[GRASS-SVN] r74404 - grass/trunk/locale/po
Fri Apr 19 08:20:06 PDT 2019
Author: hcho
Date: 2019-04-19 08:20:06 -0700 (Fri, 19 Apr 2019)
New Revision: 74404
Removed:
   grass/trunk/locale/po/grasslibs_zh_CN.po
   grass/trunk/locale/po/grassmods_zh_CN.po
   grass/trunk/locale/po/grasswxpy_zh_CN.po
i18n: sync from Transifex
Deleted: grass/trunk/locale/po/grasslibs_zh_CN.po
--- grass/trunk/locale/po/grasslibs_zh_CN.po	2019-04-19 08:33:13 UTC (rev 74403)
+++ grass/trunk/locale/po/grasslibs_zh_CN.po	2019-04-19 15:20:06 UTC (rev 74404)
@@ -1,9834 +0,0 @@
-# Translation of grasslibs_zh_CN.po
-# Copyright (C) 2017 GRASS Development Team
-# This file is distributed under the same license as the GRASS GIS package.
-# transifex generated, 2017
-#, fuzzy
-msgid ""
-msgstr ""
-"Project-Id-Version: grasslibs_zh_CN\n"
-"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2019-03-02 23:14-0800\n"
-"PO-Revision-Date: 2017-01-25 08:30+0000\n"
-"Language-Team: Chinese (China) (https://www.transifex.com/grass-gis/teams/45198/zh_CN/)\n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
-"Language: zh_CN\n"
-"Plural-Forms: nplurals=1; plural=0;\n"
-#: ../lib/raster3d/color.c:354
-#, c-format
-msgid "mapset <%s> is not the current mapset"
-msgstr ""
-#: ../lib/raster3d/close.c:47
-#, c-format
-msgid "Unable to write history for 3D raster map <%s>"
-msgstr ""
-#: ../lib/raster3d/close.c:62
-#, c-format
-msgid "Unable to move temp raster map <%s> to 3D raster map <%s>"
-msgstr ""
-#: ../lib/raster3d/close.c:79
-msgid "Unable to flush all tiles"
-msgstr ""
-#: ../lib/raster3d/close.c:84
-msgid "Unable to flush index"
-msgstr ""
-#: ../lib/raster3d/close.c:94
-msgid "Unable to position file"
-msgstr ""
-#: ../lib/raster3d/close.c:99 ../lib/raster3d/close.c:105
-#: ../lib/raster3d/close.c:191 ../lib/raster3d/header.c:217
-#, c-format
-msgid "Unable to write header for 3D raster map <%s>"
-msgstr ""
-#: ../lib/raster3d/close.c:110 ../lib/raster3d/close.c:153
-#, c-format
-msgid "Unable to create 3D raster map <%s>"
-msgstr ""
-#: ../lib/raster3d/close.c:120 ../lib/raster3d/close.c:130
-#: ../lib/raster3d/close.c:159
-#: ../lib/python/temporal/c_libraries_interface.py:706
-#: ../lib/ogsf/gvl_file.c:470
-#, c-format, python-format
-msgid "Unable to close 3D raster map <%s>"
-msgstr ""
-#: ../lib/raster3d/close.c:169
-msgid "Error in cache"
-msgstr ""
-#: ../lib/raster3d/history.c:43
-#, c-format
-msgid "can't get history information for [%s] in mapset [%s]"
-msgstr ""
-#: ../lib/raster3d/maskfn.c:77
-#, c-format
-msgid "Adding rule: %lf - %lf"
-msgstr ""
-#: ../lib/raster3d/maskfn.c:95
-#, c-format
-msgid "%s: illegal value spec"
-msgstr ""
-#: ../lib/raster3d/open.c:20
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
-msgstr ""
-#: ../lib/raster3d/open.c:26
-msgid "Rast3d_open_cell_old_no_header: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:37
-msgid "Rast3d_open_cell_old_no_header: error in G_open_old"
-msgstr ""
-#: ../lib/raster3d/open.c:93
-msgid "Rast3d_open_cell_old: error in Rast3d_open_cell_old_no_header"
-msgstr ""
-#: ../lib/raster3d/open.c:98
-msgid "Rast3d_open_cell_old: can't rewind file"
-msgstr ""
-#: ../lib/raster3d/open.c:111
-msgid "Rast3d_open_cell_old: error in Rast3d_read_header"
-msgstr ""
-#: ../lib/raster3d/open.c:119
-msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr ""
-#: ../lib/raster3d/open.c:123
-msgid "Rast3d_open_cell_old: zone does not match window zone"
-msgstr ""
-#: ../lib/raster3d/open.c:135 ../lib/raster3d/open.c:152
-msgid "Rast3d_open_cell_old: can't read header"
-msgstr ""
-#: ../lib/raster3d/open.c:141
-msgid "Rast3d_open_cell_old: index does not fit into long"
-msgstr ""
-#: ../lib/raster3d/open.c:145
-msgid "Rast3d_open_cell_old: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:172
-msgid "Rast3d_open_cell_old: error in Rast3d_fill_header"
-msgstr ""
-#: ../lib/raster3d/open.c:219
-msgid "Rast3d_open_cell_new: error in Rast3d_mask_open_old"
-msgstr ""
-#: ../lib/raster3d/open.c:228
-msgid "Rast3d_open_cell_new: error in Rast3d_malloc"
-msgstr ""
-#: ../lib/raster3d/open.c:233
-#, c-format
-msgid "map <%s> is not in the current mapset"
-msgstr ""
-#: ../lib/raster3d/open.c:243
-msgid "Rast3d_open_cell_new: could not open file"
-msgstr ""
-#: ../lib/raster3d/open.c:287 ../lib/raster3d/open.c:292
-msgid "Rast3d_open_cell_new: can't write header"
-msgstr ""
-#: ../lib/raster3d/open.c:314
-msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
-msgstr ""
-#: ../lib/raster3d/param.c:84
-msgid "Rast3d_get_standard3d_params: precision value invalid"
-msgstr ""
-#: ../lib/raster3d/param.c:105
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr ""
-#: ../lib/raster3d/param.c:129
-msgid "Window replacing the default"
-msgstr ""
-#: ../lib/raster3d/range.c:73
-#, c-format
-msgid "Unable to open range file for [%s in %s]"
-msgstr ""
-#: ../lib/raster3d/range.c:88
-#, c-format
-msgid "Error reading range file for [%s in %s]"
-msgstr ""
-#: ../lib/raster3d/range.c:150
-#, c-format
-msgid "Unable to open range file for <%s>"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:96
-msgid "raster3d"
-msgstr ""
-#: ../lib/raster3d/test/test_main.c:97
-msgid "unit test"
-msgstr ""
-#: ../lib/manage/do_copy.c:43
-#, c-format
-msgid "Copy %s <%s> to current mapset as <%s>"
-msgstr ""
-#: ../lib/manage/do_copy.c:50 ../lib/manage/do_copy.c:67
-#, c-format
-msgid "Unable to copy <%s> to current mapset as <%s>"
-msgstr ""
-#: ../lib/manage/do_copy.c:61 ../lib/manage/do_remove.c:89
-#: ../lib/manage/do_remove.c:109 ../lib/manage/do_rename.c:87
-#: ../lib/manage/do_rename.c:107
-#, c-format
-msgid "%s is missing"
-msgstr ""
-#: ../lib/manage/do_copy.c:72
-#, c-format
-msgid "%s copied"
-msgstr ""
-#: ../lib/manage/do_list.c:30
-#, c-format
-msgid "%s: invalid index %d"
-msgstr ""
-#: ../lib/manage/do_remove.c:42
-#, c-format
-msgid "Removing %s <%s>"
-msgstr ""
-#: ../lib/manage/do_remove.c:57 ../lib/manage/do_rename.c:54
-#: ../lib/vector/Vlib/map.c:263 ../lib/vector/Vlib/legal_vname.c:141
-#: ../lib/vector/Vlib/legal_vname.c:144 ../lib/vector/Vlib/open.c:235
-#: ../lib/ogsf/gp3.c:56 ../lib/ogsf/gp3.c:191 ../lib/ogsf/gv3.c:60
-#: ../lib/ogsf/gv3.c:333
-#, c-format
-msgid "Vector map <%s> not found"
-msgstr ""
-#: ../lib/manage/do_remove.c:65
-msgid "Unable to delete vector map"
-msgstr ""
-#: ../lib/manage/do_remove.c:73 ../lib/manage/do_rename.c:71
-#: ../lib/rst/interp_float/resout2d.c:205
-#: ../lib/rst/interp_float/resout2d.c:253
-#: ../lib/rst/interp_float/resout2d.c:296
-#: ../lib/rst/interp_float/resout2d.c:327
-#: ../lib/rst/interp_float/resout2d.c:377
-#: ../lib/rst/interp_float/resout2d.c:395
-#: ../lib/rst/interp_float/resout2d.c:410
-#: ../lib/rst/interp_float/resout2d.c:426
-#: ../lib/rst/interp_float/output2d.c:247
-#: ../lib/rst/interp_float/output2d.c:328
-#: ../lib/rst/interp_float/output2d.c:397
-#: ../lib/rst/interp_float/output2d.c:447
-#: ../lib/rst/interp_float/output2d.c:461
-#: ../lib/rst/interp_float/output2d.c:475
-#: ../lib/rst/interp_float/output2d.c:491 ../lib/raster/open.c:176
-#: ../lib/raster/open.c:843 ../lib/raster/open.c:880 ../lib/raster/open.c:932
-#: ../lib/ogsf/gs3.c:125 ../lib/ogsf/gs3.c:189 ../lib/ogsf/gs3.c:264
-#: ../lib/ogsf/gs3.c:336 ../lib/ogsf/gs3.c:442 ../lib/ogsf/gs3.c:529
-#: ../lib/ogsf/gs3.c:588 ../lib/ogsf/gs3.c:645 ../lib/ogsf/gs3.c:716
-#: ../lib/ogsf/gs3.c:786 ../lib/ogsf/gsd_legend.c:239
-#: ../lib/gis/legal_name.c:94 ../lib/gis/legal_name.c:97
-#, c-format
-msgid "Raster map <%s> not found"
-msgstr ""
-#: ../lib/manage/do_remove.c:78 ../lib/manage/do_rename.c:76
-#: ../lib/gpde/n_arrays_io.c:273 ../lib/ogsf/gvl3.c:40
-#: ../lib/ogsf/gvl_file.c:427
-#, c-format
-msgid "3D raster map <%s> not found"
-msgstr ""
-#: ../lib/manage/do_remove.c:85
-#, c-format
-msgid "Unable to remove %s element"
-msgstr ""
-#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
-#, c-format
-msgid "%s removed"
-msgstr ""
-#: ../lib/manage/do_remove.c:105
-#, c-format
-msgid "Unable to remove %s"
-msgstr ""
-#: ../lib/manage/do_remove.c:121
-#, c-format
-msgid "<%s> nothing removed"
-msgstr ""
-#: ../lib/manage/do_rename.c:42
-#, c-format
-msgid "Rename %s <%s> to <%s>"
-msgstr ""
-#: ../lib/manage/do_rename.c:62
-#, c-format
-msgid "Unable to rename vector map <%s> to <%s>"
-msgstr ""
-#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
-#, c-format
-msgid "Unable to rename %s"
-msgstr ""
-#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
-#, c-format
-msgid "%s renamed"
-msgstr ""
-#: ../lib/manage/do_rename.c:119
-#, c-format
-msgid "<%s> nothing renamed"
-msgstr ""
-#: ../lib/manage/option.c:47
-#, c-format
-msgid "%s to be %s"
-msgstr ""
-#: ../lib/manage/option.c:51
-msgid "Raster"
-msgstr ""
-#: ../lib/manage/option.c:53
-msgid "Vector"
-msgstr ""
-#: ../lib/manage/option.c:55
-msgid "Region"
-msgstr ""
-#: ../lib/manage/option.c:57
-msgid "Group"
-msgstr ""
-#: ../lib/manage/read_list.c:73
-#, c-format
-msgid "Unable to open data base element list '%s'"
-msgstr ""
-#: ../lib/manage/read_list.c:134
-#, c-format
-msgid "Format error: file ('%s') line (%d) - %s"
-msgstr ""
-#: ../lib/display/icon.c:80
-#, c-format
-msgid "Unsupported icon %d"
-msgstr ""
-#: ../lib/display/r_raster.c:98
-#, c-format
-msgid "Both %s and %s are defined. %s will be ignored."
-msgstr ""
-#: ../lib/display/r_raster.c:131
-#, c-format
-msgid ""
-"Neither %s (managed by d.mon command) nor %s (used for direct rendering) "
-"defined"
-msgstr ""
-#: ../lib/display/r_raster.c:150
-#, c-format
-msgid "Unknown display driver <%s>"
-msgstr ""
-#: ../lib/display/r_raster.c:151
-#, c-format
-msgid "Using display driver <%s>..."
-msgstr ""
-#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
-#, c-format
-msgid "[%s]: No such color"
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:81
-#, c-format
-msgid "Unable to write header into category raster condition file <%s>."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:98
-#, c-format
-msgid "Unable to write into category raster condition file <%s>."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:255
-#, c-format
-msgid "Unable to open category raster conditions file <%s>."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:263
-#, c-format
-msgid "Unable to find patch raster <%s>."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:280
-#, c-format
-msgid "Resolutions of patch <%s> and patched file <%s> are not same."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:307 ../lib/imagery/iscatt_core.c:349
-#, c-format
-msgid "Corrupted  category raster conditions file <%s> (fseek failed)"
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:338
-#, c-format
-msgid "Unable to write into category raster conditions file <%s>"
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:526
-msgid "Unable to read from category raster condtition file."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:533
-msgid "Invalid size of category raster conditions file."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:579
-msgid ""
-"Data inconsistent. Value computed for scatter plot is out of initialized "
-"range."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:745
-#, c-format
-msgid "Unable to read find raster <%s>"
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:755
-#, c-format
-msgid "Unable to open raster <%s>"
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:761
-#, c-format
-msgid "Raster <%s> type is not <%s>"
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:775
-#, c-format
-msgid "Unable to read range of raster <%s>"
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:803
-#, c-format
-msgid "Unable to open category raster condtition file <%s>"
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:817
-msgid "Corrupted category raster conditions file (fseek failed)"
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:972 ../lib/imagery/iclass_statistics.c:227
-#, c-format
-msgid "prepare_signature: scan line %d has odd number of points."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:981 ../lib/imagery/iclass_statistics.c:237
-msgid "signature: perimeter points out of order."
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:109
-#, c-format
-msgid "Get area %d failed"
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:116
-msgid "Perimeter computation failed"
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:208
-msgid "Invalid polygon"
-msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:253
-msgid "Outlined area is too large."
-msgstr ""
-#: ../lib/imagery/fopen.c:23
-#, c-format
-msgid "Unable to create file [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
-#, c-format
-msgid "Unable to open file [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:49
-#, c-format
-msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:79
-#, c-format
-msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
-#, c-format
-msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/fopen.c:116
-#, c-format
-msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/georef_tps.c:219
-msgid "Calculating forward transformation coefficients"
-msgstr ""
-#: ../lib/imagery/georef_tps.c:236
-msgid "Calculating backward transformation coefficients"
-msgstr ""
-#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
-#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
-#: ../lib/imagery/georef_tps.c:293
-#, c-format
-msgid "%s: out of memory"
-msgstr ""
-#: ../lib/imagery/iclass.c:83
-#, c-format
-msgid "No areas in category %d"
-msgstr ""
-#: ../lib/imagery/iclass.c:127
-#, c-format
-msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
-msgstr ""
-#: ../lib/imagery/iclass.c:131
-#, c-format
-msgid "Raster map <%s@%s> in group <%s> does not exist"
-msgstr ""
-#: ../lib/imagery/iclass.c:143
-#, c-format
-msgid "Subgroup <%s> does not have enough files (it has %d files)"
-msgstr ""
-#: ../lib/imagery/iclass.c:147
-#, c-format
-msgid "Group <%s> does not have enough files (it has %d files)"
-msgstr ""
-#: ../lib/imagery/iclass_signatures.c:120
-#, c-format
-msgid "Unable to open output signature file '%s'"
-msgstr ""
-#: ../lib/imagery/list_gp.c:34
-#, c-format
-msgid "group <%s> is empty\n"
-msgstr ""
-#: ../lib/imagery/list_gp.c:44
-#, c-format
-msgid "group <%s> references the following raster maps\n"
-msgstr ""
-#: ../lib/imagery/list_subgp.c:72
-#, c-format
-msgid "subgroup <%s> of group <%s> is empty\n"
-msgstr ""
-#: ../lib/imagery/list_subgp.c:85
-#, c-format
-msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-#: ../lib/imagery/points.c:124
-#, c-format
-msgid "Unable to open control point file for group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/points.c:132
-#, c-format
-msgid "Bad format in control point file for group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/points.c:159
-#, c-format
-msgid "Unable to create control point file for group [%s in %s]"
-msgstr ""
-#: ../lib/imagery/target.c:38
-#, c-format
-msgid "Unable to read target file for group [%s]"
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:218
-msgid "prepare_signature: outline has odd number of points."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:248
-#, c-format
-msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:561
-#: ../lib/imagery/iclass_statistics.c:584
-#: ../lib/imagery/iclass_statistics.c:607
-#: ../lib/imagery/iclass_statistics.c:630
-#: ../lib/imagery/iclass_statistics.c:653
-#: ../lib/imagery/iclass_statistics.c:680
-#: ../lib/imagery/iclass_statistics.c:712
-#: ../lib/imagery/iclass_statistics.c:735
-#: ../lib/imagery/iclass_statistics.c:758
-msgid "Band index out of range"
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:684
-msgid "Cell category value out of range"
-msgstr ""
-#: ../lib/imagery/sigsetfile.c:41
-#, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-#: ../lib/imagery/sigsetfile.c:57
-#, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
-#: ../lib/proj/ellipse.c:97
-#, c-format
-msgid "Invalid ellipsoid <%s> in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:124
-msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:128
-msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:141
-msgid "No ellipsoid info given in file"
-msgstr ""
-#: ../lib/proj/ellipse.c:243 ../lib/gis/get_ellipse.c:263
-#, c-format
-msgid "Unable to open ellipsoid table file <%s>"
-msgstr ""
-#: ../lib/proj/datum.c:195
-msgid "Failed to detect nadgrids path, GRASS_PROJSHARE not defined"
-msgstr ""
-#: ../lib/proj/datum.c:278 ../lib/proj/datum.c:358
-#, c-format
-msgid "Unable to open datum table file <%s>"
-msgstr ""
-#: ../lib/proj/datum.c:291 ../lib/proj/datum.c:372
-#, c-format
-msgid "Error in datum table file <%s>, line %d"
-msgstr ""
-#: ../lib/proj/get_proj.c:148
-#, c-format
-msgid "Invalid zone %s specified"
-msgstr ""
-#: ../lib/proj/get_proj.c:228
-msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr ""
-#: ../lib/proj/get_proj.c:236
-#, c-format
-msgid "The error message: %s"
-msgstr ""
-#: ../lib/proj/get_proj.c:294
-msgid "Option input overflowed option table"
-msgstr ""
-#: ../lib/proj/get_proj.c:325
-#, c-format
-msgid "Unable to initialize pj cause: %s"
-msgstr ""
-#: ../lib/proj/get_proj.c:401
-msgid "Input Projection Parameters"
-msgstr ""
-#: ../lib/proj/get_proj.c:404
-msgid "Input Unit Factor"
-msgstr ""
-#: ../lib/proj/get_proj.c:414
-msgid "Output Projection Parameters"
-msgstr ""
-#: ../lib/proj/get_proj.c:417
-msgid "Output Unit Factor"
-msgstr ""
-#: ../lib/proj/convert.c:64 ../lib/vector/Vlib/build_sfa.c:714
-#: ../lib/vector/Vlib/close.c:284 ../lib/vector/Vlib/close_ogr.c:77
-#: ../lib/vector/Vlib/close_ogr.c:111 ../lib/vector/Vlib/field.c:675
-#: ../lib/vector/Vlib/header_finfo.c:41 ../lib/vector/Vlib/header_finfo.c:80
-#: ../lib/vector/Vlib/header_finfo.c:113 ../lib/vector/Vlib/header_finfo.c:153
-#: ../lib/vector/Vlib/header_finfo.c:254 ../lib/vector/Vlib/open_ogr.c:121
-#: ../lib/vector/Vlib/open_ogr.c:154 ../lib/vector/Vlib/open_ogr.c:231
-#: ../lib/vector/Vlib/read_ogr.c:56 ../lib/vector/Vlib/read_ogr.c:157
-#: ../lib/vector/Vlib/read_ogr.c:242 ../lib/vector/Vlib/rewind_ogr.c:47
-#: ../lib/vector/Vlib/rewind_ogr.c:71 ../lib/vector/Vlib/simple_features.c:310
-#: ../lib/vector/Vlib/write_ogr.c:69 ../lib/vector/Vlib/write_ogr.c:105
-#: ../lib/vector/Vlib/write_ogr.c:146 ../lib/vector/Vlib/write_sfa.c:298
-#: ../lib/vector/Vlib/build_ogr.c:101 ../lib/vector/Vlib/build_ogr.c:176
-msgid "GRASS is not compiled with OGR support"
-msgstr ""
-#: ../lib/proj/convert.c:159
-msgid "Unable parse GRASS PROJ_INFO file"
-msgstr ""
-#: ../lib/proj/convert.c:164
-msgid "Unable get PROJ.4-style parameter string"
-msgstr ""
-#: ../lib/proj/convert.c:178
-#, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-#: ../lib/proj/convert.c:191
-#, c-format
-msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-#: ../lib/proj/convert.c:427
-#, c-format
-msgid ""
-"Updating spatial reference with embedded proj4 definition failed. Proj4 "
-"definition: <%s>"
-msgstr ""
-#: ../lib/proj/convert.c:434
-msgid "Updating spatial reference with embedded proj4 definition"
-msgstr ""
-#: ../lib/proj/convert.c:564
-msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-#: ../lib/proj/convert.c:626
-#, c-format
-msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr ""
-#: ../lib/proj/convert.c:642
-#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-#: ../lib/proj/convert.c:646
-#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
-#, c-format
-msgid "pj_transform() failed: %s"
-msgstr ""
-#: ../lib/symbol/read.c:211
-#, c-format
-msgid "Cannot read symbol line coordinates: %s"
-msgstr ""
-#: ../lib/symbol/read.c:260
-#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-#: ../lib/symbol/read.c:284
-#, c-format
-msgid "Cannot find/open symbol: '%s'"
-msgstr ""
-#: ../lib/symbol/read.c:393 ../lib/symbol/read.c:411 ../lib/symbol/read.c:421
-#: ../lib/symbol/read.c:439
-#, c-format
-msgid "Incorrect symbol color: '%s', using default."
-msgstr ""
-#: ../lib/arraystats/class.c:19
-#, c-format
-msgid "Unknown algorithm '%s'"
-msgstr ""
-#: ../lib/arraystats/class.c:42
-msgid "Discont algorithm currently not available because of bugs"
-msgstr ""
-#: ../lib/arraystats/class.c:49
-msgid "Classification algorithm failed"
-msgstr ""
-#: ../lib/arraystats/class.c:227
-msgid "Equiprobable classbreaks currently limited to 10 classes"
-msgstr ""
-#: ../lib/arraystats/class.c:242
-#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
-#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
-#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
-#: ../lib/lidar/raster.c:175
-#, c-format
-msgid "Unable to access table <%s>"
-msgstr ""
-#: ../lib/lidar/zones.c:476 ../lib/lidar/zones.c:513
-#, c-format
-msgid "<%s> created in database."
-msgstr ""
-#: ../lib/lidar/zones.c:480 ../lib/lidar/zones.c:517
-#, c-format
-msgid "<%s> has not been created in database."
-msgstr ""
-#: ../lib/segment/format.c:144
-msgid "Segment format: file size too large"
-msgstr ""
-#: ../lib/segment/format.c:145
-msgid "Please recompile with Large File Support (LFS)"
-msgstr ""
-#: ../lib/segment/open.c:53
-msgid "Segment file name is NULL"
-msgstr ""
-#: ../lib/segment/open.c:58
-msgid "Segment file exists already"
-msgstr ""
-#: ../lib/segment/open.c:66
-msgid "Unable to create segment file"
-msgstr ""
-#: ../lib/segment/open.c:74
-msgid "Could not write segment file"
-msgstr ""
-#: ../lib/segment/open.c:78
-msgid "Illegal segment configuration parameter(s)"
-msgstr ""
-#: ../lib/segment/open.c:87
-msgid "Unable to re-open segment file"
-msgstr ""
-#: ../lib/segment/open.c:94
-msgid "Could not read segment file"
-msgstr ""
-#: ../lib/segment/open.c:98 ../lib/rst/interp_float/segmen2d.c:197
-#: ../lib/rst/interp_float/segmen2d.c:203
-#: ../lib/rst/interp_float/segmen2d.c:209
-#: ../lib/rst/interp_float/segmen2d.c:219
-#: ../lib/rst/interp_float/interp2d.c:139
-#: ../lib/rst/interp_float/interp2d.c:145
-#: ../lib/rst/interp_float/segmen2d_parallel.c:78
-#: ../lib/rst/interp_float/segmen2d_parallel.c:85
-#: ../lib/rst/interp_float/segmen2d_parallel.c:92
-#: ../lib/rst/interp_float/segmen2d_parallel.c:101
-#: ../lib/rst/interp_float/segmen2d_parallel.c:263
-#: ../lib/vector/diglib/struct_alloc.c:491 ../lib/vector/Vlib/line.c:50
-#: ../lib/vector/Vlib/line.c:154 ../lib/vector/Vlib/map.c:48
-#: ../lib/vector/neta/path.c:262 ../lib/vector/neta/flow.c:66
-#: ../lib/vector/neta/flow.c:190 ../lib/vector/neta/components.c:71
-#: ../lib/vector/neta/components.c:176
-#: ../lib/vector/neta/articulation_point.c:60
-#: ../lib/vector/neta/spanningtree.c:104 ../lib/vector/neta/bridge.c:58
-#: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
-#: ../lib/vector/neta/timetables.c:69 ../lib/vector/neta/timetables.c:168
-#: ../lib/vector/neta/timetables.c:178 ../lib/vector/neta/timetables.c:191
-#: ../lib/vector/neta/timetables.c:278 ../lib/vector/neta/timetables.c:413
-#: ../lib/vector/neta/timetables.c:425 ../lib/rowio/setup.c:61
-#: ../lib/rowio/setup.c:67
-msgid "Out of memory"
-msgstr ""
-#: ../lib/cairodriver/draw_bitmap.c:47
-msgid "Cairo_Bitmap: Failed to create source"
-msgstr ""
-#: ../lib/cairodriver/graph.c:67
-msgid "Unable to open display"
-msgstr ""
-#: ../lib/cairodriver/graph.c:85
-msgid "Unable to obtain visual"
-msgstr ""
-#: ../lib/cairodriver/graph.c:160
-#, c-format
-msgid "Unknown file extension: %s"
-msgstr ""
-#: ../lib/cairodriver/graph.c:190
-#, c-format
-msgid "cairo: collecting to file '%s'"
-msgstr ""
-#: ../lib/cairodriver/graph.c:192
-#, c-format
-msgid "cairo: image size %dx%d"
-msgstr ""
-#: ../lib/cairodriver/graph.c:371
-msgid "Unknown Cairo surface type"
-msgstr ""
-#: ../lib/cairodriver/graph.c:376
-msgid "Failed to initialize Cairo surface"
-msgstr ""
-#: ../lib/cairodriver/raster.c:109
-msgid "Failed to create cairo surface"
-msgstr ""
-#: ../lib/cairodriver/read_bmp.c:88 ../lib/cairodriver/read_ppm.c:28
-#, c-format
-msgid "Cairo: unable to open input file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_bmp.c:92 ../lib/cairodriver/read_ppm.c:32
-#, c-format
-msgid "Cairo: invalid input file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_bmp.c:96
-#, c-format
-msgid "Cairo: Invalid BMP header for <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:38
-#, c-format
-msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:46
-#, c-format
-msgid "Cairo: unable to open input mask file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:50
-#, c-format
-msgid "Cairo: invalid input mask file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_ppm.c:56
-#, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
-msgstr ""
-#: ../lib/cairodriver/read_xid.c:14
-#, c-format
-msgid "Unable to open input file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_xid.c:17
-#, c-format
-msgid "Unable to read input file <%s>"
-msgstr ""
-#: ../lib/cairodriver/read_xid.c:20
-#, c-format
-msgid "Unable to parse input file <%s>"
-msgstr ""
-#: ../lib/cairodriver/text.c:46
-#, c-format
-msgid "Unable to convert from <%s> to UTF-8"
-msgstr ""
-#: ../lib/cairodriver/text.c:56
-msgid "Some characters could not be converted to UTF-8"
-msgstr ""
-#: ../lib/cairodriver/write_bmp.c:72 ../lib/cairodriver/write_ppm.c:27
-#, c-format
-msgid "Cairo: unable to open output file <%s>"
-msgstr ""
-#: ../lib/cairodriver/write_ppm.c:34
-#, c-format
-msgid "Cairo: unable to open mask file <%s>"
-msgstr ""
-#: ../lib/cairodriver/write_xid.c:14 ../lib/pngdriver/read_png.c:71
-#, c-format
-msgid "Unable to open output file <%s>"
-msgstr ""
-#: ../lib/cairodriver/write_xid.c:19
-#, c-format
-msgid "Unable to write output file <%s>"
-msgstr ""
-#: ../lib/pngdriver/graph_set.c:101
-#, c-format
-msgid "png: truecolor status %s"
-msgstr ""
-#: ../lib/pngdriver/graph_set.c:102 ../lib/psdriver/graph_set.c:200
-msgid "enabled"
-msgstr ""
-msgid "disabled"
-msgstr ""
-#: ../lib/pngdriver/graph_set.c:149
-#, c-format
-msgid "png: collecting to file '%s'"
-msgstr ""
-#: ../lib/pngdriver/graph_set.c:150
-#, c-format
-msgid "png: image size %dx%d"
-msgstr ""
-#: ../lib/pngdriver/write_png.c:39
-msgid "Unable to write PNG"
-msgstr ""
-#: ../lib/pngdriver/write_png.c:71 ../lib/pngdriver/write_png.c:75
-#: ../lib/pngdriver/read_png.c:64
-msgid "Unable to allocate PNG structure"
-msgstr ""
-#: ../lib/pngdriver/write_png.c:78
-msgid "Unable to write PNG file"
-msgstr ""
-#: ../lib/pngdriver/write_png.c:82
-#, c-format
-msgid "Unable to open output PNG file <%s>"
-msgstr ""
-#: ../lib/pngdriver/read_png.c:42
-msgid "Unable to read PNG"
-msgstr ""
-#: ../lib/pngdriver/read_png.c:60
-msgid "Unable allocate PNG structure"
-msgstr ""
-#: ../lib/pngdriver/read_png.c:67
-msgid "Unable to read PNG file"
-msgstr ""
-#: ../lib/pngdriver/read_png.c:81
-msgid "Input PNG file is not 8-bit"
-msgstr ""
-#: ../lib/pngdriver/read_png.c:85
-#, c-format
-msgid "Input PNG file has incorrect dimensions: expected: %dx%d got: %lux%lu"
-msgstr ""
-#: ../lib/pngdriver/read_png.c:90
-msgid "Input PNG file is not RGBA"
-msgstr ""
-#: ../lib/pngdriver/read_png.c:94
-msgid "Input PNG file is not indexed color"
-msgstr ""
-#: ../lib/pngdriver/read_png.c:104
-msgid "Input PNG file has invalid palette"
-msgstr ""
-#: ../lib/temporal/lib/connect.c:110
-#, c-format
-msgid "Mapset <%s> does not exist."
-msgstr ""
-#: ../lib/temporal/lib/default_name.c:69
-msgid "Programmer error - only SQLite driver is currently supported"
-msgstr ""
-#: ../lib/rst/interp_float/segmen2d.c:133
-#: ../lib/rst/interp_float/segmen2d_parallel.c:188
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-#: ../lib/rst/interp_float/interp2d.c:232
-#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occurs at (%d,%d) cell."
-" Z-value %f, zmin %f, zmax %f."
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:77
-msgid "Temporarily changing the region to desired resolution..."
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:103
-#, c-format
-msgid "First change your rows number(%d) to %d"
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:110
-#, c-format
-msgid "First change your columns number(%d) to %d"
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:264
-msgid "No color table for input raster map -- will not create color table"
-msgstr ""
-#: ../lib/rst/interp_float/resout2d.c:458
-msgid "Changing the region back to initial..."
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:94
-#, c-format
-msgid "Vector map <%s> is not 3D"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:97
-msgid "Loading data from attribute table ..."
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:100 ../lib/vector/Vlib/net_build.c:159
-#: ../lib/vector/Vlib/net_build.c:206 ../lib/vector/Vlib/net_build.c:490
-#: ../lib/vector/Vlib/net_build.c:791 ../lib/vector/Vlib/net_build.c:971
-#: ../lib/vector/Vlib/ascii.c:398 ../lib/vector/Vlib/map.c:300
-#: ../lib/vector/Vlib/map.c:436 ../lib/vector/Vlib/array.c:276
-#: ../lib/vector/Vlib/cats.c:589 ../lib/vector/Vlib/copy.c:620
-#: ../lib/vector/Vlib/copy.c:730 ../lib/ogsf/gp3.c:202 ../lib/ogsf/gv3.c:344
-#, c-format
-msgid "Database connection not defined for layer %d"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:109 ../lib/db/dbmi_client/copy_tab.c:112
-#: ../lib/db/dbmi_client/copy_tab.c:133 ../lib/db/dbmi_client/db.c:46
-#: ../lib/vector/Vlib/net_build.c:165 ../lib/vector/Vlib/net_build.c:211
-#: ../lib/vector/Vlib/net_build.c:496 ../lib/vector/Vlib/net_build.c:797
-#: ../lib/vector/Vlib/net_build.c:976 ../lib/vector/Vlib/ascii.c:410
-#: ../lib/vector/Vlib/map.c:341 ../lib/vector/Vlib/array.c:282
-#: ../lib/vector/Vlib/cats.c:597 ../lib/vector/Vlib/close_nat.c:160
-#: ../lib/vector/Vlib/write_ogr.c:198 ../lib/vector/Vlib/write_pg.c:2915
-#: ../lib/vector/neta/utils.c:119 ../lib/vector/neta/timetables.c:133
-#: ../lib/ogsf/gp3.c:208 ../lib/ogsf/gv3.c:350
-#, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:115
-#: ../lib/rst/interp_float/vinput2d.c:129 ../lib/db/dbmi_client/copy_tab.c:291
-#, c-format
-msgid "Column <%s> not found"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:118
-#: ../lib/rst/interp_float/vinput2d.c:131
-#, c-format
-msgid "Data type of column <%s> must be numeric"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:142
-msgid "Reading features from vector map ..."
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:174
-#, c-format
-msgid "Database record for cat %d not found"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:192
-msgid "Negative value of smoothing detected: sm must be >= 0"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:256
-msgid "Strip exists with insufficient data"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:270
-#, c-format
-msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:273
-#, c-format
-msgid "Ignoring %d points (too dense)"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:277
-#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given "
-"NPMIN=%d"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:282
-msgid "Zero points in the given region"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:287
-#, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:293
-#, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:297
-#, c-format
-msgid "Number of points from vector map %d"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:298
-#, c-format
-msgid "Number of points outside of 2D/3D region %d"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:300
-#, c-format
-msgid "Number of points being used %d"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:333
-msgid "Some points outside of region (ignored)"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:339
-msgid "Unable to allocate memory"
-msgstr ""
-#: ../lib/rst/interp_float/vinput2d.c:347
-#, c-format
-msgid "Unable to insert %f,%f,%f a = %d"
-msgstr ""
-#: ../lib/rst/interp_float/write2d.c:53 ../lib/rst/interp_float/write2d.c:64
-#: ../lib/rst/interp_float/write2d.c:79 ../lib/rst/interp_float/write2d.c:88
-#: ../lib/rst/interp_float/write2d.c:96 ../lib/rst/interp_float/write2d.c:104
-msgid "Cannot write files"
-msgstr ""
-#: ../lib/rst/interp_float/input2d.c:58
-#, c-format
-msgid "Mask raster map <%s> not found"
-msgstr ""
-#: ../lib/rst/interp_float/input2d.c:81
-msgid "Bitmap mask created"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:117
-#, c-format
-msgid "First change your rows number to nsizr! %d %d"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:124
-#, c-format
-msgid "First change your cols number to nsizc %d %d"
-msgstr ""
-#: ../lib/rst/interp_float/segmen2d_parallel.c:109
-msgid "Starting parallel work"
-msgstr ""
-#: ../lib/gpde/n_arrays_io.c:93
-#, c-format
-msgid "Reading raster map <%s> into memory"
-msgstr ""
-#: ../lib/gpde/n_arrays_io.c:183
-msgid "N_array_2d * array is empty"
-msgstr ""
-#: ../lib/gpde/n_arrays_io.c:202
-#, c-format
-msgid "Write 2d array to raster map <%s>"
-msgstr ""
-#: ../lib/gpde/n_arrays_io.c:281
-#: ../lib/python/temporal/c_libraries_interface.py:676
-#: ../lib/ogsf/gvl_file.c:436
-msgid "Unable to open 3D raster map <%s>"
-msgstr ""
-#: ../lib/gpde/n_arrays_io.c:309
-#, c-format
-msgid "Read g3d map <%s> into the memory"
-msgstr ""
-#: ../lib/gpde/n_arrays_io.c:364 ../lib/gpde/n_arrays_io.c:464
-msgid "Error closing g3d file"
-msgstr ""
-#: ../lib/gpde/n_arrays_io.c:420
-#, c-format
-msgid "Error opening g3d map <%s>"
-msgstr ""
-#: ../lib/gpde/n_arrays_io.c:422
-#, c-format
-msgid "Write 3d array to g3d map <%s>"
-msgstr ""
-#: ../lib/gpde/n_gwflow.c:436 ../lib/gpde/n_gwflow.c:715
-#, c-format
-msgid "The total sum of the water budget: %g\n"
-msgstr ""
-#: ../lib/gpde/n_gwflow.c:438 ../lib/gpde/n_gwflow.c:717
-#, c-format
-msgid "The total sum of the water budget is significantly larger then 0: %g\n"
-msgstr ""
-#: ../lib/gpde/n_parse_options.c:106
-msgid "The calculation time in seconds"
-msgstr ""
-#: ../lib/gpde/test/test_main.c:88
-msgid "Performs unit and integration tests for gpde library"
-msgstr ""
-#: ../lib/db/dbmi_driver/d_error.c:35
-#, c-format
-msgid "DBMI-%s driver error:"
-msgstr ""
-#: ../lib/db/dbmi_base/login.c:115
-#, c-format
-msgid "Unable to read file '%s'"
-msgstr ""
-#: ../lib/db/dbmi_base/login.c:126
-#, c-format
-msgid "Login file (%s) corrupted (line: %s)"
-msgstr ""
-#: ../lib/db/dbmi_base/login.c:164
-#, c-format
-msgid "Unable to write file '%s'"
-msgstr ""
-#: ../lib/db/dbmi_base/login.c:229
-#, c-format
-msgid "DB connection <%s/%s> already exists and will be overwritten"
-msgstr ""
-#: ../lib/db/dbmi_base/login.c:232
-#, c-format
-msgid ""
-"DB connection <%s/%s> already exists. Re-run '%s' with '--%s' flag to "
-"overwrite existing settings."
-msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:52
-msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
-msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:91
-msgid "db_convert_value_into_string(): unrecongized sqltype-type"
-msgstr ""
-#: ../lib/db/dbmi_base/default_name.c:139
-msgid "Programmer error"
-msgstr ""
-#: ../lib/db/dbmi_base/index.c:180
-msgid "db_set_index_column_name(): invalid column number"
-msgstr ""
-#: ../lib/db/dbmi_base/index.c:197
-msgid "db_get_index_column_name(): invalid column number"
-msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:38
-#, c-format
-msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:45
-#, c-format
-msgid "Illegal table map name <%s>. Must start with a letter."
-msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:54
-#, c-format
-msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr ""
-#: ../lib/db/dbmi_base/xdrtable.c:109
-msgid "fetch: table has wrong number of columns"
-msgstr ""
-#: ../lib/db/dbmi_base/xdrvalue.c:82
-msgid "send data: invalid C-type"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:37
-msgid ""
-"\n"
-"++ Running column unit tests ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:42
-msgid ""
-"\n"
-"-- column unit tests failure --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:44
-msgid ""
-"\n"
-"-- column unit tests finished successfully --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:57
-msgid ""
-"\n"
-"++ Run test copy column ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:150
-msgid ""
-"\n"
-"++ Test copy column finished ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:47
-#: ../lib/vector/rtree/test_suite/test_main.c:44
-#: ../lib/gmath/test/test_main.c:47
-msgid "Choose the unit tests to run"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:54 ../lib/gmath/test/test_main.c:54
-msgid "Choose the integration tests to run"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:58 ../lib/gmath/test/test_main.c:79
-msgid "Run all unit tests"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:62 ../lib/gmath/test/test_main.c:83
-msgid "Run all integration tests"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:66 ../lib/gmath/test/test_main.c:87
-msgid "Run all unit and integration tests"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:83
-msgid "Performs unit and integration tests for the dbmi base library"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:38
-msgid ""
-"\n"
-"++ Running table unit tests ++"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:43
-msgid ""
-"\n"
-"-- Table unit tests failure --"
-msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:45
-msgid ""
-"\n"
-"-- Table unit tests finished successfully --"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:72
-msgid "<NULL error message>"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:91
-msgid "dbmi: Protocol error"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:136
-msgid "dbmi: Out of Memory"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:149
-#, c-format
-msgid "dbmi: %s() not implemented"
-msgstr ""
-#: ../lib/db/dbmi_base/error.c:163
-#, c-format
-msgid "dbmi: Invalid procedure %d"
-msgstr ""
-#: ../lib/db/dbmi_client/column.c:136 ../lib/python/script/db.py:45
-#: ../lib/vector/Vlib/ascii.c:428 ../lib/vector/Vlib/write_pg.c:666
-msgid "Unable to describe table <%s>"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:91
-#, c-format
-msgid "Array of values to select from column <%s> is empty"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:107 ../lib/db/dbmi_client/copy_tab.c:127
-#: ../lib/db/dbmi_client/db.c:41 ../lib/vector/Vlib/ascii.c:404
-#: ../lib/vector/Vlib/write_ogr.c:193 ../lib/vector/Vlib/write_pg.c:2910
-#, c-format
-msgid "Unable to start driver <%s>"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:151
-#, c-format
-msgid "Unable to get list tables in database <%s>"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:189
-#, c-format
-msgid "Table <%s> already exists in database and will be overwritten"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:194
-#, c-format
-msgid "Table <%s> already exists in database <%s>"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:242 ../lib/db/dbmi_client/copy_tab.c:319
-#: ../lib/db/dbmi_client/table.c:110 ../lib/vector/Vlib/write_ogr.c:211
-#, c-format
-msgid "Unable to open select cursor: '%s'"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:274
-#, c-format
-msgid "Column <%s> is not integer"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:294
-#, c-format
-msgid "Unable to create table <%s>"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:338 ../lib/vector/Vlib/write_ogr.c:587
-#: ../lib/vector/Vlib/write_pg.c:2017
-#, c-format
-msgid "Unable to fetch data from table <%s>"
-msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:394
-#, c-format
-msgid "Unknown column type (column <%s>)"
-msgstr ""
-#: ../lib/db/dbmi_client/delete_tab.c:40 ../lib/db/dbmi_client/table.c:46
-#, c-format
-msgid "Unable open database <%s> by driver <%s>"
-msgstr ""
-#: ../lib/db/dbmi_client/delete_tab.c:53
-#, c-format
-msgid "Unable to drop table: '%s'"
-msgstr ""
-#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
-#: ../lib/db/dbmi_client/select.c:288
-msgid "Missing column name"
-msgstr ""
-#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
-msgid "Missing key column name"
-msgstr ""
-#: ../lib/db/dbmi_client/select.c:317 ../lib/vector/Vlib/cats.c:603
-#, c-format
-msgid "Unable select records from table <%s>"
-msgstr ""
-#: ../lib/db/dbmi_client/select.c:333
-msgid "Key column type is not integer"
-msgstr ""
-#: ../lib/nviz/map_obj.c:59
-msgid "Maximum surfaces loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:88
-msgid "Maximum vector line maps loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
-#, c-format
-msgid "Error loading vector map <%s>"
-msgstr ""
-#: ../lib/nviz/map_obj.c:116
-msgid "Maximum vector point maps loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:143
-msgid "Maximum volumes loaded!"
-msgstr ""
-#: ../lib/nviz/map_obj.c:152
-#, c-format
-msgid "Error loading 3d raster map <%s>"
-msgstr ""
-#: ../lib/nviz/map_obj.c:160
-msgid "Nviz_new_map_obj(): unsupported data type"
-msgstr ""
-#: ../lib/nviz/lights.c:171
-msgid "Unable to define new light"
-msgstr ""
-#: ../lib/nviz/nviz.c:128
-#, c-format
-msgid "Invalid color (%s), using \"white\" as default"
-msgstr ""
-#: ../lib/nviz/position.c:56
-msgid "Unable to set focus"
-msgstr ""
-#: ../lib/nviz/render.c:39
-#, c-format
-msgid "Unable to get function address for %s"
-msgstr ""
-#: ../lib/nviz/render.c:163
-msgid "Bad server connection"
-msgstr ""
-#: ../lib/nviz/render.c:169
-msgid "Unable to get visual info"
-msgstr ""
-#: ../lib/nviz/render.c:176
-msgid "Unable to create rendering context"
-msgstr ""
-#: ../lib/nviz/render.c:225
-#, c-format
-msgid "Unable to choose pixel format (CGL error = %d)"
-msgstr ""
-#: ../lib/nviz/render.c:231
-#, c-format
-msgid "Unable to create context (CGL error = %d)"
-msgstr ""
-#: ../lib/nviz/render.c:266
-msgid "Unable to register window class"
-msgstr ""
-#: ../lib/nviz/render.c:275
-msgid "Unable to create window"
-msgstr ""
-#: ../lib/nviz/render.c:323
-#, c-format
-msgid "Unable to set current context (CGL error = %d)"
-msgstr ""
-#: ../lib/nviz/render.c:361
-#, c-format
-msgid "Incomplete framebuffer status (status = %d)"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:103
-msgid "input='-' must be used when stdin is specified"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:105
-msgid "stdin must be string or buffer, not PIPE"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:108
-msgid "stdin must be used when input='-'"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:110
-msgid "You cannot merge stdout and stderr and not capture them"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:112
-msgid "stdout argument not allowed, it could be overridden"
-msgstr ""
-#: ../lib/python/gunittest/gmodules.py:114
-msgid "stderr argument not allowed, it could be overridden"
-msgstr ""
-#: ../lib/python/exceptions/__init__.py:68
-#, python-format
-msgid "Module run %s %s ended with error"
-msgstr ""
-#: ../lib/python/exceptions/__init__.py:69
-#, python-format
-msgid ""
-"\n"
-"Process ended with non-zero return code %s"
-msgstr ""
-#: ../lib/python/exceptions/__init__.py:71
-#, python-format
-msgid ""
-". See the following errors:\n"
-"%s"
-msgstr ""
-#: ../lib/python/exceptions/__init__.py:75
-msgid ". See errors in the (error) output."
-msgstr ""
-#: ../lib/python/script/vector.py:88
-#, python-format
-msgid "Database connection not defined for layer %s"
-msgstr ""
-#: ../lib/python/script/vector.py:230
-#, python-format
-msgid "Missing layer %(layer)d in vector map <%(map)s>"
-msgstr ""
-#: ../lib/python/script/vector.py:245
-msgid "vector_db_select() failed"
-msgstr ""
-#: ../lib/python/script/vector.py:353
-#, python-brace-format
-msgid "Number of given vector maps ({m}) differs from number of layers ({l})"
-msgstr ""
-#: ../lib/python/script/vector.py:415
-msgid ""
-"v.what output is not valid JSON format:\n"
-" {ret}"
-msgstr ""
-#: ../lib/python/script/raster3d.py:92
-#, python-format
-msgid "An error occurred while running r3.mapcalc with expression: %s"
-msgstr ""
-#: ../lib/python/script/array.py:157 ../lib/python/script/array.py:207
-#: ../lib/python/script/array.py:254 ../lib/python/script/array.py:305
-#: ../lib/python/script/array.py:356 ../lib/python/script/array.py:398
-#, python-format
-msgid "Invalid kind <%s>"
-msgstr ""
-#: ../lib/python/script/array.py:160 ../lib/python/script/array.py:210
-#: ../lib/python/script/array.py:308 ../lib/python/script/array.py:359
-#, python-format
-msgid "Invalid size <%d>"
-msgstr ""
-#: ../lib/python/script/array.py:197
-msgid ""
-"grass.script.array.read is deprecated and does not work on MS Windows, pass "
-"raster name in the constructor"
-msgstr ""
-#: ../lib/python/script/array.py:247 ../lib/python/script/array.py:392
-#, python-format
-msgid "Invalid FP size <%d>"
-msgstr ""
-#: ../lib/python/script/array.py:251 ../lib/python/script/array.py:395
-#, python-format
-msgid "Invalid integer size <%d>"
-msgstr ""
-#: ../lib/python/script/array.py:346
-msgid ""
-"grass.script.array3d.read is deprecated and does not work on MS Windows, "
-"pass 3D raster name in the constructor"
-msgstr ""
-#: ../lib/python/script/db.py:153
-#, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
-msgstr ""
-#: ../lib/python/script/db.py:163
-msgid "Fetching data failed"
-msgstr ""
-#: ../lib/python/script/raster.py:51
-#, python-format
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
-msgstr ""
-#: ../lib/python/script/raster.py:110
-#, python-format
-msgid "An error occurred while running r.mapcalc with expression: %s"
-msgstr ""
-#: ../lib/python/script/raster.py:189
-msgid "No data"
-msgstr ""
-#: ../lib/python/script/raster.py:197
-msgid "value"
-msgstr ""
-msgid "label"
-msgstr ""
-msgid "color"
-msgstr ""
-#: ../lib/python/script/task.py:58
-msgid "unknown"
-msgstr ""
-#: ../lib/python/script/task.py:169
-#, python-format
-msgid "Parameter element '%(element)s' not found: '%(value)s'"
-msgstr ""
-#: ../lib/python/script/task.py:184
-#, python-format
-msgid "Flag not found: %s"
-msgstr ""
-#: ../lib/python/script/task.py:203
-#, python-format
-msgid "Parameter '%(name)s' (%(desc)s) is missing."
-msgstr ""
-#: ../lib/python/script/task.py:236
-msgid "<required>"
-msgstr ""
-#: ../lib/python/script/task.py:496 ../lib/python/script/task.py:500
-#, python-format
-msgid ""
-"Unable to fetch interface description for command '%(cmd)s'.\n"
-"\n"
-"Details: %(det)s"
-msgstr ""
-#: ../lib/python/script/task.py:523
-msgid "Cannot parse interface description of<{name}> module: {error}"
-msgstr ""
-#: ../lib/python/script/core.py:67
-msgid "Cannot find the executable {0}"
-msgstr ""
-#: ../lib/python/script/core.py:307
-#, python-format
-msgid ""
-"To run the module <%s> add underscore at the end of the option <%s> to avoid"
-" conflict with Python keywords. Underscore at the beginning is depreciated "
-"in GRASS GIS 7.0 and will be removed in version 7.1."
-msgstr ""
-#: ../lib/python/script/core.py:987
-msgid "Mixing value types. Will try to compare after integer conversion"
-msgstr ""
-#: ../lib/python/script/core.py:1188
-#, python-format
-msgid "Element type should be \"cell\" and not \"%s\""
-msgstr ""
-#: ../lib/python/script/core.py:1217 ../lib/python/script/core.py:1282
-#, python-format
-msgid "Element type should be \"raster\" and not \"%s\""
-msgstr ""
-#: ../lib/python/script/core.py:1298 ../lib/python/temporal/gui_support.py:58
-#, python-format
-msgid "Invalid element '%s'"
-msgstr ""
-#: ../lib/python/script/core.py:1437
-msgid "Unable to list mapsets"
-msgstr ""
-#: ../lib/python/script/core.py:1476
-#, python-format
-msgid "Location <%s> already exists. Operation canceled."
-msgstr ""
-#: ../lib/python/script/core.py:1479
-#, python-format
-msgid "Location <%s> already exists and will be overwritten"
-msgstr ""
-#: ../lib/python/script/core.py:1603
-msgid "Debug level {0}"
-msgstr ""
-#: ../lib/python/script/core.py:1606
-msgid "WARNING: Ignoring unsupported debug level (must be >=0 and <=5). {0}\n"
-msgstr ""
-#: ../lib/python/script/core.py:1622
-#, python-format
-msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
-msgstr ""
-#: ../lib/python/script/core.py:1631
-#, python-format
-msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
-msgstr ""
-#: ../lib/python/pygrass/utils.py:277
-msgid "Vector doesn't contain points"
-msgstr ""
-#: ../lib/python/pygrass/errors.py:17
-msgid "The map is close!"
-msgstr ""
-#: ../lib/python/pygrass/errors.py:28
-msgid "The self.c_mapinfo pointer must be correctly initiated"
-msgstr ""
-#: ../lib/python/pygrass/raster/abstract.py:275
-msgid "Mode type: {0} not supported ('r', 'w')"
-msgstr ""
-#: ../lib/python/pygrass/raster/abstract.py:286
-msgid "Overwrite type: {0} not supported (True/False)"
-msgstr ""
-#: ../lib/python/pygrass/raster/abstract.py:299
-#: ../lib/python/pygrass/vector/abstract.py:97
-msgid "Map name {0} not valid"
-msgstr ""
-#: ../lib/python/pygrass/raster/category.py:69
-msgid "Raster type: {0} not supported"
-msgstr ""
-#: ../lib/python/pygrass/raster/category.py:156
-msgid "Error executing: Rast_get_ith_cat"
-msgstr ""
-#: ../lib/python/pygrass/raster/category.py:184
-msgid "Null value detected"
-msgstr ""
-#: ../lib/python/pygrass/raster/category.py:186
-msgid "Error executing: Rast_set_cat"
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:209
-msgid "The map does not exist, I can't open in 'r' mode"
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:214
-msgid "Raster map <{0}> already exists and will be not overwritten"
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:218
-msgid "Raster type not defined"
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:321
-msgid "Mode type: {0} not supported ('r', 'w','rw')"
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:341
-#, python-format
-msgid "Index out of range: %r."
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:530
-msgid "Raster map <{0}> already exists. Use overwrite."
-msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:561
-msgid "Raster map <{0}> does not exist"
-msgstr ""
-#: ../lib/python/pygrass/vector/__init__.py:810
-#, python-format
-msgid "Unable to read line of feature %i"
-msgstr ""
-#: ../lib/python/pygrass/vector/__init__.py:899
-#, python-format
-msgid "Unable to read area with id %i"
-msgstr ""
-#: ../lib/python/pygrass/vector/table.py:1033
-#, python-format
-msgid "Deleting table <%s> which is attached to following map(s):"
-msgstr ""
-#: ../lib/python/pygrass/vector/table.py:1037
-msgid "You must use the force flag to actually remove it. Exiting."
-msgstr ""
-#: ../lib/python/pygrass/modules/grid/grid.py:553
-msgid "Execution of subprocesses was not successful"
-msgstr ""
-#: ../lib/python/temporal/c_libraries_interface.py:596
-#: ../lib/python/temporal/c_libraries_interface.py:613
-msgid "Unable to read range file"
-msgstr ""
-#: ../lib/python/temporal/c_libraries_interface.py:691
-#, python-format
-msgid "Unable to load range of 3D raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/c_libraries_interface.py:747
-#: ../lib/vector/Vlib/map.c:192 ../lib/vector/Vlib/map.c:202
-#: ../lib/vector/Vlib/map.c:274 ../lib/vector/Vlib/open.c:301
-#: ../lib/vector/Vlib/open.c:437 ../lib/ogsf/gp3.c:62 ../lib/ogsf/gp3.c:196
-#: ../lib/ogsf/gv3.c:66 ../lib/ogsf/gv3.c:338
-msgid "Unable to open vector map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:251
-#, python-format
-msgid "Unable to read timestamp file for raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:275
-#, python-format
-msgid "Unable to create timestamp file for raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:280
-#, python-format
-msgid "Invalid datetime in timestamp for raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:285
-#: ../lib/python/temporal/space_time_datasets.py:633
-msgid "Internal error"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:302
-#: ../lib/python/temporal/space_time_datasets.py:647
-#, python-format
-msgid "Unable to remove timestamp for raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:599
-#, python-format
-msgid "Unable to read timestamp file for 3D raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:623
-#, python-format
-msgid "Unable to create timestamp file for 3D raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:628
-#, python-format
-msgid "Invalid datetime in timestamp for 3D raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:907
-#, python-format
-msgid "Unable to read timestamp file for vector map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:930
-#, python-format
-msgid "Unable to create timestamp file for vector map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:935
-#, python-format
-msgid "Invalid datetime in timestamp for vector map <%s>"
-msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:951
-#, python-format
-msgid "Unable to remove timestamp for vector map <%s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:167
-#: ../lib/python/temporal/abstract_space_time_dataset.py:301
-#, python-format
-msgid "Unknown temporal type \"%s\""
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:294
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1062
-#, python-format
-msgid "Wrong granularity: \"%s\""
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:322
-#, python-format
-msgid "Unsupported temporal unit: %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:372
-#, python-format
-msgid "Created register table <%s> for space time %s  dataset <%s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:690
-#: ../lib/python/temporal/abstract_space_time_dataset.py:932
-msgid "The space time datasets must be of the same temporal type"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:695
-#: ../lib/python/temporal/abstract_space_time_dataset.py:937
-msgid "The temporal map type of the sample dataset must be interval"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1499
-#, python-format
-msgid "Unable to get map ids from register table <%s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1609
-#, python-format
-msgid ""
-"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
-"The mapset of the dataset does not match the current mapset"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1616
-#: ../lib/python/temporal/datetime_math.py:451
-#, python-format
-msgid "Wrong granularity format: %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1778
-#, python-format
-msgid ""
-"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1880
-#, python-format
-msgid ""
-"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database."
-" The mapset of the dataset does not match the current mapset"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1889
-msgid "Renaming of space time datasets is not supported for PostgreSQL."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1954
-#, python-format
-msgid "Delete space time %s  dataset <%s> from temporal database"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1960
-#: ../lib/python/temporal/abstract_map_dataset.py:841
-#, python-format
-msgid ""
-"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
-"database. The mapset of the dataset does not match the current mapset"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1973
-#, python-format
-msgid "Drop map register table: %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2028
-msgid "Error in register table request"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2057
-#, python-format
-msgid ""
-"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
-"the dataset does not match the current mapset"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2066
-msgid ""
-"Only a map that was inserted in the temporal database can be registered in a"
-" space time dataset"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2089
-#, python-format
-msgid "Map <%(id)s> with layer %(l)s has invalid time"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2093
-#, python-format
-msgid "Map <%s> has invalid time"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2111
-#, python-format
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
-"%(l)s are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2117
-#, python-format
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2132
-#, python-format
-msgid "Set temporal unit for space time %s dataset <%s> to %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2142
-#, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
-"layer %(l)s are different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2148
-#, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
-"different"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2154
-msgid "Only maps from the same mapset can be registered"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2159
-#, python-format
-msgid "Map <%(map)s> with layer %(l)s is already registered."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2163
-#, python-format
-msgid "Map <%s> is already registered."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2211
-#, python-format
-msgid ""
-"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
-"temporal database. The mapset of the dataset does not match the current "
-"mapset"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2224
-#, python-format
-msgid ""
-"Map <%(map)s> with layer %(l)s is not registered in space time dataset "
-"<%(base)s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2230
-#, python-format
-msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2285
-#: ../lib/python/temporal/abstract_map_dataset.py:424
-#: ../lib/python/temporal/abstract_map_dataset.py:520
-#: ../lib/python/temporal/abstract_dataset.py:426
-#: ../lib/python/temporal/abstract_dataset.py:469
-#, python-format
-msgid ""
-"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2291
-#, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of "
-"<%s>"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:85
-#, python-format
-msgid "Unable to import/link raster map <%s> from file %s."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:96
-#, python-format
-msgid "Unable to set the color rules for raster map <%s>."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:120
-#, python-format
-msgid "Unable to unpack raster map <%s> from file %s."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:144
-#, python-format
-msgid "Unable to import vector map <%s> from file %s."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:168
-#, python-format
-msgid "Unable to unpack vector map <%s> from file %s."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:207
-#, python-format
-msgid "Space time raster dataset archive <%s> not found"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:210
-#, python-format
-msgid "Extraction directory <%s> not found"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:216
-#, python-format
-msgid "Checking validity of input file (size: %0.1f MB). Make take a while..."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:223
-#, python-format
-msgid "Unable to find init file <%s>"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:225
-#, python-format
-msgid "Unable to find list file <%s>"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:227
-#, python-format
-msgid "Unable to find projection file <%s>"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:229
-msgid "Extracting data..."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:269
-msgid "Projection information does not match. Proceeding..."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:273
-msgid ""
-"Difference between PROJ_INFO file of imported map and of current location:\n"
-"{diff}"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:276
-msgid "Projection information does not match. Aborting."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:293
-#, python-format
-msgid "Unable to create location %(l)s. Reason: %(e)s"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:301
-#, python-format
-msgid "Unable to switch to location %s"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:306
-#, python-format
-msgid "Unable to create default temporal database in new location %s"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:380
-#, python-format
-msgid "Key words %(t)s, %(s)s or %(n)s not found in init file."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:386
-msgid "Number of maps mismatch in init and list file."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:397
-msgid "The archive file is of wrong space time dataset type"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:405
-#, python-format
-msgid "Unable to find GeoTIFF raster file <%s> in archive."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:411
-#, python-format
-msgid "Unable to find AAIGrid raster file <%s> in archive."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:417
-#, python-format
-msgid "Unable to find GML vector file <%s> in archive."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:426
-#, python-format
-msgid "Unable to find GRASS package file <%s> in archive."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:429
-msgid "Unsupported input format"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:435
-#, python-format
-msgid ""
-"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
-"overwrite flag."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:456
-#, python-format
-msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:468
-#, python-format
-msgid "Key word %s not found in init file."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:473
-#, python-format
-msgid "Create space time %s dataset."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:502
-msgid "Switching to original location failed"
-msgstr ""
-#: ../lib/python/temporal/list_stds.py:208
-msgid "Empty map list"
-msgstr ""
-#: ../lib/python/temporal/list_stds.py:219
-msgid "Empty entry in map list, this should not happen"
-msgstr ""
-#: ../lib/python/temporal/temporal_vector_algebra.py:386
-#, python-format
-msgid ""
-"Error vector maps with basename %s exist. Use --o flag to overwrite existing"
-" file"
-msgstr ""
-#: ../lib/python/temporal/temporal_vector_algebra.py:419
-#, python-format
-msgid ""
-"Error starting %s : \n"
-"%s"
-msgstr ""
-#: ../lib/python/temporal/temporal_vector_algebra.py:492
-#, python-format
-msgid ""
-"Error vector map %s exist in temporal database. Use overwrite flag.  : \n"
-"%s"
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:63
-#: ../lib/python/temporal/open_stds.py:119
-#, python-format
-msgid "Unknown type: %s"
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:69
-#, python-format
-msgid "Space time %(sp)s dataset <%(name)s> not found"
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:108
-msgid "Space time datasets can only be created in the current mapset"
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:125
-#, python-format
-msgid ""
-"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
-"overwrite flag."
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:160
-#, python-format
-msgid ""
-"Overwriting space time %(sp)s dataset <%(name)s> and unregistering all maps"
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:168
-#, python-format
-msgid "Creating a new space time %s dataset"
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:211
-#: ../lib/python/temporal/extract.py:131 ../lib/python/temporal/mapcalc.py:239
-#, python-format
-msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:815
-msgid ""
-"Spatio-temporal topological operators are not supported in granularity "
-"algebra mode"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:853
-msgid "All input space time datasets must have a valid temporal topology."
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:862
-msgid "All input space time datasets must have the same temporal type."
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:1113
-#, python-format
-msgid "Removing un-needed or empty %s maps"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:1168
-#, python-format
-msgid "Space time %s dataset <%s> not found"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:1196
-#: ../lib/python/temporal/temporal_algebra.py:1200
-#, python-format
-msgid ""
-"Wrong temporal type of space time dataset <%s>"
-"                                       <%s> time is required"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:1220
-msgid "Wrong type of input "
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2186
-#, python-format
-msgid ""
-"The resulting space time dataset type <%(a)s> is different from the "
-"requested type <%(b)s>"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2192
-msgid ""
-"Maps that should be registered in the resulting space time dataset have "
-"different types."
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2395
-#: ../lib/python/temporal/temporal_raster_base_algebra.py:777
-#, python-format
-msgid "%s map <%s> not found in GRASS spatial database"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2401
-msgid ""
-"Wrong map type. TMAP only supports single maps that are registered in the "
-"temporal GRASS database"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2429
-msgid "Merging empty map lists"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2432
-msgid "First Map list is empty, can't merge it. Return only last map list"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2435
-msgid "Second Map list is empty, can't merge it. Return only first map list"
-msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:2443
-msgid "Space time datasets to merge must have the same temporal type"
-msgstr ""
-#: ../lib/python/temporal/temporal_raster_base_algebra.py:690
-#, python-format
-msgid "Error computing map <%s>"
-msgstr ""
-#: ../lib/python/temporal/base.py:380
-msgid "Object not found in the temporal database"
-msgstr ""
-#: ../lib/python/temporal/base.py:462 ../lib/python/temporal/base.py:513
-msgid "Missing identifier"
-msgstr ""
-#: ../lib/python/temporal/base.py:621
-msgid "Wrong identifier, the mapset is missing"
-msgstr ""
-#: ../lib/python/temporal/univar_statistics.py:62
-#: ../lib/python/temporal/univar_statistics.py:178
-#, python-format
-msgid "Space time %(sp)s dataset <%(i)s> is empty"
-msgstr ""
-#: ../lib/python/temporal/univar_statistics.py:101
-#, python-format
-msgid "Unable to get statistics for raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/univar_statistics.py:104
-#, python-format
-msgid "Unable to get statistics for 3d raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/univar_statistics.py:168
-#, python-format
-msgid "Space time %(sp)s dataset <%(i)s> not found"
-msgstr ""
-#: ../lib/python/temporal/univar_statistics.py:222
-#, python-format
-msgid "Unable to get statistics for vector map <%s>"
-msgstr ""
-#: ../lib/python/temporal/register.py:82 ../lib/python/temporal/register.py:85
-#, python-format
-msgid "%s= and %s= are mutually exclusive"
-msgstr ""
-#: ../lib/python/temporal/register.py:89
-#, python-format
-msgid "%s= and the %s flag are mutually exclusive"
-msgstr ""
-#: ../lib/python/temporal/register.py:93
-msgid "The increment option requires the start option"
-msgstr ""
-#: ../lib/python/temporal/register.py:96
-msgid "The interval flag requires the start option"
-msgstr ""
-#: ../lib/python/temporal/register.py:99
-#, python-format
-msgid "Please specify %s= and %s="
-msgstr ""
-#: ../lib/python/temporal/register.py:103
-#, python-format
-msgid "Please specify %s= or %s="
-msgstr ""
-#: ../lib/python/temporal/register.py:114
-#, python-format
-msgid ""
-"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
-"relative unit set for %(sp)s maps"
-msgstr ""
-#: ../lib/python/temporal/register.py:175
-msgid ""
-"The increment option will be ignored because of time stamps in input file"
-msgstr ""
-#: ../lib/python/temporal/register.py:179
-msgid "The interval flag will be ignored because of time stamps in input file"
-msgstr ""
-#: ../lib/python/temporal/register.py:187
-msgid "Gathering map information..."
-msgstr ""
-#: ../lib/python/temporal/register.py:197
-#, python-format
-msgid "Unable to update %(t)s map <%(id)s>. The map does not exist."
-msgstr ""
-#: ../lib/python/temporal/register.py:215
-#, python-format
-msgid ""
-"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
-"timestamp and the start time is not set."
-msgstr ""
-#: ../lib/python/temporal/register.py:221
-#, python-format
-msgid ""
-"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
-"start time is not set."
-msgstr ""
-#: ../lib/python/temporal/register.py:229
-#, python-format
-msgid "%(u)s= can only be set for relative time"
-msgstr ""
-#: ../lib/python/temporal/register.py:232
-#, python-format
-msgid "%(u)s= must be set in case of relative time stamps"
-msgstr ""
-#: ../lib/python/temporal/register.py:245
-#, python-format
-msgid ""
-"Map is already registered in temporal database. Unable to update %(t)s map "
-"<%(id)s> with layer %(l)s. Overwrite flag is not set."
-msgstr ""
-#: ../lib/python/temporal/register.py:252
-#, python-format
-msgid ""
-"<%(id)s>. Overwrite flag is not set."
-msgstr ""
-#: ../lib/python/temporal/register.py:276
-#, python-format
-msgid ""
-"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are"
-" different."
-msgstr ""
-#: ../lib/python/temporal/register.py:282
-#, python-format
-msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
-msgstr ""
-#: ../lib/python/temporal/register.py:330
-msgid "Registering maps in the temporal database..."
-msgstr ""
-#: ../lib/python/temporal/register.py:337
-msgid "Registering maps in the space time dataset..."
-msgstr ""
-#: ../lib/python/temporal/register.py:346
-msgid "Updating space time dataset..."
-msgstr ""
-#: ../lib/python/temporal/register.py:399
-#: ../lib/python/temporal/register.py:406
-#, python-format
-msgid "Unable to convert string \"%s\"into a datetime object"
-msgstr ""
-#: ../lib/python/temporal/register.py:414
-#: ../lib/python/temporal/register.py:419
-msgid "Error occurred in increment computation"
-msgstr ""
-#: ../lib/python/temporal/register.py:422
-#, python-format
-msgid ""
-"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s -"
-" %(end)s"
-msgstr ""
-#: ../lib/python/temporal/register.py:427
-#, python-format
-msgid "Set absolute valid time for map <%s> to %s - %s"
-msgstr ""
-#: ../lib/python/temporal/register.py:444
-#, python-format
-msgid ""
-"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
-msgstr ""
-#: ../lib/python/temporal/register.py:449
-#, python-format
-msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:127
-#, python-format
-msgid "Aggregating %s raster maps"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:141
-#, python-format
-msgid ""
-"Raster map <%(name)s> is already in temporal database, use overwrite flag to"
-" overwrite"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:146
-#, python-format
-msgid "Computing aggregation of maps between %(st)s - %(end)s"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:171
-msgid "Error occurred in r.series computation"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:280
-#, python-format
-msgid "Aggregating %(len)i raster maps from %(start)s to %(end)s"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:301
-#, python-format
-msgid ""
-"Unable to perform aggregation. Output raster map <%(name)s> exists and "
-"overwrite flag was not set"
-msgstr ""
-#: ../lib/python/temporal/aggregation.py:319
-#, python-format
-msgid ""
-"The limit of open files (%i) was reached (%i). The module r.series will be "
-"run with flag z, to avoid open files limit exceeding."
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:256
-#: ../lib/python/temporal/datetime_math.py:273
-#, python-format
-msgid "Wrong increment format: %s"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:771
-msgid "Time string seems to specify relative time"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:783
-msgid "Dates Before Christ (BC) are not supported"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:787
-msgid "Time zones are not supported"
-msgstr ""
-#: ../lib/python/temporal/datetime_math.py:807
-#, python-format
-msgid "Unable to parse time string: %s"
-msgstr ""
-#: ../lib/python/temporal/sampling.py:95
-#: ../lib/python/temporal/sampling.py:100
-#, python-format
-msgid "Dataset <%s> not found in temporal database"
-msgstr ""
-#: ../lib/python/temporal/extract.py:60
-msgid "You need to specify the base name of new created maps"
-msgstr ""
-#: ../lib/python/temporal/extract.py:138
-#, python-format
-msgid "Applying r.mapcalc expression: \"%s\""
-msgstr ""
-#: ../lib/python/temporal/extract.py:143
-#, python-format
-msgid "Applying r3.mapcalc expression: \"%s\""
-msgstr ""
-#: ../lib/python/temporal/extract.py:148
-#, python-format
-msgid "Applying v.extract where statement: \"%s\""
-msgstr ""
-#: ../lib/python/temporal/extract.py:176
-msgid "Error in computation process"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:123
-msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:529
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:661
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:766
-msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:838
-msgid "Projections are different. Unable to compute cover for spatial extents"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:1690
-msgid "Volume computation is not supported for LL projections"
-msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:1708
-msgid "Area computation is not supported for LL projections"
-msgstr ""
-#: ../lib/python/temporal/temporal_granularity.py:1054
-#: ../lib/python/temporal/temporal_granularity.py:1096
-msgid ""
-"Output granularity seems not to be valid. Please use one of the following "
-"values : {gr}"
-msgstr ""
-#: ../lib/python/temporal/temporal_granularity.py:1058
-#: ../lib/python/temporal/temporal_granularity.py:1099
-#: ../lib/python/temporal/temporal_granularity.py:1172
-msgid "Invalid absolute granularity"
-msgstr ""
-#: ../lib/python/temporal/temporal_granularity.py:1169
-msgid "Probably you need to invert 'from_gran' and 'to_gran'"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:350
-#, python-format
-msgid ""
-"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:357
-#, python-format
-msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:365
-#, python-format
-msgid ""
-"End time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:372
-#, python-format
-msgid "End time must be of type datetime for %(type)s map <%(id)s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:381
-#, python-format
-msgid ""
-"End time must be greater than start time for %(type)s map <%(id)s> with "
-"layer: %(l)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:389
-#: ../lib/python/temporal/abstract_map_dataset.py:482
-#, python-format
-msgid "End time must be greater than start time for %(type)s map <%(id)s>"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:460
-#, python-format
-msgid ""
-"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
-"%(l)s: %(u)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:467
-#, python-format
-msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:476
-#, python-format
-msgid ""
-"End time must be greater than start time for %(typ)s map <%(id)s> with layer"
-" %(l)s"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:800
-#, python-format
-msgid ""
-"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is"
-" greater than end time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:806
-#, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:812
-#, python-format
-msgid "Map <%s> has incorrect start time"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:859
-#, python-format
-msgid "Delete %s dataset <%s> from temporal database"
-msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:909
-#, python-format
-msgid ""
-"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
-msgstr ""
-#: ../lib/python/temporal/factory.py:51
-#, python-format
-msgid "Unknown dataset type: %s"
-msgstr ""
-#: ../lib/python/temporal/abstract_dataset.py:386
-#, python-format
-msgid ""
-"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database."
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:107
-#, python-format
-msgid "Unable to export raster map <%s>"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:118
-#, python-format
-msgid "Unable to export color rules for raster map <%s> r.out.gdal"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:142
-#, python-format
-msgid "Unable to export raster map <%s> with r.pack"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:170
-#, python-format
-msgid "Unable to export vector map <%s> as GML with v.out.ogr"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:203
-#, python-format
-msgid "Unable to export vector map <%s> with v.pack"
-msgstr ""
-#: ../lib/python/temporal/stds_export.py:229
-#, python-format
-msgid "Unable to export raster map <%s> with r3.pack"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:109
-msgid "Starting spatio-temporal sampling..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:111
-msgid "Starting temporal sampling..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:128
-msgid "No samples found for map calculation"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:155
-msgid ""
-"Found more than a single map in a sample granule. Only the first map is used"
-" for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:173
-msgid "No maps registered in input dataset"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:189
-msgid "Starting mapcalc computation..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:259
-#, python-format
-msgid "Apply mapcalc expression: \"%s\""
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:278
-msgid "Error while mapcalc computation"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:284
-msgid "Starting map registration in temporal database..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:323
-msgid "Removing {}/{} ({}%) maps because empty..."
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:441 ../lib/python/temporal/mapcalc.py:447
-#: ../lib/python/temporal/mapcalc.py:453 ../lib/python/temporal/mapcalc.py:459
-#: ../lib/python/temporal/mapcalc.py:465 ../lib/python/temporal/mapcalc.py:471
-#: ../lib/python/temporal/mapcalc.py:477 ../lib/python/temporal/mapcalc.py:483
-#: ../lib/python/temporal/mapcalc.py:489 ../lib/python/temporal/mapcalc.py:524
-#: ../lib/python/temporal/mapcalc.py:533 ../lib/python/temporal/mapcalc.py:542
-#: ../lib/python/temporal/mapcalc.py:551 ../lib/python/temporal/mapcalc.py:560
-#: ../lib/python/temporal/mapcalc.py:569 ../lib/python/temporal/mapcalc.py:578
-#: ../lib/python/temporal/mapcalc.py:587 ../lib/python/temporal/mapcalc.py:596
-#, python-format
-msgid "The temporal operators <%s> support only absolute time."
-msgstr ""
-#: ../lib/python/temporal/core.py:603
-msgid ""
-"Unable to initialize the temporal DBMI interface. Please use t.connect to "
-"specify the driver and the database string"
-msgstr ""
-#: ../lib/python/temporal/core.py:672
-#, python-format
-msgid ""
-"Unable to receive temporal database metadata.\n"
-"Current temporal database info:%(info)s"
-msgstr ""
-#: ../lib/python/temporal/core.py:677
-#, python-format
-msgid ""
-"Unsupported temporal database: version mismatch.\n"
-" %(backup)s Supported temporal API version is: %(api)i.\n"
-"Please update your GRASS GIS installation.\n"
-msgstr ""
-#: ../lib/python/temporal/core.py:685
-#, python-format
-msgid ""
-" %(backup)sSupported temporal database version is: %(tdb)i\n"
-msgstr ""
-#: ../lib/python/temporal/core.py:773
-#, python-format
-msgid "Creating temporal database: %s"
-msgstr ""
-#: ../lib/python/temporal/core.py:782
-#, python-format
-msgid ""
-"Unable to create SQLite temporal database\n"
-"Exception: %s\n"
-"Please use t.connect to set a read- and writable temporal database path"
-msgstr ""
-#: ../lib/python/temporal/core.py:947
-msgid "Unable to mogrify sql statement. "
-msgstr ""
-#: ../lib/python/temporal/core.py:969
-msgid "Unable to check table. "
-msgstr ""
-#: ../lib/python/temporal/core.py:985
-msgid "Unable to execute sql statement. "
-msgstr ""
-#: ../lib/python/temporal/core.py:995
-msgid "Unable to fetch one. "
-msgstr ""
-#: ../lib/python/temporal/core.py:1005
-msgid "Unable to fetch all. "
-msgstr ""
-#: ../lib/python/temporal/core.py:1022
-msgid "Unable to execute transaction. "
-msgstr ""
-#: ../lib/python/temporal/core.py:1126
-#, python-format
-msgid ""
-"Unable to connect to %(db)s database: %(string)s\n"
-"Exception: \"%(ex)s\"\n"
-"Please use t.connect to set a read- and writable temporal database backend"
-msgstr ""
-#: ../lib/python/temporal/core.py:1286
-#, python-format
-msgid ""
-"Unable to execute :\n"
-" %(sql)s"
-msgstr ""
-#: ../lib/python/temporal/core.py:1330
-#, python-format
-msgid ""
-"Unable to execute transaction:\n"
-" %(sql)s"
-msgstr ""
-#: ../lib/psdriver/graph_set.c:199
-#, c-format
-msgid "ps: truecolor status %s"
-msgstr ""
-#: ../lib/psdriver/graph_set.c:214
-#, c-format
-msgid "ps: collecting to file '%s'"
-msgstr ""
-#: ../lib/psdriver/graph_set.c:215
-#, c-format
-msgid "ps: image size %dx%d"
-msgstr ""
-#: ../lib/init/lock.c:38
-#, c-format
-msgid "Usage: %s file pid"
-msgstr ""
-#: ../lib/init/lock.c:42
-msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-#: ../lib/init/lock.c:60
-#, c-format
-msgid "Unable to write lockfile %s (%s)"
-msgstr ""
-#: ../lib/init/grass.py:123
-msgid "WARNING"
-msgstr ""
-#: ../lib/init/grass.py:187 ../lib/gis/parser.c:621
-msgid "ERROR"
-msgstr ""
-#: ../lib/init/grass.py:188
-msgid "Exiting..."
-msgstr ""
-#: ../lib/init/grass.py:332
-msgid "Usage"
-msgstr ""
-#: ../lib/init/grass.py:333 ../lib/gis/parser_html.c:141
-#: ../lib/gis/parser_rest.c:146
-msgid "Flags"
-msgstr ""
-#: ../lib/init/grass.py:334
-msgid "print this help message"
-msgstr ""
-#: ../lib/init/grass.py:335
-msgid "show version information and exit"
-msgstr ""
-#: ../lib/init/grass.py:336
-msgid "create given database, location or mapset if it doesn't exist"
-msgstr ""
-#: ../lib/init/grass.py:337
-msgid "exit after creation of location or mapset. Only with -c flag"
-msgstr ""
-#: ../lib/init/grass.py:338
-msgid ""
-"force removal of .gislock if exists (use with care!). Only with -text flag"
-msgstr ""
-#: ../lib/init/grass.py:339
-msgid "use text based interface (skip welcome screen)"
-msgstr ""
-#: ../lib/init/grass.py:340 ../lib/init/grass.py:342 ../lib/init/grass.py:344
-msgid "and set as default"
-msgstr ""
-#: ../lib/init/grass.py:341
-msgid "use text based interface (show welcome screen)"
-msgstr ""
-#: ../lib/init/grass.py:343
-msgid "use $DEFAULT_GUI graphical user interface"
-msgstr ""
-#: ../lib/init/grass.py:345
-msgid "print GRASS configuration parameters"
-msgstr ""
-#: ../lib/init/grass.py:346
-msgid "options: arch,build,compiler,path,revision,svn_revision,version"
-msgstr ""
-#: ../lib/init/grass.py:347 ../lib/gis/parser_html.c:189
-#: ../lib/gis/parser_rest.c:179
-msgid "Parameters"
-msgstr ""
-#: ../lib/init/grass.py:348
-msgid "initial GRASS GIS database directory"
-msgstr ""
-#: ../lib/init/grass.py:349
-msgid "directory containing Locations"
-msgstr ""
-#: ../lib/init/grass.py:350
-msgid "initial GRASS Location"
-msgstr ""
-#: ../lib/init/grass.py:351
-msgid ""
-"directory containing Mapsets with one common coordinate system (projection)"
-msgstr ""
-#: ../lib/init/grass.py:352
-msgid "initial GRASS Mapset"
-msgstr ""
-#: ../lib/init/grass.py:353
-msgid "fully qualified initial Mapset directory"
-msgstr ""
-#: ../lib/init/grass.py:354
-msgid "Environment variables relevant for startup"
-msgstr ""
-#: ../lib/init/grass.py:355
-msgid "select GUI (text, gui, gtext)"
-msgstr ""
-#: ../lib/init/grass.py:356
-msgid "set html web browser for help pages"
-msgstr ""
-#: ../lib/init/grass.py:357
-msgid "set additional path(s) to local GRASS modules or user scripts"
-msgstr ""
-#: ../lib/init/grass.py:358
-msgid "set additional GISBASE for locally installed GRASS Addons"
-msgstr ""
-#: ../lib/init/grass.py:359
-msgid "shell script to be processed as batch job"
-msgstr ""
-#: ../lib/init/grass.py:360
-msgid "set Python interpreter name to override 'python'"
-msgstr ""
-#: ../lib/init/grass.py:361
-msgid "execute GRASS module or script"
-msgstr ""
-#: ../lib/init/grass.py:362
-msgid "provided executable will be executed in GRASS session"
-msgstr ""
-#: ../lib/init/grass.py:363
-msgid "GRASS module, script or any other executable"
-msgstr ""
-#: ../lib/init/grass.py:364
-msgid "parameters of the executable"
-msgstr ""
-#: ../lib/init/grass.py:365
-msgid "standard flags"
-msgstr ""
-#: ../lib/init/grass.py:390
-msgid "The APPDATA variable is not set, ask your operating system support"
-msgstr ""
-#: ../lib/init/grass.py:393
-msgid ""
-"The APPDATA variable points to directory which does not exist, ask your "
-"operating system support"
-msgstr ""
-#: ../lib/init/grass.py:440
-#, python-format
-msgid ""
-"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
-msgstr ""
-#: ../lib/init/grass.py:493
-msgid "Invalid line in RC file ({file}): '{line}' ({error})\n"
-msgstr ""
-#: ../lib/init/grass.py:499
-msgid "Empty RC file ({file})"
-msgstr ""
-#: ../lib/init/grass.py:549
-#, python-format
-msgid "GUI <%s> not supported in this version"
-msgstr ""
-#: ../lib/init/grass.py:710
-msgid "Searched for a web browser, but none found"
-msgstr ""
-#: ../lib/init/grass.py:750
-msgid ""
-"The python command does not work as expected!\n"
-"Please check your GRASS_PYTHON environment variable.\n"
-"Use the -help option for details.\n"
-msgstr ""
-#: ../lib/init/grass.py:754
-msgid "GRASS GUI not found. Please check your installation."
-msgstr ""
-#: ../lib/init/grass.py:756
-msgid ""
-"{}\n"
-"Switching to text based interface mode.\n"
-"\n"
-"Hit RETURN to continue.\n"
-msgstr ""
-#: ../lib/init/grass.py:765
-msgid ""
-"It appears that the X Windows system is not active.\n"
-"A graphical based user interface is not supported.\n"
-"(DISPLAY variable is not set.)\n"
-"\n"
-msgstr ""
-#: ../lib/init/grass.py:858 ../lib/gis/make_mapset.c:66
-#, c-format, python-format
-msgid "Location <%s> doesn't exist"
-msgstr ""
-#: ../lib/init/grass.py:860
-#, python-format
-msgid "<%s> is not a valid GRASS Location because PERMANENT Mapset is missing"
-msgstr ""
-#: ../lib/init/grass.py:863
-#, python-format
-msgid ""
-"<%s> is not a valid GRASS Location because PERMANENT is not a directory"
-msgstr ""
-#: ../lib/init/grass.py:868
-#, python-format
-msgid ""
-"<%s> is not a valid GRASS Location because PERMANENT Mapset does not have a "
-"DEFAULT_WIND file (default computational region)"
-msgstr ""
-#: ../lib/init/grass.py:873
-msgid ""
-"Mapset <{mapset}> doesn't exist in GRASS Location <{loc}>. A new mapset can "
-"be created by '-c' switch."
-msgstr ""
-#: ../lib/init/grass.py:877
-#, python-format
-msgid "<%s> is not a GRASS Mapset because it is not a directory"
-msgstr ""
-#: ../lib/init/grass.py:880
-#, python-format
-msgid "<%s> is not a valid GRASS Mapset because it does not have a WIND file"
-msgstr ""
-#: ../lib/init/grass.py:884
-#, python-format
-msgid "<%s> is not a valid GRASS Mapset because its WIND file is not readable"
-msgstr ""
-#: ../lib/init/grass.py:887
-msgid ""
-"Mapset <{mapset}> or Location <{location}> is invalid for an unknown reason"
-msgstr ""
-#: ../lib/init/grass.py:950
-#, python-format
-msgid "Failed to create new location. The location <%s> already exists."
-msgstr ""
-#: ../lib/init/grass.py:957
-msgid "Missing WIND file"
-msgstr ""
-#: ../lib/init/grass.py:975
-msgid ""
-"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
-"Interactive startup needed."
-msgstr ""
-#: ../lib/init/grass.py:999
-#, python-format
-msgid ""
-"Invalid user interface specified - <%s>. Use the --help option to see valid "
-"interface names."
-msgstr ""
-#: ../lib/init/grass.py:1019
-msgid ""
-"Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.\n"
-"On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.\n"
-"To run GRASS GIS in text mode use the -text flag.\n"
-"Use '--help' for further options\n"
-"     {cmd_name} --help\n"
-"See also: https://grass.osgeo.org/{cmd_name}/manuals/helptext.html"
-msgstr ""
-#: ../lib/init/grass.py:1031
-msgid ""
-"Exit was requested in GUI.\n"
-"GRASS GIS will not start. Bye."
-msgstr ""
-#: ../lib/init/grass.py:1034
-msgid ""
-"Invalid return code from GUI startup script.\n"
-"Please advise GRASS developers of this error."
-msgstr ""
-#: ../lib/init/grass.py:1081
-msgid ""
-"Error reading data path information from g.gisenv.\n"
-"GISDBASE={gisbase}\n"
-"LOCATION_NAME={location}\n"
-"MAPSET={mapset}\n"
-"\n"
-"Check the <{file}> file."
-msgstr ""
-#: ../lib/init/grass.py:1162 ../lib/init/grass.py:1166
-msgid "Default locale settings are missing. GRASS running with C locale."
-msgstr ""
-#: ../lib/init/grass.py:1244
-#, python-format
-msgid "Path '%s' doesn't exist"
-msgstr ""
-#: ../lib/init/grass.py:1246
-#, python-format
-msgid "Path '%s' not accessible."
-msgstr ""
-#. GTC %s is mapset's folder path
-#: ../lib/init/grass.py:1251
-#, python-format
-msgid "You are not the owner of '%s'."
-msgstr ""
-#: ../lib/init/grass.py:1259
-#, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed.\n"
-"You can force launching GRASS using -f flag (note that you need permission for this operation). Have another look in the processor manager just to be sure..."
-msgstr ""
-#: ../lib/init/grass.py:1266
-#, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Forcing to launch GRASS..."
-msgstr ""
-#: ../lib/init/grass.py:1270
-#, python-format
-msgid ""
-"Unable to properly access '%s'.\n"
-"Please notify system personnel."
-msgstr ""
-#: ../lib/init/grass.py:1291
-msgid "Building user fontcap..."
-msgstr ""
-#: ../lib/init/grass.py:1350
-msgid "The SHELL variable is not set"
-msgstr ""
-#: ../lib/init/grass.py:1366
-msgid "Unsupported shell <{sh}>: {env_file}"
-msgstr ""
-#: ../lib/init/grass.py:1382
-#, python-format
-msgid ""
-"Job file <%s> has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
-"\n"
-"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
-msgstr ""
-#: ../lib/init/grass.py:1389
-#, python-format
-msgid "Change file permission to 'executable' for <%s>"
-msgstr ""
-#: ../lib/init/grass.py:1404
-#, python-format
-msgid "Executing <%s> ..."
-msgstr ""
-#: ../lib/init/grass.py:1411
-msgid ""
-"Execution of <{cmd}> failed:\n"
-"{error}"
-msgstr ""
-#: ../lib/init/grass.py:1414
-#, python-format
-msgid "Execution of <%s> finished."
-msgstr ""
-#: ../lib/init/grass.py:1444
-msgid "Unable to close GUI. {0}"
-msgstr ""
-#: ../lib/init/grass.py:1472
-#, python-format
-msgid "Welcome to GRASS GIS %s"
-msgstr ""
-#: ../lib/init/grass.py:1494
-msgid "GRASS GIS homepage:"
-msgstr ""
-#. GTC Running through: SHELL NAME
-#: ../lib/init/grass.py:1496
-msgid "This version running through:"
-msgstr ""
-#: ../lib/init/grass.py:1498
-msgid "Help is available with the command:"
-msgstr ""
-#: ../lib/init/grass.py:1499
-msgid "See the licence terms with:"
-msgstr ""
-#: ../lib/init/grass.py:1500
-msgid "See citation options with:"
-msgstr ""
-#: ../lib/init/grass.py:1503
-msgid "If required, restart the GUI with:"
-msgstr ""
-#: ../lib/init/grass.py:1505
-msgid "Start the GUI with:"
-msgstr ""
-#: ../lib/init/grass.py:1507
-msgid "When ready to quit enter:"
-msgstr ""
-#: ../lib/init/grass.py:1593
-msgid "2D and 3D raster MASKs present"
-msgstr ""
-#: ../lib/init/grass.py:1594
-msgid "Raster MASK present"
-msgstr ""
-#: ../lib/init/grass.py:1595
-msgid "3D raster MASK present"
-msgstr ""
-#: ../lib/init/grass.py:1633
-msgid "Done."
-msgstr ""
-#: ../lib/init/grass.py:1635
-msgid "Goodbye from GRASS GIS"
-msgstr ""
-#: ../lib/init/grass.py:1640
-msgid "Cleaning up temporary files..."
-msgstr ""
-#: ../lib/init/grass.py:1660
-msgid "Please install the GRASS GIS development package"
-msgstr ""
-#: ../lib/init/grass.py:1704
-#, python-format
-msgid "Parameter <%s> not supported"
-msgstr ""
-#: ../lib/init/grass.py:1848
-msgid "Flag -e requires also flag -c"
-msgstr ""
-#: ../lib/init/grass.py:1896
-msgid ""
-"Unable to start GRASS GIS. You have the choice to:\n"
-" - Launch the graphical user interface with the '-gui' switch\n"
-"     {cmd_name} -gui\n"
-" - Launch with path to the location/mapset as an argument\n"
-"     {cmd_name} /path/to/location/mapset`\n"
-" - Create a location with '-c' and launch in its PERMANENT mapset\n"
-"     {cmd_name} -c EPSG:number /path/to/location\n"
-"     {cmd_name} -c geofile /path/to/location\n"
-" - Create manually the GISRC file ({gisrcrc})\n"
-" - Use '--help' for further options\n"
-msgstr ""
-#: ../lib/init/grass.py:1919
-msgid "Creating new GRASS GIS location/mapset..."
-msgstr ""
-#: ../lib/init/grass.py:1921
-msgid "Starting GRASS GIS..."
-msgstr ""
-#: ../lib/init/grass.py:1942
-msgid ""
-"<{0}> requested, but not available. Run GRASS in text mode (-text) or "
-"install missing package (usually 'grass-gui')."
-msgstr ""
-#: ../lib/init/grass.py:1996
-#, python-format
-msgid "Launching <%s> GUI in the background, please wait..."
-msgstr ""
-#: ../lib/init/grass.py:2018
-#, python-format
-msgid "Failed to start shell '%s'"
-msgstr ""
-#: ../lib/driver/parse_ftcap.c:84
-#, c-format
-msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-#: ../lib/driver/parse_ftcap.c:90
-#, c-format
-msgid "%s: No font definition file"
-msgstr ""
-#: ../lib/raster/color_read.c:103
-msgid "missing"
-msgstr ""
-#: ../lib/raster/color_read.c:106
-msgid "invalid"
-msgstr ""
-#: ../lib/raster/color_read.c:112
-#, c-format
-msgid "Color support for <%s@%s> %s"
-msgstr ""
-#: ../lib/raster/close.c:77 ../lib/raster/close.c:110
-#, c-format
-msgid "Invalid descriptor: %d"
-msgstr ""
-#: ../lib/raster/close.c:392 ../lib/raster/close.c:520
-#, c-format
-msgid "Unable to rename null file '%s' to '%s': %s"
-msgstr ""
-#: ../lib/raster/close.c:462
-#, c-format
-msgid "Unable to rename cell file '%s' to '%s': %s"
-msgstr ""
-#: ../lib/raster/close.c:542
-msgid "unable to write f_format file for CELL maps"
-msgstr ""
-#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
-#, c-format
-msgid "Unable to get history information for <%s@%s>"
-msgstr ""
-#: ../lib/raster/history.c:162
-#, c-format
-msgid "Unable to write history information for <%s>"
-msgstr ""
-#: ../lib/raster/history.c:235
-#, c-format
-msgid "generated by %s"
-msgstr ""
-#: ../lib/raster/cats.c:109
-#, c-format
-msgid "Category support for <%s@%s> missing"
-msgstr ""
-#: ../lib/raster/cats.c:112
-#, c-format
-msgid "Category support for <%s@%s> invalid"
-msgstr ""
-#: ../lib/raster/cats.c:145
-#, c-format
-msgid "Category support for vector map <%s@%s> missing"
-msgstr ""
-#: ../lib/raster/cats.c:149
-#, c-format
-msgid "Category support for vector map <%s@%s> invalid"
-msgstr ""
-#: ../lib/raster/cats.c:971
-#, c-format
-msgid "Unable to open %s file for map <%s>"
-msgstr ""
-#: ../lib/raster/range.c:101
-#, c-format
-msgid "Unable to read fp range file for <%s>"
-msgstr ""
-#: ../lib/raster/range.c:168
-#, c-format
-msgid "Unable to read quant rules for raster map <%s>"
-msgstr ""
-#: ../lib/raster/range.c:205 ../lib/raster/range.c:225
-#, c-format
-msgid "Unable to read range file for <%s>"
-msgstr ""
-#: ../lib/raster/range.c:263 ../lib/raster/range.c:269
-#: ../lib/raster/range.c:299 ../lib/raster/range.c:313
-#, c-format
-msgid "Unable to write range file for <%s>"
-msgstr ""
-#: ../lib/raster/format.c:162
-#, c-format
-msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr ""
-#: ../lib/raster/format.c:176
-#, c-format
-msgid "Fail of initial read of compressed null file [%s in %s]"
-msgstr ""
-#: ../lib/raster/histogram.c:55
-#, c-format
-msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr ""
-#: ../lib/raster/histogram.c:62
-#, c-format
-msgid "Can't read histogram for [%s in %s]"
-msgstr ""
-#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
-#, c-format
-msgid "Invalid histogram file for [%s in %s]"
-msgstr ""
-#: ../lib/raster/histogram.c:331
-#, c-format
-msgid "Unable to create histogram file for <%s>"
-msgstr ""
-#: ../lib/raster/alloc_cell.c:151
-#, c-format
-msgid "Rast__null_bitstream_size: cols (%d) is negative"
-msgstr ""
-#: ../lib/raster/auto_mask.c:69
-msgid "Unable to open automatic MASK file"
-msgstr ""
-#: ../lib/raster/color_rand.c:33
-#, c-format
-msgid "Rast_make_random_colors: min (%d) > max (%d)"
-msgstr ""
-#: ../lib/raster/color_rules.c:120
-msgid "syntax error in the color rule"
-msgstr ""
-#: ../lib/raster/color_rules.c:122
-msgid "syntax error in the color format"
-msgstr ""
-#: ../lib/raster/color_rules.c:130
-msgid "percentage not in range 0-100"
-msgstr ""
-#: ../lib/raster/color_rules.c:132
-msgid "invalid value"
-msgstr ""
-#: ../lib/raster/color_rules.c:134
-msgid "unknown error"
-msgstr ""
-#: ../lib/raster/color_rules.c:180
-#, c-format
-msgid "bad rule (%s): [%s]"
-msgstr ""
-#: ../lib/raster/color_rules.c:232
-msgid "Unknown error reading color rule"
-msgstr ""
-#: ../lib/raster/color_rules.c:330
-#, c-format
-msgid "Unable to load color rules <%s>"
-msgstr ""
-#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
-#, c-format
-msgid "Qualified name <%s> doesn't match mapset <%s>"
-msgstr ""
-#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
-#, c-format
-msgid "Unable to create <%s> file for map <%s>"
-msgstr ""
-#: ../lib/raster/get_cellhd.c:66
-#, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>. It is a reclass of raster"
-" map <%s@%s> %s"
-msgstr ""
-#: ../lib/raster/get_cellhd.c:70
-msgid "which is missing."
-msgstr ""
-#: ../lib/raster/get_cellhd.c:71
-msgid "whose header file can't be opened."
-msgstr ""
-#: ../lib/raster/get_cellhd.c:76
-#, c-format
-msgid "Unable to open header file for raster map <%s@%s>"
-msgstr ""
-#: ../lib/raster/interp.c:211
-#, c-format
-msgid "Unknown interpolation method: %s"
-msgstr ""
-#: ../lib/raster/mask_info.c:43
-#, c-format
-msgid "<%s> in mapset <%s>"
-msgstr ""
-#: ../lib/raster/mask_info.c:46
-msgid "none"
-msgstr ""
-#: ../lib/raster/mask_info.c:49
-msgid "not known"
-msgstr ""
-#: ../lib/raster/null_val.c:64
-msgid "EmbedGivenNulls: wrong data type"
-msgstr ""
-#: ../lib/raster/null_val.c:114
-msgid "Rast_set_null_value: wrong data type!"
-msgstr ""
-#: ../lib/raster/put_cellhd.c:34
-#, c-format
-msgid "Unable to create header file for <%s>"
-msgstr ""
-#: ../lib/raster/put_title.c:28
-#, c-format
-msgid "category information for [%s] in [%s] missing or invalid"
-msgstr ""
-#: ../lib/raster/put_title.c:37
-msgid "G_put_title - can't create a temp file"
-msgstr ""
-#: ../lib/raster/put_title.c:53
-#, c-format
-msgid "category information for [%s] in [%s] invalid"
-msgstr ""
-#: ../lib/raster/put_title.c:60
-msgid "G_put_title - can't reopen temp file"
-msgstr ""
-#: ../lib/raster/put_title.c:67
-#, c-format
-msgid "can't write category information for [%s] in [%s]"
-msgstr ""
-#: ../lib/raster/quant_io.c:43
-#, c-format
-msgid "Floating data range for raster map <%s> is empty"
-msgstr ""
-#: ../lib/raster/quant_io.c:52
-#, c-format
-msgid "Integer data range for raster map <%s> is empty"
-msgstr ""
-#: ../lib/raster/quant_io.c:105
-#, c-format
-msgid "Attempt to open quantization table for CELL raster map <%s>"
-msgstr ""
-#: ../lib/raster/quant_io.c:135
-#, c-format
-msgid "Quantization file for raster map <%s> is missing"
-msgstr ""
-#: ../lib/raster/quant_io.c:145
-#, c-format
-msgid "Quantization file for raster map <%s> is empty"
-msgstr ""
-#: ../lib/raster/quant_rw.c:88
-#, c-format
-msgid "Unable to read fp range for raster map <%s>"
-msgstr ""
-#: ../lib/raster/quant_rw.c:92
-#, c-format
-msgid "Raster map <%s> is empty"
-msgstr ""
-#: ../lib/raster/quant_rw.c:157
-#, c-format
-msgid "Unable to write quant rules: raster map <%s> is integer"
-msgstr ""
-#: ../lib/raster/quant_rw.c:166
-#, c-format
-msgid "Unable to write quant rules for raster map <%s>"
-msgstr ""
-#: ../lib/raster/raster_metadata.c:109
-#, c-format
-msgid "Unable to read <%s> for raster map <%s@%s>"
-msgstr ""
-#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
-#, c-format
-msgid "Error closing <%s> metadata file for raster map <%s@%s>"
-msgstr ""
-#: ../lib/raster/raster_metadata.c:142
-#, c-format
-msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
-msgstr ""
-#: ../lib/raster/reclass.c:168
-#, c-format
-msgid "Too many reclass categories for <%s@%s>"
-msgstr ""
-#: ../lib/raster/reclass.c:171
-#, c-format
-msgid "Illegal reclass format in header file for <%s@%s>"
-msgstr ""
-#: ../lib/raster/reclass.c:273
-msgid "Illegal reclass request"
-msgstr ""
-#: ../lib/raster/reclass.c:278
-msgid "Illegal reclass type"
-msgstr ""
-#: ../lib/raster/reclass.c:284
-#, c-format
-msgid "Unable to create header file for <%s@%s>"
-msgstr ""
-#: ../lib/raster/reclass.c:332
-#, c-format
-msgid "Unable to create dependency file in <%s@%s>"
-msgstr ""
-#: ../lib/raster/sample.c:70
-msgid "Unknown interpolation type"
-msgstr ""
-#: ../lib/raster/sample.c:327
-msgid "\"no data\" label found; setting to zero"
-msgstr ""
-#: ../lib/raster/set_window.c:48
-msgid "Rast_set_window() called while window split"
-msgstr ""
-#: ../lib/raster/set_window.c:131
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
-msgstr ""
-#: ../lib/raster/set_window.c:158
-#, c-format
-msgid "Input window changed while maps are open for read. Map name <%s>"
-msgstr ""
-#: ../lib/raster/set_window.c:174
-#, c-format
-msgid "Output window changed while maps are open for write. Map name <%s>"
-msgstr ""
-#: ../lib/raster/window.c:31
-msgid ""
-"Internal error: Rast_get_window() called with split window. Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
-msgstr ""
-#: ../lib/raster/window.c:90
-msgid ""
-"Internal error: Rast_window_rows() called with split window. Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
-msgstr ""
-#: ../lib/raster/window.c:125
-msgid ""
-"Internal error: Rast_window_cols() called with split window. Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
-msgstr ""
-#: ../lib/raster/init.c:61
-msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr ""
-#: ../lib/raster/init.c:109
-#, c-format
-msgid "Unknown compression method <%s>, using default ZLIB"
-msgstr ""
-#: ../lib/raster/init.c:113
-msgid ""
-"No compression is not supported for GRASS raster maps, using default ZLIB"
-msgstr ""
-#: ../lib/raster/init.c:118
-#, c-format
-msgid "This GRASS version does not support %s compression, using default ZLIB"
-msgstr ""
-#: ../lib/raster/open.c:191
-#, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map "
-"<%s@%s> which does not exist"
-msgstr ""
-#: ../lib/raster/open.c:196
-#, c-format
-msgid "Error reading reclass file for raster map <%s>"
-msgstr ""
-#: ../lib/raster/open.c:207
-#, c-format
-msgid "Error reading map type for raster map <%s>"
-msgstr ""
-#: ../lib/raster/open.c:215
-#, c-format
-msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr ""
-#: ../lib/raster/open.c:234
-#, c-format
-msgid "Compression with %s is not supported in this GRASS GIS installation"
-msgstr ""
-#: ../lib/raster/open.c:238
-#, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
-msgstr ""
-#: ../lib/raster/open.c:245
-#, c-format
-msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-#: ../lib/raster/open.c:250
-#, c-format
-msgid "Raster map <%s>: bytes per cell (%d) too large"
-msgstr ""
-#: ../lib/raster/open.c:275
-#, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
-#: ../lib/raster/open.c:283
-#, c-format
-msgid "Unable to open %s file for raster map <%s@%s>"
-msgstr ""
-#: ../lib/raster/open.c:320
-#, c-format
-msgid "Error reading format for <%s@%s>"
-msgstr ""
-#: ../lib/raster/open.c:525
-msgid "Unable to create GDAL link"
-msgstr ""
-#: ../lib/raster/open.c:597 ../lib/raster/gdal.c:479
-#, c-format
-msgid "Invalid map type <%d>"
-msgstr ""
-#: ../lib/raster/open.c:602 ../lib/raster/open.c:757
-#, c-format
-msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr ""
-#: ../lib/raster/open.c:609
-#, c-format
-msgid "<%s> is an illegal file name"
-msgstr ""
-#: ../lib/raster/open.c:624 ../lib/raster/open.c:704 ../lib/raster/open.c:780
-#, c-format
-msgid "No temp files available: %s"
-msgstr ""
-#: ../lib/raster/open.c:753
-#, c-format
-msgid "Raster map <%s> does not exist in the current mapset (%s)"
-msgstr ""
-#: ../lib/raster/open.c:819
-msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
-#: ../lib/raster/open.c:877
-#, c-format
-msgid "Raster map <%s> not found in mapset <%s>"
-msgstr ""
-#: ../lib/raster/open.c:938
-#, c-format
-msgid "Unable to find '%s'"
-msgstr ""
-#: ../lib/raster/open.c:949
-#, c-format
-msgid "Invalid type: field '%s' in file '%s'"
-msgstr ""
-#: ../lib/raster/open.c:954
-#, c-format
-msgid "Missing type: field in file '%s'"
-msgstr ""
-#: ../lib/raster/open.c:959
-#, c-format
-msgid "Raster map <%s> is not xdr: byte_order: %s"
-msgstr ""
-#: ../lib/raster/open.c:1028
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
-#: ../lib/raster/gdal.c:89
-#, c-format
-msgid "Unable to locate symbol <%s>"
-msgstr ""
-#: ../lib/raster/gdal.c:147
-msgid "Unable to load GDAL library"
-msgstr ""
-#: ../lib/raster/gdal.c:377
-msgid "Unable to open GDAL file"
-msgstr ""
-#: ../lib/raster/gdal.c:485
-#, c-format
-msgid "Unable to get <%s> driver"
-msgstr ""
-#: ../lib/raster/gdal.c:494
-#, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
-msgstr ""
-#: ../lib/raster/gdal.c:502
-#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
-msgstr ""
-#: ../lib/raster/gdal.c:508
-msgid "Unable to get in-memory raster driver"
-msgstr ""
-#: ../lib/raster/gdal.c:515
-#, c-format
-msgid "Unable to create <%s> dataset using memory driver"
-msgstr ""
-#: ../lib/raster/gdal.c:519
-#, c-format
-msgid "Driver <%s> does not support creating rasters"
-msgstr ""
-#: ../lib/raster/gdal.c:535
-msgid "Unable to set geo transform"
-msgstr ""
-#: ../lib/raster/gdal.c:539
-msgid "Unable to set projection"
-msgstr ""
-#: ../lib/raster/gdal.c:543
-#, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
-msgstr ""
-#: ../lib/raster/gdal.c:559
-#, c-format
-msgid "Error writing cell_misc/%s/gdal file"
-msgstr ""
-#: ../lib/raster/gdal.c:607
-#, c-format
-msgid "Unable to create output file <%s> using driver <%s>"
-msgstr ""
-#: ../lib/raster/put_row.c:121
-#, c-format
-msgid "Error writing uncompressed FP data for row %d of <%s>: %s"
-msgstr ""
-#: ../lib/raster/put_row.c:131
-#, c-format
-msgid "Error writing compressed FP data for row %d of <%s>: %s"
-msgstr ""
-#: ../lib/raster/put_row.c:386 ../lib/raster/put_row.c:392
-#, c-format
-msgid "Error writing compressed data for row %d of <%s>"
-msgstr ""
-#: ../lib/raster/put_row.c:402
-#, c-format
-msgid "Error writing uncompressed data for row %d of <%s>"
-msgstr ""
-#: ../lib/raster/put_row.c:462
-#, c-format
-msgid "Error writing data via GDAL for row %d of <%s>"
-msgstr ""
-#: ../lib/raster/put_row.c:486
-msgid "GDAL output doesn't support writing null rows separately"
-msgstr ""
-#: ../lib/raster/put_row.c:489
-#, c-format
-msgid "No null file for <%s>"
-msgstr ""
-#: ../lib/raster/put_row.c:513 ../lib/raster/put_row.c:518
-#, c-format
-msgid "Error writing compressed null data for row %d of <%s>"
-msgstr ""
-#: ../lib/raster/put_row.c:552 ../lib/raster/put_row.c:555
-#, c-format
-msgid "Error writing null row %d of <%s>"
-msgstr ""
-#: ../lib/raster/put_row.c:680
-#, c-format
-msgid "put_raster_row: raster map <%s> not open for write - request ignored"
-msgstr ""
-#: ../lib/raster/put_row.c:687
-msgid "put_raster_row: unopened file descriptor - request ignored"
-msgstr ""
-#: ../lib/raster/get_row.c:35 ../lib/raster/get_row.c:901
-#, c-format
-msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-#: ../lib/raster/get_row.c:95
-#, c-format
-msgid "Error seeking fp raster data file for row %d of <%s>: %s"
-msgstr ""
-#: ../lib/raster/get_row.c:103
-#, c-format
-msgid "Error uncompressing fp raster data for row %d of <%s>: error code %d"
-msgstr ""
-#: ../lib/raster/get_row.c:138
-#, c-format
-msgid "Error seeking raster data file for row %d of <%s>: %s"
-msgstr ""
-#: ../lib/raster/get_row.c:145
-#, c-format
-msgid "Error reading raster data for row %d of <%s>: %s"
-msgstr ""
-#: ../lib/raster/get_row.c:169
-#, c-format
-msgid "Error uncompressing raster data for row %d of <%s>"
-msgstr ""
-#: ../lib/raster/get_row.c:188 ../lib/raster/get_row.c:192
-#, c-format
-msgid "Error reading raster data for row %d of <%s>"
-msgstr ""
-#: ../lib/raster/get_row.c:228
-#, c-format
-msgid "Error reading raster data via GDAL for row %d of <%s>"
-msgstr ""
-#: ../lib/raster/get_row.c:830
-#, c-format
-msgid "Error seeking compressed null data for row %d of <%s>"
-msgstr ""
-#: ../lib/raster/get_row.c:835 ../lib/raster/get_row.c:845
-#, c-format
-msgid "Error reading compressed null data for row %d of <%s>"
-msgstr ""
-#: ../lib/raster/get_row.c:851
-#, c-format
-msgid "Error uncompressing null data for row %d of <%s>"
-msgstr ""
-#: ../lib/raster/get_row.c:885
-#, c-format
-msgid "Error seeking null row %d for <%s>"
-msgstr ""
-#: ../lib/raster/get_row.c:888
-#, c-format
-msgid "Error reading null row %d for <%s>"
-msgstr ""
-#: ../lib/vector/diglib/port_init.c:158
-#, c-format
-msgid "Unable to find '%x' in %s"
-msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:523
-#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this topology format. Try "
-"to rebuild topology or upgrade GRASS to at least version %d."
-msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:529
-#, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:539
-#, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
-"rebuild topology using v.build or v.build.all module."
-msgstr ""
-#: ../lib/vector/diglib/plus_struct.c:563 ../lib/vector/diglib/portable.c:208
-#: ../lib/vector/diglib/portable.c:241 ../lib/vector/diglib/portable.c:683
-msgid "Vector exceeds supported file size limit"
-msgstr ""
-#: ../lib/vector/diglib/cindex_rw.c:156
-#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this category index format."
-" Try to rebuild topology or upgrade GRASS to at least version %d."
-msgstr ""
-#: ../lib/vector/diglib/file.c:159
-msgid "Writing to file loaded to memory not supported"
-msgstr ""
-#: ../lib/vector/diglib/file.c:197
-msgid "Unable to load file to memory, file not open"
-msgstr ""
-#: ../lib/vector/diglib/file.c:212
-msgid "Vector memory mode not supported, using 'AUTO'"
-msgstr ""
-#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
-#, c-format
-msgid "Vector format not recognized: %s"
-msgstr ""
-#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
-#, c-format
-msgid "Vector format '%s' not supported"
-msgstr ""
-#: ../lib/vector/diglib/frmt.c:97
-#, c-format
-msgid "Format definition is not correct: %s"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:222
-msgid "Unable read topology for nodes"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:227
-#, c-format
-msgid "Unable to read topology for node %d"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:232
-msgid "Unable read topology for lines"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:237
-#, c-format
-msgid "Unable to read topology for line %d"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:242
-msgid "Unable to read topo for areas"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:247
-#, c-format
-msgid "Unable read topology for area %d"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:252
-msgid "Unable to read topology for isles"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:257
-#, c-format
-msgid "Unable to read topology for isle %d"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:279 ../lib/vector/diglib/plus.c:305
-msgid "Unable to write head to plus file"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:284
-msgid "Unable to write nodes to plus file"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:289
-msgid "Unable to write lines to plus file"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:294
-msgid "Unable to write areas to plus file"
-msgstr ""
-#: ../lib/vector/diglib/plus.c:299
-msgid "Unable to write isles to plus file"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:215 ../lib/vector/diglib/plus_area.c:716
-#, c-format
-msgid "Line %d already has area/isle %d to left"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:225 ../lib/vector/diglib/plus_area.c:724
-#, c-format
-msgid "Line %d already has area/isle %d to right"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:279
-msgid "Isle already registered in area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:313
-msgid "Attempt to delete isle from dead area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:330
-#, c-format
-msgid "Attempt to delete not registered isle %d from area %d"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:369
-msgid "Attempt to delete dead area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:408
-#, c-format
-msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:431
-#, c-format
-msgid "Attempt to delete area %d info from dead isle %d"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:782
-#, c-format
-msgid "Attempt to delete isle %d info from dead area %d"
-msgstr ""
-#: ../lib/vector/diglib/plus_node.c:214
-#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-#: ../lib/vector/diglib/spindex.c:450
-#, c-format
-msgid "Unable to delete node %d from spatial index"
-msgstr ""
-#: ../lib/vector/diglib/spindex.c:493
-#, c-format
-msgid "Unable to delete line %d from spatial index"
-msgstr ""
-#: ../lib/vector/diglib/spindex.c:529
-msgid "Attempt to delete sidx for dead area"
-msgstr ""
-#: ../lib/vector/diglib/spindex.c:546
-#, c-format
-msgid "Unable to delete area %d from spatial index"
-msgstr ""
-#: ../lib/vector/diglib/spindex.c:595
-#, c-format
-msgid "Unable to delete isle %d from spatial index"
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:99 ../lib/vector/diglib/spindex_rw.c:107
-msgid "Topology file must be written before spatial index file"
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:303
-#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:309
-#, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:318
-#, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
-msgstr ""
-#: ../lib/vector/diglib/test.c:58
-msgid "Unable to open test.tmp file"
-msgstr ""
-#: ../lib/vector/diglib/test.c:75
-#, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
-msgstr ""
-#: ../lib/vector/diglib/test.c:89
-#, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
-msgstr ""
-#: ../lib/vector/diglib/test.c:104
-#, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
-msgstr ""
-#: ../lib/vector/diglib/test.c:119
-#, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
-msgstr ""
-#: ../lib/vector/diglib/test.c:134
-#, c-format
-msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/diglib/test.c:150
-#, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/diglib/test.c:165
-#, c-format
-msgid ""
-"Error in read/write portable char, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:40
-msgid ""
-"\n"
-"++ Running basic unit tests ++"
-msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:48
-msgid ""
-"\n"
-"-- Basic rtree unit tests failure --"
-msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:50
-msgid ""
-"\n"
-"-- Basic rtree unit tests finished successfully --"
-msgstr ""
-#: ../lib/vector/rtree/test_suite/test_main.c:61
-msgid "Unit tests for the vector rtree library"
-msgstr ""
-#: ../lib/vector/Vlib/area.c:50
-msgid "Attempt to read points of nonexistent area"
-msgstr ""
-#: ../lib/vector/Vlib/area.c:81
-msgid "Attempt to read points of nonexistent isle"
-msgstr ""
-#: ../lib/vector/Vlib/area.c:94 ../lib/vector/Vlib/area.c:499
-#: ../lib/vector/Vlib/read_pg.c:91 ../lib/vector/Vlib/read_pg.c:214
-#: ../lib/vector/Vlib/read_pg.c:298 ../lib/vector/Vlib/read_pg.c:416
-#: ../lib/vector/Vlib/open_pg.c:143 ../lib/vector/Vlib/open_pg.c:200
-#: ../lib/vector/Vlib/open_pg.c:299 ../lib/vector/Vlib/open_pg.c:349
-#: ../lib/vector/Vlib/build_sfa.c:721 ../lib/vector/Vlib/build_pg.c:117
-#: ../lib/vector/Vlib/close.c:275 ../lib/vector/Vlib/close_pg.c:99
-#: ../lib/vector/Vlib/close_pg.c:146 ../lib/vector/Vlib/header_finfo.c:47
-#: ../lib/vector/Vlib/header_finfo.c:86 ../lib/vector/Vlib/header_finfo.c:123
-#: ../lib/vector/Vlib/header_finfo.c:171 ../lib/vector/Vlib/rewind_pg.c:56
-#: ../lib/vector/Vlib/rewind_pg.c:81 ../lib/vector/Vlib/simple_features.c:336
-#: ../lib/vector/Vlib/write_sfa.c:306 ../lib/vector/Vlib/write_pg.c:123
-#: ../lib/vector/Vlib/write_pg.c:157 ../lib/vector/Vlib/write_pg.c:196
-#: ../lib/vector/Vlib/write_pg.c:294 ../lib/vector/Vlib/write_pg.c:354
-#: ../lib/vector/Vlib/write_pg.c:476 ../lib/vector/Vlib/copy.c:428
-msgid "GRASS is not compiled with PostgreSQL support"
-msgstr ""
-#: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
-#: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
-#, c-format
-msgid "Attempt to read topo for dead area (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
-#, c-format
-msgid "Attempt to read topo for dead isle (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:192 ../lib/vector/Vlib/read_sfa.c:117
-#, c-format
-msgid "Unexpected feature type (%d) - should be (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
-#, c-format
-msgid "Feature %ld without geometry skipped"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:331 ../lib/vector/Vlib/box.c:249
-#: ../lib/vector/Vlib/write_nat.c:182 ../lib/vector/Vlib/write_nat.c:295
-#: ../lib/vector/Vlib/write_nat.c:651 ../lib/vector/Vlib/read.c:173
-#: ../lib/vector/Vlib/read_nat.c:144 ../lib/vector/Vlib/read_sfa.c:50
-#: ../lib/vector/Vlib/write_sfa.c:158 ../lib/vector/Vlib/write_sfa.c:207
-#: ../lib/vector/Vlib/write_pg.c:236 ../lib/vector/Vlib/write_pg.c:381
-#: ../lib/vector/Vlib/write_pg.c:396
-#, c-format
-msgid "Attempt to access feature with invalid id (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:337 ../lib/vector/Vlib/write_nat.c:301
-#: ../lib/vector/Vlib/write_nat.c:657 ../lib/vector/Vlib/read_nat.c:150
-#: ../lib/vector/Vlib/read_sfa.c:56 ../lib/vector/Vlib/write_pg.c:242
-#: ../lib/vector/Vlib/write_pg.c:402 ../lib/vector/Vlib/write_pg.c:2592
-#: ../lib/vector/Vlib/write_pg.c:2689
-#, c-format
-msgid "Attempt to access dead feature %d"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:365
-#, c-format
-msgid ""
-"Requesting invalid feature from cache (%d). Number of features in cache: %d"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:368
-#, c-format
-msgid "Feature %d: unexpected type (%d) - should be %d"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:378 ../lib/vector/Vlib/build_sfa.c:354
-#: ../lib/vector/Vlib/build_sfa.c:364
-#, c-format
-msgid "Feature %d without geometry skipped"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:482 ../lib/vector/Vlib/read_ogr.c:382
-msgid "Feature without geometry. Skipped."
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:575
-msgid "No geometry or topo geometry column defined"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:585
-msgid "Random access not supported. Primary key not defined."
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:652
-msgid "Inconsistency in topology: detected centroid (should be point)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:662
-msgid "Inconsistency in topology: detected boundary (should be line)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:787
-#, c-format
-msgid "Invalid WKB content: %d bytes"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:803
-msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:884 ../lib/vector/Vlib/read_pg.c:1192
-#: ../lib/vector/Vlib/read_pg.c:1362 ../lib/vector/Vlib/read_pg.c:1455
-#: ../lib/vector/Vlib/write_pg.c:737 ../lib/vector/Vlib/write_pg.c:1176
-#: ../lib/vector/Vlib/write_pg.c:1285 ../lib/vector/Vlib/write_pg.c:1798
-#: ../lib/vector/Vlib/write_pg.c:1975 ../lib/vector/Vlib/write_pg.c:2333
-#, c-format
-msgid "Unsupported feature type %d"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1066
-#: ../lib/vector/Vlib/read_pg.c:1137
-msgid "Length of input WKB is too small"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1077
-#, c-format
-msgid "Invalid cache index %d (max: %d)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1215
-#, c-format
-msgid "Corrupted data. %s."
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1217
-msgid "Corrupted data"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1252
-#, c-format
-msgid "Unable to parse '%s'"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1420 ../lib/vector/Vlib/close_pg.c:66
-#, c-format
-msgid "Unable to close cursor %s"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1530
-#, c-format
-msgid ""
-"Execution failed: %s (...)\n"
-"Reason: %s"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1561
-#, c-format
-msgid ""
-"Execution failed: %s\n"
-"Reason: %s"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1693
-#, c-format
-msgid ""
-"Unable to read features. Reason:\n"
-"%s"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:102
-msgid "Break polygons: Bug in binary tree!"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:156
-#: ../lib/vector/Vlib/break_polygons.c:435
-msgid "Breaking polygons (pass 1: select break points)..."
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:286
-#: ../lib/vector/Vlib/break_polygons.c:552
-msgid "Breaking polygons (pass 2: break at selected points)..."
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:398
-#: ../lib/vector/Vlib/break_polygons.c:650
-#, c-format
-msgid "Breaks: %d"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:592
-msgid "Point not in search tree!"
-msgstr ""
-#: ../lib/vector/Vlib/constraint.c:150
-msgid "Layer constraint ignored for non-native vector formats"
-msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:56
-#, c-format
-msgid "Unable to open coor file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:152
-#, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:156
-#, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
-msgstr ""
-#: ../lib/vector/Vlib/box.c:264
-#, c-format
-msgid "Unable to determine bbox for feature %d"
-msgstr ""
-#: ../lib/vector/Vlib/box.c:313 ../lib/vector/Vlib/box.c:359
-#, c-format
-msgid "Attempt to access area with invalid id (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/box.c:325
-#, c-format
-msgid "Unable to determine bbox for area %d"
-msgstr ""
-#: ../lib/vector/Vlib/box.c:371
-#, c-format
-msgid "Unable to determine bbox for isle %d"
-msgstr ""
-#: ../lib/vector/Vlib/box.c:429
-#, c-format
-msgid "Topology not available for vector map <%s>. Registering primitives..."
-msgstr ""
-#: ../lib/vector/Vlib/box.c:436 ../lib/vector/Vlib/build_nat.c:84
-msgid "Unable to read vector map"
-msgstr ""
-#: ../lib/vector/Vlib/poly.c:268
-msgid "Unable to find point in polygon"
-msgstr ""
-#: ../lib/vector/Vlib/poly.c:810
-msgid "conditions failed"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:361
-msgid "Line is not looped"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:443
-#, c-format
-msgid "Unexpected result of line_intersection() res = %d"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:589
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:600
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:648
-msgid "side != 0 feature not implemented"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
-msgid "zero area size"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
-msgid "Line was not closed"
-msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
-msgid "Vect_get_point_in_poly() failed"
-msgstr ""
-#: ../lib/vector/Vlib/graph.c:105 ../lib/vector/Vlib/net_build.c:661
-#: ../lib/vector/Vlib/net_build.c:1067 ../lib/vector/neta/flow.c:331
-msgid "GngFlatten error"
-msgstr ""
-#: ../lib/vector/Vlib/graph.c:138
-msgid "Unable to add network arc"
-msgstr ""
-#: ../lib/vector/Vlib/graph.c:226 ../lib/vector/Vlib/net_analyze.c:201
-#, c-format
-msgid "dglShortestPath error: %s"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:101 ../lib/vector/Vlib/net_build.c:727
-msgid "Building graph..."
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:143 ../lib/vector/Vlib/net_build.c:775
-msgid "Unable to build network graph"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:149 ../lib/vector/Vlib/net_build.c:781
-msgid "Forward costs column not specified"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:156
-msgid "Turntable field < 1"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:172
-#, c-format
-msgid "Turntable column <%s> not found in table <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:182 ../lib/vector/Vlib/net_build.c:223
-#: ../lib/vector/Vlib/net_build.c:508 ../lib/vector/Vlib/net_build.c:526
-#: ../lib/vector/Vlib/net_build.c:809 ../lib/vector/Vlib/net_build.c:827
-#: ../lib/vector/Vlib/net_build.c:988
-#, c-format
-msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:202 ../lib/vector/Vlib/net_build.c:967
-msgid "Setting node costs..."
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:216 ../lib/vector/Vlib/net_build.c:501
-#: ../lib/vector/Vlib/net_build.c:519 ../lib/vector/Vlib/net_build.c:802
-#: ../lib/vector/Vlib/net_build.c:820 ../lib/vector/Vlib/net_build.c:981
-#: ../lib/vector/Vlib/ascii.c:756
-#, c-format
-msgid "Column <%s> not found in table <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:277 ../lib/vector/Vlib/net_build.c:1032
-#, c-format
-msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:332 ../lib/vector/Vlib/net_build.c:352
-msgid "Cannot add network arc for virtual node connection."
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:364
-#, c-format
-msgid ""
-"There exists more than one point of node <%d> with unique category field  <%d>.\n"
-"The unique categories layer is not valid therefore you will probably get incorrect results."
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:393
-#, c-format
-msgid ""
-"Unable to find point representing intersection <%d> in unique categories field <%d>.\n"
-"Cost for the intersection was set to 0.\n"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:407
-#, c-format
-msgid ""
-"Unable to find node for point representing intersection <%d> in unique categories field <%d>.\n"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:432
-#, c-format
-msgid ""
-"Database record for turn with cat = %d in not found. (The turn was skipped."
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:465
-msgid "Cannot add network arc representing turn."
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:487 ../lib/vector/Vlib/net_build.c:788
-msgid "Arc field < 1"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:539 ../lib/vector/Vlib/net_build.c:840
-msgid "Registering arcs..."
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:558
-#, c-format
-msgid ""
-"Line with id <%d> has more unique categories defined in field <%d>.\n"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:579
-#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(cost was set to 0)"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:596
-#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found(cost "
-"was set to 0)"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1064
-msgid "Flattening the graph..."
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:667 ../lib/vector/Vlib/net_build.c:1073
-msgid "Graph was built"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:869
-#, c-format
-msgid ""
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:888
-#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
-msgstr ""
-#: ../lib/vector/Vlib/net_build.c:937
-msgid "Cannot add network arc"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:85 ../lib/vector/Vlib/open_pg.c:232
-#: ../lib/vector/Vlib/write_pg.c:1072
-msgid "Connection string not defined"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:90 ../lib/vector/Vlib/open_pg.c:237
-#: ../lib/vector/Vlib/write_pg.c:1077 ../lib/vector/Vlib/write_pg.c:1217
-#: ../lib/vector/Vlib/write_pg.c:1375
-msgid "PostGIS feature table not defined"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
-msgid "No feature tables found in database."
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:133
-#, c-format
-msgid "Feature table <%s> not found in 'geometry_columns'"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:181
-msgid "Topology schema not found."
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:193 ../lib/vector/Vlib/open_ogr.c:145
-#, c-format
-msgid "Unable to open feature index file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:273
-#, c-format
-msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:276
-#, c-format
-msgid "Unable to delete PostGIS layer <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:282
-#, c-format
-msgid "PostGIS layer <%s.%s> already exists in database '%s'"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:390
-msgid "No key column detected."
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
-#, c-format
-msgid "Execution failed: %s"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:476
-#, c-format
-msgid "PostGIS topology schema <%s> dropped"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:559
-msgid ""
-"Connection to PostgreSQL database failed. Try to set up username/password by"
-" db.login."
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:566
-msgid "Unable to get database name"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:571
-#, c-format
-msgid "<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:580
-#, c-format
-msgid "PostGIS Topology extension not found in the database <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:667
-msgid "Empty bounding box"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:768
-#, c-format
-msgid "Inconsistency in topology: unable to read node %d"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:834
-#, c-format
-msgid "Inconsistency in topology: node %d - unexpected feature type %d"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1003
-#, c-format
-msgid "Area %d without boundary detected"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1061
-#, c-format
-msgid "Isle %d without boundary detected"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1128
-msgid "Unable to get map bounding box from topology"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1135
-#, c-format
-msgid ""
-"Unable to parse map bounding box:\n"
-"%s"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1159
-#, c-format
-msgid "Different number of nodes detected (%d, %d)"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1187 ../lib/vector/Vlib/open_pg.c:1209
-#, c-format
-msgid "Different number of areas detected (%d, %d)"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1380
-msgid "To be implemented: isles not attached in Topo-Geo-only mode"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1485 ../lib/vector/Vlib/build_pg.c:212
-#, c-format
-msgid "Inconsistency in topology: number of nodes %d (should be %d)"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1569
-#, c-format
-msgid "Inconsistency in topology: number of points %d (should be %d)"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1614
-#, c-format
-msgid "Inconsistency in topology: number of lines %d (should be %d)"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1668
-#, c-format
-msgid "Inconsistency in topology: number of centroids %d (should be %d)"
-msgstr ""
-#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
-#: ../lib/vector/Vlib/line.c:250
-msgid "Index out of range in"
-msgstr ""
-#: ../lib/vector/Vlib/line.c:550
-msgid "Segment outside line, no segment created"
-msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
-#, c-format
-msgid "Unable to calculate centroid for area %d"
-msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:305
-#, c-format
-msgid "Feature type %d not supported"
-msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:339 ../lib/vector/Vlib/build_sfa.c:632
-#: ../lib/vector/Vlib/build_nat.c:74
-msgid "Registering primitives..."
-msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:385 ../lib/vector/Vlib/build_sfa.c:664
-#: ../lib/vector/Vlib/build_nat.c:117
-#, c-format
-msgid "One primitive registered"
-msgid_plural "%d primitives registered"
-msgstr[0] ""
-#: ../lib/vector/Vlib/build_sfa.c:386 ../lib/vector/Vlib/build_sfa.c:665
-#: ../lib/vector/Vlib/build_nat.c:118
-#, c-format
-msgid "One vertex registered"
-msgid_plural "%d vertices registered"
-msgstr[0] ""
-#: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
-#: ../lib/vector/Vlib/read_ogr.c:578
-#, c-format
-msgid "OGR feature type %d not supported"
-msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:668
-#, c-format
-msgid "One feature without geometry skipped"
-msgid_plural "%d features without geometry skipped"
-msgstr[0] ""
-#: ../lib/vector/Vlib/build_sfa.c:725
-#, c-format
-msgid "%s: Native format unsupported"
-msgstr ""
-#: ../lib/vector/Vlib/build_sfa.c:751
-msgid "Feature index is built only for non-native formats. Nothing to dump."
-msgstr ""
-#: ../lib/vector/Vlib/header.c:86
-#, c-format
-msgid "Unable to create header file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/header.c:129
-#, c-format
-msgid "Unable to open header file of vector <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/header.c:137
-#, c-format
-msgid "Corrupted row in head: %s"
-msgstr ""
-#: ../lib/vector/Vlib/header.c:175
-#, c-format
-msgid "Unknown keyword '%s' in vector head"
-msgstr ""
-#: ../lib/vector/Vlib/header.c:552 ../lib/gis/proj3.c:121
-msgid "Unknown projection"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:88
-msgid "No DB connection"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:93 ../lib/vector/Vlib/build_ogr.c:87
-#, c-format
-msgid "Feature table <%s> has no primary key defined"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:95
-msgid "Random read is not supported for this layer. Unable to build topology."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:101 ../lib/vector/Vlib/build_ogr.c:95
-#, c-format
-msgid "Using external data format '%s' (feature type '%s')"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:105
-msgid "Building pseudo-topology over simple features..."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:107
-#, c-format
-msgid "Building topology from PostGIS topology schema <%s>..."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:237
-msgid "Cleaning-up topology schema..."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:282
-msgid "Updating faces..."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:314
-msgid "Updating edges..."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:323
-msgid "Inconsistency in topology detected. Dead line found."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:377
-msgid "Updating TopoGeometry data..."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:411 ../lib/vector/Vlib/write_pg.c:612
-#: ../lib/vector/Vlib/write_pg.c:880 ../lib/vector/Vlib/open.c:1355
-msgid "Unable to open PG file"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:462
-#, c-format
-msgid "Unsupported topo geometry type %d"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:491
-#, c-format
-msgid "Unable to create <%s.%s>"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:642
-msgid "Unable to write nodes, offset array mismatch"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:671
-msgid "Unable to write nodes"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:716
-#, c-format
-msgid "Inconsistency in topology: number of boundaries %d (should be %d)"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:739
-msgid "Unable to write lines"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:790
-#, c-format
-msgid "Topology for centroid %d not available. Area %d skipped"
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:1000
-msgid "Create simple features topology from topogeometry data..."
-msgstr ""
-#: ../lib/vector/Vlib/build_pg.c:1018
-#, c-format
-msgid ""
-"Unable to build simple features from topogeometry data. Unsupported type %d."
-msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:398
-msgid "Attempt to access feature with invalid id (%"
-msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:404
-#, c-format
-msgid "Attempt to access alive feature %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:566 ../lib/vector/Vlib/write_nat.c:602
-#, c-format
-msgid "%s: Area %d does not exist"
-msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:756
-#, c-format
-msgid "Attempt to access dead area %d"
-msgstr ""
-#: ../lib/vector/Vlib/write.c:30 ../lib/vector/Vlib/write.c:36
-#: ../lib/vector/Vlib/write.c:42 ../lib/vector/Vlib/write.c:49
-#: ../lib/vector/Vlib/read.c:25
-msgid "for this format/level not supported"
-msgstr ""
-#: ../lib/vector/Vlib/write.c:56 ../lib/vector/Vlib/write.c:62
-#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/read.c:32
-#: ../lib/vector/Vlib/rewind.c:29 ../lib/vector/Vlib/build.c:37
-#: ../lib/vector/Vlib/open.c:59
-msgid "Requested format is not compiled in this version"
-msgstr ""
-#: ../lib/vector/Vlib/write.c:194
-#, c-format
-msgid "Unable to write feature in vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/write.c:234
-#, c-format
-msgid "Unable to rewrite feature/offset %lu in vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/write.c:266
-#, c-format
-msgid "Unable to delete feature/offset %lu from vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/write.c:299
-msgid "Unable to restore feature/offset %"
-msgstr ""
-#: ../lib/vector/Vlib/write.c:308
-#, c-format
-msgid "Vector map <%s> is not opened"
-msgstr ""
-#: ../lib/vector/Vlib/write.c:313
-#, c-format
-msgid "Vector map <%s> is not opened in write mode"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:84
-#, c-format
-msgid "Error reading ASCII file: (bad type) [%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:123
-#, c-format
-msgid "Error reading ASCII file: (unknown type) [%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:143
-msgid "End of ASCII file reached before end of coordinates"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:155
-#, c-format
-msgid "Error reading ASCII file: (bad point) [%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:160
-#, c-format
-msgid "Unparsable longitude value: [%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:165
-#, c-format
-msgid "Unparsable latitude value: [%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:201
-msgid "End of ASCII file reached before end of categories"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:212
-#, c-format
-msgid "Error reading categories: [%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:225
-msgid "Unable to copy points"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:238
-#, c-format
-msgid "Vector map <%s> is 2D. %d 3D features (faces or kernels) skipped."
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:270
-#, c-format
-msgid ""
-"Unexpected data in vector header:\n"
-"[%s]"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:306
-#, c-format
-msgid "Unknown keyword <%s> in vector head"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:465
-#, c-format
-msgid "Column <%s> does not exist"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:467
-msgid "Available columns:"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:472
-msgid "Export cancelled"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:505
-#, c-format
-msgid "Unknown type of column <%s>, export cancelled"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:539
-#, c-format
-msgid "Unable to select record from table <%s> (key %s, column %s)"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:661
-#, c-format
-msgid "Unknown feature type %d"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:701
-#, c-format
-msgid "Feature has more categories. Only one category (%d) is exported."
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:718
-#, c-format
-msgid "Cannot select attributes for cat = %d"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:724
-msgid "Unable to fetch data from table"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:758
-#, c-format
-msgid "Column <%s>: unsupported data type"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:840
-msgid "Unknown format"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:850
-msgid "Topology not available, unable to process areas"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:863
-#, c-format
-msgid "Unable to get boundary of area id %d"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:875
-#, c-format
-msgid "Unable to get boundary of isle id %d (area id %d)"
-msgstr ""
-#: ../lib/vector/Vlib/ascii.c:889
-#, c-format
-msgid ""
-"%d features without category skipped. To export also features without "
-"category use '%s=-1'."
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:32
-msgid "Category index is not up to date"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:38
-msgid "Layer index out of range"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:268
-msgid "Category index out of range"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:488
-#, c-format
-msgid "Unable to create category index file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:497
-msgid "Error writing out category index file"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:539 ../lib/vector/Vlib/open.c:393
-#, c-format
-msgid "Unable to open category index file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:52
-msgid "vector map is not opened"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:55
-#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:60
-msgid "only native format supported"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:258
-msgid "Attempt to read dead line"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:90
-#, c-format
-msgid "Vect_read_area_geos(): unable to read area id %d"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:104
-#, c-format
-msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:205
-#, c-format
-msgid "Unable to read line offset %ld"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:412
-#, c-format
-msgid "Attempt to read points of nonexistent area id %d"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:472
-#, c-format
-msgid "Unable to read feature id %d"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:139 ../lib/vector/Vlib/map.c:245
-msgid "Vector map name is not SQL compliant"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:143
-#, c-format
-msgid "Unable to find vector map <%s> in <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:155 ../lib/vector/Vlib/map.c:249
-#: ../lib/vector/Vlib/open.c:821
-#, c-format
-msgid "Vector map <%s> already exists and will be overwritten"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:159 ../lib/vector/Vlib/open.c:813
-#: ../lib/vector/Vlib/open.c:826
-#, c-format
-msgid "Unable to delete vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:179 ../lib/vector/Vlib/map.c:267
-#, c-format
-msgid "Unable to copy vector map <%s> to <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:317 ../lib/vector/Vlib/close_nat.c:102
-#: ../lib/vector/Vlib/copy.c:764
-#, c-format
-msgid "Unable to copy table <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:331 ../lib/vector/Vlib/map.c:462
-#, c-format
-msgid "Unable to delete table <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:346
-#, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:402
-#, c-format
-msgid "Ignoring invalid mapset: %s"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:407
-#, c-format
-msgid "Invalid vector map name <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:417
-#, c-format
-msgid "Unable to open header file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:449
-#, c-format
-msgid "Unable to find table <%s> linked to vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:472
-#, c-format
-msgid "Table <%s> linked to vector map <%s> does not exist"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:485
-#, c-format
-msgid "Unable to open directory '%s'"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:499
-#, c-format
-msgid "Unable to delete file '%s'"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:519
-#, c-format
-msgid "Unable to rename directory '%s' to '%s'"
-msgstr ""
-#: ../lib/vector/Vlib/map.c:528
-#, c-format
-msgid "Unable to remove directory '%s': %s"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:96
-#, c-format
-msgid "%d errors in category string"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
-msgid "Mixed area and other type requested for vector array"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
-#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
-msgid "Not enough space in vector array"
-msgstr ""
-#: ../lib/vector/Vlib/array.c:292
-#, c-format
-msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr ""
-#: ../lib/vector/Vlib/break_lines.c:574
-#, c-format
-msgid "Intersections: %d"
-msgstr ""
-#: ../lib/vector/Vlib/bridges.c:213
-#, c-format
-msgid "Removed lines: %d"
-msgstr ""
-#: ../lib/vector/Vlib/bridges.c:214
-#, c-format
-msgid "Removed bridges: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:129
-msgid "Building areas..."
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:153
-#, c-format
-msgid "One area built"
-msgid_plural "%d areas built"
-msgstr[0] ""
-#: ../lib/vector/Vlib/build_nat.c:154
-#, c-format
-msgid "One isle built"
-msgid_plural "%d isles built"
-msgstr[0] ""
-#: ../lib/vector/Vlib/build_nat.c:163
-msgid "Attaching islands..."
-msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:180
-msgid "Attaching centroids..."
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:45
-msgid "Vect_new_cats_struct(): Out of memory"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:127
-#, c-format
-msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:419
-#, c-format
-msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
-msgid "Layer number must be > 0 for category constraints"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:585
-#, c-format
-msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:593
-#, c-format
-msgid "Loading categories from table <%s>..."
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:605
-#, c-format
-msgid "One category loaded"
-msgid_plural "%d categories loaded"
-msgstr[0] ""
-#: ../lib/vector/Vlib/cats.c:627
-#, c-format
-msgid "No categories selected with '%s' option"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:637
-#, c-format
-msgid "%d errors in '%s' option"
-msgstr ""
-#: ../lib/vector/Vlib/clean_nodes.c:248
-#, c-format
-msgid "Modifications: %d"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:91
-#, c-format
-msgid "Unable to create vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:108
-msgid "Copying features failed"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:141
-#, c-format
-msgid "Unable to open %s file"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:226
-#, c-format
-msgid "Unable to close vector <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:257
-#, c-format
-msgid "Invalid request for writing frmt file - map format is %d"
-msgstr ""
-#: ../lib/vector/Vlib/close.c:289
-#, c-format
-msgid "Link to vector map <%s> created"
-msgstr ""
-#: ../lib/vector/Vlib/close_nat.c:74
-#, c-format
-msgid "Unable to create '%s': %s"
-msgstr ""
-#: ../lib/vector/Vlib/close_nat.c:81
-#, c-format
-msgid "Unable to copy '%s': %s"
-msgstr ""
-#: ../lib/vector/Vlib/close_nat.c:167
-#, c-format
-msgid "Unable to drop table <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/close_ogr.c:104 ../lib/vector/Vlib/close_pg.c:139
-#, c-format
-msgid "Unable to save feature index file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:148
-msgid "Changed"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:151
-msgid "Removed"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:154
-msgid "Selected"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:262
-#, c-format
-msgid "%s lines: %d"
-msgstr ""
-#: ../lib/vector/Vlib/dangles.c:263
-#, c-format
-msgid "%s dangles: %d"
-msgstr ""
-#: ../lib/vector/Vlib/dgraph.c:432
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:91
-msgid "Layer number must be 1 or greater"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:96
-msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:103
-msgid "Unable to add attribute link"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:109
-msgid "Unable to write attribute links"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:154
-msgid "Unable to write database links"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:178
-msgid "Database connection not defined. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/field.c:185
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
-msgstr ""
-#: ../lib/vector/Vlib/field.c:261
-#, c-format
-msgid "Layer number %d or name <%s> already exists"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:345
-#, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:352
-msgid "Default driver is not set"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:355
-msgid "Default database is not set"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:428
-#, c-format
-msgid "Requested dblink %d, maximum link number %d"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:614 ../lib/vector/Vlib/field.c:622
-#, c-format
-msgid "Error in rule on row %d in <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:690 ../lib/vector/Vlib/open_ogr.c:77
-#, c-format
-msgid "Unable to open OGR data source '%s'"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:707
-#, c-format
-msgid "Unable to open OGR layer <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:734
-msgid "Unable to open OGR DBMI driver"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:773
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:840
-#, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
-msgstr ""
-#: ../lib/vector/Vlib/field.c:860
-msgid "GRASS not compiled with PostgreSQL support"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:892
-msgid "Unknown vector map format"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:925
-#, c-format
-msgid "Unable to create database definition file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:1020
-msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-#: ../lib/vector/Vlib/intersect2.c:1215 ../lib/vector/Vlib/intersect2.c:1221
-#: ../lib/vector/Vlib/intersect2.c:1223 ../lib/vector/Vlib/intersect2.c:1275
-#: ../lib/vector/Vlib/intersect2.c:1284 ../lib/vector/Vlib/intersect2.c:1305
-#: ../lib/vector/Vlib/intersect2.c:1322 ../lib/vector/Vlib/intersect.c:1194
-#: ../lib/vector/Vlib/intersect.c:1200 ../lib/vector/Vlib/intersect.c:1202
-#: ../lib/vector/Vlib/intersect.c:1257 ../lib/vector/Vlib/intersect.c:1266
-#: ../lib/vector/Vlib/intersect.c:1287 ../lib/vector/Vlib/intersect.c:1304
-msgid "Error while adding point to array. Out of memory"
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:43
-#, c-format
-msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:50
-#, c-format
-msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:58
-#, c-format
-msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:65
-#, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:100 ../lib/vector/Vlib/legal_vname.c:104
-#, c-format
-msgid "Output vector map name <%s> is not in the current mapset (%s)"
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:117 ../lib/vector/Vlib/legal_vname.c:121
-#, c-format
-msgid "Output vector map name <%s> is not SQL compliant"
-msgstr ""
-#: ../lib/vector/Vlib/legal_vname.c:159 ../lib/vector/Vlib/legal_vname.c:163
-#, c-format
-msgid "Output vector map <%s> is used as input"
-msgstr ""
-#: ../lib/vector/Vlib/level.c:34
-msgid "Map structure was never initialized"
-msgstr ""
-#: ../lib/vector/Vlib/level.c:36
-msgid "Map structure has been closed"
-msgstr ""
-#: ../lib/vector/Vlib/level_two.c:23
-#, c-format
-msgid "Vector map <%s> is not open at topological level"
-msgstr ""
-#: ../lib/vector/Vlib/level_two.c:284
-#, c-format
-msgid "Invalid node id: %d"
-msgstr ""
-#: ../lib/vector/Vlib/level_two.c:316
-#, c-format
-msgid "Nodes not available for line %d"
-msgstr ""
-#: ../lib/vector/Vlib/level_two.c:357
-#, c-format
-msgid "Areas not available for line %d"
-msgstr ""
-#: ../lib/vector/Vlib/level_two.c:362
-#, c-format
-msgid "Line %d is not a boundary"
-msgstr ""
-#: ../lib/vector/Vlib/level_two.c:445
-#, c-format
-msgid "Topology info not available for feature %d"
-msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:241
-#, c-format
-msgid "%d lines merged"
-msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:242
-#, c-format
-msgid "%d new lines"
-msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:245
-#, c-format
-msgid "%d boundaries merged"
-msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:246
-#, c-format
-msgid "%d new boundaries"
-msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:249
-#, c-format
-msgid "%d lines and boundaries merged"
-msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:250
-#, c-format
-msgid "%d new lines and boundaries"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:60
-msgid "OGR datasource not defined"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:65 ../lib/vector/Vlib/write_ogr.c:129
-msgid "OGR layer not defined"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:97
-#, c-format
-msgid "OGR layer <%s> not found"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:191
-#, c-format
-msgid "Unable to get OGR driver <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:199
-#, c-format
-msgid "Unable to create OGR data source '%s'"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:211
-#, c-format
-msgid "OGR layer <%s> already exists and will be overwritten"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:215
-#, c-format
-msgid "Unable to delete OGR layer <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:221
-#, c-format
-msgid "OGR layer <%s> already exists in datasource '%s'"
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:279
-#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:284
-#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-msgstr ""
-#: ../lib/vector/Vlib/overlay.c:72
-msgid "unknown operator"
-msgstr ""
-#: ../lib/vector/Vlib/overlay.c:124
-msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr ""
-#: ../lib/vector/Vlib/overlay.c:127
-msgid "Overlay: area x area types not supported by AND operator"
-msgstr ""
-#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
-#: ../lib/vector/Vlib/read.c:168
-msgid "Vector map is not open for reading"
-msgstr ""
-#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
-#, c-format
-msgid "Unable to read feature %d from vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/read.c:200
-msgid "Line index is out of range"
-msgstr ""
-#: ../lib/vector/Vlib/read.c:224
-msgid "Node index is out of range"
-msgstr ""
-#: ../lib/vector/Vlib/read.c:248
-msgid "Area index is out of range"
-msgstr ""
-#: ../lib/vector/Vlib/read.c:272
-msgid "Isle index is out of range"
-msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
-#, c-format
-msgid "Unable to get feature geometry, fid %ld"
-msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:390
-msgid "OGR feature without ID"
-msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:514
-#, c-format
-msgid "OGR feature type '%s' not supported"
-msgstr ""
-#: ../lib/vector/Vlib/read_sfa.c:90
-#, c-format
-msgid "Unable to construct centroid for area %d. Skipped."
-msgstr ""
-#: ../lib/vector/Vlib/read_sfa.c:95
-#, c-format
-msgid "Centroid %d: invalid area %d"
-msgstr ""
-#: ../lib/vector/Vlib/read_sfa.c:124 ../lib/vector/Vlib/write_sfa.c:131
-#: ../lib/vector/Vlib/write_sfa.c:173 ../lib/vector/Vlib/write_sfa.c:273
-msgid "GRASS is not compiled with OGR/PostgreSQL support"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:107 ../lib/vector/Vlib/remove_areas.c:268
-msgid "Area is composed of dead boundary"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:194 ../lib/vector/Vlib/remove_areas.c:602
-#, c-format
-msgid "%d areas of total size %g removed"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:395
-msgid "Could not delete line from coor"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:458
-msgid "dissolve_neighbour > 0, failed to build new area"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:501
-msgid "Dissolve with neighbour area: corrupt topology"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:497
-msgid "Failed to build new area"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:544 ../lib/vector/Vlib/remove_areas.c:571
-msgid "Failed to build new isle"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:549 ../lib/vector/Vlib/remove_areas.c:576
-msgid "Dissolve with outer isle: corrupt topology"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:581
-msgid "Area merging failed"
-msgstr ""
-#: ../lib/vector/Vlib/remove_duplicates.c:199
-#, c-format
-msgid "Removed duplicates: %d"
-msgstr ""
-#: ../lib/vector/Vlib/select.c:116
-#, c-format
-msgid "Unable to delete item %d from spatial index"
-msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:225
-#, c-format
-msgid "Unknown Simple Features type (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:324 ../lib/vector/Vlib/write_pg.c:321
-#: ../lib/vector/Vlib/write_pg.c:811 ../lib/vector/Vlib/write_pg.c:1213
-#: ../lib/vector/Vlib/write_pg.c:1371
-msgid "No connection defined"
-msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:332
-msgid "Unable to get number of simple features"
-msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:341
-#, c-format
-msgid "Unable to report simple features for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:223 ../lib/vector/Vlib/snap.c:582
-msgid "Snap vertices Pass 1: select points"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:270 ../lib/vector/Vlib/snap.c:636
-msgid "Snap vertices Pass 2: assign anchor vertices"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:339 ../lib/vector/Vlib/snap.c:705
-msgid "Snap vertices Pass 3: snap to assigned points"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:525 ../lib/vector/Vlib/snap.c:888
-#, c-format
-msgid "Snapped vertices: %d"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:526 ../lib/vector/Vlib/snap.c:889
-#, c-format
-msgid "New vertices: %d"
-msgstr ""
-#: ../lib/vector/Vlib/snap.c:916
-msgid "Reading features..."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:96 ../lib/vector/Vlib/write_sfa.c:164
-#: ../lib/vector/Vlib/write_pg.c:187 ../lib/vector/Vlib/write_pg.c:255
-msgid "Unable to rewrite feature (incompatible feature types)"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:134 ../lib/vector/Vlib/write_pg.c:326
-#, c-format
-msgid "Invalid offset (%ld)"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:140 ../lib/vector/Vlib/write_pg.c:347
-msgid "Unable to delete feature"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:240
-#, c-format
-msgid "Creating field <%s> failed"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:306 ../lib/vector/Vlib/write_pg.c:1105
-#, c-format
-msgid "Unsupported geometry type (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:328
-#, c-format
-msgid "Unable to create OGR layer <%s> in '%s'"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:340 ../lib/vector/Vlib/write_pg.c:1118
-#, c-format
-msgid "More layers defined, using driver <%s> and database <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:346 ../lib/vector/Vlib/write_pg.c:1123
-msgid "Database connection not defined. Unable to write attributes."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:410 ../lib/vector/Vlib/write_pg.c:1238
-#: ../lib/vector/Vlib/write_pg.c:1403
-#, c-format
-msgid "No category defined for layer %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:412 ../lib/vector/Vlib/write_pg.c:1240
-#: ../lib/vector/Vlib/write_pg.c:1405
-#, c-format
-msgid "Feature has more categories, using category %d (from layer %d)"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:426
-msgid "Feature is not a point. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:434
-msgid "Feature is not a line. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:441
-msgid "Feature is not a polygon. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:448
-msgid "Feature is not a face. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:454
-#, c-format
-msgid "Unsupported feature type (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:473
-msgid "Boundary is not closed. Feature skipped."
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:502
-msgid "Unable to writes feature attributes"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:567
-#, c-format
-msgid "Feature without category of layer %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:581 ../lib/vector/Vlib/write_pg.c:2013
-#, c-format
-msgid "Unable to select attributes for category %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:593 ../lib/vector/Vlib/write_pg.c:2022
-#, c-format
-msgid "No database record for category %d, no attributes will be written"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:626
-#, c-format
-msgid "Unable to create field <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:655 ../lib/vector/Vlib/write_pg.c:2082
-#, c-format
-msgid "Unsupported column type %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:117
-msgid "Unable to calculate centroid for area"
-msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:219
-msgid "Attempt to delete dead feature"
-msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:311
-#, c-format
-msgid "Unsupported vector map format (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:349 ../lib/vector/Vlib/write_pg.c:554
-#: ../lib/vector/Vlib/write_pg.c:1301
-msgid "Boundary is not closed. Skipping."
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:285
-#, c-format
-msgid "Unable to rewrite feature %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:452
-#, c-format
-msgid "Unable to delete feature (%s) %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:773
-#, c-format
-msgid "Building spatial index on <%s>..."
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:841
-#, c-format
-msgid "Schema <%s> doesn't exist, created"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:920
-#, c-format
-msgid "Creating topology schema <%s>..."
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:934
-#, c-format
-msgid "Adding new topology column <%s>..."
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1130
-msgid "Unable to create new PostGIS feature table"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1144
-msgid "Unable to create new PostGIS topology schema"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1251
-#, c-format
-msgid "Point skipped (output feature type: %s)"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1258
-#, c-format
-msgid "Line skipped (output feature type: %s)"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1265
-#, c-format
-msgid "Centroid skipped (output feature type: %s)"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1272
-#, c-format
-msgid "Boundary skipped (output feature type: %s)"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1279
-#, c-format
-msgid "Face skipped (output feature type: %s)"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1365
-#, c-format
-msgid "Invalid feature type (%d) for nodes"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1379
-msgid "PostGIS topology schema not defined"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1880
-msgid "Trying to insert 3D data into feature table which store 2D data only"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1885
-msgid "Trying to insert 2D data into feature table which store 3D data only"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1910
-msgid "Unable to insert topological element into PostGIS Topology schema"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2048
-#, c-format
-msgid "FID column must be integer, column <%s> ignored!"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2089
-msgid "Invalid value for FID column: NULL"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2181
-#, c-format
-msgid "Invalid feature %d (max: %d)"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2195
-#, c-format
-msgid "Invalid feature type (%d) for node"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2199
-#, c-format
-msgid "Invalid node %d (%d)"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2277
-#, c-format
-msgid "Unable to determine next left/right edge for edge %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2282
-msgid "Unable to insert new edge. Topology not available."
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2381 ../lib/vector/Vlib/write_pg.c:2388
-msgid "Invalid topology"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2587 ../lib/vector/Vlib/write_pg.c:2684
-#, c-format
-msgid "Attempt to access non-existing feature %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2618
-msgid "Unable to determine next left/right edge"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2704
-msgid "Unable to create new face"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2842 ../lib/vector/Vlib/write_pg.c:2854
-#, c-format
-msgid "Unable to delete node %d"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:127
-msgid "3D not supported by Vect_segment_intersection()"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:353
-msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
-msgstr ""
-#: ../lib/vector/Vlib/intersect.c:447
-msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-#: ../lib/vector/Vlib/net_analyze.c:291 ../lib/vector/Vlib/net_analyze.c:332
-#, c-format
-msgid "Unable to find point with defined unique category for node <%d>."
-msgstr ""
-#: ../lib/vector/Vlib/net_analyze.c:295 ../lib/vector/Vlib/net_analyze.c:336
-#, c-format
-msgid ""
-"There exists more than one point on node <%d> with unique category in field  <%d>.\n"
-"The unique category layer may not be valid."
-msgstr ""
-#: ../lib/vector/Vlib/net_analyze.c:452
-msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:115
-msgid "Area of size = 0.0 (less than 4 vertices) ignored"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:131
-msgid "Unable to add area (map closed, topo saved)"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:139
-msgid "Unable to add isle (map closed, topo saved)"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:149
-msgid "Area of size = 0.0 ignored"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:200
-msgid "Request to find area outside nonexistent isle"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:351
-msgid "Larger bbox but smaller area!!!"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:606
-msgid "Checking for topological errors..."
-msgstr ""
-#: ../lib/vector/Vlib/build.c:641
-#, c-format
-msgid "Number of lines of length zero: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:643
-#, c-format
-msgid "Number of boundaries of length zero: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:652
-#, c-format
-msgid "Number of boundary intersections: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:676
-msgid "Skipping further checks because of incorrect boundaries"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:726
-#, c-format
-msgid "Number of redundant holes: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:865 ../lib/vector/Vlib/open.c:367
-#: ../lib/vector/Vlib/open.c:871
-#, c-format
-msgid "Unable to open spatial index file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:871
-#, c-format
-msgid "Building topology for vector map <%s>..."
-msgstr ""
-#: ../lib/vector/Vlib/build.c:889
-msgid "Topology was built"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:900
-#, c-format
-msgid "Number of nodes: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:901
-#, c-format
-msgid "Number of primitives: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:902
-#, c-format
-msgid "Number of points: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:903
-#, c-format
-msgid "Number of lines: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:904
-#, c-format
-msgid "Number of boundaries: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:905
-#, c-format
-msgid "Number of centroids: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:908
-#, c-format
-msgid "Number of faces: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:911
-#, c-format
-msgid "Number of kernels: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:957
-#, c-format
-msgid "Number of areas: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:958
-#, c-format
-msgid "Number of isles: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:963
-#, c-format
-msgid "Number of areas without centroid: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:968
-#, c-format
-msgid "Number of centroids exceeds number of areas: %d > %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:972
-#, c-format
-msgid "Number of incorrect boundaries: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:976
-#, c-format
-msgid "Number of centroids outside area: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:980
-#, c-format
-msgid "Number of duplicate centroids: %d"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:984
-msgid "Number of areas: -"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:985
-msgid "Number of isles: -"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:1013
-#, c-format
-msgid "Unable to create topo file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:1021
-msgid "Error writing out topo file"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:1210
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:1233
-#, c-format
-msgid "%s is no longer supported"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:1256
-msgid "Spatial index not available, can not be saved"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:1268
-#, c-format
-msgid "Unable to create spatial index file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/build.c:1277
-msgid "Error writing out spatial index file"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:81
-#, c-format
-msgid "Unable to copy features. Input vector map <%s> is not open"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:102
-#, c-format
-msgid "Unable to create PostGIS layer <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:134
-#, c-format
-msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:169 ../lib/vector/Vlib/copy.c:246
-#: ../lib/ogsf/gp3.c:92
-#, c-format
-msgid "Unable to read vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:230 ../lib/vector/Vlib/copy.c:235
-msgid "Copying features..."
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:232
-#, c-format
-msgid "Copying features (%s)..."
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:358
-msgid "Writing new feature failed"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:364
-#, c-format
-msgid "%d features without category or from different layer skipped"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:396
-msgid "Exporting nodes..."
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:424
-#, c-format
-msgid "Writing node %d failed"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:502
-msgid "Exporting areas..."
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:560 ../lib/vector/Vlib/copy.c:568
-#, c-format
-msgid "Writing area %d failed"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:576
-#, c-format
-msgid "%d areas without category or from different layer skipped"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:630
-#, c-format
-msgid "Unable to copy table <%s> for layer %d from <%s> to <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:749
-#, c-format
-msgid "Unable to add database link for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:773
-#, c-format
-msgid "Unable to open database <%s> with driver <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:780
-msgid "Unable to create index"
-msgstr ""
-#: ../lib/vector/Vlib/copy.c:786
-#, c-format
-msgid "Unable to grant privileges on table <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:72
-msgid "Empty OGR layer, nothing to build"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:89
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build "
-"topology."
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:139
-#, c-format
-msgid "Unable to open fidx file for write <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:138
-#, c-format
-msgid "Programmer requested unknown access level %d"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:232
-#, c-format
-msgid "Vector map <%s> not found in current mapset"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:252
-msgid "Temporary vector maps can be accessed only in the current mapset"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:277
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:311
-#, c-format
-msgid "Unable to read header file of vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:352
-#, c-format
-msgid "Unable to open topology file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:419
-#, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"with v.build."
-msgstr ""
-#: ../lib/vector/Vlib/open.c:445
-#, c-format
-msgid "Building topology for OGR layer <%s> from datasource '%s'..."
-msgstr ""
-#: ../lib/vector/Vlib/open.c:453
-#, c-format
-msgid "Unable to open vector map <%s> on level %d"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:507
-#, c-format
-msgid "Unable to open history file for vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:777
-#, c-format
-msgid "Unable to create vector map: <%s> is not in the current mapset (%s)"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:786
-#, c-format
-msgid "Unable to create vector map: <%s> is not SQL compliant"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:846
-#, c-format
-msgid "Unable to open history file of vector map <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:887
-#, c-format
-msgid "Using OGR/%s format"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:891
-msgid "Using PostGIS Topology format"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:893
-msgid "Using PostGIS format"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:896
-msgid "Using native format"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:985
-#, c-format
-msgid "Unable to stat file <%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:1049
-#, c-format
-msgid "unknown %d (update Vect_maptype_info)"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:1138
-msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:1149 ../lib/vector/Vlib/open.c:1248
-#, c-format
-msgid "Please rebuild topology for vector map <%s@%s>"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:1237
-msgid "Size of 'coor' file differs from value saved in sidx file"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:1317
-msgid "Unable to open OGR file"
-msgstr ""
-#: ../lib/vector/Vlib/open.c:1343
-msgid "OGR output also detected, using OGR"
-msgstr ""
-#: ../lib/vector/vedit/cats.c:63
-#, c-format
-msgid "Unable to set category %d for (feature id %d)"
-msgstr ""
-#: ../lib/vector/vedit/delete.c:40
-#, c-format
-msgid "Attempt to delete dead feature (%d)"
-msgstr ""
-#: ../lib/vector/vedit/delete.c:72
-#, c-format
-msgid "No area found for centroid %d"
-msgstr ""
-#: ../lib/vector/vedit/delete.c:76
-#, c-format
-msgid "Duplicate centroid %d, unable to delete area"
-msgstr ""
-#: ../lib/vector/vedit/delete.c:105
-#, c-format
-msgid "Area %d without centroid"
-msgstr ""
-#: ../lib/vector/vedit/delete.c:121
-#, c-format
-msgid "Area %d has no boundaries"
-msgstr ""
-#: ../lib/vector/vedit/select.c:231
-msgid "Unknown query tool"
-msgstr ""
-#: ../lib/vector/neta/utils.c:200
-#, c-format
-msgid "Point %d is not connected!"
-msgstr ""
-#: ../lib/vector/neta/utils.c:235
-#, c-format
-msgid "'%s' must be > 0"
-msgstr ""
-#: ../lib/vector/neta/utils.c:244
-msgid "'where' and 'cats' parameters were supplied, cat will be ignored"
-msgstr ""
-#: ../lib/vector/neta/utils.c:247
-msgid "Unable to load data from database"
-msgstr ""
-#: ../lib/vector/neta/utils.c:254
-msgid "Problem loading category values"
-msgstr ""
-#: ../lib/vector/neta/spanningtree.c:109
-msgid "Computing minimum spanning tree..."
-msgstr ""
-#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
-#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
-#, c-format
-msgid "Unable to open select cursor: %s"
-msgstr ""
-#: ../lib/ogsf/gsd_img_tif.c:66 ../lib/ogsf/gk2.c:216
-#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
-#, c-format
-msgid "Unable to open file <%s> for writing"
-msgstr ""
-#: ../lib/ogsf/gk.c:320
-msgid "Need at least 3 keyframes for spline"
-msgstr ""
-#: ../lib/ogsf/gk.c:622
-msgid "Need at least 2 keyframes for interpolation"
-msgstr ""
-#: ../lib/ogsf/gk2.c:272 ../lib/ogsf/gk2.c:285
-msgid "Check no. of frames requested and keyframes marked"
-msgstr ""
-#: ../lib/ogsf/gp2.c:705
-msgid "Unknown icon marker, using \"sphere\""
-msgstr ""
-#: ../lib/ogsf/gp3.c:148
-#, c-format
-msgid "No points from vector map <%s> fall within current region"
-msgstr ""
-#: ../lib/ogsf/gp3.c:153
-#, c-format
-msgid "Vector map <%s> loaded (%d points)"
-msgstr ""
-#: ../lib/ogsf/gp3.c:211
-#, c-format
-msgid "Loading thematic points layer <%s>..."
-msgstr ""
-#: ../lib/ogsf/gp3.c:235 ../lib/ogsf/gv3.c:377
-#, c-format
-msgid "No color rule defined for category %d"
-msgstr ""
-#: ../lib/ogsf/gp3.c:249 ../lib/ogsf/gv3.c:392
-#, c-format
-msgid "Invalid color definition (%s)"
-msgstr ""
-#: ../lib/ogsf/gp3.c:288
-#, c-format
-msgid ""
-"%d points without category. Unable to determine color rules for features "
-"without category."
-msgstr ""
-#: ../lib/ogsf/gs2.c:1211
-#, c-format
-msgid "no category info"
-msgstr ""
-#: ../lib/ogsf/gs2.c:1230
-#, c-format
-msgid "no data"
-msgstr ""
-#: ../lib/ogsf/gs2.c:1655
-#, c-format
-msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-#: ../lib/ogsf/gs2.c:1733 ../lib/ogsf/gs2.c:1739 ../lib/ogsf/gs2.c:1747
-#: ../lib/ogsf/gs2.c:1756 ../lib/ogsf/gs2.c:1764 ../lib/ogsf/gs2.c:1774
-#: ../lib/ogsf/gs2.c:1822
-msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
-#: ../lib/ogsf/gs2.c:1850
-msgid "Loading failed"
-msgstr ""
-#: ../lib/ogsf/gs2.c:1854
-msgid "Error finding range"
-msgstr ""
-#: ../lib/ogsf/gs3.c:132 ../lib/ogsf/gs3.c:196 ../lib/ogsf/gs3.c:348
-#: ../lib/ogsf/gs3.c:454 ../lib/ogsf/gs3.c:540
-#, c-format
-msgid "Loading raster map <%s>..."
-msgstr ""
-#: ../lib/ogsf/gs3.c:596
-#, c-format
-msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-#: ../lib/ogsf/gs3.c:658 ../lib/ogsf/gs3.c:730
-#, c-format
-msgid "Translating colors from raster map <%s>..."
-msgstr ""
-#: ../lib/ogsf/gs3.c:967
-msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
-#: ../lib/ogsf/gs_bm.c:124
-msgid "Bitmap mismatch"
-msgstr ""
-#: ../lib/ogsf/gsd_label.c:58
-msgid "Max. number of labels reached!"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:246
-#, c-format
-msgid "Unable to read color file of raster map <%s>"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:252
-#, c-format
-msgid "Unable to read category file of raster map <%s>"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:269
-#, c-format
-msgid "Unable to read fp range of raster map <%s>"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:281
-#, c-format
-msgid "Unable to read range of raster map <%s>"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:295
-msgid "Range request error for legend"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:385
-msgid "Unable to show discrete FP range (use list)"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:501
-msgid "Too many categories to show as discrete!"
-msgstr ""
-#: ../lib/ogsf/gsd_legend.c:503
-msgid "Try using smaller font!"
-msgstr ""
-#: ../lib/ogsf/gsd_prim.c:155
-#, c-format
-msgid "Color Material: %d"
-msgstr ""
-#: ../lib/ogsf/gsd_prim.c:642
-#, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-#: ../lib/ogsf/gsd_surf.c:1742
-msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
-#: ../lib/ogsf/gsdrape.c:207
-msgid "Unable to process vector map - out of memory"
-msgstr ""
-#: ../lib/ogsf/gsds.c:109
-msgid "Maximum number of datasets exceeded"
-msgstr ""
-#: ../lib/ogsf/gv3.c:269
-#, c-format
-msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-#: ../lib/ogsf/gv3.c:274
-#, c-format
-msgid "Vector map <%s> loaded (%d features)"
-msgstr ""
-#: ../lib/ogsf/gv3.c:353
-#, c-format
-msgid "Loading thematic vector layer <%s>..."
-msgstr ""
-#: ../lib/ogsf/gv3.c:414
-#, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
-msgstr ""
-#: ../lib/ogsf/gvl2.c:267
-#, c-format
-msgid "Loading 3d raster map <%s>..."
-msgstr ""
-#: ../lib/ogsf/gvl_file.c:103
-msgid "Maximum number of datafiles exceeded"
-msgstr ""
-#: ../lib/ogsf/gvl_file.c:442
-#, c-format
-msgid "Unable to read range of 3D raster map <%s>"
-msgstr ""
-#: ../lib/ogsf/trans.c:180
-msgid "Out of matrix stack space"
-msgstr ""
-#: ../lib/ogsf/trans.c:200
-msgid "Tried to pop an empty stack"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:254 ../lib/gmath/solvers_krylov.c:482
-#: ../lib/gmath/solvers_krylov.c:646 ../lib/gmath/solvers_direct.c:134
-msgid "Unable to solve the linear equation system"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:262
-#, c-format
-msgid "Sparse PCG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:264
-#, c-format
-msgid "PCG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:490
-#, c-format
-msgid "Sparse CG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:492
-#, c-format
-msgid "CG -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:695
-#, c-format
-msgid "Sparse BiCGStab -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_krylov.c:698
-#, c-format
-msgid "BiCGStab -- iteration %i error  %g\n"
-msgstr ""
-#: ../lib/gmath/del2g.c:50
-msgid "    taking FFT of image..."
-msgstr ""
-#: ../lib/gmath/del2g.c:56
-msgid "    computing del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:59
-msgid "    taking FFT of del**2 g..."
-msgstr ""
-#: ../lib/gmath/del2g.c:63
-msgid "    multiplying transforms..."
-msgstr ""
-#: ../lib/gmath/del2g.c:66
-msgid "    taking inverse FFT..."
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:84
-#, c-format
-msgid "sparse Jacobi -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:156
-#, c-format
-msgid "sparse SOR -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:218
-#, c-format
-msgid "Jacobi -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:275
-#, c-format
-msgid "SOR -- iteration %5i error %g\n"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:45
-msgid "Starting direct gauss elimination solver"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:73
-msgid "Starting direct lu decomposition solver"
-msgstr ""
-#: ../lib/gmath/solvers_direct.c:131
-msgid "Starting cholesky decomposition solver"
-msgstr ""
-#: ../lib/gmath/solvers_direct_cholesky_band.c:33
-#, c-format
-msgid "Decomposition failed at row %i and col %i"
-msgstr ""
-#: ../lib/gmath/la.c:61 ../lib/gmath/la.c:117
-msgid "Matrix dimensions out of range"
-msgstr ""
-#: ../lib/gmath/la.c:150
-msgid "Matrix is not initialised fully."
-msgstr ""
-#: ../lib/gmath/la.c:155
-msgid "Unable to allocate space for matrix copy"
-msgstr ""
-#: ../lib/gmath/la.c:220
-msgid "Input matrix is uninitialized"
-msgstr ""
-#: ../lib/gmath/la.c:285
-msgid "First scalar multiplier must be non-zero"
-msgstr ""
-#: ../lib/gmath/la.c:291 ../lib/gmath/la.c:299 ../lib/gmath/la.c:364
-msgid "One or both input matrices uninitialised"
-msgstr ""
-#: ../lib/gmath/la.c:304 ../lib/gmath/la.c:369
-msgid "Matrix order does not match"
-msgstr ""
-#: ../lib/gmath/la.c:310
-msgid "Unable to allocate space for matrix sum"
-msgstr ""
-#: ../lib/gmath/la.c:374
-msgid "Unable to allocate space for matrix product"
-msgstr ""
-#: ../lib/gmath/la.c:486
-msgid "Input: one or both data matrices uninitialised"
-msgstr ""
-#: ../lib/gmath/la.c:491
-msgid "Principal matrix is not properly dimensioned"
-msgstr ""
-#: ../lib/gmath/la.c:496
-msgid "Input: you must have at least one array to solve"
-msgstr ""
-#: ../lib/gmath/la.c:502
-msgid "Could not allocate space for solution matrix"
-msgstr ""
-#: ../lib/gmath/la.c:508 ../lib/gmath/la.c:516
-msgid "Could not allocate space for working matrix"
-msgstr ""
-#: ../lib/gmath/la.c:569
-msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr ""
-#: ../lib/gmath/la.c:573
-msgid "Problem in LA routine."
-msgstr ""
-#: ../lib/gmath/la.c:580
-msgid "Procedure not yet available for selected matrix type"
-msgstr ""
-#: ../lib/gmath/la.c:614
-msgid "Matrix is not square. Cannot determine inverse"
-msgstr ""
-#: ../lib/gmath/la.c:619
-msgid "Unable to allocate space for matrix"
-msgstr ""
-#: ../lib/gmath/la.c:636
-msgid "Matrix is singular"
-msgstr ""
-#: ../lib/gmath/la.c:641
-msgid "Problem in LA procedure."
-msgstr ""
-#: ../lib/gmath/la.c:729
-msgid "Element array has not been allocated"
-msgstr ""
-#: ../lib/gmath/la.c:734
-msgid "Specified element is outside array bounds"
-msgstr ""
-#: ../lib/gmath/la.c:788
-msgid "Specified matrix column index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:793 ../lib/gmath/la.c:834 ../lib/gmath/la.c:1198
-#: ../lib/gmath/la.c:1250 ../lib/gmath/la.c:1325
-msgid "Matrix is not initialised"
-msgstr ""
-#: ../lib/gmath/la.c:798 ../lib/gmath/la.c:839
-msgid "Could not allocate space for vector structure"
-msgstr ""
-#: ../lib/gmath/la.c:829
-msgid "Specified matrix row index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:869
-msgid "Specified row index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:874
-msgid "Specified column index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:894
-msgid "Unknown vector type."
-msgstr ""
-#: ../lib/gmath/la.c:949
-msgid "Input matrix and vector have differing dimensions1"
-msgstr ""
-#: ../lib/gmath/la.c:955 ../lib/gmath/la.c:1071 ../lib/gmath/la.c:1361
-msgid "Output vector is uninitialized"
-msgstr ""
-#: ../lib/gmath/la.c:1076 ../lib/gmath/la.c:1366
-msgid "Vectors are not of the same type"
-msgstr ""
-#: ../lib/gmath/la.c:1081
-msgid "Output vector is of incorrect type"
-msgstr ""
-#: ../lib/gmath/la.c:1086 ../lib/gmath/la.c:1376
-msgid "Matrices not allowed"
-msgstr ""
-#: ../lib/gmath/la.c:1092 ../lib/gmath/la.c:1383
-msgid "Vectors have differing dimensions"
-msgstr ""
-#: ../lib/gmath/la.c:1098 ../lib/gmath/la.c:1390
-msgid "Output vector has incorrect dimension"
-msgstr ""
-#: ../lib/gmath/la.c:1143
-msgid "Vector dimensions out of range"
-msgstr ""
-#: ../lib/gmath/la.c:1148
-msgid "Row/column out of range"
-msgstr ""
-#: ../lib/gmath/la.c:1371
-msgid "Output vector is not the same type as others"
-msgstr ""
-#: ../lib/gmath/la.c:1437
-msgid "Vector structure is not initialised"
-msgstr ""
-#: ../lib/gmath/la.c:1558 ../lib/gmath/la.c:1566 ../lib/gmath/la.c:1571
-msgid "Input format error"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:40
-msgid ""
-"\n"
-"++ Running blas level 1 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:47
-msgid ""
-"\n"
-"-- blas level 1 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:49
-msgid ""
-"\n"
-"-- blas level 1 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/bench_blas2.c:35
-msgid ""
-"\n"
-"++ Running blas level 2 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/bench_blas3.c:34
-msgid ""
-"\n"
-"++ Running blas level 3 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/bench_solver_direct.c:34
-msgid ""
-"\n"
-"++ Running direct solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/bench_solver_krylov.c:34
-msgid ""
-"\n"
-"++ Running krylov solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:38
-msgid ""
-"\n"
-"++ Running blas level 2 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:44
-msgid ""
-"\n"
-"-- blas level 2 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:46
-msgid ""
-"\n"
-"-- blas level 2 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:38
-msgid ""
-"\n"
-"++ Running blas level 3 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:44
-msgid ""
-"\n"
-"-- blas level 3 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:46
-msgid ""
-"\n"
-"-- blas level 3 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:37
-msgid ""
-"\n"
-"++ Running ccmath wrapper unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:42
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:44
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:61
-msgid "The size of the matrices and vectors for benchmarking"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:68
-msgid "Choose solver benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:75
-msgid "Choose blas benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:106
-msgid "Performs benchmarks, unit and integration tests for the gmath library"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:37
-msgid ""
-"\n"
-"++ Running matrix conversion unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:42
-msgid ""
-"\n"
-"-- Matrix conversion unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:44
-msgid ""
-"\n"
-"-- Matrix conversion unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:37
-msgid ""
-"\n"
-"++ Running solver unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:42
-msgid ""
-"\n"
-"-- Solver unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:44
-msgid ""
-"\n"
-"-- Solver unit tests finished successfully --"
-msgstr ""
-#: ../lib/cluster/c_begin.c:57
-#, c-format
-msgid "produced by i.cluster"
-msgstr ""
-#: ../lib/cluster/c_exec.c:44
-#, c-format
-msgid "Not enough data points (%d) in cluster"
-msgstr ""
-#: ../lib/htmldriver/graph_set.c:97
-#, c-format
-msgid "html: collecting to file '%s'"
-msgstr ""
-#: ../lib/htmldriver/graph_set.c:98
-#, c-format
-msgid "html: image size %dx%d"
-msgstr ""
-#: ../lib/htmldriver/graph_set.c:111 ../lib/htmldriver/graph_set.c:115
-#: ../lib/htmldriver/graph_set.c:119
-#, c-format
-msgid "html: type '%s'"
-msgstr ""
-#: ../lib/gis/key_value3.c:33
-#, c-format
-msgid "Unable to open output file <%s>: %s"
-msgstr ""
-#: ../lib/gis/key_value3.c:36
-#, c-format
-msgid "Error writing file <%s>: %s"
-msgstr ""
-#: ../lib/gis/key_value3.c:39
-#, c-format
-msgid "Error closing output file <%s>: %s"
-msgstr ""
-#: ../lib/gis/key_value3.c:60
-#, c-format
-msgid "Unable to open input file <%s>: %s"
-msgstr ""
-#: ../lib/gis/key_value3.c:64
-#, c-format
-msgid "Error reading file <%s>: %s"
-msgstr ""
-#: ../lib/gis/key_value3.c:67
-#, c-format
-msgid "Error closing input file <%s>: %s"
-msgstr ""
-#: ../lib/gis/ls.c:103
-#, c-format
-msgid "Unable to open directory %s"
-msgstr ""
-#: ../lib/gis/parser_wps.c:490
-msgid "Multiple outputs are not supported by WPS 1.0.0"
-msgstr ""
-#: ../lib/gis/error.c:362
-msgid "WARNING: "
-msgstr ""
-#: ../lib/gis/error.c:363 ../lib/gis/parser.c:1588
-#, c-format
-msgid "ERROR: "
-msgstr ""
-#: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
-#, c-format
-msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr ""
-#: ../lib/gis/get_ellipse.c:356
-#, c-format
-msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr ""
-#: ../lib/gis/get_ellipse.c:370
-#, c-format
-msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr ""
-#: ../lib/gis/get_ellipse.c:383
-#, c-format
-msgid "No ellipsoid info given in file %s in <%s>"
-msgstr ""
-#: ../lib/gis/token.c:169
-msgid "parse error"
-msgstr ""
-#: ../lib/gis/cmprzlib.c:99 ../lib/gis/cmprzlib.c:195
-#: ../lib/gis/compress.c:303 ../lib/gis/cmprbzip.c:90
-#: ../lib/gis/cmprbzip.c:164 ../lib/gis/cmprlz4.c:81 ../lib/gis/cmprlz4.c:138
-msgid "No source buffer"
-msgstr ""
-#: ../lib/gis/cmprzlib.c:102 ../lib/gis/cmprzlib.c:198
-#: ../lib/gis/cmprbzip.c:93 ../lib/gis/cmprbzip.c:167 ../lib/gis/cmprlz4.c:84
-#: ../lib/gis/cmprlz4.c:141
-msgid "No destination buffer"
-msgstr ""
-#: ../lib/gis/cmprzlib.c:109 ../lib/gis/cmprzlib.c:205
-#: ../lib/gis/compress.c:305 ../lib/gis/cmprbzip.c:100
-#: ../lib/gis/cmprbzip.c:174 ../lib/gis/cmprlz4.c:91 ../lib/gis/cmprlz4.c:148
-#, c-format
-msgid "Invalid source buffer size %d"
-msgstr ""
-#: ../lib/gis/cmprzlib.c:111 ../lib/gis/cmprzlib.c:207
-#: ../lib/gis/compress.c:225 ../lib/gis/cmprbzip.c:102
-#: ../lib/gis/cmprbzip.c:176 ../lib/gis/cmprlz4.c:93 ../lib/gis/cmprlz4.c:150
-#, c-format
-msgid "Invalid destination buffer size %d"
-msgstr ""
-#: ../lib/gis/cmprzlib.c:139 ../lib/gis/cmprzlib.c:157
-#, c-format
-msgid "ZLIB compression error %d: %s"
-msgstr ""
-#: ../lib/gis/cmprzlib.c:225 ../lib/gis/cmprzlib.c:242
-#, c-format
-msgid "ZLIB decompression error %d: %s"
-msgstr ""
-#: ../lib/gis/distance.c:154
-#, c-format
-msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:147
-msgid "SQL SELECT statement"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:149
-msgid "Example: select * from towns where population > 10000"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:157
-msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:158
-msgid "Example: income < 1000 and population >= 10000"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:166
-msgid "Name of attribute table"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:175
-msgid "Name of database driver"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:184
-msgid "Name of database"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:193
-msgid "Database schema"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:194
-msgid ""
-"Do not use this option if schemas are not supported by driver/database "
-"server"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:203
-msgid "Name of attribute column"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:212
-msgid "Name of attribute column(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:221
-msgid "Name of key column"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:222
-msgid "Must refer to an integer column"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:234
-msgid "Name of input imagery group"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:242
-msgid "Name of input imagery subgroup"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:252
-msgid "Name of input raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:261
-msgid "Name of input raster map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:269
-msgid "Name for output raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:278
-msgid "Name for output raster map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:286
-msgid "Name of raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:295
-msgid "Name of raster map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:303
-msgid "Name of base raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:311
-msgid "Name of cover raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:319
-msgid "Name of input elevation raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:328
-msgid "Name of input elevation raster map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:335
-msgid "Type of raster map to be created"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:336
-msgid "Storage type for resultant raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:340
-msgid "Integer"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:341
-msgid "Single precision floating point"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:342
-msgid "Double precision floating point"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:348
-msgid "Sampling interpolation method"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:352
-msgid "Nearest-neighbor interpolation"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:353
-msgid "Bilinear interpolation"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:354
-msgid "Bicubic interpolation"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:363
-msgid "Name of input basename raster map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:372
-msgid "Name for output basename raster map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:382
-msgid "Name of input 3D raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:391
-msgid "Name of input 3D raster map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:399
-msgid "Name for output 3D raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:407
-msgid "Name of 3D raster map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:416
-msgid "Name of 3D raster map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:425
-msgid "Data type used in the output raster3d map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:434
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:444
-msgid "The compression method used in the output raster3d map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:454
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:464
-msgid "Name of input vector map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:465
-#: ../lib/gis/parser_standard_options.c:492
-msgid "Or data source for direct OGR access"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:474
-msgid "Name of input vector map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:475
-msgid "Or data source(s) for direct OGR access"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:483
-msgid "Name for output vector map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:491
-msgid "Name of vector map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:501
-msgid "Name of vector map(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:510
-#: ../lib/gis/parser_standard_options.c:519
-msgid "Input feature type"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:526
-msgid "Layer number or name"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:528
-msgid ""
-"Vector features can have category values in different layers. This number "
-"determines which layer to use. When used with direct OGR access this is the "
-"layer name."
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:538
-msgid "Layer number or name ('-1' for all layers)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:540
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:549
-msgid "Category value"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:557
-msgid "Category values"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:558
-#: ../lib/gis/parser_standard_options.c:573
-msgid "Example: 1,3,7-9,13"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:565
-msgid "Feature id"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:572
-msgid "Feature ids"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:583
-#: ../lib/gis/parser_standard_options.c:591
-msgid "Name of input file"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:599
-msgid "Name for output file"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:608
-msgid "Field separator"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:609
-msgid "Special characters: pipe, comma, space, tab, newline"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:620
-#: ../lib/gis/parser_standard_options.c:631
-msgid "Color"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:622
-msgid "Either a standard color name or R:G:B triplet"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:633
-msgid "Either a standard color name, R:G:B triplet, or \"none\""
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:644
-msgid "Name of input directory"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:654
-msgid "Units"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:663
-msgid "Data type(s)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:673
-msgid "Name of mapset (default: current search path)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:674
-msgid "'.' for current mapset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:682
-msgid "Location name"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:683
-msgid "Location name (not location path)"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:693
-msgid "GRASS GIS database directory"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:694
-msgid "Default: path to the current GRASS GIS database"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:706
-msgid "Coordinates"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:715
-msgid "Name of color table"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:726
-msgid "String representing NULL value"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:735
-msgid "Name of saved region"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:745
-msgid "Name of the input space time dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:754
-msgid "Name of the input space time datasets"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:762
-msgid "Name of the output space time dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:770
-msgid "Name of the input space time raster dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:779
-msgid "Name of the input space time raster datasets"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:787
-msgid "Name of the output space time raster dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:795
-msgid "Name of the input space time vector dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:804
-msgid "Name of the input space time vector datasets"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:812
-msgid "Name of the output space time vector dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:820
-msgid "Name of the input space time raster3d dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:829
-msgid "Name of the input space time raster3d datasets"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:837
-msgid "Name of the output space time raster3d dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:846
-msgid "Type of the input space time dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:854
-msgid "Name of the input map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:863
-msgid "Name of the input maps"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:872
-msgid "Type of the input map"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:881
-msgid "The temporal type of the space time dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:888
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword used in the "
-"temporal GIS framework"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:889
-msgid "Example: start_time > '2001-01-01 12:30:00'"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:899
-msgid "The method to be used for sampling the input dataset"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:933
-msgid "Do not create attribute table"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:937
-msgid "Do not build topology"
-msgstr ""
-#: ../lib/gis/parser_standard_options.c:938
-msgid "Advantageous when handling a large number of points"
-msgstr ""
-#: ../lib/gis/find_file.c:114
-#, c-format
-msgid "Data element '%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr ""
-#: ../lib/gis/find_file.c:127
-#, c-format
-msgid "Using <%s@%s>..."
-msgstr ""
-#: ../lib/gis/gisinit.c:53 ../lib/gis/gisinit.c:87
-#, c-format
-msgid ""
-"Module built against version %s but trying to use version %s. You need to "
-"rebuild GRASS GIS or untangle multiple installations."
-msgstr ""
-#: ../lib/gis/gisinit.c:65
-#, c-format
-msgid "MAPSET %s - permission denied"
-msgstr ""
-#: ../lib/gis/gisinit.c:68
-#, c-format
-msgid "MAPSET %s not found at %s"
-msgstr ""
-#: ../lib/gis/gisinit.c:102
-msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-#: ../lib/gis/lrand48.c:84
-#, c-format
-msgid "gettimeofday failed: %s"
-msgstr ""
-#: ../lib/gis/lrand48.c:114
-msgid "Pseudo-random number generator not seeded"
-msgstr ""
-#: ../lib/gis/parser_html.c:57 ../lib/gis/parser_rest.c:60
-msgid "NAME"
-msgstr ""
-#: ../lib/gis/parser_html.c:70 ../lib/gis/parser_rest.c:73
-msgid "KEYWORDS"
-msgstr ""
-#: ../lib/gis/parser_html.c:75 ../lib/gis/parser_rest.c:78
-msgid "SYNOPSIS"
-msgstr ""
-#: ../lib/gis/parser_html.c:167 ../lib/gis/parser_help.c:215
-#: ../lib/gis/parser_interface.c:329 ../lib/gis/parser_rest.c:164
-msgid "Allow output files to overwrite existing files"
-msgstr ""
-#: ../lib/gis/parser_html.c:171 ../lib/gis/parser_help.c:217
-#: ../lib/gis/parser_interface.c:337
-msgid "Print usage summary"
-msgstr ""
-#: ../lib/gis/parser_html.c:174 ../lib/gis/parser_help.c:218
-#: ../lib/gis/parser_interface.c:344 ../lib/gis/parser_rest.c:168
-msgid "Verbose module output"
-msgstr ""
-#: ../lib/gis/parser_html.c:177 ../lib/gis/parser_help.c:219
-#: ../lib/gis/parser_interface.c:351 ../lib/gis/parser_rest.c:171
-msgid "Quiet module output"
-msgstr ""
-#: ../lib/gis/parser_html.c:180 ../lib/gis/parser_help.c:221
-msgid "Force launching GUI dialog"
-msgstr ""
-#: ../lib/gis/parser_html.c:233 ../lib/gis/parser_rest.c:223
-msgid "Options"
-msgstr ""
-#: ../lib/gis/parser_html.c:239 ../lib/gis/parser_rest.c:230
-msgid "Default"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:141 ../lib/gis/rd_cellhd.c:180
-#: ../lib/gis/rd_cellhd.c:357
-#, c-format
-msgid "Syntax error in cell header, line %d: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:150
-msgid "Duplicate projection field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:153
-#, c-format
-msgid "Invalid projection field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:160
-msgid "Duplicate zone field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:163
-#, c-format
-msgid "Invalid zone field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:170 ../lib/gis/rd_cellhd.c:172
-#: ../lib/gis/rd_cellhd.c:363 ../lib/gis/rd_cellhd.c:365
-#: ../lib/gis/rd_cellhd.c:367 ../lib/gis/rd_cellhd.c:369
-#: ../lib/gis/rd_cellhd.c:371 ../lib/gis/rd_cellhd.c:373
-#: ../lib/gis/rd_cellhd.c:384 ../lib/gis/rd_cellhd.c:386
-#: ../lib/gis/rd_cellhd.c:388 ../lib/gis/rd_cellhd.c:390
-#, c-format
-msgid "Field <%s> missing"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:195
-msgid "Duplicate north field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:197
-#, c-format
-msgid "Invalid north field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:203
-msgid "Duplicate south field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:205
-#, c-format
-msgid "Invalid south field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:211
-msgid "Duplicate east field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:213
-#, c-format
-msgid "Invalid east field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:219
-msgid "Duplicate west field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:221
-#, c-format
-msgid "Invalid west field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:227
-msgid "Duplicate top field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:229
-#, c-format
-msgid "Invalid top field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:235
-msgid "Duplicate bottom field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:237
-#, c-format
-msgid "Invalid bottom field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:243
-msgid "Duplicate e-w resolution field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:245 ../lib/gis/rd_cellhd.c:247
-#, c-format
-msgid "Invalid e-w resolution field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:253
-msgid "Duplicate 3D e-w resolution field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:255 ../lib/gis/rd_cellhd.c:257
-#, c-format
-msgid "Invalid 3D e-w resolution field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:263
-msgid "Duplicate n-s resolution field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:265 ../lib/gis/rd_cellhd.c:267
-#, c-format
-msgid "Invalid n-s resolution field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:273
-msgid "Duplicate 3D n-s resolution field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:275 ../lib/gis/rd_cellhd.c:277
-#, c-format
-msgid "Invalid 3D n-s resolution field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:283
-msgid "Duplicate t-b resolution field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:285 ../lib/gis/rd_cellhd.c:287
-#, c-format
-msgid "Invalid t-b resolution field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:293
-msgid "Duplicate rows field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:295 ../lib/gis/rd_cellhd.c:297
-#, c-format
-msgid "Invalid rows field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:303
-msgid "Duplicate 3D rows field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:305 ../lib/gis/rd_cellhd.c:307
-#, c-format
-msgid "Invalid 3D rows field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:313
-msgid "Duplicate cols field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:315 ../lib/gis/rd_cellhd.c:317
-#, c-format
-msgid "Invalid cols field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:323
-msgid "Duplicate 3D cols field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:325 ../lib/gis/rd_cellhd.c:327
-#, c-format
-msgid "Invalid 3D cols field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:333
-msgid "Duplicate depths field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:335 ../lib/gis/rd_cellhd.c:337
-#, c-format
-msgid "Invalid depths field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:343
-msgid "Duplicate format field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:345
-#, c-format
-msgid "Invalid format field: %s"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:351
-msgid "Duplicate compressed field"
-msgstr ""
-#: ../lib/gis/rd_cellhd.c:353
-#, c-format
-msgid "Invalid compressed field: %s"
-msgstr ""
-#: ../lib/gis/spawn.c:386
-#, c-format
-msgid "CreateProcess() failed: error = %d"
-msgstr ""
-#: ../lib/gis/spawn.c:421
-#, c-format
-msgid "G_spawn: unable to redirect descriptor %d"
-msgstr ""
-#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
-#, c-format
-msgid "G_spawn: unable to open file %s"
-msgstr ""
-#: ../lib/gis/spawn.c:503
-msgid "G_spawn: unable to execute command"
-msgstr ""
-#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
-#, c-format
-msgid "G_spawn: unable to restore signal %d"
-msgstr ""
-#: ../lib/gis/spawn.c:567
-#, c-format
-msgid "G_spawn: unable to reset signal %d"
-msgstr ""
-#: ../lib/gis/spawn.c:576
-#, c-format
-msgid "G_spawn: unable to ignore signal %d"
-msgstr ""
-#: ../lib/gis/spawn.c:587
-#, c-format
-msgid "G_spawn: unable to block signal %d"
-msgstr ""
-#: ../lib/gis/spawn.c:595
-#, c-format
-msgid "G_spawn: unable to unblock signal %d"
-msgstr ""
-#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
-#, c-format
-msgid "G_spawn: unable to duplicate descriptor %d to %d"
-msgstr ""
-#: ../lib/gis/spawn.c:666
-#, c-format
-msgid "Unable to create a new process: %s"
-msgstr ""
-#: ../lib/gis/spawn.c:681
-#, c-format
-msgid "Unable to change directory to %s"
-msgstr ""
-#: ../lib/gis/spawn.c:689
-#, c-format
-msgid "Unable to execute command '%s': %s"
-msgstr ""
-#: ../lib/gis/env.c:311
-msgid "GISRC - variable not set"
-msgstr ""
-#: ../lib/gis/env.c:343 ../lib/gis/env.c:369
-#, c-format
-msgid "Variable '%s' not set"
-msgstr ""
-#: ../lib/gis/compress.c:132 ../lib/gis/compress.c:193
-#: ../lib/gis/compress.c:208
-msgid "Request for unsupported compressor"
-msgstr ""
-#: ../lib/gis/compress.c:223
-msgid "No destination buffer allocated"
-msgstr ""
-#: ../lib/gis/compress.c:230
-#, c-format
-msgid "Invalid read size %d"
-msgstr ""
-#: ../lib/gis/compress.c:251
-#, c-format
-msgid "Unable to read %d bytes: end of file"
-msgstr ""
-#: ../lib/gis/compress.c:253
-#, c-format
-msgid "Unable to read %d bytes: %s"
-msgstr ""
-#: ../lib/gis/compress.c:327 ../lib/gis/compress.c:350
-#: ../lib/gis/compress.c:391
-msgid "Unable to write compression flag"
-msgstr ""
-#: ../lib/gis/compress.c:338 ../lib/gis/compress.c:361
-#: ../lib/gis/compress.c:404
-#, c-format
-msgid "Unable to write %d bytes: nothing written"
-msgstr ""
-#: ../lib/gis/compress.c:340 ../lib/gis/compress.c:363
-#: ../lib/gis/compress.c:406
-#, c-format
-msgid "Unable to write %d bytes: %s"
-msgstr ""
-#: ../lib/gis/cmprbzip.c:83 ../lib/gis/cmprbzip.c:157
-msgid "GRASS needs to be compiled with BZIP2 for BZIP2 compression"
-msgstr ""
-#: ../lib/gis/cmprbzip.c:122
-#, c-format
-msgid "BZIP2 version %s compression error %d"
-msgstr ""
-#: ../lib/gis/cmprbzip.c:189
-#, c-format
-msgid "BZIP2 version %s decompression error %d"
-msgstr ""
-#: ../lib/gis/cmprbzip.c:200 ../lib/gis/cmprlz4.c:168
-#, c-format
-msgid "Got uncompressed size %d, expected %d"
-msgstr ""
-#: ../lib/gis/cmprlz4.c:107
-msgid "LZ4 compression error"
-msgstr ""
-#: ../lib/gis/cmprlz4.c:159
-msgid "LZ4 decompression error"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:57
-#, c-format
-msgid "Illegal n-s resolution value <%lf>"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:61 ../lib/gis/adj_cellhd.c:163
-msgid "Illegal row value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:65 ../lib/gis/adj_cellhd.c:169
-msgid "Illegal e-w resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:69 ../lib/gis/adj_cellhd.c:175
-msgid "Illegal col value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:75 ../lib/gis/adj_cellhd.c:191
-msgid "North must be north of South"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:77 ../lib/gis/adj_cellhd.c:193
-msgid "North must be larger than South"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:83 ../lib/gis/adj_cellhd.c:199
-msgid "East must be larger than West"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:102 ../lib/gis/adj_cellhd.c:242
-msgid "Invalid coordinates"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:109 ../lib/gis/adj_cellhd.c:249
-msgid "NS resolution has been changed"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:114 ../lib/gis/adj_cellhd.c:254
-msgid "EW resolution has been changed"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:117 ../lib/gis/adj_cellhd.c:257
-msgid "NS and EW resolutions are different"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:157
-msgid "Illegal n-s resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:159
-msgid "Illegal n-s3 resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:165
-msgid "Illegal row3 value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:171
-msgid "Illegal e-w3 resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:177
-msgid "Illegal col3 value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:181
-msgid "Illegal t-b3 resolution value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:185
-msgid "Illegal depths value"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:202
-msgid "Top must be larger than Bottom"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:276
-#, c-format
-msgid "East (%.15g) is not larger than West (%.15g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:311
-#, c-format
-msgid "Illegal latitude for North: %g"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:313
-#, c-format
-msgid "Illegal latitude for South: %g"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:319
-#, c-format
-msgid "Illegal longitude for West: %g"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:323
-#, c-format
-msgid "Illegal longitude for East: %g"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:351
-#, c-format
-msgid "NS extent does not match NS resolution: %g cells difference"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:360
-#, c-format
-msgid "%g cells missing to reach 90 degree north"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:363 ../lib/gis/adj_cellhd.c:377
-#: ../lib/gis/adj_cellhd.c:391
-#, c-format
-msgid "Subtle input data rounding error of north boundary (%g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:373
-#, c-format
-msgid "90 degree north is exceeded by %g cells"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:402
-msgid "Illegal latitude for North"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:410
-#, c-format
-msgid "%g cells missing to reach 90 degree south"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:413 ../lib/gis/adj_cellhd.c:427
-#: ../lib/gis/adj_cellhd.c:441
-#, c-format
-msgid "Subtle input data rounding error of south boundary (%g)"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:423
-#, c-format
-msgid "90 degree south is exceeded by %g cells"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:452
-msgid "Illegal latitude for South"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:481
-#, c-format
-msgid "EW extent does not match EW resolution: %g cells difference"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:487
-#, c-format
-msgid "360 degree EW extent is exceeded by %g cells"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:493
-#, c-format
-msgid "%g cells missing to cover 360 degree EW extent"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:528
-msgid "Invalid NS resolution"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:533
-msgid "Invalid EW resolution"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:538
-msgid "Invalid North"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:543
-msgid "Invalid South"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:548
-msgid "Invalid West"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:553
-msgid "Invalid East"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:606
-#, c-format
-msgid "NS resolution rounded from %s to %s"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:639 ../lib/gis/adj_cellhd.c:694
-#, c-format
-msgid "North rounded from %s to %s"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:651
-#, c-format
-msgid "South adjusted from %s to %s"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:666 ../lib/gis/adj_cellhd.c:709
-#, c-format
-msgid "South rounded from %s to %s"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:678
-#, c-format
-msgid "North adjusted from %s to %s"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:732
-#, c-format
-msgid "EW resolution rounded from %s to %s"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:765 ../lib/gis/adj_cellhd.c:820
-#, c-format
-msgid "West rounded from %s to %s"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:777
-#, c-format
-msgid "East adjusted from %s to %s"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:792 ../lib/gis/adj_cellhd.c:835
-#, c-format
-msgid "East rounded from %s to %s"
-msgstr ""
-#: ../lib/gis/adj_cellhd.c:804
-#, c-format
-msgid "West adjusted from %s to %s"
-msgstr ""
-#: ../lib/gis/get_window.c:118
-#, c-format
-msgid "Unable to open element file <%s> for <%s@%s>"
-msgstr ""
-#: ../lib/gis/get_window.c:123
-#, c-format
-msgid "Region file %s/%s/%s is empty"
-msgstr ""
-#: ../lib/gis/worker.c:84
-msgid "Task already has a worker"
-msgstr ""
-#: ../lib/gis/parser_help.c:84
-msgid "Description:"
-msgstr ""
-#: ../lib/gis/parser_help.c:103
-msgid "Keywords:"
-msgstr ""
-#: ../lib/gis/parser_help.c:111
-msgid "Usage:"
-msgstr ""
-#: ../lib/gis/parser_help.c:141
-msgid "ERROR: Option key not defined"
-msgstr ""
-#: ../lib/gis/parser_help.c:191
-msgid "Flags:"
-msgstr ""
-#: ../lib/gis/parser_help.c:220
-msgid "Super quiet module output"
-msgstr ""
-#: ../lib/gis/parser_help.c:230
-msgid "Parameters:"
-msgstr ""
-#: ../lib/gis/parser_help.c:253
-#, c-format
-msgid "  %*s   default: %s\n"
-msgstr ""
-#: ../lib/gis/parser_help.c:279
-#, c-format
-msgid "  %*s   options: "
-msgstr ""
-#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
-#, c-format
-msgid "Current region rows: %d, cols: %d"
-msgstr ""
-#: ../lib/gis/alloc.c:47
-#, c-format
-msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr ""
-#: ../lib/gis/alloc.c:89
-#, c-format
-msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
-msgstr ""
-#: ../lib/gis/alloc.c:135
-#, c-format
-msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
-msgstr ""
-#: ../lib/gis/color_rules.c:88
-msgid "no description"
-msgstr ""
-#: ../lib/gis/datum.c:160
-#, c-format
-msgid "unable to open datum table file: %s"
-msgstr ""
-#: ../lib/gis/datum.c:182
-#, c-format
-msgid "error in datum table file, line %d"
-msgstr ""
-#: ../lib/gis/debug.c:80
-#, c-format
-msgid "Cannot open debug file '%s'"
-msgstr ""
-#: ../lib/gis/done_msg.c:38
-#, c-format
-msgid "%s complete. %s"
-msgstr ""
-#: ../lib/gis/get_projinfo.c:37 ../lib/gis/get_projinfo.c:66
-#, c-format
-msgid "<%s> file not found for location <%s>"
-msgstr ""
-#: ../lib/gis/home.c:39
-msgid "Unable to determine user's home directory"
-msgstr ""
-#: ../lib/gis/home.c:120
-#, c-format
-msgid "Failed to create directory [%s]"
-msgstr ""
-#: ../lib/gis/legal_name.c:39
-#, c-format
-msgid "Illegal filename <%s>. Cannot start with '.' or be 'NULL'."
-msgstr ""
-#: ../lib/gis/legal_name.c:46
-#, c-format
-msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
-msgstr ""
-#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
-#, c-format
-msgid "Output raster map name <%s> is not valid map name"
-msgstr ""
-#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
-#, c-format
-msgid "Output raster map <%s> is used as input"
-msgstr ""
-#: ../lib/gis/list.c:83
-#, c-format
-msgid "no %s files available in current mapset\n"
-msgstr ""
-#: ../lib/gis/list.c:86
-#, c-format
-msgid "no %s files available in mapset <%s>\n"
-msgstr ""
-#: ../lib/gis/list.c:132
-#, c-format
-msgid "%s files available in mapset <%s>:\n"
-msgstr ""
-#: ../lib/gis/list.c:204
-msgid "G_list: Unknown element type"
-msgstr ""
-#: ../lib/gis/location.c:61
-#, c-format
-msgid "LOCATION <%s> not available"
-msgstr ""
-#: ../lib/gis/mapset.c:38
-msgid "MAPSET is not set"
-msgstr ""
-#: ../lib/gis/mapset.c:80
-#, c-format
-msgid "MAPSET <%s> not available"
-msgstr ""
-#: ../lib/gis/mapset_msc.c:90
-#, c-format
-msgid "Unable to make mapset element %s (%s): %s"
-msgstr ""
-#: ../lib/gis/mapset_msc.c:94
-#, c-format
-msgid "Unable to access mapset element %s (%s): %s"
-msgstr ""
-#: ../lib/gis/mkstemp.c:132
-msgid "Attempt to create read-only temporary file"
-msgstr ""
-#: ../lib/gis/mkstemp.c:138
-#, c-format
-msgid "Unrecognised access mode: %o"
-msgstr ""
-#: ../lib/gis/myname.c:46
-msgid "This location has no description."
