[GRASS-SVN] r73462 - grass/branches/releasebranch_7_6/scripts/v.rast.stats
svn_grass at osgeo.org
Sat Sep 29 12:33:40 PDT 2018
Author: sbl
Date: 2018-09-29 12:33:40 -0700 (Sat, 29 Sep 2018)
New Revision: 73462
grass/branches/releasebranch_7_6/scripts/v.rast.stats/v.rast.stats.py
apply multiraster patch; fix #3523
Modified: grass/branches/releasebranch_7_6/scripts/v.rast.stats/v.rast.stats.py
--- grass/branches/releasebranch_7_6/scripts/v.rast.stats/v.rast.stats.py 2018-09-29 19:31:54 UTC (rev 73461)
+++ grass/branches/releasebranch_7_6/scripts/v.rast.stats/v.rast.stats.py 2018-09-29 19:33:40 UTC (rev 73462)
@@ -40,7 +40,7 @@
#%end
#%option G_OPT_V_FIELD
#%end
-#%option G_OPT_R_INPUT
+#%option G_OPT_R_INPUTS
#% key: raster
#% description: Name of input raster map to calculate statistics from
#%end
@@ -49,6 +49,7 @@
#% type: string
#% description: Column prefix for new attribute columns
#% required : yes
+#% multiple: yes
#%end
#%option
#% key: method
@@ -98,8 +99,8 @@
nuldev = file(os.devnull, 'w')
- raster = options['raster']
- colprefix = options['column_prefix']
+ rasters = options['raster'].split(',')
+ colprefixes = options['column_prefix'].split(',')
vector = options['map']
layer = options['layer']
percentile = options['percentile']
@@ -128,13 +129,20 @@
# we need this for non-DBF driver:
dbfdriver = fi['driver'] == 'dbf'
+ # colprefix for every raster map?
+ if len(colprefixes) != len(rasters):
+ grass.fatal(_("Number of raster maps ({0}) different from \
+ number of column prefixes ({1})". format(len(rasters),
+ len(colprefixes))))
vector = vs[0]
rastertmp = "%s_%s" % (vector, tmpname)
- # check the input raster map
- if not grass.find_file(raster, 'cell')['file']:
- grass.fatal(_("Raster map <%s> not found") % raster)
+ for raster in rasters:
+ # check the input raster map
+ if not grass.find_file(raster, 'cell')['file']:
+ grass.fatal(_("Raster map <%s> not found") % raster)
# save current settings:
grass.use_temp_region()
@@ -141,7 +149,7 @@
# Temporarily aligning region resolution to $RASTER resolution
# keep boundary settings
- grass.run_command('g.region', align=raster)
+ grass.run_command('g.region', align=rasters[0])
# prepare base raster for zonal statistics
try:
@@ -168,6 +176,29 @@
if number < 1:
grass.fatal(_("No categories found in raster map"))
+ # Check if all categories got converted
+ # Report categories from vector map
+ vect_cats = grass.read_command('v.category', input=vector, option='report',
+ flags='g').rstrip('\n').split('\n')
+ # get number of all categories in selected layer
+ for vcl in vect_cats:
+ if vcl.split(' ')[0] == layer and vcl.split(' ')[1] == 'all':
+ vect_cats_n = int(vcl.split(' ')[2])
+ if vect_cats_n != number:
+ grass.warning(_("Not all vector categories converted to raster. \
+ Converted {0} of {1}.".format(number, vect_cats_n)))
+ # check if DBF driver used, in this case cut to 10 chars col names:
+ try:
+ fi = grass.vector_db(map=vector)[int(layer)]
+ except KeyError:
+ grass.fatal(
+ _('There is no table connected to this map. Run v.db.connect or v.db.addtable first.'))
