[GRASS-SVN] r73399 - grass/trunk/gui/wxpython/datacatalog
svn_grass at osgeo.org
Tue Sep 25 13:32:11 PDT 2018
Author: martinl
Date: 2018-09-25 13:32:10 -0700 (Tue, 25 Sep 2018)
New Revision: 73399
grass/trunk/gui/wxpython/datacatalog/tree.py
revert r73398 it cause troubles when switching mapset or copying data, need to be implemented in other way
Modified: grass/trunk/gui/wxpython/datacatalog/tree.py
--- grass/trunk/gui/wxpython/datacatalog/tree.py 2018-09-25 20:27:17 UTC (rev 73398)
+++ grass/trunk/gui/wxpython/datacatalog/tree.py 2018-09-25 20:32:10 UTC (rev 73399)
@@ -300,13 +300,13 @@
nlocations = len(locations)
grassdata_node = self._model.AppendNode(
parent=self._model.root, label=_('GRASS locations in {0}').format(
- genv['GISDBASE']), data=dict(type='grassdata'))
+ genv['GISDBASE']), data=dict(
+ type='grassdata'))
for location in locations:
results[location] = dict()
- label = '{} (current)'.format(location) if location == genv['LOCATION_NAME'] else location
varloc = self._model.AppendNode(
- parent=grassdata_node, label=label,
- data=dict(type='location', name=location, current=True))
+ parent=grassdata_node, label=location, data=dict(
+ type='location', name=location))
location_nodes.append(varloc)
loc_count += 1
@@ -333,10 +333,9 @@
errors.append(error)
for key in sorted(maps.keys()):
- label = '{} (current)'.format(key) if key == genv['MAPSET'] else key
mapset_node = self._model.AppendNode(
parent=location_nodes[i],
- label=label, data=dict(
+ label=key, data=dict(
type='mapset', name=key))
self._populateMapsetItem(mapset_node, maps[key])
