[GRASS-SVN] r74400 - grass/trunk/raster/r.random/testsuite
Thu Apr 18 12:29:30 PDT 2019
Author: neteler
Date: 2019-04-18 12:29:30 -0700 (Thu, 18 Apr 2019)
New Revision: 74400
Added:
   grass/trunk/raster/r.random/testsuite/test_r_random.py
Removed:
   grass/trunk/raster/r.random/testsuite/test_r.random.py
testsuite: convert the following test to a proper python module name (fixes #3792)
Deleted: grass/trunk/raster/r.random/testsuite/test_r.random.py
--- grass/trunk/raster/r.random/testsuite/test_r.random.py	2019-04-18 12:54:40 UTC (rev 74399)
+++ grass/trunk/raster/r.random/testsuite/test_r.random.py	2019-04-18 19:29:30 UTC (rev 74400)
@@ -1,117 +0,0 @@
-Name:        r.random test
-Purpose:    Tests r.random module and some of its options.
-Author:     Shubham Sharma, Google Code-in 2018
-Copyright:  (C) 2018 by Shubham Sharma and the GRASS Development Team
-Licence:    This program is free software under the GNU General Public
-            License (>=v2). Read the file COPYING that comes with GRASS
-            for details.
-from grass.gunittest.case import TestCase
-from grass.gunittest.main import test
-class TestRasterTile(TestCase):
-    input = 'landcover_1m'
-    npoints = '20'
-    raster = 'landcover_1m_raster_random'
-    vector = "landcover_1m_vector_random"
-    @classmethod
-    def setUpClass(cls):
-        cls.use_temp_region()
-        cls.runModule('g.region', raster=cls.input)
-    @classmethod
-    def tearDownClass(cls):
-        cls.del_temp_region()
-        cls.runModule('g.remove', type='raster', flags='f', name=cls.raster)
-        cls.runModule('g.remove', type='raster', flags='f', name=cls.raster + '_null')
-        cls.runModule('g.remove', type='raster', flags='f', name=cls.raster + '_without_topology')
-        cls.runModule('g.remove', type='raster', flags='f', name=cls.raster + '_3D')
-        cls.runModule('g.remove', type='raster', flags='f', name=cls.raster + '_cover_landcover_1m')
-        cls.runModule('g.remove', type='vector', flags='f', name=cls.vector)
-        cls.runModule('g.remove', type='vector', flags='f', name=cls.vector+'_null')
-        cls.runModule('g.remove', type='vector', flags='f', name=cls.vector + '_without_topology')
-        cls.runModule('g.remove', type='vector', flags='f', name=cls.vector + '_3D')
-        cls.runModule('g.remove', type='vector', flags='f', name=cls.vector + '_cover_landcover_1m')
-    def test_random_raster(self):
-        """Testing r.random  runs successfully"""
-        self.assertModule('r.random', input=self.input, npoints=self.npoints, raster=self.raster)
-        # check if random raster was created
-        self.assertRasterExists(self.raster, msg="landcover_1m_raster_random was not created")
-    def test_random_vector(self):
-        self.assertModule('r.random', input=self.input, npoints=self.npoints, vector=self.vector)
-        # check if random vector was created
-        self.assertVectorExists(self.vector, msg="landcover_1m_vector_random was not created")
-        topology = dict(points=20,primitives=20)
-        self.assertVectorFitsTopoInfo(vector=self.vector, reference=topology)
-    def test_random_raster_flag_z(self):
-        self.assertModule('r.random', flags='z', input=self.input, npoints=self.npoints, raster=self.raster+'_null')
-        # check if random raster ( with NULL values )  was created
-        self.assertRasterExists(self.raster, msg="landcover_1m_raster_random_null was not created")
-    def test_vector_random_flag_z(self):
-        self.assertModule('r.random', flags='z', input=self.input, npoints=self.npoints, vector=self.vector+'_null')
-        # check if random vector ( with NULL values ) was created
-        self.assertVectorExists(self.vector+'_null', msg="landcover_1m_vector_random_null was not created")
-        self.assertVectorFitsTopoInfo(vector=self.vector+'_null', reference=topology)
-    def test_random_raster_flag_b(self):
-        self.assertModule('r.random', flags='b', input=self.input, npoints=self.npoints, raster=self.raster+'_without_topology')