+ # we need this for non-DBF driver:
+ dbfdriver = fi['driver'] == 'dbf'
# Find out which table is linked to the vector map on the given layer
if not fi['table']:
grass.fatal(
@@ -176,132 +207,135 @@
# replaced by user choiche
#basecols = ['n', 'min', 'max', 'range', 'mean', 'stddev', 'variance', 'cf_var', 'sum']
- # we need at least three chars to distinguish [mea]n from [med]ian
- # so colprefix can't be longer than 6 chars with DBF driver
- if dbfdriver:
- colprefix = colprefix[:6]
- variables_dbf = {}
- # by default perccol variable is used only for "variables" variable
- perccol = "percentile"
- perc = None
- for b in basecols:
- if b.startswith('p'):
- perc = b
- if perc:
- # namespace is limited in DBF but the % value is important
+ for i in xrange(len(rasters)):
+ raster = rasters[i]
+ colprefix = colprefixes[i]
+ # we need at least three chars to distinguish [mea]n from [med]ian
+ # so colprefix can't be longer than 6 chars with DBF driver
if dbfdriver:
- perccol = "per" + percentile
- else:
- perccol = "percentile_" + percentile
- percindex = basecols.index(perc)
- basecols[percindex] = perccol
+ colprefix = colprefix[:6]
+ variables_dbf = {}
- # dictionary with name of methods and position in "r.univar -gt" output
- variables = {'number': 2, 'null_cells': 3, 'minimum': 4, 'maximum': 5, 'range': 6,
- 'average': 7, 'stddev': 9, 'variance': 10, 'coeff_var': 11,
- 'sum': 12, 'first_quartile': 14, 'median': 15,
- 'third_quartile': 16, perccol: 17}
- # this list is used to set the 'e' flag for r.univar
- extracols = ['first_quartile', 'median', 'third_quartile', perccol]
- addcols = []
- colnames = []
- extstat = ""
- for i in basecols:
- # this check the complete name of out input that should be truncated
- for k in variables.keys():
- if i in k:
- i = k
- break
- if i in extracols:
- extstat = 'e'
- # check if column already present
- currcolumn = ("%s_%s" % (colprefix, i))
- if dbfdriver:
- currcolumn = currcolumn[:10]
- variables_dbf[currcolumn.replace("%s_" % colprefix, '')] = i
+ # by default perccol variable is used only for "variables" variable
+ perccol = "percentile"
+ perc = None
+ for b in basecols:
+ if b.startswith('p'):
+ perc = b
+ if perc:
+ # namespace is limited in DBF but the % value is important
+ if dbfdriver:
+ perccol = "per" + percentile
+ else:
+ perccol = "percentile_" + percentile
+ percindex = basecols.index(perc)
+ basecols[percindex] = perccol
- colnames.append(currcolumn)
- if currcolumn in grass.vector_columns(vector, layer).keys():
- if not flags['c']:
- grass.fatal((_("Cannot create column <%s> (already present). ") % currcolumn) +
- _("Use -c flag to update values in this column."))
- else:
- if i == "n":
- coltype = "INTEGER"
+ # dictionary with name of methods and position in "r.univar -gt" output
+ variables = {'number': 2, 'null_cells': 2, 'minimum': 4, 'maximum': 5, 'range': 6,
+ 'average': 7, 'stddev': 9, 'variance': 10, 'coeff_var': 11,
+ 'sum': 12, 'first_quartile': 14, 'median': 15,
+ 'third_quartile': 16, perccol: 17}
+ # this list is used to set the 'e' flag for r.univar
+ extracols = ['first_quartile', 'median', 'third_quartile', perccol]
+ addcols = []
+ colnames = []
+ extstat = ""
+ for i in basecols:
+ # this check the complete name of out input that should be truncated
+ for k in variables.keys():
+ if i in k:
+ i = k
+ break
+ if i in extracols:
+ extstat = 'e'
+ # check if column already present
+ currcolumn = ("%s_%s" % (colprefix, i))
+ if dbfdriver:
+ currcolumn = currcolumn[:10]
+ variables_dbf[currcolumn.replace("%s_" % colprefix, '')] = i
+ colnames.append(currcolumn)
+ if currcolumn in grass.vector_columns(vector, layer).keys():
+ if not flags['c']:
+ grass.fatal((_("Cannot create column <%s> (already present). ") % currcolumn) +
+ _("Use -c flag to update values in this column."))
else:
- coltype = "DOUBLE PRECISION"
- addcols.append(currcolumn + ' ' + coltype)
+ if i == "n":
+ coltype = "INTEGER"
+ else:
+ coltype = "DOUBLE PRECISION"
+ addcols.append(currcolumn + ' ' + coltype)
- if addcols:
- grass.verbose(_("Adding columns '%s'") % addcols)
- try:
- grass.run_command('v.db.addcolumn', map=vector, columns=addcols,
- layer=layer)
- except CalledModuleError:
- grass.fatal(_("Adding columns failed. Exiting."))