-msgstr ""
-#: ../lib/gis/open.c:68
-#, c-format
-msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-#: ../lib/gis/open.c:89
-#, c-format
-msgid "G__open(read): Unable to open '%s': %s"
-msgstr ""
-#: ../lib/gis/open.c:98
-#, c-format
-msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
-#: ../lib/gis/open.c:122
-#, c-format
-msgid "G__open(write): Unable to open '%s': %s"
-msgstr ""
-#: ../lib/gis/open_misc.c:49
-#, c-format
-msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
-#: ../lib/gis/open_misc.c:74
-#, c-format
-msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
-#: ../lib/gis/parser_dependencies.c:122
-msgid "Internal error: option or flag not found"
-msgstr ""
-#: ../lib/gis/parser_dependencies.c:179
-#, c-format
-msgid "<%s> or <%s>"
-msgstr ""
-#, c-format
-msgid "<%s> and <%s>"
-msgstr ""
-#: ../lib/gis/parser_dependencies.c:212
-#, c-format
-msgid "Options %s are mutually exclusive"
-msgstr ""
-#: ../lib/gis/parser_dependencies.c:236
-#, c-format
-msgid "At least one of the following options is required: %s"
-msgstr ""
-#: ../lib/gis/parser_dependencies.c:270
-#, c-format
-msgid "Option <%s> requires at least one of %s"
-msgstr ""
-#: ../lib/gis/parser_dependencies.c:273
-#, c-format
-msgid "Option <%s> requires <%s>"
-msgstr ""
-#: ../lib/gis/parser_dependencies.c:305
-#, c-format
-msgid "Option %s requires all of %s"
-msgstr ""
-#: ../lib/gis/parser_dependencies.c:332
-#, c-format
-msgid "Option %s is mutually exclusive with all of %s"
-msgstr ""
-#: ../lib/gis/parser_dependencies.c:358
-#, c-format
-msgid "Either all or none of %s must be given"
-msgstr ""
-#: ../lib/gis/parser_dependencies.c:391 ../lib/gis/parser_dependencies.c:428
-#, c-format
-msgid "Internal error: invalid rule type: %d"
-msgstr ""
-#: ../lib/gis/parser.c:355
-#, c-format
-msgid "BUG in option name, '%s' is not valid"
-msgstr ""
-#: ../lib/gis/parser.c:407
-#, c-format
-msgid "BUG in descriptions, option '%s' in <%s> does not exist"
-msgstr ""
-#: ../lib/gis/parser.c:525
-msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-#: ../lib/gis/parser.c:539
-msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-#: ../lib/gis/parser.c:554
-msgid "Use either --qq or --verbose flag, not both. Assuming --qq."
-msgstr ""
-#: ../lib/gis/parser.c:585
-#, c-format
-msgid "Sorry <%s> is not a valid option"
-msgstr ""
-#: ../lib/gis/parser.c:598
-msgid "Your installation doesn't include GUI, exiting."
-msgstr ""
-#: ../lib/gis/parser.c:943
-msgid "Unable to determine program name"
-msgstr ""
-#: ../lib/gis/parser.c:965 ../lib/gis/parser.c:984
-#, c-format
-msgid "%s: Sorry, <%c> is not a valid flag"
-msgstr ""
-#: ../lib/gis/parser.c:1114
-#, c-format
-msgid "%s: Sorry, <%s=> is ambiguous"
-msgstr ""
-#: ../lib/gis/parser.c:1117
-#, c-format
-msgid "Option <%s=> matches"
-msgstr ""
-#: ../lib/gis/parser.c:1135
-#, c-format
-msgid "Please update the usage of <%s>: option <%s> has been renamed to <%s>"
-msgstr ""
-#: ../lib/gis/parser.c:1148
-#, c-format
-msgid "%s: Sorry, <%s> is not a valid parameter"
-msgstr ""
-#: ../lib/gis/parser.c:1154 ../lib/gis/parser.c:1400
-#, c-format
-msgid "<%s> is an abbreviation for <%s>"
-msgstr ""
-#: ../lib/gis/parser.c:1159
-#, c-format
-msgid "Option <%s> does not accept multiple answers"
-msgstr ""
-#: ../lib/gis/parser.c:1231
-#, c-format
-msgid ""
-"Illegal range syntax for parameter <%s>\n"
-"\tPresented as: %s"
-msgstr ""
-#: ../lib/gis/parser.c:1237
-#, c-format
-msgid ""
-"Value <%s> out of range for parameter <%s>\n"
-"\tLegal range: %s"
-msgstr ""
-#: ../lib/gis/parser.c:1243
-#, c-format
-msgid "Missing value for parameter <%s>"
-msgstr ""
-#: ../lib/gis/parser.c:1249
-#, c-format
-msgid ""
-"Value <%s> ambiguous for parameter <%s>\n"
-"\tValid options: %s"
-msgstr ""
-#: ../lib/gis/parser.c:1422
-#, c-format
-msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
-msgstr ""
-#: ../lib/gis/parser.c:1514
-#, c-format
-msgid ""
-"Option <%s> must be provided in multiples of %d\n"
-"\tYou provided %d item(s): %s"
-msgstr ""
-#: ../lib/gis/parser.c:1590 ../lib/gis/parser.c:1597
-#, c-format
-msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
-msgstr ""
-#: ../lib/gis/parser.c:1707
-#, c-format
-msgid "%s= is not a separator option"
-msgstr ""
-#: ../lib/gis/parser.c:1710
-#, c-format
-msgid "No separator given for %s="
-msgstr ""
-#: ../lib/gis/parser.c:1772 ../lib/gis/parser.c:1789
-#, c-format
-msgid "%s= is not a file option"
-msgstr ""
-#: ../lib/gis/parser.c:1774
-#, c-format
-msgid "Opening multiple files not supported for %s="
-msgstr ""
-#: ../lib/gis/parser.c:1780
-#, c-format
-msgid "Unable to open %s file <%s>"
-msgstr ""
-#: ../lib/gis/parser.c:1786
-#, c-format
-msgid "Unable to create %s file <%s>"
-msgstr ""
-#: ../lib/gis/paths.c:201
-#, c-format
-msgid "Unable to open file <%s> for reading"
-msgstr ""
-#: ../lib/gis/paths.c:217
-#, c-format
-msgid "Unable to fetch security info for <%s>"
-msgstr ""
-#: ../lib/gis/proj2.c:63
-msgid "Latitude-Longitude"
-msgstr ""
-#: ../lib/gis/proj2.c:65
-msgid "Other Projection"
-msgstr ""
-#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
-msgid "Unable to seek"
-msgstr ""
-#: ../lib/gis/seek.c:56
-msgid "Seek offset out of range"
-msgstr ""
-#: ../lib/gis/timestamp.c:292
-#, c-format
-msgid "Unable to create timestamp file for %s map <%s@%s>"
-msgstr ""
-#: ../lib/gis/timestamp.c:301
-#, c-format
-msgid "Invalid timestamp specified for %s map <%s@%s>"
-msgstr ""
-#: ../lib/gis/timestamp.c:331
-#, c-format
-msgid "Unable to open timestamp file for %s map <%s@%s>"
-msgstr ""
-#: ../lib/gis/timestamp.c:340
-#, c-format
-msgid "Invalid timestamp file for %s map <%s@%s>"
-msgstr ""
-#: ../lib/gis/timestamp.c:479
-#, c-format
-msgid "Unable to open timestamp file for vector map <%s@%s>"
-msgstr ""
-#: ../lib/gis/timestamp.c:488
-#, c-format
-msgid "Invalid timestamp file for vector map <%s@%s>"
-msgstr ""
-#: ../lib/gis/timestamp.c:524
-#, c-format
-msgid "Unable to create timestamp file for vector map <%s@%s>"
-msgstr ""
-#: ../lib/gis/timestamp.c:533
-#, c-format
-msgid "Invalid timestamp specified for vector map <%s@%s>"
-msgstr ""
-#: ../lib/gis/units.c:208
-msgid "square units"
-msgstr ""
-msgid "square unit"
-msgstr ""
-#: ../lib/gis/units.c:210
-msgid "units"
-msgstr ""
-msgid "unit"
-msgstr ""
-#: ../lib/gis/units.c:215
-msgid "square meters"
-msgstr ""
-msgid "square meter"
-msgstr ""
-#: ../lib/gis/units.c:217
-msgid "meters"
-msgstr ""
-msgid "meter"
-msgstr ""
-#: ../lib/gis/units.c:222
-msgid "square kilometers"
-msgstr ""
-msgid "square kilometer"
-msgstr ""
-#: ../lib/gis/units.c:224
-msgid "kilometers"
-msgstr ""
-msgid "kilometer"
-msgstr ""
-#: ../lib/gis/units.c:229
-msgid "acres"
-msgstr ""
-msgid "acre"
-msgstr ""
-#: ../lib/gis/units.c:237
-msgid "hectares"
-msgstr ""
-msgid "hectare"
-msgstr ""
-#: ../lib/gis/units.c:245
-msgid "square miles"
-msgstr ""
-msgid "square mile"
-msgstr ""
-#: ../lib/gis/units.c:247
-msgid "miles"
-msgstr ""
-msgid "mile"
-msgstr ""
-#: ../lib/gis/units.c:252
-msgid "square feet"
-msgstr ""
-msgid "square foot"
-msgstr ""
-#: ../lib/gis/units.c:254
-msgid "feet"
-msgstr ""
-msgid "foot"
-msgstr ""
-#: ../lib/gis/units.c:259
-msgid "square US feet"
-msgstr ""
-msgid "square US foot"
-msgstr ""
-#: ../lib/gis/units.c:261
-msgid "US feet"
-msgstr ""
-msgid "US foot"
-msgstr ""
-#: ../lib/gis/units.c:266
-msgid "square degrees"
-msgstr ""
-msgid "square degree"
-msgstr ""
-#: ../lib/gis/units.c:268
-msgid "degrees"
-msgstr ""
-msgid "degree"
-msgstr ""
-#: ../lib/gis/units.c:272
-msgid "years"
-msgstr ""
-msgid "year"
-msgstr ""
-#: ../lib/gis/units.c:276
-msgid "months"
-msgstr ""
-msgid "month"
-msgstr ""
-#: ../lib/gis/units.c:280
-msgid "days"
-msgstr ""
-msgid "day"
-msgstr ""
-#: ../lib/gis/units.c:284
-msgid "hours"
-msgstr ""
-msgid "hour"
-msgstr ""
-#: ../lib/gis/units.c:288
-msgid "minutes"
-msgstr ""
-msgid "minute"
-msgstr ""
-#: ../lib/gis/units.c:292
-msgid "seconds"
-msgstr ""
-msgid "second"
-msgstr ""
-#: ../lib/gis/view.c:176
-#, c-format
-msgid "Unable to open %s for writing"
-msgstr ""
-#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
-#, c-format
-msgid "Unable to open %s for reading"
-msgstr ""
-#: ../lib/gis/view.c:465
-#, c-format
-msgid "GRASS window when view was saved:\n"
-msgstr ""
-#: ../lib/gis/view.c:545
-#, c-format
-msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-#: ../lib/gis/view.c:549
-#, c-format
-msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
Deleted: grass/trunk/locale/po/grassmods_zh_CN.po
--- grass/trunk/locale/po/grassmods_zh_CN.po	2019-04-19 08:33:13 UTC (rev 74403)
+++ grass/trunk/locale/po/grassmods_zh_CN.po	2019-04-19 15:20:06 UTC (rev 74404)
@@ -1,45001 +0,0 @@
-# Translation of grassmods_zh_CN.po
-# Copyright (C) 2017 GRASS Development Team
-# This file is distributed under the same license as the GRASS GIS package.
-# transifex generated, 2017
-#, fuzzy
-msgid ""
-msgstr ""
-"Project-Id-Version: grasslibs_zh_CN\n"
-"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2019-03-02 23:14-0800\n"
-"PO-Revision-Date: 2017-01-25 08:23+0000\n"
-"Language-Team: Chinese (China) (https://www.transifex.com/grass-gis/teams/45198/zh_CN/)\n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
-"Language: zh_CN\n"
-"Plural-Forms: nplurals=1; plural=0;\n"
-#: ../raster/r.out.vrml/main.c:47 ../raster/r.resamp.interp/main.c:76
-#: ../raster/r.texture/main.c:102 ../raster/r.grow.distance/main.c:150
-#: ../raster/r.out.gridatb/main.c:67 ../raster/r.surf.idw/main.c:104
-#: ../raster/r.what/main.c:100 ../raster/r.stream.extract/main.c:76
-#: ../raster/r.colors.out/raster_main.c:45 ../raster/r.mfilter/main.c:56
-#: ../raster/r.category/main.c:52 ../raster/r.series/main.c:137
-#: ../raster/r.in.xyz/main.c:158 ../raster/r.compress/main.c:68
-#: ../raster/r.region/main.c:51 ../raster/r.statistics/main.c:55
-#: ../raster/r.external.out/main.c:235 ../raster/r.cross/main.c:69
-#: ../raster/r.in.bin/main.c:257 ../raster/r.circle/main.c:51
-#: ../raster/r.his/main.c:67 ../raster/r.recode/main.c:48
-#: ../raster/r.stats/main.c:106 ../raster/r.quantile/main.c:265
-#: ../raster/r.slope.aspect/main.c:151 ../raster/r.surf.area/main.c:76
-#: ../raster/r.usler/main.c:52 ../raster/r.distance/main.c:39
-#: ../raster/r.in.gridatb/main.c:45 ../raster/r.proj/main.c:144
-#: ../raster/r.to.rast3/main.c:197 ../raster/r.profile/main.c:53
-#: ../raster/r.thin/main.c:57 ../raster/r.rescale/main.c:48
-#: ../raster/r.basins.fill/main.c:54 ../raster/r.transect/main.c:103
-#: ../raster/r.what.color/main.c:88 ../raster/r.in.gdal/main.c:92
-#: ../raster/r.in.ascii/main.c:69 ../raster/r.ros/main.c:212
-#: ../raster/r.surf.gauss/main.c:38 ../raster/r.sun/main.c:251
-#: ../raster/r.carve/main.c:74 ../raster/r.horizon/main.c:180
-#: ../raster/r.resamp.rst/main.c:148 ../raster/r.out.pov/main.c:121
-#: ../raster/r.flow/main.c:421 ../raster/r.info/main.c:70
-#: ../raster/r.random.cells/main.c:47 ../raster/r.gwflow/main.c:208
-#: ../raster/r.coin/main.c:66 ../raster/r.surf.fractal/main.c:38
-#: ../raster/r.buffer/main.c:66 ../raster/r.stats.zonal/main.c:101
-#: ../raster/r.covar/main.c:51 ../raster/r.regression.multi/main.c:129
-#: ../raster/r.volume/main.c:76 ../raster/r.kappa/main.c:68
-#: ../raster/r.cost/main.c:140 ../raster/r.rescale.eq/main.c:52
-#: ../raster/r.out.ascii/main.c:59 ../raster/r.topmodel/main.c:51
-#: ../raster/r.relief/main.c:107 ../raster/r.out.vtk/main.c:59
-#: ../raster/r.in.lidar/main.c:108 ../raster/r.sim/r.sim.water/main.c:113
-#: ../raster/r.sim/r.sim.sediment/main.c:114 ../raster/r.lake/main.c:150
-#: ../raster/r.patch/main.c:58 ../raster/r.report/main.c:67
-#: ../raster/r.null/main.c:60 ../raster/r.contour/main.c:87
-#: ../raster/r.neighbors/main.c:167 ../raster/r.out.png/main.c:112
-#: ../raster/r.spreadpath/main.c:88 ../raster/r.clump/main.c:58
-#: ../raster/r.in.poly/main.c:34 ../raster/r.fill.dir/main.c:86
-#: ../raster/r.sunhours/main.c:72 ../raster/r.sunmask/main.c:116
-#: ../raster/r.watershed/front/main.c:73 ../raster/r.out.ppm3/main.c:57
-#: ../raster/r.out.ppm/main.c:54 ../raster/r.surf.random/main.c:36
-#: ../raster/r.quant/main.c:47 ../raster/r.colors/edit_colors.c:63
-#: ../raster/r.resamp.stats/main.c:261 ../raster/r.resample/main.c:54
-#: ../raster/r.topidx/main.c:39 ../raster/r.stats.quantile/main.c:516
-#: ../raster/r.describe/main.c:54 ../raster/r.regression.line/main.c:46
-#: ../raster/r.reclass/main.c:50 ../raster/r.composite/main.c:72
-#: ../raster/r.random/main.c:51 ../raster/r.solute.transport/main.c:229
-#: ../raster/r.to.vect/main.c:76 ../raster/r.surf.contour/main.c:60
-#: ../raster/r.param.scale/interface.c:54 ../raster/r.drain/main.c:109
-#: ../raster/r.tile/main.c:43 ../raster/r.series.accumulate/main.c:80
-#: ../raster/r.mode/main.c:55 ../raster/r.uslek/main.c:53
-#: ../raster/r.water.outlet/main.c:57 ../raster/r.random.surface/main.c:57
-#: ../raster/r.walk/main.c:178 ../raster/r.in.mat/main.c:91
-#: ../raster/r.resamp.bspline/main.c:79 ../raster/r.univar/r.univar_main.c:104
-#: ../raster/r.series.interp/main.c:64 ../raster/r.external/main.c:57
-#: ../raster/r.timestamp/main.c:35 ../raster/r.resamp.filter/main.c:389
-#: ../raster/r.li/r.li.cwed/cwed.c:54 ../raster/r.li/r.li.simpson/simpson.c:46
-#: ../raster/r.li/r.li.dominance/dominance.c:46
-#: ../raster/r.li/r.li.patchdensity/main.c:51
-#: ../raster/r.li/r.li.pielou/pielou.c:46 ../raster/r.li/r.li.mpa/mpa.c:44
-#: ../raster/r.li/r.li.richness/richness.c:43
-#: ../raster/r.li/r.li.padcv/padcv.c:53 ../raster/r.li/r.li.shape/main.c:49
-#: ../raster/r.li/r.li.padsd/padsd.c:53 ../raster/r.li/r.li.patchnum/main.c:50
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:48
-#: ../raster/r.li/r.li.renyi/renyi.c:47 ../raster/r.li/r.li.mps/mps.c:52
-#: ../raster/r.li/r.li.padrange/padrange.c:53
-#: ../raster/r.li/r.li.shannon/shannon.c:46 ../raster/r.latlong/main.c:56
-#: ../raster/r.mapcalc/main.c:70 ../raster/r.out.gdal/main.c:139
-#: ../raster/r.support/main.c:54 ../raster/r.out.bin/main.c:279
-#: ../raster/r.support.stats/main.c:38 ../raster/r.to.rast3elev/main.c:361
-#: ../raster/r.spread/main.c:105 ../raster/r.out.mpeg/main.c:102
-#: ../raster/r.out.mat/main.c:62 ../raster/r.in.png/main.c:519
-#: ../raster/r.geomorphon/main.c:104 ../raster/r.fill.stats/main.c:775
-#: ../display/d.rast/main.c:55 ../display/d.rgb/main.c:55
-#: ../display/d.profile/main.c:193 ../display/d.rast.arrow/main.c:99
-#: ../display/d.colortable/main.c:61 ../display/d.rast.num/main.c:79
-#: ../visualization/ximgview/main.c:292 ../vector/v.to.rast/main.c:46
-#: ../vector/v.what.rast3/main.c:66 ../vector/v.sample/main.c:77
-#: ../vector/v.what.rast/main.c:73 ../vector/v.neighbors/main.c:53
-#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.to.rast/main.c:261
-#: ../doc/raster/r.example/main.c:83
-#: ../locale/scriptstrings/d.correlate_to_translate.c:4
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:4
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
-#: ../locale/scriptstrings/i.spectral_to_translate.c:4
-#: ../locale/scriptstrings/r.blend_to_translate.c:2
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:3
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-#: ../locale/scriptstrings/r.grow_to_translate.c:2
-#: ../locale/scriptstrings/r.import_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:2
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../locale/scriptstrings/r.pack_to_translate.c:2
-#: ../locale/scriptstrings/r.plane_to_translate.c:2
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-#: ../locale/scriptstrings/r.rgb_to_translate.c:2
-#: ../locale/scriptstrings/r.shade_to_translate.c:2
-#: ../locale/scriptstrings/r.tileset_to_translate.c:2
-#: ../locale/scriptstrings/r.unpack_to_translate.c:2
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:4
-#: ../misc/m.nviz.script/main.c:71 ../misc/m.nviz.image/main.c:53
-msgid "raster"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:48 ../raster/r.out.gridatb/main.c:68
-#: ../raster/r.colors.out/raster3d_main.c:48
-#: ../raster/r.colors.out/raster_main.c:47 ../raster/r.external.out/main.c:236
-#: ../raster/r.out.pov/main.c:122 ../raster/r.out.ascii/main.c:60
-#: ../raster/r.out.vtk/main.c:60 ../raster/r.out.png/main.c:113
-#: ../raster/r.out.ppm3/main.c:58 ../raster/r.out.ppm/main.c:55
-#: ../raster/r.out.gdal/main.c:140 ../raster/r.out.bin/main.c:280
-#: ../raster/r.out.mpeg/main.c:103 ../raster/r.out.mat/main.c:63
-#: ../vector/v.out.postgis/main.c:45 ../vector/v.out.svg/main.c:78
-#: ../vector/v.out.dxf/main.c:57 ../vector/v.out.lidar/main.c:474
-#: ../vector/v.out.vtk/main.c:48 ../vector/v.external.out/main.c:44
-#: ../vector/v.out.ascii/main.c:48 ../vector/v.colors.out/main.c:51
-#: ../vector/v.out.ogr/main.c:83 ../vector/v.out.pov/main.c:47
-#: ../raster3d/r3.out.vtk/main.c:377 ../raster3d/r3.out.bin/main.c:206
-#: ../raster3d/r3.out.netcdf/main.c:587 ../raster3d/r3.out.ascii/main.c:303
-#: ../raster3d/r3.out.v5d/main.c:285
-#: ../locale/scriptstrings/d.out.file_to_translate.c:3
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:3
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
-#: ../locale/scriptstrings/r.pack_to_translate.c:3
-#: ../locale/scriptstrings/v.pack_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:3
-msgid "export"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:49
-msgid "VRML"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:51
-msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr ""
-#: ../raster/r.out.vrml/main.c:58
-msgid "Name of input color map"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:65 ../misc/m.nviz.image/args.c:575
-msgid "Vertical exaggeration"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:69
-msgid "Name for output VRML file"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:88
-#, c-format
-msgid "Range info for [%s] not available (run r.support)"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:97
-#, c-format
-msgid "Range info for <%s> not available (run r.support)"
-msgstr ""
-#: ../raster/r.out.vrml/main.c:129
-#, c-format
-msgid "Opening %s for writing... "
-msgstr ""
-#: ../raster/r.out.vrml/main.c:131 ../raster/r.colors.out/raster3d_main.c:80
-#: ../raster/r.colors.out/raster_main.c:79 ../raster/r.out.pov/main.c:173
-#: ../raster/r.out.png/main.c:205 ../raster/r.support/main.c:162
-#: ../raster/r.out.mat/main.c:91 ../general/g.cairocomp/main.c:66
-#: ../vector/v.colors.out/main.c:103 ../raster3d/r3.support/main.c:153
-#, c-format
-msgid "Unable to open output file <%s>"
-msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:38
-msgid "Writing vertices..."
-msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:83
-msgid "Writing color file..."
-msgstr ""
-#: ../raster/r.resamp.interp/main.c:77 ../raster/r.resamp.rst/main.c:149
-#: ../raster/r.resamp.stats/main.c:262 ../raster/r.resample/main.c:55
-#: ../raster/r.resamp.bspline/main.c:81 ../raster/r.resamp.filter/main.c:390
-msgid "resample"
-msgstr ""
-#: ../raster/r.resamp.interp/main.c:78 ../raster/r.surf.idw/main.c:106
-#: ../raster/r.surf.contour/main.c:62 ../raster/r.resamp.bspline/main.c:82
-#: ../raster/r.series.interp/main.c:66 ../raster/r.fill.stats/main.c:777
-#: ../vector/v.vol.rst/main.c:238 ../vector/v.surf.bspline/main.c:93
-#: ../vector/v.surf.rst/main.c:149 ../vector/v.surf.idw/main.c:89
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:3
-msgid "interpolation"
-msgstr ""
-#: ../raster/r.resamp.interp/main.c:80
-msgid "Resamples raster map to a finer grid using interpolation."
-msgstr ""
-#: ../raster/r.resamp.interp/main.c:88
-msgid "Method"
-msgstr ""
-#: ../raster/r.resamp.interp/main.c:102 ../imagery/i.topo.corr/main.c:158
-#, c-format
-msgid "Invalid method: %s"
-msgstr ""
-#: ../raster/r.resamp.interp/main.c:370 ../raster/r.resamp.stats/main.c:395
-#: ../raster/r.tile/main.c:200 ../raster/r.mode/main.c:143
-#: ../raster/r.resamp.filter/main.c:579
-#, c-format
-msgid "Unable to read color table for %s"
-msgstr ""
-#: ../raster/r.texture/h_measure.c:156
-#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
-#: ../raster/r.texture/h_measure.c:738 ../raster/r.stream.extract/load.c:44
-#: ../raster/r.stream.extract/load.c:53 ../raster/r.cost/main.c:673
-#: ../raster/r.walk/main.c:808 ../imagery/i.smap/interp.c:68
-msgid "Unable to allocate memory"
-msgstr ""
-#: ../raster/r.texture/main.c:68
-#, c-format
-msgid "Unknown measure <%s>"
-msgstr ""
-#: ../raster/r.texture/main.c:103 ../raster/r.mfilter/main.c:57
-#: ../raster/r.quantile/main.c:266 ../raster/r.neighbors/main.c:168
-#: ../raster/r.mode/main.c:57 ../raster/r.mapcalc/main.c:71
-#: ../vector/v.neighbors/main.c:51 ../raster3d/r3.neighbors/main.c:209
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:3
-msgid "algebra"
-msgstr ""
-#: ../raster/r.texture/main.c:104 ../raster/r.mfilter/main.c:58
-#: ../raster/r.in.xyz/main.c:160 ../raster/r.statistics/main.c:56
-#: ../raster/r.cross/main.c:70 ../raster/r.stats/main.c:107
-#: ../raster/r.quantile/main.c:267 ../raster/r.surf.area/main.c:78
-#: ../raster/r.coin/main.c:67 ../raster/r.stats.zonal/main.c:102
-#: ../raster/r.covar/main.c:52 ../raster/r.regression.multi/main.c:130
-#: ../raster/r.kappa/main.c:69 ../raster/r.in.lidar/main.c:111
-#: ../raster/r.report/main.c:68 ../raster/r.neighbors/main.c:169
-#: ../raster/r.clump/main.c:59 ../raster/r.quant/main.c:48
-#: ../raster/r.stats.quantile/main.c:517 ../raster/r.regression.line/main.c:47
-#: ../raster/r.mode/main.c:56 ../raster/r.univar/r.univar_main.c:105
-#: ../raster/r.univar/r3.univar_main.c:99 ../raster/r.support.stats/main.c:39
-#: ../display/d.histogram/main.c:85 ../imagery/i.cca/main.c:85
-#: ../vector/v.outlier/main.c:70 ../vector/v.kcv/main.c:56
-#: ../vector/v.univar/main.c:93 ../vector/v.class/main.c:48
-#: ../vector/v.perturb/main.c:64 ../vector/v.qcount/main.c:61
-#: ../vector/v.random/main.c:99 ../vector/v.neighbors/main.c:52
-#: ../vector/v.normal/main.c:73 ../raster3d/r3.neighbors/main.c:211
-#: ../raster3d/r3.stats/main.c:49 ../raster3d/r3.in.lidar/main.c:165
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/db.univar_to_translate.c:3
-#: ../locale/scriptstrings/i.oif_to_translate.c:4
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
-#: ../locale/scriptstrings/v.report_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:3
-msgid "statistics"
-msgstr ""
-#: ../raster/r.texture/main.c:105
-msgid "texture"
-msgstr ""
-#: ../raster/r.texture/main.c:107
-msgid "Generate images with textural features from a raster map."
-msgstr ""
-#: ../raster/r.texture/main.c:120
-msgid "The size of moving window (odd and >= 3)"
-msgstr ""
-#: ../raster/r.texture/main.c:130
-msgid "The distance between two samples (>= 1)"
-msgstr ""
-#: ../raster/r.texture/main.c:131
-msgid "The distance must be smaller than the size of the moving window"
-msgstr ""
-#: ../raster/r.texture/main.c:147
-msgid "Textural measurement method"
-msgstr ""
-#: ../raster/r.texture/main.c:151
-msgid "Separate output for each angle (0, 45, 90, 135)"
-msgstr ""
-#: ../raster/r.texture/main.c:152
-msgid ""
-"Angles are counterclockwise from east: 0 is East to West, 45 is North-East "
-"to South-West"
-msgstr ""
-#: ../raster/r.texture/main.c:157
-msgid "Calculate all textural measurements"
-msgstr ""
-#: ../raster/r.texture/main.c:161
-msgid "Allow NULL cells in a moving window"
-msgstr ""
-#: ../raster/r.texture/main.c:162
-msgid "This will also avoid cropping along edges of the current region"
-msgstr ""
-#: ../raster/r.texture/main.c:171
-msgid "Size of the moving window must be > 0"
-msgstr ""
-#: ../raster/r.texture/main.c:173
-msgid "Size of the moving window must be odd"
-msgstr ""
-#: ../raster/r.texture/main.c:176
-msgid "The distance between two samples must be > 0"
-msgstr ""
-#: ../raster/r.texture/main.c:178
-msgid ""
-"The distance between two samples must be smaller than the size of the moving"
-" window"
-msgstr ""
-#: ../raster/r.texture/main.c:199
-msgid "Nothing to compute. Use at least one textural measure."
-msgstr ""
-#: ../raster/r.texture/main.c:258 ../raster/r.texture/main.c:268
-msgid ""
-"At least one of the requested output maps exists. Use --o to overwrite."
-msgstr ""
-#: ../raster/r.texture/main.c:301 ../raster/r.carve/raster.c:13
-#: ../imagery/i.zc/main.c:157
-msgid "Reading raster map..."
-msgstr ""
-#: ../raster/r.texture/main.c:351
-#, c-format
-msgid "Calculating %d texture measure"
-msgid_plural "Calculating %d texture measures"
-msgstr[0] ""
-#: ../raster/r.texture/main.c:354 ../imagery/i.vi/main.c:226
-#, c-format
-msgid "Calculating %s..."
-msgstr ""
-#: ../raster/r.grow.distance/main.c:151 ../raster/r.distance/main.c:40
-#: ../display/d.geodesic/main.c:47 ../display/d.rhumbline/main.c:45
-#: ../vector/v.distance/main.c:122
-#: ../locale/scriptstrings/r.grow_to_translate.c:3 ../misc/m.cogo/main.c:226
-#: ../misc/m.measure/main.c:48
-msgid "distance"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:152
-#: ../locale/scriptstrings/r.grow_to_translate.c:4
-msgid "proximity"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:154
-msgid ""
-"Generates a raster map containing distances to nearest raster features."
-msgstr ""
-#: ../raster/r.grow.distance/main.c:161
-msgid "Name for distance output raster map"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:162 ../raster/r.grow.distance/main.c:168
-#: ../raster/r.in.xyz/main.c:297 ../raster/r.sun/main.c:403
-#: ../raster/r.sun/main.c:412 ../raster/r.sun/main.c:421
-#: ../raster/r.sun/main.c:430 ../raster/r.sun/main.c:439
-#: ../raster/r.sun/main.c:448 ../raster/r.resamp.rst/main.c:174
-#: ../raster/r.resamp.rst/main.c:180 ../raster/r.resamp.rst/main.c:186
-#: ../raster/r.resamp.rst/main.c:192 ../raster/r.resamp.rst/main.c:198
-#: ../raster/r.resamp.rst/main.c:204 ../raster/r.resamp.rst/main.c:264
-#: ../raster/r.in.lidar/main.c:126 ../raster/r.in.lidar/main.c:253
-#: ../raster/r.in.lidar/main.c:286 ../raster/r.in.lidar/main.c:295
-#: ../raster/r.sim/r.sim.water/main.c:197
-#: ../raster/r.sim/r.sim.water/main.c:203
-#: ../raster/r.sim/r.sim.water/main.c:209
-#: ../raster/r.sim/r.sim.water/main.c:216
-#: ../raster/r.sim/r.sim.water/main.c:223
-#: ../raster/r.sim/r.sim.water/main.c:298
-#: ../raster/r.sim/r.sim.sediment/main.c:179
-#: ../raster/r.sim/r.sim.sediment/main.c:186
-#: ../raster/r.sim/r.sim.sediment/main.c:193
-#: ../raster/r.sim/r.sim.sediment/main.c:199
-#: ../raster/r.sim/r.sim.sediment/main.c:206
-#: ../raster/r.sim/r.sim.sediment/main.c:213
-#: ../raster/r.sim/r.sim.sediment/main.c:220 ../raster/r.lake/main.c:167
-#: ../raster/r.lake/main.c:195 ../raster/r.spread/main.c:277
-#: ../raster/r.spread/main.c:289 ../raster/r.spread/main.c:301
-#: ../vector/v.out.ascii/args.c:35 ../vector/v.out.ascii/args.c:81
-#: ../vector/v.in.ogr/main.c:228 ../vector/v.in.ogr/main.c:283
-#: ../vector/v.in.ogr/main.c:333 ../vector/v.in.ogr/main.c:339
-#: ../vector/v.in.ogr/main.c:381 ../vector/v.profile/main.c:218
-#: ../vector/v.profile/main.c:223 ../vector/v.profile/main.c:229
-#: ../raster3d/r3.flow/main.c:211 ../raster3d/r3.flow/main.c:218
-#: ../raster3d/r3.in.lidar/main.c:190 ../raster3d/r3.in.lidar/main.c:196
-#: ../raster3d/r3.in.lidar/main.c:202
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:8
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:10
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:13
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:7
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:9
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:11
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:14
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:16
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:18
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:20
-#: ../locale/scriptstrings/i.spectral_to_translate.c:10
-#: ../locale/scriptstrings/i.spectral_to_translate.c:12
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
-#: ../locale/scriptstrings/m.proj_to_translate.c:23
-#: ../locale/scriptstrings/m.proj_to_translate.c:25
-#: ../locale/scriptstrings/m.proj_to_translate.c:27
-#: ../locale/scriptstrings/r.import_to_translate.c:12
-#: ../locale/scriptstrings/r.import_to_translate.c:15
-#: ../locale/scriptstrings/r.import_to_translate.c:18
-#: ../locale/scriptstrings/r.import_to_translate.c:21
-#: ../locale/scriptstrings/r.import_to_translate.c:23
-#: ../locale/scriptstrings/v.import_to_translate.c:10
-#: ../locale/scriptstrings/v.import_to_translate.c:13
-#: ../locale/scriptstrings/v.import_to_translate.c:16
-#: ../locale/scriptstrings/v.import_to_translate.c:19
-msgid "Output"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:167
-msgid "Name for value output raster map"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:174
-#: ../locale/scriptstrings/r.grow_to_translate.c:7
-msgid "Metric"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:180
-msgid "Output distances in meters instead of map units"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:184
-msgid "Calculate distance to nearest NULL cell"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:195
-msgid "Distance output is required for distance to NULL cells"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:197
-msgid "Value output is meaningless for distance to NULL cells"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:203
-msgid "At least one of distance= and value= must be given"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:218
-msgid "metric=geodesic is only valid for lat/lon"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:224
-#, c-format
-msgid "Unknown metric: '%s'"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:229
-#, c-format
-msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:249
-#, c-format
-msgid "Unable to create temporary file <%s>"
-msgstr ""
-#: ../raster/r.grow.distance/main.c:276 ../raster/r.surf.idw/main.c:713
-#: ../raster/r.series.accumulate/main.c:248
-#: ../raster/r.series.accumulate/main.c:273
-#: ../raster/r.series.accumulate/main.c:284
-#: ../raster/r.series.accumulate/main.c:292
-#: ../raster/r.series.accumulate/main.c:300 ../raster/r.out.mpeg/main.c:286
-#: ../ps/ps.map/ps_raster.c:102
-#, c-format
-msgid "Reading raster map <%s>..."
-msgstr ""
-#: ../raster/r.grow.distance/main.c:325 ../raster/r.stream.extract/close.c:255
-#: ../raster/r.fill.dir/main.c:253
-msgid "Writing output raster maps..."
-msgstr ""
-#: ../raster/r.grow.distance/main.c:382
-#: ../raster/r.colors.out/raster_main.c:69 ../raster/r.fill.dir/main.c:153
-#: ../raster/r.colors/edit_colors.c:396 ../vector/v.colors/main.c:315
-#, c-format
-msgid "Unable to read color table for raster map <%s>"
-msgstr ""
-#: ../raster/r.out.gridatb/main.c:70
-msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
-msgstr ""
-#: ../raster/r.surf.idw/main.c:105 ../raster/r.surf.area/main.c:77
-#: ../raster/r.surf.gauss/main.c:39 ../raster/r.surf.fractal/main.c:39
-#: ../raster/r.contour/main.c:88 ../raster/r.surf.random/main.c:37
-#: ../raster/r.surf.contour/main.c:61 ../raster/r.random.surface/main.c:58
-#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.fill.stats/main.c:776
-#: ../vector/v.vol.rst/main.c:237 ../vector/v.surf.bspline/main.c:92
-#: ../vector/v.surf.rst/main.c:148 ../vector/v.surf.idw/main.c:88
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-msgid "surface"
-msgstr ""
-#: ../raster/r.surf.idw/main.c:107 ../raster/r.fill.stats/main.c:778
-#: ../vector/v.surf.idw/main.c:90
-msgid "IDW"
-msgstr ""
-#: ../raster/r.surf.idw/main.c:109
-msgid ""
-"Provides surface interpolation from raster point data by Inverse Distance "
-"Squared Weighting."
-msgstr ""
-#: ../raster/r.surf.idw/main.c:119 ../vector/v.surf.idw/main.c:113
-msgid "Number of interpolation points"
-msgstr ""
-#: ../raster/r.surf.idw/main.c:124
-msgid "Output is the interpolation error"
-msgstr ""
-#: ../raster/r.surf.idw/main.c:130
-#, c-format
-msgid "Illegal value for '%s' (%s)"
-msgstr ""
-#: ../raster/r.surf.idw/main.c:164 ../raster/r.statistics/main.c:104
-#: ../raster/r.statistics/main.c:107
-msgid "This module currently only works for integer (CELL) maps"
-msgstr ""
-#: ../raster/r.surf.idw/main.c:260
-#, c-format
-msgid "Interpolating raster map <%s> (%d row)..."
-msgid_plural "Interpolating raster map <%s> (%d rows)..."
-msgstr[0] ""
-#: ../raster/r.what/main.c:101 ../raster/r.what.color/main.c:89
-#: ../display/d.where/main.c:46 ../vector/v.what/main.c:63
-#: ../vector/v.what.rast3/main.c:68 ../vector/v.what.rast/main.c:75
-#: ../locale/scriptstrings/i.spectral_to_translate.c:3
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:6
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-msgid "querying"
-msgstr ""
-#: ../raster/r.what/main.c:102 ../display/d.where/main.c:45
-#: ../vector/v.what/main.c:64 ../vector/v.what.rast3/main.c:67
-#: ../vector/v.what.rast/main.c:74
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:5
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
-msgid "position"
-msgstr ""
-#: ../raster/r.what/main.c:104
-msgid "Queries raster maps on their category values and category labels."
-msgstr ""
-#: ../raster/r.what/main.c:108
-msgid "Name of existing raster map(s) to query"
-msgstr ""
-#: ../raster/r.what/main.c:111 ../vector/v.what/main.c:77
-msgid "Coordinates for query"
-msgstr ""
-#: ../raster/r.what/main.c:112 ../raster/r.what/main.c:118
-#: ../db/db.select/main.c:203 ../db/db.select/main.c:209
-#: ../db/db.select/main.c:213 ../db/db.select/main.c:251
-#: ../db/db.select/main.c:261 ../vector/v.to.db/parse.c:106
-#: ../vector/v.to.db/parse.c:114
-msgid "Query"
-msgstr ""
-#: ../raster/r.what/main.c:116
-msgid "Name of vector points map for query"
-msgstr ""
-#: ../raster/r.what/main.c:122 ../raster/r.what/main.c:130
-#: ../raster/r.what/main.c:144 ../raster/r.what/main.c:149
-#: ../raster/r.what/main.c:154 ../raster/r.what/main.c:159
-#: ../raster/r.what/main.c:169 ../raster/r.external.out/main.c:272
-#: ../raster/r.external.out/main.c:283 ../raster/r.proj/main.c:204
-#: ../raster/r.proj/main.c:214 ../raster/r.proj/main.c:220
-#: ../raster/r.in.gdal/main.c:208 ../raster/r.in.gdal/main.c:241
-#: ../raster/r.sunmask/main.c:232 ../raster/r.sunmask/main.c:238
-#: ../raster/r.colors/edit_colors.c:128 ../raster/r.external/main.c:96
-#: ../raster/r.external/main.c:135 ../raster/r.out.gdal/main.c:145
-#: ../db/db.connect/main.c:53 ../db/db.connect/main.c:58
-#: ../db/db.login/main.c:91 ../general/g.mapset/main.c:76
-#: ../general/g.mapset/main.c:82 ../general/g.list/main.c:105
-#: ../general/g.list/main.c:116 ../general/g.list/main.c:138
-#: ../general/g.list/main.c:143 ../general/g.list/main.c:148
-#: ../general/g.list/main.c:153 ../general/g.region/main.c:89
-#: ../general/g.region/main.c:95 ../general/g.region/main.c:100
-#: ../general/g.region/main.c:106 ../general/g.region/main.c:112
-#: ../general/g.region/main.c:118 ../general/g.region/main.c:124
-#: ../general/g.region/main.c:132 ../general/g.region/main.c:137
-#: ../general/g.region/main.c:143 ../general/g.region/main.c:148
-#: ../general/g.region/main.c:153 ../general/g.mapsets/main.c:87
-#: ../general/g.mapsets/main.c:92 ../general/g.mapsets/main.c:98
-#: ../general/g.proj/main.c:80 ../general/g.proj/main.c:86
-#: ../general/g.proj/main.c:92 ../general/g.proj/main.c:98
-#: ../general/g.proj/main.c:104 ../general/g.proj/main.c:115
-#: ../general/g.proj/main.c:120 ../display/d.mon/main.c:115
-#: ../display/d.mon/main.c:120 ../display/d.mon/main.c:125
-#: ../imagery/i.group/main.c:79 ../imagery/i.group/main.c:84
-#: ../imagery/i.group/main.c:89 ../temporal/t.connect/main.c:43
-#: ../vector/v.to.db/parse.c:118 ../vector/v.to.db/parse.c:123
-#: ../vector/v.to.db/parse.c:129 ../vector/v.to.db/parse.c:135
-#: ../vector/v.vect.stats/main.c:224 ../vector/v.vect.stats/main.c:231
-#: ../vector/v.db.connect/main.c:84 ../vector/v.db.connect/main.c:89
-#: ../vector/v.db.connect/main.c:96 ../vector/v.db.connect/main.c:103
-#: ../vector/v.what/main.c:91 ../vector/v.what/main.c:96
-#: ../vector/v.what/main.c:101 ../vector/v.what/main.c:106
-#: ../vector/v.what/main.c:111 ../vector/v.external.out/args.c:63
-#: ../vector/v.external.out/args.c:75 ../vector/v.external.out/args.c:81
-#: ../vector/v.colors/main.c:133 ../vector/v.in.ogr/main.c:320
-#: ../vector/v.in.ogr/main.c:326 ../vector/v.info/parse.c:25
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.info/parse.c:46
-#: ../vector/v.external/args.c:57 ../vector/v.external/args.c:63
-#: ../vector/v.external/args.c:71
-#: ../locale/scriptstrings/g.extension_to_translate.c:16
-#: ../locale/scriptstrings/g.extension_to_translate.c:18
-#: ../locale/scriptstrings/g.extension_to_translate.c:20
-#: ../locale/scriptstrings/g.extension_to_translate.c:22
-#: ../locale/scriptstrings/r.unpack_to_translate.c:12
-#: ../locale/scriptstrings/v.unpack_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:18
-msgid "Print"
-msgstr ""
-#: ../raster/r.what/main.c:127 ../raster/r.stats/main.c:119
-#: ../raster/r.quantile/main.c:299 ../raster/r.stats.quantile/main.c:555
-#: ../raster/r.univar/r.univar_main.c:41
-#: ../raster/r.univar/r3.univar_main.c:42 ../db/db.select/main.c:241
-#: ../vector/v.db.select/main.c:95
-#: ../locale/scriptstrings/i.oif_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
-msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr ""
-#: ../raster/r.what/main.c:137
-msgid "Size of point cache"
-msgstr ""
-#: ../raster/r.what/main.c:139 ../raster/r.what/main.c:164
-#: ../display/d.legend/main.c:118 ../display/d.legend/main.c:128
-#: ../display/d.legend/main.c:136 ../display/d.legend/main.c:168
-#: ../display/d.legend/main.c:253 ../display/d.legend/main.c:258
-#: ../display/d.legend/main.c:268 ../display/d.legend/main.c:278
-#: ../display/d.legend/main.c:293
-msgid "Advanced"
-msgstr ""
-#: ../raster/r.what/main.c:143
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:11
-msgid "Output header row"
-msgstr ""
-#: ../raster/r.what/main.c:148
-msgid "Show the category labels of the grid cell(s)"
-msgstr ""
-#: ../raster/r.what/main.c:153
-msgid "Output color values as RRR:GGG:BBB"
-msgstr ""
-#: ../raster/r.what/main.c:158
-msgid "Output integer category values, not cell values"
-msgstr ""
-#: ../raster/r.what/main.c:163
-msgid "Turn on cache reporting"
-msgstr ""
-#: ../raster/r.what/main.c:168
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:13
-msgid "Show the category for vector points map"
-msgstr ""
-#: ../raster/r.what/main.c:177 ../raster/r.stats/main.c:227
-#: ../raster/r.quantile/main.c:313 ../raster/r.regression.multi/main.c:170
-#: ../raster/r.stats.quantile/main.c:319 ../raster/r.regression.line/main.c:77
-#: ../raster/r.univar/r.univar_main.c:129
-#: ../raster/r.univar/r3.univar_main.c:128 ../db/db.select/main.c:142
-#: ../vector/v.db.select/main.c:126
-#, c-format
-msgid "Unable to open file <%s> for writing"
-msgstr ""
-#: ../raster/r.what/main.c:199
-msgid "Flag 'v' required option 'points'"
-msgstr ""
-#: ../raster/r.what/main.c:214
-#, c-format
-msgid "Can only do up to %d raster maps (more than %d given)"
-msgstr ""
-#: ../raster/r.what/main.c:231
-#, c-format
-msgid "Unable to read category file for <%s>"
-msgstr ""
-#: ../raster/r.what/main.c:250 ../raster/r.region/main.c:176
-#: ../raster/r.carve/main.c:162 ../raster/r.cost/main.c:533
-#: ../raster/r.cost/main.c:606 ../raster/r.sim/simlib/observation_points.c:41
-#: ../raster/r.random/support.c:67 ../raster/r.drain/main.c:271
-#: ../raster/r.walk/main.c:673 ../raster/r.walk/main.c:742
-#: ../general/manage/lister/vector.c:32 ../general/g.region/main.c:489
-#: ../display/d.vect.chart/main.c:246 ../display/d.extract/main.c:103
-#: ../display/d.path/main.c:185 ../vector/v.out.postgis/main.c:100
-#: ../vector/v.build/main.c:118 ../vector/v.build/main.c:128
-#: ../vector/v.patch/main.c:129 ../vector/v.patch/main.c:147
-#: ../vector/v.patch/main.c:177 ../vector/v.patch/main.c:274
-#: ../vector/v.patch/main.c:355 ../vector/v.vol.rst/main.c:562
-#: ../vector/v.to.3d/main.c:72 ../vector/v.out.svg/main.c:139
-#: ../vector/v.to.rast/support.c:100 ../vector/v.to.rast/support.c:275
-#: ../vector/v.to.rast/support.c:513 ../vector/v.to.rast/vect2rast.c:39
-#: ../vector/v.rectify/main.c:150 ../vector/v.kernel/main.c:318
-#: ../vector/v.kernel/main.c:331 ../vector/v.net.spanningtree/main.c:101
-#: ../vector/v.delaunay/main.c:120 ../vector/v.to.db/main.c:65
-#: ../vector/v.segment/main.c:108 ../vector/v.net.timetable/main.c:353
-#: ../vector/v.out.dxf/main.c:80 ../vector/v.net.alloc/main.c:185
-#: ../vector/v.cluster/main.c:149 ../vector/v.vect.stats/main.c:277
-#: ../vector/v.vect.stats/main.c:288 ../vector/v.db.select/main.c:164
-#: ../vector/v.transform/main.c:197 ../vector/v.net.bridge/main.c:118
-#: ../vector/v.clean/main.c:283 ../vector/v.clean/test/topocheck.c:67
-#: ../vector/v.clean/test/topocheck.c:87 ../vector/v.out.lidar/main.c:611
-#: ../vector/v.reclass/main.c:113 ../vector/v.univar/main.c:158
-#: ../vector/v.net.components/main.c:148 ../vector/v.net.steiner/main.c:432
-#: ../vector/v.lidar.correction/main.c:161
-#: ../vector/v.net.centrality/main.c:209 ../vector/v.db.connect/main.c:154
-#: ../vector/v.split/main.c:172 ../vector/v.parallel/main.c:148
-#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
-#: ../vector/v.select/main.c:108 ../vector/v.net.distance/main.c:192
-#: ../vector/v.class/main.c:102 ../vector/v.overlay/main.c:188
-#: ../vector/v.extract/main.c:191 ../vector/v.perturb/main.c:148
-#: ../vector/v.perturb/main.c:173 ../vector/v.net.allpairs/main.c:130
-#: ../vector/v.support/main.c:134 ../vector/v.decimate/main.c:272
-#: ../vector/v.net.visibility/main.c:73 ../vector/v.net.visibility/main.c:82
-#: ../vector/v.what.rast3/main.c:114 ../vector/v.generalize/main.c:328
-#: ../vector/v.qcount/main.c:101 ../vector/v.net.connectivity/main.c:130
-#: ../vector/v.sample/main.c:124 ../vector/v.random/main.c:205
-#: ../vector/v.net/main.c:68 ../vector/v.net/main.c:92
-#: ../vector/v.colors/main.c:262 ../vector/v.net.flow/main.c:143
-#: ../vector/v.hull/main.c:87 ../vector/v.out.ascii/main.c:87
-#: ../vector/v.out.ascii/main.c:94 ../vector/v.to.points/main.c:130
-#: ../vector/v.net.path/main.c:158 ../vector/v.what.rast/main.c:131
-#: ../vector/v.lidar.edgedetection/main.c:186
-#: ../vector/v.colors.out/make_colors.c:23
-#: ../vector/v.colors.out/scan_cats.c:20 ../vector/v.out.ogr/main.c:136
-#: ../vector/v.to.rast3/main.c:73 ../vector/v.neighbors/main.c:88
-#: ../vector/v.voronoi/main.c:196 ../vector/v.info/main.c:61
-#: ../vector/v.drape/main.c:143 ../vector/v.lrs/v.lrs.segment/main.c:144
-#: ../vector/v.lrs/v.lrs.label/main.c:272
-#: ../vector/v.lrs/v.lrs.where/main.c:131
-#: ../vector/v.lrs/v.lrs.where/main.c:140
-#: ../vector/v.lrs/v.lrs.create/main.c:254
-#: ../vector/v.lrs/v.lrs.create/main.c:263 ../vector/v.type/main.c:131
-#: ../vector/v.distance/main.c:366 ../vector/v.distance/main.c:388
-#: ../vector/v.surf.rst/main.c:564 ../vector/v.surf.rst/main.c:668
-#: ../vector/v.build.polylines/main.c:151 ../vector/v.label/main.c:268
-#: ../vector/v.external/main.c:232 ../vector/v.normal/main.c:110
-#: ../vector/v.out.pov/main.c:97 ../vector/v.extrude/main.c:190
-#: ../vector/v.net.iso/main.c:243 ../vector/v.surf.idw/read_sites.c:29
-#: ../vector/v.edit/main.c:170 ../vector/v.edit/main.c:243
-#: ../vector/v.proj/main.c:237 ../vector/v.net.salesman/main.c:250
-#: ../vector/v.buffer/main.c:337 ../vector/v.profile/main.c:370
-#: ../vector/v.profile/main.c:394 ../vector/v.label.sa/labels.c:58
-#: ../raster3d/r3.flow/main.c:411 ../doc/vector/v.example/main.c:87
-#: ../misc/m.nviz.image/vector.c:280
-#, c-format
-msgid "Unable to open vector map <%s>"
-msgstr ""
-#: ../raster/r.what/main.c:314
-#, c-format
-msgid "Unable to read vector map <%s>"
-msgstr ""
-#: ../raster/r.what/main.c:318
-#, c-format
-msgid "Line %d is not point or centroid, skipped"
-msgstr ""
-#: ../raster/r.what/main.c:409
-#, c-format
-msgid "%s %s is outside your current region"
-msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:40
-msgid "A* Search..."
-msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:62
-#, c-format
-msgid "%lld surplus points"
-msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:67
-#, c-format
-msgid "Too many points in heap %lld, should be %lld"
-msgstr ""
-#: ../raster/r.stream.extract/close.c:35
-#, c-format
-msgid "Writing vector map <%s>..."
-msgstr ""
-#: ../raster/r.stream.extract/close.c:38 ../raster/r.carve/vect.c:32
-#: ../raster/r.flow/io.c:178 ../raster/r.volume/main.c:155
-#: ../raster/r.sim/simlib/output.c:38 ../raster/r.sim/simlib/output.c:44
-#: ../raster/r.contour/main.c:156 ../raster/r.random/random.c:63
-#: ../raster/r.to.vect/main.c:157 ../raster/r.drain/main.c:200
-#: ../raster/r.resamp.bspline/main.c:497 ../display/d.extract/main.c:106
-#: ../vector/v.build/main.c:154 ../vector/v.patch/main.c:283
-#: ../vector/v.patch/main.c:288 ../vector/v.outlier/main.c:229
-#: ../vector/v.outlier/main.c:234 ../vector/v.outlier/main.c:240
-#: ../vector/v.vol.rst/main.c:582 ../vector/v.vol.rst/main.c:585
-#: ../vector/v.to.3d/main.c:87 ../vector/v.rectify/main.c:216
-#: ../vector/v.kernel/main.c:337 ../vector/v.net.spanningtree/main.c:107
-#: ../vector/v.delaunay/main.c:126 ../vector/v.mkgrid/main.c:264
-#: ../vector/v.segment/main.c:114 ../vector/v.net.timetable/main.c:359
-#: ../vector/v.in.db/main.c:151 ../vector/v.in.region/main.c:75
-#: ../vector/v.net.alloc/main.c:298 ../vector/v.cluster/main.c:209
-#: ../vector/v.transform/main.c:265 ../vector/v.net.bridge/main.c:124
-#: ../vector/v.clean/main.c:288 ../vector/v.clean/main.c:295
-#: ../vector/v.reclass/main.c:117 ../vector/v.net.components/main.c:154
-#: ../vector/v.net.steiner/main.c:607 ../vector/v.lidar.correction/main.c:215
-#: ../vector/v.lidar.correction/main.c:221
-#: ../vector/v.net.centrality/main.c:215 ../vector/v.split/main.c:177
-#: ../vector/v.parallel/main.c:153 ../vector/v.select/main.c:149
-#: ../vector/v.net.distance/main.c:198 ../vector/v.overlay/main.c:220
-#: ../vector/v.extract/main.c:346 ../vector/v.perturb/main.c:154
-#: ../vector/v.net.allpairs/main.c:136 ../vector/v.decimate/main.c:391
-#: ../vector/v.net.visibility/main.c:77 ../vector/v.generalize/main.c:339
-#: ../vector/v.qcount/main.c:127 ../vector/v.net.connectivity/main.c:136
-#: ../vector/v.in.lidar/main.c:555 ../vector/v.sample/main.c:162
-#: ../vector/v.random/main.c:228 ../vector/v.net.flow/main.c:149
-#: ../vector/v.net.flow/main.c:155 ../vector/v.hull/main.c:121
-#: ../vector/v.to.points/main.c:138 ../vector/v.net.path/main.c:167
-#: ../vector/v.in.ogr/main.c:843 ../vector/v.lidar.edgedetection/main.c:251
-#: ../vector/v.voronoi/main.c:215 ../vector/v.drape/main.c:158
-#: ../vector/v.lrs/v.lrs.segment/main.c:148
-#: ../vector/v.lrs/v.lrs.label/main.c:276
-#: ../vector/v.lrs/v.lrs.create/main.c:267
-#: ../vector/v.lrs/v.lrs.create/main.c:273 ../vector/v.in.dwg/main.c:200
-#: ../vector/v.in.ascii/main.c:251 ../vector/v.surf.bspline/main.c:353
-#: ../vector/v.distance/main.c:412 ../vector/v.surf.rst/main.c:603
-#: ../vector/v.surf.rst/main.c:606 ../vector/v.surf.rst/main.c:772
-#: ../vector/v.build.polylines/main.c:156 ../vector/v.external/main.c:184
-#: ../vector/v.extrude/main.c:196 ../vector/v.net.iso/main.c:356
-#: ../vector/v.edit/main.c:107 ../vector/v.edit/main.c:122
-#: ../vector/v.in.dxf/main.c:146 ../vector/v.proj/main.c:380
-#: ../vector/v.net.salesman/main.c:551 ../vector/v.buffer/main.c:405
-#: ../vector/v.profile/main.c:537 ../raster3d/r3.flow/main.c:396
-#: ../doc/vector/v.example/main.c:100
-#: ../scripts/v.what.strds/v.what.strds.py:217
-#, c-format, python-format
-msgid "Unable to create vector map <%s>"
-msgstr ""
-#: ../raster/r.stream.extract/close.c:123
-#, c-format
-msgid "Stream id %d not set, top is %d, parent is %d"
-msgstr ""
-#: ../raster/r.stream.extract/close.c:144
-msgid "Stream id not set while tracing"
-msgstr ""
-#: ../raster/r.stream.extract/close.c:163
-msgid "Writing attribute data..."
-msgstr ""
-#: ../raster/r.stream.extract/close.c:178 ../db/db.describe/main.c:56
-#: ../db/db.execute/main.c:70 ../db/db.dropdb/main.c:42
-#: ../db/db.columns/main.c:51 ../db/db.select/main.c:75
-#: ../db/db.createdb/main.c:42 ../db/db.tables/main.c:45
-#: ../db/db.databases/main.c:48 ../display/d.vect.thematic/main.c:294
-#: ../display/d.vect/opt.c:147 ../vector/v.out.svg/main.c:152
-#: ../vector/v.db.connect/main.c:217 ../vector/v.db.connect/main.c:283
-#: ../vector/v.out.vtk/writeVTK.c:644 ../vector/v.edit/select.c:509
-#: ../vector/v.profile/main.c:420 ../vector/v.profile/main.c:575
-#: ../doc/vector/v.example/main.c:129
-#, c-format
-msgid "Unable to start driver <%s>"
-msgstr ""
-#: ../raster/r.stream.extract/close.c:194 ../raster/r.contour/main.c:183
-#: ../vector/v.net.timetable/main.c:103 ../vector/v.net.alloc/main.c:329
-#: ../vector/v.net.components/main.c:190 ../vector/v.net.centrality/main.c:266
-#: ../vector/v.net.distance/main.c:291 ../vector/v.overlay/main.c:587
-#: ../vector/v.net.allpairs/main.c:179 ../vector/v.in.lidar/attributes.c:135
-#: ../vector/v.net.flow/main.c:181 ../vector/v.to.points/main.c:192
-#: ../vector/v.net.path/path.c:109 ../vector/v.in.ogr/main.c:1143
-#: ../vector/v.in.dwg/main.c:240 ../vector/v.distance/main.c:1427
-#: ../vector/v.net.iso/main.c:390
-#, c-format
-msgid "Unable to create table: '%s'"
-msgstr ""
-#: ../raster/r.stream.extract/close.c:198
-#: ../scripts/v.db.addtable/v.db.addtable.py:147
-msgid "Unable to create index on table <%s>"
-msgstr ""
-#: ../raster/r.stream.extract/close.c:202 ../raster/r.contour/main.c:193
-#: ../raster/r.random/random.c:262 ../raster/r.to.vect/main.c:238
-#: ../vector/v.patch/main.c:333 ../vector/v.mkgrid/main.c:350
-#: ../vector/v.mkgrid/main.c:408 ../vector/v.reclass/main.c:327
-#: ../vector/v.select/copy_tabs.c:90 ../vector/v.overlay/main.c:597
-#: ../vector/v.extract/copy_tab.c:129 ../vector/v.in.lidar/attributes.c:144
-#: ../vector/v.sample/main.c:197 ../vector/v.random/main.c:265
-#: ../vector/v.to.points/main.c:202 ../vector/v.in.ogr/main.c:1150
-#: ../vector/v.in.dwg/main.c:249 ../vector/v.in.ascii/main.c:423
-#: ../vector/v.distance/main.c:1432 ../vector/v.in.dxf/write_vect.c:238
-#: ../raster3d/r3.flow/main.c:72
-#, c-format
-msgid "Unable to grant privileges on table <%s>"
-msgstr ""
-#: ../raster/r.stream.extract/close.c:219
-#, c-format
-msgid "Unable to insert new row: '%s'"
-msgstr ""
-#: ../raster/r.stream.extract/close.c:320
-#, c-format
-msgid "Unable to write vector map <%s>"
-msgstr ""
-#: ../raster/r.stream.extract/del_streams.c:130
-#, c-format
-msgid "Deleting stream segments shorter than %d cell..."
-msgid_plural "Deleting stream segments shorter than %d cells..."
-msgstr[0] ""
-#: ../raster/r.stream.extract/del_streams.c:193
-#, c-format
-msgid "%d stream segment deleted"
-msgid_plural "%d stream segments deleted"
-msgstr[0] ""
-#: ../raster/r.stream.extract/init_search.c:24
-msgid "Initializing A* search..."
-msgstr ""
-#: ../raster/r.stream.extract/streams.c:72
-#: ../raster/r.stream.extract/streams.c:668
-#, c-format
-msgid "Stream_no %d and n_stream_nodes %lld out of sync"
-msgstr ""
-#: ../raster/r.stream.extract/streams.c:128
-#, c-format
-msgid "BUG: stream node %d has only 1 tributary: %d"
-msgstr ""
-#: ../raster/r.stream.extract/streams.c:160
-msgid "Calculating flow accumulation..."
-msgstr ""
-#: ../raster/r.stream.extract/streams.c:336
-#: ../raster/r.watershed/seg/do_cum.c:487
-#: ../raster/r.watershed/ram/do_cum.c:443
-#, c-format
-msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
-msgstr ""
-#: ../raster/r.stream.extract/streams.c:392
-msgid "Extracting streams..."
-msgstr ""
-#: ../raster/r.stream.extract/streams.c:469
-msgid "Bug in stream extraction"
-msgstr ""
-#: ../raster/r.stream.extract/streams.c:631
-msgid "Can't use Montgomery's method, no stream direction found"
-msgstr ""
-#: ../raster/r.stream.extract/streams.c:700
-#, c-format
-msgid ""
-"MFD: A * path already processed when setting drainage direction: %lld of "
-"%lld cells"
-msgstr ""
-#: ../raster/r.stream.extract/thin.c:83
-msgid "Thinning stream segments..."
-msgstr ""
-#: ../raster/r.stream.extract/thin.c:169
-#, c-format
-msgid "%d of %lld stream segments were thinned"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:77 ../raster/r.usler/main.c:53
-#: ../raster/r.basins.fill/main.c:55 ../raster/r.carve/main.c:75
-#: ../raster/r.flow/main.c:422 ../raster/r.gwflow/main.c:210
-#: ../raster/r.topmodel/main.c:52 ../raster/r.sim/r.sim.water/main.c:114
-#: ../raster/r.sim/r.sim.sediment/main.c:115 ../raster/r.lake/main.c:151
-#: ../raster/r.fill.dir/main.c:87 ../raster/r.watershed/front/main.c:74
-#: ../raster/r.topidx/main.c:40 ../raster/r.solute.transport/main.c:230
-#: ../raster/r.drain/main.c:110 ../raster/r.uslek/main.c:54
-#: ../raster/r.water.outlet/main.c:58 ../raster3d/r3.gwflow/main.c:162
-#: ../raster3d/r3.flow/main.c:180
-msgid "hydrology"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:78 ../raster/r.watershed/front/main.c:78
-msgid "stream network"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:79
-msgid "Performs stream network extraction."
-msgstr ""
-#: ../raster/r.stream.extract/main.c:85
-msgid "Name of input accumulation raster map"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:88
-msgid ""
-"Stream extraction will use provided accumulation instead of calculating it "
-"anew"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:89 ../raster/r.stream.extract/main.c:97
-#: ../raster/r.flow/main.c:435 ../raster/r.flow/main.c:441
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:7
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:9
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:11
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:13
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:15
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:17
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:23
-msgid "Input maps"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:93
-msgid "Name of input raster map with real depressions"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:96
-msgid "Streams will not be routed out of real depressions"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:101
-msgid "Minimum flow accumulation for streams"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:102
-msgid "Must be > 0"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:108
-msgid "Use SFD above this threshold"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:110
-msgid ""
-"If accumulation is larger than d8cut, SFD is used instead of MFD. Applies "
-"only if no accumulation map is given."
-msgstr ""
-#: ../raster/r.stream.extract/main.c:121
-msgid "Montgomery exponent for slope, disabled with 0"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:123
-msgid ""
-"Montgomery: accumulation is multiplied with pow(slope,mexp) and then "
-"compared with threshold"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:131
-msgid "Delete stream segments shorter than stream_length cells"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:133
-msgid "Applies only to first-order stream segments (springs/stream heads)"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:140 ../raster/r.proj/main.c:191
-#: ../raster/r.in.gdal/main.c:122 ../raster/r.resamp.bspline/main.c:152
-#: ../vector/v.to.rast/main.c:116 ../vector/v.surf.bspline/main.c:194
-#: ../locale/scriptstrings/r.import_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:14
-msgid "Maximum memory to be used (in MB)"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:141 ../raster/r.proj/main.c:192
-#: ../raster/r.in.gdal/main.c:123 ../raster/r.resamp.bspline/main.c:153
-#: ../vector/v.to.rast/main.c:117 ../vector/v.surf.bspline/main.c:195
-#: ../locale/scriptstrings/r.import_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:13
-msgid "Cache size for raster rows"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:146
-msgid "Name for output raster map with unique stream ids"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:148 ../raster/r.stream.extract/main.c:155
-#: ../raster/r.stream.extract/main.c:162 ../raster/r.flow/main.c:459
-#: ../raster/r.flow/main.c:465 ../raster/r.flow/main.c:471
-msgid "Output maps"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:153
-msgid "Name for output vector map with unique stream ids"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:160
-msgid "Name for output raster map with flow direction"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:173 ../raster/r.stream.extract/main.c:177
-#: ../raster/r.stream.extract/main.c:182 ../raster/r.category/main.c:119
-#: ../raster/r.category/main.c:140 ../raster/r.compress/main.c:124
-#: ../raster/r.compress/main.c:304 ../raster/r.cross/main.c:106
-#: ../raster/r.distance/parse.c:72 ../raster/r.distance/parse.c:81
-#: ../raster/r.ros/main.c:368 ../raster/r.ros/main.c:379
-#: ../raster/r.ros/main.c:384 ../raster/r.ros/main.c:389
-#: ../raster/r.ros/main.c:394 ../raster/r.ros/main.c:408
-#: ../raster/r.ros/main.c:412 ../raster/r.ros/main.c:427
-#: ../raster/r.ros/main.c:431 ../raster/r.ros/main.c:442
-#: ../raster/r.carve/main.c:165 ../raster/r.flow/io.c:65
-#: ../raster/r.flow/io.c:242 ../raster/r.info/main.c:104
-#: ../raster/r.coin/main.c:121 ../raster/r.coin/main.c:123
-#: ../raster/r.buffer/main.c:112 ../raster/r.kappa/main.c:150
-#: ../raster/r.kappa/stats.c:33 ../raster/r.kappa/stats.c:38
-#: ../raster/r.cost/main.c:350 ../raster/r.cost/main.c:665
-#: ../raster/r.sim/simlib/output.c:363 ../raster/r.sim/simlib/output.c:372
-#: ../raster/r.sim/simlib/output.c:403 ../raster/r.sim/simlib/output.c:412
-#: ../raster/r.sim/simlib/output.c:458 ../raster/r.sim/simlib/output.c:475
-#: ../raster/r.sim/simlib/output.c:497 ../raster/r.sim/simlib/output.c:541
-#: ../raster/r.sim/simlib/output.c:583 ../raster/r.sim/simlib/output.c:755
-#: ../raster/r.report/parse.c:273 ../raster/r.null/main.c:128
-#: ../raster/r.colors/edit_colors.c:393 ../raster/r.reclass/main.c:79
-#: ../raster/r.tile/main.c:86 ../raster/r.walk/main.c:435
-#: ../raster/r.walk/main.c:440 ../raster/r.walk/main.c:801
-#: ../raster/r.univar/r.univar_main.c:234 ../raster/r.mapcalc/map.c:519
-#: ../raster/r.mapcalc/map.c:813 ../raster/r.mapcalc/map3.c:710
-#: ../raster/r.spread/main.c:439 ../raster/r.spread/main.c:442
-#: ../raster/r.spread/main.c:445 ../raster/r.spread/main.c:449
-#: ../raster/r.spread/main.c:452 ../raster/r.spread/main.c:455
-#: ../raster/r.geomorphon/memory.c:14 ../raster/r.fill.stats/main.c:1028
-#: ../general/g.region/main.c:429 ../general/g.region/main.c:766
-#: ../general/g.region/main.c:774 ../imagery/i.gensig/parse.c:38
-#: ../imagery/i.pca/main.c:139 ../imagery/i.gensigset/parse.c:44
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:197
-#: ../vector/v.vol.rst/main.c:617 ../vector/v.colors/main.c:312
-#: ../doc/raster/r.example/main.c:105 ../misc/m.nviz.image/surface.c:50
-#: ../misc/m.nviz.image/surface.c:107
-#: ../scripts/r.buffer.lowmem/r.buffer.lowmem.py:87
-#: ../scripts/d.correlate/d.correlate.py:50
-#: ../scripts/v.rast.stats/v.rast.stats.py:128
-#: ../scripts/d.polar/d.polar.py:62 ../scripts/r.pack/r.pack.py:74
-#: ../scripts/r.reclass.area/r.reclass.area.py:103
-#: ../scripts/r.reclass.area/r.reclass.area.py:213
-#: ../scripts/r.mask/r.mask.py:131 ../scripts/r.rgb/r.rgb.py:60
-#: ../scripts/r.fillnulls/r.fillnulls.py:152
-#: ../scripts/d.rast.leg/d.rast.leg.py:99
-#: ../scripts/d.rast.leg/d.rast.leg.py:103 ../scripts/r.grow/r.grow.py:123
-msgid "Raster map <%s> not found"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:191
-#, c-format
-msgid "Threshold must be > 0 but is %f"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:200
-#, c-format
-msgid "d8cut must be positive or zero but is %f"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:208
-#, c-format
-msgid "Montgomery exponent must be positive or zero but is %f"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:211
-#, c-format
-msgid "Montgomery exponent is %f, recommended range is 0.0 - 3.0"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:221
-#, c-format
-msgid "Minimum stream length must be positive or zero but is %d"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:230
-#, c-format
-msgid "Memory must be positive but is %d"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:240
-msgid "At least one output raster maps must be specified"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:314
-#, c-format
-msgid "%.2f%% of data are kept in memory"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:318
-#: ../raster/r.watershed/seg/init_vars.c:252
-#, c-format
-msgid "Will need up to %.2f MB of disk space"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:320
-#: ../raster/r.watershed/seg/init_vars.c:254
-#, c-format
-msgid "Will need up to %.2f GB (%.0f MB) of disk space"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:324
-msgid "Creating temporary files..."
-msgstr ""
-#: ../raster/r.stream.extract/main.c:344
-msgid "Unable to load input raster map(s)"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:346
-msgid "No non-NULL cells in input raster map(s)"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:397
-msgid "Unable to initialize search"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:401
-msgid "Unable to sort elevation raster map values"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:407
-msgid "Unable to calculate flow accumulation"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:412
-msgid "Unable to extract streams"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:419
-msgid "Unable to thin streams"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:424
-msgid "Unable to delete short stream segments"
-msgstr ""
-#: ../raster/r.stream.extract/main.c:430
-msgid "Unable to write output raster maps"
-msgstr ""
-#: ../raster/r.stream.extract/seg.c:20 ../raster/r.stream.extract/bseg.c:19
-#: ../raster/r.stream.extract/cseg.c:19
-msgid "Unable to create segment file"
-msgstr ""
-#: ../raster/r.stream.extract/seg.c:34 ../raster/r.stream.extract/seg.c:76
-#: ../raster/r.stream.extract/bseg.c:28 ../raster/r.stream.extract/bseg.c:78
-#: ../raster/r.stream.extract/bseg.c:87 ../raster/r.stream.extract/cseg.c:29
-#: ../raster/r.stream.extract/cseg.c:79 ../raster/r.stream.extract/cseg.c:88
-#: ../raster/r.stream.extract/dseg.c:29 ../raster/r.stream.extract/dseg.c:79
-#: ../raster/r.stream.extract/dseg.c:88
-msgid "Unable to write segment file"
-msgstr ""
-#: ../raster/r.stream.extract/seg.c:38 ../raster/r.stream.extract/bseg.c:32
-#: ../raster/r.stream.extract/cseg.c:33
-msgid "Illegal configuration parameter(s)"
-msgstr ""
-#: ../raster/r.stream.extract/seg.c:45
-#, c-format
-msgid "Unable to re-open file '%s'"
-msgstr ""
-#: ../raster/r.stream.extract/seg.c:52 ../raster/r.stream.extract/seg.c:94
-#: ../raster/r.stream.extract/seg.c:103 ../raster/r.stream.extract/bseg.c:46
-#: ../raster/r.stream.extract/bseg.c:96 ../raster/r.stream.extract/cseg.c:47
-#: ../raster/r.stream.extract/dseg.c:47 ../raster/r.stream.extract/dseg.c:97
-msgid "Unable to read segment file"
-msgstr ""
-#: ../raster/r.stream.extract/seg.c:56 ../raster/r.stream.extract/bseg.c:50
-#: ../raster/r.stream.extract/cseg.c:51 ../raster/r.stream.extract/dseg.c:51
-#: ../raster/r.to.rast3/main.c:244 ../raster/r.sun/main.c:854
-#: ../raster/r.sun/main.c:865 ../raster/r.sun/main.c:878
-#: ../raster/r.sun/main.c:890 ../raster/r.sun/main.c:901
-#: ../raster/r.sun/main.c:912 ../raster/r.sun/main.c:923
-#: ../raster/r.sun/main.c:935 ../raster/r.sun/main.c:946
-#: ../raster/r.li/r.li.daemon/list.c:49 ../db/drivers/sqlite/listdb.c:134
-#: ../db/drivers/postgres/listdb.c:88 ../db/drivers/postgres/listtab.c:92
-#: ../imagery/i.smap/multialloc.c:115 ../vector/v.vol.rst/user1.c:423
-#: ../vector/v.mkgrid/write_grid.c:28 ../vector/v.net.timetable/main.c:389
-#: ../vector/v.net.timetable/main.c:399 ../vector/v.kcv/main.c:208
-#: ../vector/v.net.components/main.c:170 ../vector/v.net.centrality/main.c:293
-#: ../vector/v.net.centrality/main.c:298 ../vector/v.net.centrality/main.c:304
-#: ../vector/v.net.centrality/main.c:310 ../vector/v.net.centrality/main.c:316
-#: ../vector/v.net.distance/main.c:228 ../vector/v.net.allpairs/main.c:201
-#: ../vector/v.generalize/simplification.c:33
-#: ../vector/v.generalize/simplification.c:40
-#: ../vector/v.generalize/simplification.c:306
-#: ../vector/v.generalize/simplification.c:314
-#: ../vector/v.generalize/simplification.c:338
-#: ../vector/v.generalize/matrix.c:144 ../vector/v.generalize/network.c:96
-#: ../vector/v.generalize/network.c:131 ../vector/v.generalize/smoothing.c:144
-#: ../vector/v.generalize/smoothing.c:231
-#: ../vector/v.generalize/smoothing.c:374
-#: ../vector/v.generalize/smoothing.c:528
-#: ../vector/v.generalize/smoothing.c:574
-#: ../vector/v.generalize/smoothing.c:578
-#: ../vector/v.generalize/smoothing.c:582
-#: ../vector/v.generalize/smoothing.c:586
-#: ../vector/v.generalize/smoothing.c:590
-#: ../vector/v.generalize/smoothing.c:594
-#: ../vector/v.generalize/smoothing.c:598
-#: ../vector/v.net.connectivity/main.c:186
-#: ../vector/v.net.connectivity/main.c:202 ../vector/v.net.flow/main.c:232
-#: ../vector/v.surf.rst/main.c:846 ../vector/v.profile/processors.c:31
-#: ../raster3d/r3.to.rast/main.c:360
-msgid "Out of memory"
-msgstr ""
-#: ../raster/r.stream.extract/seg.c:85
-msgid "seg_put_row(): could not write segment file"
-msgstr ""
-#: ../raster/r.stream.extract/load.c:33
-msgid "Loading elevation raster map..."
-msgstr ""
-#: ../raster/r.stream.extract/load.c:35
-msgid "Loading input raster maps..."
-msgstr ""
-#: ../raster/r.stream.extract/load.c:95
-msgid "Elevation raster map is NULL but accumulation map is not NULL"
-msgstr ""
-#: ../raster/r.stream.extract/bseg.c:39 ../raster/r.stream.extract/cseg.c:40
-#: ../raster/r.stream.extract/dseg.c:40
-msgid "Unable to re-open segment file"
-msgstr ""
-#: ../raster/r.stream.extract/cseg.c:97
-msgid "Unabel to read segment file"
-msgstr ""
-#: ../raster/r.stream.extract/cseg.c:120
-#, c-format
-msgid "Unable to segment put row %d for raster map <%s>"
-msgstr ""
-#: ../raster/r.stream.extract/dseg.c:19
-msgid "dseg_open(): unable to create segment file"
-msgstr ""
-#: ../raster/r.stream.extract/dseg.c:33
-msgid "Iillegal configuration parameter(s)"
-msgstr ""
-#: ../raster/r.stream.extract/dseg.c:120
-#, c-format
-msgid "Inable to segment put row %d for raster <%s>"
-msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:46
-#: ../raster/r.colors/edit_colors.c:59 ../raster/r.univar/r3.univar_main.c:98
-#: ../raster/r.to.rast3elev/main.c:363 ../raster3d/r3.support/main.c:49
-#: ../raster3d/r3.neighbors/main.c:208 ../raster3d/r3.stats/main.c:48
-#: ../raster3d/r3.gradient/main.c:43 ../raster3d/r3.gwflow/main.c:159
-#: ../raster3d/r3.out.vtk/main.c:376 ../raster3d/r3.in.ascii/main.c:354
-#: ../raster3d/r3.out.bin/main.c:205 ../raster3d/r3.cross.rast/main.c:228
-#: ../raster3d/r3.info/main.c:75 ../raster3d/r3.retile/main.c:96
-#: ../raster3d/r3.timestamp/main.c:43 ../raster3d/r3.in.bin/main.c:252
-#: ../raster3d/r3.flow/main.c:179 ../raster3d/r3.flow/test_main.c:43
-#: ../raster3d/r3.out.netcdf/main.c:586 ../raster3d/r3.in.lidar/main.c:162
-#: ../raster3d/r3.mask/main.c:133 ../raster3d/r3.out.ascii/main.c:302
-#: ../raster3d/r3.mkdspf/main.c:79 ../raster3d/r3.in.v5d/main.c:178
-#: ../raster3d/r3.out.v5d/main.c:284 ../raster3d/r3.null/main.c:180
-#: ../raster3d/r3.to.rast/main.c:259
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:4
-#: ../misc/m.nviz.script/main.c:72 ../misc/m.nviz.image/main.c:55
-msgid "raster3d"
-msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:47
-#: ../raster/r.colors.out/raster_main.c:46 ../raster/r.what.color/main.c:90
-#: ../raster/r.colors/edit_colors.c:67 ../display/d.colortable/main.c:62
-#: ../vector/v.colors/main.c:56 ../vector/v.colors.out/main.c:50
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:3
-msgid "color table"
-msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:50
-msgid "Exports the color table associated with a 3D raster map."
-msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:56
-#: ../raster/r.colors.out/raster_main.c:55 ../vector/v.colors.out/main.c:61
-msgid "Path to output rules file"
-msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:57
-#: ../raster/r.colors.out/raster_main.c:56 ../raster/r.kappa/main.c:89
-#: ../vector/v.colors.out/main.c:62
-msgid "If not given write to standard output"
-msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:62
-#: ../raster/r.colors.out/raster_main.c:61 ../vector/v.colors.out/main.c:72
-msgid "Output values as percentages"
-msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:70
-#, c-format
-msgid "Unable to read color table for raster3d map <%s>"
-msgstr ""
-#: ../raster/r.colors.out/raster_main.c:49
-msgid "Exports the color table associated with a raster map."
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:27
-#, c-format
-msgid "Cannot open filter file '%s'"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:47
-msgid "Illegal filter matrix size specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:50
-msgid "Even filter matrix size specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:72
-msgid "Illegal filter matrix"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
-#: ../raster/r.mfilter/getfilt.c:124
-msgid "Filter file format error"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:83
-msgid "Duplicate filter divisor specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:101
-msgid "Illegal divisor matrix"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:110
-msgid "Duplicate filter type specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:117
-msgid "Illegal filter type specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:127
-msgid "Duplicate filter start specified"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:135
-#, c-format
-msgid "Filter start %s ignored, using UL"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:157
-msgid "Illegal filter file format"
-msgstr ""
-#: ../raster/r.mfilter/getrow.c:23
-msgid "Error reading temporary file"
-msgstr ""
-#: ../raster/r.mfilter/main.c:59 ../raster/r.neighbors/main.c:173
-#: ../raster/r.resamp.filter/main.c:392 ../vector/v.outlier/main.c:73
-#: ../raster3d/r3.neighbors/main.c:215
-msgid "filter"
-msgstr ""
-#: ../raster/r.mfilter/main.c:60
-msgid "Performs raster map matrix filter."
-msgstr ""
-#: ../raster/r.mfilter/main.c:71
-msgid "Path to filter file"
-msgstr ""
-#: ../raster/r.mfilter/main.c:79
-msgid "Number of times to repeat the filter"
-msgstr ""
-#: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
-#: ../imagery/i.pca/main.c:109 ../imagery/i.pca/main.c:120
-msgid "Filter"
-msgstr ""
-#: ../raster/r.mfilter/main.c:86
-msgid "Output raster map title"
-msgstr ""
-#: ../raster/r.mfilter/main.c:98
-msgid "Apply filter only to null data values"
-msgstr ""
-#: ../raster/r.mfilter/main.c:125
-msgid "Raster map too small for the size of the filter"
-msgstr ""
-#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
-msgid "Unable to create temporary file"
-msgstr ""
-#: ../raster/r.mfilter/perform.c:81
-#, c-format
-msgid "Writing raster map <%s>"
-msgstr ""
-#: ../raster/r.category/cats.c:47
-#, c-format
-msgid "Reading <%s> in <%s>"
-msgstr ""
-#: ../raster/r.category/main.c:53 ../vector/v.to.db/main.c:44
-#: ../vector/v.category/main.c:76
-msgid "category"
-msgstr ""
-#: ../raster/r.category/main.c:55
-msgid ""
-"Manages category values and labels associated with user-specified raster map"
-" layers."
-msgstr ""
-#: ../raster/r.category/main.c:62 ../raster/r.category/main.c:71
-#: ../raster/r.in.lidar/main.c:193 ../raster/r.in.lidar/main.c:209
-#: ../raster/r.in.lidar/main.c:262 ../raster/r.in.lidar/main.c:272
-#: ../raster/r.in.lidar/main.c:341 ../display/d.rast/main.c:70
-#: ../display/d.rast/main.c:87 ../display/d.vect.chart/main.c:74
-#: ../display/d.vect.chart/main.c:77 ../display/d.vect.thematic/main.c:98
-#: ../display/d.vect.thematic/main.c:148 ../display/d.vect/main.c:84
-#: ../display/d.vect/main.c:109 ../display/d.vect/main.c:112
-#: ../display/d.vect/main.c:115 ../display/d.vect/main.c:317
-#: ../vector/v.out.postgis/args.c:15 ../vector/v.out.postgis/args.c:19
-#: ../vector/v.to.3d/args.c:19 ../vector/v.to.3d/args.c:25
-#: ../vector/v.to.rast/main.c:57 ../vector/v.to.rast/main.c:60
-#: ../vector/v.to.rast/main.c:63 ../vector/v.to.db/parse.c:45
-#: ../vector/v.in.db/main.c:94 ../vector/v.vect.stats/main.c:156
-#: ../vector/v.vect.stats/main.c:161 ../vector/v.vect.stats/main.c:166
-#: ../vector/v.vect.stats/main.c:171 ../vector/v.vect.stats/main.c:176
-#: ../vector/v.vect.stats/main.c:181 ../vector/v.vect.stats/main.c:186
-#: ../vector/v.db.select/main.c:64 ../vector/v.db.select/main.c:67
-#: ../vector/v.db.select/main.c:70 ../vector/v.db.select/main.c:76
-#: ../vector/v.db.select/main.c:116 ../vector/v.clean/main.c:61
-#: ../vector/v.clean/main.c:64 ../vector/v.out.lidar/main.c:489
-#: ../vector/v.out.lidar/main.c:493 ../vector/v.out.lidar/main.c:590
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.net.centrality/main.c:121 ../vector/v.net.centrality/main.c:123
-#: ../vector/v.select/args.c:18 ../vector/v.select/args.c:24
-#: ../vector/v.select/args.c:33 ../vector/v.select/args.c:39
-#: ../vector/v.select/args.c:106 ../vector/v.extract/main.c:98
-#: ../vector/v.extract/main.c:103 ../vector/v.extract/main.c:109
-#: ../vector/v.extract/main.c:112 ../vector/v.extract/main.c:115
-#: ../vector/v.extract/main.c:125 ../vector/v.extract/main.c:135
-#: ../vector/v.net.allpairs/main.c:75 ../vector/v.net.allpairs/main.c:81
-#: ../vector/v.net.allpairs/main.c:84 ../vector/v.net.allpairs/main.c:87
-#: ../vector/v.decimate/main.c:149 ../vector/v.decimate/main.c:152
-#: ../vector/v.generalize/main.c:94 ../vector/v.generalize/main.c:233
-#: ../vector/v.generalize/main.c:236 ../vector/v.in.lidar/main.c:187
-#: ../vector/v.in.lidar/main.c:197 ../vector/v.in.lidar/main.c:206
-#: ../vector/v.in.lidar/main.c:216 ../vector/v.in.lidar/main.c:223
-#: ../vector/v.in.lidar/main.c:228 ../vector/v.in.lidar/main.c:283
-#: ../vector/v.in.lidar/main.c:289 ../vector/v.in.lidar/main.c:297
-#: ../vector/v.random/main.c:119 ../vector/v.random/main.c:123
-#: ../vector/v.random/main.c:126 ../vector/v.random/main.c:129
-#: ../vector/v.out.ascii/args.c:24 ../vector/v.out.ascii/args.c:28
-#: ../vector/v.out.ascii/args.c:43 ../vector/v.out.ascii/args.c:46
-#: ../vector/v.to.points/main.c:67 ../vector/v.to.points/main.c:71
-#: ../vector/v.in.ogr/main.c:237 ../vector/v.in.ogr/main.c:242
-#: ../vector/v.in.ogr/main.c:251 ../vector/v.in.ogr/main.c:267
-#: ../vector/v.in.ogr/main.c:315 ../vector/v.in.ogr/main.c:360
-#: ../vector/v.out.ogr/args.c:12 ../vector/v.out.ogr/args.c:22
-#: ../vector/v.out.ogr/args.c:102 ../vector/v.drape/main.c:67
-#: ../vector/v.drape/main.c:70 ../vector/v.drape/main.c:73
-#: ../vector/v.drape/main.c:78 ../vector/v.surf.rst/main.c:180
-#: ../vector/v.surf.rst/main.c:192 ../vector/v.extrude/main.c:84
-#: ../vector/v.extrude/main.c:87 ../vector/v.extrude/main.c:90
-#: ../vector/v.extrude/main.c:95 ../vector/v.edit/args.c:24
-#: ../vector/v.edit/args.c:29 ../vector/v.edit/args.c:118
-#: ../vector/v.edit/args.c:122 ../vector/v.edit/args.c:131
-#: ../vector/v.edit/args.c:140 ../vector/v.edit/args.c:149
-#: ../vector/v.edit/args.c:152 ../vector/v.edit/args.c:170
-#: ../vector/v.edit/args.c:205 ../vector/v.category/main.c:85
-#: ../vector/v.category/main.c:89 ../vector/v.category/main.c:93
-#: ../vector/v.buffer/main.c:235 ../vector/v.buffer/main.c:238
-#: ../vector/v.buffer/main.c:241 ../vector/v.buffer/main.c:246
-#: ../vector/v.profile/main.c:165 ../vector/v.profile/main.c:168
-#: ../vector/v.profile/main.c:173 ../raster3d/r3.in.lidar/main.c:232
-#: ../raster3d/r3.in.lidar/main.c:242 ../raster3d/r3.in.lidar/main.c:272
-#: ../raster3d/r3.in.lidar/main.c:288
-#: ../locale/scriptstrings/v.report_to_translate.c:5
-#: ../locale/scriptstrings/t.list_to_translate.c:7
-#: ../locale/scriptstrings/t.list_to_translate.c:8
-#: ../locale/scriptstrings/t.list_to_translate.c:14
-#: ../locale/scriptstrings/t.list_to_translate.c:15
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:10
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:7
-msgid "Selection"
-msgstr ""
-#: ../raster/r.category/main.c:69
-msgid "Comma separated value list"
-msgstr ""
-#: ../raster/r.category/main.c:70
-msgid "Example: 1.4,3.8,13"
-msgstr ""
-#: ../raster/r.category/main.c:80 ../raster/r.support/main.c:115
-#: ../raster3d/r3.support/main.c:111
-msgid "Raster map from which to copy category table"
-msgstr ""
-#: ../raster/r.category/main.c:81 ../raster/r.category/main.c:88
-#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
-#: ../raster/r.colors/edit_colors.c:104 ../raster/r.colors/edit_colors.c:111
-#: ../raster/r.colors/edit_colors.c:122 ../raster/r.colors/edit_colors.c:133
-#: ../raster/r.colors/edit_colors.c:138 ../raster/r.colors/edit_colors.c:143
-#: ../raster/r.colors/edit_colors.c:148 ../display/d.linegraph/main.c:270
-#: ../vector/v.colors/main.c:81 ../vector/v.colors/main.c:92
-#: ../vector/v.colors/main.c:99 ../vector/v.colors/main.c:106
-#: ../vector/v.colors/main.c:112 ../vector/v.colors/main.c:138
-#: ../vector/v.colors/main.c:143 ../vector/v.colors/main.c:148
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:20
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:22
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:24
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:26
-msgid "Define"
-msgstr ""
-#: ../raster/r.category/main.c:87
-msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr ""
-#: ../raster/r.category/main.c:95
-msgid "Default label or format string for dynamic labeling"
-msgstr ""
-#: ../raster/r.category/main.c:97
-msgid "Used when no explicit label exists for the category"
-msgstr ""
-#: ../raster/r.category/main.c:105
-msgid "Dynamic label coefficients"
-msgstr ""
-#: ../raster/r.category/main.c:107
-msgid "Two pairs of category multiplier and offsets, for $1 and $2"
-msgstr ""
-#: ../raster/r.category/main.c:130 ../raster/r.support/main.c:147
-#, c-format
-msgid "Raster map <%s> not found in current mapset"
-msgstr ""
-#: ../raster/r.category/main.c:148 ../raster/r.category/main.c:230
-#: ../raster/r.report/parse.c:294 ../raster/r.mapcalc/map.c:235
-#: ../raster/r.mapcalc/map3.c:191
-#, c-format
-msgid "Unable to read category file of raster map <%s@%s>"
-msgstr ""
-#: ../raster/r.category/main.c:152
-#, c-format
-msgid "Category table for <%s> set from <%s>"
-msgstr ""
-#: ../raster/r.category/main.c:173 ../raster/r.recode/main.c:90
-#: ../raster/r.profile/main.c:176 ../raster/r.horizon/main.c:390
-#: ../raster/r.out.ascii/main.c:157 ../raster/r.in.lidar/main.c:646
-#: ../raster/r.out.ppm3/main.c:133 ../general/g.pnmcomp/main.c:242
-#: ../general/g.pnmcomp/main.c:259 ../display/d.mon/stop.c:66
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:350
-#: ../vector/v.out.vtk/main.c:173 ../vector/v.net/main.c:100
-#: ../vector/v.out.ascii/main.c:125 ../vector/v.edit/main.c:81
-#: ../vector/v.profile/main.c:330 ../raster3d/r3.out.vtk/main.c:420
-#: ../misc/m.nviz.script/main.c:202 ../misc/m.transform/main.c:276
-#, c-format
-msgid "Unable to open file <%s>"
-msgstr ""
-#: ../raster/r.category/main.c:211
-#, c-format
-msgid ""
-"Incorrect format of input rules. Check separators. Invalid line is:\n"
-"%s"
-msgstr ""
-#: ../raster/r.category/main.c:267
-#, c-format
-msgid "Unable to read category file of raster map <%s> in <%s>"
-msgstr ""
-#: ../raster/r.category/main.c:283
-msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-#: ../raster/r.category/main.c:300
-msgid "vals argument is required for floating point map!"
-msgstr ""
-#: ../raster/r.series/main.c:104 ../raster/r.neighbors/main.c:102
-#: ../raster/r.resamp.stats/main.c:301 ../raster3d/r3.neighbors/main.c:94
-#, c-format
-msgid "Unknown method <%s>"
-msgstr ""
-#: ../raster/r.series/main.c:138 ../raster/r.in.xyz/main.c:162
-#: ../raster/r.in.lidar/main.c:113 ../raster/r.patch/main.c:63
-#: ../raster/r.neighbors/main.c:170 ../vector/v.neighbors/main.c:54
-#: ../raster3d/r3.neighbors/main.c:212 ../raster3d/r3.in.lidar/main.c:167
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:3
-msgid "aggregation"
-msgstr ""
-#: ../raster/r.series/main.c:139 ../raster/r.patch/main.c:64
-#: ../raster/r.series.accumulate/main.c:81 ../raster/r.series.interp/main.c:65
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:4
-msgid "series"
-msgstr ""
-#: ../raster/r.series/main.c:141
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-#: ../raster/r.series/main.c:150
-msgid ""
-"Input file with one raster map name and optional one weight per line, field "
-"separator between name and weight is |"
-msgstr ""
-#: ../raster/r.series/main.c:161 ../raster3d/r3.neighbors/main.c:119
-msgid "Aggregate operation"
-msgstr ""
-#: ../raster/r.series/main.c:168 ../raster/r.neighbors/main.c:239
-#: ../raster/r.resamp.stats/main.c:282 ../raster3d/r3.neighbors/main.c:127
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:8
-msgid "Quantile to calculate for method=quantile"
-msgstr ""
-#: ../raster/r.series/main.c:176
-msgid ""
-"Weighting factor for each input map, default value is 1.0 for each input map"
-msgstr ""
-#: ../raster/r.series/main.c:183 ../raster/r.series.accumulate/main.c:132
-msgid "Ignore values outside this range"
-msgstr ""
-#: ../raster/r.series/main.c:187 ../raster/r.resamp.stats/main.c:288
-#: ../raster/r.series.accumulate/main.c:159
-#: ../raster/r.resamp.filter/main.c:431
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:11
-msgid "Propagate NULLs"
-msgstr ""
-#: ../raster/r.series/main.c:191 ../raster/r.series.accumulate/main.c:163
-msgid "Do not keep files open"
-msgstr ""
-#: ../raster/r.series/main.c:204 ../raster/r.neighbors/main.c:266
-#: ../raster/r.series.accumulate/main.c:206
-#: ../raster/r.series.interp/main.c:118 ../raster/r.series.interp/main.c:122
-#: ../raster/r.series.interp/main.c:134 ../raster/r.series.interp/main.c:138
-#: ../raster/r.external/main.c:170 ../raster/r.mapcalc/main.c:131
-#: ../vector/v.colors/main.c:206
-#, c-format
-msgid "%s= and %s= are mutually exclusive"
-msgstr ""
-#: ../raster/r.series/main.c:208 ../raster/r.series.accumulate/main.c:210
-#: ../raster/r.series.interp/main.c:126 ../raster/r.series.interp/main.c:142
-#, c-format
-msgid "Please specify %s= or %s="
-msgstr ""
-#: ../raster/r.series/main.c:223 ../raster/r.in.xyz/main.c:582
-#: ../raster/r.topmodel/file_io.c:28 ../raster/r.topmodel/file_io.c:136
-#: ../raster/r.topmodel/file_io.c:161 ../raster/r.series.accumulate/main.c:221
-#: ../raster/r.in.mat/main.c:125 ../raster/r.mapcalc/main.c:49
-#: ../raster/r.support/main.c:176 ../general/g.cairocomp/main.c:46
-#: ../display/d.where/main.c:163 ../display/d.linegraph/main.c:415
-#: ../display/d.linegraph/main.c:432 ../display/d.linegraph/main.c:730
-#: ../display/d.text/main.c:380 ../display/d.legend.vect/main.c:259
-#: ../display/d.legend.vect/main.c:273 ../display/d.legend.vect/draw.c:72
-#: ../vector/v.segment/main.c:98 ../vector/v.net.path/path.c:49
-#: ../vector/v.lrs/v.lrs.segment/main.c:133 ../raster3d/r3.support/main.c:167
-#, c-format
-msgid "Unable to open input file <%s>"
-msgstr ""
-#: ../raster/r.series/main.c:250 ../raster/r.series/main.c:312
-msgid "Weights must be positive"
-msgstr ""
-#: ../raster/r.series/main.c:268 ../raster/r.series/main.c:318
-#, c-format
-msgid "Reading raster map <%s> using weight %f..."
-msgstr ""
-#: ../raster/r.series/main.c:275 ../raster/r.series.accumulate/main.c:255
-msgid "No raster map name found in input file"
-msgstr ""
-#: ../raster/r.series/main.c:287 ../raster/r.stats/main.c:285
-#: ../raster/r.series.accumulate/main.c:265
-msgid "Raster map not found"
-msgstr ""
-#: ../raster/r.series/main.c:298
-msgid "input= and weights= must have the same number of values"
-msgstr ""
-#: ../raster/r.series/main.c:333
-msgid "output= and method= must have the same number of values"
-msgstr ""
-#: ../raster/r.series/main.c:351
-#, c-format
-msgid "Method %s not compatible with weights, using unweighed version instead"
-msgstr ""
-#: ../raster/r.series/main.c:386 ../raster/r.slope.aspect/main.c:544
-#: ../raster/r.relief/main.c:317 ../raster/r.patch/main.c:140
-#: ../raster/r.series.accumulate/main.c:318
-#: ../raster/r.series.interp/main.c:339
-msgid "Percent complete..."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:159 ../raster/r.in.bin/main.c:258
-#: ../raster/r.in.gridatb/main.c:46 ../raster/r.proj/main.c:147
-#: ../raster/r.in.gdal/main.c:93 ../raster/r.in.ascii/main.c:70
-#: ../raster/r.in.lidar/main.c:109 ../raster/r.in.poly/main.c:35
-#: ../raster/r.in.mat/main.c:92 ../raster/r.external/main.c:58
-#: ../raster/r.in.png/main.c:520 ../vector/v.in.db/main.c:53
-#: ../vector/v.in.lidar/main.c:137 ../vector/v.in.ogr/main.c:195
-#: ../vector/v.in.dwg/main.c:83 ../vector/v.in.ascii/main.c:71
-#: ../vector/v.external/main.c:53 ../vector/v.in.dxf/main.c:65
-#: ../vector/v.proj/main.c:71 ../raster3d/r3.in.ascii/main.c:355
-#: ../raster3d/r3.in.bin/main.c:253 ../raster3d/r3.in.lidar/main.c:163
-#: ../raster3d/r3.in.v5d/main.c:179
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
-#: ../locale/scriptstrings/r.import_to_translate.c:3
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
-#: ../locale/scriptstrings/r.unpack_to_translate.c:3
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:3
-#: ../locale/scriptstrings/v.import_to_translate.c:3
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-#: ../locale/scriptstrings/v.unpack_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:3
-msgid "import"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:161 ../raster/r.to.rast3/main.c:198
-#: ../raster/r.in.ascii/main.c:71 ../raster/r.in.lidar/main.c:112
-#: ../raster/r.to.vect/main.c:77 ../raster/r.to.rast3elev/main.c:362
-#: ../vector/v.to.rast/main.c:45 ../vector/v.to.rast3/main.c:49
-#: ../raster3d/r3.in.ascii/main.c:357 ../raster3d/r3.in.lidar/main.c:166
-#: ../raster3d/r3.out.ascii/main.c:305 ../raster3d/r3.to.rast/main.c:260
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:3
-msgid "conversion"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:163 ../raster/r.in.lidar/main.c:114
-#: ../raster3d/r3.in.lidar/main.c:168
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
-msgid "binning"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:165 ../raster/r.in.lidar/main.c:110
-#: ../vector/v.outlier/main.c:74 ../vector/v.out.lidar/main.c:475
-#: ../vector/v.lidar.correction/main.c:72 ../vector/v.lidar.growing/main.c:76
-#: ../vector/v.decimate/main.c:124 ../vector/v.in.lidar/main.c:138
-#: ../vector/v.lidar.edgedetection/main.c:76
-#: ../vector/v.surf.bspline/main.c:94 ../raster3d/r3.in.lidar/main.c:164
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:5
-msgid "LIDAR"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:167
-msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate"
-" statistics."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:171
-msgid "ASCII file containing input data (or \"-\" to read from stdin)"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:179 ../raster/r.in.lidar/main.c:139
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
-msgid "Statistic to use for raster values"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:183 ../raster/r.in.xyz/main.c:315
-#: ../raster/r.in.xyz/main.c:324 ../raster/r.in.lidar/main.c:143
-#: ../raster/r.in.lidar/main.c:235 ../raster/r.in.lidar/main.c:245
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:32
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:34
-msgid "Statistic"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:198 ../raster/r.in.lidar/main.c:158
-msgid "Number of points in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:199 ../raster/r.in.lidar/main.c:159
-msgid "Minimum value of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:200 ../raster/r.in.lidar/main.c:160
-msgid "Maximum value of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:201 ../raster/r.in.lidar/main.c:161
-msgid "Range of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:202 ../raster/r.in.lidar/main.c:162
-msgid "Sum of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:203 ../raster/r.in.lidar/main.c:163
-msgid "Mean (average) value of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:204 ../raster/r.in.lidar/main.c:164
-msgid "Standard deviation of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:205 ../raster/r.in.lidar/main.c:165
-msgid "Variance of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:206 ../raster/r.in.lidar/main.c:166
-msgid "Coefficient of variance of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:207 ../raster/r.in.lidar/main.c:167
-msgid "Median value of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:208
-msgid "Pth (nth) percentile of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:209 ../raster/r.in.lidar/main.c:169
-msgid "Skewness of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:210 ../raster/r.in.lidar/main.c:170
-msgid "Trimmed mean of point values in cell"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:213 ../raster/r.in.xyz/main.c:222
-#: ../raster/r.in.xyz/main.c:230 ../raster/r.in.xyz/main.c:241
-#: ../raster/r.in.xyz/main.c:251 ../raster/r.sun/main.c:272
-#: ../raster/r.sun/main.c:281 ../raster/r.sun/main.c:290
-#: ../raster/r.sun/main.c:299 ../raster/r.sun/main.c:307
-#: ../raster/r.sun/main.c:316 ../raster/r.sun/main.c:325
-#: ../raster/r.sun/main.c:334 ../raster/r.sun/main.c:343
-#: ../raster/r.sun/main.c:352 ../raster/r.sun/main.c:361
-#: ../raster/r.sun/main.c:370 ../raster/r.sun/main.c:379
-#: ../raster/r.sun/main.c:386 ../raster/r.sun/main.c:394
-#: ../raster/r.horizon/main.c:195 ../raster/r.horizon/main.c:204
-#: ../raster/r.horizon/main.c:212 ../raster/r.in.lidar/main.c:122
-#: ../raster/r.in.lidar/main.c:133 ../raster/r.sim/r.sim.water/main.c:138
-#: ../raster/r.sim/r.sim.water/main.c:147
-#: ../raster/r.sim/r.sim.water/main.c:154
-#: ../raster/r.sim/r.sim.water/main.c:163
-#: ../raster/r.sim/r.sim.water/main.c:169
-#: ../raster/r.sim/r.sim.water/main.c:177
-#: ../raster/r.sim/r.sim.water/main.c:184
-#: ../raster/r.sim/r.sim.water/main.c:191
-#: ../raster/r.sim/r.sim.sediment/main.c:158
-#: ../raster/r.sim/r.sim.sediment/main.c:166
-#: ../raster/r.sim/r.sim.sediment/main.c:173 ../raster/r.external/main.c:66
-#: ../raster/r.external/main.c:74 ../raster/r.external/main.c:83
-#: ../raster/r.spread/main.c:125 ../raster/r.spread/main.c:139
-#: ../raster/r.spread/main.c:151 ../raster/r.spread/main.c:164
-#: ../raster/r.spread/main.c:177 ../raster/r.spread/main.c:189
-#: ../raster/r.spread/main.c:201 ../display/d.text/main.c:149
-#: ../display/d.text/main.c:154 ../display/d.legend/main.c:88
-#: ../display/d.legend/main.c:93 ../vector/v.in.ogr/main.c:223
-#: ../vector/v.edit/args.c:96 ../vector/v.edit/args.c:215
-#: ../raster3d/r3.flow/main.c:188 ../raster3d/r3.flow/main.c:195
-#: ../raster3d/r3.flow/main.c:205 ../raster3d/r3.in.lidar/main.c:177
-#: ../raster3d/r3.in.lidar/main.c:184
-#: ../locale/scriptstrings/i.spectral_to_translate.c:6
-#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-#: ../locale/scriptstrings/i.spectral_to_translate.c:8
-#: ../locale/scriptstrings/r.import_to_translate.c:6
-#: ../locale/scriptstrings/r.import_to_translate.c:8
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:20
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
-#: ../locale/scriptstrings/v.import_to_translate.c:6
-#: ../locale/scriptstrings/v.import_to_translate.c:8
-#: ../locale/scriptstrings/t.remove_to_translate.c:6
-#: ../locale/scriptstrings/t.remove_to_translate.c:9
-#: ../locale/scriptstrings/t.remove_to_translate.c:11
-#: ../locale/scriptstrings/t.register_to_translate.c:6
-#: ../locale/scriptstrings/t.register_to_translate.c:7
-#: ../locale/scriptstrings/t.register_to_translate.c:9
-#: ../locale/scriptstrings/t.register_to_translate.c:12
-#: ../locale/scriptstrings/t.register_to_translate.c:26
-msgid "Input"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:221
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
-msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:229
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
-msgid "Column number of y coordinates in input file"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:237
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
-msgid "Column number of data values in input file"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:239
-msgid ""
-"If a separate value column is given, this option refers to the z-coordinate "
-"column to be filtered by the zrange option"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:250
-msgid "Number of header lines to skip at top of input file"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:258 ../vector/v.decimate/main.c:148
-#: ../vector/v.in.lidar/main.c:196
-msgid "Filter range for z data (min,max)"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:259 ../raster/r.in.xyz/main.c:267
-#: ../raster/r.in.xyz/main.c:276 ../raster/r.in.xyz/main.c:284
-#: ../raster/r.in.xyz/main.c:292
-msgid "Advanced Input"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:266
-msgid "Scale to apply to z data"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:274
-msgid "Alternate column number of data values in input file"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:275
-msgid "If not given (or set to 0) the z-column data is used"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:283
-msgid "Filter range for alternate value column data (min,max)"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:291
-msgid "Scale to apply to alternate value column data"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:305 ../raster/r.in.lidar/main.c:225
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
-msgid "Percent of map to keep in memory"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:314
-msgid "Pth percentile of the values"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:323 ../raster/r.in.lidar/main.c:244
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:33
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:328 ../raster/r.in.lidar/main.c:306
-#: ../raster3d/r3.in.lidar/main.c:303
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:10
-msgid "Scan data file for extent then exit"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:329 ../raster/r.in.xyz/main.c:336
-msgid "Scan"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:335 ../raster/r.in.lidar/main.c:311
-#: ../raster3d/r3.in.lidar/main.c:307
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
-msgid "In scan mode, print using shell script style"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:341
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:12
-msgid "Ignore broken lines"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:366
-msgid "Please specify a reasonable column number."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:378 ../vector/v.in.ascii/main.c:220
-msgid "Please specify reasonable number of lines to skip"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:383 ../raster/r.in.lidar/main.c:479
-msgid "Invalid zrange"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:397
-msgid "Invalid vrange"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:483 ../raster/r.in.lidar/point_binning.c:205
-msgid "Unable to calculate percentile without the pth option specified!"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:495 ../raster/r.in.lidar/point_binning.c:217
-msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:536
-#, c-format
-msgid ""
-"Unable to process the whole map at once. Please set the %s option to some "
-"value lower than 100."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:589
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:601
-msgid "Range filters will not be taken into account during scan"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:638
-msgid "Reading input data..."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:645 ../raster/r.in.poly/poly2rast.c:56
-#, c-format
-msgid "Pass #%d (of %d) ..."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:721 ../raster/r.in.xyz/main.c:729
-#: ../raster/r.in.xyz/main.c:1218 ../raster/r.in.xyz/main.c:1226
-#, c-format
-msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
-"[%s]"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:725 ../raster/r.in.xyz/main.c:1222
-msgid "Line ignored as requested"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:744 ../raster/r.in.xyz/main.c:1256
-#, c-format
-msgid "Bad y-coordinate line %lu column %d. <%s>"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:751 ../raster/r.in.xyz/main.c:1241
-#, c-format
-msgid "Bad x-coordinate line %lu column %d. <%s>"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:769 ../raster/r.in.xyz/main.c:1271
-#, c-format
-msgid "Bad z-coordinate line %lu column %d. <%s>"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:782 ../raster/r.in.xyz/main.c:1289
-#, c-format
-msgid "Bad data value line %lu column %d. <%s>"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:835
-#, c-format
-msgid "%lu points found in input file"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:838
-msgid "Writing to output raster map..."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:1177
-#, c-format
-msgid "%lu points found in region."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:1203 ../raster/r.in.lidar/info.c:108
-#: ../raster3d/r3.in.lidar/info.c:109
-msgid "Scanning data ..."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:1309 ../raster/r.in.lidar/info.c:148
-#: ../raster3d/r3.in.lidar/info.c:149
-#, c-format
-msgid "Range:     min         max\n"
-msgstr ""
-#: ../raster/r.compress/main.c:69 ../general/g.rename/main.c:46
-#: ../general/g.dirseps/main.c:35 ../general/g.access/main.c:38
-#: ../general/g.list/main.c:66 ../general/g.filename/main.c:40
-#: ../general/g.remove/main.c:70 ../general/g.findetc/main.c:29
-#: ../general/g.copy/main.c:42 ../general/g.findfile/main.c:39
-#: ../imagery/i.group/main.c:53 ../imagery/i.target/main.c:46
-#: ../locale/scriptstrings/t.create_to_translate.c:3
-#: ../locale/scriptstrings/t.list_to_translate.c:3
-#: ../locale/scriptstrings/t.remove_to_translate.c:3
-#: ../locale/scriptstrings/t.register_to_translate.c:3
-#: ../locale/scriptstrings/t.unregister_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:3
-#: ../locale/scriptstrings/t.rename_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:3
-msgid "map management"
-msgstr ""
-#: ../raster/r.compress/main.c:70
-msgid "compression"
-msgstr ""
-#: ../raster/r.compress/main.c:71
-msgid "Compresses and decompresses raster maps."
-msgstr ""
-#: ../raster/r.compress/main.c:74
-msgid "Name of existing raster map(s)"
-msgstr ""
-#: ../raster/r.compress/main.c:78
-msgid "Uncompress the map"
-msgstr ""
-#: ../raster/r.compress/main.c:82
-msgid "Print compression information and data type of input map(s)"
-msgstr ""
-#: ../raster/r.compress/main.c:86
-msgid "Print compression information in shell script style"
-msgstr ""
-#: ../raster/r.compress/main.c:128 ../raster/r.compress/main.c:308
-#, c-format
-msgid "Raster map <%s> is not in the current mapset"
-msgstr ""
-#: ../raster/r.compress/main.c:134
-#, c-format
-msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr ""
-#: ../raster/r.compress/main.c:136
-#, c-format
-msgid "<%s> is a reclass file of map <%s> in mapset <%s> - can't compress"
-msgstr ""
-#: ../raster/r.compress/main.c:141
-#, c-format
-msgid "<%s> is a GDAL-linked map - can't (un)compress"
-msgstr ""
-#: ../raster/r.compress/main.c:215
-msgid "DONE: uncompressed file is %lu %s (%.2f%) smaller"
-msgstr ""
-#: ../raster/r.compress/main.c:216
-msgid "DONE: compressed file is %lu %s (%.2f%) smaller"
-msgstr ""
-#: ../raster/r.compress/main.c:220
-msgid "DONE: uncompressed file is %lu %s (%.2f%) larger"
-msgstr ""
-#: ../raster/r.compress/main.c:221
-msgid "DONE: compressed file is %lu %s (%.2f%) larger"
-msgstr ""
-#: ../raster/r.compress/main.c:224
-msgid "same size"
-msgstr ""
-#: ../raster/r.compress/main.c:240
-#, c-format
-msgid "<%s> already uncompressed"
-msgstr ""
-#: ../raster/r.compress/main.c:243
-#, c-format
-msgid "Uncompressing <%s>"
-msgstr ""
-#: ../raster/r.compress/main.c:251
-#, c-format
-msgid "Re-compressing <%s>"
-msgstr ""
-#: ../raster/r.compress/main.c:254
-#, c-format
-msgid "Compressing <%s>"
-msgstr ""
-#: ../raster/r.compress/main.c:312
-#, c-format
-msgid "<%s> is a GDAL-linked map"
-msgstr ""
-#: ../raster/r.compress/main.c:316
-#, c-format
-msgid "<%s> is a reclass file of map <%s> in mapset <%s>"
-msgstr ""
-#: ../raster/r.compress/main.c:336
-#, c-format
-msgid "<%s> is uncompressed (method %i: %s). Data type: %s"
-msgstr ""
-#: ../raster/r.compress/main.c:343
-#, c-format
-msgid "<%s> is compressed (method %i: %s). Data type: %s"
-msgstr ""
-#: ../raster/r.compress/main.c:351
-#, c-format
-msgid "<%s> has a compressed NULL file"
-msgstr ""
-#: ../raster/r.compress/main.c:353
-#, c-format
-msgid "<%s> has an uncompressed NULL file"
-msgstr ""
-#: ../raster/r.region/main.c:52 ../raster/r.info/main.c:71
-#: ../raster/r.describe/main.c:55 ../raster/r.timestamp/main.c:36
-#: ../raster/r.support/main.c:55 ../temporal/t.connect/main.c:36
-#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:38
-#: ../vector/v.timestamp/main.c:36 ../raster3d/r3.support/main.c:50
-#: ../raster3d/r3.info/main.c:76 ../raster3d/r3.timestamp/main.c:44
-#: ../locale/scriptstrings/t.support_to_translate.c:3
-#: ../locale/scriptstrings/t.info_to_translate.c:3
-#: ../locale/scriptstrings/t.select_to_translate.c:3
-msgid "metadata"
-msgstr ""
-#: ../raster/r.region/main.c:54
-msgid "Sets the boundary definitions for a raster map."
-msgstr ""
-#: ../raster/r.region/main.c:60
-msgid "Set from current region"
-msgstr ""
-#: ../raster/r.region/main.c:61 ../raster/r.region/main.c:66
-#: ../raster/r.region/main.c:72 ../raster/r.region/main.c:87
-#: ../raster/r.region/main.c:94 ../raster/r.region/main.c:101
-#: ../raster/r.region/main.c:144 ../general/g.region/main.c:78
-#: ../general/g.region/main.c:84 ../general/g.region/main.c:171
-#: ../general/g.region/main.c:178 ../general/g.region/main.c:187
-#: ../general/g.region/main.c:195
-msgid "Existing"
-msgstr ""
-#: ../raster/r.region/main.c:65 ../general/g.region/main.c:77
-msgid "Set from default region"
-msgstr ""
-#: ../raster/r.region/main.c:70 ../raster/r.in.gdal/main.c:218
-#: ../raster/r.external/main.c:119
-msgid "Auto-adjustment for lat/lon"
-msgstr ""
-#: ../raster/r.region/main.c:71 ../raster/r.in.gdal/main.c:219
-#: ../raster/r.external/main.c:120
-msgid "Attempt to fix small precision errors in resolution and extents"
-msgstr ""
-#: ../raster/r.region/main.c:77
-msgid "Name of raster map to change"
-msgstr ""
-#: ../raster/r.region/main.c:85
-msgid "Set region from named region"
-msgstr ""
-#: ../raster/r.region/main.c:93
-msgid "Set region to match this raster map"
-msgstr ""
-#: ../raster/r.region/main.c:100
-msgid "Set region to match this vector map"
-msgstr ""
-#: ../raster/r.region/main.c:109 ../general/g.region/main.c:203
-msgid "Value for the northern edge"
-msgstr ""
-#: ../raster/r.region/main.c:110 ../raster/r.region/main.c:119
-#: ../raster/r.region/main.c:128 ../raster/r.region/main.c:137
-#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:339
-#: ../raster/r.in.bin/main.c:347 ../raster/r.in.bin/main.c:355
-#: ../raster/r.in.bin/main.c:363 ../raster/r.in.bin/main.c:370
-#: ../raster/r.in.bin/main.c:377 ../general/g.region/main.c:160
-#: ../general/g.region/main.c:204 ../general/g.region/main.c:213
-#: ../general/g.region/main.c:222 ../general/g.region/main.c:231
-#: ../general/g.region/main.c:240 ../general/g.region/main.c:249
-#: ../general/g.region/main.c:325 ../general/g.region/main.c:336
-#: ../raster3d/r3.in.bin/main.c:284 ../raster3d/r3.in.bin/main.c:292
-#: ../raster3d/r3.in.bin/main.c:300 ../raster3d/r3.in.bin/main.c:308
-#: ../raster3d/r3.in.bin/main.c:316 ../raster3d/r3.in.bin/main.c:323
-#: ../raster3d/r3.in.bin/main.c:330 ../raster3d/r3.in.bin/main.c:337
-#: ../raster3d/r3.in.bin/main.c:344
-msgid "Bounds"
-msgstr ""
-#: ../raster/r.region/main.c:118 ../general/g.region/main.c:212
-msgid "Value for the southern edge"
-msgstr ""
-#: ../raster/r.region/main.c:127 ../general/g.region/main.c:221
-msgid "Value for the eastern edge"
-msgstr ""
-#: ../raster/r.region/main.c:136 ../general/g.region/main.c:230
-msgid "Value for the western edge"
-msgstr ""
-#: ../raster/r.region/main.c:143
-msgid "Raster map to align to"
-msgstr ""
-#: ../raster/r.statistics/main.c:57 ../raster/r.stats.zonal/main.c:103
-#: ../raster/r.univar/r.univar_main.c:107 ../vector/v.vect.stats/main.c:137
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-msgid "zonal statistics"
-msgstr ""
-#: ../raster/r.statistics/main.c:59
-msgid "Calculates category or object oriented statistics."
-msgstr ""
-#: ../raster/r.statistics/main.c:69 ../raster/r.stats.zonal/main.c:115
-msgid "Method of object-based statistic"
-msgstr ""
-#: ../raster/r.statistics/main.c:92 ../raster/r.stats.zonal/main.c:138
-msgid "Resultant raster map"
-msgstr ""
-#: ../raster/r.statistics/main.c:98 ../raster/r.stats.zonal/main.c:144
-msgid "Cover values extracted from the category labels of the cover map"
-msgstr ""
-#: ../raster/r.statistics/main.c:110 ../raster/r.support/main.c:245
-#: ../display/d.title/main.c:110 ../raster3d/r3.support/main.c:248
-#, c-format
-msgid "Unable to read category file of raster map <%s>"
-msgstr ""
-#: ../raster/r.statistics/main.c:118 ../raster/r.proj/main.c:237
-#: ../raster/r.stats.zonal/main.c:165
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:151
-#: ../imagery/i.rectify/main.c:156 ../vector/v.vect.stats/main.c:312
-#, c-format
-msgid "<%s=%s> unknown %s"
-msgstr ""
-#: ../raster/r.statistics/o_adev.c:93
-msgid "o_adev: No data in array"
-msgstr ""
-#: ../raster/r.statistics/o_kurt.c:91
-msgid "o_kurto: No data in array"
-msgstr ""
-#: ../raster/r.statistics/o_sdev.c:94 ../raster/r.statistics/o_var.c:95
-msgid "o_var: No data in array"
-msgstr ""
-#: ../raster/r.statistics/o_skew.c:91
-msgid "o_skew: No data in array"
-msgstr ""
-#: ../raster/r.statistics/read_stats.c:20
-msgid "Reading r.stats output"
-msgstr ""
-#: ../raster/r.external.out/main.c:38
-#, c-format
-msgid "Supported Formats:\n"
-msgstr ""
-#: ../raster/r.external.out/main.c:132
-msgid "Unable to open GDAL file"
-msgstr ""
-#: ../raster/r.external.out/main.c:156 ../vector/v.external.out/format.c:49
-#, c-format
-msgid "Format <%s> not supported"
-msgstr ""
-#: ../raster/r.external.out/main.c:162
-#, c-format
-msgid "Format <%s> does not support direct write"
-msgstr ""
-#: ../raster/r.external.out/main.c:166 ../vector/v.external.out/format.c:52
-#, c-format
-msgid "Format <%s> does not support writing"
-msgstr ""
-#: ../raster/r.external.out/main.c:214
-msgid "Unable to create GDAL file"
-msgstr ""
-#: ../raster/r.external.out/main.c:217
-msgid "Error writing GDAL file"
-msgstr ""
-#: ../raster/r.external.out/main.c:237 ../vector/v.external.out/main.c:45
-msgid "output"
-msgstr ""
-#: ../raster/r.external.out/main.c:238 ../raster/r.external/main.c:59
-#: ../vector/v.external.out/main.c:46 ../vector/v.external/main.c:54
-msgid "external"
-msgstr ""
-#: ../raster/r.external.out/main.c:240
-msgid ""
-"Redirects raster output to file utilizing GDAL library rather than storing "
-"in GRASS raster format."
-msgstr ""
-#: ../raster/r.external.out/main.c:244
-msgid "Name of output directory"
-msgstr ""
-#: ../raster/r.external.out/main.c:251
-msgid "Extension for output files"
-msgstr ""
-#: ../raster/r.external.out/main.c:257
-msgid "Format of output files"
-msgstr ""
-#: ../raster/r.external.out/main.c:264 ../vector/v.out.postgis/args.c:52
-#: ../vector/v.external.out/args.c:39
-msgid "Creation options"
-msgstr ""
-#: ../raster/r.external.out/main.c:271 ../raster/r.in.gdal/main.c:207
-#: ../raster/r.external/main.c:95 ../vector/v.external.out/args.c:62
-#: ../vector/v.external/args.c:56
-msgid "List supported formats and exit"
-msgstr ""
-#: ../raster/r.external.out/main.c:277
-msgid "Cease using GDAL and revert to native output"
-msgstr ""
-#: ../raster/r.external.out/main.c:282 ../vector/v.external.out/args.c:74
-msgid "Print current status"
-msgstr ""
-#: ../raster/r.cross/cross.c:65
-#, c-format
-msgid "%s: STEP 1 ... "
-msgstr ""
-#: ../raster/r.cross/main.c:72
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-#: ../raster/r.cross/main.c:81
-#, c-format
-msgid "Names of 2-%d input raster maps"
-msgstr ""
-#: ../raster/r.cross/main.c:90
-msgid "Non-zero data only"
-msgstr ""
-#: ../raster/r.cross/main.c:103
-#, c-format
-msgid "More than %d files not allowed"
-msgstr ""
-#: ../raster/r.cross/main.c:119
-msgid "Must specify 2 or more input maps"
-msgstr ""
-#: ../raster/r.cross/main.c:136
-#, c-format
-msgid "%s: STEP 2 ..."
-msgstr ""
-#: ../raster/r.cross/main.c:168 ../raster/r.basins.fill/main.c:146
-#: ../raster/r.resample/main.c:125 ../raster/r.in.png/main.c:485
-#, c-format
-msgid "Creating support files for <%s>..."
-msgstr ""
-#: ../raster/r.cross/main.c:178
-#, c-format
-msgid "%d categories"
-msgstr ""
-#: ../raster/r.cross/renumber.c:33
-#, c-format
-msgid "%s: STEP 3 ... "
-msgstr ""
-#: ../raster/r.in.bin/main.c:61 ../raster/r.in.bin/main.c:70
-#: ../raster/r.in.bin/main.c:614
-msgid "Error reading data"
-msgstr ""
-#: ../raster/r.in.bin/main.c:260
-msgid "Import a binary raster file into a GRASS raster map layer."
-msgstr ""
-#: ../raster/r.in.bin/main.c:265
-msgid "Import as floating-point data (default: integer)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:270
-msgid "Import as double-precision floating-point data (default: integer)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:274 ../raster3d/r3.in.bin/main.c:369
-msgid "Signed data (two's complement)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:275 ../raster/r.in.bin/main.c:280
-#: ../raster/r.in.bin/main.c:306 ../raster/r.in.bin/main.c:314
-#: ../raster/r.in.bin/main.c:323 ../raster/r.in.bin/main.c:384
-#: ../raster/r.in.bin/main.c:398 ../raster/r.slope.aspect/main.c:181
-#: ../raster/r.slope.aspect/main.c:189 ../raster/r.slope.aspect/main.c:247
-#: ../raster/r.slope.aspect/main.c:256 ../raster/r.slope.aspect/main.c:262
-#: ../raster/r.resamp.rst/main.c:210 ../raster/r.resamp.rst/main.c:216
-#: ../raster/r.resamp.rst/main.c:224 ../raster/r.resamp.rst/main.c:232
-#: ../raster/r.resamp.rst/main.c:240 ../raster/r.walk/main.c:274
-#: ../raster/r.walk/main.c:284 ../raster/r.walk/main.c:294
-#: ../raster/r.resamp.bspline/main.c:109 ../raster/r.resamp.bspline/main.c:117
-#: ../raster/r.resamp.bspline/main.c:123 ../raster/r.resamp.bspline/main.c:135
-#: ../raster/r.resamp.bspline/main.c:140 ../raster/r.out.mpeg/main.c:132
-#: ../db/db.login/main.c:60 ../db/db.login/main.c:68 ../db/db.login/main.c:77
-#: ../db/db.login/main.c:86 ../general/g.access/main.c:50
-#: ../general/g.access/main.c:58 ../display/d.mon/main.c:82
-#: ../display/d.mon/main.c:90 ../display/d.mon/main.c:98
-#: ../display/d.mon/main.c:104 ../display/d.mon/main.c:110
-#: ../display/d.mon/main.c:145 ../display/d.mon/main.c:151
-#: ../display/d.mon/main.c:157 ../imagery/i.cluster/main.c:103
-#: ../imagery/i.cluster/main.c:120 ../imagery/i.cluster/main.c:128
-#: ../imagery/i.cluster/main.c:137 ../imagery/i.cluster/main.c:145
-#: ../imagery/i.cluster/main.c:153 ../imagery/i.landsat.toar/main.c:159
-#: ../imagery/i.landsat.toar/main.c:168 ../imagery/i.landsat.toar/main.c:178
-#: ../imagery/i.landsat.toar/main.c:187 ../imagery/i.landsat.toar/main.c:208
-#: ../imagery/i.segment/parse_args.c:68 ../imagery/i.segment/parse_args.c:77
-#: ../imagery/i.segment/parse_args.c:88 ../imagery/i.segment/parse_args.c:99
-#: ../imagery/i.segment/parse_args.c:109 ../imagery/i.segment/parse_args.c:127
-#: ../imagery/i.segment/parse_args.c:135 ../imagery/i.segment/parse_args.c:144
-#: ../imagery/i.segment/parse_args.c:151 ../imagery/i.segment/parse_args.c:157
-#: ../imagery/i.segment/parse_args.c:163 ../imagery/i.segment/parse_args.c:169
-#: ../imagery/i.segment/parse_args.c:176 ../vector/v.outlier/main.c:104
-#: ../vector/v.outlier/main.c:113 ../vector/v.outlier/main.c:121
-#: ../vector/v.vol.rst/main.c:270 ../vector/v.vol.rst/main.c:278
-#: ../vector/v.vol.rst/main.c:285 ../vector/v.vol.rst/main.c:313
-#: ../vector/v.vol.rst/main.c:322 ../vector/v.vol.rst/main.c:331
-#: ../vector/v.vol.rst/main.c:339 ../vector/v.vol.rst/main.c:348
-#: ../vector/v.vol.rst/main.c:356 ../vector/v.lidar.correction/main.c:102
-#: ../vector/v.lidar.correction/main.c:111 ../vector/v.db.connect/main.c:66
-#: ../vector/v.db.connect/main.c:72 ../vector/v.external.out/args.c:20
-#: ../vector/v.external.out/args.c:35 ../vector/v.external.out/args.c:47
-#: ../vector/v.external.out/args.c:53
-#: ../vector/v.lidar.edgedetection/main.c:99
-#: ../vector/v.lidar.edgedetection/main.c:108
-#: ../vector/v.lidar.edgedetection/main.c:117
-#: ../vector/v.lidar.edgedetection/main.c:126
-#: ../vector/v.lidar.edgedetection/main.c:135
-#: ../vector/v.lidar.edgedetection/main.c:143
-#: ../vector/v.lidar.edgedetection/main.c:152 ../vector/v.colors.out/main.c:68
-#: ../vector/v.colors.out/main.c:73 ../vector/v.surf.bspline/main.c:113
-#: ../vector/v.surf.bspline/main.c:120 ../vector/v.surf.bspline/main.c:150
-#: ../vector/v.surf.bspline/main.c:159 ../vector/v.surf.bspline/main.c:167
-#: ../vector/v.surf.bspline/main.c:179 ../vector/v.surf.idw/main.c:115
-#: ../vector/v.surf.idw/main.c:124 ../vector/v.surf.idw/main.c:132
-msgid "Settings"
-msgstr ""
-#: ../raster/r.in.bin/main.c:279
-msgid "Byte swap the data during import"
-msgstr ""
-#: ../raster/r.in.bin/main.c:284
-msgid "Get region info from GMT style header"
-msgstr ""
-#: ../raster/r.in.bin/main.c:288
-msgid "Name of binary raster file to be imported"
-msgstr ""
-#: ../raster/r.in.bin/main.c:291
-msgid "Output name or prefix if several bands are imported"
-msgstr ""
-#: ../raster/r.in.bin/main.c:298 ../raster/r.in.gdal/main.c:140
-#: ../raster/r.in.ascii/main.c:92 ../raster/r.in.poly/main.c:50
-#: ../raster/r.external/main.c:90 ../raster/r.support/main.c:66
-#: ../locale/scriptstrings/r.import_to_translate.c:24
-msgid "Title for resultant raster map"
-msgstr ""
-#: ../raster/r.in.bin/main.c:305 ../raster/r.out.bin/main.c:311
-msgid "Number of bytes per cell"
-msgstr ""
-#: ../raster/r.in.bin/main.c:313
-msgid "Header size in bytes"
-msgstr ""
-#: ../raster/r.in.bin/main.c:321
-msgid "Number of bands in input file"
-msgstr ""
-#: ../raster/r.in.bin/main.c:322
-msgid "Bands must be in band-sequential order"
-msgstr ""
-#: ../raster/r.in.bin/main.c:330 ../raster/r.out.bin/main.c:318
-#: ../raster3d/r3.out.bin/main.c:235
-msgid "Output byte order"
-msgstr ""
-#: ../raster/r.in.bin/main.c:338 ../raster3d/r3.in.bin/main.c:283
-msgid "Northern limit of geographic region (outer edge)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:346 ../raster3d/r3.in.bin/main.c:291
-msgid "Southern limit of geographic region (outer edge)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:354 ../raster3d/r3.in.bin/main.c:299
-msgid "Eastern limit of geographic region (outer edge)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:362 ../raster3d/r3.in.bin/main.c:307
-msgid "Western limit of geographic region (outer edge)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:369 ../raster3d/r3.in.bin/main.c:329
-msgid "Number of rows"
-msgstr ""
-#: ../raster/r.in.bin/main.c:376 ../raster3d/r3.in.bin/main.c:336
-msgid "Number of columns"
-msgstr ""
-#: ../raster/r.in.bin/main.c:383 ../raster3d/r3.in.bin/main.c:350
-msgid "Set Value to NULL"
-msgstr ""
-#: ../raster/r.in.bin/main.c:392
-msgid "Flip input horizontal and/or vertical"
-msgstr ""
-#: ../raster/r.in.bin/main.c:395
-msgid "Flip input horizontal (East - West)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:396
-msgid "Flip input vertical (North - South)"
-msgstr ""
-#: ../raster/r.in.bin/main.c:410
-#, c-format
-msgid "Option %s must be > 0"
-msgstr ""
-#: ../raster/r.in.bin/main.c:413
-#, c-format
-msgid "Option %s must be >= 0"
-msgstr ""
-#: ../raster/r.in.bin/main.c:426 ../raster/r.in.bin/main.c:432
-#: ../raster/r.neighbors/main.c:262 ../raster/r.stats.quantile/main.c:590
-#: ../raster/r.out.bin/main.c:369
-#, c-format
-msgid "-%c and %s= are mutually exclusive"
-msgstr ""
-#: ../raster/r.in.bin/main.c:435 ../raster/r.in.bin/main.c:438
-#, c-format
-msgid "Option %s= is ignored if -%c is set"
-msgstr ""
-#: ../raster/r.in.bin/main.c:462 ../raster/r.out.bin/main.c:379
-#: ../vector/v.colors/main.c:225
-#, c-format
-msgid "-%c and -%c are mutually exclusive"
-msgstr ""
-#: ../raster/r.in.bin/main.c:467
-#, c-format
-msgid "-%c incompatible with %s=%d; must be 4 or 8"
-msgstr ""
-#: ../raster/r.in.bin/main.c:476
-#, c-format
-msgid "-%c incompatible with %s=%d; must be 8"
-msgstr ""
-#: ../raster/r.in.bin/main.c:484
-#, c-format
-msgid "%s= required for integer data"
-msgstr ""
-#: ../raster/r.in.bin/main.c:488
-#, c-format
-msgid "Integer input doesn't support %s=8 in this build"
-msgstr ""
-#: ../raster/r.in.bin/main.c:493
-#, c-format
-msgid "%s= must be 1, 2, 4 or 8"
-msgstr ""
-#: ../raster/r.in.bin/main.c:506
-#, c-format
-msgid "Either -%c or %s= and %s= must be given"
-msgstr ""
-#: ../raster/r.in.bin/main.c:512
-#, c-format
-msgid "Either all or none of %s=, %s=, %s= and %s= must be given"
-msgstr ""
-#: ../raster/r.in.bin/main.c:521 ../display/d.grid/main.c:266
-#: ../raster3d/r3.in.bin/main.c:424
-#, c-format
-msgid "Illegal north coordinate <%s>"
-msgstr ""
-#: ../raster/r.in.bin/main.c:523 ../raster3d/r3.in.bin/main.c:426
-#, c-format
-msgid "Illegal south coordinate <%s>"
-msgstr ""
-#: ../raster/r.in.bin/main.c:525 ../display/d.grid/main.c:259
-#: ../raster3d/r3.in.bin/main.c:428
-#, c-format
-msgid "Illegal east coordinate <%s>"
-msgstr ""
-#: ../raster/r.in.bin/main.c:527 ../raster3d/r3.in.bin/main.c:430
-#, c-format
-msgid "Illegal west coordinate <%s>"
-msgstr ""
-#: ../raster/r.in.bin/main.c:533 ../raster3d/r3.in.bin/main.c:438
-#, c-format
-msgid "Unable to open <%s>"
-msgstr ""
-#: ../raster/r.in.bin/main.c:554
-#, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign %s= and %s= correctly?"
-msgstr ""
-#: ../raster/r.in.bin/main.c:575
-msgid "File Size %"
-msgstr ""
-#: ../raster/r.in.bin/main.c:577 ../raster3d/r3.in.bin/main.c:448
-msgid "Bytes do not match file size"
-msgstr ""
-#: ../raster/r.in.bin/main.c:595
-#, c-format
-msgid "Importing band %d..."
-msgstr ""
-#: ../raster/r.circle/main.c:52 ../raster/r.buffer/main.c:67
-#: ../vector/v.parallel/main.c:51 ../vector/v.buffer/main.c:222
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:4
-msgid "buffer"
-msgstr ""
-#: ../raster/r.circle/main.c:53 ../raster/r.thin/main.c:58
-#: ../raster/r.patch/main.c:59 ../raster/r.to.vect/main.c:78
-#: ../vector/v.build/main.c:38 ../vector/v.patch/main.c:70
-#: ../vector/v.to.3d/main.c:37 ../vector/v.delaunay/main.c:86
-#: ../vector/v.mkgrid/main.c:71 ../vector/v.segment/main.c:61
-#: ../vector/v.in.region/main.c:42 ../vector/v.transform/main.c:72
-#: ../vector/v.clean/main.c:53 ../vector/v.univar/main.c:96
-#: ../vector/v.split/main.c:55 ../vector/v.parallel/main.c:50
-#: ../vector/v.select/main.c:49 ../vector/v.overlay/main.c:64
-#: ../vector/v.perturb/main.c:63 ../vector/v.generalize/main.c:83
-#: ../vector/v.hull/main.c:53 ../vector/v.to.points/main.c:54
-#: ../vector/v.in.ogr/main.c:198 ../vector/v.voronoi/main.c:124
-#: ../vector/v.drape/main.c:57 ../vector/v.type/main.c:39
-#: ../vector/v.build.polylines/main.c:112 ../vector/v.extrude/main.c:68
-#: ../vector/v.edit/main.c:55 ../vector/v.buffer/main.c:225
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
-#: ../locale/scriptstrings/v.report_to_translate.c:3
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:3
-msgid "geometry"
-msgstr ""
-#: ../raster/r.circle/main.c:54 ../vector/v.buffer/main.c:224
-msgid "circle"
-msgstr ""
-#: ../raster/r.circle/main.c:56
-msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-#: ../raster/r.circle/main.c:63
-msgid "The coordinate of the center (east,north)"
-msgstr ""
-#: ../raster/r.circle/main.c:69
-msgid "Minimum radius for ring/circle map (in meters)"
-msgstr ""
-#: ../raster/r.circle/main.c:75
-msgid "Maximum radius for ring/circle map (in meters)"
-msgstr ""
-#: ../raster/r.circle/main.c:81
-msgid "Data value multiplier"
-msgstr ""
-#: ../raster/r.circle/main.c:85
-msgid "Generate binary raster map"
-msgstr ""
-#: ../raster/r.circle/main.c:108
-msgid "Please specify a radius in which min < max"
-msgstr ""
-#: ../raster/r.circle/main.c:116
-msgid "Please specify min and/or max radius when using the binary flag"
-msgstr ""
-#: ../raster/r.circle/main.c:153 ../raster/r.surf.fractal/main.c:85
-#: ../raster/r.surf.random/main.c:66 ../raster/r.composite/main.c:262
-#: ../raster/r.li/r.li.daemon/daemon.c:174
-#, c-format
-msgid "Raster map <%s> created."
-msgstr ""
-#: ../raster/r.his/main.c:68 ../display/d.his/main.c:64
-#: ../imagery/i.rgb.his/main.c:47 ../imagery/i.his.rgb/main.c:47
-msgid "color transformation"
-msgstr ""
-#: ../raster/r.his/main.c:73
-msgid ""
-"Generates red, green and blue (RGB) raster map layers combining hue, "
-"intensity and saturation (HIS) values from user-specified input raster map "
-"layers."
-msgstr ""
-#: ../raster/r.his/main.c:82 ../display/d.his/main.c:78
-msgid "Name of layer to be used for hue"
-msgstr ""
-#: ../raster/r.his/main.c:89 ../display/d.his/main.c:85
-msgid "Name of layer to be used for intensity"
-msgstr ""
-#: ../raster/r.his/main.c:96 ../display/d.his/main.c:92
-msgid "Name of layer to be used for saturation"
-msgstr ""
-#: ../raster/r.his/main.c:103
-msgid "Name of output layer to be used for red"
-msgstr ""
-#: ../raster/r.his/main.c:110
-msgid "Name of output layer to be used for green"
-msgstr ""
-#: ../raster/r.his/main.c:117
-msgid "Name of output layer to be used for blue"
-msgstr ""
-#: ../raster/r.his/main.c:121
-#: ../locale/scriptstrings/r.shade_to_translate.c:12
-msgid "Color to use instead of NULL values"
-msgstr ""
-#: ../raster/r.his/main.c:126
-#: ../locale/scriptstrings/r.shade_to_translate.c:14
-msgid "Use colors from color tables for NULL values"
-msgstr ""
-#: ../raster/r.his/main.c:145
-#, c-format
-msgid "No such color <%s>"
-msgstr ""
-#: ../raster/r.his/main.c:167 ../raster/r.his/main.c:183
-#: ../raster/r.his/main.c:201 ../raster/r.out.ppm3/main.c:115
-#: ../display/d.his/main.c:139 ../display/d.his/main.c:156
-#: ../display/d.his/main.c:174 ../display/d.rast/display.c:23
-#: ../display/d.histogram/main.c:171 ../display/d.rgb/main.c:99
-#: ../display/d.colortable/main.c:135 ../display/d.rast.num/main.c:253
-#: ../display/d.legend/main.c:409 ../display/d.legend/main.c:417
-#, c-format
-msgid "Color file for <%s> not available"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:20
-#, c-format
-msgid "Unable to read f_range for map %s"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:146
-msgid "Data range is empty"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:30
-#, c-format
-msgid "Data range of %s is %s to %s (entire map)"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:35 ../raster/r.stats/main.c:358
-#, c-format
-msgid "Unable to read range for map <%s>"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:39
-#, c-format
-msgid "Integer data range of %s is empty"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:41
-#, c-format
-msgid "Integer data range of %s is %d to %d"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:61
-msgid "Enter the rule or 'help' for the format description"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:85
-msgid "Enter a rule in one of these formats:"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:87
-msgid "old_low:old_high:new_low:new_high"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:88
-msgid "old_low:old_high:new_val      (i.e. new_high == new_low)"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:89
-msgid "*:old_val:new_val             (interval [inf, old_val])"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:90
-msgid "old_val:*:new_val             (interval [old_val, inf])"
-msgstr ""
-#: ../raster/r.recode/read_rules.c:92
-msgid "When finished type \"end\"."
-msgstr ""
-#: ../raster/r.recode/read_rules.c:126 ../raster/r.quant/read_rules.c:158
-#, c-format
-msgid "%s is not a valid rule"
-msgstr ""
-#: ../raster/r.recode/main.c:49
-msgid "recode categories"
-msgstr ""
-#: ../raster/r.recode/main.c:50 ../raster/r.reclass/main.c:51
-#: ../vector/v.reclass/main.c:68
-msgid "reclassification"
-msgstr ""
-#: ../raster/r.recode/main.c:51
-msgid "Recodes categorical raster maps."
-msgstr ""
-#: ../raster/r.recode/main.c:54
-msgid "Name of raster map to be recoded"
-msgstr ""
-#: ../raster/r.recode/main.c:60
-msgid "File containing recode rules"
-msgstr ""
-#: ../raster/r.recode/main.c:61 ../raster/r.in.ascii/main.c:79
-#: ../raster/r.reclass/main.c:66 ../db/db.execute/main.c:151
-#: ../db/db.select/main.c:208 ../general/g.proj/main.c:141
-#: ../general/g.proj/main.c:150 ../vector/v.segment/main.c:80
-#: ../vector/v.what/main.c:78 ../vector/v.edit/args.c:95
-#: ../raster3d/r3.in.ascii/main.c:87
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-msgid "'-' for standard input"
-msgstr ""
-#: ../raster/r.recode/main.c:67 ../raster/r.neighbors/main.c:221
-#: ../raster/r.clump/main.c:75 ../raster/r.reclass/main.c:72
-msgid "Title for output raster map"
-msgstr ""
-#: ../raster/r.recode/main.c:71
-msgid "Align the current region to the input raster map"
-msgstr ""
-#: ../raster/r.recode/main.c:75
-msgid "Force output to 'double' raster map type (DCELL)"
-msgstr ""
-#: ../raster/r.recode/main.c:96
-#, c-format
-msgid "No rules specified. Raster map <%s> not created."
-msgstr ""
-#: ../raster/r.recode/main.c:99 ../raster/r.quant/main.c:183
-#: ../raster/r.reclass/main.c:142
-msgid "No rules specified"
-msgstr ""
-#: ../raster/r.stats/main.c:109
-msgid "Generates area statistics for raster map."
-msgstr ""
-#: ../raster/r.stats/main.c:114 ../raster/r.report/parse.c:38
-msgid "Name of raster map(s) to report on"
-msgstr ""
-#: ../raster/r.stats/main.c:123 ../raster/r.stats/main.c:127
-#: ../raster/r.stats/main.c:151 ../raster/r.kappa/main.c:104
-#: ../raster/r.kappa/main.c:109 ../raster/r.report/parse.c:69
-#: ../raster/r.report/parse.c:77 ../raster/r.report/parse.c:85
-#: ../raster/r.report/parse.c:109 ../raster/r.report/parse.c:114
-#: ../raster/r.report/parse.c:119 ../raster/r.report/parse.c:124
-#: ../raster/r.stats.quantile/main.c:559 ../raster/r.univar/r.univar_main.c:56
-#: ../raster/r.univar/r.univar_main.c:62 ../raster/r.univar/r.univar_main.c:72
-#: ../locale/scriptstrings/t.list_to_translate.c:11
-#: ../locale/scriptstrings/t.list_to_translate.c:17
-#: ../locale/scriptstrings/t.list_to_translate.c:19
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:12
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:15
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:17
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:14
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:16
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:14
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:16
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:12
-msgid "Formatting"
-msgstr ""
-#: ../raster/r.stats/main.c:136 ../raster/r.report/parse.c:94
-msgid "Number of floating-point subranges to collect stats from"
-msgstr ""
-#: ../raster/r.stats/main.c:137 ../raster/r.stats/main.c:192
-#: ../raster/r.stats/main.c:197 ../raster/r.stats/main.c:212
-#: ../raster/r.stats/main.c:217 ../raster/r.report/parse.c:95
-#: ../raster/r.report/parse.c:139 ../raster/r.report/parse.c:145
-msgid "Floating point"
-msgstr ""
-#: ../raster/r.stats/main.c:144 ../raster/r.report/parse.c:102
-msgid "Sort output statistics by cell counts"
-msgstr ""
-#: ../raster/r.stats/main.c:145 ../raster/r.report/parse.c:103
-msgid "Default: sorted by categories or intervals"
-msgstr ""
-#: ../raster/r.stats/main.c:149 ../raster/r.report/parse.c:107
-msgid "Sort by cell counts in ascending order"
-msgstr ""
-#: ../raster/r.stats/main.c:150 ../raster/r.report/parse.c:108
-msgid "Sort by cell counts in descending order"
-msgstr ""
-#: ../raster/r.stats/main.c:157
-msgid "Print area totals in square meters"
-msgstr ""
-#: ../raster/r.stats/main.c:158 ../raster/r.stats/main.c:163
-#: ../raster/r.stats/main.c:169 ../raster/r.report/parse.c:58
-msgid "Statistics"
-msgstr ""
-#: ../raster/r.stats/main.c:162
-msgid "Print cell counts (sortable)"
-msgstr ""
-#: ../raster/r.stats/main.c:168
-msgid "Print approximate (total percent may not be 100%) percents"
-msgstr ""
-#: ../raster/r.stats/main.c:173
-msgid "Print category labels"
-msgstr ""
-#: ../raster/r.stats/main.c:177
-msgid "One cell (range) per line"
-msgstr ""
-#: ../raster/r.stats/main.c:181
-msgid "Print grid coordinates (east and north)"
-msgstr ""
-#: ../raster/r.stats/main.c:182 ../raster/r.stats/main.c:187
-msgid "Coordinates"
-msgstr ""
-#: ../raster/r.stats/main.c:186
-msgid "Print x and y (column and row)"
-msgstr ""
-#: ../raster/r.stats/main.c:191
-msgid "Print averaged values instead of intervals (floating-point maps only)"
-msgstr ""
-#: ../raster/r.stats/main.c:196
-msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
-msgstr ""
-#: ../raster/r.stats/main.c:201 ../raster/r.report/parse.c:128
-msgid "Do not report no data value"
-msgstr ""
-#: ../raster/r.stats/main.c:202 ../raster/r.stats/main.c:207
-#: ../raster/r.report/parse.c:129 ../raster/r.report/parse.c:134
-msgid "No data"
-msgstr ""
-#: ../raster/r.stats/main.c:206 ../raster/r.report/parse.c:133
-msgid "Do not report cells where all maps have no data"
-msgstr ""
-#: ../raster/r.stats/main.c:211 ../raster/r.report/parse.c:138
-msgid "Report for cats floating-point ranges (floating-point maps only)"
-msgstr ""
-#: ../raster/r.stats/main.c:216 ../raster/r.report/parse.c:144
-msgid "Read floating-point map as integer (use map's quant rules)"
-msgstr ""
-#: ../raster/r.stats/main.c:233
-#, c-format
-msgid "'%s' must be greater than zero; using %s=255"
-msgstr ""
-#: ../raster/r.stats/main.c:303
-#, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
-#: ../raster/r.stats/main.c:319
-#, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
-msgstr ""
-#: ../raster/r.stats/main.c:325
-#, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s'"
-" option"
-msgstr ""
-#: ../raster/r.stats/main.c:331 ../raster/r.contour/main.c:149
-#, c-format
-msgid "Unable to read fp range of raster map <%s>"
-msgstr ""
-#: ../raster/r.stats/raw_stats.c:118
-msgid "Invalid map type"
-msgstr ""
-#: ../raster/r.quantile/main.c:69
-msgid "Computing histogram"
-msgstr ""
-#: ../raster/r.quantile/main.c:103 ../raster/r.stats.quantile/main.c:174
-msgid "Computing bins"
-msgstr ""
-#: ../raster/r.quantile/main.c:144 ../raster/r.stats.quantile/main.c:231
-msgid "Binning data"
-msgstr ""
-#: ../raster/r.quantile/main.c:189 ../raster/r.stats.quantile/main.c:287
-msgid "Sorting bins"
-msgstr ""
-#: ../raster/r.quantile/main.c:204 ../raster/r.stats.quantile/main.c:360
-msgid "Computing quantiles"
-msgstr ""
-#: ../raster/r.quantile/main.c:268 ../raster/r.stats.quantile/main.c:518
-msgid "percentile"
-msgstr ""
-#: ../raster/r.quantile/main.c:269 ../raster/r.stats.quantile/main.c:519
-msgid "quantile"
-msgstr ""
-#: ../raster/r.quantile/main.c:270
-msgid "Compute quantiles using two passes."
-msgstr ""
-#: ../raster/r.quantile/main.c:278 ../raster/r.stats.quantile/main.c:530
-msgid "Number of quantiles"
-msgstr ""
-#: ../raster/r.quantile/main.c:286 ../raster/r.stats.quantile/main.c:536
-msgid "List of percentiles"
-msgstr ""
-#: ../raster/r.quantile/main.c:292 ../raster/r.stats.quantile/main.c:543
-msgid "Number of bins to use"
-msgstr ""
-#: ../raster/r.quantile/main.c:303
-msgid "Generate recode rules based on quantile-defined intervals"
-msgstr ""
-#: ../raster/r.quantile/main.c:337
-msgid "Too many quantiles"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:152 ../raster/r.relief/main.c:110
-#: ../raster/r.param.scale/interface.c:56 ../imagery/i.topo.corr/main.c:48
-msgid "terrain"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:153
-msgid "aspect"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:154
-msgid "slope"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:155
-msgid "curvature"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:156
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from an elevation raster map."
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:158
-msgid "Aspect is calculated counterclockwise from east."
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:165 ../vector/v.surf.rst/main.c:203
-msgid "Name for output slope raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:166 ../raster/r.slope.aspect/main.c:172
-#: ../raster/r.slope.aspect/main.c:196 ../raster/r.slope.aspect/main.c:203
-#: ../raster/r.slope.aspect/main.c:210 ../raster/r.slope.aspect/main.c:217
-#: ../raster/r.slope.aspect/main.c:224 ../raster/r.slope.aspect/main.c:231
-#: ../raster/r.slope.aspect/main.c:238 ../raster/r.watershed/front/main.c:139
-#: ../raster/r.watershed/front/main.c:146
-#: ../raster/r.watershed/front/main.c:153
-#: ../raster/r.watershed/front/main.c:160
-#: ../raster/r.watershed/front/main.c:166
-#: ../raster/r.watershed/front/main.c:172
-#: ../raster/r.watershed/front/main.c:180
-#: ../raster/r.watershed/front/main.c:188
-#: ../raster/r.watershed/front/main.c:195 ../vector/v.vol.rst/main.c:293
-#: ../vector/v.vol.rst/main.c:299 ../vector/v.vol.rst/main.c:362
-#: ../vector/v.vol.rst/main.c:368 ../vector/v.vol.rst/main.c:374
-#: ../vector/v.vol.rst/main.c:381 ../vector/v.vol.rst/main.c:387
-#: ../vector/v.vol.rst/main.c:393 ../vector/v.vol.rst/main.c:399
-#: ../vector/v.vol.rst/main.c:405 ../vector/v.surf.bspline/main.c:130
-#: ../vector/v.surf.bspline/main.c:135 ../vector/v.surf.rst/main.c:174
-#: ../vector/v.surf.rst/main.c:198 ../vector/v.surf.rst/main.c:204
-#: ../vector/v.surf.rst/main.c:210 ../vector/v.surf.rst/main.c:216
-#: ../vector/v.surf.rst/main.c:222 ../vector/v.surf.rst/main.c:228
-#: ../vector/v.surf.rst/main.c:234 ../vector/v.surf.rst/main.c:241
-#: ../vector/v.surf.rst/main.c:248 ../vector/v.surf.rst/main.c:255
-msgid "Outputs"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:171 ../vector/v.surf.rst/main.c:209
-msgid "Name for output aspect raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:180
-msgid "Format for reporting the slope"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:187
-msgid "Type of output aspect and slope maps"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:195 ../vector/v.surf.rst/main.c:215
-msgid "Name for output profile curvature raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:202 ../vector/v.surf.rst/main.c:221
-msgid "Name for output tangential curvature raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:223
-msgid "Name for output second order partial derivative dxx raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:230
-msgid "Name for output second order partial derivative dyy raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:237
-msgid "Name for output second order partial derivative dxy raster map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:243
-msgid "Multiplicative factor to convert elevation units to horizontal units"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:252
-msgid "Minimum slope value (in percent) for which aspect is computed"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:261
-msgid "Do not align the current region to the raster elevation map"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:315 ../raster/r.relief/main.c:221
-#, c-format
-msgid "%s=%s - must be a positive number"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:321 ../raster/r.relief/main.c:202
-#: ../raster/r.relief/main.c:208
-#, c-format
-msgid "%s=%s - must be a non-negative number"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:336
-#, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, "
-"<%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:358
-#, c-format
-msgid "Wrong raster type: %s"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:387
-msgid ""
-"r.slope.aspect does not convert horizontal units to meters in this version, "
-"see manual page."
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:968
-#, c-format
-msgid "Elevation products for mapset <%s> in <%s>"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:987
-#, c-format
-msgid "Min computed aspect %.4f, max computed aspect %.4f"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1051
-#, c-format
-msgid "Aspect raster map <%s> complete"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1108
-#, c-format
-msgid "Min computed slope %.4f, max computed slope %.4f"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1161
-#, c-format
-msgid "Slope raster map <%s> complete"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1233
-#, c-format
-msgid "Profile curve raster map <%s> complete"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1260
-#, c-format
-msgid "Tangential curve raster map <%s> complete"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1285
-#, c-format
-msgid "E-W slope raster map <%s> complete"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1310
-#, c-format
-msgid "N-S slope raster map <%s> complete"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1335
-#, c-format
-msgid "Dxx raster map <%s> complete"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1360
-#, c-format
-msgid "Dyy raster map <%s> complete"
-msgstr ""
-#: ../raster/r.slope.aspect/main.c:1385
-#, c-format
-msgid "Dxy raster map <%s> complete"
-msgstr ""
-#: ../raster/r.surf.area/main.c:79
-msgid "area estimation"
-msgstr ""
-#: ../raster/r.surf.area/main.c:80
-msgid "Prints estimation of surface area for raster map."
-msgstr ""
-#: ../raster/r.surf.area/main.c:89
-msgid "Vertical scale"
-msgstr ""
-#: ../raster/r.surf.area/main.c:93
-msgid "Output units"
-msgstr ""
-#: ../raster/r.surf.area/main.c:94
-msgid "Default: square map units"
-msgstr ""
-#: ../raster/r.surf.area/main.c:102
-#, c-format
-msgid "Output in '%s'"
-msgstr ""
-#: ../raster/r.surf.area/main.c:106
-msgid "Output in 'square map units'"
-msgstr ""
-#: ../raster/r.surf.area/main.c:153
-msgid "Null value area ignored in calculation:"
-msgstr ""
-#: ../raster/r.surf.area/main.c:155
-msgid "Plan area used in calculation:"
-msgstr ""
-#: ../raster/r.surf.area/main.c:158
-msgid "Surface area calculation(low, high, avg):"
-msgstr ""
-#: ../raster/r.surf.area/main.c:163
-msgid "Current region plan area:"
-msgstr ""
-#: ../raster/r.surf.area/main.c:165
-msgid "Estimated region Surface Area:"
-msgstr ""
-#: ../raster/r.usler/main.c:54
-msgid "rainfall"
-msgstr ""
-#: ../raster/r.usler/main.c:55 ../raster/r.sim/r.sim.water/main.c:115
-#: ../raster/r.sim/r.sim.sediment/main.c:116 ../raster/r.uslek/main.c:55
-msgid "soil"
-msgstr ""
-#: ../raster/r.usler/main.c:56 ../raster/r.sim/r.sim.sediment/main.c:118
-#: ../raster/r.uslek/main.c:56
-msgid "erosion"
-msgstr ""
-#: ../raster/r.usler/main.c:57
-msgid "Computes USLE R factor, Rainfall erosivity index."
-msgstr ""
-#: ../raster/r.usler/main.c:60
-msgid "Name of annual precipitation raster map [mm/year]"
-msgstr ""
-#: ../raster/r.usler/main.c:63
-msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
-msgstr ""
-#: ../raster/r.usler/main.c:70
-msgid "Name of USLE R equation"
-msgstr ""
-#: ../raster/r.usler/main.c:75
-msgid "Roosle (1975)"
-msgstr ""
-#: ../raster/r.usler/main.c:76
-msgid "Morgan (1974)"
-msgstr ""
-#: ../raster/r.usler/main.c:77
-msgid "Foster (1981)"
-msgstr ""
-#: ../raster/r.usler/main.c:78
-msgid "El-Swaify (1985)"
-msgstr ""
-#: ../raster/r.distance/distance.c:102
-#, c-format
-msgid "Reading maps  <%s,%s> while finding 0 distance ..."
-msgstr ""
-#: ../raster/r.distance/edges.c:47
-#, c-format
-msgid "Reading map %s ..."
-msgstr ""
-#: ../raster/r.distance/main.c:42
-msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-#: ../raster/r.distance/parse.c:35
-msgid "Name of two input raster maps for computing inter-class distances"
-msgstr ""
-#: ../raster/r.distance/parse.c:45
-msgid "Sort output by distance"
-msgstr ""
-#: ../raster/r.distance/parse.c:46
-msgid "Default: sorted by categories"
-msgstr ""
-#: ../raster/r.distance/parse.c:50
-msgid "Sort by distance in ascending order"
-msgstr ""
-#: ../raster/r.distance/parse.c:51
-msgid "Sort by distance in descending order"
-msgstr ""
-#: ../raster/r.distance/parse.c:55
-msgid "Include category labels in the output"
-msgstr ""
-#: ../raster/r.distance/parse.c:60
-msgid "Report zero distance if rasters are overlapping"
-msgstr ""
-#: ../raster/r.distance/parse.c:64
-msgid "Report null objects as *"
-msgstr ""
-#: ../raster/r.distance/parse.c:74 ../raster/r.distance/parse.c:83
-#, c-format
-msgid "Raster map <%s> is not CELL"
-msgstr ""
-#: ../raster/r.distance/report.c:61
-#: ../scripts/i.colors.enhance/i.colors.enhance.py:161
-#: ../scripts/i.colors.enhance/i.colors.enhance.py:184
-#: ../scripts/i.colors.enhance/i.colors.enhance.py:194
-#: ../scripts/i.colors.enhance/i.colors.enhance.py:218
-msgid "Processing..."
-msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:35
-msgid "Setting window header failed"
-msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:38
-msgid "Rows changed"
-msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:41
-msgid "Cols changed"
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:48
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:51
-msgid "GRIDATB i/o map file"
-msgstr ""
-#: ../raster/r.in.gridatb/main.c:68
-#, c-format
-msgid "File not found: %s"
-msgstr ""
-#: ../raster/r.proj/bordwalk.c:216
-msgid "Input raster map is outside current region"
-msgstr ""
-#: ../raster/r.proj/bordwalk.c:242
-msgid "Unable to reproject map center"
-msgstr ""
-#: ../raster/r.proj/readcell.c:59 ../raster/r.proj/readcell.c:129
-#: ../raster/r.stats.zonal/main.c:482 ../raster/r.stats.quantile/main.c:427
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:66
-#: ../imagery/i.rectify/readcell.c:55
-msgid "Unable to open temporary file"
-msgstr ""
-#: ../raster/r.proj/readcell.c:67
-msgid "Allocating memory and reading input raster map..."
-msgstr ""
-#: ../raster/r.proj/readcell.c:92
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:102
-#: ../imagery/i.rectify/readcell.c:89
-msgid "Error writing segment file"
-msgstr ""
-#: ../raster/r.proj/readcell.c:125
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:132
-#: ../imagery/i.rectify/readcell.c:116
-msgid "Internal error: cache miss on fully-cached map"
-msgstr ""
-#: ../raster/r.proj/readcell.c:138
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:141
-#: ../imagery/i.rectify/readcell.c:125
-msgid "Error seeking on segment file"
-msgstr ""
-#: ../raster/r.proj/readcell.c:141
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:144
-#: ../imagery/i.rectify/readcell.c:128
-msgid "Error reading segment file"
-msgstr ""
-#: ../raster/r.proj/main.c:145 ../raster/r.latlong/main.c:59
-#: ../general/g.setproj/main.c:79 ../general/g.proj/main.c:65
-#: ../vector/v.proj/main.c:69 ../locale/scriptstrings/m.proj_to_translate.c:3
-#: ../locale/scriptstrings/r.import_to_translate.c:4
-#: ../locale/scriptstrings/v.import_to_translate.c:4
-msgid "projection"
-msgstr ""
-#: ../raster/r.proj/main.c:146 ../imagery/i.ifft/main.c:78
-#: ../imagery/i.pca/main.c:73 ../imagery/i.fft/main.c:79
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:392
-#: ../vector/v.transform/main.c:71 ../vector/v.proj/main.c:70
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
-#: ../locale/scriptstrings/m.proj_to_translate.c:4
-#: ../misc/m.transform/main.c:317
-msgid "transformation"
-msgstr ""
-#: ../raster/r.proj/main.c:149
-msgid "Re-projects a raster map from given location to the current location."
-msgstr ""
-#: ../raster/r.proj/main.c:153
-msgid "Location containing input raster map"
-msgstr ""
-#: ../raster/r.proj/main.c:154 ../raster/r.proj/main.c:159
-#: ../raster/r.proj/main.c:164 ../vector/v.net.flow/main.c:108
-#: ../vector/v.net.flow/main.c:114 ../vector/v.proj/main.c:79
-#: ../vector/v.proj/main.c:84 ../vector/v.proj/main.c:90
-msgid "Source"
-msgstr ""
-#: ../raster/r.proj/main.c:157
-msgid "Mapset containing input raster map"
-msgstr ""
-#: ../raster/r.proj/main.c:158 ../vector/v.proj/main.c:83
-msgid "Default: name of current mapset"
-msgstr ""
-#: ../raster/r.proj/main.c:162
-msgid "Name of input raster map to re-project"
-msgstr ""
-#: ../raster/r.proj/main.c:167 ../vector/v.proj/main.c:93
-msgid "Path to GRASS database of input location"
-msgstr ""
-#: ../raster/r.proj/main.c:171
-msgid "Name for output raster map (default: same as 'input')"
-msgstr ""
-#: ../raster/r.proj/main.c:172 ../raster/r.proj/main.c:183
-#: ../raster/r.proj/main.c:199 ../vector/v.proj/main.c:102
-#: ../vector/v.proj/main.c:107 ../vector/v.proj/main.c:119
-#: ../vector/v.proj/main.c:126
-msgid "Target"
-msgstr ""
-#: ../raster/r.proj/main.c:182
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:126
-#: ../imagery/i.rectify/main.c:132
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
-msgid "Interpolation method to use"
-msgstr ""
-#: ../raster/r.proj/main.c:198
-msgid "Resolution of output raster map"
-msgstr ""
-#: ../raster/r.proj/main.c:203
-msgid "List raster maps in input mapset and exit"
-msgstr ""
-#: ../raster/r.proj/main.c:208
-#: ../locale/scriptstrings/r.import_to_translate.c:28
-msgid "Do not perform region cropping optimization"
-msgstr ""
-#: ../raster/r.proj/main.c:213
-msgid "Print input map's bounds in the current projection and exit"
-msgstr ""
-#: ../raster/r.proj/main.c:219
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
-msgstr ""
-#: ../raster/r.proj/main.c:245 ../display/d.mon/start.c:52
-#: ../imagery/i.gensig/parse.c:50 ../imagery/i.cluster/main.c:179
-#: ../imagery/i.gensigset/parse.c:57 ../vector/v.external/main.c:141
-#: ../vector/v.proj/main.c:150
-#, c-format
-msgid "option <%s>: <%s> exists. To overwrite, use the --overwrite flag"
-msgstr ""
-#: ../raster/r.proj/main.c:252 ../vector/v.proj/main.c:165
-msgid "Input and output locations can not be the same"
-msgstr ""
-#: ../raster/r.proj/main.c:254
-msgid "Input and output locations are the same"
-msgstr ""
-#: ../raster/r.proj/main.c:264
-msgid "Unable to get projection info of output raster map"
-msgstr ""
-#: ../raster/r.proj/main.c:267
-msgid "Unable to get projection units of output raster map"
-msgstr ""
-#: ../raster/r.proj/main.c:270
-msgid "Unable to get projection key values of output raster map"
-msgstr ""
-#: ../raster/r.proj/main.c:279
-#, c-format
-msgid "Mapset <%s> in input location <%s> - %s"
-msgstr ""
-#: ../raster/r.proj/main.c:281 ../raster/r.in.gdal/main.c:944
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
-#: ../imagery/i.rectify/target.c:32 ../vector/v.rectify/target.c:41
-msgid "permission denied"
-msgstr ""
-#: ../raster/r.proj/main.c:282 ../raster/r.in.gdal/main.c:945
-msgid "not found"
-msgstr ""
-#: ../raster/r.proj/main.c:288 ../vector/v.proj/main.c:189
-#, c-format
-msgid "Checking location <%s> mapset <%s>"
-msgstr ""
-#: ../raster/r.proj/main.c:300 ../vector/v.select/main.c:89
-#: ../vector/v.net/args.c:152 ../vector/v.net/args.c:159
-#: ../vector/v.net/args.c:165 ../vector/v.net/args.c:169
-#: ../vector/v.net/args.c:179 ../vector/v.in.ogr/main.c:444
-#: ../vector/v.what.rast/main.c:121 ../vector/v.external/main.c:114
-#: ../vector/v.edit/main.c:89 ../vector/v.proj/main.c:206
-#: ../scripts/d.frame/d.frame.py:288
-#, c-format, python-format
-msgid "Required parameter <%s> not set"
-msgstr ""
-#: ../raster/r.proj/main.c:303
-#, c-format
-msgid "Raster map <%s> in location <%s> in mapset <%s> not found"
-msgstr ""
-#: ../raster/r.proj/main.c:311
-msgid "Unable to get projection info of input map"
-msgstr ""
-#: ../raster/r.proj/main.c:319
-msgid "Unable to get projection units of input map"
-msgstr ""
-#: ../raster/r.proj/main.c:322
-msgid "Unable to get projection key values of input map"
-msgstr ""
-#: ../raster/r.proj/main.c:337
-msgid "Unable to work with unprojected data (xy location)"
-msgstr ""
-#: ../raster/r.proj/main.c:356
-#, c-format
-msgid "Input map <%s@%s> in location <%s>:"
-msgstr ""
-#: ../raster/r.proj/main.c:448
-msgid "Input:"
-msgstr ""
-#: ../raster/r.proj/main.c:449 ../raster/r.proj/main.c:460
-#, c-format
-msgid "Cols: %d (%d)"
-msgstr ""
-#: ../raster/r.proj/main.c:450 ../raster/r.proj/main.c:461
-#, c-format
-msgid "Rows: %d (%d)"
-msgstr ""
-#: ../raster/r.proj/main.c:451 ../raster/r.proj/main.c:462
-#, c-format
-msgid "North: %f (%f)"
-msgstr ""
-#: ../raster/r.proj/main.c:452 ../raster/r.proj/main.c:463
-#, c-format
-msgid "South: %f (%f)"
-msgstr ""
-#: ../raster/r.proj/main.c:453 ../raster/r.proj/main.c:464
-#, c-format
-msgid "West: %f (%f)"
-msgstr ""
-#: ../raster/r.proj/main.c:454 ../raster/r.proj/main.c:465
-#, c-format
-msgid "East: %f (%f)"
-msgstr ""
-#: ../raster/r.proj/main.c:455 ../raster/r.proj/main.c:466
-#, c-format
-msgid "EW-res: %f"
-msgstr ""
-#: ../raster/r.proj/main.c:456 ../raster/r.proj/main.c:467
-#, c-format
-msgid "NS-res: %f"
-msgstr ""
-#: ../raster/r.proj/main.c:459
-msgid "Output:"
-msgstr ""
-#: ../raster/r.proj/main.c:496
-msgid "Projecting..."
-msgstr ""
-#: ../raster/r.to.rast3/main.c:59 ../raster/r.to.rast3elev/main.c:136
-msgid "Could not close the map"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:79
-msgid "2D raster maps which represent the slices"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:84 ../raster/r.to.rast3elev/main.c:175
-msgid "The maximum tile size in kilo bytes. Default is 32KB."
-msgstr ""
-#: ../raster/r.to.rast3/main.c:93
-msgid "Use 3D raster mask (if exists) with output map"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:199 ../raster/r.to.rast3elev/main.c:364
-#: ../vector/v.vol.rst/main.c:236 ../vector/v.to.rast3/main.c:50
-#: ../raster3d/r3.support/main.c:51 ../raster3d/r3.neighbors/main.c:210
-#: ../raster3d/r3.stats/main.c:50 ../raster3d/r3.gradient/main.c:45
-#: ../raster3d/r3.gwflow/main.c:161 ../raster3d/r3.out.vtk/main.c:378
-#: ../raster3d/r3.in.ascii/main.c:356 ../raster3d/r3.out.bin/main.c:207
-#: ../raster3d/r3.cross.rast/main.c:231 ../raster3d/r3.info/main.c:77
-#: ../raster3d/r3.retile/main.c:98 ../raster3d/r3.timestamp/main.c:47
-#: ../raster3d/r3.in.bin/main.c:254 ../raster3d/r3.flow/main.c:181
-#: ../raster3d/r3.out.netcdf/main.c:589 ../raster3d/r3.mask/main.c:135
-#: ../raster3d/r3.out.ascii/main.c:304 ../raster3d/r3.mkdspf/main.c:81
-#: ../raster3d/r3.in.v5d/main.c:180 ../raster3d/r3.out.v5d/main.c:286
-#: ../raster3d/r3.null/main.c:182 ../raster3d/r3.to.rast/main.c:262
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
-msgid "voxel"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:201
-msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-#: ../raster/r.to.rast3/main.c:213
-msgid "No output map"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:230
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D region settings to"
-" adjust the 2D region."
-msgstr ""
-#: ../raster/r.to.rast3/main.c:262
-#, c-format
-msgid "Open raster map %s - one time for each depth (%d/%d)"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:275
-msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
-msgid "Creating 3D raster map"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:291 ../raster/r.to.rast3elev/main.c:443
-msgid "Error opening 3D raster map"
-msgstr ""
-#: ../raster/r.to.rast3/main.c:326 ../raster/r.to.rast3elev/main.c:501
-msgid "Error closing 3d raster map"
-msgstr ""
-#: ../raster/r.profile/input.c:30 ../raster/r.profile/input.c:47
-#: ../raster/r.profile/input.c:60
-msgid "One coordinate pair per line, please"
-msgstr ""
-#: ../raster/r.profile/main.c:54 ../raster/r.transect/main.c:104
-#: ../display/d.profile/main.c:192 ../vector/v.profile/main.c:154
-#: ../raster3d/r3.cross.rast/main.c:229
-msgid "profile"
-msgstr ""
-#: ../raster/r.profile/main.c:55 ../raster/r.transect/main.c:105
-#: ../vector/v.profile/main.c:155
-msgid "transect"
-msgstr ""
-#: ../raster/r.profile/main.c:57
-msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-#: ../raster/r.profile/main.c:65 ../raster/r.horizon/main.c:304
-msgid "Name of file for output (use output=- for stdout)"
-msgstr ""
-#: ../raster/r.profile/main.c:70 ../display/d.profile/main.c:203
-msgid "Profile coordinate pairs"
-msgstr ""
-#: ../raster/r.profile/main.c:76
-msgid "Name of input file containing coordinate pairs"
-msgstr ""
-#: ../raster/r.profile/main.c:78
-msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
-msgstr ""
-#: ../raster/r.profile/main.c:86
-msgid "Resolution along profile (default = current region resolution)"
-msgstr ""
-#: ../raster/r.profile/main.c:94 ../raster/r.transect/main.c:127
-msgid "Output easting and northing in first two columns of four column output"
-msgstr ""
-#: ../raster/r.profile/main.c:99
-msgid "Output RRR:GGG:BBB color values for each profile point"
-msgstr ""
-#: ../raster/r.profile/main.c:104
-msgid ""
-"If units are not specified, current location units are used. Meters are used"
-" by default in geographic (latlon) locations."
-msgstr ""
-#: ../raster/r.profile/main.c:118
-msgid "Either use profile option or coordinate_file  option, but not both"
-msgstr ""
-#: ../raster/r.profile/main.c:145
-#, c-format
-msgid "Illegal resolution %g [%s]"
-msgstr ""
-#: ../raster/r.profile/main.c:152
-#, c-format
-msgid "Using resolution: %g [%s]"
-msgstr ""
-#: ../raster/r.profile/main.c:183
-msgid "Output columns:"
-msgstr ""
-#: ../raster/r.profile/main.c:186
-#, c-format
-msgid "Easting, Northing, Along track dist. [%s], Elevation"
-msgstr ""
-#: ../raster/r.profile/main.c:188
-#, c-format
-msgid "Along track dist. [%s], Elevation"
-msgstr ""
-#: ../raster/r.profile/main.c:190
-msgid " RGB color"
-msgstr ""
-#: ../raster/r.profile/main.c:201
-#, c-format
-msgid "Could not open <%s>"
-msgstr ""
-#: ../raster/r.profile/main.c:208
-#, c-format
-msgid "Invalid coordinates %s %s"
-msgstr ""
-#: ../raster/r.profile/main.c:279
-#, c-format
-msgid "Approx. transect length: %f [%s]"
-msgstr ""
-#: ../raster/r.profile/main.c:282
-msgid "Endpoint coordinates are outside of current region settings"
-msgstr ""
-#: ../raster/r.thin/main.c:60
-msgid ""
-"Thins non-null cells that denote linear features in a raster map layer."
-msgstr ""
-#: ../raster/r.thin/main.c:72
-msgid "Maximal number of iterations"
-msgstr ""
-#: ../raster/r.thin/io.c:98
-msgid "Input raster must be of type CELL."
-msgstr ""
-#. GTC Count of raster rows
-#. GTC Count of window rows
-#: ../raster/r.thin/io.c:105 ../raster/r.thin/io.c:172
-#: ../raster/r.thin/io.c:181 ../display/d.rast.num/main.c:199
-#: ../vector/v.kernel/main.c:302 ../vector/v.surf.idw/main.c:259
-#, c-format
-msgid "%d row"
-msgid_plural "%d rows"
-msgstr[0] ""
-#. GTC Count of raster columns
-#. GTC Count of window columns
-#: ../raster/r.thin/io.c:107 ../raster/r.thin/io.c:174
-#: ../raster/r.thin/io.c:183 ../vector/v.kernel/main.c:303
-#: ../vector/v.surf.idw/main.c:261
-#, c-format
-msgid "%d column"
-msgid_plural "%d columns"
-msgstr[0] ""
-#. GTC First argument is the raster map name, second and third - a string
-#. representing number of rows and cols
-#: ../raster/r.thin/io.c:109
-#, c-format
-msgid "Raster map <%s> - %s X %s"
-msgstr ""
-#: ../raster/r.thin/io.c:122
-#, c-format
-msgid "Unable to create temporary file <%s> -- errno = %d"
-msgstr ""
-#: ../raster/r.thin/io.c:131 ../raster/r.thin/io.c:138
-#: ../raster/r.thin/io.c:147 ../raster/r.resamp.rst/main.c:547
-#: ../vector/v.surf.rst/main.c:872
-#, c-format
-msgid "Error writing temporary file <%s>"
-msgstr ""
-#. GTC %s will be replaced with number of rows and columns
-#: ../raster/r.thin/io.c:176
-#, c-format
-msgid "Output map %s X %s"
-msgstr ""
-#: ../raster/r.thin/io.c:185
-#, c-format
-msgid "Window %s X %s"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:67
-msgid "Unable to find bounding box for lines"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:69
-#, c-format
-msgid "Bounding box:  l = %d, r = %d, t = %d, b = %d"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:116
-#, c-format
-msgid "Pass number %d"
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:167
-#, c-format
-msgid "Deleted %d pixel"
-msgid_plural "Deleted %d pixels"
-msgstr[0] ""
-#: ../raster/r.thin/thin_lines.c:171
-msgid "Thinning completed successfully."
-msgstr ""
-#: ../raster/r.thin/thin_lines.c:173
-msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr ""
-#: ../raster/r.rescale/get_range.c:24 ../raster/r.rescale.eq/get_stats.c:19
-#, c-format
-msgid "Reading %s ..."
-msgstr ""
-#: ../raster/r.rescale/main.c:49 ../raster/r.rescale.eq/main.c:53
-msgid "rescale"
-msgstr ""
-#: ../raster/r.rescale/main.c:51
-msgid "Rescales the range of category values in a raster map layer."
-msgstr ""
-#: ../raster/r.rescale/main.c:56 ../raster/r.rescale.eq/main.c:61
-msgid "The name of the raster map to be rescaled"
-msgstr ""
-#: ../raster/r.rescale/main.c:64 ../raster/r.rescale.eq/main.c:69
-msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-#: ../raster/r.rescale/main.c:67 ../raster/r.rescale.eq/main.c:72
-msgid "The resulting raster map name"
-msgstr ""
-#: ../raster/r.rescale/main.c:74 ../raster/r.rescale.eq/main.c:79
-msgid "The output data range"
-msgstr ""
-#: ../raster/r.rescale/main.c:81 ../raster/r.rescale.eq/main.c:86
-msgid "Title for new raster map"
-msgstr ""
-#: ../raster/r.rescale/main.c:110
-#, c-format
-msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
-msgstr ""
-#: ../raster/r.basins.fill/read_map.c:39
-#, c-format
-msgid "Reading <%s> ... "
-msgstr ""
-#: ../raster/r.basins.fill/main.c:56 ../raster/r.watershed/front/main.c:75
-#: ../raster/r.water.outlet/main.c:59
-msgid "watershed"
-msgstr ""
-#: ../raster/r.basins.fill/main.c:58
-msgid "Generates watershed subbasins raster map."
-msgstr ""
-#: ../raster/r.basins.fill/main.c:62
-msgid "Name of input coded stream network raster map"
-msgstr ""
-#: ../raster/r.basins.fill/main.c:66
-msgid "Name of input thinned ridge network raster map"
-msgstr ""
-#: ../raster/r.basins.fill/main.c:74
-msgid "Number of passes through the dataset"
-msgstr ""
-#: ../raster/r.basins.fill/main.c:122
-msgid "Forward sweep complete"
-msgstr ""
-#: ../raster/r.basins.fill/main.c:139
-msgid "Reverse sweep complete"
-msgstr ""
-#: ../raster/r.transect/main.c:84
-#, c-format
-msgid "End coordinate: %.15g, %.15g"
-msgstr ""
-#: ../raster/r.transect/main.c:107
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-#: ../raster/r.transect/main.c:111
-msgid "Raster map to be queried"
-msgstr ""
-#: ../raster/r.transect/main.c:117
-msgid "Transect definition"
-msgstr ""
-#: ../raster/r.what.color/main.c:91
-msgid "Queries colors for a raster map layer."
-msgstr ""
-#: ../raster/r.what.color/main.c:99
-msgid "Name of existing raster map to query colors"
-msgstr ""
-#: ../raster/r.what.color/main.c:106
-msgid "Values to query colors for"
-msgstr ""
-#: ../raster/r.what.color/main.c:113
-msgid "Output format (printf-style)"
-msgstr ""
-#: ../raster/r.what.color/main.c:117
-msgid "Read values from stdin"
-msgstr ""
-#: ../raster/r.what.color/main.c:123
-msgid "Either \"-i\" or \"value=\" must be given"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:94 ../general/g.proj/main.c:66
-#: ../vector/v.in.ogr/main.c:200
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:6
-msgid "create location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:96
-msgid "Imports raster data into a GRASS raster map using GDAL library."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:102
-msgid "Name of raster file to be imported"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:111
-msgid "Band(s) to select (default is all bands)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:112 ../raster/r.in.gdal/main.c:225
-#: ../scripts/i.spectral/i.spectral.py:196
-msgid "Bands"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:129
-msgid "Name of GCPs target location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:131
-msgid ""
-"Name of location to create or to read projection from for GCPs "
-"transformation"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:133 ../raster/r.in.gdal/main.c:188
-#: ../raster/r.in.gdal/main.c:195 ../vector/v.info/print.c:505
-#: ../vector/v.info/print.c:510
-msgid "Projection"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:141 ../raster/r.in.gdal/main.c:150
-#: ../raster/r.in.gdal/main.c:159 ../raster/r.in.gdal/main.c:165
-#: ../raster/r.external/main.c:91 ../imagery/i.landsat.toar/main.c:94
-#: ../imagery/i.landsat.toar/main.c:116 ../imagery/i.landsat.toar/main.c:125
-#: ../imagery/i.landsat.toar/main.c:134 ../imagery/i.landsat.toar/main.c:142
-#: ../imagery/i.landsat.toar/main.c:151
-#: ../locale/scriptstrings/r.import_to_translate.c:25
-msgid "Metadata"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:148
-msgid "Offset to be added to band numbers"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:149
-msgid "If 0, no offset is added and the first band is 1"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:157
-msgid ""
-"Zero-padding of band number by filling with leading zeros up to given number"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:158
-msgid "If 0, length will be adjusted to 'offset' number without leading zeros"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:164
-msgid "Name of the output file that contains the imported map names"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:171 ../vector/v.in.lidar/main.c:272
-#: ../vector/v.in.ogr/main.c:281
-msgid "Name for new location to create"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:178
-msgid "File prefix for raster attribute tables"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:179
-msgid "The band number and \".csv\" will be appended to the file prefix"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:185 ../raster/r.in.lidar/main.c:300
-#: ../raster/r.external/main.c:102 ../vector/v.in.lidar/main.c:321
-#: ../vector/v.in.ogr/main.c:347 ../vector/v.external/args.c:45
-#: ../raster3d/r3.in.lidar/main.c:293
-#: ../locale/scriptstrings/r.import_to_translate.c:31
-#: ../locale/scriptstrings/r.unpack_to_translate.c:8
-#: ../locale/scriptstrings/v.import_to_translate.c:27
-#: ../locale/scriptstrings/v.unpack_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:18
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:14
-msgid "Override projection check (use current location's projection)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:187 ../raster/r.in.lidar/main.c:302
-#: ../raster/r.external/main.c:104 ../vector/v.in.lidar/main.c:323
-#: ../raster3d/r3.in.lidar/main.c:295
-#: ../locale/scriptstrings/r.unpack_to_translate.c:9
-#: ../locale/scriptstrings/v.unpack_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:19
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:15
-msgid "Assume that the dataset has same projection as the current location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:193 ../raster/r.external/main.c:109
-#: ../vector/v.in.ogr/main.c:354 ../vector/v.external/args.c:52
-msgid "Perform projection check only and exit"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:200 ../raster/r.external/main.c:114
-#: ../vector/v.in.lidar/main.c:302 ../vector/v.in.ogr/main.c:366
-msgid "Extend region extents based on new dataset"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:202 ../raster/r.external/main.c:115
-#: ../vector/v.in.ogr/main.c:368
-msgid "Also updates the default region if in the PERMANENT mapset"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:203 ../raster/r.in.gdal/main.c:236
-#: ../vector/v.db.select/main.c:101
-#: ../locale/scriptstrings/v.clip_to_translate.c:9
-msgid "Region"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:214
-#: ../locale/scriptstrings/r.import_to_translate.c:30
-msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:224
-msgid "Keep band numbers instead of using band color names"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:230
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the raster file."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:235 ../vector/v.in.lidar/main.c:284
-#: ../vector/v.in.ogr/main.c:361
-msgid "Limit import to the current region"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:240
-msgid "Print number of bands and exit"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:272 ../raster/r.external/list.c:23
-#: ../vector/v.external.out/list.c:102 ../vector/v.in.ogr/main.c:403
-#: ../vector/v.out.ogr/list.c:116 ../vector/v.external/list.c:94
-msgid "Supported formats:"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:315
-msgid "You have to specify a target location different from output location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:319
-msgid "You need to specify valid location name."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:323
-msgid "The '-l' flag only works in Lat/Lon locations"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:326
-msgid ""
-"The number of digits for band numbering must be equal or greater than 0"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:339
-msgid "Disabling '-r' flag for new location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:347 ../raster/r.in.gdal/main.c:350
-#, c-format
-msgid "Using memory cache size: %.1f MiB"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:359
-#, c-format
-msgid "Unable to open datasource <%s>"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:370
-#, c-format
-msgid ""
-"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
-"plate spline transformation (%s or %s)."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:383
-msgid "Input contains subdatasets which may need to be imported separately"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:400 ../raster/r.in.gdal/main.c:688
-#: ../raster/r.relief/main.c:195 ../imagery/i.landsat.toar/main.c:548
-#, c-format
-msgid "Raster map <%s> already exists and will be overwritten"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:403 ../raster/r.in.gdal/main.c:691
-#: ../raster/r.relief/main.c:198
-#, c-format
-msgid "Raster map <%s> already exists"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:423
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:442
-#, c-format
-msgid ""
-"Unable to fetch the affine transformation coefficients. Flag -%c cannot be "
-"used in this case."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:470
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them"
-" with r.region before going any further."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:515 ../raster/r.in.gdal/main.c:545
-msgid ""
-"Input raster does not overlap current computational region. Nothing to "
-"import."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:585
-#, c-format
-msgid "Importing %d raster bands..."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:604 ../raster/r.external/main.c:230
-#, c-format
-msgid "Selected band (%d) does not exist"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:629
-msgid "Unable to open the map names output text file"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:660
-#, c-format
-msgid "Unable to get raster band number %d"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:737
-#, c-format
-msgid "Copying %d GCPS in points file for <%s>"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:745
-msgid "GCPs have the following OpenGIS WKT Coordinate System:"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:768
-msgid "Re-projecting GCPs table:"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:769
-#, c-format
-msgid "* Input projection for GCP table: %s"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:771
-#, c-format
-msgid "* Output projection for GCP table: %s"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:792
-#, c-format
-msgid "Error in pj_do_proj (can't re-projection GCP %i)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:814 ../raster/r.in.gdal/proj.c:63
-#: ../raster/r.external/proj.c:63 ../vector/v.in.lidar/main.c:507
-#: ../vector/v.in.ogr/proj.c:253 ../vector/v.external/proj.c:154
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:838 ../raster/r.in.gdal/proj.c:69
-#: ../raster/r.external/proj.c:69 ../vector/v.in.lidar/main.c:513
-#: ../vector/v.in.ogr/proj.c:259 ../vector/v.external/proj.c:160
-#, c-format
-msgid "Unable to create new location <%s>"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:844 ../raster/r.in.gdal/proj.c:72
-#: ../raster/r.external/proj.c:72 ../general/g.proj/create.c:15
-#: ../vector/v.in.lidar/main.c:516 ../vector/v.in.ogr/proj.c:262
-#: ../vector/v.external/proj.c:163
-#, c-format
-msgid "Location <%s> created"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:847
-#, c-format
-msgid ""
-"The target for the output group <%s> has been set to location <%s>, mapset "
-"<PERMANENT>."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:887 ../raster/r.external/window.c:93
-#: ../vector/v.in.ogr/main.c:1877
-msgid "Default region for this location updated"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:890 ../raster/r.external/window.c:96
-#: ../vector/v.in.ogr/main.c:1880
-msgid "Region for the current mapset updated"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:918
-msgid "Unable to translate projection key values of input GCPs"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:934
-msgid "Unable to get projection info of target location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:936
-msgid "Unable to get projection units of target location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:938
-msgid "Unable to get projection key values of target location"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:942
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
-#: ../imagery/i.rectify/target.c:31 ../vector/v.rectify/target.c:40
-#, c-format
-msgid "Mapset <%s> in target location <%s> - "
-msgstr ""
-#: ../raster/r.in.gdal/main.c:980
-#, c-format
-msgid "Importing raster map <%s>..."
-msgstr ""
-#: ../raster/r.in.gdal/main.c:1097 ../raster/r.in.gdal/main.c:1152
-#: ../raster/r.in.gdal/main.c:1226
-msgid "Invalid row"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:1494 ../raster/r.in.gdal/main.c:1551
-msgid "Inconsistent color rules in RAT"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:1608
-#, c-format
-msgid "Setting grey color table for <%s> (8bit, full range)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:1622
-#, c-format
-msgid "Setting grey color table for <%s> (16bit, image range)"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:1724
-#, c-format
-msgid "Unable to open file <%s>: %s."
-msgstr ""
-#: ../raster/r.in.gdal/proj.c:42 ../raster/r.external/proj.c:42
-#, c-format
-msgid ""
-"Input contains an invalid SRS. WKT definition:\n"
-"%s"
-msgstr ""
-#: ../raster/r.in.gdal/proj.c:51 ../raster/r.external/proj.c:51
-msgid "No projection information available"
-msgstr ""
-#: ../raster/r.in.gdal/proj.c:94 ../raster/r.external/proj.c:94
-#: ../vector/v.in.ogr/proj.c:284 ../vector/v.external/proj.c:185
-msgid "Unable to convert input map projection information to GRASS format."
-msgstr ""
-#: ../raster/r.in.gdal/proj.c:122 ../raster/r.in.lidar/projection.c:128
-#: ../raster/r.external/proj.c:122 ../vector/v.in.lidar/projection.c:126
-#: ../vector/v.in.ogr/proj.c:313 ../vector/v.external/proj.c:214
-#: ../raster3d/r3.in.lidar/projection.c:130
-msgid "Over-riding projection check"
-msgstr ""
-#: ../raster/r.in.gdal/proj.c:131 ../raster/r.in.lidar/projection.c:34
-#: ../raster/r.external/proj.c:131 ../vector/v.in.pdal/projection.c:31
-#: ../vector/v.in.lidar/projection.c:32 ../vector/v.in.ogr/proj.c:322
-#: ../vector/v.external/proj.c:223 ../raster3d/r3.in.lidar/projection.c:36
-msgid ""
-"Projection of dataset does not appear to match current location.\n"
-"\n"
-msgstr ""
-#: ../raster/r.in.gdal/proj.c:138 ../raster/r.external/proj.c:138
-#: ../vector/v.in.ogr/proj.c:329 ../vector/v.external/proj.c:230
-msgid "Location PROJ_INFO is:\n"
-msgstr ""
-#: ../raster/r.in.gdal/proj.c:148 ../raster/r.in.gdal/proj.c:155
-#: ../raster/r.external/proj.c:148 ../raster/r.external/proj.c:155
-#: ../vector/v.in.ogr/proj.c:339 ../vector/v.in.ogr/proj.c:346
-#: ../vector/v.external/proj.c:240 ../vector/v.external/proj.c:247
-msgid "Dataset PROJ_INFO is:\n"
-msgstr ""
-#: ../raster/r.in.gdal/proj.c:237 ../raster/r.in.lidar/projection.c:91
-#: ../raster/r.external/proj.c:237 ../vector/v.in.pdal/projection.c:88
-#: ../vector/v.in.lidar/projection.c:89 ../vector/v.in.ogr/proj.c:428
-#: ../vector/v.external/proj.c:329 ../raster3d/r3.in.lidar/projection.c:93
-#, c-format
-msgid ""
-"\n"
-"In case of no significant differences in the projection definitions, use the -o flag to ignore them and use current location definition.\n"
-msgstr ""
-#: ../raster/r.in.gdal/proj.c:241 ../raster/r.external/proj.c:241
-#: ../vector/v.in.ogr/proj.c:432 ../vector/v.external/proj.c:333
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-#: ../raster/r.in.gdal/proj.c:260 ../raster/r.in.lidar/projection.c:139
-#: ../raster/r.external/proj.c:260 ../vector/v.in.pdal/projection.c:137
-#: ../vector/v.in.lidar/projection.c:137 ../vector/v.in.ogr/proj.c:451
-#: ../vector/v.external/proj.c:352 ../raster3d/r3.in.lidar/projection.c:141
-msgid "Projection of input dataset and current location appear to match"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:74
-msgid "Converts a GRASS ASCII raster file to binary raster map."
-msgstr ""
-#: ../raster/r.in.ascii/main.c:78 ../vector/v.in.ascii/main.c:80
-#: ../raster3d/r3.in.ascii/main.c:86
-msgid "Name of input file to be imported"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:85
-msgid "Default: CELL for integer values, DCELL for floating-point values"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:97 ../raster/r.in.ascii/main.c:102
-msgid "Default: read from header"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:99
-msgid "Multiplier for ASCII data"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:103
-msgid "String representing NULL value data cell"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:104
-msgid "NULL data"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:109
-msgid "SURFER (Golden Software) ASCII file will be imported"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:120 ../raster/r.in.ascii/main.c:150
-#: ../raster/r.resamp.rst/main.c:542 ../general/g.setproj/get_stp.c:162
-#: ../general/g.setproj/get_stp.c:165 ../general/g.setproj/get_stp.c:282
-#: ../general/g.setproj/get_stp.c:286 ../display/d.title/main.c:117
-#: ../vector/v.in.ascii/main.c:275 ../vector/v.surf.rst/main.c:867
-#: ../raster3d/r3.in.ascii/main.c:169
-#, c-format
-msgid "Unable to open temporary file <%s>"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:128
-#, c-format
-msgid "Wrong entry for multiplier: %s"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:153 ../raster3d/r3.in.ascii/main.c:172
-msgid "Unable to read input from stdin"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:160
-#, c-format
-msgid "Unable to read input from <%s>"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:180
-msgid "Can't get cell header"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:187 ../raster/r.horizon/main.c:659
-#, c-format
-msgid "OOPS: rows changed from %d to %d"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:190 ../raster/r.horizon/main.c:663
-#, c-format
-msgid "OOPS: cols changed from %d to %d"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:202
-#, c-format
-msgid "Data conversion failed at row %d, col %d"
-msgstr ""
-#: ../raster/r.in.ascii/main.c:275 ../raster3d/r3.in.ascii/main.c:130
-msgid "Unable to write to file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:35
-msgid "input file is not a Surfer ascii grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:41
-msgid "error reading the column and row dimension from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:47
-msgid "error reading the X range from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:53
-msgid "error reading the Y range from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:59
-msgid "error reading the Z range from the Surfer grid file"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:105
-msgid "error getting file position"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:164
-msgid "illegal type field: using type int"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:169
-msgid "ignoring type filed in header, type is set on command line"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:176
-msgid "illegal multiplier field: using 1.0"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:181
-msgid "ignoring multiplier filed in header, multiplier is set on command line"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:189
-msgid "ignoring null filed in header, null string is set on command line"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:218
-msgid "error in ascii data format"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:248
-#, c-format
-msgid "Duplicate \"%s\" field in header"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:253
-#, c-format
-msgid "Illegal \"%s\" value in header: %s"
-msgstr ""
-#: ../raster/r.in.ascii/gethead.c:261
-#, c-format
-msgid "\"%s\" field missing from header"
-msgstr ""
-#: ../raster/r.ros/main.c:213 ../raster/r.spreadpath/main.c:89
-#: ../raster/r.spread/main.c:106
-msgid "fire"
-msgstr ""
-#: ../raster/r.ros/main.c:214 ../raster/r.spread/main.c:107
-msgid "spread"
-msgstr ""
-#: ../raster/r.ros/main.c:215
-msgid "rate of spread"
-msgstr ""
-#: ../raster/r.ros/main.c:216 ../raster/r.lake/main.c:152
-#: ../raster/r.spread/main.c:108
-msgid "hazard"
-msgstr ""
-#: ../raster/r.ros/main.c:217 ../raster/r.topmodel/main.c:53
-#: ../raster/r.sim/r.sim.water/main.c:118
-#: ../raster/r.sim/r.sim.sediment/main.c:120 ../raster/r.spread/main.c:109
-msgid "model"
-msgstr ""
-#: ../raster/r.ros/main.c:218
-msgid "Generates rate of spread raster maps."
-msgstr ""
-#: ../raster/r.ros/main.c:220
-msgid ""
-"Generates three, or four raster map layers showing the base (perpendicular) "
-"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
-"maximum ROS, and optionally the maximum potential spotting distance for fire"
-" spread simulation."
-msgstr ""
-#: ../raster/r.ros/main.c:227
-msgid "Raster map containing fuel models"
-msgstr ""
-#: ../raster/r.ros/main.c:229
-msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the standard fuel models defined by the USDA Forest Service."
-" Valid values are 1-13; other numbers are recognized as barriers by r.ros."
-msgstr ""
-#: ../raster/r.ros/main.c:238
-msgid "Raster map containing the 1-hour fuel moisture (%)"
-msgstr ""
-#: ../raster/r.ros/main.c:240 ../raster/r.spread/main.c:205
-msgid ""
-"path containing the 1-hour (<.25\") fuel moisture (percentage content "
-"multiplied by 100)."
-msgstr ""
-#: ../raster/r.ros/main.c:248
-msgid "Raster map containing the 10-hour fuel moisture (%)"
-msgstr ""
-#: ../raster/r.ros/main.c:250
-msgid ""
-"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
-msgstr ""
-#: ../raster/r.ros/main.c:258
-msgid "Raster map containing the 100-hour fuel moisture (%)"
-msgstr ""
-#: ../raster/r.ros/main.c:260
-msgid ""
-"path containing the 100-hour (1-3\") fuel moisture (percentage content "
-msgstr ""
-#: ../raster/r.ros/main.c:267
-msgid "Raster map containing live fuel moisture (%)"
-msgstr ""
-#: ../raster/r.ros/main.c:269
-msgid ""
-"path containing live (herbaceous) fuel moisture (percentage content "
-msgstr ""
-#: ../raster/r.ros/main.c:277
-msgid "Raster map containing midflame wind velocities (ft/min)"
-msgstr ""
-#: ../raster/r.ros/main.c:279 ../raster/r.spread/main.c:193
-msgid ""
-"path containing wind velocities at half of the average flame height "
-"(feet/minute)."
-msgstr ""
-#: ../raster/r.ros/main.c:287
-msgid "Name of raster map containing wind directions (degree)"
-msgstr ""
-#: ../raster/r.ros/main.c:289
-msgid ""
-"path containing wind direction, clockwise from north (degree)."
-msgstr ""
-#: ../raster/r.ros/main.c:297
-msgid "Name of raster map containing slope (degree)"
-msgstr ""
-#: ../raster/r.ros/main.c:299
-msgid ""
-"path containing topographic slope (degree)."
-msgstr ""
-#: ../raster/r.ros/main.c:307
-msgid "Raster map containing aspect (degree, CCW from E)"
-msgstr ""
-#: ../raster/r.ros/main.c:309
-msgid ""
-"path containing topographic aspect, counterclockwise from east (GRASS "
-"convention) in degrees."
-msgstr ""
-#: ../raster/r.ros/main.c:317
-msgid "Raster map containing elevation (m, required for spotting)"
-msgstr ""
-#: ../raster/r.ros/main.c:319
-msgid ""
-"path containing elevation (meters). Option is required from spotting "
-"distance computation (when spotting_distance option is provided)"
-msgstr ""
-#: ../raster/r.ros/main.c:328
-msgid "Output raster map containing base ROS (cm/min)"
-msgstr ""
-#: ../raster/r.ros/main.c:330
-msgid "Base (perpendicular) rate of spread (ROS)"
-msgstr ""
-#: ../raster/r.ros/main.c:336
-msgid "Output raster map containing maximal ROS (cm/min)"
-msgstr ""
-#: ../raster/r.ros/main.c:338
-msgid "The maximum (forward) rate of spread (ROS)"
-msgstr ""
-#: ../raster/r.ros/main.c:344
-msgid "Output raster map containing directions of maximal ROS (degree)"
-msgstr ""
-#: ../raster/r.ros/main.c:346
-msgid "The direction of the maximal (forward) rate of spread (ROS)"
-msgstr ""
-#: ../raster/r.ros/main.c:352
-msgid "Output raster map containing maximal spotting distance (m)"
-msgstr ""
-#: ../raster/r.ros/main.c:354
-msgid ""
-"The maximal potential spotting distance (requires elevation raster map to be"
-" provided)."
-msgstr ""
-#: ../raster/r.ros/main.c:373
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
-msgstr ""
-#: ../raster/r.ros/main.c:397
-#, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
-msgstr ""
-#: ../raster/r.ros/main.c:402
-#, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
-msgstr ""
-#: ../raster/r.ros/main.c:416
-#, c-format
-msgid "An aspect layer should be given if the slope layer <%s> has been given"
-msgstr ""
-#: ../raster/r.ros/main.c:421
-#, c-format
-msgid "A slope layer should be given if the aspect layer <%s> has been given"
-msgstr ""
-#: ../raster/r.ros/main.c:437
-msgid "An elevation layer should be given if considering spotting"
-msgstr ""
-#: ../raster/r.ros/main.c:873
-#, c-format
-msgid "Raster maps <%s>, <%s> and <%s> created."
-msgstr ""
-#: ../raster/r.surf.gauss/main.c:40 ../raster/r.random.cells/main.c:49
-#: ../raster/r.surf.random/main.c:38 ../raster/r.random/main.c:54
-#: ../raster/r.random.surface/main.c:59 ../vector/v.extract/main.c:81
-#: ../vector/v.perturb/main.c:65 ../vector/v.random/main.c:100
-msgid "random"
-msgstr ""
-#: ../raster/r.surf.gauss/main.c:42
-msgid "Generates a raster map using gaussian random number generator."
-msgstr ""
-#: ../raster/r.surf.gauss/main.c:44
-msgid ""
-"Mean and standard deviation of gaussian deviates can be expressed by the "
-"user."
-msgstr ""
-#: ../raster/r.surf.gauss/main.c:51
-msgid "Distribution mean"
-msgstr ""
-#: ../raster/r.surf.gauss/main.c:57
-msgid "Standard deviation"
-msgstr ""
-#: ../raster/r.sun/main.c:252 ../raster/r.horizon/main.c:181
-#: ../raster/r.sunhours/main.c:73 ../raster/r.sunmask/main.c:117
-msgid "solar"
-msgstr ""
-#: ../raster/r.sun/main.c:253 ../raster/r.sunhours/main.c:74
-msgid "sun energy"
-msgstr ""
-#: ../raster/r.sun/main.c:254 ../raster/r.sunmask/main.c:119
-msgid "shadow"
-msgstr ""
-#: ../raster/r.sun/main.c:255
-msgid "Solar irradiance and irradiation model."
