[GRASS-SVN] r74373 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Sat Apr 13 12:42:00 PDT 2019
Author: mmetz
Date: 2019-04-13 12:41:59 -0700 (Sat, 13 Apr 2019)
New Revision: 74373
grass/trunk/raster/r.in.gdal/main.c
r.in.gdal: +info on subdatasets, see #798
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2019-04-11 17:49:07 UTC (rev 74372)
+++ grass/trunk/raster/r.in.gdal/main.c 2019-04-13 19:41:59 UTC (rev 74373)
@@ -50,6 +50,36 @@
static void error_handler_ds(void *p);
static int l1bdriver;
+static GDALDatasetH opends(char *dsname, const char **doo, GDALDriverH *hDriver)
+ GDALDatasetH hDS = NULL;
+#if GDAL_VERSION_NUM >= 2000000
+ hDS = GDALOpenEx(dsname, GDAL_OF_RASTER | GDAL_OF_READONLY, NULL,
+ doo, NULL);
+#else
+ hDS = GDALOpen(dsname, GA_ReadOnly);
+#endif
+ if (hDS == NULL)
+ G_fatal_error(_("Unable to open datasource <%s>"), dsname);
+ G_add_error_handler(error_handler_ds, hDS);
+ *hDriver = GDALGetDatasetDriver(hDS); /* needed for AVHRR data */
+ /* L1B - NOAA/AVHRR data must be treated differently */
+ /* for hDriver names see gdal/frmts/gdalallregister.cpp */
+ G_debug(3, "GDAL Driver: %s", GDALGetDriverShortName(*hDriver));
+ if (strcmp(GDALGetDriverShortName(*hDriver), "L1B") != 0)
+ l1bdriver = 0;
+ else {
+ l1bdriver = 1; /* AVHRR found, needs north south flip */
+ G_warning(_("Input seems to be NOAA/AVHRR data which needs to be "
+ "georeferenced with thin plate spline transformation "
+ "(%s or %s)."), "i.rectify -t", "gdalwarp -tps");
+ return hDS;
/* main() */
@@ -407,28 +437,7 @@
/* Open the dataset. */
-#if GDAL_VERSION_NUM >= 2000000
- hDS = GDALOpenEx(input, GDAL_OF_RASTER | GDAL_OF_READONLY, NULL,
- (const char **) doo, NULL);
-#else
- hDS = GDALOpen(input, GA_ReadOnly);
-#endif
- if (hDS == NULL)
- G_fatal_error(_("Unable to open datasource <%s>"), input);
- G_add_error_handler(error_handler_ds, hDS);
- hDriver = GDALGetDatasetDriver(hDS); /* needed for AVHRR data */
- /* L1B - NOAA/AVHRR data must be treated differently */
- /* for hDriver names see gdal/frmts/gdalallregister.cpp */
- G_debug(3, "GDAL Driver: %s", GDALGetDriverShortName(hDriver));
- if (strcmp(GDALGetDriverShortName(hDriver), "L1B") != 0)
- l1bdriver = 0;
- else {
- l1bdriver = 1; /* AVHRR found, needs north south flip */
- G_warning(_("Input seems to be NOAA/AVHRR data which needs to be "
- "georeferenced with thin plate spline transformation "
- "(%s or %s)."), "i.rectify -t", "gdalwarp -tps");
+ hDS = opends(input, (const char **)doo, &hDriver);
/* does the driver support subdatasets? */
/* test for capability GDAL_DMD_SUBDATASETS */
@@ -438,12 +447,79 @@
char **sds = GDALGetMetadata(hDS, "SUBDATASETS");
if (sds && *sds) {
+ int i;
G_warning(_("Input contains subdatasets which may need to "
- "be imported separately"));
- /* list subdatasets? */
+ "be imported separately by name:"));
+ /* list subdatasets */
+ for (i = 0; sds[i] != NULL; i++) {
+ char *sdsi = G_store(sds[i]);
+ char *p = sdsi;
+ while (*p != '=' && *p != '\0')
+ p++;
+ if (*p == '=')
+ p++;
+ if ((i & 1) == 0) {
+ fprintf(stderr, "Subdataset %d:\n", i + 1);
+ fprintf(stderr, " Name: %s\n", p);
+ else {
+ char *sdsdim, *sdsdesc, *sdstype;
+ int sdsdlen;
+ sdsdim = sdsdesc = sdstype = NULL;
+ sdsdlen = strlen(sdsi);
+ while (*p != '[' && *p != '\0')
+ p++;
+ if (*p == '[') {
+ p++;
+ sdsdim = p;
+ while (*p != ']' && *p != '\0')
+ p++;
+ if (*p == ']') {
+ *p = '\0';
+ p++;
+ while (*p == ' ' && *p != '\0')
+ p++;
+ sdsdesc = p;
+ if (*p != '\0') {
+ p = sdsi + sdsdlen - 1;
+ if (*p == ')') {
+ *p = '\0';
+ p--;
+ while (*p != '(')
+ p--;
+ if (*p == '(') {
+ sdstype = p + 1;
+ p--;
+ while (*p == ' ')
+ p--;
+ p++;
+ if (*p == ' ')
+ *p = '\0';
+ if (sdsdesc && *sdsdesc)
+ fprintf(stderr, " Description: %s\n", sdsdesc);
+ if (sdsdim && *sdsdim)
+ fprintf(stderr, " Dimension: %s\n", sdsdim);
+ if (sdstype && *sdstype)
+ fprintf(stderr, " Data type: %s\n", sdstype);
+ G_free(sdsi);
+ if (GDALGetRasterCount(hDS) == 0) {
+ G_fatal_error(_("No raster bands found in <%s>"), input);
if (flag_p->answer) {
/* print number of bands */
fprintf(stdout, "%d\n", GDALGetRasterCount(hDS));
@@ -477,9 +553,14 @@
if (GDALGetGeoTransform(hDS, adfGeoTransform) == CE_None) {
if (adfGeoTransform[2] != 0.0 || adfGeoTransform[4] != 0.0 ||
- adfGeoTransform[1] <= 0.0 || adfGeoTransform[5] >= 0.0)
+ adfGeoTransform[1] <= 0.0 || adfGeoTransform[5] >= 0.0) {
+ G_debug(0, "adfGeoTransform[2] %g", adfGeoTransform[2]);
+ G_debug(0, "adfGeoTransform[4] %g", adfGeoTransform[4]);
+ G_debug(0, "adfGeoTransform[1] %g", adfGeoTransform[1]);
+ G_debug(0, "adfGeoTransform[5] %g", adfGeoTransform[5]);
G_fatal_error(_("Input raster map is flipped or rotated - cannot import. "
"You may use 'gdalwarp' to transform the map to North-up."));
cellhd.north = adfGeoTransform[3];
cellhd.ns_res = fabs(adfGeoTransform[5]);
cellhd.ns_res3 = fabs(adfGeoTransform[5]);
@@ -676,7 +757,7 @@
else {
struct Ref ref;
- char szBandName[512];
+ char szBandName[1024];
int nBand = 0;
char colornamebuf[512], colornamebuf2[512];
FILE *map_names_file = NULL;
@@ -965,7 +1046,7 @@
struct Cell_head cellhd;
struct Key_Value *proj_info = NULL, *proj_units = NULL;
- char errbuf[256];
+ char errbuf[1024];
int permissions;
char target_mapset[GMAPSET_MAX];
struct Key_Value *out_proj_info, /* projection information of */
