[GRASS-SVN] r74395 - grass/trunk/scripts/g.search.modules
Thu Apr 18 01:23:24 PDT 2019
Author: neteler
Date: 2019-04-18 01:23:24 -0700 (Thu, 18 Apr 2019)
New Revision: 74395
   grass/trunk/scripts/g.search.modules/g.search.modules.py
g.search.modules: include system wide addons in search (contributed by AnikaBettge)
Modified: grass/trunk/scripts/g.search.modules/g.search.modules.py
--- grass/trunk/scripts/g.search.modules/g.search.modules.py	2019-04-18 07:25:30 UTC (rev 74394)
+++ grass/trunk/scripts/g.search.modules/g.search.modules.py	2019-04-18 08:23:24 UTC (rev 74395)
@@ -4,7 +4,7 @@
 # MODULE:	g.search.modules
 # AUTHOR(S):	Jachym Cepicky <jachym.cepicky gmail.com>
 # PURPOSE:	g.search.modules in grass modules using keywords
-# COPYRIGHT:	(C) 2015-2016 by the GRASS Development Team
+# COPYRIGHT:	(C) 2015-2019 by the GRASS Development Team
 #		This program is free software under the GNU General
 #		Public License (>=v2). Read the file COPYING that
@@ -202,12 +202,22 @@
     # add installed addons to modules list
     if os.getenv("GRASS_ADDON_BASE"):
         filename_addons = os.path.join(os.getenv("GRASS_ADDON_BASE"), 'modules.xml')
-        addon_menudata_file = open(filename_addons, 'r')
-        addon_menudata = etree.parse(addon_menudata_file)
-        addon_menudata_file.close()
-        addon_items = addon_menudata.findall('task')
-        items.extend(addon_items)
+        if os.path.isfile(filename_addons):
+            addon_menudata_file = open(filename_addons, 'r')
+            addon_menudata = etree.parse(addon_menudata_file)
+            addon_menudata_file.close()
+            addon_items = addon_menudata.findall('task')
+            items.extend(addon_items)
+    # add system-wide installed addons to modules list
+    filename_addons_s = os.path.join(os.getenv("GISBASE"), 'modules.xml')
+    if os.path.isfile(filename_addons_s):
+        addon_menudata_file_s = open(filename_addons_s, 'r')
+        addon_menudata_s = etree.parse(addon_menudata_file_s)
+        addon_menudata_file_s.close()
+        addon_items_s = addon_menudata_s.findall('task')
+        items.extend(addon_items_s)
     found_modules = []
     for item in items:
         name = item.attrib['name']
@@ -228,7 +238,10 @@
                 keyword_found = _basic_search(keyword, name, description,
                                               module_keywords)
-            if not keyword_found and manpages:
+            # meta-modules (i.sentinel, r.modis, ...) do not have descriptions
+            # and keywords, but they have a manpage
+            # TODO change the handling of meta-modules
+            if (description and module_keywords) and not keyword_found and manpages:
                 keyword_found = _manpage_search(keyword, name)
             if keyword_found:
@@ -295,7 +308,6 @@
     return manpage.lower().find(pattern) > -1
 if __name__ == "__main__":
     options, flags = grass.parser()
     sys.exit(main())