-msgstr ""
-#: ../raster/r.sun/main.c:257
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
-msgstr ""
-#: ../raster/r.sun/main.c:271
-msgid "Name of the input elevation raster map [meters]"
-msgstr ""
-#: ../raster/r.sun/main.c:280
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
-msgstr ""
-#: ../raster/r.sun/main.c:289
-msgid "A single value of the orientation (aspect), 270 is south"
-msgstr ""
-#: ../raster/r.sun/main.c:298
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
-msgstr ""
-#: ../raster/r.sun/main.c:306
-msgid "A single value of inclination (slope)"
-msgstr ""
-#: ../raster/r.sun/main.c:315
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr ""
-#: ../raster/r.sun/main.c:324
-msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
-msgstr ""
-#: ../raster/r.sun/main.c:333
-msgid "Name of the ground albedo coefficient input raster map [-]"
-msgstr ""
-#: ../raster/r.sun/main.c:342
-msgid "A single value of the ground albedo coefficient [-]"
-msgstr ""
-#: ../raster/r.sun/main.c:351
-msgid "Name of input raster map containing latitudes [decimal degrees]"
-msgstr ""
-#: ../raster/r.sun/main.c:360
-msgid "Name of input raster map containing longitudes [decimal degrees]"
-msgstr ""
-#: ../raster/r.sun/main.c:369
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
-msgstr ""
-#: ../raster/r.sun/main.c:378
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
-msgstr ""
-#: ../raster/r.sun/main.c:385
-msgid "The horizon information input map basename"
-msgstr ""
-#: ../raster/r.sun/main.c:393 ../raster/r.horizon/main.c:211
-msgid "Angle step size for multidirectional horizon [degrees]"
-msgstr ""
-#: ../raster/r.sun/main.c:402
-msgid "Output incidence angle raster map (mode 1 only)"
-msgstr ""
-#: ../raster/r.sun/main.c:411
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map "
-"[Wh.m-2.day-1] (mode 2)"
-msgstr ""
-#: ../raster/r.sun/main.c:420
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map "
-msgstr ""
-#: ../raster/r.sun/main.c:429
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-#: ../raster/r.sun/main.c:438
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or "
-"irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-#: ../raster/r.sun/main.c:447
-msgid "Output insolation time raster map [h] (mode 2 only)"
-msgstr ""
-#: ../raster/r.sun/main.c:454
-msgid "No. of day of the year (1-365)"
-msgstr ""
-#: ../raster/r.sun/main.c:456 ../raster/r.sun/main.c:465
-#: ../raster/r.sun/main.c:482 ../raster/r.sun/main.c:529
-#: ../raster/r.sunhours/main.c:103 ../raster/r.sunhours/main.c:112
-#: ../raster/r.sunhours/main.c:120 ../raster/r.sunhours/main.c:129
-#: ../raster/r.sunhours/main.c:138 ../raster/r.sunhours/main.c:147
-#: ../raster/r.sunmask/main.c:153 ../raster/r.sunmask/main.c:161
-#: ../raster/r.sunmask/main.c:169 ../raster/r.sunmask/main.c:177
-#: ../raster/r.sunmask/main.c:185 ../raster/r.sunmask/main.c:194
-#: ../raster/r.sunmask/main.c:203 ../imagery/i.landsat.toar/main.c:206
-msgid "Time"
-msgstr ""
-#: ../raster/r.sun/main.c:464
-msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr ""
-#: ../raster/r.sun/main.c:472
-msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr ""
-#: ../raster/r.sun/main.c:480
-msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr ""
-#: ../raster/r.sun/main.c:491
-msgid "Number of threads which will be used for parallel computing"
-msgstr ""
-#: ../raster/r.sun/main.c:513 ../raster/r.horizon/main.c:296
-msgid "Sampling distance step coefficient (0.5-1.5)"
-msgstr ""
-#: ../raster/r.sun/main.c:521
-msgid "Read the input files in this number of chunks"
-msgstr ""
-#: ../raster/r.sun/main.c:528
-msgid "Civil time zone value, if none, the time will be local solar time"
-msgstr ""
-#: ../raster/r.sun/main.c:534
-msgid "Do not incorporate the shadowing effect of terrain"
-msgstr ""
-#: ../raster/r.sun/main.c:539
-msgid "Use the low-memory version of the program"
-msgstr ""
-#: ../raster/r.sun/main.c:578
-#, c-format
-msgid ""
-"<%d> is not valid number of threads. Number of threads will be set to <%d>"
-msgstr ""
-#: ../raster/r.sun/main.c:587
-#, c-format
-msgid "Number of threads <%d>"
-msgstr ""
-#: ../raster/r.sun/main.c:594
-msgid "You must give the longitude raster if you use civil time"
-msgstr ""
-#: ../raster/r.sun/main.c:597
-msgid "Error reading civil time zone value"
-msgstr ""
-#: ../raster/r.sun/main.c:600
-msgid "Invalid civil time zone value"
-msgstr ""
-#: ../raster/r.sun/main.c:625
-msgid "insol_time and incidout are incompatible options"
-msgstr ""
-#: ../raster/r.sun/main.c:630
-msgid "Error reading time step size"
-msgstr ""
-#: ../raster/r.sun/main.c:632
-msgid "Invalid time step size"
-msgstr ""
-#: ../raster/r.sun/main.c:636
-msgid "Error reading horizon step size"
-msgstr ""
-#: ../raster/r.sun/main.c:641
-msgid "The horizon step size must be greater than 0."
-msgstr ""
-#: ../raster/r.sun/main.c:644
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
-#: ../raster/r.sun/main.c:650
-msgid "Time and insol_time are incompatible options"
-msgstr ""
-#: ../raster/r.sun/main.c:652
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
-msgstr ""
-#: ../raster/r.sun/main.c:657
-msgid "incidout requires time parameter to be set"
-msgstr ""
-#: ../raster/r.sun/main.c:659
-msgid "Mode 2: integrated daily irradiation for a given day of the year"
-msgstr ""
-#: ../raster/r.sun/main.c:682
-#, c-format
-msgid "Using Linke constant: %lf"
-msgstr ""
-#: ../raster/r.sun/main.c:684
-#, c-format
-msgid "Using Linke map <%s>"
-msgstr ""
-#: ../raster/r.sun/main.c:689
-#, c-format
-msgid "Using albedo constant: %lf"
-msgstr ""
-#: ../raster/r.sun/main.c:691
-#, c-format
-msgid "Using albedo map <%s>"
-msgstr ""
-#: ../raster/r.sun/main.c:696
-#, c-format
-msgid "Using slope constant: %lf"
-msgstr ""
-#: ../raster/r.sun/main.c:699
-#, c-format
-msgid "Using slope map <%s>"
-msgstr ""
-#: ../raster/r.sun/main.c:704
-#, c-format
-msgid "Using aspect constant: %lf"
-msgstr ""
-#: ../raster/r.sun/main.c:707
-#, c-format
-msgid "Using aspect map <%s>"
-msgstr ""
-#: ../raster/r.sun/main.c:722
-msgid "If you use -s and no horizon rasters, numpartitions must be =1"
-msgstr ""
-#: ../raster/r.sun/main.c:735
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
-msgstr ""
-#: ../raster/r.sun/main.c:780 ../raster/r.horizon/main.c:536
-#: ../general/g.region/printwindow.c:251 ../general/g.region/printwindow.c:475
-#: ../general/g.region/printwindow.c:542 ../display/d.where/main.c:107
-msgid "Can't get projection info of current location"
-msgstr ""
-#: ../raster/r.sun/main.c:784 ../raster/r.horizon/main.c:539
-#: ../general/g.region/printwindow.c:254 ../general/g.region/printwindow.c:478
-#: ../general/g.region/printwindow.c:547 ../display/d.where/main.c:110
-msgid "Can't get projection units of current location"
-msgstr ""
-#: ../raster/r.sun/main.c:788 ../raster/r.horizon/main.c:543
-#: ../general/g.region/printwindow.c:257 ../general/g.region/printwindow.c:481
-#: ../general/g.region/printwindow.c:550 ../display/d.where/main.c:113
-#: ../display/d.grid/plot.c:554 ../ps/ps.map/do_geogrid.c:272
-msgid "Can't get projection key values of current location"
-msgstr ""
-#: ../raster/r.sun/main.c:798 ../raster/r.horizon/main.c:553
-#: ../raster/r.latlong/main.c:114 ../display/d.where/main.c:120
-#: ../display/d.where/main.c:146 ../display/d.grid/plot.c:561
-#: ../display/d.grid/plot.c:588 ../ps/ps.map/do_geogrid.c:278
-msgid "Unable to set up lat/long projection parameters"
-msgstr ""
-#: ../raster/r.sun/main.c:802
-msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
-msgstr ""
-#: ../raster/r.sun/main.c:807
-msgid "Both latin and longin raster maps must be given, or neither"
-msgstr ""
-#: ../raster/r.carve/lobf.c:74
-msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-#: ../raster/r.carve/main.c:76
-msgid "Generates stream channels."
-msgstr ""
-#: ../raster/r.carve/main.c:77
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-#: ../raster/r.carve/main.c:82
-msgid "Name of input raster elevation map"
-msgstr ""
-#: ../raster/r.carve/main.c:87
-msgid "Name of input vector map containing stream(s)"
-msgstr ""
-#: ../raster/r.carve/main.c:95
-msgid "Name for output vector map for adjusted stream points"
-msgstr ""
-#: ../raster/r.carve/main.c:100
-msgid "Stream width (in meters)"
-msgstr ""
-#: ../raster/r.carve/main.c:101
-msgid "Default is raster cell width"
-msgstr ""
-#: ../raster/r.carve/main.c:106
-msgid "Additional stream depth (in meters)"
-msgstr ""
-#: ../raster/r.carve/main.c:110
-msgid "No flat areas allowed in flow direction"
-msgstr ""
-#: ../raster/r.carve/main.c:134
-#, c-format
-msgid "Invalid width value '%s' - using default."
-msgstr ""
-#: ../raster/r.carve/main.c:148
-#, c-format
-msgid "Invalid depth value '%s' - using default."
-msgstr ""
-#: ../raster/r.carve/main.c:158 ../raster/r.cost/main.c:325
-#: ../raster/r.walk/main.c:410 ../general/g.region/main.c:479
-#: ../display/d.extract/main.c:98 ../vector/v.outlier/main.c:176
-#: ../vector/v.vect.stats/main.c:273 ../vector/v.vect.stats/main.c:281
-#: ../vector/v.clean/test/topocheck.c:63
-#: ../vector/v.lidar.correction/main.c:157
-#: ../vector/v.lidar.growing/main.c:126 ../vector/v.colors/main.c:238
-#: ../vector/v.lidar.edgedetection/main.c:180
-#: ../vector/v.lrs/v.lrs.segment/main.c:140
-#: ../vector/v.lrs/v.lrs.label/main.c:268
-#: ../vector/v.lrs/v.lrs.where/main.c:127
-#: ../vector/v.lrs/v.lrs.where/main.c:136
-#: ../vector/v.lrs/v.lrs.create/main.c:251
-#: ../vector/v.lrs/v.lrs.create/main.c:260 ../vector/v.surf.bspline/main.c:263
-#: ../vector/v.surf.bspline/main.c:332 ../vector/v.edit/main.c:155
-#: ../vector/v.profile/main.c:359 ../vector/v.profile/main.c:363
-#: ../doc/vector/v.example/main.c:75 ../misc/m.nviz.image/vector.c:84
-#: ../scripts/v.pack/v.pack.py:65 ../scripts/v.report/v.report.py:74
-#: ../scripts/v.db.univar/v.db.univar.py:75 ../scripts/r.mask/r.mask.py:150
-#: ../scripts/v.dissolve/v.dissolve.py:68
-msgid "Vector map <%s> not found"
-msgstr ""
-#: ../raster/r.carve/main.c:213 ../raster/r.gwflow/main.c:222
-#: ../raster/r.topidx/main.c:57 ../raster/r.solute.transport/main.c:244
-#, c-format
-msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr ""
-#: ../raster/r.carve/raster.c:33 ../raster/r.in.poly/poly2rast.c:81
-#: ../vector/v.to.rast/vect2rast.c:179
-msgid "Writing raster map..."
-msgstr ""
-#: ../raster/r.carve/enforce_ds.c:83
-msgid "Processing lines... "
-msgstr ""
-#: ../raster/r.carve/enforce_ds.c:175
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-#: ../raster/r.horizon/main.c:182 ../raster/r.sunhours/main.c:75
-#: ../raster/r.sunmask/main.c:118
-msgid "sun position"
-msgstr ""
-#: ../raster/r.horizon/main.c:184
-msgid "Computes horizon angle height from a digital elevation model."
-msgstr ""
-#: ../raster/r.horizon/main.c:186
-msgid ""
-"The module has two different modes of operation: 1. Computes the entire "
-"horizon around a single point whose coordinates are given with the 'coord' "
-"option. The horizon height (in radians). 2. Computes one or more raster maps"
-" of the horizon height in a single direction. The input for this is the "
-"angle (in degrees), which is measured counterclockwise with east=0, north=90"
-" etc. The output is the horizon height in radians."
-msgstr ""
-#: ../raster/r.horizon/main.c:203
-msgid "Direction in which you want to know the horizon height"
-msgstr ""
-#: ../raster/r.horizon/main.c:220
-msgid "Start angle for multidirectional horizon [degrees]"
-msgstr ""
-#: ../raster/r.horizon/main.c:221 ../raster/r.horizon/main.c:230
-#: ../raster/r.horizon/main.c:238 ../raster/r.horizon/main.c:246
-#: ../raster/r.horizon/main.c:254 ../raster/r.horizon/main.c:262
-#: ../raster/r.horizon/main.c:270 ../raster/r.horizon/main.c:283
-msgid "Raster mode"
-msgstr ""
-#: ../raster/r.horizon/main.c:229
-msgid "End angle for multidirectional horizon [degrees]"
-msgstr ""
-#: ../raster/r.horizon/main.c:237
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
-msgstr ""
-#: ../raster/r.horizon/main.c:245
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
-msgstr ""
-#: ../raster/r.horizon/main.c:253
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
-msgstr ""
-#: ../raster/r.horizon/main.c:261
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present"
-" region"
-msgstr ""
-#: ../raster/r.horizon/main.c:269
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present"
-" region"
-msgstr ""
-#: ../raster/r.horizon/main.c:277
-msgid "The maximum distance to consider when finding the horizon height"
-msgstr ""
-#: ../raster/r.horizon/main.c:278 ../raster/r.horizon/main.c:297
-#: ../locale/scriptstrings/r.import_to_translate.c:27
-#: ../locale/scriptstrings/r.import_to_translate.c:29
-msgid "Optional"
-msgstr ""
-#: ../raster/r.horizon/main.c:288
-msgid "Coordinate for which you want to calculate the horizon"
-msgstr ""
-#: ../raster/r.horizon/main.c:289 ../raster/r.horizon/main.c:305
-msgid "Point mode"
-msgstr ""
-#: ../raster/r.horizon/main.c:310
-msgid "Write output in degrees (default is radians)"
-msgstr ""
-#: ../raster/r.horizon/main.c:315
-msgid "Write output in compass orientation (default is CCW, East=0)"
-msgstr ""
-#: ../raster/r.horizon/main.c:355
-msgid ""
-"Note: In latitude-longitude coordinate system specify buffers in degree unit"
-msgstr ""
-#: ../raster/r.horizon/main.c:368
-msgid "Can't read the coordinates from the \"coordinate\" option."
-msgstr ""
-#: ../raster/r.horizon/main.c:373
-msgid "Coordinates are outside of the current region"
-msgstr ""
-#: ../raster/r.horizon/main.c:400
-msgid "You didn't specify a direction value or step size. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:405
-msgid "You didn't specify a horizon raster name. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:420
-msgid "Negative values of start angle are not allowed. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:424
-msgid "End angle is not between 0 and 360. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:428
-msgid "You specify a start grater than the end angle. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:436
-msgid "You didn't specify an angle step size. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:447
-msgid "Could not read bufferzone size. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:452 ../raster/r.horizon/main.c:458
-#: ../raster/r.horizon/main.c:465 ../raster/r.horizon/main.c:472
-#, c-format
-msgid "Could not read %s bufferzone size. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:453
-msgid "east"
-msgstr ""
-#: ../raster/r.horizon/main.c:459
-msgid "west"
-msgstr ""
-#: ../raster/r.horizon/main.c:466
-msgid "south"
-msgstr ""
-#: ../raster/r.horizon/main.c:473
-msgid "north"
-msgstr ""
-#: ../raster/r.horizon/main.c:478
-msgid "Could not read maximum distance. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:489
-msgid "The distance value must be 0.5-1.5. Aborting."
-msgstr ""
-#: ../raster/r.horizon/main.c:851 ../raster/r.horizon/main.c:869
-#: ../raster/r.latlong/main.c:133 ../display/d.grid/plot.c:287
-#: ../display/d.grid/plot.c:293 ../display/d.grid/plot.c:334
-#: ../display/d.grid/plot.c:340 ../display/d.grid/plot.c:427
-#: ../display/d.grid/plot.c:433 ../display/d.grid/plot.c:485
-#: ../display/d.grid/plot.c:491 ../display/d.grid/plot.c:635
-#: ../display/d.grid/plot.c:651 ../display/d.grid/plot.c:668
-#: ../display/d.grid/plot.c:685 ../ps/ps.map/do_geogrid.c:86
-#: ../ps/ps.map/do_geogrid.c:91 ../ps/ps.map/do_geogrid.c:115
-#: ../ps/ps.map/do_geogrid.c:120 ../ps/ps.map/do_geogrid.c:189
-#: ../ps/ps.map/do_geogrid.c:230 ../ps/ps.map/do_geogrid.c:306
-#: ../ps/ps.map/do_geogrid.c:322 ../ps/ps.map/do_geogrid.c:339
-#: ../ps/ps.map/do_geogrid.c:356 ../ps/ps.map/do_geogrid.c:412
-#: ../ps/ps.map/do_geogrid.c:418 ../ps/ps.map/do_geogrid.c:422
-#: ../ps/ps.map/do_geogrid.c:430 ../ps/ps.map/do_geogrid.c:434
-msgid "Error in pj_do_proj"
-msgstr ""
-#: ../raster/r.horizon/main.c:1179
-#, c-format
-msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:151
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:162
-msgid "Desired east-west resolution"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:168
-msgid "Desired north-south resolution"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:173
-msgid "Name for output elevation raster map"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:179
-msgid "Name for output slope map (or fx)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:185
-msgid "Name for output aspect map (or fy)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:191
-msgid "Name for output profile curvature map (or fxx)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:197
-msgid "Name for output tangential curvature map (or fyy)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:203
-msgid "Name for output mean curvature map (or fxy)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:209
-msgid "Name of input raster map containing smoothing"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:215
-msgid "Name of input raster map to be used as mask"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:223
-msgid "Rows/columns overlap for segmentation"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:231
-msgid "Multiplier for z-values"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:239
-msgid "Spline tension value"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:246 ../vector/v.surf.rst/main.c:343
-msgid "Anisotropy angle (in degrees counterclockwise from East)"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:247 ../raster/r.resamp.rst/main.c:254
-msgid "Anisotropy"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:253 ../vector/v.surf.rst/main.c:350
-msgid "Anisotropy scaling factor"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:258
-msgid "Use dnorm independent tension"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:263 ../vector/v.surf.rst/main.c:173
-msgid "Output partial derivatives instead of topographic parameters"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:297
-msgid "Unable to read ew_res value"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:300
-msgid "Unable to read ns_res value"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:303
-msgid "Invalid value for tension"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:306
-msgid "Invalid value for zmult"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:309
-msgid "Invalid value for overlap"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:313
-msgid "Invalid value for theta"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:317
-msgid "Invalid value for scalex"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:319
-msgid "When using anisotropy both theta and scalex must be specified"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:357
-#, c-format
-msgid "Map <%s> is the wrong resolution"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:365
-msgid "Smoothing values can not be negative or NULL"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:371
-msgid "Input map resolution differs from current region resolution!"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:387
-msgid "Processing all selected output files will require"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:391
-#, c-format
-msgid "%.2f GB of disk space for temp files."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:394
-#, c-format
-msgid "%.2f MB of disk space for temp files."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:397
-#, c-format
-msgid "%.2f KB of disk space for temp files."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:400
-#, c-format
-msgid "%d byte of disk space for temp files."
-msgid_plural "%d bytes of disk space for temp files."
-msgstr[0] ""
-#: ../raster/r.resamp.rst/main.c:436
-msgid "Maximum value of a raster map is NULL."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:464
-msgid "Temporarily changing the region to desired resolution ..."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:469
-msgid "Changing back to the original region ..."
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:478 ../raster/r.resample/main.c:112
-msgid "Percent complete: "
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:490
-#, c-format
-msgid "dnorm in mainc after grid before out1= %f"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:494
-msgid "split_and_interpolate() failed"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:509
-#, c-format
-msgid "dnorm in mainc after grid before out2= %f"
-msgstr ""
-#: ../raster/r.resamp.rst/main.c:515
-msgid "Unable to write raster maps -- try increasing cell size"
-msgstr ""
-#: ../raster/r.out.pov/main.c:124
-msgid "Converts a raster map layer into a height-field file for POV-Ray."
-msgstr ""
-#: ../raster/r.out.pov/main.c:131
-msgid "Name of output povray file (TGA height field file)"
-msgstr ""
-#: ../raster/r.out.pov/main.c:138
-msgid "Height-field type (0=actual heights 1=normalized)"
-msgstr ""
-#: ../raster/r.out.pov/main.c:144
-msgid "Elevation bias"
-msgstr ""
-#: ../raster/r.out.pov/main.c:150 ../raster/r.param.scale/interface.c:118
-msgid "Vertical scaling factor"
-msgstr ""
-#: ../raster/r.out.pov/main.c:170
-#, c-format
-msgid "Invalid output filename <%s>"
-msgstr ""
-#: ../raster/r.out.pov/main.c:180
-#, c-format
-msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr ""
-#: ../raster/r.out.pov/main.c:201
-msgid "Negative elevation values in input"
-msgstr ""
-#: ../raster/r.flow/io.c:87
-msgid "Elevation raster map resolution differs from current region resolution"
-msgstr ""
-#: ../raster/r.flow/io.c:89 ../raster/r.flow/io.c:107
-#: ../raster/r.buffer/read_map.c:52
-#, c-format
-msgid "Reading input raster map <%s>..."
-msgstr ""
-#: ../raster/r.flow/io.c:104
-msgid "Resolution of aspect file differs from current region resolution"
-msgstr ""
-#: ../raster/r.flow/io.c:121
-msgid "Reading input files: barrier"
-msgstr ""
-#: ../raster/r.flow/io.c:149
-#, c-format
-msgid "Cannot create segment file %s"
-msgstr ""
-#: ../raster/r.flow/io.c:154
-#, c-format
-msgid "Cannot format segment file %s"
-msgstr ""
-#: ../raster/r.flow/io.c:160
-#, c-format
-msgid "Cannot open segment file %s"
-msgstr ""
-#: ../raster/r.flow/io.c:207 ../raster/r.buffer/write_map.c:45
-#: ../raster/r.cost/main.c:1034
-#, c-format
-msgid "Writing output raster map <%s>..."
-msgstr ""
-#: ../raster/r.flow/main.c:314 ../raster/r.topidx/topidx.c:41
-#: ../imagery/i.landsat.toar/main.c:534
-msgid "Calculating..."
-msgstr ""
-#: ../raster/r.flow/main.c:423
-msgid "Constructs flowlines."
-msgstr ""
-#: ../raster/r.flow/main.c:425
-msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
-msgstr ""
-#: ../raster/r.flow/main.c:434
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
-msgid "Name of input aspect raster map"
-msgstr ""
-#: ../raster/r.flow/main.c:440
-msgid "Name of input barrier raster map"
-msgstr ""
-#: ../raster/r.flow/main.c:447
-msgid "Number of cells between flowlines"
-msgstr ""
-#: ../raster/r.flow/main.c:453
-msgid "Maximum number of segments per flowline"
-msgstr ""
-#: ../raster/r.flow/main.c:458
-msgid "Name for output flow line vector map"
-msgstr ""
-#: ../raster/r.flow/main.c:464
-msgid "Name for output flow path length raster map"
-msgstr ""
-#: ../raster/r.flow/main.c:470
-msgid "Name for output flow accumulation raster map"
-msgstr ""
-#: ../raster/r.flow/main.c:476
-msgid "Compute upslope flowlines instead of default downhill flowlines"
-msgstr ""
-#: ../raster/r.flow/main.c:480
-msgid "3D lengths instead of 2D"
-msgstr ""
-#: ../raster/r.flow/main.c:484
-msgid "Use less memory, at a performance penalty"
-msgstr ""
-#: ../raster/r.flow/main.c:539
-msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr ""
-#: ../raster/r.flow/main.c:555
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
-msgstr ""
-#: ../raster/r.flow/mem.c:40
-#, c-format
-msgid "Unable to write segment file for %s"
-msgstr ""
-#: ../raster/r.flow/precomp.c:48
-msgid "Precomputing e/w distances..."
-msgstr ""
-#: ../raster/r.flow/precomp.c:50
-msgid "Precomputing quantization tolerances..."
-msgstr ""
-#: ../raster/r.flow/precomp.c:53
-msgid "Precomputing inverted elevations..."
-msgstr ""
-#: ../raster/r.flow/precomp.c:57
-msgid "Precomputing interpolated border elevations..."
-msgstr ""
-#: ../raster/r.flow/precomp.c:63
-msgid "Precomputing re-oriented aspects..."
-msgstr ""
-#: ../raster/r.flow/precomp.c:67
-msgid "Precomputing aspects..."
-msgstr ""
-#: ../raster/r.flow/precomp.c:111
-#, c-format
-msgid ""
-"Resolution too unbalanced:\n"
-"atan2(%f deg, %f deg) =%f < %f tolerance\n"
-"please resample input map"
-msgstr ""
-#: ../raster/r.flow/precomp.c:116
-#, c-format
-msgid "Resolution too unbalanced (%f x %f); please resample input map"
-msgstr ""
-#: ../raster/r.info/main.c:72 ../general/g.region/main.c:67
-#: ../vector/v.info/main.c:40 ../raster3d/r3.info/main.c:78
-#: ../locale/scriptstrings/t.info_to_translate.c:4
-msgid "extent"
-msgstr ""
-#: ../raster/r.info/main.c:73 ../vector/v.info/main.c:41
-msgid "history"
-msgstr ""
-#: ../raster/r.info/main.c:75
-msgid "Outputs basic information about a raster map."
-msgstr ""
-#: ../raster/r.info/main.c:81
-msgid "Print raster array information in shell script style"
-msgstr ""
-#: ../raster/r.info/main.c:85
-msgid "Print range in shell script style"
-msgstr ""
-#: ../raster/r.info/main.c:89
-msgid "Print extended metadata information in shell script style"
-msgstr ""
-#: ../raster/r.info/main.c:93 ../raster3d/r3.info/main.c:94
-msgid "Print raster history instead of info"
-msgstr ""
-#: ../raster/r.info/main.c:99
-#, c-format
-msgid "Flags -%c and -%c/%c/%c are mutually exclusive"
-msgstr ""
-#: ../raster/r.info/main.c:127
-msgid "Unable to read range file"
-msgstr ""
-#: ../raster/r.info/main.c:303 ../raster/r.info/main.c:445
-#: ../raster3d/r3.info/main.c:138 ../raster3d/r3.info/main.c:145
-#: ../raster3d/r3.info/main.c:151 ../raster3d/r3.info/main.c:156
-#: ../raster3d/r3.info/main.c:162 ../raster3d/r3.info/main.c:167
-#: ../raster3d/r3.info/main.c:172 ../raster3d/r3.info/main.c:183
-#: ../raster3d/r3.info/main.c:189 ../raster3d/r3.info/main.c:204
-#: ../raster3d/r3.info/main.c:211 ../raster3d/r3.info/main.c:218
-#: ../raster3d/r3.info/main.c:223 ../raster3d/r3.info/main.c:228
-#: ../raster3d/r3.info/main.c:235 ../raster3d/r3.info/main.c:245
-#: ../raster3d/r3.info/main.c:251 ../raster3d/r3.info/main.c:257
-#: ../raster3d/r3.info/main.c:273 ../raster3d/r3.info/main.c:280
-#: ../raster3d/r3.info/main.c:287 ../raster3d/r3.info/main.c:296
-#: ../raster3d/r3.info/main.c:306 ../raster3d/r3.info/main.c:316
-#: ../raster3d/r3.info/main.c:326 ../raster3d/r3.info/main.c:346
-#: ../raster3d/r3.info/main.c:356 ../raster3d/r3.info/main.c:361
-#: ../raster3d/r3.info/main.c:369 ../raster3d/r3.info/main.c:382
-msgid "Cannot allocate memory for string"
-msgstr ""
-#: ../raster/r.random.cells/random.c:50
-#, c-format
-msgid "RAN1: j == %d shouldn't happen"
-msgstr ""
-#: ../raster/r.random.cells/indep.c:139 ../raster/r.composite/main.c:191
-#: ../raster/r.drain/main.c:522 ../raster/r.random.surface/save.c:98
-#: ../imagery/i.ifft/main.c:207
-#, c-format
-msgid "Writing raster map <%s>..."
-msgstr ""
-#: ../raster/r.random.cells/init.c:77
-msgid "Distance must be >= 0.0"
-msgstr ""
-#: ../raster/r.random.cells/init.c:96 ../raster/r.random.surface/main.c:128
-#, c-format
-msgid "Generating raster map <%s>..."
-msgstr ""
-#: ../raster/r.random.cells/main.c:48 ../raster/r.random/main.c:52
-#: ../display/d.where/main.c:44 ../vector/v.what.rast3/main.c:65
-#: ../vector/v.sample/main.c:76 ../vector/v.random/main.c:98
-#: ../vector/v.what.rast/main.c:72 ../vector/v.drape/main.c:58
-#: ../vector/v.extrude/main.c:69
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:4
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-#: ../locale/scriptstrings/t.sample_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:3
-msgid "sampling"
-msgstr ""
-#: ../raster/r.random.cells/main.c:50
-msgid "autocorrelation"
-msgstr ""
-#: ../raster/r.random.cells/main.c:52
-msgid "Generates random cell values with spatial dependence."
-msgstr ""
-#: ../raster/r.random.cells/main.c:62 ../raster/r.random.surface/main.c:77
-msgid "Maximum distance of spatial correlation (value >= 0.0)"
-msgstr ""
-#: ../raster/r.random.cells/main.c:70
-msgid "Maximum number of cells to be created"
-msgstr ""
-#: ../raster/r.random.cells/main.c:77
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
-msgstr ""
-#: ../raster/r.gwflow/main.c:57
-msgid "Name of input raster map with initial piezometric head in [m]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:62
-msgid ""
-"Name of input raster map providing boundary condition status: 0-inactive, "
-"1-active, 2-dirichlet"
-msgstr ""
-#: ../raster/r.gwflow/main.c:67
-msgid ""
-"Name of input raster map with x-part of the hydraulic conductivity tensor in"
-" [m/s]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:72
-msgid ""
-"Name of input raster map with y-part of the hydraulic conductivity tensor in"
-" [m/s]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:77
-msgid "Name of input raster map with water sources and sinks in [m^3/s]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:81
-msgid ""
-"Name of input raster map with storativity for confined or effective porosity"
-" for unconfined groundwater flow booth in [-] "
-msgstr ""
-#: ../raster/r.gwflow/main.c:86
-msgid "Recharge"
-msgstr ""
-#: ../raster/r.gwflow/main.c:88
-msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:92
-msgid ""
-"Name of input raster map describing the top surface of the aquifer in [m]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:96
-msgid ""
-"Name of input raster map describing the bottom surface of the aquifer in [m]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:100
-msgid "Output raster map storing the numerical result [m]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:106
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in x "
-"direction [m/s]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:112
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in y "
-"direction [m/s]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:118
-msgid ""
-"Output raster map to store the groundwater budget for each cell [m^3/s]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:126
-msgid "The type of groundwater flow"
-msgstr ""
-#: ../raster/r.gwflow/main.c:132
-msgid "Name of input raster map providing the height of the river bed in [m]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:140
-msgid ""
-"Name of input raster map providing the water level (head) of the river with "
-"leakage connection in [m]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:147
-msgid ""
-"Name of input raster map providing the leakage coefficient of the river bed "
-"in [1/s]."
-msgstr ""
-#: ../raster/r.gwflow/main.c:155
-msgid ""
-"Name of input raster map providing the height of the drainage bed in [m]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:162
-msgid ""
-"Name of input raster map providing the leakage coefficient of the drainage "
-"bed in [1/s]"
-msgstr ""
-#: ../raster/r.gwflow/main.c:167
-msgid "The maximum number of iterations in the linearization approach"
-msgstr ""
-#: ../raster/r.gwflow/main.c:176
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear"
-" equation system."
-msgstr ""
-#: ../raster/r.gwflow/main.c:209 ../raster3d/r3.gwflow/main.c:160
-msgid "groundwater flow"
-msgstr ""
-#: ../raster/r.gwflow/main.c:212
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
-msgstr ""
-#: ../raster/r.gwflow/main.c:237
-msgid "Please provide river_head, river_leak and river_bed maps"
-msgstr ""
-#: ../raster/r.gwflow/main.c:249
-msgid "Please provide drain_head and drain_leak maps"
-msgstr ""
-#: ../raster/r.gwflow/main.c:263
-msgid ""
-"The cholesky solver dos not work with sparse matrices. You may choose a full"
-" filled quadratic matrix, flag -f."
-msgstr ""
-#: ../raster/r.gwflow/main.c:293
-#, c-format
-msgid "Calculation time: %g"
-msgstr ""
-#: ../raster/r.gwflow/main.c:380
-#, c-format
-msgid "Calculation of unconfined groundwater flow loop %i"
-msgstr ""
-#: ../raster/r.gwflow/main.c:403
-#, c-format
-msgid "Maximum difference between this and last increment: %g"
-msgstr ""
-#: ../raster/r.gwflow/main.c:546 ../raster3d/r3.gwflow/main.c:279
-msgid "Unable to create and solve the linear equation system"
-msgstr ""
-#: ../raster/r.coin/main.c:69
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-#: ../raster/r.coin/main.c:74
-msgid "Name of first input raster map"
-msgstr ""
-#: ../raster/r.coin/main.c:78
-msgid "Name of second input raster map"
-msgstr ""
-#: ../raster/r.coin/main.c:84
-msgid "Unit of measure"
-msgstr ""
-#: ../raster/r.coin/main.c:86
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr ""
-#: ../raster/r.coin/main.c:93
-msgid "Wide report, 132 columns (default: 80)"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:48
-#, c-format
-msgid "Tabulating Coincidence between '%s' and '%s'"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:61
-msgid "Unable to create any tempfiles"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:65
-msgid "Unable to run r.stats"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:72
-msgid "Unexpected output from r.stats"
-msgstr ""
-#: ../raster/r.coin/make_coin.c:84
-msgid "Unable to open tempfile"
-msgstr ""
-#: ../raster/r.coin/print_coin.c:44
-#, c-format
-msgid "Preparing report ..."
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:40
-msgid "fractal"
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:42
-msgid "Creates a fractal surface of a given fractal dimension."
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:48
-msgid "Fractal dimension of surface (2 < D < 3)"
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:55
-msgid "Number of intermediate images to produce"
-msgstr ""
-#: ../raster/r.surf.fractal/main.c:79
-#, c-format
-msgid "Fractal dimension of %.2lf must be between 2 and 3."
-msgstr ""
-#: ../raster/r.surf.fractal/process.c:54
-msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr ""
-#: ../raster/r.surf.fractal/spec_syn.c:60
-msgid "Preliminary surface calculations..."
-msgstr ""
-#: ../raster/r.surf.fractal/spec_syn.c:119
-#, c-format
-msgid "Calculating surface %d (of %d)..."
-msgstr ""
-#: ../raster/r.buffer/execute.c:34
-msgid "Finding buffer zones..."
-msgstr ""
-#: ../raster/r.buffer/main.c:69
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain "
-"non-NULL category values."
-msgstr ""
-#: ../raster/r.buffer/main.c:81
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
-msgid "Distance zone(s)"
-msgstr ""
-#: ../raster/r.buffer/main.c:88
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:7
-msgid "Units of distance"
-msgstr ""
-#: ../raster/r.buffer/main.c:94
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
-msgid "Ignore zero (0) data cells instead of NULL cells"
-msgstr ""
-#: ../raster/r.buffer/main.c:131
-msgid "Parse distances error"
-msgstr ""
-#: ../raster/r.buffer/main.c:150
-#, c-format
-msgid "Pass %d (of %d)"
-msgstr ""
-#: ../raster/r.buffer/parse_dist.c:54
-#, c-format
-msgid "%s: %s - illegal distance specification"
-msgstr ""
-#: ../raster/r.stats.zonal/main.c:105
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
-msgstr ""
-#: ../raster/r.stats.zonal/main.c:149 ../raster/r.stats.quantile/main.c:564
-msgid "Create reclass map with statistics as category labels"
-msgstr ""
-#: ../raster/r.stats.zonal/main.c:178
-#, c-format
-msgid "Unable to read category file of cover map <%s>"
-msgstr ""
-#: ../raster/r.stats.zonal/main.c:181 ../raster/r.stats.quantile/main.c:624
-msgid "The base map must be an integer (CELL) map"
-msgstr ""
-#: ../raster/r.stats.zonal/main.c:184 ../raster/r.stats.quantile/main.c:627
-#, c-format
-msgid "Unable to read range of base map <%s>"
-msgstr ""
-#: ../raster/r.stats.zonal/main.c:248
-msgid "First pass"
-msgstr ""
-#: ../raster/r.stats.zonal/main.c:327
-msgid "Second pass"
-msgstr ""
-#: ../raster/r.stats.zonal/main.c:474
-msgid "Generating reclass map"
-msgstr ""
-#: ../raster/r.stats.zonal/main.c:496
-msgid "Writing output map"
-msgstr ""
-#: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
-msgstr ""
-#: ../raster/r.covar/main.c:61
-msgid "Print correlation matrix"
-msgstr ""
-#: ../raster/r.covar/main.c:86
-#, c-format
-msgid "%s: complete ... "
-msgstr ""
-#: ../raster/r.covar/main.c:110 ../imagery/i.pca/main.c:197
-msgid "No non-null values"
-msgstr ""
-#: ../raster/r.regression.multi/main.c:61
-msgid "Matrix is unsolvable"
-msgstr ""
-#: ../raster/r.regression.multi/main.c:131
-#: ../raster/r.regression.line/main.c:48
-msgid "regression"
-msgstr ""
-#: ../raster/r.regression.multi/main.c:133
-msgid "Calculates multiple linear regression from raster maps."
-msgstr ""
-#: ../raster/r.regression.multi/main.c:138
-#: ../raster/r.regression.line/main.c:55
-msgid "Map for x coefficient"
-msgstr ""
-#: ../raster/r.regression.multi/main.c:142
-#: ../raster/r.regression.line/main.c:59
-msgid "Map for y coefficient"
-msgstr ""
-#: ../raster/r.regression.multi/main.c:147
-msgid "Map to store residuals"
-msgstr ""
-#: ../raster/r.regression.multi/main.c:152
-msgid "Map to store estimates"
-msgstr ""
-#: ../raster/r.regression.multi/main.c:158
-#: ../raster/r.regression.line/main.c:65
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not"
-" specified)."
-msgstr ""
-#: ../raster/r.regression.multi/main.c:162
-#: ../raster/r.regression.line/main.c:69 ../general/g.region/main.c:147
-#: ../imagery/i.group/main.c:88 ../locale/scriptstrings/i.oif_to_translate.c:6
-#: ../locale/scriptstrings/t.info_to_translate.c:9
-msgid "Print in shell script style"
-msgstr ""
-#: ../raster/r.regression.multi/main.c:250
-msgid "First pass..."
-msgstr ""
-#: ../raster/r.regression.multi/main.c:323
-msgid "Not enough valid cells available"
-msgstr ""
-#: ../raster/r.regression.multi/main.c:337
-msgid "Multiple regression failed"
-msgstr ""
-#: ../raster/r.regression.multi/main.c:342
-msgid "Second pass..."
-msgstr ""
-#: ../raster/r.volume/main.c:77 ../raster3d/r3.stats/main.c:51
-msgid "volume"
-msgstr ""
-#: ../raster/r.volume/main.c:78 ../raster/r.clump/main.c:61
-msgid "clumps"
-msgstr ""
-#: ../raster/r.volume/main.c:80
-msgid "Calculates the volume of data \"clumps\"."
-msgstr ""
-#: ../raster/r.volume/main.c:81
-msgid ""
-"Optionally produces a GRASS vector points map containing the calculated "
-"centroids of these clumps."
-msgstr ""
-#: ../raster/r.volume/main.c:86
-msgid ""
-"Name of input raster map representing data that will be summed within clumps"
-msgstr ""
-#: ../raster/r.volume/main.c:92
-msgid "Name of input clump raster map"
-msgstr ""
-#: ../raster/r.volume/main.c:93
-msgid ""
-"Preferably the output of r.clump. If no clump map is given than MASK is "
-"used."
-msgstr ""
-#: ../raster/r.volume/main.c:99
-msgid "Name for output vector points map to contain clump centroids"
-msgstr ""
-#: ../raster/r.volume/main.c:104 ../raster/r.report/parse.c:63
-msgid "Name for output file to hold the report"
-msgstr ""
-#: ../raster/r.volume/main.c:106 ../raster/r.report/parse.c:65
-msgid "If no output file given report is printed to standard output"
-msgstr ""
-#: ../raster/r.volume/main.c:110
-msgid "Generate unformatted report (items separated by colon)"
-msgstr ""
-#: ../raster/r.volume/main.c:143
-msgid ""
-"No MASK found. If no clump map is given than the MASK is required. You need "
-"to define a clump raster map or create a MASK by r.mask command."
-msgstr ""
-#: ../raster/r.volume/main.c:145
-msgid "No clump map given, using MASK"
-msgstr ""
-#: ../raster/r.volume/main.c:198
-#, c-format
-msgid "Invalid category value %d (max=%d): row=%d col=%d"
-msgstr ""
-#: ../raster/r.volume/main.c:231
-#, c-format
-msgid "Creating vector point map <%s>..."
-msgstr ""
-#: ../raster/r.volume/main.c:233
-#, c-format
-msgid "From '%s' on raster map <%s> using clumps from <%s>"
-msgstr ""
-#: ../raster/r.volume/main.c:243 ../raster/r.contour/main.c:172
-#: ../raster/r.random/random.c:73 ../raster/r.to.vect/main.c:188
-#: ../display/d.vect.chart/plot.c:44 ../display/d.vect.thematic/plot1.c:111
-#: ../display/d.vect/attr.c:43 ../display/d.vect/shape.c:44
-#: ../vector/v.out.postgis/table.c:34 ../vector/v.patch/main.c:156
-#: ../vector/v.patch/main.c:188 ../vector/v.patch/main.c:309
-#: ../vector/v.patch/main.c:391 ../vector/v.vol.rst/main.c:602
-#: ../vector/v.vol.rst/user1.c:99 ../vector/v.to.3d/trans2.c:55
-#: ../vector/v.to.3d/trans3.c:57 ../vector/v.out.svg/main.c:159
-#: ../vector/v.to.rast/support.c:109 ../vector/v.to.rast/support.c:287
-#: ../vector/v.to.rast/support.c:526 ../vector/v.to.rast/vect2rast.c:60
-#: ../vector/v.to.db/query.c:89 ../vector/v.to.db/update.c:48
-#: ../vector/v.mkgrid/main.c:278 ../vector/v.net.timetable/main.c:93
-#: ../vector/v.in.db/main.c:164 ../vector/v.in.db/main.c:302
-#: ../vector/v.net.alloc/main.c:316 ../vector/v.db.select/main.c:177
-#: ../vector/v.kcv/main.c:126 ../vector/v.transform/trans_digit.c:41
-#: ../vector/v.reclass/main.c:133 ../vector/v.net.components/main.c:180
-#: ../vector/v.net.centrality/main.c:246 ../vector/v.db.connect/main.c:223
-#: ../vector/v.db.connect/main.c:331 ../vector/v.out.vtk/writeVTK.c:649
-#: ../vector/v.select/copy_tabs.c:82 ../vector/v.net.distance/main.c:279
-#: ../vector/v.class/main.c:117 ../vector/v.overlay/main.c:246
-#: ../vector/v.overlay/main.c:413 ../vector/v.extract/main.c:263
-#: ../vector/v.net.allpairs/main.c:166 ../vector/v.what.rast3/main.c:126
-#: ../vector/v.sample/main.c:179 ../vector/v.random/main.c:239
-#: ../vector/v.colors/read_rgb.c:28 ../vector/v.colors/scan_attr.c:29
-#: ../vector/v.colors/write_rgb.c:25 ../vector/v.net.flow/main.c:169
-#: ../vector/v.to.points/main.c:177 ../vector/v.net.path/path.c:96
-#: ../vector/v.in.ogr/main.c:1136 ../vector/v.in.ogr/main.c:1182
-#: ../vector/v.what.rast/main.c:144 ../vector/v.colors.out/make_colors.c:36
-#: ../vector/v.out.ogr/main.c:634 ../vector/v.to.rast3/main.c:84
-#: ../vector/v.info/print.c:147 ../vector/v.lrs/v.lrs.create/main.c:296
-#: ../vector/v.lrs/v.lrs.create/main.c:305 ../vector/v.in.dwg/main.c:213
-#: ../vector/v.in.ascii/main.c:348 ../vector/v.surf.bspline/crosscorr.c:123
-#: ../vector/v.surf.bspline/main.c:384 ../vector/v.distance/main.c:527
-#: ../vector/v.distance/main.c:562 ../vector/v.distance/main.c:608
-#: ../vector/v.distance/main.c:1348 ../vector/v.distance/main.c:1367
-#: ../vector/v.surf.rst/main.c:623 ../vector/v.label/main.c:278
-#: ../vector/v.normal/main.c:122 ../vector/v.extrude/main.c:229
-#: ../vector/v.net.iso/main.c:376 ../vector/v.surf.idw/read_sites.c:55
-#: ../vector/v.edit/select.c:516 ../vector/v.in.dxf/write_vect.c:211
-#: ../vector/v.buffer/main.c:431 ../vector/v.profile/main.c:426
-#: ../vector/v.profile/main.c:580 ../vector/v.label.sa/labels.c:78
-#: ../raster3d/r3.flow/main.c:46 ../doc/vector/v.example/main.c:137
-#: ../ps/ps.map/catval.c:53 ../ps/ps.map/catval.c:115
-#: ../ps/ps.map/catval.c:181 ../misc/m.nviz.image/vector.c:293
-#, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-msgstr ""
-#: ../raster/r.volume/main.c:260 ../raster/r.to.vect/main.c:229
-#: ../vector/v.mkgrid/main.c:342 ../vector/v.mkgrid/main.c:400
-#: ../vector/v.random/main.c:253 ../vector/v.lrs/v.lrs.create/main.c:338
-#: ../vector/v.in.ascii/main.c:415 ../vector/v.in.dxf/write_vect.c:233
-#: ../raster3d/r3.flow/main.c:64
-#, c-format
-msgid "Unable to create table: %s"
-msgstr ""
-#: ../raster/r.volume/main.c:266
-#, c-format
-msgid ""
-"\n"
-"Volume report on data from <%s> using clumps on <%s> raster map"
-msgstr ""
-#: ../raster/r.volume/main.c:270
-#, c-format
-msgid "Category   Average   Data   # Cells        Centroid             Total\n"
-msgstr ""
-#: ../raster/r.volume/main.c:272
-#, c-format
-msgid "Number     in clump  Total  in clump   Easting     Northing     Volume"
-msgstr ""
-#: ../raster/r.volume/main.c:296 ../raster/r.to.vect/util.c:157
-#: ../raster/r.to.vect/areas_io.c:359 ../vector/v.vol.rst/vector.c:80
-#: ../vector/v.in.lidar/attributes.c:240 ../vector/v.random/main.c:470
-#: ../vector/v.random/main.c:594
-#, c-format
-msgid "Cannot insert new row: %s"
-msgstr ""
-#: ../raster/r.volume/main.c:319
-msgid "Total Volume"
-msgstr ""
-#: ../raster/r.kappa/calc_kappa.c:32
-#, c-format
-msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr ""
-#: ../raster/r.kappa/main.c:70 ../imagery/i.gensig/main.c:40
-#: ../imagery/i.smap/main.c:39 ../imagery/i.cluster/main.c:76
-#: ../imagery/i.segment/main.c:38 ../imagery/i.gensigset/main.c:41
-#: ../imagery/i.maxlik/main.c:62 ../vector/v.class/main.c:46
-msgid "classification"
-msgstr ""
-#: ../raster/r.kappa/main.c:72
-msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-#: ../raster/r.kappa/main.c:78
-msgid "Name of raster map containing classification result"
-msgstr ""
-#: ../raster/r.kappa/main.c:83
-msgid "Name of raster map containing reference classes"
-msgstr ""
-#: ../raster/r.kappa/main.c:88
-msgid "Name for output file containing error matrix and kappa"
-msgstr ""
-#: ../raster/r.kappa/main.c:90 ../raster/r.kappa/main.c:98
-#: ../raster/r.univar/r.univar_main.c:42 ../ps/ps.map/main.c:100
-#: ../ps/ps.map/main.c:113 ../ps/ps.map/main.c:135
-#: ../locale/scriptstrings/r.unpack_to_translate.c:7
-#: ../locale/scriptstrings/r.unpack_to_translate.c:10
-#: ../locale/scriptstrings/v.unpack_to_translate.c:8
-#: ../locale/scriptstrings/v.unpack_to_translate.c:11
-msgid "Output settings"
-msgstr ""
-#: ../raster/r.kappa/main.c:96
-msgid "Title for error matrix and kappa"
-msgstr ""
-#: ../raster/r.kappa/main.c:102
-msgid "Wide report"
-msgstr ""
-#: ../raster/r.kappa/main.c:103
-msgid "132 columns (default: 80)"
-msgstr ""
-#: ../raster/r.kappa/main.c:108
-msgid "No header in the report"
-msgstr ""
-#: ../raster/r.kappa/prt_hdr.c:18
-#, c-format
-msgid "Cannot open file <%s> to write header"
-msgstr ""
-#: ../raster/r.kappa/prt_label.c:17
-#, c-format
-msgid "Can't open file <%s> to write label"
-msgstr ""
-#: ../raster/r.kappa/prt_mat.c:39
-#, c-format
-msgid "Cannot open file <%s> to write cats and counts (error matrix)"
-msgstr ""
-#: ../raster/r.kappa/stats.c:14 ../raster/r.report/stats.c:128
-msgid "Problem reading r.stats output"
-msgstr ""
-#: ../raster/r.cost/main.c:141 ../raster/r.drain/main.c:111
-#: ../raster/r.walk/main.c:179
-msgid "cost surface"
-msgstr ""
-#: ../raster/r.cost/main.c:142 ../raster/r.spreadpath/main.c:90
-#: ../raster/r.walk/main.c:180
-msgid "cumulative costs"
-msgstr ""
-#: ../raster/r.cost/main.c:143 ../raster/r.walk/main.c:181
-#: ../vector/v.net.alloc/main.c:66 ../vector/v.net.iso/main.c:78
-msgid "cost allocation"
-msgstr ""
-#: ../raster/r.cost/main.c:145
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different"
-" geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-#: ../raster/r.cost/main.c:152
-msgid "Name of input raster map containing grid cell cost information"
-msgstr ""
-#: ../raster/r.cost/main.c:160
-msgid "Name for output raster map with nearest start point"
-msgstr ""
-#: ../raster/r.cost/main.c:161 ../raster/r.cost/main.c:168
-#: ../raster/r.walk/main.c:203
-msgid "Optional outputs"
-msgstr ""
-#: ../raster/r.cost/main.c:167 ../raster/r.walk/main.c:202
-msgid "Name for output raster map to contain movement directions"
-msgstr ""
-#: ../raster/r.cost/main.c:173 ../raster/r.walk/main.c:208
-msgid "Name of starting vector points map"
-msgstr ""
-#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:186
-#: ../raster/r.cost/main.c:193 ../raster/r.cost/main.c:243
-#: ../raster/r.drain/main.c:139 ../raster/r.drain/main.c:146
-#: ../raster/r.walk/main.c:209 ../raster/r.walk/main.c:221
-#: ../raster/r.walk/main.c:228 ../raster/r.walk/main.c:309
-msgid "Start"
-msgstr ""
-#: ../raster/r.cost/main.c:179 ../raster/r.walk/main.c:214
-msgid "Name of stopping vector points map"
-msgstr ""
-#: ../raster/r.cost/main.c:180 ../raster/r.cost/main.c:200
-#: ../raster/r.walk/main.c:215 ../raster/r.walk/main.c:235
-msgid "Stop"
-msgstr ""
-#: ../raster/r.cost/main.c:185 ../raster/r.walk/main.c:220
-msgid "Name of starting raster points map"
-msgstr ""
-#: ../raster/r.cost/main.c:192 ../raster/r.drain/main.c:138
-#: ../raster/r.walk/main.c:227
-msgid "Coordinates of starting point(s) (E,N)"
-msgstr ""
-#: ../raster/r.cost/main.c:199 ../raster/r.walk/main.c:234
-msgid "Coordinates of stopping point(s) (E,N)"
-msgstr ""
-#: ../raster/r.cost/main.c:209 ../raster/r.walk/main.c:244
-msgid "Maximum cumulative cost"
-msgstr ""
-#: ../raster/r.cost/main.c:218 ../raster/r.walk/main.c:253
-msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-#: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:238
-#: ../raster/r.walk/main.c:254 ../raster/r.walk/main.c:304
-msgid "NULL cells"
-msgstr ""
-#: ../raster/r.cost/main.c:228 ../raster/r.walk/main.c:263
-msgid "Maximum memory to be used in MB"
-msgstr ""
-#: ../raster/r.cost/main.c:233 ../raster/r.walk/main.c:299
-msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr ""
-#: ../raster/r.cost/main.c:237 ../raster/r.walk/main.c:303
-msgid "Keep null values in output raster map"
-msgstr ""
-#: ../raster/r.cost/main.c:242 ../raster/r.walk/main.c:308
-msgid "Start with values in raster map"
-msgstr ""
-#: ../raster/r.cost/main.c:247 ../raster/r.walk/main.c:313
-msgid "Print info about disk space and memory requirements and exit"
-msgstr ""
-#: ../raster/r.cost/main.c:297 ../raster/r.walk/main.c:357
-msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr ""
-#: ../raster/r.cost/main.c:302 ../raster/r.cost/main.c:712
-#: ../raster/r.walk/main.c:362 ../raster/r.walk/main.c:845
-msgid "No start points"
-msgstr ""
-#: ../raster/r.cost/main.c:309 ../raster/r.walk/main.c:369
-#, c-format
-msgid "Inappropriate maximum cost: %d"
-msgstr ""
-#: ../raster/r.cost/main.c:312 ../raster/r.walk/main.c:372
-#, c-format
-msgid "Inappropriate amount of memory: %d"
-msgstr ""
-#: ../raster/r.cost/main.c:330 ../raster/r.walk/main.c:415
-msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-#: ../raster/r.cost/main.c:412 ../raster/r.cost/main.c:424
-#: ../raster/r.walk/main.c:525 ../raster/r.walk/main.c:538
-#, c-format
-msgid "Will need at least %.2f MB of disk space"
-msgstr ""
-#: ../raster/r.cost/main.c:414 ../raster/r.cost/main.c:425
-#: ../raster/r.walk/main.c:527 ../raster/r.walk/main.c:539
-#, c-format
-msgid "Will need at least %.2f MB of memory"
-msgstr ""
-#: ../raster/r.cost/main.c:416 ../raster/r.cost/main.c:426
-#: ../raster/r.walk/main.c:529 ../raster/r.walk/main.c:540
-#, c-format
-msgid "%d of %d segments are kept in memory"
-msgstr ""
-#: ../raster/r.cost/main.c:431 ../raster/r.walk/main.c:545
-msgid "Creating some temporary files..."
-msgstr ""
-#: ../raster/r.cost/main.c:435 ../raster/r.cost/main.c:440
-#: ../raster/r.walk/main.c:549 ../raster/r.walk/main.c:554
-#: ../raster/r.resamp.bspline/main.c:318 ../raster/r.resamp.bspline/main.c:403
-#: ../raster/r.resamp.bspline/main.c:475 ../vector/v.surf.bspline/main.c:475
-#: ../vector/v.surf.bspline/main.c:503
-msgid "Can not create temporary file"
-msgstr ""
-#: ../raster/r.cost/main.c:444
-#, c-format
-msgid "Reading raster map <%s>, initializing output..."
-msgstr ""
-#: ../raster/r.cost/main.c:489
-#, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
-msgstr ""
-#: ../raster/r.cost/main.c:504 ../raster/r.walk/main.c:643
-msgid "Initializing directional output..."
-msgstr ""
-#: ../raster/r.cost/main.c:535 ../raster/r.drain/main.c:273
-#: ../raster/r.walk/main.c:675
-#, c-format
-msgid "Reading vector map <%s> with start points..."
-msgstr ""
-#: ../raster/r.cost/main.c:548 ../raster/r.cost/main.c:618
-#: ../raster/r.to.vect/main.c:289 ../raster/r.drain/main.c:286
-#: ../raster/r.walk/main.c:688 ../raster/r.walk/main.c:754
-#: ../display/d.vect.thematic/display.c:75 ../display/d.vect/attr.c:51
-#: ../display/d.vect/dir.c:30 ../display/d.vect/label.c:44
-#: ../display/d.vect/lines.c:143 ../display/d.vect/topo.c:52
-#: ../display/d.vect/vert.c:27 ../display/d.vect/zcoor.c:38
-#: ../vector/v.vol.rst/user1.c:140 ../vector/v.to.3d/trans2.c:84
-#: ../vector/v.to.3d/trans3.c:85 ../vector/v.out.lidar/main.c:734
-#: ../vector/v.perturb/main.c:182 ../vector/v.decimate/main.c:406
-#: ../vector/v.colors/scan_cats.c:24 ../vector/v.colors/scan_z.c:36
-#: ../vector/v.what.rast/main.c:213 ../vector/v.colors.out/scan_cats.c:32
-#: ../vector/v.info/level1.c:38 ../vector/v.label/main.c:293
-#: ../vector/v.label.sa/labels.c:141
-msgid "Unable to read vector map"
-msgstr ""
-#: ../raster/r.cost/main.c:582
-#, c-format
-msgid "No start points found in vector map <%s>"
-msgstr ""
-#: ../raster/r.cost/main.c:584
-#, c-format
-msgid "%d point found"
-msgid_plural "%d points found"
-msgstr[0] ""
-#: ../raster/r.cost/main.c:598 ../raster/r.walk/main.c:734
-#, c-format
-msgid "Reading vector map <%s> with stop points..."
-msgstr ""
-#: ../raster/r.cost/main.c:652 ../raster/r.walk/main.c:788
-#, c-format
-msgid "No stop points found in vector <%s>"
-msgstr ""
-#: ../raster/r.cost/main.c:675 ../raster/r.walk/main.c:810
-#, c-format
-msgid "Reading raster map <%s> with start points..."
-msgstr ""
-#: ../raster/r.cost/main.c:726 ../raster/r.walk/main.c:859
-msgid "Specified starting location outside database window"
-msgstr ""
-#: ../raster/r.cost/main.c:748 ../raster/r.walk/main.c:879
-msgid "Finding cost path..."
-msgstr ""
-#: ../raster/r.cost/main.c:1011 ../raster/r.walk/main.c:1356
-msgid "Error, ct == pres_cell"
-msgstr ""
-#: ../raster/r.cost/main.c:1036
-#, c-format
-msgid "Writing raster map with nearest start point <%s>..."
-msgstr ""
-#: ../raster/r.cost/main.c:1131 ../raster/r.walk/main.c:1432
-#, c-format
-msgid "Writing output movement direction raster map <%s>..."
-msgstr ""
-#: ../raster/r.cost/main.c:1197 ../raster/r.walk/main.c:1477
-#, c-format
-msgid "Peak cost value: %g"
-msgstr ""
-#: ../raster/r.cost/main.c:1219 ../raster/r.walk/main.c:1498
-#, c-format
-msgid "Illegal x coordinate <%s>"
-msgstr ""
-#: ../raster/r.cost/main.c:1221 ../raster/r.walk/main.c:1500
-#, c-format
-msgid "Illegal y coordinate <%s>"
-msgstr ""
-#: ../raster/r.cost/main.c:1225 ../raster/r.walk/main.c:1504
-#, c-format
-msgid "Warning, ignoring point outside window: %g, %g"
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:55
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-#: ../raster/r.rescale.eq/main.c:115
-#, c-format
-msgid "Rescale %s[%d,%d] to %s[%d,%d]"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:63
-msgid "Converts a raster map layer into a GRASS ASCII text file."
-msgstr ""
-#: ../raster/r.out.ascii/main.c:72
-msgid "Name for output ASCII grid map (use out=- for stdout)"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:79 ../raster/r.out.vtk/parameters.c:98
-#: ../display/d.rast.num/main.c:104 ../vector/v.out.vtk/main.c:70
-#: ../vector/v.out.ascii/args.c:75 ../raster3d/r3.out.vtk/parameters.c:107
-msgid "Number of significant digits (floating point only)"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:86
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:91
-msgid "String to represent null cell (GRASS grid only)"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:95 ../raster3d/r3.out.ascii/main.c:102
-msgid "Suppress printing of header information"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:99
-msgid "Write SURFER (Golden Software) ASCII grid"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:103
-msgid "Write MODFLOW (USGS) ASCII array"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:107
-msgid "Force output of integer values"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:114
-msgid "Failed to interpret dp as an integer"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:116 ../raster3d/r3.out.vtk/main.c:394
-msgid "dp has to be from 0 to 20"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:122
-msgid "Failed to interpret width as an integer"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:128
-msgid "Both -s and -h doesn't make sense"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:131
-msgid "Use -M or -s, not both"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:166
-#, c-format
-msgid "Unable to read fp range for <%s>"
-msgstr ""
-#: ../raster/r.out.ascii/main.c:182
-#, c-format
-msgid "Read failed at row %d"
-msgstr ""
-#: ../raster/r.topmodel/main.c:55
-msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr ""
-#: ../raster/r.topmodel/main.c:60
-msgid "Name of input TOPMODEL parameters file"
-msgstr ""
-#: ../raster/r.topmodel/main.c:65
-msgid "Name of input topographic index statistics file"
-msgstr ""
-#: ../raster/r.topmodel/main.c:69
-msgid "Name of input rainfall and potential evapotranspiration data file"
-msgstr ""
-#: ../raster/r.topmodel/main.c:72 ../general/g.list/main.c:114
-#: ../locale/scriptstrings/d.out.file_to_translate.c:4
-msgid "Name for output file"
-msgstr ""
-#: ../raster/r.topmodel/main.c:76
-msgid "Time step"
-msgstr ""
-#: ../raster/r.topmodel/main.c:77
-msgid "Generate output for this time step"
-msgstr ""
-#: ../raster/r.topmodel/main.c:83
-msgid "Topographic index class"
-msgstr ""
-#: ../raster/r.topmodel/main.c:85
-msgid "Generate output for this topographic index class"
-msgstr ""
-#: ../raster/r.topmodel/main.c:92
-msgid "Name of input topographic index raster map"
-msgstr ""
-#: ../raster/r.topmodel/main.c:94
-msgid ""
-"Must be clipped to the catchment boundary. Used for generating "
-"outtopidxstats"
-msgstr ""
-#: ../raster/r.topmodel/main.c:96 ../raster/r.topmodel/main.c:106
-#: ../raster/r.topmodel/main.c:115
-msgid "Preprocess"
-msgstr ""
-#: ../raster/r.topmodel/main.c:100
-msgid "Number of topographic index classes"
-msgstr ""
-#: ../raster/r.topmodel/main.c:102
-msgid "Used for generating outtopidxstats"
-msgstr ""
-#: ../raster/r.topmodel/main.c:111
-msgid "Name for output topographic index statistics file"
-msgstr ""
-#: ../raster/r.topmodel/main.c:113
-msgid "Requires topidx and ntopidxclasses"
-msgstr ""
-#: ../raster/r.topmodel/main.c:120
-msgid "Preprocess only and stop after generating outtopidxstats"
-msgstr ""
-#: ../raster/r.topmodel/main.c:150
-#, c-format
-msgid "%s must be greater than 1"
-msgstr ""
-#: ../raster/r.topmodel/main.c:154 ../raster/r.topmodel/main.c:157
-#, c-format
-msgid "Ignoring %s because %s is not specified"
-msgstr ""
-#: ../raster/r.topmodel/file_io.c:56
-#, c-format
-msgid "%s cannot be 0"
-msgstr ""
-#: ../raster/r.topmodel/file_io.c:209 ../raster/r.topmodel/topmodel.c:77
-#: ../vector/v.out.pov/main.c:104
-#, c-format
-msgid "Unable to create output file <%s>"
-msgstr ""
-#: ../raster/r.topmodel/topmodel.c:32
-#, c-format
-msgid "Unable to run %s"
-msgstr ""
-#: ../raster/r.topmodel/topmodel.c:74
-#, c-format
-msgid "Invalid %s output"
-msgstr ""
-#: ../raster/r.topmodel/infiltration.c:148
-#: ../raster/r.topmodel/infiltration.c:217
-#, c-format
-msgid "Maximum number of iterations exceeded at time step %d"
-msgstr ""
-#: ../raster/r.relief/main.c:108 ../raster/r.param.scale/interface.c:57
-#: ../locale/scriptstrings/d.shade_to_translate.c:3
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
-#: ../locale/scriptstrings/r.plane_to_translate.c:3
-#: ../locale/scriptstrings/r.shade_to_translate.c:3
-msgid "elevation"
-msgstr ""
-#: ../raster/r.relief/main.c:109
-#: ../locale/scriptstrings/d.shade_to_translate.c:4
-#: ../locale/scriptstrings/r.shade_to_translate.c:4
-msgid "relief"
-msgstr ""
-#: ../raster/r.relief/main.c:111
-#: ../locale/scriptstrings/d.shade_to_translate.c:5
-#: ../locale/scriptstrings/r.shade_to_translate.c:5
-msgid "hillshade"
-msgstr ""
-#: ../raster/r.relief/main.c:112
-msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-#: ../raster/r.relief/main.c:115
-msgid "Name of input raster (typically elevation) map"
-msgstr ""
-#: ../raster/r.relief/main.c:118
-msgid "Name for output shaded relief map"
-msgstr ""
-#: ../raster/r.relief/main.c:126
-msgid "Altitude of the sun in degrees above the horizon"
-msgstr ""
-#: ../raster/r.relief/main.c:127 ../raster/r.relief/main.c:137
-msgid "Sun position"
-msgstr ""
-#: ../raster/r.relief/main.c:136
-msgid "Azimuth of the sun in degrees to the east of north"
-msgstr ""
-#: ../raster/r.relief/main.c:144
-msgid "Factor for exaggerating relief"
-msgstr ""
-#: ../raster/r.relief/main.c:152
-msgid "Scale factor for converting meters to elevation units"
-msgstr ""
-#: ../raster/r.relief/main.c:159
-msgid "Elevation units (overrides scale factor)"
-msgstr ""
-#: ../raster/r.relief/main.c:164
-msgid "international feet"
-msgstr ""
-#: ../raster/r.relief/main.c:165
-msgid "survey feet"
-msgstr ""
-#: ../raster/r.relief/main.c:216
-#, c-format
-msgid "%s=%s - must not be zero"
-msgstr ""
-#: ../raster/r.relief/main.c:475
-#, c-format
-msgid "Shaded relief raster map <%s> complete"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:62
-msgid "Converts raster maps into the VTK-ASCII format."
-msgstr ""
-#: ../raster/r.out.vtk/main.c:73
-msgid ""
-"No input maps specified. You need to specify at least one input map or three"
-" vector maps or three rgb maps."
-msgstr ""
-#: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
-#: ../raster/r.out.vtk/main.c:212 ../raster/r.out.vtk/main.c:251
-#, c-format
-msgid "Open Raster file %s"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:222
-msgid "Writing VTK ImageData\n"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:232
-msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:261
-msgid "Writing VTK Vector Data\n"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:271
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
-#: ../raster/r.out.vtk/main.c:283
-msgid "Error closing VTK-ASCII file"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:32
-msgid "Raster map(s) to be converted to VTK-ASCII data format"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:36 ../raster3d/r3.out.vtk/parameters.c:34
-msgid "Name for VTK-ASCII output file"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:45
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
-msgid "Value to represent no data cell"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:53
-msgid "Constant elevation (if no elevation map is specified)"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:59
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is "
-"given)"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:69
-msgid ""
-"Three (r,g,b) raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:79
-msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:85 ../vector/v.out.vtk/main.c:76
-#: ../raster3d/r3.out.vtk/parameters.c:94
-msgid "Scale factor for elevation"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:104
-msgid "Use structured grid for elevation (not recommended)"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:110
-msgid "Use polydata-trianglestrips for elevation grid creation"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:116
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:122
-msgid "Scale factor affects the origin (if no elevation map is given)"
-msgstr ""
-#: ../raster/r.out.vtk/parameters.c:128
-#: ../raster3d/r3.out.vtk/parameters.c:123
-msgid "Correct the coordinates to match the VTK-OpenGL precision"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:75
-msgid "write_vtk_normal_header: Writing VTK-Header"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:108
-msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:124
-msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:139
-msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:148
-msgid "writeVTKPointHeader: Writing VTK-DataHeader"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:169
-msgid "write_vtk_structured_coordinates: Writing Coordinates"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:225
-msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:334
-msgid "write_vtk_data: Writing VTK-Data"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:384
-msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:412
-msgid "Wrong map values! Values should in between 0 and 255!\n"
-msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:442
-msgid "write_vtk_vector_data: Writing VTK-vector data"
-msgstr ""
-#: ../raster/r.in.lidar/string_list.c:34
-#: ../raster3d/r3.in.lidar/string_list.c:47
-#, c-format
-msgid "Cannot open file %s for reading"
-msgstr ""
-#: ../raster/r.in.lidar/rast_segment.c:40
-#: ../raster3d/r3.in.lidar/rast_segment.c:53
-msgid "Cannot create temporary file with segments of a raster map"
-msgstr ""
-#: ../raster/r.in.lidar/projection.c:40 ../vector/v.in.pdal/projection.c:37
-#: ../vector/v.in.lidar/projection.c:38
-#: ../raster3d/r3.in.lidar/projection.c:42
-msgid "GRASS LOCATION PROJ_INFO is:\n"
-msgstr ""
-#: ../raster/r.in.lidar/projection.c:49 ../raster/r.in.lidar/projection.c:55
-#: ../vector/v.in.pdal/projection.c:46 ../vector/v.in.pdal/projection.c:52
-#: ../vector/v.in.lidar/projection.c:47 ../vector/v.in.lidar/projection.c:53
-#: ../raster3d/r3.in.lidar/projection.c:51
-#: ../raster3d/r3.in.lidar/projection.c:57
-msgid "Import dataset PROJ_INFO is:\n"
-msgstr ""
-#: ../raster/r.in.lidar/projection.c:95 ../vector/v.in.pdal/projection.c:92
-#: ../vector/v.in.lidar/projection.c:93
-#: ../raster3d/r3.in.lidar/projection.c:97
-msgid ""
-"Consider generating a new location with 'location' parameter from input data"
-" set.\n"
-msgstr ""
-#: ../raster/r.in.lidar/projection.c:113 ../vector/v.in.pdal/projection.c:110
-#: ../vector/v.in.pdal/projection.c:156 ../vector/v.in.pdal/projection.c:189
-#: ../vector/v.in.lidar/projection.c:111
-#: ../raster3d/r3.in.lidar/projection.c:115
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:116
-msgid ""
-"Creates a raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:120 ../vector/v.in.lidar/main.c:144
-#: ../raster3d/r3.in.lidar/main.c:174
-msgid "LAS input file"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:121 ../raster/r.in.lidar/main.c:131
-#: ../vector/v.in.lidar/main.c:145 ../raster3d/r3.in.lidar/main.c:182
-msgid "LiDAR input files in LAS format (*.las or *.laz)"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:130 ../raster3d/r3.in.lidar/main.c:181
-msgid "File containing names of LAS input files"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:168
-msgid "pth (nth) percentile of point values in cell"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:180
-msgid "Subtract raster values from the Z coordinates"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:182
-msgid ""
-"The scale for Z is applied beforehand, the range filter for Z afterwards"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:184 ../raster/r.in.lidar/main.c:201
-#: ../raster/r.in.lidar/main.c:217 ../raster/r.in.lidar/main.c:333
-#: ../raster3d/r3.in.lidar/main.c:251 ../raster3d/r3.in.lidar/main.c:264
-#: ../raster3d/r3.in.lidar/main.c:280
-msgid "Transform"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:191
-msgid "Filter range for Z data (min,max)"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:192
-msgid "Applied after base_raster transformation step"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:200 ../raster3d/r3.in.lidar/main.c:263
-msgid "Scale to apply to Z data"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:208 ../raster3d/r3.in.lidar/main.c:271
-msgid "Filter range for intensity values (min,max)"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:216 ../raster3d/r3.in.lidar/main.c:279
-msgid "Scale to apply to intensity values"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:234
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
-msgid "pth percentile of the values"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:242
-msgid "Discard given percentage of the smallest and largest values"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:252
-msgid "Output raster resolution"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:259 ../vector/v.in.lidar/main.c:203
-#: ../raster3d/r3.in.lidar/main.c:229
-msgid "Only import points of selected return type"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:260 ../vector/v.in.lidar/main.c:204
-#: ../raster3d/r3.in.lidar/main.c:230
-msgid "If not specified, all points are imported"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:269 ../vector/v.in.lidar/main.c:213
-#: ../raster3d/r3.in.lidar/main.c:239
-msgid "Only import points of selected class(es)"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:270 ../vector/v.in.lidar/main.c:214
-#: ../raster3d/r3.in.lidar/main.c:240
-msgid ""
-"Input is comma separated integers. If not specified, all points are "
-"imported."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:277 ../vector/v.in.lidar/main.c:278
-#: ../raster3d/r3.in.lidar/main.c:299
-msgid "Print LAS file info and exit"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:282
-msgid "Use the extent of the input for the raster extent"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:284
-msgid "Set internally computational region extents based on the point cloud"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:291
-msgid "Set computation region to match the new raster map"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:293
-msgid ""
-"Set computation region to match the 2D extent and resolution of the newly "
-"created new raster map"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:316
-msgid "Use intensity values rather than Z values"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:318
-msgid "Uses intensity values everywhere as if they would be Z coordinates"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:324
-msgid "Use Z values for filtering, but intensity values for statistics"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:329
-msgid "Use base raster resolution instead of computational region"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:331
-msgid ""
-"For getting values from base raster, use its actual resolution instead of "
-"computational region resolution"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:337 ../vector/v.in.lidar/main.c:293
-#: ../raster3d/r3.in.lidar/main.c:284
-msgid "Use only valid points"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:339 ../vector/v.in.lidar/main.c:295
-#: ../raster3d/r3.in.lidar/main.c:286
-msgid ""
-"Points invalid according to APSRS LAS specification will be filtered out"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:359
-#, c-format
-msgid "Flag %c makes sense only with %s option or -%c flag"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:369 ../raster3d/r3.in.lidar/main.c:340
-#, c-format
-msgid "File <%s> does not exist"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:386
-msgid "zrange will not be taken into account during scan"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:399 ../vector/v.in.lidar/main.c:349
-#: ../raster3d/r3.in.lidar/main.c:374
-#, c-format
-msgid "Input file <%s> does not exist"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:403 ../raster3d/r3.in.lidar/main.c:378
-#, c-format
-msgid "Unable to open file <%s> as a LiDAR point cloud"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:407 ../vector/v.in.lidar/main.c:358
-#: ../raster3d/r3.in.lidar/main.c:382
-#, c-format
-msgid "Unable to read LAS header of <%s>"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:423 ../raster3d/r3.in.lidar/main.c:398
-msgid ""
-"First file's projection checked, checking projection of the other files..."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:461
-#, c-format
-msgid "Unknown filter option <%s>"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:493
-#, c-format
-msgid "Invalid %s"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:525 ../general/g.region/main.c:815
-#, c-format
-msgid "Invalid input <%s=%s>"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:528
-#, c-format
-msgid "Option '%s' must be > 0.0"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:596
-#, c-format
-msgid ""
-"Unable to process the whole map at once. Please set the '%s' option to some "
-"value lower than 100."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:608 ../raster/r.contour/main.c:237
-#: ../vector/v.generalize/displacement.c:78
-msgid "Reading data..."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:616
-#, c-format
-msgid "Pass #%d (of %d)..."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:755 ../raster/r.drain/main.c:470
-msgid "Writing output raster map..."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:778
-#, c-format
-msgid "%lu points found in input file(s)"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:798
-#, c-format
-msgid "%lu input points were invalid and filtered out"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:801
-#, c-format
-msgid "%lu input points were invalid, use -%c flag to filter them out"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:804
-#, c-format
-msgid "Raster map <%s> created. %lu points from %d files found in region."
-msgstr ""
-#: ../raster/r.in.lidar/main.c:809
-#, c-format
-msgid "Raster map <%s> created. %lu points found in region."
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:116 ../vector/v.net.flow/main.c:60
-msgid "flow"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:117
-msgid "overland flow"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:120
-msgid ""
-"Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:127
-#: ../raster/r.sim/r.sim.sediment/main.c:133
-msgid "Name of x-derivatives raster map [m/m]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:131
-#: ../raster/r.sim/r.sim.sediment/main.c:137
-msgid "Name of y-derivatives raster map [m/m]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:137
-msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:146
-msgid "Rainfall excess rate unique value [mm/hr]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:153
-msgid "Name of runoff infiltration rate raster map [mm/hr]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:162
-msgid "Runoff infiltration rate unique value [mm/hr]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:168
-#: ../raster/r.sim/r.sim.sediment/main.c:157
-msgid "Name of Manning's n raster map"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:176
-#: ../raster/r.sim/r.sim.sediment/main.c:165
-msgid "Manning's n unique value"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:183
-msgid "Name of flow controls raster map (permeability ratio 0-1)"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:190
-#: ../raster/r.sim/r.sim.sediment/main.c:172
-msgid "Name of sampling locations vector points map"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:196
-msgid "Name for output water depth raster map [m]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:202
-msgid "Name for output water discharge raster map [m3/s]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:208
-msgid "Name for output simulation error raster map [m]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:215
-#: ../raster/r.sim/r.sim.sediment/main.c:219
-msgid "Base name of the output walkers vector points map"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:222
-#: ../raster/r.sim/r.sim.sediment/main.c:212
-msgid ""
-"Name for sampling points output text file. For each observation vector point"
-" the time series of sediment transport is stored."
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:230
-msgid "Number of walkers, default is twice the number of cells"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:231
-#: ../raster/r.sim/r.sim.water/main.c:239
-#: ../raster/r.sim/r.sim.water/main.c:248
-#: ../raster/r.sim/r.sim.water/main.c:266
-#: ../raster/r.sim/r.sim.water/main.c:276
-#: ../raster/r.sim/r.sim.water/main.c:284
-#: ../raster/r.sim/r.sim.water/main.c:293
-#: ../raster/r.sim/r.sim.water/main.c:324
-#: ../raster/r.sim/r.sim.sediment/main.c:227
-#: ../raster/r.sim/r.sim.sediment/main.c:235
-#: ../raster/r.sim/r.sim.sediment/main.c:244
-#: ../raster/r.sim/r.sim.sediment/main.c:262
-#: ../raster/r.sim/r.sim.sediment/main.c:289
-#: ../imagery/i.eb.hsebal01/main.c:141 ../imagery/i.eb.hsebal01/main.c:150
-#: ../imagery/i.eb.hsebal01/main.c:157 ../imagery/i.eb.hsebal01/main.c:164
-#: ../imagery/i.eb.hsebal01/main.c:171 ../imagery/i.eb.hsebal01/main.c:178
-#: ../vector/v.surf.rst/main.c:163 ../vector/v.surf.rst/main.c:168
-#: ../vector/v.surf.rst/main.c:189 ../vector/v.surf.rst/main.c:264
-#: ../vector/v.surf.rst/main.c:270 ../vector/v.surf.rst/main.c:278
-#: ../vector/v.surf.rst/main.c:286 ../vector/v.surf.rst/main.c:294
-#: ../vector/v.surf.rst/main.c:302 ../vector/v.surf.rst/main.c:311
-#: ../vector/v.surf.rst/main.c:319 ../vector/v.surf.rst/main.c:327
-#: ../vector/v.surf.rst/main.c:336 ../vector/v.surf.rst/main.c:344
-#: ../vector/v.surf.rst/main.c:351
-msgid "Parameters"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:238
-#: ../raster/r.sim/r.sim.sediment/main.c:234
-msgid "Time used for iterations [minutes]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:247
-#: ../raster/r.sim/r.sim.sediment/main.c:243
-msgid "Time interval for creating output maps [minutes]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:265
-#: ../raster/r.sim/r.sim.sediment/main.c:261
-msgid "Water diffusion constant"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:274
-msgid "Threshold water depth [m]"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:275
-msgid "Diffusion increases after this water depth is reached"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:283
-msgid "Diffusion increase constant"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:292
-msgid "Weighting factor for water flow velocity vector"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:297
-msgid "Time-series output"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:304
-#: ../raster/r.sim/r.sim.sediment/main.c:269
-msgid "Seed for random number generator"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:306
-#: ../raster/r.sim/r.sim.sediment/main.c:271
-msgid ""
-"The same seed can be used to obtain same results or random seed can be "
-"generated by other means."
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:312
-#: ../raster/r.sim/r.sim.sediment/main.c:277
-msgid "Generate random seed"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:314
-#: ../raster/r.sim/r.sim.sediment/main.c:279
-msgid ""
-"Automatically generates random seed for random number generator (use when "
-"you don't want to provide the seed option)"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:323
-#: ../raster/r.sim/r.sim.sediment/main.c:288
-msgid "Number of threads which will be used for parallel compute"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:331
-#: ../raster/r.sim/r.sim.sediment/main.c:296
-#, c-format
-msgid "Generated random seed (-s): %ld"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:336
-#: ../raster/r.sim/r.sim.sediment/main.c:301
-#, c-format
-msgid "Read random seed from %s option: %ld"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:402
-#: ../raster/r.sim/r.sim.sediment/main.c:374 ../vector/v.surf.rst/main.c:407
-#, c-format
-msgid ""
-"<%d> is not valid number of threads. Number of threads will be set on <%d>"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:411
-#: ../raster/r.sim/r.sim.sediment/main.c:383
-#, c-format
-msgid "Number of threads: %d"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:505
-#: ../raster/r.sim/r.sim.sediment/main.c:397
-msgid "More than 100 files are going to be created !!!!!"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:511
-#: ../raster/r.sim/r.sim.sediment/main.c:403
-#, c-format
-msgid "default nwalk=%d, rwalk=%f"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:521
-#: ../raster/r.sim/r.sim.sediment/main.c:412
-#, c-format
-msgid "Using metric conversion factor %f, step=%f"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:527
-msgid "You are not outputting any raster maps"
-msgstr ""
-#: ../raster/r.sim/r.sim.water/main.c:530
-#: ../raster/r.sim/r.sim.sediment/main.c:422 ../vector/v.vol.rst/main.c:916
-#: ../vector/v.surf.rst/main.c:659 ../vector/v.surf.rst/main.c:714
-msgid "Input failed"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:117
-msgid "sediment flow"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:119
-msgid "deposition"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:122
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:129
-msgid "Name of water depth raster map [m]"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:142
-msgid "Name of detachment capacity coefficient raster map [s/m]"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:147
-msgid "Name of transport capacity coefficient raster map [s]"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:152
-msgid "Name of critical shear stress raster map [Pa]"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:178
-msgid "Name for output transport capacity raster map [kg/ms]"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:185
-msgid ""
-"Name for output transport limited erosion-deposition raster map [kg/m2s]"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:192
-msgid "Name for output sediment concentration raster map [particle/m3]"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:198
-msgid "Name for output sediment flux raster map [kg/ms]"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:205
-msgid "Name for output erosion-deposition raster map [kg/m2s]"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:226
-msgid "Number of walkers"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:419
-msgid "You are not outputting any raster or site files"
-msgstr ""
-#: ../raster/r.sim/r.sim.sediment/main.c:435
-#: ../raster/r.sim/simlib/hydro.c:478
-msgid "Cannot write raster maps"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:307
-#, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed"
-" to process"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:420
-msgid "Zero value in Mannings n"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:471
-msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:495
-#, c-format
-msgid ""
-"Min elevation \t= %.2f m\n"
-"Max elevation \t= %.2f m\n"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:497
-#, c-format
-msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:499
-#, c-format
-msgid "Mean flow velocity \t= %f m/s\n"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:500
-#, c-format
-msgid "Mean Mannings \t= %f\n"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:504
-#, c-format
-msgid "Number of iterations \t= %d cell\n"
-msgid_plural "Number of iterations \t= %d cells\n"
-msgstr[0] ""
-#: ../raster/r.sim/simlib/input.c:506
-#, c-format
-msgid "Time step \t= %.2f s\n"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:508
-#, c-format
-msgid ""
-"Sigmax \t= %f\n"
-"Max velocity \t= %f m/s\n"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:510
-#, c-format
-msgid "Time step used \t= %.2f s\n"
-msgstr ""
-#: ../raster/r.sim/simlib/input.c:562
-msgid "Unable to write et file"
-msgstr ""
-#: ../raster/r.sim/simlib/output.c:321 ../raster/r.sim/simlib/output.c:329
-#, c-format
-msgid "FP raster map <%s> not found"
-msgstr ""
-#: ../raster/r.sim/simlib/hydro.c:202
-#, c-format
-msgid "nwalk (%d) > maxw (%d)!"
-msgstr ""
-#: ../raster/r.sim/simlib/hydro.c:411
-msgid "Unable to write raster maps"
-msgstr ""
-#: ../raster/r.sim/simlib/observation_points.c:64
-#, c-format
-msgid "Unable to read points from map %s"
-msgstr ""
-#: ../raster/r.sim/simlib/observation_points.c:85
-#, c-format
-msgid "Unable to open observation logfile %s for writing"
-msgstr ""
-#: ../raster/r.lake/main.c:153
-msgid "flood"
-msgstr ""
-#: ../raster/r.lake/main.c:154
-msgid "Fills lake at given point to given level."
-msgstr ""
-#: ../raster/r.lake/main.c:160
-msgid "Water level"
-msgstr ""
-#: ../raster/r.lake/main.c:170
-msgid "Seed point coordinates"
-msgstr ""
-#: ../raster/r.lake/main.c:171
-msgid "Either this coordinates pair or a seed map have to be specified"
-msgstr ""
-#: ../raster/r.lake/main.c:175 ../raster/r.lake/main.c:184
-msgid "Seed"
-msgstr ""
-#: ../raster/r.lake/main.c:180
-msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
-msgstr ""
-#: ../raster/r.lake/main.c:182
-msgid "Either this parameter or a coordinates pair have to be specified"
-msgstr ""
-#: ../raster/r.lake/main.c:189
-msgid "Use negative depth values for lake raster map"
-msgstr ""
-#: ../raster/r.lake/main.c:194
-msgid "Overwrite seed map with result (lake) map"
-msgstr ""
-#: ../raster/r.lake/main.c:201
-msgid "Both seed map and coordinates cannot be specified"
-msgstr ""
-#: ../raster/r.lake/main.c:204
-msgid "Seed map or seed coordinates must be set!"
-msgstr ""
-#: ../raster/r.lake/main.c:207
-msgid "Seed coordinates and output map lake= must be set!"
-msgstr ""
-#: ../raster/r.lake/main.c:210
-msgid "Both lake and overwrite cannot be specified"
-msgstr ""
-#: ../raster/r.lake/main.c:213
-msgid "Output lake map or overwrite flag must be set!"
-msgstr ""
-#: ../raster/r.lake/main.c:240
-msgid "Seed point outside the current region"
-msgstr ""
-#: ../raster/r.lake/main.c:254
-msgid "G_malloc: out of memory"
-msgstr ""
-#: ../raster/r.lake/main.c:276
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level"
-" or move seed point."
-msgstr ""
-#: ../raster/r.lake/main.c:355
-#, c-format
-msgid "Lake depth from %f to %f (specified water level is taken as zero)"
-msgstr ""
-#: ../raster/r.lake/main.c:356
-#, c-format
-msgid "Lake area %f square meters"
-msgstr ""
-#: ../raster/r.lake/main.c:357
-#, c-format
-msgid "Lake volume %f cubic meters"
-msgstr ""
-#: ../raster/r.lake/main.c:358
-msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr ""
-#: ../raster/r.patch/main.c:60
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
-msgid "mosaicking"
-msgstr ""
-#: ../raster/r.patch/main.c:61
-#: ../locale/scriptstrings/t.merge_to_translate.c:4
-msgid "merge"
-msgstr ""
-#: ../raster/r.patch/main.c:62
-msgid "patching"
-msgstr ""
-#: ../raster/r.patch/main.c:66
-msgid ""
-"Creates a composite raster map layer by using known category values from one"
-" (or more) map layer(s) to fill in areas of \"no data\" in another map "
-"layer."
-msgstr ""
-#: ../raster/r.patch/main.c:73
-msgid "Name of raster maps to be patched together"
-msgstr ""
-#: ../raster/r.patch/main.c:76
-msgid "Name for resultant raster map"
-msgstr ""
-#: ../raster/r.patch/main.c:83
-msgid "Use zero (0) for transparency instead of NULL"
-msgstr ""
-#: ../raster/r.patch/main.c:88
-msgid "Do not create color and category files"
-msgstr ""
-#: ../raster/r.patch/main.c:103
-msgid "The minimum number of input raster maps is two"
-msgstr ""
-#: ../raster/r.patch/main.c:180
-#, c-format
-msgid "Creating support files for raster map <%s>..."
-msgstr ""
-#: ../raster/r.report/label.c:13
-msgid "Page width is too small"
-msgstr ""
-#: ../raster/r.report/main.c:69
-msgid "Reports statistics for raster maps."
-msgstr ""
-#: ../raster/r.report/parse.c:45
-msgid "Units to report"
-msgstr ""
-#: ../raster/r.report/parse.c:49
-msgid "area in square miles"
-msgstr ""
-#: ../raster/r.report/parse.c:50
-msgid "area in square meters"
-msgstr ""
-#: ../raster/r.report/parse.c:51
-msgid "area in square kilometers"
-msgstr ""
-#: ../raster/r.report/parse.c:52
-msgid "area in acres"
-msgstr ""
-#: ../raster/r.report/parse.c:53
-msgid "area in hectares"
-msgstr ""
-#: ../raster/r.report/parse.c:54
-msgid "number of cells"
-msgstr ""
-#: ../raster/r.report/parse.c:55
-msgid "percent cover"
-msgstr ""
-#: ../raster/r.report/parse.c:75
-msgid "Page length"
-msgstr ""
-#: ../raster/r.report/parse.c:83
-msgid "Page width"
-msgstr ""
-#: ../raster/r.report/parse.c:113
-msgid "Suppress page headers"
-msgstr ""
-#: ../raster/r.report/parse.c:118
-msgid "Use formfeeds between pages"
-msgstr ""
-#: ../raster/r.report/parse.c:123
-msgid "Scientific format"
-msgstr ""
-#: ../raster/r.report/parse.c:187
-msgid "nsteps has to be > 0; using nsteps=255"
-msgstr ""
-#: ../raster/r.report/parse.c:193
-msgid "Illegal page length"
-msgstr ""
-#: ../raster/r.report/parse.c:198
-msgid "Illegal page width"
-msgstr ""
-#: ../raster/r.report/parse.c:253
-#, c-format
-msgid "Only %d unit%s allowed"
-msgstr ""
-#: ../raster/r.report/parse.c:286
-#, c-format
-msgid "Unable to read fp range for raster map <%s>"
-msgstr ""
-#: ../raster/r.report/stats.c:93
-#, c-format
-msgid "Unable to open result file <%s>"
-msgstr ""
-#: ../raster/r.null/main.c:61 ../raster3d/r3.null/main.c:181
-msgid "null data"
-msgstr ""
-#: ../raster/r.null/main.c:62
-msgid "Manages NULL-values of given raster map."
-msgstr ""
-#: ../raster/r.null/main.c:65
-msgid "Name of raster map for which to edit null values"
-msgstr ""
-#: ../raster/r.null/main.c:73 ../raster3d/r3.null/main.c:63
-msgid "List of cell values to be set to NULL"
-msgstr ""
-#: ../raster/r.null/main.c:74 ../raster/r.null/main.c:82
-#: ../general/g.proj/main.c:193
-msgid "Modify"
-msgstr ""
-#: ../raster/r.null/main.c:81 ../raster3d/r3.null/main.c:70
-msgid "The value to replace the null value by"
-msgstr ""
-#: ../raster/r.null/main.c:86
-msgid "Only do the work if the map is floating-point"
-msgstr ""
-#: ../raster/r.null/main.c:87 ../raster/r.null/main.c:92
-#: ../raster/r.null/main.c:98
-msgid "Check"
-msgstr ""
-#: ../raster/r.null/main.c:91
-msgid "Only do the work if the map is integer"
-msgstr ""
-#: ../raster/r.null/main.c:97
-msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr ""
-#: ../raster/r.null/main.c:103
-msgid "Create NULL-value bitmap file validating all data cells"
-msgstr ""
-#: ../raster/r.null/main.c:107
-msgid "Remove NULL-value bitmap file"
-msgstr ""
-#: ../raster/r.null/main.c:108 ../raster/r.colors/edit_colors.c:116
-#: ../vector/v.colors/main.c:122
-#: ../locale/scriptstrings/g.extension_to_translate.c:30
-#: ../locale/scriptstrings/r.mask_to_translate.c:20
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:15
-msgid "Remove"
-msgstr ""
-#: ../raster/r.null/main.c:113
-msgid "Re-create NULL-value bitmap file (to compress or uncompress)"
-msgstr ""
-#: ../raster/r.null/main.c:132
-#, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
-msgstr ""
-#: ../raster/r.null/main.c:138
-#, c-format
-msgid "Raster map <%s> is not in your mapset <%s>"
-msgstr ""
-#: ../raster/r.null/main.c:145
-#, c-format
-msgid "%s is illegal entry for null"
-msgstr ""
-#: ../raster/r.null/main.c:152
-#, c-format
-msgid "Raster map <%s> already has a null bitmap file"
-msgstr ""
-#: ../raster/r.null/main.c:156
-#, c-format
-msgid "<%s> is integer raster map (CELL)"
-msgstr ""
-#: ../raster/r.null/main.c:160
-#, c-format
-msgid "<%s> is integer raster map (CELL). Using null=%d."
-msgstr ""
-#: ../raster/r.null/main.c:166
-#, c-format
-msgid "<%s> is floating pointing raster map"
-msgstr ""
-#: ../raster/r.null/main.c:183 ../raster/r.null/main.c:226
-#, c-format
-msgid "Writing new null file for raster map <%s>..."
-msgstr ""
-#: ../raster/r.null/main.c:193 ../raster/r.null/main.c:238
-#: ../raster/r.null/main.c:252
-#, c-format
-msgid "Raster map <%s> modified."
-msgstr ""
-#: ../raster/r.null/main.c:208
-msgid "The NULL file is already compressed, nothing to do."
-msgstr ""
-#: ../raster/r.null/main.c:214
-msgid "The NULL file is already uncompressed, nothing to do."
-msgstr ""
-#: ../raster/r.null/main.c:245
-#, c-format
-msgid "Removing null file for raster map <%s>..."
-msgstr ""
-#: ../raster/r.null/main.c:316
-#, c-format
-msgid "%s: %s: illegal value spec"
-msgstr ""
-#: ../raster/r.null/main.c:318
-#, c-format
-msgid "%s: illegal value spec"
-msgstr ""
-#: ../raster/r.null/main.c:379
-#, c-format
-msgid "Writing new data for raster map <%s>..."
-msgstr ""
-#: ../raster/r.contour/cont.c:82
-#, c-format
-msgid "Writing vector contour (one level)..."
-msgid_plural "Writing vector contours (total levels %d)..."
-msgstr[0] ""
-#: ../raster/r.contour/cont.c:214
-#, c-format
-msgid "%d crossing found"
-msgid_plural "%d crossings found"
-msgstr[0] ""
-#: ../raster/r.contour/cont.c:267
-msgid "Illegal edge number"
-msgstr ""
-#: ../raster/r.contour/cont.c:375
-msgid "Edge number out of range"
-msgstr ""
-#: ../raster/r.contour/main.c:89
-msgid "contours"
-msgstr ""
-#: ../raster/r.contour/main.c:90 ../raster/r.random/main.c:53
-#: ../display/d.extract/main.c:50 ../display/d.vect/main.c:75
-#: ../display/d.legend.vect/main.c:52 ../visualization/ximgview/main.c:293
-#: ../vector/v.out.postgis/main.c:44 ../vector/v.build/main.c:36
-#: ../vector/v.patch/main.c:69 ../vector/v.outlier/main.c:69
-#: ../vector/v.vol.rst/main.c:235 ../vector/v.to.3d/main.c:36
-#: ../vector/v.out.svg/main.c:77 ../vector/v.to.rast/main.c:44
-#: ../vector/v.rectify/main.c:70 ../vector/v.kernel/main.c:108
-#: ../vector/v.net.spanningtree/main.c:46 ../vector/v.delaunay/main.c:85
-#: ../vector/v.to.db/main.c:36 ../vector/v.mkgrid/main.c:70
-#: ../vector/v.segment/main.c:60 ../vector/v.net.timetable/main.c:260
-#: ../vector/v.in.db/main.c:52 ../vector/v.in.region/main.c:41
-#: ../vector/v.out.dxf/main.c:56 ../vector/v.net.alloc/main.c:64
-#: ../vector/v.cluster/main.c:90 ../vector/v.vect.stats/main.c:133
-#: ../vector/v.db.select/main.c:54 ../vector/v.kcv/main.c:55
-#: ../vector/v.transform/main.c:70 ../vector/v.net.bridge/main.c:47
-#: ../vector/v.clean/main.c:51 ../vector/v.clean/test/topocheck.c:42
-#: ../vector/v.out.lidar/main.c:473 ../vector/v.reclass/main.c:67
-#: ../vector/v.univar/main.c:92 ../vector/v.net.components/main.c:72
-#: ../vector/v.net.steiner/main.c:346 ../vector/v.lidar.correction/main.c:71
-#: ../vector/v.net.centrality/main.c:96 ../vector/v.db.connect/main.c:52
-#: ../vector/v.split/main.c:54 ../vector/v.what/main.c:62
-#: ../vector/v.out.vtk/main.c:47 ../vector/v.parallel/main.c:49
-#: ../vector/v.lidar.growing/main.c:75 ../vector/v.select/main.c:48
-#: ../vector/v.net.distance/main.c:66 ../vector/v.class/main.c:45
-#: ../vector/v.overlay/main.c:63 ../vector/v.extract/main.c:77
-#: ../vector/v.perturb/main.c:62 ../vector/v.net.allpairs/main.c:61
-#: ../vector/v.support/main.c:39 ../vector/v.decimate/main.c:123
-#: ../vector/v.net.visibility/main.c:45 ../vector/v.what.rast3/main.c:64
-#: ../vector/v.generalize/main.c:76 ../vector/v.qcount/main.c:60
-#: ../vector/v.net.connectivity/main.c:52 ../vector/v.in.lidar/main.c:136
-#: ../vector/v.sample/main.c:75 ../vector/v.random/main.c:97
-#: ../vector/v.external.out/main.c:43 ../vector/v.net/main.c:47
-#: ../vector/v.colors/main.c:55 ../vector/v.net.flow/main.c:58
-#: ../vector/v.hull/main.c:52 ../vector/v.out.ascii/main.c:47
-#: ../vector/v.to.points/main.c:53 ../vector/v.net.path/main.c:42
-#: ../vector/v.in.ogr/main.c:194 ../vector/v.what.rast/main.c:71
-#: ../vector/v.lidar.edgedetection/main.c:75 ../vector/v.colors.out/main.c:49
-#: ../vector/v.out.ogr/main.c:82 ../vector/v.to.rast3/main.c:48
-#: ../vector/v.neighbors/main.c:50 ../vector/v.voronoi/main.c:123
-#: ../vector/v.info/print.c:436 ../vector/v.info/main.c:37
-#: ../vector/v.drape/main.c:56 ../vector/v.lrs/v.lrs.segment/main.c:71
-#: ../vector/v.lrs/v.lrs.label/main.c:102
-#: ../vector/v.lrs/v.lrs.where/main.c:57
-#: ../vector/v.lrs/v.lrs.create/main.c:121 ../vector/v.in.dwg/main.c:82
-#: ../vector/v.type/main.c:38 ../vector/v.in.ascii/main.c:70
-#: ../vector/v.surf.bspline/main.c:91 ../vector/v.distance/main.c:121
-#: ../vector/v.surf.rst/main.c:147 ../vector/v.build.polylines/main.c:110
-#: ../vector/v.label/main.c:59 ../vector/v.external/main.c:52
-#: ../vector/v.normal/main.c:72 ../vector/v.out.pov/main.c:46
-#: ../vector/v.extrude/main.c:67 ../vector/v.net.iso/main.c:76
-#: ../vector/v.surf.idw/main.c:87 ../vector/v.edit/main.c:54
-#: ../vector/v.timestamp/main.c:35 ../vector/v.in.dxf/main.c:64
-#: ../vector/v.category/main.c:75 ../vector/v.proj/main.c:68
-#: ../vector/v.net.salesman/main.c:127 ../vector/v.buffer/main.c:221
-#: ../vector/v.profile/main.c:153 ../vector/v.label.sa/main.c:38
-#: ../doc/vector/v.example/main.c:50
-#: ../locale/scriptstrings/d.what.rast_to_translate.c:3
-#: ../locale/scriptstrings/d.what.vect_to_translate.c:3
-#: ../locale/scriptstrings/v.build.all_to_translate.c:2
-#: ../locale/scriptstrings/v.centroids_to_translate.c:2
-#: ../locale/scriptstrings/v.clip_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.join_to_translate.c:2
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.db.update_to_translate.c:2
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-#: ../locale/scriptstrings/v.import_to_translate.c:2
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-#: ../locale/scriptstrings/v.report_to_translate.c:2
-#: ../locale/scriptstrings/v.pack_to_translate.c:2
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:2
-#: ../locale/scriptstrings/v.unpack_to_translate.c:2
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:4
-#: ../misc/m.nviz.script/main.c:73 ../misc/m.nviz.image/main.c:54
-msgid "vector"
-msgstr ""
-#: ../raster/r.contour/main.c:91
-msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-#: ../raster/r.contour/main.c:101
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:10
-msgid "Increment between contour levels"
-msgstr ""
-#: ../raster/r.contour/main.c:102 ../raster/r.contour/main.c:110
-#: ../raster/r.contour/main.c:117 ../raster/r.contour/main.c:124
-msgid "Contour levels"
-msgstr ""
-#: ../raster/r.contour/main.c:109
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:11
-msgid "List of contour levels"
-msgstr ""
-#: ../raster/r.contour/main.c:116
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:12
-msgid "Minimum contour level"
-msgstr ""
-#: ../raster/r.contour/main.c:123
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:13
-msgid "Maximum contour level"
-msgstr ""
-#: ../raster/r.contour/main.c:132
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:14
-msgid "Minimum number of points for a contour line (0 -> no limit)"
-msgstr ""
-#: ../raster/r.contour/main.c:140
-#, c-format
-msgid "Neither <%s> nor <%s> option must be specified"
-msgstr ""
-#: ../raster/r.contour/main.c:188 ../vector/v.reclass/main.c:322
-#: ../vector/v.in.lidar/attributes.c:139 ../vector/v.to.points/main.c:197
-#: ../vector/v.in.ogr/main.c:1365 ../vector/v.in.dwg/main.c:244
-#: ../vector/v.in.ascii/main.c:523 ../vector/v.in.dxf/write_vect.c:241
-#: ../raster3d/r3.flow/main.c:67
-#, c-format
-msgid "Unable to create index for table <%s>, key <%s>"
-msgstr ""
-#: ../raster/r.contour/main.c:203 ../vector/v.select/copy_tabs.c:17
-#: ../vector/v.extract/copy_tab.c:57 ../vector/v.generalize/misc.c:134
-#: ../vector/v.voronoi/main.c:384
-msgid "Writing attributes..."
-msgstr ""
-#: ../raster/r.contour/main.c:216 ../vector/v.overlay/area_area.c:348
-#: ../vector/v.overlay/line_area.c:443 ../vector/v.to.points/write.c:57
-#: ../raster3d/r3.flow/flowline.c:60
-#, c-format
-msgid "Unable to insert new record: '%s'"
-msgstr ""
-#: ../raster/r.contour/main.c:263
-#, c-format
-msgid "Range of data: min=%f, max=%f"
-msgstr ""
-#: ../raster/r.contour/main.c:265
-msgid "Range of data: empty"
-msgstr ""
-#: ../raster/r.contour/main.c:293 ../raster/r.contour/main.c:296
-msgid "This step value is not allowed"
-msgstr ""
-#: ../raster/r.contour/main.c:321
-#, c-format
-msgid "Range of levels: min = %f, max = %f"
-msgstr ""
-#: ../raster/r.contour/main.c:350
-msgid "Displacing data..."
-msgstr ""
-#: ../raster/r.neighbors/readweights.c:18
-#, c-format
-msgid "Unable to open weights file %s"
-msgstr ""
-#: ../raster/r.neighbors/readweights.c:23
-#, c-format
-msgid "Error reading weights file %s"
-msgstr ""
-#: ../raster/r.neighbors/main.c:121
-#, c-format
-msgid "Invalid out_type enumeration: %d"
-msgstr ""
-#: ../raster/r.neighbors/main.c:171 ../raster3d/r3.neighbors/main.c:213
-msgid "neighbor"
-msgstr ""
-#: ../raster/r.neighbors/main.c:172 ../raster3d/r3.neighbors/main.c:214
-msgid "focal statistics"
-msgstr ""
-#: ../raster/r.neighbors/main.c:175
-msgid ""
-"Makes each cell category value a function of the category values assigned to"
-" the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-#: ../raster/r.neighbors/main.c:185
-msgid ""
-"Name of an input raster map to select the cells which should be processed"
-msgstr ""
-#: ../raster/r.neighbors/main.c:204 ../vector/v.neighbors/main.c:72
-msgid "Neighborhood operation"
-msgstr ""
-#: ../raster/r.neighbors/main.c:206 ../raster/r.neighbors/main.c:214
-#: ../raster/r.neighbors/main.c:249
-msgid "Neighborhood"
-msgstr ""
-#: ../raster/r.neighbors/main.c:212
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
-msgid "Neighborhood size"
-msgstr ""
-#: ../raster/r.neighbors/main.c:226
-msgid "Text file containing weights"
-msgstr ""
-#: ../raster/r.neighbors/main.c:232
-msgid "Sigma (in cells) for Gaussian filter"
-msgstr ""
-#: ../raster/r.neighbors/main.c:244
-msgid "Do not align output with the input"
-msgstr ""
-#: ../raster/r.neighbors/main.c:248
-msgid "Use circular neighborhood"
-msgstr ""
-#: ../raster/r.neighbors/main.c:256
-msgid "Neighborhood size must be positive"
-msgstr ""
-#: ../raster/r.neighbors/main.c:258
-msgid "Neighborhood size must be odd"
-msgstr ""
-#: ../raster/r.neighbors/main.c:293
-#, c-format
-msgid "%s= and %s= must have the same number of values"
-msgstr ""
-#: ../raster/r.neighbors/main.c:329
-#, c-format
-msgid ""
-"Method %s not compatible with weighing window, using weight mask instead"
-msgstr ""
-#: ../raster/r.neighbors/main.c:337
-#, c-format
-msgid ""
-"Method %s not compatible with Gaussian filter, using unweighed version "
-"instead"
-msgstr ""
-#: ../raster/r.neighbors/main.c:386
-#, c-format
-msgid "Opening selection map <%s>"
-msgstr ""
-#: ../raster/r.out.png/main.c:116
-msgid "Export a GRASS raster map as a non-georeferenced PNG image."
-msgstr ""
-#: ../raster/r.out.png/main.c:122
-msgid "Name for new PNG file (use '-' for stdout)"
-msgstr ""
-#: ../raster/r.out.png/main.c:130
-msgid "Compression level of PNG file"
-msgstr ""
-#: ../raster/r.out.png/main.c:131
-msgid "(0 = none, 1 = fastest, 9 = best)"
-msgstr ""
-#: ../raster/r.out.png/main.c:138
-msgid "Make NULL cells transparent"
-msgstr ""
-#: ../raster/r.out.png/main.c:142
-msgid "Output world file"
-msgstr ""
-#: ../raster/r.out.png/main.c:175 ../display/d.rast/display.c:27
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.graph/main.c:104
-#: ../display/d.labels/color.c:68 ../display/d.legend.vect/draw.c:193
-#: ../display/d.legend.vect/draw.c:204
-#, c-format
-msgid "[%s]: No such color"
-msgstr ""
-#: ../raster/r.out.png/main.c:257
-#, c-format
-msgid "Converting <%s>..."
-msgstr ""
-#: ../raster/r.out.png/main.c:272 ../raster/r.univar/r.univar_main.c:201
-#, c-format
-msgid "Raster <%s> type mismatch"
-msgstr ""
-#: ../raster/r.out.png/main.c:422
-msgid "Writing world file"
-msgstr ""
-#: ../raster/r.out.png/main.c:425
-msgid "Got null file name"
-msgstr ""
-#: ../raster/r.out.png/main.c:427
-msgid "Got null region struct"
-msgstr ""
-#: ../raster/r.out.png/main.c:429
-msgid "Unable to open world file for writing"
-msgstr ""
-#: ../raster/r.spreadpath/main.c:92
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-#: ../raster/r.spreadpath/main.c:98
-msgid "Name of raster map containing back-path easting information"
-msgstr ""
-#: ../raster/r.spreadpath/main.c:103
-msgid "Name of raster map containing back-path northing information"
-msgstr ""
-#: ../raster/r.spreadpath/main.c:108
-msgid "The map E and N grid coordinates of starting points"
-msgstr ""
-#: ../raster/r.spreadpath/main.c:161
-#, c-format
-msgid ""
-"eading the input map -%s- and -%s- and creating some temporary files..."
-msgstr ""
-#: ../raster/r.spreadpath/main.c:281
-msgid "Finding the least cost paths ..."
-msgstr ""
-#: ../raster/r.spreadpath/main.c:296
-#, c-format
-msgid "Writing the output map  -%s-..."
-msgstr ""
-#: ../raster/r.clump/clump.c:53 ../imagery/i.segment/cluster.c:386
-#: ../vector/v.cluster/main.c:406 ../vector/v.cluster/main.c:615
-#: ../vector/v.cluster/main.c:972
-msgid "Generating renumbering scheme..."
-msgstr ""
-#: ../raster/r.clump/clump.c:83
-msgid "Pass 2 of 2..."
-msgstr ""
-#: ../raster/r.clump/clump.c:99 ../raster/r.clump/clump.c:151
-#: ../raster/r.clump/minsize.c:152 ../raster/r.clump/minsize.c:253
-#: ../raster/r.clump/minsize.c:287 ../raster/r.clump/minsize.c:293
-#: ../raster/r.clump/minsize.c:424 ../raster/r.clump/minsize.c:447
-#: ../raster/r.clump/minsize.c:518 ../imagery/i.segment/cluster.c:431
-msgid "Unable to read from temp file"
-msgstr ""
-#: ../raster/r.clump/clump.c:115 ../raster/r.clump/clump.c:347
-#: ../raster/r.clump/clump.c:361 ../raster/r.clump/clump.c:648
-#: ../raster/r.clump/clump.c:662 ../raster/r.clump/minsize.c:163
-#: ../raster/r.clump/minsize.c:390 ../imagery/i.segment/cluster.c:363
-#: ../imagery/i.segment/cluster.c:377
-msgid "Unable to write to temp file"
-msgstr ""
-#: ../raster/r.clump/clump.c:124
-#, c-format
-msgid "%d initial clumps"
-msgstr ""
-#: ../raster/r.clump/clump.c:213 ../raster/r.clump/clump.c:477
-#: ../raster/r.clump/minsize.c:373 ../imagery/i.segment/cluster.c:121
-msgid "Unable to open temp file"
-msgstr ""
-#: ../raster/r.clump/clump.c:235 ../raster/r.clump/clump.c:492
-msgid "Pass 1 of 2..."
-msgstr ""
-#: ../raster/r.clump/clump.c:427
-#, c-format
-msgid "%d-band clumping with threshold %g"
-msgstr ""
-#: ../raster/r.clump/clump.c:451 ../imagery/i.segment/write_output.c:114
-#: ../imagery/i.segment/open_files.c:71 ../imagery/i.segment/open_files.c:246
-#: ../imagery/i.segment/open_files.c:254
-#, c-format
-msgid "No min/max found in raster map <%s>"
-msgstr ""
-#: ../raster/r.clump/main.c:60
-msgid "reclass"
-msgstr ""
-#: ../raster/r.clump/main.c:63
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-#: ../raster/r.clump/main.c:82
-msgid "Threshold to identify similar cells"
-msgstr ""
-#: ../raster/r.clump/main.c:83
-msgid "Valid range: 0 = identical to < 1 = maximal difference"
-msgstr ""
-#: ../raster/r.clump/main.c:90
-msgid "Minimum clump size in cells"
-msgstr ""
-#: ../raster/r.clump/main.c:91
-msgid "Clumps smaller than minsize will be merged to form larger clumps"
-msgstr ""
-#: ../raster/r.clump/main.c:95
-msgid "Clump also diagonal cells"
-msgstr ""
-#: ../raster/r.clump/main.c:96
-msgid "Clumps are also traced along diagonal neighboring cells"
-msgstr ""
-#: ../raster/r.clump/main.c:100
-msgid "Print only the number of clumps in shell script style"
-msgstr ""
-#: ../raster/r.clump/main.c:122
-#, c-format
-msgid "Valid range for option <%s> is 0 <= value < 1"
-msgstr ""
-#: ../raster/r.clump/main.c:180
-#, c-format
-msgid "%d clump."
-msgid_plural "%d clumps."
-msgstr[0] ""
-#: ../raster/r.clump/minsize.c:357
-msgid "Minimum size must be larger than 1"
-msgstr ""
-#: ../raster/r.clump/minsize.c:368
-msgid "Loading input ..."
-msgstr ""
-#: ../raster/r.clump/minsize.c:418
-#, c-format
-msgid "Merging clumps smaller than %d cells..."
-msgstr ""
-#: ../raster/r.clump/minsize.c:509
-#, c-format
-msgid "Renumbering remaining %d clumps..."
-msgstr ""
-#: ../raster/r.clump/rclist.c:17 ../imagery/i.segment/rclist.c:17
-msgid "rclist out of memory"
-msgstr ""
-#: ../raster/r.in.poly/main.c:37
-msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr ""
-#: ../raster/r.in.poly/main.c:41
-msgid "Name of input file; or \"-\" to read from stdin"
-msgstr ""
-#: ../raster/r.in.poly/main.c:60
-msgid "Integer representing NULL value data cell"
-msgstr ""
-#: ../raster/r.in.poly/main.c:66
-msgid "Number of rows to hold in memory"
-msgstr ""
-#: ../raster/r.in.poly/main.c:74
-msgid "Minimum number of rows to hold in memory is 1"
-msgstr ""
-#: ../raster/r.in.poly/main.c:83
-msgid "Type doesn't exist"
-msgstr ""
-#: ../raster/r.in.poly/get_item.c:97
-#, c-format
-msgid "Illegal coordinate <%s, %s>, skipping."
-msgstr ""
-#: ../raster/r.in.poly/get_item.c:102
-#, c-format
-msgid "Illegal north coordinate <%s>, skipping."
-msgstr ""
-#: ../raster/r.in.poly/get_item.c:107
-#, c-format
-msgid "Illegal east coordinate <%s>, skipping."
-msgstr ""
-#: ../raster/r.fill.dir/main.c:88
-msgid "sink"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:89
-msgid "fill sinks"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:90
-msgid "depressions"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:92
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-#: ../raster/r.fill.dir/main.c:99
-msgid "Name for output depressionless elevation raster map"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:103
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:108
-msgid "Name for output raster map of problem areas"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:115
-msgid "Aspect direction format"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:121
-msgid "Find unresolved areas only"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:127
-#, c-format
-msgid "The '%c' flag requires '%s'to be specified"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:148
-msgid "Direction map is D8 resolution, i.e. 45 degrees"
-msgstr ""
-#: ../raster/r.fill.dir/main.c:190
-msgid "Reading input elevation raster map..."
-msgstr ""
-#: ../raster/r.fill.dir/main.c:200
-msgid "Filling sinks..."
-msgstr ""
-#: ../raster/r.fill.dir/main.c:204
-msgid "Determining flow directions for ambiguous cases..."
-msgstr ""
-#: ../raster/r.fill.dir/main.c:217
-msgid "Repeat to get the final directions..."
-msgstr ""
-#: ../raster/r.fill.dir/dopolys.c:84
-#, c-format
-msgid "Found %d unresolved area"
-msgid_plural "Found %d unresolved areas"
-msgstr[0] ""
-#: ../raster/r.fill.dir/resolve.c:136
-#, c-format
-msgid "Downward pass %d"
-msgstr ""
-#: ../raster/r.fill.dir/resolve.c:173
-#, c-format
-msgid "Upward pass %d"
-msgstr ""
-#: ../raster/r.fill.dir/wtrshed.c:95
-#, c-format
-msgid "Watershed pass %d"
-msgstr ""
-#: ../raster/r.sunhours/main.c:76
-msgid "Calculates solar elevation, solar azimuth, and sun hours."
-msgstr ""
-#: ../raster/r.sunhours/main.c:77
-msgid ""
-"Solar elevation: the angle between the direction of the geometric center of "
-"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
-"angle from due north in clockwise direction."
-msgstr ""
-#: ../raster/r.sunhours/main.c:83
-msgid "Output raster map with solar elevation angle"
-msgstr ""
-#: ../raster/r.sunhours/main.c:88
-msgid "Output raster map with solar azimuth angle"
-msgstr ""
-#: ../raster/r.sunhours/main.c:93
-msgid "Output raster map with sunshine hours"
-msgstr ""
-#: ../raster/r.sunhours/main.c:94
-msgid "Sunshine hours require SOLPOS use and Greenwich standard time"
-msgstr ""
-#: ../raster/r.sunhours/main.c:101
-msgid "Year"
-msgstr ""
-#: ../raster/r.sunhours/main.c:109
-msgid "Month"
-msgstr ""
-#: ../raster/r.sunhours/main.c:110
-msgid "If not given, day is interpreted as day of the year"
-msgstr ""
-#: ../raster/r.sunhours/main.c:118
-msgid "Day"
-msgstr ""
-#: ../raster/r.sunhours/main.c:126
-msgid "Hour"
-msgstr ""
-#: ../raster/r.sunhours/main.c:135
-msgid "Minutes"
-msgstr ""
-#: ../raster/r.sunhours/main.c:144
-msgid "Seconds"
-msgstr ""
-#: ../raster/r.sunhours/main.c:151
-msgid "Time is local sidereal time, not Greenwich standard time"
-msgstr ""
-#: ../raster/r.sunhours/main.c:155
-msgid "Do not use SOLPOS algorithm of NREL"
-msgstr ""
-#: ../raster/r.sunhours/main.c:167
-msgid "No output requested, exiting."
-msgstr ""
-#: ../raster/r.sunhours/main.c:193
-msgid "NREL SOLPOS algorithm uses Greenwich standard time."
-msgstr ""
-#: ../raster/r.sunhours/main.c:194 ../raster/r.sunhours/main.c:202
-msgid "Time will be interpreted as Greenwich standard time."
-msgstr ""
-#: ../raster/r.sunhours/main.c:200
-msgid "Time will be interpreted as local sidereal time."
-msgstr ""
-#: ../raster/r.sunhours/main.c:205
-msgid "Sunshine hours require NREL SOLPOS."
-msgstr ""
-#: ../raster/r.sunhours/main.c:210
-msgid "Current projection is x,y (undefined)."
-msgstr ""
-#: ../raster/r.sunhours/main.c:216
-msgid "Cannot get projection info of current location"
-msgstr ""
-#: ../raster/r.sunhours/main.c:219
-msgid "Cannot get projection units of current location"
-msgstr ""
-#: ../raster/r.sunhours/main.c:222
-msgid "Cannot get projection key values of current location"
-msgstr ""
-#: ../raster/r.sunhours/main.c:232 ../general/g.region/printwindow.c:267
-#: ../general/g.region/printwindow.c:488 ../general/g.region/printwindow.c:569
-msgid "Unable to update lat/long projection parameters"
-msgstr ""
-#: ../raster/r.sunhours/main.c:296 ../raster/r.sunhours/main.c:391
-#: ../raster/r.sunmask/g_solposition.c:127
-#: ../general/g.region/printwindow.c:285 ../general/g.region/printwindow.c:293
-#: ../general/g.region/printwindow.c:301 ../general/g.region/printwindow.c:309
-#: ../general/g.region/printwindow.c:319 ../general/g.region/printwindow.c:503
-#: ../general/g.region/printwindow.c:596 ../general/g.region/printwindow.c:608
-#: ../general/g.region/printwindow.c:625 ../general/g.region/printwindow.c:643
-#: ../general/g.region/printwindow.c:658
-msgid "Error in pj_do_proj (projection of input coordinate pair)"
-msgstr ""
-#: ../raster/r.sunhours/main.c:324 ../raster/r.sunhours/main.c:335
-#: ../raster/r.sunhours/main.c:346 ../raster/r.mapcalc/map3.c:607
-#: ../imagery/i.landsat.toar/main.c:566
-#: ../imagery/i.landsat.acca/algorithm.c:234
-#: ../imagery/i.landsat.acca/algorithm.c:388
-#: ../imagery/i.landsat.acca/tools.c:136
-#, c-format
-msgid "Unable to create raster map <%s>"
-msgstr ""
-#: ../raster/r.sunhours/main.c:356
-msgid "Calculating solar elevation and azimuth..."
-msgstr ""
-#: ../raster/r.sunhours/main.c:359
-msgid "Calculating solar elevation..."
-msgstr ""
-#: ../raster/r.sunhours/main.c:362
-msgid "Calculating solar azimuth..."
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:994 ../raster/r.sunmask/solpos00.c:950
-#, c-format
-msgid "S_decode ==> Please fix the year: %d [1950-2050]"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:997 ../raster/r.sunmask/solpos00.c:953
-#, c-format
-msgid "S_decode ==> Please fix the month: %d"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:999 ../raster/r.sunmask/solpos00.c:955
-#, c-format
-msgid "S_decode ==> Please fix the day-of-month: %d"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1002 ../raster/r.sunmask/solpos00.c:958
-#, c-format
-msgid "S_decode ==> Please fix the day-of-year: %d"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1005 ../raster/r.sunmask/solpos00.c:961
-#, c-format
-msgid "S_decode ==> Please fix the hour: %d"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1007 ../raster/r.sunmask/solpos00.c:963
-#, c-format
-msgid "S_decode ==> Please fix the minute: %d"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1009 ../raster/r.sunmask/solpos00.c:965
-#, c-format
-msgid "S_decode ==> Please fix the second: %d"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1011 ../raster/r.sunmask/solpos00.c:967
-#, c-format
-msgid "S_decode ==> Please fix the time zone: %f"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1014 ../raster/r.sunmask/solpos00.c:970
-#, c-format
-msgid "S_decode ==> Please fix the interval: %d"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1017 ../raster/r.sunmask/solpos00.c:973
-#, c-format
-msgid "S_decode ==> Please fix the latitude: %f"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1020 ../raster/r.sunmask/solpos00.c:976
-#, c-format
-msgid "S_decode ==> Please fix the longitude: %f"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1023 ../raster/r.sunmask/solpos00.c:979
-#, c-format
-msgid "S_decode ==> Please fix the temperature: %f"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1026 ../raster/r.sunmask/solpos00.c:982
-#, c-format
-msgid "S_decode ==> Please fix the pressure: %f"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1028 ../raster/r.sunmask/solpos00.c:984
-#, c-format
-msgid "S_decode ==> Please fix the tilt: %f"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1030 ../raster/r.sunmask/solpos00.c:986
-#, c-format
-msgid "S_decode ==> Please fix the aspect: %f"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1032 ../raster/r.sunmask/solpos00.c:988
-#, c-format
-msgid "S_decode ==> Please fix the shadowband width: %f"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1035 ../raster/r.sunmask/solpos00.c:991
-#, c-format
-msgid "S_decode ==> Please fix the shadowband radius: %f"
-msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1038 ../raster/r.sunmask/solpos00.c:994
-#, c-format
-msgid "S_decode ==> Please fix the shadowband sky factor: %f"
-msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
-msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:88
-#, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
-msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
-msgid "Unable to get projection info of current location"
-msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:101 ../raster/r.latlong/main.c:103
-msgid "Unable to get projection units of current location"
-msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:104 ../raster/r.latlong/main.c:105
-msgid "Unable to get projection key values of current location"
-msgstr ""
-#: ../raster/r.sunmask/main.c:120
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
-msgstr ""
-#: ../raster/r.sunmask/main.c:121
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-#: ../raster/r.sunmask/main.c:135
-msgid "Altitude of the sun in degrees above the horizon (A)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:136 ../raster/r.sunmask/main.c:145
-#: ../raster/r.sunmask/main.c:213 ../raster/r.sunmask/main.c:223
-#: ../display/d.text/main.c:199 ../display/d.text/main.c:208
-#: ../display/d.text/main.c:217 ../display/d.text/main.c:254
-#: ../display/d.text/main.c:259
-msgid "Position"
-msgstr ""
-#: ../raster/r.sunmask/main.c:144
-msgid "Azimuth of the sun in degrees from north (A)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:151
-msgid "Year (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:159
-msgid "Month (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:167
-msgid "Day (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:175
-msgid "Hour (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:183
-msgid "Minutes (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:191
-msgid "Seconds (B)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:201
-msgid "Timezone"
-msgstr ""
-#: ../raster/r.sunmask/main.c:202
-msgid "East positive, offset from GMT, also use to adjust daylight savings"
-msgstr ""
-#: ../raster/r.sunmask/main.c:211
-msgid "Easting coordinate (point of interest)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:212 ../raster/r.sunmask/main.c:222
-msgid "Default: map center"
-msgstr ""
-#: ../raster/r.sunmask/main.c:221
-msgid "Northing coordinate (point of interest)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:227
-msgid "Do not ignore zero elevation"
-msgstr ""
-#: ../raster/r.sunmask/main.c:231
-msgid "Calculate sun position only and exit"
-msgstr ""
-#: ../raster/r.sunmask/main.c:237
-msgid "Print the sun position output in shell script style"
-msgstr ""
-#: ../raster/r.sunmask/main.c:251
-#, c-format
-msgid "Using map center coordinates: %f %f"
-msgstr ""
-#: ../raster/r.sunmask/main.c:258
-msgid "Empty east coordinate specified"
-msgstr ""
-#: ../raster/r.sunmask/main.c:260
-msgid "Empty north coordinate specified"
-msgstr ""
-#: ../raster/r.sunmask/main.c:279
-msgid "Either define sun position or location/date/time parameters"
-msgstr ""
-#: ../raster/r.sunmask/main.c:282
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
-msgstr ""
-#: ../raster/r.sunmask/main.c:286
-#, c-format
-msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:291
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:399
-msgid "Please correct settings"
-msgstr ""
-#: ../raster/r.sunmask/main.c:413
-#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:417
-#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise"
-msgstr ""
-#: ../raster/r.sunmask/main.c:420 ../raster/r.sunmask/main.c:430
-msgid "Nothing to calculate. Please verify settings."
-msgstr ""
-#: ../raster/r.sunmask/main.c:424
-#, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
-msgstr ""
-#: ../raster/r.sunmask/main.c:428
-#, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset"
-msgstr ""
-#: ../raster/r.sunmask/main.c:439
-msgid "You already know the sun position"
-msgstr ""
-#: ../raster/r.sunmask/main.c:444 ../vector/v.colors/main.c:199
-#, c-format
-msgid "Option <%s> required"
-msgstr ""
-#: ../raster/r.sunmask/main.c:456
-#, c-format
-msgid "Unable to open range file for raster map <%s>"
-msgstr ""
-#: ../raster/r.sunmask/main.c:472
-msgid "Calculating shadows from DEM..."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:12
-msgid ""
-"\n"
-"\n"
-"Please indicate which map layers you wish to use in the lumped"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:13
-msgid "parameter hydrologic/soil erosion model.  Continue inputing cell map"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:14
-msgid "layers, one at a time, until all desired map layers are in."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:15
-#, c-format
-msgid "You can have %s include a list of categories in each."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:17
-#, c-format
-msgid ""
-"\n"
-"Hit <return> at the map prompt to continue with %s"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:36
-#, c-format
-msgid ""
-"\n"
-"The output from %s will be divided into watershed"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:38
-msgid "basins.  There are two possible methods of tabulating the information:"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:39
-msgid "1) by only including data pertaining to the basin itself, or 2) using"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:40
-msgid "data from the basin, and all basins upstream of it."
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:43
-msgid ""
-"\n"
-"Would you like the data organized:"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:44
-msgid ""
-"1) Basin only\n"
-"2) Upstream only\n"
-"3) Both\n"
-"OR 0) to cancel program"
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:45
-#, c-format
-msgid ""
-"\n"
-"Your choice: "
-msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:69
-#: ../raster/r.watershed/shed/basin_maps.c:73
-#, c-format
-msgid ""
-"\n"
-"OK, %s should start running now using the following form:\n"
-"%s"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:23
-msgid ""
-"\n"
-"This set of questions will organize the command line for the"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:24
-#, c-format
-msgid "%s program to run properly for your application."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:26
-#, c-format
-msgid "The first question is whether you want %s to run"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:28
-#, c-format
-msgid "in its fast mode or its slow mode.  If you run %s"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:30
-msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:31
-msgid "than in the slow mode, but will not allow other programs to run"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:32
-msgid "at the same time.  The fast mode also places all of the data into"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:33
-msgid "RAM, which limits the size of window that can be run.  The slow"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:34
-msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:35
-msgid "stored.  Thus, if the program does not work in the slow mode, you will"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:36
-msgid "need to remove unnecessary files from that partition.  The slow mode"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:37
-#, c-format
-msgid "will allow other processes to run concurrently with %s.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:69
-#: ../raster/r.watershed/shed/com_line.c:182
-msgid ""
-"\n"
-"If you hit <return> by itself for the next question, this"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:70
-#: ../raster/r.watershed/shed/com_line.c:183
-msgid "program will terminate."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:81
-#, c-format
-msgid ""
-"\n"
-"One of the options for %s is a `depression map'.  A"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:86
-msgid ""
-"have a depression map, prepare a map where non-zero values indicate the"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:87
-msgid "locations where depressions occur.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:99
-#, c-format
-msgid ""
-"\n"
-"The %s program will divide the elevation map into a number of"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins.  The number of watershed basins is indirectly determined"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value.  The basin threshold is the area necessary "
-"for"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:103
-#, c-format
-msgid "%s to define a unique watershed basin.  This area only applies to"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'.  An exterior drainage basin does not have any"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it.  Interior drainage basin size is determined"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:108
-#, c-format
-msgid "Thus interior drainage basins can be of any size.  The %s program"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:110
-msgid "also allows the user to relate basin size to potential overland flow"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration "
-"rates)."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:114
-#, c-format
-msgid "%s will accumulate those values instead of area.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:116
-msgid "What unit of measure will you use for the basin threshold:"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:119
-msgid " 1) acres,          2) meters sq., 3) miles sq., 4) hectares,"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:120
-msgid " 5) kilometers sq., 6) map cells,  7) overland flow units"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:121
-#, c-format
-msgid "Choose 1-7 or 0 to exit this program: "
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:131
-msgid ""
-"\n"
-"How large an area (or how many overland flow units) must a drainage basin"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:132
-#, c-format
-msgid "be for it to be an exterior drainage basin: "
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:201
-#, c-format
-msgid ""
-"\n"
-"%s must create a map layer of watershed basins"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:203
-#: ../raster/r.watershed/shed/com_line.c:224
-#, c-format
-msgid "before %s can run properly."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:222
-#, c-format
-msgid ""
-"\n"
-"%s must create a file of watershed basin relationships"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:228
-#: ../raster/r.watershed/shed/com_line.c:263
-#, c-format
-msgid ""
-"\n"
-"Please name this file:"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:231
-#: ../raster/r.watershed/shed/com_line.c:266 ../raster/r.geomorphon/main.c:196
-#: ../general/g.rename/main.c:85 ../general/g.copy/main.c:80
-#: ../imagery/i.landsat.toar/main.c:563 ../imagery/i.landsat.acca/main.c:188
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
-#, c-format
-msgid "<%s> is an illegal file name"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:257
-#, c-format
-msgid ""
-"\n"
-"%s will generate a lot of output.  Indicate a file"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:259
-#, c-format
-msgid "name for %s to send the output to."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:277
-#, c-format
-msgid ""
-"\n"
-"The accumulation map from %s must be present for"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:279
-#, c-format
-msgid "%s to work properly."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:290
-#, c-format
-msgid ""
-"\n"
-"%s can produce several maps not necessary for"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:292
-#, c-format
-msgid "%s to function (stream channels, overland flow aspect, and"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:294
-#, c-format
-msgid "a display version of the accumulation map).  %s also has the"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:297
-msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:348
-msgid ""
-"\n"
-"The Slope Length factor (LS) and Slope Steepness (S) are influenced by"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:349
-#, c-format
-msgid "disturbed land.  %s reflects this with an optional map layer or value"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:352
-msgid "Type <return> if you do not have a disturbed land map layer."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:364
-msgid ""
-"\n"
-"Type the value indicating the percent of disturbed land.  This value will"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:365
-msgid "be used for every cell in the current region."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:368
-#, c-format
-msgid ""
-"\n"
-"Input value here [0-100]: "
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:379
-msgid ""
-"\n"
-"Overland surface flow only occurs for a set distance before swales form."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:380
-#, c-format
-msgid "Because of digital terrain model limitations, %s cannot pick up"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:382
-#, c-format
-msgid "these swales.  %s allows for an input (warning: kludge factor)"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long.  Normally,"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:385
-msgid "maximum slope length is around 600 feet (about 183 meters)."
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:400
-msgid ""
-"\n"
-"Roads, ditches, changes in ground cover, and other factors will stop"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length.  You may input a raster map indicating the locations of these"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:402
-msgid "blocking factors.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
-msgstr ""
-#: ../raster/r.watershed/shed/file_in.c:15
-msgid "unable to open ARMSED file"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:8
-#, c-format
-msgid "%s provides a text-based user-interface to the %s program."
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:10
-#, c-format
-msgid "%s also allows the user to prepare a report of map layers for each"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:12
-#, c-format
-msgid "watershed basin determined in %s.\n"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:14
-#, c-format
-msgid "%s will help the user determine which options to use for the"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:16
-#, c-format
-msgid "%s program.  %s will then ask for map layers that will be"
-msgstr ""
-#: ../raster/r.watershed/shed/intro.c:18
-#, c-format
-msgid "divided by basin. %s will then run %s and create the report."
-msgstr ""
-#: ../raster/r.watershed/shed/main.c:41
-msgid "Slow version of water analysis program starting now"
-msgstr ""
-#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
-#, c-format
-msgid "<<%s>> command line failed"
-msgstr ""
-#: ../raster/r.watershed/shed/main.c:72
-msgid "unable to open output file"
-msgstr ""
-#: ../raster/r.watershed/shed/read.c:23
-msgid "unable to open basin/half basin map"
-msgstr ""
-#: ../raster/r.watershed/shed/valid.c:24
-msgid "accum file missing in valid_basins()"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:76
-#: ../raster/r.series.accumulate/main.c:82
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:3
-msgid "accumulation"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:77
-msgid "drainage"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:79
-msgid "stream power index"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:80 ../raster/r.topidx/main.c:42
-msgid "topographic index"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:81
-msgid "Calculates hydrological parameters and RUSLE factors."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:84 ../raster/r.watershed/front/main.c:91
-#: ../raster/r.watershed/front/main.c:97
-#: ../raster/r.watershed/front/main.c:104
-#: ../raster/r.watershed/front/main.c:113
-#: ../raster/r.watershed/front/main.c:121
-#: ../raster/r.watershed/front/main.c:130
-msgid "Inputs"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:88
-msgid "Name of input depressions raster map"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:89
-msgid "All non-NULL and non-zero cells are considered as real depressions"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:95
-msgid "Name of input raster representing amount of overland flow per cell"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:101
-msgid "Name of input raster map percent of disturbed land"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:102
-#: ../raster/r.watershed/front/main.c:127
-msgid "For USLE"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:109
-msgid "Name of input raster map blocking overland surface flow"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:111
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking "
-"terrain."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:118
-msgid "Minimum size of exterior watershed basin"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:126
-msgid "Maximum length of surface flow in map units"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:135
-msgid "Name for output accumulation raster map"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:137
-msgid "Number of cells that drain through each cell"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:144
-msgid "Name for output topographic index ln(a / tan(b)) map"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:151
-msgid "Stream power index a * tan(b)"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:157
-msgid "Name for output drainage direction raster map"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:158
-msgid "Directions numbered from 1 to 8"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:164
-msgid "Name for output basins raster map"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:170
-msgid "Name for output stream segments raster map"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:176
-msgid "Name for output half basins raster map"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:178
-msgid "Each half-basin is given a unique value"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:184
-msgid "Name for output slope length raster map"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:186
-msgid "Slope length and steepness (LS) factor for USLE"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:192
-msgid "Name for output slope steepness raster map"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:193
-msgid "Slope steepness (S) factor for USLE"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:202
-msgid "Convergence factor for MFD (1-10)"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:204
-msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:211
-msgid "Maximum memory to be used with -m flag (in MB)"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:215
-msgid "SFD (D8) flow (default is MFD)"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:217
-msgid "SFD: single flow direction, MFD: multiple flow direction"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:222
-msgid "Allow only horizontal and vertical flow of water"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:227
-msgid "Enable disk swap memory option: Operation is slow"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:229
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:234
-msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:236
-msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:241
-msgid "Beautify flat areas"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:243
-msgid "Flow direction in flat areas is modified to look prettier"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:259
-msgid "Sorry, you must choose an output map."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:265
-msgid "The basin threshold must be a positive number."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:281
-msgid ""
-"Sorry, if any of the following options are set:\n"
-"    basin, stream, half_basin, length_slope, or slope_steepness\n"
-"    you MUST provide a value for the basin threshold parameter."
-msgstr ""
-#: ../raster/r.watershed/front/main.c:308
-msgid "Beautify flat areas is not yet supported for disk swap mode"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:338
-#, c-format
-msgid "Subprocess failed with exit code %d"
-msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:119
-#: ../raster/r.watershed/ram/do_cum.c:114
-msgid "SECTION 3: Accumulating Surface Flow with SFD."
-msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:293
-#: ../raster/r.watershed/ram/do_cum.c:276
-msgid "SECTION 3a: Accumulating Surface Flow with MFD."
-msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:529
-msgid "MFD: A * path already processed when distributing flow: %d of %"
-msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:533
-#: ../raster/r.watershed/ram/do_cum.c:486
-msgid "SECTION 3b: Adjusting drainage directions."
-msgstr ""
-#: ../raster/r.watershed/seg/main.c:92 ../raster/r.watershed/seg/main.c:107
-#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
-#, c-format
-msgid "SECTION %d: Closing Maps."
-msgstr ""
-#: ../raster/r.watershed/seg/main.c:105 ../raster/r.watershed/ram/main.c:96
-#, c-format
-msgid "SECTION %d: Watershed determination."
-msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:30
-#: ../raster/r.watershed/ram/do_astar.c:27
-msgid "SECTION 2: A* Search."
-msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:48
-msgid "No seeds for A* Search"
-msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:146
-msgid "bug in A* Search: doer %"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:20
-msgid "Closing accumulation map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:136
-msgid "Closing TCI and SPI maps"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:138
-msgid "Closing TCI map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:140
-msgid "Closing SPI map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:300
-msgid "Closing flow direction map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:327
-msgid "Closing LS map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:332
-msgid "Closing SL map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:38
-#: ../raster/r.watershed/ram/close_maps2.c:34
-msgid "No basins were created. Verify threshold and region settings."
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:86
-msgid "Closing stream segments map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:109
-msgid "Closing basins map"
-msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:116
-msgid "Closing half basins map"
-msgstr ""
-#: ../raster/r.watershed/seg/sg_factor.c:14
-msgid "SECTION 5: RUSLE LS and/or S factor determination."
-msgstr ""
-#: ../raster/r.watershed/seg/usage.c:9 ../raster/r.watershed/ram/usage.c:9
-#, c-format
-msgid ""
-"USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
-"\n"
-"USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
-"\n"
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:139
-#, c-format
-msgid "SECTION 1 beginning: Initiating Variables. %d section total."
-msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
-msgstr[0] ""
-#: ../raster/r.watershed/seg/init_vars.c:175
-msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
-msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:470
-msgid "SECTION 1b: Determining Offmap Flow."
-msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:480
-#, c-format
-msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
-msgid_plural ""
-"MFD: A * path already processed when distributing flow: %d of %d cells"
-msgstr[0] ""
-#: ../raster/r.watershed/ram/do_astar.c:256
-msgid "heapsize too large"
-msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:121
-#, c-format
-msgid "SECTION 1a (of %1d): Initiating Memory."
-msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:311
-#, c-format
-msgid "SECTION 1b (of %1d): Determining Offmap Flow."
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:56
-msgid "Beautify flat areas: priority queue error"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:229
-msgid "flat cell escaped for uphill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:235
-#, c-format
-msgid "queue error: last uphill order %d > current uphill order %d"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:240
-msgid "uphill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:266
-msgid "flat cell escaped in uphill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:302
-msgid "downhill order: no more points in down queue"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:310
-msgid "flat cell escaped for downhill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:316
-#, c-format
-msgid "queue error: last downhill order %d > current downhill order %d"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:321
-msgid "downhill order: downhill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:344
-msgid "flat cell escaped in downhill correction"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:382
-msgid "flat cell escaped for adjustment"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:389
-msgid "adjustment: uphill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:391
-msgid "adjustment: downhill order not set"
-msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:417
-msgid "flat cell escaped in adjustment"
-msgstr ""
-#: ../raster/r.watershed/ram/sg_factor.c:14
-msgid "SECTION 4: RUSLE LS and/or S factor determination."
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:59
-msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:64 ../raster/r.composite/main.c:90
-#: ../display/d.rgb/main.c:69
-#, c-format
-msgid "Name of raster map to be used for <%s>"
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:84
-msgid "Name for new PPM file. (use '-' for stdout)"
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:88
-msgid "Add comments to describe the region"
-msgstr ""
-#: ../raster/r.out.ppm3/main.c:95 ../raster/r.out.ppm/main.c:101
-#, c-format
-msgid "row = %d"
-msgid_plural "rows = %d"
-msgstr[0] ""
-#. GTC Raster columns
-#: ../raster/r.out.ppm3/main.c:97 ../raster/r.out.ppm/main.c:102
-#, c-format
-msgid "column = %d"
-msgid_plural "columns = %d"
-msgstr[0] ""
-#: ../raster/r.out.ppm3/main.c:160
-msgid "Converting... "
-msgstr ""
-#: ../raster/r.out.ppm/main.c:56
-msgid "Converts a GRASS raster map to a PPM image file."
-msgstr ""
-#: ../raster/r.out.ppm/main.c:64
-msgid "Name for new PPM file (use '-' for stdout)"
-msgstr ""
-#: ../raster/r.out.ppm/main.c:68
-msgid "Output greyscale instead of color"
-msgstr ""
-#: ../raster/r.out.ppm/main.c:72
-msgid "Suppress printing of PPM header"
-msgstr ""
-#: ../raster/r.out.ppm/main.c:124
-#, c-format
-msgid "Unable to open file <%s> for write"
-msgstr ""
-#: ../raster/r.out.ppm/main.c:154
-msgid "Converting..."
-msgstr ""
-#: ../raster/r.out.ppm/main.c:234
-#, c-format
-msgid "File <%s> created"
-msgstr ""
-#: ../raster/r.surf.random/main.c:40
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
-msgstr ""
-#: ../raster/r.surf.random/main.c:46
-msgid "Minimum random value"
-msgstr ""
-#: ../raster/r.surf.random/main.c:52
-msgid "Maximum random value"
-msgstr ""
-#: ../raster/r.surf.random/main.c:58
-msgid "Create an integer raster map"
-msgstr ""
-#: ../raster/r.quant/main.c:49
-msgid "quantization"
-msgstr ""
-#: ../raster/r.quant/main.c:51
-msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-#: ../raster/r.quant/main.c:59
-msgid "Raster map(s) to be quantized"
-msgstr ""
-#: ../raster/r.quant/main.c:64
-msgid "Path to rules file (\"-\" to read from stdin)"
-msgstr ""
-#: ../raster/r.quant/main.c:70
-msgid "Base map to take quant rules from"
-msgstr ""
-#: ../raster/r.quant/main.c:75
-msgid "Floating point range: dmin,dmax"
-msgstr ""
-#: ../raster/r.quant/main.c:81
-msgid "Integer range: min,max"
-msgstr ""
-#: ../raster/r.quant/main.c:86
-msgid "Truncate floating point data"
-msgstr ""
-#: ../raster/r.quant/main.c:90
-msgid "Round floating point data"
-msgstr ""
-#: ../raster/r.quant/main.c:111
-#, c-format
-msgid "-%c, -%c, %s=, %s= and %s= are mutually exclusive"
-msgstr ""
-#: ../raster/r.quant/main.c:120
-#, c-format
-msgid "%s= and %s= must be used together"
-msgstr ""
-#: ../raster/r.quant/main.c:131
-#, c-format
-msgid "%s is integer map, it can't be quantized"
-msgstr ""
-#: ../raster/r.quant/main.c:139
-msgid "Truncating..."
-msgstr ""
-#: ../raster/r.quant/main.c:144
-msgid "Rounding..."
-msgstr ""
-#: ../raster/r.quant/main.c:152
-#, c-format
-msgid "%s is integer map, it can't be used as basemap"
-msgstr ""
-#: ../raster/r.quant/main.c:156
-#, c-format
-msgid "unable to read quant rules for basemap <%s>"
-msgstr ""
-#: ../raster/r.quant/main.c:163 ../raster/r.quant/main.c:166
-#, c-format
-msgid "invalid value for %s= <%s>"
-msgstr ""
-#: ../raster/r.quant/main.c:168
-#, c-format
-msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
-msgstr ""
-#: ../raster/r.quant/main.c:181
-msgid "No rules specified. Quant table(s) not changed."
-msgstr ""
-#: ../raster/r.quant/main.c:189
-#, c-format
-msgid "New quant table created for %s"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:50
-msgid "Old data range is empty"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:56
-#, c-format
-msgid "Old data range is %s to %s"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:59
-msgid "Old integer data range is empty"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:61
-#, c-format
-msgid "Old integer data range is %d to %d"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:83
-#, c-format
-msgid "unable to open input file <%s>"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:89
-#, c-format
-msgid ""
-"\n"
-"Enter the rule or 'help' for the format description or 'end' to exit:\n"
-msgstr ""
-#: ../raster/r.quant/read_rules.c:112
-msgid "quant rules do not cover the whole range map"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:61
-msgid "Creates/modifies the color table associated with a 3D raster map."
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:65
-msgid "Creates/modifies the color table associated with a raster map."
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:75 ../raster/r.colors/edit_colors.c:87
-msgid "Map"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:81
-msgid "Input file with one map name per line"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:83
-msgid ""
-"Input map names can be defined in an input file in case a large amount of "
-"maps must be specified. This option is mutual exclusive to the map option."
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:96 ../vector/v.colors/main.c:98
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
-msgid "Raster map from which to copy color table"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:103 ../vector/v.colors/main.c:105
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:10
-msgid "3D raster map from which to copy color table"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:109 ../vector/v.colors/main.c:111
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:12
-msgid "Path to rules file"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:110
-msgid "\"-\" to read rules from stdin"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:115 ../vector/v.colors/main.c:121
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
-msgid "Remove existing color table"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:121 ../vector/v.colors/main.c:127
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
-msgid "Only write new color table if it does not already exist"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:126 ../vector/v.colors/main.c:131
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:17
-msgid "List available rules then exit"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:132 ../vector/v.colors/main.c:137
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:19
-msgid "Invert colors"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:137 ../vector/v.colors/main.c:142
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:21
-msgid "Logarithmic scaling"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:142 ../vector/v.colors/main.c:147
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:23
-msgid "Logarithmic-absolute scaling"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:147
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:25
-msgid "Histogram equalization"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:186 ../raster/r.series.interp/main.c:180
-#, c-format
-msgid "Unable to open %s file <%s>"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:229 ../raster/r.colors/edit_colors.c:262
-#, c-format
-msgid "%s map <%s> not found"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:235
-#, c-format
-msgid "No %s map name found in input file <%s>"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:278
-#, c-format
-msgid "Unable to remove color table of %s map <%s>"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:280
-#, c-format
-msgid "Color table of %s map <%s> not found"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:302
-#, c-format
-msgid "Color table exists for %s map <%s>. Exiting."
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:358
-#, c-format
-msgid "Color table 'random' is not supported for floating point %s map"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:362
-#, c-format
-msgid "Color table 'grey.eq' is not supported for floating point %s map"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:368
-#, c-format
-msgid "Color table 'grey.log' is not supported for floating point %s map"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:376 ../imagery/i.vi/main.c:546
-#, c-format
-msgid "Unknown color request '%s'"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:386 ../vector/v.colors/make_colors.c:51
-#, c-format
-msgid "Unable to load rules file <%s>"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:400
-#: ../raster/r.univar/r3.univar_main.c:144
-#: ../raster/r.univar/r3.univar_main.c:182 ../general/g.region/main.c:455
-#: ../vector/v.colors/main.c:319 ../raster3d/r3.support/main.c:135
-#: ../raster3d/r3.neighbors/main.c:229 ../raster3d/r3.stats/main.c:97
-#: ../raster3d/r3.out.vtk/main.c:142 ../raster3d/r3.out.bin/main.c:299
-#: ../raster3d/r3.cross.rast/main.c:245 ../raster3d/r3.retile/main.c:113
-#: ../raster3d/r3.timestamp/main.c:73 ../raster3d/r3.flow/main.c:87
-#: ../raster3d/r3.out.netcdf/main.c:600 ../raster3d/r3.mask/main.c:58
-#: ../raster3d/r3.out.ascii/main.c:326 ../raster3d/r3.out.v5d/main.c:307
-#: ../raster3d/r3.null/main.c:103 ../raster3d/r3.to.rast/main.c:275
-#, c-format
-msgid "3D raster map <%s> not found"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:403 ../vector/v.colors/main.c:322
-#, c-format
-msgid "Unable to read color table for 3D raster map <%s>"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:447
-#, c-format
-msgid "Color table for %s map <%s> set to '%s'"
-msgstr ""
-#: ../raster/r.colors/rules.c:40
-#, c-format
-msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:49
-#, c-format
-msgid "fp: Data range is %s to %s\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:53
-#, c-format
-msgid "Data range is %ld to %ld\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:64
-#, c-format
-msgid ""
-"Your color rules do not cover the whole range of data!\n"
-" (rules %f to %f but data %f to %f)"
-msgstr ""
-#: ../raster/r.colors/rules.c:104 ../raster/r.reclass/parse.c:41
-#, c-format
-msgid "Enter a rule in one of these formats:\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:105
-#, c-format
-msgid " val color\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:106
-#, c-format
-msgid " n%% color\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:107
-#, c-format
-msgid " nv color\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:108
-#, c-format
-msgid " default color\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:109
-#, c-format
-msgid "color can be one of:\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:111
-#, c-format
-msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
-msgstr ""
-#: ../raster/r.colors/rules.c:132
-#, c-format
-msgid "bad rule (%s); rule not added"
-msgstr ""
-#: ../raster/r.colors/rules.c:134
-#, c-format
-msgid "bad rule (%s): [%s]"
-msgstr ""
-#: ../raster/r.colors/stats.c:39
-#, c-format
-msgid "(%i/%i) Reading raster map <%s>..."
-msgstr ""
-#: ../raster/r.colors/stats.c:73
-msgid "Unable to use logarithmic scaling if range includes zero"
-msgstr ""
-#: ../raster/r.colors/stats.c:118
-msgid "Error opening 3d raster map"
-msgstr ""
-#: ../raster/r.colors/stats.c:125
-#, c-format
-msgid "(%i/%i) Reading map <%s>..."
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:264
-msgid "Resamples raster map layers to a coarser grid using aggregation."
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:274
-msgid "Aggregation method"
-msgstr ""
-#: ../raster/r.resamp.stats/main.c:292
-msgid "Weight according to area (slower)"
-msgstr ""
-#: ../raster/r.resample/main.c:57
-msgid "GRASS raster map layer data resampling capability."
-msgstr ""
-#: ../raster/r.resample/main.c:66
-msgid "Name of an input layer"
-msgstr ""
-#: ../raster/r.resample/main.c:73
-msgid "Name of an output layer"
-msgstr ""
-#: ../raster/r.resample/main.c:138
-msgid "Creating new cats file..."
-msgstr ""
-#: ../raster/r.topidx/file_io.c:35
-#, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or"
-" coarser than, the input map's resolution."
-msgstr ""
-#: ../raster/r.topidx/file_io.c:42
-msgid "Reading elevation map..."
-msgstr ""
-#: ../raster/r.topidx/file_io.c:87
-msgid "Writing topographic index map..."
-msgstr ""
-#: ../raster/r.topidx/topidx.c:272
-#, c-format
-msgid "Number of sinks or boundaries: %d"
-msgstr ""
-#: ../raster/r.topidx/main.c:41
-msgid "wetness"
-msgstr ""
-#: ../raster/r.topidx/main.c:44
-msgid ""
-"Creates a topographic index (wetness index) raster map from an elevation "
-"raster map."
-msgstr ""
-#: ../raster/r.topidx/main.c:50
-msgid "Name for output topographic index raster map"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:86
-msgid "Computing histograms"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:123
-msgid "No cells found where both base and cover are not NULL"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:315
-msgid "Printing quantiles"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:412
-msgid "Generating reclass maps"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:454
-msgid "Writing output maps"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:520
-msgid "Compute category quantiles using two passes."
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:547
-msgid "Resultant raster map(s)"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:569
-msgid "Do not create output maps; just print statistics"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:574
-msgid "Print statistics in table format"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:586
-#, c-format
-msgid "Either -%c or %s= must be given"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:615
-#, c-format
-msgid "Number of quantiles (%d) does not match number of output maps (%d)"
-msgstr ""
-#: ../raster/r.stats.quantile/main.c:632
-#, c-format
-msgid ""
-"Base map <%s> has many categories (%d), computation might be slow and might "
-"need a lot of memory"
-msgstr ""
-#: ../raster/r.describe/describe.c:94
-#, c-format
-msgid "Reading <%s> ..."
-msgstr ""
-#: ../raster/r.describe/main.c:57
-msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-#: ../raster/r.describe/main.c:71
-msgid "Number of quantization steps"
-msgstr ""
-#: ../raster/r.describe/main.c:77
-msgid "Print the output one value per line"
-msgstr ""
-#: ../raster/r.describe/main.c:81
-msgid "Only print the range of the data"
-msgstr ""
-#: ../raster/r.describe/main.c:85
-msgid "Suppress reporting of any NULLs"
-msgstr ""
-#: ../raster/r.describe/main.c:89
-msgid "Use the current region"
-msgstr ""
-#: ../raster/r.describe/main.c:93
-msgid "Read floating-point map as integer"
-msgstr ""
-#: ../raster/r.describe/main.c:105
-#, c-format
-msgid "%s = %s -- must be greater than zero"
-msgstr ""
-#: ../raster/r.regression.line/main.c:50
-msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr ""
-#: ../raster/r.reclass/main.c:52
-msgid "Reclassify raster map based on category values."
-msgstr ""
-#: ../raster/r.reclass/main.c:54
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
-msgstr ""
-#: ../raster/r.reclass/main.c:59
-msgid "Name of raster map to be reclassified"
-msgstr ""
-#: ../raster/r.reclass/main.c:65
-msgid "File containing reclass rules"
-msgstr ""
-#: ../raster/r.reclass/main.c:83
-msgid "Input map can NOT be the same as output map"
-msgstr ""
-#: ../raster/r.reclass/main.c:89
-#, c-format
-msgid "Cannot open rules file <%s>"
-msgstr ""
-#: ../raster/r.reclass/main.c:103
-#, c-format
-msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:105
-#, c-format
-msgid "FCELL: Data range is %.7g to %.7g\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:108
-#, c-format
-msgid "DCELL: Data range is %.15g to %.15g\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:111
-#, c-format
-msgid "CELL: Data range is %ld to %ld\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:119
-#, c-format
-msgid "Illegal reclass rule -"
-msgstr ""
-#: ../raster/r.reclass/main.c:120
-#, c-format
-msgid " ignored\n"
-msgstr ""
-#: ../raster/r.reclass/main.c:123
-msgid " - invalid reclass rule"
-msgstr ""
-#: ../raster/r.reclass/main.c:139
-#, c-format
-msgid "No rules specified. Raster map <%s> not created"
-msgstr ""
-#: ../raster/r.reclass/reclass.c:51 ../raster/r.reclass/reclass.c:111
-msgid "Too many categories"
-msgstr ""
-#: ../raster/r.reclass/reclass.c:216
-#, c-format
-msgid "Cannot read header file of <%s@%s>"
-msgstr ""
-#: ../raster/r.reclass/reclass.c:234
-#, c-format
-msgid "Cannot overwrite existing raster map <%s>"
-msgstr ""
-#: ../raster/r.reclass/reclass.c:239
-#, c-format
-msgid "Cannot create reclass file of <%s>"
-msgstr ""
-#: ../raster/r.reclass/reclass.c:247
-#, c-format
-msgid "Cannot create raster map <%s>"
-msgstr ""
-#: ../raster/r.reclass/parse.c:42
-msgid "poor quality"
-msgstr ""
-#: ../raster/r.reclass/parse.c:44
-msgid "medium quality"
-msgstr ""
-#: ../raster/r.reclass/parse.c:59
-msgid "Can't have null on the left-hand side of the rule"
-msgstr ""
-#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
-msgid "Can't have null on the right-hand side of the rule"
-msgstr ""
-#: ../raster/r.reclass/parse.c:196
-#, c-format
-msgid "%f rounded up to %d\n"
-msgstr ""
-#: ../raster/r.composite/main.c:73
-#: ../locale/scriptstrings/r.blend_to_translate.c:3
-msgid "composite"
-msgstr ""
-#: ../raster/r.composite/main.c:76
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-#: ../raster/r.composite/main.c:102
-msgid "Number of levels to be used for each component"
-msgstr ""
-#: ../raster/r.composite/main.c:103 ../raster/r.composite/main.c:121
-msgid "Levels"
-msgstr ""
-#: ../raster/r.composite/main.c:118
-#, c-format
-msgid "Number of levels to be used for <%s>"
-msgstr ""
-#: ../raster/r.composite/main.c:128
-msgid "Dither"
-msgstr ""
-#: ../raster/r.composite/main.c:132
-msgid "Use closest color"
-msgstr ""
-#: ../raster/r.composite/main.c:164
-#, c-format
-msgid "Unable to read color file of raster map <%s>"
-msgstr ""
-#: ../raster/r.composite/main.c:286
-msgid "Creating color table for output raster map..."
-msgstr ""
-#: ../raster/r.random/count.c:68
-msgid "Collecting Stats..."
-msgstr ""
-#: ../raster/r.random/count.c:123
-msgid "Programmer error in get_stats/switch"
-msgstr ""
-#: ../raster/r.random/random.c:43 ../raster/r.random/random.c:47
-#: ../raster/r.mapcalc/map3.c:518 ../imagery/i.landsat.toar/main.c:406
-#: ../imagery/i.landsat.toar/main.c:544
-#: ../imagery/i.landsat.acca/algorithm.c:380
-#: ../imagery/i.landsat.acca/tools.c:126 ../imagery/i.landsat.acca/main.c:57
-#, c-format
-msgid "Unable to open raster map <%s>"
-msgstr ""
-#: ../raster/r.random/random.c:100
-msgid "Cannot create new table"
-msgstr ""
-#: ../raster/r.random/random.c:110
-#, c-format
-msgid "Writing raster map <%s> and vector map <%s> ..."
-msgstr ""
-#: ../raster/r.random/random.c:113
-#, c-format
-msgid "Writing raster map <%s> ..."
-msgstr ""
-#: ../raster/r.random/random.c:115
-#, c-format
-msgid "Writing vector map <%s> ..."
-msgstr ""
-#: ../raster/r.random/random.c:190 ../vector/v.net.timetable/main.c:134
-#: ../vector/v.net.timetable/main.c:156 ../vector/v.net.alloc/main.c:432
-#: ../vector/v.net.alloc/main.c:464 ../vector/v.net.alloc/main.c:495
-#: ../vector/v.net.alloc/main.c:533 ../vector/v.net.alloc/main.c:561
-#: ../vector/v.net.alloc/main.c:612 ../vector/v.net.alloc/main.c:648
-#: ../vector/v.net.alloc/main.c:679 ../vector/v.net.components/main.c:39
-#: ../vector/v.net.centrality/main.c:69 ../vector/v.net.distance/main.c:363
-#: ../vector/v.net.allpairs/main.c:271 ../vector/v.net.flow/main.c:262
-#: ../vector/v.net.path/path.c:350 ../vector/v.net.iso/main.c:724
-#: ../vector/v.net.iso/main.c:754
-#, c-format
-msgid "Cannot insert new record: %s"
-msgstr ""
-#: ../raster/r.random/random.c:244
-#, c-format
-msgid "Only [%llu] random points created"
-msgstr ""
-#: ../raster/r.random/random.c:247
-#, c-format
-msgid "Only [%lu] random points created"
-msgstr ""
-#: ../raster/r.random/random.c:258 ../raster/r.to.vect/main.c:233
-#: ../db/drivers/postgres/index.c:59 ../vector/v.patch/main.c:328
-#: ../vector/v.mkgrid/main.c:346 ../vector/v.mkgrid/main.c:404
-#: ../vector/v.select/copy_tabs.c:87 ../vector/v.overlay/main.c:592
-#: ../vector/v.extract/copy_tab.c:124 ../vector/v.random/main.c:259
-msgid "Unable to create index"
-msgstr ""
-#: ../raster/r.random/main.c:55 ../general/g.region/main.c:69
-#: ../display/d.vect/main.c:76 ../vector/v.patch/main.c:71
-#: ../vector/v.rectify/main.c:72 ../vector/v.cluster/main.c:94
-#: ../vector/v.perturb/main.c:67 ../vector/v.decimate/main.c:130
-#: ../vector/v.in.lidar/main.c:139 ../vector/v.random/main.c:103
-#: ../vector/v.info/main.c:43 ../vector/v.in.ascii/main.c:73
-#: ../vector/v.external/main.c:57 ../vector/v.edit/main.c:61
-#: ../vector/v.in.dxf/main.c:67
-msgid "level1"
-msgstr ""
-#: ../raster/r.random/main.c:58
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-#: ../raster/r.random/main.c:62 ../raster/r.out.bin/main.c:290
-#: ../imagery/i.zc/main.c:66
-msgid "Name of input raster map"
-msgstr ""
-#: ../raster/r.random/main.c:67
-msgid "Name of cover raster map"
-msgstr ""
-#: ../raster/r.random/main.c:74
-msgid "The number of points to allocate"
-msgstr ""
-#: ../raster/r.random/main.c:86
-msgid "Generate points also for NULL category"
-msgstr ""
-#: ../raster/r.random/main.c:91
-msgid "Report information about input raster and exit"
-msgstr ""
-#: ../raster/r.random/main.c:95
-msgid "Generate vector points as 3D points"
-msgstr ""
-#: ../raster/r.random/main.c:98 ../vector/v.in.ascii/main.c:195
-msgid "Do not build topology in points mode"
-msgstr ""
-#: ../raster/r.random/main.c:99 ../display/d.linegraph/main.c:353
-#: ../display/d.linegraph/main.c:362 ../display/d.linegraph/main.c:371
-#: ../display/d.linegraph/main.c:386 ../vector/v.out.ascii/args.c:40
-#: ../vector/v.out.ascii/args.c:66 ../vector/v.out.ascii/args.c:76
-#: ../vector/v.out.ascii/args.c:86 ../vector/v.out.ascii/args.c:92
-#: ../vector/v.in.ascii/main.c:119 ../vector/v.in.ascii/main.c:126
-#: ../vector/v.in.ascii/main.c:138 ../vector/v.in.ascii/main.c:148
-#: ../vector/v.in.ascii/main.c:158 ../vector/v.in.ascii/main.c:168
-#: ../vector/v.in.ascii/main.c:192 ../vector/v.in.ascii/main.c:196
-#: ../vector/v.in.ascii/main.c:202 ../vector/v.in.ascii/main.c:207
-msgid "Points"
-msgstr ""
-#: ../raster/r.random/main.c:143
-#, c-format
-msgid "Note: one (or both) of %s and %s must be specified"
-msgstr ""
-#: ../raster/r.random/main.c:151
-#, c-format
-msgid "<%s=%s> invalid percentage"
-msgstr ""
-#: ../raster/r.random/main.c:162
-#, c-format
-msgid "<%s=%s> invalid number of points"
-msgstr ""
-#: ../raster/r.random/main.c:176
-#, c-format
-msgid "There aren't [%llu] cells in the current region"
-msgstr ""
-#: ../raster/r.random/main.c:179
-#, c-format
-msgid "There aren't [%llu] non-NULL cells in the current region"
-msgstr ""
-#: ../raster/r.random/main.c:183
-#, c-format
-msgid "There aren't [%lu] cells in the current region"
-msgstr ""
-#: ../raster/r.random/main.c:186
-#, c-format
-msgid "There aren't [%lu] non-NULL cells in the current region"
-msgstr ""
-#: ../raster/r.random/main.c:192
-msgid "There are no valid locations in the current region"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:59
-msgid "The initial concentration in [kg/m^3]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:63
-msgid "The piezometric head in [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:68
-msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:73
-msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:79
-msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:85
-msgid "The x-part of the diffusion tensor in [m^2/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:90
-msgid "The y-part of the diffusion tensor in [m^2/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:94
-#: ../raster/r.solute.transport/main.c:102
-#: ../raster/r.solute.transport/main.c:138
-#: ../raster/r.solute.transport/main.c:145
-msgid "Water flow"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:96
-msgid "Groundwater sources and sinks in [m^3/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:103
-msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:117
-msgid "Retardation factor [-]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:121
-msgid "Effective porosity [-]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:125
-msgid "Top surface of the aquifer in [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:129
-msgid "Bottom surface of the aquifer in [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:132
-msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:140
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:147
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
-msgstr ""
-#: ../raster/r.solute.transport/main.c:161
-msgid "The longditudinal dispersivity length. [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:169
-msgid "The transversal dispersivity length. [m]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:177
-msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:187
-msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:192 ../raster3d/r3.gwflow/main.c:131
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:199
-msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:231
-msgid "solute transport"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:233
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:258
-msgid "The direct LU solver do not work with sparse matrices"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:260
-msgid "The direct Gauss solver do not work with sparse matrices"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:370
-#, c-format
-msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:371
-#, c-format
-msgid "The largest stable time step is %g"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:380
-#, c-format
-msgid "Number of inner loops is %g"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:381
-#, c-format
-msgid "Time step for each loop %g"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:385
-#, c-format
-msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
-msgstr ""
-#: ../raster/r.solute.transport/main.c:397
-#, c-format
-msgid "Time step %i with time sum %g"
-msgstr ""
-#: ../raster/r.solute.transport/main.c:543
-msgid "Could not create and solve the linear equation system"
-msgstr ""
-#: ../raster/r.to.vect/lines_io.c:76
-msgid "write_line:  found half a loop!"
-msgstr ""
-#: ../raster/r.to.vect/lines_io.c:177
-#, c-format
-msgid ""
-"write_line: line terminated unexpectedly\n"
-"  previous (%d) point %p (%d,%d,%d) %p %p"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:71
-msgid "Extracting lines..."
-msgstr ""
-#: ../raster/r.to.vect/lines.c:504
-#, c-format
-msgid "Crowded cell at (%f, %f): row %d, col %d, count %d"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:508
-msgid ""
-"Raster map is not thinned properly.\n"
-"Please run r.thin."
-msgstr ""
-#: ../raster/r.to.vect/lines.c:582
-msgid "join_lines: p front pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:588
-msgid "join_lines: q front pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:606
-msgid "extend line:  p is NULL"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:632
-msgid "extend_lines: p front pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/lines.c:639
-msgid "extend_lines: q back pointer not NULL!"
-msgstr ""
-#: ../raster/r.to.vect/areas.c:122
-msgid "Extracting areas..."
-msgstr ""
-#: ../raster/r.to.vect/points.c:36
-msgid "Extracting points..."
-msgstr ""
-#: ../raster/r.to.vect/areas_io.c:154
-#, c-format
-msgid ""
-"write_bnd:  line terminated unexpectedly\n"
-"previous (%d) point %p (%d,%d,%d) %p %p"
-msgstr ""
-#: ../raster/r.to.vect/areas_io.c:287
-msgid "Writing areas..."
-msgstr ""
-#: ../raster/r.to.vect/main.c:79
-msgid "vectorization"
-msgstr ""
-#: ../raster/r.to.vect/main.c:80
-msgid "Converts a raster map into a vector map."
-msgstr ""
-#: ../raster/r.to.vect/main.c:87 ../vector/v.mkgrid/main.c:136
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:7
-msgid "Output feature type"
-msgstr ""
-#: ../raster/r.to.vect/main.c:94
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:11
-msgid "Name of attribute column to store value"
-msgstr ""
-#: ../raster/r.to.vect/main.c:95
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:19
-msgid "Name must be SQL compliant"
-msgstr ""
-#: ../raster/r.to.vect/main.c:100
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:15
-msgid "Smooth corners of area features"
-msgstr ""
-#: ../raster/r.to.vect/main.c:105
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:20
-msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-#: ../raster/r.to.vect/main.c:106 ../raster/r.to.vect/main.c:113
-#: ../vector/v.to.rast/main.c:88 ../vector/v.to.rast/main.c:94
-#: ../vector/v.to.rast/main.c:100 ../vector/v.overlay/main.c:135
-#: ../vector/v.overlay/main.c:145 ../vector/v.extract/main.c:93
-#: ../vector/v.extract/main.c:145 ../vector/v.generalize/main.c:245
-#: ../vector/v.in.ogr/main.c:289 ../vector/v.in.ogr/main.c:299
-#: ../vector/v.in.ogr/main.c:309 ../vector/v.in.ogr/main.c:342
-#: ../vector/v.in.ogr/main.c:374 ../vector/v.buffer/main.c:306
-msgid "Attributes"
-msgstr ""
-#: ../raster/r.to.vect/main.c:110
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:16
-msgid "Write raster values as z coordinate"
-msgstr ""
-#: ../raster/r.to.vect/main.c:111
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:17
-msgid "Table is not created. Currently supported only for points."
-msgstr ""
-#: ../raster/r.to.vect/main.c:117 ../vector/v.proj/main.c:130
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:18
-msgid "Do not build vector topology"
-msgstr ""
-#: ../raster/r.to.vect/main.c:118
-msgid "Recommended for massive point conversion"
-msgstr ""
-#: ../raster/r.to.vect/main.c:131
-msgid "z flag is supported only for points"
-msgstr ""
-#: ../raster/r.to.vect/main.c:142
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
-msgstr ""
-#: ../raster/r.to.vect/main.c:144
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
-msgstr ""
-#: ../raster/r.to.vect/main.c:146
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be lost."
-msgstr ""
-#: ../raster/r.to.vect/main.c:151
-msgid "Categories will be unique sequence, raster values will be lost."
-msgstr ""
-#: ../raster/r.to.vect/main.c:312
-msgid "Updating attributes..."
-msgstr ""
-#: ../raster/r.to.vect/main.c:335
-#, c-format
-msgid "Unable to insert into table: %s"
-msgstr ""
-#: ../raster/r.surf.contour/main.c:64
-msgid "Generates surface raster map from rasterized contours."
-msgstr ""
-#: ../raster/r.surf.contour/main.c:67
-msgid "Name of input raster map containing contours"
-msgstr ""
-#: ../raster/r.param.scale/main.c:42
-msgid "Lat/Long locations are not supported by this module"
-msgstr ""
-#: ../raster/r.param.scale/process.c:75
-msgid "E-W and N-S grid resolutions are different. Taking average."
-msgstr ""
-#: ../raster/r.param.scale/interface.c:55
-msgid "geomorphology"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:58
-msgid "landform"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:59
-msgid "Extracts terrain parameters from a DEM."
-msgstr ""
-#: ../raster/r.param.scale/interface.c:60
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
-#: ../raster/r.param.scale/interface.c:78
-msgid "Name for output raster map containing morphometric parameter"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:82
-msgid "Slope tolerance that defines a 'flat' surface (degrees)"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:89
-msgid "Curvature tolerance that defines 'planar' surface"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:96
-msgid "Size of processing window (odd number only)"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:104
-msgid "Morphometric parameter in 'size' window to calculate"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:112
-msgid "Exponent for distance weighting (0.0-4.0)"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:124
-msgid "Constrain model through central window cell"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:167
-msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
-msgstr ""
-#: ../raster/r.param.scale/interface.c:175
-msgid "Inappropriate window size (too big or even)"
-msgstr ""
-#: ../raster/r.drain/main.c:113
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
-msgstr ""
-#: ../raster/r.drain/main.c:116
-msgid "Name of input elevation or cost surface raster map"
-msgstr ""
-#: ../raster/r.drain/main.c:121
-msgid "Name of input movement direction map associated with the cost surface"
-msgstr ""
-#: ../raster/r.drain/main.c:123
-msgid "Direction in degrees CCW from east"
-msgstr ""
-#: ../raster/r.drain/main.c:125 ../raster/r.drain/main.c:167
-msgid "Cost surface"
-msgstr ""
-#: ../raster/r.drain/main.c:133
-msgid "Name for output drain vector map"
-msgstr ""
-#: ../raster/r.drain/main.c:134
-msgid "Recommended for cost surface made using knight's move"
-msgstr ""
-#: ../raster/r.drain/main.c:144
-msgid "Name of starting vector points map(s)"
-msgstr ""
-#: ../raster/r.drain/main.c:150
-msgid "Copy input cell values on output"
-msgstr ""
-#: ../raster/r.drain/main.c:151 ../raster/r.drain/main.c:156
-#: ../raster/r.drain/main.c:161
-msgid "Path settings"
-msgstr ""
-#: ../raster/r.drain/main.c:155
-msgid "Accumulate input values along the path"
-msgstr ""
-#: ../raster/r.drain/main.c:160
-msgid "Count cell numbers along the path"
-msgstr ""
-#: ../raster/r.drain/main.c:166
-msgid ""
-"The input raster map is a cost surface (direction surface must also be "
-"specified)"
-msgstr ""
-#: ../raster/r.drain/main.c:178
-msgid "Directional drain selected... checking for direction raster map"
-msgstr ""
-#: ../raster/r.drain/main.c:181
-msgid "Surface/Hydrology drain selected"
-msgstr ""
-#: ../raster/r.drain/main.c:186
-#, c-format
-msgid ""
-"Direction raster map <%s> not specified, if direction flag is on, a "
-"direction raster must be given"
-msgstr ""
-#: ../raster/r.drain/main.c:193
-#, c-format
-msgid ""
-"Direction raster map <%s> should not be specified for Surface/Hydrology "
-"drains"
-msgstr ""
-#: ../raster/r.drain/main.c:212
-msgid "Specify just one of the -c, -a and -n flags"
-msgstr ""
-#: ../raster/r.drain/main.c:243
-#, c-format
-msgid "Starting point %d is outside the current region"
-msgstr ""
-#: ../raster/r.drain/main.c:318
-#, c-format
-msgid "Starting vector map <%s> contains no points in the current region"
-msgstr ""
-#: ../raster/r.drain/main.c:326
-msgid "No start/stop point(s) specified"
-msgstr ""
-#: ../raster/r.drain/main.c:401
-msgid "Calculating flow directions..."
-msgstr ""
-#: ../raster/r.drain/main.c:692
-#, c-format
-msgid "direction read: %lf, neighbour found: %i"
-msgstr ""
-#: ../raster/r.tile/main.c:44 ../raster3d/r3.retile/main.c:97
-#: ../locale/scriptstrings/r.tileset_to_translate.c:3
-msgid "tiling"
-msgstr ""
-#: ../raster/r.tile/main.c:46
-msgid "Splits a raster map into tiles."
-msgstr ""
-#: ../raster/r.tile/main.c:55
-msgid "Output base name"
-msgstr ""
-#: ../raster/r.tile/main.c:62
-msgid "Width of tiles (columns)"
-msgstr ""
-#: ../raster/r.tile/main.c:69
-msgid "Height of tiles (rows)"
-msgstr ""
-#: ../raster/r.tile/main.c:76
-msgid "Overlap of tiles"
-msgstr ""
-#: ../raster/r.tile/main.c:129
-#, c-format
-msgid "Generating %d x %d = %d tiles..."
-msgstr ""
-#: ../raster/r.tile/main.c:184
-#, c-format
-msgid "Unable to read cats for %s"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:84
-msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:90
-msgid "Existing map to be added to output"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:98
-msgid "Input file with raster map names, one per line"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:109
-msgid "Scale factor for input"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:116
-msgid "Shift factor for input"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:121
-msgid ""
-"The raster map specifying the lower accumulation limit, also called baseline"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:126
-msgid ""
-"The raster map specifying the upper accumulation limit, also called cutoff. "
-"Only applied to BEDD computation."
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:139
-msgid "Use these limits in case lower and/or upper input maps are not defined"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:151
-msgid "Growing Degree Days or Winkler indices"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:152
-msgid "Mean: sum(input maps)/(number of input maps)"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:153
-msgid "Biologically Effective Degree Days"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:154
-msgid "Huglin Heliothermal index"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:167
-msgid "Create a FCELL map (floating point single precision) as output"
-msgstr ""
-#: ../raster/r.series.accumulate/main.c:354
-#, c-format
-msgid "'%s'=%f must be > '%s'=%f"
-msgstr ""
-#: ../raster/r.mode/read_stats.c:14
-msgid "reading r.stats output"
-msgstr ""
-#: ../raster/r.mode/main.c:59
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-#: ../raster/r.mode/main.c:65
-msgid "Base map to be reclassified"
-msgstr ""
-#: ../raster/r.mode/main.c:72
-msgid "Coverage map"
-msgstr ""
-#: ../raster/r.mode/main.c:79
-msgid "Output map"
-msgstr ""
-#: ../raster/r.mode/main.c:92
-#, c-format
-msgid "%s: Unable to read category labels"
-msgstr ""
-#: ../raster/r.uslek/main.c:57
-msgid "Computes USLE Soil Erodibility Factor (K)."
-msgstr ""
-#: ../raster/r.uslek/main.c:62
-msgid "Name of soil sand fraction raster map [0.0-1.0]"
-msgstr ""
-#: ../raster/r.uslek/main.c:66
-msgid "Name of soil clay fraction raster map [0.0-1.0]"
-msgstr ""
-#: ../raster/r.uslek/main.c:70
-msgid "Name of soil silt fraction raster map [0.0-1.0]"
-msgstr ""
-#: ../raster/r.uslek/main.c:74
-msgid "Name of soil organic matter raster map [0.0-1.0]"
-msgstr ""
-#: ../raster/r.uslek/main.c:77
-msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
-msgstr ""
-#: ../raster/r.water.outlet/main.c:56
-msgid "Creates watershed basins from a drainage direction map."
-msgstr ""
-#: ../raster/r.water.outlet/main.c:62
-msgid "Name of input drainage direction map"
-msgstr ""
-#: ../raster/r.water.outlet/main.c:65
-msgid "Name for output watershed basin map"
-msgstr ""
-#: ../raster/r.water.outlet/main.c:68
-msgid "Coordinates of outlet point"
-msgstr ""
-#: ../raster/r.water.outlet/main.c:81
-#, c-format
-msgid "Illegal east coordinate '%s'"
-msgstr ""
-#: ../raster/r.water.outlet/main.c:83
-#, c-format
-msgid "Illegal north coordinate '%s'"
-msgstr ""
-#: ../raster/r.water.outlet/main.c:88
-#, c-format
-msgid "Ignoring point outside computation region: %.4f,%.4f"
-msgstr ""
-#: ../raster/r.random.surface/init.c:73
-#, c-format
-msgid "High (%d) must be greater than 1"
-msgstr ""
-#: ../raster/r.random.surface/init.c:82
-#, c-format
-msgid "Rastar map <%s> repeated, maps must be unique"
-msgstr ""
-#: ../raster/r.random.surface/init.c:92
-msgid "Output raster map required"
-msgstr ""
-#: ../raster/r.random.surface/init.c:108
-#, c-format
-msgid "Seed (%d) larger than maximum (%d)"
-msgstr ""
-#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
-#, c-format
-msgid " seed is set to %d"
-msgstr ""
-#: ../raster/r.random.surface/init.c:116
-#, c-format
-msgid "Seed (%d) smaller than minimum (%d)"
-msgstr ""
-#: ../raster/r.random.surface/init.c:159
-#, c-format
-msgid "Distance value (%d): %lf must be >= 0.0"
-msgstr ""
-#: ../raster/r.random.surface/init.c:187
-#, c-format
-msgid "Exponent value (%lf) must be > 0.0"
-msgstr ""
-#: ../raster/r.random.surface/init.c:211
-#, c-format
-msgid "Flat value (%lf) must be less than distance value (%lf)"
-msgstr ""
-#: ../raster/r.random.surface/init.c:232
-msgid "Must have a distance value for each filter"
-msgstr ""
-#: ../raster/r.random.surface/init.c:264
-msgid "Must have a exponent value for each filter"
-msgstr ""
-#: ../raster/r.random.surface/init.c:281
-msgid "Must have a weight value for each filter"
-msgstr ""
-#: ../raster/r.random.surface/main.c:61
-msgid "Generates random surface(s) with spatial dependence."
-msgstr ""
-#: ../raster/r.random.surface/main.c:68
-msgid "Name for output raster map(s)"
-msgstr ""
-#: ../raster/r.random.surface/main.c:85
-msgid "Distance decay exponent (value > 0.0)"
-msgstr ""
-#: ../raster/r.random.surface/main.c:94
-msgid "Distance filter remains flat before beginning exponent"
-msgstr ""
-#: ../raster/r.random.surface/main.c:102
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
-msgstr ""
-#: ../raster/r.random.surface/main.c:108
-msgid "Maximum cell value of distribution"
-msgstr ""
-#: ../raster/r.random.surface/main.c:113
-msgid "Uniformly distributed cell values"
-msgstr ""
-#: ../raster/r.walk/main.c:183
-msgid ""
-"Creates a raster map showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input raster map whose cell "
-"category values represent cost."
-msgstr ""
-#: ../raster/r.walk/main.c:193
-msgid "Name of input raster map containing friction costs"
-msgstr ""
-#: ../raster/r.walk/main.c:196
-msgid "Name for output raster map to contain walking costs"
-msgstr ""
-#: ../raster/r.walk/main.c:273
-msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr ""
-#: ../raster/r.walk/main.c:283
-msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
-#: ../raster/r.walk/main.c:293
-msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-#: ../raster/r.walk/main.c:377
-#, c-format
-msgid "Missing required value: got %d instead of 4"
-msgstr ""
-#: ../raster/r.walk/main.c:380
-#, c-format
-msgid "Walking costs are a=%g b=%g c=%g d=%g"
-msgstr ""
-#: ../raster/r.walk/main.c:385 ../raster/r.walk/main.c:393
-#, c-format
-msgid "Missing required value: %d"
-msgstr ""
-#: ../raster/r.walk/main.c:388
-#, c-format
-msgid "Lambda is %g"
-msgstr ""
-#: ../raster/r.walk/main.c:396
-#, c-format
-msgid "Slope_factor is %g"
-msgstr ""
-#: ../raster/r.walk/main.c:558
-#, c-format
-msgid "Reading raster maps <%s> and <%s>, initializing output..."
-msgstr ""
-#: ../raster/r.walk/main.c:722
-#, c-format
-msgid "No start points found in vector <%s>"
-msgstr ""
-#: ../raster/r.walk/main.c:1368
-#, c-format
-msgid "Writing output raster map <%s>... "
-msgstr ""
-#: ../raster/r.in.mat/main.c:94
-msgid "Imports a binary MAT-File(v4) to a GRASS raster."
-msgstr ""
-#: ../raster/r.in.mat/main.c:101
-msgid "Name of input MAT-File(v4)"
-msgstr ""
-#: ../raster/r.in.mat/main.c:105
-msgid "Name for output raster map (override)"
-msgstr ""
-#: ../raster/r.in.mat/main.c:149
-msgid "Reading MAT-File..."
-msgstr ""
-#: ../raster/r.in.mat/main.c:175
-msgid "Array contains no data"
-msgstr ""
-#: ../raster/r.in.mat/main.c:180
-msgid "Array contains imaginary data"
-msgstr ""
-#: ../raster/r.in.mat/main.c:186
-msgid "Invalid array name"
-msgstr ""
-#: ../raster/r.in.mat/main.c:206
-msgid "Invalid 'map_name' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:216
-msgid "Error reading 'map_name' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:227
-msgid "Invalid 'map_northern_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:236
-msgid "Invalid 'map_southern_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:245
-msgid "Invalid 'map_eastern_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:254
-msgid "Invalid 'map_western_edge' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:262
-msgid "Invalid 'map_title' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:272
-msgid "Error reading 'map_title' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:285
-msgid "Invalid 'map_data' array"
-msgstr ""
-#: ../raster/r.in.mat/main.c:311 ../raster/r.in.mat/main.c:443
-#: ../raster/r.in.mat/main.c:522
-msgid "Please contact the GRASS development team"
-msgstr ""
-#: ../raster/r.in.mat/main.c:316
-#, c-format
-msgid "Skipping unknown array '%s'"
-msgstr ""
-#: ../raster/r.in.mat/main.c:344
-#, c-format
-msgid "No 'map_data' array found in <%s>"
-msgstr ""
-#: ../raster/r.in.mat/main.c:351
-#, c-format
-msgid "Setting map name to <%s> which overrides <%s>"
-msgstr ""
-#: ../raster/r.in.mat/main.c:358
-#, c-format
-msgid "Setting map name to <%s>"
-msgstr ""
-#: ../raster/r.in.mat/main.c:362
-msgid "No 'map_name' array found; using <MatFile>"
-msgstr ""
-#: ../raster/r.in.mat/main.c:373
-msgid "Missing bound"
-msgstr ""
-#: ../raster/r.in.mat/main.c:377
-msgid "Using default bounds"
-msgstr ""
-#: ../raster/r.in.mat/main.c:391
-#, c-format
-msgid "Map <%s> bounds set to:"
-msgstr ""
-#: ../raster/r.in.mat/main.c:392 ../raster/r.out.mat/main.c:174
-#, c-format
-msgid "northern edge=%f"
-msgstr ""
-#: ../raster/r.in.mat/main.c:393 ../raster/r.out.mat/main.c:175
-#, c-format
-msgid "southern edge=%f"
-msgstr ""
-#: ../raster/r.in.mat/main.c:394 ../raster/r.out.mat/main.c:176
-#, c-format
-msgid "eastern edge=%f"
-msgstr ""
-#: ../raster/r.in.mat/main.c:395 ../raster/r.out.mat/main.c:177
-#, c-format
-msgid "western edge=%f"
-msgstr ""
-#: ../raster/r.in.mat/main.c:396 ../raster/r.out.mat/main.c:178
-#, c-format
-msgid "nsres=%f"
-msgstr ""
-#: ../raster/r.in.mat/main.c:397 ../raster/r.out.mat/main.c:179
-#, c-format
-msgid "ewres=%f"
-msgstr ""
-#: ../raster/r.in.mat/main.c:398 ../raster/r.out.mat/main.c:180
-#: ../raster3d/r3.out.bin/main.c:330
-#, c-format
-msgid "rows=%d"
-msgstr ""
-#: ../raster/r.in.mat/main.c:399 ../raster/r.out.mat/main.c:181
-#: ../raster3d/r3.out.bin/main.c:331
-#, c-format
-msgid "cols=%d"
-msgstr ""
-#: ../raster/r.in.mat/main.c:408
-msgid "Writing new raster map..."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:160
-#, c-format
-msgid ""
-"%d are too many cells, recommended are < 100 cells. The cross validation "
-"would take too much time."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:169
-#, c-format
-msgid "%d point read in region"
-msgid_plural "%d points read in region"
-msgstr[0] ""
-#: ../raster/r.resamp.bspline/crosscorr.c:174
-msgid "Maybe it takes too long. Consider reducing the region extents."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:197
-#: ../vector/v.surf.bspline/crosscorr.c:151
-#, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"ew_step=\" "
-"\"ns_step=\"."
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:215
-#: ../vector/v.surf.bspline/crosscorr.c:169
-#, c-format
-msgid "Beginning cross validation with lambda_i=%.4f ... (%d of %d)"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:306
-#: ../vector/v.surf.bspline/crosscorr.c:295
-#, c-format
-msgid "Mean = %.5lf"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:307
-#: ../vector/v.surf.bspline/crosscorr.c:296
-#, c-format
-msgid "Root Mean Square (RMS) = %.5lf"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:324
-#: ../vector/v.surf.bspline/crosscorr.c:313
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:326
-#: ../vector/v.surf.bspline/crosscorr.c:315
-#, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:334
-#: ../vector/v.surf.bspline/crosscorr.c:323
-msgid "Table of results:"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:335
-#: ../vector/v.surf.bspline/crosscorr.c:324
-#, c-format
-msgid "    lambda |       mean |        rms |\n"
-msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:345
-#: ../vector/v.surf.bspline/crosscorr.c:334
-msgid "No point lies into the current region"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:83
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-msgid "splines"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:84 ../raster/r.fill.stats/main.c:779
-#: ../vector/v.vol.rst/main.c:241 ../vector/v.surf.rst/main.c:152
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
-msgid "no-data filling"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:86
-msgid ""
-"Performs bilinear or bicubic spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:94
-msgid "Name for output vector map with interpolation grid"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:99
-msgid "Name of raster map to use for masking"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:100 ../vector/v.surf.bspline/main.c:140
-msgid "Only cells that are not NULL and not zero are interpolated"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:108
-msgid ""
-"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:116
-msgid ""
-"Length of each spline step in the north-south direction. Default: 1.5 * "
-"nsres."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:120 ../vector/v.surf.bspline/main.c:163
-msgid "Spline interpolation algorithm"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:126 ../vector/v.outlier/main.c:418
-#: ../vector/v.lidar.correction/main.c:407 ../vector/v.surf.bspline/main.c:170
-msgid "Bilinear interpolation"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:127 ../vector/v.surf.bspline/main.c:171
-msgid "Bicubic interpolation"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:133 ../vector/v.surf.bspline/main.c:177
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:19
-msgid "Tykhonov regularization parameter (affects smoothing)"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:139
-msgid "Only interpolate null cells in input raster map"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:145 ../vector/v.surf.bspline/main.c:101
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:185
-msgid "ew_step must be positive"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:193
-msgid "ns_step must be positive"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:220
-#, c-format
-msgid "spline step in ew direction %g"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:221
-#, c-format
-msgid "spline step in ns direction %g"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:222
-#, c-format
-msgid "adjusted EW splines %d"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:223
-#, c-format
-msgid "adjusted NS splines %d"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:302 ../vector/v.surf.bspline/main.c:461
-msgid "Memory in MB must be >= 3"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:323 ../raster/r.resamp.bspline/main.c:408
-#: ../raster/r.resamp.bspline/main.c:480 ../vector/v.surf.bspline/main.c:480
-#: ../vector/v.surf.bspline/main.c:508
-msgid "Can not initialize temporary file"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:329
-#, c-format
-msgid "Loading input raster <%s>"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:343 ../raster/r.resamp.bspline/main.c:454
-#: ../raster/r.resamp.bspline/main.c:490
-msgid "Can not write to temp file"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:348
-msgid "Only NULL cells in input raster"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:372 ../vector/v.surf.bspline/main.c:313
-msgid "Cross validation didn't finish correctly"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:376 ../vector/v.surf.bspline/main.c:319
-#, c-format
-msgid "Cross validation finished for ew_step = %f and ns_step = %f"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:396
-msgid "Mark cells for interpolation"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:468
-msgid "No NULL cells found in input raster."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:483 ../vector/v.surf.bspline/main.c:483
-msgid "Initializing output..."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:558
-#, c-format
-msgid "subregion %d of %d"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:732
-msgid "No data within this subregion. Consider increasing the spline step."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:748 ../vector/v.out.postgis/main.c:174
-#: ../vector/v.net.components/main.c:213 ../vector/v.surf.bspline/main.c:899
-msgid "Writing output..."
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:36
-msgid "Raster map used for zoning, must be of type CELL"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:52
-#: ../raster/r.univar/r3.univar_main.c:52 ../vector/v.univar/main.c:122
-#: ../locale/scriptstrings/db.univar_to_translate.c:6
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
-msgid "Percentile to calculate (requires extended statistics flag)"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:53 ../raster/r.univar/r.univar_main.c:67
-msgid "Extended"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:61
-#: ../raster/r.univar/r3.univar_main.c:59 ../vector/v.univar/main.c:126
-#: ../vector/v.what/main.c:100
-msgid "Print the stats in shell script style"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:66
-#: ../raster/r.univar/r3.univar_main.c:63 ../vector/v.univar/main.c:130
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:10
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:10
-msgid "Calculate extended statistics"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:71
-#: ../raster/r.univar/r3.univar_main.c:67
-msgid "Table output format instead of standard output format"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:76
-msgid ""
-"Use the native resolution and extent of the raster map, instead of the "
-"current region"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:106
-#: ../raster/r.univar/r3.univar_main.c:100 ../vector/v.vect.stats/main.c:136
-#: ../vector/v.univar/main.c:94
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-msgid "univariate statistics"
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:110
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:112
-#: ../raster/r.univar/r3.univar_main.c:105
-msgid ""
-"Statistics include number of cells counted, minimum and maximum cell values,"
-" range, arithmetic mean, population variance, standard deviation, "
-"coefficient of variation, and sum."
-msgstr ""
-#: ../raster/r.univar/r.univar_main.c:123
-msgid "zones option and region flag -r are mutually exclusive"
-msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:37
-msgid "3D Raster map used for zoning, must be of type CELL"
-msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:103
-msgid ""
-"Calculates univariate statistics from the non-null cells of a 3D raster map."
-msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:151
-#: ../raster/r.univar/r3.univar_main.c:189 ../raster3d/r3.neighbors/main.c:266
-#: ../raster3d/r3.neighbors/main.c:275 ../raster3d/r3.stats/main.c:104
-#: ../raster3d/r3.gradient/main.c:113 ../raster3d/r3.gradient/main.c:122
-#: ../raster3d/r3.out.vtk/main.c:207 ../raster3d/r3.out.vtk/main.c:292
-#: ../raster3d/r3.out.vtk/main.c:512 ../raster3d/r3.out.bin/main.c:314
-#: ../raster3d/r3.cross.rast/main.c:279 ../raster3d/r3.info/main.c:110
-#: ../raster3d/r3.retile/main.c:127 ../raster3d/r3.flow/main.c:118
-#: ../raster3d/r3.flow/main.c:132 ../raster3d/r3.flow/main.c:373
-#: ../raster3d/r3.flow/main.c:385 ../raster3d/r3.flow/test_main.c:82
-#: ../raster3d/r3.out.netcdf/main.c:617 ../raster3d/r3.mask/main.c:64
-#: ../raster3d/r3.out.ascii/main.c:339 ../raster3d/r3.mkdspf/main.c:168
-#: ../raster3d/r3.out.v5d/main.c:312 ../raster3d/r3.null/main.c:110
-#: ../raster3d/r3.to.rast/main.c:298 ../raster3d/r3.to.rast/main.c:322
-#, c-format
-msgid "Unable to open 3D raster map <%s>"
-msgstr ""
-#: ../raster/r.series.interp/main.c:69
-msgid ""
-"Interpolates raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
-msgstr ""
-#: ../raster/r.series.interp/main.c:79
-msgid "Data point position for each input map"
-msgstr ""
-#: ../raster/r.series.interp/main.c:84
-msgid ""
-"Input file with one input raster map name and data point position per line, "
-"field separator between name and sample point is |"
-msgstr ""
-#: ../raster/r.series.interp/main.c:97
-msgid "Sampling point position for each output map"
-msgstr ""
-#: ../raster/r.series.interp/main.c:101
-msgid ""
-"Input file with one output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
-msgstr ""
-#: ../raster/r.series.interp/main.c:111
-msgid "Interpolation method, currently only linear interpolation is supported"
-msgstr ""
-#: ../raster/r.series.interp/main.c:130 ../raster/r.series.interp/main.c:146
-#, c-format
-msgid "Please specify %s= and %s="
-msgstr ""
-#: ../raster/r.series.interp/main.c:213
-#, c-format
-msgid "Missing point position for %s map <%s> in file <%s> near line %i"
-msgstr ""
-#: ../raster/r.series.interp/main.c:228 ../raster/r.series.interp/main.c:262
-#, c-format
-msgid "Preparing %s map <%s> at position %g"
-msgstr ""
-#: ../raster/r.series.interp/main.c:232
-#, c-format
-msgid "No raster map name found in %s file <%s>"
-msgstr ""
-#: ../raster/r.series.interp/main.c:243
-#, c-format
-msgid "No %s raster map not found"
-msgstr ""
-#: ../raster/r.series.interp/main.c:250
-#, c-format
-msgid "The number of %s maps and %s point positions must be equal"
-msgstr ""
-#: ../raster/r.series.interp/main.c:279
-#, c-format
-msgid "Start interpolation run with %i input maps and %i output maps"
-msgstr ""
-#: ../raster/r.series.interp/main.c:299
-#, c-format
-msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
-msgstr ""
-#: ../raster/r.series.interp/main.c:319
-msgid "At least 2 input maps are required for linear interpolation"
-msgstr ""
-#: ../raster/r.series.interp/main.c:337
-#, c-format
-msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
-msgstr ""
-#: ../raster/r.external/link.c:46
-msgid "Complex types not supported"
-msgstr ""
-#: ../raster/r.external/link.c:58
-#, c-format
-msgid "Copying color table for %s"
-msgstr ""
-#: ../raster/r.external/link.c:76
-#, c-format
-msgid "Setting grey color table for <%s> (full 8bit range)"
-msgstr ""
-#: ../raster/r.external/link.c:82
-#, c-format
-msgid "Setting grey color table for <%s> (data range)"
-msgstr ""
-#: ../raster/r.external/link.c:96
-#, c-format
-msgid "Unable to create cell/%s file"
-msgstr ""
-#: ../raster/r.external/link.c:105
-#, c-format
-msgid "Unable to create fcell/%s file"
-msgstr ""
-#: ../raster/r.external/link.c:141
-#, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
-msgstr ""
-#: ../raster/r.external/link.c:144
-#, c-format
-msgid "Error writing cell_misc/%s/gdal file"
-msgstr ""
-#: ../raster/r.external/link.c:169
-#, c-format
-msgid "Unable to create cell_misc/%s/f_format file"
-msgstr ""
-#: ../raster/r.external/link.c:172
-#, c-format
-msgid "Error writing cell_misc/%s/f_format file"
-msgstr ""
-#: ../raster/r.external/link.c:219
-#, c-format
-msgid "Creating support files for %s"
-msgstr ""
-#: ../raster/r.external/link.c:231
-#, c-format
-msgid "Link to raster map <%s> created."
-msgstr ""
-#: ../raster/r.external/window.c:23
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
-#: ../raster/r.external/window.c:26
-msgid "Applying horizontal flip"
-msgstr ""
-#: ../raster/r.external/window.c:30
-msgid "Applying vertical flip"
-msgstr ""
-#: ../raster/r.external/main.c:61
-msgid "Links GDAL supported raster data as a pseudo GRASS raster map."
-msgstr ""
-#: ../raster/r.external/main.c:64
-msgid "Name of raster file to be linked"
-msgstr ""
-#: ../raster/r.external/main.c:70
-msgid "Name of non-file GDAL data source"
-msgstr ""
-#: ../raster/r.external/main.c:82
-msgid "Band to select (default is all bands)"
-msgstr ""
-#: ../raster/r.external/main.c:124
-msgid "Flip horizontally"
-msgstr ""
-#: ../raster/r.external/main.c:128
-msgid "Flip vertically"
-msgstr ""
-#: ../raster/r.external/main.c:133
-msgid "List available bands including band type in dataset and exit"
-msgstr ""
-#: ../raster/r.external/main.c:134
-msgid "Format: band number,type,projection check"
-msgstr ""
-#: ../raster/r.external/main.c:166
-#, c-format
-msgid "%s= or %s= must be given"
-msgstr ""
-#: ../raster/r.external/main.c:177 ../display/d.mon/start.c:86
-msgid "Unable to get current working directory"
-msgstr ""
-#: ../raster/r.external/main.c:214
-msgid "Proceeding with import..."
-msgstr ""
-#: ../raster/r.external/main.c:218
-#, c-format
-msgid "Imagery group <%s> already exists and will be overwritten."
-msgstr ""
-#: ../raster/r.external/main.c:225
-#, c-format
-msgid "Reading band %d of %d..."
-msgstr ""
-#: ../raster/r.external/main.c:262
-#, c-format
-msgid "Imagery group <%s> created"
-msgstr ""
-#: ../raster/r.timestamp/main.c:37 ../vector/v.timestamp/main.c:37
-#: ../raster3d/r3.timestamp/main.c:45
-msgid "timestamp"
-msgstr ""
-#: ../raster/r.timestamp/main.c:38 ../vector/v.timestamp/main.c:38
-#: ../raster3d/r3.timestamp/main.c:46
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:8
-#: ../locale/scriptstrings/t.create_to_translate.c:5
-#: ../locale/scriptstrings/t.support_to_translate.c:4
-#: ../locale/scriptstrings/t.topology_to_translate.c:4
-#: ../locale/scriptstrings/t.list_to_translate.c:5
-#: ../locale/scriptstrings/t.info_to_translate.c:5
-#: ../locale/scriptstrings/t.merge_to_translate.c:5
-#: ../locale/scriptstrings/t.remove_to_translate.c:5
-#: ../locale/scriptstrings/t.sample_to_translate.c:4
-#: ../locale/scriptstrings/t.register_to_translate.c:5
-#: ../locale/scriptstrings/t.unregister_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:7
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.rename_to_translate.c:5
-#: ../locale/scriptstrings/t.select_to_translate.c:4
-#: ../locale/scriptstrings/t.snap_to_translate.c:5
-#: ../locale/scriptstrings/t.shift_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:5
-msgid "time"
-msgstr ""
-#: ../raster/r.timestamp/main.c:39
-msgid "Modifies a timestamp for a raster map."
-msgstr ""
-#: ../raster/r.timestamp/main.c:40
-msgid "Print/add/remove a timestamp for a raster map."
-msgstr ""
-#: ../raster/r.timestamp/main.c:49 ../vector/v.timestamp/main.c:50
-msgid "Datetime, datetime1/datetime2, or 'none' to remove"
-msgstr ""
-#: ../raster/r.timestamp/main.c:50 ../vector/v.timestamp/main.c:51
-msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
-msgstr ""
-#: ../raster/r.timestamp/main.c:65
-#, c-format
-msgid "Raster map <%s> not found %s"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:142
-#, c-format
-msgid "Filter <%s> not found"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:391
-msgid "kernel filter"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:394
-msgid "Resamples raster map layers using an analytic kernel."
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:405
-msgid "Filter kernel(s)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:413
-msgid "Filter radius"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:420
-msgid "Filter radius (horizontal)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:427
-msgid "Filter radius (vertical)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:438 ../vector/v.external.out/args.c:90
-#, c-format
-msgid "%s= and %s=/%s= are mutually exclusive"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:443
-#, c-format
-msgid "Either %s= or %s=/%s= required"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:446
-#, c-format
-msgid "Both %s= and %s= required"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:469
-msgid "Differing number of values for filter= and [xy_]radius="
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:472
-#, c-format
-msgid "Too many filters (max: %d)"
-msgstr ""
-#: ../raster/r.resamp.filter/main.c:490
-msgid "At least one filter must be finite"
-msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:53
-msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:55 ../raster/r.li/r.li.simpson/simpson.c:47
-#: ../raster/r.li/r.li.dominance/dominance.c:47
-#: ../raster/r.li/r.li.patchdensity/main.c:52
-#: ../raster/r.li/r.li.pielou/pielou.c:47 ../raster/r.li/r.li.mpa/mpa.c:45
-#: ../raster/r.li/r.li.richness/richness.c:44
-#: ../raster/r.li/r.li.padcv/padcv.c:54 ../raster/r.li/r.li.shape/main.c:50
-#: ../raster/r.li/r.li.padsd/padsd.c:54 ../raster/r.li/r.li.patchnum/main.c:51
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:49
-#: ../raster/r.li/r.li.renyi/renyi.c:48 ../raster/r.li/r.li.mps/mps.c:53
-#: ../raster/r.li/r.li.padrange/padrange.c:54
-#: ../raster/r.li/r.li.shannon/shannon.c:47
-msgid "landscape structure analysis"
-msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:56
-#: ../raster/r.li/r.li.patchdensity/main.c:53 ../raster/r.li/r.li.mpa/mpa.c:46
-#: ../raster/r.li/r.li.padcv/padcv.c:55 ../raster/r.li/r.li.shape/main.c:51
-#: ../raster/r.li/r.li.padsd/padsd.c:55 ../raster/r.li/r.li.patchnum/main.c:52
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:50
-#: ../raster/r.li/r.li.mps/mps.c:54 ../raster/r.li/r.li.padrange/padrange.c:55
-msgid "patch index"
-msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:64 ../raster/r.li/r.li.simpson/simpson.c:56
-#: ../raster/r.li/r.li.dominance/dominance.c:56
-#: ../raster/r.li/r.li.patchdensity/main.c:61
-#: ../raster/r.li/r.li.pielou/pielou.c:56 ../raster/r.li/r.li.mpa/mpa.c:53
-#: ../raster/r.li/r.li.richness/richness.c:53
-#: ../raster/r.li/r.li.padcv/padcv.c:62 ../raster/r.li/r.li.shape/main.c:59
-#: ../raster/r.li/r.li.padsd/padsd.c:62 ../raster/r.li/r.li.patchnum/main.c:59
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:58
-#: ../raster/r.li/r.li.renyi/renyi.c:57 ../raster/r.li/r.li.mps/mps.c:62
-#: ../raster/r.li/r.li.padrange/padrange.c:62
-#: ../raster/r.li/r.li.shannon/shannon.c:56
-msgid "Configuration file"
-msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:70
-msgid "Name of file that contains the weight to calculate the index"
-msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:306 ../raster/r.li/r.li.cwed/cwed.c:453
-#: ../raster/r.li/r.li.cwed/cwed.c:599
-msgid "Row cache is too small"
-msgstr ""
-#: ../raster/r.li/r.li.simpson/simpson.c:45
-msgid "Calculates Simpson's diversity index on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.simpson/simpson.c:48
-#: ../raster/r.li/r.li.dominance/dominance.c:48
-#: ../raster/r.li/r.li.pielou/pielou.c:48
-#: ../raster/r.li/r.li.richness/richness.c:45
-#: ../raster/r.li/r.li.renyi/renyi.c:49
-#: ../raster/r.li/r.li.shannon/shannon.c:48
-msgid "diversity index"
-msgstr ""
-#: ../raster/r.li/r.li.dominance/dominance.c:45
-msgid "Calculates dominance's diversity index on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.patchdensity/main.c:50
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-#: ../raster/r.li/r.li.pielou/pielou.c:45
-msgid "Calculates Pielou's diversity index on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.mpa/mpa.c:43
-msgid "Calculates mean pixel attribute index on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.richness/richness.c:42
-msgid "Calculates richness index on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.padcv/padcv.c:52
-msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.shape/main.c:48
-msgid "Calculates shape index on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.padsd/padsd.c:52
-msgid "Calculates standard deviation of patch area a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:97
-msgid "Cannot create random access file"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:105
-#: ../raster/r.li/r.li.daemon/daemon.c:111
-#: ../raster/r.li/r.li.daemon/daemon.c:117
-#, c-format
-msgid "Cannot create %s directory"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:201
-#, c-format
-msgid "Cannot find configuration file <%s>"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:208
-#: ../raster/r.li/r.li.daemon/daemon.c:212
-msgid "Cannot read setup file"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:216
-msgid "Unable to parse configuration file (sampling frame)"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:475
-msgid "Irregular MASKEDOVERLAY areas definition"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:479
-#, c-format
-msgid "The configuration file can only be used with the <%s> raster map"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:485
-msgid "Unable to parse configuration file (sample area)"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:520
-msgid "Too many units to place"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:589
-msgid "Too many stratified random sample for raster map"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:623
-msgid "Illegal areas disposition"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:695
-msgid "Cannot make lseek"
-msgstr ""
-#: ../raster/r.li/r.li.daemon/worker.c:135
-#, c-format
-msgid "unable to open <%s> mask ... continuing without!"
