[GRASS-SVN] r73446 - grass-addons/grass7/vector/v.gsflow.grid
svn_grass at osgeo.org
Fri Sep 28 06:53:50 PDT 2018
Author: awickert
Date: 2018-09-28 06:53:50 -0700 (Fri, 28 Sep 2018)
New Revision: 73446
grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py
v.gsflow.grid: b.c. cell - resample to coarse res w/ minimum cell elevation before r.drain
Modified: grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py
--- grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py 2018-09-27 21:07:04 UTC (rev 73445)
+++ grass-addons/grass7/vector/v.gsflow.grid/v.gsflow.grid.py 2018-09-28 13:53:50 UTC (rev 73446)
@@ -131,6 +131,7 @@
gscript.fatal('Mask and pour point must be set to define b.c. cell')
# Create grid -- overlaps DEM, three cells of padding
+ g.region(raster=raster_input, ewres=dx, nsres=dy)
gscript.use_temp_region()
reg = gscript.region()
reg_grid_edges_sn = np.linspace(reg['s'], reg['n'], reg['rows'])
@@ -159,7 +160,7 @@
# Finally make the region
g.region(w=str(_w), e=str(_e), s=str(_s), n=str(_n), nsres=str(grid_ratio_ns*reg['nsres']), ewres=str(grid_ratio_ew*reg['ewres']))
# And then make the grid
- v.mkgrid(map=grid, overwrite=gscript.overwrite())
+ v.mkgrid(map=grid, overwrite=gscript.overwrite)
# Cell numbers (row, column, continuous ID)
v.db_addcolumn(map=grid, columns='id int', quiet=True)
@@ -191,7 +192,7 @@
# Fine resolution region:
g.region(n=reg['n'], s=reg['s'], w=reg['w'], e=reg['e'], nsres=reg['nsres'], ewres=reg['ewres'])
# Rasterize basin
- v.to_rast(input=basin, output=mask, use='val', value=1, overwrite=gscript.overwrite(), quiet=True)
+ v.to_rast(input=basin, output=mask, use='val', value=1, overwrite=gscript.overwrite, quiet=True)
# Coarse resolution region:
r.resamp_stats(input=mask, output=mask, method='sum', overwrite=True, quiet=True)
@@ -205,7 +206,7 @@
# Resampled raster
if len(raster_output) > 0:
- r.resamp_stats(input=raster_input, output=raster_output, method='average', overwrite=gscript.overwrite(), quiet=True)
+ r.resamp_stats(input=raster_input, output=raster_output, method='average', overwrite=gscript.overwrite, quiet=True)
# Pour point
@@ -218,6 +219,9 @@
# Next point downstream of the pour point
# Requires pp (always) and mask (sometimes)
# Dependency set above w/ gscript.fatal
+ #g.region(raster='DEM')
+ #dx = gscript.region()['ewres']
+ #dy = gscript.region()['nsres']
if len(bc_cell) > 0:
########## NEED TO USE TRUE TEMPORARY FILE ##########
# May not work with dx != dy!
@@ -224,16 +228,21 @@
v.to_rast(input=pp, output='tmp', use='val', value=1, overwrite=True)
r.buffer(input='tmp', output='tmp', distances=float(dx)*1.5, overwrite=True)
r.mapcalc('tmp2 = if(tmp==2,1,null()) * '+raster_input, overwrite=True)
- g.rename(raster=('tmp2','tmp'), overwrite=True, quiet=True)
#r.mapcalc('tmp = if(isnull('+raster_input+',0,(tmp == 2)))', overwrite=True)
#g.region(rast='tmp')
#r.null(map=raster_input,
- r.drain(input=raster_input, start_points=pp, output='tmp2', overwrite=True)
+ #g.region(raster=raster_input)
+ #r.resample(input=raster_input, output='tmp3', overwrite=True)
+ r.resamp_stats(input=raster_input, output='tmp3', method='minimum', overwrite=True)
+ r.drain(input='tmp3', start_points=pp, output='tmp', overwrite=True)
+ #g.region(w=str(_w), e=str(_e), s=str(_s), n=str(_n), nsres=str(grid_ratio_ns*reg['nsres']), ewres=str(grid_ratio_ew*reg['ewres']))
+ #r.resamp_stats(input='tmp2', output='tmp3', overwrite=True)
+ #g.rename(raster=('tmp3','tmp2'), overwrite=True, quiet=True)
r.mapcalc('tmp3 = tmp2 * tmp', overwrite=True, quiet=True)
g.rename(raster=('tmp3','tmp'), overwrite=True, quiet=True)
#r.null(map='tmp', setnull=0) # Not necessary: center point removed above
r.to_vect(input='tmp', output=bc_cell, type='point', column='z',
- overwrite=gscript.overwrite(), quiet=True)
+ overwrite=gscript.overwrite, quiet=True)
v.db_addcolumn(map=bc_cell, columns=('row integer','col integer','x double precision','y double precision'), quiet=True)
v.build(map=bc_cell, quiet=True)
v.what_vect(map=bc_cell, query_map=grid, column='row', \
@@ -240,8 +249,13 @@
query_column='row', quiet=True)
v.what_vect(map=bc_cell, query_map=grid, column='col', \
query_column='col', quiet=True)
- v.to_db(map=bc_cell, option='coor', columns=('x,y'))
+ v.to_db(map=bc_cell, option='coor', columns=('x,y'))
+ # Of the candidates, the pour point is the closest one
+ #v.db_addcolumn(map=bc_cell, columns=('dist_to_pp double precision'), quiet=True)
+ #v.distance(from_=bc_cell, to=pp, upload='dist', column='dist_to_pp')
# Find out if this is diagonal: finite difference works only N-S, W-E
colNames = np.array(gscript.vector_db_select(pp, layer=1)['columns'])
colValues = np.array(gscript.vector_db_select(pp, layer=1)['values'].values())
@@ -275,8 +289,8 @@
# maybe just try setting both and seeing what happens for now!
else:
# Get dx and dy
- dx = gscript.region()['ewres']
- dy = gscript.region()['nsres']
# Build tool to handle multiple b.c. cells?
bcvect = vector.Vector(bc_cell)
bcvect.open('rw')
