[GRASS-SVN] r74342 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Thu Apr 4 02:54:28 PDT 2019
Author: mmetz
Date: 2019-04-04 02:54:28 -0700 (Thu, 04 Apr 2019)
New Revision: 74342
grass/trunk/lib/python/script/raster.py
libpython: + option to overwrite history with raster_history()
Modified: grass/trunk/lib/python/script/raster.py
--- grass/trunk/lib/python/script/raster.py 2019-04-03 21:45:26 UTC (rev 74341)
+++ grass/trunk/lib/python/script/raster.py 2019-04-04 09:54:28 UTC (rev 74342)
@@ -26,7 +26,7 @@
from .core import *
from grass.exceptions import CalledModuleError
-from .utils import float_or_dms, parse_key_val
+from .utils import float_or_dms, parse_key_val, try_remove
if sys.version_info.major == 3:
@@ -33,7 +33,7 @@
unicode = str
-def raster_history(map):
+def raster_history(map, overwrite=False):
"""Set the command history for a raster map to the command used to
invoke the script (interface to `r.support`).
@@ -45,7 +45,15 @@
current_mapset = gisenv()['MAPSET']
if find_file(name=map)['mapset'] == current_mapset:
- run_command('r.support', map=map, history=os.environ['CMDLINE'])
+ if overwrite == True:
+ historyfile = tempfile()
+ f = open(historyfile, 'w')
+ f.write(os.environ['CMDLINE'])
+ f.close()
+ run_command('r.support', map=map, loadhistory=historyfile)
+ try_remove(historyfile)
+ else:
+ run_command('r.support', map=map, history=os.environ['CMDLINE'])
return True
warning(_("Unable to write history for <%(map)s>. "
