[GRASS-SVN] r74408 - in grass/trunk: raster/r.out.ascii raster/r.out.bin raster/r.out.gdal raster/r.out.gridatb raster/r.out.mat raster/r.out.mpeg raster/r.out.png raster/r.out.pov raster/r.out.ppm raster/r.out.ppm3 raster/r.out.vrml raster/r.out.vtk raster3d/r3.out.ascii raster3d/r3.out.netcdf raster3d/r3.out.v5d raster3d/r3.out.vtk scripts/d.out.file scripts/db.out.ogr scripts/r.out.xyz temporal/t.rast.out.vtk vector/v.out.ascii vector/v.out.dxf vector/v.out.lidar vector/v.out.ogr vector/v.out.postgis vector/v.out.pov vector/v.out.svg vector/v.out.vtk
svn_grass at osgeo.org
Sat Apr 20 02:46:08 PDT 2019
Author: neteler
Date: 2019-04-20 02:46:08 -0700 (Sat, 20 Apr 2019)
New Revision: 74408
grass/trunk/raster/r.out.ascii/main.c
grass/trunk/raster/r.out.bin/main.c
grass/trunk/raster/r.out.gdal/main.c
grass/trunk/raster/r.out.gridatb/main.c
grass/trunk/raster/r.out.mat/main.c
grass/trunk/raster/r.out.mpeg/main.c
grass/trunk/raster/r.out.png/main.c
grass/trunk/raster/r.out.pov/main.c
grass/trunk/raster/r.out.ppm/main.c
grass/trunk/raster/r.out.ppm3/main.c
grass/trunk/raster/r.out.vrml/main.c
grass/trunk/raster/r.out.vtk/main.c
grass/trunk/raster3d/r3.out.ascii/main.c
grass/trunk/raster3d/r3.out.netcdf/main.c
grass/trunk/raster3d/r3.out.v5d/main.c
grass/trunk/raster3d/r3.out.vtk/main.c
grass/trunk/scripts/d.out.file/d.out.file.py
grass/trunk/scripts/db.out.ogr/db.out.ogr.py
grass/trunk/scripts/r.out.xyz/r.out.xyz.py
grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
grass/trunk/vector/v.out.ascii/main.c
grass/trunk/vector/v.out.dxf/main.c
grass/trunk/vector/v.out.lidar/main.c
grass/trunk/vector/v.out.ogr/main.c
grass/trunk/vector/v.out.postgis/main.c
grass/trunk/vector/v.out.pov/main.c
grass/trunk/vector/v.out.svg/main.c
grass/trunk/vector/v.out.vtk/main.c
manual: keyword 'output' added
Modified: grass/trunk/raster/r.out.ascii/main.c
--- grass/trunk/raster/r.out.ascii/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.ascii/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -58,6 +58,7 @@
module = G_define_module();
G_add_keyword(_("raster"));
G_add_keyword(_("export"));
+ G_add_keyword(_("output"));
G_add_keyword("ASCII");
module->description =
_("Converts a raster map layer into a GRASS ASCII text file.");
Modified: grass/trunk/raster/r.out.bin/main.c
--- grass/trunk/raster/r.out.bin/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.bin/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -278,6 +278,7 @@
module->description = _("Exports a GRASS raster to a binary array.");
/* Define the different options */
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.gdal/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -138,6 +138,7 @@
_("Exports GRASS raster maps into GDAL supported formats.");
flag_l = G_define_flag();
flag_l->key = 'l';
Modified: grass/trunk/raster/r.out.gridatb/main.c
--- grass/trunk/raster/r.out.gridatb/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.gridatb/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -66,6 +66,7 @@
_("Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL).");
Modified: grass/trunk/raster/r.out.mat/main.c
--- grass/trunk/raster/r.out.mat/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.mat/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -61,6 +61,7 @@
module->description = _("Exports a GRASS raster to a binary MAT-File.");
Modified: grass/trunk/raster/r.out.mpeg/main.c
--- grass/trunk/raster/r.out.mpeg/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.mpeg/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -101,6 +101,7 @@
G_add_keyword(_("animation"));
Modified: grass/trunk/raster/r.out.png/main.c
--- grass/trunk/raster/r.out.png/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.png/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -111,6 +111,7 @@
G_add_keyword("PNG");
_("Export a GRASS raster map as a non-georeferenced PNG image.");
Modified: grass/trunk/raster/r.out.pov/main.c
--- grass/trunk/raster/r.out.pov/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.pov/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -120,6 +120,7 @@
_("Converts a raster map layer into a height-field file for POV-Ray.");
Modified: grass/trunk/raster/r.out.ppm/main.c
--- grass/trunk/raster/r.out.ppm/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.ppm/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -53,6 +53,7 @@
module->description = _("Converts a GRASS raster map to a PPM image file.");
Modified: grass/trunk/raster/r.out.ppm3/main.c
--- grass/trunk/raster/r.out.ppm3/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.ppm3/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -56,6 +56,7 @@
module->description = _("Converts 3 GRASS raster layers (R,G,B) to a PPM image file.");
for (i = 0; i < 3; i++) {
Modified: grass/trunk/raster/r.out.vrml/main.c
--- grass/trunk/raster/r.out.vrml/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.vrml/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -46,6 +46,7 @@
G_add_keyword(_("VRML"));
_("Exports a raster map to the Virtual Reality Modeling Language (VRML).");
Modified: grass/trunk/raster/r.out.vtk/main.c
--- grass/trunk/raster/r.out.vtk/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster/r.out.vtk/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -58,6 +58,7 @@
G_add_keyword("VTK");
module->description = _("Converts raster maps into the VTK-ASCII format.");
Modified: grass/trunk/raster3d/r3.out.ascii/main.c
--- grass/trunk/raster3d/r3.out.ascii/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster3d/r3.out.ascii/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -301,6 +301,7 @@
G_add_keyword(_("raster3d"));
G_add_keyword(_("voxel"));
G_add_keyword(_("conversion"));
Modified: grass/trunk/raster3d/r3.out.netcdf/main.c
--- grass/trunk/raster3d/r3.out.netcdf/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster3d/r3.out.netcdf/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -586,6 +586,7 @@
G_add_keyword(_("netCDF"));
module->description = _("Export a 3D raster map as netCDF file.");
Modified: grass/trunk/raster3d/r3.out.v5d/main.c
--- grass/trunk/raster3d/r3.out.v5d/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster3d/r3.out.v5d/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -283,6 +283,7 @@
_("Exports GRASS 3D raster map to 3-dimensional Vis5D file.");
Modified: grass/trunk/raster3d/r3.out.vtk/main.c
--- grass/trunk/raster3d/r3.out.vtk/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/raster3d/r3.out.vtk/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -375,6 +375,7 @@
Modified: grass/trunk/scripts/d.out.file/d.out.file.py
--- grass/trunk/scripts/d.out.file/d.out.file.py 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/scripts/d.out.file/d.out.file.py 2019-04-20 09:46:08 UTC (rev 74408)
@@ -17,6 +17,7 @@
#% description: Saves the contents of the active display monitor to a graphics file.
#% keyword: display
#% keyword: export
+#% keyword: output
#%end
#%option G_OPT_F_OUTPUT
#% description: Name for output file
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2019-04-20 09:46:08 UTC (rev 74408)
@@ -18,6 +18,7 @@
#% description: Exports attribute tables into various formats.
#% keyword: database
#% keyword: export
+#% keyword: output
#% keyword: attribute table
#%end
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2019-04-20 09:46:08 UTC (rev 74408)
@@ -20,6 +20,7 @@
#% description: Exports a raster map to a text file as x,y,z values based on cell centers.
#% keyword: raster
#% keyword: export
+#% keyword: output
#% keyword: ASCII
#% keyword: conversion
#%end
Modified: grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
--- grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2019-04-20 09:46:08 UTC (rev 74408)
@@ -24,6 +24,7 @@
#% description: Exports space time raster dataset as VTK time series.
#% keyword: temporal
#% keyword: export
+#% keyword: output
#% keyword: raster
#% keyword: VTK
#% keyword: time
Modified: grass/trunk/vector/v.out.ascii/main.c
--- grass/trunk/vector/v.out.ascii/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/vector/v.out.ascii/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -46,6 +46,7 @@
G_add_keyword(_("vector"));
module->label =
_("Exports a vector map to a GRASS ASCII vector representation.");
Modified: grass/trunk/vector/v.out.dxf/main.c
--- grass/trunk/vector/v.out.dxf/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/vector/v.out.dxf/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -55,6 +55,7 @@
G_add_keyword(_("DXF"));
_("Exports vector map to DXF file format.");
Modified: grass/trunk/vector/v.out.lidar/main.c
--- grass/trunk/vector/v.out.lidar/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/vector/v.out.lidar/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -472,6 +472,7 @@
G_add_keyword(_("LIDAR"));
G_add_keyword(_("points"));
module->label = _("Exports vector points as LAS point cloud");
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/vector/v.out.ogr/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -82,7 +82,9 @@
G_add_keyword("OGR");
module->label =
_("Exports a vector map layer to any of the supported OGR vector formats.");
Modified: grass/trunk/vector/v.out.postgis/main.c
--- grass/trunk/vector/v.out.postgis/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/vector/v.out.postgis/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -43,6 +43,7 @@
G_add_keyword(_("PostGIS"));
G_add_keyword(_("simple features"));
G_add_keyword(_("topology"));
Modified: grass/trunk/vector/v.out.pov/main.c
--- grass/trunk/vector/v.out.pov/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/vector/v.out.pov/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -45,6 +45,7 @@
_("Converts GRASS x,y,z points to POV-Ray x,z,y format.");
Modified: grass/trunk/vector/v.out.svg/main.c
--- grass/trunk/vector/v.out.svg/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/vector/v.out.svg/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -76,6 +76,7 @@
module->description = _("Exports a vector map to SVG file.");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.out.vtk/main.c
--- grass/trunk/vector/v.out.vtk/main.c 2019-04-20 09:36:06 UTC (rev 74407)
+++ grass/trunk/vector/v.out.vtk/main.c 2019-04-20 09:46:08 UTC (rev 74408)
@@ -46,6 +46,7 @@
_("Converts a vector map to VTK ASCII output.");