-msgstr ""
-#: ../raster/r.li/r.li.patchnum/main.c:49
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour "
-"algorithm."
-msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:68
-msgid "The value of the patch type"
-msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:69
-msgid ""
-"It can be integer, double or float; it will be changed in function of map "
-"type"
-msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:74
-msgid "Exclude border edges"
-msgstr ""
-#: ../raster/r.li/r.li.renyi/renyi.c:46
-msgid "Calculates Renyi's diversity index on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.renyi/renyi.c:63
-msgid "Alpha value is the order of the generalized entropy"
-msgstr ""
-#: ../raster/r.li/r.li.mps/mps.c:51
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-#: ../raster/r.li/r.li.padrange/padrange.c:52
-msgid "Calculates range of patch area size on a raster map"
-msgstr ""
-#: ../raster/r.li/r.li.shannon/shannon.c:45
-msgid "Calculates Shannon's diversity index on a raster map"
-msgstr ""
-#: ../raster/r.latlong/main.c:57
-msgid "latitude"
-msgstr ""
-#: ../raster/r.latlong/main.c:58
-msgid "longitude"
-msgstr ""
-#: ../raster/r.latlong/main.c:60
-msgid "Creates a latitude/longitude raster map."
-msgstr ""
-#: ../raster/r.latlong/main.c:66
-msgid "Name for output latitude or longitude raster map"
-msgstr ""
-#: ../raster/r.latlong/main.c:70
-msgid "Longitude output"
-msgstr ""
-#: ../raster/r.mapcalc/map.c:226 ../raster/r.mapcalc/map3.c:182
-#, c-format
-msgid "Unable to read color file for raster map <%s@%s>"
-msgstr ""
-#: ../raster/r.mapcalc/map.c:239 ../raster/r.mapcalc/map3.c:195
-#, c-format
-msgid "Unable to create btree for raster map <%s@%s>"
-msgstr ""
-#: ../raster/r.mapcalc/map.c:288 ../raster/r.mapcalc/map.c:495
-#: ../raster/r.mapcalc/map.c:536 ../raster/r.mapcalc/map.c:634
-#: ../raster/r.mapcalc/map3.c:240 ../raster/r.mapcalc/map3.c:424
-#: ../raster/r.mapcalc/map3.c:469 ../raster/r.mapcalc/map3.c:566
-#: ../raster/r.mapcalc/expression.c:357
-#, c-format
-msgid "Invalid map modifier: '%c'"
-msgstr ""
-#: ../raster/r.mapcalc/map.c:426 ../raster/r.mapcalc/map3.c:354
-#: ../raster/r.mapcalc/evaluate.c:143 ../raster/r.mapcalc/evaluate.c:283
-#, c-format
-msgid "Unknown type: %d"
-msgstr ""
-#: ../raster/r.mapcalc/map3.c:129 ../raster/r.mapcalc/map3.c:143
-#: ../raster/r.mapcalc/map3.c:157 ../raster/r.out.bin/main.c:53
-#: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:470
-#: ../raster3d/r3.out.bin/main.c:113
-msgid "Error writing data"
-msgstr ""
-#: ../raster/r.mapcalc/map3.c:373
-#, c-format
-msgid "Unable to close raster map <%s@%s>"
-msgstr ""
-#: ../raster/r.mapcalc/map3.c:632
-msgid "Unable to close output raster map"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:72
-msgid "Raster map calculator."
-msgstr ""
-#: ../raster/r.mapcalc/main.c:79
-msgid "Expression to evaluate"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:80 ../raster/r.mapcalc/main.c:99
-msgid "Expression"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:88
-msgid ""
-"The computational region that should be used.\n"
-"               - current uses the current region of the mapset.\n"
-"               - intersect computes the intersection region between\n"
-"                 all input maps and uses the smallest resolution\n"
-"               - union computes the union extent of all map regions\n"
-"                 and uses the smallest resolution"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:98
-msgid "File containing expression(s) to evaluate"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:105
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:18
-msgid "Seed for rand() function"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:109
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:20
-msgid "Generate random seed (result is non-deterministic)"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:113
-msgid "List input and output maps"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:135
-#, c-format
-msgid "%s= and -%c are mutually exclusive"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:146
-msgid "parse error"
-msgstr ""
-#: ../raster/r.mapcalc/main.c:185
-msgid "Floating point error(s) occurred in the calculation"
-msgstr ""
-#: ../raster/r.mapcalc/function.c:35
-#, c-format
-msgid "Known functions:"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:206
-#, c-format
-msgid "Undefined variable '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:221
-#, c-format
-msgid "Invalid map <%s>"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:262
-#, c-format
-msgid "Undefined function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:267
-#, c-format
-msgid "Too few arguments (%d) to function %s()"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:271
-#, c-format
-msgid "Too many arguments (%d) to function %s()"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:275
-#, c-format
-msgid "Incorrect argument types to function %s()"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:278
-#, c-format
-msgid "Internal error for function %s()"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:453
-#, c-format
-msgid "Illegal number of arguments (%d) for operator '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/expression.c:493
-#, c-format
-msgid "Format_expression_prec: unknown type: %d"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:189
-#, c-format
-msgid "Invalid type: %d"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:228
-#, c-format
-msgid "Too few arguments for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:232
-#, c-format
-msgid "Too many arguments for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:236
-#, c-format
-msgid "Invalid argument type for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:240
-#, c-format
-msgid "Invalid return type for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:244
-#, c-format
-msgid "Unknown type for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:247
-#, c-format
-msgid "Number of arguments for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:251
-#, c-format
-msgid "Unknown error for function '%s'"
-msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:329
-#, c-format
-msgid "output map <%s> exists. To overwrite, use the --overwrite flag"
-msgstr ""
-#: ../raster/r.out.gdal/attr.c:140 ../raster/r.out.gdal/attr.c:178
-msgid "Failed to set raster attribute table"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:52
-#, c-format
-msgid "Supported formats:\n"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:138
-msgid "Exports GRASS raster maps into GDAL supported formats."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:144
-msgid "List supported output formats"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:150
-msgid "Do not write GDAL standard colortable"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:151
-msgid "Only applicable to Byte or UInt16 data types"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:152 ../raster/r.out.gdal/main.c:158
-#: ../raster/r.out.gdal/main.c:205 ../raster/r.out.gdal/main.c:216
-#: ../raster/r.out.gdal/main.c:227 ../raster/r.out.gdal/main.c:240
-#: ../raster/r.out.gdal/main.c:251 ../vector/v.out.postgis/args.c:38
-#: ../vector/v.out.postgis/args.c:48 ../vector/v.out.postgis/args.c:61
-#: ../vector/v.out.postgis/args.c:67 ../vector/v.out.postgis/args.c:73
-#: ../vector/v.out.postgis/args.c:79 ../vector/v.out.ogr/args.c:48
-#: ../vector/v.out.ogr/args.c:59 ../vector/v.out.ogr/args.c:69
-#: ../vector/v.out.ogr/args.c:79 ../vector/v.out.ogr/args.c:95
-#: ../vector/v.out.ogr/args.c:108 ../vector/v.out.ogr/args.c:115
-#: ../vector/v.out.ogr/args.c:121 ../vector/v.out.ogr/args.c:128
-msgid "Creation"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:156
-msgid "Do not write non-standard metadata"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:157
-msgid "Enhances compatibility with other GIS software"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:162
-msgid "Write raster attribute table"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:163
-msgid "Some export formats may not be supported"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:167
-msgid "Force raster export despite any warnings of data loss"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:168
-msgid "Overrides nodata safety check"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:171
-msgid "Name of raster map (or group) to export"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:174
-msgid "Name for output raster file"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:180
-msgid "Raster data format to write (case sensitive, see also -l flag)"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:201
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:11
-msgid "Data type"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:211
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:13
-msgid "Creation option(s) to pass to the output format driver"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:213
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:14
-msgid "In the form of \"NAME=VALUE\", separate multiple entries with a comma"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:221
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:15
-msgid "Metadata key(s) and value(s) to include"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:223
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:16
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:233
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:17
-msgid "Assign a specified nodata value to output bands"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:235
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:18
-msgid ""
-"If given, the nodata value is always written to metadata even if there are "
-"no NULL cells in the input band (enhances output compatibility)."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:248
-msgid "Number of overviews to create for the output dataset"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:278
-#, c-format
-msgid "Raster map or group <%s> not found"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:282
-#, c-format
-msgid "No raster maps in group <%s>"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:297
-#, c-format
-msgid "Unable to get <%s> driver"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:303
-#, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:308
-msgid "Unable to get in-memory raster driver"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:312
-#, c-format
-msgid "Driver <%s> does not support creating rasters"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:387
-#, c-format
-msgid "Could not read data range of raster <%s>"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:444
-#, c-format
-msgid "Exporting to GDAL data type: %s"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:459
-msgid "Raster export would result in complete data loss, aborting."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:470
-#, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be"
-" avoided by using %s."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:481
-#, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:489
-#, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>."
-" This can be avoided by using Float64"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:498
-msgid "Forcing raster export"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:500
-#, c-format
-msgid "Raster export aborted. To override data loss check, use the -%c flag"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:515 ../raster/r.out.gdal/main.c:544
-#: ../raster/r.out.gdal/main.c:548
-msgid "Raster export aborted."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:525
-msgid "Checking GDAL data type and nodata value..."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:528
-#, c-format
-msgid "Checking options for raster map <%s> (band %d)..."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:542
-msgid "Forcing raster export."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:573
-msgid "Unable to create dataset using memory raster driver"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:582
-#, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:597
-msgid "Unable to set geo transform"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:605
-msgid "Unable to set projection"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:633
-#, c-format
-msgid "Exporting raster data to %s format..."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:636
-#, c-format
-msgid "Exporting raster map <%s> (band %d)..."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:649
-#, c-format
-msgid "Unable to export raster map <%s>"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:662
-msgid "Number of overviews must be between 0 and 5"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:669
-msgid "Building overviews ..."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:679
-msgid "Unable to build overviews"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:690
-#, c-format
-msgid "Unable to create raster map <%s> using driver <%s>"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:713 ../raster/r.out.gdal/main.c:725
-#: ../raster/r.out.gdal/main.c:738 ../raster/r.out.gdal/main.c:751
-#: ../raster/r.out.gdal/main.c:763 ../raster/r.out.gdal/main.c:777
-#: ../raster/r.out.gdal/export_band.c:477
-#: ../raster/r.out.gdal/export_band.c:489
-#: ../raster/r.out.gdal/export_band.c:502
-#: ../raster/r.out.gdal/export_band.c:515
-#: ../raster/r.out.gdal/export_band.c:527
-#: ../raster/r.out.gdal/export_band.c:540
-#: ../raster/r.out.gdal/export_band.c:554
-msgid "Selected GDAL datatype does not cover data range."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:714 ../raster/r.out.gdal/main.c:726
-#: ../raster/r.out.gdal/main.c:739 ../raster/r.out.gdal/main.c:752
-#: ../raster/r.out.gdal/export_band.c:478
-#: ../raster/r.out.gdal/export_band.c:490
-#: ../raster/r.out.gdal/export_band.c:503
-#: ../raster/r.out.gdal/export_band.c:516
-#, c-format
-msgid "GDAL datatype: %s, range: %d - %d"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:717 ../raster/r.out.gdal/main.c:729
-#: ../raster/r.out.gdal/main.c:742 ../raster/r.out.gdal/main.c:755
-#: ../raster/r.out.gdal/main.c:767 ../raster/r.out.gdal/main.c:781
-#, c-format
-msgid "Range to be exported: %g - %g"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:764 ../raster/r.out.gdal/export_band.c:528
-#, c-format
-msgid "GDAL datatype: %s, range: %u - %u"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:778 ../raster/r.out.gdal/export_band.c:541
-#: ../raster/r.out.gdal/export_band.c:555
-#, c-format
-msgid "GDAL datatype: %s, range: %g - %g"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:805 ../raster/r.out.gdal/main.c:818
-#: ../raster/r.out.gdal/main.c:832 ../raster/r.out.gdal/main.c:845
-#: ../raster/r.out.gdal/main.c:860
-#, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:808 ../raster/r.out.gdal/main.c:835
-#: ../raster/r.out.gdal/main.c:863
-#, c-format
-msgid "GDAL datatype: %s, valid range: %d - %d"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:821 ../raster/r.out.gdal/main.c:848
-#, c-format
-msgid "GDAL datatype: %s, valid range: %u - %u"
-msgstr ""
-#: ../raster/r.out.gdal/main.c:874
-#, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
-msgstr ""
-#: ../raster/r.out.gdal/main.c:877
-#, c-format
-msgid "GDAL datatype: %s, valid range: %g - %g"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:53
-#: ../raster/r.out.gdal/export_band.c:359
-msgid "Unable to allocate buffer for reading raster map"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:168
-#, c-format
-msgid "Using GDAL data type <%s>"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:173
-#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will"
-" be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:178
-#, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:188
-#, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:195
-#, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:240
-msgid "Unable to get raster band"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:396
-#: ../raster/r.out.gdal/export_band.c:425
-#: ../raster/r.out.gdal/export_band.c:454
-msgid "Unable to write GDAL raster file"
-msgstr ""
-#: ../raster/r.out.gdal/export_band.c:481
-#: ../raster/r.out.gdal/export_band.c:493
-#: ../raster/r.out.gdal/export_band.c:506
-#: ../raster/r.out.gdal/export_band.c:519
-#: ../raster/r.out.gdal/export_band.c:531
-#: ../raster/r.out.gdal/export_band.c:544
-#: ../raster/r.out.gdal/export_band.c:558
-#, c-format
-msgid "Raster map <%s> range: %g - %g"
-msgstr ""
-#: ../raster/r.support/check.c:26
-#, c-format
-msgid ""
-"\n"
-"  Updating statistics for [%s]"
-msgstr ""
-#: ../raster/r.support/check.c:69
-#, c-format
-msgid ""
-"   Updating the number of categories for [%s]\n"
-"\n"
-msgstr ""
-#: ../raster/r.support/main.c:56
-msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-#: ../raster/r.support/main.c:74 ../raster3d/r3.support/main.c:70
-msgid "Text to append to the next line of the map's metadata file"
-msgstr ""
-#: ../raster/r.support/main.c:80
-msgid "Text to use for map data units"
-msgstr ""
-#: ../raster/r.support/main.c:86
-msgid "Text to use for map vertical datum"
-msgstr ""
-#: ../raster/r.support/main.c:93 ../raster3d/r3.support/main.c:89
-msgid "Text to use for data source, line 1"
-msgstr ""
-#: ../raster/r.support/main.c:100 ../raster3d/r3.support/main.c:96
-msgid "Text to use for data source, line 2"
-msgstr ""
-#: ../raster/r.support/main.c:108 ../raster3d/r3.support/main.c:104
-msgid "Text to use for data description or keyword(s)"
-msgstr ""
-#: ../raster/r.support/main.c:120 ../raster3d/r3.support/main.c:116
-msgid "Text file from which to load history"
-msgstr ""
-#: ../raster/r.support/main.c:125 ../raster3d/r3.support/main.c:121
-msgid "Text file in which to save history"
-msgstr ""
-#: ../raster/r.support/main.c:129
-msgid "Update statistics (histogram, range)"
-msgstr ""
-#: ../raster/r.support/main.c:133
-msgid "Create/reset the null file"
-msgstr ""
-#: ../raster/r.support/main.c:137
-msgid "Delete the null file"
-msgstr ""
-#: ../raster/r.support/main.c:249 ../raster3d/r3.support/main.c:252
-#, c-format
-msgid "cats table for [%s] set to %s"
-msgstr ""
-#: ../raster/r.support/main.c:273 ../raster/r.support/main.c:301
-#, c-format
-msgid "[%s] is a reclass of another map. Exiting."
-msgstr ""
-#: ../raster/r.support/main.c:285
-#, c-format
-msgid "Writing new null file for [%s]... "
-msgstr ""
-#: ../raster/r.support/main.c:305
-#, c-format
-msgid "Removing null file for [%s]...\n"
-msgstr ""
-#: ../raster/r.support/main.c:312 ../scripts/i.in.spotvgt/i.in.spotvgt.py:280
-#: ../scripts/r.in.aster/r.in.aster.py:144 ../scripts/r.plane/r.plane.py:122
-#: ../scripts/d.polar/d.polar.py:407 ../scripts/v.in.e00/v.in.e00.py:165
-#: ../scripts/r.fillnulls/r.fillnulls.py:496
-msgid "Done."
-msgstr ""
-#: ../raster/r.out.bin/main.c:139
-#, c-format
-msgid "Header File = %s"
-msgstr ""
-#: ../raster/r.out.bin/main.c:144 ../raster/r.out.bin/main.c:228
-#: ../raster/r.out.bin/main.c:414 ../display/d.mon/start.c:181
-#: ../display/d.mon/start.c:224 ../raster3d/r3.out.bin/main.c:321
-#, c-format
-msgid "Unable to create file <%s>"
-msgstr ""
-#: ../raster/r.out.bin/main.c:223
-#, c-format
-msgid "World File = %s"
-msgstr ""
-#: ../raster/r.out.bin/main.c:281
-msgid "Exports a GRASS raster to a binary array."
-msgstr ""
-#: ../raster/r.out.bin/main.c:297
-msgid "Name for output binary map (use output=- for stdout)"
-msgstr ""
-#: ../raster/r.out.bin/main.c:304 ../raster3d/r3.out.bin/main.c:221
-msgid "Value to write out for null"
-msgstr ""
-#: ../raster/r.out.bin/main.c:323
-msgid "Generate integer output"
-msgstr ""
-#: ../raster/r.out.bin/main.c:327
-msgid "Generate floating-point output"
-msgstr ""
-#: ../raster/r.out.bin/main.c:331
-msgid "Export array with GMT compatible header"
-msgstr ""
-#: ../raster/r.out.bin/main.c:335
-msgid "Generate BIL world and header files"
-msgstr ""
-#: ../raster/r.out.bin/main.c:339
-msgid "Byte swap output"
-msgstr ""
-#: ../raster/r.out.bin/main.c:347 ../raster3d/r3.out.bin/main.c:256
-msgid "Invalid value for null (integers only)"
-msgstr ""
-#: ../raster/r.out.bin/main.c:399
-#, c-format
-msgid "Floating-point output requires %s=4 or %s=8"
-msgstr ""
-#: ../raster/r.out.bin/main.c:404
-#, c-format
-msgid "Integer output doesn't support %s=8 in this build"
-msgstr ""
-#: ../raster/r.out.bin/main.c:419
-msgid "GMT grid doesn't support 64-bit integers"
-msgstr ""
-#: ../raster/r.out.bin/main.c:425
-msgid "Creating BIL support files..."
-msgstr ""
-#: ../raster/r.out.bin/main.c:442
-#, c-format
-msgid "Exporting raster as floating values (%s=%d)"
-msgstr ""
-#: ../raster/r.out.bin/main.c:445
-msgid "Writing GMT float format ID=1"
-msgstr ""
-#: ../raster/r.out.bin/main.c:448
-#, c-format
-msgid "Exporting raster as integer values (%s=%d)"
-msgstr ""
-#: ../raster/r.out.bin/main.c:451
-msgid "Writing GMT integer format ID=2"
-msgstr ""
-#: ../raster/r.out.bin/main.c:454 ../raster3d/r3.out.bin/main.c:323
-msgid "Using the current region settings..."
-msgstr ""
-#: ../raster/r.out.bin/main.c:455 ../raster3d/r3.out.bin/main.c:324
-#, c-format
-msgid "north=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:456 ../raster3d/r3.out.bin/main.c:325
-#, c-format
-msgid "south=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:457 ../raster3d/r3.out.bin/main.c:326
-#, c-format
-msgid "east=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:458 ../raster3d/r3.out.bin/main.c:327
-#, c-format
-msgid "west=%f"
-msgstr ""
-#: ../raster/r.out.bin/main.c:459
-#, c-format
-msgid "r=%d"
-msgstr ""
-#: ../raster/r.out.bin/main.c:460
-#, c-format
-msgid "c=%d"
-msgstr ""
-#: ../raster/r.support.stats/check.c:43
-#, c-format
-msgid "Updating statistics for [%s]..."
-msgstr ""
-#: ../raster/r.support.stats/check.c:56
-msgid "Updating histogram range..."
-msgstr ""
-#: ../raster/r.support.stats/check.c:88
-#, c-format
-msgid "Updating the number of categories for [%s]..."
-msgstr ""
-#: ../raster/r.support.stats/main.c:37
-msgid "Update raster map statistics"
-msgstr ""
-#: ../raster/r.support.stats/main.c:49
-#, c-format
-msgid "Statistics for <%s> updated"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:99
-msgid "The number of input and elevation maps is not equal"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:165
-msgid "The value to fill the upper cells, default is null"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:172
-msgid "The value to fill the lower cells, default is null"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:185
-msgid "Use the input map values to fill the upper cells"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:190
-msgid "Use the input map values to fill the lower cells"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:194 ../raster3d/r3.cross.rast/main.c:109
-#: ../raster3d/r3.out.netcdf/main.c:116 ../raster3d/r3.out.ascii/main.c:118
-#: ../raster3d/r3.to.rast/main.c:128
-msgid "Use 3D raster mask (if exists) with input map"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
-msgid "Error writing 3D raster double data"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:366
-msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:400
-msgid "The upper value is not valid"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:410
-msgid "The lower value is not valid"
-msgstr ""
-#: ../raster/r.to.rast3elev/main.c:427
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
-msgstr ""
-#: ../raster/r.spread/main.c:111
-msgid "Simulates elliptically anisotropic spread."
-msgstr ""
-#: ../raster/r.spread/main.c:113
-msgid ""
-"Generates a raster map of the cumulative time of spread, given raster maps "
-"containing the rates of spread (ROS), the ROS directions and the spread "
-"origins. It optionally produces raster maps to contain backlink UTM "
-"coordinates for tracing spread paths. Usable for fire spread simulations."
-msgstr ""
-#: ../raster/r.spread/main.c:127
-msgid "Raster map containing base ROS (cm/min)"
-msgstr ""
-#: ../raster/r.spread/main.c:129
-msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the ROS values in the directions perpendicular to maximum "
-"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
-"directional factors."
-msgstr ""
-#: ../raster/r.spread/main.c:141
-msgid "Raster map containing maximal ROS (cm/min)"
-msgstr ""
-#: ../raster/r.spread/main.c:143
-msgid ""
-"path containing the maximum ROS values (cm/minute)."
-msgstr ""
-#: ../raster/r.spread/main.c:153
-msgid "Raster map containing directions of maximal ROS (degree)"
-msgstr ""
-#: ../raster/r.spread/main.c:155
-msgid ""
-"path containing directions of the maximum ROSes, clockwise from north "
-"(degree)."
-msgstr ""
-#: ../raster/r.spread/main.c:166
-msgid "Raster map containing starting sources"
-msgstr ""
-#: ../raster/r.spread/main.c:168
-msgid ""
-"path containing starting locations of the spread phenomenon. Any positive "
-"integers in this map are recognized as starting sources (seeds)."
-msgstr ""
-#: ../raster/r.spread/main.c:179
-msgid "Raster map containing maximal spotting distance (m, required with -s)"
-msgstr ""
-#: ../raster/r.spread/main.c:181
-msgid ""
-"path containing the maximum potential spotting distances (meters)."
-msgstr ""
-#: ../raster/r.spread/main.c:191
-msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
-msgstr ""
-#: ../raster/r.spread/main.c:203
-msgid ""
-"Raster map containing fine fuel moisture of the cell receiving a spotting "
-"firebrand (%, required with -s)"
-msgstr ""
-#: ../raster/r.spread/main.c:215
-msgid "Basic sampling window size needed to meet certain accuracy (3)"
-msgstr ""
-#: ../raster/r.spread/main.c:217
-msgid ""
-"An odd integer ranging 3 - 15 indicating the basic sampling window size "
-"within which all cells will be considered to see whether they will be "
-"reached by the current spread cell. The default number is 3 which means a "
-"3x3 window."
-msgstr ""
-#: ../raster/r.spread/main.c:227
-msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
-msgstr ""
-#: ../raster/r.spread/main.c:229
-msgid ""
-"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will"
-" be considered to see whether they will be reached by the current spread "
-"cell. The closer to 1.0 the decimal number is, the longer the program will "
-"run and the higher the simulation accuracy will be. The default number is "
-"0.5."
-msgstr ""
-#: ../raster/r.spread/main.c:241
-msgid "Initial time for current simulation (0) (min)"
-msgstr ""
-#: ../raster/r.spread/main.c:243
-msgid ""
-"A non-negative number specifying the initial time for the current spread "
-"simulation (minutes). This is useful when multiple phase simulation is "
-"conducted. The default time is 0."
-msgstr ""
-#: ../raster/r.spread/main.c:252
-msgid "Simulating time duration LAG (fill the region) (min)"
-msgstr ""
-#: ../raster/r.spread/main.c:254
-msgid ""
-"A non-negative integer specifying the simulating duration time lag "
-"(minutes). The default is infinite, but the program will terminate when the "
-"current geographic region/mask has been filled. It also controls the "
-"computational time, the shorter the time lag, the faster the program will "
-"run."
-msgstr ""
-#: ../raster/r.spread/main.c:266
-msgid "Name of raster map as a display backdrop"
-msgstr ""
-#: ../raster/r.spread/main.c:268
-msgid ""
-"path to be used as the background on which the \"live\" movement will be "
-"shown."
-msgstr ""
-#: ../raster/r.spread/main.c:279
-msgid "Raster map to contain output spread time (min)"
-msgstr ""
-#: ../raster/r.spread/main.c:281
-msgid ""
-"Name of the new raster map layer to contain the results of the cumulative "
-"spread time needed for a phenomenon to reach each cell from the starting "
-"sources (minutes)."
-msgstr ""
-#: ../raster/r.spread/main.c:291
-msgid "Name of raster map to contain X back coordinates"
-msgstr ""
-#: ../raster/r.spread/main.c:293
-msgid ""
-"Name of the new raster map layer to contain the results of backlink "
-"information in UTM easting coordinates for each cell."
-msgstr ""
-#: ../raster/r.spread/main.c:303
-msgid "Name of raster map to contain Y back coordinates"
-msgstr ""
-#: ../raster/r.spread/main.c:305
-msgid ""
-"information in UTM northing coordinates for each cell."
-msgstr ""
-#: ../raster/r.spread/main.c:312
-msgid "DISPLAY 'live' spread process on screen"
-msgstr ""
-#: ../raster/r.spread/main.c:314
-msgid ""
-"Display the 'live' simulation on screen. A graphics window must be opened "
-"and selected before using this option."
-msgstr ""
-#: ../raster/r.spread/main.c:320
-msgid "Consider spotting effect (for wildfires)"
-msgstr ""
-#: ../raster/r.spread/main.c:324
-msgid "Use start raster map values in output spread time raster map"
-msgstr ""
-#: ../raster/r.spread/main.c:326
-msgid ""
-"Designed to be used with output of previous run of r.spread when computing "
-"spread iteratively. The values in start raster map are considered as time. "
-"Allowed values in raster map are from zero to the value of init_time option."
-" If not enabled, init_time is used in the area of start raster map"
-msgstr ""
-#: ../raster/r.spread/main.c:502
-msgid "Reading inputs..."
-msgstr ""
-#: ../raster/r.spread/main.c:543
-#, c-format
-msgid "Maximum of start raster map is grater than init_time (%d > %d)"
-msgstr ""
-#: ../raster/r.spread/main.c:547
-#, c-format
-msgid "Minimum of start raster map is less than zero (%d < 0)"
-msgstr ""
-#: ../raster/r.spread/main.c:555
-#, c-format
-msgid "Reading %s..."
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:104
-msgid "animation"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:107
-msgid "Converts raster map series to MPEG movie."
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:115
-#, c-format
-msgid "Name of input raster map(s) for view no.%d"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:117
-msgid "Views"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:131
-msgid "Quality factor (1 = highest quality, lowest compression)"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:136
-msgid "Convert on the fly, uses less disk space"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:137
-msgid "Requires r.out.ppm with stdout option"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:160
-msgid "Either mpeg_encode or ppmtompeg must be installed"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:291
-#, c-format
-msgid "Unable to read color table for <%s>"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:341 ../raster/r.out.mpeg/main.c:374
-msgid "mpeg_encode ERROR"
-msgstr ""
-#: ../raster/r.out.mpeg/main.c:417
-msgid "Error reading wildcard"
-msgstr ""
-#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
-msgid "Size mismatch error!"
-msgstr ""
-#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
-msgid "Unable to open output file"
-msgstr ""
-#: ../raster/r.out.mpeg/write.c:215
-msgid "Unable to create temporary files."
-msgstr ""
-#: ../raster/r.out.mat/main.c:64
-msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr ""
-#: ../raster/r.out.mat/main.c:73
-msgid "Name for output binary MAT file"
-msgstr ""
-#: ../raster/r.out.mat/main.c:113
-#, c-format
-msgid "Exporting <%s>"
-msgstr ""
-#: ../raster/r.out.mat/main.c:173
-msgid "Using the Current Region settings:"
-msgstr ""
-#: ../raster/r.out.mat/main.c:248
-msgid "Exporting raster as integer values"
-msgstr ""
-#: ../raster/r.out.mat/main.c:253
-msgid "Exporting raster as floating point values"
-msgstr ""
-#: ../raster/r.out.mat/main.c:258
-msgid "Exporting raster as double FP values"
-msgstr ""
-#: ../raster/r.out.mat/main.c:301
-msgid "Reading in map ... "
-msgstr ""
-#: ../raster/r.out.mat/main.c:314
-msgid "Writing out map..."
-msgstr ""
-#: ../raster/r.out.mat/main.c:374
-#, c-format
-msgid "%ld bytes written to '%s'"
-msgstr ""
-#: ../raster/r.in.png/main.c:297
-#, c-format
-msgid "Unable to open PNG file '%s'"
-msgstr ""
-#: ../raster/r.in.png/main.c:300
-msgid "Input file empty or too short"
-msgstr ""
-#: ../raster/r.in.png/main.c:303
-msgid "Input file not a PNG file"
-msgstr ""
-#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
-#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
-msgid "Unable to allocate PNG structure"
-msgstr ""
-#: ../raster/r.in.png/main.c:314
-msgid "PNG error"
-msgstr ""
-#: ../raster/r.in.png/main.c:522
-msgid "Imports non-georeferenced PNG format image."
-msgstr ""
-#: ../raster/r.in.png/main.c:532
-msgid "Title for created raster map"
-msgstr ""
-#: ../raster/r.in.png/main.c:538
-msgid "Display gamma"
-msgstr ""
-#: ../raster/r.in.png/main.c:544
-msgid "Alpha threshold"
-msgstr ""
-#: ../raster/r.in.png/main.c:548
-msgid "Create floating-point map (0.0 - 1.0)"
-msgstr ""
-#: ../raster/r.in.png/main.c:552
-msgid "Output image file header only and exit"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:103
-msgid ""
-"Calculates geomorphons (terrain forms) and associated geometry using machine"
-" vision approach."
-msgstr ""
-#: ../raster/r.geomorphon/main.c:105
-msgid "geomorphons"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:106
-msgid "terrain patterns"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:107
-msgid "machine vision geomorphometry"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:127
-msgid "Outer search radius"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:134
-msgid "Inner search radius"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:141
-msgid "Flatenss threshold (degrees)"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:149
-msgid "Flatenss distance, zero for none"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:155
-msgid "Prefix for maps resulting from multiresolution approach"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:156 ../raster/r.geomorphon/main.c:164
-#: ../raster/r.geomorphon/main.c:172
-msgid "Multires"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:163
-msgid "Distance step for every iteration (zero to omit)"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:171
-msgid "Distance where serch will start in multiple mode (zero to omit)"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:177
-msgid "Use meters to define search units (default is cells)"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:181
-msgid "Use extended form correction"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:201
-#, c-format
-msgid "At least one output is required, e.g. %s"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:227
-msgid "Search radius size must cover at least 1 cell"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:239
-msgid "Skip radius size must be at least 1 cell lower than radius"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:245
-msgid "Flatenss threshold must be grater than 0"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:254
-msgid ""
-"Flatenss distance should be between skip and search radius. Otherwise "
-"ignored"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:272
-msgid ""
-"For multiresolution mode step must be greater than or equal to resolution of"
-" one cell"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:276
-#, c-format
-msgid "<%s> is an incorrect prefix"
-msgstr ""
-#: ../raster/r.geomorphon/main.c:368
-msgid "Unknown output data type"
-msgstr ""
-#: ../raster/r.geomorphon/memory.c:21
-#, c-format
-msgid ""
-"Region resolution shoudn't be lesser than map %s resolution. Run g.region "
-"raster=%s to set proper resolution"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:155
-msgid "Spatial weights neighborhood (cells):"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:781
-msgid ""
-"Rapidly fills 'no data' cells (NULLs) of a raster map with interpolated "
-"values (IDW)."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:789
-msgid "Raster map with data gaps to fill"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:794
-msgid "Name of result output map"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:799
-msgid "Name of uncertainty output map"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:808
-msgid "Distance threshold (default: in cells) for interpolation"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:817
-msgid "Statistic for interpolated cell values"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:828
-msgid "Minimum input data value to include in interpolation"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:837
-msgid "Maximum input data value to include in interpolation"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:846
-msgid "Power coefficient for IDW interpolation"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:856
-msgid "Minimum number of data cells within search radius"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:861
-msgid "Interpret distance as map units, not number of cells"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:865
-msgid "Keep (preserve) original cell values"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:867
-msgid "By default original values are smoothed"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:871
-msgid "Just print the spatial weights matrix"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:875
-msgid "Just print estimated memory usage"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:880
-msgid "Single precision floating point output"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:893
-msgid "You are working with lat/lon data."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:894
-msgid "This module uses a straight-line distance metric."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:895
-msgid "Expect inaccuracies."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:910
-msgid "Result map name cannot be identical with uncertainty map name."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:919
-msgid "Maximum distance must be larger than zero."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:923
-#, c-format
-msgid "Maximum distance must be at least '%.6f' (W-E resolution)."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:928
-#, c-format
-msgid "Maximum distance must be at least '%.6f' (S-N resolution)."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:933
-#, c-format
-msgid "Maximum distance must be at least '%.6f' (W-E and S-N resolution)."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:938
-#, c-format
-msgid ""
-"Maximum distance too large. Adjusted to '%.6f' (diagonal of current region)."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:948
-msgid "Maximum distance must be at least one cell."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:954
-#, c-format
-msgid ""
-"Maximum distance too large. Adjusted to '%lu' cells (diagonal of current "
-"region)."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:961
-msgid "Minimum number of cells must be at least '1'."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:964
-msgid "Specified minimum number of cells unreachable with current settings."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:969
-msgid "Value for 'minimum' must be smaller than value for 'maximum'."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:973
-msgid "The 'power' option has no effect in any mode other than 'wmean'."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:984
-msgid ""
-"The specified maximum distance cannot be resolved to whole cells\n"
-" at the current resolution settings."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:995
-#, c-format
-msgid "W-E size of neighborhood is %lu cells."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:996
-#, c-format
-msgid "S-N size of neighborhood is %lu cells."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:999
-msgid "Neighborhood cannot be smaller than 3 cells in X or Y direction."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:1052
-#, c-format
-msgid "Input data range is %f to %f.\n"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:1068
-#, c-format
-msgid "Input data type is integer but interpolation mode is '%s'."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:1072
-msgid "Output type changed to floating point (single)."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:1076
-msgid "Output type changed to floating point (double)."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:1081
-#, c-format
-msgid "Ignoring '%c' flag. Output data type will be integer."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:1111
-#, c-format
-msgid ""
-"Input data type is '%s' (%i bytes) and output data type is '%s' (%i bytes)."
-msgstr ""
-#: ../raster/r.fill.stats/main.c:1252
-msgid "Interpolating:"
-msgstr ""
-#: ../raster/r.fill.stats/main.c:1386
-#, c-format
-msgid "Processing time was %ih%im%is."
-msgstr ""
-#: ../db/db.describe/main.c:50 ../db/db.columns/main.c:44
-#: ../db/db.select/main.c:53 ../db/db.copy/main.c:100
-#, c-format
-msgid "Table <%s> not found in database <%s> using driver <%s>"
-msgstr ""
-#: ../db/db.describe/main.c:61 ../db/db.execute/main.c:76
-#: ../db/db.columns/main.c:56 ../db/db.select/main.c:81
-#: ../db/db.tables/main.c:50 ../display/d.vect.thematic/main.c:299
-#: ../display/d.vect/opt.c:152
-#, c-format
-msgid "Unable to open database <%s>"
-msgstr ""
-#: ../db/db.describe/main.c:67 ../db/db.columns/main.c:62
-#: ../vector/v.out.postgis/table.c:41 ../vector/v.patch/main.c:164
-#: ../vector/v.patch/main.c:204 ../vector/v.out.svg/main.c:165
-#: ../vector/v.reclass/main.c:193 ../vector/v.db.connect/main.c:228
-#: ../vector/v.out.vtk/writeVTK.c:655 ../vector/v.random/main.c:272
-#: ../vector/v.out.ogr/main.c:639 ../vector/v.info/print.c:152
-#: ../vector/v.in.ascii/main.c:435 ../vector/v.profile/main.c:433
-#: ../vector/v.profile/main.c:586 ../doc/vector/v.example/main.c:142
-#: ../scripts/db.univar/db.univar.py:112
-#, c-format, python-format
-msgid "Unable to describe table <%s>"
-msgstr ""
-#: ../db/db.describe/main.c:108
-msgid "Print column names only instead of full column descriptions"
-msgstr ""
-#: ../db/db.describe/main.c:113
-msgid "Print table structure"
-msgstr ""
-#: ../db/db.describe/main.c:129 ../db/db.execute/main.c:137
-#: ../db/db.dropdb/main.c:71 ../db/db.connect/main.c:43
-#: ../db/db.columns/main.c:99 ../db/db.select/main.c:265
-#: ../db/db.login/main.c:40 ../db/db.createdb/main.c:71
-#: ../db/db.copy/main.c:35 ../db/db.tables/main.c:97
-#: ../db/db.databases/main.c:95 ../db/db.drivers/main.c:71
-#: ../vector/v.to.db/main.c:38 ../vector/v.in.db/main.c:54
-#: ../vector/v.vect.stats/main.c:135 ../vector/v.db.select/main.c:56
-#: ../vector/v.db.connect/main.c:54 ../vector/v.distance/main.c:123
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:2
-#: ../locale/scriptstrings/db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
-#: ../locale/scriptstrings/db.test_to_translate.c:2
-#: ../locale/scriptstrings/db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:4
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-#: ../locale/scriptstrings/v.db.join_to_translate.c:4
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:4
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:4
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:4
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-#: ../locale/scriptstrings/v.db.update_to_translate.c:4
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:5
-msgid "database"
-msgstr ""
-#: ../db/db.describe/main.c:130 ../db/db.execute/main.c:138
-#: ../db/db.dropdb/main.c:72 ../db/db.connect/main.c:44
-#: ../db/db.columns/main.c:100 ../db/db.select/main.c:266
-#: ../db/db.createdb/main.c:72 ../db/db.copy/main.c:36
-#: ../db/db.tables/main.c:98 ../db/db.databases/main.c:96
-#: ../vector/v.to.db/main.c:37 ../vector/v.vect.stats/main.c:134
-#: ../vector/v.db.select/main.c:55 ../vector/v.univar/main.c:95
-#: ../vector/v.db.connect/main.c:53 ../vector/v.class/main.c:47
-#: ../vector/v.what.rast3/main.c:69 ../vector/v.what.rast/main.c:76
-#: ../vector/v.distance/main.c:124
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:3
-#: ../locale/scriptstrings/db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
-#: ../locale/scriptstrings/db.test_to_translate.c:3
-#: ../locale/scriptstrings/db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:3
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-#: ../locale/scriptstrings/v.db.join_to_translate.c:3
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:3
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:3
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:3
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.db.update_to_translate.c:3
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:7
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:3
-msgid "attribute table"
-msgstr ""
-#: ../db/db.describe/main.c:131
-msgid "Describes a table in detail."
-msgstr ""
-#: ../db/db.execute/main.c:57 ../db/db.select/main.c:63
-#, c-format
-msgid "Unable to open file <%s>: %s"
-msgstr ""
-#: ../db/db.execute/main.c:86 ../db/db.execute/main.c:91
-#: ../db/db.execute/main.c:106 ../db/db.execute/main.c:111
-#, c-format
-msgid "Error while executing: '%s'"
-msgstr ""
-#: ../db/db.execute/main.c:139 ../db/db.execute/main.c:146
-#: ../db/db.execute/main.c:152 ../db/db.dropdb/main.c:73
-#: ../db/db.select/main.c:267 ../db/db.createdb/main.c:73
-#: ../db/db.copy/main.c:37 ../db/db.databases/main.c:97
-#: ../vector/v.db.select/main.c:57
-msgid "SQL"
-msgstr ""
-#: ../db/db.execute/main.c:140
-msgid "Executes any SQL statement."
-msgstr ""
-#: ../db/db.execute/main.c:141
-msgid "For SELECT statements use 'db.select'."
-msgstr ""
-#: ../db/db.execute/main.c:144
-msgid "SQL statement"
-msgstr ""
-#: ../db/db.execute/main.c:145
-msgid "Example: update rybniky set kapri = 'hodne' where kapri = 'malo'"
-msgstr ""
-#: ../db/db.execute/main.c:150
-msgid "Name of file containing SQL statement(s)"
-msgstr ""
-#: ../db/db.execute/main.c:156 ../db/db.execute/main.c:161
-#: ../db/db.execute/main.c:166 ../db/db.select/main.c:219
-#: ../db/db.select/main.c:224 ../db/db.databases/main.c:80
-#: ../db/db.databases/main.c:91
-#: ../locale/scriptstrings/db.droptable_to_translate.c:7
-#: ../locale/scriptstrings/db.droptable_to_translate.c:10
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
-msgid "Connection"
-msgstr ""
-#: ../db/db.execute/main.c:172
-msgid "Ignore SQL errors and continue"
-msgstr ""
-#: ../db/db.execute/main.c:173 ../vector/v.build/main.c:51
-#: ../vector/v.build/main.c:77
-msgid "Errors"
-msgstr ""
-#: ../db/db.execute/main.c:179
-#, c-format
-msgid "You must provide <%s> or <%s> option"
-msgstr ""
-#: ../db/db.dropdb/main.c:74
-msgid "Removes an existing database."
-msgstr ""
-#: ../db/db.connect/main.c:45 ../db/db.login/main.c:41
-#: ../db/db.drivers/main.c:72
-msgid "connection settings"
-msgstr ""
-#: ../db/db.connect/main.c:47
-msgid "Prints/sets general DB connection for current mapset."
-msgstr ""
-#: ../db/db.connect/main.c:51 ../temporal/t.connect/main.c:42
-msgid "Print current connection parameters and exit"
-msgstr ""
-#: ../db/db.connect/main.c:52
-msgid "Substitute variables in database settings"
-msgstr ""
-#: ../db/db.connect/main.c:57
-msgid "Print current connection parameters using shell style and exit"
-msgstr ""
-#: ../db/db.connect/main.c:63 ../temporal/t.connect/main.c:48
-msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr ""
-#: ../db/db.connect/main.c:64 ../db/db.connect/main.c:70
-#: ../db/db.connect/main.c:82 ../db/db.connect/main.c:91
-#: ../db/db.connect/main.c:94 ../db/db.connect/main.c:103
-#: ../general/g.gisenv/main.c:66 ../general/g.gisenv/main.c:74
-#: ../general/g.gisenv/main.c:84 ../temporal/t.connect/main.c:49
-#: ../temporal/t.connect/main.c:55 ../temporal/t.connect/main.c:60
-#: ../temporal/t.connect/main.c:65 ../temporal/t.connect/main.c:69
-msgid "Set"
-msgstr ""
-#: ../db/db.connect/main.c:68 ../temporal/t.connect/main.c:53
-msgid "Set from default settings and exit"
-msgstr ""
-#: ../db/db.connect/main.c:69
-msgid "Overwrite current settings if already initialized"
-msgstr ""
-#: ../db/db.connect/main.c:101
-msgid "Default group of database users to which select privilege is granted"
-msgstr ""
-#: ../db/db.connect/main.c:151 ../db/db.tables/main.c:41
-msgid "Database connection not defined. Run db.connect."
-msgstr ""
-#: ../db/db.connect/main.c:171 ../db/db.connect/main.c:197
-#: ../temporal/t.connect/main.c:133
-#, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
-msgstr ""
-#: ../db/db.connect/main.c:176
-msgid "DB settings already defined, nothing to do"
-msgstr ""
-#: ../db/db.connect/main.c:182
-msgid "Default driver is not set"
-msgstr ""
-#: ../db/db.connect/main.c:185
-msgid "Default database is not set"
-msgstr ""
-#: ../db/db.connect/main.c:221
-msgid "Unable to set default database connection"
-msgstr ""
-#: ../db/db.columns/main.c:101
-msgid "List all columns for a given table."
-msgstr ""
-#: ../db/db.select/main.c:105
-#, c-format
-msgid "Test %s."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
-#: ../imagery/i.rectify/report.c:10
-msgid "failed"
-msgstr ""
-msgid "succeeded"
-msgstr ""
-#: ../db/db.select/main.c:207
-msgid "Name of file containing SQL select statement(s)"
-msgstr ""
-#: ../db/db.select/main.c:212
-msgid "Name of table to query"
-msgstr ""
-#: ../db/db.select/main.c:227 ../db/db.select/main.c:233
-#: ../db/db.select/main.c:236 ../db/db.select/main.c:246
-#: ../db/db.select/main.c:256 ../general/g.gisenv/main.c:93
-#: ../general/g.gisenv/main.c:98 ../vector/v.db.select/main.c:85
-#: ../vector/v.db.select/main.c:88 ../vector/v.db.select/main.c:106
-#: ../vector/v.db.select/main.c:111 ../vector/v.profile/main.c:184
-#: ../vector/v.profile/main.c:187 ../vector/v.profile/main.c:196
-msgid "Format"
-msgstr ""
-#: ../db/db.select/main.c:231
-msgid "Vertical record separator (requires -v flag)"
-msgstr ""
-#: ../db/db.select/main.c:245 ../vector/v.db.select/main.c:105
-msgid "Do not include column names in output"
-msgstr ""
-#: ../db/db.select/main.c:250
-msgid "Describe query only (don't run it)"
-msgstr ""
-#: ../db/db.select/main.c:255 ../vector/v.db.select/main.c:110
-msgid "Vertical output (instead of horizontal)"
-msgstr ""
-#: ../db/db.select/main.c:260
-msgid "Only test query, do not execute"
-msgstr ""
-#: ../db/db.select/main.c:268
-msgid "Selects data from attribute table."
-msgstr ""
-#: ../db/db.select/main.c:269
-msgid "Performs SQL query statement(s)."
-msgstr ""
-#: ../db/db.select/main.c:304
-#, c-format
-msgid "You must provide one of these options: <%s>, <%s>, or <%s>"
-msgstr ""
-#: ../db/db.login/main.c:42
-msgid "Sets user/password for DB driver/database."
-msgstr ""
-#: ../db/db.login/main.c:59
-msgid "Username"
-msgstr ""
-#: ../db/db.login/main.c:67
-msgid "Password"
-msgstr ""
-#: ../db/db.login/main.c:75
-msgid "Hostname"
-msgstr ""
-#: ../db/db.login/main.c:76 ../db/db.login/main.c:85
-msgid "Relevant only for pg and mysql driver"
-msgstr ""
-#: ../db/db.login/main.c:84
-msgid "Port"
-msgstr ""
-#: ../db/db.login/main.c:90
-msgid "Print connection settings and exit"
-msgstr ""
-#: ../db/db.login/main.c:105
-msgid "Unable to set user/password"
-msgstr ""
-#: ../db/db.login/main.c:109
-#, c-format
-msgid "The password was stored in file (%s%cdblogin)"
-msgstr ""
-#: ../db/db.createdb/main.c:74
-msgid "Creates an empty database."
-msgstr ""
-#: ../db/db.copy/main.c:38
-msgid "Copy a table."
-msgstr ""
-#: ../db/db.copy/main.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-#: ../db/db.copy/main.c:46
-msgid "Input driver name"
-msgstr ""
-#: ../db/db.copy/main.c:52
-msgid "Input database name"
-msgstr ""
-#: ../db/db.copy/main.c:59
-msgid "Input table name (only, if 'select' is not used)"
-msgstr ""
-#: ../db/db.copy/main.c:65
-msgid "Output driver name"
-msgstr ""
-#: ../db/db.copy/main.c:71
-msgid "Output database name"
-msgstr ""
-#: ../db/db.copy/main.c:78
-msgid "Output table name"
-msgstr ""
-#: ../db/db.copy/main.c:87
-msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
-#: ../db/db.copy/main.c:88
-msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
-msgstr ""
-#: ../db/db.copy/main.c:96
-msgid "Cannot combine 'from_table' and 'select' options"
-msgstr ""
-#: ../db/db.copy/main.c:122
-msgid "Either 'from_table' or 'select' option must be given."
-msgstr ""
-#: ../db/db.copy/main.c:125
-msgid "Cannot combine 'select' and 'where' options"
-msgstr ""
-#: ../db/db.copy/main.c:135
-msgid "Copy table failed"
-msgstr ""
-#: ../db/db.tables/main.c:54
-#, c-format
-msgid "Unable to list tables from database <%s>"
-msgstr ""
-#: ../db/db.tables/main.c:60
-msgid "No tables found"
-msgstr ""
-#: ../db/db.tables/main.c:89
-msgid "Print tables and exit"
-msgstr ""
-#: ../db/db.tables/main.c:93
-msgid "System tables instead of user tables"
-msgstr ""
-#: ../db/db.tables/main.c:99
-msgid "Lists all tables for a given database."
-msgstr ""
-#: ../db/db.databases/main.c:53
-msgid ""
-"Unable to list databases. Try to define correct connection settings by "
-"db.login."
-msgstr ""
-#: ../db/db.databases/main.c:63
-msgid "No databases found"
-msgstr ""
-#: ../db/db.databases/main.c:87
-msgid "Location"
-msgstr ""
-#: ../db/db.databases/main.c:88
-msgid "Path for SQLite driver, or connection string for PostgreSQL driver"
-msgstr ""
-#: ../db/db.databases/main.c:99
-msgid "Lists all databases for a given driver and location."
-msgstr ""
-#: ../db/db.drivers/main.c:39
-msgid "Unable to read dbmscap file"
-msgstr ""
-#: ../db/db.drivers/main.c:63
-msgid "Full output"
-msgstr ""
-#: ../db/db.drivers/main.c:67
-msgid "Print drivers and exit"
-msgstr ""
-#: ../db/db.drivers/main.c:73
-msgid "Lists all database drivers."
-msgstr ""
-#: ../db/drivers/mysql/dbe.c:45
-msgid "Unable parse MySQL embedded database name"
-msgstr ""
-#: ../db/drivers/mysql/dbe.c:61
-msgid "Cannot initialize MySQL embedded server"
-msgstr ""
-#: ../db/drivers/mysql/dbe.c:80
-msgid "Unable to connect to MySQL embedded server: "
-msgstr ""
-#: ../db/drivers/mysql/create_table.c:108
-#: ../db/drivers/sqlite/create_table.c:122
-#: ../db/drivers/postgres/create_table.c:103
-msgid "Unable to create table:"
-msgstr ""
-#: ../db/drivers/mysql/cursor.c:44 ../db/drivers/postgres/cursor.c:41
-msgid "Unable allocate cursor."
-msgstr ""
-#: ../db/drivers/mysql/cursor.c:53
-msgid "Unable to add dnew token."
-msgstr ""
-#: ../db/drivers/mysql/db.c:61 ../db/drivers/postgres/db.c:71
-#: ../db/drivers/postgres/db.c:250
-msgid "Connection failed."
-msgstr ""
-#: ../db/drivers/mysql/describe.c:32 ../db/drivers/sqlite/describe.c:92
-#: ../db/drivers/sqlite/select.c:95
-msgid "Unable to describe table:"
-msgstr ""
-#: ../db/drivers/mysql/describe.c:50 ../db/drivers/postgres/select.c:69
-msgid "Unable to describe table"
-msgstr ""
-#: ../db/drivers/mysql/describe.c:121
-#, c-format
-msgid "MySQL driver: column '%s', type %d is not supported"
-msgstr ""
-#: ../db/drivers/mysql/describe.c:127
-#, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-#: ../db/drivers/mysql/fetch.c:34 ../db/drivers/mysql/fetch.c:276
-#: ../db/drivers/ogr/fetch.c:55 ../db/drivers/ogr/fetch.c:188
-#: ../db/drivers/sqlite/fetch.c:265 ../db/drivers/postgres/fetch.c:33
-msgid "Cursor not found"
-msgstr ""
-#: ../db/drivers/mysql/fetch.c:52
-msgid "Cursor position is not supported by MySQL driver"
-msgstr ""
-#: ../db/drivers/mysql/fetch.c:191
-msgid "Unable to scan timestamp: "
-msgstr ""
-#: ../db/drivers/mysql/fetch.c:200
-msgid "Unknown timestamp format: "
-msgstr ""
-#: ../db/drivers/mysql/fetch.c:215
-msgid "Unable to scan date: "
-msgstr ""
-#: ../db/drivers/mysql/fetch.c:229
-msgid "Unable to scan time: "
-msgstr ""
-#: ../db/drivers/mysql/fetch.c:245
-msgid "Unable to scan datetime:"
-msgstr ""
-#: ../db/drivers/mysql/index.c:55 ../db/drivers/sqlite/index.c:77
-msgid "Unable to create index:"
-msgstr ""
-#: ../db/drivers/mysql/listtab.c:37
-msgid "Unable get list of tables:"
-msgstr ""
-#: ../db/drivers/mysql/parse.c:62
-msgid "Wrong port number in MySQL database definition: "
-msgstr ""
-#: ../db/drivers/mysql/parse.c:73 ../db/drivers/postgres/parse.c:60
-msgid "'user' in database definition is not supported, use db.login"
-msgstr ""
-#: ../db/drivers/mysql/parse.c:77 ../db/drivers/postgres/parse.c:64
-msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-#: ../db/drivers/mysql/parse.c:82
-msgid "Unknown option in database definition for MySQL: "
-msgstr ""
-#: ../db/drivers/mysql/select.c:42
-msgid "Unable to select data:"
-msgstr ""
-#: ../db/drivers/mysql/select.c:64 ../db/drivers/postgres/describe.c:40
-msgid "Unable to describe table."
-msgstr ""
-#: ../db/drivers/mysql/execute.c:41 ../db/drivers/postgres/execute.c:42
-msgid "Unable to execute:"
-msgstr ""
-#: ../db/drivers/mysql/execute.c:62
-msgid "Unable to start transaction:"
-msgstr ""
-#: ../db/drivers/mysql/execute.c:77
-msgid "Unable to commit transaction:"
-msgstr ""
-#: ../db/drivers/ogr/describe.c:55
-#, c-format
-msgid "OGR layer <%s> does not exist\n"
-msgstr ""
-#: ../db/drivers/ogr/describe.c:63 ../db/drivers/ogr/select.c:58
-msgid "Unable to describe table\n"
-msgstr ""
-#: ../db/drivers/ogr/describe.c:116
-#, c-format
-msgid "OGR driver: column '%s', OGR type %d is not supported"
-msgstr ""
-#: ../db/drivers/ogr/describe.c:186 ../db/drivers/postgres/describe.c:130
-#, c-format
-msgid ""
-"Column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-#: ../db/drivers/ogr/describe.c:204
-#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-#: ../db/drivers/ogr/describe.c:212 ../db/drivers/ogr/fetch.c:160
-msgid "Unknown type"
-msgstr ""
-#: ../db/drivers/ogr/select.c:50
-msgid "Unable to select: \n"
-msgstr ""
-#: ../db/drivers/ogr/cursor.c:65 ../db/drivers/odbc/cursor.c:36
-msgid "Unable to allocate cursor"
-msgstr ""
-#: ../db/drivers/ogr/cursor.c:74
-msgid "Unable to add new token"
-msgstr ""
-#: ../db/drivers/ogr/db.c:56
-msgid "Had to open data source read-only"
-msgstr ""
-#: ../db/drivers/ogr/db.c:60
-msgid "Unable to open OGR data source"
-msgstr ""
-#: ../db/drivers/ogr/execute.c:56 ../vector/v.out.ogr/main.c:592
-#, c-format
-msgid "OGR layer <%s> not found"
-msgstr ""
-#: ../db/drivers/ogr/execute.c:69 ../vector/v.to.3d/trans2.c:63
-#: ../vector/v.to.3d/trans3.c:65 ../vector/v.in.db/main.c:187
-#: ../vector/v.vect.stats/main.c:438 ../vector/v.transform/trans_digit.c:116
-#: ../vector/v.out.lidar/main.c:118 ../vector/v.out.lidar/main.c:157
-#: ../vector/v.reclass/main.c:145 ../vector/v.univar/main.c:355
-#: ../vector/v.db.connect/main.c:289 ../vector/v.colors/scan_attr.c:35
-#: ../vector/v.colors.out/make_colors.c:42 ../vector/v.distance/main.c:540
-#: ../vector/v.distance/main.c:581
-#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:97
-#: ../scripts/db.univar/db.univar.py:120 ../scripts/v.db.join/v.db.join.py:98
-#: ../scripts/v.db.join/v.db.join.py:106 ../scripts/v.db.join/v.db.join.py:123
-msgid "Column <%s> not found in table <%s>"
-msgstr ""
-#: ../db/drivers/ogr/fetch.c:71
-msgid "DB_PREVIOUS not supported"
-msgstr ""
-#: ../db/drivers/ogr/fetch.c:82
-msgid "DB_LAST not supported"
-msgstr ""
-#: ../db/drivers/ogr/listtab.c:49 ../db/drivers/sqlite/listtab.c:78
-msgid "Unable to db_alloc_string_array()"
-msgstr ""
-#: ../db/drivers/sqlite/create_table.c:141 ../db/drivers/sqlite/describe.c:78
-#: ../db/drivers/sqlite/describe.c:132 ../db/drivers/sqlite/execute.c:69
-#: ../db/drivers/sqlite/index.c:96 ../db/drivers/sqlite/select.c:80
-msgid "Error in sqlite3_step():"
-msgstr ""
-#: ../db/drivers/sqlite/cursor.c:47
-msgid "Unable to allocate cursor."
-msgstr ""
-#: ../db/drivers/sqlite/cursor.c:56 ../db/drivers/odbc/cursor.c:55
-#: ../db/drivers/postgres/cursor.c:50
-msgid "Unable to add new token."
-msgstr ""
-#: ../db/drivers/sqlite/db.c:99
-#, c-format
-msgid "Unable to create directory '%s' for sqlite database"
-msgstr ""
-#: ../db/drivers/sqlite/db.c:107
-msgid "Unable to open database:"
-msgstr ""
-#: ../db/drivers/sqlite/db.c:134
-msgid "SQLite database connection is still busy"
-msgstr ""
-#: ../db/drivers/sqlite/db.c:155
-#, c-format
-msgid "Database <%s> already exists"
-msgstr ""
-#: ../db/drivers/sqlite/db.c:162
-msgid "Unable to create database:"
-msgstr ""
-#: ../db/drivers/sqlite/db.c:186
-#, c-format
-msgid "Database <%s> not found"
-msgstr ""
-#: ../db/drivers/sqlite/describe.c:60 ../db/drivers/sqlite/execute.c:53
-#: ../db/drivers/sqlite/select.c:63
-msgid "Error in sqlite3_prepare():"
-msgstr ""
-#: ../db/drivers/sqlite/describe.c:194
-#, c-format
-msgid "SQLite driver: column '%s', SQLite type %d  is not supported"
-msgstr ""
-#: ../db/drivers/sqlite/execute.c:83
-msgid "Error in sqlite3_finalize():"
-msgstr ""
-#: ../db/drivers/sqlite/execute.c:111
-msgid "'BEGIN' transaction failed:"
-msgstr ""
-#: ../db/drivers/sqlite/execute.c:139
-msgid "'COMMIT' transaction failed:"
-msgstr ""
-#: ../db/drivers/sqlite/fetch.c:72
-msgid "Unable to fetch:"
-msgstr ""
-#: ../db/drivers/sqlite/fetch.c:87
-msgid "DB_PREVIOUS is not supported"
-msgstr ""
-#: ../db/drivers/sqlite/fetch.c:93
-msgid "DB_LAST is not supported"
-msgstr ""
-#: ../db/drivers/sqlite/fetch.c:171 ../db/drivers/postgres/fetch.c:129
-msgid "Unable to scan date:"
-msgstr ""
-#: ../db/drivers/sqlite/fetch.c:188 ../db/drivers/postgres/fetch.c:147
-msgid "Unable to scan time:"
-msgstr ""
-#: ../db/drivers/sqlite/fetch.c:203
-msgid "Unable to scan timestamp:"
-msgstr ""
-#: ../db/drivers/sqlite/fetch.c:218
-msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
-msgstr ""
-#: ../db/drivers/sqlite/fetch.c:223
-msgid "Unable to scan interval:"
-msgstr ""
-#: ../db/drivers/sqlite/fetch.c:286
-msgid "Unable to get number of rows:"
-msgstr ""
-#: ../db/drivers/sqlite/listdb.c:45 ../db/drivers/postgres/listdb.c:35
-msgid "No path given"
-msgstr ""
-#: ../db/drivers/sqlite/listdb.c:99
-#, c-format
-msgid "Unable to open directory '%s'"
-msgstr ""
-#: ../db/drivers/sqlite/listdb.c:117
-#, c-format
-msgid "SQLite database connection '%s' is still busy"
-msgstr ""
-#: ../db/drivers/sqlite/listdb.c:147 ../db/drivers/odbc/listdb.c:40
-#: ../db/drivers/postgres/listdb.c:96
-msgid "Unable to set handle"
-msgstr ""
-#: ../db/drivers/sqlite/listtab.c:50 ../db/drivers/sqlite/listtab.c:66
-msgid "Unable to list tables:"
-msgstr ""
-#: ../db/drivers/sqlite/main.c:47
-#, c-format
-msgid "Busy SQLITE db, already waiting for %d seconds..."
-msgstr ""
-#: ../db/drivers/sqlite/table.c:37
-msgid "Error in sqlite3_exec():"
-msgstr ""
-#: ../db/drivers/odbc/listdb.c:29
-msgid "Unable to allocate handle."
-msgstr ""
-#: ../db/drivers/odbc/table.c:159
-#, c-format
-msgid "Table %s doesn't exist"
-msgstr ""
-#: ../db/drivers/odbc/table.c:176
-#, c-format
-msgid "Table %s isn't 'TABLE' or 'VIEW' but %s"
-msgstr ""
-#: ../db/drivers/postgres/priv.c:53
-msgid "Unable grant on table:"
-msgstr ""
-#: ../db/drivers/postgres/describe.c:123
-#, c-format
-msgid "PostgreSQL driver: column '%s', type %d is not supported"
-msgstr ""
-#: ../db/drivers/postgres/describe.c:134
-#, c-format
-msgid ""
-"Column '%s' : type character varying is stored as varchar(250) some data may"
-" be lost"
-msgstr ""
-#: ../db/drivers/postgres/describe.c:140
-#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1"
-" (true)"
-msgstr ""
-#: ../db/drivers/postgres/execute.c:68
-msgid "Unable to 'BEGIN' transaction"
-msgstr ""
-#: ../db/drivers/postgres/execute.c:88
-msgid "Unable to 'COMMIT' transaction"
-msgstr ""
-#: ../db/drivers/postgres/db.c:99
-msgid "Unable to set schema:"
-msgstr ""
-#: ../db/drivers/postgres/db.c:117
-msgid "Unable to select data types"
-msgstr ""
-#: ../db/drivers/postgres/db.c:269
-#, c-format
-msgid "Unable to create database <%s>"
-msgstr ""
-#: ../db/drivers/postgres/db.c:271
-#, c-format
-msgid "Unable to drop database <%s>"
-msgstr ""
-#: ../db/drivers/postgres/create_table.c:90
-#, c-format
-msgid "Unknown column type (%s)"
-msgstr ""
-#: ../db/drivers/postgres/create_table.c:132
-msgid "Unable to grant select on table:"
-msgstr ""
-#: ../db/drivers/postgres/fetch.c:166
-msgid "Unable to scan timestamp (no idea how to process time zone):"
-msgstr ""
-#: ../db/drivers/postgres/fetch.c:174
-msgid "Unable to scan timestamp (not enough arguments):"
-msgstr ""
-#: ../db/drivers/postgres/fetch.c:188
-msgid "Unable to recognize boolean value"
-msgstr ""
-#: ../db/drivers/postgres/fetch.c:206
-msgid "Taken not found"
-msgstr ""
-#: ../db/drivers/postgres/listdb.c:65
-msgid "Unable to connect to Postgres:"
-msgstr ""
-#: ../db/drivers/postgres/listdb.c:76
-msgid "Unable to select from Postgres:"
-msgstr ""
-#: ../db/drivers/postgres/listtab.c:38
-msgid "Unable to select table names."
-msgstr ""
-#: ../db/drivers/postgres/listtab.c:65
-msgid "Unable to select view names."
-msgstr ""
-#: ../db/drivers/postgres/parse.c:69
-msgid "Unknown option in database definition for PostgreSQL: "
-msgstr ""
-#: ../db/drivers/postgres/select.c:31
-msgid "Unable set DATESTYLE"
-msgstr ""
-#: ../db/drivers/postgres/select.c:55
-msgid "Unable to select:"
-msgstr ""
-#: ../db/drivers/postgres/table.c:37
-msgid "Unable to execute():"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:72
-msgid "SQL parser error"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:74
-msgid "in statement:"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:88
-#, c-format
-msgid "Table '%s' doesn't exist."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:96
-msgid "Unable to load table head."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:106
-msgid "Unable to modify table, don't have write permission for DBF file."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:121 ../db/drivers/dbf/dbfexe.c:1023
-#, c-format
-msgid "Column '%s' not found"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:145
-msgid "Incompatible value type."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:161
-msgid "Unable to add column."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:183
-msgid "Unable to delete column."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:191
-#, c-format
-msgid "Table %s already exists"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:206
-msgid "Unable to create table."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:263 ../db/drivers/dbf/dbfexe.c:273
-#: ../db/drivers/dbf/dbfexe.c:303
-msgid "Error in selecting rows"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:552
-msgid "Cannot load table."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:567
-msgid "Incompatible types in WHERE condition."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:572
-msgid "Result of WHERE condition is not of type BOOL."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:588
-msgid "Error in evaluation of WHERE condition."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:600
-#, c-format
-msgid "Unknown result (%d) of WHERE evaluation"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:607
-msgid "Unknown WHERE condition type (bug in DBF driver)."
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:633
-#, c-format
-msgid "Unable to find order column '%s'"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:778
-msgid "Division by zero"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:917
-msgid "Value operand for AND"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:931
-msgid "Value operand for OR"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:946
-msgid "Value operand for NOT"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:954 ../db/drivers/dbf/dbfexe.c:1151
-#, c-format
-msgid "Unknown operator %d"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:1061
-msgid "Arithmetical operation with strings is not allowed"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:1083
-msgid "Comparison between string and number is not allowed"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:1098
-#, c-format
-msgid "Comparison '%s' between strings not allowed"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:1112
-msgid "Match (~) between numbers not allowed"
-msgstr ""
-#: ../db/drivers/dbf/column.c:49
-#, c-format
-msgid "Column '%s' already exists (duplicate name)"
-msgstr ""
-#: ../db/drivers/dbf/column.c:99
-#, c-format
-msgid "Column '%s' does not exist"
-msgstr ""
-#: ../db/drivers/dbf/create_table.c:22
-msgid "Unable to create table"
-msgstr ""
-#: ../db/drivers/dbf/cursor.c:47
-msgid "Unable to allocate new cursor"
-msgstr ""
-#: ../db/drivers/dbf/cursor.c:59
-msgid "Unable to tokenize new cursor"
-msgstr ""
-#: ../db/drivers/dbf/db.c:94
-#, c-format
-msgid "Unable create DBF database: %s"
-msgstr ""
-#: ../db/drivers/dbf/db.c:102
-#, c-format
-msgid "Cannot open DBF database directory: %s"
-msgstr ""
-#: ../db/drivers/dbf/db.c:110
-#, c-format
-msgid "Unable to open DBF database: %s"
-msgstr ""
-#: ../db/drivers/dbf/describe.c:34
-#, c-format
-msgid "Table '%s' doesn't exist"
-msgstr ""
-#: ../db/drivers/dbf/execute.c:32
-msgid "Unable to execute statement."
-msgstr ""
-#: ../db/drivers/dbf/select.c:44
-msgid "Unable to open cursor."
-msgstr ""
-#: ../db/drivers/dbf/table.c:117 ../db/drivers/dbf/table.c:170
-msgid "Unable to open DBF file."
-msgstr ""
-#: ../db/drivers/dbf/table.c:312
-#, c-format
-msgid "Unable to move '%s' to '%s'."
-msgstr ""
-#: ../general/g.gisenv/main.c:43 ../general/g.mapset/main.c:49
-#: ../general/g.rename/main.c:45 ../general/g.dirseps/main.c:34
-#: ../general/g.access/main.c:37 ../general/g.pnmcomp/main.c:282
-#: ../general/g.list/main.c:65 ../general/g.region/main.c:64
-#: ../general/g.mapsets/main.c:63 ../general/g.gui/main.c:39
-#: ../general/g.filename/main.c:39 ../general/g.setproj/main.c:78
-#: ../general/g.remove/main.c:69 ../general/g.tempfile/main.c:38
-#: ../general/g.cairocomp/main.c:196 ../general/g.findetc/main.c:28
-#: ../general/g.copy/main.c:41 ../general/g.message/main.c:33
-#: ../general/g.ppmtopng/main.c:117 ../general/g.mkfontcap/main.c:71
-#: ../general/g.proj/main.c:64 ../general/g.findfile/main.c:38
-#: ../general/g.version/main.c:65
-#: ../locale/scriptstrings/g.extension_to_translate.c:3
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:3
-#: ../locale/scriptstrings/g.manual_to_translate.c:2
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:2
-msgid "general"
-msgstr ""
-#: ../general/g.gisenv/main.c:44 ../general/g.mapset/main.c:50
-#: ../general/g.region/main.c:65 ../general/g.mapsets/main.c:64
-#: ../display/d.colorlist/main.c:36 ../display/d.font/main.c:46
-#: ../display/d.fontlist/main.c:46 ../temporal/t.connect/main.c:35
-msgid "settings"
-msgstr ""
-#: ../general/g.gisenv/main.c:45
-msgid "variables"
-msgstr ""
-#: ../general/g.gisenv/main.c:46 ../general/g.dirseps/main.c:36
-#: ../general/g.filename/main.c:41 ../general/g.tempfile/main.c:40
-#: ../general/g.findetc/main.c:30 ../general/g.message/main.c:35
-#: ../general/g.findfile/main.c:40
-msgid "scripts"
-msgstr ""
-#: ../general/g.gisenv/main.c:48
-msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-#: ../general/g.gisenv/main.c:49
-msgid "Prints all defined GRASS variables if no option is given."
-msgstr ""
-#: ../general/g.gisenv/main.c:54
-msgid "GRASS variable to get"
-msgstr ""
-#: ../general/g.gisenv/main.c:57
-msgid "Get"
-msgstr ""
-#: ../general/g.gisenv/main.c:63
-msgid "GRASS variable to set"
-msgstr ""
-#: ../general/g.gisenv/main.c:71
-msgid "GRASS variable to unset"
-msgstr ""
-#: ../general/g.gisenv/main.c:82
-msgid "Where GRASS variable is stored"
-msgstr ""
-#: ../general/g.gisenv/main.c:87
-msgid "Separator for multiple GRASS variables"
-msgstr ""
-#: ../general/g.gisenv/main.c:92
-msgid "Use shell syntax (for \"eval\")"
-msgstr ""
-#: ../general/g.gisenv/main.c:97
-msgid "Do not use shell syntax"
-msgstr ""
-#: ../general/g.gisenv/main.c:171
-#, c-format
-msgid "Variable <%s> is mandatory. No operation performed."
-msgstr ""
-#: ../general/g.gisenv/main.c:177
-#, c-format
-msgid "Value '%s' ignored when unsetting the GRASS variable"
-msgstr ""
-#: ../general/g.gisenv/main.c:216
-msgid "GRASS variable not defined"
-msgstr ""
-#: ../general/g.gisenv/main.c:222
-#, c-format
-msgid "GRASS variable must be uppercase. Using '%s'."
-msgstr ""
-#: ../general/g.mapset/main.c:51
-msgid "Changes/reports current mapset."
-msgstr ""
-#: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
-msgstr ""
-#: ../general/g.mapset/main.c:56
-msgid "Name of mapset where to switch"
-msgstr ""
-#: ../general/g.mapset/main.c:57 ../general/g.mapset/main.c:61
-#: ../general/g.mapset/main.c:64
-msgid "Mapset"
-msgstr ""
-#: ../general/g.mapset/main.c:68
-msgid "Create mapset if it doesn't exist"
-msgstr ""
-#: ../general/g.mapset/main.c:70 ../general/g.proj/main.c:201
-#: ../locale/scriptstrings/r.mask_to_translate.c:18
-msgid "Create"
-msgstr ""
-#: ../general/g.mapset/main.c:75
-msgid "List available mapsets and exit"
-msgstr ""
-#: ../general/g.mapset/main.c:81
-msgid "Print current mapset and exit"
-msgstr ""
-#: ../general/g.mapset/main.c:136
-#, c-format
-msgid "<%s> is already the current mapset"
-msgstr ""
-#: ../general/g.mapset/main.c:145
-#, c-format
-msgid "You don't have permission to use the mapset <%s>"
-msgstr ""
-#: ../general/g.mapset/main.c:153
-#, c-format
-msgid "Unable to create new mapset <%s>"
-msgstr ""
-#: ../general/g.mapset/main.c:156
-#, c-format
-msgid "Mapset <%s> does not exist. Use -c flag to create it."
-msgstr ""
-#: ../general/g.mapset/main.c:166
-msgid "Unable to read GIS_LOCK environment variable"
-msgstr ""
-#: ../general/g.mapset/main.c:182
-#, c-format
-msgid "Lock file of mapset <%s> cannot be checked"
-msgstr ""
-#: ../general/g.mapset/main.c:185
-#, c-format
-msgid "There appears to be an active GRASS session in selected mapset <%s>"
-msgstr ""
-#: ../general/g.mapset/main.c:191
-msgid "Cleaning up temporary files..."
-msgstr ""
-#: ../general/g.mapset/main.c:205
-msgid ""
-"Mapset switched. Your shell continues to use the history for the old mapset"
-msgstr ""
-#: ../general/g.mapset/main.c:210
-#, c-format
-msgid ""
-"You can switch the history by commands:\n"
-"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
-msgstr ""
-#: ../general/g.mapset/main.c:215
-#, c-format
-msgid ""
-"history -S; history -L %s/.history; setenv histfile=%s/.history"
-msgstr ""
-#: ../general/g.mapset/main.c:221
-#, c-format
-msgid "Your current mapset is <%s>"
-msgstr ""
-#: ../general/g.rename/main.c:47
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
-#: ../locale/scriptstrings/t.rename_to_translate.c:4
-msgid "rename"
-msgstr ""
-#: ../general/g.rename/main.c:49
-msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-#: ../general/g.rename/main.c:55
-msgid "renamed"
-msgstr ""
-#: ../general/g.rename/main.c:76
-#, c-format
-msgid "%s <%s> not found"
-msgstr ""
-#: ../general/g.rename/main.c:80
-#, c-format
-msgid "<%s> already exists in mapset <%s>"
-msgstr ""
-#: ../general/g.rename/main.c:90
-#, c-format
-msgid "%s=%s,%s: files could be the same, no rename possible"
-msgstr ""
-#: ../general/g.rename/main.c:116
-msgid "Updating reclass maps"
-msgstr ""
-#: ../general/g.rename/main.c:184
-#, c-format
-msgid "Unable to find reclass information for <%s> in base map <%s@%s>"
-msgstr ""
-#: ../general/g.rename/main.c:188
-#, c-format
-msgid "Updating base map <%s@%s>"
-msgstr ""
-#: ../general/g.rename/main.c:194
-#, c-format
-msgid "Unable to update dependency file in <%s@%s>"
-msgstr ""
-#: ../general/g.dirseps/main.c:38
-msgid "Internal GRASS utility for converting directory separator characters."
-msgstr ""
-#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
-msgid "have"
-msgstr ""
-#: ../general/g.access/exp_perms.c:12
-msgid "read "
-msgstr ""
-#: ../general/g.access/exp_perms.c:15
-msgid "Everyone"
-msgstr ""
-#: ../general/g.access/exp_perms.c:16
-msgid "has"
-msgstr ""
-#: ../general/g.access/exp_perms.c:19
-msgid "Only users in your group"
-msgstr ""
-#: ../general/g.access/exp_perms.c:22
-msgid "Only users outside your group"
-msgstr ""
-#: ../general/g.access/exp_perms.c:25
-msgid "Only you"
-msgstr ""
-#: ../general/g.access/exp_perms.c:31
-#, c-format
-msgid "%s %s %s %saccess to mapset %s"
-msgstr ""
-#: ../general/g.access/exp_perms.c:32
-msgid "will"
-msgstr ""
-msgid "now"
-msgstr ""
-#: ../general/g.access/main.c:39
-msgid "permission"
-msgstr ""
-#: ../general/g.access/main.c:41
-msgid "Controls access to the current mapset for other users on the system."
-msgstr ""
-#: ../general/g.access/main.c:42
-msgid "If no option given, prints current status."
-msgstr ""
-#: ../general/g.access/main.c:49
-msgid "Access for group"
-msgstr ""
-#: ../general/g.access/main.c:57
-msgid "Access for others"
-msgstr ""
-#: ../general/g.access/main.c:64
-msgid "UNIX filesystem access controls are not supported by MS-Windows"
-msgstr ""
-#: ../general/g.access/main.c:72
-msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr ""
-#: ../general/g.access/main.c:76
-msgid "Unable to determine mapset permissions"
-msgstr ""
-#: ../general/g.access/set_perms.c:26
-msgid "Unable to change mapset permissions"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:38 ../general/g.cairocomp/main.c:150
-#, c-format
-msgid "Invalid color: %s"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:54
-msgid "Error reading PPM file"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:69 ../general/g.pnmcomp/main.c:74
-#: ../general/g.pnmcomp/main.c:83 ../general/g.pnmcomp/main.c:134
-#: ../general/g.pnmcomp/main.c:147
-msgid "Invalid PPM file"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:96 ../scripts/v.db.update/v.db.update.py:92
-#: ../scripts/v.in.geonames/v.in.geonames.py:57
-#: ../scripts/v.unpack/v.unpack.py:75
-msgid "File <%s> not found"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:104
-msgid "Expecting PPM but got PGM"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:109
-msgid "Expecting PGM but got PPM"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:112
-#, c-format
-msgid "Invalid magic number: 'P%c'"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:125 ../general/g.pnmcomp/main.c:142
-msgid "Invalid PGM file"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:247
-msgid "Error writing PPM file"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:264
-msgid "Error writing PGM file"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:283 ../general/g.cairocomp/main.c:197
-#: ../general/g.ppmtopng/main.c:118 ../display/d.his/main.c:62
-#: ../display/d.rast/main.c:53 ../display/d.histogram/main.c:83
-#: ../display/d.where/main.c:43 ../display/d.title/main.c:49
-#: ../display/d.barscale/main.c:63 ../display/d.vect.chart/main.c:63
-#: ../display/d.erase/main.c:29 ../display/d.geodesic/main.c:46
-#: ../display/d.rgb/main.c:53 ../display/d.extract/main.c:49
-#: ../display/d.linegraph/main.c:231 ../display/d.profile/main.c:191
-#: ../display/d.mon/main.c:50 ../display/d.rast.arrow/main.c:97
-#: ../display/d.graph/main.c:58 ../display/d.info/main.c:34
-#: ../display/d.grid/main.c:53 ../display/d.labels/main.c:43
-#: ../display/d.rhumbline/main.c:44 ../display/d.vect.thematic/main.c:85
-#: ../display/d.text/main.c:139 ../display/d.vect/main.c:73
-#: ../display/d.colorlist/main.c:35 ../display/d.font/main.c:45
-#: ../display/d.colortable/main.c:60 ../display/d.fontlist/main.c:45
-#: ../display/d.legend.vect/main.c:50 ../display/d.northarrow/main.c:46
-#: ../display/d.rast.num/main.c:77 ../display/d.path/main.c:48
-#: ../display/d.legend/main.c:78 ../visualization/ximgview/main.c:290
-#: ../raster3d/r3.mkdspf/main.c:80
-#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#: ../locale/scriptstrings/d.frame_to_translate.c:2
-#: ../locale/scriptstrings/d.out.file_to_translate.c:2
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:2
-#: ../locale/scriptstrings/d.polar_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
-#: ../locale/scriptstrings/d.redraw_to_translate.c:2
-#: ../locale/scriptstrings/d.shade_to_translate.c:2
-#: ../locale/scriptstrings/d.what.rast_to_translate.c:2
-#: ../locale/scriptstrings/d.what.vect_to_translate.c:2
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
-msgid "display"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:285
-msgid "Overlays multiple PPM image files."
-msgstr ""
-#: ../general/g.pnmcomp/main.c:290 ../general/g.cairocomp/main.c:203
-msgid "Name of input file(s)"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:296
-msgid "Name of input mask file(s)"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:302 ../general/g.cairocomp/main.c:224
-msgid "Layer opacities"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:309
-msgid "Name for output mask file"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:315 ../general/g.cairocomp/main.c:230
-msgid "Image width"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:321 ../general/g.cairocomp/main.c:236
-msgid "Image height"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:325 ../display/d.histogram/main.c:108
-#: ../display/d.erase/main.c:37 ../display/d.mon/main.c:102
-#: ../display/d.grid/main.c:113 ../display/d.legend.vect/main.c:101
-#: ../display/d.path/main.c:115 ../display/d.legend/main.c:246
-#: ../vector/v.lrs/v.lrs.label/main.c:218 ../vector/v.label/main.c:187
-#: ../vector/v.label.sa/main.c:124
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
-#: ../misc/m.nviz.image/args.c:70
-msgid "Background color"
-msgstr ""
-#: ../general/g.parser/main.c:74
-msgid "Usage"
-msgstr ""
-#: ../general/g.parser/main.c:84
-msgid "Unable to open script file"
-msgstr ""
-#: ../general/g.parser/main.c:99
-#, c-format
-msgid "Line too long or missing newline at line %d\n"
-msgstr ""
-#: ../general/g.parser/main.c:139
-msgid "Error closing script file"
-msgstr ""
-#: ../general/g.parser/parse.c:22
-#, c-format
-msgid "Unknown boolean value \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:70
-#, c-format
-msgid "Unknown command \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:103
-#, c-format
-msgid "Unknown module parameter \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:140
-#, c-format
-msgid "Unknown flag parameter \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:155
-#, c-format
-msgid "Unknown type \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/parse.c:233
-#, c-format
-msgid "Unknown option parameter \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.parser/revoke.c:64
-msgid "G_spawn() failed"
-msgstr ""
-#: ../general/g.parser/revoke.c:72
-msgid "execl() failed"
-msgstr ""
-#: ../general/g.parser/rules.c:14
-#, c-format
-msgid "Unknown flag \"-%c\" in rule\n"
-msgstr ""
-#: ../general/g.parser/rules.c:26
-#, c-format
-msgid "Unknown option \"%s\" in rule\n"
-msgstr ""
-#: ../general/g.parser/rules.c:94
-#, c-format
-msgid "Unknown rule type \"%s\" at line %d\n"
-msgstr ""
-#: ../general/g.list/main.c:67 ../locale/scriptstrings/t.list_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:5
-msgid "list"
-msgstr ""
-#: ../general/g.list/main.c:68
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:4
-msgid "search"
-msgstr ""
-#: ../general/g.list/main.c:70
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-#: ../general/g.list/main.c:86
-msgid "Map name search pattern (default: all)"
-msgstr ""
-#: ../general/g.list/main.c:87 ../general/g.list/main.c:95
-#: ../general/g.list/main.c:121 ../general/g.list/main.c:127
-#: ../general/g.list/main.c:133 ../general/g.remove/main.c:100
-#: ../general/g.remove/main.c:106 ../general/g.remove/main.c:112
-#: ../general/g.remove/main.c:117 ../general/g.remove/main.c:123
-#: ../general/g.remove/main.c:129
-msgid "Pattern"
-msgstr ""
-#: ../general/g.list/main.c:94
-msgid "Map name exclusion pattern (default: none)"
-msgstr ""
-#: ../general/g.list/main.c:100
-msgid "Name of mapset to list (default: current search path)"
-msgstr ""
-#: ../general/g.list/main.c:102
-msgid "'.' for current mapset; '*' for all mapsets in location"
-msgstr ""
-#: ../general/g.list/main.c:108
-msgid "Name of saved region for map search (default: not restricted)"
-msgstr ""
-#: ../general/g.list/main.c:110
-msgid "'.' for current region; '*' for default region"
-msgstr ""
-#: ../general/g.list/main.c:115 ../vector/v.out.ascii/args.c:33
-msgid "If not given or '-' then standard output"
-msgstr ""
-#: ../general/g.list/main.c:120 ../general/g.remove/main.c:116
-msgid "Ignore case"
-msgstr ""
-#: ../general/g.list/main.c:126 ../general/g.remove/main.c:122
-msgid "Use basic regular expressions instead of wildcards"
-msgstr ""
-#: ../general/g.list/main.c:132 ../general/g.remove/main.c:128
-msgid "Use extended regular expressions instead of wildcards"
-msgstr ""
-#: ../general/g.list/main.c:137
-msgid "Print data types"
-msgstr ""
-#: ../general/g.list/main.c:142
-msgid "Print fully-qualified map names (including mapsets)"
-msgstr ""
-#: ../general/g.list/main.c:147
-msgid "Pretty printing in human readable format"
-msgstr ""
-#: ../general/g.list/main.c:152
-msgid "Verbose listing (also list map titles)"
-msgstr ""
-#: ../general/g.list/main.c:185 ../general/g.list/main.c:212
-#: ../general/g.remove/main.c:178 ../general/g.remove/main.c:202
-#, c-format
-msgid "Unable to compile pattern <%s>"
-msgstr ""
-#: ../general/g.list/main.c:269
-#, c-format
-msgid "Mapset <%s> does not exist"
-msgstr ""
-#: ../general/g.list/list.c:123 ../general/g.region/main.c:458
-#, c-format
-msgid "Unable to read header of 3D raster map <%s@%s>"
-msgstr ""
-#: ../general/g.list/list.c:131
-#, c-format
-msgid "Unable to open vector map <%s@%s> on topological level"
-msgstr ""
-#: ../general/g.region/printwindow.c:383
-msgid "You are already in Lat/Long. Use the -p flag instead."
-msgstr ""
-#: ../general/g.region/printwindow.c:385
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
-msgstr ""
-#: ../general/g.region/printwindow.c:559
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-#: ../general/g.region/printwindow.c:711
-msgid "Lat/Long calculations are not possible from a simple XY system"
-msgstr ""
-#: ../general/g.region/main.c:66
-msgid "computational region"
-msgstr ""
-#: ../general/g.region/main.c:68
-msgid "resolution"
-msgstr ""
-#: ../general/g.region/main.c:71
-msgid "Manages the boundary definitions for the geographic region."
-msgstr ""
-#: ../general/g.region/main.c:82
-msgid "Save as default region"
-msgstr ""
-#: ../general/g.region/main.c:83
-msgid "Only possible from the PERMANENT mapset"
-msgstr ""
-#: ../general/g.region/main.c:88
-msgid "Print the current region"
-msgstr ""
-#: ../general/g.region/main.c:93
-msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-#: ../general/g.region/main.c:99
-msgid "Print the current region extent"
-msgstr ""
-#: ../general/g.region/main.c:105
-msgid "Print the current region map center coordinates"
-msgstr ""
-#: ../general/g.region/main.c:111
-msgid "Print the current region in GMT style"
-msgstr ""
-#: ../general/g.region/main.c:117
-msgid "Print the current region in WMS style"
-msgstr ""
-#: ../general/g.region/main.c:123
-msgid "Print region resolution in meters (geodesic)"
-msgstr ""
-#: ../general/g.region/main.c:128
-msgid "Print the convergence angle (degrees CCW)"
-msgstr ""
-#: ../general/g.region/main.c:130
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
-msgstr ""
-#: ../general/g.region/main.c:136
-msgid "Print also 3D settings"
-msgstr ""
-#: ../general/g.region/main.c:142
-msgid "Print the maximum bounding box in lat/long on WGS84"
-msgstr ""
-#: ../general/g.region/main.c:152
-msgid "Print in shell script style, but in one line (flat)"
-msgstr ""
-#: ../general/g.region/main.c:158
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-#: ../general/g.region/main.c:164
-msgid "Do not update the current region"
-msgstr ""
-#: ../general/g.region/main.c:165 ../general/g.region/main.c:347
-#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
-#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
-msgid "Effects"
-msgstr ""
-#: ../general/g.region/main.c:170
-msgid "Set current region from named region"
-msgstr ""
-#: ../general/g.region/main.c:177
-msgid "Set region to match raster map(s)"
-msgstr ""
-#: ../general/g.region/main.c:185
-msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
-msgstr ""
-#: ../general/g.region/main.c:193
-msgid "Set region to match vector map(s)"
-msgstr ""
-#: ../general/g.region/main.c:239
-msgid "Value for the top edge"
-msgstr ""
-#: ../general/g.region/main.c:248
-msgid "Value for the bottom edge"
-msgstr ""
-#: ../general/g.region/main.c:257
-msgid "Number of rows in the new region"
-msgstr ""
-#: ../general/g.region/main.c:258 ../general/g.region/main.c:267
-#: ../general/g.region/main.c:277 ../general/g.region/main.c:287
-#: ../general/g.region/main.c:296 ../general/g.region/main.c:305
-#: ../general/g.region/main.c:314
-msgid "Resolution"
-msgstr ""
-#: ../general/g.region/main.c:266
-msgid "Number of columns in the new region"
-msgstr ""
-#: ../general/g.region/main.c:276
-msgid "2D grid resolution (north-south and east-west)"
-msgstr ""
-#: ../general/g.region/main.c:286
-msgid "3D grid resolution (north-south, east-west and top-bottom)"
-msgstr ""
-#: ../general/g.region/main.c:295
-msgid "North-south 2D grid resolution"
-msgstr ""
-#: ../general/g.region/main.c:304
-msgid "East-west 2D grid resolution"
-msgstr ""
-#: ../general/g.region/main.c:313
-msgid "Top-bottom 3D grid resolution"
-msgstr ""
-#: ../general/g.region/main.c:323
-msgid "Shrink region until it meets non-NULL data from this raster map"
-msgstr ""
-#: ../general/g.region/main.c:334
-msgid "Adjust region cells to cleanly align with this raster map"
-msgstr ""
-#: ../general/g.region/main.c:345
-msgid "Save current region settings in named region file"
-msgstr ""
-#: ../general/g.region/main.c:414 ../scripts/r.in.wms/r.in.wms.py:196
-msgid "Region <%s> not found"
-msgstr ""
-#: ../general/g.region/main.c:499
-msgid "Unable to get map bounding box"
-msgstr ""
-#: ../general/g.region/main.c:784
-#, c-format
-msgid "Unable to set region <%s>"
-msgstr ""
-#: ../general/g.region/main.c:790
-msgid "Unable to update current region"
-msgstr ""
-#: ../general/g.region/main.c:798
-msgid ""
-"Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
-#: ../general/g.mapsets/list.c:10
-msgid "Available mapsets:"
-msgstr ""
-#: ../general/g.mapsets/list.c:35
-msgid "Accessible mapsets:"
-msgstr ""
-#: ../general/g.mapsets/main.c:65
-msgid "search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:66
-msgid "Modifies/prints the user's current mapset search path."
-msgstr ""
-#: ../general/g.mapsets/main.c:67
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
-msgstr ""
-#: ../general/g.mapsets/main.c:73
-msgid "Name(s) of existing mapset(s) to add/remove or set"
-msgstr ""
-#: ../general/g.mapsets/main.c:81 ../vector/v.net/args.c:36
-#: ../locale/scriptstrings/g.extension_to_translate.c:10
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:6
-msgid "Operation to be performed"
-msgstr ""
-#: ../general/g.mapsets/main.c:85
-msgid "Field separator for printing (-l and -p flags)"
-msgstr ""
-#: ../general/g.mapsets/main.c:91
-msgid "List all available mapsets in alphabetical order"
-msgstr ""
-#: ../general/g.mapsets/main.c:97
-msgid "Print mapsets in current search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:103
-msgid "Launch mapset selection GUI dialog"
-msgstr ""
-#: ../general/g.mapsets/main.c:126
-#, c-format
-msgid "Unknown operation '%s'"
-msgstr ""
-#: ../general/g.mapsets/main.c:136 ../general/g.mapsets/main.c:138
-#: ../general/g.mapsets/main.c:148 ../display/d.mon/main.c:169
-#, c-format
-msgid "Flag -%c ignored"
-msgstr ""
-#: ../general/g.mapsets/main.c:140 ../general/g.mapsets/main.c:150
-#: ../general/g.mapsets/main.c:158 ../display/d.mon/main.c:214
-#, c-format
-msgid "Option <%s> ignored"
-msgstr ""
-#: ../general/g.mapsets/main.c:174 ../general/g.mapsets/main.c:208
-#, c-format
-msgid "Mapset <%s> not found"
-msgstr ""
-#: ../general/g.mapsets/main.c:181 ../general/g.mapsets/main.c:240
-#, c-format
-msgid "Current mapset (<%s>) must always included in the search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:203
-#, c-format
-msgid "Mapset <%s> already in the path"
-msgstr ""
-#: ../general/g.mapsets/main.c:210
-#, c-format
-msgid "Mapset <%s> added to search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:243
-#, c-format
-msgid "Mapset <%s> removed from search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:255
-msgid "Search path not modified"
-msgstr ""
-#: ../general/g.mapsets/main.c:273
-msgid "Unable to open SEARCH_PATH for write"
-msgstr ""
-#: ../general/g.gui/main.c:40
-msgid "GUI"
-msgstr ""
-#: ../general/g.gui/main.c:41
-msgid "user interface"
-msgstr ""
-#: ../general/g.gui/main.c:44
-msgid "Launches a GRASS graphical user interface (GUI) session."
-msgstr ""
-#: ../general/g.gui/main.c:45
-msgid "Optionally updates default user interface settings."
-msgstr ""
-#: ../general/g.gui/main.c:50
-msgid "User interface"
-msgstr ""
-#: ../general/g.gui/main.c:54
-msgid "wxPython based GUI (wxGUI)"
-msgstr ""
-#: ../general/g.gui/main.c:55
-msgid "command line interface only"
-msgstr ""
-#: ../general/g.gui/main.c:56
-msgid "command line interface with GUI startup screen"
-msgstr ""
-#: ../general/g.gui/main.c:60 ../general/g.message/main.c:43
-#: ../general/g.message/main.c:48 ../general/g.message/main.c:53
-#: ../general/g.message/main.c:58
-msgid "Type"
-msgstr ""
-#: ../general/g.gui/main.c:66
-msgid "Name of workspace file to load on start-up"
-msgstr ""
-#: ../general/g.gui/main.c:67
-msgid "This is valid only for wxGUI (wxpython)"
-msgstr ""
-#: ../general/g.gui/main.c:71
-msgid "Start GUI in the foreground"
-msgstr ""
-#: ../general/g.gui/main.c:72
-msgid ""
-"By default the GUI starts in the background and control is immediately "
-"returned to the caller. When GUI runs in foregreound, it blocks the command "
-"line"
-msgstr ""
-#: ../general/g.gui/main.c:78
-msgid "Update default user interface settings"
-msgstr ""
-#: ../general/g.gui/main.c:79 ../general/g.gui/main.c:85
-msgid "Default"
-msgstr ""
-#: ../general/g.gui/main.c:84
-msgid "Do not launch GUI after updating the default user interface settings"
-msgstr ""
-#: ../general/g.gui/main.c:95
-#, c-format
-msgid "<%s> is now the default GUI"
-msgstr ""
-#: ../general/g.gui/main.c:101
-#, c-format
-msgid "Nothing to do. For setting up <%s> as default UI use -%c flag."
-msgstr ""
-#: ../general/g.gui/main.c:108
-msgid "Your installation doesn't include GUI, exiting."
-msgstr ""
-#: ../general/g.gui/main.c:111
-#, c-format
-msgid "Launching <%s> GUI, please wait..."
-msgstr ""
-#: ../general/g.gui/main.c:122
-#, c-format
-msgid "Launching <%s> GUI in the background, please wait..."
-msgstr ""
-#: ../general/g.filename/main.c:42
-msgid "Prints GRASS data base file names."
-msgstr ""
-#: ../general/g.filename/main.c:50 ../general/g.findfile/main.c:53
-msgid "Name of an element"
-msgstr ""
-#: ../general/g.filename/main.c:56
-msgid "Name of a database file"
-msgstr ""
-#: ../general/g.filename/main.c:62
-msgid "Name of a mapset (default: current)"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:43
-msgid "This should not happen. See your system admin."
-msgstr ""
-#: ../general/g.setproj/get_stp.c:99
-msgid "Unable to open FIPS code file"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:125
-#, c-format
-msgid "No match of FIPS state %d county %d"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:179
-msgid "Reading sf key_value temp file"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:212
-msgid "Invalid State FIPS code"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:302
-msgid "Reading cf key_value temp file"
-msgstr ""
-#: ../general/g.setproj/get_stp.c:336
-msgid "Invalid County FIPS code"
-msgstr ""
-#: ../general/g.setproj/main.c:81
-msgid "Interactively reset the location's projection settings."
-msgstr ""
-#: ../general/g.setproj/main.c:88
-msgid "You must be in the PERMANENT mapset to run g.setproj"
-msgstr ""
-#: ../general/g.setproj/main.c:101
-msgid "PERMANENT: permission denied"
-msgstr ""
-#: ../general/g.setproj/main.c:105
-msgid "Current region cannot be set"
-msgstr ""
-#: ../general/g.setproj/main.c:108
-msgid "Retrieving and setting region failed"
-msgstr ""
-#: ../general/g.setproj/main.c:135
-msgid "Would you still like to change some of the parameters?"
-msgstr ""
-#: ../general/g.setproj/main.c:137
-msgid "The projection information will not be updated"
-msgstr ""
-#: ../general/g.setproj/main.c:148
-#, c-format
-msgid ""
-"Zone in default geographic region definition: %d\n"
-" is different from zone in PROJ_INFO file: %d"
-msgstr ""
-#: ../general/g.setproj/main.c:158
-msgid "XY-location cannot be projected"
-msgstr ""
-#: ../general/g.setproj/main.c:192
-msgid "Unknown projection"
-msgstr ""
-#: ../general/g.setproj/main.c:198
-#, c-format
-msgid "Projection %s is not specified in the file 'proj-parms.table'"
-msgstr ""
-#: ../general/g.setproj/main.c:205
-msgid "Do you wish to specify a geodetic datum for this location?"
-msgstr ""
-#: ../general/g.setproj/main.c:214
-#, c-format
-msgid "The current datum is %s (%s)"
-msgstr ""
-#: ../general/g.setproj/main.c:217
-msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr ""
-#: ../general/g.setproj/main.c:225
-msgid "The datum information has not been changed"
-msgstr ""
-#: ../general/g.setproj/main.c:288
-#, c-format
-msgid "The current ellipsoid is %s"
-msgstr ""
-#: ../general/g.setproj/main.c:290
-msgid "Do you want to change ellipsoid parameter?"
-msgstr ""
-#: ../general/g.setproj/main.c:294
-msgid "The ellipse information has not been changed"
-msgstr ""
-#: ../general/g.setproj/main.c:311
-#, c-format
-msgid "The radius is currently %f"
-msgstr ""
-#: ../general/g.setproj/main.c:312
-msgid "Do you want to change the radius?"
-msgstr ""
-#: ../general/g.setproj/main.c:314 ../general/g.setproj/main.c:320
-msgid "Enter radius for the sphere in meters"
-msgstr ""
-#: ../general/g.setproj/main.c:336
-msgid "Invalid input ellipsoid"
-msgstr ""
-#: ../general/g.setproj/main.c:447
-#, c-format
-msgid "The UTM zone is now set to %d"
-msgstr ""
-#: ../general/g.setproj/main.c:450
-msgid "Do you want to change the UTM zone?"
-msgstr ""
-#: ../general/g.setproj/main.c:451
-msgid "UTM zone information has not been updated"
-msgstr ""
-#: ../general/g.setproj/main.c:456
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
-msgstr ""
-#: ../general/g.setproj/main.c:461
-msgid "Would you still like to change the UTM zone?"
-msgstr ""
-#: ../general/g.setproj/main.c:497
-#, c-format
-msgid "Error writing PROJ_INFO file <%s>"
-msgstr ""
-#: ../general/g.setproj/main.c:571
-#, c-format
-msgid "Enter plural form of units [meters]: "
-msgstr ""
-#: ../general/g.setproj/main.c:603
-#, c-format
-msgid "Enter singular for unit: "
-msgstr ""
-#: ../general/g.setproj/main.c:611
-#, c-format
-msgid "Enter conversion factor from %s to meters: "
-msgstr ""
-#: ../general/g.setproj/main.c:636
-#, c-format
-msgid "Error writing into UNITS output file <%s>"
-msgstr ""
-#: ../general/g.setproj/main.c:643
-msgid "Unable to write to DEFAULT_WIND region file"
-msgstr ""
-#: ../general/g.setproj/main.c:645
-#, c-format
-msgid ""
-"\n"
-"Projection information has been recorded for this location\n"
-"\n"
-msgstr ""
-#: ../general/g.setproj/main.c:647
-msgid "The geographic region information in WIND is now obsolete"
-msgstr ""
-#: ../general/g.setproj/main.c:648
-msgid "Run g.region -d to update it"
-msgstr ""
-#: ../general/g.setproj/proj.c:168
-#, c-format
-msgid "Unrecognized 'ask' value in parms.table: %s"
-msgstr ""
-#: ../general/g.setproj/proj.c:178
-#, c-format
-msgid "Unrecognized default value in parms.table: %s"
-msgstr ""
-#: ../general/g.remove/main.c:71
-#: ../locale/scriptstrings/t.remove_to_translate.c:4
-msgid "remove"
-msgstr ""
-#: ../general/g.remove/main.c:73
-msgid ""
-"Removes data base element files from the user's current mapset using the "
-"search pattern."
-msgstr ""
-#: ../general/g.remove/main.c:83 ../general/g.remove/main.c:91
-#: ../general/g.remove/main.c:133 ../vector/v.kernel/main.c:121
-#: ../vector/v.kernel/main.c:135 ../vector/v.kernel/main.c:149
-msgid "Basic"
-msgstr ""
-#: ../general/g.remove/main.c:90
-msgid "Name of file(s) to remove"
-msgstr ""
-#: ../general/g.remove/main.c:99
-msgid "Name of file(s) to ignore (default: none)"
-msgstr ""
-#: ../general/g.remove/main.c:105
-msgid "File name search pattern"
-msgstr ""
-#: ../general/g.remove/main.c:111
-msgid "File name exclusion pattern (default: none)"
-msgstr ""
-#: ../general/g.remove/main.c:135
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-msgid "Force removal (required for actual deletion of files)"
-msgstr ""
-#: ../general/g.remove/main.c:139
-msgid "Remove base raster maps"
-msgstr ""
-#: ../general/g.remove/main.c:208
-msgid "The following data base element files would be deleted:"
-msgstr ""
-#: ../general/g.remove/main.c:259
-msgid "No data base element files found"
-msgstr ""
-#: ../general/g.remove/main.c:267
-#, c-format
-msgid ""
-"Nothing removed. You must use the force flag (-%c) to actually remove them. "
-"Exiting."
-msgstr ""
-#: ../general/g.remove/construct_pattern.c:37
-#, c-format
-msgid "%s: Cannot remove or exclude files not in the current mapset."
-msgstr ""
-#: ../general/g.remove/construct_pattern.c:57
-msgid "Illegal filenames not allowed in the name or ignore option."
-msgstr ""
-#: ../general/g.remove/check_reclass.c:16
-#, c-format
-msgid "Raster map <%s@%s> is a base map for <%s>. Remove forced."
-msgstr ""
-#: ../general/g.remove/check_reclass.c:19
-#, c-format
-msgid "Raster map <%s@%s> is a base map. Remove reclassed map <%s> first."
-msgstr ""
-#: ../general/g.remove/check_reclass.c:41
-#: ../general/g.remove/check_reclass.c:54
-#, c-format
-msgid "Removing information about reclassed map from <%s@%s> failed"
-msgstr ""
-#: ../general/g.tempfile/main.c:39 ../general/g.message/main.c:34
-#: ../general/g.version/main.c:66
-msgid "support"
-msgstr ""
-#: ../general/g.tempfile/main.c:41
-msgid "Creates a temporary file and prints it's file name."
-msgstr ""
-#: ../general/g.tempfile/main.c:47
-msgid "Process id to use when naming the tempfile"
-msgstr ""
-#: ../general/g.tempfile/main.c:51
-msgid "Dry run - don't create a file, just prints it's file name"
-msgstr ""
-#: ../general/g.cairocomp/main.c:49 ../scripts/v.in.lines/v.in.lines.py:75
-#: ../scripts/r3.in.xyz/r3.in.xyz.py:212
-#, c-format, python-format
-msgid "Unable to read input file <%s>"
-msgstr ""
-#: ../general/g.cairocomp/main.c:52
-#, c-format
-msgid "Unable to parse input file <%s>"
-msgstr ""
-#: ../general/g.cairocomp/main.c:71
-#, c-format
-msgid "Unable to write output file <%s>"
-msgstr ""
-#: ../general/g.cairocomp/main.c:89 ../general/g.cairocomp/main.c:256
-#: ../visualization/ximgview/main.c:64
-msgid "Unable to open display"
-msgstr ""
-#: ../general/g.cairocomp/main.c:113
-msgid "Unable to obtain visual"
-msgstr ""
-#: ../general/g.cairocomp/main.c:129
-msgid "Failed to initialize output surface"
-msgstr ""
-#: ../general/g.cairocomp/main.c:171
-msgid "Failed to initialize input surface"
-msgstr ""
-#: ../general/g.cairocomp/main.c:198
-msgid "Overlays multiple X Pixmaps."
-msgstr ""
-#: ../general/g.cairocomp/main.c:212
-msgid "Output Visual XID"
-msgstr ""
-#: ../general/g.cairocomp/main.c:218
-msgid "Output screen"
-msgstr ""
-#: ../general/g.cairocomp/main.c:240
-msgid "Background color (R:G:B:A)"
-msgstr ""
-#: ../general/g.cairocomp/main.c:245
-msgid "Do not composite; just delete input Pixmaps"
-msgstr ""
-#: ../general/g.cairocomp/main.c:277
-msgid "input= and opacity= must have the same number of values"
-msgstr ""
-#: ../general/g.copy/main.c:44
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
-msgstr ""
-#: ../general/g.copy/main.c:51
-msgid "copied"
-msgstr ""
-#: ../general/g.copy/main.c:66
-#, c-format
-msgid "<%s> not found"
-msgstr ""
-#: ../general/g.copy/main.c:71
-#, c-format
-msgid "%s=%s,%s: files are the same, no copy required"
-msgstr ""
-#: ../general/g.copy/main.c:76
-#, c-format
-msgid "<%s> already exists. File not copied."
-msgstr ""
-#: ../general/g.message/main.c:37
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
-msgstr ""
-#: ../general/g.message/main.c:39
-msgid "This module should be used in scripts for messages served to user."
-msgstr ""
-#: ../general/g.message/main.c:44
-msgid "Print message as warning"
-msgstr ""
-#: ../general/g.message/main.c:49
-msgid "Print message as fatal error"
-msgstr ""
-#: ../general/g.message/main.c:54
-msgid "Print message as debug message"
-msgstr ""
-#: ../general/g.message/main.c:59
-msgid "Print message as progress info"
-msgstr ""
-#: ../general/g.message/main.c:63 ../general/g.message/main.c:69
-#: ../general/g.message/main.c:85
-msgid "Level"
-msgstr ""
-#: ../general/g.message/main.c:64
-msgid "Print message in all modes except of quiet mode"
-msgstr ""
-#: ../general/g.message/main.c:65
-msgid "Message is printed on GRASS_VERBOSE>=1"
-msgstr ""
-#: ../general/g.message/main.c:70
-msgid "Print message only in verbose mode"
-msgstr ""
-#: ../general/g.message/main.c:71
-msgid "Message is printed only on GRASS_VERBOSE>=3"
-msgstr ""
-#: ../general/g.message/main.c:78
-msgid "Text of the message to be printed"
-msgstr ""
-#: ../general/g.message/main.c:79
-msgid "Message is printed on GRASS_VERBOSE>=2"
-msgstr ""
-#: ../general/g.message/main.c:88
-msgid "Level to use for debug messages"
-msgstr ""
-#: ../general/g.message/main.c:95
-msgid "Select only one message level"
-msgstr ""
-#: ../general/g.message/main.c:108
-msgid "Unable to parse input message"
-msgstr ""
-#: ../general/g.ppmtopng/main.c:34
-#, c-format
-msgid "Unable to open input file %s"
-msgstr ""
-#: ../general/g.ppmtopng/main.c:37
-#, c-format
-msgid "Invalid input file %s"
-msgstr ""
-#: ../general/g.ppmtopng/main.c:77
-msgid "Error writing PNG file"
-msgstr ""
-#: ../general/g.ppmtopng/main.c:81
-#, c-format
-msgid "Unable to open output file %s"
-msgstr ""
-#: ../general/g.ppmtopng/main.c:119
-msgid "Converts between PPM/PGM and PNG image formats."
-msgstr ""
-#: ../general/g.mkfontcap/freetype_fonts.c:55
-msgid "Unable to initialise Freetype"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:73
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts."
-msgstr ""
-#: ../general/g.mkfontcap/main.c:79
-msgid "Overwrite font configuration file if already existing"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:84
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:91
-msgid "List of extra directories to scan"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:93
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:110
-#, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:122
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:149
-#, c-format
-msgid "Cannot open %s for writing: %s"
-msgstr ""
-#: ../general/g.proj/output.c:146
-msgid "Unable to convert projection information to PROJ.4 format"
-msgstr ""
-#: ../general/g.proj/output.c:190
-msgid "Unable to convert to WKT"
-msgstr ""
-#: ../general/g.proj/datumtrans.c:47
-#, c-format
-msgid "Invalid datum code <%s>"
-msgstr ""
-#: ../general/g.proj/datumtrans.c:77
-#, c-format
-msgid "Datum set to <%s>"
-msgstr ""
-#: ../general/g.proj/datumtrans.c:79
-#, c-format
-msgid "Ellipsoid set to <%s>"
-msgstr ""
-#: ../general/g.proj/create.c:17
-#, c-format
-msgid "Unable to create location <%s>: %s"
-msgstr ""
-#: ../general/g.proj/create.c:20
-#, c-format
-msgid "Unable to create projection files: %s"
-msgstr ""
-#: ../general/g.proj/create.c:24
-#, c-format
-msgid "Unable to create location <%s>"
-msgstr ""
-#: ../general/g.proj/create.c:30
-#, c-format
-msgid ""
-"You can switch to the new location by\n"
-"`%s=%s`"
-msgstr ""
-#: ../general/g.proj/create.c:40
-#, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)"
-msgstr ""
-#: ../general/g.proj/create.c:66
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
-msgstr ""
-#: ../general/g.proj/create.c:70
-msgid "Projection information updated"
-msgstr ""
-#: ../general/g.proj/create.c:91
-#, c-format
-msgid "Unable to create PROJ_EPSG file: %s"
-msgstr ""
-#: ../general/g.proj/main.c:69
-msgid ""
-"Prints or modifies GRASS projection information files (in various co-"
-"ordinate system descriptions)."
-msgstr ""
-#: ../general/g.proj/main.c:72
-msgid "Can also be used to create new GRASS locations."
-msgstr ""
-#: ../general/g.proj/main.c:75
-msgid "Prints and manipulates GRASS projection information files."
-msgstr ""
-#: ../general/g.proj/main.c:82
-msgid "Print projection information in conventional GRASS format"
-msgstr ""
-#: ../general/g.proj/main.c:88
-msgid "Print projection information in shell script style"
-msgstr ""
-#: ../general/g.proj/main.c:94
-msgid "Verify datum information and print transformation parameters"
-msgstr ""
-#: ../general/g.proj/main.c:100
-msgid "Print projection information in PROJ.4 format"
-msgstr ""
-#: ../general/g.proj/main.c:106
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
-msgstr ""
-#: ../general/g.proj/main.c:116
-msgid "Print projection information in WKT format"
-msgstr ""
-#: ../general/g.proj/main.c:122
-msgid "Use ESRI-style format (applies to WKT output only)"
-msgstr ""
-#: ../general/g.proj/main.c:129 ../general/g.proj/main.c:138
-#: ../general/g.proj/main.c:148 ../general/g.proj/main.c:158
-msgid "Specification"
-msgstr ""
-#: ../general/g.proj/main.c:130
-msgid "Name of georeferenced data file to read projection information from"
-msgstr ""
-#: ../general/g.proj/main.c:139
-msgid "Name of ASCII file containing a WKT projection description"
-msgstr ""
-#: ../general/g.proj/main.c:149
-msgid "PROJ.4 projection description"
-msgstr ""
-#: ../general/g.proj/main.c:159
-#: ../locale/scriptstrings/v.import_to_translate.c:21
-msgid "EPSG projection code"
-msgstr ""
-#: ../general/g.proj/main.c:167 ../general/g.proj/main.c:180
-#: ../general/g.proj/main.c:186
-msgid "Datum"
-msgstr ""
-#: ../general/g.proj/main.c:169
-msgid "Datum (overrides any datum specified in input co-ordinate system)"
-msgstr ""
-#: ../general/g.proj/main.c:171
-msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
-msgstr ""
-#: ../general/g.proj/main.c:181
-#: ../locale/scriptstrings/v.import_to_translate.c:23
-msgid "Index number of datum transform parameters"
-msgstr ""
-#: ../general/g.proj/main.c:182
-msgid "\"0\" for unspecified or \"-1\" to list and exit"
-msgstr ""
-#: ../general/g.proj/main.c:188
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
-msgstr ""
-#: ../general/g.proj/main.c:194
-msgid "Modify current location projection files"
-msgstr ""
-#: ../general/g.proj/main.c:202
-msgid "Name of new location to create"
-msgstr ""
-#: ../general/g.proj/main.c:218
-#, c-format
-msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr ""
-#: ../general/g.proj/main.c:263
-msgid "Projection files missing"
-msgstr ""
-#: ../general/g.proj/main.c:283
-#, c-format
-msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
-msgstr ""
-#: ../general/g.proj/main.c:310
-#, c-format
-msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
-msgstr ""
-#: ../general/g.proj/main.c:314
-#, c-format
-msgid "No output format specified, define one of flags -%c, -%c, or -%c"
-msgstr ""
-#: ../general/g.proj/input.c:91
-msgid "Error reading WKT projection description"
-msgstr ""
-#: ../general/g.proj/input.c:98
-#, c-format
-msgid "Unable to open file '%s' for reading"
-msgstr ""
-#: ../general/g.proj/input.c:143
-msgid "Can't parse PROJ.4-style parameter string"
-msgstr ""
-#: ../general/g.proj/input.c:181
-msgid "Unable to translate EPSG code"
-msgstr ""
-#: ../general/g.proj/input.c:218
-msgid "Trying to open with OGR..."
-msgstr ""
-#: ../general/g.proj/input.c:226 ../general/g.proj/input.c:245
-msgid "...succeeded."
-msgstr ""
-#: ../general/g.proj/input.c:239
-msgid "Trying to open with GDAL..."
-msgstr ""
-#: ../general/g.proj/input.c:254
-#, c-format
-msgid "Could not read georeferenced file %s using either OGR nor GDAL"
-msgstr ""
-#: ../general/g.proj/input.c:259
-#, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-#: ../general/g.findfile/element.c:7
-msgid "List of available elements:"
-msgstr ""
-#: ../general/g.findfile/main.c:42
-msgid "Searches for GRASS data base files and sets variables for the shell."
-msgstr ""
-#: ../general/g.findfile/main.c:59
-msgid "Name of an existing map"
-msgstr ""
-#: ../general/g.findfile/main.c:65
-msgid "Name of a mapset (default: search path)"
-msgstr ""
-#: ../general/g.findfile/main.c:66
-msgid "'.' for current mapset"
-msgstr ""
-#: ../general/g.findfile/main.c:70
-msgid "Do not add quotes"
-msgstr ""
-#: ../general/g.findfile/main.c:74
-msgid "List available elements and exit"
-msgstr ""
-#: ../general/g.findfile/main.c:97
-#, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter "
-"<%s> does not correspond"
-msgstr ""
-#: ../general/g.version/main.c:67
-msgid "citing"
-msgstr ""
-#: ../general/g.version/main.c:68
-msgid "copyright"
-msgstr ""
-#: ../general/g.version/main.c:69
-msgid "version"
-msgstr ""
-#: ../general/g.version/main.c:70
-msgid "license"
-msgstr ""
-#: ../general/g.version/main.c:71
-msgid "Displays GRASS GIS version info."
-msgstr ""
-#: ../general/g.version/main.c:72
-msgid "Optionally also prints build or copyright information."
-msgstr ""
-#: ../general/g.version/main.c:76
-msgid "Print also the copyright message"
-msgstr ""
-#: ../general/g.version/main.c:77 ../general/g.version/main.c:82
-#: ../general/g.version/main.c:87 ../general/g.version/main.c:93
-#: ../general/g.version/main.c:99
-msgid "Additional info"
-msgstr ""
-#: ../general/g.version/main.c:81
-msgid "Print also the citation options"
-msgstr ""
-#: ../general/g.version/main.c:86
-msgid "Print also the build information"
-msgstr ""
-#: ../general/g.version/main.c:92
-msgid "Print also the GIS library revision number and date"
-msgstr ""
-#: ../general/g.version/main.c:97
-msgid "Print also extended info for additional libraries"
-msgstr ""
-#: ../general/g.version/main.c:98
-msgid "GDAL/OGR, PROJ.4, GEOS"
-msgstr ""
-#: ../general/g.version/main.c:103
-msgid "Print info in shell script style (including SVN revision number)"
-msgstr ""
-#: ../general/g.version/main.c:104
-msgid "Shell"
-msgstr ""
-#: ../general/g.version/main.c:172
-#, c-format
-msgid ""
-"Cannot determine GRASS libgis version and date number. The GRASS build might"
-" be broken. Report this to developers or packagers.\n"
-msgstr ""
-#: ../general/g.version/main.c:179
-msgid ""
-"GRASS GIS libgis version and date number don't have the expected format. "
-"Trying to print the original strings..."
-msgstr ""
-#: ../general/g.version/main.c:181
-#, c-format
-msgid "GIS_H_VERSION=\"%s\""
-msgstr ""
-#: ../general/g.version/main.c:182
-#, c-format
-msgid "GIS_H_DATE=\"%s\""
-msgstr ""
-#: ../general/g.version/main.c:212
-msgid "GRASS not compiled with GDAL/OGR support"
-msgstr ""
-#: ../general/g.version/main.c:223
-msgid "GRASS not compiled with GEOS support"
-msgstr ""
-#: ../general/g.version/main.c:234
-msgid "GRASS not compiled with SQLite support"
-msgstr ""
-#: ../display/d.his/main.c:63 ../display/d.rast/main.c:54
-#: ../display/d.erase/main.c:30 ../display/d.rgb/main.c:54
-#: ../display/d.mon/main.c:51 ../display/d.info/main.c:35
-#: ../display/d.vect/main.c:74 ../visualization/ximgview/main.c:291
-#: ../locale/scriptstrings/d.frame_to_translate.c:3
-#: ../locale/scriptstrings/d.redraw_to_translate.c:3
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:3
-#: ../misc/m.nviz.script/main.c:70 ../misc/m.nviz.image/main.c:52
-msgid "graphics"
-msgstr ""
-#: ../display/d.his/main.c:69
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(HIS) values from user-specified input raster map layers."
-msgstr ""
-#: ../display/d.his/main.c:97
-msgid "Percent to brighten intensity channel"
-msgstr ""
-#: ../display/d.his/main.c:103
-msgid "Respect NULL values while drawing"
-msgstr ""
-#: ../display/d.rast/main.c:56
-msgid "Displays user-specified raster map in the active graphics frame."
-msgstr ""
-#: ../display/d.rast/main.c:61
-msgid "Name of raster map to be displayed"
-msgstr ""
-#: ../display/d.rast/main.c:69
-msgid "List of categories or values to be displayed"
-msgstr ""
-#: ../display/d.rast/main.c:76
-msgid "Background color (for null)"
-msgstr ""
-#: ../display/d.rast/main.c:77 ../display/d.rast/main.c:82
-#: ../display/d.rgb/main.c:64
-msgid "Null cells"
-msgstr ""
-#: ../display/d.rast/main.c:81 ../display/d.rgb/main.c:63
-msgid "Make null cells opaque"
-msgstr ""
-#: ../display/d.rast/main.c:86
-msgid "Invert value list"
-msgstr ""
-#: ../display/d.rast/main.c:204
-#, c-format
-msgid "[%s]: illegal category specified"
-msgstr ""
-#: ../display/d.rast/main.c:235
-#, c-format
-msgid "[%s]: illegal value specified"
-msgstr ""
-#: ../display/d.histogram/main.c:84
-msgid "histogram"
-msgstr ""
-#: ../display/d.histogram/main.c:87
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
-msgstr ""
-#: ../display/d.histogram/main.c:91
-msgid "Raster map for which histogram will be displayed"
-msgstr ""
-#: ../display/d.histogram/main.c:95
-msgid "Indicate if a pie or bar chart is desired"
-msgstr ""
-#: ../display/d.histogram/main.c:104
-msgid "Color for text and axes"
-msgstr ""
-#: ../display/d.histogram/main.c:115
-msgid "Indicate if cell counts or map areas should be displayed"
-msgstr ""
-#: ../display/d.histogram/main.c:125
-msgid "Number of steps to divide the data range into (fp maps only)"
-msgstr ""
-#: ../display/d.histogram/main.c:132
-msgid "Display information for null cells"
-msgstr ""
-#: ../display/d.histogram/main.c:137
-msgid "Report for ranges defined in cats file (fp maps only)"
-msgstr ""
-#: ../display/d.histogram/main.c:161
-#, c-format
-msgid "Invalid number of steps: %s"
-msgstr ""
-#: ../display/d.histogram/main.c:166
-msgid "When -C flag is set, the nsteps argument is ignored"
-msgstr ""
-#: ../display/d.histogram/main.c:174 ../ps/ps.map/ps_clrtbl.c:39
-#, c-format
-msgid "Category file for <%s> not available"
-msgstr ""
-#: ../display/d.histogram/main.c:177 ../display/d.legend/draw.c:282
-#: ../display/d.legend/draw.c:287
-#, c-format
-msgid "Range information for <%s> not available"
-msgstr ""
-#: ../display/d.where/main.c:48
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
-msgstr ""
-#: ../display/d.where/main.c:58
-msgid "Display coordinates to convert"
-msgstr ""
-#: ../display/d.where/main.c:63
-msgid "File from which to read coordinates (\"-\" to read from stdin)"
-msgstr ""
-#: ../display/d.where/main.c:67
-msgid "Output lat/long in decimal degree"
-msgstr ""
-#: ../display/d.where/main.c:72
-msgid "Output lat/long referenced to current ellipsoid"
-msgstr ""
-#: ../display/d.where/main.c:77
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
-msgstr ""
-#: ../display/d.where/main.c:83
-msgid "Output frame coordinates of current display monitor (percentage)"
-msgstr ""
-#: ../display/d.where/main.c:91
-msgid "Ambiguous request for lat/long ellipsoids"
-msgstr ""
-#: ../display/d.where/main.c:94
-msgid "Please specify a lat/long ellipsoid with -l or -w"
-msgstr ""
-#: ../display/d.where/main.c:136
-msgid ""
-"WGS84 output not possible as this location does not contain\n"
-"datum transformation parameters. Try running g.setproj."
-msgstr ""
-#: ../display/d.where/where.c:29
-#, c-format
-msgid "Invalid coordinates <%s,%s>"
-msgstr ""
-#: ../display/d.title/main.c:50 ../display/d.barscale/main.c:64
-#: ../display/d.vect.chart/main.c:64 ../display/d.linegraph/main.c:232
-#: ../display/d.graph/main.c:59 ../display/d.grid/main.c:54
-#: ../display/d.vect.thematic/main.c:86 ../display/d.text/main.c:140
-#: ../display/d.legend.vect/main.c:51 ../display/d.northarrow/main.c:47
-#: ../display/d.legend/main.c:79
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
-msgid "cartography"
-msgstr ""
-#: ../display/d.title/main.c:52
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
-msgstr ""
-#: ../display/d.title/main.c:63
-msgid "Sets the text color"
-msgstr ""
-#: ../display/d.title/main.c:71
-msgid "Sets the text size as percentage of the frame's height"
-msgstr ""
-#: ../display/d.title/main.c:75
-msgid "Draw title on current display"
-msgstr ""
-#: ../display/d.title/main.c:79
-msgid "Do a fancier title"
-msgstr ""
-#: ../display/d.title/main.c:84
-msgid "Do a simple title"
-msgstr ""
-#: ../display/d.title/main.c:102
-msgid "Title can be fancy or simple, not both"
-msgstr ""
-#: ../display/d.title/main.c:105
-msgid "No map name given"
-msgstr ""
-#: ../display/d.barscale/draw_scale.c:220 ../display/d.barscale/main.c:237
-#: ../display/d.barscale/main.c:254
-msgid "Programmer error"
-msgstr ""
-#: ../display/d.barscale/draw_scale.c:611
-#: ../display/d.northarrow/draw_n_arrow.c:200
-#, c-format
-msgid "Could not read symbol \"%s\""
-msgstr ""
-#: ../display/d.barscale/main.c:65
-msgid "Displays a barscale on the graphics monitor."
-msgstr ""
-#: ../display/d.barscale/main.c:69
-msgid "Use feet/miles instead of meters"
-msgstr ""
-#: ../display/d.barscale/main.c:73
-msgid "Draw the scale bar without text"
-msgstr ""
-#: ../display/d.barscale/main.c:74 ../display/d.barscale/main.c:141
-#: ../display/d.barscale/main.c:166 ../display/d.barscale/main.c:183
-#: ../display/d.text/main.c:164 ../display/d.text/main.c:173
-#: ../display/d.text/main.c:182 ../display/d.text/main.c:190
-#: ../display/d.text/main.c:264 ../display/d.text/main.c:269
-#: ../display/d.northarrow/main.c:100 ../display/d.northarrow/main.c:130
-#: ../display/d.northarrow/main.c:135 ../display/d.northarrow/main.c:140
-msgid "Text"
-msgstr ""
-#: ../display/d.barscale/main.c:78
-msgid "Display north-arrow symbol."
-msgstr ""
-#: ../display/d.barscale/main.c:79 ../display/d.barscale/main.c:88
-#: ../display/d.barscale/main.c:149 ../display/d.northarrow/main.c:73
-msgid "Style"
-msgstr ""
-#: ../display/d.barscale/main.c:83
-msgid "Type of barscale to draw"
-msgstr ""
-#: ../display/d.barscale/main.c:102
-msgid "Classic style"
-msgstr ""
-#: ../display/d.barscale/main.c:103
-msgid "Line style"
-msgstr ""
-#: ../display/d.barscale/main.c:104
-msgid "Solid style"
-msgstr ""
-#: ../display/d.barscale/main.c:105
-msgid "Hollow style"
-msgstr ""
-#: ../display/d.barscale/main.c:106
-msgid "Full checker style"
-msgstr ""
-#: ../display/d.barscale/main.c:107
-msgid "Part checker style"
-msgstr ""
-#: ../display/d.barscale/main.c:108
-msgid "Mixed checker style"
-msgstr ""
-#: ../display/d.barscale/main.c:109
-msgid "Tail checker style"
-msgstr ""
-#: ../display/d.barscale/main.c:110
-msgid "Up ticks style"
-msgstr ""
-#: ../display/d.barscale/main.c:111
-msgid "Down ticks style"
-msgstr ""
-#: ../display/d.barscale/main.c:112
-msgid "Both ticks style"
-msgstr ""
-msgid "Arrow ends style"
-msgstr ""
-#: ../display/d.barscale/main.c:121 ../display/d.northarrow/main.c:83
-msgid "Screen coordinates of the rectangle's top-left corner"
-msgstr ""
-#: ../display/d.barscale/main.c:122 ../display/d.northarrow/main.c:84
-msgid "(0,0) is lower-left of the display frame"
-msgstr ""
-#: ../display/d.barscale/main.c:130
-msgid "Length of barscale in map units"
-msgstr ""
-#: ../display/d.barscale/main.c:134
-msgid "Barscale units to display"
-msgstr ""
-#: ../display/d.barscale/main.c:139
-msgid "Custom label of unit"
-msgstr ""
-#: ../display/d.barscale/main.c:148
-msgid "Number of segments"
-msgstr ""
-#: ../display/d.barscale/main.c:152
-msgid "Bar scale and text color"
-msgstr ""
-#: ../display/d.barscale/main.c:153 ../display/d.barscale/main.c:159
-#: ../display/d.rast.arrow/main.c:119 ../display/d.rast.arrow/main.c:125
-#: ../display/d.rast.arrow/main.c:131 ../display/d.rast.arrow/main.c:137
-#: ../display/d.vect/main.c:121 ../display/d.vect/main.c:127
-#: ../display/d.vect/main.c:131 ../display/d.vect/main.c:138
-#: ../display/d.vect/main.c:309 ../display/d.northarrow/main.c:104
-#: ../display/d.northarrow/main.c:109 ../display/d.northarrow/main.c:115
-#: ../display/d.rast.num/main.c:89 ../display/d.rast.num/main.c:95
-#: ../display/d.rast.num/main.c:113 ../vector/v.label/main.c:152
-#: ../vector/v.label/main.c:176 ../vector/v.label/main.c:189
-#: ../vector/v.label/main.c:195 ../vector/v.label/main.c:205
-#: ../vector/v.label.sa/main.c:103 ../vector/v.label.sa/main.c:113
-#: ../vector/v.label.sa/main.c:120 ../vector/v.label.sa/main.c:130
-#: ../vector/v.label.sa/main.c:140 ../vector/v.label.sa/main.c:150
-#: ../vector/v.label.sa/main.c:157
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:11
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:13
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:15
-msgid "Colors"
-msgstr ""
-#: ../display/d.barscale/main.c:158
-msgid "Background color (drawn behind the bar)"
-msgstr ""
-#: ../display/d.barscale/main.c:163
-msgid "Text position"
-msgstr ""
-#: ../display/d.barscale/main.c:174
-msgid "Scale factor to change bar width"
-msgstr ""
-#: ../display/d.barscale/main.c:182 ../display/d.legend.vect/main.c:123
-#: ../display/d.northarrow/main.c:129 ../display/d.legend/main.c:218
-msgid "Font size"
-msgstr ""
-#: ../display/d.barscale/main.c:193
-#, c-format
-msgid "%s does not work with a latitude-longitude location"
-msgstr ""
-#: ../display/d.vect.chart/main.c:65
-msgid "chart maps"
-msgstr ""
-#: ../display/d.vect.chart/main.c:67
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
-msgstr ""
-#: ../display/d.vect.chart/main.c:86
-msgid "Chart type"
-msgstr ""
-#: ../display/d.vect.chart/main.c:87 ../display/d.vect.chart/main.c:97
-#: ../display/d.vect.chart/main.c:105 ../display/d.vect.chart/main.c:112
-#: ../display/d.vect.chart/main.c:117 ../display/d.vect.chart/main.c:123
-#: ../display/d.vect.chart/main.c:129 ../display/d.vect.chart/main.c:148
-msgid "Chart properties"
-msgstr ""
-#: ../display/d.vect.chart/main.c:91
-msgid "Attribute columns containing data"
-msgstr ""
-#: ../display/d.vect.chart/main.c:96
-msgid "Column used for pie chart size"
-msgstr ""
-#: ../display/d.vect.chart/main.c:104
-msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr ""
-#: ../display/d.vect.chart/main.c:111
-msgid "Scale for size (to get size in pixels)"
-msgstr ""
-#: ../display/d.vect.chart/main.c:116
-msgid "Outline color"
-msgstr ""
-#: ../display/d.vect.chart/main.c:122
-msgid "Colors used to fill charts"
-msgstr ""
-#: ../display/d.vect.chart/main.c:128
-msgid "Center the bar chart around a data point"
-msgstr ""
-#: ../display/d.vect.chart/main.c:137
-msgid "Maximum value used for bar plot reference"
-msgstr ""
-#: ../display/d.vect.chart/main.c:142 ../display/d.vect.thematic/main.c:223
-msgid "Create legend information and send to stdout"
-msgstr ""
-#: ../display/d.vect.chart/main.c:147
-msgid "Create 3D charts"
-msgstr ""
-#: ../display/d.vect.chart/plot.c:38 ../display/d.vect.thematic/plot1.c:105
-#: ../display/d.vect/shape.c:38 ../vector/v.to.rast/support.c:104
-#: ../vector/v.to.rast/support.c:279 ../vector/v.to.rast/support.c:518
-#: ../vector/v.vect.stats/main.c:340 ../vector/v.vect.stats/main.c:414
-#: ../vector/v.univar/main.c:229 ../vector/v.overlay/main.c:398
-#: ../vector/v.what.rast3/main.c:120 ../vector/v.generalize/misc.c:170
-#: ../vector/v.colors/read_rgb.c:23 ../vector/v.colors/scan_attr.c:24
-#: ../vector/v.colors/write_rgb.c:20 ../vector/v.what.rast/main.c:138
-#: ../vector/v.surf.bspline/crosscorr.c:114 ../vector/v.distance/main.c:556
-#: ../vector/v.extrude/main.c:224 ../vector/v.edit/select.c:502
-#: ../vector/v.buffer/main.c:426 ../doc/vector/v.example/main.c:109
-#, c-format
-msgid "Database connection not defined for layer %d"
-msgstr ""
-#: ../display/d.vect.chart/plot.c:86 ../display/d.vect/attr.c:110
-#: ../vector/v.in.db/main.c:225
-#, c-format
-msgid "Unable to open select cursor: '%s'"
-msgstr ""
-#: ../display/d.erase/main.c:31 ../display/d.mon/main.c:52
-#: ../display/d.info/main.c:36
-#: ../locale/scriptstrings/d.frame_to_translate.c:4
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-msgid "monitors"
-msgstr ""
-#: ../display/d.erase/main.c:33
-msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
-msgstr ""
-#: ../display/d.erase/main.c:42
-msgid "Remove all frames and erase the screen"
-msgstr ""
-#: ../display/d.geodesic/main.c:48
-msgid "great circle"
-msgstr ""
-#: ../display/d.geodesic/main.c:49 ../display/d.path/main.c:50
-#: ../vector/v.net.timetable/main.c:262 ../vector/v.net.distance/main.c:68
-#: ../vector/v.net.allpairs/main.c:63 ../vector/v.net.visibility/main.c:47
-#: ../vector/v.net.path/main.c:44
-msgid "shortest path"
-msgstr ""
-#: ../display/d.geodesic/main.c:51
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
-msgstr ""
-#: ../display/d.geodesic/main.c:58 ../display/d.rhumbline/main.c:53
-#: ../display/d.path/main.c:65
-msgid "Starting and ending coordinates"
-msgstr ""
-#: ../display/d.geodesic/main.c:62 ../display/d.rhumbline/main.c:57
-#: ../display/d.northarrow/main.c:103
-msgid "Line color"
-msgstr ""
-#: ../display/d.geodesic/main.c:66 ../display/d.grid/main.c:107
-#: ../display/d.rhumbline/main.c:62 ../display/d.northarrow/main.c:113
-#: ../display/d.rast.num/main.c:88 ../display/d.legend/main.c:203
-#: ../vector/v.lrs/v.lrs.label/main.c:193 ../vector/v.label/main.c:151
-#: ../vector/v.label.sa/main.c:98
-msgid "Text color"
-msgstr ""
-#: ../display/d.geodesic/main.c:78 ../display/d.rhumbline/main.c:75
-#, c-format
-msgid "Location is not %s"
-msgstr ""
-#: ../display/d.geodesic/main.c:87 ../display/d.rhumbline/main.c:86
-#: ../display/d.path/main.c:140
-msgid "No coordinates given"
-msgstr ""
-#: ../display/d.geodesic/main.c:90 ../display/d.geodesic/main.c:93
-#: ../display/d.geodesic/main.c:96 ../display/d.geodesic/main.c:99
-#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:92
-#: ../display/d.rhumbline/main.c:95 ../display/d.rhumbline/main.c:98
-#, c-format
-msgid "%s - illegal longitude"
-msgstr ""
-#: ../display/d.rgb/main.c:58
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
-msgstr ""
-#: ../display/d.extract/extract.c:43
-msgid "Select vector(s) with mouse"
-msgstr ""
-#: ../display/d.extract/extract.c:44
-msgid " - L: draw box with left mouse button to select"
-msgstr ""
-#: ../display/d.extract/extract.c:45
-msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
-#: ../display/d.extract/extract.c:46
-msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
-#: ../display/d.extract/extract.c:48
-msgid "L: add  M: remove  R: quit and save\n"
-msgstr ""
-#: ../display/d.extract/main.c:52
-msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
-#: ../display/d.extract/main.c:65 ../display/d.path/main.c:99
-msgid "Original line color"
-msgstr ""
-#: ../display/d.extract/main.c:71 ../display/d.path/main.c:107
-msgid "Highlight color"
-msgstr ""
-#: ../display/d.extract/main.c:79 ../vector/v.label/main.c:233
-msgid "No graphics device selected"
-msgstr ""
-#: ../display/d.extract/main.c:122
-msgid "Copying tables..."
-msgstr ""
-#: ../display/d.extract/main.c:130
-msgid "Cannot get db link info -> cannot copy table."
-msgstr ""
-#: ../display/d.linegraph/main.c:234
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
-msgstr ""
-#: ../display/d.linegraph/main.c:238
-msgid "Name of data file for X axis of graph"
-msgstr ""
-#: ../display/d.linegraph/main.c:244
-msgid "Name of data file(s) for Y axis of graph"
-msgstr ""
-#: ../display/d.linegraph/main.c:251
-msgid "Path to files"
-msgstr ""
-#: ../display/d.linegraph/main.c:253
-msgid "Path to the directory where the input files are located"
-msgstr ""
-#: ../display/d.linegraph/main.c:261
-msgid "Color for Y data"
-msgstr ""
-#: ../display/d.linegraph/main.c:274
-msgid "Width of the lines"
-msgstr ""
-#: ../display/d.linegraph/main.c:281
-msgid "Color for axis, tics, numbers, and title"
-msgstr ""
-#: ../display/d.linegraph/main.c:289
-msgid "Title for X data"
-msgstr ""
-#: ../display/d.linegraph/main.c:296
-msgid "Title for Y data"
-msgstr ""
-#: ../display/d.linegraph/main.c:303
-msgid "Title for Graph"
-msgstr ""
-#: ../display/d.linegraph/main.c:311
-msgid "Minimum and maximun value for Y axis (min,max)"
-msgstr ""
-#: ../display/d.linegraph/main.c:318
-msgid "Tic values for the Y axis"
-msgstr ""
-#: ../display/d.linegraph/main.c:325
-msgid "Scale for X values"
-msgstr ""
-#: ../display/d.linegraph/main.c:331
-msgid "Scale for Y values"
-msgstr ""
-#: ../display/d.linegraph/main.c:352
-msgid "Symbol for point"
-msgstr ""
-#: ../display/d.linegraph/main.c:361
-msgid "Point size"
-msgstr ""
-#: ../display/d.linegraph/main.c:370
-msgid "Color for point symbol edge color"
-msgstr ""
-#: ../display/d.linegraph/main.c:376
-msgid "Width of point symbol lines"
-msgstr ""
-#: ../display/d.linegraph/main.c:437
-msgid "Maximum of 10 Y data files exceeded"
-msgstr ""
-#: ../display/d.linegraph/main.c:494
-#, c-format
-msgid "Cannot find/open symbol: '%s'"
-msgstr ""
-#: ../display/d.linegraph/main.c:511
-#, c-format
-msgid "Color <%s> cannot for option %s be parsed"
-msgstr ""
-#: ../display/d.linegraph/main.c:549
-#, c-format
-msgid "Only <%d> colors given for <%d> lines"
-msgstr ""
-#: ../display/d.linegraph/main.c:593
-#, c-format
-msgid "Number of widths (%d) is higher then the number of files (%d)"
-msgstr ""
-#: ../display/d.linegraph/main.c:606
-#, c-format
-msgid "Number of widths (%d) is lower then the number of files (%d)"
-msgstr ""
-#: ../display/d.linegraph/main.c:659
-#, c-format
-msgid "Y input file <%s> contains fewer data points than the X input file"
-msgstr ""
-#: ../display/d.linegraph/main.c:663
-#, c-format
-msgid "Y input file <%s> contains more data points than the X input file"
-msgstr ""
-#: ../display/d.linegraph/main.c:668
-#, c-format
-msgid "The last point will be ignored"
-msgid_plural "The last %d points will be ignored"
-msgstr[0] ""
-#: ../display/d.linegraph/main.c:722
-#, c-format
-msgid "Scale X labels cannot be used with this range of data (%f, %f)"
-msgstr ""
-#: ../display/d.linegraph/main.c:752
-#, c-format
-msgid "Problem reading X data file at line %d"
-msgstr ""
-#: ../display/d.linegraph/main.c:764
-#, c-format
-msgid "Problem reading <%s> data file at line %d"
-msgstr ""
-#: ../display/d.linegraph/main.c:971
-#, c-format
-msgid "Scale Y labels cannot be used with this range of data (%f, %f)"
-msgstr ""
-#: ../display/d.profile/main.c:68
-#, c-format
-msgid "Unable to read range for %s"
-msgstr ""
-#: ../display/d.profile/main.c:79
-#, c-format
-msgid "Unable to read FP range for %s"
-msgstr ""
-#: ../display/d.profile/main.c:194
-msgid "Plots profile of a transect."
-msgstr ""
-#: ../display/d.profile/main.c:198
-msgid "Raster map to be profiled"
-msgstr ""
-#: ../display/d.profile/main.c:207
-msgid "Use map's range recorded range"
-msgstr ""
-#: ../display/d.profile/main.c:256
-msgid "At least two points are required"
-msgstr ""
-#: ../display/d.mon/start.c:46 ../display/d.mon/start.c:74
-#, c-format
-msgid "File <%s> already exists and will be overwritten"
-msgstr ""
-#: ../display/d.mon/start.c:67
-#, c-format
-msgid "Unable to start monitor, don't have write permission for <%s>"
-msgstr ""
-#: ../display/d.mon/start.c:76
-#, c-format
-msgid "Unable to delete <%s>"
-msgstr ""
-#: ../display/d.mon/start.c:93
-#, c-format
-msgid "Output file: %s"
-msgstr ""
-#: ../display/d.mon/start.c:148
-#, c-format
-msgid "Monitor <%s> already running"
-msgstr ""
-#: ../display/d.mon/start.c:151
-#, c-format
-msgid "Starting monitor <%s>..."
-msgstr ""
-#: ../display/d.mon/start.c:169
-msgid "Unable to copy render command file"
-msgstr ""
-#: ../display/d.mon/list.c:80
-msgid "List of running monitors:"
-msgstr ""
-#: ../display/d.mon/list.c:82
-msgid "No monitors running"
-msgstr ""
-#: ../display/d.mon/list.c:116 ../scripts/d.what.rast/d.what.rast.py:40
-#: ../scripts/d.redraw/d.redraw.py:41 ../scripts/d.what.vect/d.what.vect.py:40
-msgid "Unable to open file '%s'"
-msgstr ""
-#: ../display/d.mon/list.c:145
-#, c-format
-msgid "No support files found for monitor <%s>"
-msgstr ""
-#: ../display/d.mon/select.c:14
-#, c-format
-msgid "Monitor <%s> is already selected"
-msgstr ""
-#: ../display/d.mon/select.c:30 ../display/d.mon/stop.c:18
-#, c-format
-msgid "Monitor <%s> is not running"
-msgstr ""
-#: ../display/d.mon/stop.c:41
-#, c-format
-msgid "Unable to delete file <%s>"
-msgstr ""
-#: ../display/d.mon/stop.c:46
-#, c-format
-msgid "Unable to delete directory <%s>"
-msgstr ""
-#: ../display/d.mon/stop.c:75
-#, c-format
-msgid "Unable to read file <%s>"
-msgstr ""
-#: ../display/d.mon/main.c:53
-msgid "Controls graphics display monitors from the command line."
-msgstr ""
-#: ../display/d.mon/main.c:58
-msgid "Name of monitor to start"
-msgstr ""
-#: ../display/d.mon/main.c:60 ../display/d.mon/main.c:67
-#: ../display/d.mon/main.c:74 ../display/d.mon/main.c:135
-#: ../display/d.mon/main.c:140
-msgid "Manage"
-msgstr ""
-#: ../display/d.mon/main.c:65
-msgid "Name of monitor to stop"
-msgstr ""
-#: ../display/d.mon/main.c:72
-msgid "Name of monitor to select"
-msgstr ""
-#: ../display/d.mon/main.c:78
-msgid "Width for display monitor if not set by GRASS_RENDER_WIDTH"
-msgstr ""
-#: ../display/d.mon/main.c:79
-msgid "Default value: 720"
-msgstr ""
-#: ../display/d.mon/main.c:86
-msgid "Height for display monitor if not set by GRASS_RENDER_HEIGHT"
-msgstr ""
-#: ../display/d.mon/main.c:87
-msgid "Default value: 480"
-msgstr ""
-#: ../display/d.mon/main.c:94
-msgid "Dimensions of display monitor versus current size"
-msgstr ""
-#: ../display/d.mon/main.c:95
-msgid "Example: resolution=2 enlarge display monitor twice to 1280x960"
-msgstr ""
-#: ../display/d.mon/main.c:108
-msgid "Name for output file (when starting new monitor)"
-msgstr ""
-#: ../display/d.mon/main.c:109
-msgid "Ignored for 'wx' monitors"
-msgstr ""
-#: ../display/d.mon/main.c:114
-msgid "List running monitors and exit"
-msgstr ""
-#: ../display/d.mon/main.c:119
-msgid "Print name of currently selected monitor and exit"
-msgstr ""
-#: ../display/d.mon/main.c:124
-msgid "Print commands for currently selected monitor and exit"
-msgstr ""
-#: ../display/d.mon/main.c:130
-msgid "Print path to support files of currently selected monitor and exit"
-msgstr ""
-#: ../display/d.mon/main.c:134
-msgid "Do not automatically select when starting"
-msgstr ""
-#: ../display/d.mon/main.c:139
-msgid "Release and stop currently selected monitor and exit"
-msgstr ""
-#: ../display/d.mon/main.c:144
-msgid "Disable true colors"
-msgstr ""
-#: ../display/d.mon/main.c:149
-msgid "Open output file in update mode"
-msgstr ""
-#: ../display/d.mon/main.c:150
-msgid "Requires --overwrite flag"
-msgstr ""
-#: ../display/d.mon/main.c:155
-msgid "Launch light-weight wx monitor without toolbars and statusbar"
-msgstr ""
-#: ../display/d.mon/main.c:156
-msgid "Requires 'start=wx0-7'"
-msgstr ""
-#: ../display/d.mon/main.c:163
-#, c-format
-msgid "Flag -%c has effect only for wx monitors (%s=wx0-7)"
-msgstr ""
-#: ../display/d.mon/main.c:173
-msgid "Currently selected monitor:"
-msgstr ""
-#: ../display/d.mon/main.c:177
-#, c-format
-msgid "List of commands for monitor <%s>:"
-msgstr ""
-#: ../display/d.mon/main.c:185
-#, c-format
-msgid "Monitor <%s> released"
-msgstr ""
-#: ../display/d.mon/main.c:190
-msgid "No monitor selected"
-msgstr ""
-#: ../display/d.mon/main.c:209
-#, c-format
-msgid "Either <%s>, <%s> or <%s> must be given"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:98 ../display/d.rast.num/main.c:78
-msgid "map annotations"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:101
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
-msgstr ""
-#: ../display/d.rast.arrow/main.c:105
-msgid "Name of raster aspect map to be displayed"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:113
-msgid "Type of existing raster aspect map"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:118
-msgid "Color for drawing arrows"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:124
-msgid "Color for drawing drawing grid"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:130
-msgid "Color for drawing null values (X symbol)"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:136
-msgid "Color for showing unknown information (? symbol)"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:144
-msgid "Draw arrow every Nth grid cell"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:153
-msgid "Raster map containing values used for arrow length"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:160
-msgid "Scale factor for arrows (magnitude map)"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:164 ../display/d.rast.num/main.c:108
-msgid "Align grids with raster cells"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:210
-msgid "Illegal value for scale factor"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:214
-msgid "Illegal value for skip factor"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:219
-msgid "Magnitude is only supported for GRASS and compass aspect maps."
-msgstr ""
-#: ../display/d.rast.arrow/main.c:224
-msgid "Scale option requires magnitude_map"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:275
-msgid "Problem reading range file"
-msgstr ""
-#: ../display/d.graph/do_graph.c:65 ../display/d.graph/do_graph.c:81
-#, c-format
-msgid "Problem parsing coordinates [%s]"
-msgstr ""
-#: ../display/d.graph/do_graph.c:98
-msgid "Unable to read color"
-msgstr ""
-#: ../display/d.graph/do_graph.c:129 ../display/d.graph/do_graph.c:195
-#: ../display/d.graph/do_graph.c:216 ../display/d.graph/do_graph.c:267
-#: ../display/d.graph/do_graph.c:334 ../display/d.graph/graphics.c:60
-#, c-format
-msgid "Problem parsing command [%s]"
-msgstr ""
-#: ../display/d.graph/do_graph.c:377
-msgid "Cannot read symbol, cannot display points"
-msgstr ""
-#: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display "
-"monitor."
-msgstr ""
-#: ../display/d.graph/main.c:66
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
-msgstr ""
-#: ../display/d.graph/main.c:73
-msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-#: ../display/d.graph/main.c:80
-msgid "Coordinates are given in map units"
-msgstr ""
-#: ../display/d.graph/main.c:91
-#, c-format
-msgid "Graph file <%s> not found"
-msgstr ""
-#: ../display/d.info/main.c:38
-msgid "Displays information about the active display monitor."
-msgstr ""
-#: ../display/d.info/main.c:40
-msgid "Display monitors are maintained by d.mon."
-msgstr ""
-#: ../display/d.info/main.c:45
-msgid "Display screen rectangle (left, right, top, bottom)"
-msgstr ""
-#: ../display/d.info/main.c:49
-msgid "Display screen dimensions (width, height)"
-msgstr ""
-#: ../display/d.info/main.c:53
-msgid "Display active frame rectangle"
-msgstr ""
-#: ../display/d.info/main.c:57
-msgid "Display frame dimensions (width, height)"
-msgstr ""
-#: ../display/d.info/main.c:61
-msgid "Display screen rectangle of current region"
-msgstr ""
-#: ../display/d.info/main.c:66
-msgid "Display geographic coordinates and resolution of entire frame"
-msgstr ""
-#: ../display/d.grid/plot.c:373
-msgid "Geo-grid option only available for LL projection, use without -g/-w"
-msgstr ""
-#: ../display/d.grid/plot.c:575
-msgid ""
-"WGS84 grid output not possible as this location does not contain\n"
-msgstr ""
-#: ../display/d.grid/plot.c:743
-msgid "Error in pj_do_proj1"
-msgstr ""
-#: ../display/d.grid/plot.c:749
-msgid "Error in pj_do_proj2"
-msgstr ""
-#: ../display/d.grid/plot.c:753
-msgid "Error in pj_do_proj3"
-msgstr ""
-#: ../display/d.grid/plot.c:761
-msgid "Error in pj_do_proj5"
-msgstr ""
-#: ../display/d.grid/plot.c:765
-msgid "Error in pj_do_proj6"
-msgstr ""
-#: ../display/d.grid/fiducial.c:61
-msgid "Reading symbol"
-msgstr ""
-#: ../display/d.grid/main.c:55
-msgid "graticule"
-msgstr ""
-#: ../display/d.grid/main.c:56 ../vector/v.mkgrid/main.c:72
-msgid "grid"
-msgstr ""
-#: ../display/d.grid/main.c:58
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
-msgstr ""
-#: ../display/d.grid/main.c:66
-msgid "Size of grid to be drawn (in map units)"
-msgstr ""
-#: ../display/d.grid/main.c:68
-msgid ""
-"0 for north-south resolution of the current region. In map units or "
-"DDD:MM:SS format. Example: \"1000\" or \"0:10\""
-msgstr ""
-#: ../display/d.grid/main.c:76
-msgid "Lines of the grid pass through this coordinate"
-msgstr ""
-#: ../display/d.grid/main.c:85
-msgid "Draw only east-west lines, north-south lines, or both "
-msgstr ""
-#: ../display/d.grid/main.c:86 ../display/d.grid/main.c:159
-#: ../display/d.grid/main.c:164 ../display/d.grid/main.c:169
-msgid "Disable"
-msgstr ""
-#: ../display/d.grid/main.c:92
-msgid "Grid line width"
-msgstr ""
-#: ../display/d.grid/main.c:96 ../display/d.rast.num/main.c:94
-msgid "Grid color"
-msgstr ""
-#: ../display/d.grid/main.c:97 ../display/d.grid/main.c:102
-#: ../display/d.grid/main.c:108 ../display/d.grid/main.c:114
-msgid "Color"
-msgstr ""
-#: ../display/d.grid/main.c:101 ../display/d.legend.vect/main.c:95
-#: ../display/d.legend/main.c:240 ../vector/v.lrs/v.lrs.label/main.c:223
-#: ../vector/v.label/main.c:193 ../vector/v.label.sa/main.c:144
-msgid "Border color"
-msgstr ""
-#: ../display/d.grid/main.c:122
-msgid "Font size for gridline coordinate labels"
-msgstr ""
-#: ../display/d.grid/main.c:127
-msgid "Align the origin to the east-north corner of the current region"
-msgstr ""
-#: ../display/d.grid/main.c:132
-msgid "Draw geographic grid (referenced to current ellipsoid)"
-msgstr ""
-#: ../display/d.grid/main.c:133 ../display/d.grid/main.c:139
-#: ../display/d.grid/main.c:144 ../display/d.grid/main.c:149
-#: ../display/d.grid/main.c:154 ../misc/m.nviz.image/args.c:233
-#: ../misc/m.nviz.image/args.c:244 ../misc/m.nviz.image/args.c:255
-#: ../misc/m.nviz.image/args.c:267 ../misc/m.nviz.image/args.c:279
-#: ../misc/m.nviz.image/args.c:288 ../misc/m.nviz.image/args.c:298
-#: ../misc/m.nviz.image/args.c:608 ../misc/m.nviz.image/args.c:620
-msgid "Draw"
-msgstr ""
-#: ../display/d.grid/main.c:138
-msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
-msgstr ""
-#: ../display/d.grid/main.c:143
-msgid "Draw '+' marks instead of grid lines"
-msgstr ""
-#: ../display/d.grid/main.c:148
-msgid "Draw '.' marks instead of grid lines"
-msgstr ""
-#: ../display/d.grid/main.c:153
-msgid "Draw fiducial marks instead of grid lines"
-msgstr ""
-#: ../display/d.grid/main.c:158
-msgid "Disable grid drawing"
-msgstr ""
-#: ../display/d.grid/main.c:163
-msgid "Disable border drawing"
-msgstr ""
-#: ../display/d.grid/main.c:168
-msgid "Disable text drawing"
-msgstr ""
-#: ../display/d.grid/main.c:178
-msgid "Both grid and border drawing are disabled"
-msgstr ""
-#: ../display/d.grid/main.c:182
-msgid "Geo-grid option not available for LL projection, use without -g/-w"
-msgstr ""
-#: ../display/d.grid/main.c:184
-msgid "Geo-grid option not available for XY projection, use without -g/-w"
-msgstr ""
-#: ../display/d.grid/main.c:203
-msgid "Choose a single mark style"
-msgstr ""
-#: ../display/d.grid/main.c:234
-#, c-format
-msgid "Invalid geo-grid size <%s>"
-msgstr ""
-#: ../display/d.grid/main.c:239
-#, c-format
-msgid "Invalid grid size <%s>"
-msgstr ""
-#: ../display/d.labels/do_labels.c:142
-#, c-format
-msgid "Error: %s\n"
-msgstr ""
-#: ../display/d.labels/main.c:44 ../vector/v.label/main.c:60
-#: ../vector/v.label.sa/main.c:39
-msgid "paint labels"
-msgstr ""
-#: ../display/d.labels/main.c:46
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
-msgstr ""
-#: ../display/d.labels/main.c:52
-msgid "Ignore rotation setting and draw horizontally"
-msgstr ""
-#: ../display/d.labels/main.c:59
-msgid "Name of label file"
-msgstr ""
-#: ../display/d.labels/main.c:66
-msgid "Minimum region size (diagonal) when labels are displayed"
-msgstr ""
-#: ../display/d.labels/main.c:73
-msgid "Maximum region size (diagonal) when labels are displayed"
-msgstr ""
-#: ../display/d.labels/main.c:85
-#, c-format
-msgid "Label file <%s> not found"
-msgstr ""
-#: ../display/d.labels/main.c:97
-msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
-#: ../display/d.labels/main.c:105
-msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
-#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:283
-#, c-format
-msgid "Unable to open label file <%s>"
-msgstr ""
-#: ../display/d.rhumbline/main.c:46
-msgid "rhumbline"
-msgstr ""
-#: ../display/d.rhumbline/main.c:48
-msgid "Displays the rhumbline joining two longitude/latitude coordinates."
-msgstr ""
-#: ../display/d.vect.thematic/main.c:87
-msgid "choropleth map"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:88 ../display/d.legend.vect/main.c:53
-#: ../display/d.legend/main.c:80
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
-msgid "legend"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:90
-msgid "Displays a thematic vector map in the active graphics frame."
-msgstr ""
-#: ../display/d.vect.thematic/main.c:97
-msgid "Layer number. If -1, all layers are displayed."
-msgstr ""
-#: ../display/d.vect.thematic/main.c:103
-msgid "Name of attribute column to be classified"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:110
-msgid "Class breaks, without minimum and maximum"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:111 ../display/d.vect.thematic/main.c:129
-#: ../display/d.vect.thematic/main.c:137
-msgid "Classes"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:119 ../vector/v.class/main.c:68
-msgid "Algorithm to use for classification"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:123 ../vector/v.class/main.c:76
-msgid "simple intervals"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:124 ../vector/v.class/main.c:77
-msgid "standard deviations"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:125 ../vector/v.class/main.c:78
-msgid "quantiles"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:126 ../vector/v.class/main.c:79
-msgid "equiprobable (normal distribution)"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:136 ../vector/v.class/main.c:88
-msgid "Number of classes to define"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:144
-msgid "Colors (one per class)"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:154 ../display/d.vect.thematic/main.c:160
-msgid "Boundaries"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:155
-msgid "Boundary width"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:159
-msgid "Boundary color"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:168 ../display/d.vect.thematic/main.c:178
-#: ../display/d.vect/main.c:167 ../display/d.vect/main.c:177
-#: ../display/d.vect/main.c:184 ../display/d.vect/main.c:190
-#: ../display/d.vect/main.c:326
-msgid "Symbols"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:172 ../display/d.vect/main.c:171
-msgid "Point and centroid symbol"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:179 ../display/d.vect/main.c:178
-#: ../display/d.legend.vect/main.c:88
-msgid "Symbol size"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:186 ../display/d.vect.thematic/main.c:197
-#: ../display/d.vect.thematic/main.c:206 ../display/d.vect.thematic/main.c:218
-#: ../display/d.vect.thematic/main.c:224 ../display/d.vect.thematic/main.c:229
-#: ../display/d.vect.thematic/main.c:239 ../display/d.vect.thematic/main.c:244
-#: ../display/d.vect/main.c:201 ../display/d.vect/main.c:211
-#: ../display/d.vect/main.c:219 ../display/d.vect/main.c:331
-msgid "Legend"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:190
-msgid "Legend symbol for lines"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:201
-msgid "Legend symbol for areas"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:207
-msgid "Thematic map title"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:214 ../display/d.vect.thematic/main.c:236
-msgid "DEPRECATED"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:215
-msgid "Output legend file"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:228
-msgid "Do not draw map, only output the legend information"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:237
-msgid ""
-"When printing legend info, include extended statistical info from "
-"classification algorithm"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:243 ../display/d.vect/main.c:330
-msgid "Do not show this layer in vector legend"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:255
-msgid ""
-"Flag -e is deprecated, set verbose mode with --v to get the extended "
-"statistical info."
-msgstr ""
-#: ../display/d.vect.thematic/main.c:258
-msgid ""
-"Option legendfile is deprecated, either use flag -l to print legend to "
-"standard output, or set GRASS_LEGEND_FILE environment variable (see "
-"d.legend.vect for details)."
-msgstr ""
-#: ../display/d.vect.thematic/main.c:277
-#, c-format
-msgid "%s: You must build topology on vector map. Run v.build."
-msgstr ""
-#: ../display/d.vect.thematic/main.c:288
-msgid "'layer' must be > 0"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:290 ../display/d.vect/opt.c:143
-#: ../vector/v.db.connect/main.c:180
-msgid "Database connection not defined"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:312
-#, c-format
-msgid "Data (%s) not numeric. Column must be numeric."
-msgstr ""
-#: ../display/d.vect.thematic/main.c:316
-#: ../display/d.vect.thematic/plot1.c:135
-#: ../display/d.vect.thematic/plot1.c:163
-#, c-format
-msgid "Cannot select data (%s) from table"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:379
-#, c-format
-msgid "Unknown color: [%s]"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:390
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
-msgstr ""
-#: ../display/d.vect.thematic/main.c:427
-msgid "You must either give classbreaks or a classification algorithm"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:440
-#, c-format
-msgid ""
-"Not enough colors or error in color specifications.\n"
-"Need %i entries for 'colors' parameter"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:445
-#, c-format
-msgid "Error interpreting color %s"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:462
-msgid "Plotting ..."
-msgstr ""
-#: ../display/d.vect.thematic/main.c:474
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
-#: ../display/d.vect.thematic/main.c:523
-#, c-format
-msgid ""
-"\n"
-"Total number of records: %.0f\n"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:525
-#, c-format
-msgid "Classification of %s into %i classes\n"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:527 ../vector/v.class/main.c:203
-#, c-format
-msgid "Using algorithm: *** %s ***\n"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:529 ../vector/v.class/main.c:204
-#, c-format
-msgid "Mean: %f\tStandard deviation = %f\n"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:533
-#, c-format
-msgid "Last chi2 = %f\n"
-msgstr ""
-#: ../display/d.vect.thematic/main.c:535 ../vector/v.class/main.c:211
-#, c-format
-msgid "Stdev multiplied by %.4f to define step\n"
-msgstr ""
-#: ../display/d.vect.thematic/display.c:51 ../display/d.vect/lines.c:107
-#: ../display/d.vect/lines.c:335
-#, c-format
-msgid "Unable to read symbol <%s>, unable to display points"
-msgstr ""
-#: ../display/d.vect.thematic/display.c:118 ../display/d.vect/lines.c:175
-#, c-format
-msgid "%d point plotted"
-msgid_plural "%d points plotted"
-msgstr[0] ""
-#: ../display/d.vect.thematic/display.c:121 ../display/d.vect/lines.c:177
-#, c-format
-msgid "%d line plotted"
-msgid_plural "%d lines plotted"
-msgstr[0] ""
-#: ../display/d.vect.thematic/display.c:125 ../display/d.vect/lines.c:179
-#, c-format
-msgid "%d centroid plotted"
-msgid_plural "%d centroids plotted"
-msgstr[0] ""
-#: ../display/d.vect.thematic/display.c:129 ../display/d.vect/lines.c:181
-#, c-format
-msgid "%d boundary plotted"
-msgid_plural "%d boundaries plotted"
-msgstr[0] ""
-#: ../display/d.vect.thematic/display.c:132 ../display/d.vect/lines.c:183
-#, c-format
-msgid "%d face plotted"
-msgid_plural "%d faces plotted"
-msgstr[0] ""
-#: ../display/d.vect.thematic/plot1.c:120
-msgid "Color definition column not specified"
-msgstr ""
-#: ../display/d.vect.thematic/plot1.c:130
-#, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form "
-"RRR:GGG:BBB where RGB values range 0-255."
-msgstr ""
-#: ../display/d.vect.thematic/plot1.c:148
-msgid "Line width column not specified."
-msgstr ""
-#: ../display/d.vect.thematic/plot1.c:159
-#, c-format
-msgid "Line width column (%s) not a number."
-msgstr ""
-#: ../display/d.vect.thematic/plot1.c:204
-#, c-format
-msgid ""
-"\n"
-"ERROR: vector map - can't read\n"
-msgstr ""
-#: ../display/d.vect.thematic/plot1.c:279
-#, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
-msgstr ""
-#: ../display/d.vect.thematic/plot1.c:286
-#, c-format
-msgid "Error in color definition column (%s), element %d with cat %d"
-msgstr ""
-#: ../display/d.vect.thematic/plot1.c:354
-#, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr ""
-#: ../display/d.text/main.c:142
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
-msgstr ""
-#: ../display/d.text/main.c:148
-msgid "Text to display"
-msgstr ""
-#: ../display/d.text/main.c:153
-msgid "Input file"
-msgstr ""
-#: ../display/d.text/main.c:162
-msgid "Text color, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-#: ../display/d.text/main.c:171
-msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-#: ../display/d.text/main.c:181 ../display/d.northarrow/main.c:92
-#: ../vector/v.label/main.c:156
-msgid "Rotation angle in degrees (counter-clockwise)"
-msgstr ""
-#: ../display/d.text/main.c:189
-msgid "Line spacing"
-msgstr ""
-#: ../display/d.text/main.c:198
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
-msgstr ""
-#: ../display/d.text/main.c:207
-msgid "The screen line number on which text will begin to be drawn"
-msgstr ""
-#: ../display/d.text/main.c:216
-msgid "Text alignment"
-msgstr ""
-#: ../display/d.text/main.c:223 ../display/d.vect/main.c:266
-#: ../display/d.legend.vect/main.c:115 ../display/d.rast.num/main.c:119
-#: ../display/d.legend/main.c:210 ../vector/v.label/main.c:122
-msgid "Font name"
-msgstr ""
-#: ../display/d.text/main.c:224 ../display/d.text/main.c:234
-#: ../display/d.text/main.c:241 ../display/d.text/main.c:249
-#: ../display/d.text/main.c:274 ../display/d.legend.vect/main.c:116
-#: ../display/d.legend.vect/main.c:125 ../display/d.legend.vect/main.c:132
-#: ../display/d.legend.vect/main.c:148 ../display/d.legend.vect/main.c:157
-#: ../display/d.legend.vect/main.c:163 ../display/d.rast.num/main.c:120
-#: ../display/d.rast.num/main.c:127 ../display/d.rast.num/main.c:135
-#: ../display/d.legend/main.c:204 ../display/d.legend/main.c:211
-#: ../display/d.legend/main.c:220 ../display/d.legend/main.c:227
-#: ../display/d.legend/main.c:235
-msgid "Font settings"
-msgstr ""
-#: ../display/d.text/main.c:233
-msgid "Height of letters in percentage of available frame height"
-msgstr ""
-#: ../display/d.text/main.c:239 ../display/d.rast.num/main.c:125
-#: ../display/d.legend/main.c:225
-msgid "Path to font file"
-msgstr ""
-#: ../display/d.text/main.c:248 ../display/d.rast.num/main.c:134
-#: ../display/d.legend/main.c:234
-msgid "Text encoding (only applicable to TrueType fonts)"
-msgstr ""
-#: ../display/d.text/main.c:253
-msgid "Screen position in pixels ([0,0] is top left)"
-msgstr ""
-#: ../display/d.text/main.c:258
-msgid "Screen position in geographic coordinates"
-msgstr ""
-#: ../display/d.text/main.c:263
-msgid "Use bold text"
-msgstr ""
-#: ../display/d.text/main.c:268 ../display/d.northarrow/main.c:144
-msgid "Use radians instead of degrees for rotation"
-msgstr ""
-#: ../display/d.text/main.c:273
-msgid "Font size is height in pixels"
-msgstr ""
-#: ../display/d.text/main.c:385
-#, c-format
-msgid ""
-"\n"
-"Please enter text instructions.  Enter EOF (ctrl-d) on last line to quit\n"
-msgstr ""
-#: ../display/d.text/main.c:576
-#, c-format
-msgid "[%s]: No such color. Use '%s'"
-msgstr ""
-#: ../display/d.text/main.c:591
-msgid "Invalid coordinates"
-msgstr ""
-#: ../display/d.vect/area.c:37
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
-msgstr ""
-#: ../display/d.vect/area.c:135
-#, c-format
-msgid "Invalid area %d skipped (not enough points)"
-msgstr ""
-#: ../display/d.vect/area.c:234
-#, c-format
-msgid "%d invalid color rule for areas skipped"
-msgid_plural "%d invalid color rules for areas skipped"
-msgstr[0] ""
-#: ../display/d.vect/attr.c:28
-msgid "attrcol not specified, cannot display attributes"
-msgstr ""
-#: ../display/d.vect/attr.c:129
-#, c-format
-msgid "No attribute found for cat %d: %s"
-msgstr ""
-#: ../display/d.vect/label.c:33
-msgid "Topology level required for drawing centroids for OGR layers"
-msgstr ""
-#: ../display/d.vect/lines.c:121
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
-msgstr ""
-#: ../display/d.vect/lines.c:169
-#, c-format
-msgid "%d invalid color rule for lines skipped"
-msgid_plural "%d invalid color rules for lines skipped"
-msgstr[0] ""
-#: ../display/d.vect/opt.c:126
-#, c-format
-msgid "Unknown color: '%s'"
-msgstr ""
-#: ../display/d.vect/shape.c:53
-#, c-format
-msgid "Both color table and <%s> option detected. Color table will ignored."
-msgstr ""
-#: ../display/d.vect/shape.c:68
-#, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form "
-"'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to "
-"define color rules. Unable to colorize features."
-msgstr ""
-#: ../display/d.vect/shape.c:77 ../display/d.vect/shape.c:100
-#: ../display/d.vect/shape.c:131 ../display/d.vect/shape.c:162
-#, c-format
-msgid "Unable to select data ('%s') from table"
-msgstr ""
-#: ../display/d.vect/shape.c:85
-msgid "Line width column not specified"
-msgstr ""
-#: ../display/d.vect/shape.c:96
-#, c-format
-msgid "Line width column ('%s') not a number"
-msgstr ""
-#: ../display/d.vect/shape.c:116
-msgid "Symbol size column not specified"
-msgstr ""
-#: ../display/d.vect/shape.c:127
-#, c-format
-msgid "Symbol size column ('%s') is not numeric"
-msgstr ""
-#: ../display/d.vect/shape.c:147
-msgid "Symbol rotation column not specified"
-msgstr ""
-#: ../display/d.vect/shape.c:158
-#, c-format
-msgid "Symbol rotation column ('%s') is not numeric"
-msgstr ""
-#: ../display/d.vect/shape.c:182
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
-msgstr ""
-#: ../display/d.vect/shape.c:201
-msgid "Unable to colorize features, unknown map bounding box"
-msgstr ""
-#: ../display/d.vect/shape.c:338
-#, c-format
-msgid "Invalid negative value - feature %d with category %d"
-msgstr ""
-#: ../display/d.vect/topo.c:18
-msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
-msgstr ""
-#: ../display/d.vect/main.c:77
-msgid "Displays user-specified vector map in the active graphics frame."
-msgstr ""
-#: ../display/d.vect/main.c:93
-msgid "Display"
-msgstr ""
-#: ../display/d.vect/main.c:97
-msgid "Display geometry of features"
-msgstr ""
-#: ../display/d.vect/main.c:98
-msgid "Display category numbers of features"
-msgstr ""
-#: ../display/d.vect/main.c:99
-msgid "Display topology information (nodes, edges)"
-msgstr ""
-#: ../display/d.vect/main.c:100
-msgid "Display vertices of features"
-msgstr ""
-#: ../display/d.vect/main.c:101
-msgid "Display direction of linear features"
-msgstr ""
-#: ../display/d.vect/main.c:102
-msgid "Display z-coordinate of features (only for 3D vector maps)"
-msgstr ""
-#: ../display/d.vect/main.c:120
-msgid "Feature color"
-msgstr ""
-#: ../display/d.vect/main.c:126
-msgid "Area fill color"
-msgstr ""
-#: ../display/d.vect/main.c:132
-msgid "Colorize features according to color definition column"
-msgstr ""
-#: ../display/d.vect/main.c:133 ../vector/v.out.lidar/main.c:546
-msgid "Color definition in R:G:B form"
-msgstr ""
-#: ../display/d.vect/main.c:137
-msgid "Colorize point or area features according to z-coordinate"
-msgstr ""
-#: ../display/d.vect/main.c:145 ../display/d.vect/main.c:150
-#: ../display/d.vect/main.c:158
-msgid "Lines"
-msgstr ""
-#: ../display/d.vect/main.c:146 ../display/d.northarrow/main.c:121
-msgid "Line width"
-msgstr ""
-#: ../display/d.vect/main.c:151
-msgid "Name of numeric column containing line width"
-msgstr ""
-#: ../display/d.vect/main.c:152
-msgid "These values will be scaled by width_scale"
-msgstr ""
-#: ../display/d.vect/main.c:159
-msgid "Scale factor for width_column"
-msgstr ""
-#: ../display/d.vect/main.c:180
-msgid "When used with the size_column option this becomes the scale factor"
-msgstr ""
-#: ../display/d.vect/main.c:186
-msgid "Name of numeric column containing symbol size"
-msgstr ""
-#: ../display/d.vect/main.c:192
-msgid "Name of numeric column containing symbol rotation angle"
-msgstr ""
-#: ../display/d.vect/main.c:194
-msgid "Measured in degrees CCW from east"
-msgstr ""
-#: ../display/d.vect/main.c:204
-msgid "Area/boundary symbol for legend"
-msgstr ""
-#: ../display/d.vect/main.c:214
-msgid "Line symbol for legend"
-msgstr ""
-#: ../display/d.vect/main.c:220
-msgid "Label to display after symbol in vector legend"
-msgstr ""
-#: ../display/d.vect/main.c:226 ../display/d.vect/main.c:233
-#: ../display/d.vect/main.c:240 ../display/d.vect/main.c:245
-#: ../display/d.vect/main.c:252 ../display/d.vect/main.c:259
-#: ../display/d.vect/main.c:265 ../display/d.vect/main.c:271
-#: ../display/d.vect/main.c:277 ../display/d.vect/main.c:285
-msgid "Labels"
-msgstr ""
-#: ../display/d.vect/main.c:228
-msgid "Layer number for labels (default: the given layer number)"
-msgstr ""
-#: ../display/d.vect/main.c:234
-msgid "Name of column to be displayed as a label"
-msgstr ""
-#: ../display/d.vect/main.c:239
-msgid "Label color"
-msgstr ""
-#: ../display/d.vect/main.c:246
-msgid "Label background color"
-msgstr ""
-#: ../display/d.vect/main.c:253
-msgid "Label border color"
-msgstr ""
-#: ../display/d.vect/main.c:260
-msgid "Label size (pixels)"
-msgstr ""
-#: ../display/d.vect/main.c:272
-msgid "Text encoding"
-msgstr ""
-#: ../display/d.vect/main.c:280
-msgid "Label horizontal justification"
-msgstr ""
-#: ../display/d.vect/main.c:288
-msgid "Label vertical justification"
-msgstr ""
-#: ../display/d.vect/main.c:295
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
-msgstr ""
-#: ../display/d.vect/main.c:303
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
-msgstr ""
-#: ../display/d.vect/main.c:311
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is"
-" given)"
-msgstr ""
-#: ../display/d.vect/main.c:318
-msgid "Use values from 'cats' option as feature id"
-msgstr ""
-#: ../display/d.vect/main.c:322
-msgid "Use square root of the value of size_column"
-msgstr ""
-#: ../display/d.vect/main.c:324
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
-msgstr ""
-#: ../display/d.vect/main.c:349
-msgid "Region size is lower than minreg, nothing displayed"
-msgstr ""
-#: ../display/d.vect/main.c:357
-msgid "Region size is greater than maxreg, nothing displayed"
-msgstr ""
-#: ../display/d.vect/main.c:370
-#, c-format
-msgid ""
-"The -%c flag and <%s> option cannot be used together, the -%c flag will be "
-"ignored!"
-msgstr ""
-#: ../display/d.vect/main.c:394 ../display/d.vect/main.c:400
-#, c-format
-msgid "Option <%s> must be > 0"
-msgstr ""
-#: ../display/d.vect/main.c:404
-#, c-format
-msgid "%d error in cat option"
-msgid_plural "%d errors in cat option"
-msgstr[0] ""
-#: ../display/d.vect/main.c:420
-msgid "Plotting..."
-msgstr ""
-#: ../display/d.vect/main.c:431
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
-msgstr ""
-#: ../display/d.vect/main.c:502
-msgid "Rendering failed"
-msgstr ""
-#: ../display/d.vect/zcoor.c:19
-msgid "Vector map is not 3D. Unable to display z-coordinates."
-msgstr ""
-#: ../display/d.colorlist/main.c:37
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:5
-msgid "colors"
-msgstr ""
-#: ../display/d.colorlist/main.c:39
-msgid "Outputs a list of all available display colors."
-msgstr ""
-#: ../display/d.font/main.c:48
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
-#: ../display/d.font/main.c:56
-msgid "Choose new current font"
-msgstr ""
-#: ../display/d.font/main.c:62
-msgid "Path to Freetype-compatible font including file name"
-msgstr ""
-#: ../display/d.font/main.c:70
-msgid "Character encoding"
-msgstr ""
-#: ../display/d.font/main.c:74
-msgid "List fonts"
-msgstr ""
-#: ../display/d.font/main.c:78 ../display/d.fontlist/main.c:55
-msgid "List fonts verbosely"
-msgstr ""
-#: ../display/d.font/main.c:103
-#, c-format
-msgid "Unable to access font path %s: %s"
-msgstr ""
-#: ../display/d.font/main.c:107
-#, c-format
-msgid "Font path %s is not a file"
-msgstr ""
-#: ../display/d.font/main.c:124
-#, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
-msgstr ""
-#: ../display/d.colortable/main.c:64
-msgid "Displays the color table associated with a raster map layer."
-msgstr ""
-#: ../display/d.colortable/main.c:68
-msgid "Name of raster map whose color table is to be displayed"
-msgstr ""
-#: ../display/d.colortable/main.c:73
-msgid "Color of lines separating the colors of the color table"
-msgstr ""
-#: ../display/d.colortable/main.c:79
-msgid "Number of lines to appear in the color table"
-msgstr ""
-#: ../display/d.colortable/main.c:85
-msgid "Number of columns to appear in the color table"
-msgstr ""
-#: ../display/d.colortable/main.c:90
-msgid "Do not draw a collar showing the NULL color in FP maps"
-msgstr ""
-#: ../display/d.colortable/main.c:112
-#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
-msgstr ""
-#: ../display/d.colortable/main.c:126
-#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
-msgstr ""
-#: ../display/d.colortable/main.c:137
-#, c-format
-msgid "Range file for <%s> not available"
-msgstr ""
-#: ../display/d.fontlist/main.c:47
-msgid "Lists the available fonts."
-msgstr ""
-#: ../display/d.fontlist/main.c:51
-msgid "List fonts (default; provided for compatibility with d.font)"
-msgstr ""
-#: ../display/d.legend.vect/main.c:55
-msgid "Displays a vector legend in the active graphics frame."
-msgstr ""
-#: ../display/d.legend.vect/main.c:66
-msgid ""
-"Screen position of legend to be drawn (percentage, [0,0] is lower left)"
-msgstr ""
-#: ../display/d.legend.vect/main.c:74
-msgid "Number of legend columns"
-msgstr ""
-#: ../display/d.legend.vect/main.c:75 ../display/d.legend.vect/main.c:90
-msgid "Layout"
-msgstr ""
-#: ../display/d.legend.vect/main.c:81 ../display/d.legend/main.c:99
-msgid "Legend title"
-msgstr ""
-#: ../display/d.legend.vect/main.c:82 ../display/d.legend.vect/main.c:141
-#: ../display/d.legend/main.c:100 ../display/d.legend/main.c:109
-msgid "Title"
-msgstr ""
-#: ../display/d.legend.vect/main.c:96 ../display/d.legend.vect/main.c:102
-#: ../display/d.legend.vect/main.c:109 ../display/d.legend.vect/main.c:168
-#: ../display/d.legend/main.c:241 ../display/d.legend/main.c:247
-#: ../display/d.legend/main.c:288
-msgid "Background"
-msgstr ""
-#: ../display/d.legend.vect/main.c:108
-msgid "Background border width"
-msgstr ""
-#: ../display/d.legend.vect/main.c:124
-msgid "Default: 12"
-msgstr ""
-#: ../display/d.legend.vect/main.c:131
-msgid "Title font name"
-msgstr ""
-#: ../display/d.legend.vect/main.c:139 ../display/d.legend/main.c:107
-msgid "Title font size"
-msgstr ""
-#: ../display/d.legend.vect/main.c:140
-msgid "Default: 18"
-msgstr ""
-#: ../display/d.legend.vect/main.c:147
-msgid "Subtitle font name"
-msgstr ""
-#: ../display/d.legend.vect/main.c:155
-msgid "Subtitle font size"
-msgstr ""
-#: ../display/d.legend.vect/main.c:156
-msgid "Default: 14"
-msgstr ""
-#: ../display/d.legend.vect/main.c:162
-msgid "Font color"
-msgstr ""
-#: ../display/d.legend.vect/main.c:167
-msgid "Display legend background"
-msgstr ""
-#: ../display/d.legend.vect/main.c:171 ../display/d.legend.vect/main.c:178
-#: ../display/d.legend.vect/main.c:185
-msgid "In/Out"
-msgstr ""
-#: ../display/d.legend.vect/main.c:172
-msgid "Field separator for input file"
-msgstr ""
-#: ../display/d.legend.vect/main.c:175
-msgid "Input legend file"
-msgstr ""
-#: ../display/d.legend.vect/main.c:176
-msgid "Path to legend file "
-msgstr ""
-#: ../display/d.legend.vect/main.c:181
-msgid "Output csv file"
-msgstr ""
-#: ../display/d.legend.vect/main.c:182
-msgid "Path to output file or '-' for standard output"
-msgstr ""
-#: ../display/d.legend.vect/draw.c:178
-msgid "Cannot read symbol"
-msgstr ""
-#: ../display/d.legend.vect/draw.c:238
-msgid "Invalid value for color type in legend file. Use one of 'lf' or 'ps'."
-msgstr ""
-#: ../display/d.northarrow/draw_n_arrow.c:108
-#: ../display/d.northarrow/draw_n_arrow.c:174
-msgid "Could not parse symbol"
-msgstr ""
-#: ../display/d.northarrow/main.c:49
-msgid "Displays a north arrow on the graphics monitor."
-msgstr ""
-#: ../display/d.northarrow/main.c:53
-msgid "North arrow style"
-msgstr ""
-#: ../display/d.northarrow/main.c:61
-msgid "Two color arrowhead"
-msgstr ""
-#: ../display/d.northarrow/main.c:62
-msgid "Two color arrowhead with circle"
-msgstr ""
-#: ../display/d.northarrow/main.c:63
-msgid "Narrow with blending N"
-msgstr ""
-msgid "Long with small arrowhead"
-msgstr ""
-#: ../display/d.northarrow/main.c:64
-msgid "Inverted narrow inside a circle"
-msgstr ""
-#: ../display/d.northarrow/main.c:65
-msgid "Triangle and N inside a circle"
-msgstr ""
-#: ../display/d.northarrow/main.c:66
-msgid "Arrowhead and N inside a circle"
-msgstr ""
-#: ../display/d.northarrow/main.c:67
-msgid "Tall half convex arrowhead"
-msgstr ""
-#: ../display/d.northarrow/main.c:68
-msgid "Tall half concave arrowhead"
-msgstr ""
-msgid "Thin arrow in a circle"
-msgstr ""
-#: ../display/d.northarrow/main.c:69
-msgid "Fat arrow in a circle"
-msgstr ""
-msgid "One color arrowhead"
-msgstr ""
-#: ../display/d.northarrow/main.c:70
-msgid "Fancy compass"
-msgstr ""
-msgid "Basic compass"
-msgstr ""
-msgid "Simple arrow"
-msgstr ""
-#: ../display/d.northarrow/main.c:71
-msgid "Thin arrow"
-msgstr ""
-msgid "Fat arrow"
-msgstr ""
-msgid "4-point star"
-msgstr ""
-#: ../display/d.northarrow/main.c:99
-msgid "Displayed letter on the top of arrow"
-msgstr ""
-#: ../display/d.northarrow/main.c:108
-msgid "Fill color"
-msgstr ""
-#: ../display/d.northarrow/main.c:134
-msgid "Draw the symbol without text"
-msgstr ""
-#: ../display/d.northarrow/main.c:139
-msgid "Do not rotate text with symbol"
-msgstr ""
-#: ../display/d.rast.num/main.c:81
-msgid ""
-"Overlays cell category values on a raster map displayed in the active "
-"graphics frame."
-msgstr ""
-#: ../display/d.rast.num/main.c:112
-msgid "Get text color from cell color value"
-msgstr ""
-#: ../display/d.rast.num/main.c:200
-#, c-format
-msgid "%d col"
-msgid_plural "%d cols"
-msgstr[0] ""
-#. GTC %s will be replaced by strings "X rows" and "Y cols"
-#: ../display/d.rast.num/main.c:202
-#, c-format
-msgid ""
-"Current region size: %s X %s\n"
-"Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
-msgstr ""
-#: ../display/d.rast.num/main.c:212
-msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
-msgstr ""
-#: ../display/d.path/main.c:49 ../vector/v.net.spanningtree/main.c:47
-#: ../vector/v.net.timetable/main.c:261 ../vector/v.net.alloc/main.c:65
-#: ../vector/v.net.bridge/main.c:48 ../vector/v.net.components/main.c:73
-#: ../vector/v.net.steiner/main.c:347 ../vector/v.net.centrality/main.c:97
-#: ../vector/v.net.distance/main.c:67 ../vector/v.net.allpairs/main.c:62
-#: ../vector/v.net.visibility/main.c:46 ../vector/v.net.connectivity/main.c:53
-#: ../vector/v.net/main.c:48 ../vector/v.net.flow/main.c:59
-#: ../vector/v.net.path/main.c:43 ../vector/v.lrs/v.lrs.segment/main.c:73
-#: ../vector/v.lrs/v.lrs.label/main.c:104
-#: ../vector/v.lrs/v.lrs.where/main.c:59
-#: ../vector/v.lrs/v.lrs.create/main.c:123 ../vector/v.net.iso/main.c:77
-#: ../vector/v.net.salesman/main.c:128
-msgid "network"
-msgstr ""
-#: ../display/d.path/main.c:52
-msgid "Finds shortest path for selected starting and ending node."
-msgstr ""
-#: ../display/d.path/main.c:60 ../vector/v.net.alloc/main.c:103
-#: ../vector/v.net.steiner/main.c:363 ../vector/v.net.distance/main.c:89
-#: ../vector/v.net/args.c:63 ../vector/v.net.path/main.c:61
-#: ../vector/v.net.iso/main.c:124 ../vector/v.net.salesman/main.c:156
-msgid "Arc type"
-msgstr ""
-#: ../display/d.path/main.c:70 ../vector/v.net.spanningtree/main.c:59
-#: ../vector/v.net.timetable/main.c:274 ../vector/v.net.alloc/main.c:96
-#: ../vector/v.net.bridge/main.c:60 ../vector/v.net.components/main.c:84
-#: ../vector/v.net.steiner/main.c:368 ../vector/v.net.centrality/main.c:109
-#: ../vector/v.net.distance/main.c:82 ../vector/v.net.allpairs/main.c:74
-#: ../vector/v.net.connectivity/main.c:64 ../vector/v.net/args.c:56
-#: ../vector/v.net.flow/main.c:70 ../vector/v.net.path/main.c:54
-#: ../vector/v.net.iso/main.c:117 ../vector/v.net.salesman/main.c:149
-msgid "Arc layer"
-msgstr ""
-#: ../display/d.path/main.c:75 ../vector/v.net.spanningtree/main.c:65
-#: ../vector/v.net.timetable/main.c:280 ../vector/v.net.alloc/main.c:109
-#: ../vector/v.net.bridge/main.c:66 ../vector/v.net.components/main.c:90
-#: ../vector/v.net.centrality/main.c:115 ../vector/v.net.distance/main.c:95
-#: ../vector/v.net.allpairs/main.c:80 ../vector/v.net.connectivity/main.c:70
-#: ../vector/v.net/args.c:70 ../vector/v.net.flow/main.c:76
-#: ../vector/v.net.path/main.c:67 ../vector/v.net.iso/main.c:130
-msgid "Node layer"
-msgstr ""
-#: ../display/d.path/main.c:81 ../vector/v.net.spanningtree/main.c:72
-#: ../vector/v.net.timetable/main.c:288 ../vector/v.net.alloc/main.c:114
-#: ../vector/v.net.bridge/main.c:73 ../vector/v.net.components/main.c:97
-#: ../vector/v.net.centrality/main.c:129 ../vector/v.net.distance/main.c:141
-#: ../vector/v.net.allpairs/main.c:93 ../vector/v.net.connectivity/main.c:77
-#: ../vector/v.net.flow/main.c:90 ../vector/v.net.path/main.c:79
-#: ../vector/v.net.iso/main.c:135 ../vector/v.net.salesman/main.c:168
-msgid "Arc forward/both direction(s) cost column (number)"
-msgstr ""
-#: ../display/d.path/main.c:87 ../vector/v.net.timetable/main.c:295
-#: ../vector/v.net.alloc/main.c:119 ../vector/v.net.bridge/main.c:79
-#: ../vector/v.net.components/main.c:103 ../vector/v.net.centrality/main.c:135
-#: ../vector/v.net.distance/main.c:147 ../vector/v.net.allpairs/main.c:99
-#: ../vector/v.net.connectivity/main.c:83 ../vector/v.net.flow/main.c:96
-#: ../vector/v.net.path/main.c:86 ../vector/v.net.iso/main.c:140
-msgid "Arc backward direction cost column (number)"
-msgstr ""
-#: ../display/d.path/main.c:93
-msgid "Node cost column"
-msgstr ""
-#: ../display/d.path/main.c:101 ../display/d.path/main.c:109
-#: ../display/d.path/main.c:117 ../display/d.path/main.c:127
-msgid "Rendering"
-msgstr ""
-#: ../display/d.path/main.c:122 ../vector/v.net.spanningtree/main.c:84
-#: ../vector/v.net.alloc/main.c:151 ../vector/v.net.steiner/main.c:398
-#: ../vector/v.net.centrality/main.c:188 ../vector/v.net.distance/main.c:159
-#: ../vector/v.net.allpairs/main.c:112 ../vector/v.net.path/main.c:132
-#: ../vector/v.net.iso/main.c:172 ../vector/v.net.salesman/main.c:208
-msgid "Use geodesic calculation for longitude-latitude locations"
-msgstr ""
-#: ../display/d.path/main.c:126
-msgid "Render bold lines"
-msgstr ""
-#: ../display/d.path/main.c:143 ../display/d.path/main.c:147
-#, c-format
-msgid "%s - illegal x value"
-msgstr ""
-#: ../display/d.path/main.c:145 ../display/d.path/main.c:149
-#, c-format
-msgid "%s - illegal y value"
-msgstr ""
-#: ../display/d.path/main.c:178 ../vector/v.net.spanningtree/main.c:113
-#: ../vector/v.net.centrality/main.c:222 ../vector/v.net.distance/main.c:205
-#: ../vector/v.net.allpairs/main.c:142 ../vector/v.net.path/main.c:148
-msgid "The current projection is not longitude-latitude"
-msgstr ""
-#: ../display/d.path/select.c:84 ../display/d.path/select.c:101
-#, c-format
-msgid "Node %d: %f %f\n"
-msgstr ""
-#: ../display/d.path/select.c:122
-#, c-format
-msgid "Destination unreachable\n"
-msgstr ""
-#: ../display/d.path/select.c:125
-#, c-format
-msgid "Costs on the network = %f\n"
-msgstr ""
-#: ../display/d.path/select.c:126
-#, c-format
-msgid ""
-"  Distance to the network = %f, distance from the network = %f\n"
-"\n"
-msgstr ""
-#: ../display/d.legend/main.c:82
-msgid ""
-"Displays a legend for a 2D or 3D raster map in the active frame of the "
-msgstr ""
-#: ../display/d.legend/main.c:108
-msgid "Default: Same as fontsize"
-msgstr ""
-#: ../display/d.legend/main.c:117
-msgid "Number of text lines (useful for truncating long legends)"
-msgstr ""
-#: ../display/d.legend/main.c:127
-msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
-msgstr ""
-#: ../display/d.legend/main.c:135
-msgid "Units to display after labels (e.g. meters)"
-msgstr ""
-#: ../display/d.legend/main.c:144
-msgid "Number of text labels for smooth gradient legend"
-msgstr ""
-#: ../display/d.legend/main.c:145 ../display/d.legend/main.c:154
-#: ../display/d.legend/main.c:161 ../display/d.legend/main.c:263
-#: ../display/d.legend/main.c:273 ../display/d.legend/main.c:283
-msgid "Gradient"
-msgstr ""
-#: ../display/d.legend/main.c:151
-msgid "Specific values to draw ticks"
-msgstr ""
-#: ../display/d.legend/main.c:160
-msgid "Display label every step"
-msgstr ""
-#: ../display/d.legend/main.c:167
-msgid "Number of digits after decimal point"
-msgstr ""
-#: ../display/d.legend/main.c:179
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
-msgstr ""
-#: ../display/d.legend/main.c:189
-msgid "List of discrete category numbers/values for legend"
-msgstr ""
-#: ../display/d.legend/main.c:191 ../display/d.legend/main.c:200
-msgid "Subset"
-msgstr ""
-#: ../display/d.legend/main.c:199
-msgid "Use a subset of the map range for the legend (min,max)"
-msgstr ""
-#: ../display/d.legend/main.c:219
-msgid "Default: Auto-scaled"
-msgstr ""
-#: ../display/d.legend/main.c:252
-msgid "Do not show category labels"
-msgstr ""
-#: ../display/d.legend/main.c:257
-msgid "Do not show category numbers"
-msgstr ""
-#: ../display/d.legend/main.c:262
-msgid "Draw legend ticks for labels"
-msgstr ""
-#: ../display/d.legend/main.c:267
-msgid "Skip categories with no label"
-msgstr ""
-#: ../display/d.legend/main.c:272
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
-msgid "Draw smooth gradient"
-msgstr ""
-#: ../display/d.legend/main.c:277
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
-msgid "Flip legend"
-msgstr ""
-#: ../display/d.legend/main.c:282
-msgid "Add histogram to smoothed legend"
-msgstr ""
-#: ../display/d.legend/main.c:287
-msgid "Show background"
-msgstr ""
-#: ../display/d.legend/main.c:292
-msgid "Use logarithmic scale"
-msgstr ""
-#: ../display/d.legend/draw.c:109
-msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr ""
-#: ../display/d.legend/draw.c:114
-msgid "Drawing horizontal legend as box width exceeds height"
-msgstr ""
-#: ../display/d.legend/draw.c:126
-#, c-format
-msgid "Range information for <%s> not available (run r.support)"
-msgstr ""
-#: ../display/d.legend/draw.c:131
-msgid "Input map contains no data"
-msgstr ""
-#: ../display/d.legend/draw.c:145
-msgid "Requested range exceeds lower limit of actual data"
-msgstr ""
-#: ../display/d.legend/draw.c:152
-msgid "Requested range exceeds upper limit of actual data"
-msgstr ""
-#: ../display/d.legend/draw.c:214
-#, c-format
-msgid "use=%s out of range [%d,%d] (extend with range= ?)"
-msgstr ""
-#: ../display/d.legend/draw.c:239
-msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr ""
-#: ../display/d.legend/draw.c:250
-msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr ""
-#: ../display/d.legend/draw.c:301
-msgid "Color range exceeds lower limit of actual data"
-msgstr ""
-#: ../display/d.legend/draw.c:305
-msgid "Color range exceeds upper limit of actual data"
-msgstr ""
-#: ../display/d.legend/draw.c:312
-#, c-format
-msgid "Range [%.3f, %.3f] out of the logarithm domain."
-msgstr ""
-#: ../display/d.legend/draw.c:319
-#, c-format
-msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
-msgstr ""
-#: ../display/d.legend/draw.c:613
-#, c-format
-msgid "tick_value=%.3f out of range [%.3f, %.3f]"
-msgstr ""
-#: ../display/d.legend/draw.c:1029
-msgid ""
-"Histogram plotting not implemented for categorical legends. Use the '-s' "
-"flag"
-msgstr ""
-#: ../display/d.legend/draw.c:1286
-msgid "Nothing to draw! (no categories with labels?)"
-msgstr ""
-#: ../display/d.legend/histogram.c:115
-msgid ""
-"Histogram constrained by range not yet implemented for categorical rasters"
-msgstr ""
-#: ../imagery/i.vi/main.c:89 ../imagery/i.cca/main.c:84
-#: ../imagery/i.ifft/main.c:77 ../imagery/i.modis.qc/main.c:168
-#: ../imagery/i.evapo.mh/main.c:69 ../imagery/i.group/main.c:52
-#: ../imagery/i.gensig/main.c:39 ../imagery/i.eb.hsebal01/main.c:104
-#: ../imagery/i.smap/main.c:38 ../imagery/i.albedo/main.c:95
-#: ../imagery/i.cluster/main.c:75 ../imagery/i.landsat.toar/main.c:70
-#: ../imagery/i.zc/main.c:53 ../imagery/i.pca/main.c:72
-#: ../imagery/i.evapo.pt/main.c:66 ../imagery/i.fft/main.c:78
-#: ../imagery/i.aster.toar/main.c:97 ../imagery/i.topo.corr/main.c:47
-#: ../imagery/i.rgb.his/main.c:46 ../imagery/i.his.rgb/main.c:46
-#: ../imagery/i.eb.evapfr/main.c:47 ../imagery/i.biomass/main.c:50
-#: ../imagery/i.emissivity/main.c:44 ../imagery/i.landsat.acca/main.c:105
-#: ../imagery/i.eb.netrad/main.c:56 ../imagery/i.evapo.time/main.c:77
-#: ../imagery/i.target/main.c:45 ../imagery/i.evapo.pm/main.c:58
-#: ../imagery/i.segment/main.c:36 ../imagery/i.gensigset/main.c:40
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:390
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:64
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:87
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:56
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:47
-#: ../imagery/i.ortho.photo/i.ortho.target/main.c:47
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:46
-#: ../imagery/i.maxlik/main.c:61 ../imagery/i.eb.eta/main.c:42
-#: ../imagery/i.rectify/main.c:83 ../imagery/i.eb.soilheatflux/main.c:49
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:2
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#: ../locale/scriptstrings/i.oif_to_translate.c:2
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:2
-#: ../locale/scriptstrings/i.spectral_to_translate.c:2
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
-msgid "imagery"
-msgstr ""
-#: ../imagery/i.vi/main.c:90
-msgid "vegetation index"
-msgstr ""
-#: ../imagery/i.vi/main.c:91
-msgid "biophysical parameters"
-msgstr ""
-#: ../imagery/i.vi/main.c:92
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
-msgid "NDVI"
-msgstr ""
-#: ../imagery/i.vi/main.c:94
-msgid "Calculates different types of vegetation indices."
-msgstr ""
-#: ../imagery/i.vi/main.c:95
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
-msgstr ""
-#: ../imagery/i.vi/main.c:102
-msgid "Name of input red channel surface reflectance map"
-msgstr ""
-#: ../imagery/i.vi/main.c:103 ../imagery/i.vi/main.c:142
-#: ../imagery/i.vi/main.c:150 ../imagery/i.vi/main.c:158
-#: ../imagery/i.vi/main.c:166 ../imagery/i.vi/main.c:174
-msgid "Range: [0.0;1.0]"
-msgstr ""
-#: ../imagery/i.vi/main.c:111
-msgid "Type of vegetation index"
-msgstr ""
-#: ../imagery/i.vi/main.c:116
-msgid "Atmospherically Resistant Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:117
-msgid "Difference Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:118
-msgid "Enhanced Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:119
-msgid "Enhanced Vegetation Index 2"
-msgstr ""
-#: ../imagery/i.vi/main.c:120
-msgid "Green Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:121
-msgid "Green Atmospherically Resistant Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:122
-msgid "Global Environmental Monitoring Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:123
-msgid "Infrared Percentage Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:124
-msgid "Modified Soil Adjusted Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:125
-msgid "second Modified Soil Adjusted Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:126
-msgid "Normalized Difference Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:127
-msgid "Perpendicular Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:128
-msgid "Soil Adjusted Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:129
-msgid "Simple Ratio"
-msgstr ""
-#: ../imagery/i.vi/main.c:130
-msgid "Visible Atmospherically Resistant Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:131
-msgid "Weighted Difference Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:135
-msgid "type"
-msgstr ""
-#: ../imagery/i.vi/main.c:141
-msgid "Name of input nir channel surface reflectance map"
-msgstr ""
-#: ../imagery/i.vi/main.c:143 ../imagery/i.vi/main.c:151
-#: ../imagery/i.vi/main.c:159 ../imagery/i.vi/main.c:167
-#: ../imagery/i.vi/main.c:175 ../vector/v.vol.rst/main.c:256
-#: ../vector/v.vol.rst/main.c:305
-msgid "Optional inputs"
-msgstr ""
-#: ../imagery/i.vi/main.c:149
-msgid "Name of input green channel surface reflectance map"
-msgstr ""
-#: ../imagery/i.vi/main.c:157
-msgid "Name of input blue channel surface reflectance map"
-msgstr ""
-#: ../imagery/i.vi/main.c:165
-msgid "Name of input 5th channel surface reflectance map"
-msgstr ""
-#: ../imagery/i.vi/main.c:173
-msgid "Name of input 7th channel surface reflectance map"
-msgstr ""
-#: ../imagery/i.vi/main.c:181
-msgid "Value of the slope of the soil line (MSAVI only)"
-msgstr ""
-#: ../imagery/i.vi/main.c:182 ../imagery/i.vi/main.c:189
-#: ../imagery/i.vi/main.c:196
-msgid "MSAVI settings"
-msgstr ""
-#: ../imagery/i.vi/main.c:188
-msgid "Value of the intercept of the soil line (MSAVI only)"
-msgstr ""
-#: ../imagery/i.vi/main.c:195
-msgid "Value of the factor of reduction of soil noise (MSAVI only)"
-msgstr ""
-#: ../imagery/i.vi/main.c:202
-msgid "Maximum bits for digital numbers"
-msgstr ""
-#: ../imagery/i.vi/main.c:203
-msgid ""
-"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8"
-" for Landsat -> [0-255])"
-msgstr ""
-#: ../imagery/i.vi/main.c:229
-msgid "sr index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:232
-msgid "ndvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:235
-msgid "ipvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:238
-msgid "dvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:241
-msgid "pvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:244
-msgid "wdvi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:247
-msgid "savi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:252
-msgid ""
-"msavi index requires red and nir maps, and 3 parameters related to soil line"
-msgstr ""
-#: ../imagery/i.vi/main.c:255
-msgid "msavi2 index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:258
-msgid "gemi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:262
-msgid "arvi index requires blue, red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:266
-msgid "evi index requires blue, red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:269
-msgid "evi2 index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:273
-msgid "vari index requires blue, green and red maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:277
-msgid "gari index requires blue, green, red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:282
-msgid "gvi index requires blue, green, red, nir, chan5 and chan7 maps"
-msgstr ""
-#: ../imagery/i.cca/transform.c:24
-msgid "Unable to allocate cell buffers."
-msgstr ""
-#: ../imagery/i.cca/transform.c:58
-msgid "Transform completed.\n"
-msgstr ""
-#: ../imagery/i.cca/main.c:87
-msgid "canonical components analysis"
-msgstr ""
-#: ../imagery/i.cca/main.c:89
-msgid "Canonical components analysis (CCA) program for image processing."
-msgstr ""
-#: ../imagery/i.cca/main.c:96
-msgid "Name of input imagery subgroup"
-msgstr ""
-#: ../imagery/i.cca/main.c:103
-msgid "File containing spectral signatures"
-msgstr ""
-#: ../imagery/i.cca/main.c:106
-msgid "Output raster map prefix name"
-msgstr ""
-#: ../imagery/i.cca/main.c:114
-msgid "Unknown imagery group."
-msgstr ""
-#: ../imagery/i.cca/main.c:117
-msgid "Unable to find subgroup reference information."
-msgstr ""
-#: ../imagery/i.cca/main.c:123
-msgid "Unable to open the signature file"
-msgstr ""
-#: ../imagery/i.cca/main.c:127
-msgid "Error while reading the signatures file."
-msgstr ""
-#: ../imagery/i.cca/main.c:132
-msgid "Need at least two signatures in signature file."
-msgstr ""
-#: ../imagery/i.cca/main.c:226
-#, c-format
-msgid "The output cell map <%s.%d> has values outside the 0-255 range."
-msgstr ""
-#: ../imagery/i.ifft/main.c:79 ../imagery/i.fft/main.c:80
-msgid "Fast Fourier Transform"
-msgstr ""
-#: ../imagery/i.ifft/main.c:81
-msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
-msgstr ""
-#: ../imagery/i.ifft/main.c:86
-msgid "Name of input raster map (image fft, real part)"
-msgstr ""
-#: ../imagery/i.ifft/main.c:90
-msgid "Name of input raster map (image fft, imaginary part"
-msgstr ""
-#: ../imagery/i.ifft/main.c:93 ../vector/v.kernel/main.c:133
-#: ../locale/scriptstrings/r.import_to_translate.c:11
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
-msgid "Name for output raster map"
-msgstr ""
-#: ../imagery/i.ifft/main.c:115
-msgid "The real and imaginary original windows did not match"
-msgstr ""
-#: ../imagery/i.ifft/main.c:141 ../imagery/i.cluster/main.c:293
-#: ../imagery/i.gensigset/read_data.c:22
-msgid "Reading raster maps..."
-msgstr ""
-#: ../imagery/i.ifft/main.c:157
-msgid "Masking raster maps..."
-msgstr ""
-#: ../imagery/i.ifft/main.c:191 ../imagery/i.fft/main.c:166
-msgid "Rotating data..."
-msgstr ""
-#: ../imagery/i.ifft/main.c:200
-msgid "Starting Inverse FFT..."
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:169
-msgid "imagery quality assessment"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:170 ../imagery/i.albedo/main.c:97
-#: ../imagery/i.landsat.toar/main.c:73 ../imagery/i.landsat.toar/main.c:579
-#: ../imagery/i.aster.toar/main.c:100
-msgid "reflectance"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:171
-msgid "land surface temperature"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:172
-msgid "vegetation"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:173 ../imagery/i.albedo/main.c:98
-#: ../imagery/i.landsat.toar/main.c:76 ../imagery/i.aster.toar/main.c:102
-#: ../imagery/i.landsat.acca/main.c:108
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:4
-msgid "satellite"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:174 ../imagery/i.albedo/main.c:102
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
-msgid "MODIS"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:176
-msgid "Extracts quality control parameters from MODIS QC layers."
