description: Step to use between thresholds
+#% required: no
+#%end
-# %option
-# % key: minsizes
-# % type: integer
-# % description: Minimum number of cells in a segment to test
-# % multiple: yes
-# % required: no
-# %end
+#%option
+#% key: minsizes
+#% type: integer
+#% description: Minimum number of cells in a segment to test
+#% multiple: yes
+#% required: no
+#%end
-# %option
-# % key: minsize_start
-# % type: integer
-# % description: Lowest minimum segment size to test
-# % required: no
-# %end
+#%option
+#% key: minsize_start
+#% type: integer
+#% description: Lowest minimum segment size to test
+#% required: no
+#%end
-# %option
-# % key: minsize_stop
-# % type: integer
-# % description: Value for minimum segment size at which to stop (not included)
-# % required: no
-# %end
+#%option
+#% key: minsize_stop
+#% type: integer
+#% description: Value for minimum segment size at which to stop (not included)
+#% required: no
+#%end
-# %option
-# % key: minsize_step
-# % type: integer
-# % description: Step to use between minimum segment sizes
-# % required: no
-# %end
+#%option
+#% key: minsize_step
+#% type: integer
+#% description: Step to use between minimum segment sizes
+#% required: no
+#%end
-# %option
-# % key: radiuses
-# % type: double
-# % description: Radiuses to test
-# % required: no
-# % multiple: yes
-# % guisection: Mean Shift
-# %end
+#%option
+#% key: radiuses
+#% type: double
+#% description: Radiuses to test
+#% required: no
+#% multiple: yes
+#% guisection: Mean Shift
+#%end
-# %option
-# % key: radius_start
-# % type: double
-# % description: Lowest radius to test
-# % required: no
-# %end
+#%option
+#% key: radius_start
+#% type: double
+#% description: Lowest radius to test
+#% required: no
+#%end
-# %option
-# % key: radius_stop
-# % type: double
-# % description: Radius at which to stop (not included)
-# % required: no
-# %end
+#%option
+#% key: radius_stop
+#% type: double
+#% description: Radius at which to stop (not included)
+#% required: no
+#%end
-# %option
-# % key: radius_step
-# % type: double
-# % description: Step to use between radiuses
-# % required: no
-# %end
+#%option
+#% key: radius_step
+#% type: double
+#% description: Step to use between radiuses
+#% required: no
+#%end
-# %option
-# % key: hrs
-# % type: double
-# % description: Spectral bandwidths to test
-# % required: no
-# % multiple: yes
-# %end
+#%option
+#% key: hrs
+#% type: double
+#% description: Spectral bandwidths to test
+#% required: no
+#% multiple: yes
+#%end
-# %option
-# % key: hr_start
-# % type: double
-# % description: Lowest spectral bandwith to test
-# % required: no
-# %end
+#%option
+#% key: hr_start
+#% type: double
+#% description: Lowest spectral bandwith to test
+#% required: no
+#%end
-# %option
-# % key: hr_stop
-# % type: double
-# % description: Spectral bandwith at which to stop (not included)
-# % required: no
-# %end
+#%option
+#% key: hr_stop
+#% type: double
+#% description: Spectral bandwith at which to stop (not included)
+#% required: no
+#%end
-# %option
-# % key: hr_step
-# % type: double
-# % description: Step to use between spectral bandwidths
-# % required: no
-# %end
+#%option
+#% key: hr_step
+#% type: double
+#% description: Step to use between spectral bandwidths
+#% required: no
+#%end
-# %option
-# % key: autocorrelation_indicator
-# % type: string
-# % description: Indicator for measuring inter-segment heterogeneity
-# % required: no
-# % options: morans,geary
-# % answer: morans
-# % guisection: Evaluation
-# %end
+#%option
+#% key: autocorrelation_indicator
+#% type: string
+#% description: Indicator for measuring inter-segment heterogeneity
+#% required: no
+#% options: morans,geary
+#% answer: morans
+#% guisection: Evaluation
+#%end
-# %option
-# % key: optimization_function
-# % type: string
-# % description: Optimization function used to determine "best" parameters
-# % required: no
-# % options: sum,f
-# % answer: sum
-# %end
+#%option
+#% key: optimization_function
+#% type: string
+#% description: Optimization function used to determine "best" parameters
+#% required: no
+#% options: sum,f
+#% answer: sum
+#%end
-# %option
-# % key: f_function_alpha
-# % type: double
-# % description: Alpha value used for F-measure optimization function
-# % required: no
-# % answer: 1
-# %end
+#%option
+#% key: f_function_alpha
+#% type: double
+#% description: Alpha value used for F-measure optimization function
+#% required: no
+#% answer: 1
+#%end
-# %option
-# % key: number_best
-# % type: integer
-# % description: Number of desired best parameter values and maps
-# % required: no
-# % answer: 1
-# %end
+#%option
+#% key: number_best
+#% type: integer
+#% description: Number of desired best parameter values and maps
+#% required: no
+#% answer: 1
+#%end
-# %option
-# % key: memory
-# % type: integer
-# % description: Total memory (in MB) to allocate (will be divided by processes)
-# % required: no
-# % answer: 300
-# %end
+#%option
+#% key: memory
+#% type: integer
+#% description: Total memory (in MB) to allocate (will be divided by processes)
+#% required: no
+#% answer: 300
+#%end
-# %option
-# % key: processes
-# % type: integer
-# % description: Number of processes to run in parallel
-# % required: no
-# % answer: 1
-# %end
+#%option
+#% key: processes
+#% type: integer
+#% description: Number of processes to run in parallel
+#% required: no
+#% answer: 1
+#%end
-# %flag
-# % key: k
-# % description: Keep all segmented maps
-# %end
+#%flag
+#% key: k
+#% description: Keep all segmented maps
+#%end
-# %flag
-# % key: h
-# % description: Use hierarchical segmentation
-# %end
+#%flag
+#% key: h
+#% description: Use hierarchical segmentation
+#%end
-# %flag
-# % key: a
-# % description: Use adaptive spectral bandwidth (with mean shift)
-# %end
+#%flag
+#% key: a
+#% description: Use adaptive spectral bandwidth (with mean shift)
+#%end
-# %rules
-# % required: thresholds,threshold_start
-# % excludes: thresholds,threshold_start,threshold_stop,threshold_step
-# % collective: threshold_start,threshold_stop,threshold_step
-# % required: minsizes,minsize_start
-# % excludes: minsizes,minsize_start,minsize_stop,minsize_step
-# % collective: minsize_start,minsize_stop,minsize_step
-# % excludes: radiuses,radius_start,radius_stop,radius_step
-# % excludes: hrs,hr_start,hr_stop,hr_step
-# % collective: radius_start,radius_stop,radius_step
-# % collective: hr_start,hr_stop,hr_step
-# %end
+#%rules
+#% required: thresholds,threshold_start
+#% excludes: thresholds,threshold_start,threshold_stop,threshold_step
+#% collective: threshold_start,threshold_stop,threshold_step
+#% required: minsizes,minsize_start
+#% excludes: minsizes,minsize_start,minsize_stop,minsize_step
+#% collective: minsize_start,minsize_stop,minsize_step
+#% excludes: radiuses,radius_start,radius_stop,radius_step
+#% excludes: hrs,hr_start,hr_stop,hr_step
+#% collective: radius_start,radius_stop,radius_step
+#% collective: hr_start,hr_stop,hr_step
+#%end
 import grass.script as gscript
 import sys