-        # check if random raster ( without topology )  was created
-        self.assertRasterExists(self.raster, msg="landcover_1m_raster_random_without_topologywas not created")
-    def test_vector_random_flag_b(self):
-        self.assertModule('r.random', flags='b', input=self.input, npoints=self.npoints, vector=self.vector+'_without_topology')
-        # check if random vector ( without topology ) was created
-        self.assertVectorExists(self.vector+'_without_topology', msg="landcover_1m_vector_random_without_topology was not created")
-        self.assertVectorFitsTopoInfo(vector=self.vector+'_without_topology', reference=topology)
-    def test_random_raster_flag_d(self):
-        self.assertModule('r.random', flags='d', input=self.input, npoints=self.npoints, raster=self.raster+'_3D')
-        # check if random raster ( 3D points )  was created
-        self.assertRasterExists(self.raster, msg="landcover_1m_raster_random_3D not created")
-    def test_vector_random_flag_d(self):
-        self.assertModule('r.random', flags='d', input=self.input, npoints=self.npoints, vector=self.vector+'_3D')
-        # check if random vector ( 3D points ) was created
-        self.assertVectorExists(self.vector+'_3D', msg="landcover_1m_vector_random_3D was not created")
-        self.assertVectorFitsTopoInfo(vector=self.vector+'_3D', reference=topology)
-    def test_random_raster_cover(self):
-        self.assertModule('r.random',input='landuse96_28m', npoints=self.npoints, cover='landcover_1m', raster=self.raster+'_cover_landcover_1m')
-        self.assertRasterExists(self.raster+'_cover_landcover_1m', msg="landcover_1m_raster_random_cover_landcover_1m was not created")
-        self.assertModule('r.random',input='landuse96_28m', npoints=self.npoints, cover='landcover_1m', vector=self.vector+'_cover_landcover_1m')
-        self.assertVectorExists(self.vector+'_cover_landcover_1m', msg="landcover_1m_vector_cover_landcover_1m was not created")
-        topology = dict(points=20, primitives=20)
-        self.assertVectorFitsTopoInfo(vector=self.vector+'_cover_landcover_1m', reference=topology)
-if __name__ == '__main__':
-    test()
Copied: grass/trunk/raster/r.random/testsuite/test_r_random.py (from rev 74399, grass/trunk/raster/r.random/testsuite/test_r.random.py)
--- grass/trunk/raster/r.random/testsuite/test_r_random.py	                        (rev 0)
+++ grass/trunk/raster/r.random/testsuite/test_r_random.py	2019-04-18 19:29:30 UTC (rev 74400)
@@ -0,0 +1,117 @@
+Name:        r.random test
+Purpose:    Tests r.random module and some of its options.
+Author:     Shubham Sharma, Google Code-in 2018
+Copyright:  (C) 2018 by Shubham Sharma and the GRASS Development Team
+Licence:    This program is free software under the GNU General Public
+            License (>=v2). Read the file COPYING that comes with GRASS
+            for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+class TestRasterTile(TestCase):
+    input = 'landcover_1m'
+    npoints = '20'
+    raster = 'landcover_1m_raster_random'
+    vector = "landcover_1m_vector_random"
+    @classmethod
+    def setUpClass(cls):
+        cls.use_temp_region()
+        cls.runModule('g.region', raster=cls.input)
+    @classmethod
+    def tearDownClass(cls):
+        cls.del_temp_region()
+        cls.runModule('g.remove', type='raster', flags='f', name=cls.raster)
+        cls.runModule('g.remove', type='raster', flags='f', name=cls.raster + '_null')
+        cls.runModule('g.remove', type='raster', flags='f', name=cls.raster + '_without_topology')
+        cls.runModule('g.remove', type='raster', flags='f', name=cls.raster + '_3D')
+        cls.runModule('g.remove', type='raster', flags='f', name=cls.raster + '_cover_landcover_1m')
+        cls.runModule('g.remove', type='vector', flags='f', name=cls.vector)
+        cls.runModule('g.remove', type='vector', flags='f', name=cls.vector+'_null')
+        cls.runModule('g.remove', type='vector', flags='f', name=cls.vector + '_without_topology')