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:181
-msgid "Name of input surface reflectance QC layer [bit array]"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:186
-msgid "Name for output QC type classification layer"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:192
-msgid "Name of MODIS product type"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:209
-msgid "surf. refl. 250m 8-days"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:210
-msgid "surf. refl. 500m 8-days"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:211
-msgid "surf. refl. 500m 8-days, State QA"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:212
-msgid "surf. refl. 500m daily"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:213
-msgid "surf. refl. 500m daily, State QA"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:214
-msgid "surf. refl. 5000m daily"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:215
-msgid "surf. refl. 5000m daily, State QA"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:216
-msgid "surf. refl. 5000m daily, Internal Climatology"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:217
-msgid "LST 1km daily (Day/Night)"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:218
-msgid "LST 1km 8-days (Day/Night)"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:219
-msgid "VI 1km 16-days"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:220
-msgid "Brdf-Albedo Quality (Ancillary SDS) 1km 8-days"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:221
-msgid "Brdf-Albedo Quality (BRDF SDS) 1km 8-days"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:222
-msgid "VI 250m 16-days"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:230
-msgid "Name of QC type to extract"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:295
-msgid "mod09: Adjacency Correction"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:296
-msgid "mod09: Atmospheric Correction"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:297
-msgid "mod09: Cloud State"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:298
-msgid "mod09: Band-Wise Data Quality Flag"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:299
-msgid "mod09: 250m Band is at Different Orbit than 500m"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:300
-msgid "mod09: MODIS Land General Quality Assessment"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:301
-msgid "mod11A1: MODIS Land General Quality Assessment"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:302
-msgid "mod11A1: Detailed Quality Indications"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:303
-msgid "mod11A1: Average Emissivity Error Classes"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:304
-msgid "mod11A1: Average LST Error Classes"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:305
-msgid "mod11A2: Detailed Quality Indications"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:306
-msgid "mod11A2: Average Emissivity Error Classes"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:307
-msgid "mod11A2: MODIS Land General Quality Assessment"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:308
-msgid "mod11A2: Average LST Error Classes"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:309
-msgid "mod09*s: StateQA Aerosol Quantity"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:310
-msgid "mod09*s: StateQA BRDF Correction Performed"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:311
-msgid "mod09*s: StateQA Cirrus Detected"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:312
-msgid "mod09*s: StateQA Cloud Shadow"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:313
-msgid "mod09*s: StateQA Cloud State"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:314
-msgid "mod09*s: StateQA Internal Cloud Algorithm"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:315
-msgid "mod09*s: StateQA Internal Fire Algorithm"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:316
-msgid "mod09*s: StateQA Internal Snow Mask"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:317
-msgid "mod09*s: StateQA Land Water"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:318
-msgid "mod09*s: StateQA mod35 Snow Ice"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:319
-msgid "mod09*s: StateQA Pixel Adjacent to Cloud"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:320
-msgid "mod09*s: StateQA Salt Pan (mod09GAs)"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:321
-msgid "mod09*i: Internal CM: Cloudy"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:322
-msgid "mod09*i: Internal CM: Clear"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:323
-msgid "mod09*i: Internal CM: High Clouds"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:324
-msgid "mod09*i: Internal CM: Low Clouds"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:325
-msgid "mod09*i: Internal CM: Snow"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:326
-msgid "mod09*i: Internal CM: Fire"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:327
-msgid "mod09*i: Internal CM: Sun Glint"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:328
-msgid "mod09*i: Internal CM: Dust"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:329
-msgid "mod09*i: Internal CM: Cloud Shadow"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:330
-msgid "mod09*i: Internal CM: Pixel is Adjacent to Cloud"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:331
-msgid "mod09*i: Internal CM: Cirrus"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:332
-msgid "mod09*i: Internal CM: Pan Flag"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:333
-msgid "mod09*i: Internal CM: Criteria for Aerosol Retrieval"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:334
-msgid "mod09*i: Internal CM: AOT (aerosol optical depth) has clim. val."
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:335
-msgid "mod13A2: MODIS Land General Quality Assessment"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:336
-msgid "mod13A2: Quality estimation of the pixel"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:337
-msgid "mod13A2: Quantity range of Aerosol"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:338
-msgid "mod13A2: if pixel is a cloud neighbour"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:339
-msgid "mod13A2: if BRDF correction performed"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:340
-msgid "mod13A2: if pixel mixed with clouds"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:341
-msgid "mod13A2: separate land from various water objects"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:342
-msgid "mod13A2: if snow/ice present in pixel"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:343
-msgid "mod13A2: if shadow is present in pixel"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:344 ../imagery/i.modis.qc/main.c:345
-#: ../imagery/i.modis.qc/main.c:346
-msgid "mcd43B2: Quality of BRDF correction performed"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:347
-msgid "mcd43B2q: Quality of BRDF correction performed"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:348
-msgid "mod13Q1: MODIS Land General Quality Assessment"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:349
-msgid "mod13Q1: Quality estimation of the pixel"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:350
-msgid "mod13Q1: Quantity range of Aerosol"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:351
-msgid "mod13Q1: if pixel is a cloud neighbour"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:352
-msgid "mod13Q1: if BRDF correction performed"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:353
-msgid "mod13Q1: if pixel mixed with clouds"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:354
-msgid "mod13Q1: separate land from various water objects"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:355
-msgid "mod13Q1: if snow/ice present in pixel"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:356
-msgid "mod13Q1: if shadow is present in pixel"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:365
-msgid ""
-"Band number of MODIS product "
-"(mod09Q1=[1,2],mod09A1=[1-7],m[o/y]d09GA=[1-7],m[o/y]d09CMG=[1-7], "
-"mcd43B2q=[1-7])"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:369
-msgid "Band 1: Red"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:370
-msgid "Band 2: NIR"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:371
-msgid "Band 3: Blue"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:372
-msgid "Band 4: Green"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:373
-msgid "Band 5: SWIR 1"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:374
-msgid "Band 6: SWIR 2"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:375
-msgid "Band 7: SWIR 3"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:392
-msgid "Please specify a product to extract"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:395
-msgid "Please specify a valid QC flag to extract"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:400
-msgid "This bit flag is only available for MOD09Q1 @ 250m products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:404
-msgid "Band number out of allowed range [1-2]"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:406 ../imagery/i.modis.qc/main.c:408
-#: ../imagery/i.modis.qc/main.c:410 ../imagery/i.modis.qc/main.c:412
-#: ../imagery/i.modis.qc/main.c:414 ../imagery/i.modis.qc/main.c:416
-#: ../imagery/i.modis.qc/main.c:418 ../imagery/i.modis.qc/main.c:455
-msgid "Band number out of allowed range [1-7]"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:420
-msgid "mod09Q1 product only has 2 bands"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:425
-msgid ""
-"This bit flag is only available for MOD09A1s @ 500m or MOD09CMG @ 5000m "
-"products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:429
-msgid "This bit flag is only available for MOD09GAs @ 500m products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:440
-msgid "This bit flag is only available for mod09CMGi @ 5000m products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:446
-msgid "This bit flag is only available for MOD13A2 @ 1km products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:451
-msgid "This bit flag is only available for MCD43B2 @ 1km products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:461
-msgid "This bit flag is only available for MOD13Q1 @ 250m products"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:826
-msgid "Unknown names and/or combination, please check spelling"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:70 ../imagery/i.evapo.pt/main.c:67
-#: ../imagery/i.evapo.time/main.c:78 ../imagery/i.evapo.pm/main.c:59
-msgid "evapotranspiration"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:78
-msgid "Name of input diurnal net radiation raster map [W/m2/d]"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:82
-msgid "Name of input average air temperature raster map [C]"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:86
-msgid "Name of input minimum air temperature raster map [C]"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:90
-msgid "Name of input maximum air temperature raster map [C]"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:96
-msgid "Name of precipitation raster map [mm/month]"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:97
-msgid "Disabled for original Hargreaves (1985)"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:100
-msgid "Name for output raster map [mm/d]"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:105 ../imagery/i.evapo.pt/main.c:102
-msgid "Set negative ETa to zero"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:109
-msgid "Use original Hargreaves (1985)"
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:113
-msgid "Use Hargreaves-Samani (1985)"
-msgstr ""
-#: ../imagery/i.group/main.c:55
-msgid "Creates, edits, and lists groups of imagery data."
-msgstr ""
-#: ../imagery/i.group/main.c:59
-msgid "Name of imagery group"
-msgstr ""
-#: ../imagery/i.group/main.c:63
-msgid "Name of imagery subgroup"
-msgstr ""
-#: ../imagery/i.group/main.c:67
-msgid "Name of raster map(s) to include in group"
-msgstr ""
-#: ../imagery/i.group/main.c:68 ../imagery/i.group/main.c:74
-msgid "Maps"
-msgstr ""
-#: ../imagery/i.group/main.c:73
-msgid "Remove selected files from specified group or subgroup"
-msgstr ""
-#: ../imagery/i.group/main.c:78
-msgid "List files from specified (sub)group"
-msgstr ""
-#: ../imagery/i.group/main.c:83
-msgid "List subgroups from specified group"
-msgstr ""
-#: ../imagery/i.group/main.c:109
-msgid "No input raster map(s) specified"
-msgstr ""
-#: ../imagery/i.group/main.c:117 ../imagery/i.target/main.c:80
-msgid "Group must exist in the current mapset"
-msgstr ""
-#: ../imagery/i.group/main.c:128 ../imagery/i.group/main.c:150
-msgid "Specified group does not exist in current mapset"
-msgstr ""
-#: ../imagery/i.group/main.c:132
-#, c-format
-msgid "Removing raster maps from subgroup <%s>..."
-msgstr ""
-#: ../imagery/i.group/main.c:137
-#, c-format
-msgid "Removing raster maps from group <%s>..."
-msgstr ""
-#: ../imagery/i.group/main.c:158
-#, c-format
-msgid "Subgroup <%s> of group <%s> references the following raster maps:"
-msgstr ""
-#: ../imagery/i.group/main.c:173
-#, c-format
-msgid "Group <%s> references the following raster maps:"
-msgstr ""
-#: ../imagery/i.group/main.c:185
-#, c-format
-msgid "Group <%s> does not yet exist. Creating..."
-msgstr ""
-#: ../imagery/i.group/main.c:189 ../imagery/i.group/main.c:198
-#, c-format
-msgid "Adding raster maps to group <%s>..."
-msgstr ""
-#: ../imagery/i.group/main.c:193
-#, c-format
-msgid "Adding raster maps to subgroup <%s>..."
-msgstr ""
-#: ../imagery/i.group/main.c:219
-msgid "No input raster maps defined"
-msgstr ""
-#: ../imagery/i.group/main.c:223 ../imagery/i.group/main.c:265
-#, c-format
-msgid "Raster map <%s> not found. Skipped."
-msgstr ""
-#: ../imagery/i.group/main.c:228
-#, c-format
-msgid "Adding raster map <%s> to group"
-msgstr ""
-#: ../imagery/i.group/main.c:234
-#, c-format
-msgid "Raster map <%s> exists in group. Skipped."
-msgstr ""
-#: ../imagery/i.group/main.c:271
-#, c-format
-msgid "Adding raster map <%s> to subgroup"
-msgstr ""
-#: ../imagery/i.group/main.c:278
-#, c-format
-msgid "Raster map <%s> exists in subgroup. Skipping..."
-msgstr ""
-#: ../imagery/i.group/main.c:327
-#, c-format
-msgid "Removing raster map <%s> from group"
-msgstr ""
-#: ../imagery/i.group/main.c:344 ../imagery/i.group/main.c:403
-msgid "No raster map removed"
-msgstr ""
-#: ../imagery/i.group/main.c:386
-#, c-format
-msgid "Removing raster map <%s> from subgroup"
-msgstr ""
-#: ../imagery/i.group/main.c:422
-#, c-format
-msgid "Group <%s> does not contain any subgroup.\n"
-msgstr ""
-#: ../imagery/i.group/main.c:433
-#, c-format
-msgid "group <%s> references the following subgroups\n"
-msgstr ""
-#: ../imagery/i.gensig/parse.c:14 ../imagery/i.gensigset/parse.c:13
-msgid "Ground truth training map"
-msgstr ""
-#: ../imagery/i.gensig/parse.c:26 ../imagery/i.cluster/main.c:95
-#: ../imagery/i.gensigset/parse.c:25
-msgid "Name for output file containing result signatures"
-msgstr ""
-#: ../imagery/i.gensig/parse.c:41 ../imagery/i.smap/parse.c:61
-#: ../imagery/i.cluster/main.c:169 ../imagery/i.gensigset/parse.c:47
-#: ../imagery/i.maxlik/open.c:17
-#, c-format
-msgid "Group <%s> not found in current mapset"
-msgstr ""
-#: ../imagery/i.gensig/parse.c:44 ../imagery/i.smap/parse.c:64
-#: ../imagery/i.cluster/main.c:172 ../imagery/i.gensigset/parse.c:50
-#: ../imagery/i.maxlik/open.c:20
-#, c-format
-msgid "Subgroup <%s> in group <%s> not found"
-msgstr ""
-#: ../imagery/i.gensig/check.c:21
-#, c-format
-msgid "Signature %d not invertible"
-msgstr ""
-#: ../imagery/i.gensig/check.c:27
-#, c-format
-msgid "Signature %d unable to get eigen values"
-msgstr ""
-#: ../imagery/i.gensig/check.c:33
-#, c-format
-msgid "Signature %d not positive definite"
-msgstr ""
-#: ../imagery/i.gensig/covariance.c:30
-msgid "Calculating class covariance matrices..."
-msgstr ""
-#: ../imagery/i.gensig/get_train.c:32 ../imagery/i.gensigset/get_train.c:35
-msgid "Finding training classes..."
-msgstr ""
-#: ../imagery/i.gensig/get_train.c:55 ../imagery/i.gensigset/get_train.c:58
-#, c-format
-msgid "Training class %d only has one cell - this class will be ignored"
-msgstr ""
-#: ../imagery/i.gensig/get_train.c:60 ../imagery/i.gensigset/get_train.c:63
-msgid "Training map has no classes"
-msgstr ""
-#: ../imagery/i.gensig/get_train.c:75 ../imagery/i.gensigset/get_train.c:79
-msgid "1 class found"
-msgstr ""
-#: ../imagery/i.gensig/get_train.c:77 ../imagery/i.gensigset/get_train.c:81
-#, c-format
-msgid "%d classes found"
-msgstr ""
-#: ../imagery/i.gensig/main.c:41 ../imagery/i.smap/main.c:40
-#: ../imagery/i.gensigset/main.c:42
-msgid "supervised classification"
-msgstr ""
-#: ../imagery/i.gensig/main.c:42 ../imagery/i.maxlik/main.c:63
-msgid "Maximum Likelihood Classification"
-msgstr ""
-#: ../imagery/i.gensig/main.c:44 ../imagery/i.cluster/main.c:77
-#: ../imagery/i.gensigset/main.c:44
-msgid "signatures"
-msgstr ""
-#: ../imagery/i.gensig/main.c:46
-msgid "Generates statistics for i.maxlik from raster map."
-msgstr ""
-#: ../imagery/i.gensig/means.c:26
-msgid "Calculating class means..."
-msgstr ""
-#: ../imagery/i.gensig/openfiles.c:19 ../imagery/i.smap/openfiles.c:18
-#: ../imagery/i.smap/read_sig.c:13 ../imagery/i.gensigset/openfiles.c:18
-#, c-format
-msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-msgstr ""
-#: ../imagery/i.gensig/openfiles.c:23 ../imagery/i.gensigset/openfiles.c:22
-#, c-format
-msgid "Subgroup <%s> in group <%s> contains no raster maps."
-msgstr ""
-#: ../imagery/i.gensig/write_sig.c:15 ../imagery/i.gensigset/write_sig.c:13
-#, c-format
-msgid "Unable to create signature file <%s>"
-msgstr ""
-#: ../imagery/i.gensig/write_sig.c:18 ../imagery/i.gensigset/write_sig.c:16
-msgid "Writing signatures..."
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:105 ../imagery/i.eb.evapfr/main.c:48
-#: ../imagery/i.emissivity/main.c:47 ../imagery/i.eb.netrad/main.c:57
-#: ../imagery/i.eb.eta/main.c:43 ../imagery/i.eb.soilheatflux/main.c:50
-msgid "energy balance"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:106 ../imagery/i.eb.evapfr/main.c:49
-msgid "soil moisture"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:107 ../imagery/i.eb.evapfr/main.c:50
-msgid "evaporative fraction"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:108 ../imagery/i.eb.evapfr/main.c:51
-#: ../imagery/i.eb.netrad/main.c:59 ../imagery/i.eb.eta/main.c:45
-#: ../imagery/i.eb.soilheatflux/main.c:52
-msgid "SEBAL"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:110
-msgid "Computes sensible heat flux iteration SEBAL 01."
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:116
-msgid "Name of instantaneous net radiation raster map [W/m2]"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:121
-msgid "Name of instantaneous soil heat flux raster map [W/m2]"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:126
-msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:131
-msgid "Name of altitude corrected surface temperature raster map [K]"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:140
-msgid "Value of the height independent friction velocity (u*) [m/s]"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:149
-msgid "Value of the actual vapour pressure (e_act) [KPa]"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:156
-msgid "Row value of the wet pixel"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:163
-msgid "Column value of the wet pixel"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:170
-msgid "Row value of the dry pixel"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:177
-msgid "Column value of the dry pixel"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:182
-msgid "Name for output sensible heat flux raster map [W/m2]"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:187
-msgid "Automatic wet/dry pixel (careful!)"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:192
-msgid "Dry/Wet pixels coordinates are in image projection, not row/col"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:210
-msgid "Automatic mode selected"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:222
-msgid "Manual wet/dry pixels in image coordinates"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:223
-#, c-format
-msgid "Wet Pixel=> x:%f y:%f"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:224
-#, c-format
-msgid "Dry Pixel=> x:%f y:%f"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:228
-msgid "Either auto-mode either wet/dry pixels coordinates should be provided!"
-msgstr ""
-#: ../imagery/i.eb.hsebal01/main.c:233
-#, c-format
-msgid "<%s> is an illegal name"
-msgstr ""
-#: ../imagery/i.smap/interp.c:233
-msgid "Invalid parameter values"
-msgstr ""
-#: ../imagery/i.smap/main.c:41 ../imagery/i.segment/main.c:37
-msgid "segmentation"
-msgstr ""
-#: ../imagery/i.smap/main.c:42 ../imagery/i.gensigset/main.c:43
-msgid "SMAP"
-msgstr ""
-#: ../imagery/i.smap/main.c:44
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-#: ../imagery/i.smap/model.c:43
-#, c-format
-msgid "Nonsymetric covariance for class %d subclass %d"
-msgstr ""
-#: ../imagery/i.smap/model.c:55
-#, c-format
-msgid "Nonpositive eigenvalues for class %d subclass %d"
-msgstr ""
-#: ../imagery/i.smap/openfiles.c:22 ../imagery/i.smap/read_sig.c:17
-#, c-format
-msgid "Subgroup <%s> in group <%s> contains no raster maps"
-msgstr ""
-#: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:81
-msgid "Name of input file containing signatures"
-msgstr ""
-#: ../imagery/i.smap/parse.c:21
-msgid "Generated by i.gensigset"
-msgstr ""
-#: ../imagery/i.smap/parse.c:28 ../imagery/i.maxlik/main.c:86
-msgid "Name for output raster map holding classification results"
-msgstr ""
-#: ../imagery/i.smap/parse.c:33
-msgid "Name for output raster map holding goodness of fit (lower is better)"
-msgstr ""
-#: ../imagery/i.smap/parse.c:37
-msgid "Size of submatrix to process at one time"
-msgstr ""
-#: ../imagery/i.smap/parse.c:45
-msgid "Use maximum likelihood estimation (instead of smap)"
-msgstr ""
-#: ../imagery/i.smap/read_sig.c:23 ../imagery/i.cluster/open_files.c:60
-#: ../imagery/i.maxlik/open.c:53
-#, c-format
-msgid "Unable to read signature file <%s>"
-msgstr ""
-#: ../imagery/i.smap/read_sig.c:27
-#, c-format
-msgid "Signature file <%s> is invalid"
-msgstr ""
-#: ../imagery/i.smap/read_sig.c:30
-#, c-format
-msgid "Signature file <%s> is empty"
-msgstr ""
-#: ../imagery/i.smap/segment.c:67
-msgid "Number of classes must be < 256"
-msgstr ""
-#: ../imagery/i.smap/segment.c:102
-#, c-format
-msgid "Processing rows %d-%d (of %d)..."
-msgstr ""
-#: ../imagery/i.smap/write_img.c:15
-msgid "Writing output raster map(s)..."
-msgstr ""
-#: ../imagery/i.albedo/main.c:96
-msgid "albedo"
-msgstr ""
-#: ../imagery/i.albedo/main.c:99 ../imagery/i.landsat.toar/main.c:77
-#: ../imagery/i.landsat.acca/main.c:109
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
-msgid "Landsat"
-msgstr ""
-#: ../imagery/i.albedo/main.c:100 ../imagery/i.aster.toar/main.c:103
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-msgid "ASTER"
-msgstr ""
-#: ../imagery/i.albedo/main.c:101
-msgid "AVHRR"
-msgstr ""
-#: ../imagery/i.albedo/main.c:103
-msgid "Computes broad band albedo from surface reflectance."
-msgstr ""
-#: ../imagery/i.albedo/main.c:116
-msgid "MODIS (7 input bands:1,2,3,4,5,6,7)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:120
-msgid "NOAA AVHRR (2 input bands:1,2)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:124
-msgid "Landsat 5+7 (6 input bands:1,2,3,4,5,7)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:128
-msgid "Landsat 8 (7 input bands:1,2,3,4,5,6,7)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:132
-msgid "ASTER (6 input bands:1,3,5,6,8,9)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:136
-msgid "Aggressive mode (Landsat)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:138 ../imagery/i.albedo/main.c:145
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
-msgstr ""
-#: ../imagery/i.albedo/main.c:143
-msgid "Soft mode (MODIS)"
-msgstr ""
-#: ../imagery/i.albedo/main.c:167 ../imagery/i.aster.toar/main.c:231
-#, c-format
-msgid "Too many input maps. Only %d allowed."
-msgstr ""
-#: ../imagery/i.albedo/main.c:181
-msgid "At least two raster maps are required"
-msgstr ""
-#: ../imagery/i.cluster/print3.c:16
-#, c-format
-msgid "%sinitial means for each band%s%s"
-msgstr ""
-#: ../imagery/i.cluster/print3.c:20
-#, c-format
-msgid "class %-3d "
-msgstr ""
-#: ../imagery/i.cluster/print4.c:16
-#, c-format
-msgid "class centroids (sum/count=mean)%s"
-msgstr ""
-#: ../imagery/i.cluster/print4.c:18
-#, c-format
-msgid "band %d"
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:16
-#, c-format
-msgid "using seed means (%d files)%s"
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:29
-#, c-format
-msgid "%s######## iteration %d ###########%s"
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:31
-#, c-format
-msgid "%d classes, %.2f%% points stable%s"
-msgstr ""
-#: ../imagery/i.cluster/checkpt.c:42
-#, c-format
-msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
-msgstr ""
-#: ../imagery/i.cluster/print5.c:15
-#, c-format
-msgid "%sclass separability matrix%s%s"
-msgstr ""
-#: ../imagery/i.cluster/print6.c:11
-#, c-format
-msgid "class distribution"
-msgstr ""
-#: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
-msgstr ""
-#: ../imagery/i.cluster/main.c:82
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
-msgstr ""
-#: ../imagery/i.cluster/main.c:102
-msgid "Initial number of classes"
-msgstr ""
-#: ../imagery/i.cluster/main.c:111
-msgid "Name of file containing initial signatures"
-msgstr ""
-#: ../imagery/i.cluster/main.c:119
-msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
-msgstr ""
-#: ../imagery/i.cluster/main.c:126 ../imagery/i.segment/parse_args.c:126
-msgid "Maximum number of iterations"
-msgstr ""
-#: ../imagery/i.cluster/main.c:135
-msgid "Percent convergence"
-msgstr ""
-#: ../imagery/i.cluster/main.c:143
-msgid "Cluster separation"
-msgstr ""
-#: ../imagery/i.cluster/main.c:151
-msgid "Minimum number of pixels in a class"
-msgstr ""
-#: ../imagery/i.cluster/main.c:158
-msgid "Name for output file containing final report"
-msgstr ""
-#: ../imagery/i.cluster/main.c:192
-#, c-format
-msgid "Illegal number of initial classes (%s)"
-msgstr ""
-#: ../imagery/i.cluster/main.c:203
-#, c-format
-msgid "Illegal value(s) of sample intervals (%s)"
-msgstr ""
-#: ../imagery/i.cluster/main.c:217
-#, c-format
-msgid "Illegal value of iterations (%s)"
-msgstr ""
-#: ../imagery/i.cluster/main.c:223
-#, c-format
-msgid "Illegal value of convergence (%s)"
-msgstr ""
-#: ../imagery/i.cluster/main.c:228
-#, c-format
-msgid "Illegal value of separation (%s)"
-msgstr ""
-#: ../imagery/i.cluster/main.c:233
-#, c-format
-msgid "Illegal value of min_size (%s)"
-msgstr ""
-#: ../imagery/i.cluster/main.c:242
-#, c-format
-msgid "Unable to create report file <%s>"
-msgstr ""
-#: ../imagery/i.cluster/main.c:250
-#, c-format
-msgid "#################### CLUSTER (%s) ####################%s%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:252
-#, c-format
-msgid "Location: %s%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:253
-#, c-format
-msgid "Mapset:   %s%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:254
-#, c-format
-msgid "Group:    %s%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:255
-#, c-format
-msgid "Subgroup: %s%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:257
-#, c-format
-msgid " %s%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:260
-#, c-format
-msgid "Result signature file: %s%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:262
-#, c-format
-msgid "Region%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:263
-#, c-format
-msgid "  North: %12.2f  East: %12.2f%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:265
-#, c-format
-msgid "  South: %12.2f  West: %12.2f%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:267
-#, c-format
-msgid "  Res:   %12.2f  Res:  %12.2f%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:269
-#, c-format
-msgid "  Rows:  %12d  Cols: %12d  Cells: %d%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:271
-#, c-format
-msgid "Mask: %s%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:273
-#, c-format
-msgid "Cluster parameters%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:274
-#, c-format
-msgid " Number of initial classes:    %d"
-msgstr ""
-#: ../imagery/i.cluster/main.c:276
-#, c-format
-msgid " [from signature file %s]"
-msgstr ""
-#: ../imagery/i.cluster/main.c:278
-#, c-format
-msgid " Minimum class size:           %d%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:279
-#, c-format
-msgid " Minimum class separation:     %f%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:280
-#, c-format
-msgid " Percent convergence:          %f%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:281
-#, c-format
-msgid " Maximum number of iterations: %d%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:283
-#, c-format
-msgid " Row sampling interval:        %d%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:284
-#, c-format
-msgid " Col sampling interval:        %d%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:303
-msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr ""
-#: ../imagery/i.cluster/main.c:309
-#, c-format
-msgid "Sample size: %d points%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:312
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
-msgstr ""
-#: ../imagery/i.cluster/main.c:316
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and "
-"mask)."
-msgstr ""
-#: ../imagery/i.cluster/main.c:329
-#, c-format
-msgid "%s########## final results #############%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:330
-#, c-format
-msgid "%d classes (convergence=%.1f%%)%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:341
-#, c-format
-msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr ""
-#: ../imagery/i.cluster/main.c:346
-#, c-format
-msgid "%s%s#################### CLASSES ####################%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:348
-#, c-format
-msgid "%s%d classes, %.2f%% points stable%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:350
-#, c-format
-msgid "%s######## CLUSTER END (%s) ########%s"
-msgstr ""
-#: ../imagery/i.cluster/main.c:354 ../misc/m.nviz.image/main.c:242
-#, c-format
-msgid "File <%s> created."
-msgstr ""
-#: ../imagery/i.cluster/open_files.c:24
-#, c-format
-msgid "Raster map <%s> do not exists in subgroup <%s>"
-msgstr ""
-#: ../imagery/i.cluster/open_files.c:29
-msgid "No raster maps found"
-msgstr ""
-#: ../imagery/i.cluster/open_files.c:33
-#, c-format
-msgid "Subgroup <%s> doesn't have any raster maps"
-msgstr ""
-#: ../imagery/i.cluster/open_files.c:36
-#, c-format
-msgid "Subgroup <%s> only has 1 raster map"
-msgstr ""
-#: ../imagery/i.cluster/open_files.c:37
-msgid "Subgroup must have at least 2 raster maps"
-msgstr ""
-#: ../imagery/i.cluster/open_files.c:54
-#, c-format
-msgid "Unable to open seed signature file <%s>"
-msgstr ""
-#: ../imagery/i.cluster/open_files.c:64 ../imagery/i.maxlik/open.c:57
-#, c-format
-msgid "<%s> has too many signatures (limit is 255)"
-msgstr ""
-#: ../imagery/i.cluster/print1.c:12
-#, c-format
-msgid "means and standard deviations for %d band%s%s%s"
-msgstr ""
-#: ../imagery/i.cluster/print1.c:14
-#, c-format
-msgid " means  "
-msgstr ""
-#: ../imagery/i.cluster/print1.c:18
-#, c-format
-msgid " stddev "
-msgstr ""
-#: ../imagery/i.cluster/print2.c:18
-#, c-format
-msgid "%sclass means/stddev for each band%s%s"
-msgstr ""
-#: ../imagery/i.cluster/print2.c:23
-#, c-format
-msgid "class %d (%d)%s"
-msgstr ""
-#: ../imagery/i.cluster/print2.c:24
-#, c-format
-msgid "  means "
-msgstr ""
-#: ../imagery/i.cluster/print2.c:29
-#, c-format
-msgid "  stddev"
-msgstr ""
-#: ../imagery/i.landsat.toar/landsat.c:116
-msgid ""
-"The DOS4 method is not applicable here: approximation of atmospheric "
-"transmittance coefficients is unstable. Use another DOS method or use other "
-"sun_elevation parameter"
-msgstr ""
-#: ../imagery/i.landsat.toar/landsat_met.c:117
-#, c-format
-msgid "Metadata file <%s> not found"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:69
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:71 ../imagery/i.aster.toar/main.c:98
-msgid "radiometric conversion"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:72 ../imagery/i.landsat.toar/main.c:577
-#: ../imagery/i.aster.toar/main.c:99
-msgid "radiance"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:74 ../imagery/i.aster.toar/main.c:101
-msgid "brightness temperature"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:75
-msgid "atmospheric correction"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:82 ../imagery/i.landsat.acca/main.c:112
-msgid "Base name of input raster bands"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:83 ../imagery/i.landsat.acca/main.c:113
-msgid "Example: 'B.' for B.1, B.2, ..."
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:86
-msgid "Prefix for output raster maps"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:88
-msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:93
-msgid "Name of Landsat metadata file (.met or MTL.txt)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:99
-msgid "Spacecraft sensor"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:100
-msgid "Required only if 'metfile' not given (recommended for sanity)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:105
-msgid "Landsat-1 MSS"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:106
-msgid "Landsat-2 MSS"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:107
-msgid "Landsat-3 MSS"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:108
-msgid "Landsat-4 MSS"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:109
-msgid "Landsat-5 MSS"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:110
-msgid "Landsat-4 TM"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:111
-msgid "Landsat-5 TM"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:112
-msgid "Landsat-7 ETM+"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:113
-msgid "Landsat_8 OLI/TIRS"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:123
-msgid "Atmospheric correction method"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:132
-msgid "Image acquisition date (yyyy-mm-dd)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:133 ../imagery/i.landsat.toar/main.c:141
-#: ../imagery/i.landsat.toar/main.c:150 ../imagery/i.landsat.toar/main.c:158
-msgid "Required only if 'metfile' not given"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:140
-msgid "Sun elevation in degrees"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:149
-msgid "Image creation date (yyyy-mm-dd)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:157
-msgid "Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:165
-msgid "Percent of solar radiance in path radiance"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:166 ../imagery/i.landsat.toar/main.c:176
-msgid "Required only if 'method' is any DOS"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:175
-msgid "Minimum pixels to consider digital number as dark object"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:184
-msgid "Rayleigh atmosphere (diffuse sky irradiance)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:185
-msgid "Required only if 'method' is DOS3"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:194
-msgid "return value stored for a given metadata"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:195
-msgid "Required only if 'metfile' and -p given"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:201
-msgid "Landsat Number"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:202
-msgid "Creation timestamp"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:203
-msgid "Date"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:204
-msgid "Sun Elevation"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:205
-msgid "Sensor"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:206
-msgid "Bands count"
-msgstr ""
-msgid "Sun Azimuth Angle"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:215
-msgid "Scale factor for output"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:221
-msgid "Output at-sensor radiance instead of reflectance for all bands"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:226
-msgid ""
-"Input raster maps use as extension the number of the band instead the code"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:230
-msgid "Print output metadata info"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:256 ../imagery/i.landsat.toar/main.c:264
-#, c-format
-msgid "Illegal date format: [%s] (yyyy-mm-dd)"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:286
-msgid "Please use a metadata keyword with -p"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:323
-msgid "Failed to identify satellite"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:337
-#, c-format
-msgid "Lacking '%s' and/or '%s' for this satellite"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:343
-msgid "Landsat-7 requires band gain with 9 (H/L) characters"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:363
-#, c-format
-msgid "Unknown satellite type (defined by '%s')"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:410 ../imagery/i.landsat.toar/main.c:559
-#, c-format
-msgid "Unable to read data type of raster map <%s>"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:552
-#, c-format
-msgid "Raster map <%s> exists. Skipping."
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:575
-#, c-format
-msgid "Writing %s of <%s> to <%s>..."
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:579
-msgid "temperature"
-msgstr ""
-#: ../imagery/i.zc/main.c:54 ../vector/v.lidar.edgedetection/main.c:77
-msgid "edges"
-msgstr ""
-#: ../imagery/i.zc/main.c:56
-msgid "Zero-crossing \"edge detection\" raster function for image processing."
-msgstr ""
-#: ../imagery/i.zc/main.c:74
-msgid "Zero crossing raster map"
-msgstr ""
-#: ../imagery/i.zc/main.c:81
-msgid "x-y extent of the Gaussian filter"
-msgstr ""
-#: ../imagery/i.zc/main.c:89
-msgid "Sensitivity of Gaussian filter"
-msgstr ""
-#: ../imagery/i.zc/main.c:97
-msgid "Number of azimuth directions categorized"
-msgstr ""
-#: ../imagery/i.zc/main.c:109
-msgid "Threshold less than or equal to zero not allowed"
-msgstr ""
-#: ../imagery/i.zc/main.c:119
-msgid "Width less than or equal to zero not allowed"
-msgstr ""
-#: ../imagery/i.zc/main.c:123
-msgid "Fewer than 1 orientation classes not allowed"
-msgstr ""
-#: ../imagery/i.zc/main.c:137
-#, c-format
-msgid "Power 2 values : %d rows %d columns"
-msgstr ""
-#: ../imagery/i.zc/main.c:147
-msgid "Initializing data..."
-msgstr ""
-#: ../imagery/i.zc/main.c:177
-msgid "Writing transformed data to file..."
-msgstr ""
-#: ../imagery/i.zc/main.c:200
-msgid "Transform successful"
-msgstr ""
-#: ../imagery/i.pca/main.c:74
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
-msgid "PCA"
-msgstr ""
-#: ../imagery/i.pca/main.c:75
-msgid "principal components analysis"
-msgstr ""
-#: ../imagery/i.pca/main.c:76
-msgid "Principal components analysis (PCA) for image processing."
-msgstr ""
-#: ../imagery/i.pca/main.c:82
-msgid "Name of two or more input raster maps or imagery group"
-msgstr ""
-#: ../imagery/i.pca/main.c:85
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
-msgid "Name for output basename raster map(s)"
-msgstr ""
-#: ../imagery/i.pca/main.c:87
-msgid "A numerical suffix will be added for each component map"
-msgstr ""
-#: ../imagery/i.pca/main.c:96
-msgid "Rescaling range for output maps"
-msgstr ""
-#: ../imagery/i.pca/main.c:98
-msgid "For no rescaling use 0,0"
-msgstr ""
-#: ../imagery/i.pca/main.c:99
-msgid "Rescale"
-msgstr ""
-#: ../imagery/i.pca/main.c:108
-msgid "Cumulative percent importance for filtering"
-msgstr ""
-#: ../imagery/i.pca/main.c:113
-msgid "Normalize (center and scale) input maps"
-msgstr ""
-#: ../imagery/i.pca/main.c:114
-msgid "Default: center only"
-msgstr ""
-#: ../imagery/i.pca/main.c:118
-msgid "Output will be filtered input bands"
-msgstr ""
-#: ../imagery/i.pca/main.c:119
-msgid "Apply inverse PCA after PCA"
-msgstr ""
-#: ../imagery/i.pca/main.c:148
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:179
-#: ../imagery/i.rectify/main.c:187
-#, c-format
-msgid "Group <%s> not found"
-msgstr ""
-#: ../imagery/i.pca/main.c:154
-msgid "Sorry, at least 2 input bands must be provided"
-msgstr ""
-#: ../imagery/i.pca/main.c:169
-#, c-format
-msgid "'%s' must be positive"
-msgstr ""
-#: ../imagery/i.pca/main.c:171
-#, c-format
-msgid "'%s' must be < 100"
-msgstr ""
-#: ../imagery/i.pca/main.c:233
-msgid "Not enough principal components left for filtering"
-msgstr ""
-#: ../imagery/i.pca/main.c:235
-#, c-format
-msgid "Using %d of %d principal components for filtering"
-msgstr ""
-#: ../imagery/i.pca/main.c:297
-msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr ""
-#: ../imagery/i.pca/main.c:343
-msgid "Computing covariance matrix..."
-msgstr ""
-#: ../imagery/i.pca/main.c:456
-#, c-format
-msgid "Rescaling to range %d,%d..."
-msgstr ""
-#: ../imagery/i.pca/main.c:464
-msgid "Calculating principal components..."
-msgstr ""
-#: ../imagery/i.pca/support.c:50
-msgid "Eigen values, (vectors), and [percent importance]:"
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:69
-msgid ""
-"Computes evapotranspiration calculation Priestley and Taylor formulation, "
-"1972."
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:75
-msgid "Name of input net radiation raster map [W/m2]"
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:79
-msgid "Name of input soil heat flux raster map [W/m2]"
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:83
-msgid "Name of input air temperature raster map [K]"
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:87
-msgid "Name of input atmospheric pressure raster map [millibars]"
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:93
-msgid "Priestley-Taylor coefficient"
-msgstr ""
-#: ../imagery/i.evapo.pt/main.c:97
-msgid "Name of output evapotranspiration raster map [mm/d]"
-msgstr ""
-#: ../imagery/i.fft/main.c:82
-msgid "Fast Fourier Transform (FFT) for image processing."
-msgstr ""
-#: ../imagery/i.fft/main.c:90
-msgid "Name for output real part arrays stored as raster map"
-msgstr ""
-#: ../imagery/i.fft/main.c:94
-msgid "Name for output imaginary part arrays stored as raster map"
-msgstr ""
-#: ../imagery/i.fft/main.c:106
-msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr ""
-#: ../imagery/i.fft/main.c:129
-#, c-format
-msgid "Reading the raster map <%s>..."
-msgstr ""
-#: ../imagery/i.fft/main.c:145
-msgid "Starting FFT..."
-msgstr ""
-#: ../imagery/i.fft/main.c:174
-msgid "Writing transformed data..."
-msgstr ""
-#: ../imagery/i.fft/main.c:200
-msgid "FFT is now complete"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:105
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN."
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:109
-msgid "Names of ASTER DN layers (15 layers)"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:116
-msgid "Day of Year of satellite overpass [0-366]"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:123
-msgid "Sun elevation angle (degrees, < 90.0)"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:126
-msgid "Base name of the output layers (will add .x)"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:131
-msgid "Output is radiance (W/m2)"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:135
-msgid "VNIR is High Gain"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:139
-msgid "SWIR is High Gain"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:143
-msgid "VNIR is Low Gain 1"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:147
-msgid "SWIR is Low Gain 1"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:151
-msgid "SWIR is Low Gain 2"
-msgstr ""
-#: ../imagery/i.aster.toar/main.c:246
-msgid "The input band number should be 15"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:49
-msgid "topographic correction"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:50
-msgid "Computes topographic correction of reflectance."
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:58
-msgid "Name of reflectance raster maps to be corrected topographically"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:62
-msgid "Name (flag -i) or prefix for output raster maps"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:66
-msgid "Name of input base raster map (elevation or illumination)"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:72
-msgid "Solar zenith in degrees"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:78
-msgid "Solar azimuth in degrees (only if flag -i)"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:85
-msgid "Topographic correction method"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:90
-msgid "Output sun illumination terrain model"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:94
-msgid "Scale output to input and copy color rules"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:100
-msgid "Solar azimuth is necessary to calculate illumination terrain model"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:104
-msgid "Reflectance maps are necessary to make topographic correction"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:164
-msgid "Illumination model is of CELL type"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:167
-#, c-format
-msgid "Band %s: "
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:175
-#, c-format
-msgid "Reflectance of <%s> is not of DCELL type - ignored."
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:52
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:58
-msgid "Name of input raster map (red)"
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:62
-msgid "Name of input raster map (green)"
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:66
-msgid "Name of input raster map (blue)"
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:70
-msgid "Name for output raster map (hue)"
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:74
-msgid "Name for output raster map (intensity)"
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:78
-msgid "Name for output raster map (saturation)"
-msgstr ""
-#: ../imagery/i.his.rgb/main.c:52
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
-msgstr ""
-#: ../imagery/i.his.rgb/main.c:58
-msgid "Name of input raster map (hue)"
-msgstr ""
-#: ../imagery/i.his.rgb/main.c:62
-msgid "Name of input raster map (intensity)"
-msgstr ""
-#: ../imagery/i.his.rgb/main.c:66
-msgid "Name of input raster map (saturation)"
-msgstr ""
-#: ../imagery/i.his.rgb/main.c:70
-msgid "Name for output raster map (red)"
-msgstr ""
-#: ../imagery/i.his.rgb/main.c:74
-msgid "Name for output raster map (green)"
-msgstr ""
-#: ../imagery/i.his.rgb/main.c:78
-msgid "Name for output raster map (blue)"
-msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:53
-msgid "Computes evaporative fraction and root zone soil moisture."
-msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:58 ../imagery/i.eb.soilheatflux/main.c:71
-msgid "Name of Net Radiation raster map [W/m2]"
-msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:62
-msgid "Name of soil heat flux raster map [W/m2]"
-msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:66
-msgid "Name of sensible heat flux raster map [W/m2]"
-msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:71
-msgid "Name for output evaporative fraction raster map"
-msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:77
-msgid "Name for output root zone soil moisture raster map"
-msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:82
-msgid "Root zone soil moisture output (Makin, Molden and Bastiaanssen, 2001)"
-msgstr ""
-#: ../imagery/i.biomass/main.c:51
-msgid "biomass"
-msgstr ""
-#: ../imagery/i.biomass/main.c:53
-msgid "yield"
-msgstr ""
-#: ../imagery/i.biomass/main.c:55
-msgid "Computes biomass growth, precursor of crop yield calculation."
-msgstr ""
-#: ../imagery/i.biomass/main.c:60
-msgid "Name of fPAR raster map"
-msgstr ""
-#: ../imagery/i.biomass/main.c:65
-msgid "Name of light use efficiency raster map (UZB:cotton=1.9)"
-msgstr ""
-#: ../imagery/i.biomass/main.c:69
-msgid "Name of degree latitude raster map [dd.ddd]"
-msgstr ""
-#: ../imagery/i.biomass/main.c:73
-msgid "Name of Day of Year raster map [1-366]"
-msgstr ""
-#: ../imagery/i.biomass/main.c:78
-msgid "Name of single-way transmissivity raster map [0.0-1.0]"
-msgstr ""
-#: ../imagery/i.biomass/main.c:83
-msgid "Value of water availability raster map [0.0-1.0]"
-msgstr ""
-#: ../imagery/i.biomass/main.c:87
-msgid "Name for output daily biomass growth raster map [kg/ha/d]"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:45
-msgid "emissivity"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:46
-msgid "land flux"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:49
-msgid "Computes emissivity from NDVI, generic method for sparse land."
-msgstr ""
-#: ../imagery/i.emissivity/main.c:53
-msgid "Name of the NDVI map [-]"
-msgstr ""
-#: ../imagery/i.emissivity/main.c:56
-msgid "Name of the output emissivity layer"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:124
-msgid "Preliminary scene analysis:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:125
-#, c-format
-msgid "* Desert index: %.2lf"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:126
-#, c-format
-msgid "* Snow cover: %.2lf %%"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:127
-#, c-format
-msgid "* Cloud cover: %.2lf %%"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:128
-msgid "* Temperature of clouds:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:129
-#, c-format
-msgid "** Maximum: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:130
-#, c-format
-msgid "** Mean (%s cloud): %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:132
-#, c-format
-msgid "** Minimum: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:142
-msgid "Histogram cloud signature:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:148
-#, c-format
-msgid "* Mean temperature: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:149
-#, c-format
-msgid "* Standard deviation: %.2lf"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:150
-#, c-format
-msgid "* Skewness: %.2lf"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:151
-#, c-format
-msgid "* Histogram classes: %d"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:163
-#, c-format
-msgid "* 98.75 percentile: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:164
-#, c-format
-msgid "* 97.50 percentile: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:165
-#, c-format
-msgid "* 83.50 percentile: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:186
-msgid "Maximum temperature:"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:187
-#, c-format
-msgid "* Cold cloud: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:188
-#, c-format
-msgid "* Warm cloud: %.2lf K"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:193
-msgid "Result: Scene with clouds"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:200
-msgid "Result: Scene cloud free"
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:237
-msgid "Processing first pass..."
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:391
-msgid "Removing ambiguous pixels..."
-msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:393
-msgid "Pass two processing..."
-msgstr ""
-#: ../imagery/i.landsat.acca/tools.c:138
-msgid "Filling small holes in clouds..."
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:70
-#, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar"
-" to radiance first)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:104
-msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:107
-msgid "cloud detection"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:121
-msgid "B56composite (step 6)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:128
-msgid "B45ratio: Desert detection (step 10)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:136
-msgid "Number of classes in the cloud temperature histogram"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:138 ../imagery/i.landsat.acca/main.c:153
-#: ../imagery/i.landsat.acca/main.c:159 ../imagery/i.landsat.acca/main.c:164
-msgid "Cloud settings"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:142
-msgid "Data is Landsat-5 TM"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:143
-msgid "I.e. Thermal band is '.6' not '.61')"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:148
-msgid "Apply post-processing filter to remove small holes"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:152
-msgid "Always use cloud signature (step 14)"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:158
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold "
-"clouds"
-msgstr ""
-#: ../imagery/i.landsat.acca/main.c:163
-msgid "Include a category for cloud shadows"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:58
-msgid "net radiation"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:61
-msgid "Net radiation approximation (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:66 ../imagery/i.eb.soilheatflux/main.c:58
-msgid "Name of albedo raster map [0.0;1.0]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:70 ../imagery/i.eb.soilheatflux/main.c:62
-msgid "Name of NDVI raster map [-1.0;+1.0]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:75
-msgid "Name of surface temperature raster map [K]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:80 ../imagery/i.eb.soilheatflux/main.c:76
-msgid "Name of time of satellite overpass raster map [local time in UTC]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:85
-msgid ""
-"Name of the difference map of temperature from surface skin to about 2 m "
-"height [K]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:89
-msgid "Name of the emissivity map [-]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:94
-msgid "Name of the single-way atmospheric transmissivitymap [-]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:98
-msgid "Name of the Day Of Year (DOY) map [-]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:102
-msgid "Name of the sun zenith angle map [degrees]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:105
-msgid "Name of the output net radiation layer"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:86
-msgid "Names of satellite ETa raster maps [mm/d or cm/d]"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:91
-msgid "Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:96
-msgid "Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:102
-msgid "Value of DOY for ETo first day"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:108
-msgid "Value of DOY for the first day of the period studied"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:114
-msgid "Value of DOY for the last day of the period studied"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:142
-msgid "The DOY for end_period can not be smaller than start_period"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:146
-msgid "The DOY for start_period can not be smaller than eto_doy_min"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:151
-#, c-format
-msgid "Too many ETa files. Only %d allowed."
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
-#: ../imagery/i.evapo.time/main.c:200
-msgid "The min specified input map is two"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:167
-#, c-format
-msgid "Too many ETa_doy files. Only %d allowed."
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:183
-msgid "ETa and ETa_DOY file numbers are not equal!"
-msgstr ""
-#: ../imagery/i.evapo.time/main.c:189
-#, c-format
-msgid "Too many ETo files. Only %d allowed."
-msgstr ""
-#: ../imagery/i.target/main.c:48
-msgid "Targets an imagery group to a GRASS location and mapset."
-msgstr ""
-#: ../imagery/i.target/main.c:57
-msgid "Name of imagery target location"
-msgstr ""
-#: ../imagery/i.target/main.c:63
-msgid "Name of target mapset"
-msgstr ""
-#: ../imagery/i.target/main.c:68
-msgid "Set current location and mapset as target for imagery group"
-msgstr ""
-#: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
-#: ../imagery/i.target/main.c:116
-#, c-format
-msgid "Group <%s> targeted for location [%s], mapset [%s]"
-msgstr ""
-#: ../imagery/i.target/main.c:93
-#, c-format
-msgid "Group <%s> has no target"
-msgstr ""
-#: ../imagery/i.target/main.c:101
-msgid ""
-"Use either the Current Mapset and Location Flag (-c)\n"
-" OR\n"
-" manually enter the variables"
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:65
-msgid "Name of input elevation raster map [m a.s.l.]"
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:69
-msgid "Name of input temperature raster map [C]"
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:73
-msgid "Name of input relative humidity raster map [%]"
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:77
-msgid "Name of input wind speed raster map [m/s]"
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:82
-msgid "Name of input net solar radiation raster map [MJ/m2/h]"
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:86
-msgid "Name of input crop height raster map [m]"
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:89
-msgid "Name for output raster map [mm/h]"
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:93
-msgid "Set negative evapotranspiration to zero"
-msgstr ""
-#: ../imagery/i.evapo.pm/main.c:97
-msgid "Use Night-time"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:30
-msgid "Suffix for output bands with modified band values"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:36
-msgid "Difference threshold between 0 and 1"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:37
-msgid "Threshold = 0 merges only identical segments; threshold = 1 merges all"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:46
-msgid "Spatial radius in number of cells"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:47
-msgid ""
-"Must be >= 1, only cells within spatial bandwidth are considered for mean "
-"shift"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:53
-msgid "Range (spectral) bandwidth [0, 1]"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:54
-msgid ""
-"Only cells within range (spectral) bandwidth are considered for mean shift. "
-"Range bandwidth is used as conductance parameter for adaptive bandwidth"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:67
-msgid "Segmentation method"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:76
-msgid "Similarity calculation method"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:85
-msgid "Minimum number of cells in a segment"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:87
-msgid "The final step will merge small segments with their best neighbor"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:98
-msgid "Importance of radiometric (input raster) values relative to shape"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:108
-msgid "Importance of smoothness relative to compactness"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:117
-msgid "Memory in MB"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:134
-msgid "Name for input raster map with starting seeds"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:141
-msgid "Name of input bounding/constraining raster map"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:143
-msgid ""
-"Must be integer values, each area will be segmented independent of the "
-"others"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:150
-msgid "Name for output goodness of fit estimate map"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:156
-msgid ""
-"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
-"each pixel"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:162
-msgid ""
-"Weighted input, do not perform the default scaling of input raster maps"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:167
-msgid "Use adaptive bandwidth for mean shift"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:168
-msgid "Range (spectral) bandwidth is adapted for each moving window"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:173
-msgid "Use progressive bandwidth for mean shift"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:175
-msgid ""
-"Spatial bandwidth is increased, range (spectral) bandwidth is decreased in "
-"each iteration"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:194
-msgid "Threshold should be > 0 and < 1"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:200
-#, c-format
-msgid "Option '%s' must be >= 1"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:208
-#, c-format
-msgid "Negative value %s for option '%s': disabling"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:213
-#, c-format
-msgid "Value %s for option '%s' is >= 1: disabling"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:235
-msgid "Unable to assign segmentation method"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:245
-msgid "Invalid similarity method"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:251
-#, c-format
-msgid "Option '%s' must be > 0"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:253 ../imagery/i.segment/parse_args.c:258
-#, c-format
-msgid "Option '%s' must be <= 1"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:256
-#, c-format
-msgid "Option '%s' must be >= 0"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:284
-msgid "Seeds raster map not found"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:288
-msgid "Seeeds raster map must be CELL type (integers)"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:298
-msgid "Segmentation constraint/boundary raster map not found"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:302
-msgid "Segmentation constraint raster map must be CELL type (integers)"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:321
-msgid "Integer overflow: too many cells in current region"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:334
-msgid "Invalid output raster name for goodness of fit"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:341
-#, c-format
-msgid "Maximum number of iterations set to %d"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:351
-#, c-format
-msgid "Invalid number of iterations, %d will be used"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:360
-msgid "Invalid number of MB, 300 will be used"
-msgstr ""
-#: ../imagery/i.segment/flag.c:21 ../imagery/i.segment/flag.c:28
-#: ../vector/v.distance/main.c:817 ../vector/v.distance/main.c:894
-#: ../vector/v.distance/main.c:1105
-msgid "Out of memory!"
-msgstr ""
-#: ../imagery/i.segment/main.c:39
-msgid "object recognition"
-msgstr ""
-#: ../imagery/i.segment/main.c:41
-msgid "Identifies segments (objects) from imagery data."
-msgstr ""
-#: ../imagery/i.segment/main.c:47
-msgid "Error in reading data"
-msgstr ""
-#: ../imagery/i.segment/main.c:51
-msgid "Error in creating segments"
-msgstr ""
-#: ../imagery/i.segment/main.c:55
-msgid "Error in writing IDs"
-msgstr ""
-#: ../imagery/i.segment/main.c:59
-msgid "Error in writing goodness of fit"
-msgstr ""
-#: ../imagery/i.segment/main.c:64
-msgid "Error in writing new band values"
-msgstr ""
-#: ../imagery/i.segment/main.c:70
-#, c-format
-msgid "Number of segments created: %d"
-msgstr ""
-#: ../imagery/i.segment/write_output.c:24
-msgid "Writing out segment IDs..."
-msgstr ""
-#: ../imagery/i.segment/write_output.c:122
-msgid "Writing out goodness of fit"
-msgstr ""
-#: ../imagery/i.segment/write_output.c:238
-msgid "Writing out shifted band values..."
-msgstr ""
-#: ../imagery/i.segment/open_files.c:39
-#, c-format
-msgid "Group <%s> not found in the current mapset"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:43
-#, c-format
-msgid "Group <%s> contains no raster maps"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:75
-#, c-format
-msgid "Input map <%s> is all NULL"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:79
-#, c-format
-msgid "Input map <%s> is a constant of value %g"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:128
-msgid "Insufficient number of non-NULL cells in current region"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:159
-msgid "Loading input bands..."
-msgstr ""
-#: ../imagery/i.segment/open_files.c:161
-msgid "Loading input band..."
-msgstr ""
-#: ../imagery/i.segment/open_files.c:193 ../imagery/i.segment/open_files.c:198
-#: ../imagery/i.segment/open_files.c:220 ../imagery/i.segment/open_files.c:278
-#: ../imagery/i.segment/open_files.c:366 ../imagery/i.segment/open_files.c:432
-#: ../imagery/i.segment/open_files.c:488
-msgid "Unable to write to temporary file"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:285
-#, c-format
-msgid "There are no boundary constraints in '%s'"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:341
-#, c-format
-msgid "Loading seeds from raster map <%s>..."
-msgstr ""
-#: ../imagery/i.segment/open_files.c:371
-#, c-format
-msgid "No seeds found in '%s'!"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:391
-msgid "Too many seeds: integer overflow"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:508
-#, c-format
-msgid "Segment %d is already registered!"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:567
-#, c-format
-msgid "Regions with at least %d cells are stored in memory"
-msgstr ""
-#: ../imagery/i.segment/open_files.c:608
-#, c-format
-msgid "Number of segments in memory: %d of %d total"
-msgstr ""
-#: ../imagery/i.segment/watershed.c:19
-msgid "Watershed is not yet implemented"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:93 ../imagery/i.segment/cluster.c:342
-#: ../imagery/i.segment/cluster.c:412
-msgid "Too many objects: integer overflow"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:251
-#: ../imagery/i.segment/mean_shift.c:220
-#, c-format
-msgid "Processing pass %d..."
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:529
-#, c-format
-msgid ""
-"Segmentation processes stopped at %d due to reaching max iteration limit, "
-"more merges may be possible"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:531
-#, c-format
-msgid "Segmentation converged after %d iterations"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:534
-msgid "Assigning region IDs to remaining single-cell regions..."
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:558
-#: ../imagery/i.segment/mean_shift.c:665
-#, c-format
-msgid "Merging segments smaller than %d cells..."
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:972
-#, c-format
-msgid "Region stats should go in tree, %d >= %d"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:979
-msgid "Region ids are different"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:983
-#, c-format
-msgid "Region id %d is invalid"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:987
-msgid "Region consists of only one cell, nothing to update"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:1031
-#: ../imagery/i.segment/region_growing.c:1485
-#, c-format
-msgid "Region size is larger than 2: %d"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:1098
-#, c-format
-msgid "Region size is %d, should be %d"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:1340
-#, c-format
-msgid "Candidate flag is already %s"
-msgstr ""
-msgid "set"
-msgstr ""
-msgid "unset"
-msgstr ""
-#: ../imagery/i.segment/region_growing.c:1570
-#, c-format
-msgid "Region of size %d should be in search tree"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:93
-#, c-format
-msgid "Estimating spectral bandwidth for spatial bandwidth %g..."
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:167
-msgid "Empty moving windows"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:186
-#, c-format
-msgid "Initial range bandwidth: %g"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:188 ../imagery/i.segment/mean_shift.c:192
-#, c-format
-msgid "Estimated range bandwidth: %g"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:208 ../imagery/i.segment/mean_shift.c:245
-#, c-format
-msgid "Spatial bandwidth: %g"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:209 ../imagery/i.segment/mean_shift.c:246
-#, c-format
-msgid "Range bandwidth: %g"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:395
-#, c-format
-msgid "Changes > threshold: %d, largest change: %g"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:398
-#, c-format
-msgid ""
-"Mean shift stopped at %d due to reaching max iteration limit, more changes "
-"may be possible"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:400
-#, c-format
-msgid "Mean shift converged after %d iterations"
-msgstr ""
-#: ../imagery/i.segment/mean_shift.c:748
-#, c-format
-msgid "Renumbering remaining %d segments..."
-msgstr ""
-#: ../imagery/i.segment/cluster.c:66
-#, c-format
-msgid "%d-band clustering with threshold %g"
-msgstr ""
-#: ../imagery/i.segment/cluster.c:135
-msgid "Assigning initial region IDs..."
-msgstr ""
-#: ../imagery/i.segment/cluster.c:425
-msgid "Assigning final region IDs..."
-msgstr ""
-#: ../imagery/i.segment/cluster.c:455
-#, c-format
-msgid "Found %d clumps"
-msgstr ""
-#: ../imagery/i.find/main.c:63
-#, c-format
-msgid "usage: %s location mapset element file."
-msgstr ""
-#: ../imagery/i.find/main.c:83
-msgid "Unable to open temp file."
-msgstr ""
-#: ../imagery/i.gensigset/main.c:46
-msgid "Generates statistics for i.smap from raster map."
-msgstr ""
-#: ../imagery/i.gensigset/main.c:56
-#, c-format
-msgid "Clustering class %d (%d pixels)..."
-msgstr ""
-#: ../imagery/i.gensigset/main.c:59
-#, c-format
-msgid "Number of subclasses is %d"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:76
-#, c-format
-msgid "Not enough pixels in class %d"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:86
-#, c-format
-msgid "Too many subclasses for class index %d"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:88
-#, c-format
-msgid "Number of subclasses set to %d"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:106
-#, c-format
-msgid "Combining subclasses (%d,%d)..."
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:318
-#, c-format
-msgid "Subsignature %d only contains %.0f pixels"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:552
-msgid "Unreliable clustering. Try a smaller initial number of clusters"
-msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:561
-#, c-format
-msgid "Removed a singular subsignature number %d (%d remain)"
-msgstr ""
-#: ../imagery/i.gensigset/parse.c:29
-msgid "Maximum number of sub-signatures in any class"
-msgstr ""
-#: ../imagery/i.gensigset/parse.c:63
-#, c-format
-msgid "Illegal number of sub-signatures (%s)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:93
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:136
-#: ../misc/m.transform/main.c:96
-#, c-format
-msgid "Error conducting transform (%d)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:253
-msgid "Poorly placed image to photo control points"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:255
-msgid "Poorly placed image to target control points"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:257
-#: ../misc/m.transform/main.c:196
-msgid "Insufficient memory"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:259
-#: ../misc/m.transform/main.c:198
-msgid "Parameter error"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:261
-#: ../misc/m.transform/main.c:200
-msgid "No active control points"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:369
-#: ../misc/m.transform/main.c:295
-#, c-format
-msgid "Invalid coordinates: [%s]"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:391
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:65
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:88
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:57
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:48
-#: ../imagery/i.ortho.photo/i.ortho.target/main.c:48
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:47
-msgid "orthorectify"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
-msgid "GCP"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:395
-#: ../misc/m.transform/main.c:320
-msgid "Computes a coordinate transformation based on the control points."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:408
-#: ../misc/m.transform/main.c:341
-msgid "point index"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:409
-#: ../misc/m.transform/main.c:342
-msgid "source coordinates"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:410
-#: ../misc/m.transform/main.c:343
-msgid "destination coordinates"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:411
-#: ../misc/m.transform/main.c:344
-msgid "forward coordinates (destination)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:412
-#: ../misc/m.transform/main.c:345
-msgid "reverse coordinates (source)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:413
-#: ../misc/m.transform/main.c:346
-msgid "forward coordinates difference (destination)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:414
-#: ../misc/m.transform/main.c:347
-msgid "reverse coordinates difference (source)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:415
-#: ../misc/m.transform/main.c:348
-msgid "forward error (destination)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:416
-#: ../misc/m.transform/main.c:349
-msgid "reverse error (source)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:419
-#: ../vector/v.out.ascii/args.c:55 ../misc/m.transform/main.c:352
-msgid "Output format"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:423
-#: ../misc/m.transform/main.c:356
-msgid "Display summary information"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:429
-#: ../misc/m.transform/main.c:361
-msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:430
-msgid "Local x,y,z coordinates to target east,north,height"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:434
-#: ../misc/m.transform/main.c:366
-msgid "Reverse transform of coords file or coeff. dump"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:435
-msgid "Target east,north,height coordinates to local x,y,z"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:439
-#: ../misc/m.transform/main.c:371
-msgid "Display transform matrix coefficients"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:454
-#, c-format
-msgid "Can not read reference points for group <%s>"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:458
-#, c-format
-msgid "Can not read control points for group <%s>"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:67
-msgid "Select or modify the target elevation model."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:71
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:64
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:57
-#: ../imagery/i.ortho.photo/i.ortho.target/main.c:54
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:53
-msgid "Name of imagery group for ortho-rectification"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:76
-msgid "Name of the target location"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:81
-msgid "Name of the target mapset"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:86
-msgid "Name of elevation map to use for ortho-rectification"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:92
-msgid "Math expression to convert to real elevation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:97
-msgid "Unit of the elevation map"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:102
-msgid "No data value"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:107
-msgid "Print currently selected elevation map and exit"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:141
-#, c-format
-msgid "Please select a target for group [%s] first"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:146
-#, c-format
-msgid "Target location [%s] not found\n"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:153
-#, c-format
-msgid "Cannot find default elevation map for target in group [%s]"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:190
-#, c-format
-msgid "Elevation map name is missing. Please set '%s' option"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:212
-#, c-format
-msgid "Mapset [%s] in target location [%s] - %s "
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:214
-msgid "permission denied\n"
-msgstr ""
-msgid "not found\n"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:12
-#, c-format
-msgid "Control Z Point file for group <%s@%s> - "
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:15
-#: ../imagery/i.rectify/cp.c:15
-msgid "Computing equations..."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:21
-#: ../imagery/i.rectify/cp.c:27 ../imagery/i.rectify/cp.c:51
-#: ../vector/v.rectify/cp.c:363
-msgid "Poorly placed control points."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:22
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:27
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:52
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:58
-#: ../imagery/i.rectify/cp.c:28 ../imagery/i.rectify/cp.c:52
-#: ../vector/v.rectify/cp.c:364
-msgid " Can not generate the transformation equation."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:23
-msgid " Run OPTION 7 of i.ortho.photo again!\n"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:26
-msgid "No active Control Points!"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:28
-msgid " Run OPTION 7 of i.ortho.photo!\n"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:45
-#, c-format
-msgid "Reference Point file for group <%s@%s> - "
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:51
-msgid "Poorly placed reference points."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:53
-msgid " Run OPTION 5 of i.ortho.photo again!"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:57
-msgid "No active reference points."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:59
-msgid " Run OPTION 5 of i.ortho.photo!"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:13
-#: ../imagery/i.rectify/target.c:13 ../vector/v.rectify/target.c:18
-#, c-format
-msgid "Target information for group <%s> missing"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:19
-#: ../imagery/i.rectify/target.c:19 ../vector/v.rectify/target.c:29
-#, c-format
-msgid "Target location <%s> not found"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:35
-#: ../imagery/i.rectify/target.c:35
-msgid "Please run i.target for group "
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:36
-msgid "Calculating camera angle to local surface..."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:50
-#: ../imagery/i.ortho.photo/i.ortho.rectify/exec.c:47
-msgid "Could not open elevation raster"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:66
-#, c-format
-msgid "Converting units to meters, factor=%.6f"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:90
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:102
-#: ../imagery/i.rectify/main.c:100
-msgid "Output raster map(s) suffix"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:108
-#: ../imagery/i.rectify/main.c:114
-msgid "Target resolution (ignored if -c flag used)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:116
-#: ../imagery/i.rectify/main.c:122
-msgid "Amount of memory to use in MB"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:131
-msgid "Raster map with camera angle relative to ground surface"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:136
-#: ../imagery/i.rectify/main.c:137
-msgid ""
-"Use current region settings in target location (def.=calculate smallest "
-"area)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:140
-#: ../imagery/i.rectify/main.c:141
-msgid "Rectify all raster maps in group"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:184
-#: ../imagery/i.rectify/main.c:192
-#, c-format
-msgid "Location: %s"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:185
-#: ../imagery/i.rectify/main.c:193
-#, c-format
-msgid "Mapset: %s"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:186
-#: ../imagery/i.rectify/main.c:194
-#, c-format
-msgid "Could not read REF file for group <%s>"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:191
-#: ../imagery/i.rectify/main.c:199
-#, c-format
-msgid "Group <%s> contains no raster maps; run i.group"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:245
-#, c-format
-msgid "No camera reference file selected for group <%s>"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:249
-#, c-format
-msgid "Bad format in camera file for group <%s>"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:255
-#, c-format
-msgid "Bad format in initial exposure station file for group <%s>"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:285
-#: ../imagery/i.rectify/main.c:274
-#, c-format
-msgid "Extension <%s> is illegal"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:288
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:297
-#: ../imagery/i.rectify/main.c:277
-msgid "The following raster map already exists in"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:289
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:298
-#: ../imagery/i.rectify/main.c:278 ../vector/v.rectify/main.c:204
-#, c-format
-msgid "target LOCATION %s, MAPSET %s:"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:292
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:301
-#: ../imagery/i.rectify/main.c:281
-msgid "Orthorectification cancelled."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:316
-#: ../imagery/i.rectify/main.c:296
-msgid "Target resolution must be > 0, ignored"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:323
-#: ../imagery/i.rectify/main.c:303
-#, c-format
-msgid "Using region: N=%f S=%f, E=%f W=%f"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:331
-#, c-format
-msgid "No target elevation model selected for group <%s>"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:390
-#: ../imagery/i.rectify/main.c:325
-#, c-format
-msgid "Input raster map <%s> does not exist in group <%s>."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:392
-#: ../imagery/i.rectify/main.c:327
-msgid "Try:"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:397
-#: ../imagery/i.rectify/main.c:332
-msgid "Exit!"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:74
-#: ../imagery/i.rectify/readcell.c:63
-msgid "Allocating memory and reading input map..."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:43
-#: ../imagery/i.rectify/rectify.c:43
-#, c-format
-msgid "Rectify <%s@%s> (location <%s>)"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:47
-#: ../imagery/i.rectify/rectify.c:46
-#, c-format
-msgid "into  <%s@%s> (location <%s>) ..."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:81
-#, c-format
-msgid "No elevation available at row = %d, col = %d"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:127
-#: ../imagery/i.rectify/rectify.c:110
-#, c-format
-msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:133
-#: ../imagery/i.rectify/rectify.c:116
-#, c-format
-msgid "Raster map <%s@%s>: zone don't match current settings"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
-#: ../imagery/i.rectify/report.c:10
-msgid "complete"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:20
-#: ../imagery/i.rectify/report.c:20
-#, c-format
-msgid "%d rows, %d cols (%ld cells) completed in"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:23
-#: ../imagery/i.rectify/report.c:23
-#, c-format
-msgid "%d:%02d:%02d hours"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:25
-#: ../imagery/i.rectify/report.c:25
-#, c-format
-msgid "%d:%02d minutes"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:27
-#: ../imagery/i.rectify/report.c:27
-#, c-format
-msgid "%.1f cells per minute"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:59
-msgid "Select and modify the imagery group camera reference file."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:71
-msgid "Name of camera reference file"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:77
-msgid "Camera name"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:83
-msgid "Camera id"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:89
-msgid "Calibrated focal length"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:94
-msgid "Principal point coordinates"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:100
-msgid "Fiducial coordinates"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:129
-#, c-format
-msgid "Can not read camera file '%s'"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:132
-#, c-format
-msgid "Replacing camera name '%s' with '%s'"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:138
-#, c-format
-msgid "Replacing camera cam_id '%s' with '%s'"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:146
-#, c-format
-msgid "Replacing calibrated focal length '%g' with '%g'"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
-#, c-format
-msgid ""
-"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
-msgid "Please provide a camera name for a new camera definition"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:168
-msgid "Please provide a camera ID for a new camera definition"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:172
-msgid "Please provide calibrated focal length for a new camera definition"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:176
-msgid "Using default coordinates 0.0, 0.0 for the principal point"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:190
-msgid "Too many fiducials!"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:212
-#, c-format
-msgid "No group '%s' in current mapset"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:217
-#, c-format
-msgid "Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
-msgid "Initial Camera Exposure X-coordinate"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:67
-msgid "Initial Camera Exposure Y-coordinate"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:72
-msgid "Initial Camera Exposure Z-coordinate"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:77
-msgid "Apriori X-coordinate standard deviation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:82
-msgid "Apriori Y-coordinate standard deviation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:87
-msgid "Apriori Z-coordinate standard deviation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:92
-msgid "Initial Camera Omega (roll) degrees"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:97
-msgid "Initial Camera Phi (pitch) degrees"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:102
-msgid "Initial Camera Kappa (yaw) degrees"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:107
-msgid "Apriori Omega (roll) standard deviation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:112
-msgid "Apriori Phi (pitch) standard deviation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:117
-msgid "Apriori Kappa (yaw) standard deviation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:121
-msgid "Use initial values at run time"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:125
-msgid "Print initial values"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:137
-#, c-format
-msgid "Group [%s] not found"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:150
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:154
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:158
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:162
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:166
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:170
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:174
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:178
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:182
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:186
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:190
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:194
-#, c-format
-msgid "Option '%s' is required for new exposure info"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.target/main.c:50
-msgid "Select or modify the imagery group target."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.target/main.c:60
-msgid "Name of target location for ortho-rectification"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.target/main.c:66
-msgid "Name of target mapset for ortho-rectification"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.target/main.c:81
-#, c-format
-msgid "Group [%s] targeted for location [%s], mapset [%s]"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:48
-msgid "Menu driver for the photo imagery programs."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:59
-msgid "Name of Modules"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:70
-msgid "1 - Select/Modify imagery group"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:71
-msgid "2 - Select/Modify imagery group target"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:72
-msgid "3 - Select/Modify target elevation model"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:73
-msgid "4 - Select/Modify imagery group camera"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:74
-msgid "5 - Compute image-to-photo transformation"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:75
-msgid "6 - Initialize exposure station parameters"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:76
-msgid "7 - Compute ortho-rectification parameters"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.photo/menu.c:77
-msgid "8 - Ortho-rectify imagery files"
-msgstr ""
-#: ../imagery/i.maxlik/invert.c:28
-#, c-format
-msgid "Signature %d is not valid (ill-conditioned) - ignored"
-msgstr ""
-#: ../imagery/i.maxlik/invert.c:31
-#, c-format
-msgid "Signature %d is not valid (singular) - ignored"
-msgstr ""
-#: ../imagery/i.maxlik/main.c:66
-msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
-#: ../imagery/i.maxlik/main.c:68
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, g.gui.iclass, or i.gensig."
-msgstr ""
-#: ../imagery/i.maxlik/main.c:82
-msgid "Generated by either i.cluster, g.gui.iclass, or i.gensig"
-msgstr ""
-#: ../imagery/i.maxlik/main.c:92
-msgid "Name for output raster map holding reject threshold results"
-msgstr ""
-#: ../imagery/i.maxlik/open.c:27
-#, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
-msgstr ""
-#: ../imagery/i.maxlik/open.c:30
-#, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at"
-" least 2 raster maps."
-msgstr ""
-#: ../imagery/i.maxlik/open.c:47
-#, c-format
-msgid "Unable to open signature file <%s>"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:44
-msgid "actual evapotranspiration"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:47
-msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:52
-msgid "Name of the diurnal net radiation map [W/m2]"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:57
-msgid "Name of the evaporative fraction map [-]"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:62
-msgid "Name of the surface skin temperature [K]"
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:67
-msgid "Name of the output actual evapotranspiration layer [mm/d]"
-msgstr ""
-#: ../imagery/i.rectify/get_wind.c:180
-#, c-format
-msgid "Region N=%f S=%f E=%f W=%f"
-msgstr ""
-#: ../imagery/i.rectify/get_wind.c:182
-#, c-format
-msgid "Resolution EW=%f NS=%f"
-msgstr ""
-#: ../imagery/i.rectify/main.c:84 ../vector/v.rectify/main.c:71
-msgid "rectify"
-msgstr ""
-#: ../imagery/i.rectify/main.c:86
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-#: ../imagery/i.rectify/main.c:108 ../vector/v.rectify/main.c:104
-msgid "Rectification polynomial order (1-3)"
-msgstr ""
-#: ../imagery/i.rectify/main.c:145
-msgid "Use thin plate spline"
-msgstr ""
-#: ../imagery/i.rectify/main.c:180 ../vector/v.rectify/main.c:145
-#, c-format
-msgid "Invalid order (%d); please enter 1 to %d"
-msgstr ""
-#: ../imagery/i.rectify/cp.c:12 ../vector/v.rectify/cp.c:350
-#, c-format
-msgid "Control Point file for group <%s@%s> - "
-msgstr ""
-#: ../imagery/i.rectify/cp.c:24
-msgid "Not enough active control points for thin plate spline."
-msgstr ""
-#: ../imagery/i.rectify/cp.c:31 ../imagery/i.rectify/cp.c:55
-msgid "Not enough memory to solve transformation equations."
-msgstr ""
-#: ../imagery/i.rectify/cp.c:34
-msgid "Invalid order."
-msgstr ""
-#: ../imagery/i.rectify/cp.c:47 ../vector/v.rectify/cp.c:359
-#, c-format
-msgid "Not enough active control points for current order, %d are required."
-msgstr ""
-#: ../imagery/i.rectify/cp.c:58 ../vector/v.rectify/cp.c:370
-msgid "Invalid order"
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:51
-msgid "soil heat flux"
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:53
-msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:67
-msgid "Name of Surface temperature raster map [K]"
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:83
-msgid "HAPEX-Sahel empirical correction (Roerink, 1995)"
-msgstr ""
-#: ../temporal/t.connect/main.c:34
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:3
-#: ../locale/scriptstrings/t.create_to_translate.c:2
-#: ../locale/scriptstrings/t.support_to_translate.c:2
-#: ../locale/scriptstrings/t.topology_to_translate.c:2
-#: ../locale/scriptstrings/t.list_to_translate.c:2
-#: ../locale/scriptstrings/t.info_to_translate.c:2
-#: ../locale/scriptstrings/t.merge_to_translate.c:2
-#: ../locale/scriptstrings/t.remove_to_translate.c:2
-#: ../locale/scriptstrings/t.sample_to_translate.c:2
-#: ../locale/scriptstrings/t.register_to_translate.c:2
-#: ../locale/scriptstrings/t.unregister_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:2
-#: ../locale/scriptstrings/t.rename_to_translate.c:2
-#: ../locale/scriptstrings/t.select_to_translate.c:2
-#: ../locale/scriptstrings/t.snap_to_translate.c:2
-#: ../locale/scriptstrings/t.shift_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:2
-msgid "temporal"
-msgstr ""
-#: ../temporal/t.connect/main.c:38
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
-msgstr ""
-#: ../temporal/t.connect/main.c:54
-msgid "Overwrite current settings if initialized"
-msgstr ""
-#: ../temporal/t.connect/main.c:59
-msgid "Print current connection parameter in shell style and exit"
-msgstr ""
-#: ../temporal/t.connect/main.c:83 ../temporal/t.connect/main.c:95
-msgid "Temporal GIS database connection not defined. Run t.connect."
-msgstr ""
-#: ../temporal/t.connect/main.c:111
-#, c-format
-msgid ""
-"Default TGIS driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
-msgstr ""
-#: ../temporal/t.connect/main.c:118
-msgid "Default TGIS driver is not set"
-msgstr ""
-#: ../temporal/t.connect/main.c:121
-msgid "Default TGIS database is not set"
-msgstr ""
-#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
-#, c-format
-msgid "Unknown visual class [%d]."
-msgstr ""
-#: ../visualization/ximgview/color.c:239
-msgid "Unable to get sufficient gray shades."
-msgstr ""
-#: ../visualization/ximgview/color.c:256
-msgid "Unable to get sufficient colors."
-msgstr ""
-#: ../visualization/ximgview/color.c:269
-msgid "Using private colormap for DirectColor visual."
-msgstr ""
-#: ../visualization/ximgview/main.c:84
-msgid "Unable to get window attributes"
-msgstr ""
-#: ../visualization/ximgview/main.c:258
-msgid "Unable to open image file"
-msgstr ""
-#: ../visualization/ximgview/main.c:261
-msgid "Unable to read BMP header"
-msgstr ""
-#: ../visualization/ximgview/main.c:264
-msgid "Invalid BMP header"
-msgstr ""
-#: ../visualization/ximgview/main.c:270
-msgid "Unable to map image file"
-msgstr ""
-#: ../visualization/ximgview/main.c:294
-#: ../locale/scriptstrings/d.shade_to_translate.c:6
-#: ../locale/scriptstrings/r.shade_to_translate.c:6
-#: ../misc/m.nviz.script/main.c:74 ../misc/m.nviz.image/main.c:51
-msgid "visualization"
-msgstr ""
-#: ../visualization/ximgview/main.c:295
-msgid "View BMP images from the PNG driver."
-msgstr ""
-#: ../visualization/ximgview/main.c:301
-msgid "Image file"
-msgstr ""
-#: ../visualization/ximgview/main.c:308
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:6
-msgid "Percentage of CPU time to use"
-msgstr ""
-#: ../vector/v.out.postgis/args.c:25
-msgid "Name for output PostGIS datasource"
-msgstr ""
-#: ../vector/v.out.postgis/args.c:27
-msgid "Starts with 'PG' prefix, eg. 'PG:dbname=grass'"
-msgstr ""
-#: ../vector/v.out.postgis/args.c:35
-msgid "Name for output PostGIS layer"
-msgstr ""
-#: ../vector/v.out.postgis/args.c:37
-msgid "If not specified, input name is used"
-msgstr ""
-#: ../vector/v.out.postgis/args.c:44
-msgid ""
-"Name for output vector map defined as a link to the PostGIS feature table"
-msgstr ""
-#: ../vector/v.out.postgis/args.c:46
-msgid ""
-"If not specified, the vector link is not created. The link can be also "
-"manually created by 'v.external' module."
-msgstr ""
-#: ../vector/v.out.postgis/args.c:53
-msgid ""
-"Examples:\n"
-"\t\t'FID=cat': define feature id column 'cat'\n"
-"\t\t'GEOMETRY_NAME=wkb_geometry': define geometry column 'wkb_geometry'\n"
-"\t\t'SPATIAL_INDEX=NO': do not create spatial index on geometry column"
-msgstr ""
-#: ../vector/v.out.postgis/args.c:66
-msgid "Do not export attribute table"
-msgstr ""
-#: ../vector/v.out.postgis/args.c:72
-msgid "Export PostGIS topology instead of simple features"
-msgstr ""
-#: ../vector/v.out.postgis/args.c:77
-msgid "Force 2D output even if input is 3D "
-msgstr ""
-#: ../vector/v.out.postgis/args.c:78 ../vector/v.in.ogr/main.c:338
-#: ../vector/v.out.ogr/args.c:114
-msgid "Useful if input is 3D but all z coordinates are identical"
-msgstr ""
-#: ../vector/v.out.postgis/table.c:27
-#, c-format
-msgid "No database connection for layer <%s>"
-msgstr ""
-#: ../vector/v.out.postgis/table.c:50
-#, c-format
-msgid ""
-"Invalid FID column (%s). FID column must be integer. Please specify "
-"different FID column by 'options=\"FID=<name>\"'."
-msgstr ""
-#: ../vector/v.out.postgis/table.c:57
-#, c-format
-msgid ""
-"Column (%s) already exists in the table. Please specify different geometry "
-"column by 'options=\"GEOMETRY_NAME=<name>\"'."
-msgstr ""
-#: ../vector/v.out.postgis/create.c:28
-#, c-format
-msgid "Unable to create <%s> file"
-msgstr ""
-#: ../vector/v.out.postgis/create.c:66
-#, c-format
-msgid "Invalid option skipped: %s"
-msgstr ""
-#: ../vector/v.out.postgis/create.c:77
-#, c-format
-msgid "EPSG code defined for current location (%s) is overridden by %s"
-msgstr ""
-#: ../vector/v.out.postgis/create.c:105
-#, c-format
-msgid "Error writing <%s> file"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:46
-msgid "PostGIS"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:47
-msgid "simple features"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:48 ../vector/v.build/main.c:37
-#: ../vector/v.clean/main.c:52 ../vector/v.generalize/main.c:82
-#: ../vector/v.in.ogr/main.c:197 ../vector/v.info/main.c:39
-#: ../vector/v.build.polylines/main.c:111
-#: ../locale/scriptstrings/v.build.all_to_translate.c:3
-#: ../locale/scriptstrings/t.topology_to_translate.c:3
-msgid "topology"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:49 ../vector/v.vol.rst/main.c:240
-#: ../vector/v.to.3d/main.c:38 ../vector/v.hull/main.c:54
-#: ../vector/v.drape/main.c:59 ../vector/v.surf.rst/main.c:151
-#: ../vector/v.extrude/main.c:70
-msgid "3D"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:52
-msgid "Exports a vector map layer to PostGIS feature table."
-msgstr ""
-#: ../vector/v.out.postgis/main.c:103
-#, c-format
-msgid "Vector map <%s> is not in native format. Export cancelled."
-msgstr ""
-#: ../vector/v.out.postgis/main.c:110
-#, c-format
-msgid "Unable to open vector map <%s> on topological level"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:134
-#, c-format
-msgid "Unable to create PostGIS layer <%s>"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:156
-#, c-format
-msgid "Feature type '%s' not supported"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:161
-#, c-format
-msgid "Feature type %d is not supported"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:168
-msgid "Copying features failed"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:181
-#, c-format
-msgid "Building %s topology failed"
-msgstr ""
-#: ../vector/v.out.postgis/main.c:186
-#, c-format
-msgid "No features exported. PostGIS layer <%s> not created."
-msgstr ""
-#: ../vector/v.out.postgis/main.c:190
-#, c-format
-msgid "%d feature (%s type) written to <%s>."
-msgid_plural "%d features (%s type) written to <%s>."
-msgstr[0] ""
-#: ../vector/v.out.postgis/main.c:196
-#, c-format
-msgid "%d primitive written to <%s>."
-msgid_plural "%d primitives written to <%s>."
-msgstr[0] ""
-#: ../vector/v.out.postgis/main.c:247
-#, c-format
-msgid "Unable to drop topology schema <%s>"
-msgstr ""
-#: ../vector/v.build/main.c:39
-msgid "Creates topology for vector map."
-msgstr ""
-#: ../vector/v.build/main.c:40
-msgid "Optionally also checks for topological errors."
-msgstr ""
-#: ../vector/v.build/main.c:44
-msgid "Name of vector map"
-msgstr ""
-#: ../vector/v.build/main.c:49
-msgid ""
-"Name for output vector map where erroneous vector features are written to"
-msgstr ""
-#: ../vector/v.build/main.c:61
-msgid "Build topology or dump topology or indices to standard output"
-msgstr ""
-#: ../vector/v.build/main.c:65
-msgid "build topology"
-msgstr ""
-#: ../vector/v.build/main.c:66
-msgid "write topology to stdout"
-msgstr ""
-#: ../vector/v.build/main.c:67
-msgid "write spatial index to stdout"
-msgstr ""
-#: ../vector/v.build/main.c:68
-msgid "write category index to stdout"
-msgstr ""
-#: ../vector/v.build/main.c:69
-msgid "write feature index to stdout (OGR simple-feature-based formats only)"
-msgstr ""
-#: ../vector/v.build/main.c:75
-msgid "Extensive checks for topological errors"
-msgstr ""
-#: ../vector/v.build/main.c:76
-msgid "Perform in-depth checks for topological errors when building topology"
-msgstr ""
-#: ../vector/v.build/main.c:106
-#, c-format
-msgid ""
-"Direct read access to OGR layers is not supported by this module. Run %s to "
-"create a link as GRASS vector map in the current mapset."
-msgstr ""
-#: ../vector/v.build/main.c:111
-#, c-format
-msgid "Vector map <%s> is not in current mapset"
-msgstr ""
-#: ../vector/v.patch/main.c:73
-msgid "Creates a new vector map by combining other vector maps."
-msgstr ""
-#: ../vector/v.patch/main.c:84
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
-msgstr ""
-#: ../vector/v.patch/main.c:88
-msgid "Do not expect input with topology"
-msgstr ""
-#: ../vector/v.patch/main.c:90
-msgid "Applicable when input is points without topology"
-msgstr ""
-#: ../vector/v.patch/main.c:94
-msgid "Expect z coordinate even when not using topology"
-msgstr ""
-#: ../vector/v.patch/main.c:96
-msgid "Applicable when input is points with z coordinate but without topology"
-msgstr ""
-#: ../vector/v.patch/main.c:100
-msgid "Copy also attribute table"
-msgstr ""
-#: ../vector/v.patch/main.c:102
-msgid "Only the table of layer 1 is currently supported"
-msgstr ""
-#: ../vector/v.patch/main.c:106
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
-msgstr ""
-#: ../vector/v.patch/main.c:216
-msgid "Missing table"
-msgstr ""
-#: ../vector/v.patch/main.c:220
-msgid "Key columns differ"
-msgstr ""
-#: ../vector/v.patch/main.c:226
-msgid "Number of columns differ"
-msgstr ""
-#: ../vector/v.patch/main.c:238
-msgid "Column names differ"
-msgstr ""
-#: ../vector/v.patch/main.c:246
-msgid "Column types differ"
-msgstr ""
-#: ../vector/v.patch/main.c:251
-msgid "Length of string columns differ"
-msgstr ""
-#: ../vector/v.patch/main.c:265
-msgid "Key column not found"
-msgstr ""
-#: ../vector/v.patch/main.c:277
-msgid "The output map is not 3D"
-msgstr ""
-#: ../vector/v.patch/main.c:322 ../vector/v.sample/main.c:190
-#: ../scripts/v.db.addtable/v.db.addtable.py:138
-#, c-format, python-format
-msgid "Unable to create table <%s>"
-msgstr ""
-#: ../vector/v.patch/main.c:349
-#, c-format
-msgid "Patching vector map <%s>..."
-msgstr ""
-#: ../vector/v.patch/main.c:373
-#, c-format
-msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr ""
-#: ../vector/v.patch/main.c:429
-#, c-format
-msgid "Building topology for vector map <%s>..."
-msgstr ""
-#: ../vector/v.patch/main.c:435
-msgid "Intersections at borders will have to be snapped"
-msgstr ""
-#: ../vector/v.patch/main.c:436
-msgid "Lines common between files will have to be edited"
-msgstr ""
-#: ../vector/v.patch/main.c:437
-msgid "The header information also may have to be edited"
-msgstr ""
-#: ../vector/v.patch/main.c:439
-#, c-format
-msgid "%d vector maps patched"
-msgstr ""
-#: ../vector/v.patch/main.c:462
-#, c-format
-msgid "Cannot open select cursor: '%s'"
-msgstr ""
-#: ../vector/v.patch/main.c:474
-msgid "Cannot fetch row"
-msgstr ""
-#: ../vector/v.patch/main.c:524
-msgid "Unknown column type"
-msgstr ""
-#: ../vector/v.patch/main.c:532
-#, c-format
-msgid "Cannot insert new record: '%s'"
-msgstr ""
-#: ../vector/v.outlier/outlier.c:86 ../vector/v.outlier/outlier.c:123
-#: ../vector/v.outlier/outlier.c:148 ../vector/v.outlier/outlier.c:161
-#: ../vector/v.outlier/outlier.c:185
-#: ../vector/v.lidar.correction/correction.c:93
-#: ../vector/v.lidar.correction/correction.c:127
-#: ../vector/v.lidar.correction/correction.c:151
-#: ../vector/v.lidar.correction/correction.c:163
-#: ../vector/v.lidar.correction/correction.c:187
-msgid "Impossible to read the database"
-msgstr ""
-#: ../vector/v.outlier/outlier.c:90 ../vector/v.outlier/outlier.c:152
-#: ../vector/v.lidar.correction/correction.c:97
-#: ../vector/v.lidar.correction/correction.c:155
-msgid "Impossible to update the database"
-msgstr ""
-#: ../vector/v.outlier/outlier.c:101 ../vector/v.outlier/outlier.c:110
-#: ../vector/v.outlier/outlier.c:207
-#: ../vector/v.lidar.correction/correction.c:107
-#: ../vector/v.lidar.correction/correction.c:115
-#: ../vector/v.lidar.correction/correction.c:210
-msgid "Impossible to write in the database"
-msgstr ""
-#: ../vector/v.outlier/main.c:71 ../vector/v.extract/main.c:78
-#: ../vector/v.decimate/main.c:127
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:3
-msgid "extract"
-msgstr ""
-#: ../vector/v.outlier/main.c:72 ../vector/v.extract/main.c:79
-#: ../vector/v.decimate/main.c:128
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
-msgid "select"
-msgstr ""
-#: ../vector/v.outlier/main.c:75
-msgid "Removes outliers from vector point data."
-msgstr ""
-#: ../vector/v.outlier/main.c:79 ../vector/v.surf.bspline/main.c:105
-msgid "Estimate point density and distance"
-msgstr ""
-#: ../vector/v.outlier/main.c:81
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
-msgstr ""
-#: ../vector/v.outlier/main.c:90
-msgid "Name for output outlier vector map"
-msgstr ""
-#: ../vector/v.outlier/main.c:95
-msgid "Name for vector map for visualization in QGIS"
-msgstr ""
-#: ../vector/v.outlier/main.c:102 ../vector/v.lidar.correction/main.c:100
-#: ../vector/v.lidar.edgedetection/main.c:97
-#: ../vector/v.surf.bspline/main.c:148
-msgid "Length of each spline step in the east-west direction"
-msgstr ""
-#: ../vector/v.outlier/main.c:103
-msgid "Default: 10 * east-west resolution"
-msgstr ""
-#: ../vector/v.outlier/main.c:111 ../vector/v.lidar.correction/main.c:109
-#: ../vector/v.lidar.edgedetection/main.c:106
-#: ../vector/v.surf.bspline/main.c:157
-msgid "Length of each spline step in the north-south direction"
-msgstr ""
-#: ../vector/v.outlier/main.c:112
-msgid "Default: 10 * north-south resolution"
-msgstr ""
-#: ../vector/v.outlier/main.c:119
-msgid "Tykhonov regularization weight"
-msgstr ""
-#: ../vector/v.outlier/main.c:127
-msgid "Threshold for the outliers"
-msgstr ""
-#: ../vector/v.outlier/main.c:134
-msgid "Filtering option"
-msgstr ""
-#: ../vector/v.outlier/main.c:146 ../vector/v.lidar.correction/main.c:182
-#: ../vector/v.lidar.edgedetection/main.c:207
-msgid "Unable to read name of database"
-msgstr ""
-#: ../vector/v.outlier/main.c:149 ../vector/v.lidar.correction/main.c:185
-#: ../vector/v.lidar.edgedetection/main.c:210
-msgid "Unable to read name of driver"
-msgstr ""
-#: ../vector/v.outlier/main.c:193 ../vector/v.outlier/main.c:261
-#: ../vector/v.lidar.correction/main.c:199
-#: ../vector/v.lidar.correction/main.c:235
-#: ../vector/v.lidar.growing/main.c:163
-#: ../vector/v.lidar.edgedetection/main.c:227
-#: ../vector/v.lidar.edgedetection/main.c:239
-#: ../vector/v.lidar.edgedetection/main.c:261
-#: ../vector/v.surf.bspline/main.c:252 ../vector/v.surf.bspline/main.c:412
-#, c-format
-msgid "No database connection for driver <%s> is defined. Run db.connect."
-msgstr ""
-#: ../vector/v.outlier/main.c:198 ../vector/v.lidar.correction/main.c:204
-#: ../vector/v.lidar.edgedetection/main.c:230
-#: ../vector/v.lidar.edgedetection/main.c:242
-#: ../vector/v.surf.bspline/main.c:257
-msgid "Old auxiliary table could not be dropped"
-msgstr ""
-#: ../vector/v.outlier/main.c:205 ../vector/v.surf.bspline/main.c:267
-#: ../vector/v.surf.bspline/main.c:336
-#, c-format
-msgid "Unable to open vector map <%s> at the topological level"
-msgstr ""
-#: ../vector/v.outlier/main.c:210 ../vector/v.lidar.correction/main.c:165
-#: ../vector/v.lidar.edgedetection/main.c:190
-#, c-format
-msgid "Input vector map <%s> is not 3D!"
-msgstr ""
-#: ../vector/v.outlier/main.c:220 ../vector/v.lidar.correction/main.c:175
-#: ../vector/v.lidar.edgedetection/main.c:200
-msgid "No points in current region!"
-msgstr ""
-#: ../vector/v.outlier/main.c:268
-#, c-format
-msgid "It was impossible to create <%s> table."
-msgstr ""
-#: ../vector/v.outlier/main.c:300 ../vector/v.lidar.edgedetection/main.c:304
-#: ../vector/v.surf.bspline/main.c:554
-#, c-format
-msgid "Adjusted EW splines %d"
-msgstr ""
-#: ../vector/v.outlier/main.c:301 ../vector/v.lidar.edgedetection/main.c:305
-#: ../vector/v.surf.bspline/main.c:555
-#, c-format
-msgid "Adjusted NS splines %d"
-msgstr ""
-#: ../vector/v.outlier/main.c:357 ../vector/v.surf.bspline/main.c:626
-#, c-format
-msgid "Processing subregion %d of %d..."
-msgstr ""
-#: ../vector/v.outlier/main.c:430
-msgid "Outlier detection"
-msgstr ""
-#: ../vector/v.outlier/main.c:450 ../vector/v.surf.bspline/main.c:893
-msgid "No data within this subregion. Consider increasing spline step values."
-msgstr ""
-#: ../vector/v.outlier/main.c:460 ../vector/v.lidar.correction/main.c:444
-#: ../vector/v.lidar.edgedetection/main.c:476
-#: ../vector/v.surf.bspline/main.c:946
-msgid "Auxiliary table could not be dropped"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:239 ../vector/v.surf.rst/main.c:150
-msgid "RST"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:243
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
-msgstr ""
-#: ../vector/v.vol.rst/main.c:248
-msgid "Name of input 3D vector points map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:255
-msgid "Name of input surface raster map for cross-section"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:262
-msgid "Name of column containing w-values attribute to interpolate"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:269 ../vector/v.surf.rst/main.c:277
-msgid "Tension parameter"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:277 ../vector/v.surf.rst/main.c:284
-msgid "Smoothing parameter"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:284
-msgid "Name of column with smoothing parameters"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:292 ../vector/v.surf.rst/main.c:233
-msgid "Name for output deviations vector point map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:298 ../vector/v.surf.rst/main.c:240
-msgid "Name for output cross-validation errors vector point map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:304
-msgid "Name of input raster map used as mask"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:312 ../vector/v.surf.rst/main.c:301
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:17
-msgid "Maximum number of points in a segment"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:321 ../vector/v.surf.rst/main.c:310
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:15
-msgid "Minimum number of points for approximation in a segment (>segmax)"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:330
-msgid "Maximum number of points for approximation in a segment (>npmin)"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:338 ../vector/v.surf.rst/main.c:318
-msgid "Minimum distance between points (to remove almost identical points)"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:347
-msgid "Conversion factor for w-values used for interpolation"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:355
-msgid "Conversion factor for z-values"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:361
-msgid "Name for output cross-section raster map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:367
-msgid "Name for output elevation 3D raster map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:373
-msgid "Name for output gradient magnitude 3D raster map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:380
-msgid "Name for output gradient horizontal angle 3D raster map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:386
-msgid "Name for output gradient vertical angle 3D raster map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:392
-msgid "Name for output change of gradient 3D raster map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:398
-msgid "Name for output Gaussian curvature 3D raster map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:404
-msgid "Name for output mean curvature 3D raster map"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:410
-msgid "Perform a cross-validation procedure without volume interpolation"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:473
-msgid "Smoothing must be a positive value"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:479
-#, c-format
-msgid "Both crossvalidation options (-%c, %s) must be specified"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:482
-msgid "Both crossvalidation and deviations must be specified"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:493
-msgid ""
-"Crossvalidation cannot be computed simultanuously with output grids or devi "
-"file"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:509 ../vector/v.vol.rst/main.c:512
-#: ../vector/v.vol.rst/main.c:515 ../vector/v.vol.rst/main.c:518
-#: ../vector/v.vol.rst/main.c:521 ../vector/v.vol.rst/main.c:524
-#: ../vector/v.vol.rst/main.c:527 ../vector/v.vol.rst/main.c:530
-#: ../vector/v.vol.rst/main.c:533 ../vector/v.vol.rst/main.c:536
-#: ../vector/v.vol.rst/main.c:623 ../vector/v.vol.rst/main.c:654
-#: ../vector/v.vol.rst/main.c:676 ../vector/v.vol.rst/main.c:698
-#: ../vector/v.vol.rst/main.c:720 ../vector/v.vol.rst/main.c:742
-#: ../vector/v.vol.rst/main.c:764 ../vector/v.vol.rst/main.c:786
-#: ../vector/v.vol.rst/user3.c:273 ../vector/v.vol.rst/user3.c:279
-#: ../vector/v.vol.rst/user3.c:285 ../vector/v.vol.rst/user2.c:122
-#: ../vector/v.vol.rst/user2.c:232 ../vector/v.surf.rst/main.c:518
-#: ../vector/v.surf.rst/main.c:523 ../vector/v.surf.rst/main.c:527
-#: ../vector/v.surf.rst/main.c:532 ../vector/v.surf.rst/main.c:536
-#: ../vector/v.surf.rst/main.c:540
-#, c-format
-msgid "Not enough memory for %s"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:541 ../vector/v.vol.rst/main.c:546
-#: ../vector/v.vol.rst/main.c:548 ../vector/v.surf.rst/main.c:547
-#: ../vector/v.surf.rst/main.c:553 ../vector/v.surf.rst/main.c:556
-#: ../vector/v.surf.rst/main.c:560
-#, c-format
-msgid "Unable to create %s"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:557
-#, c-format
-msgid "Unable to open %s"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:565
-msgid "Vector is not 3D"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:607 ../vector/v.surf.rst/main.c:628
-#, c-format
-msgid "Unable to create table '%s'"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:630 ../vector/v.vol.rst/main.c:661
-#: ../vector/v.vol.rst/main.c:683 ../vector/v.vol.rst/main.c:705
-#: ../vector/v.vol.rst/main.c:727 ../vector/v.vol.rst/main.c:749
-#: ../vector/v.vol.rst/main.c:771 ../vector/v.vol.rst/main.c:793
-#, c-format
-msgid "Unable to open temp file '%s'"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:638 ../vector/v.vol.rst/main.c:667
-#: ../vector/v.vol.rst/main.c:689 ../vector/v.vol.rst/main.c:711
-#: ../vector/v.vol.rst/main.c:733 ../vector/v.vol.rst/main.c:755
-#: ../vector/v.vol.rst/main.c:777 ../vector/v.vol.rst/main.c:799
-msgid "Not enough disk space - cannot write temp files"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:642
-msgid ""
-"Unable to create 'cross_output' raster map without 'cross_input' raster map "
-"being specified"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:820
-msgid "Finished interpolating"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:855
-#, c-format
-msgid "Raster map <%s> created"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:895
-#, c-format
-msgid "Vector map <%s> created"
-msgstr ""
-#: ../vector/v.vol.rst/main.c:911
-msgid "Interpolation failed"
-msgstr ""
-#: ../vector/v.vol.rst/user3.c:548
-msgid "Secpar_loop failed"
-msgstr ""
-#: ../vector/v.vol.rst/user3.c:588 ../vector/v.vol.rst/user3.c:599
-#: ../vector/v.vol.rst/user3.c:610 ../vector/v.vol.rst/user3.c:621
-#: ../vector/v.vol.rst/user3.c:632 ../vector/v.vol.rst/user3.c:643
-#: ../vector/v.vol.rst/user3.c:654 ../vector/v.vol.rst/user3.c:665
-msgid "Not enough disk space--cannot write files"
-msgstr ""
-#: ../vector/v.vol.rst/dataoct.c:196
-msgid "Points are too concentrated -- please increase DMIN"
-msgstr ""
-#: ../vector/v.vol.rst/dataoct.c:245
-msgid "Point out of range"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:95 ../vector/v.class/main.c:111
-#: ../vector/v.label/main.c:274 ../vector/v.label.sa/labels.c:75
-#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110
-#: ../ps/ps.map/catval.c:176
-msgid "Unable to get layer info for vector map"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:109
-msgid "Column type of wcolumn is not supported (must be integer or double)"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:112 ../vector/v.out.lidar/main.c:134
-#: ../vector/v.out.lidar/main.c:169 ../vector/v.univar/main.c:366
-#: ../vector/v.class/main.c:132 ../vector/v.sample/main.c:152
-#: ../vector/v.to.rast3/main.c:95 ../vector/v.surf.bspline/main.c:398
-#: ../vector/v.normal/main.c:134 ../vector/v.surf.idw/read_sites.c:68
-#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131
-#: ../ps/ps.map/catval.c:198
-msgid "Unable to select data from table"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:123
-msgid "Cannot read column type of smooth column"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:126
-msgid "Column type of smooth column (datetime) is not supported"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:128
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:150
-msgid "Point without category"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:172 ../vector/v.what.rast3/main.c:272
-#: ../vector/v.sample/main.c:226 ../vector/v.sample/main.c:234
-#: ../vector/v.what.rast/main.c:623 ../vector/v.label/main.c:325
-#: ../vector/v.buffer/main.c:540 ../vector/v.buffer/main.c:642
-#: ../vector/v.label.sa/labels.c:166
-#, c-format
-msgid "No record for category %d in table <%s>"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:208
-msgid "Some points outside of region -- will ignore..."
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:215
-msgid "Cannot allocate memory for point"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:223
-#, c-format
-msgid "Can't insert %lf,%lf,%lf,%lf,%lf a=%d"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:270
-msgid "Strip exists with insufficient data"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:280
-msgid "Zero segments!"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:311
-#, c-format
-msgid ""
-"There are points outside specified 2D/3D region--ignored %d points (total "
-"points: %d)"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:315
-#, c-format
-msgid ""
-"Points are more dense than specified 'DMIN'--ignored %d points (remain %d)"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:321
-#, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given "
-"NPMIN=%d"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:341
-#, c-format
-msgid ""
-"There is less than %d points for interpolation, no segmentation is "
-"necessary, to run the program faster, set segmax=%d (see manual)"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:368
-#, c-format
-msgid "Mask raster map [%s] not found"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:383
-msgid "Bitmap mask created"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:432 ../vector/v.vol.rst/user1.c:485
-#: ../vector/v.vol.rst/user1.c:538 ../vector/v.vol.rst/user1.c:591
-#: ../vector/v.vol.rst/user1.c:644 ../vector/v.vol.rst/user1.c:697
-#: ../vector/v.vol.rst/user1.c:750
-#, c-format
-msgid "Unable to open %s for writing"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:443 ../vector/v.vol.rst/user1.c:496
-#: ../vector/v.vol.rst/user1.c:549 ../vector/v.vol.rst/user1.c:602
-#: ../vector/v.vol.rst/user1.c:655 ../vector/v.vol.rst/user1.c:708
-#: ../vector/v.vol.rst/user1.c:761
-msgid "Unable to read data from temp file"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:461 ../vector/v.vol.rst/user1.c:514
-#: ../vector/v.vol.rst/user1.c:567 ../vector/v.vol.rst/user1.c:620
-#: ../vector/v.vol.rst/user1.c:673 ../vector/v.vol.rst/user1.c:726
-#: ../vector/v.vol.rst/user1.c:779
-#, c-format
-msgid "Error writing cell (%d,%d,%d) with value %f"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:474 ../vector/v.vol.rst/user1.c:527
-#: ../vector/v.vol.rst/user1.c:580 ../vector/v.vol.rst/user1.c:633
-#: ../vector/v.vol.rst/user1.c:686 ../vector/v.vol.rst/user1.c:739
-#: ../vector/v.vol.rst/user1.c:792
-#, c-format
-msgid "Error closing output file %s"
-msgstr ""
-#: ../vector/v.vol.rst/user1.c:476 ../vector/v.vol.rst/user1.c:529
-#: ../vector/v.vol.rst/user1.c:582 ../vector/v.vol.rst/user1.c:635
-#: ../vector/v.vol.rst/user1.c:688 ../vector/v.vol.rst/user1.c:741
-#: ../vector/v.vol.rst/user1.c:794
-#, c-format
-msgid "3D raster map <%s> created"
-msgstr ""
-#: ../vector/v.vol.rst/user2.c:213
-msgid "Cannot allocate A"
-msgstr ""
-#: ../vector/v.vol.rst/user2.c:217
-msgid "Cannot allocate b"
-msgstr ""
-#: ../vector/v.vol.rst/user2.c:221
-msgid "Cannot allocate w"
-msgstr ""
-#: ../vector/v.to.3d/args.c:11
-msgid "Reverse transformation; 3D vector features to 2D"
-msgstr ""
-#: ../vector/v.to.3d/args.c:14
-msgid "Do not copy attribute table"
-msgstr ""
-#: ../vector/v.to.3d/args.c:30
-msgid "Name of attribute column used for height"
-msgstr ""
-#: ../vector/v.to.3d/args.c:32
-msgid "Can be used for reverse transformation, to store height of points"
-msgstr ""
-#: ../vector/v.to.3d/args.c:33 ../vector/v.to.3d/args.c:41
-#: ../vector/v.extrude/main.c:105 ../vector/v.extrude/main.c:113
-#: ../vector/v.extrude/main.c:119
-msgid "Height"
-msgstr ""
-#: ../vector/v.to.3d/args.c:40 ../vector/v.extrude/main.c:112
-msgid "Fixed height for 3D vector features"
-msgstr ""
-#: ../vector/v.to.3d/main.c:40
-msgid "Performs transformation of 2D vector features to 3D."
-msgstr ""
-#: ../vector/v.to.3d/main.c:52
-#, c-format
-msgid "Either '%s' or '%s' parameter have to be used"
-msgstr ""
-#: ../vector/v.to.3d/main.c:58
-#, c-format
-msgid "Parameters '%s' ignored"
-msgstr ""
-#: ../vector/v.to.3d/main.c:63
-msgid "Attribute table required"
-msgstr ""
-#: ../vector/v.to.3d/main.c:76
-#, c-format
-msgid "Vector map <%s> is 2D"
-msgstr ""
-#: ../vector/v.to.3d/main.c:80
-#, c-format
-msgid "Vector map <%s> is 3D"
-msgstr ""
-#: ../vector/v.to.3d/main.c:96 ../vector/v.to.3d/main.c:117
-#: ../vector/v.in.db/main.c:282 ../vector/v.transform/main.c:302
-#: ../vector/v.net/main.c:156
-msgid "Copying attributes..."
-msgstr ""
-#: ../vector/v.to.3d/main.c:98 ../vector/v.to.3d/main.c:119
-msgid "Unable to copy attributes"
-msgstr ""
-#: ../vector/v.to.3d/main.c:128
-#, c-format
-msgid "Vertical extent of vector map <%s>: B: %f T: %f"
-msgstr ""
-#: ../vector/v.to.3d/trans2.c:43 ../vector/v.to.3d/trans3.c:45
-#, c-format
-msgid "Invalid layer number %d, assuming 1"
-msgstr ""
-#: ../vector/v.to.3d/trans2.c:49 ../vector/v.to.3d/trans3.c:51
-#: ../vector/v.to.rast/vect2rast.c:55 ../vector/v.db.select/main.c:171
-#: ../vector/v.db.connect/main.c:213 ../vector/v.extract/main.c:255
-#: ../vector/v.colors.out/make_colors.c:31 ../vector/v.to.rast3/main.c:80
-#: ../vector/v.info/print.c:138 ../vector/v.distance/main.c:522
-#: ../vector/v.distance/main.c:603
-#, c-format
-msgid "Database connection not defined for layer <%s>"
-msgstr ""
-#: ../vector/v.to.3d/trans2.c:67 ../vector/v.to.3d/trans3.c:69
-msgid "Column must be numeric"
-msgstr ""
-#: ../vector/v.to.3d/trans2.c:70
-#, c-format
-msgid "Fetching height from <%s> column..."
-msgstr ""
-#: ../vector/v.to.3d/trans2.c:79 ../vector/v.to.3d/trans3.c:80
-#: ../vector/v.transform/main.c:296
-msgid "Transforming features..."
-msgstr ""
-#: ../vector/v.to.3d/trans2.c:101
-msgid "Skipping feature without category"
-msgstr ""
-#: ../vector/v.to.3d/trans2.c:116
-#, c-format
-msgid "Unable to get height for feature category %d"
-msgstr ""
-#: ../vector/v.to.3d/trans3.c:75
-msgid "Reading categories..."
-msgstr ""
-#: ../vector/v.to.3d/trans3.c:101
-#, c-format
-msgid "Feature id %d has no category - skipping"
-msgstr ""
-#: ../vector/v.to.3d/trans3.c:104
-#, c-format
-msgid "Feature id %d has more categories. Using category %d."
-msgstr ""
-#: ../vector/v.to.3d/trans3.c:130 ../vector/v.to.db/update.c:259
-#, c-format
-msgid "Record (cat %d) does not exist (not updated)"
-msgstr ""
-#: ../vector/v.out.svg/main.c:76
-msgid "Exports a vector map to SVG file."
-msgstr ""
-#: ../vector/v.out.svg/main.c:85
-msgid "Name for SVG output file"
-msgstr ""
-#: ../vector/v.out.svg/main.c:94
-msgid "Output type"
-msgstr ""
-#: ../vector/v.out.svg/main.c:95
-msgid "Defines which feature-type will be extracted"
-msgstr ""
-#: ../vector/v.out.svg/main.c:103
-msgid "Coordinate precision"
-msgstr ""
-#: ../vector/v.out.svg/main.c:109
-msgid "Attribute(s) to include in output SVG"
-msgstr ""
-#: ../vector/v.out.svg/main.c:130
-msgid "Precision must not be negative"
-msgstr ""
-#: ../vector/v.out.svg/main.c:133
-msgid "Precision must not be higher than 15"
-msgstr ""
-#: ../vector/v.out.svg/main.c:201
-#, c-format
-msgid "Unable to create SVG file <%s>"
-msgstr ""
-#: ../vector/v.out.svg/main.c:218
-#, c-format
-msgid "No areas found, skipping %s"
-msgstr ""
-#: ../vector/v.out.svg/main.c:233 ../vector/v.extrude/main.c:275
-#, c-format
-msgid "Skipping area %d without centroid"
-msgstr ""
-#: ../vector/v.out.svg/main.c:259
-#, c-format
-msgid "%d areas extracted"
-msgstr ""
-#: ../vector/v.out.svg/main.c:266
-#, c-format
-msgid "No points found, skipping %s"
-msgstr ""
-#: ../vector/v.out.svg/main.c:295
-#, c-format
-msgid "%d points extracted"
-msgstr ""
-#: ../vector/v.out.svg/main.c:302
-#, c-format
-msgid "No lines found, skipping %s"
-msgstr ""
-#: ../vector/v.out.svg/main.c:329
-#, c-format
-msgid "%d lines extracted"
-msgstr ""
-#: ../vector/v.out.svg/main.c:396
-#, c-format
-msgid "Cannot select attributes for cat=%d"
-msgstr ""
-#: ../vector/v.out.svg/main.c:400 ../vector/v.out.vtk/writeVTK.c:589
-#: ../vector/v.overlay/main.c:487 ../vector/v.out.ogr/attrb.c:53
-#: ../vector/v.lrs/v.lrs.label/main.c:331
-msgid "Unable to fetch data from table"
-msgstr ""
-#: ../vector/v.to.rast/do_areas.c:34 ../vector/v.to.db/areas.c:28
-msgid "Reading areas..."
-msgstr ""
-#: ../vector/v.to.rast/do_areas.c:50 ../vector/v.to.rast/do_areas.c:58
-#, c-format
-msgid "No record for area (cat = %d)"
-msgstr ""
-#: ../vector/v.to.rast/do_areas.c:64 ../vector/v.to.rast/do_lines.c:73
-msgid "Unable to use column specified"
-msgstr ""
-#: ../vector/v.to.rast/do_areas.c:79
-#, c-format
-msgid "Get area %d failed"
-msgstr ""
-#: ../vector/v.to.rast/do_areas.c:84
-msgid "Failed to plot polygon"
-msgstr ""
-#: ../vector/v.to.rast/do_areas.c:118
-msgid "Area without centroid (OK for island)"
-msgstr ""
-#: ../vector/v.to.rast/do_areas.c:128
-msgid "Area centroid without category"
-msgstr ""
-#: ../vector/v.to.rast/do_lines.c:36 ../vector/v.to.db/lines.c:75
-#: ../vector/v.to.db/query.c:23 ../vector/v.colors/scan_cats.c:19
-#: ../vector/v.colors/scan_z.c:31 ../vector/v.colors.out/scan_cats.c:28
-#: ../vector/v.voronoi/main.c:208
-msgid "Reading features..."
-msgstr ""
-#: ../vector/v.to.rast/do_lines.c:59 ../vector/v.to.rast/do_lines.c:67
-#: ../vector/v.to.rast3/main.c:145
-#, c-format
-msgid "No record for line (cat = %d)"
-msgstr ""
-#: ../vector/v.to.rast/do_lines.c:133
-#, c-format
-msgid "%d lines with varying height were not written to raster"
-msgstr ""
-#: ../vector/v.to.rast/main.c:47
-msgid "rasterization"
-msgstr ""
-#: ../vector/v.to.rast/main.c:48
-msgid "Converts (rasterize) a vector map into a raster map."
-msgstr ""
-#: ../vector/v.to.rast/main.c:73
-msgid "Source of raster values"
-msgstr ""
-#: ../vector/v.to.rast/main.c:77
-msgid "read values from attribute table"
-msgstr ""
-#: ../vector/v.to.rast/main.c:78 ../vector/v.colors/main.c:74
-msgid "use category values"
-msgstr ""
-#: ../vector/v.to.rast/main.c:79
-msgid "use value specified by value option"
-msgstr ""
-#: ../vector/v.to.rast/main.c:80
-msgid "use z coordinate (points or contours only)"
-msgstr ""
-#: ../vector/v.to.rast/main.c:81
-msgid "line direction in degrees CCW from east (lines only)"
-msgstr ""
-#: ../vector/v.to.rast/main.c:87
-msgid "Name of column for 'attr' parameter (data type must be numeric)"
-msgstr ""
-#: ../vector/v.to.rast/main.c:93
-msgid "Name of color definition column (with RRR:GGG:BBB entries)"
-msgstr ""
-#: ../vector/v.to.rast/main.c:99
-msgid "Name of column used as raster category labels"
-msgstr ""
-#: ../vector/v.to.rast/main.c:108
-msgid "Raster value (for use=val)"
-msgstr ""
-#: ../vector/v.to.rast/main.c:121
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
-msgid "Create densified lines (default: thin lines)"
-msgstr ""
-#: ../vector/v.to.rast/main.c:122
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
-msgid ""
-"All cells touched by the line will be set, not only those on the render path"
-msgstr ""
-#: ../vector/v.to.rast/main.c:132
-#, c-format
-msgid "Cache size must be at least 1 MiB, changing %d to 1"
-msgstr ""
-#: ../vector/v.to.rast/main.c:141
-msgid "Column parameter missing (or use value parameter)"
-msgstr ""
-#: ../vector/v.to.rast/main.c:146
-msgid "Column parameter cannot be combined with use of category values option"
-msgstr ""
-#: ../vector/v.to.rast/main.c:151
-msgid "Column parameter cannot be combined with use of value option"
-msgstr ""
-#: ../vector/v.to.rast/main.c:156
-msgid "Column parameter cannot be combined with use of z coordinate"
-msgstr ""
-#: ../vector/v.to.rast/main.c:162
-#, c-format
-msgid "Unknown option '%s'"
-msgstr ""
-#: ../vector/v.to.rast/support.c:119 ../vector/v.to.rast/support.c:294
-#: ../vector/v.to.rast/support.c:533
-#, c-format
-msgid "Unknown column <%s> in table <%s>"
-msgstr ""
-#: ../vector/v.to.rast/support.c:123 ../vector/v.to.rast/support.c:298
-#: ../vector/v.to.rast/support.c:537 ../vector/v.to.rast/vect2rast.c:78
-#: ../vector/v.reclass/main.c:241
-#, c-format
-msgid "No records selected from table <%s>"
-msgstr ""
-#: ../vector/v.to.rast/support.c:140 ../vector/v.to.rast/support.c:323
-msgid "No records selected"
-msgstr ""
-#: ../vector/v.to.rast/support.c:153
-#, c-format
-msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr ""
-#: ../vector/v.to.rast/support.c:156
-msgid "Color set to [200:200:200]"
-msgstr ""
-#: ../vector/v.to.rast/support.c:161
-#, c-format
-msgid "Error in color definition column (%s), with cat %d"
-msgstr ""
-#: ../vector/v.to.rast/support.c:266
-msgid "Label column was not specified, no labels will be written"
-msgstr ""
-#: ../vector/v.to.rast/support.c:311 ../vector/v.to.rast/support.c:550
-#: ../vector/v.to.rast/vect2rast.c:69 ../vector/v.what.rast3/main.c:141
-#: ../scripts/v.db.update/v.db.update.py:98
-#: ../scripts/v.dissolve/v.dissolve.py:85
-msgid "Column <%s> not found"
-msgstr ""
-#: ../vector/v.to.rast/support.c:346 ../vector/v.to.rast/support.c:579
-#, c-format
-msgid "Column type (%s) not supported"
-msgstr ""
-#: ../vector/v.to.rast/support.c:395 ../vector/v.to.rast/support.c:436
-msgid "Different labels for the same value are not supported"
-msgstr ""
-#: ../vector/v.to.rast/support.c:655 ../vector/v.to.rast/vect2rast.c:122
-#, c-format
-msgid "Unknown use type: %d"
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:36
-msgid "Loading data..."
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:48 ../vector/v.colors/main.c:266
-#: ../raster3d/r3.flow/main.c:414
-#, c-format
-msgid "Vector map <%s> is not 3D"
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:74
-#, c-format
-msgid "Column type (%s) not supported (did you mean 'labelcolumn'?)"
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:104
-#, c-format
-msgid "Unable to use column <%s>"
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:131
-#, c-format
-msgid "No areas selected from vector map <%s>"
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:137
-msgid ""
-"Area conversion and line densification are mutually exclusive, disabling "
-"line densification."
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:152
-#, c-format
-msgid "Pass %d of %d:"
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:160
-#, c-format
-msgid "Problem processing areas from vector map <%s>, continuing..."
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:172
-#, c-format
-msgid "Problem processing lines from vector map <%s>, continuing..."
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:197
-msgid "Creating support files for raster map..."
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:204
-msgid "Color can be updated from database only if use=attr"
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:224
-#, c-format
-msgid "Converted areas: %d of %d"
-msgstr ""
-#: ../vector/v.to.rast/vect2rast.c:231
-#, c-format
-msgid "Converted points/lines: %d of %d"
-msgstr ""
-#: ../vector/v.rectify/cp.c:307 ../vector/v.rectify/cp.c:331
-#, c-format
-msgid "Can not open file <%s>"
-msgstr ""
-#: ../vector/v.rectify/cp.c:314 ../vector/v.rectify/cp.c:338
-#, c-format
-msgid "Bad format in control point file <%s>"
-msgstr ""
-#: ../vector/v.rectify/cp.c:367
-msgid "Not enough memory to solve for transformation equation"
-msgstr ""
-#: ../vector/v.rectify/target.c:43
-msgid "Please run i.target for group."
-msgstr ""
-#: ../vector/v.rectify/main.c:75
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
-msgstr ""
-#: ../vector/v.rectify/main.c:90
-msgid "Name of input file with control points"
-msgstr ""
-#: ../vector/v.rectify/main.c:95
-msgid ""
-"Name of output file with RMS errors (if omitted or '-' output to stdout"
-msgstr ""
-#: ../vector/v.rectify/main.c:107
-msgid "Field separator for RMS report"
-msgstr ""
-#: ../vector/v.rectify/main.c:111
-msgid "Perform 3D transformation"
-msgstr ""
-#: ../vector/v.rectify/main.c:115
-msgid "Perform orthogonal 3D transformation"
-msgstr ""
-#: ../vector/v.rectify/main.c:119
-msgid "Print RMS errors"
-msgstr ""
-#: ../vector/v.rectify/main.c:120
-msgid "Print RMS errors and exit without rectifying the input map"
-msgstr ""
-#: ../vector/v.rectify/main.c:138
-msgid "Please select a group or give an input file."
-msgstr ""
-#: ../vector/v.rectify/main.c:140
-msgid "Points in group will be ignored, GCPs in input file are used."
-msgstr ""
-#: ../vector/v.rectify/main.c:156
-msgid "3D transformation requires a 3D vector"
-msgstr ""
-#: ../vector/v.rectify/main.c:159
-msgid "A file with 3D control points is needed for 3D transformation"
-msgstr ""
-#: ../vector/v.rectify/main.c:172 ../vector/v.net.salesman/main.c:580
-#, c-format
-msgid "Unable to open file '%s' for writing"
-msgstr ""
-#: ../vector/v.rectify/main.c:203
-#, c-format
-msgid "The vector map <%s> already exists in"
-msgstr ""
-#: ../vector/v.rectify/main.c:206
-msgid "Rectification cancelled."
-msgstr ""
-#: ../vector/v.rectify/main.c:235 ../vector/v.proj/main.c:291
-#: ../vector/v.proj/main.c:417
-msgid "Reading input vector map"
-msgstr ""
-#: ../vector/v.rectify/main.c:276 ../vector/v.category/main.c:761
-msgid "Copying attribute table(s)..."
-msgstr ""
-#: ../vector/v.rectify/main.c:278 ../vector/v.transform/main.c:304
-#: ../vector/v.net/main.c:158 ../vector/v.type/main.c:155
-#: ../vector/v.build.polylines/main.c:241 ../vector/v.category/main.c:763
-#: ../vector/v.proj/main.c:503
-msgid "Failed to copy attribute table to output map"
-msgstr ""
-#: ../vector/v.kernel/main.c:68
-#, c-format
-msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
-msgstr ""
-#: ../vector/v.kernel/main.c:109
-msgid "kernel density"
-msgstr ""
-#: ../vector/v.kernel/main.c:110
-msgid "point density"
-msgstr ""
-#: ../vector/v.kernel/main.c:111
-msgid "heatmap"
-msgstr ""
-#: ../vector/v.kernel/main.c:112
-msgid "hotspot"
-msgstr ""
-#: ../vector/v.kernel/main.c:114
-msgid "Generates a raster density map from vector points map."
-msgstr ""
-#: ../vector/v.kernel/main.c:115
-msgid ""
-"Density is computed using a moving kernel. Optionally generates a vector "
-"density map on a vector network."
-msgstr ""
-#: ../vector/v.kernel/main.c:119
-msgid "Name of input vector map with training points"
-msgstr ""
-#: ../vector/v.kernel/main.c:125
-msgid "Name of input network vector map"
-msgstr ""
-#: ../vector/v.kernel/main.c:128 ../vector/v.kernel/main.c:142
-#: ../vector/v.kernel/main.c:164 ../vector/v.kernel/main.c:172
-#: ../vector/v.kernel/main.c:194 ../vector/v.kernel/main.c:219
-#: ../vector/v.kernel/main.c:225
-msgid "Network"
-msgstr ""
-#: ../vector/v.kernel/main.c:140
-msgid "Name for output vector density map"
-msgstr ""
-#: ../vector/v.kernel/main.c:141
-msgid "Outputs vector map if network map is given"
-msgstr ""
-#: ../vector/v.kernel/main.c:148
-msgid "Kernel radius in map units"
-msgstr ""
-#: ../vector/v.kernel/main.c:155
-msgid "Discretization error in map units"
-msgstr ""
-#: ../vector/v.kernel/main.c:162
-msgid "Maximum length of segment on network"
-msgstr ""
-#: ../vector/v.kernel/main.c:170
-msgid "Maximum distance from point to network"
-msgstr ""
-#: ../vector/v.kernel/main.c:178
-msgid "Multiply the density result by this number"
-msgstr ""
-#: ../vector/v.kernel/main.c:185
-msgid "Node method"
-msgstr ""
-#: ../vector/v.kernel/main.c:191
-msgid "No method applied at nodes with more than 2 arcs"
-msgstr ""
-#: ../vector/v.kernel/main.c:192
-msgid "Equal split (Okabe 2009) applied at nodes"
-msgstr ""
-#: ../vector/v.kernel/main.c:200
-msgid "Kernel function"
-msgstr ""
-#: ../vector/v.kernel/main.c:208
-msgid ""
-"Try to calculate an optimal radius with given 'radius' taken as maximum "
-"(experimental)"
-msgstr ""
-#: ../vector/v.kernel/main.c:213
-msgid "Only calculate optimal radius and exit (no map is written)"
-msgstr ""
-#: ../vector/v.kernel/main.c:218
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
-msgstr ""
-#: ../vector/v.kernel/main.c:224
-msgid "In network mode, multiply the result by number of input points"
-msgstr ""
-#: ../vector/v.kernel/main.c:237
-msgid ""
-"Use option net_output if you compute network density. Name provided in "
-"option output will be used for net_output."
-msgstr ""
-#: ../vector/v.kernel/main.c:256
-msgid "Unknown node method"
-msgstr ""
-#: ../vector/v.kernel/main.c:274
-msgid "Unknown kernel function"
-msgstr ""
-#: ../vector/v.kernel/main.c:280
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
-msgstr ""
-#: ../vector/v.kernel/main.c:284
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function"
-" 'gaussian'."
-msgstr ""
-#: ../vector/v.kernel/main.c:301
-#, c-format
-msgid "Standard deviation: %f"
-msgstr ""
-#: ../vector/v.kernel/main.c:306
-#, c-format
-msgid "Output raster map: resolution: %f\t%s\t%s"
-msgstr ""
-#: ../vector/v.kernel/main.c:309
-#, c-format
-msgid "Output raster map resolution: %f"
-msgstr ""
-#: ../vector/v.kernel/main.c:357
-#, c-format
-msgid "%d point outside threshold"
-msgid_plural "%d points outside threshold"
-msgstr[0] ""
-#: ../vector/v.kernel/main.c:380
-#, c-format
-msgid ""
-"Automatic choice of smoothing parameter (radius), maximum possible value of "
-"radius is set to %f"
-msgstr ""
-#: ../vector/v.kernel/main.c:387
-#, c-format
-msgid "Using maximum distance between points: %f"
-msgstr ""
-#: ../vector/v.kernel/main.c:401
-#, c-format
-msgid "Number of input points: %d."
-msgstr ""
-#: ../vector/v.kernel/main.c:402
-#, c-format
-msgid "%d distance read from the map."
-msgid_plural "%d distances read from the map."
-msgstr[0] ""
-#: ../vector/v.kernel/main.c:407
-#, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-#: ../vector/v.kernel/main.c:418
-#, c-format
-msgid "Optimal smoothing parameter (standard deviation): %f."
-msgstr ""
-#: ../vector/v.kernel/main.c:449
-#, c-format
-msgid "Writing output vector map using smooth parameter %f"
-msgstr ""
-#: ../vector/v.kernel/main.c:451 ../vector/v.kernel/main.c:561
-#, c-format
-msgid "Normalising factor %f"
-msgstr ""
-#: ../vector/v.kernel/main.c:559
-#, c-format
-msgid "Writing output raster map using smooth parameter %f"
-msgstr ""
-#: ../vector/v.kernel/main.c:611
-#, c-format
-msgid "Maximum value in output: %e."
-msgstr ""
-#: ../vector/v.net.spanningtree/main.c:48
-msgid "spanning tree"
-msgstr ""
-#: ../vector/v.net.spanningtree/main.c:50
-msgid "Computes minimum spanning tree for the network."
-msgstr ""
-#: ../vector/v.net.spanningtree/main.c:60
-#: ../vector/v.net.spanningtree/main.c:66
-#: ../vector/v.net.spanningtree/main.c:73
-#: ../vector/v.net.spanningtree/main.c:79 ../vector/v.net.timetable/main.c:275
-#: ../vector/v.net.timetable/main.c:281 ../vector/v.net.timetable/main.c:289
-#: ../vector/v.net.timetable/main.c:296 ../vector/v.net.timetable/main.c:303
-#: ../vector/v.net.alloc/main.c:82 ../vector/v.net.alloc/main.c:115
-#: ../vector/v.net.alloc/main.c:120 ../vector/v.net.alloc/main.c:125
-#: ../vector/v.net.bridge/main.c:61 ../vector/v.net.bridge/main.c:67
-#: ../vector/v.net.bridge/main.c:74 ../vector/v.net.bridge/main.c:80
-#: ../vector/v.net.bridge/main.c:87 ../vector/v.net.components/main.c:85
-#: ../vector/v.net.components/main.c:91 ../vector/v.net.components/main.c:98
-#: ../vector/v.net.components/main.c:104 ../vector/v.net.components/main.c:111
-#: ../vector/v.net.centrality/main.c:110 ../vector/v.net.centrality/main.c:116
-#: ../vector/v.net.centrality/main.c:130 ../vector/v.net.centrality/main.c:136
-#: ../vector/v.net.centrality/main.c:143 ../vector/v.net.distance/main.c:83
-#: ../vector/v.net.distance/main.c:90 ../vector/v.net.distance/main.c:96
-#: ../vector/v.net.distance/main.c:142 ../vector/v.net.distance/main.c:148
-#: ../vector/v.net.distance/main.c:154 ../vector/v.net.allpairs/main.c:94
-#: ../vector/v.net.allpairs/main.c:100 ../vector/v.net.allpairs/main.c:107
-#: ../vector/v.net.connectivity/main.c:65
-#: ../vector/v.net.connectivity/main.c:71
-#: ../vector/v.net.connectivity/main.c:78
-#: ../vector/v.net.connectivity/main.c:84
-#: ../vector/v.net.connectivity/main.c:92 ../vector/v.net.flow/main.c:71
-#: ../vector/v.net.flow/main.c:77 ../vector/v.net.flow/main.c:91
-#: ../vector/v.net.flow/main.c:97 ../vector/v.net.flow/main.c:103
-#: ../vector/v.net.path/main.c:80 ../vector/v.net.path/main.c:87
-#: ../vector/v.net.path/main.c:94 ../vector/v.net.iso/main.c:96
-#: ../vector/v.net.iso/main.c:136 ../vector/v.net.iso/main.c:141
-#: ../vector/v.net.iso/main.c:146 ../vector/v.net.salesman/main.c:169
-#: ../vector/v.net.salesman/main.c:177
-msgid "Cost"
-msgstr ""
-#: ../vector/v.net.spanningtree/main.c:78 ../vector/v.net.timetable/main.c:302
-#: ../vector/v.net.alloc/main.c:124 ../vector/v.net.bridge/main.c:86
-#: ../vector/v.net.components/main.c:110 ../vector/v.net.centrality/main.c:142
-#: ../vector/v.net.distance/main.c:153 ../vector/v.net.allpairs/main.c:106
-#: ../vector/v.net.connectivity/main.c:91 ../vector/v.net.flow/main.c:102
-#: ../vector/v.net.path/main.c:93 ../vector/v.net.iso/main.c:145
-msgid "Node cost column (number)"
-msgstr ""
-#: ../vector/v.net.spanningtree/main.c:124
-#: ../vector/v.net.timetable/main.c:405 ../vector/v.net.bridge/main.c:134
-#: ../vector/v.net.components/main.c:163 ../vector/v.net.centrality/main.c:284
-#: ../vector/v.net.distance/main.c:264 ../vector/v.generalize/network.c:89
-#: ../vector/v.net.connectivity/main.c:178 ../vector/v.net.flow/main.c:226
-#, c-format
-msgid "Unable to build graph for vector map <%s>"
-msgstr ""
-#: ../vector/v.delaunay/in_out.c:93 ../vector/v.voronoi/main.c:230
-msgid "Writing edges..."
-msgstr ""
-#: ../vector/v.delaunay/in_out.c:214
-msgid "Reading point features..."
-msgstr ""
-#: ../vector/v.delaunay/main.c:87 ../vector/v.voronoi/main.c:125
-msgid "triangulation"
-msgstr ""
-#: ../vector/v.delaunay/main.c:88
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-#: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:96
-msgid "Use only points in current region"
-msgstr ""
-#: ../vector/v.delaunay/main.c:103
-msgid "Output triangulation as a graph (lines), not areas"
-msgstr ""
-#: ../vector/v.delaunay/main.c:144 ../vector/v.overlay/area_area.c:116
-#: ../vector/v.in.ogr/main.c:1432 ../vector/v.in.ogr/main.c:1446
-#: ../vector/v.buffer/main.c:755 ../vector/v.buffer/main.c:762
-msgid "Removing duplicates..."
-msgstr ""
-#: ../vector/v.delaunay/main.c:147
-msgid "no points to triangulate"
-msgstr ""
-#: ../vector/v.delaunay/main.c:150
-msgid "Delaunay triangulation..."
-msgstr ""
-#: ../vector/v.delaunay/main.c:162
-msgid "Calculating area centroids..."
-msgstr ""
-#: ../vector/v.delaunay/main.c:172 ../vector/v.in.ogr/main.c:1504
-#: ../vector/v.category/main.c:364
-msgid "Unable to calculate area centroid"
-msgstr ""
-#: ../vector/v.delaunay/main.c:178
-msgid "Unable to calculate area centroid z coordinate"
-msgstr ""
-#: ../vector/v.delaunay/memory.c:64 ../vector/v.delaunay/memory.c:70
-#: ../vector/v.delaunay/memory.c:74 ../vector/v.delaunay/memory.c:84
-#: ../vector/v.delaunay/memory.c:92 ../vector/v.delaunay/memory.c:104
-#: ../vector/v.delaunay/memory.c:108
-msgid "Not enough memory."
-msgstr ""
-#: ../vector/v.delaunay/memory.c:124
-msgid "All allocated edges have been used."
-msgstr ""
-#: ../vector/v.to.db/parse.c:36
-msgid "Layer number or name (write to)"
-msgstr ""
-#: ../vector/v.to.db/parse.c:41 ../vector/v.vect.stats/main.c:154
-#: ../vector/v.net.bridge/main.c:101
-msgid "Feature type"
-msgstr ""
-#: ../vector/v.to.db/parse.c:43
-msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-#: ../vector/v.to.db/parse.c:54
-msgid "Value to upload"
-msgstr ""
-#: ../vector/v.to.db/parse.c:73
-msgid "insert new row for each category if doesn't exist yet"
-msgstr ""
-#: ../vector/v.to.db/parse.c:74
-msgid "area size"
-msgstr ""
-#: ../vector/v.to.db/parse.c:75
-msgid ""
-"compactness of an area, calculated as \n"
-"              compactness = perimeter / (2 * sqrt(PI * area))"
-msgstr ""
-#: ../vector/v.to.db/parse.c:77
-msgid ""
-"fractal dimension of boundary defining a polygon, calculated as \n"
-"              fd = 2 * (log(perimeter) / log(area))"
-msgstr ""
-#: ../vector/v.to.db/parse.c:79
-msgid "perimeter length of an area"
-msgstr ""
-#: ../vector/v.to.db/parse.c:80
-msgid "line length"
-msgstr ""
-#: ../vector/v.to.db/parse.c:81
-msgid "number of features for each category"
-msgstr ""
-#: ../vector/v.to.db/parse.c:82
-msgid "point coordinates, X,Y or X,Y,Z"
-msgstr ""
-#: ../vector/v.to.db/parse.c:83
-msgid "line/boundary starting point coordinates, X,Y or X,Y,Z"
-msgstr ""
-#: ../vector/v.to.db/parse.c:84
-msgid "line/boundary end point coordinates, X,Y or X,Y,Z"
-msgstr ""
-#: ../vector/v.to.db/parse.c:85
-msgid ""
-"categories of areas on the left and right side of the boundary, "
-"'query_layer' is used for area category"
-msgstr ""
-#: ../vector/v.to.db/parse.c:87
-msgid ""
-"result of a database query for all records of the geometry(or geometries) "
-"from table specified by 'query_layer' option"
-msgstr ""
-#: ../vector/v.to.db/parse.c:89
-msgid "slope steepness of vector line or boundary"
-msgstr ""
-#: ../vector/v.to.db/parse.c:90
-msgid ""
-"line sinuousity, calculated as line length / distance between end points"
-msgstr ""
-#: ../vector/v.to.db/parse.c:91
-msgid ""
-"line azimuth, calculated as angle between North direction and endnode "
-"direction at startnode"
-msgstr ""
-#: ../vector/v.to.db/parse.c:92
-msgid "bounding box of area, N,S,E,W"
-msgstr ""
-#: ../vector/v.to.db/parse.c:96
-msgid "Name of attribute column(s) to populate"
-msgstr ""
-#: ../vector/v.to.db/parse.c:105
-msgid "Query layer number or name (read from)"
-msgstr ""
-#: ../vector/v.to.db/parse.c:111
-msgid "Name of attribute column used for 'query' option"
-msgstr ""
-#: ../vector/v.to.db/parse.c:112
-msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
-msgstr ""
-#: ../vector/v.to.db/parse.c:117
-msgid "Field separator for print mode"
-msgstr ""
-#: ../vector/v.to.db/parse.c:122
-msgid "Print only"
-msgstr ""
-#: ../vector/v.to.db/parse.c:128
-msgid "Only print SQL statements"
-msgstr ""
-#: ../vector/v.to.db/parse.c:134
-msgid "Print also totals for option length, area, or count"
-msgstr ""
-#: ../vector/v.to.db/parse.c:143 ../vector/v.to.db/parse.c:146
-#: ../vector/v.univar/main.c:147 ../ps/ps.map/main.c:213
-#: ../ps/ps.map/main.c:232
-#, c-format
-msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
-msgstr ""
-#: ../vector/v.to.db/parse.c:181
-msgid "This option requires one column"
-msgstr ""
-#: ../vector/v.to.db/parse.c:186
-msgid "This option requires two columns"
-msgstr ""
-#: ../vector/v.to.db/parse.c:191
-msgid "This option requires at least two columns"
-msgstr ""
-#: ../vector/v.to.db/parse.c:196
-msgid "This option requires four columns"
-msgstr ""
-#: ../vector/v.to.db/parse.c:203
-msgid "Parameter 'qcolumn' must be specified for 'option=query'"
-msgstr ""
-#: ../vector/v.to.db/parse.c:208
-msgid "The 'sides' option makes sense only for boundaries"
-msgstr ""
-#: ../vector/v.to.db/parse.c:211
-msgid "The 'sinuous' option makes sense only for lines"
-msgstr ""
-#: ../vector/v.to.db/parse.c:214
-msgid "The 'azimuth' option makes sense only for lines"
-msgstr ""
-#: ../vector/v.to.db/query.c:83 ../vector/v.to.db/update.c:30
-#: ../vector/v.to.db/update.c:34 ../vector/v.to.db/main.c:71
-#, c-format
-msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-#: ../vector/v.to.db/query.c:93
-msgid "Querying database... "
-msgstr ""
-#: ../vector/v.to.db/query.c:109
-#, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
-msgstr ""
-#: ../vector/v.to.db/query.c:146
-#, c-format
-msgid "Multiple query results, output value set to NULL (category [%d])"
-msgstr ""
-#: ../vector/v.to.db/query.c:153
-msgid "Unable to fetch record"
-msgstr ""
-#: ../vector/v.to.db/report.c:14
-msgid "No totals for selected option"
-msgstr ""
-#: ../vector/v.to.db/report.c:230
-#, c-format
-msgid "%d categories read from vector map (layer %d)"
-msgstr ""
-#: ../vector/v.to.db/report.c:234
-#, c-format
-msgid "%d records selected from table (layer %d)"
-msgstr ""
-#: ../vector/v.to.db/report.c:237
-#, c-format
-msgid "%d categories read from vector map exist in selection from table"
-msgstr ""
-#: ../vector/v.to.db/report.c:240
-#, c-format
-msgid "%d categories read from vector map don't exist in selection from table"
-msgstr ""
-#: ../vector/v.to.db/report.c:242
-#, c-format
-msgid "%d records updated/inserted (layer %d)"
-msgstr ""
-#: ../vector/v.to.db/report.c:245
-#, c-format
-msgid "%d update/insert errors (layer %d)"
-msgstr ""
-#: ../vector/v.to.db/report.c:248
-#, c-format
-msgid "%d categories with more points (coordinates not loaded)"
-msgstr ""
-#: ../vector/v.to.db/update.c:86
-msgid "Updating database..."
-msgstr ""
-#: ../vector/v.to.db/update.c:151
-#, c-format
-msgid "More elements of category %d, nothing loaded to database"
-msgstr ""
-#: ../vector/v.to.db/update.c:251
-#, c-format
-msgid "Record (cat %d) already exists (not inserted)"
-msgstr ""
-#: ../vector/v.to.db/update.c:279
-#, c-format
-msgid "Cannot update table: %s"
-msgstr ""
-#: ../vector/v.to.db/main.c:39 ../vector/v.type/main.c:41
-#: ../vector/v.category/main.c:695 ../vector/v.buffer/main.c:223
-#: ../locale/scriptstrings/v.centroids_to_translate.c:4
-#: ../locale/scriptstrings/v.clip_to_translate.c:4
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:4
-#: ../misc/m.measure/main.c:49
-msgid "area"
-msgstr ""
-#: ../vector/v.to.db/main.c:40
-msgid "length"
-msgstr ""
-#: ../vector/v.to.db/main.c:41
-msgid "perimeter"
-msgstr ""
-#: ../vector/v.to.db/main.c:42
-msgid "coordinates"
-msgstr ""
-#: ../vector/v.to.db/main.c:43
-msgid "bounding box"
-msgstr ""
-#: ../vector/v.to.db/main.c:45
-msgid "Populates attribute values from vector features."
-msgstr ""
-#: ../vector/v.to.db/main.c:54
-#, c-format
-msgid ""
-"Vector map <%s> not found in the current mapset. Unable to modify vector "
-"maps from different mapsets."
-msgstr ""
-#: ../vector/v.to.db/main.c:120
-#, c-format
-msgid "Category index for vector map <%s> is not sorted"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:73 ../vector/v.kcv/main.c:58
-#: ../vector/v.perturb/main.c:66 ../vector/v.qcount/main.c:62
-#: ../vector/v.random/main.c:101 ../vector/v.normal/main.c:75
-msgid "point pattern"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:74
-msgid "hexagon"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:75
-msgid "Creates a vector map of a user-defined grid."
-msgstr ""
-#: ../vector/v.mkgrid/main.c:82
-msgid "rows,columns"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:86
-msgid "Number of rows and columns in grid"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:95
-msgid "Where to place the grid"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:99
-msgid "current region"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:100
-msgid "use 'coor' and 'box' options"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:105
-msgid "Lower left easting and northing coordinates of map"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:109
-msgid "width,height"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:113
-msgid "Width and height of boxes in grid"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:120
-msgid "Angle of rotation (in degrees counter-clockwise)"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:128
-msgid "Number of vertex points per grid cell"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:141
-msgid "Create hexagons (default: rectangles)"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:146
-msgid "Allow asymmetric hexagons"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:186
-msgid "'coor' and 'position=region' are exclusive options"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:189
-msgid "'box' and 'grid' are exclusive options for 'position=region'"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:212 ../vector/v.mkgrid/main.c:248
-msgid "Invalid width"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:215 ../vector/v.mkgrid/main.c:251
-msgid "Invalid height"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:231
-msgid "'grid' option missing"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:234
-msgid "'coor' option missing"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:237
-msgid "'box' option missing"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:241
-msgid "Invalid easting"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:244
-msgid "Invalid northing"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:309
-msgid "The hexagons will be asymmetrical."
-msgstr ""
-#: ../vector/v.mkgrid/main.c:322 ../vector/v.mkgrid/main.c:325
-msgid "Please use a higher resolution or a larger region"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:329
-#, c-format
-msgid "The number of rows has been adjusted from %d to %d"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:332
-#, c-format
-msgid "The number of columns has been adjusted from %d to %d"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:361 ../vector/v.mkgrid/main.c:446
-#: ../vector/v.mkgrid/main.c:458
-msgid "Unable to fill attribute table"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:365 ../vector/v.mkgrid/main.c:463
-#: ../vector/v.in.ascii/points.c:452 ../vector/v.in.dxf/write_vect.c:70
-#, c-format
-msgid "Unable to insert new record: %s"
-msgstr ""
-#: ../vector/v.mkgrid/main.c:372
-msgid "The rectangles will be asymmetrical."
-msgstr ""
-#: ../vector/v.mkgrid/main.c:417
-msgid "Creating centroids..."
-msgstr ""
-#: ../vector/v.mkgrid/write_grid.c:68
-msgid "Writing out vector rows..."
-msgstr ""
-#: ../vector/v.mkgrid/write_grid.c:107
-msgid "Writing out vector columns..."
-msgstr ""
-#: ../vector/v.mkgrid/hexgrid.c:86
-msgid "Writing out hexagon grid..."
-msgstr ""
-#: ../vector/v.segment/main.c:62 ../vector/v.split/main.c:57
-#: ../vector/v.to.points/main.c:57 ../vector/v.build.polylines/main.c:114
-#: ../vector/v.edit/main.c:58
-msgid "node"
-msgstr ""
-#: ../vector/v.segment/main.c:63 ../vector/v.to.points/main.c:59
-#: ../vector/v.type/main.c:43 ../vector/v.edit/main.c:59
-#: ../vector/v.category/main.c:679
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:6
-msgid "point"
-msgstr ""
-#: ../vector/v.segment/main.c:64 ../vector/v.split/main.c:58
-msgid "segment"
-msgstr ""
-#: ../vector/v.segment/main.c:65 ../vector/v.split/main.c:59
-#: ../vector/v.to.points/main.c:58 ../vector/v.build.polylines/main.c:115
-#: ../vector/v.edit/main.c:60
-msgid "vertex"
-msgstr ""
-#: ../vector/v.segment/main.c:67
-msgid "Creates points/segments from input vector lines and positions."
-msgstr ""
-#: ../vector/v.segment/main.c:70
-msgid "Name of input vector lines map"
-msgstr ""
-#: ../vector/v.segment/main.c:79
-msgid "Name of file containing segment rules"
-msgstr ""
-#: ../vector/v.segment/main.c:146 ../vector/v.segment/main.c:190
-#, c-format
-msgid "Unable to read input: %s"
-msgstr ""
-#: ../vector/v.segment/main.c:157 ../vector/v.segment/main.c:201
-#, c-format
-msgid "Unable to find line of cat %d"
-msgstr ""
-#: ../vector/v.segment/main.c:172
-#, c-format
-msgid ""
-"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
-"%s"
-msgstr ""
-#: ../vector/v.segment/main.c:226
-msgid "End of segment > line length -> cut"
-msgstr ""
-#: ../vector/v.segment/main.c:232
-#, c-format
-msgid ""
-"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
-"%s"
-msgstr ""
-#: ../vector/v.segment/main.c:256 ../vector/v.lrs/v.lrs.segment/main.c:337
-#, c-format
-msgid "Incorrect segment type: %s"
-msgstr ""
-#: ../vector/v.segment/main.c:263
-#, c-format
-msgid "%d point read from input"
-msgid_plural "%d points read from input"
-msgstr[0] ""
-#. GTC Number of lost points
-#. GTC Number of lost lines
-#: ../vector/v.segment/main.c:267 ../vector/v.segment/main.c:278
-#: ../vector/v.lrs/v.lrs.segment/main.c:360
-#: ../vector/v.lrs/v.lrs.segment/main.c:372
-#, c-format
-msgid "%d lost"
-msgid_plural "%d lost"
-msgstr[0] ""
-#. GTC %s is replaced with message indicating number of lost points.
-#: ../vector/v.segment/main.c:269
-#, c-format
-msgid "%d point written to output map (%s)"
-msgid_plural "%d points written to output map (%s)"
-msgstr[0] ""
-#: ../vector/v.segment/main.c:274
-#, c-format
-msgid "%d line read from input"
-msgid_plural "%d lines read from input"
-msgstr[0] ""
-#. GTC %s is replaced with message indicating number of lost lines.
-#: ../vector/v.segment/main.c:280
-#, c-format
-msgid "%d line written to output map (%s)"
-msgid_plural "%d lines written to output map (%s)"
-msgstr[0] ""
-#: ../vector/v.in.pdal/projection.c:125
-msgid "Overriding projection check"
-msgstr ""
-#: ../vector/v.in.pdal/filters.c:46
-#, c-format
-msgid "4 values required for '%s' option"
-msgstr ""
-#: ../vector/v.in.pdal/filters.c:68 ../vector/v.decimate/main.c:294
-#: ../vector/v.in.lidar/main.c:435
-#, c-format
-msgid "Invalid zrange <%s>"
-msgstr ""
-#: ../vector/v.in.pdal/filters.c:95 ../vector/v.in.lidar/filters.c:36
-#: ../raster3d/r3.in.lidar/filters.c:54
-#, c-format
-msgid "Unknown return filter value <%s>"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:107 ../vector/v.net.alloc/main.c:333
-#: ../vector/v.kcv/main.c:175 ../vector/v.net.components/main.c:194
-#: ../vector/v.net.centrality/main.c:270 ../vector/v.db.connect/main.c:336
-#: ../vector/v.net.distance/main.c:295 ../vector/v.net.allpairs/main.c:183
-#: ../vector/v.sample/main.c:193 ../vector/v.net.flow/main.c:185
-#: ../vector/v.net.path/path.c:113 ../vector/v.net.iso/main.c:394
-msgid "Cannot create index"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:112 ../vector/v.net.alloc/main.c:337
-#: ../vector/v.net.components/main.c:198 ../vector/v.net.centrality/main.c:274
-#: ../vector/v.net.distance/main.c:299 ../vector/v.net.allpairs/main.c:187
-#: ../vector/v.net.flow/main.c:189 ../vector/v.net.path/path.c:117
-#: ../vector/v.net.iso/main.c:398
-#, c-format
-msgid "Cannot grant privileges on table <%s>"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:218
-#, c-format
-msgid "Could not find a path between stops %d and %d"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:263
-msgid "Finds shortest path using timetables."
-msgstr ""
-#: ../vector/v.net.timetable/main.c:309
-msgid "Layer number or name with walking connections or -1"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:315
-msgid "Name of column with route ids"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:322
-msgid "Name of column with stop timestamps"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:328
-msgid "Name of column with stop ids"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:334
-msgid "Name of column with walk lengths"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:381
-msgid "Could not initialize the timetables"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:459 ../vector/v.net.timetable/main.c:490
-#: ../vector/v.net.timetable/main.c:498
-#, c-format
-msgid "No stop with category: %d"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:482 ../vector/v.net.path/path.c:153
-#, c-format
-msgid "Wrong input format: %s"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:505
-msgid "'From' and 'To' stops are the same"
-msgstr ""
-#: ../vector/v.net.timetable/main.c:514
-msgid "No path between the stops"
-msgstr ""
-#: ../vector/v.in.db/main.c:55 ../vector/v.kcv/main.c:57
-#: ../vector/v.out.lidar/main.c:476 ../vector/v.decimate/main.c:129
-#: ../vector/v.normal/main.c:74
-msgid "points"
-msgstr ""
-#: ../vector/v.in.db/main.c:57
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-#: ../vector/v.in.db/main.c:61
-msgid "Input table name"
-msgstr ""
-#: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
-msgid "Input DB"
-msgstr ""
-#: ../vector/v.in.db/main.c:75
-msgid "Name of column containing x coordinate"
-msgstr ""
-#: ../vector/v.in.db/main.c:80
-msgid "Name of column containing y coordinate"
-msgstr ""
-#: ../vector/v.in.db/main.c:84
-msgid "Name of column containing z coordinate"
-msgstr ""
-#: ../vector/v.in.db/main.c:85 ../vector/v.random/main.c:138
-#: ../vector/v.random/main.c:147 ../vector/v.random/main.c:160
-#: ../vector/v.random/main.c:170 ../vector/v.random/main.c:175
-msgid "3D output"
-msgstr ""
-#: ../vector/v.in.db/main.c:90
-msgid "Name of column containing category number"
-msgstr ""
-#: ../vector/v.in.db/main.c:91
-msgid "Must refer to an integer column"
-msgstr ""
-#: ../vector/v.in.db/main.c:101
-msgid "Use imported table as attribute table for new map"
-msgstr ""
-#: ../vector/v.in.db/main.c:141
-#, c-format
-msgid ""
-"Vector map <%s> cannot be overwritten because input table <%s> is linked to "
-"this map."
-msgstr ""
-#: ../vector/v.in.db/main.c:177
-#, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
-msgstr ""
-#: ../vector/v.in.db/main.c:190 ../vector/v.db.connect/main.c:295
-msgid "Data type of key column must be integer"
-msgstr ""
-#: ../vector/v.in.db/main.c:194
-#, c-format
-msgid "Option <%s> must be specified when -%c flag is given"
-msgstr ""
-#: ../vector/v.in.db/main.c:199
-#, c-format
-msgid ""
-"Unable to define key column. This operation is not supported by <%s> driver."
-" You need to define <%s> option."
-msgstr ""
-#: ../vector/v.in.db/main.c:235 ../vector/v.voronoi/main.c:322
-msgid "Writing features..."
-msgstr ""
-#: ../vector/v.in.db/main.c:243
-msgid "Key column must be integer"
-msgstr ""
-#: ../vector/v.in.db/main.c:256
-msgid "x/y/z column must be integer or double"
-msgstr ""
-#: ../vector/v.in.db/main.c:288
-msgid "Unable to copy table"
-msgstr ""
-#: ../vector/v.in.db/main.c:313
-#, c-format
-msgid "Unable to add key column <%s>: SERIAL type is not supported by <%s>"
-msgstr ""
-#: ../vector/v.in.db/main.c:324
-#, c-format
-msgid "Failed to update key column <%s>"
-msgstr ""
-#: ../vector/v.in.db/main.c:340
-#, c-format
-msgid "%d point written to vector map."
-msgid_plural "%d points written to vector map."
-msgstr[0] ""
-#: ../vector/v.in.region/main.c:43
-msgid "Creates a vector polygon from the current region extent."
-msgstr ""
-#: ../vector/v.in.region/main.c:51
-msgid "Select type: line or area"
-msgstr ""
-#: ../vector/v.in.region/main.c:58
-msgid "Densify lines using region resolution"
-msgstr ""
-#: ../vector/v.out.dxf/main.c:58
-msgid "DXF"
-msgstr ""
-#: ../vector/v.out.dxf/main.c:60
-msgid "Exports vector map to DXF file format."
-msgstr ""
-#: ../vector/v.out.dxf/main.c:68
-msgid "Name for DXF output file"
-msgstr ""
-#: ../vector/v.out.dxf/main.c:93
-#, c-format
-msgid "%d features written to '%s'."
-msgstr ""
-#: ../vector/v.out.dxf/write_dxf.c:21
-#, c-format
-msgid "The file '%s' already exists."
-msgstr ""
-#: ../vector/v.out.dxf/write_dxf.c:23
-#, c-format
-msgid "The file '%s' already exists and will be overwritten."
-msgstr ""
-#: ../vector/v.out.dxf/write_dxf.c:27
-#, c-format
-msgid "%s: Cannot write dxf file."
-msgstr ""
-#: ../vector/v.net.alloc/main.c:67
-msgid "Allocates subnets for nearest centers."
-msgstr ""
-#: ../vector/v.net.alloc/main.c:69
-msgid ""
-"Center node must be opened (costs >= 0). Costs of center node are used in "
-"calculation."
-msgstr ""
-#: ../vector/v.net.alloc/main.c:81 ../vector/v.net.iso/main.c:95
-msgid "Use costs from centers or costs to centers"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:88 ../vector/v.net.iso/main.c:102
-msgid ""
-"Categories of centers (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:129 ../vector/v.net.path/main.c:110
-#: ../vector/v.net.iso/main.c:150 ../vector/v.net.salesman/main.c:181
-msgid "Use turntable"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:130 ../vector/v.net.alloc/main.c:138
-#: ../vector/v.net.alloc/main.c:146 ../vector/v.net/args.c:64
-#: ../vector/v.net/args.c:111 ../vector/v.net/args.c:123
-#: ../vector/v.net.path/main.c:111 ../vector/v.net.path/main.c:119
-#: ../vector/v.net.path/main.c:127 ../vector/v.net.iso/main.c:151
-#: ../vector/v.net.iso/main.c:159 ../vector/v.net.iso/main.c:167
-#: ../vector/v.net.salesman/main.c:182 ../vector/v.net.salesman/main.c:189
-#: ../vector/v.net.salesman/main.c:196
-msgid "Turntable"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:135 ../vector/v.net.path/main.c:116
-#: ../vector/v.net.iso/main.c:156 ../vector/v.net.salesman/main.c:187
-msgid "Layer with turntable"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:137 ../vector/v.net.alloc/main.c:145
-#: ../vector/v.net.path/main.c:118 ../vector/v.net.path/main.c:126
-#: ../vector/v.net.iso/main.c:158 ../vector/v.net.iso/main.c:166
-#: ../vector/v.net.salesman/main.c:188 ../vector/v.net.salesman/main.c:195
-msgid "Relevant only with -t flag"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:143 ../vector/v.net/args.c:114
-#: ../vector/v.net.path/main.c:124 ../vector/v.net.iso/main.c:164
-#: ../vector/v.net.salesman/main.c:194
-msgid "Layer with unique categories used in turntable"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:156 ../vector/v.net.iso/main.c:177
-msgid "Create unique categories and attribute table"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:158
-msgid "Default: same category like nearest center"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:224 ../vector/v.net.iso/main.c:282
-#: ../vector/v.net.salesman/main.c:277
-msgid "Point is not connected to the network"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:232 ../vector/v.net.iso/main.c:290
-msgid "Center at closed node (costs = -1) ignored"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:250 ../vector/v.net.iso/main.c:308
-#, c-format
-msgid "Number of centers: %d (nlayer %d)"
-msgstr ""
-#: ../vector/v.net.alloc/main.c:253 ../vector/v.net.iso/main.c:311
-msgid "Not enough centers for selected nlayer. Nothing will be allocated."
-msgstr ""
-#: ../vector/v.net.alloc/main.c:275 ../vector/v.net.alloc/main.c:287
-#: ../vector/v.net.iso/main.c:333 ../vector/v.net.iso/main.c:345
-msgid "Calculating costs from centers ..."
-msgstr ""
-#: ../vector/v.net.alloc/main.c:280 ../vector/v.net.alloc/main.c:291
-#: ../vector/v.net.iso/main.c:338 ../vector/v.net.iso/main.c:349
-msgid "Calculating costs to centers ..."
-msgstr ""
-#: ../vector/v.net.alloc/main.c:342
-msgid "Allocating subnets..."
-msgstr ""
-#: ../vector/v.net.alloc/main.c:592 ../vector/v.net.alloc/main.c:627
-#: ../vector/v.net.iso/main.c:704
-msgid "Cannot get line segment, segment out of line"
-msgstr ""
-#: ../vector/v.cluster/main.c:91
-msgid "point cloud"
-msgstr ""
-#: ../vector/v.cluster/main.c:92
-msgid "cluster"
-msgstr ""
-#: ../vector/v.cluster/main.c:93
-msgid "clump"
-msgstr ""
-#: ../vector/v.cluster/main.c:96
-msgid "Performs cluster identification."
-msgstr ""
-#: ../vector/v.cluster/main.c:104
-msgid "Layer number or name for cluster ids"
-msgstr ""
-#: ../vector/v.cluster/main.c:111
-msgid "Maximum distance to neighbors"
-msgstr ""
-#: ../vector/v.cluster/main.c:117
-msgid "Minimum number of points to create a cluster"
-msgstr ""
-#: ../vector/v.cluster/main.c:125
-msgid "Clustering method"
-msgstr ""
-#: ../vector/v.cluster/main.c:129
-msgid "Force 2D clustering"
-msgstr ""
-#: ../vector/v.cluster/main.c:146 ../vector/v.profile/main.c:366
-#: ../doc/vector/v.example/main.c:81
-msgid "Unable to set predetermined vector open level"
-msgstr ""
-#: ../vector/v.cluster/main.c:167
-msgid "Minimum number of points must be at least 2"
-msgstr ""
-#: ../vector/v.cluster/main.c:175 ../vector/v.to.points/main.c:113
-#, c-format
-msgid "Option %s must be positive"
-msgstr ""
-#: ../vector/v.cluster/main.c:188
-msgid "Counting input points ..."
-msgstr ""
-#: ../vector/v.cluster/main.c:194
-#, c-format
-msgid "Layer %d is not empty, choose another layer"
-msgstr ""
-#: ../vector/v.cluster/main.c:201
-msgid "Not enough points in input, nothing to do"
-msgstr ""
-#: ../vector/v.cluster/main.c:218
-msgid "Creating search index ..."
-msgstr ""
-#: ../vector/v.cluster/main.c:253 ../vector/v.cluster/main.c:458
-#: ../vector/v.cluster/main.c:708
-#, c-format
-msgid "Option %s must be a positive number"
-msgstr ""
-#: ../vector/v.cluster/main.c:262 ../vector/v.cluster/main.c:467
-msgid "Estimating maximum distance ..."
-msgstr ""
-#: ../vector/v.cluster/main.c:293 ../vector/v.cluster/main.c:498
-msgid "No neighbors found"
-msgstr ""
-#: ../vector/v.cluster/main.c:303 ../vector/v.cluster/main.c:508
-#, c-format
-msgid "Distance to the %d nearest neighbor:"
-msgstr ""
-#: ../vector/v.cluster/main.c:304 ../vector/v.cluster/main.c:509
-#, c-format
-msgid "Min: %g, max: %g"
-msgstr ""
-#: ../vector/v.cluster/main.c:305 ../vector/v.cluster/main.c:510
-#, c-format
-msgid "Mean: %g"
-msgstr ""
-#: ../vector/v.cluster/main.c:306 ../vector/v.cluster/main.c:511
-#, c-format
-msgid "Standard deviation: %g"
-msgstr ""
-#: ../vector/v.cluster/main.c:308 ../vector/v.cluster/main.c:513
-#, c-format
-msgid "Estimated maximum distance: %g"
-msgstr ""
-#: ../vector/v.cluster/main.c:312 ../vector/v.cluster/main.c:517
-#: ../vector/v.cluster/main.c:930 ../vector/v.cluster/main.c:1091
-msgid "Building clusters ..."
-msgstr ""
-#: ../vector/v.cluster/main.c:354 ../vector/v.cluster/main.c:562
-#, c-format
-msgid "nlines: %d, nclusters: %d"
-msgstr ""
-#: ../vector/v.cluster/main.c:398 ../vector/v.cluster/main.c:607
-#, c-format
-msgid "No clusters found, adjust option %s"
-msgstr ""
-#: ../vector/v.cluster/main.c:434 ../vector/v.cluster/main.c:649
-#: ../vector/v.cluster/main.c:828 ../vector/v.cluster/main.c:1000
-#: ../vector/v.cluster/main.c:1154
-msgid "Write out cluster ids ..."
-msgstr ""
-#: ../vector/v.cluster/main.c:712
-msgid "Loading points ..."
-msgstr ""
-#: ../vector/v.cluster/main.c:736 ../vector/v.cluster/main.c:880
-msgid "Reachability network ..."
-msgstr ""
-#: ../vector/v.cluster/main.c:748 ../vector/v.cluster/main.c:781
-#: ../vector/v.cluster/main.c:890 ../vector/v.cluster/main.c:1068
-#: ../vector/v.cluster/main.c:1102 ../vector/v.cluster/main.c:1139
-msgid "Not enough points found"
-msgstr ""
-#: ../vector/v.cluster/main.c:809
-msgid "Set cluster ids ..."
-msgstr ""
-#: ../vector/v.cluster/main.c:911
-msgid "Neighbor point's core dist is -1"
-msgstr ""
-#: ../vector/v.cluster/main.c:1056
-msgid "Core density ..."
-msgstr ""
-#: ../vector/v.cluster/main.c:1180
-#, c-format
-msgid "%d clusters found"
-msgstr ""
-#: ../vector/v.cluster/main.c:1181
-#, c-format
-msgid "%d outliers found"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:138
-msgid "Count points in areas, calculate statistics from point attributes."
-msgstr ""
-#: ../vector/v.vect.stats/main.c:142
-msgid "Name of existing vector map with points"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:147
-msgid "Name of existing vector map with areas"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:160
-msgid "Layer number for points map"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:165
-msgid "Category values for points map"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:170
-msgid ""
-"WHERE conditions of SQL statement without 'where' keyword for points map"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:175
-msgid "Layer number for area map"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:180
-msgid "Category values for area map"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:185
-msgid "WHERE conditions of SQL statement without 'where' keyword for area map"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:202
-msgid "Method for aggregate statistics"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:207
-msgid "Column name of points map to use for statistics"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:208
-msgid "Column of points map must be numeric"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:213
-msgid "Column name to upload points count"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:215
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not"
-" existing"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:219
-msgid "Column name to upload statistics"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:221
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:229
-msgid "Print output to stdout, do not update attribute table"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:230
-msgid "First column is always area category"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:283
-#, c-format
-msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:345 ../vector/v.vect.stats/main.c:427
-#: ../vector/v.extract/copy_tab.c:117
-#, c-format
-msgid "Unable to open database <%s> with driver <%s>"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:349
-msgid "count_column is required to upload point counts"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:358
-msgid "count_column must be of type integer"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:371 ../vector/v.vect.stats/main.c:401
-#, c-format
-msgid "Unable to add column <%s>"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:377
-msgid "stats_column is required to upload point stats"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:388
-msgid "stats_column must be of type double precision"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:410
-msgid "collecting attributes from points vector..."
-msgstr ""
-#: ../vector/v.vect.stats/main.c:447
-msgid "column for points vector must be numeric"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:508
-#, c-format
-msgid "No area categories in vector <%s>, layer <%s>"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:533
-msgid "Selecting points for each area..."
-msgstr ""
-#: ../vector/v.vect.stats/main.c:638
-#, c-format
-msgid "could not find area category %d"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:764
-#, c-format
-msgid "%d records updated"
-msgstr ""
-#: ../vector/v.vect.stats/main.c:766 ../vector/v.what.rast/main.c:688
-#: ../vector/v.distance/main.c:1750
-#, c-format
-msgid "%d update errors"
-msgstr ""
-#: ../vector/v.db.select/main.c:58
-msgid "Prints vector map attributes."
-msgstr ""
-#: ../vector/v.db.select/main.c:61 ../vector/v.db.select/main.c:79
-#: ../vector/v.db.select/main.c:93
-msgid "Main"
-msgstr ""
-#: ../vector/v.db.select/main.c:75
-msgid "GROUP BY conditions of SQL statement without 'group by' keyword"
-msgstr ""
-#: ../vector/v.db.select/main.c:83
-msgid "Output vertical record separator"
-msgstr ""
-#: ../vector/v.db.select/main.c:100
-msgid ""
-"Print minimal region extent of selected vector features instead of "
-"attributes"
-msgstr ""
-#: ../vector/v.db.select/main.c:115
-msgid "Exclude attributes not linked to features"
-msgstr ""
-#: ../vector/v.db.select/main.c:157
-#, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
-msgstr ""
-#: ../vector/v.db.select/main.c:208
-msgid "Unable to open select cursor"
-msgstr ""
-#: ../vector/v.db.select/main.c:229 ../vector/v.reclass/main.c:267
-#, c-format
-msgid "Unable to fetch data from table <%s>"
-msgstr ""
-#: ../vector/v.db.select/main.c:286
-#, c-format
-msgid "Unable to get bounding box of area %d"
-msgstr ""
-#: ../vector/v.db.select/main.c:292
-#, c-format
-msgid "Unable to get bounding box of line %d"
-msgstr ""
-#: ../vector/v.kcv/main.c:60
-msgid "Randomly partition points into test/train sets."
-msgstr ""
-#: ../vector/v.kcv/main.c:70
-msgid "Number of partitions"
-msgstr ""
-#: ../vector/v.kcv/main.c:71
-msgid "Must be > 1"
-msgstr ""
-#: ../vector/v.kcv/main.c:76
-msgid "Name for new column to which partition number is written"
-msgstr ""
-#: ../vector/v.kcv/main.c:85
-#, c-format
-msgid "'%s' must be > 1"
-msgstr ""
-#: ../vector/v.kcv/main.c:96 ../vector/v.kcv/main.c:186
-#: ../vector/v.category/main.c:186 ../vector/v.category/main.c:250
-#: ../vector/v.category/main.c:258
-#, c-format
-msgid "Unable to open vector map <%s> at topological level %d"
-msgstr ""
-#: ../vector/v.kcv/main.c:102
-msgid "Layer number must be positive"
-msgstr ""
-#: ../vector/v.kcv/main.c:107
-#, c-format
-msgid "More partitions than points (%d)"
-msgstr ""
-#: ../vector/v.kcv/main.c:120
-#, c-format
-msgid "Unable to get layer info for vector map <%s>"
-msgstr ""
-#: ../vector/v.kcv/main.c:145
-#, c-format
-msgid "Column <%s> already exists but is not numeric"
-msgstr ""
-#: ../vector/v.kcv/main.c:160
-#, c-format
-msgid "Unable to alter table: %s"
-msgstr ""
-#: ../vector/v.kcv/main.c:168 ../vector/v.db.connect/main.c:158
-msgid "Unable to modify vector map stored in other mapset"
-msgstr ""
-#: ../vector/v.kcv/main.c:179 ../vector/v.db.connect/main.c:341
-#, c-format
-msgid "Cannot grant privileges on table %s"
-msgstr ""
-#: ../vector/v.kcv/main.c:182 ../vector/v.db.connect/main.c:344
-msgid "Select privileges were granted on the table"
-msgstr ""
-#: ../vector/v.kcv/main.c:267
-#, c-format
-msgid "No category for line %d in layer %d"
-msgstr ""
-#: ../vector/v.kcv/main.c:284 ../vector/v.sample/main.c:263
-#, c-format
-msgid "Unable to insert row: %s"
-msgstr ""
-#: ../vector/v.kcv/main.c:300
-msgid "internal error"
-msgstr ""
-#: ../vector/v.transform/main.c:75
-msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
-msgstr ""
-#: ../vector/v.transform/main.c:80
-msgid "Shift all z values to bottom=0"
-msgstr ""
-#: ../vector/v.transform/main.c:85
-msgid "Swap coordinates x, y and then apply other parameters"
-msgstr ""
-#: ../vector/v.transform/main.c:90
-msgid "Swap coordinates x, z and then apply other parameters"
-msgstr ""
-#: ../vector/v.transform/main.c:95
-msgid "Swap coordinates y, z and then apply other parameters"
-msgstr ""
-#: ../vector/v.transform/main.c:100
-msgid "Swap coordinates after the other transformations"
-msgstr ""
-#: ../vector/v.transform/main.c:104
-msgid "Do not build topology"
-msgstr ""
-#: ../vector/v.transform/main.c:109 ../vector/v.transform/main.c:120
-#: ../vector/v.transform/main.c:129 ../vector/v.transform/main.c:138
-#: ../vector/v.transform/main.c:147 ../vector/v.transform/main.c:156
-#: ../vector/v.transform/main.c:165 ../vector/v.transform/main.c:175
-#: ../vector/v.transform/main.c:182
-msgid "Custom"
-msgstr ""
-#: ../vector/v.transform/main.c:118
-msgid "Shifting value for x coordinates"
-msgstr ""
-#: ../vector/v.transform/main.c:127
-msgid "Shifting value for y coordinates"
-msgstr ""
-#: ../vector/v.transform/main.c:136 ../vector/v.extrude/main.c:101
-msgid "Shifting value for z coordinates"
-msgstr ""
-#: ../vector/v.transform/main.c:145
-msgid "Scaling factor for x coordinates"
-msgstr ""
-#: ../vector/v.transform/main.c:154
-msgid "Scaling factor for y coordinates"
-msgstr ""
-#: ../vector/v.transform/main.c:163
-msgid "Scaling factor for z coordinates"
-msgstr ""
-#: ../vector/v.transform/main.c:173
-msgid "Rotation around z axis in degrees (counter-clockwise)"
-msgstr ""
-#: ../vector/v.transform/main.c:179
-msgid "Name of attribute column(s) used as transformation parameters"
-msgstr ""
-#: ../vector/v.transform/main.c:181
-msgid "Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr"
-msgstr ""
-#: ../vector/v.transform/main.c:201
-#, c-format
-msgid "Columns require a valid layer. Please use '%s' parameter."
-msgstr ""
-#: ../vector/v.transform/main.c:231
-#, c-format
-msgid "Unknown column parameter '%s'"
-msgstr ""
-#: ../vector/v.transform/main.c:242
-#, c-format
-msgid "Unable to tokenize column string: [%s]"
-msgstr ""
-#: ../vector/v.transform/main.c:310
-#, c-format
-msgid "New vector map <%s> boundary coordinates:"
-msgstr ""
-#: ../vector/v.transform/main.c:312
-#, c-format
-msgid " N: %-10.3f    S: %-10.3f"
-msgstr ""
-#: ../vector/v.transform/main.c:313
-#, c-format
-msgid " E: %-10.3f    W: %-10.3f"
-msgstr ""
-#: ../vector/v.transform/main.c:314
-#, c-format
-msgid " B: %6.3f    T: %6.3f"
-msgstr ""
-#: ../vector/v.transform/trans_digit.c:119
-#, c-format
-msgid "Unsupported column type of <%s>"
-msgstr ""
-#: ../vector/v.transform/trans_digit.c:127
-#, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
-msgstr ""
-#: ../vector/v.transform/trans_digit.c:138
-msgid "No category number defined. Using default transformation parameters."
-msgstr ""
-#: ../vector/v.net.bridge/main.c:49
-msgid "articulation points"
-msgstr ""
-#: ../vector/v.net.bridge/main.c:51
-msgid "Computes bridges and articulation points in the network."
-msgstr ""
-#: ../vector/v.net.bridge/main.c:98
-msgid "Finds bridges"
-msgstr ""
-#: ../vector/v.net.bridge/main.c:99
-msgid "Finds articulation points"
-msgstr ""
-#: ../vector/v.clean/main.c:54 ../vector/v.in.ogr/main.c:199
-#: ../locale/scriptstrings/t.snap_to_translate.c:4
-msgid "snapping"
-msgstr ""
-#: ../vector/v.clean/main.c:55
-msgid "Toolset for cleaning topology of vector map."
-msgstr ""
-#: ../vector/v.clean/main.c:70
-msgid "Name of output map where errors are written"
-msgstr ""
-#: ../vector/v.clean/main.c:81
-msgid "Cleaning tool"
-msgstr ""
-#: ../vector/v.clean/main.c:97
-msgid "break lines at each intersection"
-msgstr ""
-#: ../vector/v.clean/main.c:98
-msgid "remove duplicate geometry features (pay attention to categories!)"
-msgstr ""
-#: ../vector/v.clean/main.c:99
-msgid "remove dangles, threshold ignored if < 0"
-msgstr ""
-#: ../vector/v.clean/main.c:100
-msgid ""
-"change the type of boundary dangle to line, threshold ignored if < 0, input "
-"line type is ignored"
-msgstr ""
-#: ../vector/v.clean/main.c:102
-msgid "remove bridges connecting area and island or 2 islands"
-msgstr ""
-#: ../vector/v.clean/main.c:103
-msgid ""
-"change the type of bridges connecting area and island or 2 islands from "
-"boundary to line"
-msgstr ""
-#: ../vector/v.clean/main.c:105
-msgid "snap lines to vertex in threshold"
-msgstr ""
-#: ../vector/v.clean/main.c:106
-msgid "remove duplicate area centroids ('type' option ignored)"
-msgstr ""
-#: ../vector/v.clean/main.c:107
-msgid ""
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different"
-msgstr ""
-#: ../vector/v.clean/main.c:110
-msgid ""
-"remove vertices in threshold from lines and boundaries, boundary is pruned "
-"only if topology is not damaged (new intersection, changed attachment of "
-"centroid), first and last segment of the boundary is never changed"
-msgstr ""
-#: ../vector/v.clean/main.c:114
-msgid "remove small areas, the longest boundary with adjacent area is removed"
-msgstr ""
-#: ../vector/v.clean/main.c:115
-msgid "remove all lines or boundaries of zero length, threshold is ignored"
-msgstr ""
-#: ../vector/v.clean/main.c:116
-msgid "remove small angles between lines at nodes"
-msgstr ""
-#: ../vector/v.clean/main.c:124
-msgid "Threshold in map units, one value for each tool"
-msgstr ""
-#: ../vector/v.clean/main.c:125
-msgid "Default: 0.0[,0.0,...])"
-msgstr ""
-#: ../vector/v.clean/main.c:130
-msgid "Do not build topology for the output vector"
-msgstr ""
-#: ../vector/v.clean/main.c:135
-msgid "Combine tools with recommended follow-up tools"
-msgstr ""
-#: ../vector/v.clean/main.c:156
-msgid "You must select at least one tool"
-msgstr ""
-#: ../vector/v.clean/main.c:191
-msgid "Tool doesn't exist"
-msgstr ""
-#: ../vector/v.clean/main.c:202
-msgid ""
-"Note: In latitude-longitude coordinate system specify threshold in degree "
-"unit"
-msgstr ""
-#: ../vector/v.clean/main.c:215
-#, c-format
-msgid "Threshold for tool %d may not be > 0, set to 0"
-msgstr ""
-#: ../vector/v.clean/main.c:224
-msgid "Tool: Threshold"
-msgstr ""
-#: ../vector/v.clean/main.c:229
-msgid "Break"
-msgstr ""
-#: ../vector/v.clean/main.c:232
-msgid "Remove duplicates"
-msgstr ""
-#: ../vector/v.clean/main.c:235
-msgid "Remove dangles"
-msgstr ""
-#: ../vector/v.clean/main.c:238
-msgid "Change type of boundary dangles"
-msgstr ""
-#: ../vector/v.clean/main.c:242
-msgid "Remove bridges"
-msgstr ""
-#: ../vector/v.clean/main.c:245
-msgid "Change type of boundary bridges"
-msgstr ""
-#: ../vector/v.clean/main.c:249
-msgid "Snap vertices"
-msgstr ""
-#: ../vector/v.clean/main.c:252
-msgid "Remove duplicate area centroids"
-msgstr ""
-#: ../vector/v.clean/main.c:256
-msgid "Break polygons"
-msgstr ""
-#: ../vector/v.clean/main.c:259
-msgid "Prune"
-msgstr ""
-#: ../vector/v.clean/main.c:262
-msgid "Remove small areas"
-msgstr ""
-#: ../vector/v.clean/main.c:265
-msgid "Remove small angles at nodes"
-msgstr ""
-#: ../vector/v.clean/main.c:270
-msgid "Remove all lines or boundaries of zero length"
-msgstr ""
-#: ../vector/v.clean/main.c:314
-msgid "Topological cleaning works best with native GRASS vector format"
-msgstr ""
-#: ../vector/v.clean/main.c:325
-msgid "Failed to copy attribute table to output vector map"
-msgstr ""
-#: ../vector/v.clean/main.c:340 ../vector/v.clean/main.c:351
-msgid "Rebuilding parts of topology..."
-msgstr ""
-#: ../vector/v.clean/main.c:360 ../vector/v.clean/main.c:405
-#: ../vector/v.clean/main.c:456
-msgid "Tool: Split lines"
-msgstr ""
-#: ../vector/v.clean/main.c:363 ../vector/v.clean/main.c:409
-#: ../vector/v.clean/main.c:462
-msgid "Tool: Break lines at intersections"
-msgstr ""
-#: ../vector/v.clean/main.c:366 ../vector/v.clean/main.c:375
-#: ../vector/v.clean/main.c:411 ../vector/v.clean/main.c:427
-#: ../vector/v.clean/main.c:464
-msgid "Tool: Remove duplicates"
-msgstr ""
-#: ../vector/v.clean/main.c:369 ../vector/v.clean/main.c:418
-#: ../vector/v.clean/main.c:469
-msgid "Tool: Merge lines"
-msgstr ""
-#: ../vector/v.clean/main.c:379
-msgid "Tool: Remove dangles"
-msgstr ""
-#: ../vector/v.clean/main.c:383
-msgid "Tool: Change type of boundary dangles"
-msgstr ""
-#: ../vector/v.clean/main.c:387
-msgid "Tool: Remove bridges"
-msgstr ""
-#: ../vector/v.clean/main.c:391
-msgid "Tool: Change type of boundary bridges"
-msgstr ""
-#: ../vector/v.clean/main.c:395
-msgid "Tool: Remove duplicate area centroids"
-msgstr ""
-#: ../vector/v.clean/main.c:399
-msgid "Tool: Snap line to vertex in threshold"
-msgstr ""
-#: ../vector/v.clean/main.c:413 ../vector/v.clean/main.c:447
-#: ../vector/v.clean/main.c:466
-msgid "Tool: Remove small angles at nodes"
-msgstr ""
-#: ../vector/v.clean/main.c:424
-msgid "Tool: Break polygons"
-msgstr ""
-#: ../vector/v.clean/main.c:432
-msgid "Tool: Prune lines/boundaries"
-msgstr ""
-#: ../vector/v.clean/main.c:436
-msgid "Tool: Remove small areas"
-msgstr ""
-#: ../vector/v.clean/main.c:442
-msgid "Tool: Merge boundaries"
-msgstr ""
-#: ../vector/v.clean/main.c:475
-msgid "Tool: Remove all lines and boundaries of zero length"
-msgstr ""
-#: ../vector/v.clean/main.c:484
-msgid "Rebuilding topology for output vector map..."
-msgstr ""
-#: ../vector/v.clean/main.c:495
-msgid "Building topology for error vector map..."
-msgstr ""
-#: ../vector/v.clean/prune.c:216
-#, c-format
-msgid ""
-"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
-msgstr ""
-#: ../vector/v.clean/prune.c:220
-#, c-format
-msgid "%d boundaries not pruned because pruning would damage topology"
-msgstr ""
-#: ../vector/v.clean/rmdac.c:60
-#, c-format
-msgid "Duplicate area centroids: %d"
-msgstr ""
-#: ../vector/v.clean/rmline.c:64
-#, c-format
-msgid "Lines / boundaries removed: %d"
-msgstr ""
-#: ../vector/v.clean/split.c:85
-#, c-format
-msgid "Line splits: %d"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:77
-#, c-format
-msgid "Database connection not defined for layer <%d>"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:121
-#, c-format
-msgid "Only numeric column type is supported (column <%s> in table <%s>)"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:124
-#, c-format
-msgid ""
-"Double values will be converted to integers (column <%s> in table <%s>)"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:160 ../vector/v.univar/main.c:358
-msgid "Only numeric column type is supported"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:186
-#, c-format
-msgid "No record for cat = %d"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:189
-#, c-format
-msgid "NULL value for cat = %d"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:198
-#, c-format
-msgid "Column type is not numeric (type = %d, cat = %d"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:477
-msgid "Exports vector points as LAS point cloud"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:478
-msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:498 ../vector/v.in.lidar/main.c:151
-msgid "Layer number to store generated point ID as category"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:500 ../vector/v.out.lidar/main.c:507
-#: ../vector/v.out.lidar/main.c:514 ../vector/v.out.lidar/main.c:521
-#: ../vector/v.in.lidar/main.c:154 ../vector/v.in.lidar/main.c:162
-#: ../vector/v.in.lidar/main.c:170 ../vector/v.in.lidar/main.c:178
-msgid "Categories"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:505
-msgid "Layer number to store return number as category"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:512 ../vector/v.in.lidar/main.c:167
-msgid "Layer number to store class number as category"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:519
-msgid "Layer number where RGB color is stored as category"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:527 ../vector/v.out.lidar/main.c:533
-#: ../vector/v.out.lidar/main.c:539
-msgid "Column with return number"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:529 ../vector/v.out.lidar/main.c:535
-#: ../vector/v.out.lidar/main.c:541 ../vector/v.out.lidar/main.c:548
-#: ../vector/v.out.lidar/main.c:554 ../vector/v.out.lidar/main.c:560
-#: ../vector/v.out.lidar/main.c:566 ../vector/v.net.centrality/main.c:149
-#: ../vector/v.net.centrality/main.c:155 ../vector/v.net.centrality/main.c:161
-#: ../vector/v.net.centrality/main.c:167
-msgid "Columns"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:545
-msgid "RGB color definition column"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:552
-msgid "Column with red color"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:558
-msgid "Column with green color"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:564
-msgid "Column with blue color"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:573
-msgid "Internal scale to apply to X and Y values"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:574 ../vector/v.out.lidar/main.c:584
-msgid ""
-"This scale does not change the values itself but only how precisely they are"
-" stored, for example 0.01 will preserve two decimal places"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:583
-msgid "Internal scale to apply to z values"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:591
-msgid "Limit export to the current region"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:595
-msgid "Ignore color table"
-msgstr ""
-#: ../vector/v.out.lidar/main.c:597
-msgid "Ignore color table even when set and not other options are present"
-msgstr ""
-#: ../vector/v.reclass/main.c:69
-msgid "attributes"
-msgstr ""
-#: ../vector/v.reclass/main.c:71
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-#: ../vector/v.reclass/main.c:88
-msgid "The name of the column whose values are to be used as new categories"
-msgstr ""
-#: ../vector/v.reclass/main.c:89
-msgid "The source for the new key column must be type integer or string"
-msgstr ""
-#: ../vector/v.reclass/main.c:94
-msgid "Full path to the reclass rule file"
-msgstr ""
-#: ../vector/v.reclass/main.c:104
-#, c-format
-msgid "Either '%s' or '%s' must be specified"
-msgstr ""
-#: ../vector/v.reclass/main.c:128 ../vector/v.sample/main.c:133
-#: ../vector/v.surf.idw/read_sites.c:50
-#, c-format
-msgid "Database connection not defined for layer %s"
-msgstr ""
-#: ../vector/v.reclass/main.c:254
-msgid "Key column type is not integer"
-msgstr ""
-#: ../vector/v.reclass/main.c:298
-#, c-format
-msgid "Cannot insert data: [%s]"
-msgstr ""
-#: ../vector/v.reclass/main.c:336
-msgid "Column type must be integer or string"
-msgstr ""
-#: ../vector/v.reclass/main.c:348
-#, c-format
-msgid "Unable to open rule file <%s>"
-msgstr ""
-#: ../vector/v.reclass/main.c:364
-#, c-format
-msgid "Category %d overwritten by '%s'"
-msgstr ""
-#: ../vector/v.reclass/main.c:368
-#, c-format
-msgid "Category '%s' invalid"
-msgstr ""
-#: ../vector/v.reclass/main.c:372
-#, c-format
-msgid "Label '%s' overwritten by '%s'"
-msgstr ""
-#: ../vector/v.reclass/main.c:378
-#, c-format
-msgid "Condition '%s' overwritten by '%s'"
-msgstr ""
-#: ../vector/v.reclass/main.c:383
-#, c-format
-msgid "Unknown rule option: '%s'"
-msgstr ""
-#: ../vector/v.reclass/main.c:397
-msgid "Cannot select values from database"
-msgstr ""
-#: ../vector/v.reclass/main.c:413
-#, c-format
-msgid "%d previously set categories overwritten by new category %d"
-msgstr ""
-#: ../vector/v.reclass/main.c:439
-msgid "Incomplete rule"
-msgstr ""
-#: ../vector/v.reclass/main.c:475
-#, c-format
-msgid "%d features reclassed."
-msgstr ""
-#: ../vector/v.univar/main.c:98
-msgid "Calculates univariate statistics of vector map features."
-msgstr ""
-#: ../vector/v.univar/main.c:99
-msgid ""
-"Variance and standard deviation is calculated only for points if specified."
-msgstr ""
-#: ../vector/v.univar/main.c:134
-msgid "Weigh by line length or area size"
-msgstr ""
-#: ../vector/v.univar/main.c:138
-msgid "Calculate geometric distances instead of attribute statistics"
-msgstr ""
-#: ../vector/v.univar/main.c:192
-#, c-format
-msgid "Geometry distances are not supported for areas. Use '%s' instead."
-msgstr ""
-#: ../vector/v.univar/main.c:195
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
-msgstr ""
-#: ../vector/v.univar/main.c:200
-msgid "Extended statistics is currently supported only for points/centroids"
-msgstr ""
-#: ../vector/v.univar/main.c:225
-msgid "'layer' must be > 0 for 'where'."
-msgstr ""
-#: ../vector/v.univar/main.c:242
-#, c-format
-msgid "Unable select categories from table <%s>"
-msgstr ""
-#: ../vector/v.univar/main.c:253
-#, c-format
-msgid "Calculating geometric distances between %d primitives..."
-msgstr ""
-#: ../vector/v.univar/main.c:343
-#, c-format
-msgid " Database connection not defined for layer <%s>"
-msgstr ""
-#: ../vector/v.univar/main.c:652
-msgid "Cannot sort the key/value array"
-msgstr ""
-#: ../vector/v.net.components/main.c:74
-msgid "components"
-msgstr ""
-#: ../vector/v.net.components/main.c:76
-msgid "Computes strongly and weakly connected components in the network."
-msgstr ""
-#: ../vector/v.net.components/main.c:124
-msgid "Weakly connected components"
-msgstr ""
-#: ../vector/v.net.components/main.c:125
-msgid "Strongly connected components"
-msgstr ""
-#: ../vector/v.net.components/main.c:127
-msgid "Type of components"
-msgstr ""
-#: ../vector/v.net.components/main.c:131 ../vector/v.net.centrality/main.c:192
-msgid "Add points on nodes"
-msgstr ""
-#: ../vector/v.net.components/main.c:203
-msgid "Computing weakly connected components..."
-msgstr ""
-#: ../vector/v.net.components/main.c:207
-msgid "Computing strongly connected components..."
-msgstr ""
-#: ../vector/v.net.components/main.c:279
-#, c-format
-msgid "Found %d components."
-msgstr ""
-#: ../vector/v.net.steiner/main.c:58
-#, c-format
-msgid "Init costs from node %d"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:348
-msgid "steiner tree"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:350
-msgid "Creates Steiner tree for the network and given terminals."
-msgstr ""
-#: ../vector/v.net.steiner/main.c:352
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal."
-msgstr ""
-#: ../vector/v.net.steiner/main.c:373
-msgid "Node layer (used for terminals)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:379
-msgid "Arcs' cost column (for both directions)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:385
-msgid "Categories of points on terminals (layer is specified by nlayer)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:393
-msgid "Number of Steiner points (-1 for all possible)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:448
-#, c-format
-msgid "Point is not connected to the network (cat=%d)"
-msgstr ""
-#. GTC Terminal refers to an Steiner tree endpoint
-#: ../vector/v.net.steiner/main.c:458
-#, c-format
-msgid "Number of terminals: %d\n"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:462
-msgid "Not enough terminals (< 2)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:469
-msgid "Requested number of Steiner points > than possible"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:475
-#, c-format
-msgid "Number of Steiner points set to %d\n"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:522
-#, c-format
-msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:538
-#, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:543
-#, c-format
-msgid "MST costs = %f"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:549
-#, c-format
-msgid "Search for [%d]. Steiner point"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:570
-#, c-format
-msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:582
-msgid "No Steiner point found -> leaving cycle"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:587
-#, c-format
-msgid "Number of added Steiner points: %d (theoretic max is %d).\n"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:598
-#, c-format
-msgid ""
-"Spanning tree costs on complete graph = %f\n"
-"(may be higher than resulting Steiner tree costs!!!)"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:603
-#, c-format
-msgid "Steiner tree costs = %f"
-msgstr ""
-#: ../vector/v.net.steiner/main.c:656
-#, c-format
-msgid "A Steiner tree with %d arc has been built"
-msgid_plural "A Steiner tree with %d arcs has been built"
-msgstr[0] ""
-#: ../vector/v.lidar.correction/main.c:74
-msgid ""
-"Corrects the v.lidar.growing output. It is the last of the three algorithms "
-"for LIDAR filtering."
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:78
-#: ../vector/v.lidar.edgedetection/main.c:83
-msgid "Estimate point density and distance and quit"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:80
-#: ../vector/v.lidar.edgedetection/main.c:85
-#: ../vector/v.surf.bspline/main.c:107
-msgid ""
-"Estimate point density and distance in map units for the input vector points"
-" within the current region extents and quit"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:85
-msgid "Input observation vector map name (v.lidar.growing output)"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:88
-msgid "Output classified vector map name"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:93
-msgid "Name for output only 'terrain' points vector map"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:101
-msgid "Default: 25 * east-west resolution"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:110
-msgid "Default: 25 * north-south resolution"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:118
-msgid "Regularization weight in reclassification evaluation"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:126
-msgid "High threshold for object to terrain reclassification"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:134
-msgid "Low threshold for terrain to object reclassification"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:171
-#: ../vector/v.lidar.edgedetection/main.c:196
-#, c-format
-msgid "Estimated point density: %.4g\n"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:172
-#: ../vector/v.lidar.edgedetection/main.c:197
-#, c-format
-msgid "Estimated mean distance between points: %.4g\n"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:278
-#, c-format
-msgid "Adjusted EW spline %d"
-msgid_plural "Adjusted EW splines %d"
-msgstr[0] ""
-#: ../vector/v.lidar.correction/main.c:281
-#, c-format
-msgid "Adjusted NS spline %d"
-msgid_plural "Adjusted NS splines %d"
-msgstr[0] ""
-#: ../vector/v.lidar.correction/main.c:338
-#: ../vector/v.lidar.growing/main.c:246
-#: ../vector/v.lidar.edgedetection/main.c:360
-#, c-format
-msgid "Subregion %d of %d"
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:376
-msgid "Performing mean calculation..."
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:420
-msgid "Correction and creation of terrain vector map..."
-msgstr ""
-#: ../vector/v.lidar.correction/main.c:433
-#: ../vector/v.lidar.edgedetection/main.c:466
-msgid "No data within this subregion. Consider changing the spline step."
-msgstr ""
-#: ../vector/v.net.centrality/main.c:98
-msgid "centrality measures"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:100
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
-msgstr ""
-#: ../vector/v.net.centrality/main.c:148
-msgid "Name of degree centrality column"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:154
-msgid "Name of closeness centrality column"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:160
-msgid "Name of betweenness centrality column"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:166
-msgid "Name of eigenvector centrality column"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:175
-msgid "Maximum number of iterations to compute eigenvector centrality"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:183
-msgid "Cumulative error tolerance for eigenvector centrality"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:321
-msgid "Computing degree centrality measure"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:325
-msgid "Computing betweenness and/or closeness centrality measure"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:332
-msgid "Computing eigenvector centrality measure"
-msgstr ""
-#: ../vector/v.net.centrality/main.c:339
-msgid "Writing data into the table..."
-msgstr ""
-#: ../vector/v.db.connect/main.c:55 ../vector/v.category/main.c:77
-msgid "layer"
-msgstr ""
-#: ../vector/v.db.connect/main.c:57
-msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-#: ../vector/v.db.connect/main.c:79
-msgid "Format: layer number[/layer name]"
-msgstr ""
-#: ../vector/v.db.connect/main.c:83
-msgid "Field separator for shell script style output"
-msgstr ""
-#: ../vector/v.db.connect/main.c:88
-msgid "Print all map connection parameters and exit"
-msgstr ""
-#: ../vector/v.db.connect/main.c:93
-msgid "Print all map connection parameters in shell script style and exit"
-msgstr ""
-#: ../vector/v.db.connect/main.c:95
-msgid "Format: layer[/layer name] table key database driver"
-msgstr ""
-#: ../vector/v.db.connect/main.c:101
-msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-#: ../vector/v.db.connect/main.c:108
-msgid "Overwrite connection parameter for certain layer"
-msgstr ""
-#: ../vector/v.db.connect/main.c:113
-msgid "Delete connection for certain layer (not the table)"
-msgstr ""
-#: ../vector/v.db.connect/main.c:149
-msgid "Please choose only one print style"
-msgstr ""
-#: ../vector/v.db.connect/main.c:166
-#, c-format
-msgid "Map <%s> is not connected to a database"
-msgstr ""
-#: ../vector/v.db.connect/main.c:175
-#, c-format
-msgid "Vector map <%s> is connected by:\n"
-msgstr ""
-#: ../vector/v.db.connect/main.c:197
-#, c-format
-msgid ""
-"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key "
-"<%s>\n"
-msgstr ""
-#: ../vector/v.db.connect/main.c:203
-#, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
-#: ../vector/v.db.connect/main.c:266
-#, c-format
-msgid "Use -o to overwrite existing link for layer <%d>"
-msgstr ""
-#: ../vector/v.db.connect/main.c:274 ../vector/v.db.connect/main.c:314
-#, c-format
-msgid "Table <%s> does not exist in database <%s>"
-msgstr ""
-#: ../vector/v.db.connect/main.c:302 ../vector/v.db.connect/main.c:320
-#, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-#: ../vector/v.db.connect/main.c:351
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-#: ../vector/v.split/main.c:56
-msgid "densification"
-msgstr ""
-#: ../vector/v.split/main.c:60
-msgid "Splits vector lines to shorter segments."
-msgstr ""
-#: ../vector/v.split/main.c:73
-msgid "Maximum segment length"
-msgstr ""
-#: ../vector/v.split/main.c:82
-msgid "Length units"
-msgstr ""
-#: ../vector/v.split/main.c:89
-msgid "Maximum number of vertices in segment"
-msgstr ""
-#: ../vector/v.split/main.c:93
-msgid "Add new vertices, but do not split"
-msgstr ""
-#: ../vector/v.split/main.c:94 ../vector/v.split/main.c:99
-msgid "Applies only to 'length' option"
-msgstr ""
-#: ../vector/v.split/main.c:98
-msgid "Force segments to be exactly of given length, except for last one"
-msgstr ""
-#: ../vector/v.split/main.c:108
-msgid "Use either length or vertices"
-msgstr ""
-#: ../vector/v.split/main.c:115
-#, c-format
-msgid "Length must be positive but is %g"
-msgstr ""
-#: ../vector/v.split/main.c:131
-#, c-format
-msgid "Unknown unit %s"
-msgstr ""
-#: ../vector/v.split/main.c:149
-msgid "Can not get projection units"
-msgstr ""
-#: ../vector/v.split/main.c:156
-#, c-format
-msgid "Length in map units: %g"
-msgstr ""
-#: ../vector/v.split/main.c:158
-#, c-format
-msgid "Length in meters: %g"
-msgstr ""
-#: ../vector/v.split/main.c:164
-msgid "Number of vertices must be at least 2"
-msgstr ""
-#: ../vector/v.split/main.c:250
-#, c-format
-msgid "Unable to make line segment: %f - %f (line length = %f)"
-msgstr ""
-#: ../vector/v.what/what.c:45
-msgid "Cannot open driver"
-msgstr ""
-#: ../vector/v.what/what.c:53
-msgid "Cannot open database"
-msgstr ""
-#: ../vector/v.what/what.c:66
-msgid "Cannot open select cursor"
-msgstr ""
-#: ../vector/v.what/what.c:73
-msgid "Cannot fetch next record"
-msgstr ""
-#: ../vector/v.what/what.c:76
-msgid "No database record"
-msgstr ""
-#: ../vector/v.what/what.c:177
-#, c-format
-msgid ""
-"Layer: %d\n"
-"Category: %d\n"
-msgstr ""
-#: ../vector/v.what/what.c:201
-#, c-format
-msgid ""
-"\n"
-"Driver: %s\n"
-"Database: %s\n"
-"Table: %s\n"
-"Key column: %s\n"
-msgstr ""
-#: ../vector/v.what/what.c:380
-#, c-format
-msgid "Nothing found.\n"
-msgstr ""
-#: ../vector/v.what/what.c:475
-#, c-format
-msgid ""
-"Id: %d\n"
-"Type: %s\n"
-"Left: %d\n"
-"Right: %d\n"
-msgstr ""
-#: ../vector/v.what/what.c:481 ../vector/v.what/what.c:557
-#, c-format
-msgid "Length: %f\n"
-msgstr ""
-#: ../vector/v.what/what.c:501
-#, c-format
-msgid ""
-"Node[%d]=%d\n"
-"Number_lines=%d\n"
-"Coordinates=%.6f,%.6f,%.6f\n"
-msgstr ""
-#: ../vector/v.what/what.c:506
-#, c-format
-msgid ""
-",\n"
-"\"Node[%d]\": %d,\n"
-"\"Number_lines\": %d,\n"
-"\"Coordinates\": %.6f,%.6f,%.6f"
-msgstr ""
-#: ../vector/v.what/what.c:511
-#, c-format
-msgid ""
-"Node[%d]: %d\n"
-"Number of lines: %d\n"
-"Coordinates: %.6f, %.6f, %.6f\n"
-msgstr ""
-#: ../vector/v.what/what.c:531
-#, c-format
-msgid ""
-"Id: %5d\n"
-"Angle: %.8f\n"
-msgstr ""
-#: ../vector/v.what/what.c:554
-#, c-format
-msgid "Type: %s\n"
-msgstr ""
-#: ../vector/v.what/what.c:555
-#, c-format
-msgid "Id: %d\n"
-msgstr ""
-#: ../vector/v.what/what.c:576
-#, c-format
-msgid "Point height: %f\n"
-msgstr ""
-#: ../vector/v.what/what.c:600
-#, c-format
-msgid "Line height: %f\n"
-msgstr ""
-#: ../vector/v.what/what.c:618
-#, c-format
-msgid ""
-"Line height min: %f\n"
-"Line height max: %f\n"
-msgstr ""
-#: ../vector/v.what/what.c:662
-#, c-format
-msgid ""
-"Type: Area\n"
-"Area height: %f\n"
-msgstr ""
-#: ../vector/v.what/what.c:676
-#, c-format
-msgid "Type: Area\n"
-msgstr ""
-#: ../vector/v.what/what.c:704
-#, c-format
-msgid ""
-"Area: %d\n"
-"Number of isles: %d\n"
-msgstr ""
-#: ../vector/v.what/what.c:719
-#, c-format
-msgid "Isle[%d]: %d\n"
-msgstr ""
-#: ../vector/v.what/what.c:738
-#, c-format
-msgid "Island: %d In area: %d\n"
-msgstr ""
-#: ../vector/v.what/what.c:759
-#, c-format
-msgid ""
-"Sq Meters: %.3f\n"
-"Hectares: %.3f\n"
-msgstr ""
-#: ../vector/v.what/what.c:761
-#, c-format
-msgid ""
-"Acres: %.3f\n"
-"Sq Miles: %.4f\n"
-msgstr ""
-#: ../vector/v.what/main.c:65
-msgid "Queries a vector map at given locations."
-msgstr ""
-#: ../vector/v.what/main.c:85
-msgid "Query threshold distance"
-msgstr ""
-#: ../vector/v.what/main.c:86
-msgid "Threshold"
-msgstr ""
-#: ../vector/v.what/main.c:90
-msgid "Print topological information (debugging)"
-msgstr ""
-#: ../vector/v.what/main.c:95
-msgid "Print attribute information"
-msgstr ""
-#: ../vector/v.what/main.c:105
-msgid "Print the stats in JSON"
-msgstr ""
-#: ../vector/v.what/main.c:110
-msgid "Print multiple features if overlapping features are found"
-msgstr ""
-#: ../vector/v.what/main.c:127
-msgid "No input vector maps!"
-msgstr ""
-#: ../vector/v.what/main.c:175
-#, c-format
-msgid "Number of given vector maps (%d) differs from number of layers (%d)"
-msgstr ""
-#: ../vector/v.what/main.c:184
-#, c-format
-msgid "You must build topology on vector map <%s>"
-msgstr ""
-#: ../vector/v.what/main.c:202
-#, c-format
-msgid "Unknown input format, skipping: '%s'"
-msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:196
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
-msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:585 ../vector/v.out.ogr/attrb.c:48
-#, c-format
-msgid "Cannot select attributes for cat = %d"
-msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:632
-msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:640
-msgid "No attribute table found"
-msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:673
-msgid "No numerical attributes found. Skipping export"
-msgstr ""
-#: ../vector/v.out.vtk/writeVTK.c:732 ../vector/v.out.vtk/writeVTK.c:763
-#: ../vector/v.out.vtk/writeVTK.c:794 ../vector/v.out.vtk/writeVTK.c:823
-#, c-format
-msgid "Error reading value of attribute '%s'"
-msgstr ""
-#: ../vector/v.out.vtk/head.c:27
-msgid "writeVTKHeader: Writing VTK-Header"
-msgstr ""
-#: ../vector/v.out.vtk/main.c:51
-msgid "Converts a vector map to VTK ASCII output."
-msgstr ""
-#: ../vector/v.out.vtk/main.c:59
-msgid "Name for output VTK file"
-msgstr ""
-#: ../vector/v.out.vtk/main.c:84
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
-msgid "Correct the coordinates to fit the VTK-OpenGL precision"
-msgstr ""
-#: ../vector/v.out.vtk/main.c:89
-msgid "Export numeric attribute table fields as VTK scalar variables"
-msgstr ""
-#: ../vector/v.out.vtk/main.c:153 ../vector/v.out.ascii/args.c:109
-msgid "Failed to interpret 'dp' parameter as an integer"
-msgstr ""
-#: ../vector/v.out.vtk/main.c:155
-msgid "dp has to be from 0 to 8"
-msgstr ""
-#: ../vector/v.out.vtk/main.c:164
-msgid "Failed to interpret 'layer' parameter as an integer"
-msgstr ""
-#: ../vector/v.out.vtk/main.c:183
-#, c-format
-msgid ""
-"Export of areas requires topology. Please adjust '%s' option or rebuild "
-"topology."
-msgstr ""
-#: ../vector/v.parallel/main.c:52 ../vector/v.to.points/main.c:56
-#: ../vector/v.type/main.c:42 ../vector/v.build.polylines/main.c:113
-#: ../vector/v.edit/main.c:57 ../vector/v.category/main.c:683
-#: ../vector/v.buffer/main.c:226
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:5
-msgid "line"
-msgstr ""
-#: ../vector/v.parallel/main.c:53
-msgid "Creates parallel line to input vector lines."
