[GRASS-SVN] r73417 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Wed Sep 26 13:37:41 PDT 2018
Author: martinl
Date: 2018-09-26 13:37:41 -0700 (Wed, 26 Sep 2018)
New Revision: 73417
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/gui/wxpython/gui_core/prompt.py
Command prompt - Log files produces empty log files, see #3657
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2018-09-26 19:18:37 UTC (rev 73416)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2018-09-26 20:37:41 UTC (rev 73417)
@@ -173,6 +173,7 @@
size=self.btnCmdClear.GetSize())
self.btnCmdProtocol.SetToolTip(_("Toggle to save list of executed commands into "
"a file; content saved when switching off."))
+ self.cmdFileProtocol = None
if not self._gcstyle & GC_PROMPT:
self.btnCmdClear.Hide()
@@ -484,24 +485,23 @@
def CmdProtocolSave(self):
"""Save list of manually entered commands into a text log file"""
- if not hasattr(self, 'cmdFileProtocol'):
+ if self.cmdFileProtocol is None:
return # it should not happen
try:
- output = open(self.cmdFileProtocol, "a")
- cmds = self.cmdPrompt.GetCommands()
- output.write('\n'.join(cmds))
- if len(cmds) > 0:
- output.write('\n')
+ with open(self.cmdFileProtocol, "a") as output:
+ cmds = self.cmdPrompt.GetCommands()
+ output.write(os.linesep.join(cmds))
+ if len(cmds) > 0:
+ output.write(os.linesep)
except IOError as e:
- GError(_("Unable to write file '%(filePath)s'.\n\nDetails: %(error)s") %
- {'filePath': self.cmdFileProtocol, 'error': e})
- finally:
- output.close()
+ GError(_("Unable to write file '{filePath}'.\n\nDetails: {error}").format(
+ filePath=self.cmdFileProtocol, error=e))
- message = _("Command log saved to '%s'") % self.cmdFileProtocol
- self.showNotification.emit(message=message)
- del self.cmdFileProtocol
+ self.showNotification.emit(
+ message=_("Command log saved to '{}'".format(self.cmdFileProtocol))
def OnCmdProtocol(self, event=None):
"""Save commands into file"""
Modified: grass/trunk/gui/wxpython/gui_core/prompt.py
--- grass/trunk/gui/wxpython/gui_core/prompt.py 2018-09-26 19:18:37 UTC (rev 73416)
+++ grass/trunk/gui/wxpython/gui_core/prompt.py 2018-09-26 20:37:41 UTC (rev 73417)
@@ -111,8 +111,6 @@
if not cmdString:
return
- self.commands.append(cmdString) # trace commands
# parse command into list
try:
cmd = utils.split(str(cmdString))
@@ -122,8 +120,6 @@
self.promptRunCmd.emit(cmd=cmd)
- # add command to history & clean prompt
- # self.UpdateCmdHistory(cmd)
self.OnCmdErase(None)
self.ShowStatusText('')
@@ -300,6 +296,8 @@
self.cmdbuffer.append(cmd)
+ # update also traced commands
+ self.commands.append(cmd)
# keep command history to a managable size
if len(self.cmdbuffer) > 200:
