[GRASS-SVN] r74406 - in grass/trunk/lib/python/gunittest: . testsuite
svn_grass at osgeo.org
Sat Apr 20 02:16:40 PDT 2019
Author: neteler
Date: 2019-04-20 02:16:40 -0700 (Sat, 20 Apr 2019)
New Revision: 74406
grass/trunk/lib/python/gunittest/checkers.py
grass/trunk/lib/python/gunittest/testsuite/test_checkers.py
testsuite: gunnitest.test_checkers update for Python3 (fixes #3821) (contributed by pmav99)
Modified: grass/trunk/lib/python/gunittest/checkers.py
--- grass/trunk/lib/python/gunittest/checkers.py 2019-04-19 15:23:23 UTC (rev 74405)
+++ grass/trunk/lib/python/gunittest/checkers.py 2019-04-20 09:16:40 UTC (rev 74406)
@@ -603,7 +603,7 @@
continue
if exclude_re and regexp.match(line):
continue
- hasher.update(line)
+ hasher.update(line.encode("utf-8"))
if append_lines:
for line in append_lines:
hasher.update(line)
Modified: grass/trunk/lib/python/gunittest/testsuite/test_checkers.py
--- grass/trunk/lib/python/gunittest/testsuite/test_checkers.py 2019-04-19 15:23:23 UTC (rev 74405)
+++ grass/trunk/lib/python/gunittest/testsuite/test_checkers.py 2019-04-20 09:16:40 UTC (rev 74406)
@@ -190,9 +190,9 @@
# although it does not support stripping (we don't merge separators)
keyvals = text_to_keyvalue("a 1 2 3", sep=' ', val_sep=' ')
self.assertDictEqual({'a': [1, 2, 3]}, keyvals)
#def test_projection_files(self):
# obtained by r.univar elevation -g
# floats removed
R_UNIVAR_KEYVAL = """n=2025000
@@ -354,7 +354,7 @@
for line in CORRECT_LINES:
# \n should be converted to platform newline
f.write(line + '\n')
- with open(cls.correct_file_name_unix_nl, 'wb') as f:
+ with open(cls.correct_file_name_unix_nl, 'w') as f:
# binary mode will write pure \n