-msgstr ""
-#: ../vector/v.parallel/main.c:68
-msgid "Offset along major axis in map units"
-msgstr ""
-#: ../vector/v.parallel/main.c:76
-msgid "Offset along minor axis in map units"
-msgstr ""
-#: ../vector/v.parallel/main.c:84 ../vector/v.buffer/main.c:271
-msgid "Angle of major axis in degrees"
-msgstr ""
-#: ../vector/v.parallel/main.c:93
-msgid "Side"
-msgstr ""
-#: ../vector/v.parallel/main.c:97
-msgid "Parallel line is on the left"
-msgstr ""
-#: ../vector/v.parallel/main.c:98
-msgid "Parallel line is on the right"
-msgstr ""
-#: ../vector/v.parallel/main.c:99
-msgid "Parallel lines on both sides"
-msgstr ""
-#: ../vector/v.parallel/main.c:108
-msgid "Tolerance of arc polylines in map units"
-msgstr ""
-#: ../vector/v.parallel/main.c:112
-msgid "Make outside corners round"
-msgstr ""
-#: ../vector/v.parallel/main.c:116
-msgid "Create buffer-like parallel lines"
-msgstr ""
-#: ../vector/v.lidar.growing/ConvexHull.c:269
-msgid "...now exiting to system..."
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:78
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:83
-msgid "Input vector (v.lidar.edgedetection output)"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:93
-msgid "Name of the first pulse vector map"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:100
-msgid "Threshold for cell object frequency in region growing"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:108
-msgid "Threshold for double pulse in region growing"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:176
-#, c-format
-msgid "Unable to open table <%s>"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:201
-msgid "Setting regions and boxes"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:267
-#, c-format
-msgid "Rows = %d"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:268
-#, c-format
-msgid "Columns = %d"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:288
-msgid "read points in input vector"
-msgstr ""
-#: ../vector/v.lidar.growing/main.c:446
-msgid "Region Growing"
-msgstr ""
-#: ../vector/v.select/select.c:48 ../vector/v.drape/main.c:177
-#: ../vector/v.category/main.c:332
-msgid "Processing features..."
-msgstr ""
-#: ../vector/v.select/select.c:104 ../vector/v.select/select.c:154
-#, c-format
-msgid "Unable to read line id %d from vector map <%s>"
-msgstr ""
-#: ../vector/v.select/select.c:200 ../vector/v.out.pov/main.c:175
-msgid "Processing areas..."
-msgstr ""
-#: ../vector/v.select/select.c:252 ../vector/v.select/select.c:318
-#, c-format
-msgid "Unable to read area id %d from vector map <%s>"
-msgstr ""
-#: ../vector/v.select/write.c:27
-msgid "Writing selected features..."
-msgstr ""
-#: ../vector/v.select/args.c:12
-msgid "Input vector map from which to select features (A)"
-msgstr ""
-#: ../vector/v.select/args.c:16
-msgid "Layer number (vector map A)"
-msgstr ""
-#: ../vector/v.select/args.c:21 ../vector/v.overlay/main.c:81
-msgid "Feature type (vector map A)"
-msgstr ""
-#: ../vector/v.select/args.c:27
-msgid "Query vector map (B)"
-msgstr ""
-#: ../vector/v.select/args.c:31
-msgid "Layer number (vector map B)"
-msgstr ""
-#: ../vector/v.select/args.c:36 ../vector/v.overlay/main.c:95
-msgid "Feature type (vector map B)"
-msgstr ""
-#: ../vector/v.select/args.c:49
-msgid "Operator defines required relation between features"
-msgstr ""
-#: ../vector/v.select/args.c:51
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-"given layer is defined."
-msgstr ""
-#: ../vector/v.select/args.c:59 ../vector/v.select/args.c:75
-msgid "features partially or completely overlap"
-msgstr ""
-#: ../vector/v.select/args.c:76
-msgid "features are spatially equals (using GEOS)"
-msgstr ""
-#: ../vector/v.select/args.c:77
-msgid "features do not spatially intersect (using GEOS)"
-msgstr ""
-#: ../vector/v.select/args.c:78
-msgid "features spatially intersect (using GEOS)"
-msgstr ""
-#: ../vector/v.select/args.c:79
-msgid "features spatially touches (using GEOS)"
-msgstr ""
-#: ../vector/v.select/args.c:80
-msgid "features spatially crosses (using GEOS)"
-msgstr ""
-#: ../vector/v.select/args.c:81
-msgid "feature A is completely inside feature B (using GEOS)"
-msgstr ""
-#: ../vector/v.select/args.c:82
-msgid "feature B is completely inside feature A (using GEOS)"
-msgstr ""
-#: ../vector/v.select/args.c:83
-msgid "features spatially overlap (using GEOS)"
-msgstr ""
-#: ../vector/v.select/args.c:84
-msgid ""
-"feature A is spatially related to feature B (using GEOS, requires 'relate' "
-"option)"
-msgstr ""
-#: ../vector/v.select/args.c:94
-msgid "Intersection Matrix Pattern used for 'relate' operator"
-msgstr ""
-#: ../vector/v.select/args.c:101
-msgid "Do not skip features without category"
-msgstr ""
-#: ../vector/v.select/args.c:105 ../vector/v.extract/main.c:97
-#: ../vector/v.edit/args.c:204
-msgid "Reverse selection"
-msgstr ""
-#: ../vector/v.select/copy_tabs.c:51 ../scripts/v.to.lines/v.to.lines.py:157
-#, c-format, python-format
-msgid "No table for layer %d"
-msgstr ""
-#: ../vector/v.select/copy_tabs.c:71
-#, c-format
-msgid "Unable to copy table for layer %d"
-msgstr ""
-#: ../vector/v.select/main.c:50 ../vector/v.overlay/main.c:65
-msgid "spatial query"
-msgstr ""
-#: ../vector/v.select/main.c:52
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-#: ../vector/v.select/main.c:85 ../vector/v.overlay/main.c:178
-#, c-format
-msgid "Unknown operator '%s'"
-msgstr ""
-#: ../vector/v.select/main.c:94
-msgid "Operator can only be 'overlap'"
-msgstr ""
-#: ../vector/v.select/main.c:152
-msgid "Output from v.select"
-msgstr ""
-#: ../vector/v.select/main.c:184
-#, c-format
-msgid "%d features from <%s> without category skipped"
-msgstr ""
-#: ../vector/v.select/main.c:193
-#, c-format
-msgid "%d features written to output."
-msgstr ""
-#: ../vector/v.select/main.c:198
-msgid "No features found !"
-msgstr ""
-#: ../vector/v.net.distance/main.c:69
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
-msgstr ""
-#: ../vector/v.net.distance/main.c:72
-msgid ""
-"Finds the shortest paths from each 'from' point to the nearest 'to' feature "
-"and various information about this relation are uploaded to the attribute "
-"table."
-msgstr ""
-#: ../vector/v.net.distance/main.c:100
-msgid "From layer number or name"
-msgstr ""
-#: ../vector/v.net.distance/main.c:101 ../vector/v.net.distance/main.c:106
-#: ../vector/v.net.distance/main.c:112 ../vector/v.distance/main.c:131
-#: ../vector/v.distance/main.c:136 ../vector/v.distance/main.c:143
-#: ../vector/v.distance/main.c:189 ../vector/v.distance/main.c:226
-msgid "From"
-msgstr ""
-#: ../vector/v.net.distance/main.c:105
-msgid "From category values"
-msgstr ""
-#: ../vector/v.net.distance/main.c:111
-msgid "From WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.distance/main.c:116
-msgid "To layer number or name"
-msgstr ""
-#: ../vector/v.net.distance/main.c:117 ../vector/v.net.distance/main.c:124
-#: ../vector/v.net.distance/main.c:129 ../vector/v.net.distance/main.c:135
-#: ../vector/v.distance/main.c:148 ../vector/v.distance/main.c:153
-#: ../vector/v.distance/main.c:160 ../vector/v.distance/main.c:232
-msgid "To"
-msgstr ""
-#: ../vector/v.net.distance/main.c:123
-msgid "To feature type"
-msgstr ""
-#: ../vector/v.net.distance/main.c:128
-msgid "To category values"
-msgstr ""
-#: ../vector/v.net.distance/main.c:134
-msgid "To WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.distance/main.c:165 ../vector/v.net.path/main.c:136
-msgid "Write output as original input segments, not each path as one line."
-msgstr ""
-#: ../vector/v.net.distance/main.c:169
-msgid "Write each output path as one line, not as original input segments."
-msgstr ""
-#: ../vector/v.net.distance/main.c:244
-#, c-format
-msgid "No 'from' features selected. Please check options '%s', '%s', '%s'."
-msgstr ""
-#: ../vector/v.net.distance/main.c:251
-#, c-format
-msgid "No 'to' features selected. Please check options '%s', '%s', '%s'."
-msgstr ""
-#: ../vector/v.net.distance/main.c:260
-msgid "No 'to' features"
-msgstr ""
-#: ../vector/v.net.distance/main.c:268
-msgid "Distances to 'to' features ..."
-msgstr ""
-#: ../vector/v.net.distance/main.c:307
-msgid "Tracing paths from 'from' features ..."
-msgstr ""
-#: ../vector/v.net.distance/main.c:423
-#, c-format
-msgid "%d 'from' feature was not reachable"
-msgid_plural "%d 'from' features were not reachable"
-msgstr[0] ""
-#: ../vector/v.class/main.c:50
-msgid "Classifies attribute data, e.g. for thematic mapping"
-msgstr ""
-#: ../vector/v.class/main.c:58
-msgid "Column name or expression"
-msgstr ""
-#: ../vector/v.class/main.c:93
-msgid "Print only class breaks (without min and max)"
-msgstr ""
-#: ../vector/v.class/main.c:129 ../vector/v.sample/main.c:240
-#: ../vector/v.what.rast/main.c:183 ../vector/v.to.rast3/main.c:99
-#: ../vector/v.surf.bspline/crosscorr.c:133
-#: ../vector/v.surf.bspline/main.c:395 ../vector/v.surf.idw/read_sites.c:65
-#: ../vector/v.buffer/main.c:448
-msgid "Column type not supported"
-msgstr ""
-#: ../vector/v.class/main.c:138
-msgid "Unable to sort array of values"
-msgstr ""
-#: ../vector/v.class/main.c:173
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
-msgstr ""
-#: ../vector/v.class/main.c:201
-#, c-format
-msgid ""
-"\n"
-"Classification of %s into %i classes\n"
-msgstr ""
-#: ../vector/v.class/main.c:208
-#, c-format
-msgid "Lowest chi2 = %f\n"
-msgstr ""
-#: ../vector/v.class/main.c:214
-#, c-format
-msgid ""
-"%15s%15s%15s\n"
-"\n"
-msgstr ""
-#: ../vector/v.class/main.c:226
-#, c-format
-msgid ""
-"\n"
-"Note: Minimum of first class is including\n"
-"\n"
-msgstr ""
-#: ../vector/v.overlay/area_area.c:54
-#, c-format
-msgid "Snapping boundaries with %g ..."
-msgstr ""
-#: ../vector/v.overlay/area_area.c:102
-#, c-format
-msgid "%d boundary snapped"
-msgid_plural "%d boundaries snapped"
-msgstr[0] ""
-#: ../vector/v.overlay/area_area.c:112 ../vector/v.overlay/line_area.c:256
-msgid "Breaking lines..."
-msgstr ""
-#: ../vector/v.overlay/area_area.c:119 ../vector/v.in.ogr/main.c:1450
-msgid "Cleaning boundaries at nodes..."
-msgstr ""
-#: ../vector/v.overlay/area_area.c:157
-msgid "Merging lines..."
-msgstr ""
-#: ../vector/v.overlay/area_area.c:161 ../vector/v.buffer/main.c:779
-msgid "Attaching islands..."
-msgstr ""
-#: ../vector/v.overlay/area_area.c:174 ../vector/v.buffer/main.c:800
-msgid "Cannot calculate area centroid"
-msgstr ""
-#: ../vector/v.overlay/area_area.c:184
-#, c-format
-msgid "Querying vector map <%s>..."
-msgstr ""
-#: ../vector/v.overlay/area_area.c:211 ../vector/v.overlay/area_area.c:293
-#: ../vector/v.overlay/area_area.c:321 ../vector/v.overlay/line_area.c:387
-#: ../vector/v.overlay/line_area.c:415
-msgid "Attribute not found"
-msgstr ""
-#: ../vector/v.overlay/area_area.c:221 ../vector/v.in.ogr/main.c:1579
-msgid "Writing centroids..."
-msgstr ""
-#: ../vector/v.overlay/main.c:66
-#: ../locale/scriptstrings/v.clip_to_translate.c:3
-msgid "clip"
-msgstr ""
-#: ../vector/v.overlay/main.c:67
-msgid "difference"
-msgstr ""
-#: ../vector/v.overlay/main.c:68
-msgid "intersection"
-msgstr ""
-#: ../vector/v.overlay/main.c:69
-msgid "union"
-msgstr ""
-#: ../vector/v.overlay/main.c:70
-msgid ""
-"Overlays two vector maps offering clip, intersection, difference, "
-"symmetrical difference, union operators."
-msgstr ""
-#: ../vector/v.overlay/main.c:73
-msgid "Name of input vector map (A)"
-msgstr ""
-#: ../vector/v.overlay/main.c:77
-msgid "Layer number or name (vector map A)"
-msgstr ""
-#: ../vector/v.overlay/main.c:87
-msgid "Name of input vector map (B)"
-msgstr ""
-#: ../vector/v.overlay/main.c:91
-msgid "Layer number or name (vector map B)"
-msgstr ""
-#: ../vector/v.overlay/main.c:106
-msgid "Operator defines features written to output vector map"
-msgstr ""
-#: ../vector/v.overlay/main.c:109
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
-msgstr ""
-#: ../vector/v.overlay/main.c:116
-msgid "also known as 'intersection' in GIS"
-msgstr ""
-#: ../vector/v.overlay/main.c:117
-msgid "also known as 'union' in GIS (only for atype=area)"
-msgstr ""
-#: ../vector/v.overlay/main.c:118
-msgid ""
-"also known as 'difference' (features from ainput not overlaid by features "
-"from binput)"
-msgstr ""
-#: ../vector/v.overlay/main.c:120
-msgid ""
-"also known as 'symmetrical difference' (features from either ainput or "
-"binput but not those from ainput overlaid by binput (only for atype=area)"
-msgstr ""
-#: ../vector/v.overlay/main.c:131
-msgid "Output layer for new category, ainput and binput"
-msgstr ""
-#: ../vector/v.overlay/main.c:132
-msgid "If 0 or not given, the category is not written"
-msgstr ""
-#: ../vector/v.overlay/main.c:139
-msgid "Snapping threshold for boundaries"
-msgstr ""
-#: ../vector/v.overlay/main.c:140
-msgid "Disable snapping with snap <= 0"
-msgstr ""
-#: ../vector/v.overlay/main.c:195
-#, c-format
-msgid "Unable to determine feature type for <%s>"
-msgstr ""
-#: ../vector/v.overlay/main.c:201
-#, c-format
-msgid "Invalid feature type (%d) for <%s>. Only '%s' or '%s' supported."
-msgstr ""
-#: ../vector/v.overlay/main.c:209
-#, c-format
-msgid "Operator '%s' is not supported for type line"
-msgstr ""
-#: ../vector/v.overlay/main.c:227 ../vector/v.in.ogr/main.c:854
-#: ../vector/v.buffer/main.c:414
-msgid "Unable to create temporary vector map"
-msgstr ""
-#: ../vector/v.overlay/main.c:264
-#, c-format
-msgid "Copying vector features from <%s>..."
-msgstr ""
-#: ../vector/v.overlay/main.c:345
-#, c-format
-msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
-msgstr ""
-#: ../vector/v.overlay/main.c:394
-msgid "Collecting input attributes..."
-msgstr ""
-#: ../vector/v.overlay/main.c:423 ../vector/v.label/main.c:319
-#: ../vector/v.label.sa/labels.c:162
-msgid "Unable to select attributes"
-msgstr ""
-#: ../vector/v.overlay/main.c:474
-#, c-format
-msgid "Unknown column type '%s' of column '%s'"
-msgstr ""
-#: ../vector/v.overlay/main.c:539
-#, c-format
-msgid "Unknown column type '%s' of column '%s', values lost"
-msgstr ""
-#: ../vector/v.overlay/line_area.c:273
-msgid "Selecting lines..."
-msgstr ""
-#: ../vector/v.overlay/line_area.c:345
-#, c-format
-msgid "Ambiguous line %d: not all vertices are really outside any area"
-msgstr ""
-#: ../vector/v.extract/main.c:80
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
-msgid "dissolve"
-msgstr ""
-#: ../vector/v.extract/main.c:83
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector"
-" map containing only the selected features."
-msgstr ""
-#: ../vector/v.extract/main.c:88
-msgid "Dissolve common boundaries (default is no)"
-msgstr ""
-#: ../vector/v.extract/main.c:92
-msgid "Do not copy attributes (see also 'new' parameter)"
-msgstr ""
-#: ../vector/v.extract/main.c:108
-msgid "Types to be extracted"
-msgstr ""
-#: ../vector/v.extract/main.c:123
-msgid "Input text file with category numbers/number ranges to be extracted"
-msgstr ""
-#: ../vector/v.extract/main.c:124
-msgid "If '-' given reads from standard input"
-msgstr ""
-#: ../vector/v.extract/main.c:132
-msgid "Number of random categories matching vector objects to extract"
-msgstr ""
-#: ../vector/v.extract/main.c:134
-msgid "Number must be smaller than unique cat count in layer"
-msgstr ""
-#: ../vector/v.extract/main.c:142
-msgid "Desired new category value (enter -1 to keep original categories)"
-msgstr ""
-#: ../vector/v.extract/main.c:144
-msgid "If new >= 0, attributes is not copied"
-msgstr ""
-#: ../vector/v.extract/main.c:161
-#, c-format
-msgid ""
-"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only"
-" one of them."
-msgstr ""
-#: ../vector/v.extract/main.c:208
-#, c-format
-msgid "Category value in '%s' not valid"
-msgstr ""
-#: ../vector/v.extract/main.c:224
-#, c-format
-msgid "Process file <%s> for category numbers..."
-msgstr ""
-#: ../vector/v.extract/main.c:229
-#, c-format
-msgid "Unable to open specified file <%s>"
-msgstr ""
-#: ../vector/v.extract/main.c:240
-#, c-format
-msgid "Ignored text entry: %s"
-msgstr ""
-#: ../vector/v.extract/main.c:259
-#, c-format
-msgid "Loading categories from table <%s>..."
-msgstr ""
-#: ../vector/v.extract/main.c:269
-#, c-format
-msgid "Unable select records from table <%s>"
-msgstr ""
-#: ../vector/v.extract/main.c:271
-#, c-format
-msgid "%d category loaded"
-msgid_plural "%d categories loaded"
-msgstr[0] ""
-#: ../vector/v.extract/main.c:286
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
-msgstr ""
-#: ../vector/v.extract/main.c:293
-msgid "Please specify random number larger than 0"
-msgstr ""
-#: ../vector/v.extract/main.c:297
-#, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
-msgstr ""
-#: ../vector/v.extract/main.c:320
-#, c-format
-msgid ""
-"Random category count is larger or equal to uniq <%s> feature category count"
-" %d"
-msgstr ""
-#: ../vector/v.extract/main.c:354
-msgid "Extracting features..."
-msgstr ""
-#: ../vector/v.extract/main.c:378
-msgid "Removing duplicate centroids..."
-msgstr ""
-#: ../vector/v.extract/extract.c:171
-#, c-format
-msgid "No category found for area %d. Skipping."
-msgstr ""
-#: ../vector/v.extract/extract.c:175
-#, c-format
-msgid "More categories (%d) found for area %d. Using first found category %d"
-msgstr ""
-#: ../vector/v.extract/extract.c:228
-msgid ""
-"Topology level required for extracting areas for OGR layers. Areas will be "
-"not processed."
-msgstr ""
-#: ../vector/v.extract/copy_tab.c:90
-#, c-format
-msgid "Writing attributes for layer %d"
-msgstr ""
-#: ../vector/v.extract/copy_tab.c:95
-#, c-format
-msgid "No attribute table for layer %d"
-msgstr ""
-#: ../vector/v.extract/copy_tab.c:108 ../vector/v.generalize/misc.c:184
-#: ../vector/v.to.points/main.c:165
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:128
-msgid "Unable to copy table <%s>"
-msgstr ""
-#: ../vector/v.perturb/normalsv.c:29
-msgid "normalsv: save of uninitialized block"
-msgstr ""
-#: ../vector/v.perturb/normalrs.c:31
-msgid "normalsv: restoration of uninitialized block"
-msgstr ""
-#: ../vector/v.perturb/main.c:70
-msgid "Random location perturbations of vector points."
-msgstr ""
-#: ../vector/v.perturb/main.c:84
-msgid "Distribution of perturbation"
-msgstr ""
-#: ../vector/v.perturb/main.c:91
-msgid "Parameter(s) of distribution"
-msgstr ""
-#: ../vector/v.perturb/main.c:92
-msgid ""
-"If the distribution is uniform, only one parameter, the maximum, is needed. "
-"For a normal distribution, two parameters, the mean and standard deviation, "
-"are required."
-msgstr ""
-#: ../vector/v.perturb/main.c:102
-msgid "Minimum deviation in map units"
-msgstr ""
-#: ../vector/v.perturb/main.c:109
-msgid "Seed for random number generation"
-msgstr ""
-#: ../vector/v.perturb/main.c:130 ../vector/v.perturb/main.c:137
-msgid "Error scanning arguments"
-msgstr ""
-#: ../vector/v.perturb/main.c:133
-msgid "Maximum of uniform distribution must be >= zero"
-msgstr ""
-#: ../vector/v.perturb/main.c:140
-msgid "Standard deviation of normal distribution must be >= zero"
-msgstr ""
-#: ../vector/v.perturb/main.c:245
-msgid "Cannot get db link info"
-msgstr ""
-#: ../vector/v.net.allpairs/main.c:65
-msgid "Computes the shortest path between all pairs of nodes in the network."
-msgstr ""
-#: ../vector/v.net.allpairs/main.c:208
-msgid "Writing node points..."
-msgstr ""
-#: ../vector/v.net.allpairs/main.c:242
-msgid "Collecting shortest paths..."
-msgstr ""
-#: ../vector/v.net.allpairs/main.c:296
-msgid "Writing shortest paths..."
-msgstr ""
-#: ../vector/v.support/main.c:41
-msgid "Updates vector map metadata."
-msgstr ""
-#: ../vector/v.support/main.c:52
-msgid "Organization where vector map was created"
-msgstr ""
-#: ../vector/v.support/main.c:61
-msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
-msgstr ""
-#: ../vector/v.support/main.c:68
-msgid "Person who created vector map"
-msgstr ""
-#: ../vector/v.support/main.c:75
-msgid "Vector map title"
-msgstr ""
-#: ../vector/v.support/main.c:83
-msgid "Date when the source map was originally produced"
-msgstr ""
-#: ../vector/v.support/main.c:89
-msgid "Vector map scale number (e.g., 24000)"
-msgstr ""
-#: ../vector/v.support/main.c:95
-msgid "Vector map projection zone"
-msgstr ""
-#: ../vector/v.support/main.c:102
-msgid "Vector map digitizing threshold number (e.g., 0.5)"
-msgstr ""
-#: ../vector/v.support/main.c:110
-msgid "Text to append to the comment line of the map's metadata file"
-msgstr ""
-#: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
-msgstr ""
-#: ../vector/v.support/main.c:122
-msgid "Replace comment instead of appending it"
-msgstr ""
-#: ../vector/v.support/main.c:126
-msgid "Replace command line instead of appending it"
-msgstr ""
-#: ../vector/v.support/main.c:190
-#, c-format
-msgid "Unable to open history file for vector map <%s>"
-msgstr ""
-#: ../vector/v.decimate/main.c:125 ../vector/v.generalize/main.c:77
-msgid "generalization"
-msgstr ""
-#: ../vector/v.decimate/main.c:126
-msgid "decimation"
-msgstr ""
-#: ../vector/v.decimate/main.c:132
-msgid "Decimates a point cloud"
-msgstr ""
-#: ../vector/v.decimate/main.c:133
-msgid ""
-"Copies points from one vector to another while applying different "
-"decimations"
-msgstr ""
-#: ../vector/v.decimate/main.c:161
-msgid "Throw away every n-th point"
-msgstr ""
-#: ../vector/v.decimate/main.c:163
-msgid ""
-"For example, 5 will import 80 percent of points. If not specified, all "
-"points are copied"
-msgstr ""
-#: ../vector/v.decimate/main.c:165 ../vector/v.decimate/main.c:176
-#: ../vector/v.decimate/main.c:186 ../vector/v.decimate/main.c:195
-msgid "Count"
-msgstr ""
-#: ../vector/v.decimate/main.c:172
-msgid "Preserve only every n-th point"
-msgstr ""
-#: ../vector/v.decimate/main.c:174
-msgid ""
-"For example, 4 will import 25 percent of points. If not specified, all "
-msgstr ""
-#: ../vector/v.decimate/main.c:183 ../vector/v.in.lidar/main.c:255
-msgid "Skip first n points"
-msgstr ""
-#: ../vector/v.decimate/main.c:185 ../vector/v.in.lidar/main.c:256
-msgid "Skips the given number of points at the beginning."
-msgstr ""
-#: ../vector/v.decimate/main.c:193
-msgid "Copy only n points"
-msgstr ""
-#: ../vector/v.decimate/main.c:194
-msgid "Copies only the given number of points"
-msgstr ""
-#: ../vector/v.decimate/main.c:201
-msgid "Minimal difference of z values"
-msgstr ""
-#: ../vector/v.decimate/main.c:203
-msgid "Minimal difference between z values in grid-based decimation"
-msgstr ""
-#: ../vector/v.decimate/main.c:204 ../vector/v.decimate/main.c:214
-#: ../vector/v.decimate/main.c:219 ../vector/v.decimate/main.c:225
-#: ../vector/v.decimate/main.c:230 ../vector/v.decimate/main.c:235
-msgid "Grid"
-msgstr ""
-#: ../vector/v.decimate/main.c:211
-msgid "Preserve only n points per grid cell"
-msgstr ""
-#: ../vector/v.decimate/main.c:213
-msgid ""
-"Preserves only the given number of points per grid cell in grid-based "
-"decimation"
-msgstr ""
-#: ../vector/v.decimate/main.c:218
-msgid "Apply grid-based decimation"
-msgstr ""
-#: ../vector/v.decimate/main.c:224
-msgid "Use only first point in grid cell during grid-based decimation"
-msgstr ""
-#: ../vector/v.decimate/main.c:229
-msgid "Only one point per cat in grid cell"
-msgstr ""
-#: ../vector/v.decimate/main.c:234
-msgid "Use z in grid decimation"
-msgstr ""
-#: ../vector/v.decimate/main.c:240
-msgid "Store only the coordinates, throw away categories"
-msgstr ""
-#: ../vector/v.decimate/main.c:242
-msgid "Do not story any categories even if they are present in input data"
-msgstr ""
-#: ../vector/v.decimate/main.c:243 ../vector/v.decimate/main.c:246
-#: ../vector/v.in.lidar/main.c:305 ../vector/v.in.lidar/main.c:313
-#: ../vector/v.in.lidar/main.c:316
-msgid "Speed"
-msgstr ""
-#: ../vector/v.decimate/main.c:276
-#, c-format
-msgid ""
-"Input layer must be set to a particular layer, not <%s>, when using <%s> "
-"option or <-%c> flag"
-msgstr ""
-#: ../vector/v.decimate/main.c:318
-msgid "Cannot use z for decimation, input is not 3D"
-msgstr ""
-#: ../vector/v.decimate/main.c:320
-msgid "Cannot select by z range, input is not 3D"
-msgstr ""
-#: ../vector/v.decimate/main.c:344 ../vector/v.in.lidar/main.c:605
-msgid "Settings for count-based decimation are not valid"
-msgstr ""
-#: ../vector/v.decimate/main.c:350
-msgid ""
-"Settings for count-based decimation would cause it to do nothing and no "
-"other options has been set."
-msgstr ""
-#: ../vector/v.net.visibility/main.c:48
-msgid "visibility"
-msgstr ""
-#: ../vector/v.net.visibility/main.c:49
-msgid "Performs visibility graph construction."
-msgstr ""
-#: ../vector/v.net.visibility/main.c:60
-msgid "Name of input vector map containing visible points"
-msgstr ""
-#: ../vector/v.net.visibility/main.c:61
-msgid "Add points after computing the visibility graph"
-msgstr ""
-#: ../vector/v.net.visibility/main.c:85
-#, c-format
-msgid "Unable to copy elements from vector map <%s>"
-msgstr ""
-#: ../vector/v.net.visibility/main.c:90
-msgid "Lat-long projection"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:70 ../vector/v.what.rast/main.c:77
-#: ../vector/v.drape/main.c:60
-msgid "surface information"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:72
-msgid "Uploads 3D raster values at positions of vector points to the table."
-msgstr ""
-#: ../vector/v.what.rast3/main.c:76 ../vector/v.what.rast/main.c:83
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
-msgid "Name of vector points map for which to edit attributes"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:82
-msgid "Name of existing 3D raster map to be queried"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:87 ../vector/v.what.rast/main.c:98
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:11
-msgid "Name of attribute column to be updated with the query result"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:135
-#, c-format
-msgid "Error opening 3D raster map <%s>"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:144
-msgid "Column type not supported, please use a column with double type"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:158 ../vector/v.what.rast/main.c:206
-msgid "Reading features from vector map..."
-msgstr ""
-#: ../vector/v.what.rast3/main.c:215
-#, c-format
-msgid "%d point outside current region was skipped"
-msgid_plural "%d points outside current region were skipped"
-msgstr[0] ""
-#: ../vector/v.what.rast3/main.c:220
-#, c-format
-msgid "%d point without category was skipped"
-msgid_plural "%d points without category were skipped"
-msgstr[0] ""
-#: ../vector/v.what.rast3/main.c:259
-#, c-format
-msgid "More points (%d) of category %d, value set to 'NULL'"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:329
-#, c-format
-msgid "%d category loaded from table"
-msgid_plural "%d categories loaded from table"
-msgstr[0] ""
-#: ../vector/v.what.rast3/main.c:332
-#, c-format
-msgid "%d category loaded from vector"
-msgid_plural "%d categories loaded from vector"
-msgstr[0] ""
-#: ../vector/v.what.rast3/main.c:335
-#, c-format
-msgid "%d category from vector missing in table"
-msgid_plural "%d categories from vector missing in table"
-msgstr[0] ""
-#: ../vector/v.what.rast3/main.c:339
-#, c-format
-msgid "%d duplicate category in vector"
-msgid_plural "%d duplicate categories in vector"
-msgstr[0] ""
-#: ../vector/v.what.rast3/main.c:343
-#, c-format
-msgid "%d update error"
-msgid_plural "%d update errors"
-msgstr[0] ""
-#: ../vector/v.what.rast3/main.c:347
-#, c-format
-msgid "%d record updated."
-msgid_plural "%d records updated."
-msgstr[0] ""
-#: ../vector/v.generalize/displacement.c:199
-msgid "Inverting matrix..."
-msgstr ""
-#: ../vector/v.generalize/displacement.c:201
-msgid "Unable to calculate the inverse matrix"
-msgstr ""
-#: ../vector/v.generalize/displacement.c:204
-msgid "Resolving conflicts..."
-msgstr ""
-#: ../vector/v.generalize/misc.c:166
-#, c-format
-msgid "Layer %d"
-msgstr ""
-#: ../vector/v.generalize/network.c:166
-msgid "Calculating centrality measures..."
-msgstr ""
-#: ../vector/v.generalize/smoothing.c:135
-#: ../vector/v.generalize/smoothing.c:225
-msgid "Look ahead parameter must be odd"
-msgstr ""
-#: ../vector/v.generalize/smoothing.c:664
-msgid "Unable to find the inverse matrix"
-msgstr ""
-#: ../vector/v.generalize/smoothing.c:671
-msgid "Unable to calculate the output vectors"
-msgstr ""
-#: ../vector/v.generalize/main.c:78
-msgid "simplification"
-msgstr ""
-#: ../vector/v.generalize/main.c:79
-msgid "smoothing"
-msgstr ""
-#: ../vector/v.generalize/main.c:80
-msgid "displacement"
-msgstr ""
-#: ../vector/v.generalize/main.c:81
-msgid "network generalization"
-msgstr ""
-#: ../vector/v.generalize/main.c:84
-msgid "Performs vector based generalization."
-msgstr ""
-#: ../vector/v.generalize/main.c:102
-msgid "Error map with failed generalizations"
-msgstr ""
-#: ../vector/v.generalize/main.c:104
-msgid ""
-"Lines and boundaries causing errors (collapsed to a point or topology "
-"errors)"
-msgstr ""
-#: ../vector/v.generalize/main.c:128
-msgid "Douglas-Peucker Algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:129
-msgid "Douglas-Peucker Algorithm with reduction parameter"
-msgstr ""
-#: ../vector/v.generalize/main.c:130
-msgid "Lang Simplification Algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:131
-msgid "Vertex Reduction Algorithm eliminates points close to each other"
-msgstr ""
-#: ../vector/v.generalize/main.c:132
-msgid "Reumann-Witkam Algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:133
-msgid "Boyle's Forward-Looking Algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:134
-msgid "McMaster's Sliding Averaging Algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:135
-msgid "McMaster's Distance-Weighting Algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:136
-msgid "Chaiken's Algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:137
-msgid "Interpolation by Cubic Hermite Splines"
-msgstr ""
-#: ../vector/v.generalize/main.c:138
-msgid "Snakes method for line smoothing"
-msgstr ""
-#: ../vector/v.generalize/main.c:139
-msgid "Network generalization"
-msgstr ""
-#: ../vector/v.generalize/main.c:140
-msgid "Displacement of lines close to each other"
-msgstr ""
-#: ../vector/v.generalize/main.c:143
-msgid "Generalization algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:150
-msgid "Maximal tolerance value"
-msgstr ""
-#: ../vector/v.generalize/main.c:157
-msgid "Look-ahead parameter"
-msgstr ""
-#: ../vector/v.generalize/main.c:166
-msgid ""
-"Percentage of the points in the output of 'douglas_reduction' algorithm"
-msgstr ""
-#: ../vector/v.generalize/main.c:175
-msgid "Slide of computed point toward the original point"
-msgstr ""
-#: ../vector/v.generalize/main.c:184
-msgid "Minimum angle between two consecutive segments in Hermite method"
-msgstr ""
-#: ../vector/v.generalize/main.c:192
-msgid "Degree threshold in network generalization"
-msgstr ""
-#: ../vector/v.generalize/main.c:201
-msgid "Closeness threshold in network generalization"
-msgstr ""
-#: ../vector/v.generalize/main.c:209
-msgid "Betweeness threshold in network generalization"
-msgstr ""
-#: ../vector/v.generalize/main.c:216
-msgid "Snakes alpha parameter"
-msgstr ""
-#: ../vector/v.generalize/main.c:223
-msgid "Snakes beta parameter"
-msgstr ""
-#: ../vector/v.generalize/main.c:230
-msgid "Number of iterations"
-msgstr ""
-#: ../vector/v.generalize/main.c:240
-msgid "Disable loop support"
-msgstr ""
-#: ../vector/v.generalize/main.c:241
-msgid "Do not modify end points of lines forming a closed loop"
-msgstr ""
-#: ../vector/v.generalize/main.c:244
-msgid "Do not copy attributes"
-msgstr ""
-#: ../vector/v.generalize/main.c:298
-msgid "Unknown method"
-msgstr ""
-#: ../vector/v.generalize/main.c:331
-#, c-format
-msgid "No lines found in input map <%s>"
-msgstr ""
-#: ../vector/v.generalize/main.c:345
-#, c-format
-msgid "Unable to create error vector map <%s>"
-msgstr ""
-#: ../vector/v.generalize/main.c:365
-msgid "Displacement..."
-msgstr ""
-#: ../vector/v.generalize/main.c:374
-msgid "Network generalization..."
-msgstr ""
-#: ../vector/v.generalize/main.c:389
-msgid "Attributes are needed for 'where' option, copying table"
-msgstr ""
-#: ../vector/v.generalize/main.c:405
-#, c-format
-msgid "Generalization (%s)..."
-msgstr ""
-#: ../vector/v.generalize/main.c:406
-#, c-format
-msgid "Using threshold: %g %s"
-msgstr ""
-#: ../vector/v.generalize/main.c:526
-#, c-format
-msgid "Method '%s' did not preserve first point"
-msgstr ""
-#: ../vector/v.generalize/main.c:531
-#, c-format
-msgid "Method '%s' did not preserve last point"
-msgstr ""
-#: ../vector/v.generalize/main.c:538
-#, c-format
-msgid "Method '%s' did not preserve loop"
-msgstr ""
-#: ../vector/v.generalize/main.c:570
-#, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
-msgstr ""
-#: ../vector/v.generalize/main.c:573
-#, c-format
-msgid "%d lines/boundaries were not modified due to over-simplification"
-msgstr ""
-#: ../vector/v.generalize/main.c:594
-#, c-format
-msgid ""
-"Number of vertices for selected features %s from %d to %d (%d%% remaining)"
-msgstr ""
-#: ../vector/v.generalize/main.c:595
-msgid "reduced"
-msgstr ""
-msgid "changed"
-msgstr ""
-#: ../vector/v.qcount/main.c:63
-msgid "Indices for quadrat counts of vector point lists."
-msgstr ""
-#: ../vector/v.qcount/main.c:72
-msgid ""
-"Name for output quadrat centers map (number of points is written as "
-"category)"
-msgstr ""
-#: ../vector/v.qcount/main.c:78
-msgid "Number of quadrats"
-msgstr ""
-#: ../vector/v.qcount/main.c:84
-msgid "Quadrat radius"
-msgstr ""
-#: ../vector/v.qcount/main.c:88
-msgid "Print results in shell script style"
-msgstr ""
-#: ../vector/v.qcount/main.c:104
-msgid "Finding quadrats..."
-msgstr ""
-#: ../vector/v.qcount/main.c:109
-msgid "Counting points quadrats..."
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:54
-msgid "connectivity"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:56
-msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:96
-msgid "Set1 category values"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:97
-#: ../vector/v.net.connectivity/main.c:103
-msgid "Set1"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:102
-msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:107
-msgid "Set2 category values"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:108
-#: ../vector/v.net.connectivity/main.c:114
-msgid "Set2"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:113
-msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:146
-#: ../vector/v.net.connectivity/main.c:153
-#, c-format
-msgid "No features for %s selected. Please check options '%s', '%s'."
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:167
-#: ../vector/v.net.connectivity/main.c:170
-#, c-format
-msgid "%s is empty"
-msgstr ""
-#: ../vector/v.in.lidar/vector_mask.c:20
-#, c-format
-msgid "Failed to open vector <%s>"
-msgstr ""
-#: ../vector/v.in.lidar/attributes.c:129
-#, c-format
-msgid "Unable open database <%s> by driver <%s>"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:48
-#, c-format
-msgid ""
-"Values of %s and %s are the same. All categories would be stored only in "
-"layer number <%d>"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:141
-msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
-msgstr ""
-#: ../vector/v.in.lidar/main.c:152
-msgid "Set to 1 by default, use -c to not store it"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:159
-msgid "Layer number to store return information as category"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:160 ../vector/v.in.lidar/main.c:168
-#: ../vector/v.in.lidar/main.c:176
-msgid "Leave empty to not store it"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:175
-msgid "Layer number where RBG colors are stored as category"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:186 ../vector/v.in.ogr/main.c:236
-msgid "Import subregion only"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:189 ../vector/v.in.ogr/main.c:239
-msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:221
-msgid "Areas where to import points"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:222
-msgid "Name of vector map with areas where the points should be imported"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:227
-msgid "Layer number or name for mask option"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:235
-msgid "Do not import every n-th point"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:236
-msgid ""
-"points are imported"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:238 ../vector/v.in.lidar/main.c:248
-#: ../vector/v.in.lidar/main.c:257 ../vector/v.in.lidar/main.c:266
-msgid "Decimation"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:245
-msgid "Import only every n-th point"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:246
-msgid ""
-msgstr ""
-#: ../vector/v.in.lidar/main.c:264
-msgid "Import only n points"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:265
-msgid "Imports only the given number of points"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:288
-msgid "Invert mask when selecting points"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:310
-msgid "Do not automatically add unique ID as category to each point"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:312
-msgid "Create only requested layers and categories"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:328 ../vector/v.in.ogr/main.c:379
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the vector data."
-msgstr ""
-#: ../vector/v.in.lidar/main.c:354
-#, c-format
-msgid "Unable to open file <%s> as a LiDAR point cloud. %s"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:415
-#, c-format
-msgid "-%c flag is not set but ID layer is not specified"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:416
-msgid "ID layer is required to store attribute table"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:425
-#, c-format
-msgid ""
-"Storing generated point IDs as categories in the layer <%d>, consequently no"
-" more than %d points can be imported"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:450 ../vector/v.in.ogr/main.c:702
-#: ../vector/v.in.ogr/main.c:2102
-msgid "Select either the current region flag or the spatial option, not both"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:478 ../vector/v.in.ogr/main.c:2129
-msgid "4 parameters required for 'spatial' parameter"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:542 ../scripts/v.unpack/v.unpack.py:118
-msgid "Vector map <%s> already exists and will be overwritten"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:545 ../vector/v.in.ogr/main.c:673
-#: ../vector/v.edit/main.c:99 ../scripts/v.unpack/v.unpack.py:116
-msgid "Vector map <%s> already exists"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:609
-#, c-format
-msgid "Scanning %llu points..."
-msgstr ""
-#: ../vector/v.in.lidar/main.c:611
-#, c-format
-msgid "Scanning %lu points..."
-msgstr ""
-#: ../vector/v.in.lidar/main.c:746
-msgid ""
-"The underlying libLAS library is at its limits. Previously reported counts "
-"might have been distorted. However, the import itself should be unaffected."
-msgstr ""
-#: ../vector/v.in.lidar/main.c:752
-#, c-format
-msgid "%llu points imported (limit was %llu)"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:757
-#, c-format
-msgid "%llu points imported"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:760
-#, c-format
-msgid "%llu input points were not valid and filtered out"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:762
-#, c-format
-msgid "%llu input points were outside of the selected area"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:764
-#, c-format
-msgid "%llu input points were outside of the area specified by mask"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:766
-#, c-format
-msgid "%llu input points were filtered out by return number"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:768
-#, c-format
-msgid "%llu input points were filtered out by class number"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:770
-#, c-format
-msgid "%llu input points were filtered outsite the range for z coordinate"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:772
-#, c-format
-msgid "%llu input points were skipped at the begging using offset"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:775
-#, c-format
-msgid "%llu input points were skipped by count-based decimation"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:779
-#, c-format
-msgid "%lu points imported (limit was %d)"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:783
-#, c-format
-msgid "%lu points imported"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:785 ../raster3d/r3.in.lidar/main.c:707
-#, c-format
-msgid "%lu input points were not valid and filtered out"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:787
-#, c-format
-msgid "%lu input points were outside of the selected area"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:789
-#, c-format
-msgid "%lu input points were outside of the area specified by mask"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:791 ../raster3d/r3.in.lidar/main.c:710
-#, c-format
-msgid "%lu input points were filtered out by return number"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:793 ../raster3d/r3.in.lidar/main.c:712
-#, c-format
-msgid "%lu input points were filtered out by class number"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:795
-#, c-format
-msgid "%lu input points were filtered outsite the range for z coordinate"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:797
-#, c-format
-msgid "%lu input points were skipped at the begging using offset"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:800
-#, c-format
-msgid "%lu input points were skipped by count-based decimation"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:802
-msgid ""
-"Accuracy of the printed point counts might be limited by your computer "
-"architecture."
-msgstr ""
-#: ../vector/v.in.lidar/main.c:805
-msgid "The rest of points was ignored"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:809
-#, c-format
-msgid "%llu input points were not valid, use -%c flag to filter them out"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:813 ../raster3d/r3.in.lidar/main.c:716
-#, c-format
-msgid "%lu input points were not valid, use -%c flag to filter them out"
-msgstr ""
-#: ../vector/v.in.lidar/main.c:818
-#, c-format
-msgid ""
-"Maximum number of categories reached (%d). Import ended prematurely. Try to "
-"import without using category as an ID."
-msgstr ""
-#: ../vector/v.sample/main.c:79
-msgid "Samples a raster map at vector point locations."
-msgstr ""
-#: ../vector/v.sample/main.c:82 ../vector/v.surf.bspline/main.c:110
-msgid "Name of input vector point map"
-msgstr ""
-#: ../vector/v.sample/main.c:89
-msgid "Name of attribute column to use for comparison"
-msgstr ""
-#: ../vector/v.sample/main.c:92
-msgid "Name for output vector map to store differences"
-msgstr ""
-#: ../vector/v.sample/main.c:96
-msgid "Name of raster map to be sampled"
-msgstr ""
-#: ../vector/v.sample/main.c:107
-msgid "Scaling factor for values read from raster map"
-msgstr ""
-#: ../vector/v.sample/main.c:109
-msgid "Sampled values will be multiplied by this factor"
-msgstr ""
-#: ../vector/v.sample/main.c:148
-#, c-format
-msgid "Column type <%s> not supported (must be integer or double precision)"
-msgstr ""
-#: ../vector/v.sample/main.c:154
-#, c-format
-msgid "%d record selected from table"
-msgid_plural "%d records selected from table"
-msgstr[0] ""
-#: ../vector/v.sample/main.c:200 ../raster3d/r3.in.lidar/main.c:574
-msgid "Reading points..."
-msgstr ""
-#: ../vector/v.random/main.c:102
-msgid "stratified random sampling"
-msgstr ""
-#: ../vector/v.random/main.c:105
-msgid "Generates random 2D/3D vector points."
-msgstr ""
-#: ../vector/v.random/main.c:113
-msgid "Number of points to be created"
-msgstr ""
-#: ../vector/v.random/main.c:118
-msgid "Restrict points to areas in input vector"
-msgstr ""
-#: ../vector/v.random/main.c:120 ../vector/v.random/main.c:180
-msgid "Restrict"
-msgstr ""
-#: ../vector/v.random/main.c:136
-msgid "Minimum z height (needs -z flag or column name)"
-msgstr ""
-#: ../vector/v.random/main.c:145
-msgid "Maximum z height (needs -z flag or column name)"
-msgstr ""
-#: ../vector/v.random/main.c:154
-msgid ""
-"The seed to initialize the random generator. If not set the process ID is "
-"used"
-msgstr ""
-#: ../vector/v.random/main.c:157
-msgid "Name of column for z values"
-msgstr ""
-#: ../vector/v.random/main.c:159
-msgid "Writes z values to column"
-msgstr ""
-#: ../vector/v.random/main.c:167
-msgid "Type of column for z values"
-msgstr ""
-#: ../vector/v.random/main.c:174
-msgid "Create 3D output"
-msgstr ""
-#: ../vector/v.random/main.c:179
-msgid ""
-"Generate n points for each individual area (requires restrict parameter)"
-msgstr ""
-#: ../vector/v.random/main.c:196
-#, c-format
-msgid "Number of points must be > 0 (%d given)"
-msgstr ""
-#: ../vector/v.random/main.c:212 ../vector/v.drape/main.c:150
-#: ../vector/v.buffer/main.c:347
-#, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
-"'1'."
-msgstr ""
-#: ../vector/v.random/main.c:222
-#, c-format
-msgid "No areas in vector map <%s>"
-msgstr ""
-#: ../vector/v.random/main.c:276
-msgid "Table should contain only two columns"
-msgstr ""
-#: ../vector/v.random/main.c:285
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
-msgstr ""
-#: ../vector/v.random/main.c:348
-#, c-format
-msgid ""
-"Selected areas in input vector <%s> do not overlap with the current region"
-msgstr ""
-#: ../vector/v.random/main.c:360
-#, c-format
-msgid "Input vector <%s> does not overlap with the current region"
-msgstr ""
-#: ../vector/v.random/main.c:385
-msgid "Generating points..."
-msgstr ""
-#: ../vector/v.external.out/format.c:22 ../vector/v.external/main.c:78
-msgid ""
-"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
-"OGR support. Using GRASS-PostGIS data driver instead."
-msgstr ""
-#: ../vector/v.external.out/format.c:27 ../vector/v.external/main.c:83
-msgid ""
-"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
-"instead of native GRASS-PostGIS data driver."
-msgstr ""
-#: ../vector/v.external.out/args.c:14
-msgid "Name of output directory or OGR or PostGIS data source"
-msgstr ""
-#: ../vector/v.external.out/args.c:15 ../vector/v.external/args.c:15
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: directory containing a shapefile\n"
-"\t\tMapInfo File: directory containing a mapinfo file\n"
-"\t\tPostGIS database: connection string, eg. 'PG:dbname=db user=grass'"
-msgstr ""
-#: ../vector/v.external.out/args.c:24
-msgid "Format for output vector data"
-msgstr ""
-#: ../vector/v.external.out/args.c:40
-msgid ""
-"Examples:\n"
-"\t\t'SHPT=POINTZ': create 3D point Shapefile data\n"
-"\t\t'GEOM_TYPE=geography': use geography PostGIS data\n"
-"\t\t'SCHEMA=grass': create new PostGIS tables in 'grass' schema"
-msgstr ""
-#: ../vector/v.external.out/args.c:52
-msgid "Name of input file to read settings from"
-msgstr ""
-#: ../vector/v.external.out/args.c:58
-msgid "Name for output file where to save current settings"
-msgstr ""
-#: ../vector/v.external.out/args.c:68
-msgid "Cease using OGR/PostGIS, revert to native output and exit"
-msgstr ""
-#: ../vector/v.external.out/args.c:70
-msgid "Native"
-msgstr ""
-#: ../vector/v.external.out/args.c:80
-msgid "Print current status in shell script style"
-msgstr ""
-#: ../vector/v.external.out/args.c:98
-#, c-format
-msgid "%s= or %s= must be specified"
-msgstr ""
-#: ../vector/v.external.out/args.c:101
-#, c-format
-msgid "%s= must be specified"
-msgstr ""
-#: ../vector/v.external.out/link.c:26 ../vector/v.out.ogr/main.c:102
-#, c-format
-msgid ""
-"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format "
-"(\"%s\" given)"
-msgstr ""
-#: ../vector/v.external.out/link.c:88 ../vector/v.external.out/status.c:158
-msgid "Unable to create settings file"
-msgstr ""
-#: ../vector/v.external.out/link.c:91 ../vector/v.external.out/status.c:160
-msgid "Error writing settings file"
-msgstr ""
-#: ../vector/v.external.out/link.c:96
-#, c-format
-msgid "Switched to OGR format (%s)"
-msgstr ""
-#: ../vector/v.external.out/link.c:99
-msgid "Switched to PostGIS format"
-msgstr ""
-#: ../vector/v.external.out/link.c:110
-#, c-format
-msgid "Unable to parse option '%s'"
-msgstr ""
-#: ../vector/v.external.out/main.c:49
-msgid "Defines vector output format."
-msgstr ""
-#: ../vector/v.external.out/main.c:63
-msgid "Switched from OGR to native format"
-msgstr ""
-#: ../vector/v.external.out/main.c:67
-msgid "Switched from PostGIS to native format"
-msgstr ""
-#: ../vector/v.external.out/main.c:69 ../vector/v.external.out/main.c:96
-#, c-format
-msgid "Current output format for vectors: %s"
-msgstr ""
-#: ../vector/v.external.out/status.c:25
-#, c-format
-msgid "format: native\n"
-msgstr ""
-#: ../vector/v.external.out/status.c:80
-msgid "No settings defined"
-msgstr ""
-#: ../vector/v.external.out/status.c:109 ../vector/v.external.out/status.c:149
-msgid "Format not defined"
-msgstr ""
-#: ../vector/v.external.out/status.c:116
-msgid "OGR datasource (dsn) not defined"
-msgstr ""
-#: ../vector/v.external.out/status.c:124
-msgid "PG connection info (conninfo) not defined"
-msgstr ""
-#: ../vector/v.net/turntable.c:326 ../vector/v.net/turntable.c:346
-#: ../vector/v.net/turntable.c:366 ../vector/v.net/turntable.c:487
-#: ../vector/v.net/turntable.c:554
-#, c-format
-msgid "Unable to read line from <%s>."
-msgstr ""
-#: ../vector/v.net/turntable.c:448 ../vector/v.net/turntable.c:523
-msgid "Unable to insert data into turntable."
-msgstr ""
-#: ../vector/v.net/turntable.c:637
-#, c-format
-msgid "Unable to open vector map <%s>."
-msgstr ""
-#: ../vector/v.net/turntable.c:642
-#, c-format
-msgid "Unable to create vector map <%s>."
-msgstr ""
-#: ../vector/v.net/turntable.c:655
-#, c-format
-msgid "Arc layer <%s> does not exist in map <%s>."
-msgstr ""
-#: ../vector/v.net/turntable.c:660
-#, c-format
-msgid ""
-"Layer <%s> already exist in map <%s>.\n"
-"It will be overwritten by tlayer data."
-msgstr ""
-#: ../vector/v.net/turntable.c:665
-#, c-format
-msgid ""
-"It will be overwritten by tuclayer data."
-msgstr ""
-#: ../vector/v.net/turntable.c:700
-#, c-format
-msgid "Unable to open database <%s> using driver <%s>"
-msgstr ""
-#: ../vector/v.net/turntable.c:715
-#, c-format
-msgid "Unable to create turntable <%s>."
-msgstr ""
-#: ../vector/v.net/turntable.c:722
-#, c-format
-msgid "Unable to connect table <%s> to vector map <%s>."
-msgstr ""
-#: ../vector/v.net/turntable.c:727
-#, c-format
-msgid "Unable to create index for column <%s> in table <%s>."
-msgstr ""
-#: ../vector/v.net/arcs.c:42
-#, c-format
-msgid "Error reading file: '%s'"
-msgstr ""
-#: ../vector/v.net/arcs.c:48
-#, c-format
-msgid "Skipping arc %d"
-msgstr ""
-#: ../vector/v.net/arcs.c:85
-#, c-format
-msgid "No point with category %d found"
-msgstr ""
-#: ../vector/v.net/arcs.c:89
-#, c-format
-msgid "More points with category %d found"
-msgstr ""
-#: ../vector/v.net/args.c:14
-msgid "Name of input vector line map (arcs)"
-msgstr ""
-#: ../vector/v.net/args.c:15
-msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
-msgstr ""
-#: ../vector/v.net/args.c:17 ../vector/v.net/args.c:57
-msgid "Arcs"
-msgstr ""
-#: ../vector/v.net/args.c:21
-msgid "Name of input vector point map (nodes)"
-msgstr ""
-#: ../vector/v.net/args.c:23
-msgid "Required for operation 'connect' and 'arcs'"
-msgstr ""
-#: ../vector/v.net/args.c:25 ../vector/v.net/args.c:71
-#: ../vector/v.net/args.c:93 ../vector/v.net/args.c:100
-msgid "Nodes"
-msgstr ""
-#: ../vector/v.net/args.c:40
-msgid "new point is placed on each node (line end) if doesn't exist"
-msgstr ""
-#: ../vector/v.net/args.c:42
-msgid ""
-"connect still unconnected points to vector network by inserting new line(s)"
-msgstr ""
-#: ../vector/v.net/args.c:44
-msgid "new line is created from start point to end point"
-msgstr ""
-#: ../vector/v.net/args.c:46
-msgid ""
-"print to standard output {line_category start_point_category "
-"end_point_category}"
-msgstr ""
-#: ../vector/v.net/args.c:48
-msgid ""
-"print to standard output {point_category line_category[,line_category...]}"
-msgstr ""
-#: ../vector/v.net/args.c:50
-msgid "create turntable on vector network"
-msgstr ""
-#: ../vector/v.net/args.c:80
-msgid "Required for operation 'connect'. Connect points in given threshold."
-msgstr ""
-#: ../vector/v.net/args.c:84
-msgid "Name of input file"
-msgstr ""
-#: ../vector/v.net/args.c:86
-msgid "Required for operation 'arcs' ('-' for standard input)"
-msgstr ""
-#: ../vector/v.net/args.c:91
-msgid "Assign unique categories to new points"
-msgstr ""
-#: ../vector/v.net/args.c:92
-msgid "For operation 'nodes'"
-msgstr ""
-#: ../vector/v.net/args.c:97
-msgid "Snap points to network"
-msgstr ""
-#: ../vector/v.net/args.c:99
-msgid ""
-"For operation 'connect'. By default, a new line from the point to the "
-"network is created."
-msgstr ""
-#: ../vector/v.net/args.c:103
-msgid "Turntable layer"
-msgstr ""
-#: ../vector/v.net/args.c:106
-msgid ""
-"Layer where turntable will be attached. Format: layer number[/layer "
-"name].Required for operation 'turntable'."
-msgstr ""
-#: ../vector/v.net/args.c:117
-msgid ""
-"Layer with unique categories for every line in arc_layer and point on every "
-"node.  The categories are used in turntable. Format: layer number[/layer "
-"name]. Required for operation 'turntable'."
-msgstr ""
-#: ../vector/v.net/args.c:146
-msgid "Unknown operation"
-msgstr ""
-#: ../vector/v.net/args.c:175
-msgid "Threshold value must be >= 0"
-msgstr ""
-#: ../vector/v.net/connect.c:78
-msgid "Failed to find intersection segment"
-msgstr ""
-#: ../vector/v.net/report.c:37
-#, c-format
-msgid "Line %d has no category"
-msgstr ""
-#: ../vector/v.net/report.c:67
-#, c-format
-msgid "%d points found: %g %g %g line category: %d"
-msgstr ""
-#: ../vector/v.net/report.c:94
-#, c-format
-msgid "Duplicate nodes at x=%g y=%g z=%g "
-msgstr ""
-#: ../vector/v.net/main.c:49
-msgid "network maintenance"
-msgstr ""
-#: ../vector/v.net/main.c:50
-msgid "Performs network maintenance."
-msgstr ""
-#: ../vector/v.net/main.c:122
-#, c-format
-msgid "Unable to open vector map <%s> at topology level %d"
-msgstr ""
-#: ../vector/v.net/main.c:139
-#, c-format
-msgid "%d new points (nodes) written to output."
-msgstr ""
-#: ../vector/v.net/main.c:151
-#, c-format
-msgid "%d lines (network arcs) written to output."
-msgstr ""
-#: ../vector/v.colors/main.c:58
-msgid "Creates/modifies the color table associated with a vector map."
-msgstr ""
-#: ../vector/v.colors/main.c:70
-msgid "Source values"
-msgstr ""
-#: ../vector/v.colors/main.c:73
-msgid "read values from attribute table (requires <column> option)"
-msgstr ""
-#: ../vector/v.colors/main.c:75
-msgid "use z coordinate (3D points or centroids only)"
-msgstr ""
-#: ../vector/v.colors/main.c:79
-msgid "Name of column containing numeric data"
-msgstr ""
-#: ../vector/v.colors/main.c:80
-msgid "Required for use=attr"
-msgstr ""
-#: ../vector/v.colors/main.c:87
-msgid "Manually set range (refers to 'column' option)"
-msgstr ""
-#: ../vector/v.colors/main.c:88
-msgid "Ignored when 'rules' given"
-msgstr ""
-#: ../vector/v.colors/main.c:116
-msgid "Name of color column to populate RGB values"
-msgstr ""
-#: ../vector/v.colors/main.c:117
-msgid "If not given writes color table"
-msgstr ""
-#: ../vector/v.colors/main.c:152
-msgid "Convert color rules from RGB values to color table"
-msgstr ""
-#: ../vector/v.colors/main.c:153
-msgid "Option 'rgb_column' with valid RGB values required"
-msgstr ""
-#: ../vector/v.colors/main.c:196
-msgid "No vector map specified"
-msgstr ""
-#: ../vector/v.colors/main.c:201
-#, c-format
-msgid "Option <%s> given, assuming <use=attr>..."
-msgstr ""
-#: ../vector/v.colors/main.c:216
-#, c-format
-msgid "One of -%c, -%c or %s=, %s= or %s= must be specified"
-msgstr ""
-#: ../vector/v.colors/main.c:221
-#, c-format
-msgid "%s=, %s= and %s= are mutually exclusive"
-msgstr ""
-#: ../vector/v.colors/main.c:229
-#, c-format
-msgid "%s= required for -%c"
-msgstr ""
-#: ../vector/v.colors/main.c:234
-msgid ""
-"Reading rules from standard input is not implemented yet, please provide "
-"path to rules file instead."
-msgstr ""
-#: ../vector/v.colors/main.c:244
-#, c-format
-msgid "Unable to remove color table of vector map <%s>"
-msgstr ""
-#: ../vector/v.colors/main.c:246
-#, c-format
-msgid "Color table of vector map <%s> not found"
-msgstr ""
-#: ../vector/v.colors/main.c:254
-msgid "Color table exists. Exiting."
-msgstr ""
-#: ../vector/v.colors/main.c:270 ../vector/v.out.ascii/main.c:104
-#: ../vector/v.colors.out/make_colors.c:27
-#: ../vector/v.colors.out/scan_cats.c:24 ../vector/v.surf.rst/main.c:573
-#, c-format
-msgid "Layer <%s> not found"
-msgstr ""
-#: ../vector/v.colors/main.c:276
-#, c-format
-msgid "Option <%s>: min must be greater or equal to max"
-msgstr ""
-#: ../vector/v.colors/main.c:282
-msgid "Reading color rules from standard input is currently not supported"
-msgstr ""
-#: ../vector/v.colors/main.c:289
-#, c-format
-msgid "Color table <%s> not found"
-msgstr ""
-#: ../vector/v.colors/main.c:347
-msgid "Writing color rules..."
-msgstr ""
-#: ../vector/v.colors/main.c:363
-#, c-format
-msgid "Color table for vector map <%s> set to '%s'"
-msgstr ""
-#: ../vector/v.colors/make_colors.c:14
-#, c-format
-msgid "Color table '%s' is not supported for floating point attributes"
-msgstr ""
-#: ../vector/v.colors/make_colors.c:18 ../vector/v.colors/make_colors.c:25
-#, c-format
-msgid "Color table <%s> not supported"
-msgstr ""
-#: ../vector/v.colors/read_rgb.c:32
-#, c-format
-msgid "Data type of RGB column <%s> must be char"
-msgstr ""
-#: ../vector/v.colors/read_rgb.c:37
-msgid "No RGB values found"
-msgstr ""
-#: ../vector/v.colors/read_rgb.c:65
-#, c-format
-msgid "%d invalid RGB color values skipped"
-msgstr ""
-#: ../vector/v.colors/scan_attr.c:38 ../vector/v.colors.out/make_colors.c:45
-#: ../scripts/db.univar/db.univar.py:118
-msgid "Column <%s> is not numeric"
-msgstr ""
-#: ../vector/v.colors/scan_attr.c:45 ../vector/v.colors.out/make_colors.c:52
-msgid "No data selected"
-msgstr ""
-#: ../vector/v.colors/scan_attr.c:59 ../vector/v.colors/scan_z.c:68
-#, c-format
-msgid "Min value (%f) is out of range %f,%f"
-msgstr ""
-#: ../vector/v.colors/scan_attr.c:65 ../vector/v.colors/scan_z.c:74
-#, c-format
-msgid "Max value (%f) is out of range %f,%f"
-msgstr ""
-#: ../vector/v.colors/scan_attr.c:77 ../vector/v.colors/scan_cats.c:43
-#, c-format
-msgid "Min value (%d) is out of range %d,%d"
-msgstr ""
-#: ../vector/v.colors/scan_attr.c:83 ../vector/v.colors/scan_cats.c:49
-#, c-format
-msgid "Max value (%d) is out of range %d,%d"
-msgstr ""
-#: ../vector/v.colors/scan_attr.c:108
-msgid "Converting color rules into categories..."
-msgstr ""
-#: ../vector/v.colors/write_rgb.c:37 ../vector/v.what.rast/main.c:177
-#, c-format
-msgid "Unable to add column <%s> to table <%s>"
-msgstr ""
-#: ../vector/v.colors/write_rgb.c:60
-#, c-format
-msgid "Column <%s> added to table <%s>"
-msgstr ""
-#: ../vector/v.colors/write_rgb.c:64
-#, c-format
-msgid "Data type of column <%s> must be char"
-msgstr ""
-#: ../vector/v.colors/write_rgb.c:68
-msgid "No categories found"
-msgstr ""
-#: ../vector/v.colors/write_rgb.c:78
-#, c-format
-msgid "No color value defined for category %d"
-msgstr ""
-#: ../vector/v.colors/write_rgb.c:86
-msgid "Unable to update RGB values"
-msgstr ""
-#: ../vector/v.net.flow/main.c:62
-msgid "Computes the maximum flow between two sets of nodes in the network."
-msgstr ""
-#: ../vector/v.net.flow/main.c:84
-msgid "Name for output vector map containing a minimum cut"
-msgstr ""
-#: ../vector/v.net.flow/main.c:107
-msgid "Source category values"
-msgstr ""
-#: ../vector/v.net.flow/main.c:113
-msgid "Source WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.flow/main.c:118
-msgid "Sink category values"
-msgstr ""
-#: ../vector/v.net.flow/main.c:119 ../vector/v.net.flow/main.c:125
-msgid "Sink"
-msgstr ""
-#: ../vector/v.net.flow/main.c:124
-msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.flow/main.c:199
-#, c-format
-msgid "No source features selected. Please check options '%s', '%s'."
-msgstr ""
-#: ../vector/v.net.flow/main.c:206
-#, c-format
-msgid "No sink features selected. Please check options '%s', '%s'."
-msgstr ""
-#: ../vector/v.net.flow/main.c:215
-msgid "No sources"
-msgstr ""
-#: ../vector/v.net.flow/main.c:218
-msgid "No sinks"
-msgstr ""
-#: ../vector/v.net.flow/main.c:242
-msgid "Writing the output..."
-msgstr ""
-#: ../vector/v.hull/hull.c:107
-msgid "Simple planar hulls not implemented yet"
-msgstr ""
-#: ../vector/v.hull/chull.c:212
-msgid "Reading 3D vertices..."
-msgstr ""
-#: ../vector/v.hull/chull.c:396
-msgid "Constructing 3D hull..."
-msgstr ""
-#: ../vector/v.hull/main.c:56
-msgid "Produces a 2D/3D convex hull for a given vector map."
-msgstr ""
-#: ../vector/v.hull/main.c:70
-msgid "Limit to current region"
-msgstr ""
-#: ../vector/v.hull/main.c:75
-msgid "Create a 'flat' 2D hull even if the input is 3D points"
-msgstr ""
-#: ../vector/v.hull/main.c:100
-#, c-format
-msgid "Error loading vector points from <%s>"
-msgstr ""
-#: ../vector/v.hull/main.c:103
-#, c-format
-msgid "Convex hull calculation requires at least three points (%d found)"
-msgstr ""
-#: ../vector/v.hull/main.c:105
-#, c-format
-msgid "%d points read from vector map <%s>"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:31
-msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:38
-msgid "Name of attribute column(s) to be exported (point mode)"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:39
-msgid "\"*\" for all columns"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:59
-msgid "Simple point format (point per row)"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:60
-msgid "GRASS ASCII vector format"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:61
-msgid "OGC well-known text"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:65
-msgid "Field separator (points mode)"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:80
-msgid "Create old (version 4) ASCII file"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:85
-msgid "Include column names in output (points mode)"
-msgstr ""
-#: ../vector/v.out.ascii/args.c:91
-msgid "Only export points falling within current 3D region (points mode)"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:51
-msgid "Exports a vector map to a GRASS ASCII vector representation."
-msgstr ""
-#: ../vector/v.out.ascii/main.c:52
-msgid ""
-"By default only features with category are exported. To export all features "
-"use 'layer=-1'."
-msgstr ""
-#: ../vector/v.out.ascii/main.c:60
-#, c-format
-msgid "Parameter '%s' ignored in standard mode"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:69
-#, c-format
-msgid "Format '%s' is not supported for old version"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:73
-#, c-format
-msgid "Parameter '%s' must be given for old version"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:80
-#, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
-msgstr ""
-#: ../vector/v.out.ascii/main.c:107
-#, c-format
-msgid "%d error in <%s> option"
-msgid_plural "%d errors in <%s> option"
-msgstr[0] ""
-#: ../vector/v.out.ascii/main.c:141
-msgid "dig_att file already exist"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:144
-#, c-format
-msgid "Unable to open dig_att file <%s>"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:149
-msgid "Fetching data..."
-msgstr ""
-#: ../vector/v.out.ascii/main.c:156
-msgid "No points found, nothing to be exported"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:159
-msgid "No features found, nothing to be exported"
-msgstr ""
-#: ../vector/v.out.ascii/main.c:163
-msgid "An error occurred, nothing to be exported"
-msgstr ""
-#: ../vector/v.to.points/main.c:61
-msgid "Creates points along input lines in new vector map with 2 layers."
-msgstr ""
-#: ../vector/v.to.points/main.c:79
-msgid "Use line nodes or vertices only"
-msgstr ""
-#: ../vector/v.to.points/main.c:87
-msgid "Maximum distance between points in map units or percentage with -p"
-msgstr ""
-#: ../vector/v.to.points/main.c:91
-msgid "Interpolate points between line vertices (only for use=vertex)"
-msgstr ""
-#: ../vector/v.to.points/main.c:95
-msgid "Use dmax as percentage of line length"
-msgstr ""
-#: ../vector/v.to.points/main.c:99
-msgid "Start from the end node"
-msgstr ""
-#: ../vector/v.to.points/main.c:246
-#, c-format
-msgid ""
-"%d features without category in layer <%d> skipped. Note that features "
-"without category (usually boundaries) are not skipped when '%s=-1' is given."
-msgstr ""
-#: ../vector/v.to.points/main.c:310
-#, c-format
-msgid "%d points written to output vector map."
-msgstr ""
-#: ../vector/v.net.path/main.c:45
-msgid "Finds shortest path on vector network."
-msgstr ""
-#: ../vector/v.net.path/main.c:72
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
-msgstr ""
-#: ../vector/v.net.path/main.c:101
-msgid "Maximum distance to the network"
-msgstr ""
-#: ../vector/v.net.path/main.c:102
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
-msgstr ""
-#: ../vector/v.net.path/path.c:82
-#, c-format
-msgid "[%d] points without category (nfield: [%d])"
-msgstr ""
-#: ../vector/v.net.path/path.c:146 ../vector/v.net.path/path.c:211
-#, c-format
-msgid "From and to are identical (id %d)"
-msgstr ""
-#: ../vector/v.net.path/path.c:164 ../vector/v.net.path/path.c:188
-#, c-format
-msgid "No point with category [%d]"
-msgstr ""
-#: ../vector/v.net.path/path.c:234
-#, c-format
-msgid ""
-"Point with category [%d] is not reachable from point with category [%d]"
-msgstr ""
-#: ../vector/v.net.path/path.c:303
-#, c-format
-msgid "Point %f,%f is not reachable from point %f,%f"
-msgstr ""
-#: ../vector/v.net.path/path.c:368
-#, c-format
-msgid "[%d] input format errors"
-msgstr ""
-#: ../vector/v.net.path/path.c:370
-#, c-format
-msgid "[%d] points of given category missing"
-msgstr ""
-#: ../vector/v.net.path/path.c:372
-#, c-format
-msgid "%d destination(s) unreachable (including points out of threshold)"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:76 ../vector/v.in.ogr/geom.c:261
-#: ../vector/v.in.ogr/geom.c:275 ../vector/v.in.ogr/geom.c:304
-#: ../vector/v.in.ogr/geom.c:352
-#, c-format
-msgid "Skipping empty geometry feature %d"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:199 ../vector/v.in.ogr/geom.c:220
-msgid "Unable to read part of geometry"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:320
-#, c-format
-msgid "Feature (cat %d): degenerated polygon (%d vertices)"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:366
-#, c-format
-msgid "Degenerate island (%d vertices)"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:400
-msgid "Unable calculate centroid"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:431
-msgid "No centroid written for polygon with 0 vertices"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:452
-msgid "Unable to write part of geometry"
-msgstr ""
-#: ../vector/v.in.ogr/geom.c:458
-#, c-format
-msgid "Skipping unsupported geometry type '%s'"
-msgstr ""
-#: ../vector/v.in.ogr/dsn.c:28 ../vector/v.out.ogr/dsn.c:27
-#: ../vector/v.external/dsn.c:27
-msgid "Invalid connection string (dbname missing)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:201
-msgid "Imports vector data into a GRASS vector map using OGR library."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:207
-#: ../locale/scriptstrings/v.import_to_translate.c:5
-msgid "Name of OGR datasource to be imported"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:208
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: directory containing shapefiles\n"
-"\t\tMapInfo File: directory containing mapinfo files"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:219
-#: ../locale/scriptstrings/v.import_to_translate.c:7
-msgid "OGR layer name. If not given, all available layers are imported"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:221
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: shapefile name\n"
-"\t\tMapInfo File: mapinfo file name"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:250
-msgid "Minimum size of area to be imported (square meters)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:252
-msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:258
-msgid "Optionally change default input type"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:262
-msgid "import area centroids as points"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:263
-msgid "import area boundaries as lines"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:264
-msgid "import lines as area boundaries"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:265
-msgid "import points as centroids"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:274
-#: ../locale/scriptstrings/v.import_to_translate.c:17
-msgid "Snapping threshold for boundaries (map units)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:275
-msgid "'-1' for no snap"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:287
-msgid ""
-"List of column names to be used instead of original names, first is used for"
-" category column"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:296
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:11
-#: ../locale/scriptstrings/v.import_to_translate.c:14
-msgid "Encoding value for attribute data"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:298
-#: ../locale/scriptstrings/v.import_to_translate.c:15
-msgid ""
-"Overrides encoding interpretation, useful when importing ESRI Shapefile"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:306
-msgid "Name of column used for categories"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:308
-msgid ""
-"If not given, categories are generated as unique values and stored in 'cat' "
-"column"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:313
-msgid "Name of geometry column"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:314
-msgid "If not given, all geometry columns from the input are used"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:319
-#: ../locale/scriptstrings/v.import_to_translate.c:25
-msgid "List supported OGR formats and exit"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:325
-#: ../locale/scriptstrings/v.import_to_translate.c:26
-msgid "List available OGR layers in data source and exit"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:332
-msgid "Do not clean polygons (not recommended)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:337
-msgid "Force 2D output even if input is 3D"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:349 ../vector/v.external/args.c:47
-#: ../locale/scriptstrings/r.import_to_translate.c:32
-#: ../locale/scriptstrings/v.import_to_translate.c:28
-msgid ""
-"Assume that the dataset has the same projection as the current location"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:373
-msgid "Change column names to lowercase characters"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:504 ../vector/v.external/main.c:155
-#, c-format
-msgid "Unable to open data source <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:509
-#, c-format
-msgid "Using OGR driver '%s/%s'"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:513
-#, c-format
-msgid "Using OGR driver '%s'"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:531
-msgid "Using interleaved reading mode"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:537 ../vector/v.in.ogr/main.c:541
-#, c-format
-msgid ""
-"Option <%s> will be ignored. OGR doesn't support it for selected format "
-"(%s)."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:547
-#, c-format
-msgid ""
-"Option <%s> will be ignored. Multiple geometry fields are supported by GDAL "
-">= 1.11"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:557
-#, c-format
-msgid "Encoding value not supported by OGR driver <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:567
-msgid "No OGR layers available"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:574
-#, c-format
-msgid "Data source <%s> (format '%s') contains %d layers:"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:613 ../vector/v.external/main.c:128
-#, c-format
-msgid "Layer <%s> not available"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:627
-msgid ""
-"Detected different projections of input layers. Input layers must be "
-"imported separately."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:667
-#, c-format
-msgid "Illegal output name <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:688
-#, c-format
-msgid "All available OGR layers will be imported into vector map <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:697
-msgid ""
-"When creating a new location, the current region can not be used as spatial "
-"filter, disabling"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:715 ../vector/v.in.ogr/main.c:1968
-#, c-format
-msgid "Error setting attribute filter '%s'"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:755
-#, c-format
-msgid "Geometry column <%s> not found in OGR layer <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:768
-#, c-format
-msgid "Check if OGR layer <%s> contains polygons..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:826
-#, c-format
-msgid "Boundary splitting distance in map units: %G"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:856
-#, c-format
-msgid "Using temporary vector <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:898
-#, c-format
-msgid "Key column '%s' not found in input layer <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:911
-#, c-format
-msgid "Key column '%s' in input layer <%s> is not integer"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:923
-#, c-format
-msgid "Creating attribute table for layer <%s>..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:993
-#, c-format
-msgid "Column name <%s> renamed to <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1025
-#, c-format
-msgid "Writing column <%s> with integer 64 as integer 32"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1038
-#, c-format
-msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1062
-#, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1079
-#, c-format
-msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1083
-#, c-format
-msgid "Column type (Ogr_ftype: %d) not supported (Ogr_fieldname: %s)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1104
-#, c-format
-msgid "Column name <%s> renamed to <%s_%d>"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1168
-#, c-format
-msgid "Importing %lld features (OGR layer <%s>)..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1331
-#, c-format
-msgid "Cannot insert new row for input layer <%s>: %s"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1347
-#, c-format
-msgid "%d %s without geometry in input layer <%s> skipped"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1348
-msgid "feature"
-msgstr ""
-msgid "features"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1372
-#, c-format
-msgid "Unable to drop table: '%s'"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1407
-msgid "Cleaning polygons"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1411
-#, c-format
-msgid "Snapping boundaries (threshold = %.3e)..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1427 ../vector/v.buffer/main.c:752
-msgid "Breaking polygons..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1442 ../vector/v.buffer/main.c:759
-msgid "Breaking boundaries..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1457
-msgid "Merging boundaries..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1462
-msgid "Changing boundary dangles to lines..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1466 ../vector/v.voronoi/clean_topo.c:87
-#: ../vector/v.buffer/main.c:773
-msgid "Removing dangles..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1475
-msgid "Changing boundary bridges to lines..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1481 ../vector/v.voronoi/clean_topo.c:89
-#: ../vector/v.buffer/main.c:776
-msgid "Removing bridges..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1521
-#, c-format
-msgid "Finding centroids for OGR layer <%s>..."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1622
-#, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table."
-" The number of features for those areas is stored as category in layer %d"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1632
-#, c-format
-msgid "%d input polygons\n"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1633
-#, c-format
-msgid "%d input polygons"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1636
-#, c-format
-msgid "Total area: %G (%d areas)\n"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1637
-#, c-format
-msgid "Total area: %G (%d areas)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1640
-#, c-format
-msgid "Overlapping area: %G (%d areas)\n"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1643
-#, c-format
-msgid "Overlapping area: %G (%d areas)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1648
-#, c-format
-msgid "Area without category: %G (%d areas)\n"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1651
-#, c-format
-msgid "Area without category: %G (%d areas)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1773
-msgid "The output contains topological errors:"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1775
-#, c-format
-msgid "Unable to calculate a centroid for %d areas"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1777
-#, c-format
-msgid "Number of incorrect boundaries: %d"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1780
-#, c-format
-msgid "Number of centroids outside area: %d"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1783
-#, c-format
-msgid "Number of duplicate centroids: %d"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1786 ../vector/v.in.ogr/main.c:1808
-#: ../vector/v.in.ogr/main.c:1841
-msgid "The input could be cleaned by snapping vertices to each other."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1789 ../vector/v.in.ogr/main.c:1812
-#: ../vector/v.in.ogr/main.c:1836 ../vector/v.in.ogr/main.c:1842
-#, c-format
-msgid "Estimated range of snapping threshold: [%g, %g]"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1793 ../vector/v.in.ogr/main.c:1816
-#, c-format
-msgid "Try to import again, snapping with at least %g: 'snap=%g'"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1797 ../vector/v.in.ogr/main.c:1820
-#, c-format
-msgid "Try to import again, snapping with %g: 'snap=%g'"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1801 ../vector/v.in.ogr/main.c:1824
-msgid "Manual cleaning may be needed."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1806
-msgid "Some input polygons are overlapping each other."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1807
-msgid "If overlapping is not desired, the data need to be cleaned."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1829
-#, c-format
-msgid "%d input polygons got lost during import."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1832
-#, c-format
-msgid "%d additional areas where created during import."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1835
-#, c-format
-msgid "The snapping threshold %g might be too large."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1838
-msgid "Try to reduce the snapping threshold or clean the output manually."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1849 ../vector/v.in.ascii/main.c:552
-#: ../vector/v.in.ascii/main.c:555
-msgid "Import failed"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1884
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
-"to import 3D vector."
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1906
-#, c-format
-msgid "Using GDAL 2.2+ style interleaved reading for GDAL version %d"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1909
-#, c-format
-msgid "Using GDAL 1.x style interleaved reading for GDAL version %d"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:1959
-#, c-format
-msgid "Unable to re-open data source <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:2131
-msgid "xmin is larger than xmax in 'spatial' parameters"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:2133
-msgid "ymin is larger than ymax in 'spatial' parameters"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:2150
-#, c-format
-msgid ""
-"The spatial filter does not overlap with OGR layer <%s>. Nothing to import."
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:33 ../vector/v.external/proj.c:33
-#, c-format
-msgid "Geometry column <%s> not found in input layer <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:51 ../vector/v.external/proj.c:51
-msgid ""
-"Unable to convert input layer projection information to GRASS format for "
-"checking"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:57 ../vector/v.in.ogr/proj.c:85
-#: ../vector/v.external/proj.c:57 ../vector/v.external/proj.c:85
-msgid "Can't get WKT parameter string"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:60 ../vector/v.in.ogr/proj.c:88
-#: ../vector/v.external/proj.c:60 ../vector/v.external/proj.c:88
-#, c-format
-msgid ""
-"WKT definition:\n"
-"%s"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:70 ../vector/v.external/proj.c:70
-#, c-format
-msgid "No OGR projection available for layer <%s>"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:78 ../vector/v.external/proj.c:78
-#, c-format
-msgid "OGR projection for layer <%s> does not contain a valid SRS"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:96 ../vector/v.external/proj.c:96
-#, c-format
-msgid "OGR projection for layer <%s> can not be converted to proj4"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:103 ../vector/v.external/proj.c:103
-msgid "Can't get WKT-style parameter string"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:106 ../vector/v.external/proj.c:106
-#, c-format
-msgid ""
-"WKT-style definition:\n"
-"%s"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:151
-msgid "Layer projections are unreadable"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:162
-#, c-format
-msgid "Projection for layer <%s> is unreadable"
-msgstr ""
-#: ../vector/v.in.ogr/proj.c:196
-#, c-format
-msgid "Projection of layer <%s> is different from projection of layer <%s>"
-msgstr ""
-#: ../vector/v.what.rast/main.c:79
-msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-#: ../vector/v.what.rast/main.c:93
-msgid "Name of existing raster map to be queried"
-msgstr ""
-#: ../vector/v.what.rast/main.c:105
-msgid "Interpolate values from the nearest four cells"
-msgstr ""
-#: ../vector/v.what.rast/main.c:110
-msgid "Print categories and values instead of updating the database"
-msgstr ""
-#: ../vector/v.what.rast/main.c:170
-#, c-format
-msgid "Column <%s> not found in the table <%s>. Creating..."
-msgstr ""
-#: ../vector/v.what.rast/main.c:186
-msgid "Raster type is integer and column type is float"
-msgstr ""
-#: ../vector/v.what.rast/main.c:189
-msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-#: ../vector/v.what.rast/main.c:271
-#, c-format
-msgid "No features of type (%s) found in vector map <%s>"
-msgstr ""
-#: ../vector/v.what.rast/main.c:295
-#, c-format
-msgid "%d points outside current region were skipped"
-msgstr ""
-#: ../vector/v.what.rast/main.c:299
-#, c-format
-msgid "%d points without category were skipped"
-msgstr ""
-#: ../vector/v.what.rast/main.c:570 ../vector/v.what.rast/main.c:610
-#, c-format
-msgid "Multiple points (%d) of category %d, value set to 'NULL'"
-msgstr ""
-#: ../vector/v.what.rast/main.c:678
-#, c-format
-msgid "%d categories loaded from vector"
-msgstr ""
-#: ../vector/v.what.rast/main.c:680
-#, c-format
-msgid "%d duplicate categories in vector map <%s>"
-msgstr ""
-#: ../vector/v.what.rast/main.c:684
-#, c-format
-msgid "%d categories loaded from table"
-msgstr ""
-#: ../vector/v.what.rast/main.c:685
-#, c-format
-msgid "%d categories from vector missing in table"
-msgstr ""
-#: ../vector/v.what.rast/main.c:690 ../vector/v.distance/main.c:1752
-#, c-format
-msgid "%d records updated."
-msgstr ""
-#: ../vector/v.lidar.edgedetection/edgedetection.c:228
-#: ../vector/v.lidar.edgedetection/edgedetection.c:274
-#: ../vector/v.lidar.edgedetection/edgedetection.c:304
-#: ../vector/v.lidar.edgedetection/edgedetection.c:322
-#: ../vector/v.lidar.edgedetection/edgedetection.c:352
-msgid "Impossible to read from aux table"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/edgedetection.c:233
-#: ../vector/v.lidar.edgedetection/edgedetection.c:309
-msgid "Impossible to update aux table"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/edgedetection.c:246
-#: ../vector/v.lidar.edgedetection/edgedetection.c:258
-#: ../vector/v.lidar.edgedetection/edgedetection.c:379
-msgid "Impossible to write to aux table"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:79
-msgid "Detects the object's edges from a LIDAR data set."
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:98
-#: ../vector/v.surf.bspline/main.c:149
-msgid "Default: 4 * east-west resolution"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:107
-#: ../vector/v.surf.bspline/main.c:158
-msgid "Default: 4 * north-south resolution"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:115
-msgid "Regularization weight in gradient evaluation"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:124
-msgid "High gradient threshold for edge classification"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:133
-msgid "Low gradient threshold for edge classification"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:141
-msgid "Angle range for same direction detection"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:150
-msgid "Regularization weight in residual evaluation"
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:267
-#, c-format
-msgid "It was impossible to create <%s>."
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:270
-#, c-format
-msgid "It was impossible to create <%s> interpolation table in database."
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:423
-msgid "Performing bilinear interpolation..."
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:440
-msgid "Performing bicubic interpolation..."
-msgstr ""
-#: ../vector/v.lidar.edgedetection/main.c:452
-msgid "Point classification..."
-msgstr ""
-#: ../vector/v.colors.out/main.c:53
-msgid "Exports the color table associated with a vector map."
-msgstr ""
-#: ../vector/v.colors.out/main.c:66
-msgid "Name of attribute (numeric) column to which refer color rules"
-msgstr ""
-#: ../vector/v.colors.out/main.c:67
-msgid "If not given, color rules refer to categories"
-msgstr ""
-#: ../vector/v.colors.out/main.c:85
-#, c-format
-msgid "Unable to read color table for vector map <%s>"
-msgstr ""
-#: ../vector/v.colors.out/main.c:88
-#, c-format
-msgid "No color table defined for vector map <%s>"
-msgstr ""
-#: ../vector/v.out.ogr/export_areas.c:103
-#: ../vector/v.out.ogr/export_areas.c:204
-#: ../vector/v.out.ogr/export_areas.c:255
-#: ../vector/v.out.ogr/export_lines.c:135
-#: ../vector/v.out.ogr/export_lines.c:231
-#: ../vector/v.out.ogr/export_lines.c:280
-msgid "Failed to create OGR feature"
-msgstr ""
-#: ../vector/v.out.ogr/export_areas.c:147
-#: ../vector/v.out.ogr/export_lines.c:180
-#, c-format
-msgid "Unable to export multi-features. No category index for layer %d."
-msgstr ""
-#: ../vector/v.out.ogr/export_areas.c:158
-msgid "Exporting features with category..."
-msgstr ""
-#: ../vector/v.out.ogr/export_areas.c:180
-#: ../vector/v.out.ogr/export_lines.c:214
-#, c-format
-msgid ""
-"Unable to create multi-feature. Category %d not found in line %d, field %d"
-msgstr ""
-#: ../vector/v.out.ogr/export_areas.c:220
-msgid "Exporting features without category..."
-msgstr ""
-#: ../vector/v.out.ogr/create.c:20
-#, c-format
-msgid "OGR driver <%s> not available"
-msgstr ""
-#: ../vector/v.out.ogr/create.c:26
-#, c-format
-msgid "Creation of output OGR datasource <%s> failed"
-msgstr ""
-#: ../vector/v.out.ogr/create.c:36
-#, c-format
-msgid "Creation of OGR layer <%s> failed"
-msgstr ""
-#: ../vector/v.out.ogr/attrb.c:65
-#, c-format
-msgid "No database record for cat = %d and export of 'cat' disabled"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:9
-msgid "Name of input vector map to export"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:18
-msgid "Feature type(s)"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:20
-msgid ""
-"Combination of types is not supported by all output formats. Default is to "
-"use first type found in input vector map."
-msgstr ""
-#: ../vector/v.out.ogr/args.c:25
-msgid "Name of output OGR datasource"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:27
-msgid ""
-"For example: ESRI Shapefile: filename or directory for storage\n"
-"\t\t\tPostGIS database: connection string"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:37
-msgid "Data format to write"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:44
-msgid "Name for output OGR layer. If not specified, input name is used"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:46
-msgid ""
-"For example: ESRI Shapefile: shapefile name\n"
-"\t\t\tPostGIS database: table name"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:54
-msgid "Optionally change default output type"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:57
-msgid "export area boundaries as linestrings"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:58
-msgid "export lines as polygons"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:68
-msgid "OGR dataset creation option (format specific, NAME=VALUE)"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:78
-msgid "OGR layer creation option (format specific, NAME=VALUE)"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:83
-msgid "Open an existing OGR datasource for update"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:87
-msgid "Append to existing layer"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:88
-msgid "A new OGR layer is created if it does not exist"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:94
-msgid "Skip export of GRASS category ID ('cat') attribute"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:100
-msgid ""
-"Also export features without category (not labeled). Otherwise only features"
-" with category are exported."
-msgstr ""
-#: ../vector/v.out.ogr/args.c:106
-msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:112
-msgid "Force 2D output even if input is 3D (applies to Shapefile output only)"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:120
-msgid "Export vector data as multi-features"
-msgstr ""
-#: ../vector/v.out.ogr/args.c:126
-msgid ""
-"Create a new empty layer in defined OGR datasource and exit. Nothing is read"
-" from input."
-msgstr ""
-#: ../vector/v.out.ogr/args.c:133
-msgid "List supported output formats and exit"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:87
-msgid "Exports a vector map layer to any of the supported OGR vector formats."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:88
-msgid "By default a vector map layer is exported to OGC GeoPackage format."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:171
-msgid "Volumes will be exported as sets of faces"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:189
-msgid "Unable to determine input map's vector feature type(s)."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:254
-msgid "The combination of types is not supported by all formats."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:271
-msgid "Unable to create OGR spatial reference"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:293
-#, c-format
-msgid "OGR layer <%s> created in datasource <%s> (format '%s')"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:305
-msgid ""
-"The map contains islands. With the -c flag, islands will appear as filled "
-"areas, not holes in the output map."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:311
-#, c-format
-msgid ""
-"%d point found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d points found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:319
-#, c-format
-msgid ""
-"%d line found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:328
-#, c-format
-msgid ""
-"%d boundary found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgid_plural ""
-"%d boundaries found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:337
-#, c-format
-msgid ""
-"%d centroid found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgid_plural ""
-"%d centroids found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:345
-#, c-format
-msgid ""
-"%d area found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:353
-#, c-format
-msgid ""
-"%d face found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d faces found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:361
-#, c-format
-msgid ""
-"%d volume found, but not requested to be exported. Verify 'type' parameter."
-msgid_plural ""
-"%d volumes found, but not requested to be exported. Verify 'type' parameter."
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:371
-msgid ""
-"No points found, but requested to be exported. Will skip this feature type."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:380
-msgid ""
-"No lines found, but requested to be exported. Will skip this feature type."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:390
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this feature "
-"type."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:399
-msgid ""
-"No areas found, but requested to be exported. Will skip this feature type."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:409
-msgid ""
-"No centroids found, but requested to be exported. Will skip this feature "
-"type."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:418
-msgid ""
-"No faces found, but requested to be exported. Will skip this feature type."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:427
-msgid ""
-"No kernels found, but requested to be exported. Will skip this feature type."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:436
-msgid ""
-"No volumes found, but requested to be exported. Will skip this feature type."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:461
-#, c-format
-msgid "OGR driver <%s> not found"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:488
-#, c-format
-msgid "Unable to open OGR data source '%s'"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:502
-#, c-format
-msgid "Layer <%s> already exists in OGR data source '%s'"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:506
-#, c-format
-msgid "OGR layer <%s> already exists and will be overwritten"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:513
-#, c-format
-msgid "OGR layer <%s> doesn't exists, creating new OGR layer instead"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:541
-msgid "Overriding existing user-defined 'SHPT=' LCO."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:556
-#, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
-"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:568
-#, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options DIM "
-"(parameter 'lco') to export in 3D rather than 2D (default)."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:575
-#, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter"
-" 'lco') to export <in 3D rather than 2D (default)."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:594
-msgid "Unable to create OGR layer"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:606
-msgid "No attribute table found -> using only category numbers as attributes"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:610
-msgid "Exporting 'cat' anyway, as it is the only attribute table field"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:619 ../vector/v.out.ogr/main.c:691
-#, c-format
-msgid "New attribute column <%s> added to the table"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:703
-#, c-format
-msgid "Key column <%s> not found"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:716
-#, c-format
-msgid "Exporting %d feature..."
-msgid_plural "Exporting %d features..."
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:731
-#, c-format
-msgid "Exporting %d area (may take some time)..."
-msgid_plural "Exporting %d areas (may take some time)..."
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:750
-#, c-format
-msgid "Exporting %d volume..."
-msgid_plural "Exporting %d volumes..."
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:754
-msgid "Export of volumes not implemented yet. Skipping."
-msgstr ""
-#: ../vector/v.out.ogr/main.c:771
-#, c-format
-msgid "%d feature without attributes was written"
-msgid_plural "%d features without attributes were written"
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:777
-#, c-format
-msgid "%d feature without category was written"
-msgid_plural "%d features without category were written"
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:781
-#, c-format
-msgid ""
-"%d feature without category was skipped. Features without category are "
-"written only when -%c flag is given."
-msgid_plural ""
-"%d features without category were skipped. Features without category are "
-msgstr[0] ""
-#: ../vector/v.out.ogr/main.c:797
-msgid "Output layer is empty, no features written"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:798
-#, c-format
-msgid "%d feature (%s type) written to <%s> (%s format)."
-msgid_plural "%d features (%s type) written to <%s> (%s format)."
-msgstr[0] ""
-#: ../vector/v.to.rast3/main.c:51
-msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr ""
-#: ../vector/v.to.rast3/main.c:62
-msgid "Name of attribute column (data type must be numeric)"
-msgstr ""
-#: ../vector/v.to.rast3/main.c:107
-msgid "Unable to create output map"
-msgstr ""
-#: ../vector/v.to.rast3/main.c:157
-msgid "Unable to close new 3d raster map"
-msgstr ""
-#: ../vector/v.neighbors/main.c:55
-msgid "Neighborhood analysis tool for vector point maps."
-msgstr ""
-#: ../vector/v.neighbors/main.c:56
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map."
-msgstr ""
-#: ../vector/v.neighbors/main.c:78
-msgid "Neighborhood diameter in map units"
-msgstr ""
-#: ../vector/v.neighbors/main.c:98
-msgid "Input vector and computational region do not overlap"
-msgstr ""
-#: ../vector/v.neighbors/main.c:103
-#, c-format
-msgid ""
-"The search diameter %g is smaller than cell diagonal %g: some points could "
-"not be detected"
-msgstr ""
-#: ../vector/v.neighbors/main.c:175 ../vector/v.normal/main.c:195
-#: ../vector/v.surf.idw/main.c:176
-msgid "No points found"
-msgstr ""
-#: ../vector/v.voronoi/clean_topo.c:20
-msgid "Searching for topology errors..."
-msgstr ""
-#: ../vector/v.voronoi/clean_topo.c:78
-msgid "Cleaning output topology"
-msgstr ""
-#: ../vector/v.voronoi/clean_topo.c:115
-msgid "Removing incorrect boundaries from output"
-msgstr ""
-#: ../vector/v.voronoi/skeleton.c:293 ../vector/v.voronoi/skeleton.c:400
-#, c-format
-msgid "Pass %d"
-msgstr ""
-#: ../vector/v.voronoi/skeleton.c:509
-msgid "Node is outside any input area"
-msgstr ""
-#: ../vector/v.voronoi/sw_main.c:188
-#, c-format
-msgid ""
-"Found %d point/centroid in <%s>, but at least 2 are needed. Are the current "
-"region extents covering at least parts of the input map?"
-msgid_plural ""
-"Found %d points/centroids in <%s>, but at least 2 are needed. Are the "
-"current region extents covering at least parts of the input map?"
-msgstr[0] ""
-#: ../vector/v.voronoi/sw_main.c:412 ../vector/v.voronoi/sw_main.c:438
-msgid "All boundaries in the list should be valid"
-msgstr ""
-#: ../vector/v.voronoi/sw_main.c:418 ../vector/v.voronoi/sw_main.c:444
-msgid "Boundary is degenerate"
-msgstr ""
-#: ../vector/v.voronoi/sw_main.c:470
-#, c-format
-msgid "Found %d vertex in <%s>, but at least 2 are needed"
-msgid_plural "Found %d vertices in <%s>, but at least 2 are needed"
-msgstr[0] ""
-#: ../vector/v.voronoi/main.c:126
-msgid "skeleton"
-msgstr ""
-#: ../vector/v.voronoi/main.c:127
-msgid ""
-"Creates a Voronoi diagram constrained to the extents of the current region "
-"from an input vector map containing points or centroids."
-msgstr ""
-#: ../vector/v.voronoi/main.c:131
-msgid "Name of input vector map"
-msgstr ""
-#: ../vector/v.voronoi/main.c:141
-msgid "Factor for output smoothness"
-msgstr ""
-#: ../vector/v.voronoi/main.c:142
-msgid ""
-"Applies to input areas only. Smaller values produce smoother output but can "
-"cause numerical instability."
-msgstr ""
-#: ../vector/v.voronoi/main.c:149
-msgid "Maximum dangle length of skeletons"
-msgstr ""
-#: ../vector/v.voronoi/main.c:150
-msgid ""
-"Applies only to skeleton extraction. Default = -1 will extract the center "
-"line."
-msgstr ""
-#: ../vector/v.voronoi/main.c:156
-msgid "Create Voronoi diagram for input areas"
-msgstr ""
-#: ../vector/v.voronoi/main.c:161
-msgid "Extract skeletons for input areas"
-msgstr ""
-#: ../vector/v.voronoi/main.c:166
-msgid "Output tessellation as a graph (lines), not areas"
-msgstr ""
-#: ../vector/v.voronoi/main.c:182
-#, c-format
-msgid "Option '%s' is too small, set to %g"
-msgstr ""
-#: ../vector/v.voronoi/main.c:226
-#, c-format
-msgid "Voronoi triangulation for %d point..."
-msgid_plural "Voronoi triangulation for %d points..."
-msgstr[0] ""
-#: ../vector/v.voronoi/main.c:239
-msgid "Thin skeletons ..."
-msgstr ""
-#: ../vector/v.voronoi/main.c:396
-msgid "No table"
-msgstr ""
-#: ../vector/v.voronoi/main.c:411
-msgid "Cannot copy table"
-msgstr ""
-#: ../vector/v.info/parse.c:24
-msgid "Print history instead of info and exit"
-msgstr ""
-#: ../vector/v.info/parse.c:30
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
-msgstr ""
-#: ../vector/v.info/parse.c:35
-msgid "Print region info in shell script style"
-msgstr ""
-#: ../vector/v.info/parse.c:40
-msgid "Print extended metadata info in shell script style"
-msgstr ""
-#: ../vector/v.info/parse.c:45
-msgid "Print topology info in shell script style"
-msgstr ""
-#: ../vector/v.info/print.c:130
-#, c-format
-msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-#: ../vector/v.info/print.c:134
-#, c-format
-msgid "Displaying column types/names for database connection of layer <%s>:"
-msgstr ""
-#: ../vector/v.info/print.c:142
-#, c-format
-msgid "Unable to open driver <%s>"
-msgstr ""
-#: ../vector/v.info/print.c:317
-msgid "Name:"
-msgstr ""
-#: ../vector/v.info/print.c:320
-msgid "Mapset:"
-msgstr ""
-#: ../vector/v.info/print.c:324
-msgid "Location:"
-msgstr ""
-#: ../vector/v.info/print.c:327
-msgid "Database:"
-msgstr ""
-#: ../vector/v.info/print.c:331
-msgid "Title:"
-msgstr ""
-#: ../vector/v.info/print.c:334
-msgid "Map scale:"
-msgstr ""
-#: ../vector/v.info/print.c:338
-msgid "Name of creator:"
-msgstr ""
-#: ../vector/v.info/print.c:341
-msgid "Organization:"
-msgstr ""
-#: ../vector/v.info/print.c:344
-msgid "Source date:"
-msgstr ""
-#: ../vector/v.info/print.c:351
-msgid "Timestamp (first layer): "
-msgstr ""
-#: ../vector/v.info/print.c:355
-msgid "Timestamp (first layer): none"
-msgstr ""
-#: ../vector/v.info/print.c:363 ../vector/v.info/print.c:387
-#: ../vector/v.info/print.c:427
-msgid "Map format:"
-msgstr ""
-#: ../vector/v.info/print.c:368
-msgid "OGR layer:"
-msgstr ""
-#: ../vector/v.info/print.c:371
-msgid "OGR datasource:"
-msgstr ""
-#: ../vector/v.info/print.c:374 ../vector/v.info/print.c:403
-msgid "Feature type:"
-msgstr ""
-#: ../vector/v.info/print.c:392
-msgid "DB table:"
-msgstr ""
-#: ../vector/v.info/print.c:395
-msgid "DB name:"
-msgstr ""
-#: ../vector/v.info/print.c:399
-msgid "Geometry column:"
-msgstr ""
-#: ../vector/v.info/print.c:413 ../vector/v.info/print.c:422
-msgid "Topology:"
-msgstr ""
-#: ../vector/v.info/print.c:414
-msgid "schema:"
-msgstr ""
-#: ../vector/v.info/print.c:418
-msgid "Topology column:"
-msgstr ""
-#: ../vector/v.info/print.c:436
-msgid "Type of map"
-msgstr ""
-msgid "level"
-msgstr ""
-#: ../vector/v.info/print.c:443
-msgid "Number of points:"
-msgstr ""
-#: ../vector/v.info/print.c:445
-msgid "Number of centroids:"
-msgstr ""
-#: ../vector/v.info/print.c:450
-msgid "Number of lines:"
-msgstr ""
-#: ../vector/v.info/print.c:452
-msgid "Number of boundaries:"
-msgstr ""
-#: ../vector/v.info/print.c:457
-msgid "Number of areas:"
-msgstr ""
-#: ../vector/v.info/print.c:459
-msgid "Number of islands:"
-msgstr ""
-#: ../vector/v.info/print.c:465
-msgid "Number of faces:"
-msgstr ""
-#: ../vector/v.info/print.c:467
-msgid "Number of kernels:"
-msgstr ""
-#: ../vector/v.info/print.c:472
-msgid "Number of volumes:"
-msgstr ""
-#: ../vector/v.info/print.c:474
-msgid "Number of holes:"
-msgstr ""
-#: ../vector/v.info/print.c:481
-msgid "Map is 3D:"
-msgstr ""
-#: ../vector/v.info/print.c:482
-msgid "Yes"
-msgstr ""
-msgid "No"
-msgstr ""
-#: ../vector/v.info/print.c:485
-msgid "Number of dblinks:"
-msgstr ""
-#: ../vector/v.info/print.c:498
-msgid "invalid"
-msgstr ""
-#: ../vector/v.info/print.c:500
-msgid "unspecified"
-msgstr ""
-#: ../vector/v.info/print.c:506
-msgid "zone"
-msgstr ""
-#: ../vector/v.info/print.c:539
-msgid "Digitization threshold"
-msgstr ""
-#: ../vector/v.info/print.c:541
-msgid "Comment"
-msgstr ""
-#: ../vector/v.info/main.c:42
-msgid "attribute columns"
-msgstr ""
-#: ../vector/v.info/main.c:46
-msgid "Outputs basic information about a vector map."
-msgstr ""
-#: ../vector/v.info/level1.c:29
-#, c-format
-msgid "Topology not available for vector map <%s>. Registering primitives..."
-msgstr ""
-#: ../vector/v.drape/main.c:62
-msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
-msgstr ""
-#: ../vector/v.drape/main.c:83 ../vector/v.extrude/main.c:124
-msgid "Elevation raster map for height extraction"
-msgstr ""
-#: ../vector/v.drape/main.c:87 ../vector/v.drape/main.c:94
-#: ../vector/v.drape/main.c:101 ../vector/v.extrude/main.c:79
-#: ../vector/v.extrude/main.c:125 ../vector/v.extrude/main.c:129
-#: ../vector/v.extrude/main.c:136 ../vector/v.extrude/main.c:143
-msgid "Elevation"
-msgstr ""
-#: ../vector/v.drape/main.c:92 ../vector/v.extrude/main.c:134
-msgid "Scale factor sampled raster values"
-msgstr ""
-#: ../vector/v.drape/main.c:100 ../vector/v.extrude/main.c:142
-msgid "Height for sampled raster NULL values"
-msgstr ""
-#: ../vector/v.drape/main.c:199
-#, c-format
-msgid "Undefined height for feature %d. Skipping."
-msgstr ""
-#: ../vector/v.drape/main.c:204
-msgid "Copying attribute tables..."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:72
-#: ../vector/v.lrs/v.lrs.label/main.c:103
-#: ../vector/v.lrs/v.lrs.where/main.c:58
-#: ../vector/v.lrs/v.lrs.create/main.c:122
-msgid "linear reference system"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:75
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:79
-#: ../vector/v.lrs/v.lrs.label/main.c:109
-#: ../vector/v.lrs/v.lrs.where/main.c:66
-#: ../vector/v.lrs/v.lrs.create/main.c:128
-msgid "Input vector map containing lines"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:83
-msgid "Output vector map where segments will be written"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:88
-#: ../vector/v.lrs/v.lrs.label/main.c:118
-#: ../vector/v.lrs/v.lrs.where/main.c:75
-#: ../vector/v.lrs/v.lrs.create/main.c:147
-msgid "Line layer"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:94
-#: ../vector/v.lrs/v.lrs.label/main.c:124
-#: ../vector/v.lrs/v.lrs.where/main.c:86
-#: ../vector/v.lrs/v.lrs.create/main.c:207
-msgid "Driver name for reference system table"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:102
-#: ../vector/v.lrs/v.lrs.label/main.c:132
-#: ../vector/v.lrs/v.lrs.where/main.c:94
-#: ../vector/v.lrs/v.lrs.create/main.c:215
-msgid "Database name for reference system table"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:109
-#: ../vector/v.lrs/v.lrs.label/main.c:139
-#: ../vector/v.lrs/v.lrs.where/main.c:101
-msgid "Name of the reference system table"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:114
-msgid "Name of file containing segment rules. If not given, read from stdin."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:155
-#: ../vector/v.lrs/v.lrs.label/main.c:292
-#: ../vector/v.lrs/v.lrs.where/main.c:147
-#: ../vector/v.lrs/v.lrs.create/main.c:315
-msgid "Unable to open database for reference table"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:184
-#: ../vector/v.lrs/v.lrs.segment/main.c:238
-#, c-format
-msgid "Cannot read input: %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:196
-#, c-format
-msgid "No record in LR table for: %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:200
-#, c-format
-msgid "More than one record in LR table for: %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:207
-#: ../vector/v.lrs/v.lrs.segment/main.c:294
-#, c-format
-msgid "Unable to find line of cat [%d]"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:217
-#, c-format
-msgid ""
-"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
-"%s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:253
-#, c-format
-msgid ""
-"No record in LRS table for 1. point of:\n"
-"  %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:258
-#, c-format
-msgid ""
-"Using last from more offsets found for 1. point of:\n"
-"  %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:262
-#, c-format
-msgid ""
-"Requested offset for the 1. point not found, using nearest found:\n"
-"  %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:273
-#, c-format
-msgid ""
-"No record in LRS table for 2. point of:\n"
-"  %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:278
-#, c-format
-msgid ""
-"Requested offset for the 2. point not found, using nearest found:\n"
-"  %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:282
-#, c-format
-msgid ""
-"Using first from more offsets found for 2. point of:\n"
-"  %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:287
-msgid "Segment over 2 (or more) segments, not yet supported"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:304
-#, c-format
-msgid "End of segment > line length (%e) -> cut"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:313
-#, c-format
-msgid ""
-"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
-"%s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:357
-#: ../vector/v.lrs/v.lrs.where/main.c:222
-#, c-format
-msgid "[%d] point read from input"
-msgid_plural "[%d] points read from input"
-msgstr[0] ""
-#. GTC %s will be replaced with a message about lost points.
-#: ../vector/v.lrs/v.lrs.segment/main.c:364
-#, c-format
-msgid "[%d] point written to output map (%s)"
-msgid_plural "[%d] points written to output map (%s)"
-msgstr[0] ""
-#: ../vector/v.lrs/v.lrs.segment/main.c:369
-#, c-format
-msgid "[%d] line read from input"
-msgid_plural "[%d] lines read from input"
-msgstr[0] ""
-#. GTC %s will be replaced with a message about lost lines.
-#: ../vector/v.lrs/v.lrs.segment/main.c:376
-#, c-format
-msgid "[%d] line written to output map (%s)"
-msgid_plural "[%d] lines written to output map (%s)"
-msgstr[0] ""
-#: ../vector/v.lrs/v.lrs.label/main.c:105
-msgid "Creates stationing from input lines, and linear reference system."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:113
-msgid "Output vector map where stationing will be written"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:147
-msgid "Label file"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:156
-msgid "PM left, MP right, stationing left, stationing right offset"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:161
-msgid "Offset label in label x-direction in map units"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:168
-msgid "Offset label in label y-direction in map units"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:174 ../vector/v.label/main.c:113
-msgid "Reference position"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:181 ../vector/v.label/main.c:125
-#: ../vector/v.label/main.c:132 ../vector/v.label/main.c:140
-#: ../vector/v.label/main.c:148 ../vector/v.label.sa/main.c:72
-#: ../vector/v.label.sa/main.c:80
-msgid "Font"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:187 ../vector/v.label/main.c:129
-#: ../vector/v.label.sa/main.c:77
-msgid "Label size (in map-units)"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:197
-msgid "Line width of text"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:198
-#: ../vector/v.lrs/v.lrs.label/main.c:211
-msgid "Only for d.label output"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:205 ../vector/v.label/main.c:174
-#: ../vector/v.label.sa/main.c:107
-msgid "Highlight color for text"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:210
-msgid "Line width of highlight color"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:228
-msgid "Opaque to vector"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:229
-msgid "Only relevant if background color is selected"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:322
-#, c-format
-msgid "Unable to select records from LRS table: %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:412
-msgid "No record in LR table"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.label/main.c:416
-msgid "More than one record in LR table"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear"
-" reference system."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:70
-msgid "Input vector map containing points"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:80
-#: ../vector/v.lrs/v.lrs.create/main.c:151
-msgid "Point layer"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:108
-msgid "Maximum distance to nearest line"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.where/main.c:225
-#, c-format
-msgid "[%d] position found"
-msgid_plural "[%d] positions found"
-msgstr[0] ""
-#: ../vector/v.lrs/v.lrs.where/main.c:229
-#, c-format
-msgid "[%d] point outside threshold"
-msgid_plural "[%d] points outside threshold"
-msgstr[0] ""
-#: ../vector/v.lrs/v.lrs.where/main.c:233
-#, c-format
-msgid "[%d] point - no record found"
-msgid_plural "[%d] points - no record found"
-msgstr[0] ""
-#: ../vector/v.lrs/v.lrs.where/main.c:237
-#, c-format
-msgid "[%d] point - too many records found"
-msgid_plural "[%d] points - too many records found"
-msgstr[0] ""
-#: ../vector/v.lrs/v.lrs.create/main.c:124
-msgid "Creates a linear reference system."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:133
-msgid "Output vector map where oriented lines are written"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:138
-msgid "Output vector map of errors"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:143
-msgid "Input vector map containing reference points"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:158
-msgid "Column containing line identifiers for lines"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:165
-msgid "Column containing line identifiers for points"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:173
-msgid "Column containing milepost position for the beginning of next segment"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:191
-msgid "Column containing milepost position for the end of previous segment"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:200
-msgid "Column containing offset from milepost for the end of previous segment"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:223
-msgid "Name of table where the reference system will be written"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:224
-msgid "New table is created by this module"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:231
-msgid "Maximum distance of point to line allowed"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:286
-msgid "Cannot get layer info for lines"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:289
-msgid "Cannot get layer info for points"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:327
-#, c-format
-msgid "Unable to drop table: %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:346
-#, c-format
-msgid "Unable to select line id values from %s.%s."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:356
-msgid "Line id column must be integer"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:367
-#: ../vector/v.lrs/v.lrs.create/main.c:469
-msgid "Unable to fetch line id from line table"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:419
-#, c-format
-msgid "Line [%d] without category (layer [%d])"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:439
-#, c-format
-msgid "No lines selected for line id [%d]"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:459
-#, c-format
-msgid "Unable to select point attributes from <%s>"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:490
-#, c-format
-msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:512
-#, c-format
-msgid "Milepost (end) %f+%f used as %f+%f (change MP to integer)"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:538
-#, c-format
-msgid "Point [%d] without category (layer [%d])"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:585
-#, c-format
-msgid "Point [%d] cat [%d] is out of threshold (distance = %f)"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:717
-#, c-format
-msgid "End > start for point cat [%d]"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:734
-msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:751
-#, c-format
-msgid "Start of 1. MP >= start of 2. MP for points' cats [%d], [%d]"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:761
-#, c-format
-msgid "Distance along line identical for points' cats [%d], [%d]"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:775
-#, c-format
-msgid "Not enough points (%d) attached to the line (cat %d), line skip."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:780
-#, c-format
-msgid "Unable to guess direction for the line (cat %d), line skip."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:784
-#, c-format
-msgid "Incorrect order of points along line cat [%d]"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:834
-#, c-format
-msgid "Unable to insert reference records: %s"
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:875
-msgid "Building topology for output (out_lines) map..."
-msgstr ""
-#: ../vector/v.lrs/v.lrs.create/main.c:886
-msgid "Building topology for error (err) map..."
-msgstr ""
-#: ../vector/v.in.dwg/main.c:84
-msgid "Converts DWG/DXF to GRASS vector map"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:87
-msgid "Name of DWG or DXF file"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:97
-msgid "List of layers to import"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:102
-msgid "Invert selection by layers (don't import layers in list)"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:106 ../vector/v.in.ascii/main.c:176
-msgid "Create 3D vector map"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:110
-msgid "Write circles as points (centre)"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:114
-msgid "List available layers and exit"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:118
-msgid "Use numeric type for attribute \"layer\""
-msgstr ""
-#: ../vector/v.in.dwg/main.c:138
-#, c-format
-msgid "Unable to initialize OpenDWG Toolkit, error: %d: %s."
-msgstr ""
-#: ../vector/v.in.dwg/main.c:141
-#, c-format
-msgid "%s Cannot open %s"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:149
-#, c-format
-msgid "Unable to open input file <%s>. Error %d: %s"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:287
-#, c-format
-msgid "%d elements skipped (layer name was not in list)"
-msgstr ""
-#: ../vector/v.in.dwg/main.c:290
-#, c-format
-msgid "%d elements processed"
-msgstr ""
-#: ../vector/v.type/main.c:40 ../vector/v.edit/main.c:56
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
-msgid "editing"
-msgstr ""
-#: ../vector/v.type/main.c:44
-msgid "Changes type of vector features."
-msgstr ""
-#: ../vector/v.type/main.c:57
-msgid "Feature type to convert from"
-msgstr ""
-#: ../vector/v.type/main.c:65
-msgid "Feature type to convert to"
-msgstr ""
-#: ../vector/v.type/main.c:120
-msgid "Incompatible types"
-msgstr ""
-#: ../vector/v.in.ascii/points.c:82
-msgid "Scanning input for column types..."
-msgstr ""
-#: ../vector/v.in.ascii/points.c:130
-#, c-format
-msgid "Row %d: '%s' can not be imported into the attribute table"
-msgstr ""
-#: ../vector/v.in.ascii/points.c:134 ../vector/v.in.ascii/points.c:144
-#, c-format
-msgid "Broken row %d: '%s'"
-msgstr ""
-#: ../vector/v.in.ascii/points.c:188 ../vector/v.in.ascii/points.c:207
-#, c-format
-msgid ""
-"Current row %d:\n"
-"%s\n"
-msgstr ""
-#: ../vector/v.in.ascii/points.c:189 ../vector/v.in.ascii/points.c:217
-#, c-format
-msgid "Unparsable longitude value in column %d: %s"
-msgstr ""
-#: ../vector/v.in.ascii/points.c:208 ../vector/v.in.ascii/points.c:221
-#, c-format
-msgid "Unparsable latitude value in column %d: %s"
-msgstr ""
-#: ../vector/v.in.ascii/points.c:298
-#, c-format
-msgid "Skipping %d of %d row falling outside of current region"
-msgid_plural "Skipping %d of %d rows falling outside of current region"
-msgstr[0] ""
-#: ../vector/v.in.ascii/points.c:328
-msgid "Importing points..."
-msgstr ""
-#: ../vector/v.in.ascii/main.c:76
-msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr ""
-#: ../vector/v.in.ascii/main.c:94
-msgid "simple x,y[,z] list"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:95
-msgid "GRASS vector ASCII format"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:98
-msgid "Input file format"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:99 ../vector/v.in.ascii/main.c:102
-#: ../vector/v.in.ascii/main.c:109 ../vector/v.in.ascii/main.c:187
-msgid "Input format"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:108
-msgid "Special characters: doublequote, singlequote, none"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:118
-msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:127
-msgid "Column definition in SQL style (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:128
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name "
-"varchar(10)'"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:140 ../vector/v.in.ascii/main.c:150
-msgid "First column is 1"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:149
-msgid "Number of column used as y coordinate (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:159
-msgid "Number of column used as z coordinate (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:160
-msgid "First column is 1. If 0, z coordinate is not used"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:170
-msgid "Number of column used as category (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:172
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written"
-" to new column 'cat'"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:181
-msgid "Create a new empty vector map and exit. Nothing is read from input."
-msgstr ""
-#: ../vector/v.in.ascii/main.c:186
-msgid "Do not expect a header when reading in standard format"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:191
-msgid "Do not create table in points mode"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:201
-msgid "Only import points falling within current region (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:206
-msgid "Ignore broken line(s) in points mode"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:223
-msgid "Please specify z column"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:234
-msgid "Please specify reasonable z column"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:239
-msgid "Column numbers must not be negative"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:283
-#, c-format
-msgid "Maximum input row length: %d"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:285
-#, c-format
-msgid "Maximum number of columns: %d"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:286
-#, c-format
-msgid "Minimum number of columns: %d"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:289
-#, c-format
-msgid "Number of columns: %d"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:292
-#, c-format
-msgid "Number of rows: %d"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:296 ../vector/v.in.ascii/main.c:300
-#: ../vector/v.in.ascii/main.c:305 ../vector/v.in.ascii/main.c:310
-#, c-format
-msgid ""
-"'%s' column number > minimum last column number (incorrect field separator "
-"or format?)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:315 ../vector/v.in.ascii/main.c:318
-#: ../vector/v.in.ascii/main.c:321 ../vector/v.in.ascii/main.c:324
-#, c-format
-msgid "'%s' column is not of number type"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:366
-msgid "Category column is not of integer type"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:443
-#, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in "
-"input"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:471
-#, c-format
-msgid "Column number %d <%s> defined as double has only integer values"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:476
-#, c-format
-msgid "Column number %d <%s> defined as string has only integer values"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:483
-#, c-format
-msgid "Column number %d <%s> defined as integer has double values"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:488
-#, c-format
-msgid "Column number %d <%s> defined as string has double values"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:495
-#, c-format
-msgid "Column number %d <%s> defined as integer has string values"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:500
-#, c-format
-msgid "Column number %d <%s> defined as double has string values"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:505
-#, c-format
-msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:541
-msgid "Populating table..."
-msgstr ""
-#: ../vector/v.in.ascii/main.c:544
-msgid ""
-"Unable to close attribute table. The DBMI driver did not accept all "
-"attributes"
-msgstr ""
-#: ../vector/v.surf.bspline/crosscorr.c:75
-#, c-format
-msgid "%d are too many points. The cross validation would take too much time."
-msgstr ""
-#: ../vector/v.surf.bspline/crosscorr.c:84
-#, c-format
-msgid "%d points read in region"
-msgstr ""
-#: ../vector/v.surf.bspline/crosscorr.c:88
-msgid ""
-"Maybe it takes too long. It will depend on how many points you are "
-"considering."
-msgstr ""
-#: ../vector/v.surf.bspline/crosscorr.c:119
-#, c-format
-msgid "CrossCorrelation: driver=%s db=%s"
-msgstr ""
-#: ../vector/v.surf.bspline/crosscorr.c:136
-#, c-format
-msgid "No records selected from table <%s> "
-msgstr ""
-#: ../vector/v.surf.bspline/crosscorr.c:220
-#: ../vector/v.surf.idw/read_sites.c:107
-#, c-format
-msgid "No record for point (cat = %d)"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:96
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:118 ../vector/v.surf.rst/main.c:186
-msgid "Name of the attribute column with values to be used for approximation"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:119
-msgid "If not given and input is 3D vector map then z-coordinates are used."
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:126
-msgid "Name of input vector map with sparse points"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:139
-msgid "Raster map to use for masking (applies to raster output only)"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:207
-msgid "Choose either vector or raster output, not both"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:210
-msgid "No raster or vector or cross-validation output"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:231
-msgid "Unable to set default DB connection"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:236
-msgid "No default DB defined"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:277 ../vector/v.surf.rst/main.c:577
-msgid ""
-"Input is 3D: using attribute values instead of z-coordinates for "
-"approximation"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:279 ../vector/v.surf.rst/main.c:579
-msgid "Input is 3D: using z-coordinates for approximation"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:283
-#, c-format
-msgid "Input vector map is 2D. Parameter <%s> required."
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:295
-#, c-format
-msgid "Estimated point density: %.4g"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:296
-#, c-format
-msgid "Estimated mean distance between points: %.4g"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:299
-#, c-format
-msgid "No points in current region"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:328
-#, c-format
-msgid "Vector map <%s> of sparse points will be interpolated"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:344
-#, c-format
-msgid ""
-"Sorry, the <%s> driver is not compatible with the vector output of this "
-"module. Try with raster output or another driver."
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:367
-#, c-format
-msgid "Points in input vector map <%s> will be interpolated"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:374
-msgid "Reading values from attribute table..."
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:378
-msgid "Cannot read layer info"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:400 ../vector/v.normal/main.c:135
-#, c-format
-msgid "%d records selected from table"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:420
-#, c-format
-msgid "Interpolation: Creating table: It was impossible to create table <%s>."
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:437
-#, c-format
-msgid "Cells for raster map <%s> will be interpolated"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:498
-msgid "Load masking map"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:710
-#, c-format
-msgid "%d points found in this subregion"
-msgstr ""
-#: ../vector/v.surf.bspline/main.c:757
-#, c-format
-msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
-msgstr ""
-#: ../vector/v.distance/distance.c:49
-#, c-format
-msgid "Invalid segment number %d for %d points"
-msgstr ""
-#: ../vector/v.distance/distance.c:426
-msgid "At least one point is really inside the area!"
-msgstr ""
-#: ../vector/v.distance/main.c:126
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-#: ../vector/v.distance/main.c:130
-msgid "Name of existing vector map (from)"
-msgstr ""
-#: ../vector/v.distance/main.c:135
-msgid "Layer number or name (from)"
-msgstr ""
-#: ../vector/v.distance/main.c:142
-msgid "Feature type (from)"
-msgstr ""
-#: ../vector/v.distance/main.c:147
-msgid "Name of existing vector map (to)"
-msgstr ""
-#: ../vector/v.distance/main.c:152
-msgid "Layer number or name (to)"
-msgstr ""
-#: ../vector/v.distance/main.c:159
-msgid "Feature type (to)"
-msgstr ""
-#: ../vector/v.distance/main.c:165
-msgid ""
-"Name for output vector map containing lines connecting nearest elements"
-msgstr ""
-#: ../vector/v.distance/main.c:173
-msgid "Maximum distance or -1 for no limit"
-msgstr ""
-#: ../vector/v.distance/main.c:174 ../vector/v.distance/main.c:182
-msgid "Map units, meters for ll"
-msgstr ""
-#: ../vector/v.distance/main.c:181
-msgid "Minimum distance or -1 for no limit"
-msgstr ""
-#: ../vector/v.distance/main.c:192
-msgid "Values describing the relation between two nearest features"
-msgstr ""
-#: ../vector/v.distance/main.c:202
-msgid "category of the nearest feature"
-msgstr ""
-#: ../vector/v.distance/main.c:203
-msgid "minimum distance to nearest feature"
-msgstr ""
-#: ../vector/v.distance/main.c:204
-msgid "x coordinate of the nearest point on the 'to' feature"
-msgstr ""
-#: ../vector/v.distance/main.c:205
-msgid "y coordinate of the nearest point on the 'to' feature"
-msgstr ""
-#: ../vector/v.distance/main.c:206
-msgid ""
-"distance to the nearest point on the 'to' feature along that linear feature"
-msgstr ""
-#: ../vector/v.distance/main.c:208
-msgid ""
-"angle along the nearest linear feature in the 'to' map, measured CCW from "
-"the +x axis, in radians, between -Pi and Pi inclusive"
-msgstr ""
-#: ../vector/v.distance/main.c:211
-msgid "attribute of nearest feature given by to_column option"
-msgstr ""
-#: ../vector/v.distance/main.c:225
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
-msgstr ""
-#: ../vector/v.distance/main.c:231
-msgid "Column name of nearest feature (used with upload=to_attr)"
-msgstr ""
-#: ../vector/v.distance/main.c:236
-msgid "Name for new attribute table"
-msgstr ""
-#: ../vector/v.distance/main.c:239
-msgid "Field separator for printing output to stdout"
-msgstr ""
-#: ../vector/v.distance/main.c:244
-msgid "Print output to stdout, don't update attribute table"
-msgstr ""
-#: ../vector/v.distance/main.c:246
-msgid "First column is always category of 'from' feature called from_cat"
-msgstr ""
-#: ../vector/v.distance/main.c:251
-msgid "Calculate distances to all features within the threshold"
-msgstr ""
-#: ../vector/v.distance/main.c:253
-msgid ""
-"Output may be written to stdout using the '-p' flag or uploaded to a new "
-"table created by the 'table' option; multiple 'upload' options may be used."
-msgstr ""
-#: ../vector/v.distance/main.c:293
-msgid "Updating the from= table is not supported with -a"
-msgstr ""
-#: ../vector/v.distance/main.c:309
-msgid "Printing distance matrix is not supported with dmin= or dmax="
-msgstr ""
-#: ../vector/v.distance/main.c:336
-msgid "to_column option missing"
-msgstr ""
-#: ../vector/v.distance/main.c:352
-msgid "Too many column names"
-msgstr ""
-#: ../vector/v.distance/main.c:359
-msgid "Not enough column names"
-msgstr ""
-#: ../vector/v.distance/main.c:371 ../vector/v.distance/main.c:391
-#, c-format
-msgid "Input vector map <%s> is 3D"
-msgstr ""
-#: ../vector/v.distance/main.c:382 ../vector/v.distance/main.c:403
-#, c-format
-msgid "No features of selected type found in <%s>"
-msgstr ""
-#: ../vector/v.distance/main.c:478
-msgid "dmin can not be larger than dmax"
-msgstr ""
-#: ../vector/v.distance/main.c:624
-msgid "Incompatible column types"
-msgstr ""
-#: ../vector/v.distance/main.c:674
-msgid "No categories for 'from' for slected type and layer"
-msgstr ""
-#: ../vector/v.distance/main.c:702
-msgid "Finding nearest features..."
-msgstr ""
-#: ../vector/v.distance/main.c:803 ../vector/v.distance/main.c:1091
-#, c-format
-msgid "More cats found in to_layer (line=%d)"
-msgstr ""
-#: ../vector/v.distance/main.c:880 ../vector/v.distance/main.c:1238
-#, c-format
-msgid "More cats found in to_layer (area=%d)"
-msgstr ""
-#: ../vector/v.distance/main.c:990
-msgid "Finding nearest features for areas..."
-msgstr ""
-#: ../vector/v.distance/main.c:1357
-msgid "DATETIME type not yet supported, no attributes will be uploaded"
-msgstr ""
-#: ../vector/v.distance/main.c:1373
-msgid "Unable to open default database"
-msgstr ""
-#: ../vector/v.distance/main.c:1721
-#, c-format
-msgid "%d categories with more than 1 feature in vector map <%s>"
-msgstr ""
-#: ../vector/v.distance/main.c:1724
-#, c-format
-msgid "%d categories - no nearest feature found"
-msgstr ""
-#: ../vector/v.distance/main.c:1733
-#, c-format
-msgid "%d distances calculated"
-msgstr ""
-#: ../vector/v.distance/main.c:1734
-#, c-format
-msgid "%d records inserted"
-msgstr ""
-#: ../vector/v.distance/main.c:1736
-#, c-format
-msgid "%d insert errors"
-msgstr ""
-#: ../vector/v.distance/main.c:1740
-#, c-format
-msgid "%d categories read from the map"
-msgstr ""
-#: ../vector/v.distance/main.c:1742
-#, c-format
-msgid "%d categories exist in the table"
-msgstr ""
-#: ../vector/v.distance/main.c:1744
-#, c-format
-msgid "%d categories read from the map exist in the table"
-msgstr ""
-#: ../vector/v.distance/main.c:1747
-#, c-format
-msgid "%d categories read from the map don't exist in the table"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:153
-msgid "Performs surface interpolation from vector points map by splines."
-msgstr ""
-#: ../vector/v.surf.rst/main.c:155
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-#: ../vector/v.surf.rst/main.c:162
-msgid "Perform cross-validation procedure without raster approximation"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:167
-msgid "Use scale dependent tension"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:187 ../vector/v.surf.idw/main.c:102
-msgid ""
-"If not given and input is 2D vector map then category values are used. If "
-"input is 3D vector map then z-coordinates are used."
-msgstr ""
-#: ../vector/v.surf.rst/main.c:197
-msgid "Name for output surface elevation raster map"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:227
-msgid "Name for output mean curvature raster map"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:247
-msgid "Name for output vector map showing quadtree segmentation"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:254
-msgid "Name for output vector map showing overlapping windows"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:263
-msgid "Number of threads for parallel computing"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:269
-msgid "Name of raster map used as mask"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:285
-msgid "Smoothing is by default 0.5 unless smooth_column is specified"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:293
-msgid "Name of the attribute column with smoothing parameters"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:326
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:335
-msgid "Conversion factor for values used for approximation"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:412
-msgid "Parallel computation disabled when deviation output is required"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:419
-msgid ""
-"GRASS GIS is not compiled with OpenMP support, parallel computation is "
-"disabled."
-msgstr ""
-#: ../vector/v.surf.rst/main.c:424 ../vector/v.surf.rst/main.c:429
-#: ../vector/v.surf.rst/main.c:434 ../vector/v.surf.rst/main.c:439
-#, c-format
-msgid "Output vector map name <%s> is not valid map name"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:452
-msgid "You are not outputting any raster or vector maps"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:461
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:464
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or"
-" devi file"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:482
-msgid "Using anisotropy - both theta and scalex have to be specified"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:490
-msgid "Both smatt and smooth options specified - using constant"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:500
-msgid "The computation will last too long - lower npmin is suggested"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:583
-msgid "Input is 2D: using attribute values for approximation"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:585
-msgid "Input is 2D: using category values for approximation"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:698
-#, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for"
-" temp files"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:719
-msgid "Processing segments in parallel..."
-msgstr ""
-#: ../vector/v.surf.rst/main.c:725 ../vector/v.surf.rst/main.c:734
-msgid "Interp_segmets failed"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:728
-msgid "Processing segments..."
-msgstr ""
-#: ../vector/v.surf.rst/main.c:752
-msgid "Unable to write raster maps - try to increase resolution"
-msgstr ""
-#: ../vector/v.build.polylines/main.c:116
-msgid "Builds polylines from lines or boundaries."
-msgstr ""
-#: ../vector/v.build.polylines/main.c:126
-msgid "Category number mode"
-msgstr ""
-#: ../vector/v.build.polylines/main.c:131
-msgid "Do not assign any category number to polyline"
-msgstr ""
-#: ../vector/v.build.polylines/main.c:132
-msgid "Assign category number of first line to polyline"
-msgstr ""
-#: ../vector/v.build.polylines/main.c:133
-msgid "Assign multiple category numbers to polyline"
-msgstr ""
-#: ../vector/v.build.polylines/main.c:134
-msgid "Create polyline from lines with same categories"
-msgstr ""
-#: ../vector/v.build.polylines/main.c:231
-#, c-format
-msgid "%d line or boundaries found in input vector map"
-msgid_plural "%d lines or boundaries found in input vector map"
-msgstr[0] ""
-#: ../vector/v.build.polylines/main.c:234
-#, c-format
-msgid "%d polyline stored in output vector map"
-msgid_plural "%d polylines stored in output vector map"
-msgstr[0] ""
-#: ../vector/v.label/main.c:62
-msgid "Creates paint labels for a vector map from attached attributes."
-msgstr ""
-#: ../vector/v.label/main.c:67 ../vector/v.label.sa/main.c:61
-msgid "Name for new paint-label file"
-msgstr ""
-#: ../vector/v.label/main.c:69
-msgid "If not given the name of the input map is used"
-msgstr ""
-#: ../vector/v.label/main.c:78 ../vector/v.label.sa/main.c:57
-msgid "Name of attribute column to be used for labels"
-msgstr ""
-#: ../vector/v.label/main.c:89
-msgid "Rotate labels to align with lines"
-msgstr ""
-#: ../vector/v.label/main.c:94
-msgid "Curl labels along lines"
-msgstr ""
-#: ../vector/v.label/main.c:99
-msgid "Offset label in x-direction"
-msgstr ""
-#: ../vector/v.label/main.c:102 ../vector/v.label/main.c:109
-#: ../vector/v.label/main.c:118 ../vector/v.label/main.c:162
-msgid "Placement"
-msgstr ""
-#: ../vector/v.label/main.c:106
-msgid "Offset label in y-direction"
-msgstr ""
-#: ../vector/v.label/main.c:137
-msgid "Space between letters for curled labels (in map-units)"
-msgstr ""
-#: ../vector/v.label/main.c:144
-msgid "Label size (in points)"
-msgstr ""
-#: ../vector/v.label/main.c:166
-msgid "Border width"
-msgstr ""
-#: ../vector/v.label/main.c:180 ../vector/v.label.sa/main.c:117
-msgid "Width of highlight coloring"
-msgstr ""
-#: ../vector/v.label/main.c:200 ../vector/v.label.sa/main.c:135
-msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr ""
-#: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-#: ../vector/v.label/main.c:259
-msgid "Too many parameters for <reference>"
-msgstr ""
-#: ../vector/v.label/main.c:438
-#, c-format
-msgid "Labeled %d lines."
-msgstr ""
-#: ../vector/v.external/list.c:111
-msgid "GRASS is not compiled with PostgreSQL support"
-msgstr ""
-#: ../vector/v.external/list.c:117
-msgid "GRASS is not compiled with OGR support"
-msgstr ""
-#: ../vector/v.external/list.c:158
-msgid "Connection to PostgreSQL database failed."
-msgstr ""
-#: ../vector/v.external/list.c:168
-msgid "No feature tables found in database."
-msgstr ""
-#: ../vector/v.external/list.c:179
-#, c-format
-msgid "PostGIS database <%s> contains %d feature table:"
-msgid_plural "PostGIS database <%s> contains %d feature tables:"
-msgstr[0] ""
-#: ../vector/v.external/list.c:260
-#, c-format
-msgid "Unable to open data source '%s'"
-msgstr ""
-#: ../vector/v.external/list.c:267
-#, c-format
-msgid "Data source <%s> (format '%s') contains %d layer:"
-msgid_plural "Data source <%s> (format '%s') contains %d layers:"
-msgstr[0] ""
-#: ../vector/v.external/list.c:310
-#, c-format
-msgid ""
-"Unable to convert input map projection to GRASS format. Projection check "
-"cannot be provided for OGR layer <%s>"
-msgstr ""
-#: ../vector/v.external/list.c:326
-#, c-format
-msgid "Invalid geometry column %d"
-msgstr ""
-#: ../vector/v.external/args.c:14
-msgid "Name of input OGR or PostGIS data source"
-msgstr ""
-#: ../vector/v.external/args.c:27
-msgid "Name of OGR layer or PostGIS feature table to be linked"
-msgstr ""
-#: ../vector/v.external/args.c:28
-msgid ""
-"Examples:\n"
-"\t\tESRI Shapefile: shapefile name\n"
-"\t\tMapInfo File: mapinfo file name\n"
-"\t\tPostGIS database: table name"
-msgstr ""
-#: ../vector/v.external/args.c:40
-msgid "Name for output GRASS vector map (default: input layer)"
-msgstr ""
-#: ../vector/v.external/args.c:62
-msgid "List available layers in data source and exit"
-msgstr ""
-#: ../vector/v.external/args.c:68
-msgid "List available layers including feature type in data source and exit"
-msgstr ""
-#: ../vector/v.external/args.c:70
-msgid "Format: layer name,type,projection check,geometry"
-msgstr ""
-#: ../vector/v.external/main.c:59
-msgid ""
-"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
-"PostGIS feature table."
-msgstr ""
-#: ../vector/v.external/main.c:130
-msgid "No layer defined"
-msgstr ""
-#: ../vector/v.external/main.c:196
-#, c-format
-msgid "Unable to delete '%s'"
-msgstr ""
-#: ../vector/v.external/main.c:203
-#, c-format
-msgid "Unable to create file '%s/%s'"
-msgstr ""
-#: ../vector/v.external/main.c:237
-#, c-format
-msgid "Link to vector map <%s> created."
-msgstr ""
-#: ../vector/v.normal/main.c:76
-msgid "Tests for normality for vector points."
-msgstr ""
-#: ../vector/v.normal/main.c:88
-msgid "Lists of tests (1-15)"
-msgstr ""
-#: ../vector/v.normal/main.c:89
-msgid "E.g. 1,3-8,13"
-msgstr ""
-#: ../vector/v.normal/main.c:100
-msgid "Lognormality instead of normality"
-msgstr ""
-#: ../vector/v.normal/main.c:131
-msgid "Only numeric column type supported"
-msgstr ""
-#: ../vector/v.normal/main.c:174 ../vector/v.normal/main.c:182
-#, c-format
-msgid "No record for cat %d"
-msgstr ""
-#: ../vector/v.normal/main.c:192
-#, c-format
-msgid "Number of points: %d"
-msgstr ""
-#: ../vector/v.normal/main.c:198
-msgid "Too small sample"
-msgstr ""
-#: ../vector/v.normal/main.c:206
-msgid "Negative or very small point values set to -10.0"
-msgstr ""
-#: ../vector/v.normal/main.c:223
-#, c-format
-msgid "Moments \\sqrt{b_1} and b_2: "
-msgstr ""
-#: ../vector/v.normal/main.c:228
-#, c-format
-msgid "Geary's a-statistic & an approx. normal: "
-msgstr ""
-#: ../vector/v.normal/main.c:233
-#, c-format
-msgid "Extreme normal deviates: "
-msgstr ""
-#: ../vector/v.normal/main.c:238
-#, c-format
-msgid "D'Agostino's D & an approx. normal: "
-msgstr ""
-#: ../vector/v.normal/main.c:244
-#, c-format
-msgid "Kuiper's V (regular & modified for normality): "
-msgstr ""
-#: ../vector/v.normal/main.c:250
-#, c-format
-msgid "Watson's U^2 (regular & modified for normality): "
-msgstr ""
-#: ../vector/v.normal/main.c:256
-#, c-format
-msgid "Durbin's Exact Test (modified Kolmogorov): "
-msgstr ""
-#: ../vector/v.normal/main.c:262
-#, c-format
-msgid "Anderson-Darling's A^2 (regular & modified for normality): "
-msgstr ""
-#: ../vector/v.normal/main.c:268
-#, c-format
-msgid "Cramer-Von Mises W^2(regular & modified for normality): "
-msgstr ""
-#: ../vector/v.normal/main.c:274
-#, c-format
-msgid "Kolmogorov-Smirnov's D (regular & modified for normality): "
-msgstr ""
-#: ../vector/v.normal/main.c:280
-#, c-format
-msgid "Chi-Square stat (equal probability classes) and d.f.: "
-msgstr ""
-#: ../vector/v.normal/main.c:286
-msgid "Shapiro-Wilk's W cannot be used for n > 50"
-msgstr ""
-#: ../vector/v.normal/main.c:288
-msgid "Use Weisberg-Binghams's W''"
-msgstr ""
-#: ../vector/v.normal/main.c:291
-#, c-format
-msgid "Shapiro-Wilk W: "
-msgstr ""
-#: ../vector/v.normal/main.c:298
-msgid "Weisberg-Bingham's W'' cannot be used for n < 50 or n > 99"
-msgstr ""
-#: ../vector/v.normal/main.c:300
-#, c-format
-msgid "Weisberg-Bingham's W'': "
-msgstr ""
-#: ../vector/v.normal/main.c:307
-msgid "Royston only extended Shapiro-Wilk's W up to n = 2000"
-msgstr ""
-#: ../vector/v.normal/main.c:309
-#, c-format
-msgid "Shapiro-Wilk W'': "
-msgstr ""
-#: ../vector/v.normal/main.c:315
-#, c-format
-msgid "Kotz' T'_f (Lognormality vs. Normality): "
-msgstr ""
-#: ../vector/v.out.pov/main.c:49
-msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
-msgstr ""
-#: ../vector/v.out.pov/main.c:60
-msgid "Name for output POV file"
-msgstr ""
-#: ../vector/v.out.pov/main.c:67
-msgid "Radius of sphere for points and tube for lines"
-msgstr ""
-#: ../vector/v.out.pov/main.c:68
-msgid "May be also variable, e.g. grass_r."
-msgstr ""
-#: ../vector/v.out.pov/main.c:74
-msgid "Modifier for z coordinates"
-msgstr ""
-#: ../vector/v.out.pov/main.c:75
-msgid ""
-"This string is appended to each z coordinate. Examples: '*10', '+1000', "
-"'*10+100', '*exaggeration'"
-msgstr ""
-#: ../vector/v.out.pov/main.c:82
-msgid "Object modifier (OBJECT_MODIFIER in POV-Ray documentation)"
-msgstr ""
-#: ../vector/v.out.pov/main.c:83
-msgid "Example: \"pigment { color red 0 green 1 blue 0 }\""
-msgstr ""
-#: ../vector/v.out.pov/main.c:218
-#, c-format
-msgid "%d feature written."
-msgid_plural "%d features written."
-msgstr[0] ""
-#: ../vector/v.extrude/db.c:27
-#, c-format
-msgid "Unable to select attributes category %d"
-msgstr ""
-#: ../vector/v.extrude/main.c:72
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height."
-msgstr ""
-#: ../vector/v.extrude/main.c:74
-msgid ""
-"Optionally the height can be derived from sampling of elevation raster map."
-msgstr ""
-#: ../vector/v.extrude/main.c:78
-msgid "Trace elevation"
-msgstr ""
-#: ../vector/v.extrude/main.c:118
-msgid "Name of attribute column with feature height"
-msgstr ""
-#: ../vector/v.extrude/main.c:151
-#, c-format
-msgid "One of '%s' or '%s' parameters must be set"
-msgstr ""
-#: ../vector/v.extrude/main.c:202
-#, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
-"layer '1'."
-msgstr ""
-#: ../vector/v.extrude/main.c:234
-#, c-format
-msgid "Column <%s> does not exist"
-msgstr ""
-#: ../vector/v.extrude/main.c:243
-#, c-format
-msgid "Column <%s>: invalid data type"
-msgstr ""
-#: ../vector/v.extrude/main.c:265
-msgid "Extruding areas..."
-msgstr ""
-#: ../vector/v.extrude/main.c:287
-#, c-format
-msgid "No category defined for area %d. Using default fixed height %f."
-msgstr ""
-#: ../vector/v.extrude/main.c:293
-#, c-format
-msgid ""
-"Unable to fetch height from DB for area %d. Using default fixed height %f."
-msgstr ""
-#: ../vector/v.extrude/main.c:319
-msgid "Extruding features..."
-msgstr ""
-#: ../vector/v.extrude/main.c:340
-#, c-format
-msgid "No category defined for feature %d. Using default fixed height %f."
-msgstr ""
-#: ../vector/v.extrude/main.c:346
-#, c-format
-msgid ""
-"Unable to fetch height from DB for line %d. Using default fixed height %f."
-msgstr ""
-#: ../vector/v.extrude/main.c:364
-msgid "Copying attribute table..."
-msgstr ""
-#: ../vector/v.net.iso/main.c:79
-msgid "isolines"
-msgstr ""
-#: ../vector/v.net.iso/main.c:80
-msgid "Splits subnets for nearest centers by cost isolines."
-msgstr ""
-#: ../vector/v.net.iso/main.c:82
-msgid ""
-"Splits net to bands between cost isolines (direction from center). Center "
-"node must be opened (costs >= 0). Costs of center node are used in "
-"calculation."
-msgstr ""
-#: ../vector/v.net.iso/main.c:111
-msgid "Costs for isolines"
-msgstr ""
-#: ../vector/v.net.iso/main.c:179
-msgid "Default: one category for each iso-band"
-msgstr ""
-#: ../vector/v.net.iso/main.c:215
-#, c-format
-msgid "Wrong iso cost: %f"
-msgstr ""
-#: ../vector/v.net.iso/main.c:218
-#, c-format
-msgid "Iso cost: %f less than previous"
-msgstr ""
-#: ../vector/v.net.iso/main.c:223
-#, c-format
-msgid "Iso cost %d: %f"
-msgstr ""
-#: ../vector/v.net.iso/main.c:231
-msgid "Not enough costs, everything reachable falls to first band"
-msgstr ""
-#: ../vector/v.net.iso/main.c:403
-msgid "Generating isolines..."
-msgstr ""
-#: ../vector/v.surf.idw/main.c:92
-msgid ""
-"Provides surface interpolation from vector point data by Inverse Distance "
-"Squared Weighting."
-msgstr ""
-#: ../vector/v.surf.idw/main.c:101
-msgid "Name of attribute column with values to interpolate"
-msgstr ""
-#: ../vector/v.surf.idw/main.c:104
-msgid "Values"
-msgstr ""
-#: ../vector/v.surf.idw/main.c:121
-msgid "Power parameter"
-msgstr ""
-#: ../vector/v.surf.idw/main.c:123
-msgid "Greater values assign greater influence to closer points"
-msgstr ""
-#: ../vector/v.surf.idw/main.c:128
-msgid "Don't index points by raster cell"
-msgstr ""
-#: ../vector/v.surf.idw/main.c:129
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
-msgstr ""
-#: ../vector/v.surf.idw/main.c:139
-#, c-format
-msgid "Illegal number (%s) of interpolation points"
-msgstr ""
-#. GTC First argument is map name, second - message about number of rows,
-#. third - columns.
-#: ../vector/v.surf.idw/main.c:263
-#, c-format
-msgid "Interpolating raster map <%s> (%s, %s)..."
-msgstr ""
-#: ../vector/v.surf.idw/read_sites.c:37
-#, c-format
-msgid "Input vector map <%s> is 2D - using categories to interpolate"
-msgstr ""
-#: ../vector/v.surf.idw/read_sites.c:40
-#, c-format
-msgid "Input vector map <%s> is 3D - using z-coordinates to interpolate"
-msgstr ""
-#: ../vector/v.surf.idw/read_sites.c:70
-#, c-format
-msgid "One record selected from table"
-msgid_plural "%d records selected from table"
-msgstr[0] ""
-#: ../vector/v.surf.idw/read_sites.c:123
-#, c-format
-msgid "%ld point loaded"
-msgid_plural "%ld points loaded"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:63
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-#: ../vector/v.edit/main.c:72
-#, c-format
-msgid "Unable to get category list <%s>"
-msgstr ""
-#: ../vector/v.edit/main.c:119
-msgid "Supported feature types for non-native formats:"
-msgstr ""
-#: ../vector/v.edit/main.c:140
-#, c-format
-msgid ""
-"Unable to open vector map <%s> on topological level. Try to rebuild vector "
-"topology by v.build."
-msgstr ""
-#: ../vector/v.edit/main.c:160
-#, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
-msgstr ""
-#: ../vector/v.edit/main.c:171
-#, c-format
-msgid "Background vector map <%s> registered"
-msgstr ""
-#: ../vector/v.edit/main.c:208
-msgid "Threshold for snapping must be > 0. No snapping applied."
-msgstr ""
-#: ../vector/v.edit/main.c:215
-msgid "Selecting features..."
-msgstr ""
-#: ../vector/v.edit/main.c:227
-msgid "No features selected, nothing to edit"
-msgstr ""
-#: ../vector/v.edit/main.c:235
-#, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
-msgstr ""
-#: ../vector/v.edit/main.c:277
-#, c-format
-msgid "%d feature added"
-msgid_plural "%d features added"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:285 ../vector/v.edit/main.c:314
-#: ../vector/v.edit/main.c:325 ../vector/v.edit/main.c:357
-#: ../vector/v.edit/main.c:365 ../vector/v.edit/main.c:374
-#: ../vector/v.edit/main.c:383 ../vector/v.edit/main.c:430
-#, c-format
-msgid "Threshold value for snapping is %.2f"
-msgstr ""
-#: ../vector/v.edit/main.c:297
-#, c-format
-msgid "%d boundary closed"
-msgid_plural "%d boundaries closed"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:306
-#, c-format
-msgid "%d feature deleted"
-msgid_plural "%d features deleted"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:317
-#, c-format
-msgid "%d feature moved"
-msgid_plural "%d features moved"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:328
-#, c-format
-msgid "%d vertex moved"
-msgid_plural "%d vertices moved"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:334
-#, c-format
-msgid "%d vertex added"
-msgid_plural "%d vertices added"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:340
-#, c-format
-msgid "%d vertex removed"
-msgid_plural "%d vertices removed"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:352
-#, c-format
-msgid "%d line broken"
-msgid_plural "%d lines broken"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:360
-#, c-format
-msgid "%d line connected"
-msgid_plural "%d lines connected"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:369 ../vector/v.edit/main.c:378
-#: ../vector/v.edit/main.c:387
-#, c-format
-msgid "%d line extended"
-msgid_plural "%d lines extended"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:393
-#, c-format
-msgid "%d line merged"
-msgid_plural "%d lines merged"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:402 ../vector/v.edit/main.c:408
-#, c-format
-msgid "%d feature modified"
-msgid_plural "%d features modified"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:415
-#, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
-msgstr ""
-#: ../vector/v.edit/main.c:425
-#, c-format
-msgid "%d feature copied"
-msgid_plural "%d features copied"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:436
-#, c-format
-msgid "%d line flipped"
-msgid_plural "%d lines flipped"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:457
-#, c-format
-msgid "%d line labeled"
-msgid_plural "%d lines labeled"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:466
-#, c-format
-msgid "%d feature converted"
-msgid_plural "%d features converted"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:471
-msgid "No feature modified"
-msgstr ""
-#: ../vector/v.edit/main.c:478
-#, c-format
-msgid "Select feature %d is not centroid, ignoring..."
-msgstr ""
-#: ../vector/v.edit/main.c:485
-#, c-format
-msgid "%d area removed"
-msgid_plural "%d areas removed"
-msgstr[0] ""
-#: ../vector/v.edit/main.c:491
-msgid "Operation not implemented"
-msgstr ""
-#: ../vector/v.edit/args.c:20
-msgid "Name of vector map to edit"
-msgstr ""
-#: ../vector/v.edit/args.c:36
-msgid "Tool"
-msgstr ""
-#: ../vector/v.edit/args.c:61
-msgid "Create new (empty) vector map"
-msgstr ""
-#: ../vector/v.edit/args.c:62
-msgid "Add new features to existing vector map"
-msgstr ""
-#: ../vector/v.edit/args.c:63
-msgid "Delete selected features from vector map"
-msgstr ""
-#: ../vector/v.edit/args.c:64
-msgid "Move selected features in vector map"
-msgstr ""
-#: ../vector/v.edit/args.c:65
-msgid "Move vertex of selected vector lines"
-msgstr ""
-#: ../vector/v.edit/args.c:66
-msgid "Remove vertex from selected vector lines"
-msgstr ""
-#: ../vector/v.edit/args.c:67
-msgid "Add new vertex to selected vector lines"
-msgstr ""
-#: ../vector/v.edit/args.c:68
-msgid "Merge selected vector lines"
-msgstr ""
-#: ../vector/v.edit/args.c:69
-msgid "Break/split vector lines"
-msgstr ""
-#: ../vector/v.edit/args.c:70
-msgid "Select lines and print their ID's"
-msgstr ""
-#: ../vector/v.edit/args.c:71
-msgid "Set new categories to selected vector features for defined layer"
-msgstr ""
-#: ../vector/v.edit/args.c:73
-msgid "Delete categories from selected vector features for defined layer"
-msgstr ""
-#: ../vector/v.edit/args.c:75
-msgid "Copy selected features"
-msgstr ""
-#: ../vector/v.edit/args.c:76
-msgid "Snap vector features in given threshold"
-msgstr ""
-#: ../vector/v.edit/args.c:77
-msgid "Flip direction of selected vector lines"
-msgstr ""
-#: ../vector/v.edit/args.c:78
-msgid "Connect two lines"
-msgstr ""
-#: ../vector/v.edit/args.c:79
-msgid "Extend lines"
-msgstr ""
-#: ../vector/v.edit/args.c:80
-msgid "Extend start nodes"
-msgstr ""
-#: ../vector/v.edit/args.c:81
-msgid "Extend end nodes"
-msgstr ""
-#: ../vector/v.edit/args.c:82
-msgid "Z bulk-labeling (automated assignment of z coordinate to vector lines)"
-msgstr ""
-#: ../vector/v.edit/args.c:84
-msgid "Change feature type (point<->centroid, line<->boundary)"
-msgstr ""
-#: ../vector/v.edit/args.c:85
-msgid "Delete selected areas from vector map (based on selected centroids)"
-msgstr ""
-#: ../vector/v.edit/args.c:93
-msgid "Name of file containing data in GRASS ASCII vector format"
-msgstr ""
-#: ../vector/v.edit/args.c:105
-msgid "Difference in x,y,z direction for moving feature or vertex"
-msgstr ""
-#: ../vector/v.edit/args.c:112
-msgid "Threshold distance (coords,snap,query)"
-msgstr ""
-#: ../vector/v.edit/args.c:114
-msgid "'-1' for threshold based on the current resolution settings"
-msgstr ""
-#: ../vector/v.edit/args.c:130
-msgid "List of point coordinates"
-msgstr ""
-#: ../vector/v.edit/args.c:139
-msgid "Bounding box for selecting features"
-msgstr ""
-#: ../vector/v.edit/args.c:148
-msgid "Polygon for selecting features"
-msgstr ""
-#: ../vector/v.edit/args.c:158
-msgid "Query tool"
-msgstr ""
-#: ../vector/v.edit/args.c:160
-msgid ""
-"For 'shorter' use negative threshold value, positive value for 'longer'"
-msgstr ""
-#: ../vector/v.edit/args.c:166
-msgid "Select only lines or boundaries shorter/longer than threshold distance"
-msgstr ""
-#: ../vector/v.edit/args.c:168
-msgid "Select dangles shorter/longer than threshold distance"
-msgstr ""
-#: ../vector/v.edit/args.c:175
-msgid "Name of background vector map(s)"
-msgstr ""
-#: ../vector/v.edit/args.c:182
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
-msgstr ""
-#: ../vector/v.edit/args.c:188
-msgid "Not apply snapping"
-msgstr ""
-#: ../vector/v.edit/args.c:189
-msgid "Snap only to node"
-msgstr ""
-#: ../vector/v.edit/args.c:190
-msgid "Allow snapping also to vertex"
-msgstr ""
-#: ../vector/v.edit/args.c:198
-msgid "Starting value and step for z bulk-labeling"
-msgstr ""
-#: ../vector/v.edit/args.c:199
-msgid "Pair: value,step (e.g. 1100,10)"
-msgstr ""
-#: ../vector/v.edit/args.c:210
-msgid "Close added boundaries (using threshold distance)"
-msgstr ""
-#: ../vector/v.edit/args.c:214
-msgid "Do not expect header of input data"
-msgstr ""
-#: ../vector/v.edit/args.c:222
-msgid "Modify only first found feature in bounding box"
-msgstr ""
-#: ../vector/v.edit/args.c:227
-msgid "Connect parallel lines (using extend tools and threshold distance)"
-msgstr ""
-#: ../vector/v.edit/args.c:239
-msgid "Polygon must have at least 3 coordinate pairs"
-msgstr ""
-#: ../vector/v.edit/args.c:312
-#, c-format
-msgid "Operation '%s' not implemented"
-msgstr ""
-#: ../vector/v.edit/args.c:321
-#, c-format
-msgid "At least one option from %s must be specified"
-msgstr ""
-#: ../vector/v.edit/args.c:327 ../vector/v.edit/args.c:336
-#: ../vector/v.edit/args.c:343 ../vector/v.edit/args.c:350
-#: ../vector/v.edit/args.c:354
-#, c-format
-msgid "Tool %s requires option %s"
-msgstr ""
-#: ../vector/v.edit/close.c:56 ../vector/v.edit/snap.c:111
-#, c-format
-msgid "Unable to rewrite line %d"
-msgstr ""
-#: ../vector/v.edit/select.c:73
-#, c-format
-msgid "Threshold value for coordinates is %.2f"
-msgstr ""
-#: ../vector/v.edit/select.c:160
-#, c-format
-msgid "Threshold value for querying is %.2f"
-msgstr ""
-#: ../vector/v.edit/select.c:176
-#, c-format
-msgid "%d of %d feature selected from vector map <%s>"
-msgid_plural "%d of %d features selected from vector map <%s>"
-msgstr[0] ""
-#: ../vector/v.edit/select.c:496
-msgid "Layer must be > 0 for 'where'"
-msgstr ""
-#: ../vector/v.timestamp/main.c:39
-msgid "Modifies a timestamp for a vector map."
-msgstr ""
-#: ../vector/v.timestamp/main.c:40
-msgid "Print/add/remove a timestamp for a vector map."
-msgstr ""
-#: ../vector/v.timestamp/main.c:66
-#, c-format
-msgid "Vector map <%s> not found %s"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:70
-msgid "Converts file in DXF format to GRASS vector map."
-msgstr ""
-#: ../vector/v.in.dxf/main.c:74
-msgid "Ignore the map extent of DXF file"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:82
-msgid "Import polyface meshes as 3D wire frame"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:86
-msgid "List available DXF layers and exit"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:87 ../vector/v.in.dxf/main.c:94
-#: ../vector/v.in.dxf/main.c:99 ../vector/v.in.dxf/main.c:112
-msgid "DXF layers"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:93
-msgid "Invert selection by DXF layers (don't import layers in list)"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:98
-msgid "Import all objects into one layer"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:102
-msgid "Path to input DXF file"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:111
-msgid "List of DXF layers to import (default: all)"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:126
-msgid "Please specify list of DXF layers to exclude"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:130
-#, c-format
-msgid "Unable to open DXF file <%s>"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:133
-msgid "Layer number: layer name / GRASS compliant name"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:167
-msgid "Building topology failed"
-msgstr ""
-#: ../vector/v.in.dxf/main.c:173
-msgid "Failed to import DXF file!"
-msgstr ""
-#: ../vector/v.in.dxf/add_polyline.c:47
-msgid "vertices following flag missing"
-msgstr ""
-#: ../vector/v.in.dxf/layer_list.c:16
-#, c-format
-msgid "Layer %d: %s\n"
-msgstr ""
-#: ../vector/v.in.dxf/read_dxf.c:57
-msgid "end of file while looking for HEADER"
-msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:52
-msgid "Entity handle truncated to 16 characters."
-msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:91
-msgid "No DXF layers found!"
-msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:100
-msgid "Following DXF layers found:"
-msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:104
-#, c-format
-msgid "Layer %d: %s"
-msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:246
-#, c-format
-msgid "Unable to add database link for vector map <%s>"
-msgstr ""
-#: ../vector/v.category/main.c:79
-msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr ""
-#: ../vector/v.category/main.c:92
-msgid "Feature ids (by default all features are processed)"
-msgstr ""
-#: ../vector/v.category/main.c:104
-msgid "Action to be done"
-msgstr ""
-#: ../vector/v.category/main.c:115
-msgid "add a category to features without category in the given layer"
-msgstr ""
-#: ../vector/v.category/main.c:116
-msgid "delete category (cat=-1 to delete all categories of given layer)"
-msgstr ""
-#: ../vector/v.category/main.c:117
-msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
-msgstr ""
-#: ../vector/v.category/main.c:118
-msgid "add the value specified by cat option to the current category value"
-msgstr ""
-#: ../vector/v.category/main.c:119
-msgid ""
-"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
-"layer 1 to layer 2 and 3)"
-msgstr ""
-#: ../vector/v.category/main.c:120
-msgid "print report (statistics), in shell style: layer type count min max"
-msgstr ""
-#: ../vector/v.category/main.c:121
-msgid ""
-"print category values, layers are separated by '|', more cats in the same "
-"layer are separated by '/'"
-msgstr ""
-#: ../vector/v.category/main.c:122
-msgid "print only layer numbers"
-msgstr ""
-#: ../vector/v.category/main.c:134
-#: ../locale/scriptstrings/v.centroids_to_translate.c:7
-msgid "Category increment"
-msgstr ""
-#: ../vector/v.category/main.c:138
-msgid "Shell script style, currently only for report"
-msgstr ""
-#: ../vector/v.category/main.c:139
-msgid "Format: layer type count min max"
-msgstr ""
-#: ../vector/v.category/main.c:142
-msgid "Do not copy attribute table(s)"
-msgstr ""
-#: ../vector/v.category/main.c:160
-msgid ""
-"Database connection and attribute tables for concerned layers are not "
-"changed"
-msgstr ""
-#: ../vector/v.category/main.c:208
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
-msgstr ""
-#: ../vector/v.category/main.c:217
-#, c-format
-msgid "%d error in id option"
-msgid_plural "%d errors in id option"
-msgstr[0] ""
-#: ../vector/v.category/main.c:228
-msgid "Output vector wasn't entered"
-msgstr ""
-#: ../vector/v.category/main.c:275
-msgid "Too many layers for this operation"
-msgstr ""
-#: ../vector/v.category/main.c:278 ../vector/v.category/main.c:281
-msgid "2 layers must be specified"
-msgstr ""
-#: ../vector/v.category/main.c:289
-#, c-format
-msgid "Categories already exist in layer %d"
-msgstr ""
-#: ../vector/v.category/main.c:378
-#, c-format
-msgid "%d new centroid placed in output map"
-msgid_plural "%d new centroids placed in output map"
-msgstr[0] ""
-#: ../vector/v.category/main.c:672
-msgid "Layer/table"
-msgstr ""
-#: ../vector/v.category/main.c:676
-msgid "Layer"
-msgstr ""
-#: ../vector/v.category/main.c:678
-#, c-format
-msgid "type       count        min        max\n"
-msgstr ""
-#: ../vector/v.category/main.c:687
-msgid "boundary"
-msgstr ""
-#: ../vector/v.category/main.c:691
-#: ../locale/scriptstrings/v.centroids_to_translate.c:3
-msgid "centroid"
-msgstr ""
-#: ../vector/v.category/main.c:699
-msgid "face"
-msgstr ""
-#: ../vector/v.category/main.c:703
-msgid "kernel"
-msgstr ""
-#: ../vector/v.category/main.c:707
-msgid "all"
-msgstr ""
-#: ../vector/v.category/main.c:771
-#, c-format
-msgid "Categories copied from layer %d to layer %d"
-msgstr ""
-#: ../vector/v.category/main.c:775
-#, c-format
-msgid "%d feature modified."
-msgid_plural "%d features modified."
-msgstr[0] ""
-#: ../vector/v.proj/main.c:72
-msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-#: ../vector/v.proj/main.c:78
-msgid "Location containing input vector map"
-msgstr ""
-#: ../vector/v.proj/main.c:82
-msgid "Mapset containing input vector map"
-msgstr ""
-#: ../vector/v.proj/main.c:88
-msgid "Name of input vector map to re-project"
-msgstr ""
-#: ../vector/v.proj/main.c:100
-msgid "Maximum segment length in meters in output vector map"
-msgstr ""
-#: ../vector/v.proj/main.c:101
-msgid "Increases accuracy of reprojected shapes, disable with smax=0"
-msgstr ""
-#: ../vector/v.proj/main.c:106
-#: ../locale/scriptstrings/v.import_to_translate.c:9
-msgid "Name for output vector map (default: input)"
-msgstr ""
-#: ../vector/v.proj/main.c:111
-msgid "List vector maps in input mapset and exit"
-msgstr ""
-#: ../vector/v.proj/main.c:115
-msgid "3D vector maps only"
-msgstr ""
-#: ../vector/v.proj/main.c:117
-msgid "Assume z coordinate is ellipsoidal height and transform if possible"
-msgstr ""
-#: ../vector/v.proj/main.c:123
-msgid "Latlon output only, default is -180,180"
-msgstr ""
-#: ../vector/v.proj/main.c:125
-msgid "Disable wrapping to -180,180 for latlon output"
-msgstr ""
-#: ../vector/v.proj/main.c:131
-msgid "Recommended for massive point projection"
-msgstr ""
-#: ../vector/v.proj/main.c:200
-msgid "No vector maps found"
-msgstr ""
-#: ../vector/v.proj/main.c:213
-#, c-format
-msgid "Vector map <%s> in location <%s> mapset <%s> not found"
-msgstr ""
-#: ../vector/v.proj/main.c:243
-#, c-format
-msgid "Mapset <%s> in input location <%s> - permission denied"
-msgstr ""
-#: ../vector/v.proj/main.c:246
-#, c-format
-msgid "Mapset <%s> in input location <%s> not found"
-msgstr ""
-#: ../vector/v.proj/main.c:314
-#, c-format
-msgid "Input vector map <%s> is empty"
-msgstr ""
-#: ../vector/v.proj/main.c:322 ../vector/v.proj/main.c:333
-#: ../vector/v.proj/main.c:348 ../vector/v.proj/main.c:363
-msgid "Error in pj_do_transform"
-msgstr ""
-#: ../vector/v.proj/main.c:408
-msgid "Reprojecting primitives ..."
-msgstr ""
-#: ../vector/v.proj/main.c:445 ../vector/v.proj/main.c:452
-#: ../vector/v.proj/main.c:478 ../vector/v.proj/main.c:492
-#, c-format
-msgid "Unable to re-project vector map <%s> from <%s>"
-msgstr ""
-#: ../vector/v.proj/main.c:512
-msgid "Try to disable wrapping to -180,180 if topological errors occurred"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:129
-msgid "salesman"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:131
-msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-#: ../vector/v.net.salesman/main.c:133
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:142
-msgid ""
-"Categories of points ('cities') on nodes (layer is specified by nlayer)"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:162
-msgid "Node layer (used for cities)"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:176
-msgid "EXPERIMENTAL: Arc backward direction cost column (number)"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:203
-msgid "Name for output file holding node sequence (\"-\" for stdout)"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:286
-#, c-format
-msgid "Number of cities: %d"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:288
-msgid "Not enough cities (< 2)"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:328
-msgid "Creating cost cache..."
-msgstr ""
-#: ../vector/v.net.salesman/main.c:357 ../vector/v.net.salesman/main.c:371
-#, c-format
-msgid "No point at node %d"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:361 ../vector/v.net.salesman/main.c:375
-#, c-format
-msgid "No category for point at node %d"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:378
-#, c-format
-msgid "Destination node [cat %d] is unreachable from node [cat %d]"
-msgstr ""
-#: ../vector/v.net.salesman/main.c:421
-msgid "Searching for the shortest cycle..."
-msgstr ""
-#: ../vector/v.net.salesman/main.c:555
-#, c-format
-msgid "Cycle with total cost %.3f"
-msgstr ""
-#: ../vector/v.buffer/main.c:227
-msgid "grow"
-msgstr ""
-#: ../vector/v.buffer/main.c:228
-msgid "shrink"
-msgstr ""
-#: ../vector/v.buffer/main.c:230
-msgid "Creates a buffer around vector features of given type."
-msgstr ""
-#: ../vector/v.buffer/main.c:255
-msgid "Buffer distance along major axis in map units"
-msgstr ""
-#: ../vector/v.buffer/main.c:256 ../vector/v.buffer/main.c:264
-#: ../vector/v.buffer/main.c:272 ../vector/v.buffer/main.c:277
-#: ../vector/v.buffer/main.c:285 ../vector/v.buffer/main.c:293
-msgid "Distance"
-msgstr ""
-#: ../vector/v.buffer/main.c:263
-msgid "Buffer distance along minor axis in map units"
-msgstr ""
-#: ../vector/v.buffer/main.c:276
-msgid "Name of column to use for buffer distances"
-msgstr ""
-#: ../vector/v.buffer/main.c:284
-msgid "Scaling factor for attribute column values"
-msgstr ""
-#: ../vector/v.buffer/main.c:292
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of"
-" buffer (default 0.01)"
-msgstr ""
-#: ../vector/v.buffer/main.c:297
-msgid "Make outside corners straight"
-msgstr ""
-#: ../vector/v.buffer/main.c:301
-msgid "Do not make caps at the ends of polylines"
-msgstr ""
-#: ../vector/v.buffer/main.c:305
-msgid "Transfer categories and attributes"
-msgstr ""
-#: ../vector/v.buffer/main.c:325
-msgid ""
-"Note: In latitude-longitude coordinate system specify distances in degree "
-"unit"
-msgstr ""
-#: ../vector/v.buffer/main.c:329
-msgid "Select a buffer distance/minordistance/angle or column, but not both."
-msgstr ""
-#: ../vector/v.buffer/main.c:358
-msgid "The bufcol option requires a valid layer."
-msgstr ""
-#: ../vector/v.buffer/main.c:364
-msgid "The tolerance must be > 0."
-msgstr ""
-#: ../vector/v.buffer/main.c:368
-#, c-format
-msgid "The tolerance was reset to %g"
-msgstr ""
-#: ../vector/v.buffer/main.c:372
-msgid "Illegal scale value"
-msgstr ""
-#: ../vector/v.buffer/main.c:389
-#, c-format
-msgid "The tolerance in map units = %g"
-msgstr ""
-#: ../vector/v.buffer/main.c:393 ../vector/v.buffer/main.c:396
-#: ../vector/v.buffer/main.c:399
-#, c-format
-msgid "Option '%s' is not available with GEOS buffering"
-msgstr ""
-#: ../vector/v.buffer/main.c:442
-#, c-format
-msgid "Unable to select data from table <%s>"
-msgstr ""
-#: ../vector/v.buffer/main.c:478
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
-msgstr ""
-#: ../vector/v.buffer/main.c:495
-#, c-format
-msgid "Flags -%c/%c ignored by this version, GEOS >= 3.3 is required"
-msgstr ""
-#: ../vector/v.buffer/main.c:500
-msgid ""
-"Negative distances for internal buffers are not supported and converted to "
-"positive values."
-msgstr ""
-#: ../vector/v.buffer/main.c:510
-msgid "Buffering areas..."
-msgstr ""
-#: ../vector/v.buffer/main.c:546 ../vector/v.buffer/main.c:648
-#, c-format
-msgid "Attribute is of invalid size (%.3f) for category %d"
-msgstr ""
-#: ../vector/v.buffer/main.c:560 ../vector/v.buffer/main.c:666
-#, c-format
-msgid "The tolerance in map units: %g"
-msgstr ""
-#: ../vector/v.buffer/main.c:606
-msgid "Buffering features..."
-msgstr ""
-#: ../vector/v.buffer/main.c:609 ../vector/v.buffer/main.c:658
-msgid "Negative distances are only supported for areas"
-msgstr ""
-#: ../vector/v.buffer/main.c:732
-msgid "Cleaning buffers..."
-msgstr ""
-#: ../vector/v.buffer/main.c:735
-msgid "Building parts of topology..."
-msgstr ""
-#: ../vector/v.buffer/main.c:749
-msgid "Snapping boundaries..."
-msgstr ""
-#: ../vector/v.buffer/main.c:765
-msgid "Cleaning boundaries at nodes"
-msgstr ""
-#: ../vector/v.buffer/main.c:786
-msgid "Calculating centroids for all areas..."
-msgstr ""
-#: ../vector/v.buffer/main.c:817
-msgid "Generating list of boundaries to be deleted..."
-msgstr ""
-#: ../vector/v.buffer/main.c:850
-msgid "Deleting boundaries..."
-msgstr ""
-#: ../vector/v.buffer/main.c:882
-msgid "Calculating centroids for areas..."
-msgstr ""
-#: ../vector/v.buffer/main.c:895
-#, c-format
-msgid "Unable to calculate centroid for area %d"
-msgstr ""
-#: ../vector/v.buffer/geos.c:19 ../vector/v.profile/main.c:60
-msgid "Invalid GEOS geometry!"
-msgstr ""
-#: ../vector/v.buffer/geos.c:25 ../vector/v.profile/main.c:66
-msgid "No coordinates in GEOS geometry (can be ok for negative distance)!"
-msgstr ""
-#: ../vector/v.buffer/geos.c:33 ../vector/v.profile/main.c:74
-#, c-format
-msgid "Invalid x coordinate %f"
-msgstr ""
-#: ../vector/v.buffer/geos.c:35 ../vector/v.profile/main.c:76
-#, c-format
-msgid "Invalid y coordinate %f"
-msgstr ""
-#: ../vector/v.buffer/geos.c:107 ../vector/v.profile/main.c:93
-#: ../vector/v.profile/main.c:104
-msgid "Corrupt GEOS geometry"
-msgstr ""
-#: ../vector/v.buffer/geos.c:135
-msgid "Unknown GEOS geometry type"
-msgstr ""
-#: ../vector/v.buffer/geos.c:178
-#, c-format
-msgid "Buffering failed (feature %d)"
-msgstr ""
-#: ../vector/v.profile/main.c:156
-msgid "Vector map profiling tool"
-msgstr ""
-#: ../vector/v.profile/main.c:172
-msgid "Use features only from specified layer"
-msgstr ""
-#: ../vector/v.profile/main.c:183
-msgid "Path to output text file or - for stdout"
-msgstr ""
-#: ../vector/v.profile/main.c:195
-msgid "Number of significant digits"
-msgstr ""
-#: ../vector/v.profile/main.c:204
-msgid "Buffer (tolerance) for points in map units"
-msgstr ""
-#: ../vector/v.profile/main.c:205
-msgid "How far points can be from sampling line"
-msgstr ""
-#: ../vector/v.profile/main.c:215
-msgid "Name for profile line and buffer output map"
-msgstr ""
-#: ../vector/v.profile/main.c:217
-msgid "Profile line and buffer around it will be written"
-msgstr ""
-#: ../vector/v.profile/main.c:222
-msgid "Do not print column names"
-msgstr ""
-#: ../vector/v.profile/main.c:227
-msgid "Do not print 3D vector data (z values)"
-msgstr ""
-#: ../vector/v.profile/main.c:228
-msgid "Only affects 3D vectors"
-msgstr ""
-#: ../vector/v.profile/main.c:235
-msgid "Coordinates for profiling line nodes"
-msgstr ""
-#: ../vector/v.profile/main.c:236
-msgid "Specify profiling line vertexes and nodes"
-msgstr ""
-#: ../vector/v.profile/main.c:237 ../vector/v.profile/main.c:249
-#: ../vector/v.profile/main.c:260 ../vector/v.profile/main.c:268
-msgid "Profiling line"
-msgstr ""
-#: ../vector/v.profile/main.c:247
-msgid "Profiling line map"
-msgstr ""
-#: ../vector/v.profile/main.c:248
-msgid "Vector map containing profiling line"
-msgstr ""
-#: ../vector/v.profile/main.c:257
-msgid "WHERE conditions for input profile line map"
-msgstr ""
-#: ../vector/v.profile/main.c:259
-msgid "Use to select only one line from profiling line map"
-msgstr ""
-#: ../vector/v.profile/main.c:267
-msgid "Profiling line map layer"
-msgstr ""
-#: ../vector/v.profile/main.c:288
-msgid "Layer 0 not supported"
-msgstr ""
-#: ../vector/v.profile/main.c:293
-msgid "Failed to interpreter 'dp' parameter as an integer"
-msgstr ""
-#: ../vector/v.profile/main.c:299
-msgid "Tolerance value must be greater than 0"
-msgstr ""
-#: ../vector/v.profile/main.c:304
-#, c-format
-msgid "<%s> is not a valid vector map name"
-msgstr ""
-#: ../vector/v.profile/main.c:309
-msgid ""
-"No input profile map name provided, but WHERE conditions for it have been "
-"set"
-msgstr ""
-#: ../vector/v.profile/main.c:313
-msgid ""
-"Profile input coordinates and vector map are provided. Please provide only "
-"one of them"
-msgstr ""
-#: ../vector/v.profile/main.c:317
-msgid ""
-"No profile input coordinates nor vector map are provided. Please provide one"
-" of them"
-msgstr ""
-#: ../vector/v.profile/main.c:354
-msgid "At least profile start and end coordinates are required!"
-msgstr ""
-#: ../vector/v.profile/main.c:385 ../vector/v.profile/main.c:401
-#, c-format
-msgid ""
-"No database connection defined for map <%s> layer %d, but WHERE condition is"
-" provided"
-msgstr ""
-#: ../vector/v.profile/main.c:444 ../vector/v.profile/main.c:596
-msgid "No features match Your query"
-msgstr ""
-#: ../vector/v.profile/main.c:449 ../vector/v.profile/main.c:462
-msgid ""
-"Your query matches more than one record in input profiling map. Currently "
-"it's not supported. Enhance WHERE conditions to get only one line."
-msgstr ""
-#: ../vector/v.profile/main.c:455
-msgid "Error while initialising line list"
-msgstr ""
-#: ../vector/v.profile/main.c:467
-msgid "Error while reading vector feature from profile line map"
-msgstr ""
-#: ../vector/v.profile/main.c:481
-msgid ""
-"Your input profile map contains more than one line. Currently it's not "
-"supported. Provide WHERE conditions to get only one line."
-msgstr ""
-#: ../vector/v.profile/main.c:501
-msgid "Failed to convert GRASS line to GEOS line"
-msgstr ""
-#: ../vector/v.profile/main.c:509
-msgid "Buffering failed"
-msgstr ""
-#: ../vector/v.profile/main.c:556
-#, c-format
-msgid "Vector map <%s> does not have cat's defined on layer %d"
-msgstr ""
-#: ../vector/v.profile/main.c:683
-#, c-format
-msgid "Unabale to get attribute data for cat %d"
-msgstr ""
-#: ../vector/v.profile/main.c:692
-#, c-format
-msgid "Error while retreiving database record for cat %d"
-msgstr ""
-#: ../vector/v.profile/main.c:730
-msgid "Can not write data portion to provided output"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:68
-#, c-format
-msgid "Cannot allocate %lu bytes of memory"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:87
-msgid "Unable to initialise FreeType"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:90
-#, c-format
-msgid "Unable to find font '%s'\n"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:92
-#, c-format
-msgid "Font '%s' is not a FreeType font\n"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:96
-msgid "Font file format is not supported by FreeType"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:98
-msgid "Font file can not be loaded"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:107
-msgid "Unable to set font size"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:128
-msgid "Cannot allocate more memory"
-msgstr ""
-#: ../vector/v.label.sa/labels.c:244
-#, c-format
-msgid "Cannot load glyph for '%c'"
-msgstr ""
-#: ../vector/v.label.sa/main.c:41
-msgid "Create optimally placed labels for vector map(s)"
-msgstr ""
-#: ../vector/v.label.sa/main.c:71
-msgid "Name of TrueType font (as listed in the fontcap)"
-msgstr ""
-#: ../vector/v.label.sa/main.c:84
-msgid "Icon size of point features (in map-units)"
-msgstr ""
-#: ../vector/v.label.sa/main.c:154
-msgid "Border width (only for ps.map output)"
-msgstr ""
-#: ../vector/v.label.sa/font.c:54
-#, c-format
-msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-#: ../vector/v.label.sa/font.c:60
-#, c-format
-msgid "%s: No font definition file"
-msgstr ""
-#: ../raster3d/r3.support/check.c:20
-#, c-format
-msgid "Updating statistics for <%s>"
-msgstr ""
-#: ../raster3d/r3.support/check.c:36
-#, c-format
-msgid "Updating the number of categories for <%s>"
-msgstr ""
-#: ../raster3d/r3.support/main.c:52
-msgid ""
-"Allows creation and/or modification of 3D raster map layer support files."
-msgstr ""
-#: ../raster3d/r3.support/main.c:62
-msgid "Text to use for map title"
-msgstr ""
-#: ../raster3d/r3.support/main.c:76
-msgid "The map data unit"
-msgstr ""
-#: ../raster3d/r3.support/main.c:82
-msgid "The vertical unit of the map"
-msgstr ""
-#: ../raster3d/r3.support/main.c:125
-msgid "Update range"
-msgstr ""
-#: ../raster3d/r3.neighbors/main.c:137
-msgid ""
-"The size of the window in x, y and z direction, values must be odd integer "
-"numbers, eg: 3,3,3"
-msgstr ""
-#: ../raster3d/r3.neighbors/main.c:218
-msgid ""
-"Makes each voxel value a function of the values assigned to the voxels "
-"around it, and stores new voxel values in an output 3D raster map"
-msgstr ""
-#: ../raster3d/r3.neighbors/main.c:287
-msgid "Unable to allocate buffer"
-msgstr ""
-#: ../raster3d/r3.neighbors/main.c:311 ../raster3d/r3.in.bin/main.c:202
-msgid "Error flushing tiles"
-msgstr ""
-#: ../raster3d/r3.stats/main.c:52
-msgid "Generates volume statistics for 3D raster maps."
-msgstr ""
-#: ../raster3d/r3.stats/main.c:63
-msgid "Number of subranges to collect stats from"
-msgstr ""
-#: ../raster3d/r3.stats/main.c:68
-msgid "Calculate statistics based on equal value groups"
-msgstr ""
-#: ../raster3d/r3.stats/main.c:72
-msgid "Only print cell counts"
-msgstr ""
-#: ../raster3d/r3.stats/main.c:92
-msgid "The number of subranges has to be equal or greater than 1"
-msgstr ""
-#: ../raster3d/r3.stats/main.c:151
-msgid "Sort non-null values"
-msgstr ""
-#: ../raster3d/r3.gradient/main.c:44
-msgid "gradient"
-msgstr ""
-#: ../raster3d/r3.gradient/main.c:47
-msgid ""
-"Computes gradient of a 3D raster map and outputs gradient components as "
-"three 3D raster maps."
-msgstr ""
-#: ../raster3d/r3.gradient/main.c:56
-msgid "Name for output 3D raster map(s)"
-msgstr ""
-#: ../raster3d/r3.gradient/main.c:63
-msgid "Size of blocks"
-msgstr ""
-#: ../raster3d/r3.gradient/main.c:130
-msgid "Failed to allocate memory for blocks"
-msgstr ""
-#: ../raster3d/r3.gradient/main.c:292
-msgid "Writing gradient 3D raster maps..."
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:54
-msgid "Input 3D raster map with initial piezometric heads in [m]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:60
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:65
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:70
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:75
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:80
-msgid "Input 3D raster map with sources and sinks in [m^3/s]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:84
-msgid "Specific yield [1/m] input 3D raster map"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:89
-msgid "Recharge input 3D raster map in m^3/s"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:93
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:99
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:105
-msgid ""
-"y direction [m/s]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:111
-msgid ""
-"z direction [m/s]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:117
-msgid ""
-"Output 3D raster map storing the groundwater budget for each cell [m^3/s]"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:127
-msgid "Use 3D raster mask (if exists)"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:163
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:180
-msgid ""
-"The cholesky solver does not work with sparse matrices.\n"
-"Consider to choose a full filled quadratic matrix with flag -f "
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:365 ../raster3d/r3.in.lidar/main.c:484
-#: ../raster3d/r3.in.lidar/main.c:493 ../raster3d/r3.in.lidar/main.c:501
-#: ../raster3d/r3.in.lidar/main.c:509 ../raster3d/r3.in.lidar/main.c:517
-#: ../raster3d/r3.in.lidar/main.c:527 ../raster3d/r3.in.lidar/main.c:536
-#, c-format
-msgid "Unable to create 3D raster map <%s>"
-msgstr ""
-#: ../raster3d/r3.gwflow/main.c:412 ../raster3d/r3.out.vtk/main.c:252
-#: ../raster3d/r3.out.vtk/main.c:338 ../raster3d/r3.in.ascii/main.c:393
-#: ../raster3d/r3.cross.rast/main.c:55 ../raster3d/r3.in.bin/main.c:471
-#: ../raster3d/r3.out.netcdf/main.c:649 ../raster3d/r3.out.ascii/main.c:63
-#: ../raster3d/r3.out.ascii/main.c:367 ../raster3d/r3.in.v5d/main.c:206
-#: ../raster3d/r3.out.v5d/main.c:55 ../raster3d/r3.out.v5d/main.c:326
-#: ../raster3d/r3.to.rast/main.c:75 ../raster3d/r3.to.rast/main.c:445
-msgid "Unable to close 3D raster map"
-msgstr ""
-#: ../raster3d/r3.out.vtk/errorHandling.c:65
-#: ../raster3d/r3.cross.rast/main.c:343 ../raster3d/r3.info/main.c:499
-#: ../raster3d/r3.null/main.c:163
-#, c-format
-msgid "Unable to close 3D raster map <%s>"
-msgstr ""
-#: ../raster3d/r3.out.vtk/errorHandling.c:105
-msgid "Unable to close input raster maps"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:117
-msgid "Specify top and bottom map"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:124
-#, c-format
-msgid "Top cell map <%s> not found"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:133
-#, c-format
-msgid "Bottom cell map <%s> not found"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:152
-#, c-format
-msgid "3D raster map RGB map <%s> not found"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:155
-msgid "Please provide three RGB 3D raster maps"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:165
-#, c-format
-msgid "3D vector map <%s> not found"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:168
-msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:175
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:209
-msgid "No RGB Data will be created."
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:294
-msgid "No vector data will be created."
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:381
-msgid "Converts 3D raster maps into the VTK-ASCII format."
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:392
-msgid "failed to interpret dp as an integer"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:450 ../raster3d/r3.to.rast/main.c:332
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to"
-" adjust the 2D part of the 3D region."
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:541
-msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:556
-msgid "Unable to close VTK-ASCII file"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:30
-msgid "3D raster map(s) to be converted to VTK-ASCII data format"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:41
-msgid "Float value to represent no data cell/points"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:47
-msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:56
-msgid "Top surface 2D raster map"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:65
-msgid "Bottom surface 2D raster map"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3D elevation output with a top and a bottom surface, both raster maps"
-" are required."
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:80
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:88
-msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:112
-msgid "Use 3D raster mask (if exists) with input maps"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:117
-msgid "Scale factor affects the origin"
-msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:129
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:122
-msgid "write_vtk_points: Writing point coordinates"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:256
-msgid "write_vtk_unstructured_grid_cells: Writing the cells"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:335
-#, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:441
-msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:94
-msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:221
-#, c-format
-msgid "Unsupported GRASS version %s"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:265
-#, c-format
-msgid "Loading data ...  (%dx%dx%d)"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:298
-msgid "End of file reached while still loading data."
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:310
-#, c-format
-msgid "Invalid value detected (at col=%d row=%d depth=%d): %s"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:322
-#, c-format
-msgid ""
-"Data exists in input file after fully importing expected data.  [%.4f ...]"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:360
-msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:387 ../raster3d/r3.in.bin/main.c:463
-#: ../raster3d/r3.in.v5d/main.c:201
-msgid "Unable to open 3D raster map"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:403
-msgid "Unable to close ASCII file"
-msgstr ""
-#: ../raster3d/r3.out.bin/main.c:208
-msgid "Exports a GRASS 3D raster map to a binary array."
-msgstr ""
-#: ../raster3d/r3.out.bin/main.c:228 ../raster3d/r3.in.bin/main.c:268
-msgid "Number of bytes per cell in binary file"
-msgstr ""
-#: ../raster3d/r3.out.bin/main.c:240 ../raster3d/r3.in.bin/main.c:354
-#: ../raster3d/r3.out.ascii/main.c:106
-msgid "Switch the row order in output from north->south to south->north"
-msgstr ""
-#: ../raster3d/r3.out.bin/main.c:245 ../raster3d/r3.in.bin/main.c:359
-#: ../raster3d/r3.out.ascii/main.c:110
-msgid "Switch the depth order in output from bottom->top to top->bottom"
-msgstr ""
-#: ../raster3d/r3.out.bin/main.c:250
-msgid "Write data as integer"
-msgstr ""
-#: ../raster3d/r3.out.bin/main.c:269
-msgid "Floating-point output requires bytes=4 or bytes=8"
-msgstr ""
-#: ../raster3d/r3.out.bin/main.c:273
-msgid "Integer output doesn't support bytes=8 in this build"
-msgstr ""
-#: ../raster3d/r3.out.bin/main.c:328
-#, c-format
-msgid "top=%f"
-msgstr ""
-#: ../raster3d/r3.out.bin/main.c:329
-#, c-format
-msgid "bottom=%f"
-msgstr ""
-#: ../raster3d/r3.out.bin/main.c:332
-#, c-format
-msgid "depths=%d"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:90
-msgid "Input 3D raster map for cross section"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:97
-msgid "2D elevation map used to create the cross section map"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:104
-msgid "Resulting cross section 2D raster map"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:233
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation"
-" map"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:259
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:302
-msgid "Output map already exists. Will be overwritten!"
-msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:338
-msgid "Wrong 3D raster datatype! Cannot create raster map"
-msgstr ""
-#: ../raster3d/r3.info/main.c:80
-msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
-#: ../raster3d/r3.info/main.c:86
-msgid "Print raster3d information in shell style"
-msgstr ""
-#: ../raster3d/r3.info/main.c:90
-msgid "Print range in shell style only"
-msgstr ""
-#: ../raster3d/r3.info/main.c:103
-#, c-format
-msgid "3D Raster map <%s> not found"
-msgstr ""
-#: ../raster3d/r3.info/main.c:328 ../raster3d/r3.info/main.c:448
-#: ../raster3d/r3.mkdspf/main.c:171
-#, c-format
-msgid "Unable to read range of 3D raster map <%s>"
-msgstr ""
-#: ../raster3d/r3.info/main.c:492
-msgid "Error while reading history file"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:49
-msgid "Unable to close the 3D raster map"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:71
-msgid "Name of the retiled 3D raster map"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:99
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
-msgstr ""
-#: ../raster3d/r3.retile/main.c:135
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:148
-msgid "Error closing 3D raster map"
-msgstr ""
-#: ../raster3d/r3.timestamp/main.c:48
-msgid "Modifies a timestamp for a 3D raster map."
-msgstr ""
-#: ../raster3d/r3.timestamp/main.c:49
-msgid "Print/add/remove a timestamp for a 3D raster map."
-msgstr ""
-#: ../raster3d/r3.timestamp/main.c:58
-msgid "Datetime, datetime1/datetime2, or none"
-msgstr ""
-#: ../raster3d/r3.timestamp/main.c:91
-msgid "Timestamp format is invalid"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:73
-msgid "Error reading binary data"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:154
-#, c-format
-msgid "Loading %s data with %i  bytes ...  (%dx%dx%d)"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:256
-msgid "Imports a binary raster file into a GRASS 3D raster map."
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:259
-msgid "Name of binary 3D raster file to be imported"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:275
-msgid "Byte order in binary file"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:315
-msgid "Bottom limit of geographic region (outer edge)"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:322
-msgid "Top limit of geographic region (outer edge)"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:343
-msgid "Number of depths"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:365
-msgid "Binary data is of type integer"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:399
-#, c-format
-msgid "bytes=%d; must be 4 or 8 in case of floating point input"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:409
-msgid "Integer input doesn't support size=8 in this build"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:413
-msgid "bytes= must be 1, 2, 4 or 8"
-msgstr ""
-#: ../raster3d/r3.in.bin/main.c:446
-#, c-format
-msgid "File Size %lld ... Total Bytes %lld"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:91
-msgid "Please provide three 3D raster maps"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:98
-#, c-format
-msgid "Vector seed map <%s> not found"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:147
-msgid "init_flowaccum: error in Rast3d_put_float"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:183
-msgid "Computes 3D flow lines and 3D flow accumulation."
-msgstr ""
-#: ../raster3d/r3.flow/main.c:193
-msgid ""
-"Names of three 3D raster maps describing x, y, z components of vector field"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:200
-msgid ""
-"If no map is provided, flow lines are generated from each cell of the input "
-"3D raster"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:203
-msgid "Name of vector map with points from which flow lines are generated"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:210
-msgid "Name for vector map of flow lines"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:217
-msgid "Name for output flowaccumulation 3D raster"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:224
-msgid "Name for 3D raster sampled by flowlines"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:226
-msgid ""
-"Values of this 3D raster will be stored as attributes of flowlines segments"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:240
-msgid "elapsed time"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:241
-msgid "length in map units"
-msgstr ""
-msgid "length in cells (voxels)"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:243
-msgid "Unit of integration step"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:244
-msgid "Default unit is cell"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:245 ../raster3d/r3.flow/main.c:254
-#: ../raster3d/r3.flow/main.c:262 ../raster3d/r3.flow/main.c:272
-msgid "Integration"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:252
-msgid "Integration step in selected unit"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:253
-msgid "Default step is 0.25 cell"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:261
-msgid "Maximum number of steps"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:269
-msgid "Maximum error of integration"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:270
-msgid "Influences step, increase maximum error to allow bigger steps"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:280
-msgid "Number of cells between flow lines in x, y and z direction"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:289
-msgid "Compute flowlines upstream, downstream or in both direction."
-msgstr ""
-#: ../raster3d/r3.flow/main.c:294
-msgid "Create and fill attribute table"
-msgstr ""
-#: ../raster3d/r3.flow/main.c:349
-msgid "Please provide 3 integer values for skip option."
-msgstr ""
-#: ../raster3d/r3.flow/main.c:441
-msgid "Error during reading seed vector map"
-msgstr ""
-#: ../raster3d/r3.flow/test_main.c:44
-msgid "unit test"
-msgstr ""
-#: ../raster3d/r3.flow/test_main.c:45
-msgid "Testing flow lines."
-msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:81
-#, c-format
-msgid "Unable to close 3D raster map while catching error: %s"
-msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:97
-msgid "Name for netCDF output file"
-msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:106
-msgid "The value to be used for null values, default is the netCDF standard"
-msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:111
-msgid "Export projection information as wkt and proj4 parameter"
-msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:588
-msgid "netCDF"
-msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:590
-msgid "Export a 3D raster map as netCDF file."
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:170
-msgid ""
-"Creates a 3D raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:176
-msgid "LiDAR input file in LAS format (*.las or *.laz)"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:189
-msgid "Count of points per cell"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:195
-msgid "Sum of values of point intensities per cell"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:201
-msgid "Mean of point intensities per cell"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:209
-msgid "3D raster map of proportional point count"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:211
-msgid "Point count per 3D cell divided by point count per vertical column"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:213 ../raster3d/r3.in.lidar/main.c:223
-msgid "Proportional output"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:219
-msgid "3D raster map of proportional sum of values"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:221
-msgid "Sum of values per 3D cell divided by sum of values per vertical column"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:248
-msgid "Subtract raster values from the z coordinates"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:250
-msgid "The scale for z is applied beforehand, the filter afterwards"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:256
-msgid "Use base raster actual resolution instead of computational region"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:329
-#, c-format
-msgid "%s will not be taken into account during scan"
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:540
-msgid "Preparing the maps..."
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:656
-msgid "Computing proportional count map..."
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:661
-msgid "Computing proportional sum map..."
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:666
-msgid "Computing mean map..."
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:671
-msgid "Closing the maps..."
-msgstr ""
-#: ../raster3d/r3.in.lidar/main.c:714
-#, c-format
-msgid "%lu input points had intensity out of range"
-msgstr ""
-#: ../raster3d/r3.in.lidar/filters.c:27
-#, c-format
-msgid "Invalid range <%s> for option %s"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:75
-msgid "Unable to open 3D raster mask file"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:104
-msgid "makeMask: error flushing tiles in cube"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:109
-msgid "makeMask: error flushing all tiles"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:117
-msgid "Unable to close 3D raster mask file"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:119
-#, c-format
-msgid "Unable to close raster map <%s>"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:134
-#: ../locale/scriptstrings/r.mask_to_translate.c:3
-msgid "mask"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:137
-msgid "Establishes the current working 3D raster mask."
-msgstr ""
-#: ../raster3d/r3.mask/main.c:145
-msgid "3D raster map with reference values"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:153
-msgid "List of cell values to be masked out"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:159
-msgid "Cannot create mask file: RASTER3D_MASK already exists"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:82
-msgid "3D raster map to be converted to ASCII"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:86
-msgid "Name for ASCII output file"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:95
-msgid "Number of decimal places for floats"
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:114
-msgid "Print grass6 compatible format. Flags -d and -r are ignored."
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:308
-msgid "Converts a 3D raster map layer into a ASCII text file."
-msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:371
-msgid "Unable to close new ASCII file"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:83
-msgid ""
-"Creates a display file from an existing 3D raster map according to specified"
-" threshold levels."
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:91
-msgid "Name of an existing 3D raster map"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:96
-msgid "Name for output display file"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:103
-msgid "List of thresholds for isosurfaces"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:109
-msgid "Minimum isosurface level"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:115
-msgid "Maximum isosurface level"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:121
-msgid "Positive increment between isosurface levels"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:128
-msgid "Number of isosurface threshold levels"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:132
-msgid "Suppress progress report & min/max information"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:136
-msgid "Use flat shading rather than gradient"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:144
-#, c-format
-msgid "Region from getWindow: %d %d %d"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:156
-#, c-format
-msgid "Not able to find grid3 file for [%s]"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:200
-#, c-format
-msgid "Unable to open display file <%s>"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:221
-#, c-format
-msgid "Writing %s from %s..."
-msgstr ""
-#: ../raster3d/r3.in.v5d/main.c:66
-msgid "Name of V5D raster file to be imported"
-msgstr ""
-#: ../raster3d/r3.in.v5d/main.c:182
-msgid "Import 3-dimensional Vis5D files."
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:73
-msgid "3D raster map to be converted to Vis5D (V5D) file"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:77
-msgid "Name for V5D output file"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:147
-#, c-format
-msgid "Vis5D allows %d columns, %d columns found"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:150
-#, c-format
-msgid "Vis5D allows %d rows, %d rows found"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:257
-#, c-format
-msgid "Unable to create V5D file <%s>"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:262
-msgid "Failed writing V5D file"
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:288
-msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:295
-msgid "Use map coordinates instead of xyz coordinates"
-msgstr ""
-#: ../raster3d/r3.null/main.c:55
-msgid "3D raster map for which to modify null values"
-msgstr ""
-#: ../raster3d/r3.null/main.c:85
-msgid "Illegal value for null"
-msgstr ""
-#: ../raster3d/r3.null/main.c:122
-msgid "modifyNull: error opening tmp file"
-msgstr ""
-#: ../raster3d/r3.null/main.c:155
-msgid "modifyNull: error flushing all tiles"
-msgstr ""
-#: ../raster3d/r3.null/main.c:165
-msgid "modifyNull: Unable to close tmp file"
-msgstr ""
-#: ../raster3d/r3.null/main.c:184
-msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:100
-msgid "3D raster map(s) to be converted to 2D raster slices"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:106
-msgid "Basename for resultant raster slice maps"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:116
-msgid "Value to multiply the raster values with"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:117
-msgid "Coefficient a in the equation y = ax + b"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:123
-msgid "Value to add to the raster values"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:124
-msgid "Coefficient b in the equation y = ax + b"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:133
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:174
-#, c-format
-msgid "Unknown raster type <%d>"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:263
-msgid "Converts 3D raster maps to 2D raster maps"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:362
-#, c-format
-msgid "Creating %i raster maps"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:368
-#, c-format
-msgid "Raster map %i Filename: %s"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:373
-#, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr ""
-#: ../doc/raster/r.example/main.c:84 ../doc/vector/v.example/main.c:51
-msgid "keyword2"
-msgstr ""
-#: ../doc/raster/r.example/main.c:85 ../doc/vector/v.example/main.c:52
-msgid "keyword3"
-msgstr ""
-#: ../doc/raster/r.example/main.c:86
-msgid "My first raster module"
-msgstr ""
-#: ../doc/vector/v.example/main.c:53
-msgid "My first vector module"
-msgstr ""
-#: ../doc/vector/v.example/main.c:175
-#, c-format
-msgid "Unable to get attribute data for cat %d"
-msgstr ""
-#: ../doc/vector/v.example/main.c:184
-#, c-format
-msgid "Error while retrieving database record for cat %d"
-msgstr ""
-#: ../doc/vector/v.example/main.c:217
-#, c-format
-msgid "Unable to copy attribute table to vector map <%s>"
-msgstr ""
-#: ../ps/ps.map/catval.c:63
-msgid "Column type not supported (must be string)"
-msgstr ""
-#: ../ps/ps.map/catval.c:128
-msgid "Size column type must be numeric"
-msgstr ""
-#: ../ps/ps.map/catval.c:195
-msgid "Rotation column type must be numeric"
-msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:35 ../ps/ps.map/ps_fclrtbl.c:46
-#, c-format
-msgid "Creating color table for <%s in %s>..."
-msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:44 ../ps/ps.map/ps_fclrtbl.c:69
-msgid "Unable to read colors for colorbar"
-msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category"
-" help page. Colortable creation has been skipped."
-msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:69 ../ps/ps.map/ps_fclrtbl.c:97
-#: ../ps/ps.map/ps_fclrtbl.c:102
-msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:75 ../ps/ps.map/ps_fclrtbl.c:108
-#: ../ps/ps.map/ps_fclrtbl.c:113
-msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-#: ../ps/ps.map/eps.c:18
-#, c-format
-msgid "Can't open eps file <%s>"
-msgstr ""
-#: ../ps/ps.map/eps.c:37
-#, c-format
-msgid "Bounding box in eps file <%s> was not found"
-msgstr ""
-#: ../ps/ps.map/do_labels.c:44
-#, c-format
-msgid "Can't open label file <%s> in mapset <%s>"
-msgstr ""
-#: ../ps/ps.map/do_labels.c:48
-#, c-format
-msgid "Reading labels file <%s in %s> ..."
-msgstr ""
-#: ../ps/ps.map/do_labels.c:66
-#, c-format
-msgid "Can't open temporary label file <%s>"
-msgstr ""
-#: ../ps/ps.map/do_labels.c:69
-msgid "Reading text file ..."
-msgstr ""
-#: ../ps/ps.map/do_labels.c:162
-msgid "Text labels: 'fontsize' given so ignoring 'size'"
-msgstr ""
-#: ../ps/ps.map/do_masking.c:23
-msgid "Can't open temporary PostScript mask file."
-msgstr ""
-#: ../ps/ps.map/do_plt.c:38
-msgid "Reading point/line file ..."
-msgstr ""
-#: ../ps/ps.map/do_plt.c:169 ../ps/ps.map/ps_vpoints.c:87
-msgid "Cannot read symbol, using default icon"
-msgstr ""
-#: ../ps/ps.map/do_psfiles.c:20
-#, c-format
-msgid "Reading PostScript include file <%s> ..."
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:192
-msgid "meters"
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:194
-msgid "kilometers"
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:196
-msgid "feet"
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:198
-msgid "miles"
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:200
-msgid "nautical miles"
-msgstr ""
-#: ../ps/ps.map/do_vectors.c:33
-#, c-format
-msgid "Reading vector map <%s in %s> ..."
-msgstr ""
-#: ../ps/ps.map/do_vectors.c:136
-#, c-format
-msgid "Reading vector points file <%s in %s> ..."
-msgstr ""
-#: ../ps/ps.map/getgrid.c:61 ../ps/ps.map/getgrid.c:85
-#: ../ps/ps.map/getgrid.c:171 ../ps/ps.map/getgrid.c:195
-#: ../ps/ps.map/ps_outline.c:87 ../ps/ps.map/r_header.c:65
-#: ../ps/ps.map/r_info.c:67
-msgid "Unsupported color request"
-msgstr ""
-#: ../ps/ps.map/getgrid.c:63 ../ps/ps.map/getgrid.c:87
-#: ../ps/ps.map/getgrid.c:173 ../ps/ps.map/getgrid.c:197
-#: ../ps/ps.map/ps_outline.c:89 ../ps/ps.map/r_header.c:67
-#: ../ps/ps.map/r_info.c:69 ../ps/ps.map/r_instructions.c:149
-#: ../ps/ps.map/r_instructions.c:464
-msgid "illegal color request"
-msgstr ""
-#: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
-msgid "illegal numbers request"
-msgstr ""
-#: ../ps/ps.map/getgrid.c:126 ../ps/ps.map/getgrid.c:234
-msgid "illegal grid width request"
-msgstr ""
-#: ../ps/ps.map/getgrid.c:132
-msgid "illegal request (grid)"
-msgstr ""
-#: ../ps/ps.map/getgrid.c:240
-msgid "illegal request (geogrid)"
-msgstr ""
-#: ../ps/ps.map/main.c:93
-msgid "postscript"
-msgstr ""
-#: ../ps/ps.map/main.c:94
-msgid "printing"
-msgstr ""
-#: ../ps/ps.map/main.c:95
-msgid "Produces hardcopy PostScript map output."
-msgstr ""
-#: ../ps/ps.map/main.c:99
-msgid "Rotate plot 90 degrees"
-msgstr ""
-#: ../ps/ps.map/main.c:105
-msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr ""
-#: ../ps/ps.map/main.c:107 ../ps/ps.map/main.c:120
-msgid "Utility"
-msgstr ""
-#: ../ps/ps.map/main.c:112
-msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
-msgstr ""
-#: ../ps/ps.map/main.c:118
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
-msgstr ""
-#: ../ps/ps.map/main.c:123
-msgid "File containing mapping instructions"
-msgstr ""
-#: ../ps/ps.map/main.c:124
-msgid "Use '-' to enter instructions from keyboard)"
-msgstr ""
-#: ../ps/ps.map/main.c:127
-msgid "Name for PostScript output file"
-msgstr ""
-#: ../ps/ps.map/main.c:133
-msgid "Number of copies to print"
-msgstr ""
-#: ../ps/ps.map/main.c:205
-#, c-format
-msgid "Unable to open file '%s': %s"
-msgstr ""
-#: ../ps/ps.map/main.c:220 ../ps/ps.map/r_instructions.c:129
-msgid "illegal copies request"
-msgstr ""
-#: ../ps/ps.map/main.c:273
-#, c-format
-msgid "PostScript file '%s' successfully written."
-msgstr ""
-#: ../ps/ps.map/makeprocs.c:29
-#, c-format
-msgid "Unable to open prolog <%s>"
-msgstr ""
-#: ../ps/ps.map/map_setup.c:82
-#, c-format
-msgid "Scale set to %s"
-msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:51
-msgid "Range information not available (run r.support)"
-msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:64
-msgid "A floating point colortable must contain a range of values"
-msgstr ""
-#: ../ps/ps.map/ps_outline.c:43
-#, c-format
-msgid "Outlining areas in raster map <%s in %s> ..."
