[GRASS-SVN] r74365 - grass/branches/releasebranch_7_6/raster/r.watershed/front
Wed Apr 10 06:55:24 PDT 2019
Author: martinl
Date: 2019-04-10 06:55:24 -0700 (Wed, 10 Apr 2019)
New Revision: 74365
Added:
   grass/branches/releasebranch_7_6/raster/r.watershed/front/r_watershed_drainage.png
   grass/branches/releasebranch_7_6/raster/r.watershed/front/r.watershed.html
r.watershed: add drainage fig (merge r74364 from trunk)
Modified: grass/branches/releasebranch_7_6/raster/r.watershed/front/r.watershed.html
--- grass/branches/releasebranch_7_6/raster/r.watershed/front/r.watershed.html	2019-04-10 13:54:23 UTC (rev 74364)
+++ grass/branches/releasebranch_7_6/raster/r.watershed/front/r.watershed.html	2019-04-10 13:55:24 UTC (rev 74365)
@@ -144,6 +144,16 @@
 <p>
 Output <b>drainage</b> raster map contains drainage direction.
 Provides the "aspect" for each cell measured CCW from East.
+<div align="center" style="margin: 10px">
+<a href="r_watershed_drainage.png">
+<img src="r_watershed_drainage.png" width="116" height="89" alt="drainage" border="0">
+</a><br>
+<i>Figure: Drainage is 8 directions numbered counter-clockwise
+starting from 1 in north-east direction
+(<a href="https://idea.isnew.info/how-to-import-arcgis-flow-direction-into-grass-gis.html">source</a>)</i>
+</div>
 Multiplying positive values by 45 will give the direction in degrees
 that the surface runoff will travel from that cell.  The value 0
 (zero) indicates that the cell is a depression area (defined by the
Copied: grass/branches/releasebranch_7_6/raster/r.watershed/front/r_watershed_drainage.png (from rev 74364, grass/trunk/raster/r.watershed/front/r_watershed_drainage.png)
(Binary files differ)