+        cls.runModule('g.remove', type='vector', flags='f', name=cls.vector + '_3D')
+        cls.runModule('g.remove', type='vector', flags='f', name=cls.vector + '_cover_landcover_1m')
+    def test_random_raster(self):
+        """Testing r.random  runs successfully"""
+        self.assertModule('r.random', input=self.input, npoints=self.npoints, raster=self.raster)
+        # check if random raster was created
+        self.assertRasterExists(self.raster, msg="landcover_1m_raster_random was not created")
+    def test_random_vector(self):
+        self.assertModule('r.random', input=self.input, npoints=self.npoints, vector=self.vector)
+        # check if random vector was created
+        self.assertVectorExists(self.vector, msg="landcover_1m_vector_random was not created")
+        topology = dict(points=20,primitives=20)
+        self.assertVectorFitsTopoInfo(vector=self.vector, reference=topology)
+    def test_random_raster_flag_z(self):
+        self.assertModule('r.random', flags='z', input=self.input, npoints=self.npoints, raster=self.raster+'_null')
+        # check if random raster ( with NULL values )  was created
+        self.assertRasterExists(self.raster, msg="landcover_1m_raster_random_null was not created")
+    def test_vector_random_flag_z(self):
+        self.assertModule('r.random', flags='z', input=self.input, npoints=self.npoints, vector=self.vector+'_null')
+        # check if random vector ( with NULL values ) was created
+        self.assertVectorExists(self.vector+'_null', msg="landcover_1m_vector_random_null was not created")
+        self.assertVectorFitsTopoInfo(vector=self.vector+'_null', reference=topology)
+    def test_random_raster_flag_b(self):
+        self.assertModule('r.random', flags='b', input=self.input, npoints=self.npoints, raster=self.raster+'_without_topology')
+        # check if random raster ( without topology )  was created
+        self.assertRasterExists(self.raster, msg="landcover_1m_raster_random_without_topologywas not created")
+    def test_vector_random_flag_b(self):
+        self.assertModule('r.random', flags='b', input=self.input, npoints=self.npoints, vector=self.vector+'_without_topology')
+        # check if random vector ( without topology ) was created
+        self.assertVectorExists(self.vector+'_without_topology', msg="landcover_1m_vector_random_without_topology was not created")
+        self.assertVectorFitsTopoInfo(vector=self.vector+'_without_topology', reference=topology)
+    def test_random_raster_flag_d(self):
+        self.assertModule('r.random', flags='d', input=self.input, npoints=self.npoints, raster=self.raster+'_3D')
+        # check if random raster ( 3D points )  was created
+        self.assertRasterExists(self.raster, msg="landcover_1m_raster_random_3D not created")
+    def test_vector_random_flag_d(self):
+        self.assertModule('r.random', flags='d', input=self.input, npoints=self.npoints, vector=self.vector+'_3D')
+        # check if random vector ( 3D points ) was created
+        self.assertVectorExists(self.vector+'_3D', msg="landcover_1m_vector_random_3D was not created")
+        self.assertVectorFitsTopoInfo(vector=self.vector+'_3D', reference=topology)
+    def test_random_raster_cover(self):
+        self.assertModule('r.random',input='landuse96_28m', npoints=self.npoints, cover='landcover_1m', raster=self.raster+'_cover_landcover_1m')
+        self.assertRasterExists(self.raster+'_cover_landcover_1m', msg="landcover_1m_raster_random_cover_landcover_1m was not created")
+        self.assertModule('r.random',input='landuse96_28m', npoints=self.npoints, cover='landcover_1m', vector=self.vector+'_cover_landcover_1m')
+        self.assertVectorExists(self.vector+'_cover_landcover_1m', msg="landcover_1m_vector_cover_landcover_1m was not created")
+        topology = dict(points=20, primitives=20)
+        self.assertVectorFitsTopoInfo(vector=self.vector+'_cover_landcover_1m', reference=topology)
+if __name__ == '__main__':
+    test()