-msgstr ""
-#: ../ps/ps.map/ps_outline.c:100 ../ps/ps.map/r_colortable.c:73
-#: ../ps/ps.map/r_colortable.c:89
-msgid "illegal width request"
-msgstr ""
-#: ../ps/ps.map/ps_outline.c:107
-msgid "illegal outline sub-request"
-msgstr ""
-#: ../ps/ps.map/ps_raster.c:42
-msgid "Can't create temporary PostScript mask file."
-msgstr ""
-#: ../ps/ps.map/ps_raster.c:105
-#, c-format
-msgid "Reading raster maps in group <%s>..."
-msgstr ""
-#: ../ps/ps.map/ps_vareas.c:67 ../ps/ps.map/ps_vareas.c:78
-#: ../ps/ps.map/ps_vlines.c:84
-msgid "Read error in vector map"
-msgstr ""
-#: ../ps/ps.map/ps_vareas.c:102 ../ps/ps.map/ps_vlines.c:119
-#: ../ps/ps.map/ps_vpoints.c:160 ../ps/ps.map/ps_vpoints.c:171
-#: ../ps/ps.map/ps_vpoints.c:195 ../ps/ps.map/ps_vpoints.c:236
-#: ../ps/ps.map/ps_vpoints.c:246
-#, c-format
-msgid "No record for category [%d]"
-msgstr ""
-#: ../ps/ps.map/ps_vareas.c:108 ../ps/ps.map/ps_vlines.c:125
-#: ../ps/ps.map/ps_vpoints.c:201
-#, c-format
-msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr ""
-#: ../ps/ps.map/ps_vareas.c:161 ../ps/ps.map/ps_vlines.c:56
-#: ../ps/ps.map/ps_vpoints.c:71
-msgid "Cannot load data from table"
-msgstr ""
-#: ../ps/ps.map/ps_vpoints.c:177
-#, c-format
-msgid "Attribute is of invalid size [%.3f] for category [%d]"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:65 ../ps/ps.map/r_info.c:48
-#: ../ps/ps.map/r_vlegend.c:49
-msgid "illegal where request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:81
-msgid "illegal height request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:106
-msgid "illegal range request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:122
-msgid "illegal columns request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:141
-msgid "Unsupported color request (colortable)"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:143
-msgid "illegal color request (colortable)"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:170
-msgid "illegal colortable sub-request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:181
-msgid "No raster selected for colortable!"
-msgstr ""
-#: ../ps/ps.map/r_group.c:29
-msgid "Can't get group information"
-msgstr ""
-#: ../ps/ps.map/r_header.c:77
-msgid "illegal header sub-request"
-msgstr ""
-#: ../ps/ps.map/r_info.c:81
-msgid "illegal bgcolor request"
-msgstr ""
-#: ../ps/ps.map/r_info.c:93 ../ps/ps.map/r_vlegend.c:86
-msgid "illegal border color request"
-msgstr ""
-#: ../ps/ps.map/r_info.c:103
-msgid "illegal mapinfo sub-request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:62
-msgid "Data exist after final 'end' instruction!"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:80
-msgid "no file specified"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:84
-msgid "unable to open"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:115
-msgid "illegal maploc request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
-msgid "no raster map selected yet"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:160
-msgid "illegal value list"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:196
-msgid "scalebar is not appropriate for this projection"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:204
-msgid "Bad scalebar length"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:220
-msgid "illegal text request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:234
-msgid "illegal point request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:248
-msgid "illegal eps request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:265
-msgid "illegal line request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:282
-msgid "illegal rectangle request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:293
-msgid "illegal comments request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:309
-msgid "illegal scale request"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:369
-msgid "group not found"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:411
-msgid "illegal grid spacing"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:422
-msgid "geogrid is not available for this projection"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:432
-msgid "illegal geo-grid spacing"
-msgstr ""
-#: ../ps/ps.map/r_instructions.c:469
-msgid "illegal request"
-msgstr ""
-#: ../ps/ps.map/r_plt.c:173
-msgid "Can't open eps file"
-msgstr ""
-#: ../ps/ps.map/r_vlegend.c:97
-msgid "illegal vlegend sub-request"
-msgstr ""
-#: ../ps/ps.map/read_cfg.c:64
-#, c-format
-msgid "Paper '%s' not found, using defaults"
-msgstr ""
-#: ../ps/ps.map/scale.c:136
-msgid "PSmap: do_scale(): shouldn't happen"
-msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "Prints a graph of the correlation between raster maps (in pairs)."
-msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:5
-#: ../locale/scriptstrings/d.polar_to_translate.c:3
-msgid "diagram"
-msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:6
-msgid "correlation"
-msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:1
-msgid "Manages display frames on the user's graphics monitor."
-msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:5
-msgid "frame"
-msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:6
-msgid "Create a new frame if doesn't exist and select"
-msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:7
-msgid "Remove all frames, erase the screen and exit"
-msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:8
-msgid "Print name of current frame and exit"
-msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:9
-msgid "Print names of all frames including 'at' position and exit"
-msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:10
-msgid "Frame to be selected or created (if -c flag is given)"
-msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:11
-msgid ""
-"Screen coordinates in percent where to place the frame (0,0 is lower-left)"
-msgstr ""
-#: ../locale/scriptstrings/d.frame_to_translate.c:12
-msgid "Implies only when -c or --overwrite flag is given"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:1
-msgid "Saves the contents of the active display monitor to a graphics file."
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:5
-#: ../misc/m.nviz.image/args.c:105
-msgid "Graphics file format"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:6
-msgid "Width and height of output image"
-msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:7
-msgid "Images"
-msgstr ""
-#: ../locale/scriptstrings/d.to.rast_to_translate.c:1
-msgid "Saves the contents of the active display monitor to a raster map."
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:1
-msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:4
-msgid "Name of raster angle map"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:5
-msgid "Pixel value to be interpreted as undefined (different from NULL)"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:6
-msgid "Name for optional EPS output file"
-msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:7
-msgid "Plot using Xgraph"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
-msgid "Edits cell values in a raster map."
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
-msgid "Width of display canvas"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-msgid "Height of display canvas"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
-msgid "Minimum size of each cell"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
-msgid "Maximum number of rows to load"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
-msgid "Maximum number of columns to load"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
-msgid "Displays a raster map and its legend on a graphics window"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
-msgid "Omit entries with missing label"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
-msgid "Name of raster map to display"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
-msgid "Number of lines to appear in the legend"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:10
-msgid "Name of input raster map to generate legend from"
-msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:1
-msgid "Redraws the content of currently selected monitor."
-msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:1
-#: ../locale/scriptstrings/r.shade_to_translate.c:1
-msgid "Drapes a color raster over an shaded relief or aspect map."
-msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:7
-#: ../locale/scriptstrings/r.shade_to_translate.c:7
-msgid "Name of shaded relief or aspect raster map"
-msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:8
-#: ../locale/scriptstrings/r.shade_to_translate.c:8
-msgid "Name of raster to drape over relief raster map"
-msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:9
-#: ../locale/scriptstrings/r.shade_to_translate.c:9
-msgid "Typically, this raster is elevation or other colorful raster"
-msgstr ""
-#: ../locale/scriptstrings/d.shade_to_translate.c:10
-#: ../locale/scriptstrings/r.shade_to_translate.c:11
-msgid "Percent to brighten"
-msgstr ""
-#: ../locale/scriptstrings/d.what.rast_to_translate.c:1
-msgid ""
-"Allows the user to interactively query raster map layers at user-selected "
-"locations."
-msgstr ""
-#: ../locale/scriptstrings/d.what.vect_to_translate.c:1
-msgid ""
-"Allows the user to interactively query vector map layers at user-selected "
-"locations."
-msgstr ""
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
-msgid "Drops a column from selected attribute table."
-msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:1
-msgid "Drops an attribute table."
-msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:5
-msgid "Name of database driver"
-msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:6
-msgid "If not given then default driver is used"
-msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:8
-msgid "Name of database"
-msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:9
-msgid "If not given then default database is used"
-msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:11
-msgid "Name of table to drop"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
-msgid "Imports attribute tables in various formats."
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
-msgid "Table file to be imported or DB connection string"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
-msgid "Name of table from given DB to be imported"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
-msgid "Name for output table"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:9
-msgid "Name for auto-generated unique key column"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:12
-msgid "Overrides encoding interpretation, useful when importing DBF tables"
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
-msgid "Exports attribute tables into various formats."
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-msgid "GRASS table name"
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-msgid "Output table file name or DB connection string"
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:7
-msgid "Table format"
-msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:8
-msgid "Name for output table (default: input name)"
-msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:1
-msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:4
-msgid "Test name"
-msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:1
-msgid "Calculates univariate statistics on selected table column."
-msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:5
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:7
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-msgid "Extended statistics (quartiles and 90th percentile)"
-msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:8
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
-msgid "Print stats in shell script style"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:1
-msgid "Maintains GRASS Addons extensions in local GRASS installation."
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads and installs extensions from GRASS Addons repository or other "
-"source into the local GRASS installation or removes installed extensions."
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:4
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:4
-msgid "installation"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:5
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:5
-msgid "extensions"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:6
-msgid "addons"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:7
-msgid "download"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:8
-msgid "Name of extension to install or remove"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:9
-msgid "Name of toolbox (set of extensions) when -t flag is given"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:11
-msgid ""
-"URL or directory to get the extension from (supported only on Linux and Mac)"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:12
-msgid ""
-"The official repository is used by default. User can specify a ZIP file, "
-"directory or a repository on common hosting services. If not identified, "
-"Subversion repository is assumed. See manual for all options."
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:13
-msgid "Prefix where to install extension (ignored when flag -s is given)"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:14
-msgid "Set the proxy with: \"http=<value>,ftp=<value>\""
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:15
-msgid "List available extensions in the official GRASS GIS Addons repository"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:17
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository "
-"including module description"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:19
-msgid ""
-"List available extensions in the official GRASS GIS Addons repository (shell"
-" script style)"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:21
-msgid "List locally installed extensions"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:23
-msgid "Install system-wide (may need system administrator rights)"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:24
-#: ../locale/scriptstrings/g.extension_to_translate.c:26
-#: ../locale/scriptstrings/g.extension_to_translate.c:28
-msgid "Install"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:25
-msgid "Download source code and exit"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:27
-msgid "Do not install new extension, just compile it"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:29
-msgid "Force removal when uninstalling extension (operation=remove)"
-msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:31
-msgid "Operate on toolboxes instead of single modules (experimental)"
-msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:1
-msgid "Rebuilds or removes all locally installed GRASS Addons extensions."
-msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:2
-msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
-msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:7
-msgid "Force operation (required for removal)"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:1
-msgid "Displays the manual pages of GRASS modules."
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:3
-msgid "manual"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:4
-msgid "help"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:5
-msgid "Display index"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:6
-msgid "Display topics"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:7
-msgid "Display as MAN text page instead of HTML page in browser"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:8
-msgid "Display online manuals instead of locally installed"
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:9
-msgid ""
-"Use online manuals available at http://grass.osgeo.org website. This flag "
-"has no effect when displaying MAN text pages."
-msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:10
-msgid "Manual entry to be displayed"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:1
-msgid "Search in GRASS modules using keywords"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:3
-msgid "modules"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:5
-msgid "Keyword to be searched"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:6
-msgid ""
-"Display only modules where all keywords are available (AND), default: OR"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:8
-msgid "Invert selection (logical NOT)"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:10
-msgid "Search in manual pages too (can be slow)"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:12
-msgid "Search only for the exact keyword in module keyword list"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:13
-msgid "Instead of full text search, search only in actual keywords"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:15
-msgid "Use colorized (more readable) output to terminal"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:17
-msgid "Shell script format"
-msgstr ""
-#: ../locale/scriptstrings/g.search.modules_to_translate.c:19
-msgid "JSON format"
-msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:1
-msgid "Performs auto-balancing of colors for RGB images."
-msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:3
-#: ../locale/scriptstrings/r.rgb_to_translate.c:3
-msgid "RGB"
-msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:6
-msgid "Name of red channel"
-msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:7
-msgid "Name of green channel"
-msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:8
-msgid "Name of blue channel"
-msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:9
-msgid "Cropping intensity (upper brightness level)"
-msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:10
-msgid "Extend colors to full range of data on each channel"
-msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:12
-msgid "Preserve relative colors, adjust brightness only"
-msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:14
-msgid "Reset to standard color range"
-msgstr ""
-#: ../locale/scriptstrings/i.colors.enhance_to_translate.c:16
-#: ../locale/scriptstrings/i.oif_to_translate.c:7
-msgid "Process bands serially (default: run in parallel)"
-msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
-msgid "Mosaics several images and extends colormap."
-msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
-msgid "Imports SPOT VGT NDVI data into a raster map."
-msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
-msgid "SPOT"
-msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:6
-msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:7
-msgid "Name of input SPOT VGT NDVI HDF file"
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:1
-msgid "Calculates Optimum-Index-Factor table for spectral bands"
-msgstr ""
-#: ../locale/scriptstrings/i.oif_to_translate.c:3
-#: ../locale/scriptstrings/i.spectral_to_translate.c:5
-msgid "multispectral"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
-msgid "fusion"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:4
-msgid "sharpen"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:5
-msgid "Brovey"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:6
-msgid "IHS"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:7
-msgid "HIS"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:9
-msgid "Name of raster map to be used for <red>"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:10
-msgid "Name of raster map to be used for <green>"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:11
-msgid "Name of raster map to be used for <blue>"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:12
-msgid "Name of raster map to be used for high resolution panchromatic channel"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:13
-msgid "Method for pan sharpening"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
-msgid "Serial processing rather than parallel processing"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:15
-msgid "Rebalance blue channel for LANDSAT"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:9
-msgid "Name for output image (or text file for -t)"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:11
-msgid "Graphics format for output file"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:13
-msgid "Show sampling coordinates instead of numbering in the legend"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:14
-msgid "Use gnuplot for display"
-msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:15
-msgid "output to text file"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
-msgid "Performs Tasseled Cap (Kauth Thomas) transformation."
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
-msgid "Tasseled Cap transformation"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid ""
-"For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, "
-"7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
-msgid "Satellite sensor"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
-msgid ""
-"landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use "
-"transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules "
-"for Landsat 7 ETM;landsat8_oli;Use transformation rules for Landsat 8 "
-"OLI;modis;Use transformation rules for MODIS"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:1
-msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-#: ../misc/m.nviz.script/main.c:69 ../misc/m.cogo/main.c:225
-#: ../misc/m.nviz.image/main.c:50 ../misc/m.transform/main.c:316
-#: ../misc/m.measure/main.c:46
-msgid "miscellaneous"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:5
-msgid "Input coordinates to reproject"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
-msgid "Input coordinates"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
-msgid "Name of input coordinate file"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
-msgid "Name for output coordinate file (omit to send to stdout)"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
-msgid "Field separator (format: input[,output])"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
-msgid "Input projection parameters (PROJ.4 style)"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:15
-#: ../locale/scriptstrings/m.proj_to_translate.c:17
-#: ../locale/scriptstrings/m.proj_to_translate.c:19
-#: ../locale/scriptstrings/m.proj_to_translate.c:21
-msgid "Projections"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:16
-msgid "Output projection parameters (PROJ.4 style)"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:18
-msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:20
-msgid "Use current location as input and LL WGS84 as output projection"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:22
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:24
-msgid "Include input coordinates in output file"
-msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:26
-msgid "Include column names in output file"
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:1
-msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:4
-msgid "Name of first raster map for blending"
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:5
-msgid "Name of second raster map for blending"
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:6
-msgid "Basename for red, green and blue output raster maps"
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:7
-msgid "Percentage weight of first map for color blending"
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:8
-msgid "Combine resulting R,G,B layers into single output map"
-msgstr ""
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
-msgid "This is the low-memory alternative to the classic r.buffer module."
-msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Sets color rules based on stddev from a raster map's mean value."
-msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
-msgid "Color using standard deviation bands"
-msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
-msgid "Force center at zero"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:9
-msgid "Spline tension parameter"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:10
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:12
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:14
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:16
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:18
-msgid "RST options"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:11
-msgid "Spline smoothing parameter"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:13
-msgid "Width of hole edge used for interpolation (in cells)"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:20
-msgid "Used in bilinear and bicubic spline interpolation"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:21
-msgid "Spline options"
-msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:1
-msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:5
-msgid "Radius is in map units rather than cells"
-msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:6
-msgid "Radius of buffer in raster cells"
-msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:8
-msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
-msgstr ""
-#: ../locale/scriptstrings/r.grow_to_translate.c:9
-msgid "Value to write for \"grown\" cells"
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:1
-msgid ""
-"Imports raster data into a GRASS raster map using GDAL library and "
-"reprojects on the fly."
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:5
-msgid "Name of GDAL dataset to be imported"
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:7
-msgid "Input band(s) to select (default is all bands)"
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:13
-msgid "Resampling method to use for reprojection"
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:14
-msgid ""
-"nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic "
-"interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with "
-"fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos "
-"filter with fallback"
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:16
-msgid "Output raster map extent"
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:17
-msgid "region;extent of current region;input;extent of input map"
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:19
-msgid "Resolution of output raster map (default: estimated)"
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:20
-msgid ""
-"estimated;estimated resolution;value;user-specified "
-"resolution;region;current region resolution"
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:22
-msgid "Resolution of output raster map (use with option resolution=value)"
-msgstr ""
-#: ../locale/scriptstrings/r.import_to_translate.c:26
-msgid "Estimate resolution only"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
-msgid "Name of input ASTER image"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
-msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:9
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:10
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
-msgid "Imports SRTM HGT files into raster map."
-msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-msgid "SRTM"
-msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
-msgid "Name of SRTM input tile (file without .hgt.zip extension)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
-msgid "Name for output raster map (default: input tile)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:7
-msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
-msgid "Downloads and imports data from WMS/WMTS/NASA OnEarth server."
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
-msgid "OGC web services"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
-msgid "Typically starts with \"http://\""
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
-msgid "Layer(s) to request from the map server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
-msgid "Layer style(s) to request from the map server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
-msgid "Map style"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
-msgid "Image format requested from the server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
-msgid "Request"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
-msgid "EPSG code of requested source projection"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
-msgid "Driver used to communication with server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid ""
-"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
-"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
-"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
-msgid "WMS standard version"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
-msgid "Maximum columns to request at a time"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
-msgid "Maximum rows to request at a time"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
-msgid "Additional query parameters to pass to the server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
-msgid "Username for server connection"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
-msgid "Password for server connection"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
-msgid "Interpolation method to use in reprojection"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid ""
-"Request data for this named region instead of the current region bounds"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
-msgid "Format: 0xRRGGBB"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-msgid ""
-"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
-"OnEarth_GRASS drivers"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
-msgid "File where the server capabilities will be saved ('c' flag)"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
-msgid "Get the server capabilities then exit"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
-msgid "Do not request transparent data"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:1
-msgid "Calculates a new raster map from a simple r.mapcalc expression."
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:4
-msgid "simple"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:5
-msgid "Formula (e.g. A-B or A*C+B)"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:6
-msgid "Name of input A raster map"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:8
-msgid "Name of input B raster map"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:10
-msgid "Name of input C raster map"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:12
-msgid "Name of input D raster map"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:14
-msgid "Name of input E raster map"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:16
-msgid "Name of input F raster map"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:19
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:21
-msgid "Random"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:22
-msgid "Quote the map names"
-msgstr ""
-#: ../locale/scriptstrings/r.mapcalc.simple_to_translate.c:24
-msgid "Case sensitive variable names"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:1
-msgid "Creates a MASK for limiting raster operation."
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:4
-msgid "Name of raster map to use as mask"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:8
-msgid "Raster"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
-msgid "Raster values to use for mask"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-msgid "Format: 1 2 3 thru 7 *"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
-msgid "Name of vector map to use as mask"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:10
-#: ../locale/scriptstrings/r.mask_to_translate.c:12
-#: ../locale/scriptstrings/r.mask_to_translate.c:14
-#: ../locale/scriptstrings/r.mask_to_translate.c:16
-msgid "Vector"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:11
-msgid "Layer number or name (vector)"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:13
-msgid "Category values (vector)"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:15
-msgid "WHERE conditions of SQL statement without 'where' keyword (vector)"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:17
-msgid "Create inverse mask"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:19
-msgid "Remove existing mask (overrides other options)"
-msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-msgid "ASCII"
-msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:7
-msgid "Include no data values"
-msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:1
-msgid "Exports a raster map as GRASS GIS specific archive file"
-msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:4
-#: ../locale/scriptstrings/r.unpack_to_translate.c:4
-#: ../locale/scriptstrings/v.pack_to_translate.c:4
-#: ../locale/scriptstrings/v.unpack_to_translate.c:4
-msgid "copying"
-msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:5
-msgid "Name of raster map to pack up"
-msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:6
-#: ../locale/scriptstrings/v.pack_to_translate.c:6
-msgid "Name for output file (default is <input>.pack)"
-msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:7
-#: ../locale/scriptstrings/v.pack_to_translate.c:7
-msgid "Switch the compression off"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:4
-msgid "Dip of plane in degrees"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:5
-msgid "Azimuth of the plane in degrees"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:6
-msgid "Easting coordinate of a point on the plane"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:7
-msgid "Northing coordinate of a point on the plane"
-msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:8
-msgid "Elevation coordinate of a point on the plane"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
-msgid "Value option that sets the area size limit (in hectares)"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:10
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:8
-msgid "Area"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
-msgid "Lesser or greater than specified value"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:9
-msgid "Method used for reclassification"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:11
-msgid "Input map is clumped"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:12
-msgid "Clumps including diagonal neighbors"
-msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:1
-msgid "Splits a raster map into red, green and blue maps."
-msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:4
-msgid "separate"
-msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:5
-msgid "split"
-msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:6
-msgid "Red channel raster map name"
-msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:7
-msgid "Green channel raster map name"
-msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:8
-msgid "Blue channel raster map name"
-msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:10
-msgid "Name of shaded raster map"
-msgstr ""
-#: ../locale/scriptstrings/r.shade_to_translate.c:13
-msgid "Either a standard color name, R:G:B triplet, or \"none\""
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:4
-msgid "Produces shell script output"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid "Produces web map server query string output"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:7
-msgid "Source projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:8
-#: ../locale/scriptstrings/r.tileset_to_translate.c:10
-msgid "Conversion factor from units to meters in source projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:9
-msgid "Destination projection, defaults to this location's projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:11
-msgid "Maximum number of columns for a tile in the source projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:12
-msgid "Maximum number of rows for a tile in the source projection"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:13
-msgid "Number of cells tiles should overlap in each direction"
-msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:14
-msgid "Output field separator"
-msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:1
-msgid ""
-"Imports a GRASS GIS specific raster archive file (packed with r.pack) as a "
-"raster map"
-msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:5
-#: ../locale/scriptstrings/v.unpack_to_translate.c:5
-msgid "Name of input pack file"
-msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:6
-msgid "Name for output raster map (default: taken from input file internals)"
-msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:11
-#: ../locale/scriptstrings/v.unpack_to_translate.c:12
-msgid "Print projection information of input pack file and exit"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:1
-msgid ""
-"Create a 3D raster map from an assemblage of many coordinates using "
-"univariate statistics"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
-msgid "ASCII file containing input data"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:17
-msgid "Storage type for resultant raster map"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:23
-msgid "Column number of z coordinates in input file"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
-msgid "If not given or set to 0, the data points' z-values are used"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
-msgid "Filter range for value column data (min,max)"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
-msgid "Scaling factor to apply to value column data"
-msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:35
-msgid "Number of parallel processes to launch"
-msgstr ""
-#: ../locale/scriptstrings/v.build.all_to_translate.c:1
-msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:1
-msgid "Adds missing centroids to closed boundaries."
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:5
-msgid "Action to be taken"
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:6
-msgid "Category number starting value"
-msgstr ""
-#: ../locale/scriptstrings/v.clip_to_translate.c:1
-msgid "Extracts features of input map which overlay features of clip map."
-msgstr ""
-#: ../locale/scriptstrings/v.clip_to_translate.c:5
-msgid "Name of vector map to be clipped"
-msgstr ""
-#: ../locale/scriptstrings/v.clip_to_translate.c:6
-msgid "Name of clip vector map"
-msgstr ""
-#: ../locale/scriptstrings/v.clip_to_translate.c:7
-msgid "Do not dissolve clip map"
-msgstr ""
-#: ../locale/scriptstrings/v.clip_to_translate.c:8
-msgid "Clip by region"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
-msgid "Layer number where to add column(s)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
-msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: 'label varchar(250), value integer'"
-msgstr ""
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
-msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:9
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:12
-msgid "Definition"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
-msgid "Layer number where to add new attribute table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:1
-msgid "Joins a database table to a vector map table."
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:5
-msgid "Vector map to which to join other table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:6
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
-msgid "layer,column"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:7
-msgid "Layer where to join"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:8
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
-msgid "column"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:9
-msgid "Identifier column (e.g.: cat) in the vector table to be used for join"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:10
-msgid "Other table name"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:11
-msgid "ocolumn,scolumns"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:12
-msgid "Identifier column (e.g.: id) in the other table used for join"
-msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:13
-msgid "Subset of columns from the other table"
-msgstr ""
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
-msgid "Name of attribute column(s) to drop"
-msgstr ""
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-msgid ""
-"Removes a vector feature from a vector map through attribute selection."
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
-msgid "Removes existing attribute table of a vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-msgid "Force removal (required for actual deletion of table)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-msgid "Table name (default: vector map name)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:6
-msgid "Old and new name of the column (old,new)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a"
-" new database."
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
-msgid "Copy attribute tables to the target database if not exist"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
-msgid "Delete attribute tables from the source database"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
-msgid "Name of source database"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
-msgid "Name of source database schema"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:9
-msgid "Name for target driver"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:10
-msgid "Name for target database"
-msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:11
-msgid "Name for target database schema"
-msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector"
-" map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid "Updates a column in the attribute table connected to a vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:5
-msgid "Name of attribute column to update"
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid "Literal value to update the column with"
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:7
-msgid ""
-"Name of other attribute column to query, can be combination of columns (e.g."
-" co1+col2)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:8
-msgid ""
-"Name of SQLite extension file for extra functions (SQLite backend only)"
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number"
-" or attribute."
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-msgid "Layer number or name."
-msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
-msgid "Name of attribute column used to dissolve common boundaries"
-msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:1
-msgid ""
-"Imports vector data into a GRASS vector map using OGR library and reprojects"
-" on the fly."
-msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:11
-msgid "Output vector map extent"
-msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:12
-msgid "input;extent of input map;region;extent of current region"
-msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:18
-msgid "A suitable threshold is estimated during import"
-msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:20
-#: ../locale/scriptstrings/v.import_to_translate.c:22
-msgid "Input SRS"
-msgstr ""
-#: ../locale/scriptstrings/v.import_to_translate.c:24
-msgid "-1 to list available datum transform parameters"
-msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
-msgid "Imports E00 file into a vector map."
-msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
-msgid "E00"
-msgstr ""
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:5
-msgid "Name of input E00 file"
-msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-msgid "Imports geonames.org country files into a vector points map."
-msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
-msgid "gazetteer"
-msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
-msgid "Name of uncompressed geonames file (with .txt extension)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
-msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
-msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
-msgid "Create a 3D line from 3 column data"
-msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:7
-msgid "Name of input file (or \"-\" to read from stdin)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
-msgid "Input map is in Matlab format"
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
-msgid "Name of input file in Mapgen/Matlab format"
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
-msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-msgid "Imports GetFeature from a WFS server."
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:5
-msgid "Base URL starting with 'http' and ending in '?'"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:6
-msgid "Comma separated names of data layers to download"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:7
-msgid "Specify alternate spatial reference system (example: EPSG:4326)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid ""
-"The given code must be supported by the server, consult the capabilities "
-"file"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
-msgid "Maximum number of features to download"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:10
-msgid "(default: unlimited)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:11
-msgid "Skip earlier feature IDs and start downloading at this one"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:12
-msgid "(default: start with the first feature)"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid ""
-"Download server capabilities to 'wms_capabilities.xml' in the current "
-"directory and exit"
-msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
-msgid "Restrict fetch to features which touch the current region"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a raster map based on a vector map and"
-" uploads statistics to new attribute columns."
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
-msgid "Continue if upload column(s) already exist"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:12
-msgid "Name of input raster map to calculate statistics from"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:13
-msgid "Column prefix for new attribute columns"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:14
-msgid "The methods to use"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:15
-msgid "Percentile to calculate"
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:1
-msgid "Reports geometry statistics for vector maps."
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:6
-msgid "Value to calculate"
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:7
-msgid "Sort the result"
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:8
-msgid "asc;Sort in ascending order;desc;Sort in descending order"
-msgstr ""
-#: ../locale/scriptstrings/v.pack_to_translate.c:1
-msgid "Exports a vector map as GRASS GIS specific archive file"
-msgstr ""
-#: ../locale/scriptstrings/v.pack_to_translate.c:5
-msgid "Name of vector map to pack up"
-msgstr ""
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:1
-msgid "Converts vector polygons or points to lines."
-msgstr ""
-#: ../locale/scriptstrings/v.to.lines_to_translate.c:7
-msgid "Method used for point interpolation"
-msgstr ""
-msgid ""
-"Imports a GRASS GIS specific vector archive file (packed with v.pack) as a "
-"vector map"
-msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:6
-msgid "Name for output vector map"
-msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:7
-msgid "Default: taken from input file internals"
-msgstr ""
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:1
-msgid ""
-"Uploads space time raster dataset values at positions of vector points to "
-"the table."
-msgstr ""
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:9
-msgid "Update attribute table of input vector map"
-msgstr ""
-#: ../locale/scriptstrings/v.what.strds_to_translate.c:10
-msgid ""
-"Instead of creating a new vector map update the attribute table with "
-"value(s)"
-msgstr ""
-msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:12
-msgid "Name of vector map to be queried"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:13
-msgid "query_layer,query_column"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:14
-msgid "query_column"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:15
-msgid "Name of attribute column to be queried"
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:16
-msgid "Maximum query distance in map units (meters for ll)"
-msgstr ""
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:1
-msgid "Views BMP images from the PNG driver."
-msgstr ""
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:5
-msgid "Name of input image file"
-msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:1
-msgid "Creates a space time dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:4
-msgid "create"
-msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:6
-msgid "Type of the output space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:7
-#: ../locale/scriptstrings/t.support_to_translate.c:5
-msgid "Semantic type of the space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:10
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:10
-msgid "Title of the new space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.create_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:11
-msgid "Description of the new space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:1
-msgid "Modifies the metadata of a space time dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:6
-#: ../locale/scriptstrings/t.topology_to_translate.c:5
-#: ../locale/scriptstrings/t.info_to_translate.c:7
-#: ../locale/scriptstrings/t.rename_to_translate.c:6
-#: ../locale/scriptstrings/t.select_to_translate.c:5
-#: ../locale/scriptstrings/t.snap_to_translate.c:7
-#: ../locale/scriptstrings/t.shift_to_translate.c:7
-msgid "input"
-msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:7
-#: ../locale/scriptstrings/t.topology_to_translate.c:6
-#: ../locale/scriptstrings/t.info_to_translate.c:8
-#: ../locale/scriptstrings/t.merge_to_translate.c:7
-#: ../locale/scriptstrings/t.sample_to_translate.c:6
-#: ../locale/scriptstrings/t.sample_to_translate.c:7
-#: ../locale/scriptstrings/t.rename_to_translate.c:7
-#: ../locale/scriptstrings/t.select_to_translate.c:6
-#: ../locale/scriptstrings/t.snap_to_translate.c:8
-#: ../locale/scriptstrings/t.shift_to_translate.c:8
-msgid "Required"
-msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:8
-msgid "Title of the space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:9
-msgid "Description of the space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:10
-msgid "Aggregation type of the space time raster or 3D raster dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:11
-msgid ""
-"Update the metadata information and spatial extent of registered maps from "
-"the GRASS spatial database"
-msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:12
-msgid ""
-"Check for removed maps and delete them from the temporal database and all "
-"effected space time datasets"
-msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:13
-msgid ""
-"Update metadata information, temporal and spatial extent from registered "
-"maps based on database entries."
-msgstr ""
-#: ../locale/scriptstrings/t.topology_to_translate.c:1
-msgid "Lists temporal topology of a space time dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.topology_to_translate.c:7
-msgid "Print temporal topological relationships and exit"
-msgstr ""
-#: ../locale/scriptstrings/t.topology_to_translate.c:8
-msgid "Print spatio-temporal topological relationships and exit"
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:1
-msgid ""
-"Lists space time datasets and maps registered in the temporal database."
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:6
-msgid "Type of the space time dataset or map, default is strds"
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:9
-#: ../locale/scriptstrings/t.list_to_translate.c:12
-msgid ""
-"Columns number_of_maps and granularity only available for space time "
-"datasets"
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:7
-msgid "Sort the space time dataset by category"
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:9
-msgid "Columns to be printed to stdout"
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:16
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:14
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:13
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:13
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:8
-msgid "Field separator character between the output columns"
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:18
-#: ../locale/scriptstrings/t.sample_to_translate.c:11
-msgid "Print the column names as first row"
-msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:1
-msgid "Lists information about space time datasets and maps."
-msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:6
-msgid "Name of an existing space time dataset or map"
-msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:10
-msgid ""
-"Print history information in human readable shell style for space time "
-"datasets"
-msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:11
-msgid "Print information about the temporal DBMI interface and exit"
-msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:1
-msgid "Merges several space time datasets into a single space time dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:3
-#: ../locale/scriptstrings/t.snap_to_translate.c:3
-#: ../locale/scriptstrings/t.shift_to_translate.c:3
-msgid "time management"
-msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:6
-#: ../locale/scriptstrings/t.remove_to_translate.c:8
-msgid "inputs"
-msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:1
-msgid "Removes space time datasets from temporal database."
-msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:7
-msgid "Type of the space time dataset, default is strds"
-msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:10
-msgid "Input file with dataset names, one per line"
-msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:12
-msgid ""
-"Remove all registered maps from the temporal and also from the spatial "
-"database"
-msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:13
-msgid "Force recursive removing"
-msgstr ""
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and"
-" print the result to stdout."
-msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:5
-msgid "Name of the sample space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:8
-msgid "Type of the sample space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:9
-msgid "Field separator between output columns, default is tabular \" | \""
-msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:10
-msgid ""
-"Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
-msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:12
-msgid "Check for spatial topological overlap"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:1
-msgid ""
-"Assigns timestamps and registers raster, vector and raster3d maps in a space"
-" time dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:4
-msgid "register"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:8
-#: ../locale/scriptstrings/t.unregister_to_translate.c:7
-msgid "input,maps"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:10
-#: ../locale/scriptstrings/t.unregister_to_translate.c:6
-msgid "Input file with map names, one per line"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:11
-msgid "Additionally the start time and the end time can be specified per line"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:13
-msgid "Valid start date and time of the first map"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:14
-#: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid ""
-"Format for absolute time: \"yyyy-mm-dd HH:MM:SS +HHMM\", relative time is of"
-" type integer."
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:15
-#: ../locale/scriptstrings/t.register_to_translate.c:18
-#: ../locale/scriptstrings/t.register_to_translate.c:21
-#: ../locale/scriptstrings/t.register_to_translate.c:24
-#: ../locale/scriptstrings/t.register_to_translate.c:28
-msgid "Time & Date"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:16
-msgid "Valid end date and time of all map"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:19
-msgid "Time stamp unit"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:20
-msgid "Unit must be set in case of relative timestamps"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:22
-msgid "Time increment, works only in conjunction with start option"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:23
-msgid ""
-"Time increment between maps for creation of valid time intervals (format for"
-" absolute time: NNN seconds, minutes, hours, days, weeks, months, years; "
-"format for relative time is of type integer: 5)"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:25
-msgid "Field separator character of the input file"
-msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:27
-msgid ""
-"Create an interval (start and end time) in case an increment and the start "
-"time are provided"
-msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a"
-" specific space time dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:4
-msgid "unregister"
-msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:8
-msgid "Name(s) of existing raster, vector or raster3d map(s) to unregister"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:1
-msgid "Computes cyclic accumulations of a space time raster dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
-msgid ""
-"Input space time raster dataset that defines the lower threshold, values "
-"lower than this threshold are excluded from accumulation"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
-msgid ""
-"Input space time raster dataset that defines the upper threshold, values "
-"higher than this threshold are excluded from accumulation"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:10
-msgid "The temporal starting point to begin the accumulation, eg '2001-01-01'"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:11
-msgid "The temporal date to stop the accumulation, eg '2009-01-01'"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:12
-msgid "The temporal cycle to restart the accumulation, eg '12 months'"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:11
-msgid "The temporal offset to the beginning of the next cycle, eg '6 months'"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:12
-msgid "The granularity for accumulation '1 day'"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:8
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:8
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-msgid "Basename of the new generated output maps"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:15
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:8
-msgid ""
-"A numerical suffix separated by an underscore will be attached to create a "
-"unique identifier"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
-msgid ""
-"Suffix to add to the basename. Set 'gran' for granularity, 'time' for the "
-"full time format, 'num' for numerical suffix with a specific number of "
-"digits (default %05)"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
-msgid ""
-"Use these limits in case lower and/or upper input space time raster datasets"
-" are not defined or contain NULL values"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
-msgid "Scale factor for input space time raster dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:18
-msgid "Shift factor for input space time raster dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:19
-msgid ""
-"This method will be applied to compute the accumulative values from the "
-"input maps in a single granule"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:20
-msgid ""
-"Growing Degree Days or Winkler indices; Mean: sum(input maps)/(number of "
-"input maps); Biologically Effective Degree Days; Huglin Heliothermal index"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:21
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:19
-msgid ""
-"Register empty maps in the output space time raster dataset, otherwise they "
-"will be deleted"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:22
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:20
-msgid "Reverse time direction in cyclic accumulation"
-msgstr ""
-msgid ""
-"Detects accumulation patterns in temporally accumulated space time raster "
-"datasets created by t.rast.accumulate."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
-msgid ""
-"Input space time raster dataset that specifies the minimum values to detect "
-"the accumulation pattern"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
-msgid ""
-"Input space time raster dataset that specifies the maximum values to detect "
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
-msgid ""
-"The output space time raster dataset that stores the occurrence of the the "
-"accumulation pattern using the provided data range"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
-msgid ""
-"The output space time raster dataset that stores the indication of the "
-"start, intermediate and end of the specified data range"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:13
-msgid "The temporal offset to the begin of the next cycle, eg '6 months'"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
-msgid ""
-"Suffix to add at basename: set 'gran' for granularity, 'time' for the full "
-"time format, 'count' for numerical suffix with a specific number of digits "
-"(default %05)"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
-msgid ""
-"The minimum and maximum value of the occurrence of accumulated values, these"
-" values will be used if the min/max space time raster datasets are not "
-"specified"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:18
-msgid ""
-"The user defined values that indicate start, intermediate and end status in "
-"the indicator output space time raster dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:1
-msgid ""
-"Aggregates temporally the maps of a space time raster dataset by a user "
-"defined granularity."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
-msgid ""
-"Either a numerical suffix or the start time (s-flag) separated by an "
-"underscore will be attached to create a unique identifier"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:8
-msgid ""
-"time format, 'num' for numerical suffix with a specific number of digits "
-"(default %05)"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:9
-msgid ""
-"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
-"x days, x hours, x minutes, x seconds\" or an integer value for relative "
-"time"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:8
-msgid "Aggregate operation to be performed on the raster maps"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:12
-msgid ""
-"Offset that is used to create the output map ids, output map id is generated"
-" as: basename_ (count + offset)"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:12
-msgid "Number of r.series processes to run in parallel"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:13
-msgid "The maximum number of open files allowed for each r.series process"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:14
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:12
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:11
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:12
-msgid "Register Null maps"
-msgstr ""
-msgid ""
-"Aggregates data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
-msgid ""
-"Time intervals from this space time dataset (raster, vector or raster3d) are"
-" used for aggregation computation"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
-msgid "Type of the space time dataset from which aggregation will be copied"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:10
-msgid "Number of r.mapcalc processes to run in parallel"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
-msgid "Name of color table (see r.color help)"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:1
-msgid ""
-"Produces a space time vector dataset of specified contours from a space time"
-" raster dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:3
-msgid "contour"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:15
-msgid ""
-"Number of r.contour processes to run in parallel, more than 1 process works "
-"only in conjunction with flag -t"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:16
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:13
-msgid "Register empty vector maps"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.contour_to_translate.c:17
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:14
-msgid "Do not create attribute tables"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:1
-msgid "Converts a space time raster dataset into a 3D raster map."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered"
-" raster map of a space time raster dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:10
-msgid ""
-"Ignore the current region settings and use the raster map regions for univar"
-" statistical calculation"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:16
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:15
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:15
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:11
-msgid "Suppress printing of column names"
-msgstr ""
-msgid "Lists registered maps of a space time raster dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:12
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:12
-msgid "Method used for data listing"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:13
-msgid ""
-"The granule to be used for listing. The granule must be specified as string "
-"eg.: absolute time \"1 months\" or relative time \"1\""
-msgstr ""
-msgid ""
-"Performs spatio-temporal mapcalc expressions on temporally sampled maps of "
-"space time raster datasets."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:6
-msgid "Spatio-temporal mapcalc expression"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:7
-msgid "Basename for output raster maps"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:12
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:9
-msgid ""
-"Check the spatial topology of temporally related maps and process only "
-"spatially related maps"
-msgstr ""
-msgid ""
-"Apply temporal and spatial operations on space time raster datasets using "
-"temporal raster algebra."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:6
-msgid ""
-"r.mapcalc expression for temporal and spatial analysis of space time raster "
-"datasets"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:12
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:13
-msgid "Use granularity sampling instead of the temporal topology approach"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.algebra_to_translate.c:13
-#: ../locale/scriptstrings/t.select_to_translate.c:9
-msgid ""
-"Perform a dry run, compute all dependencies and module calls but don't run "
-"them"
-msgstr ""
-msgid ""
-"Performs a neighborhood analysis for each map in a space time raster "
-"dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:11
-msgid "Number of r.neighbor processes to run in parallel"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:13
-msgid "Ignore the current region settings and use the raster map regions"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:1
-msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:8
-msgid "Sort the maps by category"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:10
-msgid ""
-"Do not assign the space time raster dataset start and end time to the output"
-" map"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:1
-msgid "Exports space time raster dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:6
-msgid "Name of a space time raster dataset archive"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
-msgid "Path to the work directory, default is /tmp"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:8
-msgid "Compression method of the tar archive"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:9
-msgid "The export format of a single raster map"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:10
-msgid ""
-"Supported are GTiff, AAIGrid via r.out.gdal and the GRASS package format of "
-"r.pack"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:12
-msgid "Supported only for GTiff"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:1
-msgid "Exports space time raster dataset as VTK time series."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:5
-msgid "VTK"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:7
-msgid "Path to the export directory"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:11
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
-msgstr ""
-msgid "Imports space time raster dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:9
-msgid "Path to the extraction directory"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:12
-msgid ""
-"Create a new location and import the data into it. Do not run this module in"
-" parallel or interrupt it when a new location should be created"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:15
-msgid "Set the current region from the last map that was imported"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:16
-msgid "Link the raster files using r.external"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:17
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:13
-msgid "Extend location extents based on new dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:20
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not"
-" import the space time raster datasets."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
-msgid ""
-"Replaces gaps in a space time raster dataset with interpolated raster maps."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:10
-msgid "Number of interpolation processes to run in parallel"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:11
-msgid ""
-"Assign the space time raster dataset start and end time to the output map"
-msgstr ""
-msgid "Extracts a subset of a space time raster datasets."
-msgstr ""
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:6
-msgid "r.mapcalc expression assigned to all extracted raster maps"
-msgstr ""
-msgid "Converts a space time raster dataset into a space time vector dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.to.vect_to_translate.c:12
-msgid ""
-"Number of r.to.vect processes to run in parallel, more than 1 process works "
-msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:1
-msgid ""
-"Sample a space time raster dataset at specific vector point coordinates and "
-"write the output to stdout using different layouts"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:6
-msgid "Comma separated list of coordinates"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:7
-msgid "Name for the output file or \"-\" in case stdout should be used"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:9
-msgid ""
-"The layout of the output. One point per row (row), one point per column "
-"(col), all timsteps in one row (timerow)"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:10
-msgid "Number of r.what processes to run in parallel"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.what_to_translate.c:12
-msgid "Use stdin as input and ignore coordinates and point option"
-msgstr ""
-msgid "Lists registered maps of a space time raster3d dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:8
-msgid "Order the space time dataset by category"
-msgstr ""
-msgid "Extracts a subset of a space time 3D raster dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:7
-msgid "The r3.mapcalc expression assigned to all extracted 3D raster maps"
-msgstr ""
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:8
-msgid "Basename of the new generated 3D raster maps"
-msgstr ""
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:10
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:10
-msgid "Number of r3.mapcalc processes to run in parallel"
-msgstr ""
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time 3D raster "
-"datasets."
-msgstr ""
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
-msgid "r3.mapcalc expression applied to each time step of the sampled data"
-msgstr ""
-msgid ""
-"Apply temporal and spatial operations on space time 3D raster datasets using"
-" temporal 3D raster algebra."
-msgstr ""
-#: ../locale/scriptstrings/t.rast3d.algebra_to_translate.c:7
-msgid ""
-"Algebraic expression for temporal and spatial analysis of space time 3D "
-"raster datasets"
-msgstr ""
-msgid ""
-" 3D raster map of a space time 3D raster dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.rename_to_translate.c:1
-msgid "Renames a space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:1
-msgid ""
-"Select maps from space time datasets by topological relationships to other "
-"space time datasets using temporal algebra."
-msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:7
-msgid "The temporal mapcalc expression"
-msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:8
-msgid ""
-"Check the spatial topology of temporally related maps and select only "
-msgstr ""
-#: ../locale/scriptstrings/t.snap_to_translate.c:1
-msgid "Snaps temporally the maps of a space time dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.snap_to_translate.c:6
-#: ../locale/scriptstrings/t.shift_to_translate.c:6
-msgid "Name of an existing space time dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:1
-msgid "Shifts temporally the maps of a space time dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:4
-msgid "shift"
-msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:9
-msgid "Shift granularity"
-msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:10
-msgid ""
-"Format absolute time: \"x years, x months, x weeks, x days, x hours, x "
-"minutes, x seconds\", relative time is of type integer"
-msgstr ""
-msgid "Lists registered maps of a space time vector dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:1
-msgid ""
-"Exports a space time vector dataset as GRASS GIS specific archive file."
-msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:6
-msgid "Name of a space time vector dataset archive"
-msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:9
-msgid "The export format of a single vector map"
-msgstr ""
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:10
-msgid "Supported are GML via v.out.ogr and the GRASS package format of v.pack"
-msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:1
-msgid "Extracts a subset of a space time vector dataset."
-msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:9
-msgid ""
-"The number of v.extract processes to run in parallel. Use only if database "
-"backend is used which supports concurrent writing"
-msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:10
-msgid "Register empty maps"
-msgstr ""
-#: ../locale/scriptstrings/t.vect.algebra_to_translate.c:1
-msgid ""
-"Apply temporal and spatial operations on space time vector datasets using "
-"temporal vector algebra."
-msgstr ""
-msgid ""
-"Imports a space time vector dataset from a GRASS GIS specific archive file."
-msgstr ""
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:16
-msgid ""
-" import the space time vector datasets."
-msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
-msgid ""
-"Stores raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
-msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
-msgid ""
-"Name of the vector column to be created and to store sampled raster values"
-msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:7
-msgid ""
-"The use of a column name forces t.vect.what.rast to sample only values from "
-"the first map found in an interval. Otherwise the raster map names are used "
-"as column names"
-msgstr ""
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
-msgstr ""
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:6
-msgid ""
-"Name of the new created vector map that stores the sampled values in "
-"different layers"
-msgstr ""
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:7
-msgid ""
-"Names of the vector columns to be created and to store sampled raster "
-"values, one name for each STRDS"
-msgstr ""
-msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:75
-msgid "Creates fly-through script to run in NVIZ."
-msgstr ""
-#: ../misc/m.nviz.script/main.c:80
-msgid "Name of output script"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:86
-msgid "Prefix of output images (default = NVIZ)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:94
-msgid "Route coordinates (east,north)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:100
-msgid "Camera layback distance (in map units)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:106
-msgid "Camera height above terrain"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:112
-msgid "Number of frames"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:118
-msgid "Start frame number (default=0)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:123
-msgid "Full render -- Save images"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:127
-msgid "Fly at constant elevation (ht)"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:132
-msgid "Include command in the script to output a KeyFrame file"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:136
-msgid "Render images off-screen"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:140
-msgid "Enable vector and sites drawing"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:148
-msgid "Either -i flag and/or route parameter must be used"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:172
-msgid "Off-screen only available with full render mode"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:250
-#, c-format
-msgid "You must provide at least four points %d"
-msgstr ""
-#: ../misc/m.nviz.script/main.c:324
-#, c-format
-msgid "Created NVIZ script <%s>."
-msgstr ""
-#: ../misc/m.nviz.script/main.c:439
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
-msgstr ""
-#: ../misc/m.cogo/main.c:227
-msgid "polar"
-msgstr ""
-#: ../misc/m.cogo/main.c:228
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-#: ../misc/m.cogo/main.c:230
-msgid "It assumes a cartesian coordinate system"
-msgstr ""
-#: ../misc/m.cogo/main.c:234
-msgid "Lines are labelled"
-msgstr ""
-#: ../misc/m.cogo/main.c:239
-msgid "Convert from coordinates to bearing and distance"
-msgstr ""
-#: ../misc/m.cogo/main.c:244
-msgid "Repeat the starting coordinate at the end to close a loop"
-msgstr ""
-#: ../misc/m.cogo/main.c:255
-msgid "Starting coordinate pair"
-msgstr ""
-#: ../misc/m.cogo/main.c:265
-#, c-format
-msgid "Couldn't open COGO file <%s>"
-msgstr ""
-#: ../misc/m.cogo/main.c:274
-#, c-format
-msgid "Couldn't open output file <%s>"
-msgstr ""
-#: ../misc/m.cogo/main.c:301 ../misc/m.cogo/main.c:304
-msgid "Converting starting coordinate pair"
-msgstr ""
-#: ../misc/m.cogo/main.c:319
-#, c-format
-msgid "Input parse error on line %lu"
-msgstr ""
-#: ../misc/m.nviz.image/main.c:56
-msgid "Creates a 3D rendering of GIS data."
-msgstr ""
-#: ../misc/m.nviz.image/main.c:57
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
-msgstr ""
-#: ../misc/m.nviz.image/main.c:83
-msgid "Unable to render data"
-msgstr ""
-#: ../misc/m.nviz.image/main.c:142
-#, c-format
-msgid "Vertical exaggeration not given, using calculated value %.0f"
-msgstr ""
-#: ../misc/m.nviz.image/main.c:154
-#, c-format
-msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-#: ../misc/m.nviz.image/main.c:240
-msgid "Unsupported output format"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:51
-msgid "Use draw mode for all loaded surfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:133
-#: ../misc/m.nviz.image/args.c:143 ../misc/m.nviz.image/args.c:150
-#: ../misc/m.nviz.image/args.c:156 ../misc/m.nviz.image/args.c:164
-#: ../misc/m.nviz.image/args.c:173 ../misc/m.nviz.image/args.c:183
-#: ../misc/m.nviz.image/args.c:191 ../misc/m.nviz.image/args.c:201
-#: ../misc/m.nviz.image/args.c:209 ../misc/m.nviz.image/args.c:219
-msgid "Surfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:92
-msgid "Name for output image file (without extension)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:93 ../misc/m.nviz.image/args.c:107
-#: ../misc/m.nviz.image/args.c:117
-msgid "Image"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:115
-msgid "Size (width, height) of output image"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:132
-msgid "Name of raster map(s) for elevation"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:142
-msgid "Constant elevation value(s) to use instead of a raster DEM"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:149
-msgid "Name of raster map(s) for color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:155
-msgid "Color value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:163
-msgid "Name of raster map(s) for mask"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:172
-msgid "Name of raster map(s) for transparency"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:182
-msgid "Transparency value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:190
-msgid "Name of raster map(s) for shininess"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:200
-msgid "Shininess value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:208
-msgid "Name of raster map(s) for emission"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:218
-msgid "Emission value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:230
-msgid "Draw mode"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:242
-msgid "Fine resolution"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:253
-msgid "Coarse resolution"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:264
-msgid "Draw style"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:276
-msgid "Shading"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:285
-msgid "Wire color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:297
-msgid "Surface position"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:309
-msgid "Name of line vector overlay map(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:310 ../misc/m.nviz.image/args.c:318
-#: ../misc/m.nviz.image/args.c:330 ../misc/m.nviz.image/args.c:339
-#: ../misc/m.nviz.image/args.c:348 ../misc/m.nviz.image/args.c:355
-#: ../misc/m.nviz.image/args.c:369 ../misc/m.nviz.image/args.c:379
-#: ../misc/m.nviz.image/args.c:391
-msgid "Vector lines"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:317 ../misc/m.nviz.image/args.c:410
-msgid "Layer number or name for thematic mapping"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:329
-msgid "Vector line width"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:337 ../misc/m.nviz.image/args.c:449
-msgid "Name of width definition column"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:345
-msgid "Vector line color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:353 ../misc/m.nviz.image/args.c:465
-msgid "Name of color definition column"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:364
-msgid "Vector line display mode"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:366
-msgid "surface;drape on raster surface;flat;draw at constant elevation"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:378
-msgid "Vector line height"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:390
-msgid "Vector lines position"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:402
-msgid "Name of point vector overlay map(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:403 ../misc/m.nviz.image/args.c:411
-#: ../misc/m.nviz.image/args.c:423 ../misc/m.nviz.image/args.c:432
-#: ../misc/m.nviz.image/args.c:442 ../misc/m.nviz.image/args.c:451
-#: ../misc/m.nviz.image/args.c:460 ../misc/m.nviz.image/args.c:467
-#: ../misc/m.nviz.image/args.c:480 ../misc/m.nviz.image/args.c:488
-#: ../misc/m.nviz.image/args.c:503 ../misc/m.nviz.image/args.c:513
-msgid "Vector points"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:422
-msgid "Icon size (map units)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:430
-msgid "Name of size definition column"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:441
-msgid "Icon width"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:457
-msgid "Icon color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:476
-msgid "Icon marker"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:486
-msgid "Name of marker definition column"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:497
-msgid "3D vector point display mode"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:499
-msgid "surface;drape on raster surface;3D;place at 3D point's z-elevation"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:512
-msgid "Vector points position"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:529
-msgid "Viewpoint position (x,y model coordinates)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:530 ../misc/m.nviz.image/args.c:542
-#: ../misc/m.nviz.image/args.c:552 ../misc/m.nviz.image/args.c:564
-#: ../misc/m.nviz.image/args.c:586
-msgid "Viewpoint"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:541
-msgid "Viewpoint height (in map units)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:551
-msgid "Viewpoint field of view (in degrees)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:563
-msgid "Viewpoint twist angle (in degrees)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:585
-msgid "Focus to point on surface (from SW corner in map units)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:595 ../misc/m.nviz.image/args.c:630
-#: ../misc/m.nviz.image/args.c:642 ../misc/m.nviz.image/args.c:652
-#: ../misc/m.nviz.image/args.c:661 ../misc/m.nviz.image/args.c:669
-#: ../misc/m.nviz.image/args.c:678 ../misc/m.nviz.image/args.c:689
-#: ../misc/m.nviz.image/args.c:698 ../misc/m.nviz.image/args.c:709
-#: ../misc/m.nviz.image/args.c:716 ../misc/m.nviz.image/args.c:722
-#: ../misc/m.nviz.image/args.c:734 ../misc/m.nviz.image/args.c:744
-#: ../misc/m.nviz.image/args.c:755
-msgid "Volumes"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:605
-msgid "Volume draw mode"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:617
-msgid "Volume shading"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:629
-msgid "Volume position"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:640
-msgid "Volume resolution"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:651
-msgid "Isosurface level"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:660
-msgid "Name of volume for isosurface color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:668
-msgid "Isosurface color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:677
-msgid "Name of 3D raster map(s) for isosurface transparency"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:688
-msgid "Transparency value(s)for isosurfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:697
-msgid "Name of 3D raster map(s) for shininess"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:708
-msgid "Shininess value(s) for isosurfaces"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:715
-msgid "Toggles normal direction of all isosurfaces (changes light effect)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:721
-msgid "Draw volume box"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:733
-msgid "Volume slice parallel to given axis (x, y, z)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:743
-msgid "Volume slice position"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:754
-msgid "Volume slice transparency"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:771
-msgid "Light position (x,y,z model coordinates)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:772 ../misc/m.nviz.image/args.c:778
-#: ../misc/m.nviz.image/args.c:787 ../misc/m.nviz.image/args.c:797
-msgid "Lighting"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:777
-msgid "Light color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:786
-msgid "Light brightness"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:796
-msgid "Light ambient"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:810
-msgid "Cutting plane index (0-5)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:811 ../misc/m.nviz.image/args.c:820
-#: ../misc/m.nviz.image/args.c:829 ../misc/m.nviz.image/args.c:841
-#: ../misc/m.nviz.image/args.c:852
-msgid "Cutting planes"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:819
-msgid "Cutting plane x,y,z coordinates"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:831
-msgid "Cutting plane rotation along the vertical axis"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:842
-msgid "Cutting plane tilt"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:854
-msgid "Cutting plane color (between two surfaces)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:870
-msgid "North-West edge"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:871
-msgid "North-East edge"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:872
-msgid "South-West edge"
-msgstr ""
-msgid "South-East edge"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:874
-msgid "Fringe edges"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:875 ../misc/m.nviz.image/args.c:881
-#: ../misc/m.nviz.image/args.c:890
-msgid "Fringe"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:880
-msgid "Fringe color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:889
-msgid "Fringe elevation"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:903
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:905 ../misc/m.nviz.image/args.c:915
-#: ../misc/m.nviz.image/args.c:922
-msgid "Decoration"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:914
-msgid "North arrow size (in map units)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:921
-msgid "North arrow color"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:973
-#, c-format
-msgid "At least one <%s> or <%s> required"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:987 ../misc/m.nviz.image/args.c:1017
-#: ../misc/m.nviz.image/args.c:1023 ../misc/m.nviz.image/args.c:1029
-#: ../misc/m.nviz.image/args.c:1035 ../misc/m.nviz.image/args.c:1041
-#: ../misc/m.nviz.image/args.c:1047
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1058
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 3)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1064 ../misc/m.nviz.image/args.c:1070
-#: ../misc/m.nviz.image/args.c:1082 ../misc/m.nviz.image/args.c:1089
-#: ../misc/m.nviz.image/args.c:1096 ../misc/m.nviz.image/args.c:1103
-#: ../misc/m.nviz.image/args.c:1110 ../misc/m.nviz.image/args.c:1122
-#: ../misc/m.nviz.image/args.c:1127 ../misc/m.nviz.image/args.c:1164
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1146 ../misc/m.nviz.image/args.c:1156
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d, <%s>: %d)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1171
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 6)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1183
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d, <%s>: %d)"
-msgstr ""
-#: ../misc/m.nviz.image/cplane.c:40
-#, c-format
-msgid "Cutting plane number <%d> not found"
-msgstr ""
-#: ../misc/m.nviz.image/surface.c:67
-#, c-format
-msgid "Missing topography attribute for surface %d"
-msgstr ""
-#: ../misc/m.nviz.image/surface.c:131 ../misc/m.nviz.image/volume.c:159
-#, c-format
-msgid "Color attribute not defined, using default <%s>"
-msgstr ""
-#: ../misc/m.nviz.image/surface.c:137
-#, c-format
-msgid "Missing color attribute for surface %d"
-msgstr ""
-#: ../misc/m.nviz.image/surface.c:217
-#, c-format
-msgid "Surface id %d doesn't exist"
-msgstr ""
-#: ../misc/m.nviz.image/surface.c:264 ../misc/m.nviz.image/surface.c:271
-#, c-format
-msgid "Unable to set draw mode for surface id %d"
-msgstr ""
-#: ../misc/m.nviz.image/vector.c:300 ../misc/m.nviz.image/vector.c:309
-#: ../misc/m.nviz.image/vector.c:319 ../misc/m.nviz.image/vector.c:329
-#, c-format
-msgid "Column <%s> in table <%s> not found"
-msgstr ""
-#: ../misc/m.nviz.image/vector.c:304
-msgid "Data type of color column must be character"
-msgstr ""
-#: ../misc/m.nviz.image/vector.c:314
-msgid "Data type of size column must be numeric"
-msgstr ""
-#: ../misc/m.nviz.image/vector.c:324
-msgid "Data type of width column must be numeric"
-msgstr ""
-#: ../misc/m.nviz.image/vector.c:335
-msgid "Data type of marker column must be character"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:133
-#, c-format
-msgid "3d raster map <%s> not found"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:96 ../misc/m.nviz.image/volume.c:256
-#, c-format
-msgid "Error tokenize '%s'"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:103 ../misc/m.nviz.image/volume.c:271
-#, c-format
-msgid "Volume set number %d is not available"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:108
-#, c-format
-msgid "Unable to add isosurface (volume set %d)"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:119 ../misc/m.nviz.image/volume.c:140
-#: ../misc/m.nviz.image/volume.c:153 ../misc/m.nviz.image/volume.c:172
-#: ../misc/m.nviz.image/volume.c:182 ../misc/m.nviz.image/volume.c:195
-#: ../misc/m.nviz.image/volume.c:205
-#, c-format
-msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:267
-#, c-format
-msgid "Wrong name for axis: %s"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:276
-#, c-format
-msgid "Unable to add slice (volume set %d)"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:288
-#, c-format
-msgid "Unable to set slice (%d) position of volume %d"
-msgstr ""
-#: ../misc/m.nviz.image/volume.c:294
-#, c-format
-msgid "Unable to set slice (%d) transparency of volume %d"
-msgstr ""
-#: ../misc/m.transform/main.c:92
-#, c-format
-msgid "Not enough points, %d are required"
-msgstr ""
-#: ../misc/m.transform/main.c:194
-msgid "Poorly placed control points"
-msgstr ""
-#: ../misc/m.transform/main.c:330
-msgid "Rectification polynomial order"
-msgstr ""
-#: ../misc/m.transform/main.c:362
-msgid "Local x,y coordinates to target east,north"
-msgstr ""
-#: ../misc/m.transform/main.c:367
-msgid "Target east,north coordinates to local x,y"
-msgstr ""
-#: ../misc/m.measure/main.c:45
-msgid "Measures the lengths and areas of features."
-msgstr ""
-#: ../misc/m.measure/main.c:47
-msgid "measurement"
-msgstr ""
-#: ../misc/m.measure/main.c:56
-msgid "Units"
-msgstr ""
-#: ../misc/m.measure/main.c:57
-msgid "Default: location map units"
-msgstr ""
-#: ../misc/m.measure/main.c:61
-msgid "Shell script style"
-msgstr ""
-#: ../misc/m.measure/main.c:104
-msgid "Length:"
-msgstr ""
-#: ../misc/m.measure/main.c:115
-msgid "Area:"
-msgstr ""
-#: ../scripts/i.oif/i.oif.py:54
-#, python-format
-msgid "Calculating OIF for combination: %s, %s, %s"
-msgstr ""
-#: ../scripts/i.oif/i.oif.py:83
-msgid "At least four input maps required"
-msgstr ""
-#: ../scripts/i.oif/i.oif.py:87
-msgid "Calculating standard deviations for all bands..."
-msgstr ""
-#: ../scripts/i.oif/i.oif.py:128
-msgid "Calculating Correlation Matrix..."
-msgstr ""
-#: ../scripts/i.oif/i.oif.py:140
-msgid "Calculating OIF for all band combinations..."
-msgstr ""
-#: ../scripts/i.oif/i.oif.py:147
-msgid ""
-"The Optimum Index Factor analysis result (best combination shown first):"
-msgstr ""
-#: ../scripts/v.db.addtable/v.db.addtable.py:76
-#: ../scripts/v.db.update/v.db.update.py:75
-#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:60
-#: ../scripts/v.rast.stats/v.rast.stats.py:120
-#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:63
-#: ../scripts/v.db.dropcolumn/v.db.dropcolumn.py:60
-#, python-format
-msgid "Vector map <%s> not found in current mapset"
-msgstr ""
-#: ../scripts/v.db.addtable/v.db.addtable.py:82
-#, python-format
-msgid "Using vector map name as table name: <%s>"
-msgstr ""
-#: ../scripts/v.db.addtable/v.db.addtable.py:88
-#, python-format
-msgid "Using vector map name extended by layer number as table name: <%s>"
-msgstr ""
-#: ../scripts/v.db.addtable/v.db.addtable.py:91
-#, python-format
-msgid "Using user specified table name: %s"
-msgstr ""
-#: ../scripts/v.db.addtable/v.db.addtable.py:95
-msgid "Creating new DB connection based on default mapset settings..."
-msgstr ""
-#: ../scripts/v.db.addtable/v.db.addtable.py:105
-#, python-format
-msgid "There is already a table linked to layer <%s>"
-msgstr ""
-#: ../scripts/v.db.addtable/v.db.addtable.py:120
-#, python-format
-msgid "Duplicate column name '%s' not allowed"
-msgstr ""
-#: ../scripts/v.db.addtable/v.db.addtable.py:131
-#, python-format
-msgid "Creating table with columns (%s)..."
-msgstr ""
-#: ../scripts/v.db.addtable/v.db.addtable.py:169
-msgid "Current attribute table links:"
-msgstr ""
-#: ../scripts/r.in.wms/wms_cap_parsers.py:41
-msgid "Unable to parse XML file"
-msgstr ""
-#: ../scripts/r.in.wms/wms_cap_parsers.py:43
-#, python-format
-msgid ""
-"Unable to open XML file '%s'.\n"
-"%s\n"
-msgstr ""
-#: ../scripts/r.in.wms/wms_cap_parsers.py:46
-msgid "Root node was not found."
-msgstr ""
-#: ../scripts/r.in.wms/wms_cap_parsers.py:61
-#, python-format
-msgid ""
-"Unable to parse capabilities file.\n"
-"                                Tag <%s> was not found."
-msgstr ""
-#: ../scripts/r.in.wms/wms_cap_parsers.py:92
-msgid "Missing version attribute root node in Capabilities XML file"
-msgstr ""
-#: ../scripts/r.in.wms/wms_cap_parsers.py:104
-#, python-format
-msgid "WMS server does not support '%s' version."
-msgstr ""
-#: ../scripts/r.in.wms/wms_cap_parsers.py:238
-#: ../scripts/r.in.wms/wms_cap_parsers.py:250
-#, python-format
-msgid ""
-"Unable to parse capabilities file. \n"
-msgstr ""
-#: ../scripts/r.in.wms/wms_cap_parsers.py:484
-#: ../scripts/r.in.wms/wms_cap_parsers.py:499
-#, python-format
-msgid ""
-"                                Tag '%s' was not found."
-msgstr ""
-#: ../scripts/r.in.wms/wms_cap_parsers.py:555
-#, python-format
-msgid ""
-"Unable to parse tile service file. \n"
-msgstr ""
-#: ../scripts/r.in.wms/wms_gdal_drv.py:27
-msgid "Unable to load GDAL Python bindings"
-msgstr ""
-#: ../scripts/r.in.wms/wms_gdal_drv.py:126
-msgid ""
-"If module will not be able to fetch the data in this geographic projection, \n"
-" try 'WMS_GRASS' driver or use WMS version 1.1.1."
-msgstr ""
-#: ../scripts/r.in.wms/wms_gdal_drv.py:137
-msgid "Unable to open GDAL WMS driver"
-msgstr ""
-#: ../scripts/r.in.wms/wms_gdal_drv.py:143
-#, python-format
-msgid "Unable to find %s driver"
-msgstr ""
-#: ../scripts/r.in.wms/wms_gdal_drv.py:148
-#, python-format
-msgid "Driver %s supports CreateCopy() method."
-msgstr ""
-#: ../scripts/r.in.wms/wms_gdal_drv.py:155
-msgid "Incorrect WMS query"
-msgstr ""
-#: ../scripts/r.in.wms/r.in.wms.py:228
-msgid "Importing raster map into GRASS..."
-msgstr ""
-#: ../scripts/r.in.wms/r.in.wms.py:230
-msgid ""
-"Nothing to import.\n"
-"No data has been downloaded from wms server."
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:33
-msgid "Unable to load GDAL python bindings"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:65
-msgid "Downloading data from WMS server..."
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:134
-#, python-format
-msgid ""
-"Authorization failed to '%s' when fetching data.\n"
-"%s"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:138
-#, python-format
-msgid ""
-"Unable to fetch data from: '%s'\n"
-"%s"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:161
-#, python-format
-msgid ""
-"Server refused to send data for a tile.\n"
-"Request will be repeated after %d s."
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:167
-#, python-format
-msgid ""
-"Unable to write data into tempfile.\n"
-"%s"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:180
-#, python-format
-msgid ""
-"Unable to read data from tempfile.\n"
-"%s"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:185
-#, python-format
-msgid "WMS server error: %s"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:187
-msgid "WMS server unknown error"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:206
-#, python-format
-msgid "Driver %s does not supports Create() method"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:260
-#, python-format
-msgid "Unable to open %s "
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:326
-msgid "Region is out of server data extend."
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:354
-#, python-format
-msgid "Fetching %d tiles with %d x %d pixel size per tile..."
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:562 ../scripts/r.in.wms/wms_drv.py:801
-#, python-format
-msgid ""
-"Unable to parse tile service file.\n"
-"%s\n"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:606
-#, python-format
-msgid "Layer '%s' was not found in capabilities file"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:625
-#, python-format
-msgid "Layer '%s' is not available with %s code."
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:825
-#, python-format
-msgid ""
-" No tag '%s' was found."
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:836
-#, python-format
-msgid "Tiled group '%s' was not found in tile service file"
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:930
-#, python-format
-msgid ""
-"Wrong form of parameter '%s' in '%s'. \n"
-"                                  The parameter was ignored."
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:953
-#, python-format
-msgid "Parameter '%s' in '%s' is not variable in tile pattern url."
-msgstr ""
-#: ../scripts/r.in.wms/wms_drv.py:958
-#, python-format
-msgid ""
-"%s driver supports only '%s' parameter in '%s'. Other parameters are "
-"ignored."
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:90
-#, python-format
-msgid "Please insert both %s and %s parameters or none of them."
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:99
-msgid "JPEG format does not support transparency"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:108
-#, python-format
-msgid "Invalid EPSG code %d"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:114
-#, python-format
-msgid ""
-"WMS version <1.3.0> will be used, because version <1.1.1> does not support "
-"<%s>projection"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:141
-msgid "Unable to get projection info"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:148
-msgid "Maxcols must be greater than 100"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:152
-msgid "Maxrows must be greater than 100"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:193
-#, python-format
-msgid ""
-"These parameter are ignored: %s\n"
-"                             %s driver does not support the parameters."
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:204
-#, python-format
-msgid ""
-"These flags are ignored: %s\n"
-"                             %s driver does not support the flags."
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:250
-#, python-format
-msgid "Authorization failed to <%s> when fetching capabilities"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:253
-#, python-brace-format
-msgid "Unable to fetch capabilities from <{0}>. Reason: "
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:293
-#, python-format
-msgid ""
-"Unabble to open file '%s'.\n"
-"%s\n"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:330
-msgid "Unable to write data into tempfile"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:341
-#, python-format
-msgid "Unable to determine region, %s failed"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:345
-msgid "Region definition: 4 points required"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:351
-msgid "Reprojection of region using m.proj failed."
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:382
-msgid "Reprojecting raster..."
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:421 ../scripts/r.in.wms/wms_base.py:478
-#: ../scripts/r.in.wms/wms_base.py:488 ../scripts/r.in.wms/wms_base.py:519
-#: ../scripts/r.in.wms/wms_base.py:543 ../scripts/r.in.wms/wms_base.py:554
-#: ../scripts/r.in.wms/wms_base.py:566
-#, python-format
-msgid "%s failed"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:438
-msgid "Unable to create temporary files"
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:468
-#, python-format
-msgid ""
-"Please change output name, or change names of these rasters: %s, module "
-"needs to create this temporary maps during execution."
-msgstr ""
-#: ../scripts/r.in.wms/wms_base.py:568
-#, python-format
-msgid "<%s> created."
-msgstr ""
-#: ../scripts/v.pack/v.pack.py:69
-#, python-format
-msgid "Unable to pack vector map <%s>. Only native format supported."
-msgstr ""
-#: ../scripts/v.pack/v.pack.py:85 ../scripts/r.pack/r.pack.py:78
-#, python-format
-msgid "Pack file <%s> already exists and will be overwritten"
-msgstr ""
-#: ../scripts/v.pack/v.pack.py:88 ../scripts/v.import/v.import.py:272
-#, python-format
-msgid "option <%s>: <%s> exists."
-msgstr ""
-#: ../scripts/v.pack/v.pack.py:91
-#, python-format
-msgid "Packing <%s>..."
-msgstr ""
-#: ../scripts/v.pack/v.pack.py:103
-#, python-format
-msgid "There is not database connected with vector map <%s>"
-msgstr ""
-#: ../scripts/v.pack/v.pack.py:124
-#, python-format
-msgid "Pack file <%s> created"
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:127
-msgid "'gdalinfo' not found, install GDAL tools first (http://www.gdal.org)"
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:144
-#, python-format
-msgid "<%s> already exists. Aborting."
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:149
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:155
-#, python-format
-msgid "Please extract %s before import."
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:169
-msgid "Importing SPOT VGT NDVI map..."
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:173
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:245
-msgid "An error occurred. Stop."
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:175
-#, python-format
-msgid "Imported SPOT VEGETATION NDVI map <%s>."
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:192
-msgid "Remapping digital numbers to NDVI..."
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:234
-msgid "Importing SPOT VGT NDVI quality map..."
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:261
-#, python-format
-msgid "Imported SPOT VEGETATION SM quality map <%s>."
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:263
-#, python-format
-msgid "Note: A snow map can be extracted by category 252 (d.rast %s cat=252)"
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:266
-msgid "Filtering NDVI map by Status Map quality layer..."
-msgstr ""
-#: ../scripts/i.in.spotvgt/i.in.spotvgt.py:273
-#, python-format
-msgid "Filtered SPOT VEGETATION NDVI map <%s>."
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:71
-msgid ""
-"The input vector map contains both polygons and points, cannot handle mixed "
-"types"
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:81
-#, python-format
-msgid "Processing point data (%d points found)..."
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:91
-msgid "The input vector map does not contain polygons"
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:96
-#, python-format
-msgid "Processing area data (%d areas found)..."
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:105
-msgid "Error creating layer 2"
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:113
-msgid "Error creating new table for layer 2"
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:120
-msgid "Error populating new table for layer 2"
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:128
-msgid "Error converting polygon to line"
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:144
-msgid "Error removing centroids"
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:154
-msgid "Error removing table from layer 1"
-msgstr ""
-#: ../scripts/v.to.lines/v.to.lines.py:165
-msgid "Error adding categories"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:191
-#, python-format
-msgid "'%s' required. Please install '%s' first."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:254
-msgid "List of installed extensions (toolboxes):"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:256
-msgid "List of installed extensions (modules):"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:261
-msgid "No extension (toolbox) installed"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:263
-msgid "No extension (module) installed"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:335
-msgid "List of available extensions (toolboxes):"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:349
-msgid "List of available extensions (modules):"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:372
-#: ../scripts/g.extension/g.extension.py:395
-msgid "Unable to fetch addons metadata file"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:465
-#, python-format
-msgid ""
-"Unable to parse '%s'. Trying to scan SVN repository (may take some time)..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:509
-msgid ""
-"Fetching list of extensions from GRASS-Addons SVN repository (be patient)..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:515
-msgid "Flag 'c' ignored, addons metadata file not available"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:518
-msgid "Flag 'g' ignored, addons metadata file not available"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:524
-#: ../scripts/g.extension/g.extension.py:557
-#, python-format
-msgid "Checking for '%s' modules..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:532
-#: ../scripts/g.extension/g.extension.py:564
-#, python-format
-msgid "Unable to fetch '%s'"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:584
-msgid "Path to the source code:"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:666
-msgid "$GISBASE not defined"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:669
-#, python-format
-msgid "Extension <%s> already installed. Re-installing..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:673
-#, python-format
-msgid "Installing toolbox <%s>..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:678
-msgid "Nothing to install"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:695
-msgid "Installation failed, sorry. Please check above error messages."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:701
-#: ../scripts/g.extension/g.extension.py:1231
-msgid "Updating addons metadata file..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:707
-#, python-format
-msgid "Installation of <%s> successfully finished"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:711
-msgid ""
-"This add-on module will not function until you set the GRASS_ADDON_BASE "
-"environment variable (see \"g.manual variables\")"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:744
-msgid "Unable to read addons metadata file from the remote server"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:755
-msgid "No addons metadata available"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:758
-#, python-format
-msgid "No addons metadata available for <%s>"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:814
-msgid "Unable to read addons metadata file from the remote server: {0}"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:818
-#, python-format, python-brace-format
-msgid "Unable to parse '%s': {0}"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:863
-msgid "No addons metadata available. Addons metadata file not updated."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:884
-#, python-format
-msgid "No addons metadata found for <%s>"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:929
-#, python-format
-msgid "Downloading precompiled GRASS Addons <%s>..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:990
-#, python-format
-msgid "GRASS Addons <%s> not found"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1063
-msgid "ZIP file is unreadable: {0}"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1082
-msgid "Archive file is unreadable: {0}"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1100
-#: ../scripts/g.extension/g.extension.py:1262
-#: ../scripts/g.extension/g.extension.py:1285
-#, python-format
-msgid "Extension <%s> not found"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1123
-msgid ""
-"Unknown extension (addon) source type '{0}'. Please report this to the "
-"grass-user mailing list."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1135
-#, python-format
-msgid "Fetching <%s> from GRASS GIS Addons repository (be patient)..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1138
-msgid "Fetching <{name}> from <{url}> (be patient)..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1189
-msgid "To compile run:"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1191
-msgid "To install run:"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1197
-msgid "Compiling..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1200
-msgid "Please install GRASS development package"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1204
-msgid "Compilation failed, sorry. Please check above error messages."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1210
-msgid "Installing..."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1224
-msgid "List of removed files:"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1226
-msgid "Files to be removed:"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1233
-#, python-format
-msgid "Extension <%s> successfully uninstalled."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1236
-#, python-format
-msgid ""
-"Extension <%s> not removed. Re-run '%s' with '-f' flag to force removal"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1376
-#: ../scripts/g.extension/g.extension.py:1390
-#, python-format
-msgid "Unable to create '%s': %s"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1414
-#, python-format
-msgid "Manual page for <%s> updated"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1422
-#, python-format
-msgid "Unable to read manual page: %s"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1458
-#, python-format
-msgid "Unable for write manual page: %s"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1469
-#, python-format
-msgid "GRASS_ADDON_BASE is not defined, installing to ~/.grass%s/addons"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1477
-msgid ""
-"You don't have permission to install extension to <{0}>. Try to run {1} with"
-" administrator rights (su or sudo)."
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1559
-msgid "Identified {0} as known hosting service"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1564
-msgid ""
-"Not using {service} as known hosting service because the URL ends with "
-"'{suffix}'"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1576
-msgid "Will use the following URL for download: {0}"
-msgstr ""
-#: ../scripts/g.extension/g.extension.py:1716
-msgid "Flag 'd' is relevant only to 'operation=add'. Ignoring this flag."
-msgstr ""
-#: ../scripts/db.in.ogr/db.in.ogr.py:99
-#, python-format
-msgid "Table <%s> already exists and will be overwritten"
-msgstr ""
-#: ../scripts/db.in.ogr/db.in.ogr.py:105
-#, python-format
-msgid "Table <%s> already exists"
-msgstr ""
-#: ../scripts/db.in.ogr/db.in.ogr.py:120
-#, python-format
-msgid "Input table <%s> not found or not readable"
-msgstr ""
-#: ../scripts/db.in.ogr/db.in.ogr.py:123
-#, python-format
-msgid "Input DSN <%s> not found or not readable"
-msgstr ""
-#: ../scripts/db.in.ogr/db.in.ogr.py:136
-msgid "Something went wrong. Should not happen"
-msgstr ""
-#: ../scripts/db.in.ogr/db.in.ogr.py:151
-#, python-format
-msgid "Imported table <%s> with %d rows"
-msgstr ""
-#: ../scripts/r.buffer.lowmem/r.buffer.lowmem.py:110
-msgid "Extracting buffers (1/2)..."
-msgstr ""
-#: ../scripts/r.buffer.lowmem/r.buffer.lowmem.py:122
-msgid "Extracting buffers (2/2)..."
-msgstr ""
-#: ../scripts/db.out.ogr/db.out.ogr.py:86
-#, python-format
-msgid "File <%s> already exists"
-msgstr ""
-#: ../scripts/db.out.ogr/db.out.ogr.py:94
-#: ../scripts/db.out.ogr/db.out.ogr.py:102
-#, python-format
-msgid "Module <%s> failed"
-msgstr ""
-#: ../scripts/db.out.ogr/db.out.ogr.py:120
-#, python-format
-msgid "Exported table <%s>"
-msgstr ""
-#: ../scripts/v.db.update/v.db.update.py:81
-#: ../scripts/v.rast.stats/v.rast.stats.py:167
-#: ../scripts/v.rast.stats/v.rast.stats.py:174
-#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:69
-msgid ""
-"There is no table connected to this map. Run v.db.connect or v.db.addtable "
-"first."
-msgstr ""
-#: ../scripts/v.db.update/v.db.update.py:89
-msgid "Use of libsqlitefunctions only with SQLite backend"
-msgstr ""
-#: ../scripts/v.db.update/v.db.update.py:102
-msgid "<value> and <qcolumn> are mutually exclusive"
-msgstr ""
-#: ../scripts/v.db.update/v.db.update.py:107
-msgid "Either <value> or <qcolumn> must be given"
-msgstr ""
-#: ../scripts/r.in.aster/r.in.aster.py:109
-msgid "gdalwarp is not in the path and executable"
-msgstr ""
-#: ../scripts/r.in.aster/r.in.aster.py:119
-#, python-format
-msgid "This module needs to be run in a projected location (found: %s)"
-msgstr ""
-#: ../scripts/r.in.aster/r.in.aster.py:136
-#, python-format
-msgid "band %s is not an available Terra/ASTER band"
-msgstr ""
-#: ../scripts/r.in.aster/r.in.aster.py:142
-msgid "Cleaning up ..."
-msgstr ""
-#: ../scripts/r.in.aster/r.in.aster.py:152
-msgid "Georeferencing aster image ..."
-msgstr ""
-#: ../scripts/r.in.aster/r.in.aster.py:165
-msgid "Importing into GRASS ..."
-msgstr ""
-#: ../scripts/d.what.rast/d.what.rast.py:48 ../scripts/d.frame/d.frame.py:264
-#: ../scripts/d.redraw/d.redraw.py:37 ../scripts/d.to.rast/d.to.rast.py:48
-#: ../scripts/d.out.file/d.out.file.py:61
-#: ../scripts/d.what.vect/d.what.vect.py:48
-msgid "No graphics device selected. Use d.mon to select graphics device."
-msgstr ""
-#: ../scripts/v.db.droptable/v.db.droptable.py:60
-#, python-format
-msgid "No table assigned to layer <%s>"
-msgstr ""
-#: ../scripts/v.db.droptable/v.db.droptable.py:65
-#, python-format
-msgid "User selected table <%s> but the table <%s> is linked to layer <%s>"
-msgstr ""
-#: ../scripts/v.db.droptable/v.db.droptable.py:73
-#, python-format
-msgid "Removing table <%s> linked to layer <%s> of vector map <%s>"
-msgstr ""
-#: ../scripts/v.db.droptable/v.db.droptable.py:77
-msgid ""
-"You must use the -f (force) flag to actually remove the table. Exiting."
-msgstr ""
-#: ../scripts/v.db.droptable/v.db.droptable.py:79
-msgid "Leaving map/table unchanged."
-msgstr ""
-#: ../scripts/v.db.droptable/v.db.droptable.py:82
-#, python-format
-msgid "Dropping table <%s>..."
-msgstr ""
-#: ../scripts/v.db.droptable/v.db.droptable.py:88
-msgid "An error occurred while running db.execute"
-msgstr ""
-#: ../scripts/v.db.droptable/v.db.droptable.py:92
-msgid "Current attribute table link(s):"
-msgstr ""
-#: ../scripts/v.db.droptable/v.db.droptable.py:99
-msgid "(No database links remaining)"
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:100
-msgid "Required dependency NumPy not found. Exiting."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:116
-msgid ""
-"Maps with selected output prefix names already exist. Delete them or use "
-"overwrite flag"
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:133
-#, python-format
-msgid "Performing pan sharpening with hi res pan image: %f"
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:136
-msgid "Using Brovey algorithm"
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:153
-msgid "Calculating Brovey transformation..."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:186
-msgid "Using IHS<->RGB algorithm"
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:188
-msgid "Transforming to IHS color space..."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:203
-msgid "Transforming back to RGB color space and sharpening..."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:217
-msgid "Using PCA/inverse PCA algorithm"
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:218
-msgid "Creating PCA images and calculating eigenvectors..."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:225
-#: ../scripts/i.pansharpen/i.pansharpen.py:385
-msgid "Input has no data. Check region settings."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:252
-msgid "Performing inverse PCA ..."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:319
-msgid "Assigning grey equalized color tables to output images..."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:328
-msgid "Adjusting blue channel color table..."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:338
-msgid "The following pan-sharpened output maps have been generated:"
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:340
-#, python-format
-msgid "%s_%s"
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:342
-#, python-format
-msgid "To visualize output, run: g.region -p raster=%s_red"
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:343
-#, python-format
-msgid "d.rgb r=%s_red g=%s_green b=%s_blue"
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:344
-msgid "If desired, combine channels into a single RGB map with 'r.composite'."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:345
-msgid "Channel colors can be rebalanced using i.colors.enhance."
-msgstr ""
-#: ../scripts/i.pansharpen/i.pansharpen.py:362
-msgid "Histogram matching..."
-msgstr ""
-#: ../scripts/d.frame/d.frame.py:92 ../scripts/d.frame/d.frame.py:121
-#, python-format
-msgid "Unable to get monitor info. %s"
-msgstr ""
-#: ../scripts/d.frame/d.frame.py:108
-#, python-format
-msgid "Unable to get monitor info (no %s found)"
-msgstr ""
-#: ../scripts/d.frame/d.frame.py:200
-#, python-format
-msgid "Invalid frame position: %s"
-msgstr ""
-#: ../scripts/d.frame/d.frame.py:228
-#, python-format
-msgid "Invalid monitor size: %dx%d"
-msgstr ""
-#: ../scripts/d.frame/d.frame.py:284
-#, python-format
-msgid ""
-"Frame <%s> doesn't exist, exiting. To create a new frame use '-c' flag."
-msgstr ""
-#: ../scripts/d.frame/d.frame.py:293
-#, python-format
-msgid "Frame <%s> already exists and will be overwritten"
-msgstr ""
-#: ../scripts/d.frame/d.frame.py:298
-#, python-format
-msgid ""
-"Frame <%s> already found. An existing frame can be overwritten by '%s' flag."
-msgstr ""
-#: ../scripts/v.in.geonames/v.in.geonames.py:53
-msgid "This module only operates in LatLong/WGS84 locations"
-msgstr ""
-#: ../scripts/v.in.geonames/v.in.geonames.py:64
-msgid ""
-"Since DBF driver is used, the content of the 'alternatenames' column might "
-"be cut with respect to the original Geonames.org column content"
-msgstr ""
-#: ../scripts/v.in.geonames/v.in.geonames.py:68
-#, python-format
-msgid "Converting %d place names..."
-msgstr ""
-#: ../scripts/r.plane/r.plane.py:89
-msgid "dip must be between -90 and 90."
-msgstr ""
-#: ../scripts/r.plane/r.plane.py:92
-msgid "azimuth must be between 0 and 360"
-msgstr ""
-#: ../scripts/d.correlate/d.correlate.py:44
-msgid "At least 2 maps are required"
-msgstr ""
-#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:70
-msgid ""
-"There is no table connected to the input vector map. Cannot rename any "
-"column"
-msgstr ""
-#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:79
-#, python-format
-msgid ""
-"Column name <%s> too long. The DBF driver supports column names not longer "
-"than 10 characters"
-msgstr ""
-#: ../scripts/v.db.renamecolumn/v.db.renamecolumn.py:84
-#, python-format
-msgid ""
-"Cannot rename column <%s> as it is needed to keep table <%s> connected to "
-"the input vector map"
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:137
-msgid "Preprocessing input data..."
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:148
-msgid "An error occurred while converting vector to raster"
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:160
-msgid "No categories found in raster map"
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:227
-#, python-format
-msgid "Cannot create column <%s> (already present). "
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:228
-msgid "Use -c flag to update values in this column."
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:237
-#, python-format
-msgid "Adding columns '%s'"
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:242
-msgid "Adding columns failed. Exiting."
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:245
-#, python-format
-msgid "Processing input data (%d categories)..."
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:289
-msgid "Updating the database ..."
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:294
-msgid ""
-"Statistics calculated from raster map <{raster}> and uploaded to attribute "
-"table of vector map <{vector}>."
-msgstr ""
-#: ../scripts/v.rast.stats/v.rast.stats.py:300
-#, python-format
-msgid "Failed to upload statistics to attribute table of vector map <%s>."
-msgstr ""
-#: ../scripts/d.redraw/d.redraw.py:54
-#, python-format
-msgid "Unable to open file '%s' for reading. Details: %s"
-msgstr ""
-#: ../scripts/d.redraw/d.redraw.py:64
-#, python-format
-msgid "Unable to open file '%s' for writing. Details: %s"
-msgstr ""
-#: ../scripts/d.polar/d.polar.py:190
-#, python-format
-msgid "Generating %s ..."
-msgstr ""
-#: ../scripts/d.polar/d.polar.py:423
-msgid "Please select only one output method"
-msgstr ""
-#: ../scripts/d.polar/d.polar.py:428
-msgid "xgraph required, please install first (www.xgraph.org)"
-msgstr ""
-#: ../scripts/d.polar/d.polar.py:446
-msgid "Calculating statistics for polar diagram... (be patient)"
-msgstr ""
-#: ../scripts/d.polar/d.polar.py:476
-msgid "No data pixel found"
-msgstr ""
-#: ../scripts/d.polar/d.polar.py:523
-msgid "Average vector:"
-msgstr ""
-#: ../scripts/d.polar/d.polar.py:525
-#, python-format
-msgid "direction: %.1f degrees CCW from East"
-msgstr ""
-#: ../scripts/d.polar/d.polar.py:531
-#, python-format
-msgid "magnitude: %.1f percent of fullscale"
-msgstr ""
-#: ../scripts/i.spectral/i.spectral.py:121
-#, python-format
-msgid "Programmer error (%s)"
-msgstr ""
-#: ../scripts/i.spectral/i.spectral.py:195
-msgid "Spectral signatures"
-msgstr ""
-#: ../scripts/i.spectral/i.spectral.py:196
-msgid "DN Value"
-msgstr ""
-#: ../scripts/i.spectral/i.spectral.py:213
-msgid "Either group= or raster= is required"
-msgstr ""
-#: ../scripts/i.spectral/i.spectral.py:216
-msgid "group= and raster= are mutually exclusive"
-msgstr ""
-#: ../scripts/i.spectral/i.spectral.py:220
-msgid "Writing to text file requires output=filename"
-msgstr ""
-#: ../scripts/i.spectral/i.spectral.py:224
-msgid "gnuplot required, please install first"
-msgstr ""
-#: ../scripts/i.spectral/i.spectral.py:243
-msgid "No data returned from query"
-msgstr ""
-#: ../scripts/r.blend/r.blend.py:67
-#, python-format
-msgid "Raster map <%s> already exists."
-msgstr ""
-#: ../scripts/r.blend/r.blend.py:75
-msgid "Calculating the three component maps..."
-msgstr ""
-#: ../scripts/r.blend/r.blend.py:117
-msgid "Done. Use the following command to visualize the result:"
-msgstr ""
-#: ../scripts/r.blend/r.blend.py:119
-#, python-format
-msgid "d.rgb r=%s.r g=%s.g b=%s.b"
-msgstr ""
-#: ../scripts/r.pack/r.pack.py:81
-#, python-format
-msgid "option <output>: <%s> exists."
-msgstr ""
-#: ../scripts/r.pack/r.pack.py:83
-#, python-format
-msgid "Packing <%s> to <%s>..."
-msgstr ""
-#: ../scripts/r.pack/r.pack.py:100
-msgid "No raster map components found"
-msgstr ""
-#: ../scripts/r.pack/r.pack.py:126
-#, python-format
-msgid "Raster map saved to '%s'"
-msgstr ""
-#: ../scripts/d.shade/d.shade.py:63 ../scripts/r.shade/r.shade.py:127
-#, python-format
-msgid "Module %s failed. Check the above error messages."
-msgstr ""
-#: ../scripts/v.centroids/v.centroids.py:65
-msgid "Input vector map contains no boundaries."
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:63
-msgid "'avcimport' program not found, install it first"
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:68
-msgid "'e00conv' program not found, install it first"
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:73
-msgid "Must specify one of \"point\", \"line\", or \"area\"."
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:82
-msgid "Found that E00 file is split into pieces (.e01, ...). Merging..."
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:121
-msgid "An error may appear next which will be ignored..."
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:124
-msgid "E00 ASCII found and converted to Arc Coverage in current directory"
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:128
-msgid "E00 Compressed ASCII found. Will uncompress first..."
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:131
-msgid "...converted to Arc Coverage in current directory"
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:138
-#, python-format
-msgid "Importing %ss..."
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:148
-msgid "An error occurred while running v.in.ogr"
-msgstr ""
-#: ../scripts/v.in.e00/v.in.e00.py:150
-#, python-format
-msgid "Imported <%s> vector map <%s>."
-msgstr ""
-#: ../scripts/i.tasscap/i.tasscap.py:139
-#, python-format
-msgid "Satellite %s..."
-msgstr ""
-#: ../scripts/i.tasscap/i.tasscap.py:162
-#, python-format
-msgid "The number of input raster maps (bands) should be %s"
-msgstr ""
-#: ../scripts/i.tasscap/i.tasscap.py:178
-msgid "Tasseled Cap components calculated"
-msgstr ""
-#: ../scripts/v.report/v.report.py:109
-#, python-format
-msgid ""
-"There is a table connected to input vector map '%s', but there is no key "
-"column '%s'."
-msgstr ""
-#: ../scripts/v.report/v.report.py:123
-#, python-format
-msgid ""
-"There is a table connected to input vector map '%s', but there are no "
-"categories present in the key column '%s'. Consider using v.to.db to correct"
-" this."
-msgstr ""
-#: ../scripts/r.tileset/r.tileset.py:247
-#, python-format
-msgid ""
-"It is not possible to set 'maxcols=%s' and 'overlap=%s'. Please set "
-"maxcols>overlap"
-msgstr ""
-#: ../scripts/r.tileset/r.tileset.py:251
-#, python-format
-msgid ""
-"It is not possible to set 'maxrows=%s' and 'overlap=%s'. Please set "
-"maxrows>overlap"
-msgstr ""
-#: ../scripts/r.tileset/r.tileset.py:260 ../scripts/r.tileset/r.tileset.py:271
-msgid "g.proj failed"
-msgstr ""
-#: ../scripts/r.tileset/r.tileset.py:277
-#, python-format
-msgid "Scale (%s) not found, assuming '1'"
-msgstr ""
-#: ../scripts/r.tileset/r.tileset.py:308
-msgid ""
-"There are no tiles available. Probably the output projection system it is "
-"not compatible with the projection of the current location"
-msgstr ""
-#: ../scripts/r.tileset/r.tileset.py:355
-msgid "Computing tiling..."
-msgstr ""
-#: ../scripts/r.tileset/r.tileset.py:393
-#, python-format
-msgid "During computation %i tiles could not be created"
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:99
-#: ../scripts/r.reclass.area/r.reclass.area.py:205
-msgid "xy-locations are not supported"
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:100
-msgid "Need projected data with grids in meters"
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:106
-msgid "flags c and d are mutually exclusive"
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:116
-#, python-format
-msgid "Temporary raster map <%s> exists"
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:118
-msgid "Generating a clumped raster file including diagonal neighbors..."
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:123
-msgid "Generating a clumped raster file ..."
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:127
-#, python-format
-msgid ""
-"Generating a reclass map with area size less than or equal to %f hectares..."
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:130
-#, python-format
-msgid ""
-"Generating a reclass map with area size greater than or equal to %f "
-"hectares..."
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:162
-#, python-format
-msgid "No areas of size less than or equal to %f hectares found."
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:165
-#, python-format
-msgid "No areas of size greater than or equal to %f hectares found."
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:203
-msgid "Latitude-longitude locations are not supported"
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:210
-msgid "You have to specify mode='lesser' with method='rmarea'"
-msgstr ""
-#: ../scripts/r.reclass.area/r.reclass.area.py:220
-#, python-format
-msgid "Generating output raster map <%s>..."
-msgstr ""
-#: ../scripts/v.db.univar/v.db.univar.py:80
-#, python-format
-msgid "No attribute table linked to layer <%s>"
-msgstr ""
-#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:78
-msgid "There is an empty column. Did you leave a trailing comma?"
-msgstr ""
-#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:81
-#, python-format
-msgid "Column <%s> is already in the table. Skipping."
-msgstr ""
-#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:83
-#, python-format
-msgid "Adding column <%s> to the table"
-msgstr ""
-#: ../scripts/v.db.addcolumn/v.db.addcolumn.py:89
-#, python-format
-msgid "Unable to add column <%s>."
-msgstr ""
-#: ../scripts/i.image.mosaic/i.image.mosaic.py:74
-msgid "Do not forget to set region properly to cover all images."
-msgstr ""
-#: ../scripts/i.image.mosaic/i.image.mosaic.py:86
-#, python-format
-msgid "Mosaicing %d images..."
-msgstr ""
-#: ../scripts/i.image.mosaic/i.image.mosaic.py:99
-#, python-format
-msgid "Done. Raster map <%s> created."
-msgstr ""
-#: ../scripts/v.in.lines/v.in.lines.py:114
-msgid "Not enough data columns. (incorrect fs setting?)"
-msgstr ""
-#: ../scripts/db.univar/db.univar.py:83
-msgid "'sort' not found: sorting in memory"
-msgstr ""
-#: ../scripts/db.univar/db.univar.py:123
-#, python-format
-msgid "Calculation for column <%s> of table <%s>..."
-msgstr ""
-#: ../scripts/db.univar/db.univar.py:125
-msgid "Reading column values..."
-msgstr ""
-#: ../scripts/db.univar/db.univar.py:146
-#, python-format
-msgid "Table <%s> contains no data."
-msgstr ""
-#: ../scripts/db.univar/db.univar.py:151
-msgid "Calculating statistics..."
-msgstr ""
-#: ../scripts/db.univar/db.univar.py:174
-msgid "No non-null values found"
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:101
-msgid "Either parameter <raster> or parameter <vector> is required"
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:115
-msgid "Raster MASK removed"
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:117
-msgid "No existing MASK to remove"
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:122
-msgid "MASK already found in current mapset. Delete first or overwrite."
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:124
-msgid "MASK already exists and will be overwritten"
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:135
-#, python-format
-msgid ""
-"The raster map <%s> must be integer (CELL type)  in order to use the "
-"'maskcats' parameter"
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:159
-#, python-format
-msgid "No area found in vector map <%s>. Creating a convex hull for MASK."
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:171
-#, python-format
-msgid "Unable to create a convex hull for vector map <%s>"
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:187
-msgid "Creating inverted raster MASK..."
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:189
-msgid "Inverted raster MASK created"
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:191
-msgid "Raster MASK created"
-msgstr ""
-#: ../scripts/r.mask/r.mask.py:193
-msgid ""
-"All subsequent raster operations will be limited to the MASK area. Removing "
-"or renaming raster map named 'MASK' will restore raster operations to "
-"normal."
-msgstr ""
-#: ../scripts/v.import/v.import.py:159
-#, python-format
-msgid "Missing value for parameter <%s>"
-msgstr ""
-#: ../scripts/v.import/v.import.py:178 ../scripts/r.import/r.import.py:193
-#, python-format
-msgid "Input <%s> successfully imported without reprojection"
-msgstr ""
-#: ../scripts/v.import/v.import.py:182
-#, python-format
-msgid "Unable to import <%s>"
-msgstr ""
-#: ../scripts/v.import/v.import.py:190 ../scripts/r.import/r.import.py:205
-#, python-format
-msgid "Coordinate reference system not available for current location <%s>"
-msgstr ""
-#: ../scripts/v.import/v.import.py:210 ../scripts/r.import/r.import.py:225
-#, python-format
-msgid "Creating temporary location for <%s>..."
-msgstr ""
-#: ../scripts/v.import/v.import.py:215
-#, python-format
-msgid "Unable to create location from OGR datasource <%s>"
-msgstr ""
-#: ../scripts/v.import/v.import.py:231 ../scripts/r.import/r.import.py:244
-#, python-format
-msgid "Coordinate reference system not available for input <%s>"
-msgstr ""
-#: ../scripts/v.import/v.import.py:248 ../scripts/r.import/r.import.py:327
-msgid "Unable to reproject to source location"
-msgstr ""
-#: ../scripts/v.import/v.import.py:255
-#, python-format
-msgid "Importing <%s> ..."
-msgstr ""
-#: ../scripts/v.import/v.import.py:260
-#, python-format
-msgid "Unable to import OGR datasource <%s>"
-msgstr ""
-#: ../scripts/v.import/v.import.py:279 ../scripts/r.import/r.import.py:373
-#, python-format
-msgid "Reprojecting <%s>..."
-msgstr ""
-#: ../scripts/v.import/v.import.py:284
-#, python-format
-msgid "Unable to to reproject vector <%s>"
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:98
-#, python-format
-msgid ""
-"Target database doesn't exist, creating a new database using <%s> driver..."
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:104
-#, python-format
-msgid "Unable to create database <%s> by driver <%s>"
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:141
-#, python-format
-msgid "Unable to disconnect table <%s> from vector <%s>"
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:149
-#, python-format
-msgid "Unable to drop table <%s>"
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:158
-#, python-format
-msgid "Creating index <%s>..."
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:165
-#, python-format
-msgid "Unable to create index <%s>"
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:196
-msgid "Old and new database connection is identical. Nothing to do."
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:212
-#, python-format
-msgid ""
-"%s\n"
-"Reconnecting vector map <%s> (%d of %d)...\n"
-"%s"
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:249
-#, python-format
-msgid "Reconnecting layer %d..."
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:274
-#, python-format
-msgid "Unable to connect table <%s> to vector <%s> on layer <%s>"
-msgstr ""
-#: ../scripts/v.db.reconnect.all/v.db.reconnect.all.py:280
-#, python-format
-msgid ""
-"Layer <%d> will not be reconnected because database or schema do not match."
-msgstr ""
-#: ../scripts/db.test/db.test.py:48
-#, python-format
-msgid "Using DB driver: %s"
-msgstr ""
-#: ../scripts/db.test/db.test.py:75
-msgid "EXECUTE: OK"
-msgstr ""
-#: ../scripts/db.test/db.test.py:89
-msgid "RESULT: OK"
-msgstr ""
-#: ../scripts/v.db.dropcolumn/v.db.dropcolumn.py:70
-msgid ""
-"There is no table connected to the input vector map. Unable to delete any "
-"column. Exiting."
-msgstr ""
-#: ../scripts/v.db.dropcolumn/v.db.dropcolumn.py:74
-#, python-format
-msgid ""
-"Unable to delete <%s> column as it is needed to keep table <%s> connected to"
-" the input vector map <%s>"
-msgstr ""
-#: ../scripts/v.db.dropcolumn/v.db.dropcolumn.py:80
-#, python-format
-msgid "Column <%s> not found in table <%s>. Skipped"
-msgstr ""
-#: ../scripts/v.db.dropcolumn/v.db.dropcolumn.py:122
-msgid "Deleting column failed"
-msgstr ""
-#: ../scripts/g.extension.all/g.extension.all.py:58
-#, python-format
-msgid "%s not defined"
-msgstr ""
-#: ../scripts/g.extension.all/g.extension.all.py:68
-#, python-format
-msgid "Unable to parse metadata file: %s"
-msgstr ""
-#: ../scripts/g.extension.all/g.extension.all.py:97
-msgid "No extension found. Nothing to remove."
-msgstr ""
-#: ../scripts/g.extension.all/g.extension.all.py:100
-msgid "Nothing to rebuild. Rebuilding process can be forced with -f flag."
-msgstr ""
-#: ../scripts/g.extension.all/g.extension.all.py:104
-msgid "List of extensions to be removed:"
-msgstr ""
-#: ../scripts/g.extension.all/g.extension.all.py:107
-msgid "You must use the force flag (-f) to actually remove them. Exiting."
-msgstr ""
-#: ../scripts/g.extension.all/g.extension.all.py:113
-#, python-format
-msgid "Removing extension <%s>..."
-msgstr ""
-#: ../scripts/g.extension.all/g.extension.all.py:115
-#, python-format
-msgid "Reinstalling extension <%s>..."
-msgstr ""
-#: ../scripts/g.extension.all/g.extension.all.py:127
-#, python-format
-msgid "Unable to process extension:%s"
-msgstr ""
-#: ../scripts/db.dropcolumn/db.dropcolumn.py:64
-#: ../scripts/db.droptable/db.droptable.py:74
-msgid "Forcing ..."
-msgstr ""
-#: ../scripts/db.dropcolumn/db.dropcolumn.py:67
-#, python-format
-msgid ""
-"Deleting <%s> column which may be needed to keep table connected to a vector"
-" map"
-msgstr ""
-#: ../scripts/db.dropcolumn/db.dropcolumn.py:72
-#, python-format
-msgid "Column <%s> not found in table"
-msgstr ""
-#: ../scripts/db.dropcolumn/db.dropcolumn.py:75
-#, python-format
-msgid "Column <%s> would be deleted."
-msgstr ""
-#: ../scripts/db.dropcolumn/db.dropcolumn.py:77
-msgid "You must use the force flag (-f) to actually remove it. Exiting."
-msgstr ""
-#: ../scripts/db.dropcolumn/db.dropcolumn.py:113
-msgid "Cannot continue (problem deleting column)"
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:144
-msgid "This module only operates in LatLong locations"
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:162
-msgid "The \"unzip\" program is required, please install it first"
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:169
-#, python-format
-msgid "'%s' does not appear to be a valid zip file."
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:176
-#, python-format
-msgid "File '%s' or '%s' not found"
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:198
-#, python-format
-msgid "Extracting '%s'..."
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:200
-msgid "Unable to unzip file."
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:202
-msgid "Converting input file to BIL..."
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:226
-msgid "Attempting to import 1-arcsec data."
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:244
-msgid "Unable to import data"
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:252
-msgid "Done: generated map "
-msgstr ""
-#: ../scripts/r.in.srtm/r.in.srtm.py:253
-msgid ""
-"(Note: Holes in the data can be closed with 'r.fillnulls' using splines)"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:162
-msgid "A user raster mask (MASK) is present. Saving it..."
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:177
-msgid "Using RST interpolation..."
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:178
-msgid "Locating and isolating NULL areas..."
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:182
-msgid "Skipping masked raster parts"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:193
-#: ../scripts/r.fillnulls/r.fillnulls.py:462
-msgid "Restoring user mask (MASK)..."
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:197
-#: ../scripts/r.fillnulls/r.fillnulls.py:466
-msgid "Failed to restore user MASK!"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:201
-msgid "Growing NULL areas"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:208
-#: ../scripts/r.fillnulls/r.fillnulls.py:223
-#: ../scripts/r.fillnulls/r.fillnulls.py:317
-msgid "abandoned. Removing temporary map, restoring user mask if needed:"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:212
-msgid "Assigning IDs to NULL areas"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:237
-#: ../scripts/r.fillnulls/r.fillnulls.py:275
-#: ../scripts/r.fillnulls/r.fillnulls.py:290
-#: ../scripts/r.fillnulls/r.fillnulls.py:298
-#: ../scripts/r.fillnulls/r.fillnulls.py:332
-#: ../scripts/r.fillnulls/r.fillnulls.py:405
-#: ../scripts/r.fillnulls/r.fillnulls.py:426
-#: ../scripts/r.fillnulls/r.fillnulls.py:436
-msgid "abandoned. Removing temporary maps, restoring user mask if needed:"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:258
-msgid "Input map has no holes. Check region settings."
-msgstr ""
-#. GTC Hole is NULL area in a raster map
-#: ../scripts/r.fillnulls/r.fillnulls.py:261
-#, python-format
-msgid "Processing %d map holes"
-msgstr ""
-#. GTC Hole is a NULL area in a raster map
-#: ../scripts/r.fillnulls/r.fillnulls.py:267
-#, python-format
-msgid "Filling hole %s of %s"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:337
-#, python-format
-msgid "Interpolating %d points"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:340
-msgid "No points to interpolate"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:361
-#, python-format
-msgid "Failed to fill hole %s"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:375
-#, python-format
-msgid ""
-"Filling has failed silently. Leaving temporary maps with prefix <%s> for "
-"debugging."
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:440
-#, python-format
-msgid "Using %s bspline interpolation"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:474
-msgid "Patching fill data into NULL areas..."
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:482
-#, python-format
-msgid "Filled raster map is: %s"
-msgstr ""
-#: ../scripts/r.fillnulls/r.fillnulls.py:489
-msgid ""
-"Following holes where not filled. Temporary maps with are left in place to "
-"allow examination of unfilled holes"
-msgstr ""
-#: ../scripts/v.in.mapgen/v.in.mapgen.py:80
-#, python-format
-msgid "Input file <%s> not found"
-msgstr ""
-#: ../scripts/v.in.mapgen/v.in.mapgen.py:101
-#: ../scripts/v.in.wfs/v.in.wfs.py:159
-msgid "Importing data..."
-msgstr ""
-#: ../scripts/v.in.mapgen/v.in.mapgen.py:137
-#, python-format
-msgid "An error occurred on line '%s', exiting."
-msgstr ""
-#: ../scripts/v.in.mapgen/v.in.mapgen.py:202
-msgid "Importing with v.in.ascii..."
-msgstr ""
-#: ../scripts/v.in.mapgen/v.in.mapgen.py:207
-#, python-format
-msgid "An error occurred on creating \"%s\", please check"
-msgstr ""
-#: ../scripts/g.search.modules/g.search.modules.py:175
-msgid "Cannot colorize, python-termcolor is not installed"
-msgstr ""
-#: ../scripts/v.db.join/v.db.join.py:91
-msgid "JOIN is not supported for tables stored in DBF format"
-msgstr ""
-#: ../scripts/v.db.join/v.db.join.py:94
-msgid "There is no table connected to this map. Unable to join any column."
-msgstr ""
-#: ../scripts/v.db.join/v.db.join.py:159
-#, python-format
-msgid "Error creating column <%s>"
-msgstr ""
-#: ../scripts/v.db.join/v.db.join.py:166
-#, python-format
-msgid "Updating column <%s> of vector map <%s>..."
-msgstr ""
-#: ../scripts/v.db.join/v.db.join.py:172
-#, python-format
-msgid "Error filling column <%s>"
-msgstr ""
-#: ../scripts/g.manual/g.manual.py:72
-#, python-format
-msgid "Browser '%s' not found"
-msgstr ""
-#: ../scripts/g.manual/g.manual.py:86
-#, python-format
-msgid "No HTML manual page entry for '%s'"
-msgstr ""
-#: ../scripts/g.manual/g.manual.py:93
-#, python-format
-msgid "Starting browser '%(browser)s' for manual entry '%(entry)s'..."
-msgstr ""
-#: ../scripts/g.manual/g.manual.py:100
-#, python-format
-msgid "Error starting browser '%(browser)s' for HTML file '%(path)s'"
-msgstr ""
-#: ../scripts/g.manual/g.manual.py:112
-#, python-format
-msgid "Error starting 'man' for '%s'"
-msgstr ""
-#: ../scripts/g.manual/g.manual.py:113
-#, python-format
-msgid "No manual page entry for '%s'"
-msgstr ""
-#: ../scripts/g.manual/g.manual.py:120
-#, python-format
-msgid "Flags -%c and -%c are mutually exclusive"
-msgstr ""
-#: ../scripts/v.dissolve/v.dissolve.py:72
-#, python-format
-msgid ""
-"No '%s' option specified. Dissolving based on category values from layer "
-"<%s>."
-msgstr ""
-#: ../scripts/v.dissolve/v.dissolve.py:78
-#, python-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s' specified, assuming layer '1'."
-msgstr ""
-#: ../scripts/v.dissolve/v.dissolve.py:88
-msgid "Key column must be of type integer or string"
-msgstr ""
-#: ../scripts/v.dissolve/v.dissolve.py:102
-#, python-format
-msgid ""
-"Final extraction steps failed. Check above error messages and see following details:\n"
-"%s"
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:69
-msgid "File {name} not found."
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:82 ../scripts/r.unpack/r.unpack.py:120
-#: ../scripts/v.unpack/v.unpack.py:85 ../scripts/v.unpack/v.unpack.py:132
-msgid "Pack file unreadable"
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:91 ../scripts/v.unpack/v.unpack.py:94
-msgid "Pack file unreadable: file '{}' missing"
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:104
-msgid "Raster map <{name}> already exists"
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:107
-msgid "Raster map <{name}> already exists and will be overwritten"
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:117
-msgid ""
-"This GRASS GIS pack file contains vector data. Use v.unpack to unpack "
-"<{name}>"
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:125
-msgid "Overriding projection check (using current location's projection)."
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:138
-msgid ""
-"PROJ_INFO file is missing, unpack raster map in XY (unprojected) location."
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:158 ../scripts/v.unpack/v.unpack.py:163
-msgid ""
-"Difference between PROJ_INFO file of packed map and of current location:\n"
-"{diff}"
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:161 ../scripts/v.unpack/v.unpack.py:166
-msgid ""
-"Difference between PROJ_UNITS file of packed map and of current location:\n"
-"{diff}"
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:163 ../scripts/v.unpack/v.unpack.py:168
-msgid ""
-"Projection of dataset does not appear to match current location. In case of "
-"no significant differences in the projection definitions, use the -o flag to"
-" ignore them and use current location definition."
-msgstr ""
-#: ../scripts/r.unpack/r.unpack.py:183
-msgid "Raster map <{name}> unpacked"
-msgstr ""
-#: ../scripts/r.import/r.import.py:169
-msgid "To set custom resolution value, select 'value' in resolution option"
-msgstr ""
-#: ../scripts/r.import/r.import.py:172
-msgid "Resolution value can't be smaller than 0"
-msgstr ""
-#: ../scripts/r.import/r.import.py:175
-msgid ""
-"Please provide the resolution for the imported dataset or change to "
-"'estimated' resolution"
-msgstr ""
-#: ../scripts/r.import/r.import.py:197 ../scripts/r.import/r.import.py:255
-#, python-format
-msgid "Unable to import GDAL dataset <%s>"
-msgstr ""
-#: ../scripts/r.import/r.import.py:234
-#, python-format
-msgid "Unable to read GDAL dataset <%s>"
-msgstr ""
-#: ../scripts/r.import/r.import.py:247
-#, python-format
-msgid "Importing <%s> to temporary location..."
-msgstr ""
-#: ../scripts/r.import/r.import.py:266
-msgid "Input contains GCPs, rectification is required"
-msgstr ""
-#: ../scripts/r.import/r.import.py:294
-msgid "Unable to get reprojected map extent"
-msgstr ""
-#: ../scripts/r.import/r.import.py:347
-msgid "Estimated target resolution for input band <{out}>: {res}"
-msgstr ""
-#: ../scripts/r.import/r.import.py:362
-msgid "Using given resolution for input band <{out}>: {res}"
-msgstr ""
-#: ../scripts/r.import/r.import.py:368
-msgid ""
-"Using current region resolution for input band <{out}>: nsres={ns}, "
-"ewres={ew}"
-msgstr ""
-#: ../scripts/r.import/r.import.py:380
-#, python-format
-msgid "Unable to to reproject raster <%s>"
-msgstr ""
-#: ../scripts/r.import/r.import.py:383
-#, python-format
-msgid "The reprojected raster <%s> is empty"
-msgstr ""
-#: ../scripts/r.grow/r.grow.py:130
-msgid "Growing failed. Removing temporary maps."
-msgstr ""
-#: ../scripts/r.grow/r.grow.py:142
-msgid "Shrinking failed. Removing temporary maps."
-msgstr ""
-#: ../scripts/r3.in.xyz/r3.in.xyz.py:247
-msgid "The 2D and 3D region settings are different. Can not continue."
-msgstr ""
-#: ../scripts/r3.in.xyz/r3.in.xyz.py:249
-#, python-format
-msgid "Region bottom=%.15g  top=%.15g  vertical_cell_res=%.15g  (%d depths)"
-msgstr ""
-#: ../scripts/r3.in.xyz/r3.in.xyz.py:252
-msgid "Creating slices ..."
-msgstr ""
-#: ../scripts/r3.in.xyz/r3.in.xyz.py:281
-#, python-format
-msgid "Processing horizontal slice %d of %d [%.15g,%.15g) ..."
-msgstr ""
-#: ../scripts/r3.in.xyz/r3.in.xyz.py:298 ../scripts/r3.in.xyz/r3.in.xyz.py:304
-msgid "Trouble importing data. Aborting."
-msgstr ""
-#: ../scripts/r3.in.xyz/r3.in.xyz.py:308
-msgid "Assembling 3D cube ..."
-msgstr ""
-#: ../scripts/r3.in.xyz/r3.in.xyz.py:318
-#, python-format
-msgid "Done. 3D raster map <%s> created."
-msgstr ""
-#. GTC Invalid WFS maximum features parameter
-#: ../scripts/v.in.wfs/v.in.wfs.py:109
-msgid "Invalid maximum number of features"
-msgstr ""
-#. GTC Invalid WFS start index parameter
-#: ../scripts/v.in.wfs/v.in.wfs.py:115
-msgid "Features begin with index \"1\""
-msgstr ""
-#. GTC Downloading WFS features
-#: ../scripts/v.in.wfs/v.in.wfs.py:130
-msgid "Retrieving data..."
-msgstr ""
-#. GTC WFS request HTTP failure
-#: ../scripts/v.in.wfs/v.in.wfs.py:135
-#, python-format
-msgid ""
-"The server couldn't fulfill the request.\n"
-"Error code: %s"
-msgstr ""
-#. GTC WFS request network failure
-#: ../scripts/v.in.wfs/v.in.wfs.py:138
-#, python-format
-msgid ""
-"Failed to reach the server.\n"
-"Reason: %s"
-msgstr ""
-#: ../scripts/v.in.wfs/v.in.wfs.py:153
-msgid "A file called \"wms_capabilities.xml\" already exists here"
-msgstr ""
-#: ../scripts/v.in.wfs/v.in.wfs.py:162
-#, python-format
-msgid "Vector map <%s> imported from WFS."
-msgstr ""
-#: ../scripts/v.in.wfs/v.in.wfs.py:164
-msgid "WFS import failed"
-msgstr ""
-#: ../scripts/v.unpack/v.unpack.py:129
-#, python-format
-msgid ""
-"This GRASS GIS pack file contains raster data. Use r.unpack to unpack <%s>"
-msgstr ""
-#: ../scripts/v.unpack/v.unpack.py:142
-msgid ""
-"PROJ_INFO file is missing, unpack vector map in XY (unprojected) location."
-msgstr ""
-#: ../scripts/v.unpack/v.unpack.py:160
-msgid "Projection information does not match. Proceeding..."
-msgstr ""
-#: ../scripts/v.unpack/v.unpack.py:214
-#, python-format
-msgid "Coping table <%s> as table <%s>"
-msgstr ""
-#: ../scripts/v.unpack/v.unpack.py:225
-#, python-format
-msgid "Unable to copy table <%s> as table <%s>"
-msgstr ""
-#: ../scripts/v.unpack/v.unpack.py:227
-#, python-format
-msgid "Connect table <%s> to vector map <%s> at layer <%s>"
-msgstr ""
-#: ../scripts/v.unpack/v.unpack.py:237
-#, python-format
-msgid "Unable to connect table <%s> to vector map <%s>"
-msgstr ""
-#: ../scripts/v.unpack/v.unpack.py:240
-#, python-format
-msgid "Vector map <%s> successfully unpacked"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:142
-msgid ""
-"cs2cs program not found, install PROJ.4 first:             "
-"http://proj.maptools.org"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:147
-msgid "Choose only one input parameter method"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:150
-msgid "Choose only one output parameter method"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:153
-msgid "Choose only one auto-projection parameter method"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:156
-msgid "Output file already exists"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:159
-msgid "One of <coordinates> and <input> must be given"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:162
-msgid "Options <coordinates> and <input> are mutually exclusive"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:181
-msgid "Unable to project to or from a XY location"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:197
-msgid "Invalid PROJ.4 input specification"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:220
-msgid "Invalid PROJ.4 output specification"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:223
-msgid "Missing output projection parameters "
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:242
-msgid "Unable to read input data"
-msgstr ""
-#: ../scripts/m.proj/m.proj.py:304
-msgid "Projection transform probably failed, please investigate"
-msgstr ""
-#: ../scripts/v.what.strds/v.what.strds.py:113
-msgid "Cannot combine 'output' option and 'u' flag"
-msgstr ""
-#: ../scripts/v.what.strds/v.what.strds.py:115
-msgid "'output' option or 'u' flag must be given"
-msgstr ""
-#: ../scripts/v.what.strds/v.what.strds.py:117
-msgid "Attribute table of vector {name} will be updated..."
-msgstr ""
-#: ../scripts/v.what.strds/v.what.strds.py:150
-#, python-format
-msgid "Space time raster dataset <%s> is empty"
-msgstr ""
-#: ../scripts/v.what.strds/v.what.strds.py:164
-#, python-format
-msgid ""
-"Temporal type of space time raster datasets must be equal\n"
-"<%(a)s> of type %(type_a)s do not match <%(b)s> of type %(type_b)s"
-msgstr ""
-#: ../scripts/v.what.strds/v.what.strds.py:225
-#, python-format
-msgid "Unable to add table <%s> to vector map <%s>"
-msgstr ""
-#: ../scripts/v.what.strds/v.what.strds.py:250
-#, python-format
-msgid "Unable to add column %s to vector map <%s> "
-msgstr ""
-#: ../scripts/v.what.strds/v.what.strds.py:258
-#, python-format
-msgid "Unable to run v.what.rast for vector map <%s> and raster map <%s>"
-msgstr ""
-#: ../scripts/v.build.all/v.build.all.py:47
-#, python-format
-msgid ""
-"%s\n"
-"Building topology for vector map <%s> (%d of %d)...\n"
-"%s"
-msgstr ""
-#: ../scripts/v.build.all/v.build.all.py:49
-#, python-format
-msgid "v.build map=%s"
-msgstr ""
-#: ../scripts/v.build.all/v.build.all.py:53
-#, python-format
-msgid "Building topology for vector map <%s> failed"
-msgstr ""
-#: ../scripts/db.droptable/db.droptable.py:78
-#, python-format
-msgid "Table <%s> not found in database <%s>"
-msgstr ""
-#: ../scripts/db.droptable/db.droptable.py:85
-#, python-format
-msgid "Deleting table <%s> which is attached to following map(s):"
-msgstr ""
-#: ../scripts/db.droptable/db.droptable.py:90
-#, python-format
-msgid "The table <%s> would be deleted."
-msgstr ""
-#: ../scripts/db.droptable/db.droptable.py:92
-msgid "You must use the force flag to actually remove it. Exiting."
-msgstr ""
-#: ../scripts/db.droptable/db.droptable.py:101
-msgid "Cannot continue (problem deleting table)."
-msgstr ""
-#: ../scripts/v.clip/v.clip.py:73
-#, python-format
-msgid ""
-"Deleting of temporary layer failed. Check above error messages and see following details:\n"
-"%s"
-msgstr ""
-#: ../scripts/v.clip/v.clip.py:180 ../scripts/v.clip/v.clip.py:191
-#, python-format
-msgid ""
-"Clipping steps failed. Check above error messages and see following details:\n"
-"%s"
-msgstr ""
-#: ../scripts/r.mapcalc.simple/r.mapcalc.simple.py:107
-msgid "The expression is an empty string"
-msgstr ""
-#: ../scripts/r.mapcalc.simple/r.mapcalc.simple.py:141
-msgid "Expression: {}"
-msgstr ""
Deleted: grass/trunk/locale/po/grasswxpy_zh_CN.po
--- grass/trunk/locale/po/grasswxpy_zh_CN.po	2019-04-19 08:33:13 UTC (rev 74403)
+++ grass/trunk/locale/po/grasswxpy_zh_CN.po	2019-04-19 15:20:06 UTC (rev 74404)
@@ -1,20857 +0,0 @@
-# Translation of grasswxpy_zh_CN.po
-# Copyright (C) 2017 GRASS Development Team
-# This file is distributed under the same license as the GRASS GIS package.
-# transifex generated, 2017
-#, fuzzy
-msgid ""
-msgstr ""
-"Project-Id-Version: grasslibs_zh_CN\n"
-"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2019-03-02 23:14-0800\n"
-"PO-Revision-Date: 2017-01-25 08:24+0000\n"
-"Language-Team: Chinese (China) (https://www.transifex.com/grass-gis/teams/45198/zh_CN/)\n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
-"Language: zh_CN\n"
-"Plural-Forms: nplurals=1; plural=0;\n"
-#: ../gui/wxpython/psmap/frame.py:54
-msgid "GRASS GIS Cartographic Composer"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:214
-msgid ""
-"Python Imaging Library is not available.\n"
-"'Preview' functionality won't work."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:268
-msgid ""
-"Program ps2pdf is not available. Please install it first to create PDF."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:312
-msgid "Generating PDF..."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:314
-msgid "Generating PostScript..."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:316
-msgid "Generating preview..."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:333
-#, python-format
-msgid "Ps.map exited with return code %s"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:369
-#, python-format
-msgid "%(prg)s exited with return code %(code)s"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:373
-msgid "PDF generated"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:376
-#, python-format
-msgid ""
-"Program ps2pdf is not available. Please install it to create PDF.\n"
-"\n"
-" %s"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:379
-msgid "PostScript file generated"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:388
-msgid "Generating preview, wait please"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:404
-msgid "Preview not available"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:406
-msgid ""
-"Preview is not available probably because Ghostscript is not installed or "
-"not on PATH."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:409
-msgid "Please follow instructions on GRASS Trac Wiki."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:420
-msgid "Preview generated"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:452
-msgid "Save file as"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:499
-#, python-format
-msgid "Failed to read file %s."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:636 ../gui/wxpython/psmap/frame.py:661
-#: ../gui/wxpython/psmap/dialogs.py:1637
-msgid "Please, create map frame first."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:678
-msgid "Scalebar is not appropriate for this projection"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1167
-msgid "Press button with green triangle icon to generate preview."
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1190
-msgid "wxGUI Cartographic Composer"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1241
-msgid "MAP FRAME"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1242
-msgid "RASTER LEGEND"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1243
-msgid "VECTOR LEGEND"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1244
-msgid "MAP INFO"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1245
-msgid "SCALE BAR"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1246
-msgid "IMAGE"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1247
-msgid "NORTH ARROW"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:1523
-msgid "Click and drag to resize object"
-msgstr ""
-#: ../gui/wxpython/psmap/frame.py:2474
-msgid "labels: "
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:105
-msgid "inch"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:106 ../gui/wxpython/modules/vclean.py:222
-msgid "point"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:107
-msgid "centimeter"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:108
-msgid "millimeter"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:112
-msgid "meters"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:115
-msgid "kilometers"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:118
-msgid "feet"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:121
-msgid "miles"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:124 ../gui/wxpython/psmap/utils.py:128
-msgid "nautical miles"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:126
-msgid "pixel"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:127
-msgid "meter"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:130
-msgid "degree"
-msgstr ""
-#: ../gui/wxpython/psmap/utils.py:397
-msgid "Unable to run `ps.map -b`"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:139
-#, python-format
-msgid ""
-"Unable to open file\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:498
-#, python-format
-msgid "Instruction file will be loaded with following region: %s\n"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:504
-#, python-format
-msgid ""
-"Region cannot be set\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:664
-#: ../gui/wxpython/psmap/instructions.py:863
-#: ../gui/wxpython/psmap/instructions.py:996
-#: ../gui/wxpython/psmap/instructions.py:1074
-#: ../gui/wxpython/psmap/instructions.py:1248
-#: ../gui/wxpython/psmap/instructions.py:1315
-#: ../gui/wxpython/psmap/instructions.py:1382
-#: ../gui/wxpython/psmap/instructions.py:1466
-#: ../gui/wxpython/psmap/instructions.py:1588
-#: ../gui/wxpython/psmap/instructions.py:1733
-#: ../gui/wxpython/psmap/instructions.py:1787
-#: ../gui/wxpython/psmap/instructions.py:2158
-#, python-format
-msgid "Failed to read instruction %s"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:679
-#, python-format
-msgid ""
-"Scale has changed, old value: %(old)s\n"
-"new value: %(new)s"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:683
-#, python-format
-msgid ""
-"Failed to read instruction %s.\n"
-"Use 1:25000 notation."
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:693
-#, python-format
-msgid ""
-"Map frame position changed, old value: %(old1)s %(old2)s\n"
-"new value: %(new1)s %(new2)s"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:704
-#, python-format
-msgid ""
-"Map frame size changed, old value: %(old1)s %(old2)s\n"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:771
-#, python-format
-msgid ""
-"Failed to read instruction %(file)s.\n"
-"Unknown format %(for)s"
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:786
-#, python-format
-msgid "Failed to read instruction %s."
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:936
-#: ../gui/wxpython/psmap/instructions.py:2006
-#, python-format
-msgid ""
-"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding"
-" which is required by module ps.map."
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:940
-#: ../gui/wxpython/psmap/instructions.py:2010
-msgid ""
-"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
-"required by module ps.map."
-msgstr ""
-#: ../gui/wxpython/psmap/instructions.py:1077
-#, python-format
-msgid "Failed to read instruction %(inst)s: file %(file)s not found."
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:68
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2028
-#: ../gui/wxpython/menustrings.py:2062
-msgid "Generate text file with mapping instructions"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:70
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2026
-#: ../gui/wxpython/menustrings.py:2060
-msgid "Load text file with mapping instructions"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:72
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2030
-#: ../gui/wxpython/menustrings.py:2064
-msgid "Generate PostScript output"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:74
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2032
-#: ../gui/wxpython/menustrings.py:2066
-msgid "Generate PDF output"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:76 ../gui/wxpython/gcp/mapdisplay.py:426
-#: ../gui/wxpython/mapdisp/frame.py:811
-#: ../gui/wxpython/modules/histogram.py:501 ../gui/wxpython/wxplot/base.py:610
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:425
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:426
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2023
-#: ../gui/wxpython/menustrings.py:2057
-msgid "Page setup"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:77
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2024
-#: ../gui/wxpython/menustrings.py:2058
-msgid "Specify paper size, margins and orientation"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:79
-msgid "Full extent"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:80
-msgid "Zoom to full extent"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:82 ../gui/wxpython/psmap/dialogs.py:835
-#: ../gui/wxpython/psmap/dialogs.py:889
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2038
-#: ../gui/wxpython/menustrings.py:2072
-msgid "Map frame"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:83
-msgid "Click and drag to place map frame"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:85
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2057
-#: ../gui/wxpython/menustrings.py:2091
-msgid "Delete selected object"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:87
-msgid "Show preview"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:89
-msgid "Quit Cartographic Composer"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:91 ../gui/wxpython/psmap/dialogs.py:5187
-#: ../gui/wxpython/psmap/dialogs.py:5196
-#: ../gui/wxpython/animation/dialogs.py:1537
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2050
-#: ../gui/wxpython/menustrings.py:2084
-msgid "Text"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:93
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2046
-#: ../gui/wxpython/menustrings.py:2080
-msgid "Map info"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:95 ../gui/wxpython/wxplot/dialogs.py:1087
-#: ../gui/wxpython/wxplot/dialogs.py:1150
-#: ../gui/wxpython/wxplot/dialogs.py:1231
-msgid "Legend"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:97 ../gui/wxpython/nviz/tools.py:2381
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2048
-#: ../gui/wxpython/menustrings.py:2082
-msgid "Scale bar"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:99 ../gui/wxpython/psmap/dialogs.py:5722
-#: ../gui/wxpython/psmap/dialogs.py:5784
-#: ../gui/wxpython/animation/dialogs.py:1536
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2052
-#: ../gui/wxpython/menustrings.py:2086
-msgid "Image"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:101 ../gui/wxpython/psmap/dialogs.py:6246
-#: ../gui/wxpython/nviz/tools.py:2332
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2054
-#: ../gui/wxpython/menustrings.py:2088
-msgid "North Arrow"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:103 ../gui/wxpython/psmap/dialogs.py:6281
-#: ../gui/wxpython/gui_core/gselect.py:2331
-#: ../gui/wxpython/vdigit/preferences.py:800
-msgid "Point"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:105
-#: ../gui/wxpython/vdigit/preferences.py:801
-msgid "Line"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:107
-#: ../gui/wxpython/rlisetup/wizard.py:1187
-#: ../gui/wxpython/rlisetup/wizard.py:1360
-#: ../gui/wxpython/rlisetup/wizard.py:1450
-msgid "Rectangle"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:109
-msgid "Add overlays"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:111 ../gui/wxpython/lmgr/layertree.py:104
-msgid "Add labels"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:203
-msgid "Add simple graphics: points"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:219
-msgid "Add simple graphics: lines"
-msgstr ""
-#: ../gui/wxpython/psmap/toolbars.py:235
-msgid "Add simple graphics: rectangles"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:233
-msgid "Units:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:244
-msgid ""
-"Position of the top left corner\n"
-"from the top left edge of the paper"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:246
-#: ../gui/wxpython/animation/dialogs.py:1137
-msgid "X:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:248
-#: ../gui/wxpython/animation/dialogs.py:1139
-msgid "Y:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:273
-msgid "Position is given:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:275
-msgid "relative to paper"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:277
-msgid "by map coordinates"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:307
-msgid ""
-"Position from the top left\n"
-"edge of the paper"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:398
-msgid "Font:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:400 ../gui/wxpython/psmap/dialogs.py:4981
-#: ../gui/wxpython/gui_core/dialogs.py:2474
-msgid "Font size:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:426
-msgid "Choose color:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:475
-msgid "Close dialog and apply changes"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:477
-#: ../gui/wxpython/gui_core/preferences.py:103
-#: ../gui/wxpython/gmodeler/preferences.py:696
-#: ../gui/wxpython/vdigit/preferences.py:70
-#: ../gui/wxpython/wxplot/dialogs.py:838
-#: ../gui/wxpython/wxplot/dialogs.py:1433
-msgid "Close dialog and ignore changes"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:481
-#: ../gui/wxpython/web_services/dialogs.py:685
-#: ../gui/wxpython/vdigit/dialogs.py:151
-msgid "Apply changes"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:526
-msgid "Units"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:527
-#: ../gui/wxpython/animation/dialogs.py:926
-msgid "Format"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:528
-msgid "Orientation"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:529 ../gui/wxpython/psmap/dialogs.py:2890
-msgid "Width"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:530
-msgid "Height"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:531
-msgid "Left"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:532
-msgid "Right"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:533
-#: ../gui/wxpython/location_wizard/dialogs.py:276
-msgid "Top"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:534
-#: ../gui/wxpython/location_wizard/dialogs.py:284
-msgid "Bottom"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:596
-msgid "Literal is not allowed!"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:597 ../gui/wxpython/psmap/dialogs.py:1423
-#: ../gui/wxpython/psmap/dialogs.py:1447 ../gui/wxpython/psmap/dialogs.py:1498
-#: ../gui/wxpython/psmap/dialogs.py:5106
-#: ../gui/wxpython/animation/dialogs.py:743
-#: ../gui/wxpython/animation/controller.py:295
-#: ../gui/wxpython/wxplot/dialogs.py:602
-msgid "Invalid input"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:610
-msgid "Page size"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:614
-msgid "Margins"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:621
-msgid "Portrait"
-msgstr ""
-msgid "Landscape"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:704 ../gui/wxpython/psmap/dialogs.py:725
-#: ../gui/wxpython/location_wizard/wizard.py:2249
-msgid "custom"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:767
-msgid "Map settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:777
-msgid "Map frame settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:895
-msgid "Map frame options:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:896
-msgid "fit frame to match selected map"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:897
-msgid "fit frame to match saved region"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:898
-msgid "fit frame to match current computational region"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:899
-msgid "fixed scale and map center"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:916 ../gui/wxpython/psmap/dialogs.py:1226
-msgid "Map selection"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:922 ../gui/wxpython/gcp/manager.py:365
-#: ../gui/wxpython/gui_core/dialogs.py:1453
-#: ../gui/wxpython/gui_core/dialogs.py:1699
-#: ../gui/wxpython/gmodeler/frame.py:1746
-#: ../gui/wxpython/image2target/ii2t_manager.py:394
-msgid "raster"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:925 ../gui/wxpython/gcp/manager.py:365
-#: ../gui/wxpython/gmodeler/frame.py:1747
-msgid "vector"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:929 ../gui/wxpython/psmap/dialogs.py:1717
-msgid "Map:"
-msgstr ""
-msgid "Region:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:986
-msgid "Map scale and center"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:990
-msgid "Center:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:991
-msgid "E:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:992
-msgid "N:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:999 ../gui/wxpython/psmap/dialogs.py:5862
-msgid "Scale:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1000
-msgid "1 :"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1064
-msgid "Map max resolution (dpi):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1101 ../gui/wxpython/psmap/dialogs.py:3711
-msgid "Border"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1107
-msgid "draw border around map frame"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1114
-msgid "border color:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1116
-msgid "border width (pts):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1235
-msgid ""
-"Region is set to match this map,\n"
-"raster or vector map must be added later"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1242
-msgid "Region selection"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1422
-msgid "No map selected!"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1446
-msgid "No region selected!"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1497
-msgid "Invalid scale or map center!"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1542
-#: ../gui/wxpython/lmgr/layertree.py:1044 ../gui/wxpython/nviz/tools.py:827
-#: ../gui/wxpython/nviz/mapwindow.py:1675
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2040
-#: ../gui/wxpython/menustrings.py:2074
-msgid "Raster map"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1567
-msgid "Choose raster map"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1572
-msgid "no raster map"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1575
-msgid "raster:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1700 ../gui/wxpython/gmodeler/model.py:798
-msgid "Vector maps"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1713
-msgid "Add map"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1721 ../gui/wxpython/psmap/dialogs.py:2182
-msgid "points"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1721 ../gui/wxpython/psmap/dialogs.py:2184
-msgid "lines"
-msgstr ""
-msgid "areas"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1727
-msgid "Data Type"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1732 ../gui/wxpython/dbmgr/base.py:2363
-#: ../gui/wxpython/animation/dialogs.py:776
-msgid "Add"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1761
-msgid "Manage vector maps"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1766
-msgid "The topmost vector map overlaps the others"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1770 ../gui/wxpython/psmap/dialogs.py:3668
-#: ../gui/wxpython/web_services/widgets.py:267
-msgid "Up"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1771 ../gui/wxpython/psmap/dialogs.py:3669
-#: ../gui/wxpython/web_services/widgets.py:269
-msgid "Down"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1772 ../gui/wxpython/nviz/tools.py:1364
-#: ../gui/wxpython/nviz/tools.py:2367 ../gui/wxpython/nviz/tools.py:2419
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:174
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1175
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2056
-#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:1196
-#: ../gui/wxpython/menustrings.py:2090
-msgid "Delete"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:1773
-msgid "Properties..."
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2016
-msgid "Raster map settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2064
-msgid "Vector maps settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2112
-#, python-format
-msgid "%s properties"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2167
-msgid "Data selection"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2178
-#: ../gui/wxpython/gui_core/forms.py:2041
-#: ../gui/wxpython/modules/import_export.py:82
-msgid "Feature type"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2182
-msgid "centroids"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2184
-msgid "boundaries"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2222
-msgid "Layer selection"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2229
-msgid "Database connection is not defined in DB file."
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2230
-msgid "Select layer:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2259
-msgid "list of categories (e.g. 1,3,5-7)"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2312 ../gui/wxpython/nviz/tools.py:977
-#: ../gui/wxpython/nviz/tools.py:2817
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:328
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1254
-#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1277
-msgid "Mask"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2316
-msgid "Use current mask"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2335 ../gui/wxpython/psmap/dialogs.py:2491
-msgid "Colors"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2344 ../gui/wxpython/psmap/dialogs.py:2500
-msgid "Outline"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2349 ../gui/wxpython/psmap/dialogs.py:2510
-msgid "draw outline"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2352 ../gui/wxpython/psmap/dialogs.py:2515
-#: ../gui/wxpython/psmap/dialogs.py:5287 ../gui/wxpython/psmap/dialogs.py:5295
-msgid "Width (pts):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2377 ../gui/wxpython/psmap/dialogs.py:2538
-#: ../gui/wxpython/gcp/manager.py:2713
-#: ../gui/wxpython/gui_core/preferences.py:1522
-#: ../gui/wxpython/mapswipe/dialogs.py:280 ../gui/wxpython/nviz/tools.py:1423
-#: ../gui/wxpython/nviz/tools.py:2154 ../gui/wxpython/nviz/tools.py:2296
-#: ../gui/wxpython/nviz/preferences.py:372
-#: ../gui/wxpython/nviz/preferences.py:574
-#: ../gui/wxpython/nviz/preferences.py:640
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1961
-#: ../gui/wxpython/image2target/ii2t_manager.py:2786
-msgid "Color:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2416 ../gui/wxpython/psmap/dialogs.py:2577
-#: ../gui/wxpython/wxplot/dialogs.py:1137
-#: ../gui/wxpython/wxplot/dialogs.py:1218
-msgid "Fill"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2421
-msgid "fill color"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2427 ../gui/wxpython/psmap/dialogs.py:2585
-msgid "choose color:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2442 ../gui/wxpython/psmap/dialogs.py:2601
-msgid "color from map table column:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2513
-msgid "No effect for fill color from table column"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2582
-msgid "Color of lines:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2649 ../gui/wxpython/psmap/dialogs.py:2881
-#: ../gui/wxpython/psmap/dialogs.py:3006
-msgid "Size and style"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2658 ../gui/wxpython/gcp/manager.py:2656
-#: ../gui/wxpython/vdigit/preferences.py:98
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1904
-#: ../gui/wxpython/image2target/ii2t_manager.py:2729
-msgid "Symbology"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2663 ../gui/wxpython/nviz/tools.py:1717
-msgid "symbol:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2677
-msgid "eps file:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2681 ../gui/wxpython/psmap/dialogs.py:3023
-#: ../gui/wxpython/psmap/dialogs.py:5798
-#: ../gui/wxpython/gui_core/gselect.py:1196
-#: ../gui/wxpython/gui_core/gselect.py:1496
-#: ../gui/wxpython/gui_core/gselect.py:1512
-#: ../gui/wxpython/gui_core/gselect.py:1559
-#: ../gui/wxpython/gui_core/gselect.py:1595
-#: ../gui/wxpython/gui_core/forms.py:1827
-#: ../gui/wxpython/gui_core/forms.py:1919
-#: ../gui/wxpython/modules/import_export.py:752
-#: ../gui/wxpython/location_wizard/wizard.py:163
-#: ../gui/wxpython/location_wizard/wizard.py:1345
-#: ../gui/wxpython/location_wizard/wizard.py:1421
-#: ../gui/wxpython/location_wizard/wizard.py:1511
-#: ../gui/wxpython/location_wizard/wizard.py:1739
-#: ../gui/wxpython/animation/dialogs.py:508
-#: ../gui/wxpython/animation/dialogs.py:1080
-#: ../gui/wxpython/animation/dialogs.py:1198
-#: ../gui/wxpython/animation/dialogs.py:1234
-#: ../gui/wxpython/animation/dialogs.py:1258
-#: ../gui/wxpython/animation/dialogs.py:1289 ../gui/wxpython/nviz/tools.py:626
-msgid "Browse"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2682 ../gui/wxpython/psmap/dialogs.py:3024
-msgid "Type filename or click browse to choose file"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2683 ../gui/wxpython/psmap/dialogs.py:3025
-msgid "Choose a file"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2732 ../gui/wxpython/psmap/dialogs.py:3806
-#: ../gui/wxpython/psmap/dialogs.py:4854
-#: ../gui/wxpython/wxplot/dialogs.py:1123
-#: ../gui/wxpython/wxplot/dialogs.py:1204
-msgid "Size"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2737 ../gui/wxpython/nviz/tools.py:1659
-msgid "size:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2742
-msgid "size from map table column:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2744
-msgid "scale:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2809
-msgid "Rotation"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2814
-msgid "rotate symbols:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2816
-msgid "counterclockwise in degrees:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2820
-msgid "from map table column:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2895
-msgid "Set width (pts):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2912
-msgid "multiply width by category value"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2944 ../gui/wxpython/psmap/dialogs.py:6809
-#: ../gui/wxpython/wxplot/dialogs.py:1072
-msgid "Line style"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2949
-msgid "Choose line style:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:2962
-msgid "Choose linecap:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3015
-msgid "Pattern"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3020
-msgid "use pattern:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3022
-msgid "Choose pattern file:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3030
-msgid "pattern line width (pts):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3034
-msgid "pattern scale factor:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3394
-msgid "Raster legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3399
-#: ../gui/wxpython/animation/dialogs.py:473
-msgid "Show raster legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3413
-msgid "Source raster"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3418
-msgid "current raster"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3421
-msgid "select raster"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3428 ../gui/wxpython/psmap/dialogs.py:4443
-#, python-format
-msgid "%(rast)s: type %(type)s"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3477
-msgid "Type of legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3482
-msgid "discrete legend (categorical maps)"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3486
-msgid "continuous color gradient legend (floating point map)"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3512
-msgid "Advanced legend settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3517
-msgid "draw \"no data\" box"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3526
-msgid "draw ticks across color table"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3539
-#: ../gui/wxpython/modules/colorrules.py:972
-#: ../gui/wxpython/modules/colorrules.py:1654
-#: ../gui/wxpython/modules/colorrules.py:1658
-msgid "range"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3618
-msgid "Vector legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3623
-msgid "Show vector legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3637
-msgid "Source vector maps"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3642
-msgid "Choose vector maps and their order in legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3646
-#: ../gui/wxpython/lmgr/layertree.py:1048 ../gui/wxpython/nviz/tools.py:1453
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2042
-#: ../gui/wxpython/menustrings.py:2076
-msgid "Vector map"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3647
-#: ../gui/wxpython/gmodeler/frame.py:1886
-#: ../gui/wxpython/gmodeler/dialogs.py:492
-#: ../gui/wxpython/gmodeler/dialogs.py:604
-msgid "Label"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3670 ../gui/wxpython/psmap/dialogs.py:4150
-msgid "Edit label"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3716
-msgid "draw border around legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3774
-msgid "Size and position"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3800 ../gui/wxpython/psmap/dialogs.py:4520
-#: ../gui/wxpython/psmap/dialogs.py:4798 ../gui/wxpython/psmap/dialogs.py:5379
-#: ../gui/wxpython/psmap/dialogs.py:5387 ../gui/wxpython/psmap/dialogs.py:5947
-#: ../gui/wxpython/psmap/dialogs.py:5956 ../gui/wxpython/psmap/dialogs.py:6531
-#: ../gui/wxpython/psmap/dialogs.py:6540 ../gui/wxpython/nviz/tools.py:1050
-#: ../gui/wxpython/nviz/tools.py:2021
-msgid "Position"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3833
-#: ../gui/wxpython/gui_core/dialogs.py:1938
-#: ../gui/wxpython/gmodeler/preferences.py:184
-#: ../gui/wxpython/gmodeler/preferences.py:350
-#: ../gui/wxpython/gmodeler/preferences.py:462
-#: ../gui/wxpython/gmodeler/preferences.py:578
-#: ../gui/wxpython/rdigit/toolbars.py:100
-#: ../gui/wxpython/nviz/preferences.py:559
-msgid "Width:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3844
-msgid "Leave the edit field empty, to use default values."
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3851 ../gui/wxpython/psmap/dialogs.py:4068
-#: ../gui/wxpython/psmap/dialogs.py:4859
-#: ../gui/wxpython/gui_core/dialogs.py:1942
-#: ../gui/wxpython/gmodeler/preferences.py:210
-#: ../gui/wxpython/gmodeler/preferences.py:376
-#: ../gui/wxpython/gmodeler/preferences.py:488
-#: ../gui/wxpython/gmodeler/preferences.py:604
-#: ../gui/wxpython/nviz/tools.py:366 ../gui/wxpython/nviz/tools.py:1285
-#: ../gui/wxpython/nviz/tools.py:2126
-msgid "Height:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3884
-msgid ""
-"Width of the color symbol (for lines)\n"
-"in front of the legend text"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3890 ../gui/wxpython/psmap/dialogs.py:4055
-msgid "Columns:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3900
-msgid "column span:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3902
-msgid ""
-"Column separation distance between the left edges\n"
-"of two columns in a multicolumn legend"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:3949 ../gui/wxpython/psmap/dialogs.py:4556
-#: ../gui/wxpython/psmap/dialogs.py:5220
-#: ../gui/wxpython/gui_core/preferences.py:509
-#: ../gui/wxpython/gui_core/preferences.py:789
-#: ../gui/wxpython/gui_core/dialogs.py:2419
-#: ../gui/wxpython/wxplot/dialogs.py:751
-msgid "Font settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4149
-msgid "Edit legend label:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4196
-msgid "No raster map selected!"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4197
-msgid "No raster"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4487
-msgid "Mapinfo settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4591
-msgid "Color settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4597
-msgid "use border color:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4599
-msgid "use background color:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4858
-msgid "Length:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4864
-msgid "Scalebar length is given in map units"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4869
-msgid "Scalebar height is real height on paper"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4871
-msgid "default"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4944
-#: ../gui/wxpython/wxplot/dialogs.py:1164
-#: ../gui/wxpython/wxplot/dialogs.py:1245
-msgid "Style"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4948
-msgid "Type:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4967
-msgid "Number of segments:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4973
-msgid "Label every "
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4974
-msgid "segments"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:4987
-msgid "transparent text background"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5105
-msgid "Length of scale bar is not defined"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5199
-msgid "Enter text:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5270
-msgid "Text effects"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5276
-msgid "text background"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5281
-msgid "highlight"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5290
-msgid "text border"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5399
-msgid "Offset"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5403
-msgid "horizontal (pts):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5405
-msgid "vertical (pts):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5444
-msgid " Reference point"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5498
-msgid "Text rotation"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5504
-msgid "rotate text (counterclockwise)"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5596
-msgid "No text entered!"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5596 ../gui/wxpython/core/gcmd.py:113
-#: ../gui/wxpython/core/workspace.py:1616
-#: ../gui/wxpython/gui_core/preferences.py:240
-#: ../gui/wxpython/gui_core/preferences.py:1927
-#: ../gui/wxpython/gui_core/preferences.py:1960
-#: ../gui/wxpython/gui_core/preferences.py:1972
-#: ../gui/wxpython/gui_core/preferences.py:1984
-#: ../gui/wxpython/gmodeler/frame.py:1141
-#: ../gui/wxpython/location_wizard/dialogs.py:142
-#: ../gui/wxpython/location_wizard/dialogs.py:161
-#: ../gui/wxpython/location_wizard/dialogs.py:490
-#: ../gui/wxpython/location_wizard/wizard.py:675
-#: ../gui/wxpython/location_wizard/wizard.py:864
-#: ../gui/wxpython/location_wizard/wizard.py:2013
-#: ../gui/wxpython/lmgr/layertree.py:1003
-#: ../gui/wxpython/vdigit/dialogs.py:253 ../gui/wxpython/vdigit/dialogs.py:447
-#: ../gui/wxpython/gis_set.py:281 ../gui/wxpython/gis_set.py:711
-#: ../gui/wxpython/gis_set.py:755
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:276
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:654
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:698
-msgid "Error"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5796 ../gui/wxpython/nviz/tools.py:624
-msgid "Choose a directory:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5797
-msgid "Choose a directory with images"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5840
-msgid "Note: only EPS format supported"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5856
-msgid "Scale And Rotation"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5897 ../gui/wxpython/psmap/dialogs.py:6479
-msgid "Rotation angle (deg):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:5913 ../gui/wxpython/psmap/dialogs.py:6501
-msgid "Counterclockwise rotation in degrees"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6039
-msgid ""
-"PIL\n"
-"missing"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6059
-#, python-format
-msgid "Unable to read file %s"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6120
-#, python-format
-msgid "size: %(width)s x %(height)s pts"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6142
-msgid "No image selected."
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6249
-msgid "North Arrow settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6260
-msgid "Compute convergence"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6331
-msgid "Symbol"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6338
-msgid "Select symbol:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6355
-msgid ""
-"Note: Selected symbol is not displayed\n"
-"in draft mode (only in preview mode)"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6380 ../gui/wxpython/psmap/dialogs.py:6740
-#: ../gui/wxpython/iclass/dialogs.py:396
-#: ../gui/wxpython/gmodeler/preferences.py:107
-#: ../gui/wxpython/gmodeler/preferences.py:421
-#: ../gui/wxpython/gmodeler/preferences.py:533
-#: ../gui/wxpython/nviz/tools.py:976 ../gui/wxpython/nviz/tools.py:2816
-#: ../gui/wxpython/wxplot/dialogs.py:1109
-#: ../gui/wxpython/wxplot/dialogs.py:1191
-msgid "Color"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6388 ../gui/wxpython/psmap/dialogs.py:6747
-msgid "Outline color:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6391 ../gui/wxpython/psmap/dialogs.py:6418
-#: ../gui/wxpython/psmap/dialogs.py:6750 ../gui/wxpython/psmap/dialogs.py:6780
-#: ../gui/wxpython/gui_core/dialogs.py:1780
-msgid "transparent"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6415 ../gui/wxpython/psmap/dialogs.py:6777
-msgid "Fill color:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6454
-msgid "Size and Rotation"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6462
-msgid "Size (pt):"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6465
-msgid "Symbol size in points"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6700
-msgid "Rectangle settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6702
-msgid "Line settings"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6815 ../gui/wxpython/gcp/manager.py:2828
-#: ../gui/wxpython/gui_core/preferences.py:1417
-#: ../gui/wxpython/vnet/dialogs.py:1279
-#: ../gui/wxpython/mapswipe/dialogs.py:327
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2076
-#: ../gui/wxpython/image2target/ii2t_manager.py:2901
-msgid "Line width:"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6836
-msgid "Line width in points"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6910
-msgid "Vector labels"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6930
-msgid "Vector label files created beforehand by v.label module"
-msgstr ""
-#: ../gui/wxpython/psmap/dialogs.py:6947
-msgid "You can select multiple label files."
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:23
-msgid "Modify the configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:37
-#, python-brace-format
-msgid "View and modify the configuration file '{name}'"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:89
-msgid ""
-"Are you sure that you want modify r.li configuration file {name}?\n"
-"You could broke the configuration file..."
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:94
-msgid "WARNING"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:114
-msgid "GRASS GIS Setup for r.li modules"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:132
-msgid "Available sampling area configuration files"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:140
-#: ../gui/wxpython/gui_core/simplelmgr.py:463
-#: ../gui/wxpython/gmodeler/frame.py:1499
-#: ../gui/wxpython/lmgr/layertree.py:459
-#: ../gui/wxpython/animation/dialogs.py:780
-#: ../gui/wxpython/animation/dialogs.py:1012
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:936
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1862
-#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1896
-msgid "Remove"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:141
-msgid "Remove a configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:143
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:932
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1858
-#: ../gui/wxpython/menustrings.py:950 ../gui/wxpython/menustrings.py:1892
-msgid "Create"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:144
-msgid "Create a new configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:146 ../gui/wxpython/lmgr/layertree.py:468
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:172
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:934
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1173
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1860
-#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:952
-#: ../gui/wxpython/menustrings.py:1194 ../gui/wxpython/menustrings.py:1894
-msgid "Rename"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:147
-msgid "Rename a configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:149
-msgid "View/Edit"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:150
-msgid "View and edit a configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:225
-#, python-format
-msgid "Do you want remove r.li configuration file <%s>?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:228
-msgid "Remove new r.li configuration file?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:251 ../gui/wxpython/rlisetup/frame.py:271
-msgid "You have to select a configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:254
-#, python-format
-msgid ""
-"Set the new name for %s \"                                            "
-"\"configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/frame.py:256
-msgid "Rename configuration file"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:58
-msgid "Create new configuration file for r.li modules"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:124
-#, python-format
-msgid "Do you want to create r.li configuration file <%s>?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:127
-msgid "Create new r.li configuration file?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:139
-msgid "r.li.setup wizard canceled. Configuration file not created."
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:485
-msgid "Select maps and define name"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:498
-msgid "Name for new configuration file to create"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:511
-msgid "Raster map to use to select areas"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:522
-msgid "Vector map to use to select areas"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:533
-msgid "Vector map layer to use to select areas"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:545
-msgid "Define sampling region (region for analysis)"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:548
-#: ../gui/wxpython/rlisetup/wizard.py:883
-msgid "Whole map layer"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:549
-msgid "Keyboard setting"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:550
-msgid "Draw the sampling frame"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:592
-#, python-format
-msgid "The configuration file %s already exists, please change name"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:654
-#, python-format
-msgid "Vector %s was not found, please select another vector"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:658
-#, python-format
-msgid "Vector %s has no areas, please select another vector"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:663
-#, python-format
-msgid "Vector %s has no table connected, please select another vector"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:707
-msgid "Insert sampling frame parameter"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:717
-msgid "Column of upper left corner"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:731
-msgid "Row of upper left corner"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:746
-#: ../gui/wxpython/rlisetup/wizard.py:760
-msgid "Row length of sampling frame"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:824
-#: ../gui/wxpython/rlisetup/sampling_frame.py:403
-msgid "Draw sampling frame"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:876
-msgid "Insert sampling areas"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:884
-msgid "Regions"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:885
-msgid "Sample units"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:886
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:333
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1259
-#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1282
-msgid "Moving window"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:887
-msgid ""
-"Select areas from the\n"
-"overlaid vector map"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:898
-msgid "Choose a method"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:900
-msgid "Use keyboard to enter sampling area"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:901
-msgid "Use mouse to draw sampling area"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:905
-msgid "This option is not supported yet"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:917
-msgid "Number of regions to draw:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:932
-msgid "Do you want to overwrite existing temporal maps if they exist?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:937
-msgid "Do you want to check vector areas?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:939
-msgid "Select if use area by area"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:941
-msgid "All the features will be used"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:958
-msgid "Analysing all vector features..."
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1056
-msgid "Analysing vector"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1072
-msgid "All feature are been analyzed."
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1076
-msgid "An error occurred"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1108
-msgid "Draw sampling regions"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1125
-msgid "Draw sample region "
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1133
-#: ../gui/wxpython/rlisetup/wizard.py:1490
-msgid "Draw moving windows region"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1135
-#: ../gui/wxpython/rlisetup/wizard.py:1496
-#: ../gui/wxpython/rlisetup/sampling_frame.py:415
-msgid "Draw sampling region"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1172
-msgid "Select sample units from keyboard"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1186
-#: ../gui/wxpython/rlisetup/wizard.py:1359
-#: ../gui/wxpython/rlisetup/wizard.py:1449
-msgid "Select type of shape"
-msgstr ""
-msgid "Circle"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1213
-#: ../gui/wxpython/rlisetup/wizard.py:1371
-#: ../gui/wxpython/rlisetup/wizard.py:1386
-msgid "Width size (in cells)?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1214
-#: ../gui/wxpython/rlisetup/wizard.py:1387
-msgid "What radius size (in meters)?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1215
-#: ../gui/wxpython/rlisetup/wizard.py:1378
-#: ../gui/wxpython/rlisetup/wizard.py:1388
-msgid "Height size (in cells)?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1216
-#: ../gui/wxpython/rlisetup/wizard.py:1389
-msgid "Name of the circle mask"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1224
-msgid "Select method of sampling unit distribution"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1226
-msgid "Random non overlapping"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1227
-msgid "Systematic contiguos"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1228
-msgid "Stratified random"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1229
-msgid "Systematic non contiguos"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1230
-msgid "Centered over sites"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1235
-#: ../gui/wxpython/rlisetup/wizard.py:1300
-msgid "What number of Sampling Units to use?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1314
-msgid "Insert number of row strates"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1315
-msgid "Insert number of column strates"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1321
-msgid "Insert distance between units"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1351
-msgid "Set sample units"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1400
-msgid "Set moving windows"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1443
-#: ../gui/wxpython/rlisetup/wizard.py:1541
-msgid "Draw sampling units"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1461
-msgid "Number of sampling area to draw:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1558
-msgid "Draw Sampling "
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1612
-msgid "Select sampling areas"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1621
-msgid "Is this area ok?"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1644
-msgid "Select sample area "
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1671
-#: ../gui/wxpython/rlisetup/functions.py:138
-#, python-format
-msgid ""
-"The raster map <%s> already exists. Please remove or rename the maps with "
-"the prefix '%s' or select the option to overwrite existing maps"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1712
-#: ../gui/wxpython/rlisetup/functions.py:127
-msgid "The polygon seems to have 0 areas"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1715
-msgid "Select sample area 1 of "
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1738
-#: ../gui/wxpython/location_wizard/wizard.py:2072
-msgid "Summary"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1745
-msgid "Configuration file name:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1754
-msgid "Raster name:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1764
-msgid "Vector name:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1773
-msgid "Region type:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1791
-msgid "Sampling area type:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1854
-msgid "Region keyboard values:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1868
-#: ../gui/wxpython/rlisetup/wizard.py:1893
-#: ../gui/wxpython/rlisetup/wizard.py:1897
-msgid "Type of shape:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1871
-#: ../gui/wxpython/rlisetup/wizard.py:1900
-msgid "Radius size:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1872
-#: ../gui/wxpython/rlisetup/wizard.py:1901
-msgid "Name circle mask:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1874
-#: ../gui/wxpython/rlisetup/wizard.py:1903
-msgid "Width size:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1875
-#: ../gui/wxpython/rlisetup/wizard.py:1904
-msgid "Height size:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1878
-msgid "Method of distribution:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1881
-msgid "Number sampling units:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1884
-msgid "Distance between units:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1887
-msgid "Number row strates:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/wizard.py:1889
-msgid "Number column strates:"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:102
-#: ../gui/wxpython/gcp/mapdisplay.py:261 ../gui/wxpython/mapdisp/frame.py:505
-#: ../gui/wxpython/iclass/frame.py:312 ../gui/wxpython/mapswipe/frame.py:291
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:260
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:261
-msgid "Map Toolbar"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:217
-#: ../gui/wxpython/rlisetup/sampling_frame.py:326
-#, python-format
-msgid "The raster file %s already exists, please change name"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:243
-msgid "Raster map not created. Please redraw region."
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:349
-msgid "Raster map not created. redraw region again."
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:404
-msgid "Draw sampling frame by clicking and dragging"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:407
-msgid "Draw sampling rectangle"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:408
-msgid "Draw sampling rectangle by clicking and dragging"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:411
-msgid "Draw sampling circle"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:412
-msgid "Draw sampling circle radius by clicking and dragging"
-msgstr ""
-#: ../gui/wxpython/rlisetup/sampling_frame.py:416
-msgid "Draw sampling region by polygon. Right Double click to end drawing"
-msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:38
-#: ../gui/wxpython/photo2image/ip2i_statusbar.py:38
-#: ../gui/wxpython/image2target/ii2t_statusbar.py:38
-msgid "Go to GCP No."
-msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:55
-#: ../gui/wxpython/photo2image/ip2i_statusbar.py:55
-#: ../gui/wxpython/image2target/ii2t_statusbar.py:55
-msgid "Valid Range:"
-msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:121
-#: ../gui/wxpython/photo2image/ip2i_statusbar.py:121
-#: ../gui/wxpython/image2target/ii2t_statusbar.py:121
-msgid "RMS error"
-msgstr ""
-#: ../gui/wxpython/gcp/statusbar.py:125
-#: ../gui/wxpython/photo2image/ip2i_statusbar.py:125
-#: ../gui/wxpython/image2target/ii2t_statusbar.py:125
-#, python-format
-msgid "Forward: %(forw)s, Backward: %(back)s"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:148
-#: ../gui/wxpython/image2target/ii2t_manager.py:177
-msgid "Setup for georectification"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:181 ../gui/wxpython/gcp/manager.py:185
-#: ../gui/wxpython/image2target/ii2t_manager.py:210
-#: ../gui/wxpython/image2target/ii2t_manager.py:214
-msgid "Georectifying setup canceled."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:350
-#: ../gui/wxpython/image2target/ii2t_manager.py:379
-msgid "Select map type and location/mapset"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:364
-#: ../gui/wxpython/image2target/ii2t_manager.py:393
-msgid "Map type to georectify"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:375
-#: ../gui/wxpython/image2target/ii2t_manager.py:404
-msgid "Select source location:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:396
-#: ../gui/wxpython/image2target/ii2t_manager.py:425
-msgid "Select source mapset:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:452
-#: ../gui/wxpython/image2target/ii2t_manager.py:481
-msgid "You must select a valid location before selecting a mapset"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:465
-#: ../gui/wxpython/image2target/ii2t_manager.py:494
-msgid "You must select a valid location and mapset in order to continue"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:487
-#: ../gui/wxpython/image2target/ii2t_manager.py:516
-msgid "Select image/map group to georectify"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:509
-msgid "Select/create group:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:526
-#: ../gui/wxpython/image2target/ii2t_manager.py:555
-msgid "Create group if none exists"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:536 ../gui/wxpython/iclass/dialogs.py:78
-#: ../gui/wxpython/image2target/ii2t_manager.py:565
-msgid "Create/edit group..."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:540
-#: ../gui/wxpython/image2target/ii2t_manager.py:569
-msgid "Add vector map to group..."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:560 ../gui/wxpython/gcp/manager.py:2985
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2212
-#: ../gui/wxpython/image2target/ii2t_manager.py:589
-#: ../gui/wxpython/image2target/ii2t_manager.py:3058
-msgid "Extension for output maps:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:630
-#: ../gui/wxpython/image2target/ii2t_manager.py:653
-msgid "You must select a valid image/map group in order to continue"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:637
-#: ../gui/wxpython/image2target/ii2t_manager.py:660
-msgid "You must enter an map name extension in order to continue"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:706
-#: ../gui/wxpython/image2target/ii2t_manager.py:729
-msgid "Select maps to display for ground control point (GCP) creation"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:718 ../gui/wxpython/gcp/manager.py:2880
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2122
-#: ../gui/wxpython/image2target/ii2t_manager.py:741
-#: ../gui/wxpython/image2target/ii2t_manager.py:2953
-msgid "Select source map to display:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:744 ../gui/wxpython/gcp/manager.py:2894
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2136
-#: ../gui/wxpython/image2target/ii2t_manager.py:767
-#: ../gui/wxpython/image2target/ii2t_manager.py:2967
-msgid "Select target raster map to display:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:767 ../gui/wxpython/gcp/manager.py:2908
-#: ../gui/wxpython/image2target/ii2t_manager.py:790
-#: ../gui/wxpython/image2target/ii2t_manager.py:2981
-msgid "Select target vector map to display:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:839
-#: ../gui/wxpython/image2target/ii2t_manager.py:862
-msgid "You must select a source map in order to continue"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:866 ../gui/wxpython/gcp/manager.py:897
-#: ../gui/wxpython/image2target/ii2t_manager.py:889
-#: ../gui/wxpython/image2target/ii2t_manager.py:920
-#, python-format
-msgid ""
-"No maps in selected group <%s>.\n"
-"Please edit group or select another group."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:927
-#: ../gui/wxpython/image2target/ii2t_manager.py:950
-msgid "Manage Ground Control Points"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1192
-#: ../gui/wxpython/photo2image/ip2i_manager.py:616
-#: ../gui/wxpython/image2target/ii2t_manager.py:1225
-#, python-format
-msgid "At least %d GCPs required. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1335
-#: ../gui/wxpython/photo2image/ip2i_manager.py:759
-#: ../gui/wxpython/image2target/ii2t_manager.py:1367
-msgid "source"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1337
-#: ../gui/wxpython/photo2image/ip2i_manager.py:761
-#: ../gui/wxpython/image2target/ii2t_manager.py:1369
-msgid "target"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1339
-#: ../gui/wxpython/photo2image/ip2i_manager.py:763
-#: ../gui/wxpython/image2target/ii2t_manager.py:1371
-msgid "Set GCP coordinates"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1341
-#: ../gui/wxpython/photo2image/ip2i_manager.py:765
-#: ../gui/wxpython/image2target/ii2t_manager.py:1373
-#, python-format
-msgid ""
-"Set %(coor)s coordinates for GCP No. %(key)s? \n"
-"\n"
-"East: %(coor0)s \n"
-"North: %(coor1)s"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1419
-#: ../gui/wxpython/photo2image/ip2i_manager.py:441
-#: ../gui/wxpython/photo2image/ip2i_manager.py:843
-msgid "Writing POINTS file failed"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1431
-#: ../gui/wxpython/photo2image/ip2i_manager.py:856
-#, python-format
-msgid "POINTS file saved for group <%s>"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1447
-#: ../gui/wxpython/photo2image/ip2i_manager.py:872
-#: ../gui/wxpython/image2target/ii2t_manager.py:1511
-msgid "source mapwin not defined"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1452
-#: ../gui/wxpython/photo2image/ip2i_manager.py:877
-#: ../gui/wxpython/image2target/ii2t_manager.py:1516
-msgid "target mapwin not defined"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1482
-#: ../gui/wxpython/photo2image/ip2i_manager.py:907
-msgid "Reading POINTS file failed"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1567
-#: ../gui/wxpython/photo2image/ip2i_manager.py:992
-#: ../gui/wxpython/image2target/ii2t_manager.py:1633
-#, python-format
-msgid ""
-"Insufficient points defined and active (checked) for selected rectification method (order: %d).\n"
-"3+ points needed for 1st order,\n"
-"6+ points for 2nd order, and\n"
-"10+ points for 3rd order."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1595
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1020
-#: ../gui/wxpython/image2target/ii2t_manager.py:1661
-msgid "Rectifying images, please wait..."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1635
-#: ../gui/wxpython/image2target/ii2t_manager.py:1701
-#, python-format
-msgid "Transforming <%s>..."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1640
-#: ../gui/wxpython/image2target/ii2t_manager.py:1706
-#, python-format
-msgid "Rectifying vector map <%s>, please wait..."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1674
-#: ../gui/wxpython/image2target/ii2t_manager.py:1740
-#, python-format
-msgid "Georectification of vector map <%s> failed"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1680
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1072
-#: ../gui/wxpython/image2target/ii2t_manager.py:1746
-msgid "GCP Manager settings"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1727
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1117
-#: ../gui/wxpython/image2target/ii2t_manager.py:1793
-msgid "Quit GCP Manager"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1728
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1118
-#: ../gui/wxpython/image2target/ii2t_manager.py:1794
-msgid "Save ground control points?"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1807
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1196
-msgid ""
-"Could not calculate RMS Error.\n"
-"Possible error with m.transform."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:1935
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1324
-msgid ""
-"Could not calculate new extends.\n"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2067
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1456
-#: ../gui/wxpython/image2target/ii2t_manager.py:2130
-msgid "Adjust source display to target display"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2072
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1461
-#: ../gui/wxpython/image2target/ii2t_manager.py:2135
-msgid "Adjust target display to source display"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2146 ../gui/wxpython/gcp/manager.py:2164
-#: ../gui/wxpython/vnet/vnet_data.py:259 ../gui/wxpython/vnet/widgets.py:85
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1535
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1553
-#: ../gui/wxpython/image2target/ii2t_manager.py:2209
-#: ../gui/wxpython/image2target/ii2t_manager.py:2229
-msgid "use"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2147 ../gui/wxpython/gcp/manager.py:2165
-#: ../gui/wxpython/image2target/ii2t_manager.py:2210
-#: ../gui/wxpython/image2target/ii2t_manager.py:2230
-msgid "source E"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2148 ../gui/wxpython/gcp/manager.py:2166
-#: ../gui/wxpython/image2target/ii2t_manager.py:2211
-#: ../gui/wxpython/image2target/ii2t_manager.py:2231
-msgid "source N"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2149 ../gui/wxpython/gcp/manager.py:2167
-#: ../gui/wxpython/image2target/ii2t_manager.py:2213
-#: ../gui/wxpython/image2target/ii2t_manager.py:2233
-msgid "target E"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2150 ../gui/wxpython/gcp/manager.py:2168
-#: ../gui/wxpython/image2target/ii2t_manager.py:2214
-#: ../gui/wxpython/image2target/ii2t_manager.py:2234
-msgid "target N"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2151 ../gui/wxpython/gcp/manager.py:2169
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1540
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1558
-#: ../gui/wxpython/image2target/ii2t_manager.py:2216
-#: ../gui/wxpython/image2target/ii2t_manager.py:2236
-msgid "Forward error"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2152 ../gui/wxpython/gcp/manager.py:2170
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1541
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1559
-#: ../gui/wxpython/image2target/ii2t_manager.py:2217
-#: ../gui/wxpython/image2target/ii2t_manager.py:2237
-msgid "Backward error"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2307
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1696
-#: ../gui/wxpython/image2target/ii2t_manager.py:2376
-msgid "Invalid coordinate value. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2354
-#: ../gui/wxpython/image2target/ii2t_manager.py:2425
-msgid "Create vector map group"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2429
-#: ../gui/wxpython/image2target/ii2t_manager.py:2500
-msgid "Select vector map(s) to add to group:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2485
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1734
-#: ../gui/wxpython/image2target/ii2t_manager.py:2551
-msgid "Edit GCP"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2497
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1746
-#: ../gui/wxpython/image2target/ii2t_manager.py:2563
-msgid "Ground Control Point No."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2516
-#: ../gui/wxpython/image2target/ii2t_manager.py:2583
-msgid "source E:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2517
-#: ../gui/wxpython/image2target/ii2t_manager.py:2584
-msgid "target E:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2518
-#: ../gui/wxpython/image2target/ii2t_manager.py:2585
-msgid "source N:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2519
-#: ../gui/wxpython/image2target/ii2t_manager.py:2586
-msgid "target N:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2625 ../gui/wxpython/vnet/dialogs.py:1307
-#: ../gui/wxpython/iscatt/dialogs.py:397 ../gui/wxpython/wxplot/dialogs.py:829
-#: ../gui/wxpython/wxplot/dialogs.py:1428
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1873
-#: ../gui/wxpython/image2target/ii2t_manager.py:2698
-msgid "Apply changes for the current session"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2628
-#: ../gui/wxpython/gui_core/preferences.py:100
-#: ../gui/wxpython/vnet/dialogs.py:1310 ../gui/wxpython/iscatt/dialogs.py:400
-#: ../gui/wxpython/wxplot/dialogs.py:836
-#: ../gui/wxpython/wxplot/dialogs.py:1432
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1876
-#: ../gui/wxpython/image2target/ii2t_manager.py:2701
-msgid ""
-"Apply and save changes to user settings file (default for next sessions)"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2630
-#: ../gui/wxpython/web_services/dialogs.py:145
-#: ../gui/wxpython/web_services/dialogs.py:901
-#: ../gui/wxpython/modules/import_export.py:117
-#: ../gui/wxpython/modules/import_export.py:670
-#: ../gui/wxpython/vnet/dialogs.py:1312 ../gui/wxpython/iscatt/dialogs.py:402
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1878
-#: ../gui/wxpython/image2target/ii2t_manager.py:2703
-msgid "Close dialog"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2665
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1913
-#: ../gui/wxpython/image2target/ii2t_manager.py:2738
-msgid "Highlight highest RMS error only"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2678
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1926
-#: ../gui/wxpython/image2target/ii2t_manager.py:2751
-msgid "Highlight RMS error > M + SD * factor:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2682
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1930
-#: ../gui/wxpython/image2target/ii2t_manager.py:2755
-msgid ""
-"Highlight GCPs with an RMS error larger than \n"
-"mean + standard deviation * given factor. \n"
-"Recommended values for this factor are between 1 and 2."
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2705
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1953
-#: ../gui/wxpython/image2target/ii2t_manager.py:2778
-msgid "Symbol settings"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2733
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1981
-#: ../gui/wxpython/image2target/ii2t_manager.py:2806
-msgid "Color for high RMS error:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2753
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2001
-#: ../gui/wxpython/image2target/ii2t_manager.py:2826
-msgid "Color for selected GCP:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2773
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2021
-#: ../gui/wxpython/image2target/ii2t_manager.py:2846
-msgid "Color for unused GCPs:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2789
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2037
-#: ../gui/wxpython/image2target/ii2t_manager.py:2862
-msgid "Show unused GCPs"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2806
-#: ../gui/wxpython/gui_core/preferences.py:1449
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2054
-#: ../gui/wxpython/image2target/ii2t_manager.py:2879
-msgid "Symbol size:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2934
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2161
-#: ../gui/wxpython/image2target/ii2t_manager.py:3007
-msgid "Rectification"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2943
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2170
-#: ../gui/wxpython/image2target/ii2t_manager.py:3016
-msgid "Select rectification order"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2945
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2172
-#: ../gui/wxpython/image2target/ii2t_manager.py:3018
-msgid "1st order"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2946
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2173
-#: ../gui/wxpython/image2target/ii2t_manager.py:3019
-msgid "2nd order"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2947
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2174
-#: ../gui/wxpython/image2target/ii2t_manager.py:3020
-msgid "3rd order"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2959
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2186
-#: ../gui/wxpython/image2target/ii2t_manager.py:3032
-msgid "Select interpolation method:"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:2975
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2202
-#: ../gui/wxpython/image2target/ii2t_manager.py:3048
-msgid "clip to computational region in target location"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:3026
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2253
-#: ../gui/wxpython/image2target/ii2t_manager.py:3099
-msgid "RMS threshold factor must be > 0"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:3029
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2256
-#: ../gui/wxpython/image2target/ii2t_manager.py:3102
-msgid ""
-"RMS threshold factor is < 1\n"
-"Too many points might be highlighted"
-msgstr ""
-#: ../gui/wxpython/gcp/manager.py:3213
-#: ../gui/wxpython/photo2image/ip2i_manager.py:2416
-#: ../gui/wxpython/image2target/ii2t_manager.py:3286
-#, python-format
-msgid "GCP Manager settings saved to file '%s'."
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:50
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:50
-msgid "GRASS GIS Manage Ground Control Points"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:176
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:176
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:176
-msgid "GCP List"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:181
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:181
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:181
-msgid "Source Display"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:185
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:185
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:185
-msgid "Target Display"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:275
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:274
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:275
-msgid "GCP Display toolbar"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:288
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:287
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:288
-msgid "GCP Manager toolbar"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:382 ../gui/wxpython/mapdisp/frame.py:800
-#: ../gui/wxpython/mapswipe/frame.py:550
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:381
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:382
-msgid "Nothing to render (empty map). Operation canceled."
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:397 ../gui/wxpython/mapdisp/frame.py:641
-#: ../gui/wxpython/modules/histogram.py:472
-#: ../gui/wxpython/gmodeler/frame.py:707 ../gui/wxpython/mapswipe/frame.py:556
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:396
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:397
-msgid "Choose a file name to save the image (no need to add extension)"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:430 ../gui/wxpython/mapdisp/frame.py:815
-#: ../gui/wxpython/modules/histogram.py:505 ../gui/wxpython/wxplot/base.py:611
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:429
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:430
-msgid "Print preview"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:434 ../gui/wxpython/mapdisp/frame.py:819
-#: ../gui/wxpython/gui_core/toolbars.py:68
-#: ../gui/wxpython/modules/histogram.py:509 ../gui/wxpython/wxplot/base.py:612
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:433
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:434
-msgid "Print display"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:474
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:473
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:474
-msgid "Zoom to computational region (set with g.region)"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:479 ../gui/wxpython/mapdisp/frame.py:1389
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:478
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:479
-msgid "Zoom to default region"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:483 ../gui/wxpython/mapdisp/frame.py:1391
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:482
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:483
-msgid "Zoom to saved region"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:488
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:487
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:488
-msgid "Set computational region from display"
-msgstr ""
-#: ../gui/wxpython/gcp/mapdisplay.py:493 ../gui/wxpython/mapdisp/frame.py:1401
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:492
-#: ../gui/wxpython/image2target/ii2t_mapdisplay.py:493
-msgid "Save display geometry to named region"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:92
-#: ../gui/wxpython/core/render.py:779 ../gui/wxpython/gui_core/mapdisp.py:140
-#, python-format
-msgid "GRASS module '%s' not found. Unable to start map display window."
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:150
-msgid "Map window test frame"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:169
-msgid "Map display test"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:179
-msgid "Map window API test frame"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:204
-msgid "Map window distance measurement test frame"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:235
-msgid "Map window profile tool test frame"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:282
-msgid "Map window rlisetup test frame"
-msgstr ""
-#: ../gui/wxpython/mapdisp/test_mapdisp.py:343
-#, python-format
-msgid "Unknown value %s of test parameter."
-msgstr ""
-#: ../gui/wxpython/mapdisp/gprint.py:154
-msgid ""
-"There was a problem printing.\n"
-"Perhaps your current printer is not set correctly?"
-msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:187
-#, python-format
-msgid "Unsupported command %s."
-msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:281
-#, python-format
-msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
-msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:616
-#, python-format
-msgid "Starting map display <%s>..."
-msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:622
-#, python-format
-msgid "Unable to create file <%s>"
-msgstr ""
-#: ../gui/wxpython/mapdisp/main.py:638
-#, python-format
-msgid "Stopping map display <%s>..."
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:29
-#: ../gui/wxpython/mapswipe/toolbars.py:36
-msgid "Query raster/vector map(s)"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:30
-#: ../gui/wxpython/mapswipe/toolbars.py:37
-msgid "Query selected raster/vector map(s)"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:32
-msgid "Select vector feature(s)"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:33
-msgid "Select features interactively from vector map"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:35
-msgid "Add scale bar"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:37
-msgid "Add raster legend"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:39
-msgid "Add vector legend"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:41
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2055
-#: ../gui/wxpython/menustrings.py:2089
-msgid "Add north arrow"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:43
-msgid "Analyze map"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:44
-msgid "Measuring, profiling, histogramming, ..."
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:46
-msgid "Measure distance"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:48
-msgid "Measure area"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:50
-msgid "Profile surface map"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:52
-msgid "Create bivariate scatterplot of raster maps"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:54
-#: ../gui/wxpython/animation/dialogs.py:988
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2051
-#: ../gui/wxpython/menustrings.py:2085
-msgid "Add text"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:56
-msgid "Create histogram of raster map"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:58
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:645
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1571
-#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1596
-msgid "Vector network analysis tool"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:64
-msgid "Rotate 3D scene"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:65
-msgid "Drag with mouse to rotate 3D scene"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:68
-#: ../gui/wxpython/nviz/preferences.py:241
-msgid "Fly-through mode"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:70
-msgid ""
-"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:73
-msgid "Click mouse to zoom"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:75
-msgid "Click mouse to unzoom"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:97
-#: ../gui/wxpython/mapdisp/toolbars.py:301
-#: ../gui/wxpython/mapdisp/frame.py:274 ../gui/wxpython/mapdisp/frame.py:334
-#: ../gui/wxpython/lmgr/layertree.py:1175 ../gui/wxpython/animation/data.py:45
-msgid "2D view"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:104 ../gui/wxpython/lmgr/frame.py:443
-#: ../gui/wxpython/animation/data.py:46
-msgid "3D view"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:110
-msgid "3D view mode not available"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:111
-#: ../gui/wxpython/mapdisp/toolbars.py:123
-#, python-format
-msgid "Reason: %s"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:116
-#: ../gui/wxpython/mapdisp/frame.py:514 ../gui/wxpython/vdigit/toolbars.py:953
-msgid "Vector digitizer"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:122
-msgid "Vector digitizer not available"
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:126
-msgid ""
-"Note that the wxGUI's vector digitizer is disabled in this installation. "
-"Please keep an eye out for updated versions of GRASS. In the meantime you "
-"can use \"v.edit\" for non-interactive editing from the Develop vector map "
-"menu."
-msgstr ""
-#: ../gui/wxpython/mapdisp/toolbars.py:133
-msgid "Raster digitizer"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:63
-msgid "GRASS GIS - Map display"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:241
-#, python-format
-msgid ""
-"Failed to run command '%(command)s'. Details:\n"
-"%(error)s"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:258
-#, python-format
-msgid "GRASS GIS Map Display: %(name)s - %(loc)s/%(mapset)s"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:276 ../gui/wxpython/lmgr/layertree.py:1177
-#, python-format
-msgid ""
-"Unable to start wxGUI vector digitizer.\n"
-"Details: %s"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:314
-msgid "Vector Digitizer Toolbar"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:337
-#, python-format
-msgid ""
-"Unable to switch to 3D display mode.\n"
-"The Nviz python extension was not found or loaded properly.\n"
-"Switching back to 2D display mode.\n"
-"\n"
-"Details: %s"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:372
-msgid "Starting 3D view mode..."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:374
-msgid "Please wait, loading data..."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:457
-msgid "Please wait, unloading data..."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:459
-msgid "Switching back to 2D view mode..."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:594
-#: ../gui/wxpython/gui_core/vselect.py:277 ../gui/wxpython/lmgr/frame.py:2573
-msgid "No map layer selected. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:717 ../gui/wxpython/mapdisp/frame.py:725
-#: ../gui/wxpython/mapdisp/frame.py:740
-msgid "Failed to run d.to.rast:\n"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:756
-msgid "d.to.rast can be used only in 2D mode."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:889
-#, python-format
-msgid "Vector map <%s> opened for editing - skipped."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:896 ../gui/wxpython/mapswipe/frame.py:674
-msgid "No raster or vector map layer selected for querying."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:960
-msgid ""
-"Failed to query vector map(s) <{maps}>. Check database settings and "
-"topology."
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1394
-msgid "Set computational region extent from display"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1396
-msgid "Set computational region extent interactively"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1398
-msgid "Set computational region from named region"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1403
-msgid "Save computational region to named region"
-msgstr ""
-#: ../gui/wxpython/mapdisp/frame.py:1536
-msgid "Raster Digitizer Toolbar"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:418
-msgid "Render"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:422
-msgid "Enable/disable auto-rendering"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:454
-msgid "Show comp. extent"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:458
-msgid "Show computational extent"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:464
-msgid ""
-"Show/hide computational region extent (set with g.region). Display region "
-"drawn as a blue box inside the computational region, computational region "
-"inside a display region as a red box)."
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:515
-msgid "Display mode"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:520
-#: ../gui/wxpython/gui_core/preferences.py:917
-msgid "Align region extent based on display size"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:526
-msgid ""
-"Align region extent based on display size from center point. Default value "
-"for new map displays can be set up in 'User GUI settings' dialog."
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:560
-msgid "Display resolution"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:563
-#: ../gui/wxpython/gui_core/preferences.py:933
-msgid "Constrain display resolution to computational settings"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:569
-msgid ""
-"Constrain display resolution to computational region settings. Default value"
-" for new map displays can be set up in 'User GUI settings' dialog."
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:607
-msgid "Map scale"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:624
-msgid ""
-"As everyone's monitors and resolutions are set differently these values are "
-"not true map scales, but should get you into the right neighborhood."
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:677
-msgid "Go to"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:700
-#: ../gui/wxpython/mapdisp/statusbar.py:770
-#: ../gui/wxpython/mapdisp/statusbar.py:1009
-#: ../gui/wxpython/mapdisp/statusbar.py:1084
-msgid "Projection not defined (check the settings)"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:787
-#: ../gui/wxpython/mapdisp/statusbar.py:1024
-#: ../gui/wxpython/mapdisp/statusbar.py:1125
-msgid "Error in projection (check the settings)"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:824
-#: ../gui/wxpython/gui_core/preferences.py:1697
-msgid "Projection"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:826
-msgid "Use defined projection"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:841
-msgid ""
-"Reproject coordinates displayed in the statusbar. Projection can be defined "
-"in GUI preferences dialog (tab 'Projection')"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:873
-msgid "MASK"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:921
-msgid "Display geometry"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:947
-msgid "Coordinates"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:1039
-msgid "Extent"
-msgstr ""
-#: ../gui/wxpython/mapdisp/statusbar.py:1152
-#: ../gui/wxpython/web_services/dialogs.py:874
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:214
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1177
-#: ../gui/wxpython/menustrings.py:219 ../gui/wxpython/menustrings.py:1198
-msgid "Computational region"
-msgstr ""
-#: ../gui/wxpython/icons/icon.py:38
-#, python-format
-msgid "Unknown iconset '%s', using default 'grass'...\n"
-msgstr ""
-#: ../gui/wxpython/icons/icon.py:56
-#, python-format
-msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:161 ../gui/wxpython/iscatt/controllers.py:139
-msgid "Loading data..."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:168
-#, python-format
-msgid ""
-"Attribute table <%s> not found. For creating the table switch to 'Manage "
-"layers' tab."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:179
-#, python-format
-msgid "Column <%(column)s> not found in in the table <%(table)s>."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:260
-msgid "Can display only 256 columns."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:279
-#, python-format
-msgid "Inconsistent number of columns in the table <%(table)s>."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:289
-msgid "Viewing limit: 100000 records."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:317 ../gui/wxpython/dbmgr/base.py:921
-#: ../gui/wxpython/dbmgr/base.py:1091 ../gui/wxpython/dbmgr/base.py:1446
-#: ../gui/wxpython/dbmgr/base.py:2098 ../gui/wxpython/dbmgr/manager.py:223
-#, python-format
-msgid "Number of loaded records: %d"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:341
-msgid "Unknown value"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:347
-msgid ""
-"Unable to decode value. Set encoding in GUI preferences ('Attributes')."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:358
-#, python-format
-msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to convert value '%(val)s' in key column (%(key)s) to integer.\n"
-"\n"
-"Details: %(detail)s"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:452
-msgid "Sort ascending"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:453
-msgid "Sort descending"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:457
-msgid "Calculate (only numeric columns)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:460
-msgid "Field calculator"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:462 ../gui/wxpython/wxplot/dialogs.py:290
-msgid "Statistics"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:467 ../gui/wxpython/dbmgr/base.py:2309
-#: ../gui/wxpython/modules/colorrules.py:1139
-msgid "Add column"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:479
-msgid "Area size"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:480
-msgid "Line length"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:483
-msgid "Compactness of an area"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:485
-msgid "Fractal dimension of boundary defining a polygon"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:488
-msgid "Perimeter length of an area"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:490
-msgid "Number of features for each category"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:493
-msgid "Slope steepness of 3D line"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:494
-msgid "Line sinuousity"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:495
-msgid "Line azimuth"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:629
-#, python-format
-msgid "Add column to table <%s>"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1027
-msgid "Unable to add column to the table. No column name defined."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1041
-#, python-format
-msgid "Column <%(column)s> already exists in table <%(table)s>."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1124
-msgid "Attribute data - right-click to edit/manage records"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1139 ../gui/wxpython/dbmgr/base.py:2262
-#: ../gui/wxpython/dbmgr/base.py:2957 ../gui/wxpython/dbmgr/base.py:3092
-#: ../gui/wxpython/dbmgr/base.py:3361
-msgid "Table"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1141 ../gui/wxpython/dbmgr/base.py:2264
-msgid " (readonly)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1155
-msgid "SQL Query"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1185
-msgid "Simple"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1192
-msgid "Apply SELECT statement and reload data records"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1215 ../gui/wxpython/dbmgr/base.py:1241
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:496
-#, python-format
-msgid "Example: %s"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1226
-msgid "Builder"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1231
-msgid "SQL Builder"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1408 ../gui/wxpython/core/settings.py:875
-msgid "Edit selected record"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1413 ../gui/wxpython/dbmgr/base.py:1602
-msgid "Insert new record"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1414
-msgid "Delete selected record(s)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1415
-msgid "Delete all records"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1421 ../gui/wxpython/gui_core/widgets.py:969
-#: ../gui/wxpython/gui_core/dialogs.py:769
-#: ../gui/wxpython/gui_core/dialogs.py:837
-#: ../gui/wxpython/gui_core/dialogs.py:1578
-msgid "Select all"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1422 ../gui/wxpython/gui_core/widgets.py:970
-#: ../gui/wxpython/gui_core/dialogs.py:1580
-msgid "Deselect all"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1424
-#: ../gui/wxpython/gui_core/preferences.py:1515
-msgid "Highlight selected features"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1427
-msgid "Highlight selected features and zoom"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1431 ../gui/wxpython/dbmgr/base.py:1942
-msgid "Extract selected features"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1432
-msgid "Delete selected features"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1440 ../gui/wxpython/dbmgr/base.py:2590
-#: ../gui/wxpython/gmodeler/dialogs.py:851
-#: ../gui/wxpython/gmodeler/dialogs.py:1017
-#: ../gui/wxpython/vdigit/dialogs.py:290
-msgid "Reload"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1495
-msgid "Update existing record"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1522 ../gui/wxpython/dbmgr/base.py:1635
-#, python-format
-msgid "Value '%(value)s' needs to be entered as %(type)s."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1541
-#, python-format
-msgid ""
-"Unable to update existing record.\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1613
-#, python-format
-msgid "Record with category number %d already exists in the table."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1623
-#, python-format
-msgid "Category number (column %s) is missing."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1647
-#, python-format
-msgid ""
-"Unable to insert new record.\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1700
-#, python-format
-msgid ""
-"Selected data records (%d) will be permanently deleted from table. Do you "
-"want to delete them?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1703 ../gui/wxpython/dbmgr/base.py:1753
-msgid "Delete records"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1750
-#, python-format
-msgid ""
-"All data records (%d) will be permanently deleted from table. Do you want to"
-" delete them?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1937
-msgid "Nothing to extract."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:1971
-msgid "Nothing to delete."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2042 ../gui/wxpython/dbmgr/base.py:2078
-#, python-format
-msgid ""
-"Loading attribute data failed.\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2061
-#, python-format
-msgid ""
-"Invalid SQL select statement.\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2278 ../gui/wxpython/dbmgr/sqlbuilder.py:97
-msgid "Database connection"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2297
-#, python-format
-msgid "Table <%s> - right-click to delete column(s)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2321 ../gui/wxpython/dbmgr/base.py:2385
-#: ../gui/wxpython/dbmgr/dialogs.py:788
-msgid "Column"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2340 ../gui/wxpython/dbmgr/dialogs.py:799
-#: ../gui/wxpython/web_services/widgets.py:935
-#: ../gui/wxpython/gmodeler/preferences.py:255
-msgid "Type"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2356 ../gui/wxpython/dbmgr/dialogs.py:810
-msgid "Length"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2372
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:918
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1844
-#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1878
-msgid "Rename column"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2401 ../gui/wxpython/gmodeler/dialogs.py:359
-msgid "To"
-msgstr ""
-#. GTC Rename mapset
-#: ../gui/wxpython/dbmgr/base.py:2411 ../gui/wxpython/datacatalog/tree.py:990
-#: ../gui/wxpython/gis_set.py:206
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:202
-msgid "&Rename"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2519
-msgid "Unable to rename column. No column name defined."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2527
-#, python-format
-msgid ""
-"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
-"exists in the table <%(table)s>."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2545
-#, python-format
-msgid ""
-"Unable to rename column. Column <%(column)s> doesn't exist in the table "
-"<%(table)s>."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2584
-msgid "Drop selected column"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2588
-msgid "Drop all columns"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2620
-#, python-format
-msgid ""
-"Selected %s will PERMANENTLY removed from table. Do you want to drop the "
-"column?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2623 ../gui/wxpython/dbmgr/base.py:2667
-msgid "Drop column(s)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2664
-#, python-format
-msgid ""
-"Selected columns\n"
-"%s\n"
-"will PERMANENTLY removed from table. Do you want to drop the columns?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2770
-msgid "List of layers"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2855 ../gui/wxpython/dbmgr/base.py:3283
-#: ../gui/wxpython/dbmgr/base.py:3715
-#, python-format
-msgid "Drop also linked attribute table (%s)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2898
-msgid "Column name"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2898 ../gui/wxpython/gmodeler/frame.py:1732
-#: ../gui/wxpython/gmodeler/frame.py:1785
-msgid "Data type"
-msgstr ""
-msgid "Data length"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2954 ../gui/wxpython/dbmgr/base.py:3075
-#: ../gui/wxpython/dbmgr/base.py:3341 ../gui/wxpython/dbmgr/dialogs.py:512
-#: ../gui/wxpython/vdigit/preferences.py:612
-#: ../gui/wxpython/vdigit/preferences.py:615
-#: ../gui/wxpython/vdigit/dialogs.py:116 ../gui/wxpython/vdigit/dialogs.py:576
-msgid "Layer"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2955 ../gui/wxpython/dbmgr/base.py:3081
-#: ../gui/wxpython/dbmgr/base.py:3349
-msgid "Driver"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2956 ../gui/wxpython/dbmgr/base.py:3086
-#: ../gui/wxpython/dbmgr/base.py:3355 ../gui/wxpython/gui_core/gselect.py:1427
-msgid "Database"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:2958
-msgid "Key"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3057
-msgid "Add layer"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3067
-msgid "Layer description"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3097 ../gui/wxpython/dbmgr/base.py:3141
-#: ../gui/wxpython/dbmgr/base.py:3367
-msgid "Key column"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3102
-msgid "Insert record for each category into table"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3124
-msgid "You need to add categories by v.category module."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3128
-msgid "Table description"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3136
-msgid "Table name"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3150
-msgid "&Create table"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3154
-#: ../gui/wxpython/web_services/dialogs.py:537
-msgid "&Add layer"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3158
-msgid "&Set default"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3262
-msgid "Remove layer"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3265
-msgid "Layer to remove"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3291
-msgid "&Remove layer"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3334
-msgid "Modify layer"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3410
-msgid "&Modify layer"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3459
-msgid ""
-"Unable to get list of tables.\n"
-"Please use db.connect to set database parameters."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3556
-msgid "Unable to create new table. Table name or key column name is missing."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3563
-#, python-format
-msgid "Unable to create new table. Table <%s> already exists in the database."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3604
-#, python-format
-msgid ""
-"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
-"exists."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3773
-msgid "Field statistics"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3794
-msgid "Copy statistics the clipboard (Ctrl+C)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3861
-msgid "Statistics is not support for DBF tables."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3888
-msgid "Unable to calculte statistics."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3896
-#, python-format
-msgid ""
-"Unable to calculte statistics. Invalid number of lines %d (should be %d)."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3916
-msgid "Unable to calculte standard deviation."
-msgstr ""
-#: ../gui/wxpython/dbmgr/base.py:3922
-#, python-format
-msgid "Field statistics <%s>"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:79
-#, python-format
-msgid ""
-"No attribute table found.\n"
-"\n"
-"Do you want to create a new attribute table and defined a link to vector map <%s>?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:83
-msgid "Create table?"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:104
-msgid "Close dialog on submit"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:116
-msgid "No attributes found"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:122
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:689
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1615
-#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1642
-msgid "Update attributes"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:124
-msgid "Define attributes"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:126
-msgid "Display attributes"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:130
-msgid "&Reload"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:131 ../gui/wxpython/dbmgr/dialogs.py:625
-msgid "&Submit"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:149 ../gui/wxpython/vdigit/dialogs.py:175
-msgid "Feature id:"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:237
-#, python-format
-msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:451
-msgid "Unknown"
-msgstr ""
-#: ../gui/wxpython/dbmgr/dialogs.py:512 ../gui/wxpython/dbmgr/dialogs.py:640
-#: ../gui/wxpython/vdigit/dialogs.py:123 ../gui/wxpython/vdigit/dialogs.py:577
-msgid "Category"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:80
-msgid "GRASS GIS Attribute Table Manager - "
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:82
-msgid "READONLY - "
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:100
-#, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. You can "
-"define new connection in 'Manage layers' tab."
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:106
-msgid "Please wait, loading attribute data..."
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:115
-msgid "Browse data"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:123
-msgid "Manage tables"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:130
-msgid "Manage layers"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:141
-msgid "Close Attribute Table Manager"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:144
-msgid "Reload currently selected attribute data"
-msgstr ""
-#: ../gui/wxpython/dbmgr/manager.py:147
-msgid "Reload all attribute data (drop current selection)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:48
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:62
-#: ../gui/wxpython/iclass/g.gui.iclass.py:98
-#: ../gui/wxpython/nviz/wxnviz.py:435
-#, python-format
-msgid "Vector map <%s> not found"
-msgstr ""
-#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:52
-#, python-format
-msgid "Loading attribute data for vector map <%s>..."
-msgstr ""
-#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:56
-msgid "GRASS GIS Attribute Table Manager"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:113
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:900
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1826
-#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1860
-msgid "Query"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:129
-msgid "Set SQL statement to default"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:132
-msgid "Apply SQL statement"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:134
-msgid "Close the dialog"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:221
-msgid "Columns"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:236
-msgid "Interactive insertion"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:250
-msgid "Values"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:260
-msgid "Get all values"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:265
-msgid "Get sample"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:267
-msgid "Get first 256 unique values as sample"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:286
-msgid "Go to:"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:299
-msgid "Close dialog on apply"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:480
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:625
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:853
-#, python-format
-msgid "GRASS SQL Builder (%(type)s) - <%(map)s>"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:483
-msgid "Column to show (SELECT clause)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:484
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:629
-msgid "Constraint for query (WHERE clause)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:500
-msgid "Verify"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:501
-msgid "Verify SQL statement"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:509
-msgid "SQL statement not verified"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:553
-msgid "SQL statement is not valid"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:555
-#, python-format
-msgid ""
-"SQL statement is not valid.\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:557
-msgid "SQL statement is valid"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:628
-msgid "Column to set (SET clause)"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:630
-msgid "Calculate column value to set"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:702
-msgid "Functions"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:735
-msgid "SQL statement was not applied"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:737
-msgid "SQL statement applied"
-msgstr ""
-#: ../gui/wxpython/dbmgr/sqlbuilder.py:771
-msgid "Dbf driver does not support usage of SQL functions."
-msgstr ""
-#: ../gui/wxpython/iclass/plots.py:73
-msgid "Histograms"
-msgstr ""
-#: ../gui/wxpython/iclass/plots.py:74
-msgid "Coincident plots"
-msgstr ""
-#: ../gui/wxpython/iclass/plots.py:75
-msgid "Scatter plots"
-msgstr ""
-#: ../gui/wxpython/iclass/plots.py:99
-#, python-format
-msgid ""
-"Scatter plot functionality is disabled.\n"
-"\n"
-"Reason: Unable to import packages needed for scatter plot.\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:39
-#, python-format
-msgid ""
-"Loading imagery lib failed.\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:79
-msgid "GRASS GIS Supervised Classification Tool"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:325
-msgid "IClass Toolbar"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:337
-msgid "IClass Misc Toolbar"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:364
-msgid "Digitization Toolbar"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:388
-msgid "Plots"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:408
-msgid "Preview Display"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:411
-msgid "Training Areas Display"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:485
-msgid "Adjust Training Area Display to Preview Display"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:487
-msgid "Adjust Preview display to Training Area Display"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:489
-msgid "Display synchronization ON"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:491
-msgid "Display synchronization OFF"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:564
-msgid "All changes will be lost. Do you want to continue?"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:573
-msgid "Import vector map"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:593
-#, python-format
-msgid "No areas in vector map <%s>.\n"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:595
-#, python-format
-msgid "Vector map <%s> contains points or lines, these features are ignored."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:622
-#, python-format
-msgid "Unable to open vector map <%s>"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:633
-#, python-format
-msgid "Unable to copy vector features from <%s>"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:645
-msgid "Unable to open temporary vector map"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:741
-msgid "No training areas to export."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:754
-#, python-format
-msgid "%d training areas (%d classes) exported to vector map <%s>."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:994
-msgid "Failed to create temporary vector map."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1090
-#, python-format
-msgid "No area in category %s. Category skipped."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1094
-msgid "Analysis failed."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1101
-msgid "results"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1107
-msgid "No imagery group selected."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1114
-msgid ""
-"Due to recent changes in classes, signatures can be outdated and should be "
-"recalculated. Do you still want to continue?"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1117
-msgid "Outdated signatures"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1135
-#, python-format
-msgid ""
-"A signature file named %s already exists.\n"
-"Do you want to replace it?"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1138 ../gui/wxpython/gmodeler/frame.py:562
-msgid "File already exists"
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1188
-msgid "No imagery group selected. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1199
-#, python-format
-msgid ""
-"Group <%(group)s> does not have enough files (it has %(files)d files). "
-"Operation canceled."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1207
-msgid "No areas given. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/iclass/frame.py:1222
-msgid "Vector features are outside raster layers. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/iclass/statistics.py:29
-msgid "Loading imagery lib failed"
-msgstr ""
-#: ../gui/wxpython/iclass/digit.py:61
-msgid ""
-"You are trying to create a training area outside the computational region. "
-"Please, use g.region to set the appropriate region first."
-msgstr ""
-#: ../gui/wxpython/iclass/digit.py:72
-msgid ""
-"In order to create a training area, you have to select class first.\n"
-"\n"
-"There is no class yet, do you want to create one?"
-msgstr ""
-#: ../gui/wxpython/iclass/digit.py:76
-#: ../gui/wxpython/iscatt/controllers.py:413
-msgid "No class selected"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:44 ../gui/wxpython/iclass/toolbars.py:40
-#: ../gui/wxpython/iscatt/toolbars.py:46
-msgid "Select imagery group"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:85
-msgid "Name of imagery group is missing."
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:92
-msgid "Name of imagery group:"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:107
-msgid "Name of imagery subgroup:"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:182
-msgid "Please choose a subgroup."
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:186
-#, python-format
-msgid "Subgroup <%s> not found in group <%s>"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:193
-#, python-format
-msgid ""
-"No data found in subgroup <%s> of group <%s>.\n"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:198
-#, python-format
-msgid ""
-"No data found in group <%s>.\n"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:202
-#: ../gui/wxpython/iclass/g.gui.iclass.py:79
-#, python-format
-msgid "Group <%s> not found"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:250
-msgid "Name of map is missing."
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:257
-#: ../gui/wxpython/gmodeler/dialogs.py:89
-msgid "Name of raster map:"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:259
-#: ../gui/wxpython/gui_core/dialogs.py:240
-#: ../gui/wxpython/gmodeler/dialogs.py:91
-msgid "Name of vector map:"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:280 ../gui/wxpython/iclass/toolbars.py:37
-msgid "Class manager"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:295 ../gui/wxpython/iscatt/frame.py:140
-msgid "Classes"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:395 ../gui/wxpython/iscatt/frame.py:413
-msgid "Class name"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:429 ../gui/wxpython/iscatt/frame.py:451
-msgid "Please use only ASCII characters."
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:545
-msgid "Zoom to training areas of selected class"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:607
-msgid "Save signature file"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:668
-msgid "Enter name of signature file:"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:680
-msgid "Signature file path:"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:730
-msgid "Export training areas"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:777 ../gui/wxpython/iscatt/dialogs.py:281
-msgid "Enter name of new vector map:"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:790 ../gui/wxpython/lmgr/layertree.py:602
-msgid "Export attribute table"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:793
-msgid "Export attribute table containing computed statistical data"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:832
-#, python-format
-msgid "Vector map <%s> already exists. Do you want to overwrite it?"