+ if addcols:
+ grass.verbose(_("Adding columns '%s'") % addcols)
+ try:
+ grass.run_command('v.db.addcolumn', map=vector, columns=addcols,
+ layer=layer)
+ except CalledModuleError:
+ grass.fatal(_("Adding columns failed. Exiting."))
- # calculate statistics:
- grass.message(_("Processing input data (%d categories)...") % number)
+ # calculate statistics:
+ grass.message(_("Processing input data (%d categories)...") % number)
- # get rid of any earlier attempts
- grass.try_remove(sqltmp)
+ # get rid of any earlier attempts
+ grass.try_remove(sqltmp)
- f = file(sqltmp, 'w')
+ f = file(sqltmp, 'w')
- # do the stats
- p = grass.pipe_command('r.univar', flags='t' + extstat, map=raster,
- zones=rastertmp, percentile=percentile, sep=';')
+ # do the stats
+ p = grass.pipe_command('r.univar', flags='t' + extstat, map=raster,
+ zones=rastertmp, percentile=percentile, sep=';')
- first_line = 1
+ first_line = 1
- f.write("{0}\n".format(grass.db_begin_transaction(fi['driver'])))
- for line in p.stdout:
- if first_line:
- first_line = 0
- continue
+ f.write("{0}\n".format(grass.db_begin_transaction(fi['driver'])))
+ for line in p.stdout:
+ if first_line:
+ first_line = 0
+ continue
- vars = line.rstrip('\r\n').split(';')
+ vars = line.rstrip('\r\n').split(';')
- f.write("UPDATE %s SET" % fi['table'])
- first_var = 1
- for colname in colnames:
- variable = colname.replace("%s_" % colprefix, '', 1)
- if dbfdriver:
- variable = variables_dbf[variable]
- i = variables[variable]
- value = vars[i]
- # convert nan, +nan, -nan, inf, +inf, -inf, Infinity, +Infinity,
- # -Infinity to NULL
- if value.lower().endswith('nan') or 'inf' in value.lower():
- value = 'NULL'
- if not first_var:
- f.write(" , ")
- else:
- first_var = 0
- f.write(" %s=%s" % (colname, value))
+ f.write("UPDATE %s SET" % fi['table'])
+ first_var = 1
+ for colname in colnames:
+ variable = colname.replace("%s_" % colprefix, '', 1)
+ if dbfdriver:
+ variable = variables_dbf[variable]
+ i = variables[variable]
+ value = vars[i]
+ # convert nan, +nan, -nan, inf, +inf, -inf, Infinity, +Infinity,
+ # -Infinity to NULL
+ if value.lower().endswith('nan') or 'inf' in value.lower():
+ value = 'NULL'
+ if not first_var:
+ f.write(" , ")
+ else:
+ first_var = 0
+ f.write(" %s=%s" % (colname, value))
- f.write(" WHERE %s=%s;\n" % (fi['key'], vars[0]))
- f.write("{0}\n".format(grass.db_commit_transaction(fi['driver'])))
- p.wait()
- f.close()
+ f.write(" WHERE %s=%s;\n" % (fi['key'], vars[0]))
+ f.write("{0}\n".format(grass.db_commit_transaction(fi['driver'])))
+ p.wait()
+ f.close()
- grass.message(_("Updating the database ..."))
- exitcode = 0
- try:
- grass.run_command('db.execute', input=sqltmp,
- database=fi['database'], driver=fi['driver'])
- grass.verbose((_("Statistics calculated from raster map <{raster}>"
- " and uploaded to attribute table"
- " of vector map <{vector}>."
- ).format(raster=raster, vector=vector)))
- grass.warning(
- _("Failed to upload statistics to attribute table of vector map <%s>.") %
- vector)
- exitcode = 1
+ grass.message(_("Updating the database ..."))
+ exitcode = 0
+ try:
+ grass.run_command('db.execute', input=sqltmp,
+ database=fi['database'], driver=fi['driver'])
+ grass.verbose((_("Statistics calculated from raster map <{raster}>"
+ " and uploaded to attribute table"
+ " of vector map <{vector}>."
+ ).format(raster=raster, vector=vector)))
+ grass.warning(
+ _("Failed to upload statistics to attribute table of vector map <%s>.") %
+ vector)
+ exitcode = 1
- sys.exit(exitcode)
+ sys.exit(exitcode)
if __name__ == "__main__":
options, flags = grass.parser()
