[GRASS-SVN] r73393 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Tue Sep 25 07:13:06 PDT 2018
Author: martinl
Date: 2018-09-25 07:13:05 -0700 (Tue, 25 Sep 2018)
New Revision: 73393
grass/trunk/lib/python/pygrass/vector/__init__.py
pygrass wrongly reports lines for point vector maps, see #3549
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2018-09-24 20:41:08 UTC (rev 73392)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2018-09-25 14:13:05 UTC (rev 73393)
@@ -27,8 +27,8 @@
"holes": libvect.Vect_get_num_holes,
"islands": libvect.Vect_get_num_islands,
"kernels": libvect.Vect_get_num_kernels,
- "points": libvect.Vect_get_num_lines,
- "lines": libvect.Vect_get_num_lines,
+ "points": (libvect.Vect_get_num_primitives, libvect.GV_POINT),
+ "lines": (libvect.Vect_get_num_primitives, libvect.GV_LINE),
"nodes": libvect.Vect_get_num_nodes,
"updated_lines": libvect.Vect_get_num_updated_lines,
"updated_nodes": libvect.Vect_get_num_updated_nodes,
@@ -370,7 +370,11 @@
if vtype in _NUMOF.keys():
- return _NUMOF[vtype](self.c_mapinfo)
+ if isinstance(_NUMOF[vtype], tuple):
+ fn, ptype = _NUMOF[vtype]
+ return fn(self.c_mapinfo, ptype)
+ else:
+ return _NUMOF[vtype](self.c_mapinfo)
else:
keys = "', '".join(sorted(_NUMOF.keys()))
raise ValueError("vtype not supported, use one of: '%s'" % keys)