-msgstr ""
-#: ../gui/wxpython/iclass/dialogs.py:835
-#, python-format
-msgid "Vector <%s> exists"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:34
-msgid "Set opacity level"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:43
-msgid "Run analysis, update histogram and coincidence plots"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:46
-msgid "Save signature file for i.maxlik"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:49
-msgid "Remove selected map layer"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:52
-msgid "Export training areas to vector map"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:55
-msgid "Import training areas from vector map"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:58
-#: ../gui/wxpython/gui_core/simplelmgr.py:480
-#: ../gui/wxpython/lmgr/layertree.py:82
-msgid "Add RGB map layer"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:76
-msgid "Training"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:582
-msgid "Preview"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:82
-msgid "Set map canvas for "
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:84
-msgid "/ Zoom to map"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:260
-#: ../gui/wxpython/iclass/toolbars.py:269
-msgid "std dev"
-msgstr ""
-#: ../gui/wxpython/iclass/toolbars.py:343
-msgid "Add raster map"
-msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:75
-msgid "Name of subgroup required"
-msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:84
-#, python-format
-msgid "Subgroup <%s> not found"
-msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:91
-#: ../gui/wxpython/modules/histogram.py:400
-#: ../gui/wxpython/mapswipe/g.gui.mapswipe.py:79
-#: ../gui/wxpython/nviz/wxnviz.py:347 ../gui/wxpython/nviz/wxnviz.py:358
-#, python-format
-msgid "Raster map <%s> not found"
-msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:121
-#, python-format
-msgid "Loading raster map <%s>..."
-msgstr ""
-#: ../gui/wxpython/iclass/g.gui.iclass.py:124
-#, python-format
-msgid "Loading training map <%s>..."
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:502
-#, python-format
-msgid ""
-"Unable to run command:\n"
-"%(cmd)s\n"
-"\n"
-"Option <%(opt)s>: read from standard input is not supported by wxGUI"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:526
-#, python-format
-msgid "Module <%s> not found."
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:656 ../gui/wxpython/gmodeler/frame.py:299
-#, python-format
-msgid "%d sec"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:659 ../gui/wxpython/gmodeler/frame.py:302
-#, python-format
-msgid "%(min)d min %(sec)d sec"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:663 ../gui/wxpython/gui_core/ghelp.py:231
-#: ../gui/wxpython/gmodeler/frame.py:306
-#: ../gui/wxpython/gmodeler/model.py:1123
-#: ../gui/wxpython/gmodeler/model.py:1229
-msgid "unknown"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:667
-msgid ""
-"Please note that the data are left in inconsistent state and may be "
-"corrupted"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:669
-msgid "Command aborted"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:671 ../gui/wxpython/gmodeler/frame.py:312
-msgid "Command finished"
-msgstr ""
-#: ../gui/wxpython/core/gconsole.py:747
-#, python-format
-msgid ""
-"Unable to write file '%(filePath)s'.\n"
-"\n"
-"Details: %(error)s"
-msgstr ""
-#: ../gui/wxpython/core/gcmd.py:126
-msgid "Reason"
-msgstr ""
-#: ../gui/wxpython/core/gcmd.py:140 ../gui/wxpython/core/workspace.py:1635
-#: ../gui/wxpython/mapwin/buffered.py:2140
-#: ../gui/wxpython/wxplot/dialogs.py:965
-msgid "Warning"
-msgstr ""
-#: ../gui/wxpython/core/gcmd.py:151 ../gui/wxpython/lmgr/frame.py:2574
-#: ../gui/wxpython/gis_set.py:697 ../gui/wxpython/gis_set.py:740
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:640
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:683
-msgid "Message"
-msgstr ""
-#: ../gui/wxpython/core/gcmd.py:432
-msgid "Execution failed:"
-msgstr ""
-#: ../gui/wxpython/core/gcmd.py:435 ../gui/wxpython/core/render.py:1010
-#: ../gui/wxpython/core/render.py:1013 ../gui/wxpython/core/render.py:1016
-msgid "Details:"
-msgstr ""
-#: ../gui/wxpython/core/gcmd.py:437 ../gui/wxpython/core/gcmd.py:444
-msgid "Error: "
-msgstr ""
-#: ../gui/wxpython/core/gcmd.py:521
-#, python-format
-msgid "Unable to exectute command: '%s'"
-msgstr ""
-#: ../gui/wxpython/core/gcmd.py:747 ../gui/wxpython/gui_core/forms.py:2768
-#, python-format
-msgid "Error in %s"
-msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:225
-msgid ""
-"Unable to parse user toolboxes XML files. Default files will be loaded."
-msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:269
-msgid "Unable to create toolboxes directory."
-msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:493
-msgid "Custom toolboxes"
-msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:517
-#, python-format
-msgid ""
-"List of addons cannot be obtained because g.extension failed. Details: %s"
-msgstr ""
-#: ../gui/wxpython/core/toolboxes.py:574
-msgid "Addons"
-msgstr ""
-#: ../gui/wxpython/core/menutree.py:151
-#, python-format
-msgid "Unknow tag %s"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:503
-msgid "Segment break"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:569
-msgid "Data point"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:643
-msgid "animation"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:866
-msgid "Collapse all except PERMANENT and current"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:867
-msgid "Collapse all except PERMANENT"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:868
-msgid "Collapse all except current"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:869
-msgid "Collapse all"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:870
-msgid "Expand all"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:875
-msgid "Display selected"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:884
-msgid "Classic (labels only)"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:885
-msgid "Combined (labels and module names)"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:886
-msgid "Expert (module names only)"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:891
-msgid "Basic top"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:892
-msgid "Basic left"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:893
-msgid "Fancy green"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:894
-msgid "List left"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:901
-msgid "Zoom and recenter"
-msgstr ""
-msgid "Zoom to mouse cursor"
-msgstr ""
-msgid "Nothing"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:903
-msgid "Scroll forward to zoom in"
-msgstr ""
-msgid "Scroll back to zoom in"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:936 ../gui/wxpython/core/settings.py:948
-msgid "box"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:937
-msgid "sphere"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:938
-msgid "cube"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:939
-msgid "diamond"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:940
-msgid "aster"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:941
-msgid "gyro"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:942
-msgid "histogram"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:948
-msgid "cross"
-msgstr ""
-msgid "circle"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:981
-#, python-format
-msgid "Unable to read settings file <%s>\n"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:1007
-#, python-format
-msgid ""
-"Error: Reading settings from file <%(file)s> failed.\n"
-"\t\tDetails: %(detail)s\n"
-"\t\tLine: '%(line)s'\n"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:1025
-msgid "Unable to create settings directory"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:1073
-#, python-format
-msgid ""
-"Writing settings to file <%(file)s> failed.\n"
-"\n"
-msgstr ""
-#: ../gui/wxpython/core/settings.py:1179
-msgid "Unable to set "
-msgstr ""
-#: ../gui/wxpython/core/settings.py:1215 ../gui/wxpython/core/settings.py:1225
-#, python-format
-msgid "Unable to parse settings '%s'"
-msgstr ""
-#: ../gui/wxpython/core/ws.py:51
-msgid ""
-"Unable to load GDAL Python bindings.\n"
-"WMS layers can not be displayed without the bindings.\n"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:60
-#, python-format
-msgid "Syntax error: %s"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:351
-#, python-format
-msgid "Vector map <%(map)s>: %(msg)s\n"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:535
-#, python-brace-format
-msgid "failed to open '{0}'"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:841
-#, python-format
-msgid "ERROR: Unable to determine GRASS version. Details: %s"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:882
-#, python-format
-msgid "Unable to open file '%s'\n"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:892
-#, python-format
-msgid ""
-"%s: line skipped - unable to parse '%s'\n"
-"Reason: %s\n"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:897
-#, python-format
-msgid "Duplicated key: %s\n"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:913
-#, python-format
-msgid "Unable to create file '%s'\n"
-msgstr ""
-#: ../gui/wxpython/core/utils.py:996 ../gui/wxpython/gui_core/forms.py:1737
-msgid "Select Color"
-msgstr ""
-#: ../gui/wxpython/core/debug.py:48
-msgid "Wx debug level {0}."
-msgstr ""
-#: ../gui/wxpython/core/debug.py:53
-msgid ""
-"WARNING: Ignoring unsupported wx debug level (must be >=0 and <=5). {0}\n"
-msgstr ""
-#: ../gui/wxpython/core/render.py:151
-#, python-format
-msgid "<%(name)s>: layer type <%(type)s> is not supported"
-msgstr ""
-#: ../gui/wxpython/core/render.py:170
-#, python-format
-msgid "Command '%s' failed\n"
-msgstr ""
-#: ../gui/wxpython/core/render.py:173
-#, python-format
-msgid "Details: %s\n"
-msgstr ""
-#: ../gui/wxpython/core/render.py:258
-#, python-format
-msgid "Unsupported map layer type '%s'"
-msgstr ""
-#: ../gui/wxpython/core/render.py:623
-#, python-format
-msgid "Rendering failed: %s"
-msgstr ""
-#: ../gui/wxpython/core/render.py:666
-msgid "Rendering aborted"
-msgstr ""
-#: ../gui/wxpython/core/render.py:697
-msgid "Downloading data "
-msgstr ""
-#: ../gui/wxpython/core/render.py:707
-msgid "Rendering & "
-msgstr ""
-#: ../gui/wxpython/core/render.py:709
-msgid "Rendering..."
-msgstr ""
-#: ../gui/wxpython/core/render.py:754
-msgid "Trying to recover from default region..."
-msgstr ""
-#: ../gui/wxpython/core/render.py:814
-#, python-format
-msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
-msgstr ""
-#: ../gui/wxpython/core/render.py:824
-#, python-format
-msgid ""
-"\n"
-"ERROR: Unable to read WIND file: %s\n"
-msgstr ""
-#: ../gui/wxpython/core/render.py:928
-#, python-format
-msgid "Invalid map size %d,%d\n"
-msgstr ""
-#: ../gui/wxpython/core/render.py:1009
-#, python-format
-msgid "Unable to zoom to raster map <%s>."
-msgstr ""
-#: ../gui/wxpython/core/render.py:1012
-#, python-format
-msgid "Unable to zoom to vector map <%s>."
-msgstr ""
-#: ../gui/wxpython/core/render.py:1015
-#, python-format
-msgid "Unable to zoom to 3d raster map <%s>."
-msgstr ""
-#: ../gui/wxpython/core/render.py:1019
-msgid ""
-"Unable to get current geographic extent. Force quiting wxGUI. Please "
-"manually run g.region to fix the problem."
-msgstr ""
-#: ../gui/wxpython/core/workspace.py:1614
-#, python-format
-msgid "Unable to open file <%s> for reading."
-msgstr ""
-#: ../gui/wxpython/core/workspace.py:1631
-#, python-format
-msgid ""
-"Some lines were skipped when reading settings from file <%(file)s>.\n"
-"See 'Command output' window for details.\n"
-"\n"
-"Number of skipped lines: %(line)d"
-msgstr ""
-#: ../gui/wxpython/core/workspace.py:1856
-#, python-format
-msgid " row %d:"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:143
-msgid " Requested data settings "
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:170
-msgid "Request"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:175
-msgid "List of layers "
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:193
-msgid "Source projection:"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:254
-msgid "Advanced request settings"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:262
-msgid "Order of layers in raster"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:275
-msgid "Reprojection method:"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:282
-msgid "Nearest neighbor"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:283
-msgid "Linear interpolation"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:284
-msgid "Cubic interpolation"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:285
-msgid "Cubic spline interpolation"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:289
-msgid "Maximum columns to request from server at time:"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:295
-msgid "Maximum rows to request from server at time:"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:312
-msgid "Do not request transparent data"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:317
-#: ../gui/wxpython/gui_core/preferences.py:893
-#: ../gui/wxpython/animation/dialogs.py:1864 ../gui/wxpython/nviz/tools.py:465
-#: ../gui/wxpython/nviz/preferences.py:204
-msgid "Background color:"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:327
-msgid "Additional query parameters for server:"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:540
-#, python-format
-msgid ""
-"Unable to download %s capabilities file\n"
-"from <%s>:\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:557
-#, python-format
-msgid ""
-"%s web service was not found in fetched capabilities file from <%s>:\n"
-"%s\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:843
-msgid "Source image format"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:879
-msgid "Select layer in layer list.\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:884
-msgid "Select source image format.\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:889
-msgid "Select source projection.\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:893
-msgid "Choose output layer name.\n"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:934
-#: ../gui/wxpython/gui_core/ghelp.py:397 ../gui/wxpython/gui_core/ghelp.py:399
-#: ../gui/wxpython/gui_core/ghelp.py:473
-#: ../gui/wxpython/gmodeler/frame.py:1731
-#: ../gui/wxpython/gmodeler/frame.py:1778
-msgid "Name"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:937
-#: ../gui/wxpython/gui_core/forms.py:2040
-#: ../gui/wxpython/modules/import_export.py:79
-msgid "Layer name"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:974
-msgid "layer"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:994
-msgid "style"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:1167
-msgid "Add default"
-msgstr ""
-#: ../gui/wxpython/web_services/widgets.py:1184
-#, python-format
-msgid ""
-"User defined server with same name as default server <%s> already exists.\n"
-"Keeping user defined server"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:96
-msgid " Server settings "
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:99
-msgid "Server:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:103
-msgid "&Connect"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:104
-msgid "Connect to the server"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:108
-msgid "Show advanced connection settings"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:109
-msgid "Hide advanced connection settings"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:127
-msgid " Layer Manager Settings "
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:131
-msgid "Output layer name:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:257
-msgid "Username:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:261
-msgid "Password:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:302
-#: ../gui/wxpython/gui_core/gselect.py:1948
-msgid "No data source defined, settings are not saved."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:387
-#, python-format
-msgid "Connecting to <%s>..."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:455
-msgid "Available web services"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:468
-#, python-format
-msgid "Connected to <%s>"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:474
-#, python-format
-msgid "Unable to connect to <%s>"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:524
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:27
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:28
-#: ../gui/wxpython/menustrings.py:27 ../gui/wxpython/menustrings.py:28
-msgid "Add web service layer"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:539
-msgid "Add selected web service layers as map layer into layer tree"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:637
-msgid "Web service layer properties"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:684
-msgid "&Apply"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:689
-msgid "&OK"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:690
-#: ../gui/wxpython/vdigit/dialogs.py:155
-msgid "Apply changes and close dialog"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:857
-msgid "Name for output raster map:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:867
-msgid "Export region"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:872
-#: ../gui/wxpython/menustrings.py:18
-msgid "Map display"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:876
-msgid "Named region"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:878
-msgid "Extent and resolution are based on Map Display geometry."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:880
-msgid "Extent and resolution are based on computational region."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:882
-msgid "Extent and resolution are based on named region."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:887
-msgid "Overwrite existing raster map"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:892
-msgid "Choose named region:"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:905
-msgid "&Save layer"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:906
-msgid "Save web service layer as raster map"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1019
-msgid "Missing output raster."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1023
-msgid "Output map can be added only to current mapset."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1027
-#, python-format
-msgid "Output map <%s> already exists"
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1048
-#, python-format
-msgid "Region <%s> does not exist."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1077
-msgid "Downloading data..."
-msgstr ""
-#: ../gui/wxpython/web_services/dialogs.py:1104
-msgid "Unable to fetch data.\n"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:70
-#, python-format
-msgid ""
-"Unable to import pyGRASS: %s\n"
-"Some functionality will be not accessible"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:508
-msgid "Not selectable element"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:545
-#: ../gui/wxpython/gui_core/preferences.py:2205
-msgid "Mapset"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:557
-msgid "Type: "
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:575
-#, python-format
-msgid "GSelect: invalid item: %s"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:887
-msgid "No table linked to layer <{}>."
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1195 ../gui/wxpython/gis_set.py:1000
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:923
-msgid "Choose GIS Data Directory"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1400
-msgid "Output settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1402
-msgid "Source input"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1413
-msgid "Native"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1419
-msgid "File"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1423
-#: ../gui/wxpython/gui_core/forms.py:1918
-msgid "Directory"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1431
-msgid "Protocol"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1442
-msgid "Output type"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1444
-msgid "Source type"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1466
-msgid "All files"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1482
-msgid "ZIP files"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1483
-msgid "GZIP files"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1484
-msgid "TAR files"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1486
-msgid "TARGZ files"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1494
-msgid "File:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1495
-msgid "Choose file to import"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1510
-#: ../gui/wxpython/gui_core/gselect.py:1593
-#: ../gui/wxpython/animation/dialogs.py:1196
-msgid "Directory:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1511
-#: ../gui/wxpython/gui_core/gselect.py:1594
-msgid "Choose input directory"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1528
-msgid "Extension:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1557
-#: ../gui/wxpython/gui_core/gselect.py:1572
-#: ../gui/wxpython/gui_core/gselect.py:1574
-#: ../gui/wxpython/gui_core/widgets.py:1298
-#: ../gui/wxpython/gmodeler/preferences.py:706
-#: ../gui/wxpython/vnet/dialogs.py:1643
-#: ../gui/wxpython/animation/dialogs.py:402
-msgid "Name:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1558
-msgid "Choose file"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1579
-#: ../gui/wxpython/gui_core/gselect.py:2339
-msgid "Feature type:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1581
-msgid "simple features"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1582
-msgid "topological"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1693
-#: ../gui/wxpython/gui_core/gselect.py:1724
-#: ../gui/wxpython/gui_core/gselect.py:1775
-#: ../gui/wxpython/gui_core/gselect.py:1813
-msgid "Creation options:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1707
-#: ../gui/wxpython/gui_core/gselect.py:1746
-#: ../gui/wxpython/gui_core/gselect.py:1798
-msgid "Format:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1805
-msgid "Protocol:"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:1828
-msgid "No settings available"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2089
-#: ../gui/wxpython/gmodeler/dialogs.py:919
-#: ../gui/wxpython/location_wizard/wizard.py:932
-msgid "No"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2091
-#: ../gui/wxpython/gmodeler/dialogs.py:921
-msgid "Yes"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2331
-msgid "LineString"
-msgstr ""
-msgid "Polygon"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2550
-msgid "No vector map selected in layer manager. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2563
-msgid "Input vector map is not selected"
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2567
-#, python-format
-msgid ""
-"Input vector map <%s> and selected map <%s> in layer manager are different. "
-msgstr ""
-#: ../gui/wxpython/gui_core/gselect.py:2743
-msgid "No vector map selected"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:153
-msgid "Double-click or Ctrl-Enter to run selected module"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:174 ../gui/wxpython/gui_core/forms.py:605
-#: ../gui/wxpython/modules/vclean.py:173
-#: ../gui/wxpython/modules/mcalc_builder.py:158
-#: ../gui/wxpython/gmodeler/frame.py:1983
-#: ../gui/wxpython/gmodeler/model.py:2835
-msgid "&Run"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:175
-msgid "Run selected module from the tree"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:176
-msgid "H&elp"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:178
-msgid "Show manual for selected module from the tree"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:180
-msgid "Adva&nced search..."
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:182
-#, python-format
-msgid "Do advanced search using %s module"
-msgstr ""
-#: ../gui/wxpython/gui_core/menu.py:283
-#, python-format
-msgid "Documentation for %s is now open in the web browser"
-msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:48
-msgid "category"
-msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:49
-#: ../gui/wxpython/vnet/vnet_data.py:259
-msgid "type"
-msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:73
-msgid "Select features"
-msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:136
-msgid "Create a new map"
-msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:265
-#, python-format
-msgid "Selected map <%s> has been disabled for rendering. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:297
-#, python-format
-msgid "Failed to query vector map(s) <%s>."
-msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:322
-msgid "No features selected"
-msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:346
-#, python-format
-msgid "Vector map <%s> was created"
-msgstr ""
-#: ../gui/wxpython/gui_core/vselect.py:349
-#, python-format
-msgid ""
-"Unable to create a new vector map.\n"
-"\n"
-"Reason: %s"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:31
-msgid "Query results"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:43
-msgid "Right click to copy selected values to clipboard."
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:49
-msgid "Feature"
-msgstr ""
-msgid "Value"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:71
-msgid "Copy all to clipboard"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:74
-msgid "Redirect to console"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:136 ../gui/wxpython/gui_core/query.py:139
-#, python-format
-msgid "Copy from '%s' column"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:141
-msgid "Copy selected lines"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:144 ../gui/wxpython/gui_core/query.py:149
-#, python-format
-msgid "Copy '%s'"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:151
-msgid "Copy line"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:178
-msgid "Query results:"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:181
-msgid " "
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:270
-msgid "east, north"
-msgstr ""
-#: ../gui/wxpython/gui_core/query.py:281
-msgid "Nothing found"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:128
-msgid "Click here to show search module engine"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:130
-msgid "Click here to hide search module engine"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:147
-msgid "Command prompt"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:152
-msgid "Output window"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:160
-msgid "Clear output window content"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:162
-msgid "Clear command prompt content"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:165
-msgid "Save output window content to the file"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:167
-msgid "Abort running command"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:171
-msgid "&Log file"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:173
-msgid ""
-"Toggle to save list of executed commands into a file; content saved when "
-"switching off."
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:421
-#: ../gui/wxpython/gui_core/goutput.py:516
-msgid "Save file as..."
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:423
-#: ../gui/wxpython/gui_core/goutput.py:518
-#, python-format
-msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:424
-#: ../gui/wxpython/gui_core/goutput.py:519
-msgid "Text files"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:425
-#: ../gui/wxpython/gui_core/goutput.py:520
-msgid "Files"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:438
-#, python-format
-msgid ""
-"Unable to write file '%(path)s'.\n"
-"\n"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:443
-#, python-format
-msgid "Command output saved into '%s'"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:497
-msgid ""
-"Unable to write file '{filePath}'.\n"
-"\n"
-"Details: {error}"
-msgstr ""
-#: ../gui/wxpython/gui_core/goutput.py:501
-msgid "Command log saved to '{}'"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:109
-msgid "Toolbar"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:145
-msgid "Copy map names to clipboard (top to bottom)"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:146
-msgid "Copy map names to clipboard (bottom to top)"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:288
-#: ../gui/wxpython/lmgr/layertree.py:1236
-#, python-format
-msgid "Set opacity of <%s>"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:464
-msgid "Remove selected map(s) from list"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:466
-msgid "Layer up"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:467
-msgid "Move selected layer(s) up"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:469
-msgid "Layer down"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:470
-msgid "Move selected layer(s) down"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:472
-#: ../gui/wxpython/gui_core/simplelmgr.py:473
-msgid "Edit layer properties"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:475
-msgid "Change opacity"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:476
-msgid "Change layer opacity"
-msgstr ""
-#: ../gui/wxpython/gui_core/simplelmgr.py:478
-#: ../gui/wxpython/gui_core/simplelmgr.py:479
-#: ../gui/wxpython/lmgr/layertree.py:106
-msgid "Add 3D raster map layer"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:37
-msgid "Display map"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:38
-msgid "Re-render modified map layers only"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:40
-msgid "Render map"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:41
-msgid "Force re-rendering all map layers"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:43
-msgid "Erase display"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:44
-msgid "Erase display canvas with given background color"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:46
-msgid "Pointer"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:48
-msgid "Zoom in"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:49
-msgid "Drag or click mouse to zoom"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:51
-msgid "Zoom out"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:52
-msgid "Drag or click mouse to unzoom"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:54
-msgid "Return to previous zoom"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:56
-msgid "Various zoom options"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:57
-msgid "Zoom to default or saved region, save to named region, ..."
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:59
-msgid "Zoom to selected map layer(s)"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:61
-msgid "Zoom to computational region extent"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:63
-msgid "Pan"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:64
-msgid "Drag with mouse to pan"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:66
-msgid "Save display to file"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:70
-#: ../gui/wxpython/gui_core/forms.py:1328
-#: ../gui/wxpython/gui_core/forms.py:2724
-msgid "Select font"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:72
-#: ../gui/wxpython/vnet/toolbars.py:137 ../gui/wxpython/iscatt/toolbars.py:51
-msgid "Show manual"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:74
-#: ../gui/wxpython/lmgr/layertree.py:78
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2035
-#: ../gui/wxpython/menustrings.py:2069
-msgid "Quit"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:76
-#: ../gui/wxpython/lmgr/layertree.py:80
-msgid "Add raster map layer"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:78
-#: ../gui/wxpython/lmgr/layertree.py:92
-msgid "Add vector map layer"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:80
-msgid "Add map elements"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:81
-msgid "Overlay elements like scale and legend onto map"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:83
-msgid "Create histogram with d.histogram"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:85 ../gui/wxpython/vnet/dialogs.py:946
-#: ../gui/wxpython/iscatt/toolbars.py:48
-#: ../gui/wxpython/iscatt/toolbars.py:146 ../gui/wxpython/nviz/tools.py:2272
-msgid "Settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/toolbars.py:260
-msgid "Select graphics tool"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:114
-msgid " (...)"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:855
-#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII "
-"characters excluding %(chars)s and space."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:860 ../gui/wxpython/gis_set.py:1172
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:1095
-msgid "Invalid name"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1086
-msgid "Fulltext search"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1088
-msgid "Type to search in all modules. Press Enter for next match."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1155
-msgid "Searching, please type more characters."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1164
-#, python-format
-msgid "%d modules match"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1234
-msgid "Profiles"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1240
-msgid "Save current settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1244
-msgid "Delete currently selected settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1267
-msgid "Load:"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1285
-#, python-format
-msgid "Settings <%s> not found"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1299
-#: ../gui/wxpython/gui_core/widgets.py:1319
-msgid "Save settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1304
-msgid "Name not given, settings is not saved."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1316
-#, python-format
-msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1367
-msgid "No settings is defined. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/gui_core/widgets.py:1405
-msgid "Unable to save settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:279
-#: ../gui/wxpython/gmodeler/frame.py:2028
-#, python-format
-msgid "Unable to launch Python script. %s"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:315
-#: ../gui/wxpython/gmodeler/frame.py:2055
-msgid "Choose file to save"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:317
-#: ../gui/wxpython/gui_core/pyedit.py:379
-#: ../gui/wxpython/gmodeler/frame.py:2060
-msgid "Python script (*.py)|*.py"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:333
-#: ../gui/wxpython/gmodeler/frame.py:2077
-#: ../gui/wxpython/wxplot/profile.py:374
-#, python-format
-msgid "File <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:335
-#: ../gui/wxpython/gmodeler/frame.py:2080
-msgid "Save file"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:377
-msgid "Open file"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:448
-msgid "Replace the content by the template?"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:450
-msgid "Replace the content by the example?"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:452
-msgid "Replace the current content by the file content?"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:458
-msgid "Replace content"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:470
-msgid "Set parameters for the script"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:471
-msgid "Specify command line parameters for the script separated by spaces:"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:521
-msgid "Open (Ctrl+O)"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:523
-msgid "Save (Ctrl+S)"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:525
-msgid "Run (Ctrl+R)"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:528
-msgid "Activate overwrite"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:530
-msgid "Deactive overwrite"
-msgstr ""
-#: ../gui/wxpython/gui_core/pyedit.py:581
-msgid "GRASS GIS Simple Python Editor"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:53
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1033
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1034
-#: ../gui/wxpython/menustrings.py:1051 ../gui/wxpython/menustrings.py:1052
-msgid "About GRASS GIS"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:75
-msgid "Info"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:76
-msgid "Copyright"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:77
-msgid "License"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:78
-msgid "Citation"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:79
-msgid "Authors"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:80
-msgid "Contributors"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:81
-msgid "Extra contributors"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:82
-msgid "Translators"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:83
-msgid "Translation status"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:118 ../gui/wxpython/gui_core/ghelp.py:921
-#: ../gui/wxpython/lmgr/frame.py:87 ../gui/wxpython/lmgr/frame.py:1221
-msgid "Unable to get GRASS version\n"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:131 ../gui/wxpython/lmgr/frame.py:1245
-msgid "unknown version"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:147
-msgid "Official GRASS site:"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:158
-msgid "Code Revision"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:169
-msgid "Build Date"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:223 ../gui/wxpython/gui_core/ghelp.py:481
-msgid "Language"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:252 ../gui/wxpython/gui_core/ghelp.py:277
-#: ../gui/wxpython/gui_core/ghelp.py:328 ../gui/wxpython/gui_core/ghelp.py:391
-#: ../gui/wxpython/gui_core/ghelp.py:465 ../gui/wxpython/gui_core/ghelp.py:630
-#, python-format
-msgid "%s file missing"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:300
-msgid ""
-"Unable to provide citation suggestion, see GRASS GIS website instead. The "
-"error was: {0}"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:376 ../gui/wxpython/gui_core/ghelp.py:449
-#, python-format
-msgid "Error when reading file '%s'."
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:377 ../gui/wxpython/gui_core/ghelp.py:450
-msgid "Lines:"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:477
-msgid "E-mail"
-msgstr ""
-msgid "Country"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:399
-msgid "OSGeo_ID"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:485
-msgid "Nation"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:534
-#, python-format
-msgid "   %d translated"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:538 ../gui/wxpython/gui_core/ghelp.py:564
-#, python-format
-msgid "   %d fuzzy"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:542 ../gui/wxpython/gui_core/ghelp.py:573
-#, python-format
-msgid "   %d untranslated"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:555
-#, python-format
-msgid "%d translated"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:627
-#, python-format
-msgid "File <%s> not found"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:800
-msgid "&Next"
-msgstr ""
-#: ../gui/wxpython/gui_core/ghelp.py:803
-msgid "&Previous"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:61
-msgid "User settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:85
-msgid "Set to default"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:93
-msgid "Revert settings to default"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:96
-msgid "Apply changes for the current session only and close"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:97
-msgid "Save for this session only"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:167
-msgid "Settings applied to current session but not saved"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:239
-msgid "Key column cannot be empty string."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:258
-msgid "GUI Settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:283
-#: ../gui/wxpython/gmodeler/preferences.py:54
-#: ../gui/wxpython/vdigit/preferences.py:150
-#: ../gui/wxpython/animation/dialogs.py:340
-#: ../gui/wxpython/animation/dialogs.py:1854
-msgid "General"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:293
-msgid "Layer Manager settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:303
-msgid "Ask when removing map layer from layer tree"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:316
-msgid "Ask when quiting wxGUI or closing display"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:331
-#: ../gui/wxpython/gui_core/preferences.py:348
-#, python-format
-msgid "Hide '%s' tab (requires GUI restart)"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:332
-#: ../gui/wxpython/gui_core/preferences.py:1122
-#: ../gui/wxpython/lmgr/frame.py:366
-msgid "Modules"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:349
-#: ../gui/wxpython/lmgr/frame.py:390
-msgid "Python"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:368
-msgid "Automatically copy selected text to clipboard (in the Console tab)"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:396
-msgid "Workspace settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:403
-msgid "Suppress positioning Map Display Window(s)"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:419
-msgid "Suppress positioning Layer Manager window"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:434
-msgid "Save current window layout as default"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:443
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:465
-msgid "Region settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:472
-msgid "Align region to resolution"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:501
-#: ../gui/wxpython/nviz/tools.py:100
-msgid "Appearance"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:526
-msgid "Font for command output:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:531
-#: ../gui/wxpython/gui_core/preferences.py:808
-#: ../gui/wxpython/animation/dialogs.py:1061
-msgid "Set font"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:544
-msgid "Language settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:560
-msgid "Choose language (requires to save and GRASS restart):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:593
-msgid "Appearance settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:603
-msgid "Element list:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:633
-msgid "Menu style (requires to save and GUI restart):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:668
-msgid "Height of map selection popup window (in pixels):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:708
-msgid "Icon theme (requires GUI restart):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:735
-msgid "Module dialog style:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:781
-#: ../gui/wxpython/gui_core/forms.py:1447
-msgid "Map Display"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:802
-msgid "Default font for GRASS displays:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:829
-msgid "Default display settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:839
-msgid "Display driver:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:865
-msgid "Statusbar mode:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:949
-msgid "Enable auto-rendering"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:966
-msgid "Enable auto-zooming to selected map layer"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:982
-msgid "Show computational region extent"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:998
-msgid "Mouse wheel action:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1024
-msgid "Mouse scrolling direction:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1065
-msgid "Advanced display settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1074
-msgid "3D view depth buffer (possible values are 16, 24, 32):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1129
-msgid "Module dialog settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1140
-#: ../gui/wxpython/modules/vclean.py:145
-#: ../gui/wxpython/modules/import_export.py:96
-#: ../gui/wxpython/modules/mcalc_builder.py:283
-#: ../gui/wxpython/gmodeler/preferences.py:682
-msgid "Allow output files to overwrite existing files"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1154
-msgid "Close dialog when module is successfully finished"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1168
-#: ../gui/wxpython/gui_core/dialogs.py:307
-msgid "Add created map into layer tree"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1183
-msgid "Allow interactive input"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1197
-msgid "Verbosity level:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1233
-#: ../gui/wxpython/lmgr/frame.py:323
-msgid "Layers"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1243
-msgid "Default raster settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1253
-msgid "Make null cells opaque"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1268
-msgid "Default color table"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1314
-msgid "Default vector settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1320
-msgid "Display:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1345
-msgid "Feature color:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1365
-#: ../gui/wxpython/gui_core/preferences.py:1400
-#: ../gui/wxpython/gui_core/forms.py:1787
-msgid "Transparent"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1385
-msgid "Area fill color:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1433
-msgid "Random colors according to category number "
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1461
-msgid "Symbol:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1506
-#: ../gui/wxpython/vdigit/preferences.py:582
-msgid "Attributes"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1544
-msgid "Line width (in pixels):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1560
-msgid "Automatically hightlight selected features in map display"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1584
-msgid "Data browser"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1592
-msgid "Left mouse double click:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1617
-msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1632
-msgid "Ask when deleting data record(s) from table"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1656
-msgid "Create table"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1663
-#: ../gui/wxpython/gui_core/dialogs.py:352
-msgid "Key column:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1706
-msgid "Projection statusbar settings"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1715
-msgid ""
-"\n"
-"Note: This only controls the coordinates displayed in the lower-left of the Map Display\n"
-"window's status bar. It is purely cosmetic and does not affect the working location's\n"
-"projection in any way. You will need to enable the Projection check box in the drop-down\n"
-"menu located at the bottom of the Map Display window.\n"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1730
-#: ../gui/wxpython/location_wizard/wizard.py:1502
-msgid "EPSG code:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1748
-msgid "Proj.4 string (required):"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1765
-msgid "EPSG file:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1782
-msgid ""
-"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
-"directly."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1790
-msgid "&Load EPSG codes"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1810
-msgid "Coordinates format"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1818
-msgid "Lat/long projections"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1839
-msgid "Precision:"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1918
-#: ../gui/wxpython/location_wizard/wizard.py:1696
-msgid "Unable to read EPGS codes: {0}"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1925
-#, python-format
-msgid "Unable to read EPSG codes: %s"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1958
-#: ../gui/wxpython/gui_core/preferences.py:1970
-#: ../gui/wxpython/gui_core/preferences.py:1982
-#, python-format
-msgid "EPSG code %s not found"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:1992
-msgid "Select default display font"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:2006
-msgid "Failed to set default display font. Try different font."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:2025
-msgid "Select default output font"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:2114
-msgid "Manage access to mapsets"
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:2129
-msgid ""
-"Check a mapset to make it accessible, uncheck it to hide it.\n"
-"  Notes:\n"
-"    - The current mapset is always accessible.\n"
-"    - You may only write to the current mapset.\n"
-"    - You may only write to mapsets which you own."
-msgstr ""
-#: ../gui/wxpython/gui_core/preferences.py:2206
-msgid "Owner"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:559
-msgid "Enter parameters for '"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:571
-#: ../gui/wxpython/mapswipe/dialogs.py:193
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:14
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1981
-#: ../gui/wxpython/menustrings.py:14 ../gui/wxpython/menustrings.py:2015
-msgid "Close"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:575
-msgid "Close this window without executing the command (Ctrl+Q)"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:606
-msgid "Run the command (Ctrl+R)"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:621
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:168
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1169
-#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1190
-msgid "Copy"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:625
-#: ../gui/wxpython/modules/mcalc_builder.py:169
-msgid "Copy the current command string to the clipboard"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:634
-msgid "Show manual page of the command (Ctrl+H)"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:673
-msgid "Add created map(s) into layer tree"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:694
-#: ../gui/wxpython/modules/import_export.py:105
-msgid "Close dialog on finish"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:703
-msgid ""
-"Close dialog when command is successfully finished. Change this settings in "
-"Preferences dialog ('Command' tab)."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:888
-#, python-format
-msgid "'%s' copied to clipboard"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:972 ../gui/wxpython/gui_core/forms.py:986
-msgid "Required"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:975 ../gui/wxpython/gui_core/forms.py:987
-msgid "Optional"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1070
-#: ../gui/wxpython/gui_core/forms.py:2084
-msgid "Parameterized in model"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1139
-msgid "This option is required"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1160
-msgid "[multiple]"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1218
-msgid "valid range"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1441 ../gui/wxpython/lmgr/toolbars.py:158
-msgid "Graphical Modeler"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1560
-msgid "Show graphical representation of temporal extent of dataset(s) ."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1823
-#: ../gui/wxpython/gui_core/forms.py:1915
-#, python-format
-msgid "Choose %s"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1826
-#: ../gui/wxpython/gmodeler/frame.py:1750
-msgid "file"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1866
-#: ../gui/wxpython/modules/mcalc_builder.py:165
-msgid "&Load"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1868
-msgid "Load and edit content of a file"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1871
-msgid "&Save as"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1873
-msgid "Save content to a file for further use"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1878
-msgid "or enter values directly:"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:1880
-msgid ""
-"Enter file content directly instead of specifying a file. Temporary file "
-"will be automatically created."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2039
-#: ../gui/wxpython/modules/import_export.py:78
-#: ../gui/wxpython/modules/import_export.py:869
-msgid "Layer id"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2042
-#: ../gui/wxpython/modules/import_export.py:83
-#: ../gui/wxpython/modules/import_export.py:85
-msgid "Projection match"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2283
-#: ../gui/wxpython/gmodeler/frame.py:171
-msgid "Command output"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2296
-msgid "Manual"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2340
-msgid "Nothing to load."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2348
-#, python-format
-msgid ""
-"Unable to load file.\n"
-"\n"
-"Reason: %s"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2374
-#: ../gui/wxpython/modules/colorrules.py:690
-msgid "Nothing to save."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2378
-msgid "Save input as..."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2711
-msgid "No dataset given."
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2880
-#: ../gui/wxpython/gui_core/forms.py:2897
-#, python-format
-msgid "Unable to parse command '%s'"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2904
-#, python-format
-msgid "%(cmd)s: parameter '%(key)s' not available"
-msgstr ""
-#: ../gui/wxpython/gui_core/forms.py:2986
-msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:72
-msgid "Required item is not set."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:103
-msgid "Select GRASS location and mapset"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:123
-msgid "Location or mapset is not defined."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:133
-msgid "Name of GRASS location:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:144
-#: ../gui/wxpython/gui_core/dialogs.py:201
-msgid "Name of mapset:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:173
-msgid "Select mapset in GRASS location"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:193
-msgid "Name of mapset is missing."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:214
-#: ../gui/wxpython/vdigit/toolbars.py:841
-#: ../gui/wxpython/vdigit/toolbars.py:998
-#: ../gui/wxpython/vdigit/toolbars.py:1096
-msgid "Select vector map"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:234
-msgid "Name of vector map is missing."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:265
-#: ../gui/wxpython/gui_core/dialogs.py:403
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:544
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1470
-#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1495
-msgid "Create new vector map"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:287
-msgid "Create attribute table"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:321
-msgid "Name of new vector map is missing."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:333
-msgid "Name for new vector map:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:436
-#, python-format
-msgid "Unable to create vector map <%s>."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:441
-#, python-format
-msgid ""
-"Invalid or empty key column.\n"
-"Unable to create vector map <%s>."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:472
-#, python-format
-msgid ""
-"Vector map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:476
-#: ../gui/wxpython/modules/colorrules.py:679
-#: ../gui/wxpython/rdigit/dialogs.py:104
-#: ../gui/wxpython/datacatalog/tree.py:220
-#: ../gui/wxpython/lmgr/layertree.py:1085
-msgid "Overwrite?"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:562
-msgid "Load region:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:568
-msgid "Save region:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:620
-msgid ""
-"Name cannot begin with '.' and must not contain space, quotes, '/', ''', "
-"'@', ',', '=', '*', and all other non-alphanumeric characters."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:636
-msgid "Create or edit imagery groups"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:670
-msgid "Apply changes to selected group and close dialog"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:671
-msgid "Apply changes to selected group"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:672
-msgid "Close dialog, changes are not applied"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:713
-#: ../gui/wxpython/gui_core/dialogs.py:1510
-msgid ""
-"Put here a regular expression. Characters '.*' stand for anything, character"
-" '^' stands for the beginning and '$' for the end."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:720
-msgid "Select existing group or enter name of new group:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:731
-msgid "Edit/create subgroup"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:744
-msgid "Select existing subgroup or enter name of new subgroup:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:778
-#: ../gui/wxpython/gui_core/dialogs.py:846
-#: ../gui/wxpython/gui_core/dialogs.py:1495
-msgid "Pattern:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:796
-#: ../gui/wxpython/gui_core/dialogs.py:864
-#: ../gui/wxpython/gui_core/dialogs.py:1519
-msgid "List of maps:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:812
-msgid "Select map layers and add them to the list."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:817
-msgid "Remove selected layer(s) from list."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:874
-msgid "Check maps from group to be included into subgroup."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1038
-msgid "Add selected map layers into group"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1175
-#, python-format
-msgid "Group <%s> was changed, do you want to apply changes?"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1178
-#: ../gui/wxpython/gui_core/dialogs.py:1194
-msgid "Unapplied changes"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1191
-#, python-format
-msgid "Subgroup <%s> was changed, do you want to apply changes?"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1248
-msgid "No raster maps selected."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1277
-#, python-format
-msgid "No changes to apply in group <%s>."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1280
-#, python-format
-msgid "Group <%s> was successfully created."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1282
-#, python-format
-msgid "Group <%s> was successfully changed."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1285
-#, python-format
-msgid "Creating of new group <%s> failed."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1287
-#, python-format
-msgid "Changing of group <%s> failed."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1325
-msgid "No group selected."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1330
-msgid "No subgroup selected."
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1437
-msgid "Use fully-qualified map names"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1453 ../gui/wxpython/nviz/tools.py:728
-msgid "3D raster"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1463
-msgid "Map type:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1478
-msgid "Select toggle"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1485
-msgid "Mapset:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1579
-msgid "Invert selection"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1722
-#, python-format
-msgid "Dynamic series (%s)"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1749
-msgid "Set Map Layer Opacity"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1783
-msgid "opaque"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1884
-msgid "Set image size"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1899
-msgid "Image size"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1946
-msgid "Template:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:1986
-msgid "GRASS GIS SQL Query Utility"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2002
-msgid " SQL statement "
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2050
-msgid "Symbols"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2085
-msgid "Symbol directory:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2097
-msgid "Symbol name:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2331
-#: ../gui/wxpython/gui_core/dialogs.py:2355
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:211
-#: ../gui/wxpython/menustrings.py:216
-msgid "Quit GRASS GIS"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2348
-msgid ""
-"Do you want to quit GRASS including shell prompt or just close the GUI?"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2352
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:209
-#: ../gui/wxpython/menustrings.py:214
-msgid "Close GUI"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2425
-msgid "Select font:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2456
-msgid "Character encoding:"
-msgstr ""
-#: ../gui/wxpython/gui_core/dialogs.py:2526
-msgid "Example"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:79
-msgid "Check all"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:82
-msgid "Clear all"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:140
-msgid "Enter vector attribute values"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:311
-msgid "Bad color format. Use color format '0:0:0'"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:413
-#: ../gui/wxpython/wxplot/dialogs.py:467
-msgid "Select raster map:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:415
-msgid "Select vector map:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:435
-msgid "Import or export color table:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:440
-msgid "Choose file to load color table"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:441
-msgid "Load"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:443
-msgid "Type filename or click to choose file and load color table"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:449
-msgid "Choose file to save color table"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:451
-msgid "Type filename or click to choose file and save color table"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:453
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1977
-#: ../gui/wxpython/menustrings.py:10 ../gui/wxpython/menustrings.py:2011
-msgid "Save"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:465
-msgid "&Set"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:473
-msgid "Load color table:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:479
-msgid "Load color table from file:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:487
-msgid "Save color table to file:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:519
-msgid "Reload default table"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:587
-msgid "Show preview of map (current Map Display extent is used)."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:619
-#: ../gui/wxpython/modules/colorrules.py:1889
-msgid "No valid color rules given."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:676
-#, python-format
-msgid "File <%s> already already exists. Do you want to overwrite it?"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:723
-msgid "Invalid color table format"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:804
-#, python-format
-msgid "Invalid rule value '%s'. Unable to apply color table."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:890
-msgid "Create new color table for raster map"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:968
-msgid "Enter raster category values or percents"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:974
-msgid "fp range"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:976
-#, python-format
-msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1083
-msgid "Create new color rules for vector map"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1096
-#: ../gui/wxpython/modules/colorrules.py:1673
-msgid "Enter vector attribute values or percents:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1098
-#: ../gui/wxpython/modules/colorrules.py:1675
-msgid "Enter vector attribute values:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1109
-msgid "Select vector columns"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1111
-msgid "Layer:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1113
-msgid "Attribute column:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1116
-msgid "Load color from column:"
-msgstr ""
-msgid "Save color to column:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1118
-msgid "Load size from column:"
-msgstr ""
-msgid "Save size to column:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1120
-msgid "Load width from column:"
-msgstr ""
-msgid "Save width to column:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1125
-msgid "Use color column instead of color table:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1141
-msgid "Add GRASSRGB column to current attribute table."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1200
-#: ../gui/wxpython/modules/colorrules.py:1256
-msgid "Import or export color table"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1270
-#, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file.  Do you "
-"want to create and connect new attribute table?"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1274
-msgid "No database connection defined"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1347
-#, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
-"table cannot be edited."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1518
-#, python-format
-msgid "%s column already exists."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1552
-msgid "Please wait, loading data from attribute table..."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1613
-#, python-format
-msgid ""
-"Number of loaded records reached %d, displaying all the records will be "
-"time-consuming and may lead to computer freezing, do you still want to "
-"continue?"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1617
-msgid "Too many records"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1664
-#, python-format
-msgid "Enter vector attribute values or percents %s:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1668
-#, python-format
-msgid "Enter vector attribute values %s:"
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1821
-msgid "Please select column to save values to."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1857
-msgid "No color column defined. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/modules/colorrules.py:1874
-msgid "Thematic mapping for vector map in 3D view"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:41
-msgid "Fetch & install extension from GRASS Addons"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:58
-msgid "Repository (leave empty to use the official one)"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:61
-msgid "List of extensions - double-click to install"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:85
-msgid "Options"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:113
-msgid "&Fetch"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:114
-msgid "Fetch list of available modules from GRASS Addons SVN repository"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:118
-msgid "&Install"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:120
-msgid "Install selected add-ons GRASS module"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:123
-msgid "Show g.extension manual page"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:187
-msgid "Extension not defined"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:211
-msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:226
-#, python-format
-msgid "%d extensions loaded"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:238
-msgid "Install"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:243
-msgid "Show manual page"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:344
-#, python-format
-msgid "Unable to load extensions. %s"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:390
-msgid "Manage installed GRASS Addons extensions"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:406
-msgid "List of installed extensions"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:414
-msgid "Uninstall"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:416
-msgid "Uninstall selected Addons extensions"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:420
-msgid "Reinstall"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:422
-msgid "Reinstall selected Addons extensions"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:463
-msgid "No extension selected. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:490
-#, python-format
-msgid ""
-"List of files to be removed:\n"
-"%(files)s\n"
-"\n"
-"Do you want really to remove <%(ext)s> extension?"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:494
-msgid "Remove extension"
-msgstr ""
-#: ../gui/wxpython/modules/extensions.py:527
-msgid "Extension"
-msgstr ""
-#: ../gui/wxpython/modules/histogram.py:191
-#: ../gui/wxpython/mapwin/buffered.py:699
-msgid "Please wait, exporting image..."
-msgstr ""
-#: ../gui/wxpython/modules/histogram.py:293
-msgid "GRASS GIS Histogramming Tool (d.histogram)"
-msgstr ""
-#: ../gui/wxpython/modules/histogram.py:425
-msgid "Select font for histogram text"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:34 ../gui/wxpython/modules/vclean.py:120
-msgid "Set up vector cleaning tools"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:75
-msgid "break lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:76
-msgid "remove duplicates"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:77
-msgid "remove dangles"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:78
-msgid "change boundary dangles to lines"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:79
-msgid "remove bridges"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:80
-msgid "change bridges to lines"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:81
-msgid "snap lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:82
-msgid "remove duplicate area centroids"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:83
-msgid "break polygons"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:84
-msgid "prune lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:85
-msgid "remove small areas"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:86
-msgid "remove lines/boundaries of zero length"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:87
-msgid "remove small angles at nodes"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:122
-msgid "Choose cleaning tools and set thresholds"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:126
-msgid "Select input vector map:"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:132
-msgid " Feature type: "
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:136
-msgid "Select output vector map:"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:177
-msgid "Copy the current command string to the clipboard (Ctrl+C)"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:223
-msgid "line"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:224
-msgid "boundary"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:225
-msgid "centroid"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:226
-#: ../gui/wxpython/vdigit/preferences.py:695
-msgid "area"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:227
-msgid "face"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:401
-#, python-format
-msgid "%s. cleaning tool removed, will be ignored"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:404
-msgid "Please select a cleaning tool to remove"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:428
-#, python-format
-msgid "%s. cleaning tool moved up"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:430
-msgid "1. cleaning tool can not be moved up "
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:432
-msgid "Please select a cleaning tool to move up"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:460
-#, python-format
-msgid "%s. cleaning tool moved down"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:462
-msgid "Last cleaning tool can not be moved down "
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:464
-msgid "Please select a cleaning tool to move down"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:478
-#, python-format
-msgid "cleaning tool: '%s'"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:488
-#, python-format
-msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:516
-msgid "Name of input vector map"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:517
-msgid "Name for output vector map"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:518
-#: ../gui/wxpython/mapswipe/toolbars.py:29
-msgid "Tools"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:519
-msgid "Threshold"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:521
-#, python-format
-msgid "'%s' not defined"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:523
-#, python-format
-msgid ""
-"Some parameters not defined. Operation canceled.\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:528
-msgid "Executing selected cleaning operations..."
-msgstr ""
-#: ../gui/wxpython/modules/vclean.py:585
-msgid "Vector cleaning command copied to clipboard"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:52
-msgid "Multiple import"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:69
-msgid "List of raster layers"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:71
-msgid "List of vector layers"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:73
-#, python-format
-msgid "List of %s layers"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:75
-#: ../gui/wxpython/modules/import_export.py:892
-msgid "right click to (un)select all"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:80
-msgid "Name for output GRASS map (editable)"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:92
-msgid "Override projection check (use current location's projection)"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:123
-#: ../gui/wxpython/modules/import_export.py:400
-#: ../gui/wxpython/modules/import_export.py:541
-msgid "&Import"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:124
-#: ../gui/wxpython/modules/import_export.py:401
-#: ../gui/wxpython/modules/import_export.py:542
-msgid "Import selected layers"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:135
-msgid "Source settings"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:156
-msgid "Import settings"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:376
-#: ../gui/wxpython/lmgr/layertree.py:60
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:159
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1160
-#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1181
-msgid "Link external raster data"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:378
-#: ../gui/wxpython/lmgr/layertree.py:58
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:37
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1038
-#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1056
-msgid "Import raster data"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:386
-#: ../gui/wxpython/modules/import_export.py:527
-msgid "Add linked layers into layer tree"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:388
-#: ../gui/wxpython/modules/import_export.py:529
-#: ../gui/wxpython/modules/import_export.py:758
-msgid "Add imported layers into layer tree"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:397
-#: ../gui/wxpython/modules/import_export.py:538
-msgid "&Link"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:398
-#: ../gui/wxpython/modules/import_export.py:539
-msgid "Link selected layers"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:421
-#: ../gui/wxpython/modules/import_export.py:562
-msgid "No layers selected. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:447
-msgid "Unable to determine number of raster bands"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:517
-#: ../gui/wxpython/lmgr/layertree.py:68
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:161
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1162
-#: ../gui/wxpython/menustrings.py:164 ../gui/wxpython/menustrings.py:1183
-msgid "Link external vector data"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:519
-#: ../gui/wxpython/lmgr/layertree.py:66
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:67
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1068
-#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1087
-msgid "Import vector data"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:662
-msgid "Define output format for vector data"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:664
-msgid "Define output format for raster data"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:672
-msgid "Set external format and close dialog"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:729
-msgid "No data source selected."
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:744
-msgid "Import DXF layers"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:751
-msgid "Choose DXF file to import"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:780
-msgid "No layers selected."
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:858
-#: ../gui/wxpython/datacatalog/dialogs.py:32
-msgid "Reprojection"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:870
-msgid "Name for output GRASS map"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:888
-msgid ""
-"Projection of following layers do not match with projection of current "
-"location. "
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:890
-msgid "Layers to be reprojected"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:904
-msgid "&Import && reproject"
-msgstr ""
-#: ../gui/wxpython/modules/import_export.py:905
-msgid "Reproject selected layers"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:56
-msgid "GRASS GIS Raster Map Calculator"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:59
-msgid "GRASS GIS 3D Raster Map Calculator"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:75
-msgid "mapcalc statement"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:142
-msgid "Operators"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:144
-#: ../gui/wxpython/vnet/dialogs.py:348
-msgid "Output"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:146
-msgid "Operands"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:148
-msgid "Expression"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:163
-msgid "Save expression to file"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:166
-msgid "Load expression from file"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:173
-msgid "exponent"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:175
-msgid "divide"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:177
-msgid "add"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:180
-msgid "subtract"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:182
-msgid "modulus"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:185
-msgid "multiply"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:193
-msgid "left shift"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:196
-msgid "right shift"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:199
-msgid "right shift (unsigned)"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:201
-msgid "greater than"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:204
-msgid "greater than or equal to"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:206
-msgid "less than"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:209
-msgid "less than or equal to"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:211
-msgid "equal to"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:214
-msgid "not equal to"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:218
-msgid "one's complement"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:220
-msgid "NOT"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:223
-msgid "bitwise AND"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:226
-msgid "bitwise OR"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:229
-msgid "logical AND"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:232
-msgid "logical AND (ignores NULLs)"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:234
-msgid "logical OR"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:237
-msgid "logical OR (ignores NULLs)"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:242
-msgid "conditional"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:257
-msgid "Name for new 3D raster map to create"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:259
-msgid "Name for new raster map to create"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:268
-msgid "Insert existing 3D raster map"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:270
-msgid "Insert existing raster map"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:275
-msgid "Insert mapcalc function"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:292
-msgid "Generate random seed for rand()"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:294
-msgid "Seed:"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:298
-msgid "Integer seed for rand() function"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:305
-msgid "Add created raster map into layer tree"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:642
-msgid "You must enter the name of a new raster map to create."
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:653
-msgid "You must enter an expression to create a new raster map."
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:713
-msgid "Choose a file name to save the expression"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:714
-#: ../gui/wxpython/modules/mcalc_builder.py:736
-msgid "Expression file (*)|*"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:735
-msgid "Choose a file name to load the expression"
-msgstr ""
-#: ../gui/wxpython/modules/mcalc_builder.py:771
-#, python-brace-format
-msgid "'{cmd}' copied to clipboard"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:254
-msgid "Copy coordinates to clipboard"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:262
-msgid "Hide toolbars"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:264
-msgid "Show toolbars"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:271
-msgid "Hide statusbar"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:272
-msgid "Show statusbar"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:289
-msgid "Resize legend"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:989
-msgid "Unable to draw registered graphics. The graphics was unregistered."
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2078
-msgid "Zoom to saved region extents"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2080
-msgid "Set compulational region from named region"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2093
-#, python-format
-msgid "Region <%s> not found. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2123
-msgid "Save display extents to region file"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2125
-msgid "Save computational region to region file"
-msgstr ""
-#: ../gui/wxpython/mapwin/buffered.py:2137
-#, python-format
-msgid "Region file <%s> already exists. Do you want to overwrite it?"
-msgstr ""
-#: ../gui/wxpython/mapwin/base.py:205
-#, python-format
-msgid ""
-"Error occurred during calling of handler: %s \n"
-"Handler was unregistered."
-msgstr ""
-#: ../gui/wxpython/mapwin/base.py:286
-#, python-format
-msgid ""
-"Error occurred during unregistration of handler: %s \n"
-"                                        Handler was unregistered."
-msgstr ""
-#: ../gui/wxpython/mapwin/base.py:315
-#, python-format
-msgid "Handler: %s was not registered"
-msgstr ""
-#: ../gui/wxpython/mapwin/base.py:319
-#, python-format
-msgid ""
-"                                        Handler was unregistered"
-msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:178
-#: ../gui/wxpython/mapwin/decorations.py:265
-msgid ""
-"Please install Python Imaging Library (PIL)\n"
-"for better control of legend and other decorations."
-msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:197
-msgid "Remove text"
-msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:220
-msgid "Remove scale bar"
-msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:232
-msgid "Remove north arrow"
-msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:244
-msgid "Remove vector legend"
-msgstr ""
-#: ../gui/wxpython/mapwin/decorations.py:256
-msgid "Remove legend"
-msgstr ""
-#: ../gui/wxpython/mapwin/graphics.py:277
-#: ../gui/wxpython/mapwin/graphics.py:453
-#, python-format
-msgid "Property does not exist: %s"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:228
-#: ../gui/wxpython/mapwin/analysis.py:350
-msgid "Measuring finished"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:246
-#: ../gui/wxpython/mapwin/analysis.py:362
-#, python-format
-msgid ""
-"Click and drag with left mouse button to measure.%sDouble click with left "
-"button to clear."
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:252
-msgid "Measuring distance"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:255
-msgid "Measuring distance:"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:263
-#, python-format
-msgid ""
-"Geodesic distance calculation is not available.\n"
-"Reason: %s"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:301
-#: ../gui/wxpython/mapwin/analysis.py:308
-msgid "segment"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:302
-#: ../gui/wxpython/mapwin/analysis.py:309
-msgid "total distance"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:303
-msgid "bearing"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:304
-msgid "degrees (clockwise from grid-north)"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:366
-msgid "Measuring area:"
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:386
-msgid "Units not recognized, measurement failed."
-msgstr ""
-#: ../gui/wxpython/mapwin/analysis.py:391
-#: ../gui/wxpython/mapwin/analysis.py:393
-msgid "Area: {area} {unit}\n"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:32
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1991
-#: ../gui/wxpython/menustrings.py:2025
-msgid "Modeler settings"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:59
-msgid "Item properties"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:66
-msgid "Disabled:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:102
-#: ../gui/wxpython/gmodeler/frame.py:1889
-#: ../gui/wxpython/gmodeler/dialogs.py:192
-#: ../gui/wxpython/gmodeler/dialogs.py:493
-#: ../gui/wxpython/gmodeler/dialogs.py:605
-msgid "Command"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:114
-#: ../gui/wxpython/gmodeler/preferences.py:428
-#: ../gui/wxpython/gmodeler/preferences.py:540
-msgid "Valid:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:132
-msgid "Invalid:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:150
-msgid "Running:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:177
-#: ../gui/wxpython/gmodeler/preferences.py:343
-#: ../gui/wxpython/gmodeler/preferences.py:455
-#: ../gui/wxpython/gmodeler/preferences.py:571
-msgid "Shape size"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:250
-#: ../gui/wxpython/lmgr/frame.py:380 ../gui/wxpython/nviz/tools.py:96
-msgid "Data"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:262
-msgid "Raster:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:280
-msgid "3D raster:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:298
-msgid "Vector:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:316
-msgid "Table:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:416
-msgid "Loop"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:528
-msgid "Comment"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:661
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2007
-#: ../gui/wxpython/menustrings.py:2041
-msgid "Model properties"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:668
-#: ../gui/wxpython/lmgr/layertree.py:726 ../gui/wxpython/lmgr/layertree.py:837
-#: ../gui/wxpython/lmgr/layertree.py:871
-msgid "Metadata"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:670
-msgid "Commands"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:694
-msgid "Apply properties"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:715
-msgid "Description:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/preferences.py:724
-msgid "Author(s):"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:74
-msgid "GRASS GIS Graphical Modeler"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:156
-msgid "Model"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:159
-msgid "Items"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:163
-#: ../gui/wxpython/gmodeler/model.py:2879
-msgid "Variables"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:167
-msgid "Python editor"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:253
-msgid "Python script contains local modifications"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:255
-#: ../gui/wxpython/gmodeler/frame.py:2140
-msgid "Python script is up-to-date"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:272
-msgid "Redrawing model..."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:321
-msgid "Model computation finished"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:334
-msgid "Do you want to save changes in the model?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:336
-msgid "Do you want to store current model settings to model file?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:342
-msgid "Quit Graphical Modeler"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:403
-#, python-format
-msgid "%d intermediate maps deleted from current mapset"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:412
-msgid "No intermediate data to delete."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:418
-#, python-format
-msgid "Do you want to permanently delete data?%s"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:420
-msgid "Delete intermediate data?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:440 ../gui/wxpython/gmodeler/frame.py:590
-msgid ""
-"Current model is not empty. Do you want to store current settings to model "
-"file?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:443 ../gui/wxpython/gmodeler/frame.py:593
-msgid "Create new model?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:480
-msgid "Choose model file"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:482 ../gui/wxpython/gmodeler/frame.py:542
-#: ../gui/wxpython/lmgr/frame.py:600
-msgid "GRASS Model File (*.gxm)|*.gxm"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:503
-#, python-format
-msgid "%(items)d items (%(actions)d actions) loaded into model"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:515 ../gui/wxpython/gmodeler/frame.py:559
-#, python-format
-msgid "Model file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:518
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1978
-#: ../gui/wxpython/menustrings.py:2012
-msgid "Save model"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:527 ../gui/wxpython/gmodeler/frame.py:577
-#, python-format
-msgid "File <%s> saved"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:540
-msgid "Choose file to save current model"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:659
-msgid "Model is empty. Nothing to validate."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:662 ../gui/wxpython/gmodeler/model.py:618
-msgid "Validating model..."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:669
-#, python-format
-msgid ""
-"Model is not valid.\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:673
-msgid "Model is valid."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:735 ../gui/wxpython/gmodeler/frame.py:742
-#, python-format
-msgid "Model exported to <%s>"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:884
-#: ../gui/wxpython/gmodeler/frame.py:1625
-#: ../gui/wxpython/gmodeler/dialogs.py:239
-msgid "Comment:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:885
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2003
-#: ../gui/wxpython/menustrings.py:2037
-msgid "Add comment"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:895
-msgid "Empty comment. Nothing to add to the model."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:931
-msgid "wxGUI Graphical Modeler"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1050
-#, python-format
-msgid ""
-"Reading model file <%s> failed.\n"
-"Invalid file, unable to parse XML document.\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1062
-msgid "Please wait, loading model..."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1128
-msgid "Writing current settings to model file failed."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1139 ../gui/wxpython/lmgr/frame.py:1676
-#, python-format
-msgid "Unable to open file <%s> for writing."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1503
-msgid "Disable"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1509
-msgid "Enable"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1517
-#: ../gui/wxpython/gmodeler/frame.py:1612
-msgid "Set label"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1523
-#: ../gui/wxpython/gmodeler/frame.py:1626
-msgid "Set comment"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1533
-msgid "Add control point"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1540
-msgid "Remove control point"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1554
-msgid "Intermediate"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1567
-#: ../gui/wxpython/vdigit/preferences.py:161
-#: ../gui/wxpython/nviz/tools.py:1574 ../gui/wxpython/nviz/tools.py:1788
-msgid "Display"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1584
-#: ../gui/wxpython/lmgr/layertree.py:502
-msgid "Properties"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1611
-#: ../gui/wxpython/gmodeler/dialogs.py:235
-msgid "Label:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1726
-msgid "List of variables - right-click to delete"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1733
-#: ../gui/wxpython/gmodeler/frame.py:1791
-msgid "Default value"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1734
-#: ../gui/wxpython/gmodeler/frame.py:1798
-#: ../gui/wxpython/location_wizard/wizard.py:483
-#: ../gui/wxpython/location_wizard/wizard.py:1010
-#: ../gui/wxpython/location_wizard/wizard.py:1191
-#: ../gui/wxpython/location_wizard/wizard.py:1522
-#: ../gui/wxpython/location_wizard/wizard.py:1750
-msgid "Description"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1739
-msgid "Add new variable"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1743
-msgid "integer"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1744
-msgid "float"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1745
-msgid "string"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1748
-msgid "region"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1749
-msgid "mapset"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1751
-msgid "dir"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1758
-msgid "Add new variable to the model"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1881
-msgid "List of items - right-click to delete"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1887
-msgid "In loop"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1888
-msgid "Parameterized"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1944
-msgid "No items to selected."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1980
-msgid "Python script"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1984
-msgid "Run python script"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1987
-msgid "Save python script to file"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:1990
-msgid ""
-"Refresh python script based on the model.\n"
-"It will discards all local changes."
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:2117
-msgid ""
-"Python script is locally modificated. Refresh will discard all changes. Do "
-"you really want to continue?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/frame.py:2120
-msgid "Update"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:66
-msgid "model"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:67
-msgid "Script generated by wxGUI Graphical Modeler."
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:493 ../gui/wxpython/gmodeler/model.py:556
-#, python-format
-msgid "undefined variable '%s'"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:590
-msgid "Running model..."
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:609
-msgid "Model is empty. Nothing to run."
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:626
-#, python-format
-msgid ""
-"Model is not valid. Do you want to run the model anyway?\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:629
-msgid "Run model?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:668
-msgid "Variables below not defined:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:792
-msgid "Raster maps"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:795
-msgid "3D raster maps"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1511
-msgid "<not defined>"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1639
-msgid "Condition: "
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1641
-msgid "Condition: not defined"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1779
-msgid "if-else"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1887
-msgid "empty"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:1889
-msgid "Details: unsupported tag name '{0}'."
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2802
-msgid "Model parameters"
-msgstr ""
-#: ../gui/wxpython/gmodeler/model.py:2827
-msgid "Delete intermediate data when finish"
-msgstr ""
-msgid "Data properties"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:94
-#: ../gui/wxpython/gmodeler/dialogs.py:112
-msgid "Name of element:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:105
-msgid "Type of element:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:163
-msgid "Add GRASS command to the model"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:194
-msgid "Label and comment"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:292
-msgid ""
-"Command not defined.\n"
-"\n"
-"Unable to add new action to the model."
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:299
-#, python-format
-msgid ""
-"'%s' is not a GRASS module.\n"
-"\n"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:335
-msgid "Relation properties"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:357
-msgid "From"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:401
-#, python-format
-msgid "Data: %s"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:407
-msgid "Command:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:413
-msgid "Option:"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:428
-msgid ""
-"Relation doesn't start with data item.\n"
-"Unable to add relation."
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:435
-msgid ""
-"Relation doesn't point to GRASS command.\n"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:448
-msgid ""
-"No relevant option found.\n"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:487
-msgid "Condition"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:515
-msgid "Loop properties"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:521
-msgid "List of items in loop"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:524
-msgid "Series"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:526
-msgid "Define map series as condition for the loop"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:571
-msgid "Define series of maps"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:589
-msgid "If-else properties"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:596
-msgid "List of items in 'if' block"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:602
-msgid "List of items in 'else' block"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:772
-#, python-format
-msgid "Variable <%s> already exists in the model. Adding variable failed."
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:803
-msgid "Do you want to delete all variables from the model?"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:805
-msgid "Delete variables"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:844
-#: ../gui/wxpython/gmodeler/dialogs.py:1013
-#: ../gui/wxpython/vdigit/dialogs.py:284
-msgid "Delete selected"
-msgstr ""
-#: ../gui/wxpython/gmodeler/dialogs.py:845
-#: ../gui/wxpython/vdigit/dialogs.py:288
-msgid "Delete all"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:38
-#: ../gui/wxpython/location_wizard/wizard.py:176
-msgid "Set default region extent and resolution"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:109
-msgid "&Set region"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:141
-msgid "Invalid location selected."
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:160
-msgid "Invalid region"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:191
-msgid "Click here to show 3D settings"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:192
-msgid "Click here to hide 3D settings"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:218
-#: ../gui/wxpython/location_wizard/dialogs.py:526
-#, python-format
-msgid "Rows: %d"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:219
-#: ../gui/wxpython/location_wizard/dialogs.py:527
-#, python-format
-msgid "Cols: %d"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:220
-#: ../gui/wxpython/location_wizard/dialogs.py:528
-#, python-format
-msgid "Cells: %d"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:268
-#: ../gui/wxpython/location_wizard/dialogs.py:530
-#, python-format
-msgid "Depth: %d"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:272
-#: ../gui/wxpython/location_wizard/dialogs.py:531
-#, python-format
-msgid "3D Cells: %d"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:295
-msgid "T-B resolution"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:360
-msgid "North"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:368
-msgid "West"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:390
-msgid "East"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:399
-msgid "South"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:403
-msgid "N-S resolution"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:411
-msgid "E-W resolution"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:489
-#, python-format
-msgid "Invalid value: %s"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:586
-msgid "Select datum transformation"
-msgstr ""
-#: ../gui/wxpython/location_wizard/dialogs.py:612
-msgid "Select from list of datum transformations"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:156
-msgid "Define GRASS Database and Location Name"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:177
-msgid ""
-"This option allows setting default computation region immediately after new "
-"location is created. Default computation region can be defined later using "
-"g.region based on imported data."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:183
-msgid "Create user mapset"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:184
-msgid ""
-"This option allows creating user mapset immediately after new location is "
-"created. Note that GRASS always creates PERMANENT mapset."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:190
-msgid "GIS Data Directory:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:209
-msgid "Project Location"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:210
-msgid "Name of location directory in GIS Data Directory"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:224
-msgid "Location Title"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:226
-msgid "Optional location title, you can leave this field blank."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:257
-#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location. Please use only ASCII "
-"characters excluding %(chars)s and space."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:265
-msgid "Invalid location name"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:280
-msgid "Choose GRASS data directory:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:294
-#: ../gui/wxpython/location_wizard/wizard.py:2560
-msgid "Location already exists in GRASS Database."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:298
-msgid "Unable to create location"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:312
-msgid ""
-"Title of the location is limited only to one line and 256 characters. The "
-"rest of the text will be ignored."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:322
-msgid "Choose method for creating a new location"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:329
-msgid "Select EPSG code of spatial reference system"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:335
-msgid "Read projection and datum terms from a georeferenced data file"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:339
-msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:342
-msgid "Select coordinate system parameters from a list"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:345
-msgid "Specify projection and datum terms using custom PROJ.4 parameters"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:348
-msgid "Create a generic Cartesian coordinate system (XY)"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:352
-msgid "Simple methods:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:364
-msgid "Advanced methods:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:467
-msgid "Choose projection"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1521
-#: ../gui/wxpython/location_wizard/wizard.py:1749
-msgid "Code"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:487
-msgid "Projection code:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:495
-#: ../gui/wxpython/location_wizard/wizard.py:1023
-#: ../gui/wxpython/location_wizard/wizard.py:1208
-msgid "Search in description:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:674
-#, python-format
-msgid "Unable to read list: %s"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:779
-msgid "Choose projection parameters"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:793
-msgid "Select datum or ellipsoid (next page)"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:801
-msgid "Datum with associated ellipsoid"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:804
-msgid "Ellipsoid only"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:862
-#, python-format
-msgid "You must enter a value for %s"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:881
-#: ../gui/wxpython/location_wizard/wizard.py:902
-#, python-format
-msgid " Enter parameters for %s projection "
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:987
-msgid "Specify geodetic datum"
-msgstr ""
-msgid "Ellipsoid"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1014
-msgid "Datum code:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1162
-msgid "Specify ellipsoid"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1179
-msgid "Earth based"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1182
-msgid "Planetary bodies"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1196
-msgid "Ellipsoid code:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1338
-#: ../gui/wxpython/location_wizard/wizard.py:1398
-msgid "Select georeferenced file"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1343
-msgid "Georeferenced file:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1414
-#: ../gui/wxpython/location_wizard/wizard.py:1472
-msgid "Select Well Known Text (WKT) .prj file"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1419
-msgid "WKT .prj file:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1490
-msgid "Choose EPSG Code"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1499
-msgid "Path to the EPSG-codes file:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1523
-#: ../gui/wxpython/location_wizard/wizard.py:1751
-#: ../gui/wxpython/vnet/dialogs.py:365
-msgid "Parameters"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1663
-msgid "Choose EPSG codes file"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1714
-msgid "Choose IAU Code"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1723
-msgid "Path to the IAU-codes file:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1726
-msgid "IAU code:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1908
-msgid "Choose IAU codes file"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1943
-msgid "Unable to read IAU codes: {0}"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1963
-msgid "Choose method of specifying georeferencing parameters"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:1972
-msgid "Enter PROJ.4 parameters string:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2028
-#: ../gui/wxpython/location_wizard/wizard.py:2032
-msgid "Datum transform is required."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2114
-msgid "GRASS Database:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2120
-msgid "Location Name:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2126
-msgid "Location Title:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2132
-msgid "Projection:"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2140
-msgid ""
-"PROJ.4 definition:\n"
-" (non-definitive)"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2264
-#, python-format
-msgid "Do you want to create GRASS location <%s>?"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2266
-msgid "Create new location?"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2318
-msgid "Define new GRASS Location"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2417
-#, python-format
-msgid ""
-"Unable to create new location. Location <%(loc)s> not created.\n"
-"\n"
-"Details: %(err)s"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2425
-msgid "Location wizard canceled. Location not created."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2558
-msgid "Unable to create new location"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2573
-msgid "Unable to create new GRASS Database"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2585
-#, python-format
-msgid ""
-"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will"
-" need to change the default GIS data directory in the GRASS startup screen."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2590
-msgid "New GIS data directory"
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2621
-msgid "EPSG code missing."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2631
-msgid "IAU code missing."
-msgstr ""
-#: ../gui/wxpython/location_wizard/wizard.py:2642
-#: ../gui/wxpython/location_wizard/wizard.py:2651
-#, python-format
-msgid "File <%s> not found."
-msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:34
-msgid "Create new raster map"
-msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:53
-msgid "Name for new raster map:"
-msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:58
-msgid "Optionally select background raster map:"
-msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:62
-msgid "New raster map type:"
-msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:92
-msgid "Please specify name for a new raster map"
-msgstr ""
-#: ../gui/wxpython/rdigit/dialogs.py:100
-#, python-format
-msgid ""
-"Raster map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:123
-msgid "Please select first the raster map"
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:155
-msgid "Right click to finish area"
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:160
-msgid "Right click to finish line"
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:303
-msgid "Do you want to save changes?"
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:304
-msgid "Save raster map changes"
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:383
-msgid "Failed to create backup copy of edited raster map."
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:402
-msgid "Failed to create new raster map."
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:490
-#: ../gui/wxpython/rdigit/controller.py:518
-msgid "Rasterizing..."
-msgstr ""
-#: ../gui/wxpython/rdigit/controller.py:558
-msgid "Failed to set default color table for edited raster map"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:27
-msgid "Digitize area"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:29
-msgid "Digitize line"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:31
-msgid "Digitize point"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:32
-msgid "Save raster map"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:33
-#: ../gui/wxpython/vdigit/toolbars.py:185
-msgid "Undo"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:34
-msgid "Raster Digitizer manual"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:35
-msgid "Quit raster digitizer"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:52
-msgid "Select raster map"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:67
-msgid "Set drawing color (not raster cell color)"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:85
-msgid "Cell value:"
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:99
-msgid ""
-"Width of currently digitized line or diameter of a digitized point in map "
-"units."
-msgstr ""
-#: ../gui/wxpython/rdigit/toolbars.py:146
-msgid "New raster map"
-msgstr ""
-#: ../gui/wxpython/datacatalog/frame.py:36
-msgid "GRASS GIS Data Catalog"
-msgstr ""
-#: ../gui/wxpython/datacatalog/frame.py:66
-msgid "Close GRASS GIS Data Catalog"
-msgstr ""
-#: ../gui/wxpython/datacatalog/frame.py:119 ../gui/wxpython/lmgr/frame.py:505
-#: ../gui/wxpython/lmgr/frame.py:1064
-#, python-format
-msgid ""
-"Current location is <%(loc)s>.\n"
-"Current mapset is <%(mapset)s>."
-msgstr ""
-#: ../gui/wxpython/datacatalog/frame.py:127 ../gui/wxpython/lmgr/frame.py:1091
-#: ../gui/wxpython/lmgr/frame.py:1113
-#, python-format
-msgid "Current mapset is <%s>."
-msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:25
-msgid "Reload GRASS locations"
-msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:28
-msgid "Reload current GRASS mapset only"
-msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:31
-msgid "Click to restrict editing to current mapset only"
-msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:34
-msgid "Click to allow editing other mapsets"
-msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:54
-msgid "Search:"
-msgstr ""
-#: ../gui/wxpython/datacatalog/toolbars.py:56
-msgid ""
-"Type to search database by map type or name. Use prefix 'r:', 'v:' and "
-"'r3:'to show only raster, vector or 3D raster data, respectively. Use Python"
-" regular expressions to refine your search."
-msgstr ""
-#: ../gui/wxpython/datacatalog/catalog.py:33
-msgid "Data catalog"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:122
-msgid "Failed to read mapsets from location <{l}>."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:143
-msgid "Failed to read maps from location <{l}>."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:215
-msgid ""
-"Map of type {elem} <{name}> already exists in mapset <{mapset}>. Do you want"
-" to overwrite it?"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:302
-msgid "GRASS locations in {0}"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:583
-msgid "Map <{layer}> marked for moving."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:593
-msgid "Map <{layer}> marked for copying."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:603
-#: ../gui/wxpython/datacatalog/tree.py:673
-#: ../gui/wxpython/datacatalog/tree.py:683
-#: ../gui/wxpython/datacatalog/tree.py:730
-msgid "New name"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:604
-msgid "Rename map"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:616
-msgid "Editing {name}"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:635
-msgid "Renaming map <{name}>..."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:649
-msgid "{cmd} -- completed"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:657
-msgid "No map selected for copying."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:659
-msgid "No map selected for moving."
-msgstr ""
-msgid "Select new name"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:693
-msgid "Copying <{name}>..."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:695
-msgid "Moving <{name}>..."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:711
-#: ../gui/wxpython/datacatalog/tree.py:713
-msgid "g.copy completed"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:726
-msgid "Reprojection is not implemented for 3D rasters"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:761
-#: ../gui/wxpython/datacatalog/tree.py:804
-msgid "g.remove completed"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:788
-msgid ""
-"Do you really want to delete map <{m}> of type <{etype}> from mapset "
-"<{mapset}> in location <{loc}>?"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:793
-msgid "Delete map"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:794
-msgid "Deleting {name}..."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:826
-msgid "Displaying {name}..."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:836
-msgid " -- completed. Go to Layers tab for further operations."
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:841
-msgid "Failed to display layer: not in current mapset or invalid layer"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:861
-msgid "To move or copy maps to other mapsets, unlock editing of other mapsets"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:965
-msgid "&Cut"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:971
-msgid "&Copy"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:975
-msgid "Copy &name"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:979
-#: ../gui/wxpython/datacatalog/tree.py:1016
-#: ../gui/wxpython/datacatalog/tree.py:1034
-msgid "&Paste"
-msgstr ""
-#. GTC Delete mapset
-#: ../gui/wxpython/datacatalog/tree.py:985 ../gui/wxpython/gis_set.py:210
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:206
-msgid "&Delete"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:999
-msgid "&Display layer"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:1003
-msgid "Show &metadata"
-msgstr ""
-#: ../gui/wxpython/datacatalog/tree.py:1022
-msgid "&Switch mapset"
-msgstr ""
-#: ../gui/wxpython/datacatalog/dialogs.py:79
-msgid "Reproject"
-msgstr ""
-#: ../gui/wxpython/datacatalog/dialogs.py:81
-msgid "Reproject raster"
-msgstr ""
-#: ../gui/wxpython/datacatalog/dialogs.py:83
-msgid "Reproject vector"
-msgstr ""
-#: ../gui/wxpython/datacatalog/dialogs.py:92
-msgid ""
-"Map layer <{ml}> needs to be reprojected.\n"
-"Please review and modify reprojection parameters:"
-msgstr ""
-#: ../gui/wxpython/datacatalog/dialogs.py:97
-msgid "Estimated resolution:"
-msgstr ""
-#: ../gui/wxpython/datacatalog/dialogs.py:100
-msgid "Resampling method:"
-msgstr ""
-#: ../gui/wxpython/datacatalog/dialogs.py:104
-msgid "Maximum segment length:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:73
-msgid "GRASS GIS Vector Network Analysis Tool"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:190
-msgid "Point list toolbar"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:197
-msgid "Analysis toolbar"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:231
-msgid "Points for analysis:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:234
-msgid "Analysis settings:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:238
-msgid "Points"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:251
-msgid "Maximum distance of point to the network:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:268
-msgid "Iso lines:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:407
-msgid "Add vector map into layer tree"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:527
-msgid "Input tables"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:555
-msgid "Result tables"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:568
-msgid "Loading tables..."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:704
-msgid "Creating turntable..."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:869
-msgid "Input vector map does not exist."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:892
-msgid "Analysing..."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1012
-msgid "Computing nodes..."
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1210
-msgid "Other settings"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1213
-msgid "Point style:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1216
-msgid "Analysis result style:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1228
-#, python-format
-msgid "Color table style %s:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1245
-#, python-format
-msgid "Invert colors %s:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1256
-msgid "Line color:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1259
-msgid "Color for unused point:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1262
-msgid "Color for Start/From/Source/Used point:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1265
-msgid "Color for End/To/Sink point:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1268
-msgid "Color for selected point:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1280
-msgid "Point size:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1281
-msgid "Point width:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1282 ../gui/wxpython/iscatt/dialogs.py:372
-msgid "Snapping threshold in pixels:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1283
-msgid "Maximum number of results in history:"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1481
-msgid "New vector map with turntable"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1627
-msgid "Save analysis result"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1743
-msgid "Edit intersection turns costs"
-msgstr ""
-#: ../gui/wxpython/vnet/dialogs.py:1786
-msgid "Define Global Turn Costs"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:116
-msgid "Unable to perform analysis."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:226
-#, python-format
-msgid ""
-"Temporary map '%s' with result was changed outside vector network analysis tool.\n"
-"Showed result may not correspond original analysis result."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:231
-msgid "Result changed outside"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:268
-msgid "Map can be created only in current mapset"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:275 ../gui/wxpython/vnet/vnet_core.py:352
-#, python-format
-msgid "Vector map %s already exists. Do you want to overwrite it?"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:278 ../gui/wxpython/vnet/vnet_core.py:355
-msgid "Overwrite vector map"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:304
-msgid "Creation of turntable failed."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:324
-msgid "Vector map with analysis result does not exist."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:345
-msgid "Map can be saved only to currently set mapset"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:427 ../gui/wxpython/vnet/vnet_core.py:632
-#, python-format
-msgid "Please choose '%s' and '%s' point."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:639
-msgid "Please choose at least two points."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:932
-#, python-format
-msgid ""
-"Input map '%s' for analysis was changed outside vector network analysis tool.\n"
-"Topology column may not correspond to changed situation."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:937
-msgid "Input changed outside"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1011
-#, python-format
-msgid ""
-"Temporary map %s  already exists.\n"
-"Do you want to continue in analysis and overwrite it?"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1038
-msgid "Unable to use ctypes. \n"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1039
-#: ../gui/wxpython/vnet/vnet_core.py:1062
-msgid "Snapping mode can not be activated."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1069
-msgid "Do you really want to activate snapping and overwrite it?"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1079
-#, python-format
-msgid ""
-"Temporary map '%s' was changed outside vector analysis tool.\n"
-"Do you really want to activate snapping and overwrite it? "
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_core.py:1084
-msgid "Overwrite map"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:52
-msgid "Insert points from Map Display"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:55
-msgid "Activate snapping to nodes"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:58
-msgid "Activate mode for turns editing"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:61
-msgid "Activate mode for global turns editing"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:64
-msgid "Add new point"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:67
-msgid "Delete selected point"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:120
-msgid "Execute analysis"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:123
-msgid "Go to previous analysis result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:126
-msgid "Go to next analysis result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:129
-msgid "Show analysis result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:132
-msgid "Save temporary result"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:134
-msgid "Vector network analysis settings"
-msgstr ""
-#: ../gui/wxpython/vnet/toolbars.py:205
-msgid "Availiable analyses"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:162
-#, python-format
-msgid "Module <%s> does not support turns costs."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:169
-#, python-format
-msgid "Vector map '%s' does not exist."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:172
-msgid "Vector map was not chosen."
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:181
-msgid "arc layer"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:182
-msgid "node layer"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:183
-msgid "turntable layer"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:184
-msgid "unique categories layer"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:190
-#, python-format
-msgid "Chosen %s '%s' does not exist in vector map '%s'.\n"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:193
-#, python-format
-msgid "Choose existing %s.\n"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:203
-#, python-format
-msgid ""
-"Chosen column '%s' does not exist in attribute table of layer '%s' of vector"
-" map '%s'.\n"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:259
-msgid "topology"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:261 ../gui/wxpython/vnet/vnet_data.py:769
-msgid "Start point"
-msgstr ""
-msgid "End Point"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:560 ../gui/wxpython/vnet/vnet_data.py:569
-#: ../gui/wxpython/vnet/vnet_data.py:572
-msgid "new point"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:746
-msgid "Arc forward/both direction(s) cost column:"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:747
-msgid "arc forward/both"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:750
-msgid "Arc backward direction cost column:"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:751
-msgid "arc backward"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:754
-msgid "Arcs' cost column (for both directions):"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:755
-msgid "arc"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:759
-msgid "Node cost column:"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:760
-msgid "node"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:766
-#, python-format
-msgid "Shortest path %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:770
-msgid "End point"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:786
-#, python-format
-msgid "Traveling salesman %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:802
-#, python-format
-msgid "Maximum flow %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:805
-msgid "Source point"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:806
-msgid "Sink point"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:821
-#, python-format
-msgid "Subnets for nearest centers %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:837
-#, python-format
-msgid "Steiner tree for the network and given terminals %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:851
-#, python-format
-msgid "Shortest distance via the network %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:870
-#, python-format
-msgid "Cost isolines %s"
-msgstr ""
-#: ../gui/wxpython/vnet/vnet_data.py:960
-msgid "Overwrite map layer"
-msgstr ""
-#: ../gui/wxpython/vnet/widgets.py:384
-msgid "Invalid value inserted. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vnet/widgets.py:545
-msgid "Edit point"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:39
-msgid ""
-"The Timeline Tool needs the \"matplotlib\" (python-matplotlib) package to be"
-" installed. {0}"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:77
-msgid "GRASS GIS Timeline Tool"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:135 ../gui/wxpython/nviz/tools.py:850
-#: ../gui/wxpython/nviz/tools.py:1889 ../gui/wxpython/nviz/preferences.py:405
-#: ../gui/wxpython/tplot/frame.py:277
-msgid "Draw"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:137 ../gui/wxpython/tplot/frame.py:280
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2016
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2059
-#: ../gui/wxpython/menustrings.py:2050 ../gui/wxpython/menustrings.py:2093
-msgid "Help"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:141
-msgid "3D plot of spatio-temporal extents"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:144
-msgid "3D plot of spatio-temporal extents (matplotlib >= 1.0.0)"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:149
-msgid "Select space time dataset(s):"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:180 ../gui/wxpython/tplot/frame.py:309
-#: ../gui/wxpython/tplot/frame.py:422
-#, python-format
-msgid "Dataset <%s> not found in temporal database"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:196 ../gui/wxpython/tplot/frame.py:327
-#: ../gui/wxpython/tplot/frame.py:441
-msgid ""
-"Datasets have different temporal type (absolute x relative), which is not "
-"allowed."
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:215 ../gui/wxpython/tplot/frame.py:344
-#: ../gui/wxpython/tplot/frame.py:451
-msgid "Datasets have different time unit which is not allowed."
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:236
-msgid "Dataset <{name}> is empty"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:294
-#, python-format
-msgid "X [%s]"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:295
-#, python-format
-msgid "Y [%s]"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:297
-msgid "X"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:298
-msgid "Y"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:303
-#: ../gui/wxpython/animation/dialogs.py:1967
-msgid "Time"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:374 ../gui/wxpython/tplot/frame.py:594
-#: ../gui/wxpython/tplot/frame.py:646 ../gui/wxpython/tplot/frame.py:684
-#, python-format
-msgid "Time [%s]"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:465 ../gui/wxpython/animation/utils.py:70
-#: ../gui/wxpython/animation/utils.py:79
-#: ../gui/wxpython/animation/temporal_manager.py:242
-#: ../gui/wxpython/tplot/frame.py:809
-#, python-format
-msgid "Space time dataset <%s> not found."
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:480 ../gui/wxpython/tplot/frame.py:824
-#, python-format
-msgid "Please specify the space time dataset <%s>."
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:482 ../gui/wxpython/tplot/frame.py:827
-msgid "Ambiguous dataset name"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:566 ../gui/wxpython/tplot/frame.py:961
-#, python-format
-msgid "Space time raster dataset: %s"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:568 ../gui/wxpython/tplot/frame.py:963
-#, python-format
-msgid "Space time vector dataset: %s"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:570 ../gui/wxpython/tplot/frame.py:965
-#, python-format
-msgid "Space time 3D raster dataset: %s"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:572
-#, python-format
-msgid "Mapset: %s"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:573
-#, python-format
-msgid "Map name: %s"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:575
-#, python-format
-msgid "Start time: %s"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:578
-#, python-format
-msgid "End time: %s"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:582
-msgid "WARNING: invalid topology"
-msgstr ""
-#: ../gui/wxpython/timeline/frame.py:584
-msgid ""
-"\n"
-"Press Del to dismiss."
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:43
-#, python-format
-msgid "Welcome to wxGUI Interactive Python Shell %s"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:44
-#, python-format
-msgid "Type %s for more GRASS scripting related information."
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:45
-#, python-format
-msgid "Type %s to add raster or vector to the layer tree."
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:55
-msgid "Delete all text from the shell"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:60
-msgid "Simple &editor"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:63 ../gui/wxpython/lmgr/toolbars.py:166
-msgid "Open a simple Python code editor"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:117
-#, python-format
-msgid "Raster or vector map <%s> not found"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:124
-#, python-format
-msgid "Raster map <%s> added"
-msgstr ""
-#: ../gui/wxpython/lmgr/pyshell.py:126
-#, python-format
-msgid "Vector map <%s> added"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:49
-msgid "Start new map display"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:52
-msgid "Create new workspace (Ctrl+N)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:55
-msgid "Open existing workspace file (Ctrl+O)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:58
-msgid "Save current workspace to file (Ctrl+S)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:90
-msgid "Add multiple raster or vector map layers (Ctrl+Shift+L)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:92
-msgid "Add raster map layer (Ctrl+Shift+R)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:95
-msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:97
-msgid "Add vector map layer (Ctrl+Shift+V)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:100
-msgid "Add various vector map layers (thematic, chart...)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:103
-msgid "Add web service layer (WMS, WMTS, NASA OnEarth)"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:106
-msgid "Add group"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:109
-msgid "Add various overlays"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:112
-msgid "Remove selected map layer(s) from layer tree"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:154
-msgid "Import/link raster or vector data"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:156
-msgid "Raster Map Calculator"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:160
-msgid "Georectifier"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:162
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:203
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1956
-#: ../gui/wxpython/menustrings.py:206 ../gui/wxpython/menustrings.py:1990
-msgid "Cartographic Composer"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:164
-msgid "Launch user-defined script"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:204
-msgid "GUI settings"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:205
-msgid "GRASS manual"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:233
-msgid "Edit selected vector map"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:236
-msgid "Show attribute data for selected vector map"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:268
-msgid "Generate command for m.nviz.image"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:269
-msgid "Generate command for m.nviz.image based on current state"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:272
-msgid "3D view mode settings"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:273
-msgid "Show 3D view mode settings dialog"
-msgstr ""
-#: ../gui/wxpython/lmgr/toolbars.py:276
-msgid "Show 3D view mode manual"
-msgstr ""
-#: ../gui/wxpython/lmgr/menudata.py:45
-msgid ""
-"Unable to parse user toolboxes XML files. Default main menu will be loaded."
-msgstr ""
-#: ../gui/wxpython/lmgr/menudata.py:71
-msgid ""
-"Unable to parse user toolboxes XML files. Default module tree will be "
-"loaded."
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:62
-msgid "Unpack GRASS raster map"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:64
-msgid "Set raster output format"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:70
-msgid "Unpack GRASS vector map"
-msgstr ""
-msgid "Set vector output format"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:74
-msgid "Import data from WMS server"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:76
-msgid "Add command layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:84
-msgid "Add HIS map layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:86
-msgid "Add shaded relief map layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:88
-msgid "Add raster flow arrows"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:90
-msgid "Add raster cell numbers"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:94
-msgid "Add thematic (choropleth) vector map layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:96
-msgid "Add thematic chart layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:98
-msgid "Add grid layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:100
-msgid "Add geodesic line layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:102
-msgid "Add rhumbline layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:107
-msgid "Note that 3D raster data are rendered only in 3D view mode"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:109
-msgid "Add WMS layer."
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:111
-#: ../gui/wxpython/animation/dialogs.py:475
-msgid "Set options"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:113
-msgid "Editing mode"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:115
-msgid "Background vector map"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:215
-#: ../gui/wxpython/lmgr/layertree.py:1525
-msgid "Map Layers"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:491 ../gui/wxpython/iscatt/frame.py:580
-msgid "Change opacity level"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:514
-msgid "3D view properties"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:525
-msgid "Zoom to selected map(s)"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:537
-msgid "Zoom to selected map(s) (ignore NULLs)"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:546
-msgid "Set computational region from selected map(s)"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:559
-msgid "Align computational region to selected map"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:573
-msgid "Export common formats"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:589
-msgid "Export PostGIS"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:617 ../gui/wxpython/lmgr/layertree.py:755
-msgid "Create pack"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:632 ../gui/wxpython/lmgr/layertree.py:770
-msgid "Make a copy in the current mapset"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:637 ../gui/wxpython/lmgr/layertree.py:778
-#: ../gui/wxpython/lmgr/layertree.py:851
-msgid "Set color table"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:646
-msgid "Show attribute data"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:664
-msgid "Start editing"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:673
-msgid "Stop editing"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:693
-msgid "Rebuild topology"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:739
-#: ../gui/wxpython/animation/dialogs.py:934
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:964
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1890
-#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1924
-msgid "Export"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:786
-msgid "Set color table interactively"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:795
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:758
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1684
-#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1713
-msgid "Histogram"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:804 ../gui/wxpython/lmgr/layertree.py:860
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:528
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1454
-#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1479
-msgid "Univariate raster statistics"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:816
-msgid "Report raster statistics"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:828
-msgid "Profile"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:883
-msgid "Save web service layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1001
-msgid "Unable to create profile of raster map."
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1052 ../gui/wxpython/nviz/tools.py:1866
-msgid "3D raster map"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1054
-#, python-format
-msgid "Unsupported map type <%s>"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1060
-#, python-format
-msgid "Enter name for the new %s in the current mapset:"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1062
-#, python-format
-msgid "Make a copy of %s <%s>"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1080
-#, python-format
-msgid ""
-"%s <%s> already exists in the current mapset. Do you want to overwrite it?"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1092
-#, python-format
-msgid "Unable to make copy of <%s>"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1100
-#, python-format
-msgid "Unable to make copy of <%s>. Mapset <%s> is not current mapset."
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1126
-msgid "Unable to display histogram of raster map. No map name defined."
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1348
-msgid "Layer group:"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1354
-#: ../gui/wxpython/lmgr/layertree.py:1903
-msgid "Click to edit layer settings"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1421
-msgid "(double click to set properties)"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1678
-msgid "Please wait, updating data..."
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:1983 ../gui/wxpython/lmgr/frame.py:2432
-msgid "opacity:"
-msgstr ""
-#: ../gui/wxpython/lmgr/layertree.py:2001
-#: ../gui/wxpython/mapswipe/frame.py:420 ../gui/wxpython/animation/utils.py:97
-#: ../gui/wxpython/animation/utils.py:105
-#, python-format
-msgid "Map <%s> not found."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:89
-#, python-format
-msgid "GRASS GIS %s Layer Manager"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:122
-msgid "There were some issues when loading menu or Modules tab:"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:150
-msgid "Workspace Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:153
-msgid "Data Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:156 ../gui/wxpython/mapswipe/frame.py:315
-#: ../gui/wxpython/animation/frame.py:182
-msgid "Misc Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:159
-msgid "Tools Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:162
-msgid "Vector Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:165
-msgid "3D view Toolbar"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:284 ../gui/wxpython/lmgr/frame.py:1721
-msgid "Rename Map Display"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:340
-msgid "Console"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:486
-#, python-format
-msgid ""
-"Location <%s> created.\n"
-"\n"
-"Do you want to switch to the new location?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:489
-msgid "Switch to new location?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:513
-msgid "Do you want to set the default region extents and resolution now?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:515
-#, python-format
-msgid "Location <%s> created"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:598
-msgid "Choose model to run"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:663 ../gui/wxpython/lmgr/frame.py:2522
-msgid "Do you want to save changes in the workspace?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:665 ../gui/wxpython/lmgr/frame.py:2524
-msgid "Do you want to store current settings to workspace file?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:673
-#, python-format
-msgid "Close Map Display %s"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:754
-#, python-format
-msgid ""
-"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
-"layer instead."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:936 ../gui/wxpython/lmgr/frame.py:2006
-msgid "Selected map layer is not vector."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:942
-msgid "Editing is allowed only for vector maps from the current mapset."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:968
-msgid "Choose script file to run"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:970
-msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:983
-msgid ""
-"Due to the limitations of your operating system, the script path cannot "
-"contain certain non-ascii characters. Please rename the script or move it to"
-" a different location."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:990
-#, python-format
-msgid "Script file '%s' doesn't exist. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:999
-#, python-format
-msgid ""
-"Script <%s> is not executable. Do you want to set the permissions that "
-"allows you to run this script (note that you must be the owner of the file)?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1004
-msgid "Set permission?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1014
-msgid "Unable to set permission. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1028
-#, python-format
-msgid ""
-"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
-"directory to GRASS_ADDON_PATH?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1030
-msgid "Update Addons path?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1036
-#, python-format
-msgid "Launching script '%s'..."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1050
-msgid "No location/mapset provided. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1071 ../gui/wxpython/gis_set.py:1014
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:937
-msgid "Enter name for new mapset:"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1072 ../gui/wxpython/gis_set.py:614
-#: ../gui/wxpython/gis_set.py:1015
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:557
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:938
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:240
-#: ../gui/wxpython/menustrings.py:247
-msgid "Create new mapset"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1078 ../gui/wxpython/lmgr/frame.py:1103
-msgid "No mapset provided. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1137
-#, python-format
-msgid ""
-"Working directory changed to:\n"
-"\"%s\""
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1144
-msgid "Changes current working directory for this GUI."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1146
-msgid "Usage: cd [directory]"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1147
-msgid "Without parameters it opens a dialog."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1151
-msgid ""
-"If ~ (tilde) is present as the first directory on the path, it is replaced "
-"by user's home directory."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1165
-msgid "More than one parameter provided."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1185
-msgid "Choose a working directory"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1230
-msgid "System Info"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1245
-msgid "GRASS version"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1246
-msgid "GRASS SVN revision"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1248
-msgid "Build date"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1250
-msgid "Build platform"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1263
-msgid "Platform"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1326
-msgid ""
-"Current workspace is not empty. Do you want to store current settings to "
-"workspace file?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1329
-msgid "Create new workspace?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1358
-msgid "Choose workspace file"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1360 ../gui/wxpython/lmgr/frame.py:1598
-msgid "GRASS Workspace File (*.gxw)|*.gxw"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1395 ../gui/wxpython/animation/nviztask.py:43
-#, python-format
-msgid ""
-"Reading workspace file <%s> failed.\n"
-"Invalid file, unable to parse XML document."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1400 ../gui/wxpython/lmgr/frame.py:1572
-msgid "Please wait, loading workspace..."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1552
-msgid "Choose GRC file to load"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1554
-msgid "Old GRASS Workspace File (*.grc)|*.grc"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1596
-msgid "Choose file to save current workspace"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1616 ../gui/wxpython/lmgr/frame.py:1637
-#, python-format
-msgid ""
-"Workspace file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1619 ../gui/wxpython/lmgr/frame.py:1640
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:11
-#: ../gui/wxpython/menustrings.py:11
-msgid "Save workspace"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1664
-msgid "Writing current settings to workspace file failed."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1720
-msgid "Enter new name:"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1818
-#, python-format
-msgid ""
-"Unable to launch \"Supervised Classification Tool\".\n"
-"\n"
-"Reason: %s"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1860
-msgid "Unable to start Timeline Tool."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:1871
-msgid "Unable to start Temporal Plot Tool."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2141
-msgid "Add selected map layers into layer tree"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2174 ../gui/wxpython/lmgr/frame.py:2211
-#, python-format
-msgid "Unsupported map layer type <%s>."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2340
-msgid ""
-"Note that cell values can only be displayed for regions of less than 10,000 "
-"cells."
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2440
-#, python-format
-msgid ""
-"Do you want to remove map layer(s)\n"
-"%s\n"
-"from layer tree?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2443
-msgid "Do you want to remove selected map layer(s) from layer tree?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2449
-msgid "Remove map layer"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2531
-msgid "Quit GRASS GUI"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2563
-msgid "Unable to exit GRASS shell: unknown PID"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2583
-msgid ""
-"Display resolution is currently not constrained to computational settings. "
-"It's suggested to constrain map to region geometry. Do you want to constrain"
-" the resolution?"
-msgstr ""
-#: ../gui/wxpython/lmgr/frame.py:2592
-msgid "Constrain map to region geometry?"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:108
-msgid "Select area/boundary/centroid tool"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:134
-msgid "Digitize new point"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:135
-#: ../gui/wxpython/vdigit/toolbars.py:144
-#: ../gui/wxpython/vdigit/toolbars.py:147
-msgid "Left: new point"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:137
-msgid "Digitize new line"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:138
-#: ../gui/wxpython/vdigit/toolbars.py:141
-#: ../gui/wxpython/vdigit/toolbars.py:165
-msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:140
-msgid "Digitize new boundary"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:143
-msgid "Digitize new centroid"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:146
-msgid "Digitize new area (boundary without category)"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:149
-msgid "Add new vertex to line or boundary"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:150
-#: ../gui/wxpython/vdigit/toolbars.py:153
-#: ../gui/wxpython/vdigit/toolbars.py:156
-#: ../gui/wxpython/vdigit/toolbars.py:168
-#: ../gui/wxpython/vdigit/toolbars.py:171
-#: ../gui/wxpython/vdigit/toolbars.py:174
-#: ../gui/wxpython/vdigit/toolbars.py:183
-msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:152
-msgid "Delete selected point(s), line(s), boundary(ies) or centroid(s)"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:155
-msgid "Delete selected area(s)"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:158
-msgid "Display/update attributes"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:159
-#: ../gui/wxpython/vdigit/toolbars.py:162
-msgid "Left: Select"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:161
-msgid "Display/update categories"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:164
-msgid "Edit selected line/boundary"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:167
-msgid "Move selected point(s), line(s), boundary(ies) or centroid(s)"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:170
-msgid "Move selected vertex"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:173
-msgid "Remove selected vertex"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:175
-#: ../gui/wxpython/vdigit/preferences.py:33
-msgid "Digitization settings"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:176
-msgid "Quit digitizer"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:177
-msgid "Quit digitizer and save changes"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:178
-msgid "Vector Digitizer manual"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:179
-msgid "Show Vector Digitizer manual"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:181
-msgid "Additional tools (copy, flip, connect, etc.)"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:186
-msgid "Undo previous changes"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:188
-msgid "Redo"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:189
-msgid "Redo previous changes"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:559
-msgid "Break selected lines/boundaries at intersection"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:561
-msgid "Connect selected lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:563
-msgid "Copy categories"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:565
-msgid "Copy features from (background) vector map"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:567
-msgid "Copy attributes"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:569
-msgid "Feature type conversion"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:571
-msgid "Flip selected lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:573
-msgid "Merge selected lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:575
-msgid "Snap selected lines/boundaries (only to nodes)"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:577
-msgid "Split line/boundary"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:579
-msgid "Query features"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:581
-msgid "Z bulk-labeling of 3D lines"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:603 ../gui/wxpython/vdigit/wxdigit.py:63
-msgid "No vector map open for editing."
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:608
-msgid "Select background vector map"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:768
-msgid "Vector map is not 3D. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:873
-#, python-format
-msgid ""
-"Topology for vector map <%s> is not available. Topology is required by digitizer.\n"
-"Do you want to rebuild topology (takes some time) and open the vector map for editing?"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:878
-msgid "Digitizer error"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:903
-#, python-format
-msgid "Please wait, opening vector map <%s> for editing..."
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:941
-#, python-format
-msgid ""
-"Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:1011
-#, python-format
-msgid "Do you want to save changes in vector map <%s>?"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:1014
-msgid "Save changes?"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:1021
-#, python-format
-msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:1039
-#, python-format
-msgid "Editing of vector map <%s> successfully finished"
-msgstr ""
-#: ../gui/wxpython/vdigit/toolbars.py:1104
-#: ../gui/wxpython/vdigit/toolbars.py:1111
-msgid "New vector map"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:64
-msgid "Apply changes for this session"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:68
-msgid "Close dialog and save changes to user settings file"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:166
-#: ../gui/wxpython/wxplot/dialogs.py:1054
-msgid "Line width"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:202
-msgid "Snapping"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:211
-msgid "Snapping threshold"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:220
-msgid "screen pixels"
-msgstr ""
-msgid "map units"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:240
-msgid "Snap also to vertex"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:250
-#: ../gui/wxpython/vdigit/preferences.py:905
-#: ../gui/wxpython/vdigit/preferences.py:919
-#: ../gui/wxpython/vdigit/preferences.py:923
-#, python-format
-msgid "Snapping threshold is %(value).1f %(units)s"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:268
-msgid "Select vector features"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:288
-msgid "Select threshold"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:309
-msgid "Select only features inside of selection bounding box"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:316
-msgid ""
-"By default are selected all features overlapping selection bounding box "
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:319
-msgid "Check for duplicates"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:345
-msgid "Digitize lines/boundaries"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:349
-msgid "Break lines at intersection"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:372
-msgid "Digitize areas"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:376
-msgid "Close boundary (snap to the start node)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:399
-msgid "Save changes"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:402
-msgid "Save changes on exit"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:423
-msgid "Query tool"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:434
-msgid "Choose query tool"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:442
-msgid "Select by box"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:460
-#: ../gui/wxpython/vdigit/preferences.py:694
-msgid "length"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:472
-msgid "Select lines"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:475
-#: ../gui/wxpython/vdigit/preferences.py:529
-msgid "shorter than"
-msgstr ""
-msgid "longer than"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:514
-msgid "dangle"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:526
-msgid "Select dangles"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:593
-msgid "Digitize new feature"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:598
-msgid "Add new record into table"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:613
-msgid "Mode"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:645
-msgid "Next to use"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:627
-msgid "Category number"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:643
-msgid "Category mode"
-msgstr ""
-msgid "Manual entry"
-msgstr ""
-msgid "No category"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:668
-msgid "Delete existing feature(s)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:673
-msgid "Delete record from table"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:691
-msgid "Geometry attributes"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:696
-msgid "perimeter"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:767
-msgid ""
-"Note: These settings are stored in the workspace not in the vector digitizer"
-" preferences."
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:796
-msgid "Digitize new line segment"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:797
-msgid "Digitize new line/boundary"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:798
-msgid "Highlight"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:799
-msgid "Highlight (duplicates)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:802
-msgid "Boundary (no area)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:803
-msgid "Boundary (one area)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:804
-msgid "Boundary (two areas)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:805
-msgid "Centroid (in area)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:806
-msgid "Centroid (outside area)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:807
-msgid "Centroid (duplicate in area)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:808
-msgid "Node (one line)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:809
-msgid "Node (two lines)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:810
-msgid "Vertex"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:811
-msgid "Area (closed boundary + centroid)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:812
-msgid "Direction"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:896
-msgid "Snapping disabled"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:900
-#, python-format
-msgid ""
-"Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
-msgstr ""
-#: ../gui/wxpython/vdigit/preferences.py:956
-#, python-format
-msgid "Vector digitizer settings saved to file <%s>."
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:79
-msgid "List of categories - right-click to delete"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:110
-msgid "Add new category"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:153
-msgid "Ignore changes and close dialog"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:248 ../gui/wxpython/vdigit/dialogs.py:472
-#, python-format
-msgid ""
-"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
-"Layer and category number must be integer.\n"
-"Layer number must be greater than zero."
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:446
-msgid "Unable to update vector map."
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:622
-#, python-format
-msgid "%d lines selected for z bulk-labeling"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:630
-msgid "Set value"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:637
-msgid "Starting value"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:649
-msgid "Step"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:692
-msgid "List of duplicates"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:801
-msgid "Feature id"
-msgstr ""
-#: ../gui/wxpython/vdigit/dialogs.py:802
-msgid "Layer (Categories)"
-msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:69
-msgid "GRASS GIS Vector Digitizer"
-msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:85
-#, python-format
-msgid "Vector digitizer not available. %s"
-msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:90
-#, python-format
-msgid ""
-"Vector map <%s> not found in current mapset. New vector map can be created "
-"by providing '-c' flag."
-msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:94
-#, python-format
-msgid "New vector map <%s> created"
-msgstr ""
-#: ../gui/wxpython/vdigit/g.gui.vdigit.py:101
-#, python-format
-msgid "Unable to create new vector map <%s>"
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:56
-msgid "Digitization Error"
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:61
-#, python-format
-msgid "Unable to open vector map <%s>."
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:64
-msgid "Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:71
-#, python-format
-msgid ""
-"Writing new feature failed. Operation canceled.\n"
-"\n"
-"Reason: %s"
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:80
-#, python-format
-msgid "Reading feature id %d failed. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:88
-#, python-format
-msgid "Database link %d not available. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:96
-#, python-format
-msgid "Unable to start database driver <%s>. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:106
-#, python-format
-msgid ""
-"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:114
-#, python-format
-msgid "Unable to execute SQL query '%s'. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:122
-#, python-format
-msgid "Feature id %d is marked as dead. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:130
-#, python-format
-msgid "Unsupported feature type %d. Operation canceled."
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:500
-#, python-format
-msgid "Unknown feature type '%s'"
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdigit.py:505
-msgid "Not enough points for line"
-msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:425
-msgid "Update categories"
-msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:549
-#: ../gui/wxpython/vdigit/mapwindow.py:958
-msgid "No vector map selected for editing."
-msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:558
-msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
-msgstr ""
-#: ../gui/wxpython/vdigit/mapwindow.py:1092
-msgid "Z bulk-labeling dialog"
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdisplay.py:1017
-#, python-format
-msgid ""
-"Topology for vector map <%s> is not available. Topology is required by "
-"digitizer. Do you want to rebuild topology (takes some time) and open the "
-"vector map for editing?"
-msgstr ""
-#: ../gui/wxpython/vdigit/wxdisplay.py:1022
-msgid "Topology missing"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:44
-#: ../gui/wxpython/mapswipe/toolbars.py:33
-msgid "Select raster maps"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:130
-msgid "Name of top/left raster map:"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:139
-msgid "Name of bottom/right raster map:"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:185
-msgid "Switch to advanced mode"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:186
-msgid "Cancel"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:192
-msgid "Switch to simple mode"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:217
-msgid "Name of the first map is missing."
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:220
-msgid "Name of the second map is missing."
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:253
-msgid "Map Swipe settings"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:269
-#: ../gui/wxpython/mapswipe/toolbars.py:118
-msgid "Mirror mode"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:272
-msgid "Mirrored cursor"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:301
-msgid "Shape:"
-msgstr ""
-#: ../gui/wxpython/mapswipe/dialogs.py:350
-#: ../gui/wxpython/nviz/preferences.py:607
-msgid "Size:"
-msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:44
-msgid "GRASS GIS Map Swipe"
-msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:303
-#: ../gui/wxpython/animation/frame.py:160
-msgid "Main Toolbar"
-msgstr ""
-#: ../gui/wxpython/mapswipe/frame.py:417
-#, python-format
-msgid "Map <%s> not found. "
-msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:31
-msgid "Quit Map Swipe"
-msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:117
-msgid "Swipe mode"
-msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:130
-msgid "Choose view mode"
-msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:154
-msgid "Switch orientation"
-msgstr ""
-#: ../gui/wxpython/mapswipe/toolbars.py:157
-msgid "Switch maps"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:40
-msgid "Add scatter plots"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:59
-msgid "x axis:"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:66
-msgid "y axis:"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:105
-msgid "Bands of scatter plots to be added (x y):"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:155
-msgid "No scatter plots selected."
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:203
-msgid "Select both x and y bands."
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:207
-msgid "Selected bands must be different."
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:214
-msgid ""
-"Scatter plot with same bands combination (regardless x y order) has been "
-"already added into the list."
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:323
-#, python-format
-msgid "Raster map <%s> already exists. Do you want to overwrite it?"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:326
-#, python-format
-msgid "Raster <%s> exists"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:352
-msgid "Show confidence ellipses"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:359
-msgid "Selection polygon color:"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:360
-msgid "Color of selection polygon vertex:"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:361
-msgid "Selected area color:"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:373
-msgid "Selected area opacity:"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:412
-msgid "Selection style:"
-msgstr ""
-#: ../gui/wxpython/iscatt/dialogs.py:439
-msgid "Ellipses settings:"
-msgstr ""
-#: ../gui/wxpython/iscatt/core_c.py:23
-msgid "Loading ctypes libs failed"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:166
-msgid "GRASS GIS Interactive Scatter Plot Tool"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:398
-msgid "scatter plot"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:476
-msgid "Maximum limit of categories number was reached."
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:572
-msgid "Rename class"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:576
-msgid "Set color"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:584
-msgid "Hide"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:586
-msgid "Show"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:601
-msgid "Move to top"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:607
-msgid "Move to bottom"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:615
-msgid "Move category up"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:621
-msgid "Move category down"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:629
-msgid "Export class raster"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:701
-#, python-format
-msgid "Change opacity of class <%s>"
-msgstr ""
-#: ../gui/wxpython/iscatt/frame.py:726
-msgid "Empty name was inserted."
-msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:110
-#: ../gui/wxpython/iscatt/iscatt_core.py:160
-msgid "Select category for editing."
-msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:151
-msgid "Computing of scatter plots failed."
-msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:298
-msgid "Patching category raster conditions file failed."
-msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:321
-#, python-format
-msgid ""
-"v.build failed:\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/iscatt/iscatt_core.py:339
-#, python-format
-msgid ""
-"v.to.rast failed:\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:54
-msgid "Add scatter plot"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:57
-msgid "Select area with polygon"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:60
-msgid "Pan mode for scatter plots"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:63
-msgid "Zoom mode for scatter plots (left mouse button, wheel)"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:66
-msgid ""
-"Zoom to scatter plot data extend mode (click on scatter plot for zooming to "
-"extend)"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:69
-msgid "Show/hide class manager"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:175
-#: ../gui/wxpython/iscatt/toolbars.py:176
-msgid "Include selected area to class"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:178
-#: ../gui/wxpython/iscatt/toolbars.py:179
-msgid "Exclude selected area from class"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:181
-msgid "Add new vertex"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:182
-msgid "Add new vertex to polygon boundary scatter plot"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:184
-msgid "Create selection polygon"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:185
-msgid "Add new vertex between last and first points of the boundary"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:187
-msgid "Move vertex"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:188
-msgid "Move boundary vertex"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:190
-msgid "Remove vertex"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:191
-msgid "Remove boundary vertex"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:193
-msgid "Remove polygon (click on scatter plot for removing it's polygon)"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:271
-msgid "Add class"
-msgstr ""
-#: ../gui/wxpython/iscatt/toolbars.py:273
-msgid "Remove selected class"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:204
-msgid "No data set."
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:222
-#, python-format
-msgid ""
-"Interactive Scatter Plot Tool can not be used.\n"
-"Number of cells (rows*cols) <%d> in current regionis higher than maximum limit <%d>.\n"
-"\n"
-"You can reduce number of cells in current region using <g.region> command."
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:231
-#, python-format
-msgid ""
-"Number of cells (rows*cols) <%d> in current region is higher than recommended threshold <%d>.\n"
-"It is strongly advised to reduce number of cells in current region below recommend threshold.\n"
-" It can be done by <g.region> command.\n"
-"\n"
-"Do you want to continue using Interactive Scatter Plot Tool with this region?"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:288
-msgid ""
-"Scatter plot with same band combination (regardless x y order) is already "
-"displayed."
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:301
-#, python-format
-msgid "Band <%s> is not CELL (integer) type.\n"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:304
-msgid "Scatter plot cannot be added.\n"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:310
-#, python-format
-msgid ""
-"Scatter plot cannot be added.\n"
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <%d>.\n"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:320
-#, python-format
-msgid ""
-"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended limit <%d>.\n"
-"It is strongly advised to reduce range extend of bands(e. g. using r.rescale) below recommended threshold.\n"
-"\n"
-"Do you really want to add this scatter plot?"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:409
-msgid ""
-"In order to select arrea in scatter plot, you have to select class first.\n"
-"\n"
-"There is no class yet, do you want to create one?"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:444
-#, python-format
-msgid ""
-"Error occurred during computation of scatter plot category:\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:764
-#, python-format
-msgid "Export scatter plot raster of class <%s>"
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:782
-#, python-format
-msgid "Scatter plot raster of class <%s> exported to raster map <%s>."
-msgstr ""
-#: ../gui/wxpython/iscatt/controllers.py:786
-#, python-format
-msgid ""
-"Export of scatter plot raster of class <%s> to map <%s> failed.\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/iscatt/plots.py:42
-#, python-brace-format
-msgid ""
-"The Scatterplot Tool needs the \"matplotlib\" (python-matplotlib) package to"
-" be installed. {0}"
-msgstr ""
-#: ../gui/wxpython/iscatt/plots.py:617
-msgid "Zoom to scatter plot extend"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:53
-msgid "Adjust speed of animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:100
-msgid "Simple mode"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:105
-msgid "Frame duration:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:106
-#: ../gui/wxpython/animation/dialogs.py:147
-msgid "ms"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:139
-msgid "Temporal mode"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:144
-msgid "Time unit:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:146
-msgid "Duration of time unit:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:218
-msgid "year"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:219
-msgid "month"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:220
-msgid "day"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:221
-msgid "hour"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:222
-msgid "minute"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:223
-msgid "second"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:288
-msgid "Animation speed is too high."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:324
-#: ../gui/wxpython/animation/toolbars.py:51
-#: ../gui/wxpython/animation/toolbars.py:52
-msgid "Add new animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:326
-msgid "Edit animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:344
-msgid "Advanced"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:375
-msgid "top left"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:376
-msgid "top right"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:377
-msgid "bottom left"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:378
-msgid "bottom right"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:394
-msgid "Select 2D or 3D view"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:409
-msgid "Window position:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:419
-msgid "View mode:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:430
-msgid ""
-"For 3D animation, please select only one space-time dataset\n"
-"or one series of map layers."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:496
-msgid "3D view parameters"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:504
-msgid "Workspace file:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:506
-msgid "Choose workspace file to import 3D view parameters"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:515
-msgid "Parameter for animation:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:554
-msgid "Animate region change (2D view only)"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:558
-msgid "Start region:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:568
-msgid "End region:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:574
-msgid "Zoom value:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:575
-msgid "N-S/E-W distances in map units used to gradually reduce region."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:582
-msgid "N-S:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:585
-msgid "E-W:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:683
-msgid "Only one series or space-time dataset is accepted for 3D mode."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:691
-msgid "No map series or space-time dataset added."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:719
-msgid "Region information is not complete"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:753
-msgid "Add, edit or remove animations"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:765
-msgid "List of animations"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:778
-msgid "Edit"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:837
-#, python-format
-msgid "Maximum number of animations is %d."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:887
-#: ../gui/wxpython/animation/controller.py:262
-msgid ""
-"More animations are using one window. Please select different window for "
-"each animation."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:907
-#: ../gui/wxpython/animation/toolbars.py:59
-#: ../gui/wxpython/animation/toolbars.py:60
-msgid "Export animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:929 ../gui/wxpython/nviz/tools.py:782
-msgid "Decorations"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:988
-msgid "Add time stamp"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2053
-#: ../gui/wxpython/menustrings.py:2087
-msgid "Add image"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1030
-msgid "Add time stamp, image or text decoration by one of the buttons above."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1032
-msgid "Add image or text decoration by one of the buttons above."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1053
-msgid "Font settings:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1058
-msgid "Sample text"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1078
-msgid "Image file:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1079
-msgid "Choose image file"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1095
-msgid "Text:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1116
-msgid ""
-"Placement as percentage of screen coordinates (X: 0, Y: 0 is top left):"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1151
-msgid "image sequence"
-msgstr ""
-msgid "animated GIF"
-msgstr ""
-msgid "SWF"
-msgstr ""
-msgid "AVI"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1162
-msgid "Export to:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1187 ../gui/wxpython/nviz/tools.py:632
-msgid "File prefix:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1189
-msgid "animation_"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1191 ../gui/wxpython/nviz/tools.py:640
-msgid "File format:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1197
-msgid "Choose directory for export"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1232
-msgid "GIF file:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1233
-#: ../gui/wxpython/animation/dialogs.py:1257
-#: ../gui/wxpython/animation/dialogs.py:1288
-msgid "Choose file to save animation"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1256
-msgid "SWF file:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1279
-msgid ""
-"Program 'ffmpeg' was not found.\n"
-"Please install it first and make sure\n"
-"it's in the PATH variable."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1287
-msgid "AVI file:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1295
-msgid "Video codec:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1299
-msgid "Additional options:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1303
-msgid ""
-"Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality."
-" Options depend on ffmpeg version."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1340
-#, python-format
-msgid "Current frame rate: %.2f fps"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1472
-#, python-format
-msgid "File %s not found."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1476
-msgid "Decoration image file is missing."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1485
-#, python-format
-msgid "Directory %s not found."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1489
-msgid "Export directory is missing."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1493
-#: ../gui/wxpython/animation/dialogs.py:1497
-msgid "Export file is missing."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1535
-msgid "Time stamp"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1613
-msgid "Add space-time dataset layer"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1638
-msgid "Multiple raster maps"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1639
-msgid "Multiple vector maps"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1640
-msgid "Multiple 3D raster maps"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1641
-msgid "Space time raster dataset"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1642
-msgid "Space time vector dataset"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1643
-msgid "Space time 3D raster dataset"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1682
-msgid "Input data type:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1763
-msgid "Select raster/vector maps."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1792
-msgid "Please select maps or dataset first."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1821
-msgid "Animation Tool settings"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1885
-msgid "Number of parallel processes:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1914
-msgid "Text foreground color:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1935
-msgid "Text background color:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1977
-msgid "Absolute time format:"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:1997
-msgid ""
-"Click and then press key up or down to preview different date and time "
-"formats. Type custom format string."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2008
-msgid "Learn more about formatting options"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2022
-msgid "Display instances with no data"
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2025
-msgid ""
-"When animating instant-based data which have irregular timestamps you can "
-"display 'no data frame' (checked option) or keep last frame."
-msgstr ""
-#: ../gui/wxpython/animation/dialogs.py:2056
-msgid "Invalid"
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:182
-msgid "The number of maps in space-time datasets has to be the same."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:186
-msgid ""
-"The temporal type (absolute/relative) of space-time datasets has to be the "
-"same."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:190
-msgid ""
-"The map type (point/interval) of space-time datasets has to be the same."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:194
-msgid ""
-"The temporal extents of maps in space-time datasets have to be the same."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:202
-msgid "The number of maps to animate has to be the same for each map series."
-msgstr ""
-#: ../gui/wxpython/animation/utils.py:207
-msgid ""
-"The number of maps to animate has to be the same as the number of maps in "
-"temporal dataset."
-msgstr ""
-#: ../gui/wxpython/animation/g.gui.animation.py:92
-#, python-format
-msgid "%s=, %s=, %s= and %s= are mutually exclusive."
-msgstr ""
-#: ../gui/wxpython/animation/data.py:66
-msgid "No animation name selected."
-msgstr ""
-#: ../gui/wxpython/animation/data.py:132
-msgid "No workspace file selected."
-msgstr ""
-#: ../gui/wxpython/animation/data.py:135
-#, python-format
-msgid "File %s not found"
-msgstr ""
-#: ../gui/wxpython/animation/data.py:144
-#, python-format
-msgid "Animation %d"
-msgstr ""
-#: ../gui/wxpython/animation/frame.py:51
-msgid "GRASS GIS Animation tool"
-msgstr ""
-#: ../gui/wxpython/animation/frame.py:170
-msgid "Animation Toolbar"
-msgstr ""
-#: ../gui/wxpython/animation/frame.py:282
-msgid "Loading data"
-msgstr ""
-#: ../gui/wxpython/animation/frame.py:290
-msgid " ({c} out of {p})"
-msgstr ""
-#: ../gui/wxpython/animation/frame.py:605
-#: ../gui/wxpython/animation/controller.py:598
-#, python-format
-msgid "%(from)s %(dash)s %(to)s"
-msgstr ""
-#: ../gui/wxpython/animation/frame.py:610
-#, python-format
-msgid "to %(to)s"
-msgstr ""
-#: ../gui/wxpython/animation/provider.py:417
-msgid "Rendering map layers"
-msgstr ""
-#: ../gui/wxpython/animation/provider.py:530
-msgid "Overlaying map layers"
-msgstr ""
-#: ../gui/wxpython/animation/provider.py:757
-msgid "Directory {t} not removed."
-msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:53
-#, python-format
-msgid "No 3d view information in workspace file <%s>."
-msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:285
-msgid "Please add only one layer in the list."
-msgstr ""
-#: ../gui/wxpython/animation/nviztask.py:292
-msgid "No map series nor space-time dataset is added."
-msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:110
-msgid ""
-"It is not allowed to display data with different temporal types (absolute "
-"and relative)."
-msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:125
-#, python-format
-msgid "It is not allowed to display data with different units (%s)."
-msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:137
-msgid ""
-"You are going to display data with different temporal types of maps "
-"(interval and point). It is recommended to use data of one temporal type to "
-"avoid confusion."
-msgstr ""
-#: ../gui/wxpython/animation/temporal_manager.py:347
-#, python-format
-msgid "Topology of Space time dataset %s is invalid."
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:234
-#, python-format
-msgid "Maximum number of animations is %s."
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:443
-msgid "Failed to display legend."
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:475
-msgid "Inconsistent number of maps, please check input data."
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:505
-msgid "No animation to export."
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:542
-msgid "Preparing export, please wait..."
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:605
-#, python-format
-msgid "%(start)s %(unit)s"
-msgstr ""
-#: ../gui/wxpython/animation/controller.py:624
-msgid "Exporting animation, please wait..."
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:30
-msgid "Change animation speed"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:33
-msgid "Play forward"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:36
-msgid "Play back"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:39 ../gui/wxpython/nviz/tools.py:527
-msgid "Stop"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:42 ../gui/wxpython/nviz/tools.py:525
-msgid "Pause"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:45
-msgid "Repeat"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:48
-msgid "Play back and forward"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:55
-#: ../gui/wxpython/animation/toolbars.py:56
-msgid "Add, edit or remove animation"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:68
-msgid "Add space-time dataset or series of map layers"
-msgstr ""
-#: ../gui/wxpython/animation/toolbars.py:69
-msgid "Add space-time dataset or series of map layers for animation"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:92 ../gui/wxpython/nviz/preferences.py:69
-#: ../gui/wxpython/nviz/preferences.py:74
-msgid "View"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:104
-msgid "Analysis"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:107 ../gui/wxpython/nviz/tools.py:502
-msgid "Animation"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:252
-msgid "Control View"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:276
-msgid "Adjusts the distance and angular perspective of the image viewpoint"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:292 ../gui/wxpython/nviz/preferences.py:86
-msgid "Perspective:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:304
-msgid "Tilts the plane of the surface from the horizontal"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:316 ../gui/wxpython/nviz/tools.py:1263
-msgid "Tilt:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:329
-msgid ""
-"Adjusts the viewing height above the surface (angle of view automatically "
-"adjusts to maintain the same center of view)"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:345
-msgid "Adjusts the relative height of features above the plane of the surface"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:387 ../gui/wxpython/nviz/preferences.py:176
-msgid "Z-exag:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:412
-msgid "Look:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:415
-msgid "here"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:418
-msgid ""
-"Allows you to select a point on the surface that becomes the new center of "
-"view. Click on the button and then on the surface."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:424
-msgid "center"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:428
-msgid "Resets the view to the original default center of view"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:432
-msgid "top"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:436
-msgid ""
-"Sets the viewer directly over the scene's center position. This top view "
-"orients approximately north south."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:440
-msgid "reset"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:441
-msgid "Reset to default view"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:458 ../gui/wxpython/nviz/preferences.py:198
-msgid "Image Appearance"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:510
-msgid ""
-"Press 'Record' button and start changing the view. It is recommended to use "
-"fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:521
-msgid "Record"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:523
-msgid "Play"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:544
-msgid "Total number of frames :"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:551
-msgid "Frame rate (FPS):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:559
-msgid "Frames are recorded with given frequency (FPS). "
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:615
-msgid "Save image sequence"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:625
-msgid "Choose a directory for images"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:638
-msgid ""
-"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:705 ../gui/wxpython/nviz/tools.py:2236
-#: ../gui/wxpython/nviz/preferences.py:398
-msgid "Surface"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:713 ../gui/wxpython/nviz/tools.py:1345
-msgid "Constant surface"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:720 ../gui/wxpython/nviz/preferences.py:546
-msgid "Vector"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:766 ../gui/wxpython/nviz/preferences.py:287
-msgid "Lighting"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:773
-msgid "Fringe"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:804 ../gui/wxpython/nviz/tools.py:1146
-msgid "Cutting planes"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:856 ../gui/wxpython/nviz/tools.py:1896
-#: ../gui/wxpython/nviz/preferences.py:414
-msgid "Mode:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:859 ../gui/wxpython/nviz/preferences.py:420
-msgid "coarse"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:860 ../gui/wxpython/nviz/preferences.py:421
-msgid "fine"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:861 ../gui/wxpython/nviz/preferences.py:422
-msgid "both"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:871 ../gui/wxpython/nviz/tools.py:1162
-#: ../gui/wxpython/nviz/tools.py:1910
-msgid "Shading:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:874 ../gui/wxpython/nviz/tools.py:1913
-msgid "flat"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:875 ../gui/wxpython/nviz/tools.py:1914
-msgid "gouraud"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:883
-msgid "Set to all"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:884
-msgid "Use draw settings for all loaded surfaces"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:896 ../gui/wxpython/nviz/preferences.py:466
-msgid "Coarse mode:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:899 ../gui/wxpython/nviz/tools.py:945
-#: ../gui/wxpython/nviz/preferences.py:447
-#: ../gui/wxpython/nviz/preferences.py:478
-msgid "resolution:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:914 ../gui/wxpython/nviz/preferences.py:496
-msgid "style:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:917 ../gui/wxpython/nviz/preferences.py:502
-msgid "wire"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:918 ../gui/wxpython/nviz/preferences.py:503
-msgid "surface"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:930
-msgid "Change wire color"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:941 ../gui/wxpython/nviz/preferences.py:435
-msgid "Fine mode:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:969
-msgid "Surface attributes"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:978 ../gui/wxpython/nviz/tools.py:2818
-msgid "Transparency"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:979 ../gui/wxpython/nviz/tools.py:2819
-msgid "Shininess"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:985 ../gui/wxpython/nviz/tools.py:2839
-msgid "map"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:988 ../gui/wxpython/nviz/tools.py:2844
-msgid "unset"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:993 ../gui/wxpython/nviz/tools.py:2849
-msgid "constant"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1055
-msgid "Changes the x, y, and z position of the current surface"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1072 ../gui/wxpython/nviz/tools.py:1322
-#: ../gui/wxpython/nviz/tools.py:2041 ../gui/wxpython/nviz/tools.py:3042
-msgid "Reset"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1073 ../gui/wxpython/nviz/tools.py:2042
-msgid "Reset to default position"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1152
-msgid "Active cutting plane:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1164
-msgid "clear"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1165
-msgid "top color"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1166
-msgid "bottom color"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1167
-msgid "blend"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1168
-msgid "shaded"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1180
-msgid "Horizontal X:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1182
-msgid "Sets the X coordinate of the current cutting plane"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1210
-msgid "Horizontal Y:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1212
-msgid "Sets the Y coordinate of the current cutting plane"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1241
-msgid "Rotation:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1243
-msgid "Rotates the current cutting plane about vertical axis"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1265
-msgid "Rotates the current cutting plane about horizontal axis"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1288
-msgid ""
-"Sets the Z coordinate of the current cutting plane (only meaningful when "
-"tilt is not 0)"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1360
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:6
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1973
-#: ../gui/wxpython/menustrings.py:6 ../gui/wxpython/menustrings.py:2007
-msgid "New"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1385
-msgid "Fine resolution:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1399
-msgid "Value:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1411 ../gui/wxpython/nviz/tools.py:3031
-msgid "Transparency:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1477
-msgid "Show vector lines"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1487 ../gui/wxpython/nviz/preferences.py:552
-msgid "Vector lines"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1493
-msgid "Line:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1496
-msgid "width:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1512 ../gui/wxpython/nviz/tools.py:1684
-msgid "color:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1529 ../gui/wxpython/nviz/tools.py:1733
-msgid "use color for thematic mapping"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1532
-msgid "use width for thematic mapping"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1547 ../gui/wxpython/nviz/tools.py:1560
-#: ../gui/wxpython/nviz/tools.py:1756 ../gui/wxpython/nviz/tools.py:1773
-msgid "Set options..."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1579 ../gui/wxpython/nviz/tools.py:5442
-#: ../gui/wxpython/nviz/tools.py:5497
-msgid "on surface(s):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1580 ../gui/wxpython/nviz/tools.py:5442
-msgid "as 3D"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1589 ../gui/wxpython/nviz/tools.py:1796
-msgid "Height above surface:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1640
-msgid "Show vector points"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1649 ../gui/wxpython/nviz/preferences.py:592
-msgid "Vector points"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1656
-msgid "Icon:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1736
-msgid "use size for thematic mapping"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1899
-msgid "isosurfaces"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1900
-msgid "slices"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1923
-msgid "Resolution:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1937
-msgid "Draw wire box"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:1953 ../gui/wxpython/nviz/tools.py:4279
-msgid "List of isosurfaces"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2087
-msgid "Show light model"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2100
-msgid "Light source position"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2117
-msgid "Adjusts the light height"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2148
-msgid "Light color and intensity"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2166 ../gui/wxpython/nviz/preferences.py:345
-msgid "Brightness:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2168
-msgid "Adjusts the brightness of the light"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2183 ../gui/wxpython/nviz/preferences.py:359
-msgid "Ambient:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2185
-msgid "Adjusts the ambient light"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2250
-msgid "Edges with fringe"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2252
-msgid "N && W"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2253
-msgid "N && E"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2254
-msgid "S && W"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2255
-msgid "S && E"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2280
-msgid "Elevation of fringe from bottom:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2337
-msgid "Arrow length (in map units):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2349
-msgid "Arrow color:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2361
-msgid "Place arrow"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2386
-msgid "Scale bar length (in map units):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2398
-msgid "Scale bar color:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2410
-msgid "Place new scale bar"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2482
-msgid "Do you want to record new animation without saving the previous one?"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2485
-msgid "Animation already axists"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2655
-msgid "No file prefix given."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2659
-#, python-format
-msgid "Directory %s does not exist."
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2679 ../gui/wxpython/nviz/tools.py:2728
-#: ../gui/wxpython/nviz/tools.py:5172 ../gui/wxpython/nviz/mapwindow.py:2253
-#: ../gui/wxpython/nviz/mapwindow.py:2272
-msgid "constant#"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2800
-msgid "Isosurface attributes"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2806
-msgid "toggle normal direction"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2815
-msgid "Isosurface value"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2932
-msgid "Slice attributes"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:2941
-msgid "Slice parallel to axis:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3099
-msgid "W"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3100
-msgid "N"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3101
-msgid "S"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3102
-msgid "E"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3103
-msgid "NW"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3104
-msgid "NE"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3105
-msgid "SE"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3106
-msgid "SW"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:3624 ../gui/wxpython/nviz/tools.py:5560
-msgid "Level"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4285
-msgid "List of slices"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4483 ../gui/wxpython/nviz/tools.py:4485
-msgid "Level {level}"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4493 ../gui/wxpython/nviz/tools.py:4497
-msgid "Slice parallel to {axis}"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:4785 ../gui/wxpython/nviz/tools.py:5573
-msgid "Slice parallel to"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5017
-#, python-format
-msgid "Scalebar %d"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5179
-msgid "None"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5181
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:490
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1416
-#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1441
-msgid "Plane"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5381
-msgid "Vector map is 3D"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5384
-msgid "Vector map is 2D"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5386
-#, python-format
-msgid "%(features)d features (%(points)d points)"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5444 ../gui/wxpython/nviz/tools.py:5499
-msgid "on surface"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5597
-msgid "range:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5676 ../gui/wxpython/nviz/tools.py:5687
-msgid "North edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5677 ../gui/wxpython/nviz/tools.py:5688
-msgid "South edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5678 ../gui/wxpython/nviz/tools.py:5685
-#: ../gui/wxpython/nviz/tools.py:5694
-msgid "West edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5679 ../gui/wxpython/nviz/tools.py:5686
-#: ../gui/wxpython/nviz/tools.py:5695
-msgid "East edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5681 ../gui/wxpython/nviz/tools.py:5692
-#: ../gui/wxpython/nviz/tools.py:5700
-msgid "Northing (Y):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5682 ../gui/wxpython/nviz/tools.py:5691
-#: ../gui/wxpython/nviz/tools.py:5701
-msgid "Height (Z):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5683 ../gui/wxpython/nviz/tools.py:5690
-#: ../gui/wxpython/nviz/tools.py:5699
-msgid "Easting (X):"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5696
-msgid "Bottom edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5697
-msgid "Top edge:"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5808
-msgid "Adjusts the distance and direction of the image viewpoint"
-msgstr ""
-#: ../gui/wxpython/nviz/tools.py:5843
-msgid ""
-"Adjusts the light direction. Click and drag the puck to change the light "
-"direction."
-msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:33
-msgid ""
-"This module requires the NumPy module, which could not be imported. It "
-"probably is not installed (it's not part of the standard Python "
-"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
-"information on downloading source or binaries."
-msgstr ""
-#: ../gui/wxpython/nviz/wxnviz.py:505 ../gui/wxpython/nviz/wxnviz.py:517
-#, python-format
-msgid "3d raster map <%s> not found"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:35
-msgid "3D view default settings"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:62
-msgid "Revert settings to default, changes are not applied"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:90
-#: ../gui/wxpython/nviz/preferences.py:161
-#: ../gui/wxpython/nviz/preferences.py:180
-msgid "value:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:103
-msgid "step:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:118
-#: ../gui/wxpython/nviz/preferences.py:300
-msgid "Position:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:122
-#: ../gui/wxpython/nviz/preferences.py:304
-msgid "x:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:157
-msgid "Twist:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:237
-msgid "Fly-through"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:247
-msgid "Move exag:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:260
-msgid "Turn exag:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:292
-msgid "Light"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:330
-msgid "z:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:517
-msgid "wire color:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:598
-msgid "Automatic size"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:599
-msgid "Icon size is set automatically based on landscape dimensions."
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:623
-msgid "Marker:"
-msgstr ""
-#: ../gui/wxpython/nviz/preferences.py:724
-#, python-format
-msgid "3D view settings saved to file <%s>."
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:244
-msgid ""
-"Opening 3D view was not successful. Please try to change the value of depth "
-"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:509
-#, python-format
-msgid ""
-"Image is too large, your OpenGL implementation supports maximum texture size"
-" %d px."
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1021
-msgid "Easting"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1022
-msgid "Northing"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1023
-msgid "Elevation"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1029
-msgid "Surface map name"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1032
-msgid "Surface map elevation"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1034
-msgid "Surface map color"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1045
-msgid "XY distance from previous"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1048
-msgid "XYZ distance from previous"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1051
-msgid "Distance along surface"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1055
-msgid "Distance along exag. surface"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1059
-msgid "No point on surface"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1539
-msgid "Loading raster map"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1543
-msgid "Loading 3d raster map"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1551
-msgid "failed"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1554
-#, python-format
-msgid "Unsupported layer type '%s'"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1674
-msgid "Unable to unload raster map"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1679
-msgid "Unable to unload 3d raster map"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1680
-msgid "3d raster map"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1692
-msgid "unloaded successfully"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1748
-#, python-format
-msgid "Loading vector map <%(name)s> (%(type)s) failed"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1811
-#, python-format
-msgid "Unable to unload vector map <%(name)s> (%(type)s)"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:1815
-#, python-format
-msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2192
-#, python-format
-msgid "Vector point layer not found (id = %d)"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2194
-#, python-format
-msgid "Unable to set data layer properties (id = %d)"
-msgstr ""
-#: ../gui/wxpython/nviz/mapwindow.py:2198
-#, python-format
-msgid ""
-"Setting data layer properties failed.\n"
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:122
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:122
-msgid "1. Select GRASS GIS database directory"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:125
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:125
-msgid "2. Select GRASS Location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:128
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:128
-msgid "3. Select GRASS Mapset"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:146
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:146
-msgid "GRASS GIS database directory contains Locations."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:150
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:150
-msgid ""
-"All data in one Location is in the same  coordinate reference system "
-"(projection). One Location can be one project. Location contains Mapsets."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:158
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:158
-msgid ""
-"Mapset contains GIS data related to one project, task within one project, "
-"subregion or user."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:173
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:173
-msgid "Start &GRASS session"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:179
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:179
-msgid "&Browse"
-msgstr ""
-#. GTC New mapset
-#: ../gui/wxpython/gis_set.py:182
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:182
-msgid "&New"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:183
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:183
-msgid "Create a new Mapset in selected Location"
-msgstr ""
-#. GTC New location
-#: ../gui/wxpython/gis_set.py:186
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:186
-msgid "N&ew"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:189
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:189
-msgid ""
-"Create a new location using location wizard. After location is created "
-"successfully, GRASS session is started."
-msgstr ""
-#. GTC Rename location
-#: ../gui/wxpython/gis_set.py:194
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:194
-msgid "Ren&ame"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:195 ../gui/wxpython/gis_set.py:727
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:195
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:670
-msgid "Rename selected location"
-msgstr ""
-#. GTC Delete location
-#: ../gui/wxpython/gis_set.py:198
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:198
-msgid "De&lete"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:199 ../gui/wxpython/gis_set.py:810
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:199
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:753
-msgid "Delete selected location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:201 ../gui/wxpython/startup/locdownload.py:303
-msgid "Do&wnload"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:202
-msgid "Download sample location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:207 ../gui/wxpython/gis_set.py:684
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:203
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:627
-msgid "Rename selected mapset"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:211 ../gui/wxpython/gis_set.py:782
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:207
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:725
-msgid "Delete selected mapset"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:257
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:252
-#, python-format
-msgid "GRASS GIS %s startup%s"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:262
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:257
-msgid "Enter GRASS session"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:282
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:277
-msgid "Unable to set GRASS database. Check your locale settings."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:302
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:297
-#, python-format
-msgid "ERROR: Location <%s> not found\n"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:320
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:315
-#, python-format
-msgid "ERROR: Mapset <%s> not found\n"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:480
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:474
-#, python-format
-msgid "Invalid line in GISRC file (%s):%s\n"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:511 ../gui/wxpython/startup/locdownload.py:441
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:505
-msgid "Error: {text}"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:549
-msgid "Documents"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:550
-msgid "My Documents"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:574
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:1171
-msgid ""
-"GRASS needs a directory (GRASS database) in which to store its data. Create "
-"one now if you have not already done so. A popular choice is \"grassdata\", "
-"located in your home directory. Press Browse button to select the directory."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:596
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:539
-#, python-format
-msgid "Do you want to import <%(name)s> to the newly created location?"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:599
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:542
-msgid "Import data?"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:613
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:556
-msgid "New mapset:"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:655
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:598
-#, python-format
-msgid ""
-"Import of <%(name)s> failed.\n"
-"Reason: %(msg)s"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:662
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:605
-#, python-format
-msgid ""
-"Data file <%(name)s> imported successfully. The location's default region "
-"was set from this imported map."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:676
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:619
-msgid ""
-"Mapset <PERMANENT> is required for valid GRASS location.\n"
-"\n"
-"This mapset cannot be renamed."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:682 ../gui/wxpython/gis_set.py:725
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:625
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:668
-#, python-format
-msgid ""
-"Current name: %s\n"
-"\n"
-"Enter new name:"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:698
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:641
-#, python-format
-msgid ""
-"Unable to rename mapset.\n"
-"\n"
-"Mapset <%s> already exists in location."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:712
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:655
-#, python-format
-msgid ""
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:741
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:684
-#, python-format
-msgid ""
-"Unable to rename location.\n"
-"\n"
-"Location <%s> already exists in GRASS database."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:756
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:699
-#, python-format
-msgid ""
-"\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:770
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:713
-msgid ""
-"\n"
-"This mapset cannot be deleted."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:777
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:720
-#, python-format
-msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
-"\n"
-"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:791
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:734
-msgid "Unable to delete mapset"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:805
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:748
-#, python-format
-msgid ""
-"Do you want to continue with deleting location <%s>?\n"
-"\n"
-"ALL MAPS included in this location will be PERMANENTLY DELETED!"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:821
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:764
-msgid "Unable to delete location"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:851
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:774
-msgid "Unicode error detected. Check your locale settings. Details: {0}"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:863
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:786
-#, python-format
-msgid ""
-"No GRASS Location found in '%s'. Create a new Location or choose different "
-"GRASS database directory."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:985
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:908
-#, python-format
-msgid "Path '%s' doesn't exist."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1029
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:952
-#, python-format
-msgid "Mapset <%s> already exists."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1036
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:959
-#, python-format
-msgid ""
-"Mapset <%s> is reserved for direct read access to OGR layers. Please consider to use another name for your mapset.\n"
-"\n"
-"Are you really sure that you want to create this mapset?"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1041
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:964
-msgid "Reserved mapset name"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1073
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:996
-#, python-format
-msgid "Unable to create new mapset: %s"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1088
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:1011
-#, python-format
-msgid ""
-"GRASS is already running in selected mapset <%(mapset)s>\n"
-"(file %(lock)s found).\n"
-"\n"
-"Concurrent use not allowed.\n"
-"\n"
-"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1094 ../gui/wxpython/gis_set.py:1107
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:1017
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:1030
-msgid "Lock file found"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1103
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:1026
-msgid ""
-"ARE YOU REALLY SURE?\n"
-"\n"
-"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1117
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:1040
-#, python-format
-msgid ""
-"Unable to remove '%(lock)s'.\n"
-"\n"
-"Details: %(reason)s"
-msgstr ""
-#: ../gui/wxpython/gis_set.py:1167
-#: ../gui/wxpython/image2target/ii2t_gis_set.py:1090
-#, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location or mapset. Please use only "
-"ASCII characters excluding %(chars)s and space."
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:43
-msgid ""
-"The Temporal Plot Tool needs the \"matplotlib\" (python-matplotlib) package "
-"to be installed. {0}"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:97
-msgid "GRASS GIS Temporal Plot Tool"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:180
-msgid ""
-"Raster temporal dataset (strds)\n"
-"Press ENTER after typing the name or select with the combobox"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:189
-msgid "X and Y coordinates separated by comma:"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:201
-msgid ""
-"Coordinates can be obtained for example by right-clicking on Map Display."
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:216
-msgid "STRDS"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:224
-msgid ""
-"Vector temporal dataset (stvds)\n"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:238
-msgid "Select attribute column"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:251
-msgid "Select category of vector(s)"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:269
-msgid "STVDS"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:297 ../gui/wxpython/tplot/frame.py:724
-#: ../gui/wxpython/tplot/frame.py:728 ../gui/wxpython/tplot/frame.py:749
-#: ../gui/wxpython/tplot/frame.py:875
-msgid "Invalid input coordinates"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:388
-msgid "Category {ca} is not on vector map {ma} and it will be not used"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:407
-msgid ""
-"Both coordinates and categories are set, coordinates will be used. The use "
-"categories remove text from coordinate form"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:412
-msgid "With Vector temporal dataset you have to select an attribute column"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:464
-msgid ""
-"Difference number of vector layers and maps in the vector temporal dataset"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:506
-msgid "No connection between vector map {vmap} and layer {la}"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:580
-msgid ""
-"Problem getting data from raster temporal dataset. Empty list of values."
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:592 ../gui/wxpython/tplot/frame.py:644
-#: ../gui/wxpython/tplot/frame.py:682
-#, python-format
-msgid "Temporal resolution: %s"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:625
-msgid ""
-"Problem getting data from vector temporal dataset. Empty list of values for "
-"cat {ca}."
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:670
-msgid ""
-"Problem getting data from vector temporal dataset. Empty list of values."
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:717
-msgid "Incorrect coordinates format, should be: x,y"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:733
-msgid "Seed point outside the current region"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:745
-msgid "Invalid input raster dataset"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:762
-msgid "Invalid input vector dataset"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:868 ../gui/wxpython/tplot/frame.py:916
-msgid "Invalid input temporal dataset"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:937
-msgid "Datasets have different number of values"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:967
-msgid "Value for {date} is {val}"
-msgstr ""
-#: ../gui/wxpython/tplot/frame.py:970
-msgid "Press Del to dismiss."
-msgstr ""
-#: ../gui/wxpython/tplot/g.gui.tplot.py:106
-msgid "With stvds you have to set 'attr' option"
-msgstr ""
-#: ../gui/wxpython/tplot/g.gui.tplot.py:110
-msgid ""
-"With stvds it is not possible to use 'coordinates' and 'cats' options "
-"together"
-msgstr ""
-#: ../gui/wxpython/tplot/g.gui.tplot.py:113
-msgid "With stvds you have to use 'coordinates' or 'cats' option"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:37
-msgid "Draw/re-draw plot"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:40
-msgid "Draw transect in map display window to profile"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:43
-msgid "Plot options"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:46
-msgid "Plot statistics"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:49
-msgid "Save profile data to CSV file"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:51
-msgid "Quit plot tool"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:485
-msgid "Left Mouse Down at Point:"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:517 ../gui/wxpython/wxplot/base.py:584
-#: ../gui/wxpython/wxplot/dialogs.py:664
-msgid "Text settings"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:521 ../gui/wxpython/wxplot/base.py:598
-#: ../gui/wxpython/wxplot/dialogs.py:986
-msgid "Plot settings"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:534
-msgid "This feature is not yet functional"
-msgstr ""
-#: ../gui/wxpython/wxplot/base.py:535
-msgid "Under Construction"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:43
-msgid "GRASS GIS Histogramming Tool"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:51
-msgid "Histogram of"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:52
-#: ../gui/wxpython/wxplot/histogram.py:156
-#: ../gui/wxpython/wxplot/scatter.py:52 ../gui/wxpython/wxplot/scatter.py:53
-msgid "Raster cell values"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:53
-#: ../gui/wxpython/wxplot/histogram.py:162
-msgid "Cell counts"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:141
-#, python-format
-msgid "Histogram of image group <%s>"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:145
-#, python-format
-msgid "Histogram of raster map <%s>"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:147
-msgid "Histogram of selected raster maps"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:154
-#, python-format
-msgid "Raster cell values %s"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:164
-msgid "Percent of total cells"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:166
-msgid "Area"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:252
-msgid "Statistics for Map(s) Histogrammed"
-msgstr ""
-#: ../gui/wxpython/wxplot/histogram.py:257
-#, python-format
-msgid "Statistics for raster map <%s>"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:49
-msgid "GRASS Profile Analysis Tool"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:65 ../gui/wxpython/wxplot/profile.py:175
-msgid "Profile of"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:94
-#, python-format
-msgid "Distance (%s)"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:96
-msgid "Distance along transect"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:97
-msgid "Cell values"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:168
-msgid "Not all points of profile lie inside computational region."
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:239
-msgid "Raster values"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:292
-msgid "You must draw a transect to profile in the map display window."
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:293
-msgid "Nothing to profile"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:361
-msgid "Choose prefix for file(s) where to save profile values..."
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:363
-msgid "Comma separated value (*.csv)|*.csv"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:377
-msgid "Overwrite file?"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:388
-#, python-format
-msgid ""
-"Unable to open file <%s> for writing.\n"
-"Reason: %s"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:404
-#, python-format
-msgid ""
-"%d files created:\n"
-"%s"
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:407
-msgid "No files generated."
-msgstr ""
-#: ../gui/wxpython/wxplot/profile.py:415
-msgid "Statistics for Profile(s)"
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:44
-msgid "GRASS Bivariate Scatterplot Tool"
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:51
-msgid "Bivariate Scatterplot"
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:102 ../gui/wxpython/wxplot/scatter.py:254
-msgid "Nothing to plot."
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:113
-msgid "At least 2 raster maps must be specified"
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:136
-msgid "Bivariate Scatterplot of "
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:157 ../gui/wxpython/wxplot/scatter.py:158
-#, python-format
-msgid "Raster <%s> cell values"
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:162 ../gui/wxpython/wxplot/scatter.py:166
-#, python-format
-msgid ": %s"
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:260
-msgid "Regression Statistics for Scatterplot(s)"
-msgstr ""
-#: ../gui/wxpython/wxplot/scatter.py:271
-#, python-format
-msgid ""
-"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
-"\n"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:41
-msgid "Select raster maps to profile"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:81
-msgid "Select raster map(s) to profile:"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:132
-msgid "Select pairs of raster maps for scatterplots"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:180
-msgid "Select pairs of raster maps for bivariate scatterplots:"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:195 ../gui/wxpython/wxplot/dialogs.py:502
-msgid "Number of bins (for FP maps)"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:360
-msgid "C&opy"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:362
-msgid "Copy regression statistics the clipboard (Ctrl+C)"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:403
-msgid "Regression statistics copied to clipboard"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:414
-msgid "Select raster map or imagery group to histogram"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:442
-msgid "Histogram single raster"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:445
-msgid "Histogram imagery group"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:486
-msgid "Select image group:"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:515
-msgid "Histogram type"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:601
-msgid "Selected group must be in current mapset"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:674
-msgid "Profile title:"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:688
-msgid "Title font size (pts):"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:705
-msgid "X-axis label:"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:719
-msgid "Y-axis label:"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:733
-msgid "Label font size (pts):"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:761
-msgid "Font family:"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:777
-msgid "Style:"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:793
-msgid "Weight:"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:832
-#: ../gui/wxpython/wxplot/dialogs.py:1430
-msgid "Apply changes for the current session and close dialog"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:904
-#, python-format
-msgid "Plot text sizes saved to file '%s'."
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:964
-msgid "No map or image group selected to plot."
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1007
-msgid "Map/image plotted"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1019
-msgid "Settings for selected map"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1037
-msgid "Line color"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1104
-msgid "Transect segment marker settings"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1186
-msgid "Scatterplot points"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1268
-msgid "Axis settings"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1274
-msgid "X-Axis"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1275
-msgid "Y-Axis"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1284
-msgid "Scale"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1296
-msgid ""
-"Automatic axis scaling, custom max and min, or scale matches data range "
-"(min)"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1304
-msgid "Custom min"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1321
-msgid "Custom max"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1335
-msgid "Log scale"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1359
-msgid "Grid and Legend settings"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1364
-msgid "Grid color"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1374
-msgid "Show grid"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1383
-msgid "Legend font size"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1397
-msgid "Show legend"
-msgstr ""
-#: ../gui/wxpython/wxplot/dialogs.py:1597
-#, python-format
-msgid "Plot settings saved to file '%s'."
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:276
-msgid "Manage Location of Fiducial Points on a Scanned Photo"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:380
-msgid "A POINTS file exists, renaming it to POINTS_BAK"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:406
-msgid "Opening CAMERA file failed"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1042
-msgid "Writing output image to group, please wait..."
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1536
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1554
-msgid "source X"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1537
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1555
-msgid "source Y"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1538
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1556
-msgid "target X"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1539
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1557
-msgid "target Y"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1765
-msgid "source X:"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1766
-msgid "target X:"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1767
-msgid "source Y:"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_manager.py:1768
-msgid "target Y:"
-msgstr ""
-#: ../gui/wxpython/photo2image/g.gui.photo2image.py:96
-msgid "Please provide a group name to process"
-msgstr ""
-#: ../gui/wxpython/photo2image/g.gui.photo2image.py:101
-msgid "Please provide a raster map name to process"
-msgstr ""
-#: ../gui/wxpython/photo2image/g.gui.photo2image.py:106
-msgid "Please provide a camera name (generated by i.ortho.camera)"
-msgstr ""
-#: ../gui/wxpython/photo2image/g.gui.photo2image.py:111
-msgid "Please provide an order value (1 if 4 Fiducials, 2 if 8 Fiducials)"
-msgstr ""
-#: ../gui/wxpython/photo2image/g.gui.photo2image.py:116
-msgid "Please provide an output files extension (used by i.rectify)"
-msgstr ""
-#: ../gui/wxpython/photo2image/ip2i_mapdisplay.py:50
-msgid "GRASS GIS Manage Location of Tick Points on a Scanned Photo"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:150
-#, python-brace-format
-msgid "ZIP file is unreadable: {0}"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:169
-msgid "Archive file is unreadable: {0}"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:201
-msgid "Download of <{url}> failed or file <{name}> is not a ZIP file"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:217
-msgid "Unknown format '{0}'."
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:233
-msgid "Downloaded location is not valid"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:293
-msgid "Select sample location to download:"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:304
-msgid "Download selected location"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:360
-#: ../gui/wxpython/startup/locdownload.py:389
-msgid "Download in progress, wait until it is finished"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:373
-#, python-format
-msgid "Location named <%s> already exists, download canceled"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:381
-#, python-format
-msgid "Download failed: %s"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:384
-msgid ""
-"Download completed. The downloaded sample data is listed in the "
-"location/mapset tabs upon closing of this window"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:406
-#, python-format
-msgid "Location named <%s> already exists, rename it first"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:458
-msgid "GRASS GIS Location Download"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:491
-msgid "Do you want to cancel location download?"
-msgstr ""
-#: ../gui/wxpython/startup/locdownload.py:492
-msgid "Abort download"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_manager.py:538
-msgid "Select group:"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_manager.py:1483
-msgid "Writing CONTROL_POINTS file failed"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_manager.py:1495
-#, python-format
-msgid "CONTROL_POINTS file saved for group <%s>"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_manager.py:1546
-msgid "Reading CONTROL_POINTS file failed"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_manager.py:1872
-msgid ""
-"Could not calculate RMS Error.\n"
-"Possible error with i.ortho.transform."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_manager.py:1998
-msgid ""
-"Could not calculate new extends.\n"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_manager.py:2212
-#: ../gui/wxpython/image2target/ii2t_manager.py:2232
-msgid "source Z"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_manager.py:2215
-#: ../gui/wxpython/image2target/ii2t_manager.py:2235
-msgid "target Z"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_manager.py:2587
-msgid "source Z:"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_manager.py:2588
-msgid "target Z:"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1972
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2022
-#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:2006
-#: ../gui/wxpython/menustrings.py:2056
-msgid "&File"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:5
-#: ../gui/wxpython/menustrings.py:5
-msgid "Workspace"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:7
-#: ../gui/wxpython/menustrings.py:7
-msgid "Create new workspace"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:8
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1975
-#: ../gui/wxpython/menustrings.py:8 ../gui/wxpython/menustrings.py:2009
-msgid "Open"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:9
-#: ../gui/wxpython/menustrings.py:9
-msgid "Load workspace from file"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:12
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1979
-#: ../gui/wxpython/menustrings.py:12 ../gui/wxpython/menustrings.py:2013
-msgid "Save as"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:13
-#: ../gui/wxpython/menustrings.py:13
-msgid "Save workspace to file"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:15
-#: ../gui/wxpython/menustrings.py:15
-msgid "Close workspace file"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:16
-#: ../gui/wxpython/menustrings.py:16
-msgid "Load GRC file (Tcl/Tk GUI)"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:17
-#: ../gui/wxpython/menustrings.py:17
-msgid "Load map layers from GRC file to layer tree"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:19
-msgid "Add raster"
-msgstr ""
-msgid "Add raster map layer to current display"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:21
-#: ../gui/wxpython/menustrings.py:21
-msgid "Add vector"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:22
-#: ../gui/wxpython/menustrings.py:22
-msgid "Add vector map layer to current display"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:23
-#: ../gui/wxpython/menustrings.py:23
-msgid "Add multiple rasters or vectors"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:24
-#: ../gui/wxpython/menustrings.py:24
-msgid "Add multiple raster or vector map layers to current display"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:25
-#: ../gui/wxpython/menustrings.py:25
-msgid "Add RGB raster layer"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:26
-#: ../gui/wxpython/menustrings.py:26
-msgid "Add RGB raster map layer to current display"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:29
-#: ../gui/wxpython/menustrings.py:29
-msgid "New map display window"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:30
-#: ../gui/wxpython/menustrings.py:30
-msgid "Open new map display window"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:31
-#: ../gui/wxpython/menustrings.py:31
-msgid "Render all map displays"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:32
-#: ../gui/wxpython/menustrings.py:32
-msgid "Re-render maps in all open map display windows"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:33
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:34
-#: ../gui/wxpython/menustrings.py:33 ../gui/wxpython/menustrings.py:34
-msgid "Close current map display window"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:35
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:36
-#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:36
-msgid "Close all open map display windows"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:38
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1039
-msgid "Common formats import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:39
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1040
-#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:41
-#: ../gui/wxpython/menustrings.py:1058 ../gui/wxpython/menustrings.py:1060
-msgid "Imports raster data into a GRASS raster map using GDAL library."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:40
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:70
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1041
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1071
-msgid "Import of common formats with reprojection"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:41
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1042
-msgid ""
-"Imports raster data into a GRASS raster map using GDAL library and "
-"reprojects on the fly."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:42
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1043
-#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1061
-msgid "ASCII x,y,z point import and gridding"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:43
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1044
-#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1062
-msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate"
-" statistics."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:44
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1045
-#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1063
-msgid "ASCII grid import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:45
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1046
-#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1064
-msgid "Converts a GRASS ASCII raster file to binary raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:46
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1047
-#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1065
-msgid "ASCII polygons, lines, and point import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:47
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1048
-#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1066
-msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:48
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1049
-#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1067
-msgid "Raw binary array import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1050
-#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1068
-msgid "Import a binary raster file into a GRASS raster map layer."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:50
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1051
-#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1069
-msgid "GRIDATB.FOR import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:51
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1052
-#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1070
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:52
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1053
-#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1071
-msgid "Matlab 2D array import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:53
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1054
-#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1072
-msgid "Imports a binary MAT-File(v4) to a GRASS raster."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:54
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1055
-#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1073
-msgid "PNG import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:55
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1056
-#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:1074
-msgid "Imports non-georeferenced PNG format image."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:56
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1057
-#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1075
-msgid "SPOT NDVI import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:57
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1058
-#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1076
-msgid "Imports SPOT VGT NDVI data into a raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:58
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1059
-#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:1077
-msgid "SRTM HGT import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:59
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1060
-#: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:1078
-msgid "Imports SRTM HGT files into raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:60
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1061
-#: ../gui/wxpython/menustrings.py:60 ../gui/wxpython/menustrings.py:1079
-msgid "Terra ASTER HDF import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:61
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1062
-#: ../gui/wxpython/menustrings.py:61 ../gui/wxpython/menustrings.py:1080
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:62
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:86
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1063
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1087
-#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:87
-#: ../gui/wxpython/menustrings.py:1081 ../gui/wxpython/menustrings.py:1106
-msgid "LAS LiDAR points import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:63
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1064
-#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1083
-msgid "Unpack raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:64
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1065
-msgid ""
-"Imports a raster map as GRASS GIS specific archive file (packed with r.pack)"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:65
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:286
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1066
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1212
-#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:293
-#: ../gui/wxpython/menustrings.py:1085 ../gui/wxpython/menustrings.py:1235
-msgid "Reproject raster map from different GRASS location"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:66
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:287
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1067
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1213
-#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:294
-#: ../gui/wxpython/menustrings.py:1086 ../gui/wxpython/menustrings.py:1236
-msgid "Re-projects a raster map from given location to the current location."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:68
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:99
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1069
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1100
-#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1120
-msgid "Common import formats"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:69
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1070
-#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:72
-#: ../gui/wxpython/menustrings.py:1089 ../gui/wxpython/menustrings.py:1091
-msgid "Imports vector data into a GRASS vector map using OGR library."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:71
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1072
-msgid ""
-"Imports vector data into a GRASS vector map using OGR library and reprojects"
-" on the fly."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:72
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1073
-#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1092
-msgid "ASCII points or GRASS ASCII format"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:73
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1074
-#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1093
-msgid "Creates a vector map from an ASCII points file or ASCII vector file."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:74
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1075
-#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1094
-msgid "ASCII points as a vector lines"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:75
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1076
-#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1095
-msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:76
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1077
-#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1096
-msgid "DXF import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:77
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1078
-#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1097
-msgid "Converts files in DXF format to GRASS vector map format."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:78
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1079
-#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1098
-msgid "WFS"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:79
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1080
-#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1099
-msgid "Imports GetFeature from a WFS server."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:80
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1081
-#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1100
-msgid "ESRI e00 import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:81
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1082
-#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1101
-msgid "Imports E00 file into a vector map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:82
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1083
-#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1102
-msgid "Geonames import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:83
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1084
-#: ../gui/wxpython/menustrings.py:84 ../gui/wxpython/menustrings.py:1103
-msgid "Imports geonames.org country files into a vector points map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:84
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1085
-#: ../gui/wxpython/menustrings.py:85 ../gui/wxpython/menustrings.py:1104
-msgid "Matlab array or Mapgen format import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:85
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1086
-#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1105
-msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:87
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1088
-#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:1108
-msgid "Unpack vector map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:88
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1089
-msgid ""
-"Imports a vector map as GRASS GIS specific archive file (packed with v.pack)"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:89
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:564
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1090
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1490
-#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:573
-#: ../gui/wxpython/menustrings.py:1110 ../gui/wxpython/menustrings.py:1515
-msgid "Reproject vector map from different GRASS location"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:90
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:565
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1091
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1491
-#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:574
-#: ../gui/wxpython/menustrings.py:1111 ../gui/wxpython/menustrings.py:1516
-msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:91
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1092
-#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1112
-msgid "Import 3D raster data"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:92
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1093
-#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1113
-msgid "ASCII 3D import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:93
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1094
-#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1114
-msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:94
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1095
-#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1115
-msgid "Raw binary array 3D import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:95
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1096
-#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1116
-msgid "Imports a binary raster file into a GRASS 3D raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:96
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1097
-#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1117
-msgid "Vis5D import"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:97
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1098
-#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1118
-msgid "Import 3-dimensional Vis5D files."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:98
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1099
-#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:1119
-msgid "Import database table"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:100
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1101
-#: ../gui/wxpython/menustrings.py:102 ../gui/wxpython/menustrings.py:1121
-msgid "Imports attribute tables in various formats."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:101
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1102
-#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1122
-msgid "Export raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:102
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:131
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:156
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1103
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1132
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1157
-#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:133
-#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1123
-#: ../gui/wxpython/menustrings.py:1152 ../gui/wxpython/menustrings.py:1178
-msgid "Common export formats"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1104
-#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1124
-msgid "Exports GRASS raster maps into GDAL supported formats."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1105
-#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1125
-msgid "ASCII grid export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1106
-#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1126
-msgid "Converts a raster map layer into a GRASS ASCII text file."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1107
-#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1127
-msgid "ASCII x,y,z points export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1108
-#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1128
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1109
-#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1129
-msgid "GRIDATB.FOR export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1110
-#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1130
-msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1111
-#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1131
-msgid "Matlab 2D array export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1112
-#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1132
-msgid "Exports a GRASS raster to a binary MAT-File."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:112
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1113
-#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1133
-msgid "Raw binary array export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1114
-#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1134
-msgid "Exports a GRASS raster to a binary array."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:114
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1115
-#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1135
-msgid "MPEG-1 export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1116
-#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1136
-msgid "Converts raster map series to MPEG movie."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:116
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1117
-#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1137
-msgid "PNG export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:117
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1118
-#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1138
-msgid "Export a GRASS raster map as a non-georeferenced PNG image."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:118
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1119
-#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1139
-msgid "PPM export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:119
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1120
-#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1140
-msgid "Converts a GRASS raster map to a PPM image file."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:120
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1121
-#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:1141
-msgid "PPM from RGB export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1122
-#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1142
-msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:122
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:138
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1123
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1139
-#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:141
-#: ../gui/wxpython/menustrings.py:1143 ../gui/wxpython/menustrings.py:1160
-msgid "POV-Ray export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:123
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1124
-#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1144
-msgid "Converts a raster map layer into a height-field file for POV-Ray."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:124
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1125
-#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1145
-msgid "VRML export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:125
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1126
-#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1146
-msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:126
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:142
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:153
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1127
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1143
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1154
-#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:145
-#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1147
-#: ../gui/wxpython/menustrings.py:1164 ../gui/wxpython/menustrings.py:1175
-msgid "VTK export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:127
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1128
-#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1148
-msgid "Converts raster maps into the VTK-ASCII format."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:128
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1129
-#: ../gui/wxpython/menustrings.py:130 ../gui/wxpython/menustrings.py:1149
-msgid "Pack raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:129
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1130
-#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1150
-msgid "Exports a raster map as GRASS GIS specific archive file"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:130
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1131
-#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1151
-msgid "Export vector map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:132
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1133
-msgid ""
-"Exports a vector map layer to any of the supported OGR vector formats. By "
-"default a vector map layer is exported to Esri Shapefile format."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:133
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1134
-#: ../gui/wxpython/menustrings.py:135 ../gui/wxpython/menustrings.py:1154
-msgid "ASCII points or GRASS ASCII vector export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:134
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1135
-#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1155
-msgid ""
-"Exports a vector map to a GRASS ASCII vector representation. By default only"
-" features with category are exported. To export all features use 'layer=-1'."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:135
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1136
-#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1156
-msgid "DXF export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:136
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1137
-#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1157
-msgid "Exports vector map to DXF file format."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:137
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1138
-#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1158
-msgid "PostGIS export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:139
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1140
-#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1161
-msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:140
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1141
-#: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:1162
-msgid "SVG export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:141
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1142
-#: ../gui/wxpython/menustrings.py:144 ../gui/wxpython/menustrings.py:1163
-msgid "Exports a vector map to SVG file."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:143
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1144
-#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1165
-msgid "Converts a vector map to VTK ASCII output."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:144
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1145
-#: ../gui/wxpython/menustrings.py:147 ../gui/wxpython/menustrings.py:1166
-msgid "Pack vector map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:145
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1146
-#: ../gui/wxpython/menustrings.py:148 ../gui/wxpython/menustrings.py:1167
-msgid "Exports a vector map as GRASS GIS specific archive file"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:146
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1147
-#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1168
-msgid "Export 3D raster maps"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:147
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1148
-#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1169
-msgid "ASCII 3D export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:148
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1149
-#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1170
-msgid "Converts a 3D raster map layer into a ASCII text file."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1150
-#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1171
-msgid "Raw binary array 3D export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:150
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1151
-#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1172
-msgid "Exports a GRASS 3D raster map to a binary array."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:151
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1152
-#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1173
-msgid "Vis5D export"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:152
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1153
-#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1174
-msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:154
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1155
-#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1176
-msgid "Converts 3D raster maps into the VTK-ASCII format."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:155
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1156
-#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1177
-msgid "Export database table"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:157
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1158
-#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1179
-msgid "Exports attribute tables into various formats."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:158
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1159
-#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1180
-msgid "Link external data"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:160
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1161
-#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1182
-msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:162
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1163
-#: ../gui/wxpython/menustrings.py:165 ../gui/wxpython/menustrings.py:1184
-msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:163
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1164
-#: ../gui/wxpython/menustrings.py:166 ../gui/wxpython/menustrings.py:1185
-msgid "Output format for raster data"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:164
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1165
-#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:1186
-msgid ""
-"Redirects raster output to file utilizing GDAL library rather than storing "
-"in GRASS raster format."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:165
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1166
-#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:1187
-msgid "Output format for vector data"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:166
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1167
-#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1188
-msgid "Defines vector output format utilizing OGR library."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:167
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1168
-#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1189
-msgid "Manage maps"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:169
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1170
-#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1191
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:170
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:946
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1171
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1872
-#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:964
-#: ../gui/wxpython/menustrings.py:1192 ../gui/wxpython/menustrings.py:1906
-msgid "List"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:171
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1172
-#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:1193
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:173
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1174
-#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:1195
-msgid "Renames data base element files in the user's current mapset."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:175
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1176
-#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:1197
-msgid ""
-"Removes data base element files from the user's current mapset using the "
-"search pattern."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:176
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:310
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:602
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:847
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1236
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1528
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1773
-#: ../gui/wxpython/menustrings.py:179 ../gui/wxpython/menustrings.py:317
-#: ../gui/wxpython/menustrings.py:611 ../gui/wxpython/menustrings.py:865
-#: ../gui/wxpython/menustrings.py:1259 ../gui/wxpython/menustrings.py:1553
-#: ../gui/wxpython/menustrings.py:1807
-msgid "Map type conversions"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:311
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1237
-#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:318
-#: ../gui/wxpython/menustrings.py:1260
-msgid "Raster to vector"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:178
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:312
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1238
-#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:319
-#: ../gui/wxpython/menustrings.py:1261
-msgid "Converts a raster map into a vector map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:179
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:313
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1239
-#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:320
-#: ../gui/wxpython/menustrings.py:1262
-msgid "Raster series to 3D raster"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:180
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:314
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1240
-#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:321
-#: ../gui/wxpython/menustrings.py:1263
-msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:181
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:315
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1241
-#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:322
-#: ../gui/wxpython/menustrings.py:1264
-msgid "Raster 2.5D to 3D raster"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:182
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:316
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1242
-#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:323
-#: ../gui/wxpython/menustrings.py:1265
-msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:183
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:603
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1529
-#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:612
-#: ../gui/wxpython/menustrings.py:1554
-msgid "Vector to raster"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:184
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:604
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1530
-#: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:613
-#: ../gui/wxpython/menustrings.py:1555
-msgid "Converts (rasterize) a vector map into a raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:185
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:605
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1531
-#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:614
-#: ../gui/wxpython/menustrings.py:1556
-msgid "Vector to 3D raster"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:186
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:606
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1532
-#: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:615
-#: ../gui/wxpython/menustrings.py:1557
-msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:607
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1533
-#: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:616
-#: ../gui/wxpython/menustrings.py:1558
-msgid "2D vector to 3D vector"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:188
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:608
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1534
-#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:617
-#: ../gui/wxpython/menustrings.py:1559
-msgid "Performs transformation of 2D vector features to 3D."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:189
-#: ../gui/wxpython/menustrings.py:192
-msgid "3D raster to raster series"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:190
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:849
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1775
-#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:867
-#: ../gui/wxpython/menustrings.py:1809
-msgid "Converts 3D raster maps to 2D raster maps"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:191
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1958
-#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:1992
-msgid "Georectify"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:192
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1959
-#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:1993
-msgid "Manage Ground Control Points for Georectification"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:193
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1960
-#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:1994
-msgid "Graphical modeler"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:194
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1961
-#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:1995
-msgid "Launch Graphical modeler"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:2011
-#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:2045
-msgid "Run model"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:199
-msgid "Run model prepared by Graphical modeler"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:200
-msgid "3D image rendering"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:198
-#: ../gui/wxpython/menustrings.py:201
-msgid ""
-"Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D "
-"vector data, and volumes (3D raster data) in 3D."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:199
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1020
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1946
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1953
-#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:1038
-#: ../gui/wxpython/menustrings.py:1980 ../gui/wxpython/menustrings.py:1987
-msgid "Animation tool"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:200
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1021
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1947
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1954
-#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1039
-#: ../gui/wxpython/menustrings.py:1981 ../gui/wxpython/menustrings.py:1988
-msgid "Launch animation tool."
-msgstr ""
-#: ../gui/wxpython/menustrings.py:204
-msgid "Bearing/distance to coordinates"
-msgstr ""
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa. It assumes a cartesian coordinate system"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:204
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1957
-#: ../gui/wxpython/menustrings.py:207 ../gui/wxpython/menustrings.py:1991
-msgid "Launch Cartographic Composer"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:205
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1964
-#: ../gui/wxpython/menustrings.py:208 ../gui/wxpython/menustrings.py:1998
-msgid "Map Swipe"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:206
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1965
-#: ../gui/wxpython/menustrings.py:209 ../gui/wxpython/menustrings.py:1999
-msgid "Launch Map Swipe"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:207
-#: ../gui/wxpython/menustrings.py:210
-msgid "Launch script"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:208
-#: ../gui/wxpython/menustrings.py:211
-msgid "Launches script file."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:210
-#: ../gui/wxpython/menustrings.py:215
-msgid "Close graphical user interface."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:212
-#: ../gui/wxpython/menustrings.py:217
-msgid "Close GUI and exit GRASS GIS shell."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:213
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1989
-#: ../gui/wxpython/menustrings.py:218 ../gui/wxpython/menustrings.py:2023
-msgid "&Settings"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:215
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1178
-#: ../gui/wxpython/menustrings.py:220 ../gui/wxpython/menustrings.py:1199
-msgid "Show current region"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:216
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:218
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1179
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1181
-#: ../gui/wxpython/menustrings.py:221 ../gui/wxpython/menustrings.py:223
-#: ../gui/wxpython/menustrings.py:1200 ../gui/wxpython/menustrings.py:1202
-msgid "Shows the extent and resolution of the computational region."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:217
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1180
-#: ../gui/wxpython/menustrings.py:222 ../gui/wxpython/menustrings.py:1201
-msgid "Show region using latitude and longitude"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:219
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1182
-#: ../gui/wxpython/menustrings.py:226 ../gui/wxpython/menustrings.py:1205
-msgid "Set region"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:220
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1183
-#: ../gui/wxpython/menustrings.py:227 ../gui/wxpython/menustrings.py:1206
-msgid "Manages the boundary definitions for the geographic region."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:221
-#: ../gui/wxpython/menustrings.py:228
-msgid "GRASS working environment"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:222
-#: ../gui/wxpython/menustrings.py:229
-msgid "Mapset access"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:223
-#: ../gui/wxpython/menustrings.py:230
-msgid "Set/unset access to other mapsets in current location"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:224
-#: ../gui/wxpython/menustrings.py:231
-msgid "User access"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:225
-#: ../gui/wxpython/menustrings.py:232
-msgid ""
-"Controls access to the current mapset for other users on the system. If no "
-"option given, prints current status."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:226
-#: ../gui/wxpython/menustrings.py:233
-msgid "Change working environment"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:227
-#: ../gui/wxpython/menustrings.py:234
-msgid ""
-"Changes/reports current mapset. Optionally create new mapset or list "
-"available mapsets in given location."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:228
-#: ../gui/wxpython/menustrings.py:235
-msgid "Change location and mapset"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:229
-#: ../gui/wxpython/menustrings.py:236
-msgid "Change current location and mapset."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:230
-#: ../gui/wxpython/menustrings.py:237
-msgid "Change mapset"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:231
-#: ../gui/wxpython/menustrings.py:238
-msgid "Change current mapset."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:232
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:233
-#: ../gui/wxpython/menustrings.py:239 ../gui/wxpython/menustrings.py:240
-msgid "Change working directory"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:234
-#: ../gui/wxpython/menustrings.py:241
-msgid "Show settings"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:235
-#: ../gui/wxpython/menustrings.py:242
-msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:236
-#: ../gui/wxpython/menustrings.py:243
-msgid "Change settings"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:237
-#: ../gui/wxpython/menustrings.py:244
-msgid ""
-"Outputs and modifies the user's current GRASS variable settings. Prints all "
-"defined GRASS variables if no option is given."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:238
-#: ../gui/wxpython/menustrings.py:245
-msgid "Create new location"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:239
-#: ../gui/wxpython/menustrings.py:246
-msgid "Launches location wizard to create new GRASS location."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:241
-#: ../gui/wxpython/menustrings.py:248
-msgid "Creates new mapset in the current location, changes current mapset."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:242
-#: ../gui/wxpython/menustrings.py:249
-msgid "Version and copyright"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:243
-#: ../gui/wxpython/menustrings.py:250
-msgid "Displays version and copyright information."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:244
-#: ../gui/wxpython/menustrings.py:251
-msgid "Map projections"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:245
-#: ../gui/wxpython/menustrings.py:252
-msgid "Display map projection"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:246
-#: ../gui/wxpython/menustrings.py:253
-msgid ""
-"Converts co-ordinate system descriptions (i.e. projection information) "
-"between various formats (including GRASS format)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:247
-#: ../gui/wxpython/menustrings.py:254
-msgid "Manage projections"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:248
-#: ../gui/wxpython/menustrings.py:255
-msgid ""
-"Prints or modifies GRASS projection information files (in various co-"
-"ordinate system descriptions). Can also be used to create new GRASS "
-"locations."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:249
-#: ../gui/wxpython/menustrings.py:256
-msgid "Convert coordinates"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:250
-#: ../gui/wxpython/menustrings.py:257
-msgid "Converts coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:251
-#: ../gui/wxpython/menustrings.py:258
-msgid "Addons extensions"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:252
-#: ../gui/wxpython/menustrings.py:259
-msgid "Install extension from addons"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:253
-#: ../gui/wxpython/menustrings.py:260
-msgid "Installs new extension from GRASS AddOns SVN repository."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:254
-#: ../gui/wxpython/menustrings.py:261
-msgid "Manage installed extension"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:255
-#: ../gui/wxpython/menustrings.py:262
-msgid "Updates or removes installed GRASS AddOns extension(s)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:256
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1990
-#: ../gui/wxpython/menustrings.py:263 ../gui/wxpython/menustrings.py:2024
-msgid "Preferences"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:257
-#: ../gui/wxpython/menustrings.py:264
-msgid "User GUI preferences (display font, commands, digitizer, etc.)"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:258
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1184
-#: ../gui/wxpython/menustrings.py:265 ../gui/wxpython/menustrings.py:1207
-msgid "&Raster"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:259
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1185
-#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1208
-msgid "Develop raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:260
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1186
-#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1209
-msgid "Compress/decompress"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:261
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1187
-#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1210
-msgid "Compresses and decompresses raster maps."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:262
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1188
-#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1211
-msgid "Region boundaries"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:263
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1189
-#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1212
-msgid "Sets the boundary definitions for a raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:264
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1190
-#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1213
-msgid "Manage NULL values"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:265
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1191
-#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1214
-msgid "Manages NULL-values of given raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:266
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1192
-#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1215
-msgid "Quantization"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:267
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1193
-#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1216
-msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:268
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1194
-#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1217
-msgid "Timestamp"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:269
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1195
-#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1218
-msgid ""
-"Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
-"raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:270
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1196
-#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1219
-msgid "Resample using aggregate statistics"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:271
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1197
-#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1220
-msgid "Resamples raster map layers to a coarser grid using aggregation."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:272
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1198
-#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1221
-msgid "Resample using multiple methods"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:273
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1199
-#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1222
-msgid "Resamples raster map to a finer grid using interpolation."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:274
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1200
-#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1223
-msgid "Resample using nearest neighbor"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:275
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1201
-#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1224
-msgid "GRASS raster map layer data resampling capability."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:276
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1202
-#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1225
-msgid "Resample using spline tension"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:277
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1203
-#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1226
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:278
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1204
-#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:1227
-msgid "Resample using bspline"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:279
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1205
-#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1228
-msgid ""
-"Performs bilinear or bicubic spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:280
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1206
-#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1229
-msgid "Resample using analytic kernel"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:281
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1207
-#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1230
-msgid "Resamples raster map layers using an analytic kernel."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:282
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:566
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1208
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1492
-#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:575
-#: ../gui/wxpython/menustrings.py:1231 ../gui/wxpython/menustrings.py:1517
-msgid "Support file maintenance"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:283
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1209
-#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:1232
-msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:284
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1210
-#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1233
-msgid "Update map statistics"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:285
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1211
-#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1234
-msgid "Update raster map statistics"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:288
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1214
-#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:1237
-msgid "Tiling"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:289
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1215
-#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1238
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:290
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:585
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1216
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1511
-#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:594
-#: ../gui/wxpython/menustrings.py:1239 ../gui/wxpython/menustrings.py:1536
-msgid "Manage colors"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:291
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:586
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1217
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1512
-#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:595
-#: ../gui/wxpython/menustrings.py:1240 ../gui/wxpython/menustrings.py:1537
-msgid "Color tables"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:292
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1218
-#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:1241
-msgid "Creates/modifies the color table associated with a raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:293
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1219
-#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1242
-msgid "Color tables (stddev)"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:294
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1220
-#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1243
-msgid "Sets color rules based on stddev from a raster map's mean value."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:295
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:588
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1221
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1514
-#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:597
-#: ../gui/wxpython/menustrings.py:1244 ../gui/wxpython/menustrings.py:1539
-msgid "Manage color rules interactively"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:296
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1222
-#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:1245
-msgid "Interactive management of raster color tables."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:297
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:590
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1223
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1516
-#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:599
-#: ../gui/wxpython/menustrings.py:1246 ../gui/wxpython/menustrings.py:1541
-msgid "Export color table"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:298
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1224
-#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:1247
-msgid "Exports the color table associated with a raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:299
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1225
-#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:1248
-msgid "Blend 2 color rasters"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:300
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1226
-#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1249
-msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:301
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1227
-#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1250
-msgid "Create RGB"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:302
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1228
-#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1251
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:303
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:754
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1229
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1680
-#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:767
-#: ../gui/wxpython/menustrings.py:1252 ../gui/wxpython/menustrings.py:1709
-msgid "RGB to HIS"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:304
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1230
-#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:1253
-msgid ""
-"Generates red, green and blue (RGB) raster map layers combining hue, "
-"intensity and saturation (HIS) values from user-specified input raster map "
-"layers."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:305
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1231
-#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1254
-msgid "Query raster maps"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:306
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1232
-#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1255
-msgid "Query values by coordinates"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:307
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1233
-#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1256
-msgid "Queries raster maps on their category values and category labels."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:308
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1234
-#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1257
-msgid "Query colors by value"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:309
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1235
-#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:1258
-msgid "Queries colors for a raster map layer."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:317
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1243
-#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:1266
-msgid "Raster buffers and distance"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:318
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1244
-#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1267
-msgid "Buffer rasters"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:319
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1245
-#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1268
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain "
-"non-NULL category values."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:320
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1246
-#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1269
-msgid "Concentric circles"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:321
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1247
-#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1270
-msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:322
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1248
-#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1271
-msgid "Closest points"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:323
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1249
-#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1272
-msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:324
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1250
-#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:1273
-msgid "Grow by one cell"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:325
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:388
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1251
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1314
-#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:397
-#: ../gui/wxpython/menustrings.py:1274 ../gui/wxpython/menustrings.py:1339
-msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:326
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:380
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1252
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1306
-#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:389
-#: ../gui/wxpython/menustrings.py:1275 ../gui/wxpython/menustrings.py:1331
-msgid "Distance to features"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:327
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:381
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1253
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1307
-#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:390
-#: ../gui/wxpython/menustrings.py:1276 ../gui/wxpython/menustrings.py:1332
-msgid ""
-"Generates a raster map containing distances to nearest raster features."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:329
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1255
-#: ../gui/wxpython/menustrings.py:336 ../gui/wxpython/menustrings.py:1278
-msgid "Creates a MASK for limiting raster operation."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:330
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:331
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1256
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1257
-#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:338
-#: ../gui/wxpython/menustrings.py:1279 ../gui/wxpython/menustrings.py:1280
-msgid "Raster map calculator"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:332
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1258
-#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1281
-msgid "Neighborhood analysis"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:334
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1260
-#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1283
-msgid ""
-"Makes each cell category value a function of the category values assigned to"
-" the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:335
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1261
-#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1284
-msgid "Neighborhood points"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:336
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1262
-#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1285
-msgid ""
-"Neighborhood analysis tool for vector point maps. Makes each cell value a "
-"function of the attribute values assigned to the vector points or centroids "
-"around it, and stores new cell values in an output raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:337
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1263
-#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1286
-msgid "Overlay rasters"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:338
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1264
-#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1287
-msgid "Cross product"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:339
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1265
-#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1288
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:340
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1266
-#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1289
-msgid "Patch raster maps"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:341
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1267
-#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1290
-msgid ""
-"Creates a composite raster map layer by using known category values from one"
-" (or more) map layer(s) to fill in areas of \"no data\" in another map "
-"layer."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:342
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1268
-#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1291
-msgid "Raster series aggregation"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:343
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1269
-#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1292
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:344
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1270
-#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1293
-msgid "Raster series accumulation"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:345
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1271
-#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1294
-msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:346
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1272
-#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1295
-msgid "Statistical overlay"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:347
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1273
-#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1296
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:348
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1274
-#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1297
-msgid "Quantiles overlay"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:349
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1275
-#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1298
-msgid "Compute category quantiles using two passes."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:350
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1276
-#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1299
-msgid "Solar radiance and shadows"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:351
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1277
-#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1300
-msgid "LatLong map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:352
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1278
-#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1301
-msgid "Creates a latitude/longitude raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:353
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1279
-#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1302
-msgid "Solar irradiance and irradiation"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:354
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1280
-#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1303
-msgid ""
-"Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
-"reflected solar irradiation raster maps for given day, latitude, surface and"
-" atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, "
-"declination, extraterrestrial irradiance, daylight length) are saved in the "
-"map history file. Alternatively, a local time can be specified to compute "
-"solar incidence angle and/or irradiance raster maps. The shadowing effect of"
-" the topography is optionally incorporated."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:355
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1281
-#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1304
-msgid "Shadows map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:356
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1282
-#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1305
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map. "
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:357
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1283
-#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1306
-msgid "Sunshine hours and solar angles"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:358
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1284
-#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1307
-msgid ""
-"Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
-"the angle between the direction of the geometric center of the sun's "
-"apparent disk and the (idealized) horizon. Solar azimuth: the angle from due"
-" north in clockwise direction."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:359
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1285
-#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1308
-msgid "Terrain analysis"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:360
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1286
-#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1309
-msgid "Generate contour lines"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:361
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1287
-#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1310
-msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:362
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1288
-#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1311
-msgid "Cost surface"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:363
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1289
-#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1312
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different"
-" geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:364
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1290
-#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1313
-msgid "Cumulative movement costs"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:365
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1291
-#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1314
-msgid ""
-"Creates a raster map showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input raster map whose cell "
-"category values represent cost."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:366
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1292
-#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1315
-msgid "Least cost route or flow"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:367
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1293
-#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1316
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:368
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1294
-#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1317
-msgid "Compute shaded relief"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:369
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1295
-#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1318
-msgid "Creates shaded relief map from an elevation map (DEM). "
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:370
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1296
-#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1319
-msgid "Apply shade to raster"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:371
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1297
-#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1320
-msgid "Drapes a color raster over an shaded relief or aspect map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:372
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1298
-#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1321
-msgid "Slope and aspect"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:373
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1299
-#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1322
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from an elevation raster map. Aspect is calculated counterclockwise from "
-"east."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:374
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1300
-#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1325
-msgid "Terrain parameters"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:375
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1301
-#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1326
-msgid ""
-"Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
-"taking fitting quadratic parameters to any size window (via least squares)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:376
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1302
-#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1327
-msgid "Textural features"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:377
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1303
-#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1328
-msgid "Generate images with textural features from a raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:378
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1304
-#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1329
-msgid "Visibility"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:379
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1305
-#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1330
-msgid ""
-"Computes the viewshed of a point on an elevation raster map. Default format:"
-" NULL (invisible), vertical angle wrt viewpoint (visible)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:382
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1308
-#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1333
-msgid "Horizon angle"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:383
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1309
-#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1334
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has"
-" two different modes of operation: 1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction. The input for this is the angle (in "
-"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:384
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1310
-#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1335
-msgid "Transform features"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:385
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1311
-#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1336
-msgid "Clump"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:386
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1312
-#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1337
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:387
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1313
-#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1338
-msgid "Grow"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:389
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1315
-#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1340
-msgid "Thin"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:390
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1316
-#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1341
-msgid ""
-"Thins non-null cells that denote linear features in a raster map layer."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:391
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1317
-#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1342
-msgid "Hydrologic modeling"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:392
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1318
-#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1343
-msgid "Carve stream channels"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:393
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1319
-#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1344
-msgid ""
-"Generates stream channels. Takes vector stream data, transforms it to raster"
-" and subtracts depth from the output DEM."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:394
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1320
-#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1345
-msgid "Fill lake"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:395
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1321
-#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1346
-msgid "Fills lake at given point to given level."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:396
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1322
-#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1347
-msgid "Depressionless map and flowlines"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:397
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1323
-#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1348
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:398
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1324
-#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1349
-msgid "Flow accumulation"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:399
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1325
-#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1350
-msgid "Performs flow computation for massive grids."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:400
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1326
-#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1351
-msgid "Flow lines"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:401
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1327
-#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1352
-msgid ""
-"Constructs flowlines. Computes flowlines, flowpath lengths, and "
-"flowaccumulation (contributing areas) from a elevation raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:402
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1328
-#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1353
-msgid "Watershed analysis"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:403
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1329
-#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1354
-msgid "Calculates hydrological parameters and RUSLE factors."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:404
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1330
-#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1355
-msgid "Watershed subbasins"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:405
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1331
-#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1356
-msgid "Generates watershed subbasins raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:406
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1332
-#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1357
-msgid "Watershed basin creation"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:407
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1333
-#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1358
-msgid "Creates watershed basins from a drainage direction map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:408
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1334
-#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1359
-msgid "Extraction of stream networks"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:409
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1335
-#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1360
-msgid "Performs stream network extraction."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:410
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1336
-#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1361
-msgid "SIMWE Overland flow modeling"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:411
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1337
-#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1362
-msgid ""
-"Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:412
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1338
-#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1363
-msgid "SIMWE Sediment flux modeling"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:413
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1339
-#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1364
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:414
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1340
-#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1365
-msgid "Topographic index map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:415
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1341
-#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1366
-msgid ""
-"Creates a topographic index (wetness index) raster map from an elevation "
-"raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:416
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1342
-#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1367
-msgid "TOPMODEL simulation"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:417
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1343
-#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1368
-msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:418
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1344
-#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1369
-msgid "USLE K-factor"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:419
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1345
-#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1370
-msgid "Computes USLE Soil Erodibility Factor (K)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:420
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1346
-#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1371
-msgid "USLE R-factor"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:421
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1347
-#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1372
-msgid "Computes USLE R factor, Rainfall erosivity index."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:422
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:860
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1348
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1786
-#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:878
-#: ../gui/wxpython/menustrings.py:1373 ../gui/wxpython/menustrings.py:1820
-msgid "Groundwater modeling"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:423
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1349
-#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1374
-msgid "Groundwater flow"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:424
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1350
-#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1375
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:425
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1351
-#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1376
-msgid "Groundwater solute transport"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:426
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1352
-#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1377
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:427
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1353
-#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:1378
-msgid "Landscape patch analysis"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:428
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1354
-#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1379
-msgid "Set up sampling and analysis framework"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:429
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1355
-#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1380
-msgid "Configuration editor for r.li.'index'"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:430
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1356
-#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1381
-msgid "Edge density"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:431
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1357
-#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1382
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:432
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1358
-#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1383
-msgid "Contrast weighted edge density"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:433
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1359
-#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1384
-msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:434
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1360
-#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1385
-msgid "Patch area mean"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:435
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1361
-#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1386
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:436
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1362
-#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1387
-msgid "Patch area range"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:437
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1363
-#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1388
-msgid "Calculates range of patch area size on a raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:438
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1364
-#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1389
-msgid "Patch area Std Dev"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:439
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1365
-#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1390
-msgid "Calculates standard deviation of patch area a raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:440
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1366
-#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1391
-msgid "Patch area Coeff Var"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:441
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1367
-#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1392
-msgid "Calculates coefficient of variation of patch area on a raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:442
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1368
-#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1393
-msgid "Patch density"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:443
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1369
-#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1394
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:444
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1370
-#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1395
-msgid "Patch number"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:445
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1371
-#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1396
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour "
-"algorithm."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:446
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1372
-#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1397
-msgid "Dominance's diversity"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:447
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1373
-#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1398
-msgid "Calculates dominance's diversity index on a raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:448
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1374
-#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1399
-msgid "Shannon's diversity"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:449
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1375
-#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1400
-msgid "Calculates Shannon's diversity index on a raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:450
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1376
-#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1401
-msgid "Simpson's diversity"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:451
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1377
-#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1402
-msgid "Calculates Simpson's diversity index on a raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:452
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1378
-#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1403
-msgid "Richness"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:453
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1379
-#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1404
-msgid "Calculates richness index on a raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:454
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1380
-#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1405
-msgid "Shape index"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:455
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1381
-#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1406
-msgid "Calculates shape index on a raster map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:456
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1382
-#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1407
-msgid "Wildfire modeling"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:457
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1383
-#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1408
-msgid "Rate of spread"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:458
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1384
-#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1409
-msgid ""
-"Generates rate of spread raster maps. Generates three, or four raster map "
-"layers showing the base (perpendicular) rate of spread (ROS), the maximum "
-"(forward) ROS, the direction of the maximum ROS, and optionally the maximum "
-"potential spotting distance for fire spread simulation."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:459
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1385
-#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1410
-msgid "Least-cost spread paths"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:460
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1386
-#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1411
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:461
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1387
-#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1412
-msgid "Anisotropic spread simulation"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:462
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1388
-#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1413
-msgid ""
-"Simulates elliptically anisotropic spread. Generates a raster map of the "
-"cumulative time of spread, given raster maps containing the rates of spread "
-"(ROS), the ROS directions and the spread origins. It optionally produces "
-"raster maps to contain backlink UTM coordinates for tracing spread paths. "
-"Usable for fire spread simulations."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:463
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1389
-#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1414
-msgid "Change category values and labels"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:464
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:514
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1390
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1440
-#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:523
-#: ../gui/wxpython/menustrings.py:1415 ../gui/wxpython/menustrings.py:1465
-msgid "Manage category information"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:465
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:515
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1391
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1441
-#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:524
-#: ../gui/wxpython/menustrings.py:1416 ../gui/wxpython/menustrings.py:1466
-msgid ""
-"Manages category values and labels associated with user-specified raster map"
-" layers."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:466
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1392
-#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1417
-msgid "Interactively edit category values"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:467
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1393
-#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1418
-msgid "Edits cell values in a raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:468
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1394
-#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1419
-msgid "Reclassify by size"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:469
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1395
-#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1420
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:470
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:687
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1396
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1613
-#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:698
-#: ../gui/wxpython/menustrings.py:1421 ../gui/wxpython/menustrings.py:1640
-msgid "Reclassify"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:471
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1397
-#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1422
-msgid ""
-"Reclassify raster map based on category values. Creates a new raster map "
-"whose category values are based upon a reclassification of the categories in"
-" an existing raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:472
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1398
-#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1423
-msgid "Recode"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:473
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1399
-#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1424
-msgid "Recodes categorical raster maps."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:474
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1400
-#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1425
-msgid "Rescale"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:475
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1401
-#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1426
-msgid "Rescales the range of category values in a raster map layer."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:476
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1402
-#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:1427
-msgid "Rescale with histogram"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:477
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1403
-#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1428
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:478
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1404
-#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1429
-msgid "Generate random cells"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:479
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1405
-#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1430
-msgid "Random cells"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:480
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1406
-#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1431
-msgid "Generates random cell values with spatial dependence."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:481
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1407
-#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1432
-msgid "Random cells and vector points"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:482
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1408
-#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1433
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:483
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1409
-#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1434
-msgid "Generate surfaces"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:484
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1410
-#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1435
-msgid "Fractal surface"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:485
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1411
-#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1436
-msgid "Creates a fractal surface of a given fractal dimension."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:486
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1412
-#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1437
-msgid "Gaussian kernel density surface"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:487
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1413
-#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1438
-msgid ""
-"Generates a raster density map from vector points map. Density is computed "
-"using a moving kernel. Optionally generates a vector density map on a vector"
-" network."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:488
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1414
-#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1439
-msgid "Gaussian deviates surface"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:489
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1415
-#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1440
-msgid ""
-"Generates a raster map using gaussian random number generator. Mean and "
-"standard deviation of gaussian deviates can be expressed by the user."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:491
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1417
-#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1442
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:492
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1418
-#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1443
-msgid "Random deviates surface"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:493
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1419
-#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1444
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:494
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1420
-#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1445
-msgid "Random surface with spatial dependence"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:495
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1421
-#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1446
-msgid "Generates random surface(s) with spatial dependence."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:496
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1422
-#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1447
-msgid "Interpolate surfaces"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:497
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1423
-#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1448
-msgid "Bilinear and bicubic from vector points"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:498
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1424
-#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1449
-msgid ""
-"Performs bicubic or bilinear spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:499
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1425
-#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1450
-msgid "IDW from raster points"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:500
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1426
-#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1451
-msgid ""
-"Provides surface interpolation from raster point data by Inverse Distance "
-"Squared Weighting."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:501
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1427
-#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1452
-msgid "IDW from vector points"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:502
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1428
-#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1453
-msgid ""
-"Provides surface interpolation from vector point data by Inverse Distance "
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:503
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1429
-#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1454
-msgid "Raster contours"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:504
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1430
-#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1455
-msgid "Generates surface raster map from rasterized contours."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:505
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1431
-#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1456
-msgid "Regularized spline tension"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:506
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1432
-#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1457
-msgid ""
-"Performs surface interpolation from vector points map by splines. Spatial "
-"approximation and topographic analysis from given point or isoline data in "
-"vector format to floating point raster format using regularized spline with "
-"tension."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:507
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1433
-#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1458
-msgid "Raster series interpolation"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:508
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1434
-#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1459
-msgid ""
-"Interpolates raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:509
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1435
-#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1460
-msgid "Fill NULL cells"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:510
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1436
-#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1461
-msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:511
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:726
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:836
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1008
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1437
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1652
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1762
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1934
-#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:737
-#: ../gui/wxpython/menustrings.py:854 ../gui/wxpython/menustrings.py:882
-#: ../gui/wxpython/menustrings.py:1026 ../gui/wxpython/menustrings.py:1462
-#: ../gui/wxpython/menustrings.py:1679 ../gui/wxpython/menustrings.py:1796
-#: ../gui/wxpython/menustrings.py:1824 ../gui/wxpython/menustrings.py:1968
-msgid "Reports and statistics"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:512
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1438
-#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1463
-msgid "Basic raster metadata"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:513
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1439
-#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1464
-msgid "Outputs basic information about a raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:516
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1442
-#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1467
-msgid "General statistics"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:517
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1443
-#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1468
-msgid "Generates area statistics for raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:518
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1444
-#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1469
-msgid "Quantiles for large data sets"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:519
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1445
-#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:1470
-msgid "Compute quantiles using two passes."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:520
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1446
-#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1471
-msgid "Range of category values"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:521
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1447
-#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1472
-msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:522
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1448
-#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1473
-msgid "Sum area by raster map and category"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:523
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1449
-#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1474
-msgid "Reports statistics for raster maps."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:524
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1450
-#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1475
-msgid "Statistics for clumped cells"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:525
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1451
-#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1476
-msgid ""
-"Calculates the volume of data \"clumps\". Optionally produces a GRASS vector"
-" points map containing the calculated centroids of these clumps."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:526
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1452
-#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1477
-msgid "Total corrected area"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:527
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1453
-#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1478
-msgid "Prints estimation of surface area for raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:529
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1455
-#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1480
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map. "
-"Statistics include number of cells counted, minimum and maximum cell values,"
-" range, arithmetic mean, population variance, standard deviation, "
-"coefficient of variation, and sum."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:530
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1456
-#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:748
-#: ../gui/wxpython/menustrings.py:1481 ../gui/wxpython/menustrings.py:1690
-msgid "Sample transects"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:531
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1457
-#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1482
-msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:532
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1458
-#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1483
-msgid "Sample transects (bearing/distance)"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:533
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1459
-#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1484
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:534
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1460
-#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1485
-msgid "Covariance/correlation"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:535
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1461
-#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1486
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:536
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1462
-#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1487
-msgid "Linear regression"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:537
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1463
-#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1488
-msgid "Calculates linear regression from two raster maps: y = a + b*x."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:538
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1464
-#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1489
-msgid "Multiple regression"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:539
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1465
-#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1490
-msgid "Calculates multiple linear regression from raster maps."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:540
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1466
-#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1491
-msgid "Mutual category occurrences"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:541
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1467
-#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1492
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:542
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1468
-#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1493
-msgid "&Vector"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:543
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1469
-#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1494
-msgid "Develop vector map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:545
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1471
-#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1496
-msgid "Create new empty vector map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:546
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1472
-#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1497
-msgid "Edit vector map (non-interactively)"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:547
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1473
-#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1498
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:548
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1474
-#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1499
-msgid "Convert object types"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:549
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1475
-#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1500
-msgid "Changes type of vector features."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:550
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1476
-#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1501
-msgid "Parallel lines"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:551
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1477
-#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1502
-msgid "Creates parallel line to input vector lines."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:552
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1478
-#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1503
-msgid "Dissolve boundaries"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:553
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1479
-#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1504
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number"
-" or attribute."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:554
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1480
-#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1505
-msgid "Create 3D vector over raster"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:555
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1481
-#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1506
-msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:556
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1482
-#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1507
-msgid "Extrude 3D vector map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:557
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1483
-#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1508
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height. "
-"Optionally the height can be derived from sampling of elevation raster map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:558
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1484
-#: ../gui/wxpython/menustrings.py:567 ../gui/wxpython/menustrings.py:1509
-msgid "Create labels"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:559
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1485
-#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1510
-msgid "Creates paint labels for a vector map from attached attributes."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:560
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1486
-#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1511
-msgid "Reposition vector map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:561
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1487
-#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1512
-msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:562
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1488
-#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1513
-msgid "Rectify vector map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:563
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1489
-#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1514
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:567
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1493
-#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1518
-msgid "Updates vector map metadata."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:568
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1494
-#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1519
-msgid "Topology maintenance"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:569
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1495
-#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1520
-msgid "Create or rebuild topology"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:570
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1496
-#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1521
-msgid ""
-"Creates topology for vector map. Optionally also checks for topological "
-"errors."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:571
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1497
-#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1522
-msgid "Rebuild topology on all vector maps"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:572
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1498
-#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1523
-msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:573
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1499
-#: ../gui/wxpython/menustrings.py:582 ../gui/wxpython/menustrings.py:1524
-msgid "Build polylines"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:574
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1500
-#: ../gui/wxpython/menustrings.py:583 ../gui/wxpython/menustrings.py:1525
-msgid "Builds polylines from lines or boundaries."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:575
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1501
-#: ../gui/wxpython/menustrings.py:584 ../gui/wxpython/menustrings.py:1526
-msgid "Split lines"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:576
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1502
-#: ../gui/wxpython/menustrings.py:585 ../gui/wxpython/menustrings.py:1527
-msgid "Splits vector lines to shorter segments."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:577
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1503
-#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1528
-msgid "Split polylines"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:578
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1504
-#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:1529
-msgid "Creates points/segments from input vector lines and positions."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:579
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1505
-#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1530
-msgid "Clean vector map"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:580
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1506
-#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1531
-msgid "Toolset for cleaning topology of vector map."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:581
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1507
-#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1532
-msgid "Smooth or simplify"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:582
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1508
-#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1533
-msgid "Performs vector based generalization."
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:583
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1509
-#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1534
-msgid "Add centroids"
-msgstr ""
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:584
-#: ../gui/wxpython/image2target/ii2t_menustrings.py:1510
-#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1535
-msgid "Adds missing centroids to closed boundaries."
-msgstr ""
